Default gateway Internet issues
  • it_cant_be
    • Jun 2024
    • 4
    When I connect my PC to the wifi it says no Internet,secured every other device connect and runs fine on my network
    Please help!!!
  • Malnutrition
    PCHF Moderator
    • 7041
    Uninstall any third party antivirus/firewall, reboot the machine.
    Reset Network settings to default.
    Overview of settings and features available in a Kaspersky application and guides on how to use them.
    • it_cant_be
      • Jun 2024
      • 4
      I’m still having the same issues
      • Malnutrition
        PCHF Moderator
        • 7041
        What is the make and model of your machine?
        Are you able to connect via Ethernet? So that you can get me some logs so I can see what’s going on. If you can download it via Ethernet and then unplug the cord and run the tool, that will allow me to possibly see the issue.
        Please download MiniToolBox and save it to your desktop.
        Run the program by right clicking on it and selecting Run as administrator.
        When the program opens check mark Select All Then hit GO
        Please post the log in your next reply. Attach or copy and paste, whatever is easier for you.
        • it_cant_be
          • Jun 2024
          • 4
          Dell optiplex 3020
          I don’t have an Ethernet chord at all so idk how I would accomplish that
          • Malnutrition
            PCHF Moderator
            • 7041
            Are there any yellow question marks in the device manager?
            Can you open the device manager[COLOR=rgb(184, 49, 47)] click on Network Adapters and take a picture with your phone and post it here.
            https://www.dell.com/support/home/en...esktop/drivers[/COLOR]
            • it_cant_be
              • Jun 2024
              • 4
              It won’t let me attach it
              • Malnutrition
                PCHF Moderator
                • 7041
                Can you upload to Imgur or a similar site and link here so we can see.
                I am headed to sleep, work comes early for me.
                @Bruce @PeterOz @Bastet @xrobwx71
                  There would have been an ethernet cable in the modem/router you connect to, any chance you still have that one, or the box it came in?
                  What is the make/model of your modem/router, and of the wireless USB adapter you have plugged in?
                  • PeterOz
                    PCHF Technical Response Team
                    • Mar 2021
                    • 4181
                    #10
                    Just yes or no is the yellow mark showing.
                    Did this use to work or is something new?
                    • Bastet
                      • Aug 2016
                      • 1514
                      #11
                      Do you have any third party antivirus &/or are running a virtual private network?
                      Have you reset the network settings?
                      Have you run the troubleshooter?
                      Settings > System > Troubleshoot > Other troubleshooters and select Run
                        #12
                        @it cant be - you logged in recently but didn’t update - how are things looking?
                          #13
                          Closing - no activity.
