Iβve had my cyberpower gaming PC for around 2 months. Itβs been working fantastic until around 2 weeks ago. The internet suddenly started being weird, and I donβt completely understand it. I havenβt been able to browse the web when it says Iβm connected to the network and internet. From help I got earlier, apparently these pcs are netorious for their Network adapters? I almost gave a up a week ago, but then, randomly, everything was fine again. So Iβve been going by normally, but itβs happening again. Iβm able to connect perfectly well on other devices to the same router.
Network problems on my cyberpower pc
Tags: None
if the network card has known issues, why not get an add-on network card and see if that helps.
they cost about $AUD20 so for a little outlay youβd hopefully be solving the issue for good.
did anything change between it working fine, playing up then working fine again? like scans you did, new software installed, changed hardware? -
Lets get some info from your machine, to get things rolling.
Step 1: Reset Host File
[li]Click here to download RstHosts v2.0[/li][li]Save the file to your desktop.[/li][li]Right Click and Run as Administrator.[/li][li]Click on Restaurer, then click OK at the prompt.[/li][li]This will restore the default host file.[/li][li]Next Click on Creer Un Rapport.[/li][li]This will open a logfile, post that in your next reply.[/li][/ul]
Step 2: MiniToolBox Scan
Checkmark following boxes:
Flush DNS
Reset FF proxy Settings
Reset Ie Proxy Settings
Report IE Proxy Settings
Report FF Proxy Settings
List content of Hosts
List IP configuration
List Winsock Entries
List last 10 Event Viewer log
List Installed Programs
List Devices (problems only)
Click Go post the result.
Step 3: Autoruns Scan.
Step 4: HijackThis.
1- Please click here to download HijackThis.
2- Run the program.
5- Copy paste the log here.Comment
I feel like thereβs gotta be an easier wayOriginally posted by MalnutritionLets get some info from your machine, to get things rolling.
Flush DNS
Step 4: HijackThis.
2- Run the program.
Your choice without logs that tell me whatβs going on with your machine, anything else is just guessing.Comment
If computers were easy to fix, there would not be so many forums with people asking for free help.I feel like thereβs gotta be an easier way
Sure. Haul the computer to a shop, pay $$$ and hope someone else fixes it.
One thing about going through what is asked - you learn more about your computer and will be able to do some troubleshooting on your own when the next problem arises.Comment
I canβt download the links without internetOriginally posted by Nathan OnsgardI feel like thereβs gotta be an easier wayComment
Do you have a link to the same model of CyberPower computer that you have so that we have an idea of the specs.Comment
