Malwarebytes stopped working suddenly. Their Chameleon system unable to fix!
  • papeter
    • Feb 2017
    • 33
    Hi Hope you can help please.
    I have the home premium version of Malwarebytes which suddenly stopped working a few days ago (due to be renewed in 20 days)
    My Laptop op system is Wndowns 10. I also have Kaspersky Internet Security also due to be renewed shortly.
    Malwarebytes stopped suddenly and the protection is now disabled. I attempted their anti-malware CHAMELEON as suggested by clicking on the 13 buttons, but this didn’t work.
    There must some sort of virus that’s blocked Malwarebytes from functioning properly. I am wondering if I should download ADWCleaner to in the meantime. I used to use ADWC years ago and never had a problem with it.
    Thanks guys
    Peter
  • jmarket
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    Hi @papeter and welcome to PCHF
    Once downloaded right click the FRST desktop icon and select “Run as administrator” from the menu.
    Frst will open with two dialogue boxes, accept the disclaimer.
    Accept the default whitelist options,
    If the additions.txt options box is not checked please select it.
    Then select “Scan”
    Please Copy and Paste the contents of these logs in your next post for review by our Security Team
    • papeter
      • Feb 2017
      • 33
      These are the logs that were downloaded…Thanks:-
      [HEADING=1]Additional scan result of Farbar Recovery Scan Tool (x64) Version: 25-09-2017 01
      Ran by papeter (26-09-2017 18:04:45)
      Running from C:\Users\papeter\AppData\Local\Microsoft\Windows\I NetCache\IE\0TYT8C22
      Windows 10 Home Version 1703 (X64) (2017-09-21 12:43:08)
      Boot Mode: Normal[/HEADING]
      Administrator (S-1-5-21-4237603079-860989819-990887440-500 - Administrator - Disabled)
      DefaultAccount (S-1-5-21-4237603079-860989819-990887440-503 - Limited - Disabled)
      Guest (S-1-5-21-4237603079-860989819-990887440-501 - Limited - Disabled)
      papeter (S-1-5-21-4237603079-860989819-990887440-1001 - Administrator - Enabled) => C:\Users\papeter
      AV: Kaspersky Internet Security (Enabled - Up to date) {86367591-4BE4-AE08-2FD9-7FCB8259CD98}
      AS: Kaspersky Internet Security (Enabled - Up to date) {3D579475-6DDE-A186-1569-44B9F9DE8725}
      FW: Kaspersky Internet Security (Enabled) {BE0DF4B4-018B-AF50-0486-D6FE7C8A8AE3}
      Adobe Acrobat Reader DC (HKLM-x32...{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 17.012.20098 - Adobe Systems Incorporated)
      Adobe Flash Player 27 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 27.0.0.130 - Adobe Systems Incorporated)
      Adobe Premiere Elements 14 (HKLM-x32...{18EF738B-56F0-4370-8FEA-93FC9EC51DFA}) (Version: 14.1 - Adobe Systems Incorporated)
      amazeowl-desktop (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\amazeowl) (Version: 2.26.1 - AmazeOwl (c) 2017)
      Apple Application Support (32-bit) (HKLM-x32...{E92BB800-BCC5-4C25-8102-AC2C3B7C7C1E}) (Version: 5.5 - Apple Inc.)
      Apple Application Support (64-bit) (HKLM...{9C912B1E-06DD-43EF-BB2B-45CB2C88BAAE}) (Version: 5.5 - Apple Inc.)
      Apple Mobile Device Support (HKLM...{0A596141-97D5-45FA-9281-98DFAF48D579}) (Version: 10.3.2.3 - Apple Inc.)
      Apple Software Update (HKLM-x32...{52D87F32-70E4-4348-8148-C0B9F35B1314}) (Version: 2.3.0.177 - Apple Inc.)
      BlasterSuite Manager (HKLM-x32...{43431316-1F90-4D26-952C-A88F8303736A}) (Version: 1.0.6 - BlasterSuite)
      Bonjour (HKLM...{56DDDFB8-7F79-4480-89D5-25E1F52AB28F}) (Version: 3.1.0.1 - Apple Inc.)
      Canon Easy-WebPrint EX (HKLM-x32...\Easy-WebPrint EX) (Version: 1.6.0.0 - Canon Inc.)
      Canon IJ Network Scanner Selector EX (HKLM-x32...\Canon_IJ_Network_Scanner_Selector_EX) (Version: 1.5.4.4 - Canon Inc.)
      Canon IJ Network Tool (HKLM-x32...\Canon_IJ_Network_UTILITY) (Version: 3.7.0 - Canon Inc.)
      Canon IJ Scan Utility (HKLM-x32...\Canon_IJ_Scan_Utility) (Version: 1.1.20.13 - Canon Inc.)
      Canon Inkjet Printer/Scanner/Fax Extended Survey Program (HKLM-x32...\CANONIJPLM100) (Version: 5.0.1 - Canon Inc.)
      Canon MG7700 series MP Drivers (HKLM...{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}Canon_MG7700_series) (Version: 1.00 - Canon Inc.)
      Canon MG7700 series On-screen Manual (HKLM-x32...\Canon MG7700 series On-screen Manual) (Version: 7.8.0 - Canon Inc.)
      Canon MG7700 series User Registration (HKLM-x32...\Canon MG7700 series User Registration) (Version: - ‭Canon Inc.)
      Canon My Image Garden (HKLM-x32...\Canon My Image Garden) (Version: 3.3.0 - Canon Inc.)
      Canon My Image Garden Design Files (HKLM-x32...\Canon My Image Garden Design Files) (Version: 3.2.0 - Canon Inc.)
      Canon My Printer (HKLM-x32...\CanonMyPrinter) (Version: 3.3.0 - Canon Inc.)
      Canon Quick Menu (HKLM-x32...\CanonQuickMenu) (Version: 2.6.1 - Canon Inc.)
      CCleaner (HKLM...\CCleaner) (Version: 5.35 - Piriform)
      CCSDK (HKLM-x32...{AE75190B-11B4-4F90-8254-DAB275CF2557}is1) (Version: 1.0.3.4 - Lenovo)
      Click Install if prompted (HKLM-x32...{92A9572E-834E-477B-A100-C9AD3EE4B4B9}) (Version: 1.0.0.0 - ExpressVpn) Hidden
      Conexant HD Audio (HKLM...\CNXT_AUDIO_HDA) (Version: 8.65.55.62 - Conexant)
      CyberLink PowerDirector 10 (HKLM...{B0B4F6D2-F2AE-451A-9496-6F2F6A897B32}) (Version: 10.0.0.2810 - CyberLink Corp.) Hidden
      CyberLink PowerDirector 10 (HKLM-x32...\InstallShield
      Dependency Package Update (HKLM...{0788641D-D31A-478D-BB34-C41564AE9F93}) (Version: 1.6.38.00 - Lenovo Inc.) Hidden
      Dependency Package Update (HKLM...{5252431C-288E-409D-ADCF-24407E0E6F70}) (Version: 1.6.25.00 - Lenovo Inc.) Hidden
      Dependency Package Update (HKLM...{FFED38DF-94DC-4FF9-96C1-A6990EDA6B03}) (Version: 1.6.29.00 - Lenovo Inc.) Hidden
      Dolby Digital Plus Home Theater (HKLM...{7E3D8FA1-6092-469A-955B-68FC4A2C67CA}) (Version: 7.5.1.1 - Dolby Laboratories Inc)
      Dragon Assistant version 1.5.20 (HKLM-x32...{D57A8269-3BE5-4D10-B882-64D0F2D448BF}is1) (Version: 1.5.20 - Nuance Communications, Inc.)
      ELAN Touchpad 11.15.0.18_X64 (HKLM...\Elantech) (Version: 11.15.0.18 - ELAN Microelectronic Corp.)
      EPSON SX430 Series Printer Uninstall (HKLM...\EPSON SX430 Series) (Version: - SEIKO EPSON Corporation)
      ExpressVPN (HKLM-x32...{10EB2DEF-3C7F-40DD-8C58-438906E20D08}) (Version: 6.2.3.2578 - ExpressVPN) Hidden
      ExpressVPN (HKLM-x32...{a219f179-a66a-48db-934c-aca0746714e5}) (Version: 6.2.3.2578 - ExpressVPN)
      Google Chrome (HKLM-x32...\Google Chrome) (Version: 60.0.3112.113 - Google Inc.)
      Google Photos Backup (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Google Photos Backup) (Version: 1.1.2.13 - Google, Inc.)
      Google Update Helper (HKLM-x32...{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.5 - Google Inc.) Hidden
      GoTo Opener (HKLM-x32...{8B2D47CC-1558-4939-B27F-41E30530072A}) (Version: 1.0.467 - LogMeIn, Inc.)
      GoToMeeting 8.11.0.7586 (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\GoToMeeting) (Version: 8.11.0.7586 - LogMeIn, Inc.)
      HandBrake 0.10.3 (HKLM-x32...\HandBrake) (Version: 0.10.3 - )
      HiSuite (HKLM-x32...\Hi Suite) (Version: 1.0 - Huawei Technologies Co.,Ltd)
      HMA! Pro VPN (HKLM...{60A560F2-CB75-4C94-9C36-39AD2161DE73}is1) (Version: 3.5.58 - Privax)
      Intel(R) Chipset Device Software (HKLM-x32...{f5d71765-7cd1-4e68-998f-5b379e725da3}) (Version: 10.0.22 - Intel(R) Corporation) Hidden
      Intel(R) Management Engine Components (HKLM...{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 10.0.28.1006 - Intel Corporation)
      Intel(R) Processor Graphics (HKLM-x32...{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 20.19.15.4531 - Intel Corporation)
      Intel(R) Rapid Storage Technology (HKLM...{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 13.2.0.1016 - Intel Corporation)
      Intel(R) Update Manager (HKLM-x32...{7224B7CE-196C-4E2A-A1AE-1D7BF259FD36}) (Version: 3.4.1942 - Intel Corporation)
      Interst Architect (HKLM-x32...\Interst Architect1.0.0.7) (Version: 1.0.0.7 - InnAnTech Industries Inc.)
      IrfanView 64 (remove only) (HKLM...\IrfanView64) (Version: 4.42 - Irfan Skiljan)
      iTunes (HKLM...{F0C7385A-9D20-45F3-8101-05D383885180}) (Version: 12.6.1.25 - Apple Inc.)
      Kaspersky Internet Security (HKLM-x32...{E27B1D7B-3B34-43A2-9FC0-9828D5DF46E2}) (Version: 17.0.0.611 - Kaspersky Lab) Hidden
      Kaspersky Internet Security (HKLM-x32...\InstallWIX
      Kaspersky Secure Connection (HKLM-x32...{1CF84962-50F8-48CA-9082-B70F3A02C686}) (Version: 17.0.0.611 - Kaspersky Lab) Hidden
      Kaspersky Secure Connection (HKLM-x32...\InstallWIX
      Lenovo Bluetooth with Enhanced Data Rate Software (HKLM...{C6D9ED03-6FCF-4410-9CB7-45CA285F9E11}) (Version: 12.0.0.9840 - Broadcom Corporation)
      Lenovo Dependency Package (HKLM...\Lenovo Dependency Package_is1) (Version: 1.6.25.00 - Lenovo Group Limited)
      Lenovo EasyCamera (HKLM-x32...{E0A7ED39-8CD6-4351-93C3-69CCA00D12B4}) (Version: 6.2.9200.10269 - Realtek Semiconductor Corp.)
      Lenovo EasyCamera (HKLM-x32...{E399A5B3-ED53-4DEA-AF04-8011E1EB1EAC}) (Version: 6.3.9600.11105 - Realtek Semiconductor Corp.)
      Lenovo FusionEngine (HKLM-x32...\Lenovo FusionEngine) (Version: 1.0.13.0 - Lenovo, Inc.)
      Lenovo Mobile Phone Wireless Import (HKLM-x32...{DFB2E0D6-8DDE-49A4-B8F7-03C14DACCBA6}) (Version: 1.1.1.9 - Lenovo) Hidden
      Lenovo Mobile Phone Wireless Import (HKLM-x32...\InstallShield
      Lenovo OneKey Recovery (HKLM...{46F4D124-20E5-4D12-BE52-EC177A7A4B42}) (Version: 8.1.0.2619 - CyberLink Corp.) Hidden
      Lenovo OneKey Recovery (HKLM-x32...\InstallShield_{46F4D124-20E5-4D12-BE52-EC177A7A4B42}) (Version: 8.1.0.2619 - CyberLink Corp.)
      Lenovo Patch Utility (HKLM-x32...{E8F27ADF-B1ED-41AF-A7EF-D5E71778480C}) (Version: 1.3.2.6 - Lenovo Group Limited) Hidden
      Lenovo Patch Utility 64 bit (HKLM...{49A09C2C-FFF4-478E-B397-5E0979F67F5D}) (Version: 1.3.2.6 - Lenovo Group Limited) Hidden
      Lenovo PhoneCompanion (HKLM-x32...{0F82EA83-B0C5-4AB9-9695-DFE92C5FD57B}) (Version: 2.0.0.19 - Lenovo) Hidden
      Lenovo PhoneCompanion (HKLM-x32...\InstallShield_{0F82EA83-B0C5-4AB9-9695-DFE92C5FD57B}) (Version: 2.0.0.19 - Lenovo)
      Lenovo PowerDVD10 (HKLM-x32...{DEC235ED-58A4-4517-A278-C41E8DAEAB3B}) (Version: 10.0.6806.52 - CyberLink Corp.) Hidden
      Lenovo PowerDVD10 (HKLM-x32...\InstallShield_{DEC235ED-58A4-4517-A278-C41E8DAEAB3B}) (Version: 10.0.6806.52 - CyberLink Corp.)
      Lenovo Service Bridge (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\dda9ca0b023f4c56) (Version: 1.6.3.5 - Lenovo)
      Lenovo Settings - Camera Audio (HKLM...{88C6A6D9-324C-46E8-BA87-563D14021442}_is1) (Version: 4.3.24.256 - Lenovo Corporation)
      Lenovo Settings (HKLM...{D14CCBF5-1A3A-4C08-955B-BE6D519835C4}_is1) (Version: 2.0.0.5 - Lenovo)
      Lenovo Settings Dependency Package (HKLM...{3694BA2E-BE31-4B7E-886B-A0B559E69D4D}_is1) (Version: 2.3.1.27 - Lenovo Group Limited)
      Lenovo Settings Service (HKLM...{8C6F1EBA-17F1-4481-B688-9777E63E985F}_is1) (Version: 2.3.0.21 - Lenovo Group Limited)
      Lenovo Settings UMDF driver (HKLM...{2BDC7413-65EA-4B99-8C4B-02F11075BE6D}is1) (Version: 1.2.0.7 - Lenovo Group Limited)
      Lenovo Settings WiFi (HKLM...{86045A6C-C156-4349-A3E2-47A88A42F5C2}is1) (Version: 2.0.0.4 - Lenovo)
      Lenovo_Wireless_Driver (HKLM-x32...{5D642A72-8194-4A22-80DA-11FE610CCA8E}) (Version: 6.30.223.201 - Lenovo)
      LenovoUtility (HKLM-x32...{6ADA7E88-8D16-4D0D-BC90-2B93AC5E56DA}) (Version: 1.5.0.26 - Lenovo) Hidden
      LenovoUtility (HKLM-x32...\InstallShield
      Malwarebytes Anti-Exploit version 1.10.1.24 (HKLM...\Malwarebytes Anti-Exploit_is1) (Version: 1.10.1.24 - Malwarebytes)
      Malwarebytes Anti-Malware version 2.2.1.1043 (HKLM-x32...\Malwarebytes Anti-Malware_is1) (Version: 2.2.1.1043 - Malwarebytes)
      Metric Collection SDK 35 (HKLM-x32...{C2B5B5B0-2545-4E94-B4BA-548D4BF0B196}) (Version: 1.2.0001.00 - Lenovo Group Limited) Hidden
      Microsoft Office 365 - en-us (HKLM...\O365HomePremRetail - en-us) (Version: 16.0.8326.2107 - Microsoft Corporation)
      Microsoft OneDrive (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\OneDriveSetup.exe) (Version: 17.3.6998.0830 - Microsoft Corporation)
      Microsoft Silverlight (HKLM...{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50907.0 - Microsoft Corporation)
      Microsoft Support and Recovery Assistant for Office 365 (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\4415f693b586d348) (Version: 16.0.1519.6 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM...{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32...{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
      Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215 (HKLM-x32...{e2803110-78b3-4664-a479-3611a381656a}) (Version: 14.0.24215.1 - Microsoft Corporation)
      Mozilla Firefox 55.0.3 (x86 en-GB) (HKLM-x32...\Mozilla Firefox 55.0.3 (x86 en-GB)) (Version: 55.0.3 - Mozilla)
      Mozilla Maintenance Service (HKLM...\MozillaMaintenanceService) (Version: 55.0.2 - Mozilla)
      NETGEAR WNDA3100v3 (HKLM-x32...{60C50FCC-545B-4D5D-B0D1-4A773143BCE7}) (Version: 1.0.0.10 - NETGEAR) Hidden
      NETGEAR WNDA3100v3 Genie (HKLM-x32...\InstallShield
      Nuance Speech Component DA-A en-GB version 1.5.20 (HKLM-x32...{1CCBE73F-4948-4711-8D12-22E2FD65D706}_is1) (Version: 1.5.20 - Nuance Communications, Inc.)
      Nuance Speech Component DA-C version 1.1.22 (HKLM-x32...{E97BA7A6-46FC-4EBF-B24A-B8362948C696}_is1) (Version: 1.1.22 - Nuance Communications, Inc.)
      Nuance Speech Component DA-L en-GB version 1.1.5 (HKLM-x32...{CA54E6DD-70F8-4AE5-8427-522A52FC4408}_is1) (Version: 1.1.5 - Nuance Communications, Inc.)
      NVIDIA GeForce Experience 2.1.2 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 2.1.2 - NVIDIA Corporation)
      NVIDIA Graphics Driver 376.54 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 376.54 - NVIDIA Corporation)
      NVIDIA PhysX System Software 9.14.0702 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}Display.PhysX) (Version: 9.14.0702 - NVIDIA Corporation)
      Office 16 Click-to-Run Extensibility Component (HKLM-x32...{90160000-008C-0000-0000-0000000FF1CE}) (Version: 16.0.8326.2107 - Microsoft Corporation) Hidden
      Office 16 Click-to-Run Extensibility Component 64-bit Registration (HKLM...{90160000-00DD-0000-1000-0000000FF1CE}) (Version: 16.0.8326.2107 - Microsoft Corporation) Hidden
      Office 16 Click-to-Run Licensing Component (HKLM...{90160000-008F-0000-1000-0000000FF1CE}) (Version: 16.0.8326.2107 - Microsoft Corporation) Hidden
      Office 16 Click-to-Run Localization Component (HKLM-x32...{90160000-008C-0409-0000-0000000FF1CE}) (Version: 16.0.8326.2107 - Microsoft Corporation) Hidden
      paint.net (HKLM...{1F895C18-6A2F-4A9E-BBE9-246783070F37}) (Version: 4.0.16 - dotPDN LLC)
      Picasa 3 (HKLM-x32...\Picasa 3) (Version: 3.9.141.259 - Google, Inc.)
      Realtek Card Reader (HKLM-x32...{5BC2B5AB-80DE-4E83-B8CF-426902051D0A}) (Version: 6.3.9600.39059 - Realtek Semiconductor Corp.)
      Realtek Ethernet Controller Driver (HKLM-x32...{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 8.33.529.2014 - Realtek)
      Recuva (HKLM...\Recuva) (Version: 1.53 - Piriform)
      Screencast-O-Matic v2.0 (HKLM-x32...\Screencast-O-Matic v2.0) (Version: v2.0 - Screencast-O-Matic)
      Sibelius Scorch (Firefox, Opera, Netscape, Chrome only) (HKLM-x32...{41626CC0-A854-4402-AD06-D7939515C282}) (Version: 6.2.0 - Sibelius Software, a division of Avid Technology, Inc.)
      Skype Web Plugin (HKLM-x32...{D116C78B-2A53-4BF9-A089-5BE0E132C10C}) (Version: 7.25.0.32 - Skype Technologies S.A.)
      User Manuals (HKLM-x32...{F07C2CF8-4C53-4EC3-8162-A6221E36EB88}) (Version: 3.0.0.3 - Lenovo) Hidden
      User Manuals (HKLM-x32...\InstallShield
      VLC media player (HKLM-x32...\VLC media player) (Version: 2.2.6 - VideoLAN)
      Vulkan Run Time Libraries 1.0.26.0 (HKLM...\VulkanRT1.0.26.0) (Version: 1.0.26.0 - LunarG, Inc.)
      webplugin.exe version 3.1.0.4 (HKLM-x32...{ED02ABD7-1049-4984-A35A-26ABEC69E2E0}_is1) (Version: 3.1.0.4 - )
      Windows 10 Update and Privacy Settings (HKLM...{4DFCD818-036A-4229-A67D-CF17DC461D92}) (Version: 1.0.14.0 - Microsoft Corporation)
      Windows Driver Package - Lenovo (ACPIVPC) System (09/24/2013 19.29.2.34) (HKLM...\EE9B1F2037C580F36D92FA431CC02BFF04C31F15) (Version: 09/24/2013 19.29.2.34 - Lenovo)
      Windows Driver Package - Lenovo (WUDFRd) LenovoVhid (07/25/2013 10.30.0.288) (HKLM...\6BCA401E9CBEED970D75F55FA5320F60D11984E9) (Version: 07/25/2013 10.30.0.288 - Lenovo)
      Zoom (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\ZoomUMX) (Version: 4.0 - Zoom Video Communications, Inc.)
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{1233A989-8A71-4FED-9712-C4F07707E209}\InprocServer32 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\GatewayActiveX-x64.dll (Skype Technologies S.A.)
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{13C484D6-AD2C-46D9-9581-1E03CBED164C}\localserver32 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\GatewayVersion-x64.exe (Skype Technologies S.A.)
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{144DF3B2-2402-47AE-9583-5A045929A8D4}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\psuser_64.dll (Google Inc.)
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{2AD206F1-152C-4F9D-A24E-6F93FE7A4AFC}\InprocServer32 → C:\Users\papeter\AppData\Local\Grammarly\Grammarly for Microsoft Office Suite\6.5.57\159674BA1BE84D9EA82E2649B83A4305\Gram marlyShim64.dll => No File
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{4BE56754-B616-4998-B825-D16983AEE1B2}\InprocServer32 → C:\WINDOWS\system32\mscoree.dll (Microsoft Corporation)
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{590C4387-5EBD-4D46-8A84-CD0BA2EF2856}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 0.3\psuser_64.dll => No File
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{59B55F04-DE14-4BB8-92FF-C4A22EF2E5F4}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 1.5\psuser_64.dll => No File
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{84B5A313-CD5D-4904-8BA2-AFDC81C1B309}\InprocServer32 → C:\Users\papeter\AppData\Local\GoToMeeting\7586\G2 MOutlookAddin64.dll (LogMeIn, Inc.)
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{8C46158B-D978-483C-A312-16EE5013BE04}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.3\psuser_64.dll => No File
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{CB492AF1-2CEF-4E58-BE47-471C77D0C8BA}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 2.7\psuser_64.dll => No File
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{CBF9CD8C-2714-4F36-B76A-43E6C7547BC2}\localserver32 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\EdgeCalling.exe (Skype Technologies S.A.)
      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{E8CF3E55-F919-49D9-ABC0-948E6CB34B9F}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\psuser_64.dll (Google Inc.)
      ContextMenuHandlers1: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
      ContextMenuHandlers2: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
      ContextMenuHandlers3: [MBAMShlExt] → {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamext.dll [2016-03-10] (Malwarebytes)
      ContextMenuHandlers4: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
      ContextMenuHandlers4: [RecuvaShellExt] → {435E5DF5-2510-463C-B223-BDA47006D002} => C:\Program Files\Recuva\RecuvaShell64.dll [2016-06-06] (Piriform Ltd)
      ContextMenuHandlers5: [igfxcui] → {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => → No File
      ContextMenuHandlers5: [igfxDTCM] → {9B5F5829-A529-4B12-814A-E81BCB8D93FC} => C:\WINDOWS\system32\igfxDTCM.dll [2017-05-26] (Intel Corporation)
      ContextMenuHandlers5: [NvCplDesktopContext] → {3D1975AF-48C6-4f8e-A182-BE0E08FA86A9} => C:\WINDOWS\system32\nvshext.dll [2016-12-29] (NVIDIA Corporation)
      ContextMenuHandlers6: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
      ContextMenuHandlers6: [MBAMShlExt] → {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamext.dll [2016-03-10] (Malwarebytes)
      ContextMenuHandlers6: [RecuvaShellExt] → {435E5DF5-2510-463C-B223-BDA47006D002} => C:\Program Files\Recuva\RecuvaShell64.dll [2016-06-06] (Piriform Ltd)
      Task: {0AC65FA0-495B-4F4F-A25E-BFF79E288E9F} - \Microsoft\Windows\Setup\GWXTriggers\MachineUnlock-5d → No File <==== ATTENTION
      Task: {0F9EF0E7-8B28-4747-9B41-EDD8C8B11A20} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core1d257e734ba2eb7 => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe [2016-07-09] (Google Inc.)
      Task: {130945BA-E34F-406D-945F-4798B868FC9C} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe [2017-02-14] (Apple Inc.)
      Task: {1A2F50C6-F791-4308-AD89-DD4AB0D6D5DD} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe [2016-07-09] (Google Inc.)
      Task: {220D3058-5A68-4F36-AB95-53BF41A1AD8B} - \Lenovo\Lenovo Service Bridge\S-1-5-21-4237603079-860989819-990887440-1001 → No File <==== ATTENTION
      Task: {2503E967-7EFA-41A9-BAC3-831F529825E0} - \Microsoft\Windows\Setup\gwx\refreshgwxconfigandco ntent → No File <==== ATTENTION
      Task: {285FCF36-48A5-44A0-9982-E9304933A13E} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473 => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [2016-08-12] (Intel Corporation)
      Task: {2C62DFD5-E3F3-4792-A77C-0E863B4F459A} - \Microsoft\Windows\Setup\gwx\refreshgwxconfig → No File <==== ATTENTION
      Task: {2E65BEF9-5870-433F-9530-1A0013F27E5A} - System32\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001 => C:\Users\papeter\AppData\Local\Citrix\GoToMeeting\ 5530\g2mupdate.exe [2016-09-03] (Citrix Online, a division of Citrix Systems, Inc.)
      Task: {352E6CA0-7314-4DF4-89C4-682368D80D57} - System32\Tasks\Microsoft\Windows\Workplace Join\Automatic-Workplace-Join => C:\WINDOWS\System32\AutoWorkplace.exe
      Task: {3D3E30EB-E7EF-4BE0-8D55-E6A74DE09768} - System32\Tasks\Lenovo\Dependency Package Auto Update => C:\Program Files\Lenovo\iMController\AutoUpdate.exe [2014-05-22] ()
      Task: {41DCBCE3-523C-42DA-885D-FC7FF5DE288E} - System32\Tasks\AdobeAAMUpdater-1.0-Lenovo-PC-papeter => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.e xe [2015-07-29] (Adobe Systems Incorporated)
      Task: {423E7DA8-EB68-4D8D-B787-5077D4FF57E8} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2017-09-20] (Piriform Ltd)
      Task: {49C8F6D1-2C7B-4487-9026-F844DD98BDA1} - \Microsoft\Windows\Setup\gwx\refreshgwxcontent → No File <==== ATTENTION
      Task: {4D7836E4-60B1-4C23-B881-64EDEE40C12B} - System32\Tasks\Microsoft\Office\OfficeBackgroundTa skHandlerRegistration => C:\Program Files (x86)\Microsoft Office\root\Office16\officebackgroundtaskhandler.e xe [2017-09-15] ()
      Task: {656777A4-8F1C-404A-B82D-846913804747} - \Microsoft\Windows\Setup\GWXTriggers\refreshgwxcon fig-B → No File <==== ATTENTION
      Task: {677EC76F-5F1E-4B88-9EB4-895656CEA55A} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-10-28] (Google Inc.)
      Task: {705EAAAA-87FA-43D0-977E-45C77F6A18BF} - \Microsoft\Windows\Setup\GWXTriggers\Telemetry-4xd → No File <==== ATTENTION
      Task: {81EF1F8A-693D-421D-A6C7-CABAEE21D915} - System32\Tasks\Lenovo\Lenovo Customer Feedback Program 64 35 => C:\Program Files (x86)\Lenovo\Customer Feedback Program 35\Lenovo.TVT.CustomerFeedback.Agent35.exe [2014-05-30] (Lenovo)
      Task: {84918C9D-6ED4-46B6-8A5E-5F9FCB2C3162} - \Microsoft\Windows\Setup\GWXTriggers\Logon-5d → No File <==== ATTENTION
      Task: {849DFEF6-B702-4152-BC80-E4F579623C1A} - System32\Tasks\Adobe Flash Player Updater => C:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpda teService.exe [2017-09-13] (Adobe Systems Incorporated)
      Task: {994AF2EC-1CDC-4CB9-A379-995ED417AB25} - System32\Tasks\Microsoft\Office\Office Automatic Updates => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2017-09-08] (Microsoft Corporation)
      Task: {9B7176A0-ED5C-47E9-9F4E-3E285610B8A6} - System32\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001 => C:\Users\papeter\AppData\Local\Citrix\GoToMeeting\ 5530\g2mupload.exe [2016-09-03] (Citrix Online, a division of Citrix Systems, Inc.)
      Task: {9F63AB90-3171-400B-BA8A-410C5A09104F} - System32\Tasks\Microsoft\Office\Office Subscription Maintenance => C:\Program Files (x86)\Microsoft Office\root\vfs\ProgramFilesCommonx86\Microsoft Shared\Office16\OLicenseHeartbeat.exe [2017-09-15] (Microsoft Corporation)
      Task: {B5C5E4AF-7018-4583-83D2-89C4CFDE7147} - \Microsoft\Windows\Setup\GWXTriggers\Time-5d → No File <==== ATTENTION
      Task: {BB30997D-E801-4BD3-874C-7D6099EFE8D0} - System32\Tasks\HMA! Pro VPN Update => C:\Program Files (x86)\HMA! Pro VPN\VpnUpdate.exe [2017-09-13] (AVAST Software)
      Task: {C0FD436D-2E37-4DA0-B6A4-7D82B82D4544} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-10-28] (Google Inc.)
      Task: {C3991814-F472-431F-AAED-63E5B65E7BFD} - \Microsoft\Windows\Setup\gwx\launchtrayprocess → No File <==== ATTENTION
      Task: {CBBBB535-A971-4790-9F7F-1C6475FAADE4} - \Microsoft\Windows\Setup\GWXTriggers\OutOfSleep-5d → No File <==== ATTENTION
      Task: {CBF4A7BB-07E0-4F39-9264-71BF6C2BEC0D} - \Microsoft\Windows\Setup\GWXTriggers\OutOfIdle-5d → No File <==== ATTENTION
      Task: {CE8370B7-FF42-4C72-A77B-CD159741128F} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [2016-08-12] (Intel Corporation)
      Task: {E28DA3B9-7390-471A-9CA0-A95E4459FB78} - \WPD\SqmUpload_S-1-5-21-4237603079-860989819-990887440-1001 → No File <==== ATTENTION
      Task: {E43D00D7-2103-4F2D-B3A9-0AC342A4289E} - System32\Tasks\Microsoft\Office\Office ClickToRun Service Monitor => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2017-09-08] (Microsoft Corporation)
      Task: {E4DB69B8-2AA6-440B-911A-A9BA95247085} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2017-07-19] (Adobe Systems Incorporated)
      Task: {EC1A298C-94C0-458F-B031-43BB8556CF8D} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA1d257e73535f0dd => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe [2016-07-09] (Google Inc.)
      Task: {EF34F3B6-CEFC-4193-A7AA-86535DABD808} - System32\Tasks\Microsoft\Windows\RemovalTools\MRT_ HB => C:\WINDOWS\system32\MRT.exe [2017-09-13] (Microsoft Corporation)
      Task: {F7666DCF-AA1D-4BD5-905F-C8C2B58F265D} - System32\Tasks\Microsoft\Office\OfficeBackgroundTa skHandlerLogon => C:\Program Files (x86)\Microsoft Office\root\Office16\officebackgroundtaskhandler.e xe [2017-09-15] ()
      Task: {FB7DCF66-3B0D-4256-B23F-6A0D8452518E} - System32\Tasks\PDVDServ Task => C:\Program Files (x86)\Lenovo\PowerDVD10\PDVD10Serv.EXE [2013-03-09] (CyberLink Corp.)
      Task: {FCDA2712-8ABB-4D56-B1F5-EBFAD897E31B} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe [2016-07-09] (Google Inc.)
      Task: C:\WINDOWS\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001.job => C:\Users\papeter\AppData\Local\GoToMeeting\7586\g2 mupdate.exe
      Task: C:\WINDOWS\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001.job => C:\Users\papeter\AppData\Local\GoToMeeting\7586\g2 mupload.exe
      Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core.job => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe
      Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA.job => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe
      ShortcutWithArgument: C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Chrome Apps\Pocket.lnk → C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) → --profile-directory=Default --app-id=mjcnijlhddpbdemagnpefmlkjdagkogk
      2016-11-17 02:28 - 2016-11-17 02:28 - 000092472 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
      2017-05-09 00:44 - 2017-05-09 00:44 - 001354040 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
      2017-07-26 08:58 - 2017-07-26 08:58 - 000192200 _____ () C:\Program Files (x86)\HiSuite\HandSetService\HuaweiHiSuiteService6 4.exe
      2015-02-05 23:52 - 2012-04-24 11:43 - 000390632 ____N () C:\Program Files\CyberLink\Shared files\RichVideo64.exe
      2016-05-19 15:26 - 2015-11-09 13:40 - 000253528 _____ () C:\Program Files (x86)\Canon\IJPLM\IJPLMSVC.EXE
      2015-02-05 23:58 - 2015-02-05 23:57 - 000133440 _____ () C:\Program Files\Lenovo PhoneCompanion\LPAWDService.exe
      2015-02-05 23:58 - 2015-02-05 23:57 - 000815104 _____ () C:\Program Files\Lenovo PhoneCompanion\adb.exe
      2017-07-06 11:22 - 2017-07-06 11:22 - 000331264 _____ () C:\Program Files (x86)\ExpressVPN\bootstrap\AMD64\nssm.exe
      2017-07-06 11:24 - 2017-07-06 11:24 - 009239168 _____ () C:\Program Files (x86)\ExpressVPN\xvpnd\xvpnd.exe
      2017-09-21 12:54 - 2016-12-29 14:16 - 000134712 _____ () C:\Program Files\NVIDIA Corporation\Display\NvSmartMax64.dll
      2017-03-18 21:58 - 2017-03-18 21:58 - 000138000 _____ () C:\WINDOWS\SYSTEM32\inputhost.dll
      2017-05-26 05:11 - 2017-05-26 05:11 - 000401840 _____ () C:\WINDOWS\system32\igfxTray.exe
      2016-03-15 23:47 - 2017-09-15 21:43 - 008929480 _____ () C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\1033\GrooveIntlResource.dll
      2017-03-18 21:59 - 2017-03-19 03:31 - 001731072 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\Cortana.Core.dll
      2015-02-05 23:06 - 2010-10-26 05:40 - 000049056 _____ () C:\Program Files\CONEXANT\ForteConfig\fmapp.exe
      2015-02-05 23:48 - 2015-02-05 23:48 - 000097048 _____ () C:\Program Files\Lenovo\LenovoUtility\kbdhook.dll
      2017-05-09 03:05 - 2017-05-09 03:05 - 000092472 _____ () C:\Program Files\iTunes\zlib1.dll
      2017-05-09 03:05 - 2017-05-09 03:05 - 001354040 _____ () C:\Program Files\iTunes\libxml2.dll
      2017-04-07 08:41 - 2017-04-07 08:41 - 000054488 _____ () C:\Program Files\CCleaner\branding.dll
      2017-08-23 10:16 - 2017-09-22 16:40 - 024502272 _____ () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17072.131 11.0_x64__8wekyb3d8bbwe\Video.UI.exe
      2017-08-23 10:16 - 2017-09-22 16:40 - 009145344 _____ () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17072.131 11.0_x64__8wekyb3d8bbwe\EntCommon.dll
      2017-08-15 13:32 - 2017-08-15 13:32 - 003544488 _____ () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17072.131 11.0_x64__8wekyb3d8bbwe\Microsoft.UI.Xaml.dll
      2017-08-23 10:16 - 2017-09-22 16:40 - 011159040 _____ () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17072.131 11.0_x64__8wekyb3d8bbwe\EntPlat.dll
      2017-09-15 19:15 - 2017-09-15 19:15 - 001226440 _____ () C:\Program Files\WindowsApps\microsoft.windowscommunicationsa pps_17.8500.40885.0_x64__8wekyb3d8bbwe\Office.UI.X aml.Word.dll
      2017-09-14 09:15 - 2017-09-14 09:15 - 003553704 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\Microsoft.UI.Xaml.dll
      2017-09-24 11:01 - 2017-09-24 11:07 - 010634752 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\WinStore.Entertainment.M obile.dll
      2017-09-24 11:01 - 2017-09-24 11:07 - 002640896 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\MS.Entertainment.Common. Mobile.dll
      2016-06-28 00:19 - 2016-06-28 00:19 - 000865232 _____ () C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\kpcengine.2.3.dll
      2015-02-05 23:54 - 2014-03-24 23:44 - 000387984 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\fl_core.dll
      2015-02-05 23:54 - 2014-03-24 23:44 - 000229264 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\sdxg.dll
      2015-02-05 23:54 - 2014-03-24 23:44 - 000199056 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_base.dll
      2015-02-05 23:54 - 2014-03-24 23:44 - 001165712 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_asr.dll
      2015-02-05 23:54 - 2014-03-24 23:44 - 001132944 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_pron.dll
      2015-02-05 23:54 - 2014-03-24 23:44 - 000035216 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_platform.dll
      2017-09-13 18:59 - 2017-09-13 18:59 - 000057968 _____ () C:\Program Files (x86)\HMA! Pro VPN\module_lifetime.dll
      2017-09-13 18:59 - 2017-09-13 18:59 - 000240264 _____ () C:\Program Files (x86)\HMA! Pro VPN\tasks_core.dll
      2017-09-13 18:59 - 2017-09-13 18:59 - 000147928 _____ () C:\Program Files (x86)\HMA! Pro VPN\network_notifications.dll
      2017-09-13 18:59 - 2017-09-13 18:59 - 000084384 _____ () C:\Program Files (x86)\HMA! Pro VPN\WinUtils.dll
      2017-09-13 18:59 - 2017-09-13 18:59 - 000210776 _____ () C:\Program Files (x86)\HMA! Pro VPN\event_routing_rpc.dll
      2014-09-03 20:03 - 2014-09-03 20:03 - 001241560 _____ () C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\ACE.dll
      2017-07-06 11:25 - 2017-07-06 11:25 - 000441472 _____ () C:\Program Files (x86)\ExpressVPN\xvpnd\windows\ExpressVPN.FilterMa nager.dll
      2016-04-08 23:35 - 2016-04-08 23:35 - 003481600 _____ () C:\Users\papeter\AppData\Local\Programs\Google\Goo gle Photos Backup\gpuploader_i18n.dll
      2014-12-22 10:03 - 2014-12-22 10:03 - 000122880 _____ () C:\Program Files (x86)\NETGEAR\WNDA3100v3\Ralink.dll
      2012-11-21 18:26 - 2012-11-21 18:26 - 001204224 _____ () C:\Program Files (x86)\NETGEAR\WNDA3100v3\RaWLAPI.dll
      2015-02-05 23:23 - 2015-01-22 19:18 - 002201088 _____ () C:\Program Files\Lenovo\Communications Utility\cxcore210.dll
      2015-02-05 23:23 - 2015-01-22 19:18 - 002085888 _____ () C:\Program Files\Lenovo\Communications Utility\cv210.dll
      2016-03-15 23:47 - 2017-09-15 19:13 - 001009864 _____ () C:\Program Files (x86)\Microsoft Office\Root\Office16\ADDINS\UmOutlookAddin.dll
      2013-08-22 14:25 - 2013-08-22 14:25 - 000000824 _____ C:\WINDOWS\system32\Drivers\etc\hosts
      HKU\S-1-5-21-4237603079-860989819-990887440-1001\Control Panel\Desktop\Wallpaper → c:\windows\web\wallpaper\theme1\img1.jpg
      DNS Servers: 192.168.1.1
      HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\System => (ConsentPromptBehaviorAdmin: 5) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
      HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer => (SmartScreenEnabled: RequireAdmin)
      Windows Firewall is enabled.
