srkzzzi Network issues...
  • Malnutrition
    PCHF Moderator
    • 7041
    #16
    Quick Diag Fix.
    First please create a restore point!
    Right click on Quick Diag Run as Admin.
    Copy the content of the code box below to your clipboard.
    Click on the S within the User Interface of the program.
    Then click on Script.
    Allow completion.
    Post the log created in your next reply.
    Code:
    Key::
    [HKU\S-1-5-21-4011794534-997363082-2150810316-1001\Software\84E70D2ABC758A5DB518A475511EF0C7]
    [HKU\S-1-5-21-4011794534-997363082-2150810316-1001\Software\AVG]
    [HKU\S-1-5-21-4011794534-997363082-2150810316-1001\Software\AVG Web TuneUp]
    [HKU\S-1-5-21-4011794534-997363082-2150810316-1001\Software\UCBrowser]
    [HKU\S-1-5-21-4011794534-997363082-2150810316-1001\Software\UCBrowserPID]
    [HKLM\Software\84E70D2ABC758A5DB518A475511EF0C7]
    [HKLM\Software\AVG]
    [HKLM\Software\WOW6432Node\84E70D2ABC758A5DB518A475511EF0C7]
    [HKLM\Software\WOW6432Node\AVG]
    [HKLM\Software\WOW6432Node\IObit]
    [HKLM\Software\WOW6432Node\UCBrowserPID]
    File::
    C:\WINDOWS\Temp\CR_5A9D2.tmp
    c:\WINDOWS\Temp\tpm31FF.tmp
    C:\WINDOWS\Temp\tpm9AFB.tmp
    C:\WINDOWS\Temp\TS_2708.tmp
    C:\WINDOWS\Temp\TS_48A1.tmp
    C:\WINDOWS\Temp\TS_48C2.tmp
    C:\WINDOWS\Temp\TS_4E10.tmp
    C:\WINDOWS\Temp\TS_5955.tmp
    C:\WINDOWS\Temp\TS_5985.tmp
    C:\WINDOWS\Temp\tw31DE.tmp
    C:\WINDOWS\Temp\tw903C.tmp
    C:\WINDOWS\IObit
    C:\Users\Tuf Tuf\AppData\LocalLow\IObit
    C:\Users\Tuf Tuf\AppData\Roaming\IObit
    C:\Users\Tuf Tuf\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Chrome Π°ΠΏΠ»ΠΈΠΊΠ°Ρ†ΠΈΡ˜Π΅
    C:\ProgramData\IObit
    C:\ProgramData\Norton
    C:\ProgramData\NortonInstaller
    C:\Program Files (x86)\IObit
    C:\Program Files\KMSpico
    C:\Program Files (x86)\Common Files\IObit
    C:\WINDOWS\System32\Drivers\cfosspeed6.sys
    ADS::
    C:\ProgramData\Temp
    Clean::
    yes
    • srkzzzi
      • Feb 2017
      • 22
      #17
      --------------- QuickScript | g3n-h@ckm@n | V3_02.04.17.1 ---------------
      ----- XP | Vista | 7 | 8 | 8.1 | 10 - 32/64 bits ----- - Start 17/04/2017 12:13:54
      Updated 02/04/2017 | 14.30 (GMT) by g3n-h@ckm@n
      Contact : http://www.sosvirus.net/
      Time Zone : (UTC+01:00) Belgrade, Bratislava, Budapest, Ljubljana, Prague
      [Tuf Tuf (Administrator)] - [DESKTOP-HFQ2I7A] (S-1-5-21-4011794534-997363082-2150810316-1001)
      System: Microsoft Windows 10 Pro - - (10.0.14393) - BuildType: Multiprocessor Free - OSLanguage: 1033 (241a)
      System: AutoReboot: True - DebugFilePath: %SystemRoot%\MEMORY.DMP - KernelDumpOnly: False - OverwriteExistingDebugFile: True - WriteDebugInfo: True - WriteToSystemLog: True
      Boot : Microsoft Windows 10 Pro|C:\WINDOWS|\Device\Harddisk0\Partition1
      Boot : Normal boot
      PC: To Be Filled By O.E.M. - To Be Filled By O.E.M. - IdNumber: To Be Filled By O.E.M. - UUID: 03000200-0400-0500-0006-000700080009
      Processor : X64 - 3199 Mhz - Intel(R) Coreβ„’ i5-4460 CPU @ 3.20GHz
      BIOS Date: 07/23/15 21:33:02 Ver: 04.06.05 - - American Megatrends Inc. - S/N: To Be Filled By O.E.M. - P1.10 - ALASKA - 1072009
      CoreTemp : ? Celsius
      ----------| Script
      Registry saved : C:\QuickDiag\Save\Registry [17.04.2017 @ 12_13_54]
      Key : [HKU\S-1-5-21-4011794534-997363082-2150810316-1001\Software\84E70D2ABC758A5DB518A475511EF0C7] Deleted Successfully
      Key : [HKU\S-1-5-21-4011794534-997363082-2150810316-1001\Software\AVG] Deleted Successfully
      Key : [HKU\S-1-5-21-4011794534-997363082-2150810316-1001\Software\AVG Web TuneUp] Deleted Successfully
      Key : [HKU\S-1-5-21-4011794534-997363082-2150810316-1001\Software\UCBrowser] Deleted Successfully
      Key : [HKU\S-1-5-21-4011794534-997363082-2150810316-1001\Software\UCBrowserPID] Deleted Successfully
      Key : [HKLM\Software\84E70D2ABC758A5DB518A475511EF0C7] Deleted Successfully
      Key : [HKLM\Software\AVG] Deleted Successfully
      Key : [HKLM\Software\WOW6432Node\84E70D2ABC758A5DB518A475 511EF0C7] Deleted Successfully
      Key : [HKLM\Software\WOW6432Node\AVG] Deleted Successfully
      Key : [HKLM\Software\WOW6432Node\IObit] Deleted Successfully
      Key : [HKLM\Software\WOW6432Node\UCBrowserPID] Deleted Successfully
      C:\WINDOWS\Temp\CR_5A9D2.tmp Moved Successfully
      c:\WINDOWS\Temp\tpm31FF.tmp Moved Successfully
      C:\WINDOWS\Temp\tpm9AFB.tmp Moved Successfully
      C:\WINDOWS\Temp\TS_2708.tmp Moved Successfully
      C:\WINDOWS\Temp\TS_48A1.tmp Moved Successfully
      C:\WINDOWS\Temp\TS_48C2.tmp Moved Successfully
      C:\WINDOWS\Temp\TS_4E10.tmp Moved Successfully
      C:\WINDOWS\Temp\TS_5955.tmp Moved Successfully
      C:\WINDOWS\Temp\TS_5985.tmp Moved Successfully
      C:\WINDOWS\Temp\tw31DE.tmp Moved Successfully
