Malwarebytes stopped working suddenly. Their Chameleon system unable to fix!
  • papeter
    • Feb 2017
    • 33
    #16
    Here you go:-
    Zemana AntiMalware 2.74.2.150 (Installed)
    Scan Result : Completed
    Scan Date : 2017/9/27
    Operating System : Windows 10 64-bit
    Processor : 4X Intel(R) Core™ i7-5500U CPU @ 2.40GHz
    BIOS Mode : UEFI
    CUID : 12A8DBC7D7FB52E21D6592
    Scan Type : System Scan
    Duration : 15m 10s
    Scanned Objects : 127104
    Detected Objects : 1
    Excluded Objects : 0
    Read Level : Normal
    Auto Upload : Enabled
    Detect All Extensions : Disabled
    Scan Documents : Disabled
    Domain Info : WORKGROUP,0,2
    [HEADING=1]Detected Objects[/HEADING]
    Edge Homepage
    Status : Scanned
    Object : Homepage
    MD5 : -
    Publisher : -
    Version : -
    Detection : Suspicious Browser Setting
    Cleaning Action : Repair
    Related Objects :
    Browser Setting - Edge Homepage
    [HEADING=1]Cleaning Result[/HEADING]
    Cleaned : 1
    Reported as safe : 0
    Failed : 0
    • jmarket
      PCHF Owner
      • 7695
      • CachyOS
      • Intel Arc A770 (16 GB)
      #17
      I will have a fixlist ready for you when you wake up in the morning I’m based here in the US so my timezone is way behind yours
      In the meantime, I want you to try the following for me to restore Malwarebytes
      [li]Download the Malwarebytes Removal Tool. This tool is created by Malwarebytes to completely remove MBAM. It will completely remove MBAM, including license information, settings, and files for MBAM.[/li][li]Run the tool and let it complete. It will ask you to reboot. Do so.[/li][li]After the reboot, re-download the latest version of MBAM[/li][li]Let it install, and reboot the computer when asked.[/li][li]Re-enter in your license information and it should be fully working[/li][/ul]
      • papeter
        • Feb 2017
        • 33
        #18
        Yipee…I downloaded the new version 3.2.2 and it’s just done a complete scan of 382K files with no problems. Nothing found on that scan.
        Thanks for your fantastic help, I can’t tell you how grateful I am :LOL:
        • jmarket
          PCHF Owner
          • 7695
          • CachyOS
          #19
          We’re not done yet. Even though Malwarebytes is installed, we have some stuff that need to be removed and taken care of
          Download Security Check to your desktop.
          Right click it and choose Run as Administrator.
          When the program completes, the tool will automatically open a log file.
          Please post that log here in your next post.
          Please download Geek Uninstaller and uninstall the following programs:
          Lenovo EasyCamera
          Lenovo FusionEngine
          Lenovo Mobile Phone Wireless Import
          Lenovo OneKey Recovery
          Lenovo Patch Utility
          Lenovo Patch Utility 64 bit
          Lenovo PhoneCompanion
          Lenovo PowerDVD10
          Download attached fixlist.txt file and save it to the Desktop. NOTE. It’s important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system. Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
          • papeter
            • Feb 2017
            • 33
            #20
            SECURITY CHECK LOGS DONE & HAVE REMOVED THE LENOVO PROGRAMS:
            SecurityCheck by glax24 & Severnyj v.1.4.0.52 [25.07.17]
            WebSite: www.safezone.cc
            DateLog: 28.09.2017 14:54:52
            Path starting: C:\Users\papeter\AppData\Local\Temp\SecurityCheck\ SecurityCheck.exe
            Log directory: C:\SecurityCheck
            IsAdmin: True
            User: papeter
            VersionXML: 4.64is-23.09.2017
            Windows 10(6.3.15063) (x64) Core Release: 1703 Lang: English(0409)
            Installation date OS: 21.09.2017 12:43:08
            LicenseStatus: Windows(R), Core edition The machine is permanently activated.
            LicenseStatus: Office 16, Office16O365HomePremR_Subscription4 edition Timebased activation will expire :77928 minutes
            LicenseStatus: Office 16, Office16O365HomePremR_Grace edition Windows is in Notification mode
            Boot Mode: Normal
            Default Browser: Microsoft Edge (C:\WINDOWS\system32\LaunchWinApp.exe)
            SystemDrive: C: FS: [NTFS] Capacity: [888.7 Gb] Used: [482.6 Gb] Free: [406.1 Gb]
            ------------------------------- [ Windows ] -------------------------------
            Internet Explorer 11.608.15063.0
            User Account Control enabled
            Automatically download and schedule installation
            Windows Update (wuauserv) - The service is running
            Security Center (wscsvc) - The service is running
            Remote Registry (RemoteRegistry) - The service has stopped
            SSDP Discovery (SSDPSRV) - The service is running
            Remote Desktop Services (TermService) - The service has stopped
            Windows Remote Management (WS-Management) (WinRM) - The service has stopped
            ---------------------------- [ Antivirus_WMI ] ----------------------------
            Kaspersky Internet Security (enabled and up to date)
            Windows Defender (disabled)
            Malwarebytes (enabled and up to date)
            ---------------------------- [ Firewall_WMI ] -----------------------------
            Kaspersky Internet Security (enabled)
            --------------------------- [ AntiSpyware_WMI ] ---------------------------
            Windows Defender (disabled and up to date)
            ---------------------- [ AntiVirusFirewallInstall ] -----------------------
            Kaspersky Secure Connection v.17.0.0.611
            Kaspersky Internet Security v.17.0.0.611
            -------------------------- [ SecurityUtilities ] --------------------------
            Malwarebytes version 3.2.2.2029 v.3.2.2.2029
            Zemana AntiMalware v.2.74.0.150
            --------------------------- [ OtherUtilities ] ----------------------------
            Microsoft Silverlight v.5.1.50907.0
            Picasa 3 v.3.9.141.259 Warning! This software is no longer supported.
            VLC media player v.2.2.6
            --------------------------- [ AppleProduction ] ---------------------------
            Bonjour v.3.1.0.1
            iTunes v.12.6.1.25 Warning! Download Update
            ^Please use Apple Software Update tool.[1]
            Bonjour Service (Bonjour Service) - The service is running
            --------------------------- [ AdobeProduction ] ---------------------------
            Adobe Flash Player 27 NPAPI v.27.0.0.130
            Adobe Acrobat Reader DC v.17.012.20098
            ------------------------------- [ Browser ] -------------------------------
            Google Chrome v.61.0.3163.100
            Mozilla Firefox 55.0.3 (x86 en-GB) v.55.0.3
            --------------------------- [ RunningProcess ] ----------------------------
            C:\Program Files (x86)\Mozilla Firefox\firefox.exe v.55.0.3.6445
            ------------------ [ AntivirusFirewallProcessServices ] -------------------
            C:\Program Files (x86)\HMA! Pro VPN\vpnsvc.exe v.3.6.69.0
            Kaspersky Anti-Virus Service 17.0.0 (AVP17.0.0) - The service is running
            C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\avp.exe v.17.0.0.611
            klvssbrigde64 (klvssbrigde64) - The service has stopped
            C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\avpui.exe v.17.0.0.643
            C:\Program Files (x86)\Kaspersky Lab\Kaspersky Secure Connection 1.0\ksde.exe v.17.0.0.611
            C:\Program Files (x86)\Kaspersky Lab\Kaspersky Secure Connection 1.0\ksdeui.exe v.17.0.0.643
            C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe v.3.0.0.1169
            Malwarebytes Service (MBAMService) - The service is running
            C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe v.3.1.0.556
            C:\Program Files\Windows Defender\MSASCuiL.exe v.4.11.15063.0
            Windows Defender Antivirus Service (WinDefend) - The service has stopped
            Windows Defender Antivirus Network Inspection Service (WdNisSvc) - The service has stopped
            ZAM Controller Service (ZAMSvc) - The service is running
            C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe v.2.74.0.150
            ----------------------------- [ End of Log ] ------------------------------
            1. /b ↩︎
            • jmarket
              PCHF Owner
              • 7695
              • CachyOS
              #21
              Can you post the fix log and run FRST again and post fresh logs please? Things are looking much better now and you’re almost in the clear
              • papeter
                • Feb 2017
                • 33
                #22
                [HEADING=1]Fix result of Farbar Recovery Scan Tool (x64) Version: 26-09-2017 01
                Ran by papeter (28-09-2017 15:18:27) Run:3
                Running from C:\Users\papeter\Desktop
                Loaded Profiles: papeter (Available Profiles: papeter)
                Boot Mode: Normal[/HEADING]
                fixlist content:
                start
                CreateRestorePoint:
                CloseProcesses:
                HKLM...\Run: [LenovoUtility] => C:\Program Files\Lenovo\LenovoUtility\utility.exe [10828056 2015-02-05] (Lenovo(beijing) Limited)
                HKLM...\Run: [PhoneCompanion] => C:\Program Files\Lenovo PhoneCompanion\Phone Companion.exe [802800 2015-02-05] (Lenovo)
                HKLM...\Run: [LMCSSTART1] => C:\Program Files\Lenovo\Communications Utility\lmcsctrl.exe [30152 2015-03-23] (Lenovo Corporation)
                HKLM...\Run: [LMCSSTART2] => C:\Program Files\Lenovo\Communications Utility\lmcsctrl.exe [30152 2015-03-23] (Lenovo Corporation)
                HKLM...\Run: [LMCSSTART3] => C:\Program Files\Lenovo\Communications Utility\lmcsctrl.exe [30152 2015-03-23] (Lenovo Corporation)
                HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [CCleaner Monitoring] => C:\Program Files\CCleaner\CCleaner64.exe [9856176 2017-09-20] (Piriform Ltd)
                HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [Google Update] => C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\GoogleUpdateCore.exe [601168 2017-04-29] (Google Inc.)
                HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [Google Photos Backup] => C:\Users\papeter\AppData\Local\Programs\Google\Goo gle Photos Backup\Google Photos Backup.exe [3790936 2016-04-08] (Google, Inc)
                Tcpip..\Interfaces{43520b0a-4f6b-4271-bd91-0e94ebbbdbff}: [DhcpNameServer] 62.24.243.4 62.24.128.198
                Tcpip..\Interfaces{798b3fb4-2b0f-4349-8753-1c69617f003c}: [DhcpNameServer] 192.168.1.1
                Tcpip..\Interfaces{8a951e76-1a52-472e-b275-8e344bcfc594}: [DhcpNameServer] 192.168.1.1
                Tcpip..\Interfaces{9c0c9f0b-e558-47dd-84e5-2b139e86df58}: [DhcpNameServer] 10.163.0.1
                Tcpip..\Interfaces{c395cc9b-863d-41bd-b910-9b8c72cc7e3e}: [NameServer] 77.234.40.79
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = hxxp://lenovo13.msn.com/?pc=LCJB
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Internet Explorer\Main,Secondary Start Pages = hxxp://www.lenovo.com
                SearchScopes: HKLM → DefaultScope {51B4207A-1DF4-4AB6-AB39-7FAE55BB94B0} URL =
                SearchScopes: HKLM-x32 → DefaultScope {51B4207A-1DF4-4AB6-AB39-7FAE55BB94B0} URL =
                SearchScopes: HKU\S-1-5-21-4237603079-860989819-990887440-1001 → DefaultScope {012E1000-F331-11DB-8314-0800200C9A66} URL = hxxp://www.google.com/search?q={searchTerms}
                SearchScopes: HKU\S-1-5-21-4237603079-860989819-990887440-1001 → {012E1000-F331-11DB-8314-0800200C9A66} URL = hxxp://www.google.com/search?q={searchTerms}
                FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: @tools.google.com/Google Update;version=3 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\npGoogleUpdate3.dll [2017-04-29] (Google Inc.)
                FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: @tools.google.com/Google Update;version=9 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\npGoogleUpdate3.dll [2017-04-29] (Google Inc.)
                CHR DefaultSearchURL: Default → hxxps://www.google.com/search?q={searchTerms}&ie=utf-8&oe=utf-8&aq=t&q={searchTerms}&ie=utf-8&oe=utf-8&aq=t&channel=fflb&q={searchTerms}&ie=utf-8&oe=utf-8&aq=t&channel=rcs
                CHR DefaultSuggestURL: Default → hxxps://www.google.com/complete/search?q={searchTerms}
                CHR Extension: (Chrome Media Router) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcj beemfm [2017-08-16]
                CHR Profile: C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1 [2017-09-27]
                CHR HKLM...\Chrome\Extension: [fhoibnponjcgjgcnfacekaijdbbplhib] - hxxps://chrome.google.com/webstore/detail/fhoibnponjcgjgcnfacekaijdbbplhib
                CHR Extension: (SEO for Chrome) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\oangcciaeihlfmhppegpdceadp faoclj [2015-10-30]
                CHR HKLM-x32...\Chrome\Extension: [fhoibnponjcgjgcnfacekaijdbbplhib] - hxxps://chrome.google.com/webstore/detail/fhoibnponjcgjgcnfacekaijdbbplhib
                R3 LenovoUpdate; C:\WINDOWS\System32\LenovoUpdate.exe [26608 2017-09-27] (Lenovo)
                S3 MWAC; C:\WINDOWS\system32\drivers\ [0 ] () <==== ATTENTION (zero byte File/Folder)
                S3 MWAC; C:\WINDOWS\SysWOW64\drivers\ [0 ] () <==== ATTENTION (zero byte File/Folder)
                C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA1d257e73535f0dd
                C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater
                C:\WINDOWS\System32\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001
                C:\WINDOWS\System32\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001
                C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-4237603079-860989819-990887440-500
                C:\WINDOWS\System32\Tasks\Lenovo
                C:\WINDOWS\system32{A6D608F0-0BDE-491A-97AE-5C4B05D86E01}.bat
                C:\WINDOWS\system32{EC94D02F-D200-4428-9531-05AF7F9799CB}.bat
                C:\WINDOWS\system32\wpbbin.exe
                C:\WINDOWS\system32\LenovoUpdate.exe
                C:\Users\papeter\Downloads\ccsetup534.exe
                C:\WINDOWS\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001.job
                C:\WINDOWS\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001.job
                CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{590C4387-5EBD-4D46-8A84-CD0BA2EF2856}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 0.3\psuser_64.dll => No File
                Task: {3D3E30EB-E7EF-4BE0-8D55-E6A74DE09768} - System32\Tasks\Lenovo\Dependency Package Auto Update => C:\Program Files\Lenovo\iMController\AutoUpdate.exe [2014-05-22] ()
                Task: {81EF1F8A-693D-421D-A6C7-CABAEE21D915} - System32\Tasks\Lenovo\Lenovo Customer Feedback Program 64 35 => C:\Program Files (x86)\Lenovo\Customer Feedback Program 35\Lenovo.TVT.CustomerFeedback.Agent35.exe [2014-05-30] (Lenovo)
                Task: {EF34F3B6-CEFC-4193-A7AA-86535DABD808} - System32\Tasks\Microsoft\Windows\RemovalTools\MRT_ HB => C:\WINDOWS\system32\MRT.exe [2017-09-13] (Microsoft Corporation)
                Task: C:\WINDOWS\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001.job => C:\Users\papeter\AppData\Local\GoToMeeting\7586\g2 mupdate.exe
                Task: C:\WINDOWS\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001.job => C:\Users\papeter\AppData\Local\GoToMeeting\7586\g2 mupload.exe
                ShortcutWithArgument: C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Chrome Apps\Pocket.lnk → C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) → --profile-directory=Default --app-id=mjcnijlhddpbdemagnpefmlkjdagkogk
                RemoveProxy:
                EmptyTemp:
                reboot:
                end
                HKLM\Software\Microsoft\Windows\CurrentVersion\Run \LenovoUtility => value removed successfully
                HKLM\Software\Microsoft\Windows\CurrentVersion\Run \PhoneCompanion => value not found.
                HKLM\Software\Microsoft\Windows\CurrentVersion\Run \LMCSSTART1 => value removed successfully
                HKLM\Software\Microsoft\Windows\CurrentVersion\Run \LMCSSTART2 => value removed successfully
                HKLM\Software\Microsoft\Windows\CurrentVersion\Run \LMCSSTART3 => value removed successfully
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Windows\CurrentVersion\Run \CCleaner Monitoring => value removed successfully
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Windows\CurrentVersion\Run \Google Update => value removed successfully
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Windows\CurrentVersion\Run \Google Photos Backup => value removed successfully
                HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{43520b0a-4f6b-4271-bd91-0e94ebbbdbff}\DhcpNameServer => value removed successfully
                HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{798b3fb4-2b0f-4349-8753-1c69617f003c}\DhcpNameServer => value removed successfully
                HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{8a951e76-1a52-472e-b275-8e344bcfc594}\DhcpNameServer => value removed successfully
                HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{9c0c9f0b-e558-47dd-84e5-2b139e86df58}\DhcpNameServer => value removed successfully
                HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{c395cc9b-863d-41bd-b910-9b8c72cc7e3e}\NameServer => value removed successfully
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Internet Explorer\Main\Default_Page_URL => value restored successfully
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Internet Explorer\Main\Secondary Start Pages => value removed successfully
                HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\DefaultScope => value restored successfully
                HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\DefaultScope => value restored successfully
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\DefaultScope => value removed successfully
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\SOFTWARE\Microsoft\Internet Explorer\SearchScopes{012E1000-F331-11DB-8314-0800200C9A66} => key removed successfully
                HKLM\Software\Classes\CLSID{012E1000-F331-11DB-8314-0800200C9A66} => key not found.
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\MozillaPlugins@tools.google.com/Google Update;version=3 => key removed successfully
                C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\npGoogleUpdate3.dll => moved successfully
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\MozillaPlugins@tools.google.com/Google Update;version=9 => key removed successfully
                C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\npGoogleUpdate3.dll => not found.
                Chrome DefaultSearchURL => removed successfully
                Chrome DefaultSuggestURL => removed successfully
                CHR Extension: (Chrome Media Router) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcj beemfm [2017-08-16] => Error: No automatic fix found for this entry.
                C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1 => moved successfully
                HKLM\SOFTWARE\Google\Chrome\Extensions\fhoibnponjc gjgcnfacekaijdbbplhib => key removed successfully
                CHR Extension: (SEO for Chrome) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\oangcciaeihlfmhppegpdceadp faoclj [2015-10-30] => Error: No automatic fix found for this entry.
                HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions \fhoibnponjcgjgcnfacekaijdbbplhib => key removed successfully
                HKLM\System\CurrentControlSet\Services\LenovoUpdat e => key removed successfully
                LenovoUpdate => service removed successfully
                MWAC => service not found.
                C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA1d257e73535f0dd => moved successfully
                C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater => moved successfully
                C:\WINDOWS\System32\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001 => moved successfully
                C:\WINDOWS\System32\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001 => moved successfully
                C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-4237603079-860989819-990887440-500 => moved successfully
                C:\WINDOWS\System32\Tasks\Lenovo => moved successfully
                C:\WINDOWS\system32{A6D608F0-0BDE-491A-97AE-5C4B05D86E01}.bat => moved successfully
                C:\WINDOWS\system32{EC94D02F-D200-4428-9531-05AF7F9799CB}.bat => moved successfully
                C:\WINDOWS\system32\wpbbin.exe => moved successfully
                C:\WINDOWS\system32\LenovoUpdate.exe => moved successfully
                C:\Users\papeter\Downloads\ccsetup534.exe => moved successfully
                C:\WINDOWS\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001.job => moved successfully
                C:\WINDOWS\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001.job => moved successfully
                HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{590C4387-5EBD-4D46-8A84-CD0BA2EF2856} => key removed successfully
                HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{3D3E30E B-E7EF-4BE0-8D55-E6A74DE09768} => key removed successfully
                HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{3D3E30E B-E7EF-4BE0-8D55-E6A74DE09768} => key removed successfully
                C:\WINDOWS\System32\Tasks\Lenovo\Dependency Package Auto Update => not found.
                HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Lenovo\D ependency Package Auto Update => key removed successfully
                HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{81EF1F8 A-693D-421D-A6C7-CABAEE21D915} => key removed successfully
                HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{81EF1F8 A-693D-421D-A6C7-CABAEE21D915} => key removed successfully
                C:\WINDOWS\System32\Tasks\Lenovo\Lenovo Customer Feedback Program 64 35 => not found.
                HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Lenovo\L enovo Customer Feedback Program 64 35 => key removed successfully
                HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{EF34F3B 6-CEFC-4193-A7AA-86535DABD808} => key removed successfully
                HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{EF34F3B 6-CEFC-4193-A7AA-86535DABD808} => key removed successfully
                C:\WINDOWS\System32\Tasks\Microsoft\Windows\Remova lTools\MRT_HB => moved successfully
                HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\RemovalTools\MRT_HB => key removed successfully
                C:\WINDOWS\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001.job => not found.
                C:\WINDOWS\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001.job => not found.
                C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Chrome Apps\Pocket.lnk => Shortcut argument removed successfully.
                HKU.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVers ion\Internet Settings\Connections\DefaultConnectionSettings => value removed successfully
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings\Connections\DefaultConnectionSettings => value removed successfully
                HKU\S-1-5-21-4237603079-860989819-990887440-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings\Connections\SavedLegacySettings => value removed successfully
                BITS transfer queue => 7888896 B
                DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 16120783 B
                Java, Flash, Steam htmlcache => 543 B
                Windows/system/drivers => 657755 B
                Edge => 0 B
                Chrome => 155004 B
                Firefox => 35388968 B
                Opera => 0 B
                Default => 0 B
                Users => 0 B
                ProgramData => 0 B
                Public => 0 B
                systemprofile => 128 B
                systemprofile32 => 11997 B
                LocalService => 9914 B
                NetworkService => 0 B
                papeter => 29287627 B
                RecycleBin => 188783 B
                EmptyTemp: => 85.6 MB temporary data Removed.
                The system needed a reboot.
                ==== End of Fixlog 15:19:11 ====
                • papeter
                  • Feb 2017
                  • 33
                  #23
                  Sorry, I can’t get the FIX button to work on the FRST64(1)exe - I have the fixlist(1).txt on the same desktop as well.
                  The message says: the fixlist.txt should be in the same folder/directory the tool is located. I thought I had.
                  I must have done something wrong.
                  • jmarket
                    PCHF Owner
                    • 7695
                    • CachyOS
                    #24
                    Your fix worked properly
                    Now we just need fresh FRST and Addition logs
                    Use Geek Uninstaller to remove Picasa as it’s no longer supported
                    • papeter
                      • Feb 2017
                      • 33
                      #25
                      Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 26-09-2017 01
                      Ran by papeter (administrator) on LENOVO-PC (28-09-2017 20:36:11)
                      Platform: Windows 10 Home Version 1703 (X64) Language: English (United States)
                      Internet Explorer Version 11 (Default browser: FF)
                      Boot Mode: Normal
                      Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic...ery-scan-tool/
                      (Intel Corporation) C:\Windows\System32\igfxCUIService.exe
                      (Lenovo Corporation) C:\Program Files\Lenovo\Communications Utility\AVControlCenter32.exe
                      (Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
                      (LENOVO INCORPORATED.) C:\Program Files\Lenovo\iMController\SystemAgentService.exe
                      () C:\Program Files (x86)\Canon\IJPLM\ijplmsvc.exe
                      (Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
                      (Conexant Systems Inc.) C:\Windows\System32\CxAudMsg64.exe
                      (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\avp.exe
                      (Nuance Communications, Inc.) C:\Program Files (x86)\Nuance\Dragon Assistant\Core\DACore.exe
                      () C:\Program Files (x86)\ExpressVPN\bootstrap\AMD64\nssm.exe
                      (Broadcom Corporation.) C:\Windows\System32\BtwRSupportService.exe
                      (AVAST Software) C:\Program Files (x86)\HMA! Pro VPN\vpnsvc.exe
                      (Lenovo(beijing) Limited) C:\Windows\System32\LenovoWiFiHotspotSvr.exe
                      (Lenovo Group Limited) C:\Program Files\Lenovo\SettingsDependency\SettingsService.ex e
                      (Lenovo(beijing) Limited) C:\Program Files (x86)\Lenovo\Lenovo Settings\x86\LenovoSetSvr.exe
                      (NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
                      () C:\Program Files (x86)\HiSuite\HandSetService\HuaweiHiSuiteService6 4.exe
                      (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe
                      () C:\Program Files\CyberLink\Shared files\RichVideo64.exe
                      () C:\Program Files (x86)\ExpressVPN\xvpnd\xvpnd.exe
                      (Lenovo Corporation) C:\Program Files\Lenovo\Communications Utility\avfaudiosw.exe
                      (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe
                      (Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe
                      (Microsoft Corporation) C:\Windows\System32\wlanext.exe
                      (Lenovo) C:\Windows\System32\LenovoUpdate.exe
                      (Copyright 2017.) C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe
                      (ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrl.exe
                      (Microsoft Corporation) C:\Windows\Microsoft.NET\Framework64\v3.0\WPF\Pres entationFontCache.exe
                      (Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe
                      (Google Inc.) C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler.ex e
                      (Google Inc.) C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler64. exe
                      (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\avpui.exe
                      (ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrlHelper.exe
                      (Intel Corporation) C:\Windows\System32\igfxEM.exe
                      (Intel Corporation) C:\Windows\System32\igfxHK.exe
                      () C:\Windows\System32\igfxTray.exe
                      (Adobe Systems Incorporated) C:\Program Files\Adobe\Elements 14 Organizer\PhotoshopElementsFileAgent.exe
                      (Microsoft Corporation) C:\Windows\System32\PrintIsolationHost.exe
                      (Microsoft Corporation) C:\Program Files\Windows Defender\MSASCuiL.exe
                      (NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe
                      () C:\Program Files\CONEXANT\ForteConfig\fmapp.exe
                      (Conexant Systems, Inc.) C:\Program Files\CONEXANT\cAudioFilterAgent\CAudioFilterAgent 64.exe
                      (Apple Inc.) C:\Program Files\iTunes\iTunesHelper.exe
                      (ExpressVPN) C:\Program Files (x86)\ExpressVPN\xvpn-ui\ExpressVpn.exe
                      (NETGEAR) C:\Program Files (x86)\NETGEAR\WNDA3100v3\WNDA3100v3.EXE
                      () C:\Program Files (x86)\Lenovo\CCSDK\CCSDK.exe
                      (Apple Inc.) C:\Program Files\iPod\bin\iPodService.exe
                      () C:\Program Files (x86)\Lenovo\CCSDK\WinGather.exe
                      (Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
                      (Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
                      (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\FWService\IntelMeFWService.exe
                      (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
                      (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Secure Connection 1.0\ksde.exe
                      (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
                      (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Secure Connection 1.0\ksdeui.exe
                      (Microsoft Corporation) C:\Program Files\Common Files\microsoft shared\ClickToRun\OfficeClickToRun.exe
                      (Microsoft Corporation) C:\Program Files\Common Files\microsoft shared\ClickToRun\AppVShNotify.exe
                      (Microsoft Corporation) C:\Windows\SysWOW64\wbem\WmiPrvSE.exe
                      (Microsoft Corporation) C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\WinStore.App.exe
                      () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17082.141 21.0_x64__8wekyb3d8bbwe\Video.UI.exe
                      (Microsoft Corporation) C:\Program Files\WindowsApps\microsoft.windowscommunicationsa pps_17.8500.40955.0_x64__8wekyb3d8bbwe\HxOutlook.e xe
                      (Microsoft Corporation) C:\Program Files\WindowsApps\microsoft.windowscommunicationsa pps_17.8500.40955.0_x64__8wekyb3d8bbwe\HxTsr.exe
                      () C:\Program Files\WindowsApps\Microsoft.WindowsAlarms_10.1706. 2231.0_x64__8wekyb3d8bbwe\Time.exe
                      (Microsoft Corporation) C:\Windows\ImmersiveControlPanel\SystemSettings.ex e
                      (Mozilla Corporation) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
                      (Microsoft Corporation) C:\Program Files (x86)\Microsoft Office\root\Office16\EXCEL.EXE
                      (Adobe Systems Incorporated) C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroCEF\RdrCEF.exe
                      (Microsoft Corporation) C:\Windows\System32\smartscreen.exe
                      (Farbar) C:\Users\papeter\Desktop\FRST64(1).exe
                      ==================== Registry (Whitelisted) ===========================
                      HKLM...\Run: [SecurityHealth] => C:\Program Files\Windows Defender\MSASCuiL.exe [629152 2017-03-18] (Microsoft Corporation)
                      HKLM...\Run: [ETDCtrl] => C:\Program Files\Elantech\ETDCtrl.exe [3242696 2015-10-07] (ELAN Microelectronics Corp.)
                      HKLM...\Run: [NvBackend] => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe [2473800 2014-09-09] (NVIDIA Corporation)
                      HKLM...\Run: [IAStorIcon] => C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe [320360 2014-06-25] (Intel Corporation)
                      HKLM...\Run: [ForteConfig] => C:\Program Files\Conexant\ForteConfig\fmapp.exe [49056 2010-10-26] ()
                      HKLM...\Run: [SmartAudio] => C:\Program Files\CONEXANT\SAII\SACpl.exe [1830616 2014-04-10] (Conexant Systems, Inc.)
                      HKLM...\Run: [cAudioFilterAgent] => C:\Program Files\Conexant\cAudioFilterAgent\cAudioFilterAgent 64.exe [916184 2014-07-03] (Conexant Systems, Inc.)
                      HKLM...\Run: [AdobeAAMUpdater-1.0] => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.e xe [508104 2015-07-29] (Adobe Systems Incorporated)
                      HKLM...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [303928 2017-05-09] (Apple Inc.)
                      HKLM...\Run: [ZAM] => C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [15775888 2017-08-09] (Copyright 2017.)
                      HKLM...\Run: [RtsFT] => C:\WINDOWS\RTFTrack.exe [5166872 2016-07-13] (Realtek semiconductor)
                      HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [ExpressVPN4] => C:\Program Files (x86)\ExpressVPN\xvpn-ui\ExpressVpn.exe [806528 2017-07-06] (ExpressVPN)
                      HKU\S-1-5-21-4237603079-860989819-990887440-1001...\MountPoints2: {265574b1-9573-11e7-8309-38b1dbdbd186} - “F:\HiSuiteDownLoader.exe”
                      Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\NETGEAR WNDA3100v3 Genie.lnk [2017-03-27]
                      ShortcutTarget: NETGEAR WNDA3100v3 Genie.lnk → C:\Program Files (x86)\NETGEAR\WNDA3100v3\WNDA3100v3.EXE (NETGEAR)
                      Startup: C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Startup\Send to OneNote.lnk [2017-08-21]
                      ShortcutTarget: Send to OneNote.lnk → C:\Program Files (x86)\Microsoft Office\root\Office16\ONENOTEM.EXE (Microsoft Corporation)
                      Tcpip\Parameters: [DhcpNameServer] 10.51.0.1
                      Tcpip..\Interfaces{776a1195-9cf2-49ea-962f-fbed2f21c1fd}: [DhcpNameServer] 8.8.8.8 8.8.4.4
                      Tcpip..\Interfaces{9c0c9f0b-e558-47dd-84e5-2b139e86df58}: [DhcpNameServer] 10.51.0.1
                      [HEADING=1]Internet Explorer:[/HEADING]
                      BHO: Kaspersky Protection → {2E38825B-8815-42CF-9126-C58BC28D4591} → C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
                      BHO: Lync Browser Helper → {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} → C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\OCHelper.dll [2017-09-28] (Microsoft Corporation)
                      BHO: Canon Easy-WebPrint EX BHO → {3785D0AD-BFFF-47F6-BF5B-A587C162FED9} → C:\Program Files\Canon\Easy-WebPrint EX\ewpexbho.dll [2015-02-23] (CANON INC.)
                      BHO: Microsoft OneDrive for Business Browser Helper → {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} → C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\GROOVEEX.DLL [2017-09-28] (Microsoft Corporation)
                      BHO-x32: Kaspersky Protection → {2E38825B-8815-42CF-9126-C58BC28D4591} → C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
                      BHO-x32: Canon Easy-WebPrint EX BHO → {3785D0AD-BFFF-47F6-BF5B-A587C162FED9} → C:\Program Files (x86)\Canon\Easy-WebPrint EX\ewpexbho.dll [2015-02-23] (CANON INC.)
                      Toolbar: HKLM - Canon Easy-WebPrint EX - {759D9886-0C6F-4498-BAB6-4A5F47C6C72F} - C:\Program Files\Canon\Easy-WebPrint EX\ewpexhlp.dll [2015-02-23] (CANON INC.)
                      Toolbar: HKLM - Kaspersky Protection Toolbar - {093F479D-712E-46CD-9E06-62E734A05F68} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
                      Toolbar: HKLM-x32 - Canon Easy-WebPrint EX - {759D9886-0C6F-4498-BAB6-4A5F47C6C72F} - C:\Program Files (x86)\Canon\Easy-WebPrint EX\ewpexhlp.dll [2015-02-23] (CANON INC.)
                      Toolbar: HKLM-x32 - Kaspersky Protection Toolbar - {093F479D-712E-46CD-9E06-62E734A05F68} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
                      Toolbar: HKU\S-1-5-21-4237603079-860989819-990887440-1001 → Kaspersky Protection Toolbar - {093F479D-712E-46CD-9E06-62E734A05F68} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
                      Handler-x32: mso-minsb-roaming.16 - {83C25742-A9F7-49FB-9138-434302C88D07} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-28] (Microsoft Corporation)
                      Handler-x32: mso-minsb.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-28] (Microsoft Corporation)
                      Handler-x32: osf-roaming.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-28] (Microsoft Corporation)
                      Handler-x32: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-28] (Microsoft Corporation)
                      [HEADING=1]FireFox:[/HEADING]
                      FF ProfilePath: C:\Users\papeter\AppData\Roaming\Mozilla\Firefox\P rofiles\ee8pm1a2.default-1446908155165 [2017-09-28]
                      FF Extension: (Disable Hello, Pocket & Reader+) - C:\Users\papeter\AppData\Roaming\Mozilla\Firefox\P rofiles\ee8pm1a2.default-1446908155165\Extensions\NoTrash@Off.JustOff.xpi [2017-01-16]
                      FF HKLM...\Firefox\Extensions: [light_plugin_F6F079488B53499DB99380A...asp ersky.com] - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\FFExt\light_plugin_firefox\addon.xpi
                      FF Extension: (Kaspersky Protection) - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\FFExt\light_plugin_firefox\addon.xpi [2017-07-25]
                      FF HKLM-x32...\Firefox\Extensions: [light_plugin_F6F079488B53499DB99380A...asp ersky.com] - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\FFExt\light_plugin_firefox\addon.xpi
                      FF Plugin: @adobe.com/FlashPlayer → C:\WINDOWS\system32\Macromed\Flash\NPSWF64_27_0_0_ 130.dll [2017-09-13] ()
                      FF Plugin: @Microsoft.com/NpCtrl,version=1.0 → c:\Program Files\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
                      FF Plugin-x32: @adobe.com/FlashPlayer → C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_27_0_0_ 130.dll [2017-09-13] ()
                      FF Plugin-x32: @canon.com/EPPEX → C:\Program Files (x86)\Canon\My Image Garden\AddOn\CIG\npmigfpi.dll [2011-11-30] (CANON INC.)
                      FF Plugin-x32: @DVR/npmedia,version=3.1.0.4 → C:\Program Files\webrec\WEB30\DVR32\3.1.0.4\npmedia.dll [2014-05-10] ()
                      FF Plugin-x32: @DVR/npTimeGrid,version=3.1.0.4 → C:\Program Files\webrec\WEB30\DVR32\3.1.0.4\npTimeGrid.dll [2014-05-10] (Unauthorized copy)
                      FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI ipt;version=4.0.56 → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIIPT.dll [2014-09-03] (Intel Corporation)
                      FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI updater → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIUpdater.dll [2014-09-03] (Intel Corporation)
                      FF Plugin-x32: @Microsoft.com/NpCtrl,version=1.0 → c:\Program Files (x86)\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
                      FF Plugin-x32: @microsoft.com/SharePoint,version=14.0 → C:\Program Files (x86)\Microsoft Office\root\Office16\NPSPWRAP.DLL [2017-09-28] (Microsoft Corporation)
                      FF Plugin-x32: @Sibelius.com/Scorch Plugin,version=6.2.0.88 → C:\Program Files (x86)\Sibelius Software\Scorch\npsibelius.dll [2013-03-11] ()
                      FF Plugin-x32: @tools.google.com/Google Update;version=3 → C:\Program Files (x86)\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-04-28] (Google Inc.)
                      FF Plugin-x32: @tools.google.com/Google Update;version=9 → C:\Program Files (x86)\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-04-28] (Google Inc.)
                      FF Plugin-x32: @videolan.org/vlc,version=2.2.1 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2017-05-24] (VideoLAN)
                      FF Plugin-x32: @videolan.org/vlc,version=2.2.4 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2017-05-24] (VideoLAN)
                      FF Plugin-x32: @videolan.org/vlc,version=2.2.6 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2017-05-24] (VideoLAN)
                      FF Plugin-x32: Adobe Reader → C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AIR\nppdf32.dll [2017-08-10] (Adobe Systems Inc.)
                      FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: @zoom.us/ZoomVideoPlugin → C:\Users\papeter\AppData\Roaming\Zoom\bin\npzoompl ugin.dll [2017-06-21] (Zoom Video Communications, Inc.)
                      FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: SkypePlugin → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\npGatewayNpapi.dll [2016-09-01] (Skype Technologies S.A.)
                      FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: SkypePlugin64 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\npGatewayNpapi-x64.dll [2016-09-01] (Skype Technologies S.A.)
                      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\nppdf32.dll [2017-08-10] (Adobe Systems Inc.)
                      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\NPSibelius.dll [2013-03-11] ()
                      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\PDFNetC.dll [2010-03-31] (PDFTron Systems Inc.)
                      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\ScorchAxPlugin.dll [2010-04-08] ()
                      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\ScorchPDFWrapper.dll [2010-04-08] ()
                      [HEADING=1]Chrome:[/HEADING]
                      CHR DefaultProfile: Default
                      CHR Profile: C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default [2017-09-28]
                      CHR Extension: (Google Slides) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhon fmgoek [2015-10-30]
                      CHR Extension: (Sizable Send) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\abpoebooacbankjejohknechpi feimmi [2015-10-30]
                      CHR Extension: (Google Docs) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfi lokake [2015-10-30]
                      CHR Extension: (Google Drive) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigk jlhalf [2015-10-30]
                      CHR Extension: (YouTube) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldk acnbeo [2015-10-30]
                      CHR Extension: (Google Search) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\coobgpohoikkiipiblmjeljnie djpjpf [2015-10-30]
                      CHR Extension: (Google Sheets) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpeb giejap [2015-10-30]
                      CHR Extension: (Kaspersky Protection) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\fhoibnponjcgjgcnfacekaijdb bplhib [2017-02-07]
                      CHR Extension: (Google Docs Offline) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdl olhkhi [2016-04-04]
                      CHR Extension: (Pocket) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\mjcnijlhddpbdemagnpefmlkjd agkogk [2017-01-16]
                      CHR Extension: (Ghostery) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\mlomiejdfkolichcflejclcbmp eaniij [2017-09-03]
                      CHR Extension: (Chrome Web Store Payments) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccm gmieda [2017-09-03]
                      CHR Extension: (Gmail) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoe jaedia [2015-10-30]
                      CHR Extension: (Chrome Media Router) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcj beemfm [2017-09-28]
                      CHR Profile: C:\Users\papeter\AppData\Local\Google\Chrome\User Data\System Profile [2017-09-27]
                      CHR HKLM-x32...\Chrome\Extension: [efaidnbmnnnibpcajpcglclefindmkaj] - hxxps://clients2.google.com/service/update2/crx
                      R2 AdobeActiveFileMonitor14.0; C:\Program Files\Adobe\Elements 14 Organizer\PhotoshopElementsFileAgent.exe [226016 2015-12-07] (Adobe Systems Incorporated)
                      R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2017-04-03] (Apple Inc.)