      FirewallRules: [{0851DF0D-788A-4DBF-BAE1-58EDF750A7E3}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
      FirewallRules: [{DCA0D126-14AF-4A5D-87BC-81873A537E0B}] => (Allow) C:\Program Files (x86)\Microsoft Office\root\Office16\outlook.exe
      FirewallRules: [{6AAD4B02-0AA9-4E42-96E8-41C5935BEC8A}] => (Allow) C:\Program Files\iTunes\iTunes.exe
      FirewallRules: [{6DB766FF-BB4B-4C73-9D8C-A92EFDBD00E6}] => (Allow) C:\Program Files (x86)\Bonjour\mDNSResponder.exe
      FirewallRules: [{C0BE10F4-12B3-47CD-9C73-1728CE89589F}] => (Allow) C:\Program Files (x86)\Bonjour\mDNSResponder.exe
      FirewallRules: [{07906379-64D9-4D27-92C8-A7F73C3F5533}] => (Allow) C:\Program Files\Bonjour\mDNSResponder.exe
      FirewallRules: [{91366BBD-0523-405B-815B-CB9017BF8CC1}] => (Allow) C:\Program Files\Bonjour\mDNSResponder.exe
      FirewallRules: [{937E5BA2-C0DF-427D-8F8A-22791E81899B}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
      FirewallRules: [{C538B0C6-4DE1-4521-BEDF-FF966F02435A}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
      FirewallRules: [{946DD1A7-4F09-4EA9-976E-BB7BF9E7830E}] => (Allow) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
      FirewallRules: [{DEB7BDCE-9DF5-40AD-80BE-9D2654935719}] => (Allow) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
      FirewallRules: [{99C246BD-C5F0-4247-9336-8711F6D59034}] => (Allow) C:\Program Files\CyberLink\PowerDirector10\PDR10.EXE
      FirewallRules: [{C4BAEBAB-409B-48CC-ADD0-56AEF4244F9E}] => (Allow) C:\Program Files (x86)\Lenovo\PowerDVD10\PowerDVD Cinema\PowerDVDCinema10.exe
      FirewallRules: [{7105BF1E-47DA-4881-A0A0-0B133CFAF24C}] => (Allow) C:\Program Files (x86)\Lenovo\PowerDVD10\PowerDVD10.EXE
      FirewallRules: [{AAF332D1-5A20-4893-AEF1-3638E32D54D1}] => (Allow) C:\Program Files\Lenovo PhoneCompanion\LPAWDService.exe
      FirewallRules: [{21B971F8-D555-46F8-A58D-C5B6B6B4DAC2}] => (Allow) C:\Program Files\Lenovo PhoneCompanion\LPAWDService.exe
      FirewallRules: [{C1E9968D-0BEB-4CE0-B192-78BCD30E96B6}] => (Allow) LPort=55100
      FirewallRules: [{EFB666FF-BC02-4248-9E8D-84AC44260B83}] => (Allow) C:\Program Files\Lenovo PhotoMasterImport\PhotoMasterImport.exe
      FirewallRules: [{BEF637D7-4EC6-404F-A968-91532518EC75}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
      FirewallRules: [{4EEFDDB8-E20B-41B2-97DD-2790077AA4E2}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
      FirewallRules: [{25DCEF18-32BC-40CA-A52F-28C1B4D6330C}] => (Allow) C:\Users\papeter\AppData\Local\Microsoft\OneDrive\ OneDrive.exe
      21-09-2017 16:04:34 Windows Update
      Name: ExpressVPN Tap Adapter
      Description: ExpressVPN Tap Adapter
      Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
      Manufacturer: ExpressVPN
      Service: tapexpressvpn
      Problem: : This device is disabled. (Code 22)
      Resolution: In Device Manager, click “Action”, and then click “Enable Device”. This starts the Enable Device wizard. Follow the instructions.
      Error: (09/26/2017 05:52:51 PM) (Source: lupdate) (EventID: 0) (User: )
      Description: Event-ID 0
      Error: (09/26/2017 05:35:03 PM) (Source: Bonjour Service) (EventID: 100) (User: )
      Description: Task Scheduling Error: m->NextScheduledSPRetry 2406
      Description: Task Scheduling Error: m->NextScheduledEvent 2406
      Description: Task Scheduling Error: Continuously busy for more than a second
      Error: (09/26/2017 05:35:02 PM) (Source: Bonjour Service) (EventID: 100) (User: )
      Description: Task Scheduling Error: m->NextScheduledSPRetry 1218
      Description: Task Scheduling Error: m->NextScheduledEvent 1218
      Error: (09/26/2017 04:33:01 PM) (Source: Microsoft-Windows-Immersive-Shell) (EventID: 2484) (User: Lenovo-PC)
      Description: Package Microsoft.Windows.Photos_2017.35071.16410.0_x64__8 wekyb3d8bbwe+App was terminated because it took too long to suspend.
      Error: (09/26/2017 03:44:02 PM) (Source: Microsoft-Windows-Immersive-Shell) (EventID: 5973) (User: Lenovo-PC)
      Description: Activation of app Microsoft.MicrosoftStickyNotes_8wekyb3d8bbwe!App failed with error: -2144927141 See the Microsoft-Windows-TWinUI/Operational log for additional information.
      Error: (09/26/2017 05:51:59 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
      and APPID
      to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
      Error: (09/26/2017 03:46:50 PM) (Source: DCOM) (EventID: 10010) (User: NT AUTHORITY)
      Description: The server {784E29F4-5EBE-4279-9948-1E8FE941646D} did not register with DCOM within the required timeout.
      Error: (09/26/2017 03:44:02 PM) (Source: DCOM) (EventID: 10010) (User: Lenovo-PC)
      Description: The server Microsoft.MicrosoftStickyNotes_1.8.0.0_x64__8wekyb 3d8bbwe!App did not register with DCOM within the required timeout.
      Error: (09/26/2017 03:43:49 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
      {6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}
      and APPID
      {4839DDB7-58C2-48F5-8283-E1D1807D0D7D}
      to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
      and APPID
      Error: (09/26/2017 11:54:34 AM) (Source: Service Control Manager) (EventID: 7034) (User: )
      Description: The MBAMService service terminated unexpectedly. It has done this 34 time(s).
      Error: (09/26/2017 11:54:18 AM) (Source: Service Control Manager) (EventID: 7034) (User: )
      Description: The MBAMService service terminated unexpectedly. It has done this 33 time(s).
      Error: (09/26/2017 11:50:37 AM) (Source: Service Control Manager) (EventID: 7034) (User: )
      Description: The MBAMService service terminated unexpectedly. It has done this 32 time(s).
      Error: (09/26/2017 11:50:35 AM) (Source: Service Control Manager) (EventID: 7006) (User: )
      Description: The ScRegSetValueExW call failed for Start with the following error:
      Access is denied.
      Access is denied.
      Date: 2017-09-24 23:29:45.253
      Description: Code Integrity determined that a process (\Device\HarddiskVolume5\Windows\SystemApps\Micros oft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.ex e) attempted to load \Device\HarddiskVolume5\Program Files (x86)\Malwarebytes Anti-Exploit\mbae64.dll that did not meet the Store signing level requirements.
      Date: 2017-09-24 23:29:44.932
      Date: 2017-09-24 23:24:52.589
      Date: 2017-09-24 22:57:51.735
      Date: 2017-09-24 22:57:51.435
      Date: 2017-09-24 22:57:50.849
      Date: 2017-09-24 22:57:50.482
      Date: 2017-09-24 22:49:06.129
      Date: 2017-09-24 22:48:39.626
      Date: 2017-09-23 16:15:51.184
      Processor: Intel(R) Core™ i7-5500U CPU @ 2.40GHz
      Percentage of memory in use: 25%
      Total physical RAM: 16299.08 MB
      Available physical RAM: 12073.21 MB
      Total Virtual: 19243.08 MB
      Available Virtual: 14372.52 MB
      Drive c: (Windows8_OS) (Fixed) (Total:888.7 GB) (Free:407.88 GB) NTFS ==>[system with boot components (obtained from drive)]
      Drive d: (LENOVO) (Fixed) (Total:25 GB) (Free:22.68 GB) NTFS
      Disk: 0 (Size: 931.5 GB) (Disk ID: 12E6AA89)
      Partition: GPT.
      • papeter
        • Feb 2017
        • 33
        These are the FRST.txt log files:
        Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 25-09-2017 01
        Ran by papeter (administrator) on LENOVO-PC (26-09-2017 18:16:06)
        Loaded Profiles: papeter (Available Profiles: papeter)
        Platform: Windows 10 Home Version 1703 (X64) Language: English (United States)
        Internet Explorer Version 11 (Default browser: FF)
        Boot Mode: Normal
        Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic...ery-scan-tool/
        (Intel Corporation) C:\Windows\System32\igfxCUIService.exe
        (Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
        (Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
        (ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDService.exe
        (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\avp.exe
        (Broadcom Corporation.) C:\Windows\System32\BtwRSupportService.exe
        (Conexant Systems Inc.) C:\Windows\System32\CxAudMsg64.exe
        (Lenovo(beijing) Limited) C:\Windows\System32\LenovoWiFiHotspotSvr.exe
        (LENOVO INCORPORATED.) C:\Program Files\Lenovo\iMController\SystemAgentService.exe
        (Malwarebytes Corporation) C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae-svc.exe
        (Lenovo Corporation) C:\Program Files\Lenovo\Communications Utility\AVControlCenter32.exe
        (NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
        () C:\Program Files (x86)\Canon\IJPLM\ijplmsvc.exe
        (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe
        (Nuance Communications, Inc.) C:\Program Files (x86)\Nuance\Dragon Assistant\Core\DACore.exe
        (Lenovo(beijing) Limited) C:\Program Files (x86)\Lenovo\Lenovo Settings\x86\LenovoSetSvr.exe
        (Lenovo Group Limited) C:\Program Files\Lenovo\SettingsDependency\SettingsService.ex e
        (AVAST Software) C:\Program Files (x86)\HMA! Pro VPN\vpnsvc.exe
        (Lenovo) C:\Program Files\Lenovo PhoneCompanion\PhoneCompanionPusher.exe
        (Lenovo) C:\Windows\System32\LenovoUpdate.exe
        (Malwarebytes Corporation) C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae64.exe
        (Microsoft Corporation) C:\Windows\Microsoft.NET\Framework64\v3.0\WPF\Pres entationFontCache.exe
        (Google Inc.) C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler.ex e
        (Google Inc.) C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler64. exe
        (Adobe Systems Incorporated) C:\Program Files\Adobe\Elements 14 Organizer\PhotoshopElementsFileAgent.exe
        (Apple Inc.) C:\Program Files\iPod\bin\iPodService.exe
        (Microsoft Corporation) C:\Program Files\Common Files\microsoft shared\ClickToRun\OfficeClickToRun.exe
        (Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
        (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\FWService\IntelMeFWService.exe
        (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
        (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Secure Connection 1.0\ksde.exe
        (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
        (Microsoft Corporation) C:\Windows\SysWOW64\wbem\WmiPrvSE.exe
        (Malwarebytes) C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe
        (Google, Inc) C:\Users\papeter\AppData\Local\Programs\Google\Goo gle Photos Backup\Google Photos Backup.exe
        (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe
        (ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrl.exe
        (Lenovo Corporation) C:\Program Files\Lenovo\Communications Utility\avfaudiosw.exe
        (Intel Corporation) C:\Windows\System32\igfxEM.exe
        (Intel Corporation) C:\Windows\System32\igfxHK.exe
        () C:\Windows\System32\igfxTray.exe
        (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\avpui.exe
        (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Secure Connection 1.0\ksdeui.exe
        (ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrlHelper.exe
        (CyberLink Corp.) C:\Program Files (x86)\Lenovo\PowerDVD10\PDVD10Serv.exe
        (Microsoft Corporation) C:\Program Files\Windows Defender\MSASCuiL.exe
        (Realtek semiconductor) C:\Windows\RTFTrack.exe
        (NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe
        (Conexant Systems, Inc.) C:\Program Files\CONEXANT\cAudioFilterAgent\CAudioFilterAgent 64.exe
        (Lenovo(beijing) Limited) C:\Program Files\Lenovo\LenovoUtility\utility.exe
        (Lenovo) C:\Program Files\Lenovo PhoneCompanion\Phone Companion.exe
        (Apple Inc.) C:\Program Files\iTunes\iTunesHelper.exe
        (Piriform Ltd) C:\Program Files\CCleaner\CCleaner64.exe
        (ExpressVPN) C:\Program Files (x86)\ExpressVPN\xvpn-ui\ExpressVpn.exe
        (NETGEAR) C:\Program Files (x86)\NETGEAR\WNDA3100v3\WNDA3100v3.EXE
        (Microsoft Corporation) C:\Program Files (x86)\Microsoft Office\root\Office16\ONENOTEM.EXE
        (Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
        (Lenovo) C:\Users\papeter\AppData\Local\Apps\2.0\GK031YKB.Q 3Y\K26QGK1L.NK8\lsb…tion_2d7b41b05b24775e_0001.000 6_6c5982beb50abfca\LSB.exe
        (Lenovo Corporation) C:\Program Files\Lenovo\Communications Utility\tpknrres.exe
        (Microsoft Corporation) C:\Windows\System32\InstallAgent.exe
        (Microsoft Corporation) C:\Program Files\WindowsApps\microsoft.windowscommunicationsa pps_17.8500.40885.0_x64__8wekyb3d8bbwe\HxOutlook.e xe
        (Microsoft Corporation) C:\Program Files\WindowsApps\microsoft.windowscommunicationsa pps_17.8500.40885.0_x64__8wekyb3d8bbwe\HxTsr.exe
        (Microsoft Corporation) C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\WinStore.App.exe
        (Mozilla Corporation) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
        (Lenovo Corporation) C:\Program Files\Lenovo\Communications Utility\vcamsvc.exe
        (Lenovo Corporation) C:\Program Files\Lenovo\Communications Utility\cammute.exe
        (Lenovo Group Limited) C:\Program Files\Lenovo\Communications Utility\tpknrsvc.exe
        (Lenovo Corporation) C:\Program Files\Lenovo\Communications Utility\vcamsvchlpr.exe
        (Microsoft Corporation) C:\Program Files (x86)\Microsoft Office\root\Office16\OUTLOOK.EXE
        (Microsoft Corporation) C:\Program Files\Internet Explorer\iexplore.exe
        (Microsoft Corporation) C:\Windows\System32\wlanext.exe
        ==================== Registry (Whitelisted) ===========================
        HKLM...\Run: [SecurityHealth] => C:\Program Files\Windows Defender\MSASCuiL.exe [629152 2017-03-18] (Microsoft Corporation)
        HKLM...\Run: [ETDCtrl] => C:\Program Files\Elantech\ETDCtrl.exe [3242696 2015-10-07] (ELAN Microelectronics Corp.)
        HKLM...\Run: [RtsFT] => C:\WINDOWS\RTFTrack.exe [5060864 2015-06-16] (Realtek semiconductor)
        HKLM...\Run: [NvBackend] => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe [2473800 2014-09-09] (NVIDIA Corporation)
        HKLM...\Run: [IAStorIcon] => C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe [320360 2014-06-25] (Intel Corporation)
        HKLM...\Run: [ForteConfig] => C:\Program Files\Conexant\ForteConfig\fmapp.exe [49056 2010-10-26] ()
        HKLM...\Run: [SmartAudio] => C:\Program Files\CONEXANT\SAII\SACpl.exe [1830616 2014-04-10] (Conexant Systems, Inc.)
        HKLM...\Run: [cAudioFilterAgent] => C:\Program Files\Conexant\cAudioFilterAgent\cAudioFilterAgent 64.exe [916184 2014-07-03] (Conexant Systems, Inc.)
        HKLM...\Run: [LenovoUtility] => C:\Program Files\Lenovo\LenovoUtility\utility.exe [10828056 2015-02-05] (Lenovo(beijing) Limited)
        HKLM...\Run: [PhoneCompanion] => C:\Program Files\Lenovo PhoneCompanion\Phone Companion.exe [802800 2015-02-05] (Lenovo)
        HKLM...\Run: [LMCSSTART1] => C:\Program Files\Lenovo\Communications Utility\lmcsctrl.exe [30152 2015-03-23] (Lenovo Corporation)
        HKLM...\Run: [LMCSSTART2] => C:\Program Files\Lenovo\Communications Utility\lmcsctrl.exe [30152 2015-03-23] (Lenovo Corporation)
        HKLM...\Run: [LMCSSTART3] => C:\Program Files\Lenovo\Communications Utility\lmcsctrl.exe [30152 2015-03-23] (Lenovo Corporation)
        HKLM...\Run: [AdobeAAMUpdater-1.0] => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.e xe [508104 2015-07-29] (Adobe Systems Incorporated)
        HKLM...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [303928 2017-05-09] (Apple Inc.)
        HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [CCleaner Monitoring] => C:\Program Files\CCleaner\CCleaner64.exe [9856176 2017-09-20] (Piriform Ltd)
        HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [Google Update] => C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\GoogleUpdateCore.exe [601168 2017-04-29] (Google Inc.)
        HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [Google Photos Backup] => C:\Users\papeter\AppData\Local\Programs\Google\Goo gle Photos Backup\Google Photos Backup.exe [3790936 2016-04-08] (Google, Inc)
        HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [ExpressVPN4] => C:\Program Files (x86)\ExpressVPN\xvpn-ui\ExpressVpn.exe [806528 2017-07-06] (ExpressVPN)
        HKU\S-1-5-21-4237603079-860989819-990887440-1001...\MountPoints2: {265574b1-9573-11e7-8309-38b1dbdbd186} - “F:\HiSuiteDownLoader.exe”
        Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\NETGEAR WNDA3100v3 Genie.lnk [2017-03-27]
        ShortcutTarget: NETGEAR WNDA3100v3 Genie.lnk → C:\Program Files (x86)\NETGEAR\WNDA3100v3\WNDA3100v3.EXE (NETGEAR)
        Startup: C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Startup\Send to OneNote.lnk [2017-08-21]
        ShortcutTarget: Send to OneNote.lnk → C:\Program Files (x86)\Microsoft Office\root\Office16\ONENOTEM.EXE (Microsoft Corporation)
        Tcpip..\Interfaces{43520b0a-4f6b-4271-bd91-0e94ebbbdbff}: [DhcpNameServer] 62.24.243.4 62.24.128.198
        Tcpip..\Interfaces{776a1195-9cf2-49ea-962f-fbed2f21c1fd}: [DhcpNameServer] 8.8.8.8 8.8.4.4
        Tcpip..\Interfaces{8a951e76-1a52-472e-b275-8e344bcfc594}: [DhcpNameServer] 192.168.1.1
        Tcpip..\Interfaces{9c0c9f0b-e558-47dd-84e5-2b139e86df58}: [DhcpNameServer] 10.163.0.1
        Tcpip..\Interfaces{c395cc9b-863d-41bd-b910-9b8c72cc7e3e}: [NameServer] 77.234.40.79
        [HEADING=1]Internet Explorer:[/HEADING]
        HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
        HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = hxxp://lenovo13.msn.com/?pc=LCJB
        HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Internet Explorer\Main,Secondary Start Pages = hxxp://www.lenovo.com
        SearchScopes: HKU\S-1-5-21-4237603079-860989819-990887440-1001 → DefaultScope {51B4207A-1DF4-4AB6-AB39-7FAE55BB94B0} URL =
        SearchScopes: HKU\S-1-5-21-4237603079-860989819-990887440-1001 → {51B4207A-1DF4-4AB6-AB39-7FAE55BB94B0} URL =
        BHO: Kaspersky Protection → {2E38825B-8815-42CF-9126-C58BC28D4591} → C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
        BHO: Lync Browser Helper → {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} → C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\OCHelper.dll [2017-09-15] (Microsoft Corporation)
        BHO: Canon Easy-WebPrint EX BHO → {3785D0AD-BFFF-47F6-BF5B-A587C162FED9} → C:\Program Files\Canon\Easy-WebPrint EX\ewpexbho.dll [2015-02-23] (CANON INC.)
        BHO: Microsoft OneDrive for Business Browser Helper → {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} → C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\GROOVEEX.DLL [2017-09-15] (Microsoft Corporation)
        BHO-x32: Kaspersky Protection → {2E38825B-8815-42CF-9126-C58BC28D4591} → C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
        BHO-x32: Canon Easy-WebPrint EX BHO → {3785D0AD-BFFF-47F6-BF5B-A587C162FED9} → C:\Program Files (x86)\Canon\Easy-WebPrint EX\ewpexbho.dll [2015-02-23] (CANON INC.)
        Toolbar: HKLM - Canon Easy-WebPrint EX - {759D9886-0C6F-4498-BAB6-4A5F47C6C72F} - C:\Program Files\Canon\Easy-WebPrint EX\ewpexhlp.dll [2015-02-23] (CANON INC.)
        Toolbar: HKLM - Kaspersky Protection Toolbar - {093F479D-712E-46CD-9E06-62E734A05F68} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
        Toolbar: HKLM-x32 - Canon Easy-WebPrint EX - {759D9886-0C6F-4498-BAB6-4A5F47C6C72F} - C:\Program Files (x86)\Canon\Easy-WebPrint EX\ewpexhlp.dll [2015-02-23] (CANON INC.)
        Toolbar: HKLM-x32 - Kaspersky Protection Toolbar - {093F479D-712E-46CD-9E06-62E734A05F68} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
        Toolbar: HKU\S-1-5-21-4237603079-860989819-990887440-1001 → Kaspersky Protection Toolbar - {093F479D-712E-46CD-9E06-62E734A05F68} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
        Handler-x32: mso-minsb-roaming.16 - {83C25742-A9F7-49FB-9138-434302C88D07} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-15] (Microsoft Corporation)
        Handler-x32: mso-minsb.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-15] (Microsoft Corporation)
        Handler-x32: osf-roaming.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-15] (Microsoft Corporation)
        Handler-x32: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-15] (Microsoft Corporation)
        [HEADING=1]FireFox:[/HEADING]
        FF ProfilePath: C:\Users\papeter\AppData\Roaming\Mozilla\Firefox\P rofiles\ee8pm1a2.default-1446908155165 [2017-09-26]
        FF Extension: (Disable Hello, Pocket & Reader+) - C:\Users\papeter\AppData\Roaming\Mozilla\Firefox\P rofiles\ee8pm1a2.default-1446908155165\Extensions\NoTrash@Off.JustOff.xpi [2017-01-16]
        FF HKLM...\Firefox\Extensions: [light_plugin_F6F079488B53499DB99380A...asp ersky.com] - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\FFExt\light_plugin_firefox\addon.xpi
        FF Extension: (Kaspersky Protection) - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\FFExt\light_plugin_firefox\addon.xpi [2017-07-25]
        FF HKLM-x32...\Firefox\Extensions: [light_plugin_F6F079488B53499DB99380A...asp ersky.com] - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\FFExt\light_plugin_firefox\addon.xpi
        FF Plugin: @adobe.com/FlashPlayer → C:\WINDOWS\system32\Macromed\Flash\NPSWF64_27_0_0_ 130.dll [2017-09-13] ()
        FF Plugin: @Microsoft.com/NpCtrl,version=1.0 → c:\Program Files\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
        FF Plugin-x32: @adobe.com/FlashPlayer → C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_27_0_0_ 130.dll [2017-09-13] ()
        FF Plugin-x32: @canon.com/EPPEX → C:\Program Files (x86)\Canon\My Image Garden\AddOn\CIG\npmigfpi.dll [2011-11-30] (CANON INC.)
        FF Plugin-x32: @DVR/npmedia,version=3.1.0.4 → C:\Program Files\webrec\WEB30\DVR32\3.1.0.4\npmedia.dll [2014-05-10] ()
        FF Plugin-x32: @DVR/npTimeGrid,version=3.1.0.4 → C:\Program Files\webrec\WEB30\DVR32\3.1.0.4\npTimeGrid.dll [2014-05-10] (Unauthorized copy)
        FF Plugin-x32: @google.com/npPicasa3,version=3.0.0 → C:\Program Files (x86)\Google\Picasa3\npPicasa3.dll [2015-10-13] (Google, Inc.)
        FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI ipt;version=4.0.56 → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIIPT.dll [2014-09-03] (Intel Corporation)
        FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI updater → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIUpdater.dll [2014-09-03] (Intel Corporation)
        FF Plugin-x32: @Microsoft.com/NpCtrl,version=1.0 → c:\Program Files (x86)\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
        FF Plugin-x32: @microsoft.com/SharePoint,version=14.0 → C:\Program Files (x86)\Microsoft Office\root\Office16\NPSPWRAP.DLL [2017-09-15] (Microsoft Corporation)
        FF Plugin-x32: @Sibelius.com/Scorch Plugin,version=6.2.0.88 → C:\Program Files (x86)\Sibelius Software\Scorch\npsibelius.dll [2013-03-11] ()
        FF Plugin-x32: @tools.google.com/Google Update;version=3 → C:\Program Files (x86)\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-04-28] (Google Inc.)
        FF Plugin-x32: @tools.google.com/Google Update;version=9 → C:\Program Files (x86)\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-04-28] (Google Inc.)
        FF Plugin-x32: @videolan.org/vlc,version=2.2.1 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2017-05-24] (VideoLAN)
        FF Plugin-x32: @videolan.org/vlc,version=2.2.4 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2017-05-24] (VideoLAN)
        FF Plugin-x32: @videolan.org/vlc,version=2.2.6 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2017-05-24] (VideoLAN)
        FF Plugin-x32: Adobe Reader → C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AIR\nppdf32.dll [2017-08-10] (Adobe Systems Inc.)
        FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: @tools.google.com/Google Update;version=3 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\npGoogleUpdate3.dll [2017-04-29] (Google Inc.)
        FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: @tools.google.com/Google Update;version=9 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\npGoogleUpdate3.dll [2017-04-29] (Google Inc.)
        FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: @zoom.us/ZoomVideoPlugin → C:\Users\papeter\AppData\Roaming\Zoom\bin\npzoompl ugin.dll [2017-06-21] (Zoom Video Communications, Inc.)
        FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: SkypePlugin → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\npGatewayNpapi.dll [2016-09-01] (Skype Technologies S.A.)
        FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: SkypePlugin64 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\npGatewayNpapi-x64.dll [2016-09-01] (Skype Technologies S.A.)
        FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\nppdf32.dll [2017-08-10] (Adobe Systems Inc.)
        FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\NPSibelius.dll [2013-03-11] ()
        FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\PDFNetC.dll [2010-03-31] (PDFTron Systems Inc.)
        FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\ScorchAxPlugin.dll [2010-04-08] ()
        FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\ScorchPDFWrapper.dll [2010-04-08] ()
        [HEADING=1]Chrome:[/HEADING]
        CHR DefaultProfile: Default
        CHR DefaultSearchURL: Default → hxxps://www.google.com/search?q={searchTerms}&ie=utf-8&oe=utf-8&aq=t&q={searchTerms}&ie=utf-8&oe=utf-8&aq=t&channel=fflb&q={searchTerms}&ie=utf-8&oe=utf-8&aq=t&channel=rcs
        CHR DefaultSuggestURL: Default → hxxps://www.google.com/complete/search?q={searchTerms}
        CHR Profile: C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default [2017-09-26]
        CHR Extension: (Google Slides) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhon fmgoek [2015-10-30]
        CHR Extension: (Sizable Send) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\abpoebooacbankjejohknechpi feimmi [2015-10-30]
        CHR Extension: (Google Docs) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfi lokake [2015-10-30]
        CHR Extension: (Google Drive) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigk jlhalf [2015-10-30]
        CHR Extension: (YouTube) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldk acnbeo [2015-10-30]
        CHR Extension: (Google Search) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\coobgpohoikkiipiblmjeljnie djpjpf [2015-10-30]
        CHR Extension: (Google Sheets) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpeb giejap [2015-10-30]
        CHR Extension: (Kaspersky Protection) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\fhoibnponjcgjgcnfacekaijdb bplhib [2017-02-07]
        CHR Extension: (Google Docs Offline) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdl olhkhi [2016-04-04]
        CHR Extension: (Pocket) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\mjcnijlhddpbdemagnpefmlkjd agkogk [2017-01-16]
        CHR Extension: (Ghostery) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\mlomiejdfkolichcflejclcbmp eaniij [2017-09-03]
        CHR Extension: (Chrome Web Store Payments) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccm gmieda [2017-09-03]
        CHR Extension: (SEO for Chrome) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\oangcciaeihlfmhppegpdceadp faoclj [2015-10-30]
        CHR Extension: (Gmail) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoe jaedia [2015-10-30]
        CHR Extension: (Chrome Media Router) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcj beemfm [2017-08-16]
        CHR Profile: C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1 [2017-09-26]
        CHR Extension: (Google Slides) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2016-07-04]
        CHR Extension: (Google Docs) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\aohghmighlieiainnegkcijnfilokake [2016-07-04]
        CHR Extension: (Google Drive) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\apdfllckaahabafndbhieahigkjlhalf [2016-07-04]
        CHR Extension: (YouTube) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2016-07-04]
        CHR Extension: (Kaspersky Protection) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\eahebamiopdhefndnmappcihfajigkka [2016-07-04]
        CHR Extension: (Google Sheets) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2016-07-04]
        CHR Extension: (Google Docs Offline) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2016-07-04]
        CHR Extension: (Chrome Web Store Payments) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2016-07-04]
        CHR Extension: (Gmail) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2016-07-04]
        CHR Profile: C:\Users\papeter\AppData\Local\Google\Chrome\User Data\System Profile [2017-09-26]
        CHR HKLM...\Chrome\Extension: [fhoibnponjcgjgcnfacekaijdbbplhib] - hxxps://chrome.google.com/webstore/detail/fhoibnponjcgjgcnfacekaijdbbplhib
        CHR HKLM-x32...\Chrome\Extension: [efaidnbmnnnibpcajpcglclefindmkaj] - hxxps://clients2.google.com/service/update2/crx
        CHR HKLM-x32...\Chrome\Extension: [fhoibnponjcgjgcnfacekaijdbbplhib] - hxxps://chrome.google.com/webstore/detail/fhoibnponjcgjgcnfacekaijdbbplhib
        R2 AdobeActiveFileMonitor14.0; C:\Program Files\Adobe\Elements 14 Organizer\PhotoshopElementsFileAgent.exe [226016 2015-12-07] (Adobe Systems Incorporated)
        R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2017-04-03] (Apple Inc.)
        R2 AVControlCenter; C:\Program Files\Lenovo\Communications Utility\AVControlCenter32.exe [560584 2015-03-23] (Lenovo Corporation)
        R2 AVP17.0.0; C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\avp.exe [241544 2016-06-28] (AO Kaspersky Lab)
        R2 BcmBtRSupport; C:\WINDOWS\system32\BtwRSupportService.exe [2251992 2015-03-27] (Broadcom Corporation.)
        S2 CCSDK; C:\Program Files (x86)\Lenovo\CCSDK\CCSDK.exe [592880 2014-07-10] ()
        R2 ClickToRunSvc; C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe [4424392 2017-09-08] (Microsoft Corporation)
        R2 DACoreService; C:\Program Files (x86)\Nuance\Dragon Assistant\Core\DACore.exe [448400 2014-03-24] (Nuance Communications, Inc.)
        R2 ETDService; C:\Program Files\Elantech\ETDService.exe [144072 2015-10-07] (ELAN Microelectronics Corp.)
        R2 ExpressVpnService; C:\Program Files (x86)\ExpressVPN\bootstrap\AMD64\nssm.exe [331264 2017-07-06] () [File not signed]
        R2 HmaProVpn; C:\Program Files (x86)\HMA! Pro VPN\VpnSvc.exe [3568712 2017-09-13] (AVAST Software)
        R2 HuaweiHiSuiteService64.exe; C:\Program Files (x86)\HiSuite\HandSetService\HuaweiHiSuiteService6 4.exe [192200 2017-07-26] ()
        R2 IAStorDataMgrSvc; C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe [16232 2014-06-25] (Intel Corporation)
        R2 igfxCUIService2.0.0.0; C:\WINDOWS\system32\igfxCUIService.exe [373680 2017-05-26] (Intel Corporation)
        R2 IJPLMSVC; C:\Program Files (x86)\Canon\IJPLM\IJPLMSVC.EXE [253528 2015-11-09] ()
        S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [887256 2014-05-13] (Intel(R) Corporation)
        R2 Intel(R) ME Service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\FWService\IntelMeFWService.exe [131544 2014-09-03] (Intel Corporation)
        S3 iumsvc; C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [177376 2016-08-12] (Intel Corporation)
        R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [154584 2014-09-03] (Intel Corporation)
        S3 klvssbrigde64; C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\vssbridge64.exe [77328 2016-06-28] (AO Kaspersky Lab)
        R2 KSDE1.0.0; C:\Program Files (x86)\Kaspersky Lab\Kaspersky Secure Connection 1.0\ksde.exe [241544 2016-06-28] (AO Kaspersky Lab)
        R2 Lenovo Settings Service; C:\Program Files\Lenovo\SettingsDependency\SettingsService.ex e [2016040 2015-04-10] (Lenovo Group Limited)
        R2 Lenovo System Agent Service; C:\Program Files\Lenovo\iMController\SystemAgentService.exe [584960 2014-05-22] (LENOVO INCORPORATED.)
        R3 LENOVO.TVTVCAM; C:\Program Files\Lenovo\Communications Utility\vcamsvc.exe [625608 2015-03-23] (Lenovo Corporation)
        R2 LenovoPAWDService; C:\Program Files\Lenovo PhoneCompanion\LPAWDService.exe [133440 2015-02-05] ()
        R2 LenovoSetSvr; C:\Program Files (x86)\Lenovo\Lenovo Settings\x86\LenovoSetSvr.exe [258544 2014-06-19] (Lenovo(beijing) Limited)
        R3 LenovoUpdate; C:\WINDOWS\System32\LenovoUpdate.exe [26608 2017-09-24] (Lenovo)
        R2 LenovoWiFiHotspotSvr; C:\Windows\System32\LenovoWiFiHotspotSvr.exe [218952 2014-08-26] (Lenovo(beijing) Limited)
        R2 MbaeSvc; C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae-svc.exe [155080 2017-07-18] (Malwarebytes Corporation)
        R2 MBAMScheduler; C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe [1514464 2016-03-10] (Malwarebytes)
        S2 MBAMService; C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe [1136608 2016-03-10] (Malwarebytes)
        R2 NVDisplay.ContainerLocalSystem; C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe [458176 2016-12-29] (NVIDIA Corporation)
        R2 NvNetworkService; C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe [1795912 2014-09-09] (NVIDIA Corporation)
        R2 PhoneCompanionPusher; C:\Program Files\Lenovo PhoneCompanion\PhoneCompanionPusher.exe [321520 2015-02-05] (Lenovo)
        S3 PhoneCompanionVap; C:\Program Files\Lenovo PhoneCompanion\PhoneCompanionVap.exe [338416 2015-02-05] (Lenovo)
        R2 RichVideo64; C:\Program Files\CyberLink\Shared files\RichVideo64.exe [390632 2012-04-24] ()
        S3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [342264 2017-03-18] (Microsoft Corporation)
        S3 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [102816 2017-07-11] (Microsoft Corporation)
        R3 bcbtums; C:\WINDOWS\system32\drivers\bcbtums.sys [173312 2015-03-27] (Broadcom Corporation.)
        R3 BCM43XX; C:\WINDOWS\system32\DRIVERS\bcmwl63a.sys [7504560 2013-11-20] (Broadcom Corporation)
        R0 cm_km; C:\WINDOWS\System32\DRIVERS\cm_km.sys [238936 2016-06-10] (AO Kaspersky Lab)
        R1 ESProtectionDriver; C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae64.sys [77432 2017-07-18] ()
        S3 ew_usbccgpfilter; C:\WINDOWS\System32\drivers\ew_usbccgpfilter.sys [18944 2017-07-26] (Huawei Technologies Co., Ltd.)
