Problem with wifi on desktop
  • Velink
    • Apr 2021
    • 10
    Hi, I recently upgraded my wifi, it seems to work well on my smartphone, but not so on my desktop and laptop.
    My desktop was bought around 2014-2015 and I bought a 802.11n wifi adapter soon after that since the original built adapter has connection problem.
    My laptop on the other hand was just bought last year.
    Does the pc or the laptop give any code error?
    @Bastet
    • Velink
      • Apr 2021
      • 10
      No, I don’t see any error, It’s just very slow. The desktop would have the average speed around 25mpbs, but declining to just 5mbps after 5 hours.
      • Bastet
        • Aug 2016
        • 1514
        You say you’ve upgraded your wifi, does this mean a new router from your ISP or that you’ve changed providers & they’ve sent you a new router?
        Desktops don’t usually have wifi installed as these are not portable. The wifi dongle seems to be 2.4Ghz only as it is 802.11n (to use the 5Ghz you’d need one which uses 802.11ac).
        Have you tried a different USB port? Are the Ports USB 2 or USB 3? Is the dongle USB 2 or USB 3 capable?
        If you changed ISP then it may be a case of too many users online in your area, this would explain why the speed drops after 5 hours.
        • Velink
          • Apr 2021
          • 10
          It’s kind of trial and error, I found that I have the USB 3 installed.
          • Bastet
            • Aug 2016
            • 1514
            If the desktop is old it’ll most likely have USB 2 - USB 3 have blue plastic block - usb 2 has a black block.
            There are six differences between USB 2.0 vs 3.0. Size, speed, and a handful of others are the differences between USB 2.0 and 3.0.
            • Velink
              • Apr 2021
              • 10
              If there are many users, then why does the speed test results are totally different from the smartphone?
              • Velink
                • Apr 2021
                • 10
                I bought an external USB 3 and plugged it into the existing USB on my laptop, does that count?
                • Bastet
                  • Aug 2016
                  • 1514
                  It’s just one suggestion of the cause.
                  The problem may be the USB wifi dongle, is there any drivers for this available?
                  Check these settings:
                  Your Internet connection isn’t always the culprit for slow download and upload speeds. Sometimes, your Windows 10 PC limits your speeds for various reasons. Luckily, you can change these speed-throttling [...]
                  • Velink
                    • Apr 2021
                    • 10
                    #10
                    Well, it seems to solve the problem so far, but can I have a 24 hour for the speed test before you close this thread? Thanks
                    • Bastet
                      • Aug 2016
                      • 1514
                      #11
                      Yes, keep us updated.
                      • Velink
                        • Apr 2021
                        • 10
                        #12
                        I’ve just done testing, the laptop seems don’t have any problem since I don’t use it much unless I bring it to work, which means browsing is minimal.
                        But this desktop wifi speed fluctuated after a couple of hours, and I have to restart it.
                        • Velink
                          • Apr 2021
                          • 10
                          #13
                          My wifi will always do this weird thing of disconnecting from the wifi, it’s kind of nerve wrecking when you are in the middle of important work.
                          I did a 5 hour turn on, the speed is fairly good.
                          • Bastet
                            • Aug 2016
                            • 1514
                            #14
                            How far away from the router are you when using the desktop?
                            • Velink
                              • Apr 2021
                              • 10
                              #15
                              Around 15 - 20 feet. I guess. I just checked on the router, it’s definitely router problem since the router itself use sim card, not the typical fiber optic type, so reception goes bad according to weather. All in all, the speed problem is solved. Thanks.
