Lenovo Yoga 14 Problems?
  • Nick
    • 302
    Hey everyone,
    My friend has a Lenovo Yoga 14 that exhibits some weird behavior. It likes to shut down applications by itself with no warning (it doesn’t even say “___ has stopepd working” or anything) and more things that I for some reason can’t think of right now, unfortunately. I did a Lenovo hardware test on it and it had a fail on the graphics card and the PCI on the motherboard. I’ve attached that to the thread. With the problems I’m seeing, I think a re-installation of Windows would be useful, because most of the problems seem software related. What do you all think?
    [URL unfurl="true"]https://novabench.com/image/922731.png[/URL]
    Hello Nick
    @phillpower2 @Rustys
    • Rustys
      • 7862
      Have our security team check it to make sure there is nothing there.
      • system
        PCHF Owner
        • 7695
        • CachyOS
        • Intel Arc A770 (16 GB)
        Hello Nick, your issue may or may not be malware but since you have been directed here lets check out the machine.
        We need a log from Farbar Recovery Scan Tool (FRST) to examine your system.
        Once downloaded right click the FRST desktop icon and select “Run as administrator” from the menu"
        Frst will open with two dialogue boxes, accept the disclaimer.
        [ol]
        [li]Accept the default whitelist options,[/li][li]If the additions.txt options box is not checked please select it. [/li]
        [li]Then select “Scan”[/li][/ol]
        Please COPY and PASTE the contents of these two files in your next post.
        • system
          PCHF Owner
          • 7695
          • CachyOS
          Thread closed, if you are the original poster and still require assistance please notify a staff member who will open it again.
          • Nick
            • 302
            I finally did what you recommended to me. Attached are those two files. I also ran a Malwarebytes scan and found nothing.
            • Nick
              • 302
              Should I just reinstall Windows? That usually fixes whatever the problem is…
              • system
                PCHF Owner
                • 7695
                • CachyOS
                Hello Nick, Reinstalling Windows will always fix problems with the operating system, or malware but a rather drastic step. We are happy to research your logs, but as it is time consuming could you please advise if you require us to do so or if you are going to reinstall Windows. This will save a deal of effort for maybe nought.
                If you are not going to reinstall Windows could I also ask that you not run any scan tools except those requested to by us, or install/update any other software whilst your pc is being cleaned?
                Two things requiring urgent attention with the PC. The hard Disk is almost full, and system restore is disabled. Please consider removing some unused software and data.
                • system
                  PCHF Owner
                  • 7695
                  • CachyOS
                  Hello Nick, do you still require assistance, If there is no response within 48 hours this thread will be closed.
                  • Nick
                    • 302
                    #10
                    Please explain to me what you’d recommend I’d do rather than installing Windows so I can determine whether I want to go through with your steps or just reinstall Windows.
                    May I ask why?
                    She is using her little 128gb SSD to store tons of GoPro footage, and as soon as se gets an external hard drive, that will be completely remedied.
                    • system
                      PCHF Owner
                      • 7695
                      • CachyOS
                      #11
                      Removing malware can be a time consuming multi step procedure. It’s your choice atm to decide to reinstall windows or not. We are happy to help clean your system, but ask that time spent is not for nought.
                      Installing/updating software can make it harder if not impossible to clean a computer.
                      I repeat, the hard drive is almost full and system restore is disabled. Recommend priority attention to both issues.
                      • Nick
                        • 302
                        #12
                        Thanks, Gus. I think I’m just gonna go ahead and reinstall Windows, I’ve done it multiple times and it isn’t too much of a hassle for me. But thanks for the help anyway!
                        • system
                          PCHF Owner
                          • 7695
                          • CachyOS
                          #13
                          Thank you for letting us know Nick, should you need help cleaning your PC later then please ask. Marked closed for now.
