Cant connect to my home wifi
  • bbdra
    • May 2019
    • 89
    [COLOR=rgb(255, 255, 255)]Hello, i had several times problem with connecting mobile devices to my home wifi in past , usually Lenovo or Blackview. I think it has something to do with security type maybe mode and channels too, but i cant fix it.
    [COLOR=rgb(255, 255, 255)][COLOR=rgb(255, 255, 255)]I had to use a laptop hotspot which is
    [COLOR=rgb(255, 255, 255)] currently[/COLOR][COLOR=rgb(255, 255, 255)][/color][COLOR=rgb(255, 255, 255)][/color]
    [COLOR=rgb(255, 255, 255)] not available. I wondered if it could be done with the second wifi router, because i dont want use lower security type on my current router. Anyway i dont have any experiences with pairing routers. Could you help me solve this problem pleas?[/color][/COLOR][/COLOR]
    [COLOR=rgb(255, 255, 255)][COLOR=rgb(255, 255, 255)][COLOR=rgb(255, 255, 255)][/color][/color][/color]
    [COLOR=rgb(255, 255, 255)][COLOR=rgb(255, 255, 255)][COLOR=rgb(255, 255, 255)][/color][/color][/color][/COLOR]
    [COLOR=rgb(255, 255, 255)][COLOR=rgb(255, 255, 255)][COLOR=rgb(255, 255, 255)][COLOR=rgb(255, 255, 255)][/color][/color][/color][/color]
  • system
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    Are you asking how to connect another router to your existing one and use it as an access point?
    • Rustys
      • 7862
      What error messages are you getting?
      Have you tried changing the security type and channel?
      Do the devices in question have any issues connecting to other networks?
      What security is set for the modem?
      WPA
      WPA2
      WEP
      You may also want to check and see if the current system is configured to only accept specific MAC and or IP address.
        Any updates?
          Thread closed due to lack of any feedback or information from the OP.
