Odd Router issues
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    #16
    Originally posted by Penfold7
    I’ve gone back to using the isp supplied DSL router
    That’s what I mean
    Originally posted by PeterOz
    could be you need a modem router supplied by the isp
    That’s why you should try this until you can get a new one
    Originally posted by Bastet
    [IMG alt=β€œcommunity.plus.net”]https://community.plus.net/t5/image/...EACE7B206?v=v2
    [HEADING=2]Hub One as a modem only[/HEADING]
    Just upgrading to FTTC from ADSL and due to receive a Hub One. Currently I’m very happy with my TP-Link router ,particularly the wireless coverage, and it has dual WAN/LAN port,so is it possible to use the Hub One as a modem only if the wireless coverage is not as good?
    • Penfold7
      • Jul 2021
      • 159
      #17
      Try telling this to SWMBO.???. She doesn’t like where it is at the min, never mind having 2 of them… My main question was though why did the tplink not like the apps on the sky boxes? but was ok with the same apps on other devices… all connected via ethernet. Thoroughly weird ???
      • Bastet
        • Aug 2016
        • 1514
        #18
        Have you tried the 2.4Ghz connection on the Sky boxes?
        We only have SkyQ which connects via Wi-Fi on that band.
        • Penfold7
          • Jul 2021
          • 159
          #19
          I haven’t to be honest… I’ve got 2.4 turned off on both boxes, as main connected via ethernet. I’m not keen on wireless for streaming don’t feel it’s reliable enough…
          Appreciate everyone’s time on this, but I think I’ll stick with the hub1 until after Christmas as nd then get a brand new DSL router, not secondhand…
          • Bastet
            • Aug 2016
            • 1514
            #20
            If a device requires 2.4Ghz then by turning it off those devices won’t connect.
            We stream Netflix on the SkyQ with no problems. Also via iPad. Although we have Virginmedia 135mbps speed.
