The speed is usually 3mb/s because i have full packet with tv and other things, my friends have the same network provider too and they dont have ant problems. Gpu is up to date, windows 22h2, i have restarted the router and i have tried different internet provider(woth different ethernet cable and modem) too. Im connected via etherned also i hace tried via wifi usb stick
Stuttering/FPS dip in all games, while connected to LAN,WIFI
Open the command prompt and type or paste the following command including the quotes.
ipconfig /all > β%UserProfile%\Desktop\IP Address.txtβ
There will be a file called IP Address.txt on your desktop copy and paste the contents into the next post.
Looks like you network is misconfigured.Comment
As i said i tried of different internet provider that has speeds like 60 download and 80 upload on speedtest.netOriginally posted by BastetWhat speed are you paying for as 3mbps seems extremely slow.
Your friends may have the same ISP but unless they also have the same broadband package & PC components then we canβt say the ISP isnβt at fault.Comment
I would do a network reset on the system and see how things go.
Go into Setting
Select Network and Internet
Make sure you are under Status in the left
On the Right scroll down and select Network Reset
Read the information and then select Reset Now
Select Yes for the network to be reset and the system to reboot.
The rest before the system reboots may take a few minutes.
Might also try rebooting the modem and router. This will clear the buffer and sometimes help.
Then test speeds and see if that helps with the stuttering.Comment
Repost the IP Config all again.
Could be that the NIC is going out.
Letβs see if there are any error message that can be pulled by the MinitoolBox.
Download MiniToolBox and save the file to the Desktop. Right click on the file and select Run as Admin
Close the browser and run the tool, check the following options.
Select all
Click on Go.
copy and paste the contents of the file called MTB.txt or attach the file to your next post.
Few other thing that you can try and see if it make a difference.
Create a new user account on the system and see if that user preforms better.
Turn off XMP for the RAM.
The PSU age may be showing wear.
Originally posted by PeharisPSU: 750W 14CM FAN, EVGA GQ, 80+ GOLD, SEMI MODULAR, 210-GQ-0750-V2 PSU Age: 3.5 yearsComment
Files\WindowsApps\SpotifyAB.SpotifyMusic_1.210.760 .0_x86__zpdnekdrzrea0 [2023-05-05] (Spotify AB) [Startup Task]
WindowsAppRuntime.1.2 β C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.2_ 2000.802.31.0_x64__8wekyb3d8bbwe [2023-05-05] (Microsoft Corporation)
WindowsAppRuntime.1.2 β C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.2_ 2000.802.31.0_x86__8wekyb3d8bbwe [2023-05-05] (Microsoft Corporation)
Name: High precision event timer
Description: High precision event timer
Class Guid: {4d36e97d-e325-11ce-bfc1-08002be10318}
Manufacturer: (Standard system devices)
Service:
Device ID: ACPI\PNP0103\2&DABA3FF&0
Problem: : This device is disabled. (Code 22)
Resolution: In Device Manager, click βActionβ, and then click βEnable Deviceβ. This starts the Enable Device wizard. Follow the instructions.
Percentage of memory in use: 58%
Total physical RAM: 16315.24 MB
Available physical RAM: 6779.43 MB
Total Virtual: 65467.24 MB
Available Virtual: 49769.36 MB
1 Drive c: () (Fixed) (Total:223.57 GB) (Free:91.43 GB) NTFS
2 Drive d: () (Fixed) (Total:931.51 GB) (Free:816.44 GB) NTFS
3 Drive e: () (Fixed) (Total:111.74 GB) (Free:95.64 GB) NTFS
User accounts for \DESKTOP-7L7VKFK
Petar WDAGUtilityAccount
========================= Minidump Files ==================================
No minidump file found
========================= Restore Points ==================================
26-04-2023 19:11:50 4/26/2023
27-04-2023 20:59:32 Windows Assessment and Deployment Kit - Windows 10
29-04-2023 09:46:51 Installed Realtek Ethernet Controller Driver
30-04-2023 14:36:01 Installed DirectX
01-05-2023 21:36:43 timer
04-05-2023 13:29:17 Installed DirectX
**** End of log ****Comment