        R3 hmatap; C:\WINDOWS\System32\drivers\hmatap.sys [27136 2016-09-01] (The OpenVPN Project)
        R0 kl1; C:\WINDOWS\System32\DRIVERS\kl1.sys [554416 2016-06-02] (AO Kaspersky Lab)
        R0 klbackupdisk; C:\WINDOWS\System32\DRIVERS\klbackupdisk.sys [63920 2016-06-07] (AO Kaspersky Lab)
        R1 klbackupflt; C:\WINDOWS\System32\DRIVERS\klbackupflt.sys [86352 2016-06-15] (AO Kaspersky Lab)
        R2 kldisk; C:\WINDOWS\system32\DRIVERS\kldisk.sys [78216 2016-05-31] (AO Kaspersky Lab)
        S0 klelam; C:\WINDOWS\System32\DRIVERS\klelam.sys [28792 2016-03-31] (AO Kaspersky Lab)
        R3 klflt; C:\WINDOWS\system32\DRIVERS\klflt.sys [197312 2017-07-25] (AO Kaspersky Lab)
        R1 klhk; C:\WINDOWS\System32\drivers\klhk.sys [520152 2017-07-25] (AO Kaspersky Lab)
        R3 klids; C:\ProgramData\Kaspersky Lab\AVP17.0.0\Bases\klids.sys [186696 2017-09-24] (AO Kaspersky Lab)
        R1 KLIF; C:\WINDOWS\System32\DRIVERS\klif.sys [1021624 2017-07-25] (AO Kaspersky Lab)
        R1 KLIM6; C:\WINDOWS\system32\DRIVERS\klim6.sys [57424 2017-09-21] (AO Kaspersky Lab)
        R3 klkbdflt; C:\WINDOWS\system32\DRIVERS\klkbdflt.sys [52136 2016-05-19] (AO Kaspersky Lab)
        R3 klmouflt; C:\WINDOWS\system32\DRIVERS\klmouflt.sys [41656 2015-06-07] (Kaspersky Lab ZAO)
        R1 klpd; C:\WINDOWS\System32\DRIVERS\klpd.sys [45488 2016-05-31] (AO Kaspersky Lab)
        R3 kltap; C:\WINDOWS\System32\drivers\kltap.sys [52152 2016-06-07] (The OpenVPN Project)
        R0 klupd_klif_arkmon; C:\WINDOWS\System32\Drivers\klupd_klif_arkmon.sys [229288 2017-07-04] (AO Kaspersky Lab)
        R3 klupd_klif_kimul; C:\WINDOWS\System32\Drivers\klupd_klif_kimul.sys [87584 2017-08-29] (AO Kaspersky Lab)
        R3 klupd_klif_klark; C:\WINDOWS\System32\Drivers\klupd_klif_klark.sys [251656 2017-07-12] (AO Kaspersky Lab)
        R0 klupd_klif_klbg; C:\WINDOWS\System32\Drivers\klupd_klif_klbg.sys [112912 2017-07-04] (AO Kaspersky Lab)
        R3 klupd_klif_mark; C:\WINDOWS\System32\Drivers\klupd_klif_mark.sys [173144 2017-07-12] (AO Kaspersky Lab)
        R1 klwfp; C:\WINDOWS\system32\DRIVERS\klwfp.sys [85320 2016-06-18] (AO Kaspersky Lab)
        R1 Klwtp; C:\WINDOWS\system32\DRIVERS\klwtp.sys [136416 2017-03-15] (AO Kaspersky Lab)
        R3 KMDFVirtualKbd; C:\WINDOWS\System32\drivers\KMDFVirtualKbd.sys [22264 2014-08-05] ()
        R3 KMDFVirtualMouse; C:\WINDOWS\System32\drivers\KMDFVirtualMouse.sys [21240 2014-08-05] ()
        R1 kneps; C:\WINDOWS\system32\DRIVERS\kneps.sys [199640 2017-07-25] (AO Kaspersky Lab)
        R3 mbamchameleon; C:\WINDOWS\system32\drivers\mbamchameleon.sys [140672 2016-03-10] (Malwarebytes)
        R3 MBAMProtector; C:\WINDOWS\system32\drivers\mbam.sys [27008 2016-03-10] (Malwarebytes)
        R3 MBAMSwissArmy; C:\WINDOWS\system32\drivers\MBAMSwissArmy.sys [192216 2017-09-26] (Malwarebytes)
        S3 MBAMWebAccessControl; C:\WINDOWS\system32\drivers\mwac.sys [65408 2016-03-10] (Malwarebytes Corporation)
        R3 MEIx64; C:\WINDOWS\system32\DRIVERS\TeeDriverx64.sys [129312 2014-09-30] (Intel Corporation)
        S0 mfeelamk; C:\WINDOWS\System32\drivers\mfeelamk.sys [80160 2015-02-13] (McAfee, Inc.)
        S3 MWAC; C:\WINDOWS\system32\drivers\ [0 ] () <==== ATTENTION (zero byte File/Folder)
        S3 MWAC; C:\WINDOWS\SysWOW64\drivers\ [0 ] () <==== ATTENTION (zero byte File/Folder)
        R3 nvlddmkm; C:\WINDOWS\System32\DriverStore\FileRepository\nvl twu.inf_amd64_dc8ffafad3ea7ddd\nvlddmkm.sys [14190520 2017-01-17] (NVIDIA Corporation)
        R0 PxHlpa64; C:\WINDOWS\System32\drivers\PxHlpa64.sys [56336 2013-09-03] (Corel Corporation)
        R3 rt640x64; C:\WINDOWS\System32\drivers\rt640x64.sys [886528 2015-07-22] (Realtek )
        R3 RTSUER; C:\WINDOWS\system32\Drivers\RtsUer.sys [410880 2015-07-03] (Realsil Semiconductor Corporation)
        R3 rtsuvc; C:\WINDOWS\system32\DRIVERS\rtsuvc.sys [3068160 2015-06-16] (Realtek Semiconductor Corp.)
        S3 SDFRd; C:\WINDOWS\System32\drivers\SDFRd.sys [31128 2017-03-18] ()
        S3 tapexpressvpn; C:\WINDOWS\System32\drivers\tapexpressvpn.sys [45048 2017-07-06] (The OpenVPN Project)
        S3 WdBoot; C:\WINDOWS\system32\drivers\WdBoot.sys [44632 2017-03-18] (Microsoft Corporation)
        S3 WdFilter; C:\WINDOWS\system32\drivers\WdFilter.sys [294816 2017-03-18] (Microsoft Corporation)
        S3 WdNisDrv; C:\WINDOWS\System32\Drivers\WdNisDrv.sys [121248 2017-03-18] (Microsoft Corporation)
        R3 WNDA3100v3; C:\WINDOWS\system32\DRIVERS\WNDA3100v3.sys [2222736 2014-12-08] (MediaTek Inc.)
        S3 wsvd; C:\WINDOWS\system32\DRIVERS\wsvd.sys [102376 2012-06-14] ("CyberLink)
        2017-09-26 18:01 - 2017-09-26 18:16 - 000000000 ____D C:\FRST
        2017-09-26 17:55 - 2017-09-26 17:56 - 002399744 _____ (Farbar) C:\Users\papeter\Downloads\FRST64.exe
        2017-09-26 01:11 - 2017-09-26 01:11 - 000001268 _____ C:\Users\papeter\Desktop\malwarebytes screenshot.docx - Shortcut.lnk
        2017-09-26 00:28 - 2017-09-26 00:28 - 002000384 _____ C:\Users\papeter\Documents\malwarebutes.pub
        2017-09-25 22:09 - 2017-09-25 22:09 - 008604592 _____ (Yousician ) C:\Users\papeter\Downloads\YousicianSetup.exe
        2017-09-25 18:07 - 2017-09-25 18:15 - 001396224 _____ C:\Users\papeter\Documents\John Crestani Video 1 summary.pub
        2017-09-24 23:26 - 2017-09-24 23:26 - 000000035 _____ C:\Users\papeter\Documents\E-X-P-V-P-N.txt
        2017-09-24 23:12 - 2017-09-24 23:12 - 000002091 _____ C:\Users\Public\Desktop\ExpressVPN.lnk
        2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\Users\papeter\AppData\Local\ExpressVPN
        2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ExpressVPN
        2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\ProgramData\ExpressVPN
        2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\Program Files (x86)\ExpressVPN
        2017-09-24 23:11 - 2017-09-24 23:11 - 000000000 ____D C:\Program Files (x86)\ExpressVpn Tap Driver Win10
        2017-09-24 23:10 - 2017-09-24 23:10 - 018904768 _____ (ExpressVPN) C:\Users\papeter\Downloads\expressvpn_6.2.3.2578.e xe
        2017-09-22 23:31 - 2017-09-22 23:31 - 000000138 _____ C:\Users\papeter\Documents\PayPal question.txt
        2017-09-22 13:02 - 2017-09-22 13:02 - 000000507 _____ C:\Users\papeter\Documents\super juice.txt
        2017-09-21 21:45 - 2017-09-21 21:45 - 000000000 ____D C:\Windows.old
        2017-09-21 21:43 - 2017-09-21 21:43 - 023684608 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 023679488 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 021352656 _____ (Microsoft Corporation) C:\WINDOWS\system32\shell32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 020509184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 020373408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shell32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 019336192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 013844480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 012801536 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 011887104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 008319904 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 008213504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mstscax.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 008207872 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 007931392 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 007907344 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Protection.PlayR eady.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 006728704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 006557520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 006265856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 005961728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 005821496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 005808640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 005721600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BingMaps.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 005557760 _____ (Microsoft Corporation) C:\WINDOWS\system32\dbgeng.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 005225984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d2d1.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 004848960 _____ (Microsoft Corporation) C:\WINDOWS\explorer.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 004730368 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 004708504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfcore.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 004707840 _____ (Microsoft Corporation) C:\WINDOWS\system32\ExplorerFrame.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 004671832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfcore.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 004535296 _____ (Microsoft Corporation) C:\WINDOWS\system32\MFMediaEngine.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 004462120 _____ (Microsoft Corporation) C:\WINDOWS\system32\setupapi.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 004445696 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_nt.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 004417024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ExplorerFrame.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 004330920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\setupapi.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 004175872 _____ (Microsoft Corporation) C:\WINDOWS\system32\StartTileData.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 004056064 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFMediaEngine.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 003995136 _____ (Microsoft Corporation) C:\WINDOWS\system32\UIRibbon.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 003667456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_47.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 003654656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 003464704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UIRibbon.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 003307008 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininet.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 003059200 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkMobileSettings.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002859520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wininet.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002805248 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002765824 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Shell.UnifiedTile.Cura tedTileCollections.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002675104 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tcpip.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 002671616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tquery.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002647224 _____ (Microsoft Corporation) C:\WINDOWS\system32\iertutil.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002604248 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfmp4srcsnk.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002516480 _____ (Microsoft Corporation) C:\WINDOWS\system32\diagtrack.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002503680 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.pcshell.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002476712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d10warp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002445824 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002424024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfmp4srcsnk.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002399728 _____ (Microsoft Corporation) C:\WINDOWS\system32\KernelBase.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002327456 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ntfs.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 002199552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Resources.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002177024 _____ (Microsoft Corporation) C:\WINDOWS\system32\OpcServices.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002166808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iertutil.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 002078720 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetcpl.cpl
        2017-09-21 21:43 - 2017-09-21 21:43 - 002009600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\inetcpl.cpl
        2017-09-21 21:43 - 2017-09-21 21:43 - 002006528 _____ (Microsoft Corporation) C:\WINDOWS\system32\LocationFramework.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001930840 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntdll.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001886208 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.oneco re.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001833984 _____ (Microsoft Corporation) C:\WINDOWS\system32\workfolderssvc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001802752 _____ (Microsoft Corporation) C:\WINDOWS\system32\urlmon.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001736704 _____ (Microsoft Corporation) C:\WINDOWS\system32\wevtsvc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001722880 _____ (Microsoft Corporation) C:\WINDOWS\system32\dui70.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001706496 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Immersive.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001657344 _____ (Microsoft Corporation) C:\WINDOWS\system32\XpsPrint.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001639936 _____ (Microsoft Corporation) C:\WINDOWS\system32\GdiPlus.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001627136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\urlmon.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001620880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntdll.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001619816 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppobjs.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001596592 _____ (Microsoft Corporation) C:\WINDOWS\system32\gdi32full.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001583616 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieapfltr.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001536512 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Immersive.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001525760 _____ (Microsoft Corporation) C:\WINDOWS\system32\RecoveryDrive.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 001468416 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.deskt op.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001463296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieapfltr.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001397760 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwansvc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001357312 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiosrv.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001337856 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEng.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001325968 _____ (Microsoft Corporation) C:\WINDOWS\system32\ole32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001320344 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpx.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001305088 _____ (Microsoft Corporation) C:\WINDOWS\system32\dosvc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001298432 _____ (Microsoft Corporation) C:\WINDOWS\system32\lpasvc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001291776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVPXENC.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001275904 _____ (Microsoft Corporation) C:\WINDOWS\system32\werconcpl.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001269760 _____ (Microsoft Corporation) C:\WINDOWS\system32\enterprisecsps.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001260544 _____ (Microsoft Corporation) C:\WINDOWS\system32\GamePanel.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 001248768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AzureSettingSyncProvider.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001242528 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ndis.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 001178624 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.Vpn.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001146176 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfds.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001143296 _____ (Microsoft Corporation) C:\WINDOWS\system32\localspl.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001114528 _____ (Microsoft Corporation) C:\WINDOWS\system32\ReAgent.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001106904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfds.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001087488 _____ (Microsoft Corporation) C:\WINDOWS\system32\reseteng.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001068720 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001060352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XpsPrint.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001054280 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioSes.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001051136 _____ (Microsoft Corporation) C:\WINDOWS\system32\nettrace.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001046016 _____ (Microsoft Corporation) C:\WINDOWS\system32\comdlg32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001033544 _____ (Microsoft Corporation) C:\WINDOWS\system32\DolbyDecMFT.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001019904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aadtb.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 001013912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msvproc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000996864 _____ (Microsoft Corporation) C:\WINDOWS\system32\iphlpsvc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000988168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ole32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000986624 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuapi.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000972288 _____ (Microsoft Corporation) C:\WINDOWS\system32\MPSSVC.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000971264 _____ (Microsoft Corporation) C:\WINDOWS\system32\autochk.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000967584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ReAgent.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000961952 _____ (Microsoft Corporation) C:\WINDOWS\system32\efscore.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000958664 _____ (Microsoft Corporation) C:\WINDOWS\system32\msvproc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000954368 _____ (Microsoft Corporation) C:\WINDOWS\system32\autoconv.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000952832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\comdlg32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000946688 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasgcw.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000932352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GamePanel.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000926208 _____ (Microsoft Corporation) C:\WINDOWS\system32\autofmt.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000925696 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpcWebFilter.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000923040 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreMessaging.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000921600 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasdlg.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000918528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Networking.Vpn.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000899584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.appcore.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000877056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\autoconv.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000874496 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasmans.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000866808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DolbyDecMFT.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000864256 _____ (Microsoft Corporation) C:\WINDOWS\system32\NotificationController.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000853504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\autofmt.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000852480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasgcw.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000847360 _____ (Microsoft Corporation) C:\WINDOWS\system32\bisrv.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000844288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasdlg.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000832000 _____ (Microsoft Corporation) C:\WINDOWS\system32\printfilterpipelinesvc.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000827904 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32spl.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000820128 _____ (Microsoft Corporation) C:\WINDOWS\system32\WWAHost.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000810496 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasapi32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000805888 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieproxy.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000803328 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmsvc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000778240 _____ C:\WINDOWS\system32\MBR2GPT.EXE
        2017-09-21 21:43 - 2017-09-21 21:43 - 000778240 _____ (Microsoft Corporation) C:\WINDOWS\system32\DolbyHrtfEnc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000773120 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneService.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000772096 _____ (Microsoft Corporation) C:\WINDOWS\system32\PCPKsp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000761344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasapi32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000757760 _____ (Microsoft Corporation) C:\WINDOWS\system32\spoolsv.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000752640 _____ (Microsoft Corporation) C:\WINDOWS\system32\msfeeds.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000750560 _____ (Microsoft Corporation) C:\WINDOWS\system32\fontdrvhost.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000750496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WWAHost.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000742912 _____ (Microsoft Corporation) C:\WINDOWS\system32\nshwfp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000739840 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneProviders.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000724200 _____ (Microsoft Corporation) C:\WINDOWS\system32\wer.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000715168 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fvevol.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000706560 _____ (Microsoft Corporation) C:\WINDOWS\system32\winlogon.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000699904 _____ (Microsoft Corporation) C:\WINDOWS\system32\FlightSettings.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000692736 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9diag.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000687616 _____ (Microsoft Corporation) C:\WINDOWS\system32\LogonController.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000685512 _____ (Microsoft Corporation) C:\WINDOWS\system32\SHCore.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000664576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msfeeds.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000636416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WpcWebFilter.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000625152 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEndpointBuilder.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000612864 _____ (Microsoft Corporation) C:\WINDOWS\system32\shsvcs.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000610720 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\afd.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000600576 _____ (Microsoft Corporation) C:\WINDOWS\system32\FrameServer.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000593408 _____ (Microsoft Corporation) C:\WINDOWS\system32\BootMenuUX.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000586240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\nshwfp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000584192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UIRibbonRes.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000584192 _____ (Microsoft Corporation) C:\WINDOWS\system32\UIRibbonRes.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000582656 _____ (Microsoft Corporation) C:\WINDOWS\system32\SmsRouterSvc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000579072 _____ (Microsoft Corporation) C:\WINDOWS\system32\untfs.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000574464 _____ (Microsoft Corporation) C:\WINDOWS\system32\configmanager2.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000569264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SHCore.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000566784 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.UX.EapReque stHandler.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000564224 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shsvcs.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000551200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxgi.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000546816 _____ (Microsoft Corporation) C:\WINDOWS\system32\winspool.drv
        2017-09-21 21:43 - 2017-09-21 21:43 - 000536064 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Management.dl l
        2017-09-21 21:43 - 2017-09-21 21:43 - 000527976 _____ (Microsoft Corporation) C:\WINDOWS\system32\services.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000527872 _____ (Microsoft Corporation) C:\WINDOWS\system32\daxexec.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000524800 _____ (Microsoft Corporation) C:\WINDOWS\system32\TileDataRepository.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000519584 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netio.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000500224 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Shell.BlueLightReducti on.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000499712 _____ (Microsoft Corporation) C:\WINDOWS\system32\nltest.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000497152 _____ (Microsoft Corporation) C:\WINDOWS\system32\rastls.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000491520 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Display.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000482816 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmenrollengine.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000477696 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasplap.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000473240 _____ (Microsoft Corporation) C:\WINDOWS\system32\policymanager.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000463360 _____ (Microsoft Corporation) C:\WINDOWS\system32\werui.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000457728 _____ (Microsoft Corporation) C:\WINDOWS\system32\webplatstorageserver.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000455584 _____ (Microsoft Corporation) C:\WINDOWS\system32\hal.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000452608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasplap.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000450048 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcdedit.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000446464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rastls.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000440320 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.immersiveshell.service provider.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000433664 _____ (Microsoft Corporation) C:\WINDOWS\system32\msIso.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000430592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winspool.drv
        2017-09-21 21:43 - 2017-09-21 21:43 - 000420864 _____ (Microsoft Corporation) C:\WINDOWS\system32\facecredentialprovider.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000417792 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallAgentUserBroker.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000410168 _____ (Microsoft Corporation) C:\WINDOWS\system32\Faultrep.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000407040 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhext.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000406544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\policymanager.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000397312 _____ (Microsoft Corporation) C:\WINDOWS\system32\rascustom.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000394240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Internal.Management.dl l
        2017-09-21 21:43 - 2017-09-21 21:43 - 000388096 _____ (Microsoft Corporation) C:\WINDOWS\system32\iedkcs32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000387936 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmpps.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000383488 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallAgent.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000382368 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\clfs.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000381824 _____ (Microsoft Corporation) C:\WINDOWS\system32\wevtapi.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000370688 _____ (Microsoft Corporation) C:\WINDOWS\system32\rastlsext.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000370176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\daxexec.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000368128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallAgentUserBroker.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000365056 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Notifications .dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000364032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msIso.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000358400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieproxy.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000357888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ActivationManager.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000353280 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntprint.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000339968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iedkcs32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000337920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallAgent.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000331264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rastlsext.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000329728 _____ (Microsoft Corporation) C:\WINDOWS\system32\RasMediaManager.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000327168 _____ (Microsoft Corporation) C:\WINDOWS\system32\WinBioDataModel.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000323936 _____ (Microsoft Corporation) C:\WINDOWS\system32\shlwapi.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000323584 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceEnroller.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000316320 _____ (Microsoft Corporation) C:\WINDOWS\system32\WerFault.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000312320 _____ (Microsoft Corporation) C:\WINDOWS\system32\Phoneutil.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000311296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntprint.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000305152 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netbt.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000290816 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmenterprisediagnostics.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000277432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shlwapi.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000274944 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxtrans.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000268288 _____ (Microsoft Corporation) C:\WINDOWS\system32\wisp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000266240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxtrans.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000259072 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Flights.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000257440 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxAllUserStore.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000257024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Phoneutil.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000257024 _____ (Microsoft Corporation) C:\WINDOWS\system32\webcheck.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000255488 _____ (Microsoft Corporation) C:\WINDOWS\system32\scksp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000254976 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\srvnet.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000254176 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfps.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000249344 _____ (Microsoft Corporation) C:\WINDOWS\system32\coredpus.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000243712 _____ (Microsoft Corporation) C:\WINDOWS\system32\shdocvw.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000232960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webcheck.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000231936 _____ (Microsoft Corporation) C:\WINDOWS\system32\DolbyMATEnc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000229888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\scksp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000229888 _____ (Microsoft Corporation) C:\WINDOWS\system32\SIHClient.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000228256 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb20.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000225792 _____ (Microsoft Corporation) C:\WINDOWS\system32\ie4uinit.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000223744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shdocvw.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000213504 _____ (Microsoft Corporation) C:\WINDOWS\system32\dinput8.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000212384 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserbroker.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000209408 _____ (Microsoft Corporation) C:\WINDOWS\system32\psmsrv.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000204192 _____ (Microsoft Corporation) C:\WINDOWS\system32\basecsp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000201728 _____ (Microsoft Corporation) C:\WINDOWS\system32\RstrtMgr.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000197120 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcdboot.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000194048 _____ (Microsoft Corporation) C:\WINDOWS\system32\mdmregistration.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000192264 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsensorgroup.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000184832 _____ (Microsoft Corporation) C:\WINDOWS\system32\VCardParser.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000184320 _____ (Microsoft Corporation) C:\WINDOWS\system32\DWWIN.EXE
        2017-09-21 21:43 - 2017-09-21 21:43 - 000182688 _____ (Microsoft Corporation) C:\WINDOWS\system32\wermgr.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000182272 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcrecovery.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000176640 _____ (Microsoft Corporation) C:\WINDOWS\system32\wersvc.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000176024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\basecsp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000175616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\RstrtMgr.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000175104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dinput8.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000173568 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetpp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000165888 _____ (Microsoft Corporation) C:\WINDOWS\system32\storewuauth.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000160768 _____ (Microsoft Corporation) C:\WINDOWS\system32\dinput.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000159648 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\partmgr.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000156160 _____ (Microsoft Corporation) C:\WINDOWS\system32\csplte.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000153088 _____ (Microsoft Corporation) C:\WINDOWS\system32\fdeploy.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000150528 _____ (Microsoft Corporation) C:\WINDOWS\system32\qasf.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000147456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\VCardParser.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000143872 _____ (Microsoft Corporation) C:\WINDOWS\system32\profsvcext.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000143736 _____ (Microsoft Corporation) C:\WINDOWS\system32\WerFaultSecure.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000142848 _____ (Microsoft Corporation) C:\WINDOWS\system32\srpapi.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000142848 _____ (Microsoft Corporation) C:\WINDOWS\system32\dwmredir.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000140800 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmcsps.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000140288 _____ (Microsoft Corporation) C:\WINDOWS\system32\iepeers.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000138752 _____ (Microsoft Corporation) C:\WINDOWS\system32\appinfo.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000136096 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ksecdd.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000135680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\qasf.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000134656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dinput.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000133632 _____ (Microsoft Corporation) C:\WINDOWS\system32\CfgSPCellular.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000131584 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseAPNCsp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000130560 _____ (Microsoft Corporation) C:\WINDOWS\system32\policymanagerprecheck.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000128512 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasman.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000127488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fdeploy.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000124928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iepeers.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000124928 _____ (Microsoft Corporation) C:\WINDOWS\system32\httpprxm.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000119904 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmcmnutils.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000119712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tdx.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000116280 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcd.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000115712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bridge.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000113152 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhosdeployment.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000112640 _____ (Microsoft Corporation) C:\WINDOWS\system32\MDMAppInstaller.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000110592 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000109056 _____ (Microsoft Corporation) C:\WINDOWS\system32\dab.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000105472 _____ (Microsoft Corporation) C:\WINDOWS\system32\RjvMDMConfig.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000104432 _____ (Microsoft Corporation) C:\WINDOWS\system32\msacm32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000102912 _____ (Microsoft Corporation) C:\WINDOWS\system32\officecsp.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000100352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasman.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000100232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcd.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000096648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dmcmnutils.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000096256 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtmled.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000095232 _____ (Microsoft Corporation) C:\WINDOWS\system32\wudriver.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000093696 _____ (Microsoft Corporation) C:\WINDOWS\system32\spbcd.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000093184 _____ (Microsoft Corporation) C:\WINDOWS\system32\wercplsupport.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000090112 _____ (Microsoft Corporation) C:\WINDOWS\system32\ofdeploy.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000089088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\olepro32.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000089088 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsrvext.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000085784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CredentialUIBroker.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000084992 _____ (Microsoft Corporation) C:\WINDOWS\system32\MshtmlDac.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000080896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakradiag.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000080384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtmled.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000078848 _____ (Microsoft Corporation) C:\WINDOWS\system32\setbcdlocale.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000077824 _____ (Microsoft Corporation) C:\WINDOWS\system32\wsqmcons.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000077312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\spbcd.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000074240 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseDesktopAppMgmtCSP.dl l
        2017-09-21 21:43 - 2017-09-21 21:43 - 000064680 _____ (Microsoft Corporation) C:\WINDOWS\system32\appidapi.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000064512 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsrv.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MshtmlDac.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\system32\wups.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntprint.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000062464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntprint.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000061952 _____ (Microsoft Corporation) C:\WINDOWS\system32\vss_ps.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000059392 _____ (Microsoft Corporation) C:\WINDOWS\system32\DmApiSetExtImplDesktop.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000057856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\offreg.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000056832 _____ (Microsoft Corporation) C:\WINDOWS\system32\cldapi.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000052768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\appidapi.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000044032 _____ (Microsoft Corporation) C:\WINDOWS\system32\cmintegrator.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000043520 _____ (Microsoft Corporation) C:\WINDOWS\system32\TpmTasks.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000043520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\nsiproxy.sys
        2017-09-21 21:43 - 2017-09-21 21:43 - 000029696 _____ (Microsoft Corporation) C:\WINDOWS\system32\odbcconf.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000029184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cmintegrator.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000022528 _____ (Microsoft Corporation) C:\WINDOWS\system32\IpNatHlpClient.dll
        2017-09-21 21:43 - 2017-09-21 21:43 - 000022016 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpnpinst.exe
        2017-09-21 21:43 - 2017-09-21 21:43 - 000018432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\IpNatHlpClient.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 017371136 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 008333312 _____ (Microsoft Corporation) C:\WINDOWS\system32\BingMaps.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 007598080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mstscax.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 007337472 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Data.Pdf.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 007326128 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 006761560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayR eady.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 005477096 _____ (Microsoft Corporation) C:\WINDOWS\system32\OneCoreUAPCommonProxyStub.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 005302968 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepository.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 004559360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dbgeng.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 004471888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\explorer.exe
        2017-09-21 21:42 - 2017-09-21 21:42 - 004396032 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_47.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 004213656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepository.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 003668992 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 003377664 _____ (Microsoft Corporation) C:\WINDOWS\system32\tquery.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 003204608 _____ (Microsoft Corporation) C:\WINDOWS\system32\Microsoft.Bluetooth.Profiles.G att.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 003116184 _____ (Microsoft Corporation) C:\WINDOWS\system32\combase.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 002972552 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d10warp.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 002969880 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreUIComponents.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 002953216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32kfull.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 002939392 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputService.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 002680320 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.CloudStore.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 002443168 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 002330520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\combase.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 002259760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreUIComponents.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 002211840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputService.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 002199552 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.Resources.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 002153984 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlidsvc.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 002055680 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 001878016 _____ (Microsoft Corporation) C:\WINDOWS\system32\AzureSettingSyncProvider.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001839872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\KernelBase.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001668344 _____ (Microsoft Corporation) C:\WINDOWS\system32\propsys.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001460224 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsasrv.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001448960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GdiPlus.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001409048 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gdi32full.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001355264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\OpcServices.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001346112 _____ (Microsoft Corporation) C:\WINDOWS\system32\user32.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001311744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjet40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001293824 _____ (Microsoft Corporation) C:\WINDOWS\system32\aadtb.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001292880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\user32.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001195760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioEng.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001147296 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvix64.exe
        2017-09-21 21:42 - 2017-09-21 21:42 - 001085440 _____ (Microsoft Corporation) C:\WINDOWS\system32\rpcss.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001077248 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.appcore.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001057824 _____ (Microsoft Corporation) C:\WINDOWS\system32\MrmCoreR.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001052160 _____ (Microsoft Corporation) C:\WINDOWS\system32\TokenBroker.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001046016 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcsvc.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001028608 _____ (Microsoft Corporation) C:\WINDOWS\system32\modernexecserver.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 001024928 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvax64.exe
        2017-09-21 21:42 - 2017-09-21 21:42 - 001015296 _____ (Microsoft Corporation) C:\WINDOWS\system32\XblAuthManager.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000982016 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthport.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000942592 _____ (Microsoft Corporation) C:\WINDOWS\system32\wbiosrvc.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000922112 _____ (Microsoft Corporation) C:\WINDOWS\system32\kerberos.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000892928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\autochk.exe
        2017-09-21 21:42 - 2017-09-21 21:42 - 000872472 _____ (Microsoft Corporation) C:\WINDOWS\system32\ClipSVC.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000871448 _____ (Microsoft Corporation) C:\WINDOWS\system32\winhttp.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000866816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mswdat10.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000864248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioSes.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000821664 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.exe
        2017-09-21 21:42 - 2017-09-21 21:42 - 000817664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Security.Authenticatio n.Web.Core.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000805816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000798208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TokenBroker.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000787456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wuapi.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000772096 _____ (Microsoft Corporation) C:\WINDOWS\system32\netlogon.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000754176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\kerberos.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000723360 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\acpi.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000712600 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000703056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winhttp.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000691712 _____ (Microsoft Corporation) C:\WINDOWS\system32\tdh.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000660680 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxgi.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000657408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netlogon.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000654976 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentClient.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000641536 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mswstr10.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000640512 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngccredprov.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000627080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fontdrvhost.exe
