No ethernet connection
  • Ryan_Silva
    • Dec 2017
    • 1
    I just built a new pc and the ethernet ports won’t work and my dad and I have tested all of the cables and ports, they came out positive, but the pc doesn’t connect to the internet. How can I fix this without a wireless card?
  • system
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    Hello Ryan, can you tell us what O/S you are using, and if you have installed the drivers for your chipset and network?
    Please download MiniToolBox and save it to your desktop.
    Run the program by right clicking on it and selecting Run as administrator. When the program opens select the following boxes:
    Report IE Proxy Settings
    Report FF Proxy Settings
    List content of Hosts
    List IP Configuration
    List Winsock Entries
    List Installed Programs
    List Devices
    MiniToolBox will open a file on completion and also create it on the desktop. Can you please Copy and paste the contents of that file in your next post?
      Any update Ryan Silva ?
        Any update for us Ryan Silva? If unreplied to within 48hrs this thread will be closed.