                      R2 AVControlCenter; C:\Program Files\Lenovo\Communications Utility\AVControlCenter32.exe [560584 2015-03-23] (Lenovo Corporation)
                      R2 AVP17.0.0; C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\avp.exe [241544 2016-06-28] (AO Kaspersky Lab)
                      R2 BcmBtRSupport; C:\WINDOWS\system32\BtwRSupportService.exe [2251992 2015-03-27] (Broadcom Corporation.)
                      R2 CCSDK; C:\Program Files (x86)\Lenovo\CCSDK\CCSDK.exe [592880 2014-07-10] ()
                      R2 ClickToRunSvc; C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe [7761608 2017-09-08] (Microsoft Corporation)
                      R2 DACoreService; C:\Program Files (x86)\Nuance\Dragon Assistant\Core\DACore.exe [448400 2014-03-24] (Nuance Communications, Inc.)
                      S2 ETDService; C:\Program Files\Elantech\ETDService.exe [144072 2015-10-07] (ELAN Microelectronics Corp.)
                      R2 ExpressVpnService; C:\Program Files (x86)\ExpressVPN\bootstrap\AMD64\nssm.exe [331264 2017-07-06] () [File not signed]
                      R2 HmaProVpn; C:\Program Files (x86)\HMA! Pro VPN\VpnSvc.exe [3568712 2017-09-13] (AVAST Software)
                      R2 HuaweiHiSuiteService64.exe; C:\Program Files (x86)\HiSuite\HandSetService\HuaweiHiSuiteService6 4.exe [192200 2017-07-26] ()
                      R2 IAStorDataMgrSvc; C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe [16232 2014-06-25] (Intel Corporation)
                      R2 igfxCUIService2.0.0.0; C:\WINDOWS\system32\igfxCUIService.exe [373680 2017-05-26] (Intel Corporation)
                      R2 IJPLMSVC; C:\Program Files (x86)\Canon\IJPLM\IJPLMSVC.EXE [253528 2015-11-09] ()
                      S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [887256 2014-05-13] (Intel(R) Corporation)
                      R2 Intel(R) ME Service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\FWService\IntelMeFWService.exe [131544 2014-09-03] (Intel Corporation)
                      S3 iumsvc; C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [177376 2016-08-12] (Intel Corporation)
                      R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [154584 2014-09-03] (Intel Corporation)
                      S3 klvssbrigde64; C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\vssbridge64.exe [77328 2016-06-28] (AO Kaspersky Lab)
                      R2 KSDE1.0.0; C:\Program Files (x86)\Kaspersky Lab\Kaspersky Secure Connection 1.0\ksde.exe [241544 2016-06-28] (AO Kaspersky Lab)
                      R2 Lenovo Settings Service; C:\Program Files\Lenovo\SettingsDependency\SettingsService.ex e [2016040 2015-04-10] (Lenovo Group Limited)
                      R2 Lenovo System Agent Service; C:\Program Files\Lenovo\iMController\SystemAgentService.exe [584960 2014-05-22] (LENOVO INCORPORATED.)
                      S3 LENOVO.TVTVCAM; C:\Program Files\Lenovo\Communications Utility\vcamsvc.exe [625608 2015-03-23] (Lenovo Corporation)
                      R2 LenovoSetSvr; C:\Program Files (x86)\Lenovo\Lenovo Settings\x86\LenovoSetSvr.exe [258544 2014-06-19] (Lenovo(beijing) Limited)
                      R3 LenovoUpdate; C:\WINDOWS\System32\LenovoUpdate.exe [26608 2017-09-28] (Lenovo)
                      R2 LenovoWiFiHotspotSvr; C:\Windows\System32\LenovoWiFiHotspotSvr.exe [218952 2014-08-26] (Lenovo(beijing) Limited)
                      R2 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe [6058960 2017-08-07] (Malwarebytes)
                      R2 NVDisplay.ContainerLocalSystem; C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe [458176 2016-12-29] (NVIDIA Corporation)
                      R2 NvNetworkService; C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe [1795912 2014-09-09] (NVIDIA Corporation)
                      R2 RichVideo64; C:\Program Files\CyberLink\Shared files\RichVideo64.exe [390632 2012-04-24] ()
                      S3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [342264 2017-03-18] (Microsoft Corporation)
                      S3 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [102816 2017-07-11] (Microsoft Corporation)
                      R2 ZAMSvc; C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [15775888 2017-08-09] (Copyright 2017.)
                      R3 bcbtums; C:\WINDOWS\system32\drivers\bcbtums.sys [173312 2015-03-27] (Broadcom Corporation.)
                      R3 BCM43XX; C:\WINDOWS\system32\DRIVERS\bcmwl63a.sys [7504560 2013-11-20] (Broadcom Corporation)
                      R0 cm_km; C:\WINDOWS\System32\DRIVERS\cm_km.sys [238936 2016-06-10] (AO Kaspersky Lab)
                      R1 ESProtectionDriver; C:\WINDOWS\system32\drivers\mbae64.sys [77440 2017-08-24] ()
                      S3 ew_usbccgpfilter; C:\WINDOWS\System32\drivers\ew_usbccgpfilter.sys [18944 2017-07-26] (Huawei Technologies Co., Ltd.)
                      R3 hmatap; C:\WINDOWS\System32\drivers\hmatap.sys [27136 2016-09-01] (The OpenVPN Project)
                      R0 kl1; C:\WINDOWS\System32\DRIVERS\kl1.sys [554416 2016-06-02] (AO Kaspersky Lab)
                      R0 klbackupdisk; C:\WINDOWS\System32\DRIVERS\klbackupdisk.sys [63920 2016-06-07] (AO Kaspersky Lab)
                      R1 klbackupflt; C:\WINDOWS\System32\DRIVERS\klbackupflt.sys [86352 2016-06-15] (AO Kaspersky Lab)
                      R2 kldisk; C:\WINDOWS\system32\DRIVERS\kldisk.sys [78216 2016-05-31] (AO Kaspersky Lab)
                      S0 klelam; C:\WINDOWS\System32\DRIVERS\klelam.sys [28792 2016-03-31] (AO Kaspersky Lab)
                      R3 klflt; C:\WINDOWS\system32\DRIVERS\klflt.sys [197312 2017-07-25] (AO Kaspersky Lab)
                      R1 klhk; C:\WINDOWS\System32\drivers\klhk.sys [520152 2017-07-25] (AO Kaspersky Lab)
                      S3 klids; C:\ProgramData\Kaspersky Lab\AVP17.0.0\Bases\klids.sys [186696 2017-09-28] (AO Kaspersky Lab)
                      R1 KLIF; C:\WINDOWS\System32\DRIVERS\klif.sys [1021624 2017-07-25] (AO Kaspersky Lab)
                      R1 KLIM6; C:\WINDOWS\system32\DRIVERS\klim6.sys [57424 2017-09-21] (AO Kaspersky Lab)
                      R3 klkbdflt; C:\WINDOWS\system32\DRIVERS\klkbdflt.sys [52136 2016-05-19] (AO Kaspersky Lab)
                      R3 klmouflt; C:\WINDOWS\system32\DRIVERS\klmouflt.sys [41656 2015-06-07] (Kaspersky Lab ZAO)
                      R1 klpd; C:\WINDOWS\System32\DRIVERS\klpd.sys [45488 2016-05-31] (AO Kaspersky Lab)
                      R3 kltap; C:\WINDOWS\System32\drivers\kltap.sys [52152 2016-06-07] (The OpenVPN Project)
                      R0 klupd_klif_arkmon; C:\WINDOWS\System32\Drivers\klupd_klif_arkmon.sys [229288 2017-07-04] (AO Kaspersky Lab)
                      R3 klupd_klif_kimul; C:\WINDOWS\System32\Drivers\klupd_klif_kimul.sys [87584 2017-08-29] (AO Kaspersky Lab)
                      R3 klupd_klif_klark; C:\WINDOWS\System32\Drivers\klupd_klif_klark.sys [251656 2017-07-12] (AO Kaspersky Lab)
                      R0 klupd_klif_klbg; C:\WINDOWS\System32\Drivers\klupd_klif_klbg.sys [112912 2017-07-04] (AO Kaspersky Lab)
                      R3 klupd_klif_mark; C:\WINDOWS\System32\Drivers\klupd_klif_mark.sys [173144 2017-07-12] (AO Kaspersky Lab)
                      R1 klwfp; C:\WINDOWS\system32\DRIVERS\klwfp.sys [85320 2016-06-18] (AO Kaspersky Lab)
                      R1 Klwtp; C:\WINDOWS\system32\DRIVERS\klwtp.sys [136416 2017-03-15] (AO Kaspersky Lab)
                      R3 KMDFVirtualKbd; C:\WINDOWS\System32\drivers\KMDFVirtualKbd.sys [22264 2014-08-05] ()
                      S3 KMDFVirtualMouse; C:\WINDOWS\System32\drivers\KMDFVirtualMouse.sys [21240 2014-08-05] ()
                      R1 kneps; C:\WINDOWS\system32\DRIVERS\kneps.sys [199640 2017-07-25] (AO Kaspersky Lab)
                      R2 MBAMChameleon; C:\WINDOWS\system32\drivers\MBAMChameleon.sys [192960 2017-09-27] (Malwarebytes)
                      R3 MBAMFarflt; C:\WINDOWS\system32\DRIVERS\farflt.sys [101824 2017-09-28] (Malwarebytes)
                      R3 MBAMProtection; C:\WINDOWS\system32\drivers\mbam.sys [45472 2017-09-28] (Malwarebytes)
                      R3 MBAMSwissArmy; C:\WINDOWS\system32\drivers\MBAMSwissArmy.sys [253888 2017-09-28] (Malwarebytes)
                      R3 MBAMWebProtection; C:\WINDOWS\system32\drivers\mwac.sys [94144 2017-09-28] (Malwarebytes)
                      R3 MEIx64; C:\WINDOWS\system32\DRIVERS\TeeDriverx64.sys [129312 2014-09-30] (Intel Corporation)
                      S0 mfeelamk; C:\WINDOWS\System32\drivers\mfeelamk.sys [80160 2015-02-13] (McAfee, Inc.)
                      R3 nvlddmkm; C:\WINDOWS\System32\DriverStore\FileRepository\nvl twu.inf_amd64_dc8ffafad3ea7ddd\nvlddmkm.sys [14190520 2017-01-17] (NVIDIA Corporation)
                      R0 PxHlpa64; C:\WINDOWS\System32\drivers\PxHlpa64.sys [56336 2013-09-03] (Corel Corporation)
                      R3 rt640x64; C:\WINDOWS\System32\drivers\rt640x64.sys [886528 2015-07-22] (Realtek )
                      R3 RTSUER; C:\WINDOWS\system32\Drivers\RtsUer.sys [410880 2015-07-03] (Realsil Semiconductor Corporation)
                      R3 rtsuvc; C:\WINDOWS\system32\DRIVERS\rtsuvc.sys [3127576 2016-07-13] (Realtek Semiconductor Corp.)
                      S3 SDFRd; C:\WINDOWS\System32\drivers\SDFRd.sys [31128 2017-03-18] ()
                      S3 tapexpressvpn; C:\WINDOWS\System32\drivers\tapexpressvpn.sys [45048 2017-07-06] (The OpenVPN Project)
                      S3 WdBoot; C:\WINDOWS\system32\drivers\WdBoot.sys [44632 2017-03-18] (Microsoft Corporation)
                      S3 WdFilter; C:\WINDOWS\system32\drivers\WdFilter.sys [294816 2017-03-18] (Microsoft Corporation)
                      S3 WdNisDrv; C:\WINDOWS\System32\Drivers\WdNisDrv.sys [121248 2017-03-18] (Microsoft Corporation)
                      R3 WNDA3100v3; C:\WINDOWS\system32\DRIVERS\WNDA3100v3.sys [2222736 2014-12-08] (MediaTek Inc.)
                      R1 ZAM; C:\WINDOWS\System32\drivers\zam64.sys [203680 2017-09-27] (Zemana Ltd.)
                      R1 ZAM_Guard; C:\WINDOWS\System32\drivers\zamguard64.sys [203680 2017-09-27] (Zemana Ltd.)
                      2017-09-28 20:36 - 2017-09-28 20:37 - 000029199 _____ C:\Users\papeter\Desktop\FRST.txt
                      2017-09-28 20:30 - 2017-09-28 20:30 - 002399744 _____ (Farbar) C:\Users\papeter\Desktop\FRST64(1).exe
                      2017-09-28 20:29 - 2017-09-28 20:29 - 000006426 _____ C:\Users\papeter\Desktop\fixlist(1).txt
                      2017-09-28 19:52 - 2017-09-28 19:52 - 000000165 ____H C:\Users\papeter\Desktop~$MY DOMAINS (2) (Autosaved).xlsx
                      2017-09-28 15:53 - 2017-09-28 15:53 - 000006426 _____ C:\Users\papeter\Downloads\fixlist.txt
                      2017-09-28 15:48 - 2017-09-28 15:48 - 000000000 ____D C:\Users\papeter\Downloads\FRST-OlderVersion
                      2017-09-28 15:31 - 2017-09-28 15:31 - 000000000 ____D C:\WINDOWS\LastGood
                      2017-09-28 15:31 - 2017-09-28 15:31 - 000000000 ____D C:\Program Files\Realtek
                      2017-09-28 15:21 - 2017-09-28 15:21 - 000000180 _____ C:\WINDOWS\system32{A6D608F0-0BDE-491A-97AE-5C4B05D86E01}.bat
                      2017-09-28 15:20 - 2017-09-28 15:20 - 000153336 _____ C:\WINDOWS\system32\wpbbin.exe
                      2017-09-28 15:20 - 2017-09-28 15:20 - 000026608 _____ (Lenovo) C:\WINDOWS\system32\LenovoUpdate.exe
                      2017-09-28 15:02 - 2017-09-28 15:15 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Geek Uninstaller
                      2017-09-28 15:01 - 2017-09-28 15:01 - 003000643 _____ C:\Users\papeter\Downloads\geek(1).zip
                      2017-09-28 14:59 - 2017-09-28 14:59 - 003000643 _____ C:\Users\papeter\Downloads\geek.zip
                      2017-09-28 14:54 - 2017-09-28 14:54 - 000515639 _____ (glax24 (safezone.cc)) C:\Users\papeter\Desktop\SecurityCheck.exe
                      2017-09-28 14:54 - 2017-09-28 14:54 - 000000000 ____D C:\SecurityCheck
                      2017-09-27 23:57 - 2017-09-28 00:32 - 000000192 _____ C:\Users\papeter\Documents\ntes for pchelp orum.txt
                      2017-09-27 23:11 - 2017-09-28 15:21 - 000253888 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MBAMSwissArmy.sys
                      2017-09-27 23:11 - 2017-09-28 15:21 - 000101824 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\farflt.sys
                      2017-09-27 23:11 - 2017-09-28 15:21 - 000094144 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mwac.sys
                      2017-09-27 23:11 - 2017-09-28 15:21 - 000045472 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbam.sys
                      2017-09-27 23:11 - 2017-09-27 23:11 - 000192960 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MBAMChameleon.sys
                      2017-09-27 23:11 - 2017-09-27 23:11 - 000001923 _____ C:\Users\Public\Desktop\Malwarebytes.lnk
                      2017-09-27 23:11 - 2017-09-27 23:11 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes
                      2017-09-27 23:11 - 2017-09-27 23:11 - 000000000 ____D C:\ProgramData\Malwarebytes
                      2017-09-27 23:11 - 2017-09-27 23:11 - 000000000 ____D C:\Program Files\Malwarebytes
                      2017-09-27 23:11 - 2017-08-24 11:27 - 000077440 _____ C:\WINDOWS\system32\Drivers\mbae64.sys
                      2017-09-27 23:10 - 2017-09-27 23:10 - 068408664 _____ (Malwarebytes ) C:\Users\papeter\Downloads\mb3-setup-consumer-3.2.2.2029.exe
                      2017-09-27 23:04 - 2017-09-27 23:04 - 000861648 _____ (Malwarebytes) C:\Users\papeter\Downloads\mb-clean-3.1.0.1027(1).exe
                      2017-09-27 22:41 - 2017-09-27 23:05 - 000174335 _____ C:\Users\papeter\Desktop\mb-clean-results.txt
                      2017-09-27 22:41 - 2017-09-27 22:41 - 000861648 _____ (Malwarebytes) C:\Users\papeter\Downloads\mb-clean-3.1.0.1027.exe
                      2017-09-27 21:59 - 2017-09-28 20:36 - 000909753 _____ C:\WINDOWS\ZAM.krnl.trace
                      2017-09-27 21:59 - 2017-09-28 20:36 - 000134395 _____ C:\WINDOWS\ZAM_Guard.krnl.trace
                      2017-09-27 21:59 - 2017-09-27 21:59 - 000203680 _____ (Zemana Ltd.) C:\WINDOWS\system32\Drivers\zamguard64.sys
                      2017-09-27 21:59 - 2017-09-27 21:59 - 000203680 _____ (Zemana Ltd.) C:\WINDOWS\system32\Drivers\zam64.sys
                      2017-09-27 21:59 - 2017-09-27 21:59 - 000001228 _____ C:\Users\Public\Desktop\Zemana AntiMalware.lnk
                      2017-09-27 21:59 - 2017-09-27 21:59 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zemana AntiMalware
                      2017-09-27 21:59 - 2017-09-27 21:59 - 000000000 ____D C:\Program Files (x86)\Zemana AntiMalware
                      2017-09-27 21:58 - 2017-09-27 21:58 - 000000000 ____D C:\Users\papeter\AppData\Local\Zemana
                      2017-09-27 21:57 - 2017-09-27 21:57 - 006625600 _____ (Zemana Ltd. ) C:\Users\papeter\Desktop\Zemana.AntiMalware.Setup. exe
                      2017-09-27 21:32 - 2017-09-27 21:32 - 000000549 _____ C:\Users\papeter\Desktop\JRT.txt
                      2017-09-27 21:28 - 2017-09-27 21:28 - 001790024 _____ (Malwarebytes) C:\Users\papeter\Desktop\JRT(1).exe
                      2017-09-27 21:25 - 2017-09-27 21:26 - 001790024 _____ (Malwarebytes) C:\Users\papeter\Downloads\JRT.exe
                      2017-09-27 12:48 - 2017-09-27 12:49 - 000050760 _____ C:\Users\papeter\Downloads\Addition.txt
                      2017-09-27 12:47 - 2017-09-27 12:49 - 000125034 _____ C:\Users\papeter\Downloads\FRST.txt
                      2017-09-27 00:15 - 2017-09-27 00:15 - 008182736 _____ (Malwarebytes) C:\Users\papeter\Desktop\adwcleaner_7.0.2.1(1).exe
                      2017-09-27 00:07 - 2017-09-27 00:07 - 000000000 ___D C:\Users\papeter\AppData\Local\DBG
                      2017-09-26 23:47 - 2017-09-28 15:37 - 000003392 _____ C:\WINDOWS\System32\Tasks\Kaspersky_Upgrade_Launch er
                      {278ADC42-419D-4547-A6CA-5B74BE0AD901}
                      2017-09-26 23:45 - 2017-09-27 17:27 - 000000000 ____D C:\AdwCleaner
                      2017-09-26 23:45 - 2017-09-26 23:45 - 008182736 _____ (Malwarebytes) C:\Users\papeter\Downloads\adwcleaner_7.0.2.1.exe
                      2017-09-26 23:29 - 2017-09-26 23:29 - 000000000 ____D C:\ProgramData\CanonIJPLM
                      2017-09-26 23:18 - 2017-09-26 23:18 - 000000000 ____D C:\zoek
                      2017-09-26 22:48 - 2017-09-26 23:27 - 000003221 _____ C:\runcheck.txt
                      2017-09-26 22:48 - 2017-09-26 23:20 - 000000000 ____D C:\zoek_backup
                      2017-09-26 22:46 - 2017-09-26 22:46 - 001309184 _____ C:\Users\papeter\Downloads\zoek.exe
                      2017-09-26 18:01 - 2017-09-28 20:36 - 000000000 ____D C:\FRST
                      2017-09-26 17:55 - 2017-09-28 15:48 - 002399744 _____ (Farbar) C:\Users\papeter\Downloads\FRST64.exe
                      2017-09-26 01:11 - 2017-09-26 01:11 - 000001268 _____ C:\Users\papeter\Desktop\malwarebytes screenshot.docx - Shortcut.lnk
                      2017-09-26 00:28 - 2017-09-26 00:28 - 002000384 _____ C:\Users\papeter\Documents\malwarebutes.pub
                      2017-09-25 22:09 - 2017-09-25 22:09 - 008604592 _____ (Yousician ) C:\Users\papeter\Downloads\YousicianSetup.exe
                      2017-09-25 18:07 - 2017-09-25 18:15 - 001396224 _____ C:\Users\papeter\Documents\John Crestani Video 1 summary.pub
                      2017-09-24 23:26 - 2017-09-24 23:26 - 000000035 _____ C:\Users\papeter\Documents\E-X-P-V-P-N.txt
                      2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\Users\papeter\AppData\Local\ExpressVPN
                      2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ExpressVPN
                      2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\ProgramData\ExpressVPN
                      2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\Program Files (x86)\ExpressVPN
                      2017-09-24 23:10 - 2017-09-24 23:10 - 018904768 _____ (ExpressVPN) C:\Users\papeter\Downloads\expressvpn_6.2.3.2578.e xe
                      2017-09-22 23:31 - 2017-09-22 23:31 - 000000138 _____ C:\Users\papeter\Documents\PayPal question.txt
                      2017-09-22 13:02 - 2017-09-22 13:02 - 000000507 _____ C:\Users\papeter\Documents\super juice.txt
                      2017-09-21 21:45 - 2017-09-21 21:45 - 000000000 ____D C:\Windows.old
                      2017-09-21 21:43 - 2017-09-21 21:43 - 023684608 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 023679488 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 021352656 _____ (Microsoft Corporation) C:\WINDOWS\system32\shell32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 020509184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 020373408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shell32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 019336192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 013844480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 012801536 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 011887104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 008319904 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 008213504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mstscax.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 008207872 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 007931392 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 007907344 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Protection.PlayR eady.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 006728704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 006557520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 006265856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005961728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005821496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005808640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005721600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BingMaps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005557760 _____ (Microsoft Corporation) C:\WINDOWS\system32\dbgeng.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005225984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d2d1.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004848960 _____ (Microsoft Corporation) C:\WINDOWS\explorer.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004730368 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004708504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfcore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004707840 _____ (Microsoft Corporation) C:\WINDOWS\system32\ExplorerFrame.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004671832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfcore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004535296 _____ (Microsoft Corporation) C:\WINDOWS\system32\MFMediaEngine.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004462120 _____ (Microsoft Corporation) C:\WINDOWS\system32\setupapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004445696 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_nt.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004417024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ExplorerFrame.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004330920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\setupapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004175872 _____ (Microsoft Corporation) C:\WINDOWS\system32\StartTileData.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004056064 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFMediaEngine.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003995136 _____ (Microsoft Corporation) C:\WINDOWS\system32\UIRibbon.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003667456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_47.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003654656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003464704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UIRibbon.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003307008 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininet.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003059200 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkMobileSettings.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002859520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wininet.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002805248 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002765824 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Shell.UnifiedTile.Cura tedTileCollections.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002675104 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tcpip.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002671616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tquery.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002647224 _____ (Microsoft Corporation) C:\WINDOWS\system32\iertutil.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002604248 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfmp4srcsnk.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002516480 _____ (Microsoft Corporation) C:\WINDOWS\system32\diagtrack.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002503680 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.pcshell.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002476712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d10warp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002445824 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002424024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfmp4srcsnk.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002399728 _____ (Microsoft Corporation) C:\WINDOWS\system32\KernelBase.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002327456 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ntfs.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002199552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Resources.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002177024 _____ (Microsoft Corporation) C:\WINDOWS\system32\OpcServices.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002166808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iertutil.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002078720 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetcpl.cpl
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002009600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\inetcpl.cpl