        2017-09-21 21:42 - 2017-09-21 21:42 - 000616448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrepl40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000611096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wer.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000590336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PCPKsp.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000586752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Security.Authenticatio n.Web.Core.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000586240 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppReadiness.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000583160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreMessaging.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000564736 _____ (Microsoft Corporation) C:\WINDOWS\system32\dsreg.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000563200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tdh.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000556032 _____ (Microsoft Corporation) C:\WINDOWS\system32\TpmCoreProvisioning.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000554400 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\USBHUB3.SYS
        2017-09-21 21:42 - 2017-09-21 21:42 - 000546208 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\storport.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000538112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\untfs.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000529992 _____ (Microsoft Corporation) C:\WINDOWS\system32\TextInputFramework.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000527360 _____ (Microsoft Corporation) C:\WINDOWS\system32\aadcloudap.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000524288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ngccredprov.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000519680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000518144 _____ C:\WINDOWS\SysWOW64\msjetoledb40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000491520 _____ (Microsoft Corporation) C:\WINDOWS\system32\NgcCtnrSvc.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000476160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dsreg.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000475648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxbde40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000471040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TpmCoreProvisioning.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000458752 _____ (Microsoft Corporation) C:\WINDOWS\system32\NgcCtnr.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000447488 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32k.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000431616 _____ (Microsoft Corporation) C:\WINDOWS\system32\BthHFSrv.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000422400 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpAXHolder.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000414296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TextInputFramework.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000413184 _____ (Microsoft Corporation) C:\WINDOWS\system32\profsvc.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000412160 _____ (Microsoft Corporation) C:\WINDOWS\system32\ActivationManager.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000411040 _____ (Microsoft Corporation) C:\WINDOWS\system32\msv1_0.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000408576 _____ (Microsoft Corporation) C:\WINDOWS\system32\cryptngc.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000404480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\werui.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000385536 _____ (Microsoft Corporation) C:\WINDOWS\system32\tpmvsc.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000375808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mspbde40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000359560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Faultrep.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000349600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msv1_0.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000343552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrd3x40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000339968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msexcl40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000334336 _____ (Microsoft Corporation) C:\WINDOWS\system32\wc_storage.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000318232 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininit.exe
        2017-09-21 21:42 - 2017-09-21 21:42 - 000315904 _____ (Microsoft Corporation) C:\WINDOWS\system32\ncryptprov.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000310272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrd2x40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000307712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cryptngc.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000303104 _____ (Microsoft Corporation) C:\WINDOWS\system32\srvsvc.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000293376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32k.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000291904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wevtapi.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000290816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjtes40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000287648 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\sdbus.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000282112 _____ (Microsoft Corporation) C:\WINDOWS\system32\dnsrslvr.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000280480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WerFault.exe
        2017-09-21 21:42 - 2017-09-21 21:42 - 000279968 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\msiscsi.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000274432 _____ (Microsoft Corporation) C:\WINDOWS\system32\authz.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000272896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mstext40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000267264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ncryptprov.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000240640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msltus40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000221696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wisp.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000189440 _____ (Microsoft Corporation) C:\WINDOWS\system32\BluetoothApis.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000189344 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dumpsd.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000182688 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppxAllUserStore.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000181760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\authz.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000180736 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\rfcomm.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000173104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsensorgroup.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000169376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wermgr.exe
        2017-09-21 21:42 - 2017-09-21 21:42 - 000154624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DWWIN.EXE
        2017-09-21 21:42 - 2017-09-21 21:42 - 000144896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjint40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000139776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BluetoothApis.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000136192 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryUpgrade .dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000133904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WerFaultSecure.exe
        2017-09-21 21:42 - 2017-09-21 21:42 - 000130560 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthpan.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000128000 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssprxy.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000123904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\srpapi.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000117760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryUpgrade .dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000115792 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32u.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000107008 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcpopkeysrv.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000107008 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hidbth.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000105472 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthenum.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000104960 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\UcmCx.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000097792 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthhfenum.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000097280 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\Microsoft.Bluetooth.Le gacy.LEEnumerator.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000094624 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpudd.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000090464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msacm32.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000090112 _____ (Microsoft Corporation) C:\WINDOWS\system32\datamarketsvc.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000083968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjter40.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000083968 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbkmclr.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000082336 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbkmcl.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000081176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32u.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000079872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wudriver.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000078848 _____ (Microsoft Corporation) C:\WINDOWS\system32\offreg.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000071680 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\usbser.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000051712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\UcmUcsi.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000050176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cldapi.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000049720 _____ (Microsoft Corporation) C:\WINDOWS\system32\tbs.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000046592 _____ (Microsoft Corporation) C:\WINDOWS\system32\sscore.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000042496 _____ (Microsoft Corporation) C:\WINDOWS\system32\tokenbinding.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000042456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tbs.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000039424 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\buttonconverter.sys
        2017-09-21 21:42 - 2017-09-21 21:42 - 000037376 _____ (Microsoft Corporation) C:\WINDOWS\system32\SEMgrPS.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000035840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sscore.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000034816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tokenbinding.dll
        2017-09-21 21:42 - 2017-09-21 21:42 - 000031932 _____ C:\WINDOWS\system32\edgehtmlpluginpolicy.bin
        2017-09-21 21:42 - 2017-09-21 21:42 - 000025088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\odbcconf.dll
        2017-09-21 21:32 - 2017-09-21 21:32 - 000008192 _____ C:\WINDOWS\system32\config\userdiff
        2017-09-21 21:32 - 2017-09-21 12:50 - 000000000 ____D C:\WINDOWS\ServiceProfiles
        2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files\Reference Assemblies
        2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files\MSBuild
        2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files (x86)\Reference Assemblies
        2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files (x86)\MSBuild
        2017-09-21 21:28 - 2017-02-10 20:26 - 001166520 _____ (Microsoft Corporation) C:\WINDOWS\system32\PresentationNative_v0300.dll
        2017-09-21 21:28 - 2017-02-10 20:26 - 000124624 _____ (Microsoft Corporation) C:\WINDOWS\system32\PresentationCFFRasterizerNativ e_v0300.dll
        2017-09-21 21:28 - 2017-02-10 20:26 - 000035480 _____ (Microsoft Corporation) C:\WINDOWS\system32\TsWpfWrp.exe
        2017-09-21 21:28 - 2017-02-10 20:21 - 000778936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PresentationNative_v0300.dll
        2017-09-21 21:28 - 2017-02-10 20:21 - 000103120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PresentationCFFRasterizerNativ e_v0300.dll
        2017-09-21 21:28 - 2017-02-10 20:21 - 000035480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TsWpfWrp.exe
        2017-09-21 18:18 - 2017-09-21 18:18 - 000000051 _____ C:\Users\papeter\Documents\talktalk call centres.txt
        2017-09-21 14:09 - 2017-09-21 14:09 - 000003366 _____ C:\WINDOWS\System32\Tasks\OneDrive Standalone Update Task-S-1-5-21-4237603079-860989819-990887440-1001
        2017-09-21 14:06 - 2017-09-21 14:06 - 000000000 ____D C:\ProgramData\Microsoft OneDrive
        2017-09-21 14:04 - 2017-09-21 14:04 - 000000000 ____D C:\Users\papeter\AppData\Local\DBG
        2017-09-21 14:03 - 2017-09-21 14:03 - 000000020 ___SH C:\Users\papeter\ntuser.ini
        2017-09-21 13:33 - 2017-09-21 13:40 - 000007623 _____ C:\WINDOWS\diagwrn.xml
        2017-09-21 13:33 - 2017-09-21 13:40 - 000007623 _____ C:\WINDOWS\diagerr.xml
        2017-09-21 13:20 - 2017-09-26 17:55 - 000004156 _____ C:\WINDOWS\System32\Tasks\User_Feed_Synchronizatio n-{0F46EB48-50E2-4372-B3E0-FDD9244C8B47}
        2017-09-21 13:20 - 2017-09-24 20:06 - 000000006 ____H C:\WINDOWS\Tasks\SA.DAT
        2017-09-21 13:20 - 2017-09-21 13:21 - 000003548 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA1d257e73535f0dd
        2017-09-21 13:20 - 2017-09-21 13:21 - 000003344 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineU A
        2017-09-21 13:20 - 2017-09-21 13:21 - 000003338 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core
        2017-09-21 13:20 - 2017-09-21 13:21 - 000003280 _____ C:\WINDOWS\System32\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001
        2017-09-21 13:20 - 2017-09-21 13:21 - 000003278 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater
        2017-09-21 13:20 - 2017-09-21 13:21 - 000002936 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-4237603079-860989819-990887440-1001
        2017-09-21 13:20 - 2017-09-21 13:20 - 000003606 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA
        2017-09-21 13:20 - 2017-09-21 13:20 - 000003482 _____ C:\WINDOWS\System32\Tasks\Adobe Acrobat Update Task
        2017-09-21 13:20 - 2017-09-21 13:20 - 000003280 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core1d257e734ba2eb7
        2017-09-21 13:20 - 2017-09-21 13:20 - 000003184 _____ C:\WINDOWS\System32\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001
        2017-09-21 13:20 - 2017-09-21 13:20 - 000003120 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineC ore
        2017-09-21 13:20 - 2017-09-21 13:20 - 000003042 _____ C:\WINDOWS\System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473
        2017-09-21 13:20 - 2017-09-21 13:20 - 000002924 _____ C:\WINDOWS\System32\Tasks\HMA! Pro VPN Update
        2017-09-21 13:20 - 2017-09-21 13:20 - 000002762 _____ C:\WINDOWS\System32\Tasks\AdobeAAMUpdater-1.0-Lenovo-PC-papeter
        2017-09-21 13:20 - 2017-09-21 13:20 - 000002680 _____ C:\WINDOWS\System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon
        2017-09-21 13:20 - 2017-09-21 13:20 - 000002316 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-4237603079-860989819-990887440-500
        2017-09-21 13:20 - 2017-09-21 13:20 - 000002256 _____ C:\WINDOWS\System32\Tasks\PDVDServ Task
        2017-09-21 13:20 - 2017-09-21 13:20 - 000002216 _____ C:\WINDOWS\System32\Tasks\CCleanerSkipUAC
        2017-09-21 13:20 - 2017-09-21 13:20 - 000000000 ____D C:\WINDOWS\System32\Tasks\WPD
        2017-09-21 13:20 - 2017-09-21 13:20 - 000000000 ____D C:\WINDOWS\System32\Tasks\Lenovo
        2017-09-21 13:20 - 2017-09-21 13:20 - 000000000 ____D C:\WINDOWS\System32\Tasks\Apple
        2017-09-21 13:20 - 2014-08-23 22:38 - 000003596 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-3320520227-2896305394-2021013739-500
        2017-09-21 13:20 - 2014-04-03 19:35 - 000003594 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-1050727674-2070356693-977449066-500
        2017-09-21 13:17 - 2017-09-24 20:13 - 000926438 _____ C:\WINDOWS\system32\PerfStringBackup.INI
        2017-09-21 13:06 - 2017-09-21 13:06 - 000001576 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Media Player.lnk
        2017-09-21 13:01 - 2017-09-21 13:01 - 000000000 ____D C:\ProgramData\USOShared
        2017-09-21 13:00 - 2017-09-21 13:09 - 000000000 ____D C:\WINDOWS\system32\config\bbimigrate
        2017-09-21 12:56 - 2017-09-22 18:14 - 000000000 ____D C:\Users\papeter
        2017-09-21 12:55 - 2017-09-21 12:55 - 000000000 ____D C:\WINDOWS\SysWOW64\sda
        2017-09-21 12:54 - 2017-09-26 15:43 - 000000180 _____ C:\WINDOWS\system32{A6D608F0-0BDE-491A-97AE-5C4B05D86E01}.bat
        2017-09-21 12:54 - 2017-09-21 13:01 - 000000000 ____D C:\ProgramData\NVIDIA Corporation
        2017-09-21 12:54 - 2017-09-21 13:00 - 000000000 ____D C:\Program Files\NVIDIA Corporation
        2017-09-21 12:54 - 2017-09-21 13:00 - 000000000 ____D C:\Program Files\Intel
        2017-09-21 12:54 - 2017-09-21 12:55 - 000000000 ____D C:\Program Files\Elantech
        2017-09-21 12:54 - 2017-09-21 12:54 - 000000200 _____ C:\WINDOWS\system32{EC94D02F-D200-4428-9531-05AF7F9799CB}.bat
        2017-09-21 12:54 - 2017-09-21 12:54 - 000000000 _____ C:\WINDOWS\system32\GfxValDisplayLog.bin
        2017-09-21 12:54 - 2017-05-26 05:12 - 000103888 _____ (Khronos Group) C:\WINDOWS\SysWOW64\OpenCL.DLL
        2017-09-21 12:54 - 2017-05-26 05:12 - 000099792 _____ (Khronos Group) C:\WINDOWS\system32\OpenCL.DLL
        2017-09-21 12:54 - 2016-12-29 14:16 - 006384576 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcpl.dll
        2017-09-21 12:54 - 2016-12-29 14:16 - 002475968 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvc64.dll
        2017-09-21 12:54 - 2016-12-29 14:16 - 001762752 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvcr.dll
        2017-09-21 12:54 - 2016-12-29 14:16 - 000546752 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshext.dll
        2017-09-21 12:54 - 2016-12-29 14:16 - 000392128 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvmctray.dll
        2017-09-21 12:54 - 2016-12-29 14:16 - 000147000 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\oemdspif.dll
        2017-09-21 12:54 - 2016-12-29 14:16 - 000083512 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshextr.dll
        2017-09-21 12:54 - 2016-12-29 14:16 - 000069568 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvshext.dll
        2017-09-21 12:54 - 2016-12-22 00:59 - 007651057 _____ C:\WINDOWS\system32\nvcoproc.bin
        2017-09-21 12:53 - 2017-09-21 13:00 - 000000000 ____D C:\ProgramData\Conexant
        2017-09-21 12:53 - 2017-09-21 13:00 - 000000000 ____D C:\Program Files\CONEXANT
        2017-09-21 12:53 - 2017-09-21 12:53 - 000000000 ____H C:\WINDOWS\system32\Drivers\Msft_Kernel_TeeDriverx 64_01011.Wdf
        2017-09-21 12:53 - 2017-09-21 12:53 - 000000000 ____H C:\ProgramData\DP45977C.lfl
        2017-09-21 12:53 - 2017-03-18 21:56 - 002233344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PrintConfig.dll
        2017-09-21 12:50 - 2017-09-26 17:51 - 000000000 ____D C:\WINDOWS\system32\SleepStudy
        2017-09-21 12:50 - 2017-09-22 18:01 - 000418080 _____ C:\WINDOWS\system32\FNTCACHE.DAT
        2017-09-21 12:49 - 2017-09-24 20:06 - 000153336 _____ C:\WINDOWS\system32\wpbbin.exe
        2017-09-21 12:49 - 2017-09-24 20:06 - 000111088 _____ (Lenovo (Beijing) Limited) C:\WINDOWS\system32\LenovoCheck.exe
        2017-09-21 12:49 - 2017-09-24 20:06 - 000026608 _____ (Lenovo) C:\WINDOWS\system32\LenovoUpdate.exe
        2017-09-20 22:04 - 2017-09-21 18:11 - 000000000 ___DC C:\WINDOWS\Panther
        2017-09-19 23:56 - 2017-09-19 23:56 - 000743936 _____ C:\Users\papeter\Documents\JOHN CRETANI AFFIL ON YTUBE.pub
        2017-09-19 16:20 - 2017-09-19 16:20 - 000014374 _____ C:\Users\papeter\Downloads\Keyword Planner 2017-09-19 at 16_20_29.csv
        2017-09-19 14:20 - 2017-09-19 14:20 - 000059555 _____ C:\Users\papeter\Downloads\estibot-export(64).csv
        2017-09-19 00:56 - 2017-09-19 00:56 - 001182208 _____ C:\Users\papeter\Documents\Jared Polin.pub
        2017-09-19 00:13 - 2017-09-19 00:13 - 000000000 ____D C:\Users\papeter\Desktop\JohnCVideos
        2017-09-18 21:04 - 2017-09-18 21:26 - 000000293 _____ C:\Users\papeter\Documents\SUPERFOODS.txt
        2017-09-18 18:21 - 2017-09-23 15:10 - 000000874 _____ C:\Users\Public\Desktop\CCleaner.lnk
        2017-09-18 18:21 - 2017-09-18 18:21 - 009826968 _____ (Piriform Ltd) C:\Users\papeter\Downloads\ccsetup534.exe
        2017-09-18 17:15 - 2017-09-18 17:50 - 631061270 _____ C:\Users\papeter\Desktop\Mike&Brett.avi
        2017-09-18 14:53 - 2017-09-18 22:16 - 000595456 _____ C:\Users\papeter\Documents\AIDA JC.pub
        2017-09-18 14:24 - 2017-09-18 22:14 - 000000457 _____ C:\Users\papeter\Documents\JOHN CRESTANI USEFUL RESOURCES.txt
        2017-09-18 14:21 - 2017-09-18 14:21 - 004773823 _____ C:\Users\papeter\Desktop\2015-BTF-Guide-to-Everything.pdf
        2017-09-14 23:42 - 2017-09-14 23:42 - 001230204 _____ C:\Users\papeter\Downloads\5 Steps to a 7 Figure E-commerce Business(1).pdf
        2017-09-14 23:41 - 2017-09-14 23:41 - 001230204 _____ C:\Users\papeter\Downloads\5 Steps to a 7 Figure E-commerce Business.pdf
        2017-09-13 20:29 - 2017-09-13 20:29 - 009943296 _____ C:\Users\papeter\Desktop\Passion Blog Pro Starter Guide PDF.pdf
        2017-09-13 20:17 - 2017-09-13 20:17 - 000000105 _____ C:\Users\papeter\Documents\Gilles address in France.txt
        2017-09-13 20:09 - 2017-09-13 20:09 - 000373248 _____ C:\Users\papeter\Documents\ebay client address.pub
        2017-09-12 21:39 - 2017-09-12 21:39 - 000922279 _____ C:\Users\papeter\Downloads\fb_linkpost3(2).zip
        2017-09-12 21:38 - 2017-09-12 21:39 - 000922279 _____ C:\Users\papeter\Downloads\fb_linkpost3(1).zip
        2017-09-12 21:27 - 2017-09-12 21:27 - 000003136 _____ C:\Users\papeter\Downloads\Special Traffic Training.ics
        2017-09-12 10:47 - 2017-09-12 10:47 - 000922279 _____ C:\Users\papeter\Downloads\fb_linkpost3.zip
        2017-09-12 10:47 - 2017-09-12 10:47 - 000000000 ____D C:\Users\papeter\Downloads\fb_linkpost3
        2017-09-11 08:30 - 2017-09-21 10:11 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\754C0DB7.sys
        2017-09-10 15:38 - 2017-09-10 15:52 - 449847274 _____ C:\Users\papeter\Desktop\Recording #126.avi
        2017-09-08 11:37 - 2017-09-08 11:37 - 001059328 _____ C:\Users\papeter\Documents\nofap.pub
        2017-09-08 09:13 - 2017-09-10 11:41 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\1B6A4467.sys
        2017-09-07 22:57 - 2017-09-07 22:57 - 000000028 _____ C:\Users\papeter\Documents\imjetset.com John Crestani.txt
        2017-09-07 17:41 - 2017-09-07 17:41 - 000200932 _____ C:\Users\papeter\Desktop\15-HIGH-PAYING-AFFILIATE-PROGRAMS.pdf
        2017-09-07 10:36 - 2017-09-07 10:36 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\0AEA3549.sys
        2017-09-07 00:01 - 2017-09-07 00:01 - 000000087 _____ C:\Users\papeter\Documents\Frans lead gen sites re interview with Michael Cyger.txt
        2017-09-06 23:37 - 2017-09-06 23:37 - 000007672 _____ C:\Users\papeter\Downloads\estibot-export(63).csv
        2017-09-06 22:33 - 2017-09-06 22:33 - 000000093 _____ C:\Users\papeter\Documents\sky.txt
        2017-09-06 16:33 - 2017-09-06 16:33 - 000000044 _____ C:\Users\papeter\Documents\yes.txt
        2017-09-06 14:00 - 2017-09-06 14:00 - 000199680 _____ C:\Users\papeter\Documents\FLIPFLOP 1.pub
        2017-09-05 23:13 - 2017-09-05 23:13 - 000355952 _____ C:\Users\papeter\Desktop\200SocialMediaTactics.pdf
        2017-09-05 19:03 - 2017-09-05 19:03 - 001489579 _____ C:\Users\papeter\Documents\The Unseen Therapist.pdf
        2017-09-05 14:37 - 2017-09-21 13:09 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HiSuite
        2017-09-05 14:37 - 2017-09-05 14:37 - 000001071 _____ C:\Users\Public\Desktop\HiSuite.lnk
        2017-09-05 14:37 - 2017-09-05 14:37 - 000000000 ____D C:\Program Files (x86)\HiSuite
        2017-09-04 21:29 - 2017-09-08 16:44 - 000000102 _____ C:\Users\papeter\Documents\Assets.txt
        2017-09-04 20:30 - 2017-09-04 20:30 - 000000043 _____ C:\Users\papeter\Documents\ceseare.txt
        2017-09-04 17:10 - 2017-09-04 17:10 - 000000056 _____ C:\Users\papeter\Documents\Amazon pending review for t-shirts.txt
        2017-09-03 12:09 - 2017-09-03 12:11 - 357891850 _____ C:\Users\papeter\Downloads\TextSuiteBonus2(2).zip
        2017-09-03 00:41 - 2017-09-03 00:41 - 000000446 _____ C:\Users\papeter\Documents\BLASTERSUITE REFUND REQUEST.txt
        2017-09-01 12:38 - 2017-09-01 12:38 - 000599552 _____ C:\Users\papeter\Documents\ADPACK5.pub
        2017-09-01 12:33 - 2017-09-01 12:33 - 000396800 _____ C:\Users\papeter\Documents\ADPACK4.pub
        2017-09-01 12:29 - 2017-09-01 12:29 - 000334336 _____ C:\Users\papeter\Documents\ADPACKPRO 2.pub
        2017-09-01 12:28 - 2017-09-01 12:28 - 000509440 _____ C:\Users\papeter\Documents\ADPACKPRO 1.pub
        2017-08-31 20:55 - 2017-08-31 20:55 - 004125071 _____ C:\Users\papeter\Desktop\UNSEENTHERPIST.pdf
        2017-08-29 22:33 - 2017-08-29 22:33 - 000182272 _____ C:\Users\papeter\Documents\Google traffic.pub
        2017-08-29 20:15 - 2017-08-29 20:15 - 000087584 _____ (AO Kaspersky Lab) C:\WINDOWS\system32\Drivers\klupd_klif_kimul.sys
        2017-08-29 17:26 - 2017-08-29 20:01 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\19292FEB.sys
        2017-08-27 00:19 - 2017-08-28 18:55 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\514C021D.sys
        2017-09-26 17:52 - 2015-10-15 22:17 - 000000000 ____D C:\Users\papeter\Documents\Outlook Files
        2017-09-26 16:56 - 2015-10-15 23:30 - 000000000 ____D C:\ProgramData\Kaspersky Lab
        2017-09-26 16:56 - 2015-08-25 15:18 - 000000000 ____D C:\Users\papeter\AppData\Local\Adobe
        2017-09-26 15:45 - 2016-05-19 15:26 - 000000000 ____D C:\ProgramData\CanonIJPLM
        2017-09-26 15:43 - 2015-08-23 23:25 - 000000000 __SHD C:\Users\papeter\IntelGraphicsProfiles
        2017-09-26 11:54 - 2015-10-17 16:31 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MBAMSwissArmy.sys
        2017-09-26 11:37 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\appcompat
        2017-09-26 00:35 - 2017-03-18 22:01 - 000000000 ____D C:\WINDOWS\INF
        2017-09-25 15:04 - 2016-04-09 11:20 - 000000000 ____D C:\ProgramData\Malwarebytes Anti-Exploit
        2017-09-25 08:43 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\AppReadiness
        2017-09-24 23:11 - 2015-02-05 22:53 - 000000000 ____D C:\ProgramData\Package Cache
        2017-09-24 20:06 - 2017-03-18 12:40 - 000786432 _____ C:\WINDOWS\system32\config\BBI
        2017-09-24 20:06 - 2016-09-05 11:22 - 000000000 ____D C:\ProgramData\NVIDIA
        2017-09-24 16:22 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\NDF
        2017-09-24 16:11 - 2017-03-18 22:03 - 000000000 ___HD C:\Program Files\WindowsApps
        2017-09-23 22:36 - 2016-10-13 10:29 - 000000000 ____D C:\Program Files\Common Files\AV
        2017-09-23 22:15 - 2015-08-23 23:25 - 000000000 ____D C:\Users\papeter\AppData\Local\Packages
        2017-09-23 15:27 - 2015-10-20 21:34 - 000938133 _____ C:\Users\papeter\Desktop\MY DOMAINS (2) (Autosaved).xlsx
        2017-09-22 17:28 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\LiveKernelReports
        2017-09-21 21:48 - 2017-03-18 22:03 - 000028672 _____ C:\WINDOWS\system32\config\BCD-Template
        2017-09-21 21:45 - 2017-03-18 22:06 - 000000000 ____D C:\WINDOWS\Setup
        2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ___SD C:\WINDOWS\SysWOW64\F12
        2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ___SD C:\WINDOWS\system32\F12
        2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\WinMetadata
        2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\setup
        2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\WinMetadata
        2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\WinBioPlugIns
        2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\setup
        2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\ShellExperiences
        2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\Program Files\Windows Photo Viewer
        2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\Program Files (x86)\Windows Photo Viewer
        2017-09-21 21:33 - 2017-03-19 03:30 - 000000000 ____D C:\WINDOWS\OCR
        2017-09-21 16:05 - 2017-03-18 21:51 - 000000000 ____D C:\WINDOWS\CbsTemp
        2017-09-21 14:15 - 2015-12-17 09:46 - 000002460 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Outlook 2016.lnk
        2017-09-21 14:08 - 2015-10-15 20:29 - 000002380 _____ C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\OneDrive.lnk
        2017-09-21 14:08 - 2015-10-15 17:37 - 000000000 ___RD C:\Users\papeter\OneDrive
        2017-09-21 14:03 - 2017-03-18 22:03 - 000000000 ___RD C:\WINDOWS\ImmersiveControlPanel
        2017-09-21 14:03 - 2015-09-10 06:42 - 000000000 __RHD C:\Users\Public\AccountPictures
        2017-09-21 13:42 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\rescache
        2017-09-21 13:41 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\WinBioDatabase
        2017-09-21 13:31 - 2016-07-16 12:47 - 000000000 ____D C:\WINDOWS\system32\Tasks_Migrated
        2017-09-21 13:29 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\Registration
        2017-09-21 13:29 - 2016-06-20 23:41 - 000057424 _____ (AO Kaspersky Lab) C:\WINDOWS\system32\Drivers\klim6.sys
        2017-09-21 13:21 - 2017-03-19 03:31 - 000000000 ____D C:\WINDOWS\HoloShell
        2017-09-21 13:20 - 2016-01-25 00:20 - 000000662 _____ C:\WINDOWS\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001.job
        2017-09-21 13:20 - 2016-01-25 00:20 - 000000566 _____ C:\WINDOWS\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001.job
        2017-09-21 13:20 - 2015-10-15 20:15 - 000022840 _____ C:\WINDOWS\system32\emptyregdb.dat
        2017-09-21 13:19 - 2017-03-18 22:03 - 000000000 __RSD C:\WINDOWS\Media
        2017-09-21 13:19 - 2017-03-18 22:03 - 000000000 __RHD C:\Users\Public\Libraries
        2017-09-21 13:15 - 2016-10-28 20:32 - 000002283 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
        2017-09-21 13:15 - 2015-02-05 23:04 - 000889694 _____ C:\WINDOWS\SysWOW64\PerfStringBackup.INI
        2017-09-21 13:09 - 2017-08-21 20:11 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Privax
        2017-09-21 13:09 - 2017-07-11 22:23 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
        2017-09-21 13:09 - 2017-07-06 23:06 - 000000000 ____D C:\WINDOWS\system32\UNP
        2017-09-21 13:09 - 2017-06-21 15:31 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Zoom
        2017-09-21 13:09 - 2017-03-27 12:15 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NETGEAR WNDA3100v3 Genie
        2017-09-21 13:09 - 2017-03-18 22:03 - 000000000 ____D C:\ProgramData\regid.1991-06.com.microsoft
        2017-09-21 13:09 - 2016-10-13 10:34 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kaspersky Secure Connection
        2017-09-21 13:09 - 2016-10-13 10:34 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kaspersky Internet Security
        2017-09-21 13:09 - 2016-05-24 10:04 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Recuva
        2017-09-21 13:09 - 2016-05-19 15:36 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon MG7700 series User Registration
        2017-09-21 13:09 - 2016-05-19 15:33 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon MG7700 series Manual
        2017-09-21 13:09 - 2016-04-09 11:20 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes Anti-Exploit
        2017-09-21 13:09 - 2016-04-01 16:11 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner
        2017-09-21 13:09 - 2016-03-02 19:43 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Screencast-O-Matic v2.0
        2017-09-21 13:09 - 2016-02-25 01:30 - 000000000 ____D C:\ProgramData\regid.1986-12.com.adobe
        2017-09-21 13:09 - 2016-02-07 12:41 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight
        2017-09-21 13:09 - 2016-02-07 12:13 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN
        2017-09-21 13:09 - 2016-02-01 13:16 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\webplugin.exe
        2017-09-21 13:09 - 2016-01-16 19:20 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Picasa 3
        2017-09-21 13:09 - 2015-12-01 18:18 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Interst Architect
        2017-09-21 13:09 - 2015-10-22 17:00 - 000000000 ____D C:\WINDOWS\system32\STRING
        2017-09-21 13:09 - 2015-10-17 16:31 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes Anti-Malware
        2017-09-21 13:09 - 2015-10-15 17:30 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2016 Tools
        2017-09-21 13:09 - 2015-02-05 23:52 - 000000000 ___RD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CyberLink PowerDirector 10
        2017-09-21 13:09 - 2015-02-05 23:48 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Lenovo
        2017-09-21 13:09 - 2015-02-05 23:03 - 000000000 ___RD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel
        2017-09-21 13:09 - 2015-02-05 23:01 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation
        2017-09-21 13:08 - 2017-07-24 23:13 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Alexander Kabakov
        2017-09-21 13:08 - 2017-03-18 12:40 - 000008192 _____ C:\WINDOWS\system32\config\ELAM
        2017-09-21 13:08 - 2016-12-01 21:10 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Microsoft Corporation
        2017-09-21 13:08 - 2016-07-30 18:17 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Lenovo
        2017-09-21 13:08 - 2016-07-09 22:38 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Google Photos Backup
        2017-09-21 13:08 - 2016-05-08 21:11 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\IrfanView
        2017-09-21 13:08 - 2016-02-06 18:37 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Handbrake
        2017-09-21 13:07 - 2015-10-30 07:28 - 000000000 ____D C:\Users\Default.migrated
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\Macromed
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\lv-LV
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\lt-LT
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\et-EE
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\en-GB
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\spool
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\oobe
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\Macromed
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\lv-LV
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\lt-LT
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\InputMethod
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\et-EE
        2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\en-GB
        2017-09-21 13:02 - 2016-01-05 15:18 - 000000000 ____D C:\WINDOWS\SysWOW64\spool
        2017-09-21 13:02 - 2015-02-05 23:23 - 000000000 ____D C:\WINDOWS\SysWOW64\Lenovo
        2017-09-21 13:02 - 2015-02-05 23:23 - 000000000 ____D C:\WINDOWS\system32\Lenovo
        2017-09-21 13:02 - 2013-08-22 16:36 - 000000000 ____D C:\WINDOWS\system32\WindowsInternal.Inbox.Shared
        2017-09-21 13:02 - 2013-08-22 16:36 - 000000000 ____D C:\WINDOWS\system32\WindowsInternal.Inbox.Media.Sh ared
        2017-09-21 13:01 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\InputMethod
        2017-09-21 13:01 - 2017-03-18 22:03 - 000000000 ____D C:\ProgramData\USOPrivate
        2017-09-21 13:01 - 2016-05-19 15:31 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon Utilities
        2017-09-21 13:01 - 2016-05-18 20:45 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\EPSON
        2017-09-21 13:01 - 2015-02-05 23:54 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nuance
        2017-09-21 13:01 - 2015-02-05 23:07 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Conexant
        2017-09-21 13:00 - 2017-03-18 22:03 - 000000000 ____D C:\Program Files\Common Files\microsoft shared
        2017-09-21 12:58 - 2017-01-16 15:37 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Chrome Apps
        2017-09-21 12:55 - 2017-03-18 12:40 - 000000000 ____D C:\WINDOWS\system32\Sysprep
        2017-09-21 12:54 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\Help
        2017-09-21 12:03 - 2017-07-11 07:54 - 000000000 ___HD C:$WINDOWS.~BT
        2017-09-20 10:34 - 2017-02-13 20:23 - 000000000 ____D C:\Users\papeter\AppData\Local\CrashDumps
        2017-09-19 00:19 - 2016-03-02 19:43 - 000000000 ____D C:\Users\papeter\AppData\Local\Screencast-O-Matic-v2
        2017-09-18 18:19 - 2016-04-01 16:11 - 000000000 ____D C:\Program Files\CCleaner
        2017-09-18 14:57 - 2017-07-08 20:48 - 000000000 ____D C:\Users\papeter\AppData\Local\GoToMeeting
        2017-09-17 23:50 - 2016-02-07 12:14 - 000000000 ____D C:\Users\papeter\AppData\Roaming\vlc
        2017-09-15 21:44 - 2015-02-05 23:48 - 000000000 ____D C:\Program Files (x86)\Microsoft Office
        2017-09-14 09:11 - 2016-07-30 18:17 - 000000000 ____D C:\Users\papeter\AppData\Local\Apps\2.0
        2017-09-14 00:11 - 2016-06-27 00:20 - 000000000 ____D C:\Program Files (x86)\HMA! Pro VPN
        2017-09-13 17:09 - 2015-08-25 09:13 - 000000000 ____D C:\WINDOWS\system32\MRT
        2017-09-13 17:04 - 2015-08-25 09:13 - 138202976 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
        2017-09-05 23:12 - 2015-10-29 16:21 - 000000000 ____D C:\Users\papeter\Documents\MARKETING
        2017-09-05 17:58 - 2016-05-24 10:04 - 000000000 ____D C:\Program Files\Recuva
        2017-09-05 14:43 - 2016-10-25 14:23 - 000000000 ____D C:\Users\papeter\AppData\Local\Hisuite
        2017-09-03 12:16 - 2017-08-17 23:38 - 491558047 _____ C:\Users\papeter\Desktop\TextSuiteBonus2.mp4
        2017-09-02 16:15 - 2017-03-18 22:06 - 000835576 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
        2017-09-02 16:15 - 2017-03-18 22:06 - 000177656 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
        2017-08-31 21:30 - 2015-10-17 16:11 - 000002457 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acrobat Reader DC.lnk
        2017-08-27 18:11 - 2017-04-20 12:35 - 000000000 ____D C:\Program Files (x86)\Mozilla Firefox
        2017-08-27 18:11 - 2015-08-24 11:46 - 000000000 ____D C:\Program Files (x86)\Mozilla Maintenance Service
        2016-06-22 09:54 - 2016-12-01 17:41 - 000577414 _____ () C:\Users\papeter\AppData\Roaming\Scorch_Install.lo g
        2016-01-26 18:24 - 2017-04-27 00:22 - 000005632 _____ () C:\Users\papeter\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
        2016-03-31 09:56 - 2016-03-31 09:56 - 000007609 _____ () C:\Users\papeter\AppData\Local\Resmon.ResmonCfg
        2017-09-21 12:53 - 2017-09-21 12:53 - 000000000 ____H () C:\ProgramData\DP45977C.lfl
        LastRegBack: 2017-09-21 12:49
        • jmarket
          PCHF Owner
          • 7695
          • CachyOS
          • Intel Arc A770 (16 GB)
          Zoek Scan
          Disable your antivirus prior to this scan.
          Download Zoek
          Save the file to your desktop.
          Right click Zoek.exe and run as administrator. (XP Users double click)
          Copy and paste the items in red below and paste them into Zoek.
          createsrpoint;
          emptyfolderscheck;delete
          emptyclsid;
          emptyalltemp;
          ipconfig /flushdns;b
          ResetHosts;
          autoclean;
          Now hit the run script button.
          The log will appear after a reboot, also you can find it on the C: drive.
          Post the log in your next reply.
          [li]Shut down your anti-virus, anti-spyware, and firewall software now to avoid potential conflicts.[/li][/ul]
          [li]Run the tool by double-clicking it. If you are using Windows Vista or Windows 7, right-click it and select Run as administrator.[/li][/ul]
          [li]The tool will open and start scanning your system.[/li][/ul]
          [li]Please be patient as this can take a while to complete depending on your system’s specifications.[/li][/ul]
          [li]On completion, a log is saved to your desktop and will automatically open.[/li][/ul]
          [li]Please post the JRT log.[/li][/ul]
          We will need a log from AdwCleaner for further information.
          Please download a copy of AdwCleaner from HERE, it is important to download it to your desktop.
          Once downloaded to the desktop AdwCleaner will create an icon https://pchelpforum.net/attachments/...160702-jpg.828
          Should you receive any security warnings or your User Account Control warning appears whilst you are using this application you can safely allow AdwCleaner to continue.
          Before running AdwCleaner please ensure all other programs and browsers are closed, then double left click the icon to open it.
          AdwCleaner will open, click the scan button to start searching.
          The scan may take some time to complete, and when it has any malware found will be automatically selected for quarantining. Click the “Cleaning” button.
          After a few seconds a message should tell you your computer will now reboot. Allow the reboot.
          When the computer restarts a log file will be displayed, but if its closed for any reason before copying the contents, you will find a copy of the file if you navigate to C:\AdwCleaner[s#].txt
          Please Copy and Paste the contents of the log file with your next reply.
          • papeter
            • Feb 2017
            • 33
            This is the log from the Zoek scan: ( I will be doing the Junk Removal Tool as soon as I can) It’s getting late in the UK!
            Zoek.exe v5.0.0.1 Updated 27-09-2015
            Tool run by papeter on 26/09/2017 at 22:48:21.10.
            Microsoft Windows 10 Home 10.0.15063 x64
            Running in: Normal Mode No Internet Access Detected
            Launched: C:\Users\papeter\Downloads\zoek.exe [Scan all users] [Script inserted]
            ==== System Restore Info ======================
            26/09/2017 22:50:43 Zoek.exe System Restore Point Created Successfully.
            ==== Reset Hosts File ======================
            [HEADING=1]Copyright (c) 1993-2006 Microsoft Corp.[/HEADING]
            [HEADING=1]This is a sample HOSTS file used by Microsoft TCP/IP for Windows.[/HEADING]
            [HEADING=1]This file contains the mappings of IP addresses to host names. Each[/HEADING]
            [HEADING=1]entry should be kept on an individual line. The IP address should[/HEADING]
            [HEADING=1]be placed in the first column followed by the corresponding host name.[/HEADING]
            [HEADING=1]The IP address and the host name should be separated by at least one[/HEADING]
            [HEADING=1]space.[/HEADING]
            [HEADING=1]Additionally, comments (such as these) may be inserted on individual[/HEADING]
            [HEADING=1]lines or following the machine name denoted by a ‘#’ symbol.[/HEADING]
            [HEADING=1]For example:[/HEADING]
            [HEADING=1]102.54.94.97 rhino.acme.com # source server[/HEADING]
            [HEADING=1]38.25.63.10 x.acme.com # x client host[/HEADING]
            127.0.0.1 localhost
            ==== Empty Folders Check ======================
            C:\PROGRA~2\AGEIA Technologies deleted successfully
            C:\PROGRA~2\epson deleted successfully
            C:\PROGRA~2\New Folder deleted successfully
            C:\PROGRA~2\onOne Software deleted successfully
            C:\Program Files\Nitro deleted successfully
            C:\Program Files\onOne Software deleted successfully
            C:\PROGRA~3\Canon IJ Network Tool deleted successfully
            C:\PROGRA~3\CanonIJPLM deleted successfully
            C:\PROGRA~3\Comms deleted successfully
            C:\PROGRA~3\Nalpeiron deleted successfully
            C:\PROGRA~3\Office2013 deleted successfully
            C:\PROGRA~3\SoftwareDistribution deleted successfully
            C:\WINDOWS\serviceprofiles\networkservice\AppData\ LocalLow deleted successfully
            C:\Users\papeter\AppData\Local\ActiveSync deleted successfully
            C:\Users\papeter\AppData\Local\CrashDumps deleted successfully
            C:\Users\papeter\AppData\Local\DBG deleted successfully
            C:\Users\papeter\AppData\Local\EmieBrowserModeList deleted successfully
            C:\Users\papeter\AppData\Local\EmieSiteList deleted successfully
            C:\Users\papeter\AppData\Local\EmieUserList deleted successfully
            C:\Users\papeter\AppData\Local\NetworkTiles deleted successfully
            C:\WINDOWS\serviceprofiles\networkservice\AppData\ Local\Maps deleted successfully
            C:\WINDOWS\serviceprofiles\Localservice\AppData\Lo cal\NetworkTiles deleted successfully
            ==== Deleting CLSID Registry Keys ======================
            ==== Deleting CLSID Registry Values ======================
            ==== Deleting Services ======================
            ==== Batch Command(s) Run By Tool======================
            ==== Deleting Files \ Folders ======================
            C:\PROGRA~2\AGEIA Technologies not found
            C:\PROGRA~2\epson not found
            C:\PROGRA~2\New Folder not found
            C:\PROGRA~2\onOne Software not found
            C:\PROGRA~2\webplugin.exe deleted
            C:\Users\papeter\AppData\Roaming\amazeowl-desktop deleted
            C:\Users\papeter.android deleted
            C:\WINDOWS\sysWoW64\config\systemprofile.android deleted
            C:\PROGRA~2\ExpressVpn Tap Driver Win10 deleted
            C:\Users\Public\Pokki deleted
            C:\PROGRA~3\Package Cache deleted
            C:\Users\papeter\AppData\Roaming\Mozilla\Firefox\P rofiles\ee8pm1a2.default-1446908155165\Invalidprefs.js deleted
            C:\Users\papeter\AppData\Roaming\Mozilla\Firefox\P rofiles\ee8pm1a2.default-1446908155165\jetpack deleted
            ==== Firefox Extensions Registry ======================
            [HKEY_LOCAL_MACHINE\Software\Mozilla\Firefox\Extens ions]
            light_plugin_F6F079488B53499DB99380A...asp ersky.com”=“C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\FFExt\light_plugin_firefox\addon.xpi” [25/07/2017 11:58]
            [HKEY_LOCAL_MACHINE\Software\Wow6432Node\Mozilla\Fi refox\Extensions]
            ==== Firefox Extensions ======================
            ProfilePath: C:\Users\papeter\AppData\Roaming\Mozilla\Firefox\P rofiles\ee8pm1a2.default-1446908155165
            AppDir: C:\Program Files (x86)\Mozilla Firefox
            • Undetermined - %AppDir%\browser\extensions{972ce4c6-7e08-4474-a285-3208198ce6fd}.xpi
            ==== Firefox Plugins ======================
            Profilepath: C:\Users\papeter\AppData\Roaming\Mozilla\Firefox\P rofiles\ee8pm1a2.default-1446908155165
            D6A9BDBDE6AF1238DCC619EFA2FB0844 - C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_27_0_0_ 130.dll - Shockwave Flash
            56A8466F5175A400F8490777415728CD - C:\Users\papeter\AppData\Roaming\Zoom\bin\npzoompl ugin.dll - Zoom launcher - 3.0.1
            2D45A8274592D965EDFB62ACCB1150B1 - C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\npGoogleUpdate3.dll - Google Update
            D2E755D487FC57F6A9060F89724B8600 - C:\Program Files\webrec\WEB30\DVR32\3.1.0.4\npmedia.dll - npmediaDll Dynamic Link Library
            748A72495470C6B7DC6110FB83C7E53A - C:\Program Files\webrec\WEB30\DVR32\3.1.0.4\npTimeGrid.dll - TimeAxes
            328EEECD6DE8DDCB287F9E3A80846469 - C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\npGatewayNpapi-x64.dll - Skype Web Plugin
            D23D6FEF2818C5B62BCD80BCA70362CD - C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\npGatewayNpapi.dll - Skype Web Plugin
            ==== Chromium Look ======================
            HKEY_LOCAL_MACHINE\SOFTWARE\Google\Chrome\Extensio ns
            efaidnbmnnnibpcajpcglclefindmkaj - No path found
            fhoibnponjcgjgcnfacekaijdbbplhib - https://chrome.google.com/webstore/detail/fhoibnponjcgjgcnfacekaijdbbplhib[]
            Sizable Send - papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\abpoebooacbankjejohknechpi feimmi
            7.3.3.7 - papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\mlomiejdfkolichcflejclcbmp eaniij
            SEO for Chrome - papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\oangcciaeihlfmhppegpdceadp faoclj
            Chrome Media Router - papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcj beemfm
            ==== Set IE to Default ======================
            Old Values:
            [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
            “Start Page”=" http://www.google.com/ "
            [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes]
            “DefaultScope”=“{51B4207A-1DF4-4AB6-AB39-7FAE55BB94B0}”
            New Values:
            “DefaultScope”=“{012E1000-F331-11DB-8314-0800200C9A66}”
            ==== All HKCU SearchScopes ======================
            {012E1000-F331-11DB-8314-0800200C9A66} Google Url=" Google {searchTerms}"
            {0633EE93-D776-472f-A0FF-E1416B8B2E3A} Bing Url=" Search - Microsoft Bing {searchTerms}&src=IE-SearchBox&FORM=IESR02"
            {51B4207A-1DF4-4AB6-AB39-7FAE55BB94B0} Unknown Url=“Not_Found”
            HKEY_USERS\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Internet Explorer\SearchScopes{51B4207A-1DF4-4AB6-AB39-7FAE55BB94B0} deleted successfully
            HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\ Internet Explorer\SearchScopes{51B4207A-1DF4-4AB6-AB39-7FAE55BB94B0} deleted successfully
            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchScopes{51B4207A-1DF4-4AB6-AB39-7FAE55BB94B0} deleted successfully
            • papeter
              • Feb 2017
              • 33
              Adware Cleaner Log:
              [HEADING=1]AdwCleaner 7.0.2.1 - Logfile created on Tue Sep 26 22:55:47 2017[/HEADING]
              [HEADING=1]Updated on 2017/29/08 by Malwarebytes[/HEADING]
              [HEADING=1]Running on Windows 10 Home (X64)[/HEADING]
              [HEADING=1]Mode: clean[/HEADING]
              [HEADING=1]Support: https://www.malwarebytes.com/support[/HEADING]
              ***** [ Services ] *****
              No malicious services deleted.
              ***** [ Folders ] *****
              No malicious folders deleted.
              ***** [ Files ] *****
              No malicious files deleted.
              ***** [ DLL ] *****
              No malicious DLLs cleaned.
              ***** [ WMI ] *****
              No malicious WMI cleaned.
              ***** [ Shortcuts ] *****
              No malicious shortcuts cleaned.
              ***** [ Tasks ] *****
              No malicious tasks deleted.
              ***** [ Registry ] *****
              Deleted: [Key] - HKLM\SOFTWARE\Classes\TypeLib{CB6BF8B6-E12B-42FA-A478-91BCCDE475DC}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\Interface{2E5FA7B4-61A2-4662-BBCE-62BBB20FC649}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\Interface{5D7F05E3-075A-43AF-8BC7-21E2F7F38845}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\Interface{617E26CE-E6E1-4C75-A68A-A001F2B98491}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\Interface{79FBDBEA-A722-4ABD-BEC0-B7D463F6BA0E}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\Interface{8128586C-DF69-4266-873F-CF4C6F705A7C}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\Interface{C1F9CFCE-A7DC-4072-8B31-1DEA57004C86}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\Interface{EA4AD895-2A7F-430E-B973-DEE6C4E743A9}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\Interface{EBF4B60F-A863-426F-BE6F-5DFE83BC574F}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\CLSID{9AD5C084-B6E6-456A-8BA2-A559663780E5}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\CLSID{70C7334A-66D9-46DE-A4E2-6B923C7DB94E}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\CLSID{5780633B-414C-446F-8EB2-FF1C9A731C99}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\CLSID{4EECDED2-40FB-4500-85B4-86FB0EBECA68}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\CLSID{10A7F29D-4B00-40EC-B07D-8616DF8135E6}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\CLSID{05FF6A00-76A3-4AA1-A9A4-A782152ABE60}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\CLSID{02966FA9-C01A-47E7-A169-C83AEA1FB0BA}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\Interface{3AE76A17-C344-4A83-81CE-65EFEE41E42D}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\Interface{4E9EB4D5-C929-4005-AC62-1856B1DA5A24}
              Deleted: [Key] - HKLM\SOFTWARE\Classes\Interface{8FAF962C-3EDE-405E-B1D0-62B8235C6044}
              Deleted: [Key] - HKLM\SOFTWARE\VisualDiscovery
              ***** [ Firefox (and derivatives) ] *****
              No malicious Firefox entries deleted.
              ***** [ Chromium (and derivatives) ] *****
              No malicious Chromium entries deleted.
