Random performance drops possibly due to cooling problems
This topic is closed.
  • mcnugget
    • Mar 2017
    • 11
    I can run most games on high graphics settings most of the time but once every few minutes my frames will drop into the tens, upon watching the resource monitor and looking at the CPU and GPU temperatures it appears that the FPS drops happen at the points when the CPU is hottest (50-60 c), also all of the cores are active but stuck at 20% ish usage, this lasts about 10 secs and when it is finished the CPU has been cooled down to 30-35 c and the cores go back to being used normally and the FPS goes back up. The higher the graphics settings are the more often the drops happen. I think it is something to do with over heating but don’t know what to do about it.
    Specs:
    Gigabyte GTX 1060 6GB
    AMD FX™-8350 Eight-Core Processor
    16GB RAM (8GB x2)
    c drive: KINGSTON SH103S3120G SATA Disk Device
    d drive: ST1000DM 003-ER162 SATA Disk Device
    With regards to air flow I have a Bitfenix Neos case and I think the GPU fan sucks air from the space between it and the PSU (the PSU also sucks from this air) and blows it into the CPU fan that then blows it onto the top of the case where it is sucked out of the case by the exhaust fan if that is what you call it.
    If anyone has any other ideas about what the problem could be instead of overheating it would greatly appreciated to hear them and if anyone has a solution to the over heating problem it would also be very helpful, thanks
  • jmarket
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    Hi mcnugget and welcome to PCHF
    Let’s get some info about your machine shall we?
    Flush DNS
    Report IE Proxy Settings
    Reset IE Proxy Settings
    Report FF Proxy Settings
    Reset FF Proxy Settings
    List content of Hosts
    List IP Configuration
    List Winsock Entries
    List Installed Programs
    List Devices (Only Problems)
    Please post the log in your next reply
    I would also like some screenshots of your temps using Speedfan.
    • mcnugget
      • Mar 2017
      • 11
      Ran by Jake (administrator) on 15-03-2017 at 18:18:27
      Running from “C:\Users\Jake\Desktop”
      Model: To be filled by O.E.M. Manufacturer: To be filled by O.E.M.
      Boot Mode: Normal
      Windows IP Configuration
      Proxy is not enabled.
      No Proxy Server is set.
      “Reset IE Proxy Settings”: IE Proxy Settings were reset.
      LogMeIn Hamachi Virtual Ethernet Adapter = Ethernet (Connected)
      Realtek PCIe GBE Family Controller = Local Area Connection (Connected)
      [HEADING=1]----------------------------------[/HEADING]
      [HEADING=1]IPv4 Configuration[/HEADING]
      pushd interface ipv4
      reset
      set global
      add route prefix=0.0.0.0/0 interface=“Local Area Connection* 10” nexthop=25.0.0.1 publish=Yes
      add route prefix=0.0.0.0/0 interface=“Hamachi” nexthop=25.0.0.1 publish=Yes
      add route prefix=0.0.0.0/0 interface=“Ethernet” nexthop=25.0.0.1 publish=Yes
      set interface interface=“Local Area Connection* 1” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
      set interface interface=“Local Area Connection” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
      set interface interface=“Hamachi” forwarding=enabled advertise=enabled metric=9000 nud=enabled ignoredefaultroutes=disabled
      set interface interface=“Local Area Connection* 10” forwarding=disabled advertise=disabled metric=9000 siteprefixlength=0 nud=disabled routerdiscovery=disabled managedaddress=disabled otherstateful=disabled weakhostsend=disabled weakhostreceive=disabled ignoredefaultroutes=disabled advertisedrouterlifetime=0 advertisedefaultroute=disabled currenthoplimit=0 forcearpndwolpattern=disabled enabledirectedmacwolpattern=disabled ecncapability=ecndisabled
      set interface interface=“Ethernet” forwarding=enabled advertise=enabled metric=9000 nud=enabled ignoredefaultroutes=disabled
      set subinterface interface= subinterface=ethernet_32769 mtu=1404
      popd
      [HEADING=1]End of IPv4 configuration[/HEADING]
      Host Name . . . . . . . . . . . . : Jake-pc
      DNS Suffix Search List. . . . . . : home
      Ethernet adapter Ethernet:
      Description . . . . . . . . . . . : LogMeIn Hamachi Virtual Ethernet Adapter
      Physical Address. . . . . . . . . : 7A-79-19-95-FF-BB
      IPv6 Address. . . . . . . . . . . : 2620:9b::1995:ffbb(Preferred)
      Link-local IPv6 Address . . . . . : fe80::e519:b004:dc28:575f%16(Preferred)
      IPv4 Address. . . . . . . . . . . : 25.149.255.187(Preferred)
      Subnet Mask . . . . . . . . . . . : 255.0.0.0
      Lease Obtained. . . . . . . . . . : Wednesday, March 15, 2017 6:12:58 PM
      Lease Expires . . . . . . . . . . : Thursday, March 15, 2018 6:12:58 PM
      Default Gateway . . . . . . . . . : 2620:9b::1900:1
      25.0.0.1
      DHCP Server . . . . . . . . . . . : 25.0.0.1
      DHCPv6 IAID . . . . . . . . . . . : 117592306
      DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-76-D3-C2-40-16-7E-AF-53-3E
      DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
      fec0:0:0:ffff::2%1
      fec0:0:0:ffff::3%1
      Connection-specific DNS Suffix . : home
      Physical Address. . . . . . . . . : 40-16-7E-AF-53-3E
      Link-local IPv6 Address . . . . . : fe80::5463:3c06:73d4:6892%14(Preferred)
      IPv4 Address. . . . . . . . . . . : 192.168.1.82(Preferred)
      Lease Obtained. . . . . . . . . . : Wednesday, March 15, 2017 6:12:55 PM
      Lease Expires . . . . . . . . . . : Thursday, March 16, 2017 6:12:55 PM
      Default Gateway . . . . . . . . . : 192.168.1.254
      DHCP Server . . . . . . . . . . . : 192.168.1.254
      DHCPv6 IAID . . . . . . . . . . . : 255858302
      DNS Servers . . . . . . . . . . . : 192.168.1.254
      Tunnel adapter Reusable ISATAP Interface {7EF89E06-BE6B-47E9-8E6E-A0F17A25F33F}:
      Tunnel adapter Local Area Connection* 2:
      Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
      Tunnel adapter isatap.home:
      Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
      Server: BThomehub.home
      Address: 192.168.1.254
      Addresses: 2a00:1450:4009:80f::200e
      216.58.213.78
      Pinging google.com [216.58.212.78] with 32 bytes of data:
      Reply from 216.58.212.78: bytes=32 time=17ms TTL=50
      Ping statistics for 216.58.212.78:
      Minimum = 17ms, Maximum = 17ms, Average = 17ms
      Addresses: 2001:4998:58:c02::a9
      2001:4998:c:a06::2:4008
      2001:4998:44:204::a7
      206.190.36.45
      98.139.183.24
      98.138.253.109
      Pinging yahoo.com [98.138.253.109] with 32 bytes of data:
      Reply from 98.138.253.109: bytes=32 time=127ms TTL=45
      Reply from 98.138.253.109: bytes=32 time=126ms TTL=45
      Ping statistics for 98.138.253.109:
      Minimum = 126ms, Maximum = 127ms, Average = 126ms
      [HEADING=1]Ping statistics for 127.0.0.1:
      Minimum = 0ms, Maximum = 0ms, Average = 0ms[/HEADING]
      [HEADING=1]Interface List
      16…7a 79 19 95 ff bb …LogMeIn Hamachi Virtual Ethernet Adapter
      14…40 16 7e af 53 3e …Realtek PCIe GBE Family Controller
      1…Software Loopback Interface 1
      8…00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
      15…00 00 00 00 00 00 00 e0 Microsoft Teredo Tunneling Adapter
      10…00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2[/HEADING]
      [HEADING=1]IPv4 Route Table[/HEADING]
      [HEADING=1]Active Routes:
      0.0.0.0 0.0.0.0 192.168.1.254 192.168.1.82 25
      0.0.0.0 0.0.0.0 25.0.0.1 25.149.255.187 9256
      25.0.0.0 255.0.0.0 On-link 25.149.255.187 9256
      25.149.255.187 255.255.255.255 On-link 25.149.255.187 9256
      25.255.255.255 255.255.255.255 On-link 25.149.255.187 9256
      192.168.1.0 255.255.255.0 On-link 192.168.1.82 281
      192.168.1.82 255.255.255.255 On-link 192.168.1.82 281
      192.168.1.255 255.255.255.255 On-link 192.168.1.82 281
      224.0.0.0 240.0.0.0 On-link 192.168.1.82 281
      224.0.0.0 240.0.0.0 On-link 25.149.255.187 9256
      255.255.255.255 255.255.255.255 On-link 192.168.1.82 281
      255.255.255.255 255.255.255.255 On-link 25.149.255.187 9256[/HEADING]
      [HEADING=1]Persistent Routes:
      Network Address Netmask Gateway Address Metric
      0.0.0.0 0.0.0.0 25.0.0.1 Default
      0.0.0.0 0.0.0.0 25.0.0.1 Default[/HEADING]
      [HEADING=1]IPv6 Route Table[/HEADING]
      16 9015 ::/0 2620:9b::1900:1
      1 331 ::1/128 On-link
      16 271 2620:9b::/96 On-link
      16 271 2620:9b::1995:ffbb/128 On-link
      14 281 fe80::/64 On-link
      16 271 fe80::/64 On-link
      14 281 fe80::5463:3c06:73d4:6892/128
      On-link
      16 271 fe80::e519:b004:dc28:575f/128
      On-link
      1 331 ff00::/8 On-link
      14 281 ff00::/8 On-link
      16 271 ff00::/8 On-link[/HEADING]
      0 4294967295 2620:9b::/96 On-link
      0 9000 ::/0 2620:9b::1900:1
      0 9000 ::/0 2620:9b::1900:1[/HEADING]
      Catalog5 01 C:\WINDOWS\SysWoW64\napinsp.dll [55808] (Microsoft Corporation)
      Catalog5 02 C:\WINDOWS\SysWoW64\pnrpnsp.dll [70656] (Microsoft Corporation)
      Catalog5 03 C:\WINDOWS\SysWoW64\pnrpnsp.dll [70656] (Microsoft Corporation)
      Catalog5 04 C:\WINDOWS\SysWoW64\NLAapi.dll [65024] (Microsoft Corporation)
      Catalog5 05 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog5 06 C:\WINDOWS\SysWoW64\winrnr.dll [24064] (Microsoft Corporation)
      Catalog9 01 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog9 02 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog9 03 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog9 04 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog9 05 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog9 06 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog9 07 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog9 08 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog9 09 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog9 10 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog9 11 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      Catalog9 12 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
