New USB wifi dongle keeps disconnecting
  • hinotai
    • Jan 2023
    • 1
    I bought a new desktop and it came with 2 USB wifi dongles. To be honest, I’m not sure how they work exactly but I plugged one into the PC and one into the router. It does connect but disconnects when I try to download games from steam.
    It does show my network listed and that it’s trying to connect but it doesn’t connect at all.
    I’ve troubleshoot the network multiple times and it fixes it but goes off again. It says
    β€œA network cable is not properly plugged in or may be broken” and β€œproblem with wireless adapter or access point”
    But the router works and everything else connects to it just fine without issue, and for the problem, it just says it fixed it by resetting the adapter.
    I’ve looked at the device manager and theres not updates for the driver, the roll back device isn’t available and I’ve turned off β€œallow computer to turn off device to save power”
    It is a Lenovo brand and running on Windows 10 Pro and there’s no system updates available, and the wifi adapter is Realtek RTL8188FTV
  • Malnutrition
    PCHF Moderator
    • 7041
    Set a static IP with Simple Static IP
    Now run Find the best DNS server for you computer.
    Then copy and paste the following commands in elevated command prompt. Hitting enter after each command.
    [ICODE]ipconfig /flushdns ipconfig /registerdns netsh advfirewall reset[/ICODE]
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      does your router have wifi?
      What is the make and model of your router
        what is the make/model of these 2 USB wireless dongles?
        is the Realtek adapter you mentioned one of these USB dongles?
        plugging one into the PC and the other into the router doesn’t sound right.
        • PeterOz
          • Mar 2021
          • 4181
          Exactly
          • Rustys
            • 7862
            Posted several places and never return
