srkzzzi Network issues...
  • Malnutrition
    PCHF Moderator
    • 7041
    @srkzzzi Posted the new thread for you…
    Please run this tool and post the log.
    Checkmark following boxes:
    Flush DNS
    Reset FF proxy Settings
    Reset Ie Proxy Settings
    Report IE Proxy Settings
    Report FF Proxy Settings
    List content of Hosts
    List IP configuration
    List Winsock Entries
    List last 10 Event Viewer log
    List Installed Programs
    List Devices (problems only)
    Click Go and post the result.
  • srkzzzi
    • Feb 2017
    • 22
    Flush DNS
    here the log files
      Let’s wait on Mal to finish up on his request.
      • Malnutrition
        PCHF Moderator
        • 7041
        HijackThis.
        1- Please Click HERE to download HijackThis. – Unzip to your desktop.
        2- Right click run as admin.
        5- Copy paste the log here.
        • srkzzzi
          • Feb 2017
          • 22
          here’s the log
          • Malnutrition
            PCHF Moderator
            • 7041
            Ran by Tuf Tuf (administrator) on 14-04-2017 at 19:30:01
            Running from β€œC:\Users\Tuf Tuf\Downloads”
            Microsoft Windows 10 Pro (X64)
            Model: To Be Filled By O.E.M. Manufacturer: To Be Filled By O.E.M.
            Boot Mode: Normal
            Windows IP Configuration
            Proxy is not enabled.
            No Proxy Server is set.
            β€œReset IE Proxy Settings”: IE Proxy Settings were reset.
            127.0.0.1 localhost
            Realtek PCIe GBE Family Controller = Ethernet (Connected)
            LogMeIn Hamachi Virtual Ethernet Adapter = Hamachi (Connected)
            TunnelBear Adapter V9 = Ethernet 2 (Hardware not present)
            TAP-Win32 Adapter V9 (Tunngle) = Tunngle (Media disconnected)
            [HEADING=1]----------------------------------[/HEADING]
            [HEADING=1]IPv4 Configuration[/HEADING]
            pushd interface ipv4
            reset
            set global defaultcurhoplimit=64 icmpredirects=enabled
            add route prefix=0.0.0.0/0 interface=β€œHamachi” nexthop=25.0.0.1 publish=Yes
            set interface interface=β€œEthernet” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
            set interface interface=β€œLocal Area Connection* 1” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
            set interface interface=β€œEthernet 2” forwarding=enabled advertise=enabled metric=0 nud=enabled ignoredefaultroutes=disabled
            set interface interface=β€œHamachi” forwarding=enabled advertise=enabled metric=9000 nud=enabled ignoredefaultroutes=disabled
            set interface interface=β€œTunngle” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
            set subinterface interface= subinterface=ethernet_32774 mtu=1404
            popd
            [HEADING=1]End of IPv4 configuration[/HEADING]
            Host Name . . . . . . . . . . . . : DESKTOP-HFQ2I7A
            Ethernet adapter Hamachi:
            Description . . . . . . . . . . . : LogMeIn Hamachi Virtual Ethernet Adapter
            Physical Address. . . . . . . . . : 7A-79-19-38-C4-1C
            IPv6 Address. . . . . . . . . . . : 2620:9b::1938:c41c(Preferred)
            Link-local IPv6 Address . . . . . : fe80::9924:d22b:80b1:4c85%12(Preferred)
            IPv4 Address. . . . . . . . . . . : 25.56.196.28(Preferred)
            Subnet Mask . . . . . . . . . . . : 255.0.0.0
            Lease Obtained. . . . . . . . . . : petak, 14. april 2017. 18.00.11
            Lease Expires . . . . . . . . . . : subota, 14. april 2018. 19.25.18
            Default Gateway . . . . . . . . . : 2620:9b::1900:1
            25.0.0.1
            DHCP Server . . . . . . . . . . . : 25.0.0.1
            DHCPv6 IAID . . . . . . . . . . . : 318918898
            DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-B8-D1-AC-D0-50-99-A2-57-5C
            DNS Servers . . . . . . . . . . . : 8.8.8.8
            8.8.4.4
            25.0.0.1
            Ethernet adapter Ethernet:
            Physical Address. . . . . . . . . : D0-50-99-A2-57-5C
            Link-local IPv6 Address . . . . . : fe80::c4cf:1c73:303c:cac5%9(Preferred)
            IPv4 Address. . . . . . . . . . . : 192.168.0.10(Preferred)
            Lease Obtained. . . . . . . . . . : petak, 14. april 2017. 18.00.07
            Lease Expires . . . . . . . . . . : petak, 14. april 2017. 20.25.18
            DHCPv6 IAID . . . . . . . . . . . : 63983769
            8.8.4.4
            192.168.0.1
            Ethernet adapter Tunngle:
            Description . . . . . . . . . . . : TAP-Win32 Adapter V9 (Tunngle)
            Physical Address. . . . . . . . . : 00-FF-96-BD-CC-5C
            Tunnel adapter isatap.{6ACB4502-F8D6-4A8B-ABEE-2C7ABA76975A}:
            Tunnel adapter Local Area Connection* 10:
            Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
            IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:2433:6e:e778:dc1a(Preferred)
            Link-local IPv6 Address . . . . . : fe80::2433:6e:e778:dc1a%18(Preferred)
            DHCPv6 IAID . . . . . . . . . . . : 352321536
            Tunnel adapter isatap.{C41CEE96-4161-4C19-93E7-D970877C773C}:
            Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
            Server: google-public-dns-a.google.com
            Address: 8.8.8.8
            Addresses: 2a00:1450:400d:803::200e
            172.217.17.206
            Pinging google.com [216.58.214.206] with 32 bytes of data:
            Reply from 216.58.214.206: bytes=32 time=18ms TTL=57
            Reply from 216.58.214.206: bytes=32 time=13ms TTL=57
            Ping statistics for 216.58.214.206:
            Minimum = 13ms, Maximum = 18ms, Average = 15ms
            Address: 8.8.8.8
            Addresses: 2001:4998:c:a06::2:4008
            2001:4998:44:204::a7
            2001:4998:58:c02::a9
            98.139.183.24
            98.138.253.109
            206.190.36.45
            Pinging yahoo.com [98.139.183.24] with 32 bytes of data:
            Reply from 98.139.183.24: bytes=32 time=126ms TTL=52
            Reply from 98.139.183.24: bytes=32 time=127ms TTL=52
            Ping statistics for 98.139.183.24:
            Minimum = 126ms, Maximum = 127ms, Average = 126ms
            Reply from 127.0.0.1: bytes=32 time<1ms TTL=64
            [HEADING=1]Ping statistics for 127.0.0.1:
            Minimum = 0ms, Maximum = 0ms, Average = 0ms[/HEADING]
            [HEADING=1]Interface List
            12…7a 79 19 38 c4 1c …LogMeIn Hamachi Virtual Ethernet Adapter
            9…d0 50 99 a2 57 5c …Realtek PCIe GBE Family Controller
            10…00 ff 96 bd cc 5c …TAP-Win32 Adapter V9 (Tunngle)
            1…Software Loopback Interface 1
            8…00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
            18…00 00 00 00 00 00 00 e0 Microsoft Teredo Tunneling Adapter
            14…00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #3[/HEADING]
            [HEADING=1]IPv4 Route Table[/HEADING]