      x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67584] (Microsoft Corporation)
      x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
      x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
      x64-Catalog5 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31744] (Microsoft Corporation)
      x64-Catalog9 01 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 02 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 03 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 04 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 06 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 07 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 08 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 09 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 10 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 11 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 12 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      Error: (03/09/2017 10:56:58 PM) (Source: YSearchUtilSvc) (User: )
      Description: YSearchUtilSvc error: The operation completed successfully. (0x0)Could not open service (1060)
      Error: (03/09/2017 10:52:30 PM) (Source: Application Error) (User: )
      Description: Faulting application name: Battle.net.exe, version: 1.7.1.8423, time stamp: 0x58af33ec
      Faulting module name: libGLESv2.dll, version: 2.1.0.0, time stamp: 0x56ec7f41
      Exception code: 0xc0000409
      Fault offset: 0x00289f4f
      Faulting process id: 0x1a88
      Faulting application start time: 0xBattle.net.exe0
      Faulting application path: Battle.net.exe1
      Faulting module path: Battle.net.exe2
      Report Id: Battle.net.exe3
      Faulting package full name: Battle.net.exe4
      Faulting package-relative application ID: Battle.net.exe5
      Error: (03/09/2017 10:52:08 PM) (Source: Application Error) (User: )
      Description: Faulting application name: microsoftedgecp.exe, version: 11.0.14393.82, time stamp: 0x57a55786
      Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
      Exception code: 0xc0000604
      Fault offset: 0x0000000000000000
      Faulting process id: 0x648
      Faulting application start time: 0xmicrosoftedgecp.exe0
      Faulting application path: microsoftedgecp.exe1
      Faulting module path: microsoftedgecp.exe2
      Report Id: microsoftedgecp.exe3
      Faulting package full name: microsoftedgecp.exe4
      Faulting package-relative application ID: microsoftedgecp.exe5
      Error: (03/09/2017 10:52:06 PM) (Source: Application Error) (User: )
      Error: (03/09/2017 10:29:20 PM) (Source: SideBySide) (User: )
      Description: Activation context generation failed for "UccApi,processorArchitecture=“AMD64”,type=“win32” ,version=“16.0.0.0"1”.Error in manifest or policy file "UccApi,processorArchitecture=“AMD64”,type=“win32” ,version=“16.0.0.0"2” on line UccApi,processorArchitecture=“AMD64”,type=“win32”, version="16.0.0.0"3.
      Component identity found in manifest does not match the identity of the component requested.
      Reference is UccApi,processorArchitecture=“AMD64”,type=“win32”, version=“16.0.0.0”.
      Definition is UccApi,processorArchitecture=“x86”,type=“win32”,ve rsion=“16.0.0.0”.
      Please use sxstrace.exe for detailed diagnosis.
      Error: (03/09/2017 10:20:20 PM) (Source: SideBySide) (User: )
      Error: (03/09/2017 10:11:06 PM) (Source: SideBySide) (User: )
      Error: (03/09/2017 10:02:37 PM) (Source: Application Error) (User: )
      Faulting process id: 0x798
      Error: (03/09/2017 10:02:35 PM) (Source: Application Error) (User: )
      Error: (03/09/2017 09:20:36 AM) (Source: Application Error) (User: )
      Description: Faulting application name: ShellExperienceHost.exe, version: 10.0.14393.447, time stamp: 0x5819bf85
      Faulting module name: Windows.UI.ActionCenter.dll, version: 10.0.14393.693, time stamp: 0x585a25f7
      Exception code: 0xc0000005
      Fault offset: 0x00000000000a3750
      Faulting process id: 0xe80
      Faulting application start time: 0xShellExperienceHost.exe0
      Faulting application path: ShellExperienceHost.exe1
      Faulting module path: ShellExperienceHost.exe2
      Report Id: ShellExperienceHost.exe3
      Faulting package full name: ShellExperienceHost.exe4
      Faulting package-relative application ID: ShellExperienceHost.exe5
      Error: (03/15/2017 06:13:00 PM) (Source: DCOM) (User: NT AUTHORITY)
      Description: application-specificLocalActivation{8D8F4F83-3594-4F07-8369-FC3C3CAE4919}{F72671A9-012C-4725-9D2F-2A4D32D65169}NT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
      Error: (03/14/2017 11:16:48 PM) (Source: Microsoft-Windows-Kernel-Power) (User: )
      Description: 5
      Error: (03/14/2017 06:38:11 PM) (Source: Service Control Manager) (User: )
      Description: The Steam Client Service service failed to start due to the following error:
      %%1053 = The service did not respond to the start or control request in a timely fashion.
      Description: A timeout was reached (30000 milliseconds) while waiting for the Steam Client Service service to connect.