              ::Tracing keys deleted
              ::Winsock settings cleared
              ::Additional Actions: 0
              C:/AdwCleaner/AdwCleaner[S0].txt - [2879 B] - [2017/9/26 22:48:7]
              ########## EOF - C:\AdwCleaner\AdwCleaner[C0].txt ##########
              • jmarket
                PCHF Owner
                • 7695
                • CachyOS
                Download attached fixlist.txt file and save it to the Desktop. NOTE. It’s important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system. Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
                After running the fix, please follow the below instructions
                • jmarket
                  PCHF Owner
                  • 7695
                  • CachyOS
                  After running the fixlist, please do the following:
                  [li]In the searchbox, type certmgr.msc. Right-click it and select Launch as Administrator.[/li][li]Click Trusted Root Certification Authorities and click Certificates[/li][li]Scroll down and find the Superfish, Inc. certificate.[/li][li]Right-click it and select Delete.[/li][li]If you get a pop-up, select Yes to confirm the deletion.[/li][li]Restart the browser[/li][/ul]
                  After doing all this, please post fresh FRST and Addition logs as well as the JRT log
                  • papeter
                    • Feb 2017
                    • 33
                    #10
                    Just to advse you that after running certmgr.msc. I could not find the Superfish, Inc. certificate.
                    [HEADING=1]Here is the Fixlog.txt:
                    Fix result of Farbar Recovery Scan Tool (x64) Version: 26-09-2017
                    Ran by papeter (27-09-2017 11:44:34) Run:2
                    Running from C:\Users\papeter\Desktop
                    Loaded Profiles: papeter (Available Profiles: papeter)
                    Boot Mode: Normal[/HEADING]
                    fixlist content:
                    start
                    CreateRestorePoint:
                    CloseProcesses:
                    CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{2AD206F1-152C-4F9D-A24E-6F93FE7A4AFC}\InprocServer32 → C:\Users\papeter\AppData\Local\Grammarly\Grammarly for Microsoft Office Suite\6.5.57\159674BA1BE84D9EA82E2649B83A4305\Gram marlyShim64.dll => No File
                    C:\Users\papeter\AppData\Local\Google\Update\1.3.3 0.3\psuser_64.dll => No File
                    CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{59B55F04-DE14-4BB8-92FF-C4A22EF2E5F4}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 1.5\psuser_64.dll => No File
                    CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{8C46158B-D978-483C-A312-16EE5013BE04}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.3\psuser_64.dll => No File
                    CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{CB492AF1-2CEF-4E58-BE47-471C77D0C8BA}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 2.7\psuser_64.dll => No File
                    ContextMenuHandlers5: [igfxcui] → {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => → No File
                    Task: {0AC65FA0-495B-4F4F-A25E-BFF79E288E9F} - \Microsoft\Windows\Setup\GWXTriggers\MachineUnlock-5d → No File <==== ATTENTION
                    Task: {220D3058-5A68-4F36-AB95-53BF41A1AD8B} - \Lenovo\Lenovo Service Bridge\S-1-5-21-4237603079-860989819-990887440-1001 → No File <==== ATTENTION
                    Task: {2503E967-7EFA-41A9-BAC3-831F529825E0} - \Microsoft\Windows\Setup\gwx\refreshgwxconfigandco ntent → No File <==== ATTENTION
                    Task: {2C62DFD5-E3F3-4792-A77C-0E863B4F459A} - \Microsoft\Windows\Setup\gwx\refreshgwxconfig → No File <==== ATTENTION
                    Task: {49C8F6D1-2C7B-4487-9026-F844DD98BDA1} - \Microsoft\Windows\Setup\gwx\refreshgwxcontent → No File <==== ATTENTION
                    Task: {656777A4-8F1C-404A-B82D-846913804747} - \Microsoft\Windows\Setup\GWXTriggers\refreshgwxcon fig-B → No File <==== ATTENTION
                    Task: {705EAAAA-87FA-43D0-977E-45C77F6A18BF} - \Microsoft\Windows\Setup\GWXTriggers\Telemetry-4xd → No File <==== ATTENTION
                    Task: {84918C9D-6ED4-46B6-8A5E-5F9FCB2C3162} - \Microsoft\Windows\Setup\GWXTriggers\Logon-5d → No File <==== ATTENTION
                    Task: {B5C5E4AF-7018-4583-83D2-89C4CFDE7147} - \Microsoft\Windows\Setup\GWXTriggers\Time-5d → No File <==== ATTENTION
                    Task: {C3991814-F472-431F-AAED-63E5B65E7BFD} - \Microsoft\Windows\Setup\gwx\launchtrayprocess → No File <==== ATTENTION
                    Task: {CBBBB535-A971-4790-9F7F-1C6475FAADE4} - \Microsoft\Windows\Setup\GWXTriggers\OutOfSleep-5d → No File <==== ATTENTION
                    Task: {CBF4A7BB-07E0-4F39-9264-71BF6C2BEC0D} - \Microsoft\Windows\Setup\GWXTriggers\OutOfIdle-5d → No File <==== ATTENTION
                    Task: {E28DA3B9-7390-471A-9CA0-A95E4459FB78} - \WPD\SqmUpload_S-1-5-21-4237603079-860989819-990887440-1001 → No File <==== ATTENTION
                    RemoveProxy:
                    EmptyTemp:
                    reboot:
                    end
                    HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{2AD206F1-152C-4F9D-A24E-6F93FE7A4AFC} => key not found.
                    “C:\Users\papeter\AppData\Local\Google\Update\1.3. 30.3\psuser_64.dll => No File” => not found.
                    HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{59B55F04-DE14-4BB8-92FF-C4A22EF2E5F4} => key not found.
                    HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{8C46158B-D978-483C-A312-16EE5013BE04} => key not found.
                    HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{CB492AF1-2CEF-4E58-BE47-471C77D0C8BA} => key not found.
                    HKLM\Software\Classes\Directory\Background\ShellEx \ContextMenuHandlers\igfxcui => key not found.
                    HKLM\Software\Classes\CLSID{3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => key not found.
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{0AC65FA 0-495B-4F4F-A25E-BFF79E288E9F} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{0AC65FA 0-495B-4F4F-A25E-BFF79E288E9F} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\GWXTriggers\MachineUnlock-5d => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{220D305 8-5A68-4F36-AB95-53BF41A1AD8B} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{220D305 8-5A68-4F36-AB95-53BF41A1AD8B} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Lenovo\L enovo Service Bridge\S-1-5-21-4237603079-860989819-990887440-1001 => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{2503E96 7-7EFA-41A9-BAC3-831F529825E0} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{2503E96 7-7EFA-41A9-BAC3-831F529825E0} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\gwx\refreshgwxconfigandcontent => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{2C62DFD 5-E3F3-4792-A77C-0E863B4F459A} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{2C62DFD 5-E3F3-4792-A77C-0E863B4F459A} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\gwx\refreshgwxconfig => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{49C8F6D 1-2C7B-4487-9026-F844DD98BDA1} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{49C8F6D 1-2C7B-4487-9026-F844DD98BDA1} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\gwx\refreshgwxcontent => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{656777A 4-8F1C-404A-B82D-846913804747} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{656777A 4-8F1C-404A-B82D-846913804747} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\GWXTriggers\refreshgwxconfig-B => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{705EAAA A-87FA-43D0-977E-45C77F6A18BF} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{705EAAA A-87FA-43D0-977E-45C77F6A18BF} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\GWXTriggers\Telemetry-4xd => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{84918C9 D-6ED4-46B6-8A5E-5F9FCB2C3162} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{84918C9 D-6ED4-46B6-8A5E-5F9FCB2C3162} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\GWXTriggers\Logon-5d => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{B5C5E4A F-7018-4583-83D2-89C4CFDE7147} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{B5C5E4A F-7018-4583-83D2-89C4CFDE7147} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\GWXTriggers\Time-5d => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{C399181 4-F472-431F-AAED-63E5B65E7BFD} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{C399181 4-F472-431F-AAED-63E5B65E7BFD} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\gwx\launchtrayprocess => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{CBBBB53 5-A971-4790-9F7F-1C6475FAADE4} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{CBBBB53 5-A971-4790-9F7F-1C6475FAADE4} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\GWXTriggers\OutOfSleep-5d => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{CBF4A7B B-07E0-4F39-9264-71BF6C2BEC0D} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{CBF4A7B B-07E0-4F39-9264-71BF6C2BEC0D} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\GWXTriggers\OutOfIdle-5d => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{E28DA3B 9-7390-471A-9CA0-A95E4459FB78} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{E28DA3B 9-7390-471A-9CA0-A95E4459FB78} => key removed successfully
                    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\WPD\SqmU pload_S-1-5-21-4237603079-860989819-990887440-1001 => key removed successfully
                    HKU.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVers ion\Internet Settings\Connections\DefaultConnectionSettings => value removed successfully
                    HKU.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVers ion\Internet Settings\Connections\SavedLegacySettings => value removed successfully
                    HKU\S-1-5-21-4237603079-860989819-990887440-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings\Connections\DefaultConnectionSettings => value removed successfully
                    HKU\S-1-5-21-4237603079-860989819-990887440-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings\Connections\SavedLegacySettings => value removed successfully
                    BITS transfer queue => 7888896 B
                    DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 39436796 B
                    Java, Flash, Steam htmlcache => 1242 B
                    Windows/system/drivers => 1180301 B
                    Edge => 0 B
                    Chrome => 1372160 B
                    Firefox => 29889986 B
                    Opera => 0 B
                    Default => 0 B
                    Users => 0 B
                    ProgramData => 0 B
                    Public => 0 B
                    systemprofile => 128 B
                    systemprofile32 => 47604 B
                    LocalService => 3306 B
                    NetworkService => 0 B
                    papeter => 172230361 B
                    RecycleBin => 0 B
                    EmptyTemp: => 240.4 MB temporary data Removed.
                    The system needed a reboot.
                    ==== End of Fixlog 11:45:01 ====
                    • papeter
                      • Feb 2017
                      • 33
                      #11
                      Here is the FRST64 SCAN:
                      Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 26-09-2017
                      Ran by papeter (administrator) on LENOVO-PC (27-09-2017 12:47:10)
                      Running from C:\Users\papeter\Downloads
                      Platform: Windows 10 Home Version 1703 (X64) Language: English (United States)
                      Internet Explorer Version 11 (Default browser: FF)
                      Boot Mode: Normal
                      Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic...ery-scan-tool/
                      (Intel Corporation) C:\Windows\System32\igfxCUIService.exe
                      (Microsoft Corporation) C:\Windows\System32\wlanext.exe
                      (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\avp.exe
                      (Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
                      (Lenovo Corporation) C:\Program Files\Lenovo\Communications Utility\AVControlCenter32.exe
                      (Broadcom Corporation.) C:\Windows\System32\BtwRSupportService.exe
                      (Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
                      (Microsoft Corporation) C:\Program Files\Common Files\microsoft shared\ClickToRun\OfficeClickToRun.exe
                      (Conexant Systems Inc.) C:\Windows\System32\CxAudMsg64.exe
                      (Nuance Communications, Inc.) C:\Program Files (x86)\Nuance\Dragon Assistant\Core\DACore.exe
                      () C:\Program Files (x86)\ExpressVPN\bootstrap\AMD64\nssm.exe
                      (AVAST Software) C:\Program Files (x86)\HMA! Pro VPN\vpnsvc.exe
                      (ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDService.exe
                      () C:\Program Files (x86)\HiSuite\HandSetService\HuaweiHiSuiteService6 4.exe
                      () C:\Program Files (x86)\Canon\IJPLM\ijplmsvc.exe
                      (Lenovo Group Limited) C:\Program Files\Lenovo\SettingsDependency\SettingsService.ex e
                      (LENOVO INCORPORATED.) C:\Program Files\Lenovo\iMController\SystemAgentService.exe
                      () C:\Program Files\Lenovo PhoneCompanion\LPAWDService.exe
                      (Lenovo(beijing) Limited) C:\Program Files (x86)\Lenovo\Lenovo Settings\x86\LenovoSetSvr.exe
                      (Lenovo(beijing) Limited) C:\Windows\System32\LenovoWiFiHotspotSvr.exe
                      (Malwarebytes Corporation) C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae-svc.exe
                      (Malwarebytes) C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe
                      (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe
                      (NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
                      (Lenovo) C:\Program Files\Lenovo PhoneCompanion\PhoneCompanionPusher.exe
                      () C:\Program Files\CyberLink\Shared files\RichVideo64.exe
                      (Lenovo Corporation) C:\Program Files\Lenovo\Communications Utility\avfaudiosw.exe
                      () C:\Program Files (x86)\ExpressVPN\xvpnd\xvpnd.exe
                      (Malwarebytes Corporation) C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae64.exe
                      (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe
                      (Lenovo) C:\Windows\System32\LenovoUpdate.exe
                      (ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrl.exe
                      (Microsoft Corporation) C:\Windows\Microsoft.NET\Framework64\v3.0\WPF\Pres entationFontCache.exe
                      (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\avpui.exe
                      (ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrlHelper.exe
                      (Google Inc.) C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler.ex e
                      (Google Inc.) C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler64. exe
                      (Intel Corporation) C:\Windows\System32\igfxEM.exe
                      (Intel Corporation) C:\Windows\System32\igfxHK.exe
                      () C:\Windows\System32\igfxTray.exe
                      (CyberLink Corp.) C:\Program Files (x86)\Lenovo\PowerDVD10\PDVD10Serv.exe
                      (Microsoft Corporation) C:\Program Files\Windows Defender\MSASCuiL.exe
                      (Realtek semiconductor) C:\Windows\RTFTrack.exe
                      (NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe
                      () C:\Program Files\CONEXANT\ForteConfig\fmapp.exe
                      (Conexant Systems, Inc.) C:\Program Files\CONEXANT\cAudioFilterAgent\CAudioFilterAgent 64.exe
                      (Lenovo(beijing) Limited) C:\Program Files\Lenovo\LenovoUtility\utility.exe
                      (Lenovo) C:\Program Files\Lenovo PhoneCompanion\Phone Companion.exe
                      (Apple Inc.) C:\Program Files\iTunes\iTunesHelper.exe
                      (Google, Inc) C:\Users\papeter\AppData\Local\Programs\Google\Goo gle Photos Backup\Google Photos Backup.exe
                      (Piriform Ltd) C:\Program Files\CCleaner\CCleaner64.exe
                      (ExpressVPN) C:\Program Files (x86)\ExpressVPN\xvpn-ui\ExpressVpn.exe
                      (NETGEAR) C:\Program Files (x86)\NETGEAR\WNDA3100v3\WNDA3100v3.EXE
                      (Apple Inc.) C:\Program Files\iPod\bin\iPodService.exe
                      (Microsoft Corporation) C:\Program Files (x86)\Microsoft Office\root\Office16\ONENOTEM.EXE
                      (Adobe Systems Incorporated) C:\Program Files\Adobe\Elements 14 Organizer\PhotoshopElementsFileAgent.exe
                      () C:\Program Files\Lenovo PhoneCompanion\adb.exe
                      (Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
                      () C:\Program Files (x86)\Lenovo\CCSDK\CCSDK.exe
                      () C:\Program Files (x86)\Lenovo\CCSDK\WinGather.exe
                      (Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
                      (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\FWService\IntelMeFWService.exe
                      (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
                      (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Secure Connection 1.0\ksde.exe
                      (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
                      (AO Kaspersky Lab) C:\Program Files (x86)\Kaspersky Lab\Kaspersky Secure Connection 1.0\ksdeui.exe
                      (Lenovo Corporation) C:\Program Files\Lenovo\Communications Utility\tpknrres.exe
                      (Mozilla Corporation) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
                      (Microsoft Corporation) C:\Windows\SysWOW64\wbem\WmiPrvSE.exe
                      (Malwarebytes) C:\Users\papeter\Desktop\adwcleaner_7.0.2.1(1).exe
                      (Microsoft Corporation) C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\WinStore.App.exe
                      (Microsoft Corporation) C:\Windows\System32\InstallAgent.exe
                      (Microsoft Corporation) C:\Windows\System32\InstallAgentUserBroker.exe
                      () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17072.131 11.0_x64__8wekyb3d8bbwe\Video.UI.exe
                      (Microsoft Corporation) C:\Program Files\WindowsApps\microsoft.windowscommunicationsa pps_17.8500.40885.0_x64__8wekyb3d8bbwe\HxOutlook.e xe
                      (Microsoft Corporation) C:\Program Files\WindowsApps\microsoft.windowscommunicationsa pps_17.8500.40885.0_x64__8wekyb3d8bbwe\HxTsr.exe
                      (Microsoft Corporation) C:\Windows\System32\smartscreen.exe
                      (Farbar) C:\Users\papeter\Downloads\FRST64(1).exe
                      (Microsoft Corporation) C:\Windows\SysWOW64\SearchProtocolHost.exe
                      ==================== Registry (Whitelisted) ===========================
                      HKLM...\Run: [SecurityHealth] => C:\Program Files\Windows Defender\MSASCuiL.exe [629152 2017-03-18] (Microsoft Corporation)
                      HKLM...\Run: [ETDCtrl] => C:\Program Files\Elantech\ETDCtrl.exe [3242696 2015-10-07] (ELAN Microelectronics Corp.)
                      HKLM...\Run: [RtsFT] => C:\WINDOWS\RTFTrack.exe [5060864 2015-06-16] (Realtek semiconductor)
                      HKLM...\Run: [NvBackend] => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe [2473800 2014-09-09] (NVIDIA Corporation)
                      HKLM...\Run: [IAStorIcon] => C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe [320360 2014-06-25] (Intel Corporation)
                      HKLM...\Run: [ForteConfig] => C:\Program Files\Conexant\ForteConfig\fmapp.exe [49056 2010-10-26] ()
                      HKLM...\Run: [SmartAudio] => C:\Program Files\CONEXANT\SAII\SACpl.exe [1830616 2014-04-10] (Conexant Systems, Inc.)
                      HKLM...\Run: [cAudioFilterAgent] => C:\Program Files\Conexant\cAudioFilterAgent\cAudioFilterAgent 64.exe [916184 2014-07-03] (Conexant Systems, Inc.)
                      HKLM...\Run: [LenovoUtility] => C:\Program Files\Lenovo\LenovoUtility\utility.exe [10828056 2015-02-05] (Lenovo(beijing) Limited)
                      HKLM...\Run: [PhoneCompanion] => C:\Program Files\Lenovo PhoneCompanion\Phone Companion.exe [802800 2015-02-05] (Lenovo)
                      HKLM...\Run: [LMCSSTART1] => C:\Program Files\Lenovo\Communications Utility\lmcsctrl.exe [30152 2015-03-23] (Lenovo Corporation)
                      HKLM...\Run: [LMCSSTART2] => C:\Program Files\Lenovo\Communications Utility\lmcsctrl.exe [30152 2015-03-23] (Lenovo Corporation)
                      HKLM...\Run: [LMCSSTART3] => C:\Program Files\Lenovo\Communications Utility\lmcsctrl.exe [30152 2015-03-23] (Lenovo Corporation)
                      HKLM...\Run: [AdobeAAMUpdater-1.0] => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.e xe [508104 2015-07-29] (Adobe Systems Incorporated)
                      HKLM...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [303928 2017-05-09] (Apple Inc.)
                      HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [CCleaner Monitoring] => C:\Program Files\CCleaner\CCleaner64.exe [9856176 2017-09-20] (Piriform Ltd)
                      HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [Google Update] => C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\GoogleUpdateCore.exe [601168 2017-04-29] (Google Inc.)
                      HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [Google Photos Backup] => C:\Users\papeter\AppData\Local\Programs\Google\Goo gle Photos Backup\Google Photos Backup.exe [3790936 2016-04-08] (Google, Inc)
                      HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Run: [ExpressVPN4] => C:\Program Files (x86)\ExpressVPN\xvpn-ui\ExpressVpn.exe [806528 2017-07-06] (ExpressVPN)
                      HKU\S-1-5-21-4237603079-860989819-990887440-1001...\MountPoints2: {265574b1-9573-11e7-8309-38b1dbdbd186} - “F:\HiSuiteDownLoader.exe”
                      Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\NETGEAR WNDA3100v3 Genie.lnk [2017-03-27]
                      ShortcutTarget: NETGEAR WNDA3100v3 Genie.lnk → C:\Program Files (x86)\NETGEAR\WNDA3100v3\WNDA3100v3.EXE (NETGEAR)
                      Startup: C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Startup\Send to OneNote.lnk [2017-08-21]
                      ShortcutTarget: Send to OneNote.lnk → C:\Program Files (x86)\Microsoft Office\root\Office16\ONENOTEM.EXE (Microsoft Corporation)
                      Tcpip\Parameters: [DhcpNameServer] 192.168.1.1
                      Tcpip..\Interfaces{43520b0a-4f6b-4271-bd91-0e94ebbbdbff}: [DhcpNameServer] 62.24.243.4 62.24.128.198
                      Tcpip..\Interfaces{776a1195-9cf2-49ea-962f-fbed2f21c1fd}: [DhcpNameServer] 8.8.8.8 8.8.4.4
                      Tcpip..\Interfaces{798b3fb4-2b0f-4349-8753-1c69617f003c}: [DhcpNameServer] 192.168.1.1
                      Tcpip..\Interfaces{8a951e76-1a52-472e-b275-8e344bcfc594}: [DhcpNameServer] 192.168.1.1
                      Tcpip..\Interfaces{9c0c9f0b-e558-47dd-84e5-2b139e86df58}: [DhcpNameServer] 10.163.0.1
                      Tcpip..\Interfaces{c395cc9b-863d-41bd-b910-9b8c72cc7e3e}: [NameServer] 77.234.40.79
                      [HEADING=1]Internet Explorer:[/HEADING]
                      HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = hxxp://lenovo13.msn.com/?pc=LCJB
                      HKU\S-1-5-21-4237603079-860989819-990887440-1001\Software\Microsoft\Internet Explorer\Main,Secondary Start Pages = hxxp://www.lenovo.com
                      SearchScopes: HKLM → DefaultScope {51B4207A-1DF4-4AB6-AB39-7FAE55BB94B0} URL =
                      SearchScopes: HKLM-x32 → DefaultScope {51B4207A-1DF4-4AB6-AB39-7FAE55BB94B0} URL =
                      SearchScopes: HKU\S-1-5-21-4237603079-860989819-990887440-1001 → DefaultScope {012E1000-F331-11DB-8314-0800200C9A66} URL = hxxp://www.google.com/search?q={searchTerms}
                      SearchScopes: HKU\S-1-5-21-4237603079-860989819-990887440-1001 → {012E1000-F331-11DB-8314-0800200C9A66} URL = hxxp://www.google.com/search?q={searchTerms}
                      BHO: Kaspersky Protection → {2E38825B-8815-42CF-9126-C58BC28D4591} → C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
                      BHO: Lync Browser Helper → {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} → C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\OCHelper.dll [2017-09-15] (Microsoft Corporation)
                      BHO: Canon Easy-WebPrint EX BHO → {3785D0AD-BFFF-47F6-BF5B-A587C162FED9} → C:\Program Files\Canon\Easy-WebPrint EX\ewpexbho.dll [2015-02-23] (CANON INC.)
                      BHO: Microsoft OneDrive for Business Browser Helper → {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} → C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\GROOVEEX.DLL [2017-09-15] (Microsoft Corporation)
                      BHO-x32: Kaspersky Protection → {2E38825B-8815-42CF-9126-C58BC28D4591} → C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
                      BHO-x32: Canon Easy-WebPrint EX BHO → {3785D0AD-BFFF-47F6-BF5B-A587C162FED9} → C:\Program Files (x86)\Canon\Easy-WebPrint EX\ewpexbho.dll [2015-02-23] (CANON INC.)
                      Toolbar: HKLM - Canon Easy-WebPrint EX - {759D9886-0C6F-4498-BAB6-4A5F47C6C72F} - C:\Program Files\Canon\Easy-WebPrint EX\ewpexhlp.dll [2015-02-23] (CANON INC.)
                      Toolbar: HKLM - Kaspersky Protection Toolbar - {093F479D-712E-46CD-9E06-62E734A05F68} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
                      Toolbar: HKLM-x32 - Canon Easy-WebPrint EX - {759D9886-0C6F-4498-BAB6-4A5F47C6C72F} - C:\Program Files (x86)\Canon\Easy-WebPrint EX\ewpexhlp.dll [2015-02-23] (CANON INC.)
                      Toolbar: HKLM-x32 - Kaspersky Protection Toolbar - {093F479D-712E-46CD-9E06-62E734A05F68} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
                      Toolbar: HKU\S-1-5-21-4237603079-860989819-990887440-1001 → Kaspersky Protection Toolbar - {093F479D-712E-46CD-9E06-62E734A05F68} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\IEExt\ie_plugin.dll [2016-12-08] (AO Kaspersky Lab)
                      Handler-x32: mso-minsb-roaming.16 - {83C25742-A9F7-49FB-9138-434302C88D07} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-15] (Microsoft Corporation)
                      Handler-x32: mso-minsb.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-15] (Microsoft Corporation)
                      Handler-x32: osf-roaming.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-15] (Microsoft Corporation)
                      Handler-x32: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2017-09-15] (Microsoft Corporation)
                      [HEADING=1]FireFox:[/HEADING]
                      FF ProfilePath: C:\Users\papeter\AppData\Roaming\Mozilla\Firefox\P rofiles\ee8pm1a2.default-1446908155165 [2017-09-27]
                      FF Extension: (Disable Hello, Pocket & Reader+) - C:\Users\papeter\AppData\Roaming\Mozilla\Firefox\P rofiles\ee8pm1a2.default-1446908155165\Extensions\NoTrash@Off.JustOff.xpi [2017-01-16]
                      FF HKLM...\Firefox\Extensions: [light_plugin_F6F079488B53499DB99380A...asp ersky.com] - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\FFExt\light_plugin_firefox\addon.xpi
                      FF Extension: (Kaspersky Protection) - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\FFExt\light_plugin_firefox\addon.xpi [2017-07-25]
                      FF HKLM-x32...\Firefox\Extensions: [light_plugin_F6F079488B53499DB99380A...asp ersky.com] - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\FFExt\light_plugin_firefox\addon.xpi
                      FF Plugin: @adobe.com/FlashPlayer → C:\WINDOWS\system32\Macromed\Flash\NPSWF64_27_0_0_ 130.dll [2017-09-13] ()
                      FF Plugin: @Microsoft.com/NpCtrl,version=1.0 → c:\Program Files\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
                      FF Plugin-x32: @adobe.com/FlashPlayer → C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_27_0_0_ 130.dll [2017-09-13] ()
                      FF Plugin-x32: @canon.com/EPPEX → C:\Program Files (x86)\Canon\My Image Garden\AddOn\CIG\npmigfpi.dll [2011-11-30] (CANON INC.)
                      FF Plugin-x32: @DVR/npmedia,version=3.1.0.4 → C:\Program Files\webrec\WEB30\DVR32\3.1.0.4\npmedia.dll [2014-05-10] ()
                      FF Plugin-x32: @DVR/npTimeGrid,version=3.1.0.4 → C:\Program Files\webrec\WEB30\DVR32\3.1.0.4\npTimeGrid.dll [2014-05-10] (Unauthorized copy)
                      FF Plugin-x32: @google.com/npPicasa3,version=3.0.0 → C:\Program Files (x86)\Google\Picasa3\npPicasa3.dll [2015-10-13] (Google, Inc.)
                      FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI ipt;version=4.0.56 → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIIPT.dll [2014-09-03] (Intel Corporation)
                      FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI updater → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIUpdater.dll [2014-09-03] (Intel Corporation)
                      FF Plugin-x32: @Microsoft.com/NpCtrl,version=1.0 → c:\Program Files (x86)\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
                      FF Plugin-x32: @microsoft.com/SharePoint,version=14.0 → C:\Program Files (x86)\Microsoft Office\root\Office16\NPSPWRAP.DLL [2017-09-15] (Microsoft Corporation)
                      FF Plugin-x32: @Sibelius.com/Scorch Plugin,version=6.2.0.88 → C:\Program Files (x86)\Sibelius Software\Scorch\npsibelius.dll [2013-03-11] ()
                      FF Plugin-x32: @tools.google.com/Google Update;version=3 → C:\Program Files (x86)\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-04-28] (Google Inc.)
                      FF Plugin-x32: @tools.google.com/Google Update;version=9 → C:\Program Files (x86)\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-04-28] (Google Inc.)
                      FF Plugin-x32: @videolan.org/vlc,version=2.2.1 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2017-05-24] (VideoLAN)
                      FF Plugin-x32: @videolan.org/vlc,version=2.2.4 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2017-05-24] (VideoLAN)
                      FF Plugin-x32: @videolan.org/vlc,version=2.2.6 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2017-05-24] (VideoLAN)
                      FF Plugin-x32: Adobe Reader → C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AIR\nppdf32.dll [2017-08-10] (Adobe Systems Inc.)
                      FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: @tools.google.com/Google Update;version=3 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\npGoogleUpdate3.dll [2017-04-29] (Google Inc.)
                      FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: @tools.google.com/Google Update;version=9 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\npGoogleUpdate3.dll [2017-04-29] (Google Inc.)
                      FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: @zoom.us/ZoomVideoPlugin → C:\Users\papeter\AppData\Roaming\Zoom\bin\npzoompl ugin.dll [2017-06-21] (Zoom Video Communications, Inc.)
                      FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: SkypePlugin → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\npGatewayNpapi.dll [2016-09-01] (Skype Technologies S.A.)
                      FF Plugin HKU\S-1-5-21-4237603079-860989819-990887440-1001: SkypePlugin64 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\npGatewayNpapi-x64.dll [2016-09-01] (Skype Technologies S.A.)
                      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\nppdf32.dll [2017-08-10] (Adobe Systems Inc.)
                      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\NPSibelius.dll [2013-03-11] ()
                      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\PDFNetC.dll [2010-03-31] (PDFTron Systems Inc.)
                      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\ScorchAxPlugin.dll [2010-04-08] ()
                      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\ScorchPDFWrapper.dll [2010-04-08] ()
                      [HEADING=1]Chrome:[/HEADING]
                      CHR DefaultProfile: Default
                      CHR DefaultSearchURL: Default → hxxps://www.google.com/search?q={searchTerms}&ie=utf-8&oe=utf-8&aq=t&q={searchTerms}&ie=utf-8&oe=utf-8&aq=t&channel=fflb&q={searchTerms}&ie=utf-8&oe=utf-8&aq=t&channel=rcs
                      CHR DefaultSuggestURL: Default → hxxps://www.google.com/complete/search?q={searchTerms}
                      CHR Profile: C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default [2017-09-27]
                      CHR Extension: (Google Slides) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhon fmgoek [2015-10-30]
                      CHR Extension: (Sizable Send) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\abpoebooacbankjejohknechpi feimmi [2015-10-30]
                      CHR Extension: (Google Docs) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfi lokake [2015-10-30]
                      CHR Extension: (Google Drive) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigk jlhalf [2015-10-30]
                      CHR Extension: (YouTube) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldk acnbeo [2015-10-30]
                      CHR Extension: (Google Search) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\coobgpohoikkiipiblmjeljnie djpjpf [2015-10-30]
                      CHR Extension: (Google Sheets) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpeb giejap [2015-10-30]
                      CHR Extension: (Kaspersky Protection) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\fhoibnponjcgjgcnfacekaijdb bplhib [2017-02-07]
                      CHR Extension: (Google Docs Offline) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdl olhkhi [2016-04-04]
                      CHR Extension: (Pocket) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\mjcnijlhddpbdemagnpefmlkjd agkogk [2017-01-16]
                      CHR Extension: (Ghostery) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\mlomiejdfkolichcflejclcbmp eaniij [2017-09-03]
                      CHR Extension: (Chrome Web Store Payments) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccm gmieda [2017-09-03]
                      CHR Extension: (SEO for Chrome) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\oangcciaeihlfmhppegpdceadp faoclj [2015-10-30]
                      CHR Extension: (Gmail) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoe jaedia [2015-10-30]
                      CHR Extension: (Chrome Media Router) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcj beemfm [2017-08-16]
                      CHR Profile: C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1 [2017-09-27]
                      CHR Extension: (Google Slides) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2016-07-04]
                      CHR Extension: (Google Docs) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\aohghmighlieiainnegkcijnfilokake [2016-07-04]
                      CHR Extension: (Google Drive) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\apdfllckaahabafndbhieahigkjlhalf [2016-07-04]
                      CHR Extension: (YouTube) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2016-07-04]
                      CHR Extension: (Kaspersky Protection) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\eahebamiopdhefndnmappcihfajigkka [2016-07-04]
                      CHR Extension: (Google Sheets) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2016-07-04]
                      CHR Extension: (Google Docs Offline) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2016-07-04]
                      CHR Extension: (Chrome Web Store Payments) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2016-07-04]
                      CHR Extension: (Gmail) - C:\Users\papeter\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2016-07-04]
                      CHR Profile: C:\Users\papeter\AppData\Local\Google\Chrome\User Data\System Profile [2017-09-27]
                      CHR HKLM...\Chrome\Extension: [fhoibnponjcgjgcnfacekaijdbbplhib] - hxxps://chrome.google.com/webstore/detail/fhoibnponjcgjgcnfacekaijdbbplhib
                      CHR HKLM-x32...\Chrome\Extension: [efaidnbmnnnibpcajpcglclefindmkaj] - hxxps://clients2.google.com/service/update2/crx
                      CHR HKLM-x32...\Chrome\Extension: [fhoibnponjcgjgcnfacekaijdbbplhib] - hxxps://chrome.google.com/webstore/detail/fhoibnponjcgjgcnfacekaijdbbplhib
                      R2 AdobeActiveFileMonitor14.0; C:\Program Files\Adobe\Elements 14 Organizer\PhotoshopElementsFileAgent.exe [226016 2015-12-07] (Adobe Systems Incorporated)
                      R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2017-04-03] (Apple Inc.)
                      R2 AVControlCenter; C:\Program Files\Lenovo\Communications Utility\AVControlCenter32.exe [560584 2015-03-23] (Lenovo Corporation)
                      R2 AVP17.0.0; C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\avp.exe [241544 2016-06-28] (AO Kaspersky Lab)
                      R2 BcmBtRSupport; C:\WINDOWS\system32\BtwRSupportService.exe [2251992 2015-03-27] (Broadcom Corporation.)
                      R2 CCSDK; C:\Program Files (x86)\Lenovo\CCSDK\CCSDK.exe [592880 2014-07-10] ()
                      R2 ClickToRunSvc; C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe [4424392 2017-09-08] (Microsoft Corporation)
                      R2 DACoreService; C:\Program Files (x86)\Nuance\Dragon Assistant\Core\DACore.exe [448400 2014-03-24] (Nuance Communications, Inc.)
                      R2 ETDService; C:\Program Files\Elantech\ETDService.exe [144072 2015-10-07] (ELAN Microelectronics Corp.)
                      R2 ExpressVpnService; C:\Program Files (x86)\ExpressVPN\bootstrap\AMD64\nssm.exe [331264 2017-07-06] () [File not signed]
                      R2 HmaProVpn; C:\Program Files (x86)\HMA! Pro VPN\VpnSvc.exe [3568712 2017-09-13] (AVAST Software)
                      R2 HuaweiHiSuiteService64.exe; C:\Program Files (x86)\HiSuite\HandSetService\HuaweiHiSuiteService6 4.exe [192200 2017-07-26] ()
                      R2 IAStorDataMgrSvc; C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe [16232 2014-06-25] (Intel Corporation)
                      R2 igfxCUIService2.0.0.0; C:\WINDOWS\system32\igfxCUIService.exe [373680 2017-05-26] (Intel Corporation)
                      R2 IJPLMSVC; C:\Program Files (x86)\Canon\IJPLM\IJPLMSVC.EXE [253528 2015-11-09] ()
                      S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [887256 2014-05-13] (Intel(R) Corporation)
                      R2 Intel(R) ME Service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\FWService\IntelMeFWService.exe [131544 2014-09-03] (Intel Corporation)
                      S3 iumsvc; C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [177376 2016-08-12] (Intel Corporation)
                      R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [154584 2014-09-03] (Intel Corporation)
                      S3 klvssbrigde64; C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\vssbridge64.exe [77328 2016-06-28] (AO Kaspersky Lab)
                      R2 KSDE1.0.0; C:\Program Files (x86)\Kaspersky Lab\Kaspersky Secure Connection 1.0\ksde.exe [241544 2016-06-28] (AO Kaspersky Lab)
                      R2 Lenovo Settings Service; C:\Program Files\Lenovo\SettingsDependency\SettingsService.ex e [2016040 2015-04-10] (Lenovo Group Limited)
                      R2 Lenovo System Agent Service; C:\Program Files\Lenovo\iMController\SystemAgentService.exe [584960 2014-05-22] (LENOVO INCORPORATED.)
                      S3 LENOVO.TVTVCAM; C:\Program Files\Lenovo\Communications Utility\vcamsvc.exe [625608 2015-03-23] (Lenovo Corporation)
                      R2 LenovoPAWDService; C:\Program Files\Lenovo PhoneCompanion\LPAWDService.exe [133440 2015-02-05] ()
                      R2 LenovoSetSvr; C:\Program Files (x86)\Lenovo\Lenovo Settings\x86\LenovoSetSvr.exe [258544 2014-06-19] (Lenovo(beijing) Limited)
                      R3 LenovoUpdate; C:\WINDOWS\System32\LenovoUpdate.exe [26608 2017-09-27] (Lenovo)
                      R2 LenovoWiFiHotspotSvr; C:\Windows\System32\LenovoWiFiHotspotSvr.exe [218952 2014-08-26] (Lenovo(beijing) Limited)
                      R2 MbaeSvc; C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae-svc.exe [155080 2017-07-18] (Malwarebytes Corporation)
                      R2 MBAMScheduler; C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe [1514464 2016-03-10] (Malwarebytes)
                      S2 MBAMService; C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe [1136608 2016-03-10] (Malwarebytes)
                      R2 NVDisplay.ContainerLocalSystem; C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe [458176 2016-12-29] (NVIDIA Corporation)
                      R2 NvNetworkService; C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe [1795912 2014-09-09] (NVIDIA Corporation)
                      R2 PhoneCompanionPusher; C:\Program Files\Lenovo PhoneCompanion\PhoneCompanionPusher.exe [321520 2015-02-05] (Lenovo)
                      S3 PhoneCompanionVap; C:\Program Files\Lenovo PhoneCompanion\PhoneCompanionVap.exe [338416 2015-02-05] (Lenovo)
                      R2 RichVideo64; C:\Program Files\CyberLink\Shared files\RichVideo64.exe [390632 2012-04-24] ()
                      S3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [342264 2017-03-18] (Microsoft Corporation)
                      S3 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [102816 2017-07-11] (Microsoft Corporation)
                      R3 bcbtums; C:\WINDOWS\system32\drivers\bcbtums.sys [173312 2015-03-27] (Broadcom Corporation.)
                      R3 BCM43XX; C:\WINDOWS\system32\DRIVERS\bcmwl63a.sys [7504560 2013-11-20] (Broadcom Corporation)
                      R0 cm_km; C:\WINDOWS\System32\DRIVERS\cm_km.sys [238936 2016-06-10] (AO Kaspersky Lab)
                      R1 ESProtectionDriver; C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae64.sys [77432 2017-07-18] ()
                      S3 ew_usbccgpfilter; C:\WINDOWS\System32\drivers\ew_usbccgpfilter.sys [18944 2017-07-26] (Huawei Technologies Co., Ltd.)