            [HEADING=1]Active Routes:
            0.0.0.0 0.0.0.0 25.0.0.1 25.56.196.28 9256
            0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.10 25
            25.0.0.0 255.0.0.0 On-link 25.56.196.28 9256
            25.56.196.28 255.255.255.255 On-link 25.56.196.28 9256
            25.255.255.255 255.255.255.255 On-link 25.56.196.28 9256
            192.168.0.0 255.255.255.0 On-link 192.168.0.10 281
            192.168.0.10 255.255.255.255 On-link 192.168.0.10 281
            192.168.0.255 255.255.255.255 On-link 192.168.0.10 281
            224.0.0.0 240.0.0.0 On-link 25.56.196.28 9256
            224.0.0.0 240.0.0.0 On-link 192.168.0.10 281
            255.255.255.255 255.255.255.255 On-link 25.56.196.28 9256
            255.255.255.255 255.255.255.255 On-link 192.168.0.10 281[/HEADING]
            [HEADING=1]Persistent Routes:
            Network Address Netmask Gateway Address Metric
            0.0.0.0 0.0.0.0 25.0.0.1 Default[/HEADING]
            [HEADING=1]IPv6 Route Table[/HEADING]
            12 9015 ::/0 2620:9b::1900:1
            1 331 ::1/128 On-link
            18 331 2001::/32 On-link
            18 331 2001:0:4137:9e76:2433:6e:e778:dc1a/128
            On-link
            12 271 2620:9b::/96 On-link
            12 271 2620:9b::1938:c41c/128 On-link
            12 271 fe80::/64 On-link
            9 281 fe80::/64 On-link
            18 331 fe80::/64 On-link
            18 331 fe80::2433:6e:e778:dc1a/128
            On-link
            12 271 fe80::9924:d22b:80b1:4c85/128
            On-link
            9 281 fe80::c4cf:1c73:303c:cac5/128
            On-link
            1 331 ff00::/8 On-link
            12 271 ff00::/8 On-link
            9 281 ff00::/8 On-link
            18 331 ff00::/8 On-link[/HEADING]
            0 4294967295 2620:9b::/96 On-link
            0 9000 ::/0 2620:9b::1900:1[/HEADING]
            Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [55808] (Microsoft Corporation)
            Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
            Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
            Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [65024] (Microsoft Corporation)
            Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [24064] (Microsoft Corporation)
            Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [306016] (Microsoft Corporation)
            x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67584] (Microsoft Corporation)
            x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
            x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
            x64-Catalog5 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31744] (Microsoft Corporation)
            x64-Catalog9 01 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog9 02 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog9 03 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog9 04 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog9 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog9 06 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog9 07 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog9 08 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog9 09 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog9 10 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog9 11 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            x64-Catalog9 12 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
            Error: (04/14/2017 06:09:58 PM) (Source: Microsoft-Windows-CAPI2) (User: )
            Description: Cryptographic Services failed while processing the OnIdentity() call in the System Writer Object.
            Details:
            AddLegacyDriverFiles: Unable to back up image of binary Microsoft Link-Layer Discovery Protocol.
            System Error:
            Access is denied.
            Error: (04/14/2017 05:59:48 PM) (Source: Application Error) (User: )
            Description: Faulting application name: LogonUI.exe, version: 10.0.14393.0, time stamp: 0x57899b5a
            Faulting module name: USBKeyCredentialProvider.dll_unloaded, version: 0.0.0.0, time stamp: 0x53d9fa55
            Exception code: 0xc0000005
            Fault offset: 0x000000000002b4a8
            Faulting process id: 0x21c
            Faulting application start time: 0xLogonUI.exe0
            Faulting application path: LogonUI.exe1
            Faulting module path: LogonUI.exe2
            Report Id: LogonUI.exe3
            Faulting package full name: LogonUI.exe4
            Faulting package-relative application ID: LogonUI.exe5
            Error: (04/14/2017 12:00:29 PM) (Source: Application Error) (User: )
            Faulting process id: 0x22c
            Error: (04/13/2017 08:44:12 PM) (Source: Application Error) (User: )
            Description: Faulting application name: csgo.exe, version: 0.0.0.0, time stamp: 0x582e1b2f
            Faulting module name: tier0.dll, version: 0.0.0.0, time stamp: 0x58ee858f
            Fault offset: 0x000093c4
            Faulting process id: 0x1b6c
            Faulting application start time: 0xcsgo.exe0
            Faulting application path: csgo.exe1
            Faulting module path: csgo.exe2
            Report Id: csgo.exe3
            Faulting package full name: csgo.exe4
            Faulting package-relative application ID: csgo.exe5
            Error: (04/13/2017 10:15:31 AM) (Source: Application Error) (User: )
            Faulting process id: 0x2e4
            Error: (04/13/2017 12:49:19 AM) (Source: Software Protection Platform Service) (User: )
            Description: License Activation (slui.exe) failed with the following error code:
            hr=0xC004F074
            Command-line arguments:
            RuleId=dca14e37-0c5c-444f-9b35-1e2f161f5ac3;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2de67392-b7a7-462a-b1ca-108dd189f588;NotificationInterval=1440;Trigger=Tim erEvent
            Error: (04/12/2017 10:48:40 PM) (Source: Software Protection Platform Service) (User: )
            hr=0xC004F074
            Error: (04/12/2017 08:49:18 PM) (Source: Software Protection Platform Service) (User: )
            hr=0xC004F074
            RuleId=dca14e37-0c5c-444f-9b35-1e2f161f5ac3;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2de67392-b7a7-462a-b1ca-108dd189f588;NotificationInterval=1440;Trigger=Use rLogon;SessionId=1
            Error: (04/12/2017 08:48:34 PM) (Source: Application Error) (User: )
            Faulting process id: 0x280
            Error: (04/12/2017 08:47:55 PM) (Source: Software Protection Platform Service) (User: )
            hr=0x8007139F
            Error: (04/14/2017 07:24:56 PM) (Source: Schannel) (User: DESKTOP-HFQ2I7A)
            Description: The certificate received from the remote server was issued by an untrusted certificate authority. Because of this, none of the data contained in the certificate can be validated. The TLS connection request has failed. The attached data contains the server certificate.