      Error: (03/14/2017 06:35:55 PM) (Source: DCOM) (User: NT AUTHORITY)
      Error: (03/13/2017 11:18:24 PM) (Source: Microsoft-Windows-Kernel-Power) (User: )
      Description: 5
      Error: (03/13/2017 07:35:49 PM) (Source: DCOM) (User: NT AUTHORITY)
      Error: (03/13/2017 07:28:50 PM) (Source: Service Control Manager) (User: )
      Description: The NetTcpActivator service depends on the NetTcpPortSharing service which failed to start because of the following error:
      %%1058 = The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
      Error: (03/13/2017 07:28:49 PM) (Source: EventLog) (User: )
      Description: The previous system shutdown at 10:48:18 PM on ‎3/‎12/‎2017 was unexpected.
      Error: (03/13/2017 07:28:35 PM) (Source: Microsoft-Windows-Kernel-Boot) (User: NT AUTHORITY)
      Description: 32212256841088704
      [HEADING=1]Microsoft Office Sessions:[/HEADING]
      Error: (03/09/2017 10:56:58 PM) (Source: YSearchUtilSvc)(User: )
      Error: (03/09/2017 10:52:30 PM) (Source: Application Error)(User: )
      Description: Battle.net.exe1.7.1.842358af33eclibGLESv2.dll2.1.0 .056ec7f41c000040900289f4f1a8801d299198e5f8ee6D:\B attle.net\Battle.net.8423\Battle.net.exeD:\Battle. net\Battle.net.8423\libGLESv2.dllc580c0c9-b257-4140-88ac-09ca1c6fa82b
      Error: (03/09/2017 10:52:08 PM) (Source: Application Error)(User: )
      Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0 .0.000000000c0000604000000000000000064801d29927c22 f3887C:\Windows\SystemApps\Microsoft.MicrosoftEdge _8wekyb3d8bbwe\microsoftedgecp.exeunknown8763938e-3938-4e3c-a555-5904d779caaaMicrosoft.MicrosoftEdge_38.14393.0.0_n eutral__8wekyb3d8bbweMicrosoftEdge
      Error: (03/09/2017 10:52:06 PM) (Source: Application Error)(User: )
      Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0 .0.000000000c0000604000000000000000064801d29927c22 f3887C:\Windows\SystemApps\Microsoft.MicrosoftEdge _8wekyb3d8bbwe\microsoftedgecp.exeunknown132db0ac-f7ba-4d35-9f0b-24c2bd37d717Microsoft.MicrosoftEdge_38.14393.0.0_n eutral__8wekyb3d8bbweMicrosoftEdge
      Error: (03/09/2017 10:29:20 PM) (Source: SideBySide)(User: )
      Description: UccApi,processorArchitecture=“AMD64”,type=“win32”, version="16.0.0.0"UccApi,processorArchitecture=“x8 6”,type=“win32”,version="16.0.0.0"C:\Program Files (x86)\Microsoft Office\root\Office16\lync.exe.ManifestC:\Program Files (x86)\Microsoft Office\root\Office16\UccApi.DLL1
      Error: (03/09/2017 10:20:20 PM) (Source: SideBySide)(User: )
      Error: (03/09/2017 10:11:06 PM) (Source: SideBySide)(User: )
      Error: (03/09/2017 10:02:37 PM) (Source: Application Error)(User: )
      Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0 .0.000000000c0000604000000000000000079801d29920daf fc581C:\Windows\SystemApps\Microsoft.MicrosoftEdge _8wekyb3d8bbwe\microsoftedgecp.exeunknown3e7353b8-e962-4d2f-91c0-338956f02ee3Microsoft.MicrosoftEdge_38.14393.0.0_n eutral__8wekyb3d8bbweMicrosoftEdge
      Error: (03/09/2017 10:02:35 PM) (Source: Application Error)(User: )
      Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0 .0.000000000c0000604000000000000000079801d29920daf fc581C:\Windows\SystemApps\Microsoft.MicrosoftEdge _8wekyb3d8bbwe\microsoftedgecp.exeunknown9899590a-5e89-4e8a-8336-188a0cb9b0afMicrosoft.MicrosoftEdge_38.14393.0.0_n eutral__8wekyb3d8bbweMicrosoftEdge
      Error: (03/09/2017 09:20:36 AM) (Source: Application Error)(User: )
      Description: ShellExperienceHost.exe10.0.14393.4475819bf85Windo ws.UI.ActionCenter.dll10.0.14393.693585a25f7c00000 0500000000000a3750e8001d298b65aca685eC:\WINDOWS\Sy stemApps\ShellExperienceHost_cw5n1h2txyewy\ShellEx perienceHost.exeC:\Windows\ShellExperiences\Window s.UI.ActionCenter.dll16d51a41-b528-497d-8eba-15566939c758Microsoft.Windows.ShellExperienceHost_ 10.0.14393.693_neutral_neutral_cw5n1h2txyewyApp
      [HEADING=1]CodeIntegrity Errors:[/HEADING]
      Date: 2017-03-09 22:37:51.338
      Description: Code Integrity determined that a process (\Device\HarddiskVolume4\Windows\SystemApps\Micros oft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.ex e) attempted to load \Device\HarddiskVolume4\Windows\System32\nvspcap64 .dll that did not meet the Store signing level requirements.
