Win 11 Pro- New device via ethernet and adapter settings
  • hgmspaceboy
    • Mar 2024
    • 12
    Hi. I’m assuming this is some kind of networking Q.
    I have a new device (a hobby cnc machine) with an ethernet cable. My desktop (win11Pro) port is connected to my ISP router. The device is plugged into a spare port on the router.
    The device has a specific IP address. The only way I have been able to connect with the device is by switching the Internet Protocol to the device IP (see pic).
    This means I LOSE the internet. Its a massive pain to keep switching and my device needs internet access sometimes.
    Can some one help me have my PC connected to the internet and my device simultaneously. That would help my day
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    Is the device and the pc on the same ip range?
    E>G 192.168.0.*** or 10.0.0.***
    From the desktop can you ping the device.
    • hgmspaceboy
      • Mar 2024
      • 12
      One is 192. 168. 0.***
      the other 192.168.251.***
      • PeterOz
        • Mar 2021
        • 4181
        Click on the alternative tab(in your pic) and put in 192.168.251.5 (unless the device is using 5) these are internal address’s so it would have been easier if you had posted the whole address.
        Leave the standard as what is needed for the internet
        Test
        • hgmspaceboy
          • Mar 2024
          • 12
          Hi Thanks but no joy- here is the response
          Here are the addresses I need to input on the general page
          Thanks
          • xrobwx71
            • Mar 2023
            • 1066
            Open an elevated command prompt by hitting the Windows key and choosing either command or terminal as admin.
            Once the prompt is open, type ipconfig /all then Enter.
            Copy and paste the output here please.
            • hgmspaceboy
              • Mar 2024
              • 12
              thx
              Connection-specific DNS Suffix . : Hitronhub.home
              Physical Address. . . . . . . . . : 04-92-26-D5-BF-47
              Link-local IPv6 Address . . . . . : fe80::82f4:cd9b:298c:5bc1%14(Preferred)
              IPv4 Address. . . . . . . . . . . : 192.168.0.14(Preferred)
              Lease Obtained. . . . . . . . . . : 12 March 2024 09:30:20
              Lease Expires . . . . . . . . . . : 19 March 2024 09:30:50
              DHCPv6 IAID . . . . . . . . . . . : 268735014
              DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-93-0D-B7-04-92-26-D5-BF-47
              DNS Servers . . . . . . . . . . . : 192.168.0.1
              Ethernet adapter Ethernet 2:
              Description . . . . . . . . . . . : TAP-NordVPN Windows Adapter V9
              Physical Address. . . . . . . . . : 00-FF-63-63-98-86
              • hgmspaceboy
                • Mar 2024
                • 12
                So I had a troubleshooter window- But this seemed to do nothing when retrying. I have tried alternative IP addresses in the Alternative Configuration, but to no avail- heres the latest.
                I do access the IP when i force it on the general IP page, so I’m assuming it works.
                What next? Thx
                • xrobwx71
                  • Mar 2023
                  • 1066
                  What happens when you tic the circle that says obtain DNS automatically? Or if you must have it on manual try 1.1.1.1 and 1.0.0.1 in the DNS server section.
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #10
                    I would try
                    192.168.251.1
                    255.255.255.0
                    192.168.0.1
                    If no luck
                    And we assume you cannot Change the ip of the cnc - have you tried? - If not sure supply make and model.
                    The other option is to change the modem/router to output the same ip range 192.168.251.***
                    • PeterOz
                      • Mar 2021
                      • 4181
                      #11
                      Also, Try
                      Ip 192.168.251
                      Subnet 255.255.255.0
                      No gateway
                      No dns
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #12
                        Sorry 1 more question
                        Does the desktop have 2 network ports or does it support wireless.
                        • PeterOz
                          • Mar 2021
                          • 4181
                          #13
                          I cannot test this at this time. But should work in theory
                          Go back to your network adapter
                          and take out the alternate address.
                          On the general tab input your ip address for the internet.
                          Fill all in including DNS
                          Then click on advanced and add the ip address 192.168.251.1 subnet 255.255.255.0
                          Save and exit.
                          Try ping.
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #14
                            Ok I can now confirm.
                            I Have setup
                            Computer A address I have 192.168.251.5
                            Normal Ip Address on Computer B
                            IPv4 = 192.168.0.1
                            Subnet = 255.255.255.0
                            Gateway = 192.168.0.1
                            Dns = 1.1.1.1
                            Alt Dns = 1.0.0.1
                            192.168.251.1
                            gateway 255.255.255.0
                            From 192.168.0.1
                            I can ping 192.168.251.5
                            • hgmspaceboy
                              • Mar 2024
                              • 12
                              #15
                              Thanks for response. I will be by the desktop in an hour. Will do as suggested and get back to you.