            Error: (04/14/2017 07:15:25 PM) (Source: Schannel) (User: DESKTOP-HFQ2I7A)
            Error: (04/14/2017 07:06:46 PM) (Source: Schannel) (User: DESKTOP-HFQ2I7A)
            Error: (04/14/2017 06:58:28 PM) (Source: Schannel) (User: DESKTOP-HFQ2I7A)
            Error: (04/14/2017 06:58:19 PM) (Source: Schannel) (User: DESKTOP-HFQ2I7A)
            Error: (04/14/2017 06:54:23 PM) (Source: Schannel) (User: DESKTOP-HFQ2I7A)
            Error: (04/14/2017 06:53:24 PM) (Source: Schannel) (User: DESKTOP-HFQ2I7A)
            Error: (04/14/2017 06:51:31 PM) (Source: Schannel) (User: DESKTOP-HFQ2I7A)
            Error: (04/14/2017 06:50:38 PM) (Source: Schannel) (User: DESKTOP-HFQ2I7A)
            [HEADING=1]Microsoft Office Sessions:[/HEADING]
            Error: (04/14/2017 06:09:58 PM) (Source: Microsoft-Windows-CAPI2)(User: )
            Description:
            Details:
            System Error:
            Access is denied.
            Error: (04/14/2017 05:59:48 PM) (Source: Application Error)(User: )
            Description: LogonUI.exe10.0.14393.057899b5aUSBKeyCredentialPro vider.dll_unloaded0.0.0.053d9fa55c0000005000000000 002b4a821c01d2b5381fcdbb04C:\WINDOWS\system32\Logo nUI.exeUSBKeyCredentialProvider.dll540e8d65-1cd3-4205-ace4-54ab17662557
            Error: (04/14/2017 12:00:29 PM) (Source: Application Error)(User: )
            Description: LogonUI.exe10.0.14393.057899b5aUSBKeyCredentialPro vider.dll_unloaded0.0.0.053d9fa55c0000005000000000 002b4a822c01d2b505ee42cae5C:\WINDOWS\system32\Logo nUI.exeUSBKeyCredentialProvider.dll2754b26c-5b22-4cdb-b332-7baea8e0056f
            Error: (04/13/2017 08:44:12 PM) (Source: Application Error)(User: )
            Description: csgo.exe0.0.0.0582e1b2ftier0.dll0.0.0.058ee858fc00 00005000093c41b6c01d2b485ef0148e6E:\SteamLibrary\s teamapps\common\Counter-Strike Global Offensive\csgo.exeE:\SteamLibrary\steamapps\common \Counter-Strike Global Offensive\bin\tier0.dll36ae552b-a229-4937-b036-ef3069e60180
            Error: (04/13/2017 10:15:31 AM) (Source: Application Error)(User: )
            Description: LogonUI.exe10.0.14393.057899b5aUSBKeyCredentialPro vider.dll_unloaded0.0.0.053d9fa55c0000005000000000 002b4a82e401d2b42e18d1278fC:\WINDOWS\system32\Logo nUI.exeUSBKeyCredentialProvider.dll0b29f6e5-53af-4da5-8b81-0356519860a7
            Error: (04/13/2017 12:49:19 AM) (Source: Software Protection Platform Service)(User: )
            Description: hr=0xC004F074RuleId=dca14e37-0c5c-444f-9b35-1e2f161f5ac3;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2de67392-b7a7-462a-b1ca-108dd189f588;NotificationInterval=1440;Trigger=Tim erEvent
            Error: (04/12/2017 10:48:40 PM) (Source: Software Protection Platform Service)(User: )
            Error: (04/12/2017 08:49:18 PM) (Source: Software Protection Platform Service)(User: )
            Description: hr=0xC004F074RuleId=dca14e37-0c5c-444f-9b35-1e2f161f5ac3;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2de67392-b7a7-462a-b1ca-108dd189f588;NotificationInterval=1440;Trigger=Use rLogon;SessionId=1
            Error: (04/12/2017 08:48:34 PM) (Source: Application Error)(User: )
            Description: LogonUI.exe10.0.14393.057899b5aUSBKeyCredentialPro vider.dll_unloaded0.0.0.053d9fa55c0000005000000000 002b4a828001d2b3bd03cbfa9bC:\WINDOWS\system32\Logo nUI.exeUSBKeyCredentialProvider.dll3ffd0bdb-47fb-4286-9c98-3813fc880acc
            Error: (04/12/2017 08:47:55 PM) (Source: Software Protection Platform Service)(User: )
            Description: hr=0x8007139FRuleId=dca14e37-0c5c-444f-9b35-1e2f161f5ac3;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2de67392-b7a7-462a-b1ca-108dd189f588;NotificationInterval=1440;Trigger=Tim erEvent
            [HEADING=1]CodeIntegrity Errors:[/HEADING]
            Date: 2017-04-14 18:10:57.892
            Description: Code Integrity determined that a process (\Device\HarddiskVolume1\Windows\SystemApps\Micros oft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.ex e) attempted to load \Device\HarddiskVolume1\Windows\System32\nvspcap64 .dll that did not meet the Store signing level requirements.
            Date: 2017-04-14 18:10:54.283
            Date: 2017-04-14 15:29:35.305
            Description: Code Integrity determined that a process (\Device\HarddiskVolume1\Program Files\Windows Defender\MsMpEng.exe) attempted to load \Device\HarddiskVolume1\Program Files\Common Files\microsoft shared\OFFICE16\MSOXMLMF.DLL that did not meet the Custom 3 / Antimalware signing level requirements.
            Date: 2017-04-13 16:13:43.557
            Date: 2017-04-12 18:56:34.250
            Date: 2017-04-12 13:20:58.027
            Date: 2017-04-11 16:00:06.770
            Date: 2017-04-11 12:47:19.569
            Date: 2017-04-09 17:07:38.236
            Date: 2017-04-08 20:58:13.186
            Β΅Torrent (HKCU...\uTorrent) (Version: 3.4.9.43388 - BitTorrent Inc.)