      Date: 2017-03-09 22:37:47.892
      Date: 2017-03-09 21:14:52.285
      Date: 2017-03-08 20:34:00.760
      Date: 2017-03-08 20:33:59.617
      Date: 2017-02-17 21:37:12.526
      Date: 2017-02-17 21:34:43.950
      Date: 2017-02-16 15:19:28.364
      Date: 2017-02-15 22:34:23.068
      Date: 2017-02-15 22:34:20.952
      7 Days to Die (HKLM-x32...\Steam App 251570) (Version: - The Fun Pimps)
      ACA & MEP 2016 Object Enabler (HKLM...{5783F2D7-F004-0000-5102-0060B0CE6BBA}) (Version: 7.8.41.0 - Autodesk) Hidden
      ACAD Private (HKLM...{5783F2D7-F001-0000-3102-0060B0CE6BBA}) (Version: 20.1.49.0 - Autodesk) Hidden
      Adobe Flash Player 24 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 24.0.0.221 - Adobe Systems Incorporated)
      AMD Catalyst Install Manager (HKLM...{5DDB9EF7-1BC0-C9C1-9829-6B9CF68AC357}) (Version: 8.0.903.0 - Advanced Micro Devices, Inc.)
      AMD System Monitor (HKLM-x32...{6EFD0C42-4CC1-4716-A0CA-21C1A062CF34}) (Version: 1.0.9 - Advanced Micro Devices, Inc.)
      Ansel (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 378.78 - NVIDIA Corporation) Hidden
      Arma 3 (HKLM-x32...\Steam App 107410) (Version: - Bohemia Interactive)
      Armored Warfare MyCom (HKCU...\Armored Warfare MyCom) (Version: 1.108 - My.com B.V.)
      Asmedia ASM104x USB 3.0 Host Controller Driver (HKLM-x32...{E4FB0B39-C991-4EE7-95DD-1A1A7857D33D}) (Version: 1.16.12.0 - Asmedia Technology)
      AutoCAD 2016 - English (HKLM...{5783F2D7-F001-0409-2102-0060B0CE6BBA}) (Version: 20.1.49.0 - Autodesk) Hidden
      AutoCAD 2016 (HKLM...{5783F2D7-F001-0000-0102-0060B0CE6BBA}) (Version: 20.1.49.0 - Autodesk) Hidden
      AutoCAD 2016 Language Pack - English (HKLM...{5783F2D7-F001-0409-1102-0060B0CE6BBA}) (Version: 20.1.49.0 - Autodesk) Hidden
      Autodesk Advanced Material Library Image Library 2016 (HKLM-x32...{94AD53E7-493B-4291-8714-7A3B761D2783}) (Version: 6.3.0.15 - Autodesk)
      Autodesk App Manager 2016 (HKLM-x32...{4ECF9E00-2978-46AF-BD80-455EFEAB7A93}) (Version: 2.0.0 - Autodesk)
      Autodesk AutoCAD 2016 - English (HKLM...\AutoCAD 2016 - English) (Version: 20.1.49.0 - Autodesk)
      Autodesk AutoCAD Performance Feedback Tool 1.2.4 (HKLM-x32...{4E20873D-BC20-495C-AFD9-B18877B7F9BB}) (Version: 1.2.4.0 - Autodesk)
      Autodesk BIM 360 Glue AutoCAD 2016 Add-in 64 bit (HKLM...{4BEE127E-95C4-434D-ABAC-65155192BB24}) (Version: 4.35.1742 - Autodesk)
      Autodesk Content Service (HKLM...{A37CDB58-AAE8-0000-8C13-E0F7BACB0D5F}) (Version: 3.2.0.0 - Autodesk) Hidden
      Autodesk Content Service (HKLM...\Autodesk Content Service) (Version: 3.2.0.0 - Autodesk)
      Autodesk Content Service Language Pack (HKLM...{A37CDB58-AAE8-0001-8C13-E0F7BACB0D5F}) (Version: 3.2.0.0 - Autodesk) Hidden
      Autodesk Featured Apps 2016 (HKLM-x32...{D42F37CD-9AF9-4435-A474-B387C5BB6B47}) (Version: 2.0.0 - Autodesk)
      Autodesk Material Library 2016 (HKLM-x32...{29A7D6EC-63C2-42FD-8143-5812ABD2923F}) (Version: 6.3.0.15 - Autodesk)
      Autodesk Material Library Base Resolution Image Library 2016 (HKLM-x32...{6B4CFC6E-ECB0-47FE-95D3-65C680ED0687}) (Version: 6.3.0.15 - Autodesk)
      Autodesk ReCap 2016 (HKLM...{F6FD1651-0000-1033-0102-387BAF9B3B0A}) (Version: 1.5.0.33 - Autodesk) Hidden
      Autodesk ReCap 2016 (HKLM...\Autodesk ReCap 2016) (Version: 1.5.0.33 - Autodesk)
      Battle.net (HKLM-x32...\Battle.net) (Version: - Blizzard Entertainment)
      Battlefield 4™ (HKLM-x32...{ABADE36E-EC37-413B-8179-B432AD3FACE7}) (Version: 1.7.2.45672 - Electronic Arts)
      Battlefield™ 1 (HKLM-x32...{335B50BC-6130-4BAF-9A6A-F1561270587B}) (Version: 1.0.49.14731 - Electronic Arts)
      Besiege (HKLM-x32...\Steam App 346010) (Version: - Spiderling Studios)
      Bethesda.net Launcher (HKLM-x32...{3448917E-E4FE-4E30-9502-9FD52EABB6F5}_is1) (Version: 1.0 - Bethesda Softworks)
      Blender (HKLM-x32...{472ADEE9-937F-4796-B50B-273CEABFCED3}) (Version: 2.75.1 - Blender Foundation)
      BoltonsEveningWithV1 (HKLM-x32...{EBFF5494-9626-4D12-9E06-70F335A90C6A}) (Version: 1.0.0 - Default Company Name)
      Borderlands 2 (HKLM...\Steam App 49520) (Version: - Gearbox Software)
      Cities: Skylines (HKLM-x32...\Steam App 255710) (Version: - Colossal Order Ltd.)
