Originally posted by bombizzle
My wifi signal drops whenever I move my laptop
to remove the underside cover on that model it should be 2 screws (opposite side of the battery) to remove then that panel slides out to left off.
there youβll find access to most of the innards.
the smallest βholeβ is where the wireless card sits, you could detach the antennas, unscrew it and remove it.
clean the contacts and reseat and re-attach everything. you may get lucky.Comment