            Active Directory Authentication Library for SQL Server (HKLM...{32C0D7B2-1046-43AC-98AD-B748E1910916}) (Version: 13.0.1601.5 - Microsoft Corporation) Hidden
            Active Directory Authentication Library for SQL Server (x86) (HKLM-x32...{F40FA676-46B1-4609-85EF-D2F1F79E0C0E}) (Version: 13.0.1601.5 - Microsoft Corporation) Hidden
            Adobe Flash Player 25 PPAPI (HKLM-x32...\Adobe Flash Player PPAPI) (Version: 25.0.0.148 - Adobe Systems Incorporated)
            Aliens vs. Predator (HKLM-x32...{2A086701-1EEE-43F5-A9DB-DE2D73DC543D}_is1) (Version: - )
            Ansel (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 381.65 - NVIDIA Corporation) Hidden
            APP Shop v1.0.13 (HKLM-x32...{90242E9B-BC60-46E3-8EE7-8E953F702280}_is1) (Version: 1.0.13 - ASRock Inc.)
            Application Insights Tools for Visual Studio 2015 (HKLM-x32...{0E4C791E-B78E-477D-BD5A-CDD0985BA6EC}) (Version: 7.0.20622.1 - Microsoft Corporation)
            ASRock App Charger v1.0.6 (HKLM...\ASRock App Charger_is1) (Version: 1.0.6 - ASRock Inc.)
            ASRock Restart to UEFI v1.0.3 (HKLM-x32...\ASRock Restart to UEFI_is1) (Version: - )
            ASRock XFast RAM v3.0.3 (HKLM...\ASRock XFast RAM_is1) (Version: - ASRock Inc.)
            Assassin’s Creed III (HKLM-x32...\Uplay Install 54) (Version: - Ubisoft)
            A-Tuning v2.0.214 (HKLM-x32...\A-Tuning_is1) (Version: 2.0.214 - )
            Azure AD Authentication Connected Service (HKLM-x32...{8A1AD070-269F-4A15-AAB5-76AB896EF195}) (Version: 14.0.25420 - Microsoft Corporation) Hidden
            AzureTools.Notifications (HKLM-x32...{1E5CA362-39B6-4BD0-B9C0-69CF15F0FEA2}) (Version: 2.7.30611.1601 - Microsoft Corporation) Hidden
            Battle.net (HKLM-x32...\Battle.net) (Version: - Blizzard Entertainment)
            Blend for Visual Studio SDK for .NET 4.5 (HKLM-x32...{37E53780-3944-4A6A-842F-727128E8616E}) (Version: 3.0.40218.0 - Microsoft Corporation) Hidden
            Borderlands 2 GOTY version 1.8.2.0 (HKLM-x32...\Borderlands 2 GOTY_is1) (Version: 1.8.2.0 - Mr DJ)
            Call of Duty Black Ops 2 (HKLM-x32...{47D6F3E4-D158-4E47-84C4-0D6452DB2488}_is1) (Version: 1.0 - Treyarch)
            Call of Duty: Black Ops (HKLM-x32...\Call of Duty: Black Ops_is1) (Version: - )
            Call of Duty: Modern Warfare 2 - Multiplayer (HKLM...\Steam App 10190) (Version: - Infinity Ward)
            Call of Duty: Modern Warfare 2 (HKLM...\Steam App 10180) (Version: - Infinity Ward)
            CodeBlocks (HKCU...\CodeBlocks) (Version: 16.01 - The Code::Blocks Team)
            Counter-Strike: Global Offensive (HKLM...\Steam App 730) (Version: - Valve)
            CPUID CPU-Z 1.77 (HKLM...\CPUID CPU-Z_is1) (Version: - )
            Discord (HKCU...\Discord) (Version: 0.0.297 - Hammer & Chisel, Inc.)
            Dotfuscator and Analytics Community Edition 5.22.0 (HKLM-x32...{60018889-9E0F-43E8-9B89-29E8C828B40A}) (Version: 5.22.0.3788 - PreEmptive Solutions) Hidden
            Driver Booster 4.2 (HKLM-x32...\Driver Booster_is1) (Version: 4.2.0 - IObit)
            Entity Framework 6.1.3 Tools for Visual Studio 2015 Update 1 (HKLM-x32...{2A56910C-69C8-495D-8ED8-9080F0A14E58}) (Version: 14.0.41103.0 - Microsoft Corporation)
            Euro Truck Simulator 2 (HKLM-x32...\Euro Truck Simulator 2_R.G. Mechanics_is1) (Version: - R.G. Mechanics, markfiter)
            Everything 1.3.4.686 (x86) (HKLM-x32...\Everything) (Version: - )
            f.lux (HKCU...\Flux) (Version: - )
            F1 2016 version 1.0 (HKLM-x32...{9B939765-0B6B-48F5-8543-1FEDC09AE74D}_is1) (Version: 1.0 - SKIDROW)
            Far Cry 3 (HKLM-x32...{E3B9C5A9-BD7A-4B56-B754-FAEA7DD6FA88}) (Version: 1.05 - Ubisoft)
            Far Cry 3 (HKLM-x32...\Far Cry 3_R.G. Mechanics_is1) (Version: - R.G. Mechanics, spider91)
            ForHonorBETA (HKLM-x32...\Uplay Install 2184) (Version: - Ubisoft)
            Gameforge Live 2.0.12 (HKLM-x32...{9C98989A-3A15-42DA-A3B9-D20331437D67}}is1) (Version: 2.0.12 - Gameforge)
            Garry’s Mod (HKLM...\Steam App 4000) (Version: - Facepunch Studios)
            GIGABYTE OC_GURU II (HKLM-x32...{EA298EC1-2B8F-4DA9-8C5B-BC1FCBBAD72F}) (Version: 1.84.0000 - GIGABYTE Technology Co.,Ltd.) Hidden
            GIGABYTE OC_GURU II (HKLM-x32...\InstallShield
            Google Chrome (HKLM-x32...\Google Chrome) (Version: 57.0.2987.133 - Google Inc.)
            Google Update Helper (HKLM-x32...{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.3 - Google Inc.) Hidden
            Gyazo 3.3.1 (HKLM-x32...{6DB8C365-E719-4BA5-9594-10DFC244D3FD}_is1) (Version: - Nota Inc.)