      ClipGrab 3.6.2 (HKLM-x32...{8A1033B0-EF33-4FB5-97A1-C47A7DCDD7E6}_is1) (Version: - Philipp Schmieder Medien)
      Counter-Strike: Global Offensive (HKLM-x32...\Steam App 730) (Version: - Valve)
      Creation Kit: Fallout 4 (HKLM-x32...\Creation Kit: Fallout 4) (Version: - Bethesda Softworks)
      D3DX10 (HKLM-x32...{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
      DayZ (HKLM...\Steam App 221100) (Version: - Bohemia Interactive)
      Discord (HKCU...\Discord) (Version: 0.0.297 - Hammer & Chisel, Inc.)
      Don’t Starve (HKLM-x32...\Steam App 219740) (Version: - Klei Entertainment)
      Don’t Starve Together Beta (HKLM-x32...\Steam App 322330) (Version: - Klei Entertainment)
      DOOM (HKLM...\Steam App 379720) (Version: - id Software)
      Dropbox (HKLM-x32...\Dropbox) (Version: 21.4.25 - Dropbox, Inc.)
      Dropbox Update Helper (HKLM-x32...{099218A5-A723-43DC-8DB5-6173656A1E94}) (Version: 1.3.59.1 - Dropbox, Inc.) Hidden
      Fallout 4 (HKLM-x32...\Steam App 377160) (Version: - Bethesda Game Studios)
      FARO LS 1.1.502.0 (64bit) (HKLM-x32...{66D83FE0-D798-4B38-86FE-FB48151E5AEF}) (Version: 5.2.0.35213 - FARO Scanner Production)
      Garry’s Mod (HKLM-x32...\Steam App 4000) (Version: - Facepunch Studios)
      Google Chrome (HKLM-x32...\Google Chrome) (Version: 56.0.2924.87 - Google Inc.)
      Google Update Helper (HKLM-x32...{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.32.7 - Google Inc.) Hidden
      Google Update Helper (HKLM-x32...{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.25.11 - Google Inc.) Hidden
      Hi-Rez Studios Authenticate and Update Service (HKLM-x32...{3C87E0FF-BC0A-4F5E-951B-68DC3F8DF1FC}) (Version: 3.0.0.0 - Hi-Rez Studios)
      Java 8 Update 121 (HKLM-x32...{26A24AE4-039D-4CA4-87B4-2F32180121F0}) (Version: 8.0.1210.13 - Oracle Corporation)
      Kerbal Space Program (HKLM-x32...\Steam App 220200) (Version: - Squad)
      League of Legends (HKLM-x32...{B2777235-FDF0-4371-9D1E-0CD24DFE3579}) (Version: 4.2.1 - Riot Games) Hidden
      League of Legends (HKLM-x32...\League of Legends 4.2.1) (Version: 4.2.1 - Riot Games)
      LogMeIn Hamachi (HKLM-x32...{91B5DF26-717A-4A5F-AB10-CD450FAD428C}) (Version: 2.2.0.541 - LogMeIn, Inc.) Hidden
      LogMeIn Hamachi (HKLM-x32...\LogMeIn Hamachi) (Version: 2.2.0.541 - LogMeIn, Inc.)
      Mafia III (HKLM...\Steam App 360430) (Version: - Hangar 13)
      McAfee LiveSafe (HKLM-x32...\MSC) (Version: - )
      Microsoft ASP.NET MVC 4 Runtime (HKLM-x32...{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
      Microsoft Chart Controls for Microsoft .NET Framework 3.5 (HKLM-x32...{41785C66-90F2-40CE-8CB5-1C94BFC97280}) (Version: 3.5.30730.0 - Microsoft Corporation)
      Microsoft Expression Encoder 4 (HKLM-x32...\Encoder_4.0.1651.0) (Version: 4.0.1651.0 - Microsoft Corporation)
      Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32...{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
      Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}) (Version: 8.0.59192 - Microsoft Corporation)
      Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{ad8a2fa1-06e7-4b0d-927d-6e54b3d31028}) (Version: 8.0.61000 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM...{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x86 9.0.21022 (HKLM-x32...{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}) (Version: 9.0.21022 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32...{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
      Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 (HKLM-x32...{a1909659-0a08-4554-8af1-2175904903a1}) (Version: 11.0.60610.1 - Microsoft Corporation)
      Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610 (HKLM-x32...{01db25f3-1b76-4d97-88c8-1c90634d88fb}) (Version: 11.0.60610.1 - Корпорация Майкрософт)
      Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610 (HKLM-x32...{95716cce-fc71-413f-8ad5-56c2892d4b3a}) (Version: 11.0.60610.1 - Microsoft Corporation)
      Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24210 (HKLM-x32...{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}) (Version: 14.0.24210.0 - Microsoft Corporation)
      Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24210 (HKLM-x32...{23658c02-145e-483d-ba6b-1eb82c580529}) (Version: 14.0.24210.0 - Microsoft Corporation)
      Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
      Microsoft XNA Framework Redistributable 4.0 (HKLM-x32...{2BFC7AA0-544C-4E3A-8796-67F3BE655BE9}) (Version: 4.0.20823.0 - Microsoft Corporation)
      Monaco (HKLM-x32...\Steam App 113020) (Version: - Pocketwatch Games)
      Movie Maker (HKLM-x32...{38F03569-A636-4CF3-BDDE-032C8C251304}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
      Movie Maker (HKLM-x32...{DD67BE4B-7E62-4215-AFA3-F123A800A389}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
      Movie Maker (HKLM-x32...{EB3DF0F0-0525-4C5A-A2F8-DEC868A3075D}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
      MPC-HC 1.7.9 (64-bit) (HKLM...{2ACBF1FA-F5C3-4B19-A774-B22A31F231B9}_is1) (Version: 1.7.9 - MPC-HC Team)
      My.com Game Center (HKCU...\MyComGames) (Version: 3.187 - My.com B.V.)