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002006528 _____ (Microsoft Corporation) C:\WINDOWS\system32\LocationFramework.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001930840 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntdll.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001886208 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.oneco re.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001833984 _____ (Microsoft Corporation) C:\WINDOWS\system32\workfolderssvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001802752 _____ (Microsoft Corporation) C:\WINDOWS\system32\urlmon.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001736704 _____ (Microsoft Corporation) C:\WINDOWS\system32\wevtsvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001722880 _____ (Microsoft Corporation) C:\WINDOWS\system32\dui70.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001706496 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Immersive.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001657344 _____ (Microsoft Corporation) C:\WINDOWS\system32\XpsPrint.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001639936 _____ (Microsoft Corporation) C:\WINDOWS\system32\GdiPlus.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001627136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\urlmon.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001620880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntdll.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001619816 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppobjs.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001596592 _____ (Microsoft Corporation) C:\WINDOWS\system32\gdi32full.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001583616 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieapfltr.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001536512 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Immersive.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001525760 _____ (Microsoft Corporation) C:\WINDOWS\system32\RecoveryDrive.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001468416 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.deskt op.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001463296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieapfltr.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001397760 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwansvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001357312 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiosrv.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001337856 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEng.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001325968 _____ (Microsoft Corporation) C:\WINDOWS\system32\ole32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001320344 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpx.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001305088 _____ (Microsoft Corporation) C:\WINDOWS\system32\dosvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001298432 _____ (Microsoft Corporation) C:\WINDOWS\system32\lpasvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001291776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVPXENC.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001275904 _____ (Microsoft Corporation) C:\WINDOWS\system32\werconcpl.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001269760 _____ (Microsoft Corporation) C:\WINDOWS\system32\enterprisecsps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001260544 _____ (Microsoft Corporation) C:\WINDOWS\system32\GamePanel.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001248768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AzureSettingSyncProvider.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001242528 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ndis.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001178624 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.Vpn.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001146176 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfds.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001143296 _____ (Microsoft Corporation) C:\WINDOWS\system32\localspl.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001114528 _____ (Microsoft Corporation) C:\WINDOWS\system32\ReAgent.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001106904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfds.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001087488 _____ (Microsoft Corporation) C:\WINDOWS\system32\reseteng.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001068720 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001060352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XpsPrint.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001054280 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioSes.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001051136 _____ (Microsoft Corporation) C:\WINDOWS\system32\nettrace.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001046016 _____ (Microsoft Corporation) C:\WINDOWS\system32\comdlg32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001033544 _____ (Microsoft Corporation) C:\WINDOWS\system32\DolbyDecMFT.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001019904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aadtb.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001013912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msvproc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000996864 _____ (Microsoft Corporation) C:\WINDOWS\system32\iphlpsvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000988168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ole32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000986624 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000972288 _____ (Microsoft Corporation) C:\WINDOWS\system32\MPSSVC.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000971264 _____ (Microsoft Corporation) C:\WINDOWS\system32\autochk.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000967584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ReAgent.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000961952 _____ (Microsoft Corporation) C:\WINDOWS\system32\efscore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000958664 _____ (Microsoft Corporation) C:\WINDOWS\system32\msvproc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000954368 _____ (Microsoft Corporation) C:\WINDOWS\system32\autoconv.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000952832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\comdlg32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000946688 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasgcw.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000932352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GamePanel.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000926208 _____ (Microsoft Corporation) C:\WINDOWS\system32\autofmt.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000925696 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpcWebFilter.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000923040 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreMessaging.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000921600 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasdlg.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000918528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Networking.Vpn.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000899584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.appcore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000877056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\autoconv.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000874496 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasmans.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000866808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DolbyDecMFT.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000864256 _____ (Microsoft Corporation) C:\WINDOWS\system32\NotificationController.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000853504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\autofmt.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000852480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasgcw.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000847360 _____ (Microsoft Corporation) C:\WINDOWS\system32\bisrv.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000844288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasdlg.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000832000 _____ (Microsoft Corporation) C:\WINDOWS\system32\printfilterpipelinesvc.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000827904 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32spl.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000820128 _____ (Microsoft Corporation) C:\WINDOWS\system32\WWAHost.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000810496 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasapi32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000805888 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieproxy.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000803328 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmsvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000778240 _____ C:\WINDOWS\system32\MBR2GPT.EXE
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000778240 _____ (Microsoft Corporation) C:\WINDOWS\system32\DolbyHrtfEnc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000773120 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneService.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000772096 _____ (Microsoft Corporation) C:\WINDOWS\system32\PCPKsp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000761344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasapi32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000757760 _____ (Microsoft Corporation) C:\WINDOWS\system32\spoolsv.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000752640 _____ (Microsoft Corporation) C:\WINDOWS\system32\msfeeds.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000750560 _____ (Microsoft Corporation) C:\WINDOWS\system32\fontdrvhost.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000750496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WWAHost.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000742912 _____ (Microsoft Corporation) C:\WINDOWS\system32\nshwfp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000739840 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneProviders.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000724200 _____ (Microsoft Corporation) C:\WINDOWS\system32\wer.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000715168 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fvevol.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000706560 _____ (Microsoft Corporation) C:\WINDOWS\system32\winlogon.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000699904 _____ (Microsoft Corporation) C:\WINDOWS\system32\FlightSettings.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000692736 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9diag.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000687616 _____ (Microsoft Corporation) C:\WINDOWS\system32\LogonController.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000685512 _____ (Microsoft Corporation) C:\WINDOWS\system32\SHCore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000664576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msfeeds.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000636416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WpcWebFilter.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000625152 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEndpointBuilder.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000612864 _____ (Microsoft Corporation) C:\WINDOWS\system32\shsvcs.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000610720 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\afd.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000600576 _____ (Microsoft Corporation) C:\WINDOWS\system32\FrameServer.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000593408 _____ (Microsoft Corporation) C:\WINDOWS\system32\BootMenuUX.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000586240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\nshwfp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000584192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UIRibbonRes.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000584192 _____ (Microsoft Corporation) C:\WINDOWS\system32\UIRibbonRes.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000582656 _____ (Microsoft Corporation) C:\WINDOWS\system32\SmsRouterSvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000579072 _____ (Microsoft Corporation) C:\WINDOWS\system32\untfs.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000574464 _____ (Microsoft Corporation) C:\WINDOWS\system32\configmanager2.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000569264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SHCore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000566784 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.UX.EapReque stHandler.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000564224 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shsvcs.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000551200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxgi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000546816 _____ (Microsoft Corporation) C:\WINDOWS\system32\winspool.drv
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000536064 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Management.dl l
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000527976 _____ (Microsoft Corporation) C:\WINDOWS\system32\services.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000527872 _____ (Microsoft Corporation) C:\WINDOWS\system32\daxexec.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000524800 _____ (Microsoft Corporation) C:\WINDOWS\system32\TileDataRepository.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000519584 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netio.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000500224 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Shell.BlueLightReducti on.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000499712 _____ (Microsoft Corporation) C:\WINDOWS\system32\nltest.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000497152 _____ (Microsoft Corporation) C:\WINDOWS\system32\rastls.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000491520 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Display.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000482816 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmenrollengine.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000477696 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasplap.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000473240 _____ (Microsoft Corporation) C:\WINDOWS\system32\policymanager.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000463360 _____ (Microsoft Corporation) C:\WINDOWS\system32\werui.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000457728 _____ (Microsoft Corporation) C:\WINDOWS\system32\webplatstorageserver.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000455584 _____ (Microsoft Corporation) C:\WINDOWS\system32\hal.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000452608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasplap.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000450048 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcdedit.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000446464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rastls.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000440320 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.immersiveshell.service provider.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000433664 _____ (Microsoft Corporation) C:\WINDOWS\system32\msIso.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000430592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winspool.drv
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000420864 _____ (Microsoft Corporation) C:\WINDOWS\system32\facecredentialprovider.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000417792 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallAgentUserBroker.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000410168 _____ (Microsoft Corporation) C:\WINDOWS\system32\Faultrep.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000407040 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhext.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000406544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\policymanager.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000397312 _____ (Microsoft Corporation) C:\WINDOWS\system32\rascustom.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000394240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Internal.Management.dl l
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000388096 _____ (Microsoft Corporation) C:\WINDOWS\system32\iedkcs32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000387936 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmpps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000383488 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallAgent.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000382368 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\clfs.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000381824 _____ (Microsoft Corporation) C:\WINDOWS\system32\wevtapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000370688 _____ (Microsoft Corporation) C:\WINDOWS\system32\rastlsext.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000370176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\daxexec.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000368128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallAgentUserBroker.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000365056 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Notifications .dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000364032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msIso.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000358400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieproxy.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000357888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ActivationManager.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000353280 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntprint.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000339968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iedkcs32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000337920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallAgent.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000331264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rastlsext.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000329728 _____ (Microsoft Corporation) C:\WINDOWS\system32\RasMediaManager.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000327168 _____ (Microsoft Corporation) C:\WINDOWS\system32\WinBioDataModel.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000323936 _____ (Microsoft Corporation) C:\WINDOWS\system32\shlwapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000323584 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceEnroller.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000316320 _____ (Microsoft Corporation) C:\WINDOWS\system32\WerFault.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000312320 _____ (Microsoft Corporation) C:\WINDOWS\system32\Phoneutil.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000311296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntprint.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000305152 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netbt.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000290816 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmenterprisediagnostics.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000277432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shlwapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000274944 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxtrans.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000268288 _____ (Microsoft Corporation) C:\WINDOWS\system32\wisp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000266240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxtrans.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000259072 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Flights.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000257440 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxAllUserStore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000257024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Phoneutil.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000257024 _____ (Microsoft Corporation) C:\WINDOWS\system32\webcheck.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000255488 _____ (Microsoft Corporation) C:\WINDOWS\system32\scksp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000254976 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\srvnet.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000254176 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000249344 _____ (Microsoft Corporation) C:\WINDOWS\system32\coredpus.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000243712 _____ (Microsoft Corporation) C:\WINDOWS\system32\shdocvw.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000232960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webcheck.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000231936 _____ (Microsoft Corporation) C:\WINDOWS\system32\DolbyMATEnc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000229888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\scksp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000229888 _____ (Microsoft Corporation) C:\WINDOWS\system32\SIHClient.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000228256 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb20.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000225792 _____ (Microsoft Corporation) C:\WINDOWS\system32\ie4uinit.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000223744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shdocvw.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000213504 _____ (Microsoft Corporation) C:\WINDOWS\system32\dinput8.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000212384 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserbroker.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000209408 _____ (Microsoft Corporation) C:\WINDOWS\system32\psmsrv.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000204192 _____ (Microsoft Corporation) C:\WINDOWS\system32\basecsp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000201728 _____ (Microsoft Corporation) C:\WINDOWS\system32\RstrtMgr.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000197120 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcdboot.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000194048 _____ (Microsoft Corporation) C:\WINDOWS\system32\mdmregistration.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000192264 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsensorgroup.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000184832 _____ (Microsoft Corporation) C:\WINDOWS\system32\VCardParser.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000184320 _____ (Microsoft Corporation) C:\WINDOWS\system32\DWWIN.EXE
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000182688 _____ (Microsoft Corporation) C:\WINDOWS\system32\wermgr.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000182272 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcrecovery.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000176640 _____ (Microsoft Corporation) C:\WINDOWS\system32\wersvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000176024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\basecsp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000175616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\RstrtMgr.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000175104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dinput8.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000173568 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetpp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000165888 _____ (Microsoft Corporation) C:\WINDOWS\system32\storewuauth.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000160768 _____ (Microsoft Corporation) C:\WINDOWS\system32\dinput.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000159648 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\partmgr.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000156160 _____ (Microsoft Corporation) C:\WINDOWS\system32\csplte.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000153088 _____ (Microsoft Corporation) C:\WINDOWS\system32\fdeploy.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000150528 _____ (Microsoft Corporation) C:\WINDOWS\system32\qasf.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000147456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\VCardParser.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000143872 _____ (Microsoft Corporation) C:\WINDOWS\system32\profsvcext.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000143736 _____ (Microsoft Corporation) C:\WINDOWS\system32\WerFaultSecure.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000142848 _____ (Microsoft Corporation) C:\WINDOWS\system32\srpapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000142848 _____ (Microsoft Corporation) C:\WINDOWS\system32\dwmredir.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000140800 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmcsps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000140288 _____ (Microsoft Corporation) C:\WINDOWS\system32\iepeers.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000138752 _____ (Microsoft Corporation) C:\WINDOWS\system32\appinfo.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000136096 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ksecdd.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000135680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\qasf.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000134656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dinput.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000133632 _____ (Microsoft Corporation) C:\WINDOWS\system32\CfgSPCellular.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000131584 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseAPNCsp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000130560 _____ (Microsoft Corporation) C:\WINDOWS\system32\policymanagerprecheck.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000128512 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasman.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000127488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fdeploy.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000124928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iepeers.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000124928 _____ (Microsoft Corporation) C:\WINDOWS\system32\httpprxm.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000119904 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmcmnutils.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000119712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tdx.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000116280 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcd.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000115712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bridge.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000113152 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhosdeployment.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000112640 _____ (Microsoft Corporation) C:\WINDOWS\system32\MDMAppInstaller.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000110592 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000109056 _____ (Microsoft Corporation) C:\WINDOWS\system32\dab.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000105472 _____ (Microsoft Corporation) C:\WINDOWS\system32\RjvMDMConfig.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000104432 _____ (Microsoft Corporation) C:\WINDOWS\system32\msacm32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000102912 _____ (Microsoft Corporation) C:\WINDOWS\system32\officecsp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000100352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasman.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000100232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcd.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000096648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dmcmnutils.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000096256 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtmled.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000095232 _____ (Microsoft Corporation) C:\WINDOWS\system32\wudriver.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000093696 _____ (Microsoft Corporation) C:\WINDOWS\system32\spbcd.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000093184 _____ (Microsoft Corporation) C:\WINDOWS\system32\wercplsupport.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000090112 _____ (Microsoft Corporation) C:\WINDOWS\system32\ofdeploy.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000089088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\olepro32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000089088 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsrvext.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000085784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CredentialUIBroker.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000084992 _____ (Microsoft Corporation) C:\WINDOWS\system32\MshtmlDac.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000080896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakradiag.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000080384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtmled.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000078848 _____ (Microsoft Corporation) C:\WINDOWS\system32\setbcdlocale.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000077824 _____ (Microsoft Corporation) C:\WINDOWS\system32\wsqmcons.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000077312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\spbcd.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000074240 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseDesktopAppMgmtCSP.dl l
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000064680 _____ (Microsoft Corporation) C:\WINDOWS\system32\appidapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000064512 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsrv.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MshtmlDac.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\system32\wups.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntprint.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000062464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntprint.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000061952 _____ (Microsoft Corporation) C:\WINDOWS\system32\vss_ps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000059392 _____ (Microsoft Corporation) C:\WINDOWS\system32\DmApiSetExtImplDesktop.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000057856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\offreg.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000056832 _____ (Microsoft Corporation) C:\WINDOWS\system32\cldapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000052768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\appidapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000044032 _____ (Microsoft Corporation) C:\WINDOWS\system32\cmintegrator.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000043520 _____ (Microsoft Corporation) C:\WINDOWS\system32\TpmTasks.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000043520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\nsiproxy.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000029696 _____ (Microsoft Corporation) C:\WINDOWS\system32\odbcconf.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000029184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cmintegrator.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000022528 _____ (Microsoft Corporation) C:\WINDOWS\system32\IpNatHlpClient.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000022016 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpnpinst.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000018432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\IpNatHlpClient.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 017371136 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 008333312 _____ (Microsoft Corporation) C:\WINDOWS\system32\BingMaps.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 007598080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mstscax.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 007337472 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Data.Pdf.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 007326128 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 006761560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayR eady.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 005477096 _____ (Microsoft Corporation) C:\WINDOWS\system32\OneCoreUAPCommonProxyStub.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 005302968 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepository.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 004559360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dbgeng.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 004471888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\explorer.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 004396032 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_47.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 004213656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepository.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 003668992 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 003377664 _____ (Microsoft Corporation) C:\WINDOWS\system32\tquery.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 003204608 _____ (Microsoft Corporation) C:\WINDOWS\system32\Microsoft.Bluetooth.Profiles.G att.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 003116184 _____ (Microsoft Corporation) C:\WINDOWS\system32\combase.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002972552 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d10warp.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002969880 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreUIComponents.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002953216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32kfull.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002939392 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputService.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002680320 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.CloudStore.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002443168 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002330520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\combase.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002259760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreUIComponents.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002211840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputService.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002199552 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.Resources.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002153984 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlidsvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002055680 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001878016 _____ (Microsoft Corporation) C:\WINDOWS\system32\AzureSettingSyncProvider.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001839872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\KernelBase.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001668344 _____ (Microsoft Corporation) C:\WINDOWS\system32\propsys.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001460224 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsasrv.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001448960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GdiPlus.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001409048 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gdi32full.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001355264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\OpcServices.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001346112 _____ (Microsoft Corporation) C:\WINDOWS\system32\user32.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001311744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjet40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001293824 _____ (Microsoft Corporation) C:\WINDOWS\system32\aadtb.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001292880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\user32.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001195760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioEng.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001147296 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvix64.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001085440 _____ (Microsoft Corporation) C:\WINDOWS\system32\rpcss.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001077248 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.appcore.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001057824 _____ (Microsoft Corporation) C:\WINDOWS\system32\MrmCoreR.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001052160 _____ (Microsoft Corporation) C:\WINDOWS\system32\TokenBroker.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001046016 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcsvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001028608 _____ (Microsoft Corporation) C:\WINDOWS\system32\modernexecserver.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001024928 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvax64.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001015296 _____ (Microsoft Corporation) C:\WINDOWS\system32\XblAuthManager.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000982016 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthport.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000942592 _____ (Microsoft Corporation) C:\WINDOWS\system32\wbiosrvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000922112 _____ (Microsoft Corporation) C:\WINDOWS\system32\kerberos.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000892928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\autochk.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000872472 _____ (Microsoft Corporation) C:\WINDOWS\system32\ClipSVC.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000871448 _____ (Microsoft Corporation) C:\WINDOWS\system32\winhttp.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000866816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mswdat10.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000864248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioSes.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000821664 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000817664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Security.Authenticatio n.Web.Core.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000805816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000798208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TokenBroker.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000787456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wuapi.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000772096 _____ (Microsoft Corporation) C:\WINDOWS\system32\netlogon.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000754176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\kerberos.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000723360 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\acpi.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000712600 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000703056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winhttp.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000691712 _____ (Microsoft Corporation) C:\WINDOWS\system32\tdh.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000660680 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxgi.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000657408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netlogon.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000654976 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentClient.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000641536 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mswstr10.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000640512 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngccredprov.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000627080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fontdrvhost.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000616448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrepl40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000611096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wer.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000590336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PCPKsp.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000586752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Security.Authenticatio n.Web.Core.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000586240 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppReadiness.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000583160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreMessaging.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000564736 _____ (Microsoft Corporation) C:\WINDOWS\system32\dsreg.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000563200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tdh.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000556032 _____ (Microsoft Corporation) C:\WINDOWS\system32\TpmCoreProvisioning.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000554400 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\USBHUB3.SYS
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000546208 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\storport.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000538112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\untfs.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000529992 _____ (Microsoft Corporation) C:\WINDOWS\system32\TextInputFramework.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000527360 _____ (Microsoft Corporation) C:\WINDOWS\system32\aadcloudap.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000524288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ngccredprov.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000519680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000518144 _____ C:\WINDOWS\SysWOW64\msjetoledb40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000491520 _____ (Microsoft Corporation) C:\WINDOWS\system32\NgcCtnrSvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000476160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dsreg.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000475648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxbde40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000471040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TpmCoreProvisioning.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000458752 _____ (Microsoft Corporation) C:\WINDOWS\system32\NgcCtnr.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000447488 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32k.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000431616 _____ (Microsoft Corporation) C:\WINDOWS\system32\BthHFSrv.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000422400 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpAXHolder.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000414296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TextInputFramework.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000413184 _____ (Microsoft Corporation) C:\WINDOWS\system32\profsvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000412160 _____ (Microsoft Corporation) C:\WINDOWS\system32\ActivationManager.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000411040 _____ (Microsoft Corporation) C:\WINDOWS\system32\msv1_0.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000408576 _____ (Microsoft Corporation) C:\WINDOWS\system32\cryptngc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000404480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\werui.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000385536 _____ (Microsoft Corporation) C:\WINDOWS\system32\tpmvsc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000375808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mspbde40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000359560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Faultrep.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000349600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msv1_0.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000343552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrd3x40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000339968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msexcl40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000334336 _____ (Microsoft Corporation) C:\WINDOWS\system32\wc_storage.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000318232 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininit.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000315904 _____ (Microsoft Corporation) C:\WINDOWS\system32\ncryptprov.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000310272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrd2x40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000307712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cryptngc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000303104 _____ (Microsoft Corporation) C:\WINDOWS\system32\srvsvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000293376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32k.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000291904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wevtapi.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000290816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjtes40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000287648 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\sdbus.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000282112 _____ (Microsoft Corporation) C:\WINDOWS\system32\dnsrslvr.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000280480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WerFault.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000279968 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\msiscsi.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000274432 _____ (Microsoft Corporation) C:\WINDOWS\system32\authz.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000272896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mstext40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000267264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ncryptprov.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000240640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msltus40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000221696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wisp.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000189440 _____ (Microsoft Corporation) C:\WINDOWS\system32\BluetoothApis.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000189344 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dumpsd.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000182688 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppxAllUserStore.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000181760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\authz.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000180736 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\rfcomm.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000173104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsensorgroup.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000169376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wermgr.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000154624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DWWIN.EXE
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000144896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjint40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000139776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BluetoothApis.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000136192 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryUpgrade .dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000133904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WerFaultSecure.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000130560 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthpan.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000128000 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssprxy.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000123904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\srpapi.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000117760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryUpgrade .dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000115792 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32u.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000107008 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcpopkeysrv.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000107008 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hidbth.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000105472 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthenum.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000104960 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\UcmCx.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000097792 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthhfenum.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000097280 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\Microsoft.Bluetooth.Le gacy.LEEnumerator.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000094624 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpudd.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000090464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msacm32.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000090112 _____ (Microsoft Corporation) C:\WINDOWS\system32\datamarketsvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000083968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjter40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000083968 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbkmclr.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000082336 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbkmcl.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000081176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32u.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000079872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wudriver.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000078848 _____ (Microsoft Corporation) C:\WINDOWS\system32\offreg.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000071680 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\usbser.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000051712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\UcmUcsi.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000050176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cldapi.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000049720 _____ (Microsoft Corporation) C:\WINDOWS\system32\tbs.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000046592 _____ (Microsoft Corporation) C:\WINDOWS\system32\sscore.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000042496 _____ (Microsoft Corporation) C:\WINDOWS\system32\tokenbinding.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000042456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tbs.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000039424 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\buttonconverter.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000037376 _____ (Microsoft Corporation) C:\WINDOWS\system32\SEMgrPS.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000035840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sscore.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000034816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tokenbinding.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000031932 _____ C:\WINDOWS\system32\edgehtmlpluginpolicy.bin
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000025088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\odbcconf.dll
                      2017-09-21 21:32 - 2017-09-21 21:32 - 000008192 _____ C:\WINDOWS\system32\config\userdiff
                      2017-09-21 21:32 - 2017-09-21 12:50 - 000000000 ____D C:\WINDOWS\ServiceProfiles
                      2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files\Reference Assemblies
                      2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files\MSBuild
                      2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files (x86)\Reference Assemblies
                      2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files (x86)\MSBuild
                      2017-09-21 21:28 - 2017-02-10 20:26 - 001166520 _____ (Microsoft Corporation) C:\WINDOWS\system32\PresentationNative_v0300.dll
                      2017-09-21 21:28 - 2017-02-10 20:26 - 000124624 _____ (Microsoft Corporation) C:\WINDOWS\system32\PresentationCFFRasterizerNativ e_v0300.dll
                      2017-09-21 21:28 - 2017-02-10 20:26 - 000035480 _____ (Microsoft Corporation) C:\WINDOWS\system32\TsWpfWrp.exe
                      2017-09-21 21:28 - 2017-02-10 20:21 - 000778936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PresentationNative_v0300.dll
                      2017-09-21 21:28 - 2017-02-10 20:21 - 000103120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PresentationCFFRasterizerNativ e_v0300.dll
                      2017-09-21 21:28 - 2017-02-10 20:21 - 000035480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TsWpfWrp.exe
                      2017-09-21 18:18 - 2017-09-21 18:18 - 000000051 _____ C:\Users\papeter\Documents\talktalk call centres.txt
                      2017-09-21 14:09 - 2017-09-21 14:09 - 000003366 _____ C:\WINDOWS\System32\Tasks\OneDrive Standalone Update Task-S-1-5-21-4237603079-860989819-990887440-1001
                      2017-09-21 14:06 - 2017-09-21 14:06 - 000000000 ____D C:\ProgramData\Microsoft OneDrive
                      2017-09-21 14:03 - 2017-09-21 14:03 - 000000020 ___SH C:\Users\papeter\ntuser.ini
                      2017-09-21 13:33 - 2017-09-21 13:40 - 000007623 _____ C:\WINDOWS\diagwrn.xml
                      2017-09-21 13:33 - 2017-09-21 13:40 - 000007623 _____ C:\WINDOWS\diagerr.xml
                      2017-09-21 13:20 - 2017-09-28 20:07 - 000004156 _____ C:\WINDOWS\System32\Tasks\User_Feed_Synchronizatio n-{0F46EB48-50E2-4372-B3E0-FDD9244C8B47}
                      2017-09-21 13:20 - 2017-09-28 15:20 - 000000006 ____H C:\WINDOWS\Tasks\SA.DAT
                      2017-09-21 13:20 - 2017-09-27 11:55 - 000004250 _____ C:\WINDOWS\System32\Tasks\HMA! Pro VPN Update
                      2017-09-21 13:20 - 2017-09-21 13:21 - 000003344 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineU A
                      2017-09-21 13:20 - 2017-09-21 13:21 - 000003338 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core
                      2017-09-21 13:20 - 2017-09-21 13:21 - 000002936 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-4237603079-860989819-990887440-1001
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000003606 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000003482 _____ C:\WINDOWS\System32\Tasks\Adobe Acrobat Update Task
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000003280 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core1d257e734ba2eb7
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000003120 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineC ore
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000003042 _____ C:\WINDOWS\System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000002762 _____ C:\WINDOWS\System32\Tasks\AdobeAAMUpdater-1.0-Lenovo-PC-papeter
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000002680 _____ C:\WINDOWS\System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000002256 _____ C:\WINDOWS\System32\Tasks\PDVDServ Task
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000002216 _____ C:\WINDOWS\System32\Tasks\CCleanerSkipUAC
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000000000 ____D C:\WINDOWS\System32\Tasks\WPD
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000000000 ____D C:\WINDOWS\System32\Tasks\Apple
                      2017-09-21 13:20 - 2014-08-23 22:38 - 000003596 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-3320520227-2896305394-2021013739-500
                      2017-09-21 13:20 - 2014-04-03 19:35 - 000003594 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-1050727674-2070356693-977449066-500
                      2017-09-21 13:17 - 2017-09-28 15:26 - 001024758 _____ C:\WINDOWS\system32\PerfStringBackup.INI
                      2017-09-21 13:06 - 2017-09-21 13:06 - 000001576 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Media Player.lnk
                      2017-09-21 13:01 - 2017-09-21 13:01 - 000000000 ____D C:\ProgramData\USOShared
                      2017-09-21 13:00 - 2017-09-21 13:09 - 000000000 ____D C:\WINDOWS\system32\config\bbimigrate
                      2017-09-21 12:56 - 2017-09-28 15:20 - 000000000 ____D C:\Users\papeter
                      2017-09-21 12:55 - 2017-09-21 12:55 - 000000000 ____D C:\WINDOWS\SysWOW64\sda