            Hearthstone (HKLM-x32...\Hearthstone) (Version: - Blizzard Entertainment)
            Herramientas de correcciΓ³n de Microsoft Office 2016: espaΓ±ol (HKLM...{90160000-001F-0C0A-1000-0000000FF1CE}) (Version: 16.0.4266.1001 - Microsoft Corporation) Hidden
            IIS 10.0 Express (HKLM...{13FD7E30-D2F1-498D-ABC2-A4242DB6610E}) (Version: 10.0.1736 - Microsoft Corporation)
            IIS Express Application Compatibility Database for x64 (HKLM...{08274920-8908-45c2-9258-8ad67ff77b09}.sdb) (Version: - )
            IIS Express Application Compatibility Database for x86 (HKLM...{ad846bae-d44b-4722-abad-f7420e08bcd9}.sdb) (Version: - )
            Intel(R) Rapid Storage Technology (HKLM...{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 13.1.0.1058 - Intel Corporation)
            Java 8 Update 121 (HKLM-x32...{26A24AE4-039D-4CA4-87B4-2F32180121F0}) (Version: 8.0.1210.13 - Oracle Corporation)
            League of Legends (HKLM-x32...{E70D54A4-60A4-4148-A292-525922A9A108}) (Version: 4.1.2 - Riot Games) Hidden
            League of Legends (HKLM-x32...\League of Legends 4.1.2) (Version: 4.1.2 - Riot Games)
            Loadout (HKLM...\Steam App 208090) (Version: - Edge of Reality)
            LogMeIn Hamachi (HKLM-x32...{91B5DF26-717A-4A5F-AB10-CD450FAD428C}) (Version: 2.2.0.541 - LogMeIn, Inc.) Hidden
            LogMeIn Hamachi (HKLM-x32...\LogMeIn Hamachi) (Version: 2.2.0.541 - LogMeIn, Inc.)
            Malwarebytes version 3.0.6.1469 (HKLM...{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.0.6.1469 - Malwarebytes)
            Mass Effectβ„’ 2 (HKLM-x32...{75D84EF7-0D8C-4e70-B3FA-7B42A5D4E0EB}) (Version: 1.2.1604.0 - Electronic Arts)
            Microsoft .NET Framework 4.5 Multi-Targeting Pack (HKLM-x32...{56E962F0-4FB0-3C67-88DB-9EAA6EEFC493}) (Version: 4.5.50710 - Microsoft Corporation)
            Microsoft .NET Framework 4.5.1 Multi-Targeting Pack (ENU) (HKLM-x32...{D3517C62-68A5-37CF-92F7-93C029A89681}) (Version: 4.5.50932 - Microsoft Corporation)
            Microsoft .NET Framework 4.5.1 Multi-Targeting Pack (HKLM-x32...{6A0C6700-EA93-372C-8871-DCCF13D160A4}) (Version: 4.5.50932 - Microsoft Corporation)
            Microsoft .NET Framework 4.5.1 SDK (HKLM-x32...{19A5926D-66E1-46FC-854D-163AA10A52D3}) (Version: 4.5.51641 - Microsoft Corporation)
            Microsoft .NET Framework 4.5.2 Multi-Targeting Pack (ENU) (HKLM-x32...{290FC320-2F5A-329E-8840-C4193BD7A9EE}) (Version: 4.5.51209 - Microsoft Corporation)
            Microsoft .NET Framework 4.5.2 Multi-Targeting Pack (HKLM-x32...{19E8AE59-4D4A-3534-B567-6CC08FA4102E}) (Version: 4.5.51651 - Microsoft Corporation)
            Microsoft .NET Framework 4.6 SDK (HKLM-x32...{B5915D37-0637-4A26-A3AA-C5DC9F856370}) (Version: 4.6.00081 - Microsoft Corporation)
            Microsoft .NET Framework 4.6 Targeting Pack (ENU) (HKLM-x32...{034547E9-D8FA-49E7-8B9C-4C9861FB9146}) (Version: 4.6.00127 - Microsoft Corporation)
            Microsoft .NET Framework 4.6 Targeting Pack (HKLM-x32...{2CC6A4A7-AAC2-46C9-9DBB-3727B5954F65}) (Version: 4.6.00081 - Microsoft Corporation)
            Microsoft .NET Framework 4.6.1 SDK (HKLM-x32...{2F0ECC80-B9E4-4485-8083-CD32F22ABD92}) (Version: 4.6.01055 - Microsoft Corporation)
            Microsoft .NET Framework 4.6.1 Targeting Pack (ENU) (HKLM-x32...{8EEB28EE-5141-411C-9CF0-9952264FE4AF}) (Version: 4.6.01055 - Microsoft Corporation)
            Microsoft .NET Framework 4.6.1 Targeting Pack (HKLM-x32...{8BC3EEC9-090F-4C53-A8DA-1BEC913040F9}) (Version: 4.6.01055 - Microsoft Corporation)
            Microsoft .NET Version Manager (x64) 1.0.0-beta5 (HKLM...{c5a4aba3-1aba-3ef8-b2d5-c3fa37f59738}) (Version: 1.0.10609.0 - Microsoft Corporation)
            Microsoft Help Viewer 2.2 (HKLM-x32...\Microsoft Help Viewer 2.2) (Version: 2.2.25420 - Microsoft Corporation)
            Microsoft Office Professional Plus 2016 (HKLM...\Office16.PROPLUS) (Version: 16.0.4266.1001 - Microsoft Corporation)
            Microsoft OneDrive (HKCU...\OneDriveSetup.exe) (Version: 17.3.6798.0207 - Microsoft Corporation)
            Microsoft Silverlight (HKLM-x32...{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.20513.0 - Microsoft Corporation)
            Microsoft SQL Server 2012 Command Line Utilities (HKLM...{9D573E71-1077-4C7E-B4DB-4E22A5D2B48B}) (Version: 11.0.2100.60 - Microsoft Corporation)
            Microsoft SQL Server 2012 Native Client (HKLM...{49D665A2-4C2A-476E-9AB8-FCC425F526FC}) (Version: 11.0.2100.60 - Microsoft Corporation)
            Microsoft SQL Server 2014 Management Objects (HKLM-x32...{2774595F-BC2A-4B12-A25B-0C37A37049B0}) (Version: 12.0.2000.8 - Microsoft Corporation)
            Microsoft SQL Server 2014 Management Objects (x64) (HKLM...{1F9EB3B6-AED7-4AA7-B8F1-8E314B74B2A5}) (Version: 12.0.2000.8 - Microsoft Corporation)
            Microsoft SQL Server 2014 Transact-SQL ScriptDom (HKLM...{020CDFE0-C127-4047-B571-37C82396B662}) (Version: 12.0.2000.8 - Microsoft Corporation)
            Microsoft SQL Server 2014 T-SQL Language Service (HKLM-x32...{47D08E7A-92A1-489B-B0BF-415516497BCE}) (Version: 12.0.2000.8 - Microsoft Corporation)
            Microsoft SQL Server 2016 LocalDB (HKLM...{E359515A-92E6-4FA3-A2C9-E1BA02D8DE6E}) (Version: 13.0.1601.5 - Microsoft Corporation)
            Microsoft SQL Server 2016 Management Objects (HKLM-x32...{0F1C8E2F-199A-4946-B3BF-0906DACFD032}) (Version: 13.0.1601.5 - Microsoft Corporation)
            Microsoft SQL Server 2016 Management Objects (x64) (HKLM...{20EA85AA-2A1D-4F11-B09F-4BA2BF3C8989}) (Version: 13.0.1601.5 - Microsoft Corporation)
            Microsoft SQL Server 2016 T-SQL Language Service (HKLM-x32...{8BFDE775-C5B8-46DB-84EF-43FFC8A2E8AD}) (Version: 13.0.14500.10 - Microsoft Corporation)
            Microsoft SQL Server 2016 T-SQL ScriptDom (HKLM...{D091DE8C-EA0F-49AF-8DE3-BD6C79737C6E}) (Version: 13.0.1601.5 - Microsoft Corporation)