      NVIDIA 3D Vision Controller Driver 369.04 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 369.04 - NVIDIA Corporation)
      NVIDIA 3D Vision Driver 378.78 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 378.78 - NVIDIA Corporation)
      NVIDIA GeForce Experience 3.4.0.70 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.4.0.70 - NVIDIA Corporation)
      NVIDIA Graphics Driver 378.78 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 378.78 - NVIDIA Corporation)
      NVIDIA HD Audio Driver 1.3.34.23 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.23 - NVIDIA Corporation)
      NVIDIA PhysX System Software 9.16.0318 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
      NvNodejs (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs) (Version: 3.4.0.70 - NVIDIA Corporation) Hidden
      NvTelemetry (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetry) (Version: 2.3.16.0 - NVIDIA Corporation) Hidden
      NvvHci (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvvHci) (Version: 2.02.0.5 - NVIDIA Corporation) Hidden
      Origin (HKLM-x32...\Origin) (Version: 10.4.5.25153 - Electronic Arts, Inc.)
      Overwatch (HKLM-x32...\Overwatch) (Version: - Blizzard Entertainment)
      Poly Bridge (HKLM-x32...\Steam App 367450) (Version: - Dry Cactus)
      PunkBuster Services (HKLM-x32...\PunkBusterSvc) (Version: 0.993 - Even Balance, Inc.)
      Realtek Ethernet Controller Driver (HKLM-x32...{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.67.1226.2012 - Realtek)
      Realtek High Definition Audio Driver (HKLM-x32...{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7535 - Realtek Semiconductor Corp.)
      Rising Storm/Red Orchestra 2 Multiplayer (HKLM-x32...\Steam App 35450) (Version: - Tripwire Interactive)
      ShellShock Live (HKLM...\Steam App 326460) (Version: - kChamp Games)
      SHIELD Streaming (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 7.1.0351 - NVIDIA Corporation) Hidden
      SHIELD Wireless Controller Driver (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController) (Version: 3.4.0.70 - NVIDIA Corporation) Hidden
      SimplePlanes (HKLM-x32...\Steam App 397340) (Version: - Jundroo, LLC)
      Skype Click to Call (HKLM-x32...{873F8E7C-10E6-449F-BD7E-5FBA7C8E1C9B}) (Version: 8.5.0.9167 - Microsoft Corporation)
      Skype™ 7.32 (HKLM-x32...{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.32.104 - Skype Technologies S.A.)
      Space Engineers (HKLM-x32...\Steam App 244850) (Version: - )
      Steam (HKLM-x32...\Steam) (Version: - Valve Corporation)
      SteelSeries Engine 3.8.5 (HKLM...\SteelSeries Engine 3) (Version: 3.8.5 - SteelSeries ApS)
      Team Fortress 2 (HKLM-x32...\Steam App 440) (Version: - Valve)
      TeamSpeak 3 Client (HKLM...\TeamSpeak 3 Client) (Version: 3.0.16 - TeamSpeak Systems GmbH)
      Terraria (HKLM-x32...\Steam App 105600) (Version: - Re-Logic)
      The Binding of Isaac (HKLM-x32...\Steam App 113200) (Version: - Edmund McMillen and Florian Himsl)
      The Binding of Isaac: Rebirth (HKLM-x32...\Steam App 250900) (Version: - Nicalis, Inc.)
      Tom Clancy’s Rainbow Six Siege (HKLM-x32...\Steam App 359550) (Version: - Ubisoft Montreal)
      Undertale (HKLM-x32...\Steam App 391540) (Version: - tobyfox)
      Unity (HKLM-x32...\Unity) (Version: - Unity Technologies ApS)
      Unity Web Player (HKCU...\UnityWebPlayer) (Version: - Unity Technologies ApS)
      Uplay (HKLM-x32...\Uplay) (Version: 13.0 - Ubisoft)
      Vulkan Run Time Libraries 1.0.39.1 (HKLM...\VulkanRT1.0.39.1) (Version: 1.0.39.1 - LunarG, Inc.)