                      2017-09-21 12:54 - 2017-09-21 13:01 - 000000000 ____D C:\ProgramData\NVIDIA Corporation
                      2017-09-21 12:54 - 2017-09-21 13:00 - 000000000 ____D C:\Program Files\NVIDIA Corporation
                      2017-09-21 12:54 - 2017-09-21 13:00 - 000000000 ____D C:\Program Files\Intel
                      2017-09-21 12:54 - 2017-09-21 12:55 - 000000000 ____D C:\Program Files\Elantech
                      2017-09-21 12:54 - 2017-09-21 12:54 - 000000000 _____ C:\WINDOWS\system32\GfxValDisplayLog.bin
                      2017-09-21 12:54 - 2017-05-26 05:12 - 000103888 _____ (Khronos Group) C:\WINDOWS\SysWOW64\OpenCL.DLL
                      2017-09-21 12:54 - 2017-05-26 05:12 - 000099792 _____ (Khronos Group) C:\WINDOWS\system32\OpenCL.DLL
                      2017-09-21 12:54 - 2016-12-29 14:16 - 006384576 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcpl.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 002475968 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvc64.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 001762752 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvcr.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000546752 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshext.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000392128 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvmctray.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000147000 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\oemdspif.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000083512 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshextr.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000069568 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvshext.dll
                      2017-09-21 12:54 - 2016-12-22 00:59 - 007651057 _____ C:\WINDOWS\system32\nvcoproc.bin
                      2017-09-21 12:53 - 2017-09-21 13:00 - 000000000 ____D C:\ProgramData\Conexant
                      2017-09-21 12:53 - 2017-09-21 13:00 - 000000000 ____D C:\Program Files\CONEXANT
                      2017-09-21 12:53 - 2017-09-21 12:53 - 000000000 ____H C:\WINDOWS\system32\Drivers\Msft_Kernel_TeeDriverx 64_01011.Wdf
                      2017-09-21 12:53 - 2017-09-21 12:53 - 000000000 ____H C:\ProgramData\DP45977C.lfl
                      2017-09-21 12:53 - 2017-03-18 21:56 - 002233344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PrintConfig.dll
                      2017-09-21 12:50 - 2017-09-28 19:26 - 000000000 ____D C:\WINDOWS\system32\SleepStudy
                      2017-09-21 12:50 - 2017-09-22 18:01 - 000418080 _____ C:\WINDOWS\system32\FNTCACHE.DAT
                      2017-09-21 12:49 - 2017-09-28 15:20 - 000111088 _____ (Lenovo (Beijing) Limited) C:\WINDOWS\system32\LenovoCheck.exe
                      2017-09-20 22:04 - 2017-09-21 18:11 - 000000000 ___DC C:\WINDOWS\Panther
                      2017-09-19 23:56 - 2017-09-19 23:56 - 000743936 _____ C:\Users\papeter\Documents\JOHN CRETANI AFFIL ON YTUBE.pub
                      2017-09-19 16:20 - 2017-09-19 16:20 - 000014374 _____ C:\Users\papeter\Downloads\Keyword Planner 2017-09-19 at 16_20_29.csv
                      2017-09-19 14:20 - 2017-09-19 14:20 - 000059555 _____ C:\Users\papeter\Downloads\estibot-export(64).csv
                      2017-09-19 00:56 - 2017-09-19 00:56 - 001182208 _____ C:\Users\papeter\Documents\Jared Polin.pub
                      2017-09-19 00:13 - 2017-09-19 00:13 - 000000000 ____D C:\Users\papeter\Desktop\JohnCVideos
                      2017-09-18 21:04 - 2017-09-18 21:26 - 000000293 _____ C:\Users\papeter\Documents\SUPERFOODS.txt
                      2017-09-18 17:15 - 2017-09-18 17:50 - 631061270 _____ C:\Users\papeter\Desktop\Mike&Brett.avi
                      2017-09-18 14:53 - 2017-09-18 22:16 - 000595456 _____ C:\Users\papeter\Documents\AIDA JC.pub
                      2017-09-18 14:24 - 2017-09-18 22:14 - 000000457 _____ C:\Users\papeter\Documents\JOHN CRESTANI USEFUL RESOURCES.txt
                      2017-09-18 14:21 - 2017-09-18 14:21 - 004773823 _____ C:\Users\papeter\Desktop\2015-BTF-Guide-to-Everything.pdf
                      2017-09-14 23:42 - 2017-09-14 23:42 - 001230204 _____ C:\Users\papeter\Downloads\5 Steps to a 7 Figure E-commerce Business(1).pdf
                      2017-09-14 23:41 - 2017-09-14 23:41 - 001230204 _____ C:\Users\papeter\Downloads\5 Steps to a 7 Figure E-commerce Business.pdf
                      2017-09-13 20:29 - 2017-09-13 20:29 - 009943296 _____ C:\Users\papeter\Desktop\Passion Blog Pro Starter Guide PDF.pdf
                      2017-09-13 20:17 - 2017-09-13 20:17 - 000000105 _____ C:\Users\papeter\Documents\Gilles address in France.txt
                      2017-09-13 20:09 - 2017-09-13 20:09 - 000373248 _____ C:\Users\papeter\Documents\ebay client address.pub
                      2017-09-12 21:39 - 2017-09-12 21:39 - 000922279 _____ C:\Users\papeter\Downloads\fb_linkpost3(2).zip
                      2017-09-12 21:38 - 2017-09-12 21:39 - 000922279 _____ C:\Users\papeter\Downloads\fb_linkpost3(1).zip
                      2017-09-12 21:27 - 2017-09-12 21:27 - 000003136 _____ C:\Users\papeter\Downloads\Special Traffic Training.ics
                      2017-09-12 10:47 - 2017-09-12 10:47 - 000922279 _____ C:\Users\papeter\Downloads\fb_linkpost3.zip
                      2017-09-12 10:47 - 2017-09-12 10:47 - 000000000 ____D C:\Users\papeter\Downloads\fb_linkpost3
                      2017-09-11 08:30 - 2017-09-21 10:11 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\754C0DB7.sys
                      2017-09-10 15:38 - 2017-09-10 15:52 - 449847274 _____ C:\Users\papeter\Desktop\Recording #126.avi
                      2017-09-08 11:37 - 2017-09-08 11:37 - 001059328 _____ C:\Users\papeter\Documents\nofap.pub
                      2017-09-08 09:13 - 2017-09-10 11:41 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\1B6A4467.sys
                      2017-09-07 22:57 - 2017-09-07 22:57 - 000000028 _____ C:\Users\papeter\Documents\imjetset.com John Crestani.txt
                      2017-09-07 17:41 - 2017-09-07 17:41 - 000200932 _____ C:\Users\papeter\Desktop\15-HIGH-PAYING-AFFILIATE-PROGRAMS.pdf
                      2017-09-07 10:36 - 2017-09-07 10:36 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\0AEA3549.sys
                      2017-09-07 00:01 - 2017-09-07 00:01 - 000000087 _____ C:\Users\papeter\Documents\Frans lead gen sites re interview with Michael Cyger.txt
                      2017-09-06 23:37 - 2017-09-06 23:37 - 000007672 _____ C:\Users\papeter\Downloads\estibot-export(63).csv
                      2017-09-06 22:33 - 2017-09-06 22:33 - 000000093 _____ C:\Users\papeter\Documents\sky.txt
                      2017-09-06 16:33 - 2017-09-06 16:33 - 000000044 _____ C:\Users\papeter\Documents\yes.txt
                      2017-09-06 14:00 - 2017-09-06 14:00 - 000199680 _____ C:\Users\papeter\Documents\FLIPFLOP 1.pub
                      2017-09-05 23:13 - 2017-09-05 23:13 - 000355952 _____ C:\Users\papeter\Desktop\200SocialMediaTactics.pdf
                      2017-09-05 19:03 - 2017-09-05 19:03 - 001489579 _____ C:\Users\papeter\Documents\The Unseen Therapist.pdf
                      2017-09-05 14:37 - 2017-09-21 13:09 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HiSuite
                      2017-09-05 14:37 - 2017-09-05 14:37 - 000001071 _____ C:\Users\Public\Desktop\HiSuite.lnk
                      2017-09-05 14:37 - 2017-09-05 14:37 - 000000000 ____D C:\Program Files (x86)\HiSuite
                      2017-09-04 21:29 - 2017-09-08 16:44 - 000000102 _____ C:\Users\papeter\Documents\Assets.txt
                      2017-09-04 20:30 - 2017-09-04 20:30 - 000000043 _____ C:\Users\papeter\Documents\ceseare.txt
                      2017-09-04 17:10 - 2017-09-04 17:10 - 000000056 _____ C:\Users\papeter\Documents\Amazon pending review for t-shirts.txt
                      2017-09-03 12:09 - 2017-09-03 12:11 - 357891850 _____ C:\Users\papeter\Downloads\TextSuiteBonus2(2).zip
                      2017-09-03 00:41 - 2017-09-03 00:41 - 000000446 _____ C:\Users\papeter\Documents\BLASTERSUITE REFUND REQUEST.txt
                      2017-09-01 12:38 - 2017-09-01 12:38 - 000599552 _____ C:\Users\papeter\Documents\ADPACK5.pub
                      2017-09-01 12:33 - 2017-09-01 12:33 - 000396800 _____ C:\Users\papeter\Documents\ADPACK4.pub
                      2017-09-01 12:29 - 2017-09-01 12:29 - 000334336 _____ C:\Users\papeter\Documents\ADPACKPRO 2.pub
                      2017-09-01 12:28 - 2017-09-01 12:28 - 000509440 _____ C:\Users\papeter\Documents\ADPACKPRO 1.pub
                      2017-08-31 20:55 - 2017-08-31 20:55 - 004125071 _____ C:\Users\papeter\Desktop\UNSEENTHERPIST.pdf
                      2017-08-29 22:33 - 2017-08-29 22:33 - 000182272 _____ C:\Users\papeter\Documents\Google traffic.pub
                      2017-08-29 20:15 - 2017-08-29 20:15 - 000087584 _____ (AO Kaspersky Lab) C:\WINDOWS\system32\Drivers\klupd_klif_kimul.sys
                      2017-08-29 17:26 - 2017-08-29 20:01 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\19292FEB.sys
                      2017-09-28 20:19 - 2015-10-15 22:17 - 000000000 ____D C:\Users\papeter\Documents\Outlook Files
                      2017-09-28 20:14 - 2015-10-15 23:30 - 000000000 ____D C:\ProgramData\Kaspersky Lab
                      2017-09-28 20:02 - 2015-10-30 11:02 - 000000000 ____D C:\Users\papeter\AppData\Local\Google
                      2017-09-28 20:02 - 2015-10-30 11:02 - 000000000 ____D C:\Program Files (x86)\Google
                      2017-09-28 19:53 - 2015-10-20 21:34 - 000938158 _____ C:\Users\papeter\Desktop\MY DOMAINS (2) (Autosaved).xlsx
                      2017-09-28 15:31 - 2017-03-18 22:01 - 000000000 ____D C:\WINDOWS\INF
                      2017-09-28 15:30 - 2017-03-18 22:03 - 000000000 ____D C:\ProgramData\regid.1991-06.com.microsoft
                      2017-09-28 15:28 - 2015-02-05 23:48 - 000000000 ____D C:\Program Files (x86)\Microsoft Office
                      2017-09-28 15:21 - 2015-08-23 23:25 - 000000000 __SHD C:\Users\papeter\IntelGraphicsProfiles
                      2017-09-28 15:20 - 2016-09-05 11:22 - 000000000 ____D C:\ProgramData\NVIDIA
                      2017-09-28 15:19 - 2017-03-18 12:40 - 000786432 _____ C:\WINDOWS\system32\config\BBI
                      2017-09-28 15:19 - 2017-01-16 15:37 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Chrome Apps
                      2017-09-28 15:12 - 2015-02-05 23:55 - 000000000 ____D C:\ProgramData\CyberLink
                      2017-09-28 15:12 - 2015-02-05 23:48 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Lenovo
                      2017-09-28 15:12 - 2015-02-05 23:22 - 000000000 ____D C:\ProgramData\Lenovo
                      2017-09-28 15:12 - 2015-02-05 23:08 - 000000000 ____D C:\Program Files (x86)\Lenovo
                      2017-09-28 15:12 - 2015-02-05 23:03 - 000000000 ___HD C:\Program Files (x86)\InstallShield Installation Information
                      2017-09-28 15:10 - 2015-02-05 23:58 - 000000000 ____D C:\Program Files\Lenovo PhoneCompanion
                      2017-09-28 15:08 - 2015-02-05 23:09 - 000000000 ____D C:\Program Files\Lenovo
                      2017-09-28 15:05 - 2015-02-05 23:03 - 000000000 ____D C:\Program Files (x86)\Realtek
                      2017-09-28 15:01 - 2017-07-04 14:07 - 007137216 _____ (Geek Unіnstaller) C:\Users\papeter\Desktop\geek.exe
                      2017-09-28 13:24 - 2015-08-25 15:18 - 000000000 ____D C:\Users\papeter\AppData\Local\Adobe
                      2017-09-28 10:38 - 2017-03-18 22:03 - 000000000 ___HD C:\Program Files\WindowsApps
                      2017-09-28 10:38 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\AppReadiness
                      2017-09-27 20:53 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\NDF
                      2017-09-27 20:06 - 2016-02-07 12:14 - 000000000 ____D C:\Users\papeter\AppData\Roaming\vlc
                      2017-09-27 16:59 - 2015-08-23 23:25 - 000000000 ____D C:\Users\papeter\AppData\Local\Packages
                      2017-09-27 11:44 - 2015-11-30 22:09 - 000000000 ____D C:\Users\papeter\AppData\LocalLow\Temp
                      2017-09-26 23:47 - 2016-10-13 10:29 - 000000000 ____D C:\Program Files\Common Files\AV
                      2017-09-26 22:19 - 2016-10-28 20:32 - 000002283 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
                      2017-09-26 11:37 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\appcompat
                      2017-09-22 17:28 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\LiveKernelReports
                      2017-09-21 21:48 - 2017-03-18 22:03 - 000028672 _____ C:\WINDOWS\system32\config\BCD-Template
                      2017-09-21 21:45 - 2017-03-18 22:06 - 000000000 ____D C:\WINDOWS\Setup
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ___SD C:\WINDOWS\SysWOW64\F12
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ___SD C:\WINDOWS\system32\F12
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\WinMetadata
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\setup
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\WinMetadata
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\WinBioPlugIns
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\setup
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\ShellExperiences
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\Program Files\Windows Photo Viewer
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\Program Files (x86)\Windows Photo Viewer
                      2017-09-21 21:33 - 2017-03-19 03:30 - 000000000 ____D C:\WINDOWS\OCR
                      2017-09-21 16:05 - 2017-03-18 21:51 - 000000000 ____D C:\WINDOWS\CbsTemp
                      2017-09-21 14:15 - 2015-12-17 09:46 - 000002460 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Outlook 2016.lnk
                      2017-09-21 14:08 - 2015-10-15 20:29 - 000002380 _____ C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\OneDrive.lnk
                      2017-09-21 14:08 - 2015-10-15 17:37 - 000000000 ___RD C:\Users\papeter\OneDrive
                      2017-09-21 14:03 - 2017-03-18 22:03 - 000000000 ___RD C:\WINDOWS\ImmersiveControlPanel
                      2017-09-21 14:03 - 2015-09-10 06:42 - 000000000 __RHD C:\Users\Public\AccountPictures
                      2017-09-21 13:42 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\rescache
                      2017-09-21 13:41 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\WinBioDatabase
                      2017-09-21 13:31 - 2016-07-16 12:47 - 000000000 ____D C:\WINDOWS\system32\Tasks_Migrated
                      2017-09-21 13:29 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\Registration
                      2017-09-21 13:29 - 2016-06-20 23:41 - 000057424 _____ (AO Kaspersky Lab) C:\WINDOWS\system32\Drivers\klim6.sys
                      2017-09-21 13:21 - 2017-03-19 03:31 - 000000000 ____D C:\WINDOWS\HoloShell
                      2017-09-21 13:20 - 2015-10-15 20:15 - 000022840 _____ C:\WINDOWS\system32\emptyregdb.dat
                      2017-09-21 13:19 - 2017-03-18 22:03 - 000000000 __RSD C:\WINDOWS\Media
                      2017-09-21 13:19 - 2017-03-18 22:03 - 000000000 __RHD C:\Users\Public\Libraries
                      2017-09-21 13:15 - 2015-02-05 23:04 - 000889694 _____ C:\WINDOWS\SysWOW64\PerfStringBackup.INI
                      2017-09-21 13:09 - 2017-08-21 20:11 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Privax
                      2017-09-21 13:09 - 2017-07-11 22:23 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
                      2017-09-21 13:09 - 2017-07-06 23:06 - 000000000 ____D C:\WINDOWS\system32\UNP
                      2017-09-21 13:09 - 2017-06-21 15:31 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Zoom
                      2017-09-21 13:09 - 2017-03-27 12:15 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NETGEAR WNDA3100v3 Genie
                      2017-09-21 13:09 - 2016-10-13 10:34 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kaspersky Secure Connection
                      2017-09-21 13:09 - 2016-10-13 10:34 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kaspersky Internet Security
                      2017-09-21 13:09 - 2016-05-24 10:04 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Recuva
                      2017-09-21 13:09 - 2016-05-19 15:36 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon MG7700 series User Registration
                      2017-09-21 13:09 - 2016-05-19 15:33 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon MG7700 series Manual
                      2017-09-21 13:09 - 2016-04-01 16:11 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner
                      2017-09-21 13:09 - 2016-03-02 19:43 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Screencast-O-Matic v2.0
                      2017-09-21 13:09 - 2016-02-25 01:30 - 000000000 ____D C:\ProgramData\regid.1986-12.com.adobe
                      2017-09-21 13:09 - 2016-02-07 12:41 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight
                      2017-09-21 13:09 - 2016-02-07 12:13 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN
                      2017-09-21 13:09 - 2016-02-01 13:16 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\webplugin.exe
                      2017-09-21 13:09 - 2015-12-01 18:18 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Interst Architect
                      2017-09-21 13:09 - 2015-10-22 17:00 - 000000000 ____D C:\WINDOWS\system32\STRING
                      2017-09-21 13:09 - 2015-10-15 17:30 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2016 Tools
                      2017-09-21 13:09 - 2015-02-05 23:52 - 000000000 ___RD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CyberLink PowerDirector 10
                      2017-09-21 13:09 - 2015-02-05 23:03 - 000000000 ___RD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel
                      2017-09-21 13:09 - 2015-02-05 23:01 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation
                      2017-09-21 13:08 - 2017-07-24 23:13 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Alexander Kabakov
                      2017-09-21 13:08 - 2017-03-18 12:40 - 000008192 _____ C:\WINDOWS\system32\config\ELAM
                      2017-09-21 13:08 - 2016-12-01 21:10 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Microsoft Corporation
                      2017-09-21 13:08 - 2016-07-30 18:17 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Lenovo
                      2017-09-21 13:08 - 2016-07-09 22:38 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Google Photos Backup
                      2017-09-21 13:08 - 2016-05-08 21:11 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\IrfanView
                      2017-09-21 13:08 - 2016-02-06 18:37 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Handbrake
                      2017-09-21 13:07 - 2015-10-30 07:28 - 000000000 ____D C:\Users\Default.migrated
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\Macromed
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\lv-LV
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\lt-LT
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\et-EE
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\en-GB
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\spool
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\oobe
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\Macromed
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\lv-LV
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\lt-LT
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\InputMethod
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\et-EE
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\en-GB
                      2017-09-21 13:02 - 2016-01-05 15:18 - 000000000 ____D C:\WINDOWS\SysWOW64\spool
                      2017-09-21 13:02 - 2015-02-05 23:23 - 000000000 ____D C:\WINDOWS\SysWOW64\Lenovo
                      2017-09-21 13:02 - 2015-02-05 23:23 - 000000000 ____D C:\WINDOWS\system32\Lenovo
                      2017-09-21 13:02 - 2013-08-22 16:36 - 000000000 ____D C:\WINDOWS\system32\WindowsInternal.Inbox.Shared
                      2017-09-21 13:02 - 2013-08-22 16:36 - 000000000 ____D C:\WINDOWS\system32\WindowsInternal.Inbox.Media.Sh ared
                      2017-09-21 13:01 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\InputMethod
                      2017-09-21 13:01 - 2017-03-18 22:03 - 000000000 ____D C:\ProgramData\USOPrivate
                      2017-09-21 13:01 - 2016-05-19 15:31 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon Utilities
                      2017-09-21 13:01 - 2016-05-18 20:45 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\EPSON
                      2017-09-21 13:01 - 2015-02-05 23:54 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nuance
                      2017-09-21 13:01 - 2015-02-05 23:07 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Conexant
                      2017-09-21 13:00 - 2017-03-18 22:03 - 000000000 ____D C:\Program Files\Common Files\microsoft shared
                      2017-09-21 12:55 - 2017-03-18 12:40 - 000000000 ____D C:\WINDOWS\system32\Sysprep
                      2017-09-21 12:54 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\Help
                      2017-09-21 12:03 - 2017-07-11 07:54 - 000000000 ___HD C:$WINDOWS.~BT
                      2017-09-19 00:19 - 2016-03-02 19:43 - 000000000 ____D C:\Users\papeter\AppData\Local\Screencast-O-Matic-v2
                      2017-09-18 18:19 - 2016-04-01 16:11 - 000000000 ____D C:\Program Files\CCleaner
                      2017-09-18 14:57 - 2017-07-08 20:48 - 000000000 ____D C:\Users\papeter\AppData\Local\GoToMeeting
                      2017-09-14 09:11 - 2016-07-30 18:17 - 000000000 ____D C:\Users\papeter\AppData\Local\Apps\2.0
                      2017-09-14 00:11 - 2016-06-27 00:20 - 000000000 ____D C:\Program Files (x86)\HMA! Pro VPN
                      2017-09-13 17:09 - 2015-08-25 09:13 - 000000000 ____D C:\WINDOWS\system32\MRT
                      2017-09-13 17:04 - 2015-08-25 09:13 - 138202976 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
                      2017-09-05 23:12 - 2015-10-29 16:21 - 000000000 ____D C:\Users\papeter\Documents\MARKETING
                      2017-09-05 17:58 - 2016-05-24 10:04 - 000000000 ____D C:\Program Files\Recuva
                      2017-09-05 14:43 - 2016-10-25 14:23 - 000000000 ____D C:\Users\papeter\AppData\Local\Hisuite
                      2017-09-03 12:16 - 2017-08-17 23:38 - 491558047 _____ C:\Users\papeter\Desktop\TextSuiteBonus2.mp4
                      2017-09-02 16:15 - 2017-03-18 22:06 - 000835576 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
                      2017-09-02 16:15 - 2017-03-18 22:06 - 000177656 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
                      2017-08-31 21:30 - 2015-10-17 16:11 - 000002457 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acrobat Reader DC.lnk
                      2016-06-22 09:54 - 2016-12-01 17:41 - 000577414 _____ () C:\Users\papeter\AppData\Roaming\Scorch_Install.lo g
                      2016-01-26 18:24 - 2017-04-27 00:22 - 000005632 _____ () C:\Users\papeter\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
                      2016-03-31 09:56 - 2016-03-31 09:56 - 000007609 _____ () C:\Users\papeter\AppData\Local\Resmon.ResmonCfg
                      2017-09-21 12:53 - 2017-09-21 12:53 - 000000000 ____H () C:\ProgramData\DP45977C.lfl
                      [HEADING=1]Some files in TEMP:[/HEADING]
                      2017-09-28 19:56 - 2017-09-28 19:56 - 004043712 _____ (Geek Unіnstaller) C:\Users\papeter\AppData\Local\Temp\geek64.exe
                      LastRegBack: 2017-09-21 12:49
                      [HEADING=1]Additional scan result of Farbar Recovery Scan Tool (x64) Version: 26-09-2017 01
                      Ran by papeter (28-09-2017 20:38:15)
                      Running from C:\Users\papeter\Desktop
                      Windows 10 Home Version 1703 (X64) (2017-09-21 12:43:08)
                      Boot Mode: Normal[/HEADING]
                      Administrator (S-1-5-21-4237603079-860989819-990887440-500 - Administrator - Disabled)
                      DefaultAccount (S-1-5-21-4237603079-860989819-990887440-503 - Limited - Disabled)
                      Guest (S-1-5-21-4237603079-860989819-990887440-501 - Limited - Disabled)
                      papeter (S-1-5-21-4237603079-860989819-990887440-1001 - Administrator - Enabled) => C:\Users\papeter
                      AV: Kaspersky Internet Security (Enabled - Up to date) {86367591-4BE4-AE08-2FD9-7FCB8259CD98}
                      AV: Malwarebytes (Enabled - Up to date) {23007AD3-69FE-687C-2629-D584AFFAF72B}
                      AS: Malwarebytes (Enabled - Up to date) {98619B37-4FC4-67F2-1C99-EEF6D47DBD96}
                      AS: Kaspersky Internet Security (Enabled - Up to date) {3D579475-6DDE-A186-1569-44B9F9DE8725}
                      FW: Kaspersky Internet Security (Enabled) {BE0DF4B4-018B-AF50-0486-D6FE7C8A8AE3}
                      Adobe Acrobat Reader DC (HKLM-x32...{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 17.012.20098 - Adobe Systems Incorporated)
                      Adobe Flash Player 27 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 27.0.0.130 - Adobe Systems Incorporated)
                      Adobe Premiere Elements 14 (HKLM-x32...{18EF738B-56F0-4370-8FEA-93FC9EC51DFA}) (Version: 14.1 - Adobe Systems Incorporated)
                      amazeowl-desktop (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\amazeowl) (Version: 2.26.1 - AmazeOwl (c) 2017)
                      Apple Application Support (32-bit) (HKLM-x32...{E92BB800-BCC5-4C25-8102-AC2C3B7C7C1E}) (Version: 5.5 - Apple Inc.)
                      Apple Application Support (64-bit) (HKLM...{9C912B1E-06DD-43EF-BB2B-45CB2C88BAAE}) (Version: 5.5 - Apple Inc.)
                      Apple Mobile Device Support (HKLM...{0A596141-97D5-45FA-9281-98DFAF48D579}) (Version: 10.3.2.3 - Apple Inc.)
                      Apple Software Update (HKLM-x32...{52D87F32-70E4-4348-8148-C0B9F35B1314}) (Version: 2.3.0.177 - Apple Inc.)
                      Bonjour (HKLM...{56DDDFB8-7F79-4480-89D5-25E1F52AB28F}) (Version: 3.1.0.1 - Apple Inc.)
                      Canon Easy-WebPrint EX (HKLM-x32...\Easy-WebPrint EX) (Version: 1.6.0.0 - Canon Inc.)
                      Canon IJ Network Scanner Selector EX (HKLM-x32...\Canon_IJ_Network_Scanner_Selector_EX) (Version: 1.5.4.4 - Canon Inc.)
                      Canon IJ Network Tool (HKLM-x32...\Canon_IJ_Network_UTILITY) (Version: 3.7.0 - Canon Inc.)
                      Canon IJ Scan Utility (HKLM-x32...\Canon_IJ_Scan_Utility) (Version: 1.1.20.13 - Canon Inc.)
                      Canon Inkjet Printer/Scanner/Fax Extended Survey Program (HKLM-x32...\CANONIJPLM100) (Version: 5.0.1 - Canon Inc.)
                      Canon MG7700 series MP Drivers (HKLM...{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}_Canon_MG7700_series) (Version: 1.00 - Canon Inc.)
                      Canon MG7700 series On-screen Manual (HKLM-x32...\Canon MG7700 series On-screen Manual) (Version: 7.8.0 - Canon Inc.)
                      Canon MG7700 series User Registration (HKLM-x32...\Canon MG7700 series User Registration) (Version: - ‭Canon Inc.)
                      Canon My Image Garden (HKLM-x32...\Canon My Image Garden) (Version: 3.3.0 - Canon Inc.)
                      Canon My Image Garden Design Files (HKLM-x32...\Canon My Image Garden Design Files) (Version: 3.2.0 - Canon Inc.)
                      Canon My Printer (HKLM-x32...\CanonMyPrinter) (Version: 3.3.0 - Canon Inc.)
                      Canon Quick Menu (HKLM-x32...\CanonQuickMenu) (Version: 2.6.1 - Canon Inc.)
