Win 11 Pro- New device via ethernet and adapter settings
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4191
    #16
    If you need pics let me know
    • PeterOz
      • Mar 2021
      • 4191
      #17
      PS You do not have to have DNS 1.1.1.1 and 1.0.0.1
      It can be what you currently have
      • hgmspaceboy
        • Mar 2024
        • 12
        #18
        Hi PeterOz Sorry No Joy. Heres what I did There was no option to add the Gateway on Advanced.
        and Yes the cnc is on
        • hgmspaceboy
          • Mar 2024
          • 12
          #19
          A little step forward? This config gets me to open the cnc on my browser, BUT it looses me the internet.
          • PeterOz
            • Mar 2021
            • 4191
            #20
            No
            The general page put in your current ip address and subnet gateway.
            192.168.0.14
            255.255.255.0
            192.168.0.1
            On the advance page leave as is
            Or add
            Gateway
            192.168.251.0
            • PeterOz
              • Mar 2021
              • 4191
              #21
              Your screens should look like this.
              General
              [ATTACH type=β€œfull” alt=β€œDifferent ip on network 1.png”]13541[/ATTACH]
              Then on the advanced
              [ATTACH type=β€œfull” alt=β€œDifferent ip on network 2.png”]13542[/ATTACH]
              This is using google as the dns. You can use any dns you want.
              On the advanced screen you can also add Default gateway 192.168.251.0 if needed.
              • hgmspaceboy
                • Mar 2024
                • 12
                #22
                I get this warning as I attempt to save the Advanced setting and it reverts the General to 192.168.251.0
                Bit tricky hey. Im contacting the cnc provider. Please do update me with help as we go and I will also feed back what they say.
                Your help IS MUCH APPRECIATED
                • hgmspaceboy
                  • Mar 2024
                  • 12
                  #23
                  Just got last message will try again.
                  • hgmspaceboy
                    • Mar 2024
                    • 12
                    #24
                    Wooah I can access both.
                    • hgmspaceboy
                      • Mar 2024
                      • 12
                      #25
                      Well thats great. Why the 192.168.0.14 and the weird DNS servers? Do I need to change other settings anywhere due to this?
                      • PeterOz
                        • Mar 2021
                        • 4191
                        #26
                        Post #22 that warning is because you have the wrong gateway.
                        You have 192.168.251.0 on the general tab should be 192.168.0.1. as per my pic in post # 21.
                        Your post # 7 Shows that your computer was already using 192.168.0.14 so if we keep it the same there will not be a conflict on the network.
                        As I pointed out in Post #21 you do not need that DNS you can use the one from your modem/router
                        Or from your ISP. There are a lot of DNS providers around. That one is google.
                        No
                        Great
                        • PeterOz
                          • Mar 2021
                          • 4191
                          #27
                          I think this post can be closed @veeg