            Microsoft SQL Server Compact 4.0 SP1 x64 ENU (HKLM...{78909610-D229-459C-A936-25D92283D3FD}) (Version: 4.0.8876.1 - Microsoft Corporation)
            Microsoft SQL Server Data Tools - enu (14.0.60519.0) (HKLM-x32...{4E27B0EF-7BAB-432A-AF3D-3FC8F3F7353F}) (Version: 14.0.60519.0 - Microsoft Corporation)
            Microsoft System CLR Types for SQL Server 2014 (HKLM...{FC3BB979-AA54-4B60-BBA3-2C4DA6E08D80}) (Version: 12.0.2402.29 - Microsoft Corporation)
            Microsoft System CLR Types for SQL Server 2014 (HKLM-x32...{091CE6AA-2753-4F6E-AD1C-0E875744EB54}) (Version: 12.0.2402.29 - Microsoft Corporation)
            Microsoft System CLR Types for SQL Server 2016 (HKLM...{96EB5054-C775-4BEF-B7B9-AA96A295EDCD}) (Version: 13.0.1601.5 - Microsoft Corporation)
            Microsoft System CLR Types for SQL Server 2016 (HKLM-x32...{84C23ECA-FE4D-494F-9247-3EBAD57E7F0C}) (Version: 13.0.1601.5 - Microsoft Corporation)
            Microsoft Visual C++ 2005 Redistributable (HKLM-x32...{7299052b-02a4-4627-81f2-1818da5d550d}) (Version: 8.0.56336 - Microsoft Corporation)
            Microsoft Visual C++ 2005 Redistributable (HKLM-x32...{A49F249F-0C91-497F-86DF-B2585E8E76B7}) (Version: 8.0.50727.42 - Microsoft Corporation)
            Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}) (Version: 8.0.59192 - Microsoft Corporation)
            Microsoft Visual C++ 2010 Redistributable - x64 10.0.40219 (HKLM...{1D8E6291-B0D5-35EC-8441-6616F567A0F7}) (Version: 10.0.40219 - Microsoft Corporation)
            Microsoft Visual C++ 2010 Redistributable - x86 10.0.40219 (HKLM-x32...{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}) (Version: 10.0.40219 - Microsoft Corporation)
            Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 (HKLM-x32...{a1909659-0a08-4554-8af1-2175904903a1}) (Version: 11.0.60610.1 - Microsoft Corporation)
            Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610 (HKLM-x32...{95716cce-fc71-413f-8ad5-56c2892d4b3a}) (Version: 11.0.60610.1 - Microsoft Corporation)
            Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.21005 (HKLM-x32...{7f51bdb9-ee21-49ee-94d6-90afc321780e}) (Version: 12.0.21005.1 - Microsoft Corporation)
            Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.21005 (HKLM-x32...{ce085a78-074e-4823-8dc1-8a721b94b76d}) (Version: 12.0.21005.1 - Microsoft Corporation)
            Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24210 (HKLM-x32...{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}) (Version: 14.0.24210.0 - Microsoft Corporation)
            Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24215 (HKLM-x32...{d992c12e-cab2-426f-bde3-fb8c53950b0d}) (Version: 14.0.24215.1 - Microsoft Corporation)
            Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215 (HKLM-x32...{e2803110-78b3-4664-a479-3611a381656a}) (Version: 14.0.24215.1 - Microsoft Corporation)
            Microsoft Visual Studio Community 2015 with Updates (HKLM-x32...{79b486b9-c5f0-4096-a00c-8351f59587c2}) (Version: 14.0.25420.1 - Microsoft Corporation)
            Microsoft Web Deploy 3.6 (HKLM...{94E1227C-08A9-4962-B388-1F05D89AEA75}) (Version: 3.1238.1962 - Microsoft Corporation)
            Middle Earth - Shadow of Mordor (HKLM-x32...\Middle Earth - Shadow of Mordor_R.G. Mechanics_is1) (Version: - R.G. Mechanics, spider91)
            Minecraft (HKLM-x32...{1C16BCA3-EBC1-49F6-8623-8FBFB9CCC872}) (Version: 1.0.3.0 - Mojang)
            MSBuild/NuGet Integration 14.0 (x86) (HKLM-x32...{128C1654-3B9E-4959-8BFB-CE6F09C0A01D}) (Version: 14.0.25420 - Microsoft Corporation) Hidden
            Multi-Device Hybrid Apps using C# - Templates - ENU (HKLM-x32...{12D99739-FFD3-3761-8AA6-F929E0FE407E}) (Version: 14.0.23107 - Microsoft Corporation) Hidden
            My.com Game Center (HKCU...\MyComGames) (Version: 3.196 - My.com B.V.)
            Nexus Mod Manager (HKLM...\6af12c54-643b-4752-87d0-8335503010de_is1) (Version: 0.63.11 - Black Tree Gaming)
            Notepad++ (64-bit x64) (HKLM...\Notepad++) (Version: 7.2.2 - Notepad++ Team)
            NovaBench 3.0.4 (HKLM-x32...{88603FC0-6B3C-442D-981E-E3D49F083548}_is1) (Version: - Novawave Inc.)
            NVIDIA 3D Vision Controller Driver 369.04 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 369.04 - NVIDIA Corporation)
            NVIDIA 3D Vision Driver 381.65 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 381.65 - NVIDIA Corporation)
            NVIDIA GeForce Experience 3.4.0.70 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.4.0.70 - NVIDIA Corporation)
            NVIDIA Graphics Driver 381.65 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 381.65 - NVIDIA Corporation)
            NVIDIA HD Audio Driver 1.3.34.26 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.26 - NVIDIA Corporation)
            NVIDIA Miracast Virtual Audio 353.06 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Miracast.VirtualAudio) (Version: 353.06 - NVIDIA Corporation)
            NVIDIA PhysX System Software 9.17.0329 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.17.0329 - NVIDIA Corporation)
            NvNodejs (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs) (Version: 3.4.0.70 - NVIDIA Corporation) Hidden
            NvTelemetry (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetry) (Version: 2.4.5.0 - NVIDIA Corporation) Hidden
            NvvHci (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvvHci) (Version: 2.02.0.5 - NVIDIA Corporation) Hidden
            OBS Studio (HKLM-x32...\OBS Studio) (Version: 18.0.1 - OBS Project)
            Opera Stable 44.0.2510.1218 (HKLM-x32...\Opera 44.0.2510.1218) (Version: 44.0.2510.1218 - Opera Software)
            Origin (HKLM-x32...\Origin) (Version: 10.3.3.1921 - Electronic Arts, Inc.)