                      CCleaner (HKLM...\CCleaner) (Version: 5.35 - Piriform)
                      CCSDK (HKLM-x32...{AE75190B-11B4-4F90-8254-DAB275CF2557}is1) (Version: 1.0.3.4 - Lenovo)
                      Click Install if prompted (HKLM-x32...{92A9572E-834E-477B-A100-C9AD3EE4B4B9}) (Version: 1.0.0.0 - ExpressVpn) Hidden
                      Conexant HD Audio (HKLM...\CNXT_AUDIO_HDA) (Version: 8.65.55.62 - Conexant)
                      CyberLink PowerDirector 10 (HKLM...{B0B4F6D2-F2AE-451A-9496-6F2F6A897B32}) (Version: 10.0.0.2810 - CyberLink Corp.) Hidden
                      CyberLink PowerDirector 10 (HKLM-x32...\InstallShield
                      Dependency Package Update (HKLM...{0788641D-D31A-478D-BB34-C41564AE9F93}) (Version: 1.6.38.00 - Lenovo Inc.) Hidden
                      Dependency Package Update (HKLM...{5252431C-288E-409D-ADCF-24407E0E6F70}) (Version: 1.6.25.00 - Lenovo Inc.) Hidden
                      Dependency Package Update (HKLM...{FFED38DF-94DC-4FF9-96C1-A6990EDA6B03}) (Version: 1.6.29.00 - Lenovo Inc.) Hidden
                      Dolby Digital Plus Home Theater (HKLM...{7E3D8FA1-6092-469A-955B-68FC4A2C67CA}) (Version: 7.5.1.1 - Dolby Laboratories Inc)
                      Dragon Assistant version 1.5.20 (HKLM-x32...{D57A8269-3BE5-4D10-B882-64D0F2D448BF}is1) (Version: 1.5.20 - Nuance Communications, Inc.)
                      ELAN Touchpad 11.15.0.18_X64 (HKLM...\Elantech) (Version: 11.15.0.18 - ELAN Microelectronic Corp.)
                      EPSON SX430 Series Printer Uninstall (HKLM...\EPSON SX430 Series) (Version: - SEIKO EPSON Corporation)
                      ExpressVPN (HKLM-x32...{10EB2DEF-3C7F-40DD-8C58-438906E20D08}) (Version: 6.2.3.2578 - ExpressVPN) Hidden
                      ExpressVPN (HKLM-x32...{a219f179-a66a-48db-934c-aca0746714e5}) (Version: 6.2.3.2578 - ExpressVPN)
                      Google Chrome (HKLM-x32...\Google Chrome) (Version: 61.0.3163.100 - Google Inc.)
                      Google Photos Backup (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Google Photos Backup) (Version: 1.1.2.13 - Google, Inc.)
                      Google Update Helper (HKLM-x32...{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.5 - Google Inc.) Hidden
                      GoTo Opener (HKLM-x32...{8B2D47CC-1558-4939-B27F-41E30530072A}) (Version: 1.0.467 - LogMeIn, Inc.)
                      GoToMeeting 8.11.0.7586 (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\GoToMeeting) (Version: 8.11.0.7586 - LogMeIn, Inc.)
                      HandBrake 0.10.3 (HKLM-x32...\HandBrake) (Version: 0.10.3 - )
                      HiSuite (HKLM-x32...\Hi Suite) (Version: 1.0 - Huawei Technologies Co.,Ltd)
                      HMA! Pro VPN (HKLM...{60A560F2-CB75-4C94-9C36-39AD2161DE73}is1) (Version: 3.5.58 - Privax)
                      Intel(R) Chipset Device Software (HKLM-x32...{f5d71765-7cd1-4e68-998f-5b379e725da3}) (Version: 10.0.22 - Intel(R) Corporation) Hidden
                      Intel(R) Management Engine Components (HKLM...{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 10.0.28.1006 - Intel Corporation)
                      Intel(R) Processor Graphics (HKLM-x32...{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 20.19.15.4531 - Intel Corporation)
                      Intel(R) Rapid Storage Technology (HKLM...{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 13.2.0.1016 - Intel Corporation)
                      Intel(R) Update Manager (HKLM-x32...{7224B7CE-196C-4E2A-A1AE-1D7BF259FD36}) (Version: 3.4.1942 - Intel Corporation)
                      Interst Architect (HKLM-x32...\Interst Architect1.0.0.7) (Version: 1.0.0.7 - InnAnTech Industries Inc.)
                      IrfanView 64 (remove only) (HKLM...\IrfanView64) (Version: 4.42 - Irfan Skiljan)
                      iTunes (HKLM...{F0C7385A-9D20-45F3-8101-05D383885180}) (Version: 12.6.1.25 - Apple Inc.)
                      Kaspersky Internet Security (HKLM-x32...{E27B1D7B-3B34-43A2-9FC0-9828D5DF46E2}) (Version: 17.0.0.611 - Kaspersky Lab) Hidden
                      Kaspersky Internet Security (HKLM-x32...\InstallWIX
                      Kaspersky Secure Connection (HKLM-x32...{1CF84962-50F8-48CA-9082-B70F3A02C686}) (Version: 17.0.0.611 - Kaspersky Lab) Hidden
                      Kaspersky Secure Connection (HKLM-x32...\InstallWIX
                      Lenovo Bluetooth with Enhanced Data Rate Software (HKLM...{C6D9ED03-6FCF-4410-9CB7-45CA285F9E11}) (Version: 12.0.0.9840 - Broadcom Corporation)
                      Lenovo Dependency Package (HKLM...\Lenovo Dependency Package_is1) (Version: 1.6.25.00 - Lenovo Group Limited)
                      Lenovo Patch Utility (HKLM-x32...{E8F27ADF-B1ED-41AF-A7EF-D5E71778480C}) (Version: 1.3.2.6 - Lenovo Group Limited) Hidden
                      Lenovo Patch Utility 64 bit (HKLM...{49A09C2C-FFF4-478E-B397-5E0979F67F5D}) (Version: 1.3.2.6 - Lenovo Group Limited) Hidden
                      Lenovo Service Bridge (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\dda9ca0b023f4c56) (Version: 1.6.3.5 - Lenovo)
                      Lenovo Settings - Camera Audio (HKLM...{88C6A6D9-324C-46E8-BA87-563D14021442}_is1) (Version: 4.3.24.256 - Lenovo Corporation)
                      Lenovo Settings (HKLM...{D14CCBF5-1A3A-4C08-955B-BE6D519835C4}_is1) (Version: 2.0.0.5 - Lenovo)
                      Lenovo Settings Dependency Package (HKLM...{3694BA2E-BE31-4B7E-886B-A0B559E69D4D}_is1) (Version: 2.3.1.27 - Lenovo Group Limited)
                      Lenovo Settings Service (HKLM...{8C6F1EBA-17F1-4481-B688-9777E63E985F}_is1) (Version: 2.3.0.21 - Lenovo Group Limited)
                      Lenovo Settings UMDF driver (HKLM...{2BDC7413-65EA-4B99-8C4B-02F11075BE6D}_is1) (Version: 1.2.0.7 - Lenovo Group Limited)
                      Lenovo Settings WiFi (HKLM...{86045A6C-C156-4349-A3E2-47A88A42F5C2}is1) (Version: 2.0.0.4 - Lenovo)
                      Lenovo_Wireless_Driver (HKLM-x32...{5D642A72-8194-4A22-80DA-11FE610CCA8E}) (Version: 6.30.223.201 - Lenovo)
                      LenovoUtility (HKLM-x32...{6ADA7E88-8D16-4D0D-BC90-2B93AC5E56DA}) (Version: 1.5.0.26 - Lenovo) Hidden
                      LenovoUtility (HKLM-x32...\InstallShield
                      Malwarebytes version 3.2.2.2029 (HKLM...{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}is1) (Version: 3.2.2.2029 - Malwarebytes)
                      Metric Collection SDK 35 (HKLM-x32...{C2B5B5B0-2545-4E94-B4BA-548D4BF0B196}) (Version: 1.2.0001.00 - Lenovo Group Limited) Hidden
                      Microsoft Office 365 - en-us (HKLM...\O365HomePremRetail - en-us) (Version: 16.0.8431.2079 - Microsoft Corporation)
                      Microsoft OneDrive (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\OneDriveSetup.exe) (Version: 17.3.6998.0830 - Microsoft Corporation)
                      Microsoft Silverlight (HKLM...{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50907.0 - Microsoft Corporation)
                      Microsoft Support and Recovery Assistant for Office 365 (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\4415f693b586d348) (Version: 16.0.1519.6 - Microsoft Corporation)
                      Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM...{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
                      Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32...{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
                      Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215 (HKLM-x32...{e2803110-78b3-4664-a479-3611a381656a}) (Version: 14.0.24215.1 - Microsoft Corporation)
                      Mozilla Firefox 55.0.3 (x86 en-GB) (HKLM-x32...\Mozilla Firefox 55.0.3 (x86 en-GB)) (Version: 55.0.3 - Mozilla)
                      Mozilla Maintenance Service (HKLM...\MozillaMaintenanceService) (Version: 55.0.2 - Mozilla)
                      NETGEAR WNDA3100v3 (HKLM-x32...{60C50FCC-545B-4D5D-B0D1-4A773143BCE7}) (Version: 1.0.0.10 - NETGEAR) Hidden
                      NETGEAR WNDA3100v3 Genie (HKLM-x32...\InstallShield
                      Nuance Speech Component DA-A en-GB version 1.5.20 (HKLM-x32...{1CCBE73F-4948-4711-8D12-22E2FD65D706}_is1) (Version: 1.5.20 - Nuance Communications, Inc.)
                      Nuance Speech Component DA-C version 1.1.22 (HKLM-x32...{E97BA7A6-46FC-4EBF-B24A-B8362948C696}_is1) (Version: 1.1.22 - Nuance Communications, Inc.)
                      Nuance Speech Component DA-L en-GB version 1.1.5 (HKLM-x32...{CA54E6DD-70F8-4AE5-8427-522A52FC4408}_is1) (Version: 1.1.5 - Nuance Communications, Inc.)
                      NVIDIA GeForce Experience 2.1.2 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 2.1.2 - NVIDIA Corporation)
                      NVIDIA Graphics Driver 376.54 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 376.54 - NVIDIA Corporation)
                      NVIDIA PhysX System Software 9.14.0702 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}Display.PhysX) (Version: 9.14.0702 - NVIDIA Corporation)
                      Office 16 Click-to-Run Extensibility Component (HKLM-x32...{90160000-008C-0000-0000-0000000FF1CE}) (Version: 16.0.8431.2079 - Microsoft Corporation) Hidden
                      Office 16 Click-to-Run Extensibility Component 64-bit Registration (HKLM...{90160000-00DD-0000-1000-0000000FF1CE}) (Version: 16.0.8431.2079 - Microsoft Corporation) Hidden
                      Office 16 Click-to-Run Licensing Component (HKLM...{90160000-008F-0000-1000-0000000FF1CE}) (Version: 16.0.8431.2079 - Microsoft Corporation) Hidden
                      Office 16 Click-to-Run Localization Component (HKLM-x32...{90160000-008C-0409-0000-0000000FF1CE}) (Version: 16.0.8326.2107 - Microsoft Corporation) Hidden
                      paint.net (HKLM...{1F895C18-6A2F-4A9E-BBE9-246783070F37}) (Version: 4.0.16 - dotPDN LLC)
                      Realtek Card Reader (HKLM-x32...{5BC2B5AB-80DE-4E83-B8CF-426902051D0A}) (Version: 6.3.9600.39059 - Realtek Semiconductor Corp.)
                      Realtek Ethernet Controller Driver (HKLM-x32...{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 8.33.529.2014 - Realtek)
                      Recuva (HKLM...\Recuva) (Version: 1.53 - Piriform)
                      Screencast-O-Matic v2.0 (HKLM-x32...\Screencast-O-Matic v2.0) (Version: v2.0 - Screencast-O-Matic)
                      Sibelius Scorch (Firefox, Opera, Netscape, Chrome only) (HKLM-x32...{41626CC0-A854-4402-AD06-D7939515C282}) (Version: 6.2.0 - Sibelius Software, a division of Avid Technology, Inc.)
                      Skype Web Plugin (HKLM-x32...{D116C78B-2A53-4BF9-A089-5BE0E132C10C}) (Version: 7.25.0.32 - Skype Technologies S.A.)
                      User Manuals (HKLM-x32...{F07C2CF8-4C53-4EC3-8162-A6221E36EB88}) (Version: 3.0.0.3 - Lenovo) Hidden
                      User Manuals (HKLM-x32...\InstallShield
                      VLC media player (HKLM-x32...\VLC media player) (Version: 2.2.6 - VideoLAN)
                      Vulkan Run Time Libraries 1.0.26.0 (HKLM...\VulkanRT1.0.26.0) (Version: 1.0.26.0 - LunarG, Inc.)
                      webplugin.exe version 3.1.0.4 (HKLM-x32...{ED02ABD7-1049-4984-A35A-26ABEC69E2E0}_is1) (Version: 3.1.0.4 - )
                      Windows 10 Update and Privacy Settings (HKLM...{4DFCD818-036A-4229-A67D-CF17DC461D92}) (Version: 1.0.14.0 - Microsoft Corporation)
                      Windows Driver Package - Lenovo (ACPIVPC) System (09/24/2013 19.29.2.34) (HKLM...\EE9B1F2037C580F36D92FA431CC02BFF04C31F15) (Version: 09/24/2013 19.29.2.34 - Lenovo)
                      Windows Driver Package - Lenovo (WUDFRd) LenovoVhid (07/25/2013 10.30.0.288) (HKLM...\6BCA401E9CBEED970D75F55FA5320F60D11984E9) (Version: 07/25/2013 10.30.0.288 - Lenovo)
                      Zemana AntiMalware (HKLM-x32...{8F0CD7D1-42F3-4195-95CD-833578D45057}_is1) (Version: 2.74.0.150 - Zemana Ltd.)
                      Zoom (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\ZoomUMX) (Version: 4.0 - Zoom Video Communications, Inc.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{1233A989-8A71-4FED-9712-C4F07707E209}\InprocServer32 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\GatewayActiveX-x64.dll (Skype Technologies S.A.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{13C484D6-AD2C-46D9-9581-1E03CBED164C}\localserver32 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\GatewayVersion-x64.exe (Skype Technologies S.A.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{144DF3B2-2402-47AE-9583-5A045929A8D4}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\psuser_64.dll (Google Inc.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{4BE56754-B616-4998-B825-D16983AEE1B2}\InprocServer32 → C:\WINDOWS\system32\mscoree.dll (Microsoft Corporation)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{84B5A313-CD5D-4904-8BA2-AFDC81C1B309}\InprocServer32 → C:\Users\papeter\AppData\Local\GoToMeeting\7586\G2 MOutlookAddin64.dll (LogMeIn, Inc.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{CBF9CD8C-2714-4F36-B76A-43E6C7547BC2}\localserver32 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\EdgeCalling.exe (Skype Technologies S.A.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{E8CF3E55-F919-49D9-ABC0-948E6CB34B9F}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\psuser_64.dll (Google Inc.)
                      ContextMenuHandlers1: [2.0 Zemana AntiMalware] → {6ABB1C11-E261-4CEA-BBB5-3836225689DD} => C:\Program Files (x86)\Zemana AntiMalware\ZAMShellExt64.dll [2017-09-27] ()
                      ContextMenuHandlers1: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
                      ContextMenuHandlers2: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
                      ContextMenuHandlers3: [MBAMShlExt] → {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2017-08-30] (Malwarebytes)
                      ContextMenuHandlers4: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
                      ContextMenuHandlers4: [RecuvaShellExt] → {435E5DF5-2510-463C-B223-BDA47006D002} => C:\Program Files\Recuva\RecuvaShell64.dll [2016-06-06] (Piriform Ltd)
                      ContextMenuHandlers5: [igfxDTCM] → {9B5F5829-A529-4B12-814A-E81BCB8D93FC} => C:\WINDOWS\system32\igfxDTCM.dll [2017-05-26] (Intel Corporation)
                      ContextMenuHandlers5: [NvCplDesktopContext] → {3D1975AF-48C6-4f8e-A182-BE0E08FA86A9} => C:\WINDOWS\system32\nvshext.dll [2016-12-29] (NVIDIA Corporation)
                      ContextMenuHandlers6: [2.0 Zemana AntiMalware] → {6ABB1C11-E261-4CEA-BBB5-3836225689DD} => C:\Program Files (x86)\Zemana AntiMalware\ZAMShellExt64.dll [2017-09-27] ()
                      ContextMenuHandlers6: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
                      ContextMenuHandlers6: [MBAMShlExt] → {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2017-08-30] (Malwarebytes)
                      ContextMenuHandlers6: [RecuvaShellExt] → {435E5DF5-2510-463C-B223-BDA47006D002} => C:\Program Files\Recuva\RecuvaShell64.dll [2016-06-06] (Piriform Ltd)
                      Task: {0F9EF0E7-8B28-4747-9B41-EDD8C8B11A20} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core1d257e734ba2eb7 => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe [2016-07-09] (Google Inc.)
                      Task: {130945BA-E34F-406D-945F-4798B868FC9C} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe [2017-02-14] (Apple Inc.)
                      Task: {1A2F50C6-F791-4308-AD89-DD4AB0D6D5DD} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe [2016-07-09] (Google Inc.)
                      Task: {285FCF36-48A5-44A0-9982-E9304933A13E} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473 => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [2016-08-12] (Intel Corporation)
                      Task: {2E65BEF9-5870-433F-9530-1A0013F27E5A} - \G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001 → No File <==== ATTENTION
                      Task: {352E6CA0-7314-4DF4-89C4-682368D80D57} - System32\Tasks\Microsoft\Windows\Workplace Join\Automatic-Workplace-Join => C:\WINDOWS\System32\AutoWorkplace.exe
                      Task: {36FBF9F7-0174-4757-BF5C-29DD8E248DF9} - \Optimize Start Menu Cache Files-S-1-5-21-4237603079-860989819-990887440-500 → No File <==== ATTENTION
                      Task: {41DCBCE3-523C-42DA-885D-FC7FF5DE288E} - System32\Tasks\AdobeAAMUpdater-1.0-Lenovo-PC-papeter => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.e xe [2015-07-29] (Adobe Systems Incorporated)
                      Task: {423E7DA8-EB68-4D8D-B787-5077D4FF57E8} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2017-09-20] (Piriform Ltd)
                      Task: {49D59F20-EE17-4CCD-AB6A-64B26BCEFCFD} - System32\Tasks\Microsoft\Office\Office ClickToRun Service Monitor => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2017-09-08] (Microsoft Corporation)
                      Task: {677EC76F-5F1E-4B88-9EB4-895656CEA55A} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-10-28] (Google Inc.)
                      Task: {6C125CC5-2DC0-431B-950B-4FEF3ADC0AFC} - System32\Tasks\Microsoft\Office\OfficeBackgroundTa skHandlerLogon => C:\Program Files (x86)\Microsoft Office\root\Office16\officebackgroundtaskhandler.e xe [2017-09-28] ()
                      Task: {725B857D-D90E-4542-AF19-E45906878C67} - System32\Tasks\Microsoft\Office\OfficeBackgroundTa skHandlerRegistration => C:\Program Files (x86)\Microsoft Office\root\Office16\officebackgroundtaskhandler.e xe [2017-09-28] ()
                      Task: {849DFEF6-B702-4152-BC80-E4F579623C1A} - \Adobe Flash Player Updater → No File <==== ATTENTION
                      Task: {9B7176A0-ED5C-47E9-9F4E-3E285610B8A6} - \G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001 → No File <==== ATTENTION
                      Task: {9F63AB90-3171-400B-BA8A-410C5A09104F} - System32\Tasks\Microsoft\Office\Office Subscription Maintenance => C:\Program Files (x86)\Microsoft Office\root\vfs\ProgramFilesCommonx86\Microsoft Shared\Office16\OLicenseHeartbeat.exe [2017-09-28] (Microsoft Corporation)
                      Task: {A58E8A74-7AB8-473A-AAA8-D96019EFEB88} - System32\Tasks\Kaspersky_Upgrade_Launcher_{278ADC4 2-419D-4547-A6CA-5B74BE0AD901} => C:\Program Files\Common Files\AV\Kaspersky Lab\upgrade_launcher.exe [2016-07-11] (AO Kaspersky Lab)
                      Task: {BB30997D-E801-4BD3-874C-7D6099EFE8D0} - System32\Tasks\HMA! Pro VPN Update => C:\Program Files (x86)\HMA! Pro VPN\VpnUpdate.exe [2017-09-13] (AVAST Software)
                      Task: {C0FD436D-2E37-4DA0-B6A4-7D82B82D4544} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-10-28] (Google Inc.)
