Stuttering in games, and bad performance. What i have tried. Changing the Settings From High to Low in games like CSGO, Valorant, League of Legends doesnβt improve my fps or the stuttering. I have these random stutters during the games. On this rig my LOL fps is not going above 120 and it goes down till 90, on CSGO its from 200-300, on both games there is stuttering ingame. What i have also noticed is that the GPU Usage is always going from 0 - 100%. The temperatures of both GPU and CPU are good under 65C. What i have done is (updating BIOS, changed XMP Profile for the ram to 2933mhz, Disable TPM, Remove the motherboard battery, checked the pins of the cable to the GPU, Reinstalled windows from 11 to 10, overclock the CPU, DDU on the GPU Drivers and reinstalling them, the PC is in high-performance mode. No viruses as i ran many tests. I have disabled game bar. I have changed the dpi cable to HDMI and around, i have changed the hz from 170 to 144/120/90. Also i have reinstalled windows 10 full, without internet, installed the drivers Chipset first, then GPU etc.
After all this i noticed when playing CSGO offline (disconnecting the lan cable) i get no stutters.
SPECS:
CPU: AMD RYZEN 5 2600,
Motherboard: MB ASROCK AM4 B450 Fatal1ty GAMING K4 4xDDR4 3200Mhz
RAM: DDR4 16GB (2x8GB) 3000MHz G.SKILL Ripjaws4 F4-3000C15D-16GRK
SSD M.2: 240GB KINGSTON PCI-E NVMe A1000, SA1000M8
240G HDD: TOSHIBA HDWD110
GPU: MSI Radeon RX 580 ARMOR 8GB
PSU: 750W 14CM FAN, EVGA GQ, 80+ GOLD, SEMI MODULAR, 210-GQ-0750-V2 PSU Age: 3.5 years
OS: Windows 10
Chassis ATX / E-ATX Midi Tower Case: Deepcool MATREXX 55 V3 Black
Monitor: GIGABYTE G24F Gaming Monitor 170hz
BIOS VERISON: P5.30p
SPECS:
OS: Windows 10