            Outils de vΓ©rification linguistique 2016 de Microsoft Office - FranΓ§ais (HKLM...{90160000-001F-040C-1000-0000000FF1CE}) (Version: 16.0.4266.1001 - Microsoft Corporation) Hidden
            Overwatch (HKLM-x32...\Overwatch) (Version: - Blizzard Entertainment)
            PlanetSide 2 (HKCU...\DG0-PlanetSide 2) (Version: - Sony Online Entertainment)
            Popcorn Time (HKLM-x32...\Popcorn Time_is1) (Version: 5.5.1.2 - Popcorn Time)
            PowerISO (HKLM-x32...\PowerISO) (Version: 6.7 - Power Software Ltd)
            PreEmptive Analytics Visual Studio Components (HKLM-x32...{436A18DD-5F2C-4B3C-985E-AD3C13B0CC25}) (Version: 1.2.5134.1 - PreEmptive Solutions) Hidden
            Prerequisites for SSDT (HKLM-x32...{21373064-AD95-48DB-A32E-0D9E08EF7355}) (Version: 12.0.2000.8 - Microsoft Corporation)
            Prerequisites for SSDT (HKLM-x32...{B7E94916-7AE6-4F7F-A377-7A410A42BA19}) (Version: 13.0.1601.5 - Microsoft Corporation)
            Realtek Ethernet Controller Driver (HKLM-x32...{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 8.25.108.2014 - Realtek)
            Realtek High Definition Audio Driver (HKLM-x32...{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.6873 - Realtek Semiconductor Corp.)
            ROBLOX Player for Tuf Tuf (HKCU...{373B1718-8CC5-4567-8EE2-9033AD08A680}) (Version: - ROBLOX Corporation)
            Rockstar Games Social Club (HKLM-x32...\Rockstar Games Social Club) (Version: 1.1.5.8 - Rockstar Games)
            Roslyn Language Services - x86 (HKLM-x32...{6970C7E1-F99D-388D-8903-DF8FCE677FED}) (Version: 14.0.25431 - Microsoft Corporation) Hidden
            Roslyn Language Services - x86 (HKLM-x32...{6C1985E7-E1C5-3A95-86EF-2C62465F15C3}) (Version: 14.0.23107 - Microsoft Corporation) Hidden
            SHIELD Streaming (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 7.1.0351 - NVIDIA Corporation) Hidden
            SHIELD Wireless Controller Driver (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController) (Version: 3.4.0.70 - NVIDIA Corporation) Hidden
            Skypeβ„’ 7.33 (HKLM-x32...{3B7E914A-93D5-4A29-92BB-AF8C3F66C431}) (Version: 7.33.104 - Skype Technologies S.A.)
            Spybot Anti-Beacon (HKLM-x32...{419A7FCF-93E1-474D-BFE9-987CF3F90C88}_is1) (Version: 1.6 - Safer-Networking Ltd.)
            Steam (HKLM-x32...\Steam) (Version: 2.10.91.91 - Valve Corporation)
            Team Explorer for Microsoft Visual Studio 2015 Update 3.1 (HKLM-x32...{7A95671A-759E-3B83-B763-4289D1D24D73}) (Version: 14.102.25619 - Microsoft) Hidden
            Team Fortress 2 (HKLM...\Steam App 440) (Version: - Valve)
            TeamViewer 12 (HKLM-x32...\TeamViewer) (Version: 12.0.71503 - TeamViewer)
            TERA (HKLM-x32...{A2F166A0-F031-4E27-A057-C69733219434}_is1) (Version: - Gameforge4d)
            Test Tools for Microsoft Visual Studio 2015 (HKLM-x32...{9EABBFE1-7EED-47D9-8FB8-21D7E4808057}) (Version: 14.0.23107 - Microsoft Corporation) Hidden
            The Elder Scrolls V Skyrim Special Edition (HKLM-x32...\The Elder Scrolls V Skyrim Special Edition_is1) (Version: - )
            The Witcher 3 - Wild Hunt (HKLM-x32...\1495134320_is1) (Version: 2.0.0.51 - GOG.com)
            TunnelBear (HKLM-x32...{3746419F-FD3C-42FD-8C44-4C3491CFE645}) (Version: 3.0.32.0 - TunnelBear) Hidden
            TunnelBear (HKLM-x32...{999c6f10-ce15-4dce-bc57-5c6c89b2af84}) (Version: 3.0.32.0 - TunnelBear)
            Tunngle (HKLM-x32...\Tunngle_is1) (Version: 5.8.8 - Tunngle.net GmbH)
            TypeScript Power Tool (HKLM-x32...{465ACA24-B8D6-4FEC-A42D-9EFCB92CD560}) (Version: 1.8.34.0 - Microsoft Corporation) Hidden
            TypeScript Tools for Microsoft Visual Studio 2015 (HKLM-x32...{BA5762C7-D35F-4725-A4BD-525854127018}) (Version: 1.8.36.0 - Microsoft Corporation) Hidden
            Update for (KB2504637) (HKLM-x32...{CFEF48A8-BFB8-3EAC-8BA5-DE4F8AA267CE}.KB2504637) (Version: 1 - Microsoft Corporation)
            Update for Skype for Business 2016 (KB3115268) 64-Bit Edition (HKLM...{90160000-0011-0000-1000-0000000FF1CE}Office16.PROPLUS{5D633E34-0FA8-4C3F-8A16-D1A6C33C7015}) (Version: - Microsoft)
            Update for Skype for Business 2016 (KB3115268) 64-Bit Edition (HKLM...{90160000-00C1-0000-1000-0000000FF1CE}Office16.PROPLUS{5D633E34-0FA8-4C3F-8A16-D1A6C33C7015}) (Version: - Microsoft)
            Update for Skype for Business 2016 (KB3115268) 64-Bit Edition (HKLM...{90160000-012B-0409-1000-0000000FF1CE}Office16.PROPLUS{5D633E34-0FA8-4C3F-8A16-D1A6C33C7015}) (Version: - Microsoft)
            Uplay (HKLM-x32...\Uplay) (Version: 26.0 - Ubisoft)
            Visual Studio 2012 x64 Redistributables (HKLM...{8C775E70-A791-4DA8-BCC3-6AB7136F4484}) (Version: 14.0.0.1 - AVG Technologies)
            Visual Studio 2012 x86 Redistributables (HKLM-x32...{98EFF19A-30AB-4E4B-B943-F06B1C63EBF8}) (Version: 14.0.0.1 - AVG Technologies CZ, s.r.o.)
