Ok, I will check these out, I am going to be in and out a lot today, so you may not have a response till much later.
Hundreds of rundll32.exe running
This topic is closed.
[ol]
[li]Open a command prompt with administrative privileges on the device.[/li][li]Enter the following commands one at a time hitting enter after each.[/li][COLOR=rgb(184, 49, 47)]sc stop dam
[COLOR=rgb(85, 57, 130)]sc config dam start= disabled
[/ol]
[ICODE]Dump: 010524-16468-01.dmp (05.01.2024 07:07:14) Code: 0x14F - PDC_WATCHDOG_TIMEOUT Process: ctfmon.exe, probably caused by: dam.sys Third-party modules in the Raw Stack: KMPDC.sys FAILURE_BUCKET_ID: 0x14F_DAM_IMAGE_dam.sys[/ICODE][/COLOR][/COLOR]Comment
[/ol]
[/COLOR][/COLOR]
Hi, did it, but the content in the “code” is just info and nothing to do about it right?[/color][/color]Comment
Hi, there seems to be serious issues with BSOD. First time turning on the laptop today. It gave BSOD in welcome screen. Then restarted immediately, couldn’t even see what error, and gave BSOD again. then restarted immediately.
It went to BIOS screen, I just clicked save changes and exit and it went to troubleshoot option in the windows logo screen, where I clicked continue to win 11, and it just opened now.
I checked minidump immediately but the file there still shows one from January and not the recent BSOD logs.
the minidump creation is enabled, maybe because the pc immediately restarts after the BSOD, in 0% of error collection?
[ATTACH type=“full”]13872[/ATTACH]Comment
Ok. I had to go out of town for work. I’ll be back around Sunday morning. Sorry for any inconvenience.Comment
Originally posted by MalnutritionOk. I had to go out of town for work. I’ll be back around Sunday morning. Sorry for any inconvenience.Comment
I didn’t BSOD yesterday, but got today right at the start. It seems to usually happen when starting laptop for the first time. and doesn’t happen throughout the day.
the error collection doesn’t go beyond 0% even though I let it run for a while.
[ATTACH type=“full” alt=“1720335658656.png”]13874[/ATTACH]Comment
not sure if it is related, but explorer stops responding randomly (not often but maybe once or twice a day sometimes). When I end it in task manager or restart it, it takes some time, and even task manager stops responding for a while. CPU usage also spikes a little at that time.Comment
sorry for the delay, work took longer than expected.
Download AV block remover .
Unzip to your C:\Windows\System32 folder.
To do that hit the windows key and R at the same time, copy and paste C:\Windows\System32 into the run box hit ok.
Drag and drop–Unzip the program inside this folder.
Right click run as admin and follow the instructions. If it does not start, rename the AVbr.exe file to, for example, AV_br.exe
Click yes to reset hosts file.
After the machine reboots then there will be a logfile in the new folder created, post that please.Comment
After the above, then a repair is in order.
Originally posted by Malnutritionsorry for the delay, work took longer than expected.
but got this error.
[ATTACH type=“full”]13885[/ATTACH]Comment
Can you extract/unzip the program in your photos folder please. This program was designed to be not be ran from desktop or my documents folder.Comment
Originally posted by MalnutritionCan you extract/unzip the program in your photos folder please. This program was designed to be not be ran from desktop or my documents folder.
I did that just now and gives the same error. Even downloaded it anew to users\username\pictures folder and extracted it there since I couldn’t extract in sys32 folder and pasted it to sys32 folder and ran it. but the same error.
shows this when I try to extract it in sys32.
[ATTACH type=“full”]13908[/ATTACH]Comment