                      Task: {CE8370B7-FF42-4C72-A77B-CD159741128F} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [2016-08-12] (Intel Corporation)
                      Task: {E4DB69B8-2AA6-440B-911A-A9BA95247085} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2017-07-19] (Adobe Systems Incorporated)
                      Task: {EC1A298C-94C0-458F-B031-43BB8556CF8D} - \GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA1d257e73535f0dd → No File <==== ATTENTION
                      Task: {FB7DCF66-3B0D-4256-B23F-6A0D8452518E} - System32\Tasks\PDVDServ Task => C:\Program Files (x86)\Lenovo\PowerDVD10\PDVD10Serv.EXE
                      Task: {FCDA2712-8ABB-4D56-B1F5-EBFAD897E31B} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe [2016-07-09] (Google Inc.)
                      Task: {FF145775-1787-47F8-B8AF-69BC8DB8E0A4} - System32\Tasks\Microsoft\Office\Office Automatic Updates => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2017-09-08] (Microsoft Corporation)
                      Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core.job => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe
                      Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA.job => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe
                      2016-05-19 15:26 - 2015-11-09 13:40 - 000253528 _____ () C:\Program Files (x86)\Canon\IJPLM\IJPLMSVC.EXE
                      2016-11-17 02:28 - 2016-11-17 02:28 - 000092472 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
                      2017-05-09 00:44 - 2017-05-09 00:44 - 001354040 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
                      2017-07-06 11:22 - 2017-07-06 11:22 - 000331264 _____ () C:\Program Files (x86)\ExpressVPN\bootstrap\AMD64\nssm.exe
                      2017-07-26 08:58 - 2017-07-26 08:58 - 000192200 _____ () C:\Program Files (x86)\HiSuite\HandSetService\HuaweiHiSuiteService6 4.exe
                      2015-02-05 23:52 - 2012-04-24 11:43 - 000390632 ____N () C:\Program Files\CyberLink\Shared files\RichVideo64.exe
                      2017-07-06 11:24 - 2017-07-06 11:24 - 009239168 _____ () C:\Program Files (x86)\ExpressVPN\xvpnd\xvpnd.exe
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000134712 _____ () C:\Program Files\NVIDIA Corporation\Display\NvSmartMax64.dll
                      2017-09-27 23:11 - 2017-08-24 11:27 - 002264528 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\MwacLib.dll
                      2017-03-18 21:58 - 2017-03-18 21:58 - 000138000 _____ () C:\WINDOWS\SYSTEM32\inputhost.dll
                      2016-03-15 23:47 - 2017-09-28 12:57 - 008929480 _____ () C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\1033\GrooveIntlResource.dll
                      2017-09-27 21:59 - 2017-09-27 21:59 - 000155504 _____ () C:\Program Files (x86)\Zemana AntiMalware\ZAMShellExt64.dll
                      2017-05-26 05:11 - 2017-05-26 05:11 - 000401840 _____ () C:\WINDOWS\system32\igfxTray.exe
                      2017-03-18 21:59 - 2017-03-19 03:31 - 001731072 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\Cortana.Core.dll
                      2015-02-05 23:06 - 2010-10-26 05:40 - 000049056 _____ () C:\Program Files\CONEXANT\ForteConfig\fmapp.exe
                      2017-05-09 03:05 - 2017-05-09 03:05 - 000092472 _____ () C:\Program Files\iTunes\zlib1.dll
                      2017-05-09 03:05 - 2017-05-09 03:05 - 001354040 _____ () C:\Program Files\iTunes\libxml2.dll
                      2015-02-05 23:48 - 2014-07-10 02:19 - 000592880 _____ () C:\Program Files (x86)\Lenovo\CCSDK\CCSDK.exe
                      2015-02-05 23:48 - 2014-07-10 02:19 - 000397296 _____ () C:\Program Files (x86)\Lenovo\CCSDK\WinGather.exe
                      2017-09-14 09:15 - 2017-09-14 09:15 - 003553704 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\Microsoft.UI.Xaml.dll
                      2017-09-24 11:01 - 2017-09-24 11:07 - 010634752 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\WinStore.Entertainment.M obile.dll
                      2017-09-24 11:01 - 2017-09-24 11:07 - 002640896 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\MS.Entertainment.Common. Mobile.dll
                      2017-09-28 10:31 - 2017-09-28 10:37 - 026118656 _____ () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17082.141 21.0_x64__8wekyb3d8bbwe\Video.UI.exe
                      2017-09-28 10:31 - 2017-09-28 10:37 - 009162240 _____ () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17082.141 21.0_x64__8wekyb3d8bbwe\EntCommon.dll
                      2017-09-21 18:03 - 2017-09-21 18:03 - 003553704 _____ () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17082.141 21.0_x64__8wekyb3d8bbwe\Microsoft.UI.Xaml.dll
                      2017-09-28 10:31 - 2017-09-28 10:37 - 011470848 _____ () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17082.141 21.0_x64__8wekyb3d8bbwe\EntPlat.dll
                      2017-09-28 10:32 - 2017-09-28 10:38 - 001226424 _____ () C:\Program Files\WindowsApps\microsoft.windowscommunicationsa pps_17.8500.40955.0_x64__8wekyb3d8bbwe\Office.UI.X aml.Word.dll
                      2017-09-21 18:03 - 2017-09-21 18:04 - 004354560 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsAlarms_10.1706. 2231.0_x64__8wekyb3d8bbwe\Time.exe
                      2017-09-21 18:03 - 2017-09-21 18:03 - 003553704 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsAlarms_10.1706. 2231.0_x64__8wekyb3d8bbwe\Microsoft.UI.Xaml.dll
                      2017-09-21 18:03 - 2017-09-21 18:04 - 000819712 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsAlarms_10.1706. 2231.0_x64__8wekyb3d8bbwe\TimeControls.dll
                      2017-09-21 18:03 - 2017-09-21 18:04 - 000821248 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsAlarms_10.1706. 2231.0_x64__8wekyb3d8bbwe\TimeBackground.dll
                      2016-06-28 00:19 - 2016-06-28 00:19 - 000865232 _____ () C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\kpcengine.2.3.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 000387984 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\fl_core.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 001165712 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_asr.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 000229264 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\sdxg.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 000199056 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_base.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 001132944 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_pron.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 000035216 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_platform.dll
                      2017-09-13 18:59 - 2017-09-13 18:59 - 000057968 _____ () C:\Program Files (x86)\HMA! Pro VPN\module_lifetime.dll
                      2017-09-13 18:59 - 2017-09-13 18:59 - 000240264 _____ () C:\Program Files (x86)\HMA! Pro VPN\tasks_core.dll
                      2017-09-13 18:59 - 2017-09-13 18:59 - 000147928 _____ () C:\Program Files (x86)\HMA! Pro VPN\network_notifications.dll
                      2017-09-13 18:59 - 2017-09-13 18:59 - 000084384 _____ () C:\Program Files (x86)\HMA! Pro VPN\WinUtils.dll
                      2017-09-13 18:59 - 2017-09-13 18:59 - 000210776 _____ () C:\Program Files (x86)\HMA! Pro VPN\event_routing_rpc.dll
                      2017-07-06 11:25 - 2017-07-06 11:25 - 000441472 _____ () C:\Program Files (x86)\ExpressVPN\xvpnd\windows\ExpressVPN.FilterMa nager.dll
                      2014-12-22 10:03 - 2014-12-22 10:03 - 000122880 _____ () C:\Program Files (x86)\NETGEAR\WNDA3100v3\Ralink.dll
                      2012-11-21 18:26 - 2012-11-21 18:26 - 001204224 _____ () C:\Program Files (x86)\NETGEAR\WNDA3100v3\RaWLAPI.dll
                      2014-09-03 20:03 - 2014-09-03 20:03 - 001241560 _____ () C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\ACE.dll
                      2017-08-10 16:24 - 2017-08-10 16:24 - 072940016 _____ () C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroCEF\libcef.dll
                      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\MBAMService => “”=“Service”
                      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\MBAMService => “”=“Service”
                      2013-08-22 14:25 - 2017-09-26 22:51 - 000000753 _____ C:\WINDOWS\system32\Drivers\etc\hosts
                      127.0.0.1 localhost
                      HKU\S-1-5-21-4237603079-860989819-990887440-1001\Control Panel\Desktop\Wallpaper → c:\windows\web\wallpaper\theme1\img1.jpg
                      DNS Servers: 192.168.1.1
                      HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\System => (ConsentPromptBehaviorAdmin: 5) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
                      HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer => (SmartScreenEnabled: RequireAdmin)
                      Windows Firewall is enabled.
                      FirewallRules: [{DCA0D126-14AF-4A5D-87BC-81873A537E0B}] => (Allow) C:\Program Files (x86)\Microsoft Office\root\Office16\outlook.exe
                      FirewallRules: [{6AAD4B02-0AA9-4E42-96E8-41C5935BEC8A}] => (Allow) C:\Program Files\iTunes\iTunes.exe
                      FirewallRules: [{6DB766FF-BB4B-4C73-9D8C-A92EFDBD00E6}] => (Allow) C:\Program Files (x86)\Bonjour\mDNSResponder.exe
                      FirewallRules: [{C0BE10F4-12B3-47CD-9C73-1728CE89589F}] => (Allow) C:\Program Files (x86)\Bonjour\mDNSResponder.exe
                      FirewallRules: [{07906379-64D9-4D27-92C8-A7F73C3F5533}] => (Allow) C:\Program Files\Bonjour\mDNSResponder.exe
                      FirewallRules: [{91366BBD-0523-405B-815B-CB9017BF8CC1}] => (Allow) C:\Program Files\Bonjour\mDNSResponder.exe
                      FirewallRules: [{937E5BA2-C0DF-427D-8F8A-22791E81899B}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
                      FirewallRules: [{C538B0C6-4DE1-4521-BEDF-FF966F02435A}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
                      FirewallRules: [{946DD1A7-4F09-4EA9-976E-BB7BF9E7830E}] => (Allow) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
                      FirewallRules: [{DEB7BDCE-9DF5-40AD-80BE-9D2654935719}] => (Allow) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
                      FirewallRules: [{99C246BD-C5F0-4247-9336-8711F6D59034}] => (Allow) C:\Program Files\CyberLink\PowerDirector10\PDR10.EXE
                      FirewallRules: [{C1E9968D-0BEB-4CE0-B192-78BCD30E96B6}] => (Allow) LPort=55100
                      FirewallRules: [{EFB666FF-BC02-4248-9E8D-84AC44260B83}] => (Allow) C:\Program Files\Lenovo PhotoMasterImport\PhotoMasterImport.exe
                      FirewallRules: [{BEF637D7-4EC6-404F-A968-91532518EC75}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
                      FirewallRules: [{4EEFDDB8-E20B-41B2-97DD-2790077AA4E2}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
                      FirewallRules: [{25DCEF18-32BC-40CA-A52F-28C1B4D6330C}] => (Allow) C:\Users\papeter\AppData\Local\Microsoft\OneDrive\ OneDrive.exe
                      FirewallRules: [{A67B328D-EAF4-4390-9D05-48FD050ED34D}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
                      21-09-2017 16:04:34 Windows Update
                      27-09-2017 21:29:38 JRT Pre-Junkware Removal
                      28-09-2017 15:03:39 Removed BlasterSuite Manager
                      Name: ExpressVPN Tap Adapter
                      Description: ExpressVPN Tap Adapter
                      Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
                      Manufacturer: ExpressVPN
                      Service: tapexpressvpn
                      Problem: : This device is disabled. (Code 22)
                      Resolution: In Device Manager, click “Action”, and then click “Enable Device”. This starts the Enable Device wizard. Follow the instructions.
                      Error: (09/28/2017 07:26:03 PM) (Source: lupdate) (EventID: 0) (User: )
                      Description: Event-ID 0
                      Error: (09/28/2017 03:34:48 PM) (Source: lupdate) (EventID: 0) (User: )
                      Error: (09/28/2017 03:23:43 PM) (Source: lupdate) (EventID: 0) (User: )
                      Error: (09/28/2017 03:22:07 PM) (Source: Microsoft-Windows-Immersive-Shell) (EventID: 5973) (User: Lenovo-PC)
                      Description: Activation of app Microsoft.MicrosoftStickyNotes_8wekyb3d8bbwe!App failed with error: -2144927141 See the Microsoft-Windows-TWinUI/Operational log for additional information.
                      Error: (09/28/2017 03:20:32 PM) (Source: nssm) (EventID: 1018) (User: )
                      Description: Failed to read registry value AppDirectory:
                      The operation completed successfully.
                      Error: (09/28/2017 03:18:55 PM) (Source: VSS) (EventID: 8193) (User: )
                      Description: Volume Shadow Copy Service error: Unexpected error calling routine QueryFullProcessImageNameW. hr = 0x8007001f, A device attached to the system is not functioning.
                      Operation:
                      Executing Asynchronous Operation
                      Context:
                      Current State: DoSnapshotSet
                      Error: (09/28/2017 03:05:58 PM) (Source: Application Error) (EventID: 1000) (User: )
                      Description: Faulting application name: RtCamU64.exe, version: 1.12.0.0, time stamp: 0x5510f753
                      Faulting module name: RtCamU64.exe, version: 1.12.0.0, time stamp: 0x5510f753
                      Exception code: 0xc0000409
                      Fault offset: 0x0000000000195f38
                      Faulting process id: 0x35e8
                      Faulting application start time: 0x01d33862d8b0c1e5
                      Faulting application path: C:\Windows\RtCamU64.exe
                      Faulting module path: C:\Windows\RtCamU64.exe
                      Report Id: e32e3c31-8276-4799-926b-ace35077faab
                      Faulting package full name:
                      Error: (09/28/2017 02:59:09 PM) (Source: Microsoft-Windows-Immersive-Shell) (EventID: 5973) (User: Lenovo-PC)
                      Error: (09/28/2017 03:47:57 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
                      and APPID
                      to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
                      Error: (09/28/2017 03:25:54 PM) (Source: Service Control Manager) (EventID: 7022) (User: )
                      Description: The Delivery Optimization service hung on starting.
                      Error: (09/28/2017 03:24:17 PM) (Source: DCOM) (EventID: 10010) (User: NT AUTHORITY)
                      Description: The server {784E29F4-5EBE-4279-9948-1E8FE941646D} did not register with DCOM within the required timeout.
                      Error: (09/28/2017 03:22:07 PM) (Source: DCOM) (EventID: 10010) (User: Lenovo-PC)
                      Description: The server Microsoft.MicrosoftStickyNotes_1.8.0.0_x64__8wekyb 3d8bbwe!App did not register with DCOM within the required timeout.
                      Error: (09/28/2017 03:21:07 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
                      {6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}
                      and APPID
                      {4839DDB7-58C2-48F5-8283-E1D1807D0D7D}
                      to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
                      and APPID
                      Error: (09/28/2017 03:20:30 PM) (Source: Service Control Manager) (EventID: 7000) (User: )
                      Description: The CldFlt service failed to start due to the following error:
                      The request is not supported.
                      Error: (09/28/2017 03:19:45 PM) (Source: Service Control Manager) (EventID: 7000) (User: )
                      Description: The Apple Mobile Device Service service failed to start due to the following error:
                      The system cannot find the path specified.
                      Error: (09/28/2017 03:19:31 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (EventID: 10003) (User: NT AUTHORITY)
                      Description: WLAN Extensibility Module has stopped unexpectedly.
                      Module Path: C:\WINDOWS\System32\bcmihvsrv64.dll
                      Date: 2017-09-27 20:51:50.820
                      Description: Code Integrity determined that a process (\Device\HarddiskVolume5\Windows\SystemApps\Micros oft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.ex e) attempted to load \Device\HarddiskVolume5\Program Files (x86)\Malwarebytes Anti-Exploit\mbae64.dll that did not meet the Store signing level requirements.
                      Date: 2017-09-27 20:51:50.463
                      Date: 2017-09-24 23:29:45.253
                      Date: 2017-09-24 23:29:44.932
                      Date: 2017-09-24 23:24:52.589
                      Date: 2017-09-24 22:57:51.735
                      Date: 2017-09-24 22:57:51.435
                      Date: 2017-09-24 22:57:50.849
                      Date: 2017-09-24 22:57:50.482
                      Date: 2017-09-24 22:49:06.129
                      Processor: Intel(R) Core™ i7-5500U CPU @ 2.40GHz
                      Percentage of memory in use: 25%
                      Total physical RAM: 16299.08 MB
                      Available physical RAM: 12164.98 MB
                      Total Virtual: 17323.08 MB
                      Available Virtual: 12737.66 MB
                      Drive c: (Windows8_OS) (Fixed) (Total:888.7 GB) (Free:402.46 GB) NTFS ==>[system with boot components (obtained from drive)]
                      Drive d: (LENOVO) (Fixed) (Total:25 GB) (Free:22.68 GB) NTFS
                      Disk: 0 (Size: 931.5 GB) (Disk ID: 12E6AA89)
                      Partition: GPT.
                      • jmarket
                        PCHF Owner
                        • 7695
                        • CachyOS
                        • Intel Arc A770 (16 GB)
                        #26
                        Any more issues to speak of @papeter?
                        I see that you have ExpressVPN and Avast. You only need one, and I would recommend ExpressVPN and removing Avast
                        • papeter
                          • Feb 2017
                          • 33
                          #27
                          Thanks for you help, I really do appreciate it. Finally should I retain Kaspersky as my main Anti-Virus program, or do you recommend something else?
                          Regards
                          Peter
                          • papeter
                            • Feb 2017
                            • 33
                            #28
                            [HEADING=1]DelFix v1.013 - Logfile created 29/09/2017 at 10:51:33[/HEADING]
                            [HEADING=1]Updated 17/04/2016 by Xplode[/HEADING]
                            [HEADING=1]Username : papeter - LENOVO-PC[/HEADING]
                            [HEADING=1]Operating System : Windows 10 Home (64 bits)[/HEADING]
                            ~ Removing disinfection tools …
                            Deleted : C:\FRST
                            Deleted : C:\zoek_backup
                            Deleted : C:\AdwCleaner
                            Deleted : C:\SecurityCheck
                            Deleted : C:\Users\papeter\Downloads\FRST-OlderVersion
                            Deleted : C:\zoek-results.log
                            Deleted : C:\Users\papeter\Desktop\Addition.txt
                            Deleted : C:\Users\papeter\Desktop\adwcleaner_7.0.2.1(1).exe
                            Deleted : C:\Users\papeter\Desktop\FRST.txt
                            Deleted : C:\Users\papeter\Desktop\FRST64(1).exe
                            Deleted : C:\Users\papeter\Desktop\JRT(1).exe
                            Deleted : C:\Users\papeter\Desktop\JRT.txt
                            Deleted : C:\Users\papeter\Desktop\SecurityCheck.exe
                            Deleted : C:\Users\papeter\Downloads\Addition.txt
                            Deleted : C:\Users\papeter\Downloads\adwcleaner_7.0.2.1.exe
                            Deleted : C:\Users\papeter\Downloads\FRST.txt
                            Deleted : C:\Users\papeter\Downloads\FRST64.exe
                            Deleted : C:\Users\papeter\Downloads\JRT.exe
                            Deleted : C:\Users\papeter\Downloads\zoek.exe
                            ########## - EOF - ##########
                            • papeter
                              • Feb 2017
                              • 33
                              #29
                              [HEADING=1]DelFix v1.013 - Logfile created 29/09/2017 at 10:56:39[/HEADING]
                              ~ Creating registry backup … OK
                              ~ Cleaning system restore …
                              Deleted : RP #1 [Windows Update | 09/21/2017 15:04:34]
                              Deleted : RP #8 [JRT Pre-Junkware Removal | 09/27/2017 20:29:38]
                              Deleted : RP #9 [Removed BlasterSuite Manager | 09/28/2017 14:03:39]
                              New restore point created !
                              • jmarket
                                PCHF Owner
                                • 7695
                                • CachyOS
                                #30
                                Your computer is officially clean