                      R3 hmatap; C:\WINDOWS\System32\drivers\hmatap.sys [27136 2016-09-01] (The OpenVPN Project)
                      R0 kl1; C:\WINDOWS\System32\DRIVERS\kl1.sys [554416 2016-06-02] (AO Kaspersky Lab)
                      R0 klbackupdisk; C:\WINDOWS\System32\DRIVERS\klbackupdisk.sys [63920 2016-06-07] (AO Kaspersky Lab)
                      R1 klbackupflt; C:\WINDOWS\System32\DRIVERS\klbackupflt.sys [86352 2016-06-15] (AO Kaspersky Lab)
                      R2 kldisk; C:\WINDOWS\system32\DRIVERS\kldisk.sys [78216 2016-05-31] (AO Kaspersky Lab)
                      S0 klelam; C:\WINDOWS\System32\DRIVERS\klelam.sys [28792 2016-03-31] (AO Kaspersky Lab)
                      R3 klflt; C:\WINDOWS\system32\DRIVERS\klflt.sys [197312 2017-07-25] (AO Kaspersky Lab)
                      R1 klhk; C:\WINDOWS\System32\drivers\klhk.sys [520152 2017-07-25] (AO Kaspersky Lab)
                      R3 klids; C:\ProgramData\Kaspersky Lab\AVP17.0.0\Bases\klids.sys [186696 2017-09-27] (AO Kaspersky Lab)
                      R1 KLIF; C:\WINDOWS\System32\DRIVERS\klif.sys [1021624 2017-07-25] (AO Kaspersky Lab)
                      R1 KLIM6; C:\WINDOWS\system32\DRIVERS\klim6.sys [57424 2017-09-21] (AO Kaspersky Lab)
                      R3 klkbdflt; C:\WINDOWS\system32\DRIVERS\klkbdflt.sys [52136 2016-05-19] (AO Kaspersky Lab)
                      R3 klmouflt; C:\WINDOWS\system32\DRIVERS\klmouflt.sys [41656 2015-06-07] (Kaspersky Lab ZAO)
                      R1 klpd; C:\WINDOWS\System32\DRIVERS\klpd.sys [45488 2016-05-31] (AO Kaspersky Lab)
                      R3 kltap; C:\WINDOWS\System32\drivers\kltap.sys [52152 2016-06-07] (The OpenVPN Project)
                      R0 klupd_klif_arkmon; C:\WINDOWS\System32\Drivers\klupd_klif_arkmon.sys [229288 2017-07-04] (AO Kaspersky Lab)
                      R3 klupd_klif_kimul; C:\WINDOWS\System32\Drivers\klupd_klif_kimul.sys [87584 2017-08-29] (AO Kaspersky Lab)
                      S3 klupd_klif_klark; C:\WINDOWS\System32\Drivers\klupd_klif_klark.sys [251656 2017-07-12] (AO Kaspersky Lab)
                      R0 klupd_klif_klbg; C:\WINDOWS\System32\Drivers\klupd_klif_klbg.sys [112912 2017-07-04] (AO Kaspersky Lab)
                      R3 klupd_klif_mark; C:\WINDOWS\System32\Drivers\klupd_klif_mark.sys [173144 2017-07-12] (AO Kaspersky Lab)
                      R1 klwfp; C:\WINDOWS\system32\DRIVERS\klwfp.sys [85320 2016-06-18] (AO Kaspersky Lab)
                      R1 Klwtp; C:\WINDOWS\system32\DRIVERS\klwtp.sys [136416 2017-03-15] (AO Kaspersky Lab)
                      R3 KMDFVirtualKbd; C:\WINDOWS\System32\drivers\KMDFVirtualKbd.sys [22264 2014-08-05] ()
                      R3 KMDFVirtualMouse; C:\WINDOWS\System32\drivers\KMDFVirtualMouse.sys [21240 2014-08-05] ()
                      R1 kneps; C:\WINDOWS\system32\DRIVERS\kneps.sys [199640 2017-07-25] (AO Kaspersky Lab)
                      S3 mbamchameleon; C:\WINDOWS\system32\drivers\mbamchameleon.sys [140672 2016-03-10] (Malwarebytes)
                      R3 MBAMProtector; C:\WINDOWS\system32\drivers\mbam.sys [27008 2016-03-10] (Malwarebytes)
                      S3 MBAMSwissArmy; C:\WINDOWS\system32\drivers\MBAMSwissArmy.sys [192216 2017-09-27] (Malwarebytes)
                      S3 MBAMWebAccessControl; C:\WINDOWS\system32\drivers\mwac.sys [65408 2016-03-10] (Malwarebytes Corporation)
                      R3 MEIx64; C:\WINDOWS\system32\DRIVERS\TeeDriverx64.sys [129312 2014-09-30] (Intel Corporation)
                      S0 mfeelamk; C:\WINDOWS\System32\drivers\mfeelamk.sys [80160 2015-02-13] (McAfee, Inc.)
                      S3 MWAC; C:\WINDOWS\system32\drivers\ [0 ] () <==== ATTENTION (zero byte File/Folder)
                      S3 MWAC; C:\WINDOWS\SysWOW64\drivers\ [0 ] () <==== ATTENTION (zero byte File/Folder)
                      R3 nvlddmkm; C:\WINDOWS\System32\DriverStore\FileRepository\nvl twu.inf_amd64_dc8ffafad3ea7ddd\nvlddmkm.sys [14190520 2017-01-17] (NVIDIA Corporation)
                      R0 PxHlpa64; C:\WINDOWS\System32\drivers\PxHlpa64.sys [56336 2013-09-03] (Corel Corporation)
                      R3 rt640x64; C:\WINDOWS\System32\drivers\rt640x64.sys [886528 2015-07-22] (Realtek )
                      R3 RTSUER; C:\WINDOWS\system32\Drivers\RtsUer.sys [410880 2015-07-03] (Realsil Semiconductor Corporation)
                      R3 rtsuvc; C:\WINDOWS\system32\DRIVERS\rtsuvc.sys [3068160 2015-06-16] (Realtek Semiconductor Corp.)
                      S3 SDFRd; C:\WINDOWS\System32\drivers\SDFRd.sys [31128 2017-03-18] ()
                      S3 tapexpressvpn; C:\WINDOWS\System32\drivers\tapexpressvpn.sys [45048 2017-07-06] (The OpenVPN Project)
                      S3 WdBoot; C:\WINDOWS\system32\drivers\WdBoot.sys [44632 2017-03-18] (Microsoft Corporation)
                      S3 WdFilter; C:\WINDOWS\system32\drivers\WdFilter.sys [294816 2017-03-18] (Microsoft Corporation)
                      S3 WdNisDrv; C:\WINDOWS\System32\Drivers\WdNisDrv.sys [121248 2017-03-18] (Microsoft Corporation)
                      S3 WNDA3100v3; C:\WINDOWS\system32\DRIVERS\WNDA3100v3.sys [2222736 2014-12-08] (MediaTek Inc.)
                      S3 wsvd; C:\WINDOWS\system32\DRIVERS\wsvd.sys [102376 2012-06-14] ("CyberLink)
                      2017-09-27 12:47 - 2017-09-27 12:47 - 000034943 _____ C:\Users\papeter\Downloads\FRST.txt
                      2017-09-27 12:42 - 2017-09-27 12:44 - 002399744 _____ (Farbar) C:\Users\papeter\Downloads\FRST64(1).exe
                      2017-09-27 11:41 - 2017-09-27 11:45 - 000011165 _____ C:\Users\papeter\Desktop\Fixlog.txt
                      2017-09-27 11:34 - 2017-09-27 11:34 - 002399744 _____ (Farbar) C:\Users\papeter\Desktop\FRST64(1).exe
                      2017-09-27 00:15 - 2017-09-27 00:15 - 008182736 _____ (Malwarebytes) C:\Users\papeter\Desktop\adwcleaner_7.0.2.1(1).exe
                      2017-09-27 00:07 - 2017-09-27 00:07 - 000000000 ___D C:\Users\papeter\AppData\Local\DBG
                      2017-09-26 23:47 - 2017-09-27 12:04 - 000003392 _____ C:\WINDOWS\System32\Tasks\Kaspersky_Upgrade_Launch er
                      {278ADC42-419D-4547-A6CA-5B74BE0AD901}
                      2017-09-26 23:45 - 2017-09-27 12:12 - 000000000 ____D C:\AdwCleaner
                      2017-09-26 23:45 - 2017-09-26 23:45 - 008182736 _____ (Malwarebytes) C:\Users\papeter\Downloads\adwcleaner_7.0.2.1.exe
                      2017-09-26 23:29 - 2017-09-26 23:29 - 000000000 ____D C:\ProgramData\CanonIJPLM
                      2017-09-26 23:18 - 2017-09-26 23:18 - 000000000 ____D C:\zoek
                      2017-09-26 22:48 - 2017-09-26 23:27 - 000003221 _____ C:\runcheck.txt
                      2017-09-26 22:48 - 2017-09-26 23:20 - 000000000 ____D C:\zoek_backup
                      2017-09-26 22:46 - 2017-09-26 22:46 - 001309184 _____ C:\Users\papeter\Downloads\zoek.exe
                      2017-09-26 18:01 - 2017-09-27 12:47 - 000000000 ____D C:\FRST
                      2017-09-26 17:55 - 2017-09-26 17:56 - 002399744 _____ (Farbar) C:\Users\papeter\Downloads\FRST64.exe
                      2017-09-26 01:11 - 2017-09-26 01:11 - 000001268 _____ C:\Users\papeter\Desktop\malwarebytes screenshot.docx - Shortcut.lnk
                      2017-09-26 00:28 - 2017-09-26 00:28 - 002000384 _____ C:\Users\papeter\Documents\malwarebutes.pub
                      2017-09-25 22:09 - 2017-09-25 22:09 - 008604592 _____ (Yousician ) C:\Users\papeter\Downloads\YousicianSetup.exe
                      2017-09-25 18:07 - 2017-09-25 18:15 - 001396224 _____ C:\Users\papeter\Documents\John Crestani Video 1 summary.pub
                      2017-09-24 23:26 - 2017-09-24 23:26 - 000000035 _____ C:\Users\papeter\Documents\E-X-P-V-P-N.txt
                      2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\Users\papeter\AppData\Local\ExpressVPN
                      2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ExpressVPN
                      2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\ProgramData\ExpressVPN
                      2017-09-24 23:12 - 2017-09-24 23:12 - 000000000 ____D C:\Program Files (x86)\ExpressVPN
                      2017-09-24 23:10 - 2017-09-24 23:10 - 018904768 _____ (ExpressVPN) C:\Users\papeter\Downloads\expressvpn_6.2.3.2578.e xe
                      2017-09-22 23:31 - 2017-09-22 23:31 - 000000138 _____ C:\Users\papeter\Documents\PayPal question.txt
                      2017-09-22 13:02 - 2017-09-22 13:02 - 000000507 _____ C:\Users\papeter\Documents\super juice.txt
                      2017-09-21 21:45 - 2017-09-21 21:45 - 000000000 ____D C:\Windows.old
                      2017-09-21 21:43 - 2017-09-21 21:43 - 023684608 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 023679488 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 021352656 _____ (Microsoft Corporation) C:\WINDOWS\system32\shell32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 020509184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 020373408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shell32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 019336192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 013844480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 012801536 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 011887104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 008319904 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 008213504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mstscax.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 008207872 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 007931392 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 007907344 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Protection.PlayR eady.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 006728704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 006557520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 006265856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005961728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005821496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005808640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005721600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BingMaps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005557760 _____ (Microsoft Corporation) C:\WINDOWS\system32\dbgeng.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 005225984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d2d1.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004848960 _____ (Microsoft Corporation) C:\WINDOWS\explorer.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004730368 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004708504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfcore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004707840 _____ (Microsoft Corporation) C:\WINDOWS\system32\ExplorerFrame.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004671832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfcore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004535296 _____ (Microsoft Corporation) C:\WINDOWS\system32\MFMediaEngine.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004462120 _____ (Microsoft Corporation) C:\WINDOWS\system32\setupapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004445696 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_nt.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004417024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ExplorerFrame.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004330920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\setupapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004175872 _____ (Microsoft Corporation) C:\WINDOWS\system32\StartTileData.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 004056064 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFMediaEngine.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003995136 _____ (Microsoft Corporation) C:\WINDOWS\system32\UIRibbon.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003667456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_47.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003654656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003464704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UIRibbon.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003307008 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininet.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 003059200 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkMobileSettings.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002859520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wininet.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002805248 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002765824 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Shell.UnifiedTile.Cura tedTileCollections.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002675104 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tcpip.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002671616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tquery.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002647224 _____ (Microsoft Corporation) C:\WINDOWS\system32\iertutil.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002604248 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfmp4srcsnk.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002516480 _____ (Microsoft Corporation) C:\WINDOWS\system32\diagtrack.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002503680 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.pcshell.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002476712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d10warp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002445824 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002424024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfmp4srcsnk.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002399728 _____ (Microsoft Corporation) C:\WINDOWS\system32\KernelBase.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002327456 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ntfs.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002199552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Resources.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002177024 _____ (Microsoft Corporation) C:\WINDOWS\system32\OpcServices.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002166808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iertutil.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002078720 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetcpl.cpl
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002009600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\inetcpl.cpl
                      2017-09-21 21:43 - 2017-09-21 21:43 - 002006528 _____ (Microsoft Corporation) C:\WINDOWS\system32\LocationFramework.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001930840 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntdll.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001886208 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.oneco re.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001833984 _____ (Microsoft Corporation) C:\WINDOWS\system32\workfolderssvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001802752 _____ (Microsoft Corporation) C:\WINDOWS\system32\urlmon.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001736704 _____ (Microsoft Corporation) C:\WINDOWS\system32\wevtsvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001722880 _____ (Microsoft Corporation) C:\WINDOWS\system32\dui70.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001706496 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Immersive.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001657344 _____ (Microsoft Corporation) C:\WINDOWS\system32\XpsPrint.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001639936 _____ (Microsoft Corporation) C:\WINDOWS\system32\GdiPlus.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001627136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\urlmon.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001620880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntdll.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001619816 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppobjs.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001596592 _____ (Microsoft Corporation) C:\WINDOWS\system32\gdi32full.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001583616 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieapfltr.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001536512 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Immersive.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001525760 _____ (Microsoft Corporation) C:\WINDOWS\system32\RecoveryDrive.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001468416 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.deskt op.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001463296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieapfltr.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001397760 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwansvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001357312 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiosrv.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001337856 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEng.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001325968 _____ (Microsoft Corporation) C:\WINDOWS\system32\ole32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001320344 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpx.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001305088 _____ (Microsoft Corporation) C:\WINDOWS\system32\dosvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001298432 _____ (Microsoft Corporation) C:\WINDOWS\system32\lpasvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001291776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVPXENC.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001275904 _____ (Microsoft Corporation) C:\WINDOWS\system32\werconcpl.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001269760 _____ (Microsoft Corporation) C:\WINDOWS\system32\enterprisecsps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001260544 _____ (Microsoft Corporation) C:\WINDOWS\system32\GamePanel.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001248768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AzureSettingSyncProvider.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001242528 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ndis.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001178624 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.Vpn.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001146176 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfds.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001143296 _____ (Microsoft Corporation) C:\WINDOWS\system32\localspl.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001114528 _____ (Microsoft Corporation) C:\WINDOWS\system32\ReAgent.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001106904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfds.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001087488 _____ (Microsoft Corporation) C:\WINDOWS\system32\reseteng.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001068720 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001060352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XpsPrint.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001054280 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioSes.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001051136 _____ (Microsoft Corporation) C:\WINDOWS\system32\nettrace.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001046016 _____ (Microsoft Corporation) C:\WINDOWS\system32\comdlg32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001033544 _____ (Microsoft Corporation) C:\WINDOWS\system32\DolbyDecMFT.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001019904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aadtb.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 001013912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msvproc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000996864 _____ (Microsoft Corporation) C:\WINDOWS\system32\iphlpsvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000988168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ole32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000986624 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000972288 _____ (Microsoft Corporation) C:\WINDOWS\system32\MPSSVC.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000971264 _____ (Microsoft Corporation) C:\WINDOWS\system32\autochk.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000967584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ReAgent.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000961952 _____ (Microsoft Corporation) C:\WINDOWS\system32\efscore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000958664 _____ (Microsoft Corporation) C:\WINDOWS\system32\msvproc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000954368 _____ (Microsoft Corporation) C:\WINDOWS\system32\autoconv.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000952832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\comdlg32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000946688 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasgcw.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000932352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GamePanel.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000926208 _____ (Microsoft Corporation) C:\WINDOWS\system32\autofmt.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000925696 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpcWebFilter.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000923040 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreMessaging.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000921600 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasdlg.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000918528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Networking.Vpn.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000899584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.appcore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000877056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\autoconv.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000874496 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasmans.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000866808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DolbyDecMFT.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000864256 _____ (Microsoft Corporation) C:\WINDOWS\system32\NotificationController.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000853504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\autofmt.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000852480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasgcw.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000847360 _____ (Microsoft Corporation) C:\WINDOWS\system32\bisrv.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000844288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasdlg.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000832000 _____ (Microsoft Corporation) C:\WINDOWS\system32\printfilterpipelinesvc.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000827904 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32spl.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000820128 _____ (Microsoft Corporation) C:\WINDOWS\system32\WWAHost.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000810496 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasapi32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000805888 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieproxy.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000803328 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmsvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000778240 _____ C:\WINDOWS\system32\MBR2GPT.EXE
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000778240 _____ (Microsoft Corporation) C:\WINDOWS\system32\DolbyHrtfEnc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000773120 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneService.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000772096 _____ (Microsoft Corporation) C:\WINDOWS\system32\PCPKsp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000761344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasapi32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000757760 _____ (Microsoft Corporation) C:\WINDOWS\system32\spoolsv.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000752640 _____ (Microsoft Corporation) C:\WINDOWS\system32\msfeeds.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000750560 _____ (Microsoft Corporation) C:\WINDOWS\system32\fontdrvhost.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000750496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WWAHost.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000742912 _____ (Microsoft Corporation) C:\WINDOWS\system32\nshwfp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000739840 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneProviders.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000724200 _____ (Microsoft Corporation) C:\WINDOWS\system32\wer.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000715168 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fvevol.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000706560 _____ (Microsoft Corporation) C:\WINDOWS\system32\winlogon.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000699904 _____ (Microsoft Corporation) C:\WINDOWS\system32\FlightSettings.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000692736 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9diag.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000687616 _____ (Microsoft Corporation) C:\WINDOWS\system32\LogonController.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000685512 _____ (Microsoft Corporation) C:\WINDOWS\system32\SHCore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000664576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msfeeds.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000636416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WpcWebFilter.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000625152 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEndpointBuilder.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000612864 _____ (Microsoft Corporation) C:\WINDOWS\system32\shsvcs.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000610720 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\afd.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000600576 _____ (Microsoft Corporation) C:\WINDOWS\system32\FrameServer.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000593408 _____ (Microsoft Corporation) C:\WINDOWS\system32\BootMenuUX.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000586240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\nshwfp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000584192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UIRibbonRes.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000584192 _____ (Microsoft Corporation) C:\WINDOWS\system32\UIRibbonRes.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000582656 _____ (Microsoft Corporation) C:\WINDOWS\system32\SmsRouterSvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000579072 _____ (Microsoft Corporation) C:\WINDOWS\system32\untfs.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000574464 _____ (Microsoft Corporation) C:\WINDOWS\system32\configmanager2.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000569264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SHCore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000566784 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.UX.EapReque stHandler.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000564224 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shsvcs.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000551200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxgi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000546816 _____ (Microsoft Corporation) C:\WINDOWS\system32\winspool.drv
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000536064 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Management.dl l
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000527976 _____ (Microsoft Corporation) C:\WINDOWS\system32\services.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000527872 _____ (Microsoft Corporation) C:\WINDOWS\system32\daxexec.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000524800 _____ (Microsoft Corporation) C:\WINDOWS\system32\TileDataRepository.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000519584 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netio.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000500224 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Shell.BlueLightReducti on.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000499712 _____ (Microsoft Corporation) C:\WINDOWS\system32\nltest.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000497152 _____ (Microsoft Corporation) C:\WINDOWS\system32\rastls.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000491520 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Display.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000482816 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmenrollengine.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000477696 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasplap.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000473240 _____ (Microsoft Corporation) C:\WINDOWS\system32\policymanager.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000463360 _____ (Microsoft Corporation) C:\WINDOWS\system32\werui.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000457728 _____ (Microsoft Corporation) C:\WINDOWS\system32\webplatstorageserver.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000455584 _____ (Microsoft Corporation) C:\WINDOWS\system32\hal.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000452608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasplap.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000450048 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcdedit.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000446464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rastls.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000440320 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.immersiveshell.service provider.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000433664 _____ (Microsoft Corporation) C:\WINDOWS\system32\msIso.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000430592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winspool.drv
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000420864 _____ (Microsoft Corporation) C:\WINDOWS\system32\facecredentialprovider.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000417792 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallAgentUserBroker.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000410168 _____ (Microsoft Corporation) C:\WINDOWS\system32\Faultrep.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000407040 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhext.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000406544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\policymanager.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000397312 _____ (Microsoft Corporation) C:\WINDOWS\system32\rascustom.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000394240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Internal.Management.dl l
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000388096 _____ (Microsoft Corporation) C:\WINDOWS\system32\iedkcs32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000387936 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmpps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000383488 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallAgent.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000382368 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\clfs.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000381824 _____ (Microsoft Corporation) C:\WINDOWS\system32\wevtapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000370688 _____ (Microsoft Corporation) C:\WINDOWS\system32\rastlsext.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000370176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\daxexec.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000368128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallAgentUserBroker.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000365056 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Notifications .dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000364032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msIso.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000358400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieproxy.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000357888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ActivationManager.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000353280 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntprint.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000339968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iedkcs32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000337920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallAgent.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000331264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rastlsext.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000329728 _____ (Microsoft Corporation) C:\WINDOWS\system32\RasMediaManager.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000327168 _____ (Microsoft Corporation) C:\WINDOWS\system32\WinBioDataModel.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000323936 _____ (Microsoft Corporation) C:\WINDOWS\system32\shlwapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000323584 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceEnroller.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000316320 _____ (Microsoft Corporation) C:\WINDOWS\system32\WerFault.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000312320 _____ (Microsoft Corporation) C:\WINDOWS\system32\Phoneutil.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000311296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntprint.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000305152 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netbt.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000290816 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmenterprisediagnostics.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000277432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shlwapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000274944 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxtrans.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000268288 _____ (Microsoft Corporation) C:\WINDOWS\system32\wisp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000266240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxtrans.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000259072 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Flights.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000257440 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxAllUserStore.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000257024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Phoneutil.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000257024 _____ (Microsoft Corporation) C:\WINDOWS\system32\webcheck.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000255488 _____ (Microsoft Corporation) C:\WINDOWS\system32\scksp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000254976 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\srvnet.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000254176 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000249344 _____ (Microsoft Corporation) C:\WINDOWS\system32\coredpus.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000243712 _____ (Microsoft Corporation) C:\WINDOWS\system32\shdocvw.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000232960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webcheck.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000231936 _____ (Microsoft Corporation) C:\WINDOWS\system32\DolbyMATEnc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000229888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\scksp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000229888 _____ (Microsoft Corporation) C:\WINDOWS\system32\SIHClient.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000228256 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb20.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000225792 _____ (Microsoft Corporation) C:\WINDOWS\system32\ie4uinit.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000223744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shdocvw.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000213504 _____ (Microsoft Corporation) C:\WINDOWS\system32\dinput8.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000212384 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserbroker.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000209408 _____ (Microsoft Corporation) C:\WINDOWS\system32\psmsrv.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000204192 _____ (Microsoft Corporation) C:\WINDOWS\system32\basecsp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000201728 _____ (Microsoft Corporation) C:\WINDOWS\system32\RstrtMgr.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000197120 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcdboot.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000194048 _____ (Microsoft Corporation) C:\WINDOWS\system32\mdmregistration.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000192264 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsensorgroup.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000184832 _____ (Microsoft Corporation) C:\WINDOWS\system32\VCardParser.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000184320 _____ (Microsoft Corporation) C:\WINDOWS\system32\DWWIN.EXE
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000182688 _____ (Microsoft Corporation) C:\WINDOWS\system32\wermgr.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000182272 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcrecovery.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000176640 _____ (Microsoft Corporation) C:\WINDOWS\system32\wersvc.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000176024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\basecsp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000175616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\RstrtMgr.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000175104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dinput8.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000173568 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetpp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000165888 _____ (Microsoft Corporation) C:\WINDOWS\system32\storewuauth.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000160768 _____ (Microsoft Corporation) C:\WINDOWS\system32\dinput.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000159648 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\partmgr.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000156160 _____ (Microsoft Corporation) C:\WINDOWS\system32\csplte.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000153088 _____ (Microsoft Corporation) C:\WINDOWS\system32\fdeploy.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000150528 _____ (Microsoft Corporation) C:\WINDOWS\system32\qasf.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000147456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\VCardParser.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000143872 _____ (Microsoft Corporation) C:\WINDOWS\system32\profsvcext.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000143736 _____ (Microsoft Corporation) C:\WINDOWS\system32\WerFaultSecure.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000142848 _____ (Microsoft Corporation) C:\WINDOWS\system32\srpapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000142848 _____ (Microsoft Corporation) C:\WINDOWS\system32\dwmredir.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000140800 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmcsps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000140288 _____ (Microsoft Corporation) C:\WINDOWS\system32\iepeers.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000138752 _____ (Microsoft Corporation) C:\WINDOWS\system32\appinfo.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000136096 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ksecdd.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000135680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\qasf.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000134656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dinput.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000133632 _____ (Microsoft Corporation) C:\WINDOWS\system32\CfgSPCellular.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000131584 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseAPNCsp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000130560 _____ (Microsoft Corporation) C:\WINDOWS\system32\policymanagerprecheck.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000128512 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasman.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000127488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fdeploy.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000124928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iepeers.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000124928 _____ (Microsoft Corporation) C:\WINDOWS\system32\httpprxm.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000119904 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmcmnutils.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000119712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tdx.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000116280 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcd.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000115712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bridge.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000113152 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhosdeployment.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000112640 _____ (Microsoft Corporation) C:\WINDOWS\system32\MDMAppInstaller.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000110592 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000109056 _____ (Microsoft Corporation) C:\WINDOWS\system32\dab.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000105472 _____ (Microsoft Corporation) C:\WINDOWS\system32\RjvMDMConfig.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000104432 _____ (Microsoft Corporation) C:\WINDOWS\system32\msacm32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000102912 _____ (Microsoft Corporation) C:\WINDOWS\system32\officecsp.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000100352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasman.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000100232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcd.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000096648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dmcmnutils.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000096256 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtmled.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000095232 _____ (Microsoft Corporation) C:\WINDOWS\system32\wudriver.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000093696 _____ (Microsoft Corporation) C:\WINDOWS\system32\spbcd.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000093184 _____ (Microsoft Corporation) C:\WINDOWS\system32\wercplsupport.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000090112 _____ (Microsoft Corporation) C:\WINDOWS\system32\ofdeploy.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000089088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\olepro32.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000089088 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsrvext.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000085784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CredentialUIBroker.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000084992 _____ (Microsoft Corporation) C:\WINDOWS\system32\MshtmlDac.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000080896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakradiag.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000080384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtmled.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000078848 _____ (Microsoft Corporation) C:\WINDOWS\system32\setbcdlocale.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000077824 _____ (Microsoft Corporation) C:\WINDOWS\system32\wsqmcons.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000077312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\spbcd.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000074240 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseDesktopAppMgmtCSP.dl l
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000064680 _____ (Microsoft Corporation) C:\WINDOWS\system32\appidapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000064512 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsrv.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MshtmlDac.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\system32\wups.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntprint.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000062464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntprint.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000061952 _____ (Microsoft Corporation) C:\WINDOWS\system32\vss_ps.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000059392 _____ (Microsoft Corporation) C:\WINDOWS\system32\DmApiSetExtImplDesktop.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000057856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\offreg.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000056832 _____ (Microsoft Corporation) C:\WINDOWS\system32\cldapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000052768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\appidapi.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000044032 _____ (Microsoft Corporation) C:\WINDOWS\system32\cmintegrator.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000043520 _____ (Microsoft Corporation) C:\WINDOWS\system32\TpmTasks.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000043520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\nsiproxy.sys
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000029696 _____ (Microsoft Corporation) C:\WINDOWS\system32\odbcconf.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000029184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cmintegrator.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000022528 _____ (Microsoft Corporation) C:\WINDOWS\system32\IpNatHlpClient.dll
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000022016 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpnpinst.exe
                      2017-09-21 21:43 - 2017-09-21 21:43 - 000018432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\IpNatHlpClient.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 017371136 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 008333312 _____ (Microsoft Corporation) C:\WINDOWS\system32\BingMaps.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 007598080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mstscax.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 007337472 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Data.Pdf.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 007326128 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 006761560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayR eady.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 005477096 _____ (Microsoft Corporation) C:\WINDOWS\system32\OneCoreUAPCommonProxyStub.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 005302968 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepository.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 004559360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dbgeng.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 004471888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\explorer.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 004396032 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_47.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 004213656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepository.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 003668992 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 003377664 _____ (Microsoft Corporation) C:\WINDOWS\system32\tquery.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 003204608 _____ (Microsoft Corporation) C:\WINDOWS\system32\Microsoft.Bluetooth.Profiles.G att.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 003116184 _____ (Microsoft Corporation) C:\WINDOWS\system32\combase.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002972552 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d10warp.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002969880 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreUIComponents.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002953216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32kfull.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002939392 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputService.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002680320 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.CloudStore.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002443168 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002330520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\combase.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002259760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreUIComponents.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002211840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputService.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002199552 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.Resources.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002153984 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlidsvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 002055680 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001878016 _____ (Microsoft Corporation) C:\WINDOWS\system32\AzureSettingSyncProvider.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001839872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\KernelBase.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001668344 _____ (Microsoft Corporation) C:\WINDOWS\system32\propsys.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001460224 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsasrv.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001448960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GdiPlus.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001409048 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gdi32full.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001355264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\OpcServices.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001346112 _____ (Microsoft Corporation) C:\WINDOWS\system32\user32.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001311744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjet40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001293824 _____ (Microsoft Corporation) C:\WINDOWS\system32\aadtb.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001292880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\user32.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001195760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioEng.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001147296 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvix64.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001085440 _____ (Microsoft Corporation) C:\WINDOWS\system32\rpcss.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001077248 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.appcore.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001057824 _____ (Microsoft Corporation) C:\WINDOWS\system32\MrmCoreR.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001052160 _____ (Microsoft Corporation) C:\WINDOWS\system32\TokenBroker.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001046016 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcsvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001028608 _____ (Microsoft Corporation) C:\WINDOWS\system32\modernexecserver.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001024928 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvax64.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 001015296 _____ (Microsoft Corporation) C:\WINDOWS\system32\XblAuthManager.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000982016 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthport.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000942592 _____ (Microsoft Corporation) C:\WINDOWS\system32\wbiosrvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000922112 _____ (Microsoft Corporation) C:\WINDOWS\system32\kerberos.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000892928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\autochk.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000872472 _____ (Microsoft Corporation) C:\WINDOWS\system32\ClipSVC.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000871448 _____ (Microsoft Corporation) C:\WINDOWS\system32\winhttp.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000866816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mswdat10.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000864248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioSes.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000821664 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000817664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Security.Authenticatio n.Web.Core.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000805816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000798208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TokenBroker.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000787456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wuapi.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000772096 _____ (Microsoft Corporation) C:\WINDOWS\system32\netlogon.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000754176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\kerberos.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000723360 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\acpi.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000712600 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000703056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winhttp.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000691712 _____ (Microsoft Corporation) C:\WINDOWS\system32\tdh.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000660680 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxgi.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000657408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netlogon.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000654976 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentClient.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000641536 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mswstr10.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000640512 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngccredprov.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000627080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fontdrvhost.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000616448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrepl40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000611096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wer.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000590336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PCPKsp.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000586752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Security.Authenticatio n.Web.Core.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000586240 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppReadiness.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000583160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreMessaging.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000564736 _____ (Microsoft Corporation) C:\WINDOWS\system32\dsreg.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000563200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tdh.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000556032 _____ (Microsoft Corporation) C:\WINDOWS\system32\TpmCoreProvisioning.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000554400 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\USBHUB3.SYS
