My work from home setup doesnt allow wifi, its disabled in the system (and you cant just go into settings and reenable it) so its ethernet only, are there anyways around that that you guys know of to make a wired only pc still use wifi? Like would a usb wifi adapter work or maybe something like this
Or can i hook it wired to a nearby pc that DOES use wifi as a bridge of some sort so that it uses the wifi from that other PC?
Otherwise id need to find a 100 ft cable to run around my house and that aint happening.
