Cant connect to the internet
This topic is closed.
  • Malnutrition
    PCHF Moderator
    • 7041
    #16
    It appears to be on the way out.
    ALSO it see,s that many people have this same issue with the[COLOR=rgb(184, 49, 47)] Realtek RTL8723AE Wireless LAN 802.11n
    Seems that it is outdated and not able to connect to modern routers.. Can you connect via ethernet and use this tool to see if there is an update? I usually do not suggest these types of tools, but worth a shot in your case.
    Award-winning driver updating software, DriverMax is the optimal solution for your computer. Works swiftly on Windows 11, Windows 10, Windows 8.1, Windows 8, Windows Vista, Windows XP. Keep you PC up to date with DriverMax!
    I suggest only trying to find an update for the wireless driver only.!!
    Also, create a restore point prior to the update/[/COLOR]
    • Malnutrition
      PCHF Moderator
      • 7041
      #17
      @PeterOz @Bruce @xrobwx71 @Bastet @georgeks
      • saleh_Haciyev
        • Jun 2024
        • 19
        #18
        The restore points doesnt work for some reason it gives a dll error i dont have. A ethernet cable tho but i try doing something
        Δ° got the drivermax-dump.dat but i dont have a second PC so i cannot use it
        Δ° managed to connect to the internet with the USB cable but the issue still remains i will try to update the drivers
        • saleh_Haciyev
          • Jun 2024
          • 19
          #19
          Δ° updated the wireless network driver the issue still seems to remain when i run a command on cmd it says theres no user profiles could it be caused because of that i dont know
          • Malnutrition
            PCHF Moderator
            • 7041
            #20
            Your HDD is definitely on its way out…
            You can get online via Ethernet, so this is definitely an issue with the wireless card itself.
            Create a new user, test that.
            https://www.lifewire.com/create-user...dows-7-3506832
            Get yourself a wireless usb dongle, test that.
            • xrobwx71
              • Mar 2023
              • 1066
              #21
              I would back up that drive and replace it before doing much else.
              • saleh_Haciyev
                • Jun 2024
                • 19
                #22
                @Malnutrition
                I don’t know what you mean by test.
                Thanks for the help but i dont think this is gonna work sorry for wasting all of ur time if u have a solution in the future open this forum and write it i will try to check it every day
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  #23
                  I mean create a new account and see if the issue remains, but most likely the real issue is the hard drive, since it is failing that can cause multiple issues and until that is resolved our efforts are basically futile. Once you have a new hard drive then you can really work the issue out from there if it still exists.
                  • saleh_Haciyev
                    • Jun 2024
                    • 19
                    #24
                    Δ° dd create a New account but i Linda still dont know how to use it btw could u explain whats ur reason for thinking its the HDD
                    • Malnutrition
                      PCHF Moderator
                      • 7041
                      #25
                      You just log into it like any other account then see if it will connect.
                      Or enable the built in admin account.
                      Since you are able to go online with ethernet, that indicates the network is fine. The hard drive is simply failing it is starting to go…
                      [ATTACH type=β€œfull” alt=β€œ1719029458349.png”]13836[/ATTACH]
                      [ATTACH type=β€œfull” alt=β€œ1719029501459.png”]13837[/ATTACH]
                      • saleh_Haciyev
                        • Jun 2024
                        • 19
                        #26
                        Δ° thought it was normal its just 3 of them idk anymore what to do its probably HDD but when im using the computer i dont see anything wrong with it
                        • Malnutrition
                          PCHF Moderator
                          • 7041
                          #27
                          Your event viewer logs and two well trusted programs say it is failing. It could last for years longer. Or it could fail tomorrow. Point is that it is starting to fail.
                          Can you get ahold of wireless usb stick? They are pretty cheap.
                          • saleh_Haciyev
                            • Jun 2024
                            • 19
                            #28
                            Δ°m 16 years old i dont have a job i dont think i Can convice my parents to buy it the laptop is already old enough its from 2014 and the website u sent me isnt available on my country
                            • xrobwx71
                              • Mar 2023
                              • 1066
                              #29
                              Just copy the products from that link and search for them on websites available to you in your country.
                              • Malnutrition
                                PCHF Moderator
                                • 7041
                                #30
                                There are also programs where you can use your phone. To tether the internet connection via usb cord from computer to phone.
                                Use your Android phone as Wireless Modem, USB Tether, Bluetooth DUN, Wireless Router
                                The best PdaNet alternatives are EasyTether, TetherMe and Maryfi. Our crowd-sourced lists contains seven apps similar to PdaNet for Windows, Android, iPhone, Mac and more.
                                6 Alternatives to PdaNet you must know. With reviews, features, pros & cons of PdaNet. Find your best replacement here. Searching for suitable software was never easier.