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000546208 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\storport.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000538112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\untfs.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000529992 _____ (Microsoft Corporation) C:\WINDOWS\system32\TextInputFramework.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000527360 _____ (Microsoft Corporation) C:\WINDOWS\system32\aadcloudap.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000524288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ngccredprov.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000519680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000518144 _____ C:\WINDOWS\SysWOW64\msjetoledb40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000491520 _____ (Microsoft Corporation) C:\WINDOWS\system32\NgcCtnrSvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000476160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dsreg.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000475648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxbde40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000471040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TpmCoreProvisioning.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000458752 _____ (Microsoft Corporation) C:\WINDOWS\system32\NgcCtnr.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000447488 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32k.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000431616 _____ (Microsoft Corporation) C:\WINDOWS\system32\BthHFSrv.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000422400 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpAXHolder.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000414296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TextInputFramework.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000413184 _____ (Microsoft Corporation) C:\WINDOWS\system32\profsvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000412160 _____ (Microsoft Corporation) C:\WINDOWS\system32\ActivationManager.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000411040 _____ (Microsoft Corporation) C:\WINDOWS\system32\msv1_0.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000408576 _____ (Microsoft Corporation) C:\WINDOWS\system32\cryptngc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000404480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\werui.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000385536 _____ (Microsoft Corporation) C:\WINDOWS\system32\tpmvsc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000375808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mspbde40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000359560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Faultrep.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000349600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msv1_0.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000343552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrd3x40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000339968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msexcl40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000334336 _____ (Microsoft Corporation) C:\WINDOWS\system32\wc_storage.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000318232 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininit.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000315904 _____ (Microsoft Corporation) C:\WINDOWS\system32\ncryptprov.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000310272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrd2x40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000307712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cryptngc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000303104 _____ (Microsoft Corporation) C:\WINDOWS\system32\srvsvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000293376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32k.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000291904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wevtapi.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000290816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjtes40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000287648 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\sdbus.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000282112 _____ (Microsoft Corporation) C:\WINDOWS\system32\dnsrslvr.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000280480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WerFault.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000279968 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\msiscsi.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000274432 _____ (Microsoft Corporation) C:\WINDOWS\system32\authz.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000272896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mstext40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000267264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ncryptprov.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000240640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msltus40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000221696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wisp.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000189440 _____ (Microsoft Corporation) C:\WINDOWS\system32\BluetoothApis.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000189344 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dumpsd.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000182688 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppxAllUserStore.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000181760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\authz.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000180736 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\rfcomm.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000173104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsensorgroup.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000169376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wermgr.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000154624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DWWIN.EXE
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000144896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjint40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000139776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BluetoothApis.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000136192 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryUpgrade .dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000133904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WerFaultSecure.exe
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000130560 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthpan.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000128000 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssprxy.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000123904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\srpapi.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000117760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryUpgrade .dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000115792 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32u.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000107008 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcpopkeysrv.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000107008 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hidbth.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000105472 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthenum.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000104960 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\UcmCx.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000097792 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthhfenum.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000097280 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\Microsoft.Bluetooth.Le gacy.LEEnumerator.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000094624 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpudd.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000090464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msacm32.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000090112 _____ (Microsoft Corporation) C:\WINDOWS\system32\datamarketsvc.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000083968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjter40.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000083968 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbkmclr.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000082336 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbkmcl.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000081176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32u.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000079872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wudriver.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000078848 _____ (Microsoft Corporation) C:\WINDOWS\system32\offreg.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000071680 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\usbser.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000051712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\UcmUcsi.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000050176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cldapi.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000049720 _____ (Microsoft Corporation) C:\WINDOWS\system32\tbs.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000046592 _____ (Microsoft Corporation) C:\WINDOWS\system32\sscore.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000042496 _____ (Microsoft Corporation) C:\WINDOWS\system32\tokenbinding.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000042456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tbs.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000039424 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\buttonconverter.sys
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000037376 _____ (Microsoft Corporation) C:\WINDOWS\system32\SEMgrPS.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000035840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sscore.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000034816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tokenbinding.dll
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000031932 _____ C:\WINDOWS\system32\edgehtmlpluginpolicy.bin
                      2017-09-21 21:42 - 2017-09-21 21:42 - 000025088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\odbcconf.dll
                      2017-09-21 21:32 - 2017-09-21 21:32 - 000008192 _____ C:\WINDOWS\system32\config\userdiff
                      2017-09-21 21:32 - 2017-09-21 12:50 - 000000000 ____D C:\WINDOWS\ServiceProfiles
                      2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files\Reference Assemblies
                      2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files\MSBuild
                      2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files (x86)\Reference Assemblies
                      2017-09-21 21:29 - 2017-09-21 21:29 - 000000000 ____D C:\Program Files (x86)\MSBuild
                      2017-09-21 21:28 - 2017-02-10 20:26 - 001166520 _____ (Microsoft Corporation) C:\WINDOWS\system32\PresentationNative_v0300.dll
                      2017-09-21 21:28 - 2017-02-10 20:26 - 000124624 _____ (Microsoft Corporation) C:\WINDOWS\system32\PresentationCFFRasterizerNativ e_v0300.dll
                      2017-09-21 21:28 - 2017-02-10 20:26 - 000035480 _____ (Microsoft Corporation) C:\WINDOWS\system32\TsWpfWrp.exe
                      2017-09-21 21:28 - 2017-02-10 20:21 - 000778936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PresentationNative_v0300.dll
                      2017-09-21 21:28 - 2017-02-10 20:21 - 000103120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PresentationCFFRasterizerNativ e_v0300.dll
                      2017-09-21 21:28 - 2017-02-10 20:21 - 000035480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TsWpfWrp.exe
                      2017-09-21 18:18 - 2017-09-21 18:18 - 000000051 _____ C:\Users\papeter\Documents\talktalk call centres.txt
                      2017-09-21 14:09 - 2017-09-21 14:09 - 000003366 _____ C:\WINDOWS\System32\Tasks\OneDrive Standalone Update Task-S-1-5-21-4237603079-860989819-990887440-1001
                      2017-09-21 14:06 - 2017-09-21 14:06 - 000000000 ____D C:\ProgramData\Microsoft OneDrive
                      2017-09-21 14:03 - 2017-09-21 14:03 - 000000020 ___SH C:\Users\papeter\ntuser.ini
                      2017-09-21 13:33 - 2017-09-21 13:40 - 000007623 _____ C:\WINDOWS\diagwrn.xml
                      2017-09-21 13:33 - 2017-09-21 13:40 - 000007623 _____ C:\WINDOWS\diagerr.xml
                      2017-09-21 13:20 - 2017-09-27 11:55 - 000004250 _____ C:\WINDOWS\System32\Tasks\HMA! Pro VPN Update
                      2017-09-21 13:20 - 2017-09-27 11:46 - 000000006 ____H C:\WINDOWS\Tasks\SA.DAT
                      2017-09-21 13:20 - 2017-09-26 17:55 - 000004156 _____ C:\WINDOWS\System32\Tasks\User_Feed_Synchronizatio n-{0F46EB48-50E2-4372-B3E0-FDD9244C8B47}
                      2017-09-21 13:20 - 2017-09-21 13:21 - 000003548 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA1d257e73535f0dd
                      2017-09-21 13:20 - 2017-09-21 13:21 - 000003344 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineU A
                      2017-09-21 13:20 - 2017-09-21 13:21 - 000003338 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core
                      2017-09-21 13:20 - 2017-09-21 13:21 - 000003280 _____ C:\WINDOWS\System32\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001
                      2017-09-21 13:20 - 2017-09-21 13:21 - 000003278 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater
                      2017-09-21 13:20 - 2017-09-21 13:21 - 000002936 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-4237603079-860989819-990887440-1001
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000003606 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000003482 _____ C:\WINDOWS\System32\Tasks\Adobe Acrobat Update Task
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000003280 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core1d257e734ba2eb7
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000003184 _____ C:\WINDOWS\System32\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000003120 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineC ore
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000003042 _____ C:\WINDOWS\System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000002762 _____ C:\WINDOWS\System32\Tasks\AdobeAAMUpdater-1.0-Lenovo-PC-papeter
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000002680 _____ C:\WINDOWS\System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000002316 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-4237603079-860989819-990887440-500
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000002256 _____ C:\WINDOWS\System32\Tasks\PDVDServ Task
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000002216 _____ C:\WINDOWS\System32\Tasks\CCleanerSkipUAC
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000000000 ____D C:\WINDOWS\System32\Tasks\WPD
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000000000 ____D C:\WINDOWS\System32\Tasks\Lenovo
                      2017-09-21 13:20 - 2017-09-21 13:20 - 000000000 ____D C:\WINDOWS\System32\Tasks\Apple
                      2017-09-21 13:20 - 2014-08-23 22:38 - 000003596 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-3320520227-2896305394-2021013739-500
                      2017-09-21 13:20 - 2014-04-03 19:35 - 000003594 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-1050727674-2070356693-977449066-500
                      2017-09-21 13:17 - 2017-09-27 11:51 - 000970206 _____ C:\WINDOWS\system32\PerfStringBackup.INI
                      2017-09-21 13:06 - 2017-09-21 13:06 - 000001576 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Media Player.lnk
                      2017-09-21 13:01 - 2017-09-21 13:01 - 000000000 ____D C:\ProgramData\USOShared
                      2017-09-21 13:00 - 2017-09-21 13:09 - 000000000 ____D C:\WINDOWS\system32\config\bbimigrate
                      2017-09-21 12:56 - 2017-09-26 23:20 - 000000000 ____D C:\Users\papeter
                      2017-09-21 12:55 - 2017-09-21 12:55 - 000000000 ____D C:\WINDOWS\SysWOW64\sda
                      2017-09-21 12:54 - 2017-09-27 11:47 - 000000180 _____ C:\WINDOWS\system32{A6D608F0-0BDE-491A-97AE-5C4B05D86E01}.bat
                      2017-09-21 12:54 - 2017-09-21 13:01 - 000000000 ____D C:\ProgramData\NVIDIA Corporation
                      2017-09-21 12:54 - 2017-09-21 13:00 - 000000000 ____D C:\Program Files\NVIDIA Corporation
                      2017-09-21 12:54 - 2017-09-21 13:00 - 000000000 ____D C:\Program Files\Intel
                      2017-09-21 12:54 - 2017-09-21 12:55 - 000000000 ____D C:\Program Files\Elantech
                      2017-09-21 12:54 - 2017-09-21 12:54 - 000000200 _____ C:\WINDOWS\system32{EC94D02F-D200-4428-9531-05AF7F9799CB}.bat
                      2017-09-21 12:54 - 2017-09-21 12:54 - 000000000 _____ C:\WINDOWS\system32\GfxValDisplayLog.bin
                      2017-09-21 12:54 - 2017-05-26 05:12 - 000103888 _____ (Khronos Group) C:\WINDOWS\SysWOW64\OpenCL.DLL
                      2017-09-21 12:54 - 2017-05-26 05:12 - 000099792 _____ (Khronos Group) C:\WINDOWS\system32\OpenCL.DLL
                      2017-09-21 12:54 - 2016-12-29 14:16 - 006384576 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcpl.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 002475968 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvc64.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 001762752 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvcr.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000546752 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshext.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000392128 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvmctray.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000147000 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\oemdspif.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000083512 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshextr.dll
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000069568 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvshext.dll
                      2017-09-21 12:54 - 2016-12-22 00:59 - 007651057 _____ C:\WINDOWS\system32\nvcoproc.bin
                      2017-09-21 12:53 - 2017-09-21 13:00 - 000000000 ____D C:\ProgramData\Conexant
                      2017-09-21 12:53 - 2017-09-21 13:00 - 000000000 ____D C:\Program Files\CONEXANT
                      2017-09-21 12:53 - 2017-09-21 12:53 - 000000000 ____H C:\WINDOWS\system32\Drivers\Msft_Kernel_TeeDriverx 64_01011.Wdf
                      2017-09-21 12:53 - 2017-09-21 12:53 - 000000000 ____H C:\ProgramData\DP45977C.lfl
                      2017-09-21 12:53 - 2017-03-18 21:56 - 002233344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PrintConfig.dll
                      2017-09-21 12:50 - 2017-09-27 12:30 - 000000000 ____D C:\WINDOWS\system32\SleepStudy
                      2017-09-21 12:50 - 2017-09-22 18:01 - 000418080 _____ C:\WINDOWS\system32\FNTCACHE.DAT
                      2017-09-21 12:49 - 2017-09-27 11:46 - 000153336 _____ C:\WINDOWS\system32\wpbbin.exe
                      2017-09-21 12:49 - 2017-09-27 11:46 - 000111088 _____ (Lenovo (Beijing) Limited) C:\WINDOWS\system32\LenovoCheck.exe
                      2017-09-21 12:49 - 2017-09-27 11:46 - 000026608 _____ (Lenovo) C:\WINDOWS\system32\LenovoUpdate.exe
                      2017-09-20 22:04 - 2017-09-21 18:11 - 000000000 ___DC C:\WINDOWS\Panther
                      2017-09-19 23:56 - 2017-09-19 23:56 - 000743936 _____ C:\Users\papeter\Documents\JOHN CRETANI AFFIL ON YTUBE.pub
                      2017-09-19 16:20 - 2017-09-19 16:20 - 000014374 _____ C:\Users\papeter\Downloads\Keyword Planner 2017-09-19 at 16_20_29.csv
                      2017-09-19 14:20 - 2017-09-19 14:20 - 000059555 _____ C:\Users\papeter\Downloads\estibot-export(64).csv
                      2017-09-19 00:56 - 2017-09-19 00:56 - 001182208 _____ C:\Users\papeter\Documents\Jared Polin.pub
                      2017-09-19 00:13 - 2017-09-19 00:13 - 000000000 ____D C:\Users\papeter\Desktop\JohnCVideos
                      2017-09-18 21:04 - 2017-09-18 21:26 - 000000293 _____ C:\Users\papeter\Documents\SUPERFOODS.txt
                      2017-09-18 18:21 - 2017-09-18 18:21 - 009826968 _____ (Piriform Ltd) C:\Users\papeter\Downloads\ccsetup534.exe
                      2017-09-18 17:15 - 2017-09-18 17:50 - 631061270 _____ C:\Users\papeter\Desktop\Mike&Brett.avi
                      2017-09-18 14:53 - 2017-09-18 22:16 - 000595456 _____ C:\Users\papeter\Documents\AIDA JC.pub
                      2017-09-18 14:24 - 2017-09-18 22:14 - 000000457 _____ C:\Users\papeter\Documents\JOHN CRESTANI USEFUL RESOURCES.txt
                      2017-09-18 14:21 - 2017-09-18 14:21 - 004773823 _____ C:\Users\papeter\Desktop\2015-BTF-Guide-to-Everything.pdf
                      2017-09-14 23:42 - 2017-09-14 23:42 - 001230204 _____ C:\Users\papeter\Downloads\5 Steps to a 7 Figure E-commerce Business(1).pdf
                      2017-09-14 23:41 - 2017-09-14 23:41 - 001230204 _____ C:\Users\papeter\Downloads\5 Steps to a 7 Figure E-commerce Business.pdf
                      2017-09-13 20:29 - 2017-09-13 20:29 - 009943296 _____ C:\Users\papeter\Desktop\Passion Blog Pro Starter Guide PDF.pdf
                      2017-09-13 20:17 - 2017-09-13 20:17 - 000000105 _____ C:\Users\papeter\Documents\Gilles address in France.txt
                      2017-09-13 20:09 - 2017-09-13 20:09 - 000373248 _____ C:\Users\papeter\Documents\ebay client address.pub
                      2017-09-12 21:39 - 2017-09-12 21:39 - 000922279 _____ C:\Users\papeter\Downloads\fb_linkpost3(2).zip
                      2017-09-12 21:38 - 2017-09-12 21:39 - 000922279 _____ C:\Users\papeter\Downloads\fb_linkpost3(1).zip
                      2017-09-12 21:27 - 2017-09-12 21:27 - 000003136 _____ C:\Users\papeter\Downloads\Special Traffic Training.ics
                      2017-09-12 10:47 - 2017-09-12 10:47 - 000922279 _____ C:\Users\papeter\Downloads\fb_linkpost3.zip
                      2017-09-12 10:47 - 2017-09-12 10:47 - 000000000 ____D C:\Users\papeter\Downloads\fb_linkpost3
                      2017-09-11 08:30 - 2017-09-21 10:11 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\754C0DB7.sys
                      2017-09-10 15:38 - 2017-09-10 15:52 - 449847274 _____ C:\Users\papeter\Desktop\Recording #126.avi
                      2017-09-08 11:37 - 2017-09-08 11:37 - 001059328 _____ C:\Users\papeter\Documents\nofap.pub
                      2017-09-08 09:13 - 2017-09-10 11:41 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\1B6A4467.sys
                      2017-09-07 22:57 - 2017-09-07 22:57 - 000000028 _____ C:\Users\papeter\Documents\imjetset.com John Crestani.txt
                      2017-09-07 17:41 - 2017-09-07 17:41 - 000200932 _____ C:\Users\papeter\Desktop\15-HIGH-PAYING-AFFILIATE-PROGRAMS.pdf
                      2017-09-07 10:36 - 2017-09-07 10:36 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\0AEA3549.sys
                      2017-09-07 00:01 - 2017-09-07 00:01 - 000000087 _____ C:\Users\papeter\Documents\Frans lead gen sites re interview with Michael Cyger.txt
                      2017-09-06 23:37 - 2017-09-06 23:37 - 000007672 _____ C:\Users\papeter\Downloads\estibot-export(63).csv
                      2017-09-06 22:33 - 2017-09-06 22:33 - 000000093 _____ C:\Users\papeter\Documents\sky.txt
                      2017-09-06 16:33 - 2017-09-06 16:33 - 000000044 _____ C:\Users\papeter\Documents\yes.txt
                      2017-09-06 14:00 - 2017-09-06 14:00 - 000199680 _____ C:\Users\papeter\Documents\FLIPFLOP 1.pub
                      2017-09-05 23:13 - 2017-09-05 23:13 - 000355952 _____ C:\Users\papeter\Desktop\200SocialMediaTactics.pdf
                      2017-09-05 19:03 - 2017-09-05 19:03 - 001489579 _____ C:\Users\papeter\Documents\The Unseen Therapist.pdf
                      2017-09-05 14:37 - 2017-09-21 13:09 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HiSuite
                      2017-09-05 14:37 - 2017-09-05 14:37 - 000001071 _____ C:\Users\Public\Desktop\HiSuite.lnk
                      2017-09-05 14:37 - 2017-09-05 14:37 - 000000000 ____D C:\Program Files (x86)\HiSuite
                      2017-09-04 21:29 - 2017-09-08 16:44 - 000000102 _____ C:\Users\papeter\Documents\Assets.txt
                      2017-09-04 20:30 - 2017-09-04 20:30 - 000000043 _____ C:\Users\papeter\Documents\ceseare.txt
                      2017-09-04 17:10 - 2017-09-04 17:10 - 000000056 _____ C:\Users\papeter\Documents\Amazon pending review for t-shirts.txt
                      2017-09-03 12:09 - 2017-09-03 12:11 - 357891850 _____ C:\Users\papeter\Downloads\TextSuiteBonus2(2).zip
                      2017-09-03 00:41 - 2017-09-03 00:41 - 000000446 _____ C:\Users\papeter\Documents\BLASTERSUITE REFUND REQUEST.txt
                      2017-09-01 12:38 - 2017-09-01 12:38 - 000599552 _____ C:\Users\papeter\Documents\ADPACK5.pub
                      2017-09-01 12:33 - 2017-09-01 12:33 - 000396800 _____ C:\Users\papeter\Documents\ADPACK4.pub
                      2017-09-01 12:29 - 2017-09-01 12:29 - 000334336 _____ C:\Users\papeter\Documents\ADPACKPRO 2.pub
                      2017-09-01 12:28 - 2017-09-01 12:28 - 000509440 _____ C:\Users\papeter\Documents\ADPACKPRO 1.pub
                      2017-08-31 20:55 - 2017-08-31 20:55 - 004125071 _____ C:\Users\papeter\Desktop\UNSEENTHERPIST.pdf
                      2017-08-29 22:33 - 2017-08-29 22:33 - 000182272 _____ C:\Users\papeter\Documents\Google traffic.pub
                      2017-08-29 20:15 - 2017-08-29 20:15 - 000087584 _____ (AO Kaspersky Lab) C:\WINDOWS\system32\Drivers\klupd_klif_kimul.sys
                      2017-08-29 17:26 - 2017-08-29 20:01 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\19292FEB.sys
                      2017-09-27 11:49 - 2015-10-15 23:30 - 000000000 ____D C:\ProgramData\Kaspersky Lab
                      2017-09-27 11:47 - 2015-08-23 23:25 - 000000000 __SHD C:\Users\papeter\IntelGraphicsProfiles
                      2017-09-27 11:46 - 2016-09-05 11:22 - 000000000 ____D C:\ProgramData\NVIDIA
                      2017-09-27 11:45 - 2017-03-18 12:40 - 000786432 _____ C:\WINDOWS\system32\config\BBI
                      2017-09-27 11:44 - 2015-11-30 22:09 - 000000000 ____D C:\Users\papeter\AppData\LocalLow\Temp
                      2017-09-27 11:40 - 2015-08-25 15:18 - 000000000 ____D C:\Users\papeter\AppData\Local\Adobe
                      2017-09-27 10:05 - 2015-08-23 23:25 - 000000000 ____D C:\Users\papeter\AppData\Local\Packages
                      2017-09-27 09:55 - 2015-10-15 22:17 - 000000000 ____D C:\Users\papeter\Documents\Outlook Files
                      2017-09-27 00:35 - 2015-10-17 16:31 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MBAMSwissArmy.sys
                      2017-09-26 23:47 - 2016-10-13 10:29 - 000000000 ____D C:\Program Files\Common Files\AV
                      2017-09-26 23:38 - 2017-03-18 22:03 - 000000000 ___HD C:\Program Files\WindowsApps
                      2017-09-26 23:38 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\AppReadiness
                      2017-09-26 23:35 - 2016-04-09 11:20 - 000000000 ____D C:\ProgramData\Malwarebytes Anti-Exploit
                      2017-09-26 22:19 - 2016-10-28 20:32 - 000002283 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
                      2017-09-26 11:37 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\appcompat
                      2017-09-26 00:35 - 2017-03-18 22:01 - 000000000 ____D C:\WINDOWS\INF
                      2017-09-24 16:22 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\NDF
                      2017-09-23 15:27 - 2015-10-20 21:34 - 000938133 _____ C:\Users\papeter\Desktop\MY DOMAINS (2) (Autosaved).xlsx
                      2017-09-22 17:28 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\LiveKernelReports
                      2017-09-21 21:48 - 2017-03-18 22:03 - 000028672 _____ C:\WINDOWS\system32\config\BCD-Template
                      2017-09-21 21:45 - 2017-03-18 22:06 - 000000000 ____D C:\WINDOWS\Setup
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ___SD C:\WINDOWS\SysWOW64\F12
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ___SD C:\WINDOWS\system32\F12
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\WinMetadata
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\setup
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\WinMetadata
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\WinBioPlugIns
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\setup
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\ShellExperiences
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\Program Files\Windows Photo Viewer
                      2017-09-21 21:44 - 2017-03-18 22:03 - 000000000 ____D C:\Program Files (x86)\Windows Photo Viewer
                      2017-09-21 21:33 - 2017-03-19 03:30 - 000000000 ____D C:\WINDOWS\OCR
                      2017-09-21 16:05 - 2017-03-18 21:51 - 000000000 ____D C:\WINDOWS\CbsTemp
                      2017-09-21 14:15 - 2015-12-17 09:46 - 000002460 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Outlook 2016.lnk
                      2017-09-21 14:08 - 2015-10-15 20:29 - 000002380 _____ C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\OneDrive.lnk
                      2017-09-21 14:08 - 2015-10-15 17:37 - 000000000 ___RD C:\Users\papeter\OneDrive
                      2017-09-21 14:03 - 2017-03-18 22:03 - 000000000 ___RD C:\WINDOWS\ImmersiveControlPanel
                      2017-09-21 14:03 - 2015-09-10 06:42 - 000000000 __RHD C:\Users\Public\AccountPictures
                      2017-09-21 13:42 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\rescache
                      2017-09-21 13:41 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\WinBioDatabase
                      2017-09-21 13:31 - 2016-07-16 12:47 - 000000000 ____D C:\WINDOWS\system32\Tasks_Migrated
                      2017-09-21 13:29 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\Registration
                      2017-09-21 13:29 - 2016-06-20 23:41 - 000057424 _____ (AO Kaspersky Lab) C:\WINDOWS\system32\Drivers\klim6.sys
                      2017-09-21 13:21 - 2017-03-19 03:31 - 000000000 ____D C:\WINDOWS\HoloShell
                      2017-09-21 13:20 - 2016-01-25 00:20 - 000000662 _____ C:\WINDOWS\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001.job
                      2017-09-21 13:20 - 2016-01-25 00:20 - 000000566 _____ C:\WINDOWS\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001.job
                      2017-09-21 13:20 - 2015-10-15 20:15 - 000022840 _____ C:\WINDOWS\system32\emptyregdb.dat
                      2017-09-21 13:19 - 2017-03-18 22:03 - 000000000 __RSD C:\WINDOWS\Media
                      2017-09-21 13:19 - 2017-03-18 22:03 - 000000000 __RHD C:\Users\Public\Libraries
                      2017-09-21 13:15 - 2015-02-05 23:04 - 000889694 _____ C:\WINDOWS\SysWOW64\PerfStringBackup.INI
                      2017-09-21 13:09 - 2017-08-21 20:11 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Privax
                      2017-09-21 13:09 - 2017-07-11 22:23 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
                      2017-09-21 13:09 - 2017-07-06 23:06 - 000000000 ____D C:\WINDOWS\system32\UNP
                      2017-09-21 13:09 - 2017-06-21 15:31 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Zoom
                      2017-09-21 13:09 - 2017-03-27 12:15 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NETGEAR WNDA3100v3 Genie
                      2017-09-21 13:09 - 2017-03-18 22:03 - 000000000 ____D C:\ProgramData\regid.1991-06.com.microsoft
                      2017-09-21 13:09 - 2016-10-13 10:34 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kaspersky Secure Connection
                      2017-09-21 13:09 - 2016-10-13 10:34 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kaspersky Internet Security
                      2017-09-21 13:09 - 2016-05-24 10:04 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Recuva
                      2017-09-21 13:09 - 2016-05-19 15:36 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon MG7700 series User Registration
                      2017-09-21 13:09 - 2016-05-19 15:33 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon MG7700 series Manual
                      2017-09-21 13:09 - 2016-04-09 11:20 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes Anti-Exploit
                      2017-09-21 13:09 - 2016-04-01 16:11 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner
                      2017-09-21 13:09 - 2016-03-02 19:43 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Screencast-O-Matic v2.0
                      2017-09-21 13:09 - 2016-02-25 01:30 - 000000000 ____D C:\ProgramData\regid.1986-12.com.adobe
                      2017-09-21 13:09 - 2016-02-07 12:41 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight
                      2017-09-21 13:09 - 2016-02-07 12:13 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN
                      2017-09-21 13:09 - 2016-02-01 13:16 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\webplugin.exe
                      2017-09-21 13:09 - 2016-01-16 19:20 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Picasa 3
                      2017-09-21 13:09 - 2015-12-01 18:18 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Interst Architect
                      2017-09-21 13:09 - 2015-10-22 17:00 - 000000000 ____D C:\WINDOWS\system32\STRING
                      2017-09-21 13:09 - 2015-10-17 16:31 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes Anti-Malware
                      2017-09-21 13:09 - 2015-10-15 17:30 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2016 Tools
                      2017-09-21 13:09 - 2015-02-05 23:52 - 000000000 ___RD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CyberLink PowerDirector 10
                      2017-09-21 13:09 - 2015-02-05 23:48 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Lenovo
                      2017-09-21 13:09 - 2015-02-05 23:03 - 000000000 ___RD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel
                      2017-09-21 13:09 - 2015-02-05 23:01 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation
                      2017-09-21 13:08 - 2017-07-24 23:13 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Alexander Kabakov
                      2017-09-21 13:08 - 2017-03-18 12:40 - 000008192 _____ C:\WINDOWS\system32\config\ELAM
                      2017-09-21 13:08 - 2016-12-01 21:10 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Microsoft Corporation
                      2017-09-21 13:08 - 2016-07-30 18:17 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Lenovo
                      2017-09-21 13:08 - 2016-07-09 22:38 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Google Photos Backup
                      2017-09-21 13:08 - 2016-05-08 21:11 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\IrfanView
                      2017-09-21 13:08 - 2016-02-06 18:37 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Handbrake
                      2017-09-21 13:07 - 2015-10-30 07:28 - 000000000 ____D C:\Users\Default.migrated
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\Macromed
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\lv-LV
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\lt-LT
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\et-EE
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\SysWOW64\en-GB
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\spool
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\oobe
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\Macromed
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\lv-LV
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\lt-LT
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\InputMethod
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\et-EE
                      2017-09-21 13:02 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\system32\en-GB
                      2017-09-21 13:02 - 2016-01-05 15:18 - 000000000 ____D C:\WINDOWS\SysWOW64\spool
                      2017-09-21 13:02 - 2015-02-05 23:23 - 000000000 ____D C:\WINDOWS\SysWOW64\Lenovo
                      2017-09-21 13:02 - 2015-02-05 23:23 - 000000000 ____D C:\WINDOWS\system32\Lenovo
                      2017-09-21 13:02 - 2013-08-22 16:36 - 000000000 ____D C:\WINDOWS\system32\WindowsInternal.Inbox.Shared
                      2017-09-21 13:02 - 2013-08-22 16:36 - 000000000 ____D C:\WINDOWS\system32\WindowsInternal.Inbox.Media.Sh ared
                      2017-09-21 13:01 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\InputMethod
                      2017-09-21 13:01 - 2017-03-18 22:03 - 000000000 ____D C:\ProgramData\USOPrivate
                      2017-09-21 13:01 - 2016-05-19 15:31 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon Utilities
                      2017-09-21 13:01 - 2016-05-18 20:45 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\EPSON
                      2017-09-21 13:01 - 2015-02-05 23:54 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nuance
                      2017-09-21 13:01 - 2015-02-05 23:07 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Conexant
                      2017-09-21 13:00 - 2017-03-18 22:03 - 000000000 ____D C:\Program Files\Common Files\microsoft shared
                      2017-09-21 12:58 - 2017-01-16 15:37 - 000000000 ____D C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Chrome Apps
                      2017-09-21 12:55 - 2017-03-18 12:40 - 000000000 ____D C:\WINDOWS\system32\Sysprep
                      2017-09-21 12:54 - 2017-03-18 22:03 - 000000000 ____D C:\WINDOWS\Help
                      2017-09-21 12:03 - 2017-07-11 07:54 - 000000000 ___HD C:$WINDOWS.~BT
                      2017-09-19 00:19 - 2016-03-02 19:43 - 000000000 ____D C:\Users\papeter\AppData\Local\Screencast-O-Matic-v2
                      2017-09-18 18:19 - 2016-04-01 16:11 - 000000000 ____D C:\Program Files\CCleaner
                      2017-09-18 14:57 - 2017-07-08 20:48 - 000000000 ____D C:\Users\papeter\AppData\Local\GoToMeeting
                      2017-09-17 23:50 - 2016-02-07 12:14 - 000000000 ____D C:\Users\papeter\AppData\Roaming\vlc
                      2017-09-15 21:44 - 2015-02-05 23:48 - 000000000 ____D C:\Program Files (x86)\Microsoft Office
                      2017-09-14 09:11 - 2016-07-30 18:17 - 000000000 ____D C:\Users\papeter\AppData\Local\Apps\2.0
                      2017-09-14 00:11 - 2016-06-27 00:20 - 000000000 ____D C:\Program Files (x86)\HMA! Pro VPN
                      2017-09-13 17:09 - 2015-08-25 09:13 - 000000000 ____D C:\WINDOWS\system32\MRT
                      2017-09-13 17:04 - 2015-08-25 09:13 - 138202976 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
                      2017-09-05 23:12 - 2015-10-29 16:21 - 000000000 ____D C:\Users\papeter\Documents\MARKETING
                      2017-09-05 17:58 - 2016-05-24 10:04 - 000000000 ____D C:\Program Files\Recuva
                      2017-09-05 14:43 - 2016-10-25 14:23 - 000000000 ____D C:\Users\papeter\AppData\Local\Hisuite
                      2017-09-03 12:16 - 2017-08-17 23:38 - 491558047 _____ C:\Users\papeter\Desktop\TextSuiteBonus2.mp4
                      2017-09-02 16:15 - 2017-03-18 22:06 - 000835576 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
                      2017-09-02 16:15 - 2017-03-18 22:06 - 000177656 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
                      2017-08-31 21:30 - 2015-10-17 16:11 - 000002457 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acrobat Reader DC.lnk
                      2017-08-28 18:55 - 2017-08-27 00:19 - 000192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\514C021D.sys
                      2016-06-22 09:54 - 2016-12-01 17:41 - 000577414 _____ () C:\Users\papeter\AppData\Roaming\Scorch_Install.lo g
                      2016-01-26 18:24 - 2017-04-27 00:22 - 000005632 _____ () C:\Users\papeter\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
                      2016-03-31 09:56 - 2016-03-31 09:56 - 000007609 _____ () C:\Users\papeter\AppData\Local\Resmon.ResmonCfg
                      2017-09-21 12:53 - 2017-09-21 12:53 - 000000000 ____H () C:\ProgramData\DP45977C.lfl
                      [HEADING=1]C:\WINDOWS\system32\winlogon.exe => File is digitally signed
                      Additional scan result of Farbar Recovery Scan Tool (x64) Version: 26-09-2017
                      Ran by papeter (27-09-2017 12:48:32)
                      Running from C:\Users\papeter\Downloads
                      Windows 10 Home Version 1703 (X64) (2017-09-21 12:43:08)
                      Boot Mode: Normal[/HEADING]
                      Administrator (S-1-5-21-4237603079-860989819-990887440-500 - Administrator - Disabled)
                      DefaultAccount (S-1-5-21-4237603079-860989819-990887440-503 - Limited - Disabled)
                      Guest (S-1-5-21-4237603079-860989819-990887440-501 - Limited - Disabled)
                      papeter (S-1-5-21-4237603079-860989819-990887440-1001 - Administrator - Enabled) => C:\Users\papeter
                      AV: Kaspersky Internet Security (Disabled - Up to date) {86367591-4BE4-AE08-2FD9-7FCB8259CD98}
                      AS: Kaspersky Internet Security (Disabled - Up to date) {3D579475-6DDE-A186-1569-44B9F9DE8725}
                      FW: Kaspersky Internet Security (Disabled) {BE0DF4B4-018B-AF50-0486-D6FE7C8A8AE3}
                      Adobe Acrobat Reader DC (HKLM-x32...{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 17.012.20098 - Adobe Systems Incorporated)
                      Adobe Flash Player 27 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 27.0.0.130 - Adobe Systems Incorporated)
                      Adobe Premiere Elements 14 (HKLM-x32...{18EF738B-56F0-4370-8FEA-93FC9EC51DFA}) (Version: 14.1 - Adobe Systems Incorporated)
                      amazeowl-desktop (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\amazeowl) (Version: 2.26.1 - AmazeOwl (c) 2017)
                      Apple Application Support (32-bit) (HKLM-x32...{E92BB800-BCC5-4C25-8102-AC2C3B7C7C1E}) (Version: 5.5 - Apple Inc.)
                      Apple Application Support (64-bit) (HKLM...{9C912B1E-06DD-43EF-BB2B-45CB2C88BAAE}) (Version: 5.5 - Apple Inc.)
                      Apple Mobile Device Support (HKLM...{0A596141-97D5-45FA-9281-98DFAF48D579}) (Version: 10.3.2.3 - Apple Inc.)
                      Apple Software Update (HKLM-x32...{52D87F32-70E4-4348-8148-C0B9F35B1314}) (Version: 2.3.0.177 - Apple Inc.)
                      BlasterSuite Manager (HKLM-x32...{43431316-1F90-4D26-952C-A88F8303736A}) (Version: 1.0.6 - BlasterSuite)
                      Bonjour (HKLM...{56DDDFB8-7F79-4480-89D5-25E1F52AB28F}) (Version: 3.1.0.1 - Apple Inc.)
                      Canon Easy-WebPrint EX (HKLM-x32...\Easy-WebPrint EX) (Version: 1.6.0.0 - Canon Inc.)
                      Canon IJ Network Scanner Selector EX (HKLM-x32...\Canon_IJ_Network_Scanner_Selector_EX) (Version: 1.5.4.4 - Canon Inc.)
                      Canon IJ Network Tool (HKLM-x32...\Canon_IJ_Network_UTILITY) (Version: 3.7.0 - Canon Inc.)
                      Canon IJ Scan Utility (HKLM-x32...\Canon_IJ_Scan_Utility) (Version: 1.1.20.13 - Canon Inc.)
                      Canon Inkjet Printer/Scanner/Fax Extended Survey Program (HKLM-x32...\CANONIJPLM100) (Version: 5.0.1 - Canon Inc.)
                      Canon MG7700 series MP Drivers (HKLM...{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}Canon_MG7700_series) (Version: 1.00 - Canon Inc.)
                      Canon MG7700 series On-screen Manual (HKLM-x32...\Canon MG7700 series On-screen Manual) (Version: 7.8.0 - Canon Inc.)
                      Canon MG7700 series User Registration (HKLM-x32...\Canon MG7700 series User Registration) (Version: - ‭Canon Inc.)
                      Canon My Image Garden (HKLM-x32...\Canon My Image Garden) (Version: 3.3.0 - Canon Inc.)
                      Canon My Image Garden Design Files (HKLM-x32...\Canon My Image Garden Design Files) (Version: 3.2.0 - Canon Inc.)
                      Canon My Printer (HKLM-x32...\CanonMyPrinter) (Version: 3.3.0 - Canon Inc.)
                      Canon Quick Menu (HKLM-x32...\CanonQuickMenu) (Version: 2.6.1 - Canon Inc.)
                      CCleaner (HKLM...\CCleaner) (Version: 5.35 - Piriform)
                      CCSDK (HKLM-x32...{AE75190B-11B4-4F90-8254-DAB275CF2557}is1) (Version: 1.0.3.4 - Lenovo)
                      Click Install if prompted (HKLM-x32...{92A9572E-834E-477B-A100-C9AD3EE4B4B9}) (Version: 1.0.0.0 - ExpressVpn) Hidden
                      Conexant HD Audio (HKLM...\CNXT_AUDIO_HDA) (Version: 8.65.55.62 - Conexant)
                      CyberLink PowerDirector 10 (HKLM...{B0B4F6D2-F2AE-451A-9496-6F2F6A897B32}) (Version: 10.0.0.2810 - CyberLink Corp.) Hidden
                      CyberLink PowerDirector 10 (HKLM-x32...\InstallShield
                      Dependency Package Update (HKLM...{0788641D-D31A-478D-BB34-C41564AE9F93}) (Version: 1.6.38.00 - Lenovo Inc.) Hidden
                      Dependency Package Update (HKLM...{5252431C-288E-409D-ADCF-24407E0E6F70}) (Version: 1.6.25.00 - Lenovo Inc.) Hidden
                      Dependency Package Update (HKLM...{FFED38DF-94DC-4FF9-96C1-A6990EDA6B03}) (Version: 1.6.29.00 - Lenovo Inc.) Hidden
                      Dolby Digital Plus Home Theater (HKLM...{7E3D8FA1-6092-469A-955B-68FC4A2C67CA}) (Version: 7.5.1.1 - Dolby Laboratories Inc)
                      Dragon Assistant version 1.5.20 (HKLM-x32...{D57A8269-3BE5-4D10-B882-64D0F2D448BF}is1) (Version: 1.5.20 - Nuance Communications, Inc.)
                      ELAN Touchpad 11.15.0.18_X64 (HKLM...\Elantech) (Version: 11.15.0.18 - ELAN Microelectronic Corp.)
                      EPSON SX430 Series Printer Uninstall (HKLM...\EPSON SX430 Series) (Version: - SEIKO EPSON Corporation)
                      ExpressVPN (HKLM-x32...{10EB2DEF-3C7F-40DD-8C58-438906E20D08}) (Version: 6.2.3.2578 - ExpressVPN) Hidden
                      ExpressVPN (HKLM-x32...{a219f179-a66a-48db-934c-aca0746714e5}) (Version: 6.2.3.2578 - ExpressVPN)
                      Google Chrome (HKLM-x32...\Google Chrome) (Version: 61.0.3163.100 - Google Inc.)
                      Google Photos Backup (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\Google Photos Backup) (Version: 1.1.2.13 - Google, Inc.)
                      Google Update Helper (HKLM-x32...{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.5 - Google Inc.) Hidden
                      GoTo Opener (HKLM-x32...{8B2D47CC-1558-4939-B27F-41E30530072A}) (Version: 1.0.467 - LogMeIn, Inc.)
                      GoToMeeting 8.11.0.7586 (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\GoToMeeting) (Version: 8.11.0.7586 - LogMeIn, Inc.)
                      HandBrake 0.10.3 (HKLM-x32...\HandBrake) (Version: 0.10.3 - )
                      HiSuite (HKLM-x32...\Hi Suite) (Version: 1.0 - Huawei Technologies Co.,Ltd)
                      HMA! Pro VPN (HKLM...{60A560F2-CB75-4C94-9C36-39AD2161DE73}is1) (Version: 3.5.58 - Privax)
                      Intel(R) Chipset Device Software (HKLM-x32...{f5d71765-7cd1-4e68-998f-5b379e725da3}) (Version: 10.0.22 - Intel(R) Corporation) Hidden
                      Intel(R) Management Engine Components (HKLM...{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 10.0.28.1006 - Intel Corporation)
                      Intel(R) Processor Graphics (HKLM-x32...{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 20.19.15.4531 - Intel Corporation)
                      Intel(R) Rapid Storage Technology (HKLM...{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 13.2.0.1016 - Intel Corporation)
                      Intel(R) Update Manager (HKLM-x32...{7224B7CE-196C-4E2A-A1AE-1D7BF259FD36}) (Version: 3.4.1942 - Intel Corporation)
                      Interst Architect (HKLM-x32...\Interst Architect1.0.0.7) (Version: 1.0.0.7 - InnAnTech Industries Inc.)
                      IrfanView 64 (remove only) (HKLM...\IrfanView64) (Version: 4.42 - Irfan Skiljan)
                      iTunes (HKLM...{F0C7385A-9D20-45F3-8101-05D383885180}) (Version: 12.6.1.25 - Apple Inc.)
                      Kaspersky Internet Security (HKLM-x32...{E27B1D7B-3B34-43A2-9FC0-9828D5DF46E2}) (Version: 17.0.0.611 - Kaspersky Lab) Hidden
                      Kaspersky Internet Security (HKLM-x32...\InstallWIX
                      Kaspersky Secure Connection (HKLM-x32...{1CF84962-50F8-48CA-9082-B70F3A02C686}) (Version: 17.0.0.611 - Kaspersky Lab) Hidden
                      Kaspersky Secure Connection (HKLM-x32...\InstallWIX
                      Lenovo Bluetooth with Enhanced Data Rate Software (HKLM...{C6D9ED03-6FCF-4410-9CB7-45CA285F9E11}) (Version: 12.0.0.9840 - Broadcom Corporation)
                      Lenovo Dependency Package (HKLM...\Lenovo Dependency Package_is1) (Version: 1.6.25.00 - Lenovo Group Limited)
                      Lenovo EasyCamera (HKLM-x32...{E0A7ED39-8CD6-4351-93C3-69CCA00D12B4}) (Version: 6.2.9200.10269 - Realtek Semiconductor Corp.)
                      Lenovo EasyCamera (HKLM-x32...{E399A5B3-ED53-4DEA-AF04-8011E1EB1EAC}) (Version: 6.3.9600.11105 - Realtek Semiconductor Corp.)
                      Lenovo FusionEngine (HKLM-x32...\Lenovo FusionEngine) (Version: 1.0.13.0 - Lenovo, Inc.)
                      Lenovo Mobile Phone Wireless Import (HKLM-x32...{DFB2E0D6-8DDE-49A4-B8F7-03C14DACCBA6}) (Version: 1.1.1.9 - Lenovo) Hidden
                      Lenovo Mobile Phone Wireless Import (HKLM-x32...\InstallShield
                      Lenovo OneKey Recovery (HKLM...{46F4D124-20E5-4D12-BE52-EC177A7A4B42}) (Version: 8.1.0.2619 - CyberLink Corp.) Hidden
                      Lenovo OneKey Recovery (HKLM-x32...\InstallShield_{46F4D124-20E5-4D12-BE52-EC177A7A4B42}) (Version: 8.1.0.2619 - CyberLink Corp.)
                      Lenovo Patch Utility (HKLM-x32...{E8F27ADF-B1ED-41AF-A7EF-D5E71778480C}) (Version: 1.3.2.6 - Lenovo Group Limited) Hidden
                      Lenovo Patch Utility 64 bit (HKLM...{49A09C2C-FFF4-478E-B397-5E0979F67F5D}) (Version: 1.3.2.6 - Lenovo Group Limited) Hidden
                      Lenovo PhoneCompanion (HKLM-x32...{0F82EA83-B0C5-4AB9-9695-DFE92C5FD57B}) (Version: 2.0.0.19 - Lenovo) Hidden
                      Lenovo PhoneCompanion (HKLM-x32...\InstallShield_{0F82EA83-B0C5-4AB9-9695-DFE92C5FD57B}) (Version: 2.0.0.19 - Lenovo)
                      Lenovo PowerDVD10 (HKLM-x32...{DEC235ED-58A4-4517-A278-C41E8DAEAB3B}) (Version: 10.0.6806.52 - CyberLink Corp.) Hidden
                      Lenovo PowerDVD10 (HKLM-x32...\InstallShield_{DEC235ED-58A4-4517-A278-C41E8DAEAB3B}) (Version: 10.0.6806.52 - CyberLink Corp.)