      C:\WINDOWS\Temp\tw903C.tmp Moved Successfully
      C:\WINDOWS\IObit Moved Successfully
      C:\Users\Tuf Tuf\AppData\LocalLow\IObit Moved Successfully
      C:\Users\Tuf Tuf\AppData\Roaming\IObit Moved Successfully
      C:\Users\Tuf Tuf\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Chrome Π°ΠΏΠ»ΠΈΠΊΠ°Ρ†ΠΈΡ˜Π΅ Moved Successfully
      C:\ProgramData\IObit Moved Successfully
      C:\ProgramData\Norton Moved Successfully
      C:\ProgramData\NortonInstaller Moved Successfully
      C:\Program Files (x86)\IObit Moved Successfully
      C:\Program Files\KMSpico Moved Successfully
      C:\Program Files (x86)\Common Files\IObit Moved Successfully
      C:\WINDOWS\System32\Drivers\cfosspeed6.sys Moved Successfully
      -------------- | CleanDisk :
      FreeSpace : 68080
      Cleaning…
      FreeSpace : 68287
      ----------(EOF)----------
      • Malnutrition
        PCHF Moderator
        • 7041
        #18
        How is the machine performing now? Any issues to speak of?
        • srkzzzi
          • Feb 2017
          • 22
          #19
          No none really everything is fine now, just have one more quesiton
          On chrome there is an odd number that is only appearing when on youtube, and it changes from day to day.
          Today its 273 but yesterday i think it was 266 or something close.
          • Malnutrition
            PCHF Moderator
            • 7041
            #20
            Are you using Ublock origin? It may be the number of ads blocked by the tool… Just in case go ahead and run FRST for me as you did in your previous thread, I’d like to make sure before I send you on your way, that nothing is lurking that needs attention.
            • srkzzzi
              • Feb 2017
              • 22
              #21
              The only adblock extension I’m currently using is APB, and it didn’t show this number before, it’s started to show recently.
              • srkzzzi
                • Feb 2017
                • 22
                #22
                Here are newer logs
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  #23
                  FRST Fix.
                  Click Here To Download Fixlist.
                  Download attached fixlist.txt file and save it to the Desktop. NOTE. It’s important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
                  After the fix, then install Ublock Origin for Chrome.
                  • srkzzzi
                    • Feb 2017
                    • 22
                    #24
                    I’ve ran the script with both the files on desktop and installed uBlock and the number is still showing up, today it’s 283.
                    • srkzzzi
                      • Feb 2017
                      • 22
                      #25
                      Oddly enough the number doesn’t appear when i use Opera.
                      • plodr
                        • Aug 2016
                        • 1021
                        #26
                        Opera allows you to hide the total number of ads blocked, FF doesn’t.
                        The number will continue to climb because it is adding up all the ads blocked.
                        • srkzzzi
                          • Feb 2017
                          • 22
                          #27
                          Ye but i ran the FRST script and it’s still showing.
                          • system
                            PCHF Owner
                            • 7695
                            • CachyOS
                            • Intel Arc A770 (16 GB)
                            #28
                            Hope you don’t mind me butting in here, but if it’s only on Youtube have you checked your notifications by chance?
                            If you are concerned about the number of blocked ads shown by Ublock turn the display off in Ublocks options. This works for all browsers Ive used including several Mozilla based ones.
                            [ATTACH]2044[/ATTACH]
                            • srkzzzi
                              • Feb 2017
                              • 22
                              #29
                              Tried this. didn’t work
                              • plodr
                                • Aug 2016
                                • 1021
                                #30
                                Are you using AdBlockPlus or uBlockOrigin or something else? There is AdBlock and uBlock as well as several others.
                                At one point you said you are using ABP.
                                gus is showing a setting in a different ad blocker addon. So a setting for uBO would not work for ABP!
                                uBlock is NOT uBlockOrigin
                                installed uBlock
