Need help with motherboard problem
    • 15205
    #16
    • Djan1999
      • Jan 2019
      • 15
      #17
      Sorry for late reply. Motherboard was fried I bough new one and everything seems to be working properly now
      • Djan1999
        • Jan 2019
        • 15
        #18
        But I have a new problem and I ahve no idea what is causing it; so basecly I had Ram issues and it worked perfectly when I had installed 1 ram but when I put in the second stick i keept geting BSOD. so I tryed if the ram was bad and well just in case I sent it back for warenty and got new ones but the problem is still there. Tryed different DIMM slots but second stick just wont work no matter in whic slot I put it.
        • jmarket
          PCHF Owner
          • 7643
          #19
          What RAM are you trying? What board do you have? Make, model, and speed would be most helpful in this scenario
          • Djan1999
            • Jan 2019
            • 15
            #20
            Hello thanks for replying.
            I have;
            B450M Mortar
            2x4GB 3000mHz hyperX predator
            I think it works now tho I updated my windows with update tool and so far i didnt get BSOD. hopefully it stays like that but before it just keept crashing with 2 ram sticks but worked with just 1
            • Djan1999
              • Jan 2019
              • 15
              #21
              Problem that im having alot right now is that when I open some programs I get error that says: Windows cannot find location of program. Make sure you typed name corerctly, and then try again later. update didnt seem to fix that
              • Djan1999
                • Jan 2019
                • 15
                #22
                I can open programs like VLC media player but cant open steam or popcorn time and mystic light or anything like why did this started happening any clue?
                • Djan1999
                  • Jan 2019
                  • 15
                  #23
                  For whatever reason it works when I try to go to file location and rename the files name to something else but the original name like I renamed Steam to Stam and it works but when I name it Steam again it just gives the same message. this is so weird. any clues why this is happening? I tryed sfc/cleannow but it says everything is fine and tryed many other options i found googling too but nothing but this one seems to work
                  • Djan1999
                    • Jan 2019
                    • 15
                    #24
                    Update; Just decided to reinstall windows because it seemd like it was completly broken like I think SSD I bought used was corruped or something cus all of the sudden I also got error that I need to restart to turn off user control or something and Drivers stoped working for GPU again and like there was way too much problems so I just reinstalled and RAM so far seems to be fine but if something goes wrong il make new thread so you can finaly close this one. THANKS FOR ALL THE HELP LOVE UR SITE!!!
                    • jmarket
                      PCHF Owner
                      • 7643
                      #25
                      Thank you for the positive feedback
                      A fresh install is always best after getting a new SSD. Sometimes settings and files can get corrupted if you try to transfer data over.
                      I will close this thread per your wishes, and if you do experience further issues, please don’t hesitate to open a new thread