                      Lenovo Service Bridge (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\dda9ca0b023f4c56) (Version: 1.6.3.5 - Lenovo)
                      Lenovo Settings - Camera Audio (HKLM...{88C6A6D9-324C-46E8-BA87-563D14021442}_is1) (Version: 4.3.24.256 - Lenovo Corporation)
                      Lenovo Settings (HKLM...{D14CCBF5-1A3A-4C08-955B-BE6D519835C4}_is1) (Version: 2.0.0.5 - Lenovo)
                      Lenovo Settings Dependency Package (HKLM...{3694BA2E-BE31-4B7E-886B-A0B559E69D4D}_is1) (Version: 2.3.1.27 - Lenovo Group Limited)
                      Lenovo Settings Service (HKLM...{8C6F1EBA-17F1-4481-B688-9777E63E985F}_is1) (Version: 2.3.0.21 - Lenovo Group Limited)
                      Lenovo Settings UMDF driver (HKLM...{2BDC7413-65EA-4B99-8C4B-02F11075BE6D}is1) (Version: 1.2.0.7 - Lenovo Group Limited)
                      Lenovo Settings WiFi (HKLM...{86045A6C-C156-4349-A3E2-47A88A42F5C2}is1) (Version: 2.0.0.4 - Lenovo)
                      Lenovo_Wireless_Driver (HKLM-x32...{5D642A72-8194-4A22-80DA-11FE610CCA8E}) (Version: 6.30.223.201 - Lenovo)
                      LenovoUtility (HKLM-x32...{6ADA7E88-8D16-4D0D-BC90-2B93AC5E56DA}) (Version: 1.5.0.26 - Lenovo) Hidden
                      LenovoUtility (HKLM-x32...\InstallShield
                      Malwarebytes Anti-Exploit version 1.10.1.24 (HKLM...\Malwarebytes Anti-Exploit_is1) (Version: 1.10.1.24 - Malwarebytes)
                      Malwarebytes Anti-Malware version 2.2.1.1043 (HKLM-x32...\Malwarebytes Anti-Malware_is1) (Version: 2.2.1.1043 - Malwarebytes)
                      Metric Collection SDK 35 (HKLM-x32...{C2B5B5B0-2545-4E94-B4BA-548D4BF0B196}) (Version: 1.2.0001.00 - Lenovo Group Limited) Hidden
                      Microsoft Office 365 - en-us (HKLM...\O365HomePremRetail - en-us) (Version: 16.0.8326.2107 - Microsoft Corporation)
                      Microsoft OneDrive (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\OneDriveSetup.exe) (Version: 17.3.6998.0830 - Microsoft Corporation)
                      Microsoft Silverlight (HKLM...{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50907.0 - Microsoft Corporation)
                      Microsoft Support and Recovery Assistant for Office 365 (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\4415f693b586d348) (Version: 16.0.1519.6 - Microsoft Corporation)
                      Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM...{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
                      Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32...{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
                      Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215 (HKLM-x32...{e2803110-78b3-4664-a479-3611a381656a}) (Version: 14.0.24215.1 - Microsoft Corporation)
                      Mozilla Firefox 55.0.3 (x86 en-GB) (HKLM-x32...\Mozilla Firefox 55.0.3 (x86 en-GB)) (Version: 55.0.3 - Mozilla)
                      Mozilla Maintenance Service (HKLM...\MozillaMaintenanceService) (Version: 55.0.2 - Mozilla)
                      NETGEAR WNDA3100v3 (HKLM-x32...{60C50FCC-545B-4D5D-B0D1-4A773143BCE7}) (Version: 1.0.0.10 - NETGEAR) Hidden
                      NETGEAR WNDA3100v3 Genie (HKLM-x32...\InstallShield
                      Nuance Speech Component DA-A en-GB version 1.5.20 (HKLM-x32...{1CCBE73F-4948-4711-8D12-22E2FD65D706}_is1) (Version: 1.5.20 - Nuance Communications, Inc.)
                      Nuance Speech Component DA-C version 1.1.22 (HKLM-x32...{E97BA7A6-46FC-4EBF-B24A-B8362948C696}_is1) (Version: 1.1.22 - Nuance Communications, Inc.)
                      Nuance Speech Component DA-L en-GB version 1.1.5 (HKLM-x32...{CA54E6DD-70F8-4AE5-8427-522A52FC4408}_is1) (Version: 1.1.5 - Nuance Communications, Inc.)
                      NVIDIA GeForce Experience 2.1.2 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 2.1.2 - NVIDIA Corporation)
                      NVIDIA Graphics Driver 376.54 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 376.54 - NVIDIA Corporation)
                      NVIDIA PhysX System Software 9.14.0702 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}Display.PhysX) (Version: 9.14.0702 - NVIDIA Corporation)
                      Office 16 Click-to-Run Extensibility Component (HKLM-x32...{90160000-008C-0000-0000-0000000FF1CE}) (Version: 16.0.8326.2107 - Microsoft Corporation) Hidden
                      Office 16 Click-to-Run Extensibility Component 64-bit Registration (HKLM...{90160000-00DD-0000-1000-0000000FF1CE}) (Version: 16.0.8326.2107 - Microsoft Corporation) Hidden
                      Office 16 Click-to-Run Licensing Component (HKLM...{90160000-008F-0000-1000-0000000FF1CE}) (Version: 16.0.8326.2107 - Microsoft Corporation) Hidden
                      Office 16 Click-to-Run Localization Component (HKLM-x32...{90160000-008C-0409-0000-0000000FF1CE}) (Version: 16.0.8326.2107 - Microsoft Corporation) Hidden
                      paint.net (HKLM...{1F895C18-6A2F-4A9E-BBE9-246783070F37}) (Version: 4.0.16 - dotPDN LLC)
                      Picasa 3 (HKLM-x32...\Picasa 3) (Version: 3.9.141.259 - Google, Inc.)
                      Realtek Card Reader (HKLM-x32...{5BC2B5AB-80DE-4E83-B8CF-426902051D0A}) (Version: 6.3.9600.39059 - Realtek Semiconductor Corp.)
                      Realtek Ethernet Controller Driver (HKLM-x32...{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 8.33.529.2014 - Realtek)
                      Recuva (HKLM...\Recuva) (Version: 1.53 - Piriform)
                      Screencast-O-Matic v2.0 (HKLM-x32...\Screencast-O-Matic v2.0) (Version: v2.0 - Screencast-O-Matic)
                      Sibelius Scorch (Firefox, Opera, Netscape, Chrome only) (HKLM-x32...{41626CC0-A854-4402-AD06-D7939515C282}) (Version: 6.2.0 - Sibelius Software, a division of Avid Technology, Inc.)
                      Skype Web Plugin (HKLM-x32...{D116C78B-2A53-4BF9-A089-5BE0E132C10C}) (Version: 7.25.0.32 - Skype Technologies S.A.)
                      User Manuals (HKLM-x32...{F07C2CF8-4C53-4EC3-8162-A6221E36EB88}) (Version: 3.0.0.3 - Lenovo) Hidden
                      User Manuals (HKLM-x32...\InstallShield
                      VLC media player (HKLM-x32...\VLC media player) (Version: 2.2.6 - VideoLAN)
                      Vulkan Run Time Libraries 1.0.26.0 (HKLM...\VulkanRT1.0.26.0) (Version: 1.0.26.0 - LunarG, Inc.)
                      webplugin.exe version 3.1.0.4 (HKLM-x32...{ED02ABD7-1049-4984-A35A-26ABEC69E2E0}_is1) (Version: 3.1.0.4 - )
                      Windows 10 Update and Privacy Settings (HKLM...{4DFCD818-036A-4229-A67D-CF17DC461D92}) (Version: 1.0.14.0 - Microsoft Corporation)
                      Windows Driver Package - Lenovo (ACPIVPC) System (09/24/2013 19.29.2.34) (HKLM...\EE9B1F2037C580F36D92FA431CC02BFF04C31F15) (Version: 09/24/2013 19.29.2.34 - Lenovo)
                      Windows Driver Package - Lenovo (WUDFRd) LenovoVhid (07/25/2013 10.30.0.288) (HKLM...\6BCA401E9CBEED970D75F55FA5320F60D11984E9) (Version: 07/25/2013 10.30.0.288 - Lenovo)
                      Zoom (HKU\S-1-5-21-4237603079-860989819-990887440-1001...\ZoomUMX) (Version: 4.0 - Zoom Video Communications, Inc.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{1233A989-8A71-4FED-9712-C4F07707E209}\InprocServer32 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\GatewayActiveX-x64.dll (Skype Technologies S.A.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{13C484D6-AD2C-46D9-9581-1E03CBED164C}\localserver32 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\GatewayVersion-x64.exe (Skype Technologies S.A.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{144DF3B2-2402-47AE-9583-5A045929A8D4}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\psuser_64.dll (Google Inc.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{4BE56754-B616-4998-B825-D16983AEE1B2}\InprocServer32 → C:\WINDOWS\system32\mscoree.dll (Microsoft Corporation)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{590C4387-5EBD-4D46-8A84-CD0BA2EF2856}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 0.3\psuser_64.dll => No File
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{84B5A313-CD5D-4904-8BA2-AFDC81C1B309}\InprocServer32 → C:\Users\papeter\AppData\Local\GoToMeeting\7586\G2 MOutlookAddin64.dll (LogMeIn, Inc.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{CBF9CD8C-2714-4F36-B76A-43E6C7547BC2}\localserver32 → C:\Users\papeter\AppData\Local\SkypePlugin\7.25.0. 32\EdgeCalling.exe (Skype Technologies S.A.)
                      CustomCLSID: HKU\S-1-5-21-4237603079-860989819-990887440-1001_Classes\CLSID{E8CF3E55-F919-49D9-ABC0-948E6CB34B9F}\InprocServer32 → C:\Users\papeter\AppData\Local\Google\Update\1.3.3 3.5\psuser_64.dll (Google Inc.)
                      ContextMenuHandlers1: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
                      ContextMenuHandlers2: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
                      ContextMenuHandlers3: [MBAMShlExt] → {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamext.dll [2016-03-10] (Malwarebytes)
                      ContextMenuHandlers4: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
                      ContextMenuHandlers4: [RecuvaShellExt] → {435E5DF5-2510-463C-B223-BDA47006D002} => C:\Program Files\Recuva\RecuvaShell64.dll [2016-06-06] (Piriform Ltd)
                      ContextMenuHandlers5: [igfxDTCM] → {9B5F5829-A529-4B12-814A-E81BCB8D93FC} => C:\WINDOWS\system32\igfxDTCM.dll [2017-05-26] (Intel Corporation)
                      ContextMenuHandlers5: [NvCplDesktopContext] → {3D1975AF-48C6-4f8e-A182-BE0E08FA86A9} => C:\WINDOWS\system32\nvshext.dll [2016-12-29] (NVIDIA Corporation)
                      ContextMenuHandlers6: [Kaspersky Anti-Virus 17.0.0] → {39C9FA89-7012-4573-A92D-BFD1F8CA542D} => C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\x64\shellex.dll [2017-03-15] (AO Kaspersky Lab)
                      ContextMenuHandlers6: [MBAMShlExt] → {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamext.dll [2016-03-10] (Malwarebytes)
                      ContextMenuHandlers6: [RecuvaShellExt] → {435E5DF5-2510-463C-B223-BDA47006D002} => C:\Program Files\Recuva\RecuvaShell64.dll [2016-06-06] (Piriform Ltd)
                      Task: {0F9EF0E7-8B28-4747-9B41-EDD8C8B11A20} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core1d257e734ba2eb7 => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe [2016-07-09] (Google Inc.)
                      Task: {130945BA-E34F-406D-945F-4798B868FC9C} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe [2017-02-14] (Apple Inc.)
                      Task: {1A2F50C6-F791-4308-AD89-DD4AB0D6D5DD} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe [2016-07-09] (Google Inc.)
                      Task: {285FCF36-48A5-44A0-9982-E9304933A13E} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473 => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [2016-08-12] (Intel Corporation)
                      Task: {2E65BEF9-5870-433F-9530-1A0013F27E5A} - System32\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001 => C:\Users\papeter\AppData\Local\Citrix\GoToMeeting\ 5530\g2mupdate.exe [2016-09-03] (Citrix Online, a division of Citrix Systems, Inc.)
                      Task: {352E6CA0-7314-4DF4-89C4-682368D80D57} - System32\Tasks\Microsoft\Windows\Workplace Join\Automatic-Workplace-Join => C:\WINDOWS\System32\AutoWorkplace.exe
                      Task: {3D3E30EB-E7EF-4BE0-8D55-E6A74DE09768} - System32\Tasks\Lenovo\Dependency Package Auto Update => C:\Program Files\Lenovo\iMController\AutoUpdate.exe [2014-05-22] ()
                      Task: {41DCBCE3-523C-42DA-885D-FC7FF5DE288E} - System32\Tasks\AdobeAAMUpdater-1.0-Lenovo-PC-papeter => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.e xe [2015-07-29] (Adobe Systems Incorporated)
                      Task: {423E7DA8-EB68-4D8D-B787-5077D4FF57E8} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2017-09-20] (Piriform Ltd)
                      Task: {4D7836E4-60B1-4C23-B881-64EDEE40C12B} - System32\Tasks\Microsoft\Office\OfficeBackgroundTa skHandlerRegistration => C:\Program Files (x86)\Microsoft Office\root\Office16\officebackgroundtaskhandler.e xe [2017-09-15] ()
                      Task: {677EC76F-5F1E-4B88-9EB4-895656CEA55A} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-10-28] (Google Inc.)
                      Task: {81EF1F8A-693D-421D-A6C7-CABAEE21D915} - System32\Tasks\Lenovo\Lenovo Customer Feedback Program 64 35 => C:\Program Files (x86)\Lenovo\Customer Feedback Program 35\Lenovo.TVT.CustomerFeedback.Agent35.exe [2014-05-30] (Lenovo)
                      Task: {849DFEF6-B702-4152-BC80-E4F579623C1A} - System32\Tasks\Adobe Flash Player Updater => C:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpda teService.exe [2017-09-13] (Adobe Systems Incorporated)
                      Task: {994AF2EC-1CDC-4CB9-A379-995ED417AB25} - System32\Tasks\Microsoft\Office\Office Automatic Updates => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2017-09-08] (Microsoft Corporation)
                      Task: {9B7176A0-ED5C-47E9-9F4E-3E285610B8A6} - System32\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001 => C:\Users\papeter\AppData\Local\Citrix\GoToMeeting\ 5530\g2mupload.exe [2016-09-03] (Citrix Online, a division of Citrix Systems, Inc.)
                      Task: {9F63AB90-3171-400B-BA8A-410C5A09104F} - System32\Tasks\Microsoft\Office\Office Subscription Maintenance => C:\Program Files (x86)\Microsoft Office\root\vfs\ProgramFilesCommonx86\Microsoft Shared\Office16\OLicenseHeartbeat.exe [2017-09-15] (Microsoft Corporation)
                      Task: {BB30997D-E801-4BD3-874C-7D6099EFE8D0} - System32\Tasks\HMA! Pro VPN Update => C:\Program Files (x86)\HMA! Pro VPN\VpnUpdate.exe [2017-09-13] (AVAST Software)
                      Task: {C0FD436D-2E37-4DA0-B6A4-7D82B82D4544} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-10-28] (Google Inc.)
                      Task: {CCF1A276-5584-4020-ACF4-01A8E221C2E7} - System32\Tasks\Kaspersky_Upgrade_Launcher_{278ADC4 2-419D-4547-A6CA-5B74BE0AD901} => C:\Program Files\Common Files\AV\Kaspersky Lab\upgrade_launcher.exe [2016-07-11] (AO Kaspersky Lab)
                      Task: {CE8370B7-FF42-4C72-A77B-CD159741128F} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [2016-08-12] (Intel Corporation)
                      Task: {E43D00D7-2103-4F2D-B3A9-0AC342A4289E} - System32\Tasks\Microsoft\Office\Office ClickToRun Service Monitor => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2017-09-08] (Microsoft Corporation)
                      Task: {E4DB69B8-2AA6-440B-911A-A9BA95247085} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2017-07-19] (Adobe Systems Incorporated)
                      Task: {EC1A298C-94C0-458F-B031-43BB8556CF8D} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA1d257e73535f0dd => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe [2016-07-09] (Google Inc.)
                      Task: {EF34F3B6-CEFC-4193-A7AA-86535DABD808} - System32\Tasks\Microsoft\Windows\RemovalTools\MRT_ HB => C:\WINDOWS\system32\MRT.exe [2017-09-13] (Microsoft Corporation)
                      Task: {F7666DCF-AA1D-4BD5-905F-C8C2B58F265D} - System32\Tasks\Microsoft\Office\OfficeBackgroundTa skHandlerLogon => C:\Program Files (x86)\Microsoft Office\root\Office16\officebackgroundtaskhandler.e xe [2017-09-15] ()
                      Task: {FB7DCF66-3B0D-4256-B23F-6A0D8452518E} - System32\Tasks\PDVDServ Task => C:\Program Files (x86)\Lenovo\PowerDVD10\PDVD10Serv.EXE [2013-03-09] (CyberLink Corp.)
                      Task: {FCDA2712-8ABB-4D56-B1F5-EBFAD897E31B} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe [2016-07-09] (Google Inc.)
                      Task: C:\WINDOWS\Tasks\G2MUpdateTask-S-1-5-21-4237603079-860989819-990887440-1001.job => C:\Users\papeter\AppData\Local\GoToMeeting\7586\g2 mupdate.exe
                      Task: C:\WINDOWS\Tasks\G2MUploadTask-S-1-5-21-4237603079-860989819-990887440-1001.job => C:\Users\papeter\AppData\Local\GoToMeeting\7586\g2 mupload.exe
                      Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001Core.job => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe
                      Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-4237603079-860989819-990887440-1001UA.job => C:\Users\papeter\AppData\Local\Google\Update\Googl eUpdate.exe
                      ShortcutWithArgument: C:\Users\papeter\AppData\Roaming\Microsoft\Windows \Start Menu\Programs\Chrome Apps\Pocket.lnk → C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) → --profile-directory=Default --app-id=mjcnijlhddpbdemagnpefmlkjdagkogk
                      2016-11-17 02:28 - 2016-11-17 02:28 - 000092472 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
                      2017-05-09 00:44 - 2017-05-09 00:44 - 001354040 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
                      2017-07-06 11:22 - 2017-07-06 11:22 - 000331264 _____ () C:\Program Files (x86)\ExpressVPN\bootstrap\AMD64\nssm.exe
                      2017-07-26 08:58 - 2017-07-26 08:58 - 000192200 _____ () C:\Program Files (x86)\HiSuite\HandSetService\HuaweiHiSuiteService6 4.exe
                      2016-05-19 15:26 - 2015-11-09 13:40 - 000253528 _____ () C:\Program Files (x86)\Canon\IJPLM\IJPLMSVC.EXE
                      2015-02-05 23:58 - 2015-02-05 23:57 - 000133440 _____ () C:\Program Files\Lenovo PhoneCompanion\LPAWDService.exe
                      2015-02-05 23:52 - 2012-04-24 11:43 - 000390632 ____N () C:\Program Files\CyberLink\Shared files\RichVideo64.exe
                      2017-07-06 11:24 - 2017-07-06 11:24 - 009239168 _____ () C:\Program Files (x86)\ExpressVPN\xvpnd\xvpnd.exe
                      2017-09-21 12:54 - 2016-12-29 14:16 - 000134712 _____ () C:\Program Files\NVIDIA Corporation\Display\NvSmartMax64.dll
                      2017-03-18 21:58 - 2017-03-18 21:58 - 000138000 _____ () C:\WINDOWS\SYSTEM32\inputhost.dll
                      2016-03-15 23:47 - 2017-09-15 21:43 - 008929480 _____ () C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\1033\GrooveIntlResource.dll
                      2017-05-26 05:11 - 2017-05-26 05:11 - 000401840 _____ () C:\WINDOWS\system32\igfxTray.exe
                      2017-03-18 21:59 - 2017-03-19 03:31 - 001731072 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\Cortana.Core.dll
                      2015-02-05 23:06 - 2010-10-26 05:40 - 000049056 _____ () C:\Program Files\CONEXANT\ForteConfig\fmapp.exe
                      2015-02-05 23:48 - 2015-02-05 23:48 - 000097048 _____ () C:\Program Files\Lenovo\LenovoUtility\kbdhook.dll
                      2017-05-09 03:05 - 2017-05-09 03:05 - 000092472 _____ () C:\Program Files\iTunes\zlib1.dll
                      2017-05-09 03:05 - 2017-05-09 03:05 - 001354040 _____ () C:\Program Files\iTunes\libxml2.dll
                      2017-04-07 08:41 - 2017-04-07 08:41 - 000054488 _____ () C:\Program Files\CCleaner\branding.dll
                      2015-02-05 23:58 - 2015-02-05 23:57 - 000815104 _____ () C:\Program Files\Lenovo PhoneCompanion\adb.exe
                      2015-02-05 23:48 - 2014-07-10 02:19 - 000592880 _____ () C:\Program Files (x86)\Lenovo\CCSDK\CCSDK.exe
                      2015-02-05 23:48 - 2014-07-10 02:19 - 000397296 _____ () C:\Program Files (x86)\Lenovo\CCSDK\WinGather.exe
                      2017-09-14 09:15 - 2017-09-14 09:15 - 003553704 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\Microsoft.UI.Xaml.dll
                      2017-09-24 11:01 - 2017-09-24 11:07 - 010634752 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\WinStore.Entertainment.M obile.dll
                      2017-09-24 11:01 - 2017-09-24 11:07 - 002640896 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11708.100 1.26.0_x64__8wekyb3d8bbwe\MS.Entertainment.Common. Mobile.dll
                      2017-08-23 10:16 - 2017-09-22 16:40 - 024502272 _____ () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17072.131 11.0_x64__8wekyb3d8bbwe\Video.UI.exe
                      2017-08-23 10:16 - 2017-09-22 16:40 - 009145344 _____ () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17072.131 11.0_x64__8wekyb3d8bbwe\EntCommon.dll
                      2017-08-15 13:32 - 2017-08-15 13:32 - 003544488 _____ () C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.17072.131 11.0_x64__8wekyb3d8bbwe\Microsoft.UI.Xaml.dll
                      2017-09-15 19:15 - 2017-09-15 19:15 - 001226440 _____ () C:\Program Files\WindowsApps\microsoft.windowscommunicationsa pps_17.8500.40885.0_x64__8wekyb3d8bbwe\Office.UI.X aml.Word.dll
                      2016-06-28 00:19 - 2016-06-28 00:19 - 000865232 _____ () C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 17.0.0\kpcengine.2.3.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 000387984 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\fl_core.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 001165712 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_asr.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 000229264 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\sdxg.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 000199056 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_base.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 001132944 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_pron.dll
                      2015-02-05 23:54 - 2014-03-24 23:44 - 000035216 _____ () C:\Program Files (x86)\Nuance\Dragon Assistant\Core\vocon3200_platform.dll
                      2017-09-13 18:59 - 2017-09-13 18:59 - 000057968 _____ () C:\Program Files (x86)\HMA! Pro VPN\module_lifetime.dll
                      2017-09-13 18:59 - 2017-09-13 18:59 - 000240264 _____ () C:\Program Files (x86)\HMA! Pro VPN\tasks_core.dll
                      2017-09-13 18:59 - 2017-09-13 18:59 - 000147928 _____ () C:\Program Files (x86)\HMA! Pro VPN\network_notifications.dll
                      2017-09-13 18:59 - 2017-09-13 18:59 - 000084384 _____ () C:\Program Files (x86)\HMA! Pro VPN\WinUtils.dll
                      2017-09-13 18:59 - 2017-09-13 18:59 - 000210776 _____ () C:\Program Files (x86)\HMA! Pro VPN\event_routing_rpc.dll
                      2017-07-06 11:25 - 2017-07-06 11:25 - 000441472 _____ () C:\Program Files (x86)\ExpressVPN\xvpnd\windows\ExpressVPN.FilterMa nager.dll
                      2016-04-08 23:35 - 2016-04-08 23:35 - 003481600 _____ () C:\Users\papeter\AppData\Local\Programs\Google\Goo gle Photos Backup\gpuploader_i18n.dll
                      2014-12-22 10:03 - 2014-12-22 10:03 - 000122880 _____ () C:\Program Files (x86)\NETGEAR\WNDA3100v3\Ralink.dll
                      2014-09-03 20:03 - 2014-09-03 20:03 - 001241560 _____ () C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\ACE.dll
                      2016-03-15 23:45 - 2017-09-15 21:42 - 000164544 _____ () C:\Program Files (x86)\Microsoft Office\root\Office16\JitV.dll
                      2013-08-22 14:25 - 2017-09-26 22:51 - 000000753 _____ C:\WINDOWS\system32\Drivers\etc\hosts
                      127.0.0.1 localhost
                      HKU\S-1-5-21-4237603079-860989819-990887440-1001\Control Panel\Desktop\Wallpaper → c:\windows\web\wallpaper\theme1\img1.jpg
                      DNS Servers: 192.168.1.1
                      HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\System => (ConsentPromptBehaviorAdmin: 5) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
                      HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer => (SmartScreenEnabled: RequireAdmin)
                      Windows Firewall is enabled.
                      FirewallRules: [{DCA0D126-14AF-4A5D-87BC-81873A537E0B}] => (Allow) C:\Program Files (x86)\Microsoft Office\root\Office16\outlook.exe
                      FirewallRules: [{6AAD4B02-0AA9-4E42-96E8-41C5935BEC8A}] => (Allow) C:\Program Files\iTunes\iTunes.exe
                      FirewallRules: [{6DB766FF-BB4B-4C73-9D8C-A92EFDBD00E6}] => (Allow) C:\Program Files (x86)\Bonjour\mDNSResponder.exe
                      FirewallRules: [{C0BE10F4-12B3-47CD-9C73-1728CE89589F}] => (Allow) C:\Program Files (x86)\Bonjour\mDNSResponder.exe
                      FirewallRules: [{07906379-64D9-4D27-92C8-A7F73C3F5533}] => (Allow) C:\Program Files\Bonjour\mDNSResponder.exe
                      FirewallRules: [{91366BBD-0523-405B-815B-CB9017BF8CC1}] => (Allow) C:\Program Files\Bonjour\mDNSResponder.exe
                      FirewallRules: [{937E5BA2-C0DF-427D-8F8A-22791E81899B}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
                      FirewallRules: [{C538B0C6-4DE1-4521-BEDF-FF966F02435A}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
                      FirewallRules: [{946DD1A7-4F09-4EA9-976E-BB7BF9E7830E}] => (Allow) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
                      FirewallRules: [{DEB7BDCE-9DF5-40AD-80BE-9D2654935719}] => (Allow) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
                      FirewallRules: [{99C246BD-C5F0-4247-9336-8711F6D59034}] => (Allow) C:\Program Files\CyberLink\PowerDirector10\PDR10.EXE
                      FirewallRules: [{C4BAEBAB-409B-48CC-ADD0-56AEF4244F9E}] => (Allow) C:\Program Files (x86)\Lenovo\PowerDVD10\PowerDVD Cinema\PowerDVDCinema10.exe
                      FirewallRules: [{7105BF1E-47DA-4881-A0A0-0B133CFAF24C}] => (Allow) C:\Program Files (x86)\Lenovo\PowerDVD10\PowerDVD10.EXE
                      FirewallRules: [{AAF332D1-5A20-4893-AEF1-3638E32D54D1}] => (Allow) C:\Program Files\Lenovo PhoneCompanion\LPAWDService.exe
                      FirewallRules: [{21B971F8-D555-46F8-A58D-C5B6B6B4DAC2}] => (Allow) C:\Program Files\Lenovo PhoneCompanion\LPAWDService.exe
                      FirewallRules: [{C1E9968D-0BEB-4CE0-B192-78BCD30E96B6}] => (Allow) LPort=55100
                      FirewallRules: [{EFB666FF-BC02-4248-9E8D-84AC44260B83}] => (Allow) C:\Program Files\Lenovo PhotoMasterImport\PhotoMasterImport.exe
                      FirewallRules: [{BEF637D7-4EC6-404F-A968-91532518EC75}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
                      FirewallRules: [{4EEFDDB8-E20B-41B2-97DD-2790077AA4E2}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
                      FirewallRules: [{25DCEF18-32BC-40CA-A52F-28C1B4D6330C}] => (Allow) C:\Users\papeter\AppData\Local\Microsoft\OneDrive\ OneDrive.exe
                      FirewallRules: [{A67B328D-EAF4-4390-9D05-48FD050ED34D}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
                      21-09-2017 16:04:34 Windows Update
                      Name: ExpressVPN Tap Adapter
                      Description: ExpressVPN Tap Adapter
                      Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
                      Manufacturer: ExpressVPN
                      Service: tapexpressvpn
                      Problem: : This device is disabled. (Code 22)
                      Resolution: In Device Manager, click “Action”, and then click “Enable Device”. This starts the Enable Device wizard. Follow the instructions.
                      Name: NETGEAR WNDA3100v3 N600 Wireless Dual Band USB Adapter
                      Description: NETGEAR WNDA3100v3 N600 Wireless Dual Band USB Adapter
                      Manufacturer: NETGEAR Inc.
                      Service: WNDA3100v3
                      Problem: : This device cannot start. (Code10)
                      Resolution: Device failed to start. Click “Update Driver” to update the drivers for this device.
                      On the “General Properties” tab of the device, click “Troubleshoot” to start the troubleshooting wizard.
                      Error: (09/27/2017 12:03:18 PM) (Source: lupdate) (EventID: 0) (User: )
                      Description: Event-ID 0
                      Error: (09/27/2017 11:49:23 AM) (Source: lupdate) (EventID: 0) (User: )
                      Error: (09/27/2017 11:47:21 AM) (Source: Microsoft-Windows-Immersive-Shell) (EventID: 5973) (User: Lenovo-PC)
                      Description: Activation of app Microsoft.MicrosoftStickyNotes_8wekyb3d8bbwe!App failed with error: -2144927141 See the Microsoft-Windows-TWinUI/Operational log for additional information.
                      Error: (09/27/2017 11:46:25 AM) (Source: Application Error) (EventID: 1000) (User: )
                      Description: Faulting application name: mbamservice.exe, version: 3.2.21.0, time stamp: 0x56bd3616
                      Faulting module name: mbamservice.exe, version: 3.2.21.0, time stamp: 0x56bd3616
                      Exception code: 0x40000015
                      Fault offset: 0x000ad2a6
                      Faulting process id: 0xfd4
                      Faulting application start time: 0x01d3377dda9ea203
                      Faulting application path: C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe
                      Faulting module path: C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe
                      Report Id: 20d36732-a7ca-456a-85a0-eae5ba382705
                      Faulting package full name:
                      Error: (09/27/2017 11:46:20 AM) (Source: nssm) (EventID: 1018) (User: )
                      Description: Failed to read registry value AppDirectory:
                      The operation completed successfully.
                      Error: (09/27/2017 11:44:52 AM) (Source: VSS) (EventID: 8193) (User: )
                      Description: Volume Shadow Copy Service error: Unexpected error calling routine QueryFullProcessImageNameW. hr = 0x8007001f, A device attached to the system is not functioning.
                      Operation:
                      Executing Asynchronous Operation
                      Context:
                      Current State: DoSnapshotSet
                      Error: (09/27/2017 11:43:00 AM) (Source: VSS) (EventID: 8193) (User: )
                      Operation:
                      Context:
                      Error: (09/27/2017 11:42:57 AM) (Source: Application Error) (EventID: 1000) (User: )
                      Description: Faulting application name: FRST64(1).exe, version: 26.9.2017.0, time stamp: 0x59cacd3f
                      Faulting module name: FRST64(1).exe, version: 26.9.2017.0, time stamp: 0x59cacd3f
                      Exception code: 0xc0000005
                      Fault offset: 0x0000000000026519
                      Faulting process id: 0x1738
                      Faulting application start time: 0x01d3377d2847490e
                      Faulting application path: C:\Users\papeter\Desktop\FRST64(1).exe
                      Faulting module path: C:\Users\papeter\Desktop\FRST64(1).exe
                      Report Id: 10311463-ed63-4c36-9204-70685ab14ad6
                      Error: (09/27/2017 11:41:38 AM) (Source: VSS) (EventID: 8194) (User: )
                      Description: Volume Shadow Copy Service error: Unexpected error querying for the IVssWriterCallback interface. hr = 0x80070005, Access is denied.
                      This is often caused by incorrect security settings in either the writer or requestor process.
                      Operation:
                      Gathering Writer Data
                      Context:
                      Writer Class Id: {e8132975-6f93-4464-a53e-1050253ae220}
                      Writer Name: System Writer
                      Writer Instance ID: {5d6a78f7-f41a-4ed6-90b1-4e9c43c6593d}
                      Error: (09/27/2017 11:50:00 AM) (Source: DCOM) (EventID: 10010) (User: NT AUTHORITY)
                      Description: The server {784E29F4-5EBE-4279-9948-1E8FE941646D} did not register with DCOM within the required timeout.
                      Error: (09/27/2017 11:47:21 AM) (Source: DCOM) (EventID: 10010) (User: Lenovo-PC)
                      Description: The server Microsoft.MicrosoftStickyNotes_1.8.0.0_x64__8wekyb 3d8bbwe!App did not register with DCOM within the required timeout.
                      Error: (09/27/2017 11:46:58 AM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
                      {6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}
                      and APPID
                      {4839DDB7-58C2-48F5-8283-E1D1807D0D7D}
                      to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
                      and APPID
                      Error: (09/27/2017 11:46:29 AM) (Source: Service Control Manager) (EventID: 7034) (User: )
                      Description: The MBAMService service terminated unexpectedly. It has done this 1 time(s).
                      Error: (09/27/2017 11:46:19 AM) (Source: Service Control Manager) (EventID: 7000) (User: )
                      Description: The CldFlt service failed to start due to the following error:
                      The request is not supported.
                      Error: (09/27/2017 11:45:32 AM) (Source: Microsoft-Windows-WLAN-AutoConfig) (EventID: 10003) (User: NT AUTHORITY)
                      Description: WLAN Extensibility Module has stopped unexpectedly.
                      Module Path: C:\WINDOWS\System32\bcmihvsrv64.dll
                      Error: (09/27/2017 11:45:27 AM) (Source: Microsoft-Windows-WLAN-AutoConfig) (EventID: 10003) (User: NT AUTHORITY)
                      Error: (09/27/2017 11:45:17 AM) (Source: Service Control Manager) (EventID: 7032) (User: )
                      Description: The Service Control Manager tried to take a corrective action (Restart the service) after the unexpected termination of the Windows Search service, but this action failed with the following error:
                      An instance of the service is already running.
                      Date: 2017-09-24 23:29:45.253
                      Description: Code Integrity determined that a process (\Device\HarddiskVolume5\Windows\SystemApps\Micros oft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.ex e) attempted to load \Device\HarddiskVolume5\Program Files (x86)\Malwarebytes Anti-Exploit\mbae64.dll that did not meet the Store signing level requirements.
                      Date: 2017-09-24 23:29:44.932
                      Date: 2017-09-24 23:24:52.589
                      Date: 2017-09-24 22:57:51.735
                      Date: 2017-09-24 22:57:51.435
                      Date: 2017-09-24 22:57:50.849
                      Date: 2017-09-24 22:57:50.482
                      Date: 2017-09-24 22:49:06.129
                      Date: 2017-09-24 22:48:39.626
                      Date: 2017-09-23 16:15:51.184
                      Processor: Intel(R) Core™ i7-5500U CPU @ 2.40GHz
                      Percentage of memory in use: 21%
                      Total physical RAM: 16299.08 MB
                      Available physical RAM: 12871.09 MB
                      Total Virtual: 19243.08 MB
                      Available Virtual: 15730.31 MB
                      Drive c: (Windows8_OS) (Fixed) (Total:888.7 GB) (Free:407.27 GB) NTFS ==>[system with boot components (obtained from drive)]
                      Drive d: (LENOVO) (Fixed) (Total:25 GB) (Free:22.68 GB) NTFS
                      Disk: 0 (Size: 931.5 GB) (Disk ID: 12E6AA89)
                      Partition: GPT.
                      LastRegBack: 2017-09-21 12:49
                      • papeter
                        • Feb 2017
                        • 33
                        #12
                        Here is the JRT Logs:
                        [HEADING=1]AdwCleaner 7.0.2.1 - Logfile created on Wed Sep 27 11:12:37 2017[/HEADING]
                        [HEADING=1]Updated on 2017/29/08 by Malwarebytes[/HEADING]
                        [HEADING=1]Database: 09-23-2017.2[/HEADING]
                        [HEADING=1]Running on Windows 10 Home (X64)[/HEADING]
                        [HEADING=1]Mode: scan[/HEADING]
                        [HEADING=1]Support: https://www.malwarebytes.com/support[/HEADING]
                        ***** [ Services ] *****
                        No malicious services found.
                        ***** [ Folders ] *****
                        No malicious folders found.
                        ***** [ Files ] *****
                        No malicious files found.
                        ***** [ DLL ] *****
                        No malicious DLLs found.
                        ***** [ WMI ] *****
                        No malicious WMI found.
                        ***** [ Shortcuts ] *****
                        No malicious shortcuts found.
                        ***** [ Tasks ] *****
                        No malicious tasks found.
                        ***** [ Registry ] *****
                        No malicious registry entries found.
                        ***** [ Firefox (and derivatives) ] *****
                        No malicious Firefox entries.
                        ***** [ Chromium (and derivatives) ] *****
                        No malicious Chromium entries.
                        C:/AdwCleaner/AdwCleaner[C0].txt - [2802 B] - [2017/9/26 22:55:47]
                        C:/AdwCleaner/AdwCleaner[C1].txt - [2207 B] - [2017/9/26 23:27:6]
                        C:/AdwCleaner/AdwCleaner[S0].txt - [2879 B] - [2017/9/26 22:48:7]
                        C:/AdwCleaner/AdwCleaner[S1].txt - [2167 B] - [2017/9/26 23:25:9]
                        ########## EOF - C:\AdwCleaner\AdwCleaner[S2].txt ##########
                        • jmarket
                          PCHF Owner
                          • 7695
                          • CachyOS
                          • Intel Arc A770 (16 GB)
                          #13
                          Hey peter,
                          You reposted the ADWCleaner log Need the JRT log
                          [ul]Shut down your anti-virus, anti-spyware, and firewall software now to avoid potential conflicts.[/ul]
                          [ul]Run the tool by double-clicking it. If you are using Windows Vista or Windows 7, right-click it and select Run as administrator.[/ul]
                          [ul]The tool will open and start scanning your system.[/ul]
                          [ul]Please be patient as this can take a while to complete depending on your system’s specifications.[/ul]
                          [ul]On completion, a log is saved to your desktop and will automatically open.[/ul]
                          [ul]Please post the JRT log.[/ul]
                          • papeter
                            • Feb 2017
                            • 33
                            #14
                            Sorry about the mix up. This is the correct JRT log:-
                            Code:
                            Version: 8.1.4 (07.09.2017)
                            Operating System: Windows 10 Home x64
                            Ran by papeter (Administrator) on 27/09/2017 at 21:29:38.11
                            File System: 0
                            Registry: 0
                            Code:
                            Scan was completed on 27/09/2017 at 21:32:54.65
                            End of JRT log
                            • jmarket
                              PCHF Owner
                              • 7695
                              • CachyOS
                              #15
                              Awesome
                              While I make you another fix, do the following for me
                              We will need a log from Zemana, can you please download the free trial HERE. Save it to somewhere you can find, double click the downloaded file and start the installation. Accept the default install options and you can safely ignore any security warnings and allow Zemana to complete the install. Once completed click the new desktop icon https://pchelpforum.net/attachments/zamicon-jpg.786 to open the program. If Zemana opens and informs of any available updates allow it to so. Next change Zemana’s default from “Smart Scan” to Deep Scan as shown below.
                              Then click scan
                              When the scan is complete allow Zemana to Quarantine any infections found by clicking Next
                              Once the infections are quarantined a message box will indicate success, then click the logs icon as below.
                              Select the latest scan and choose Open Report from the upper menu. or simply double left click on the scan just run.
                              The log will open as a text file. Please Copy and Paste the contents of that file in your next post
                              You do have malware on the machine, and I want to ensure it’s rid of before we fix Malwarebytes
