HIDDEN NETWORK
  • koobee9
    • Jul 2022
    • 7
    HIDDEN NETWORK
    Does anyone know why do I keep see HIDDEN NETWORK on my wifi even after I disconnect all my routers and internet? I keep see that from my computer and I don’t know where it is coming from. No one lives around me because I am the only one living in the area.
    something in your region is pumping out a wireless signal that your wireless adapter is picking up.
    some β€˜smart’ device in your house, or in your neighbourhood.
    for example, I’ve setup omni-directional roof antennas between a house and a shed.
    they advertise a signal range of 7klms!
    • koobee9
      • Jul 2022
      • 7
      Thanks for responding. But it looks like it is from my router. If I connect the router and use my ssid and password, the internet get connected but when I disconnect the router it doesn’t get connected. It is really strange to see that β€œHIDDEN NETWORK” even after I disconnect my router.
      • Rustys
        • 7862
        What screen are you lookin at when you see this?
        • koobee9
          • Jul 2022
          • 7
          On my wifi
          • Rustys
            • 7862
            Can you post a screen shot this way we can see what you are seeing?
            What version of windows?
            If Windows 10 do you see Manage Known Networks if so, click that
            then
            Click on a Network name and then click Forget.
            • koobee9
              • Jul 2022
              • 7
              I tried it but for some reason it doesn’t show on my Networks on Manage. I only see it from WIFI , I already check my router setting and Hidden network is off.
                that hidden network is close, as indicated by the signal strength.
                if you turn off all your wireless devices (modem, router, etc) and still see the hidden network SSID then you either still have a wireless device transmitting, or that network isn’t coming from a source that you control.
                • koobee9
                  • Jul 2022
                  • 7
                  It is so strange because i see it even after I disconnect everything. Modem, router. Never seen anything like that and I am worry it has something to do with hacking
                    #10
                    when you say β€œdisconnect everything” I assume you mean pulling out their power, and not β€˜disconnecting’ as in the wifi terminology?
                    • koobee9
                      • Jul 2022
                      • 7
                      #11
                      Yes. Unplug everything
                        #12
                        then that network is not one of yours.
                        • koobee9
                          • Jul 2022
                          • 7
                          #13
                          We install the bridge and another hidden network is showing, this time it looks like this[ATTACH type=β€œfull”]10182[/ATTACH]i try to enter all my SSID it doesn’t work
                            #14
                            that new hidden network is Open, so doesn’t need any password to join.
                            if you can’t, it must be MAC restricted.
                            the β€˜bridge’ you speak of, does it have an ethernet port, if so, connect using that, then you’ll get an IP address, can work out the gateway address, and login on using that from a browser to configure the bridge and remove that network.
                              #15
                              @koobee9 - any news?