      War Thunder (HKLM-x32...\Steam App 236390) (Version: - Gaijin Entertainment)
      War Thunder Launcher 1.0.1.340 (HKLM-x32...{abc8eea4-29fa-3932-9612-e2122d8a62d9}}_is1) (Version: - Gaijin Entertainment)
      Windows 10 Upgrade Assistant (HKLM-x32...{D5C69738-B486-402E-85AC-2456D98A64E4}) (Version: 1.4.9200.17354 - Microsoft Corporation)
      Windows Live Essentials (HKLM-x32...\WinLiveSuite) (Version: 16.4.3528.0331 - Microsoft Corporation)
      WinPcap 4.1.3 (HKLM-x32...\WinPcapInst) (Version: 4.1.0.2980 - Riverbed Technology, Inc.)
      WinRAR 5.31 (64-bit) (HKLM...\WinRAR archiver) (Version: 5.31.0 - win.rar GmbH)
      XTREME GAMING ENGINE (HKLM-x32...\GIGABYTE XTREME GAMING ENGINE_is1) (Version: 1.0.5.3 - GIGABYTE Technology Co.,Inc.)
      Percentage of memory in use: 22%
      Total physical RAM: 16298.84 MB
      Available physical RAM: 12599.15 MB
      Total Virtual: 32682.84 MB
      Available Virtual: 28565.37 MB
      1 Drive c: () (Fixed) (Total:110.83 GB) (Free:34.04 GB) NTFS
      2 Drive d: () (Fixed) (Total:931.51 GB) (Free:317.39 GB) NTFS
      User accounts for \JAKE-PC
      Jake
      **** End of log ****
      • mcnugget
        • Mar 2017
        • 11
        Screen shot was taken whilst only discord was open in case that effects anything, do you want another screen shot whilst under stress?
        • jmarket
          PCHF Owner
          • 7695
          • CachyOS
          Yes please
          • mcnugget
            • Mar 2017
            • 11
            This was whilst playing a game of over watch on medium
              Hope you don`t mind the interjection folks
              Do you have a link to your specific case type, there are various models of the Bitfenix Neos case some of which have a better cooling system supplied as standard.
              When you post back can you let us know the brand and model name or number of your PSU.
              An observation from your second Speedfan screenshot, fan 2 is running marginally slower when the computer is under load when ideally it should be running faster as fan 1 is shown to be.
              Download then run HWMonitor and post a screenshot so that we have a comparison to the Speedfan results, details from here we will hopefully get some voltage readings.
              • mcnugget
                • Mar 2017
                • 11
                Bitfenix Neos ATX Tower Black/Black, sorry I don’t have a link to the case because it was 3 or 4 years ago when I built it, but I do know that it is the Bitfenix neos black/black on this page ( https://www.overclockers.co.uk/ocuk-...4-tl.html#t=au ) as that is the page I built my PC on.
                PSU:sf 550p14xe hx
                  Thanks for the additional info (y)
                  Your case specs here show that there may not be a front cooling fan, if yes, I would suggest that you fit an appropriate 120mm cooling fan to draw in cool, clean air and while fitting it the removable front and PSU dust filters should be removed and cleaned.
                  PSU is a decent brand and spec and has an adequate output for your hardware.
                  Most of the HWMonitor readings are fine but there is high CPU usage for a computer not under load and the voltage to the memory slots possibly marginally high, can you tell us the brand, spec and number of memory modules you have so we can check what the voltage should be, get back to us with this info first please, I don`t want to overload you with things to do.
                  • mcnugget
                    • Mar 2017
                    • 11
                    #10
                    By the way those last 2 screen shots were taken whilst playing a game of over watch, i’ll attach ones whilst idle to this reply.
                    My memory is this https://www.overclockers.co.uk/kings...my-182-ks.html
                      #11
                      Thanks, that explains the high CPU usage.
                      Still a couple of marginally high voltages for the RAM and CPU, are you or have you overclocked anything, do you know how to restore the MBs default factory settings in the BIOS.
                      Check the AMD FX-8350 specifications here then compare them with both sets of your screenshots and you will see the slight difference, likewise check the HWMonitor VIN readings and you will see that they exceed the max of 1.65V of your RAM, the readings may not look like much but the additional voltage will increase the heat which needs to be expelled from inside the case asap, the pull/push method of drawing cool, clean air in at the front and having an exhaust fan at the rear works best, any top or side fans are an added bonus when you have front and rear chassis fans.
                      • mcnugget
                        • Mar 2017
                        • 11
                        #12
                        I chose the parts for this PC on Overclockers and then they built it and sent it too me, I remember there being an option to have it over clocked but I am not sure if I decided to do it or not, and I don’t know how to restore the MBs factory settings in the BIOS
                          #13
                          Easiest way is in the BIOS menu, see example guide here
                          Please note that if you have two options as in load fail safe or optimal settings you should choose the load fail safe option, this is also sometimes listed as most stable or factory default settings, in this instance the optimal settings should not be selected as it is a form of overclocking and can lead to instability.
                          • mcnugget
                            • Mar 2017
                            • 11
                            #14
                            I am having trouble finding the option to reset to factory defaults, there are plenty of options to set to optimised settings but none that i can see to reset to factory defaults, the closest I have found is reset to previous settings (or something along those lines)
                              #15
                              Your MB may only have the optimised settings option and if so it = the same as the factory default settings and can be safely selected.