            Visual Studio 2015 Update 3 (KB3022398) (HKLM-x32...{7a68448b-9cf2-4049-bd73-5875f1aa7ba2}) (Version: 14.0.25420 - Microsoft Corporation)
            VLC media player (HKLM-x32...\VLC media player) (Version: 2.2.4 - VideoLAN)
            VS Update core components (HKLM-x32...{B2918D01-1D89-34D3-87EF-A28121BC6EB7}) (Version: 14.0.25431 - Microsoft Corporation) Hidden
            vs_update3notification (HKLM-x32...{AB3DF932-C990-34D4-BF43-970F760DA3CD}) (Version: 14.0.25431 - Microsoft Corporation) Hidden
            Vulkan Run Time Libraries 1.0.42.1 (HKLM...\VulkanRT1.0.42.1) (Version: 1.0.42.1 - LunarG, Inc.)
            War Thunder (HKLM...\Steam App 236390) (Version: - Gaijin Entertainment)
            Warface (HKLM...\Steam App 291480) (Version: - Crytek)
            Warface My.Com (HKCU...\Warface My.Com) (Version: 1.31 - My.com B.V.)
            WCF Data Services 5.6.4 Runtime (HKLM-x32...{DB85E7BD-B2DD-43D4-B3C0-23D7B527B597}) (Version: 5.6.62175.4 - Microsoft Corporation) Hidden
            WCF Data Services Tools for Microsoft Visual Studio 2015 (HKLM-x32...{0A3B508E-5638-4471-BCC9-954E1868CB86}) (Version: 5.6.62175.4 - Microsoft Corporation) Hidden
            WinRAR 5.40 (64-bit) (HKLM...\WinRAR archiver) (Version: 5.40.0 - win.rar GmbH)
            XFast LAN v9.05 (HKLM...\XFast LAN) (Version: 9.05 - cFos Software GmbH, Bonn)
            Zemana AntiMalware (HKLM-x32...{8F0CD7D1-42F3-4195-95CD-833578D45057}_is1) (Version: 2.72.101 - Zemana Ltd.)
            Name: TunnelBear Adapter V9
            Description: TunnelBear Adapter V9
            Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
            Manufacturer: TunnelBear Provider V9
            Service: tap-tb-0901
            Device ID: ROOT\NET\0000
            Problem: : This device is disabled. (Code 22)
            Resolution: In Device Manager, click β€œAction”, and then click β€œEnable Device”. This starts the Enable Device wizard. Follow the instructions.
            Percentage of memory in use: 52%
            Total physical RAM: 8131.8 MB
            Available physical RAM: 3871.69 MB
            Total Virtual: 9539.8 MB
            Available Virtual: 4433.05 MB
            1 Drive c: () (Fixed) (Total:223.13 GB) (Free:68.76 GB) NTFS
            3 Drive e: (New Volume) (Fixed) (Total:931.02 GB) (Free:589.86 GB) NTFS
            User accounts for \DESKTOP-HFQ2I7A
            Tuf Tuf
            **** End of log ****
            Logfile of HiJackThis Fork (Alpha) by Alex Dragokas v.2.6.4.17
            Platform: x64 Windows 10 (Pro), 10.0.14393 (ReleaseId: 1607), Service Pack: 0
            Time: 15.04.2017 - 01:23
            Language: OS: English (0x409). Display: English (0x409). Non-Unicode: Serbian (Latin) (0x241A)
            Elevated: Yes
            Ran by: Tuf Tuf (group: Administrator) on DESKTOP-HFQ2I7A
            Opera: 44.0.2510.1218
            Chrome: 57.0.2987.133
            Edge: 11.0.14393.1066
            Internet Explorer: 11.0.14393.953
            Boot mode: Normal
            Running processes:
            Number | Path
            1 C:\Program Files (x86)\ASRock Utility\A-Tuning\Bin\IOMonitorSrv.exe
            1 C:\Program Files (x86)\Common Files\Steam\SteamService.exe
            1 C:\Program Files (x86)\Everything\Everything.exe
            9 C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
            1 C:\Program Files (x86)\Google\Update\1.3.33.3\GoogleCrashHandler.ex e
            1 C:\Program Files (x86)\Google\Update\1.3.33.3\GoogleCrashHandler64. exe
            1 C:\Program Files (x86)\Gyazo\GyStation.exe
            1 C:\Program Files (x86)\IObit\LiveUpdate\LiveUpdate.exe
            1 C:\Program Files (x86)\LogMeIn Hamachi\x64\LMIGuardianSvc.exe
            1 C:\Program Files (x86)\LogMeIn Hamachi\x64\hamachi-2.exe
            2 C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe
            1 C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
            1 C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
            1 C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
            1 C:\Program Files (x86)\Origin\OriginWebHelperService.exe
            1 C:\Program Files (x86)\Steam\Steam.exe
            3 C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe
            2 C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe
            1 C:\Program Files\ASRock\XFast LAN\spd.exe
            1 C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
            1 C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
            1 C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe
            1 C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe
            1 C:\Program Files\Microsoft SQL Server\90\Shared\sqlwriter.exe
            2 C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe
            1 C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
            1 C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
            1 C:\Program Files\NVIDIA Corporation\ShadowPlay\nvspcaps64.exe
            1 C:\Program Files\NVIDIA Corporation\ShadowPlay\nvsphelper64.exe
            1 C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe
            1 C:\Program Files\Windows Defender\MSASCuiL.exe
            1 C:\Program Files\Windows Defender\MsMpEng.exe
            1 C:\Program Files\Windows Defender\NisSrv.exe
            1 C:\Program Files\WindowsApps\Microsoft.SkypeApp_11.13.133.0_x 64__kzf8qxf38zg5c\SkypeHost.exe
            1 C:\Program Files\WindowsApps\Microsoft.Windows.Photos_17.313. 10010.0_x64__8wekyb3d8bbwe\Microsoft.Photos.exe
            1 C:\Users\Tuf Tuf\AppData\Local\FluxSoftware\Flux\flux.exe
            1 C:\Users\Tuf Tuf\Desktop\HiJackThis.exe
            1 C:\Windows\ImmersiveControlPanel\SystemSettings.ex e
            1 C:\Windows\System32\ApplicationFrameHost.exe
            1 C:\Windows\System32\RuntimeBroker.exe
            1 C:\Windows\System32\SearchFilterHost.exe
            1 C:\Windows\System32\SearchIndexer.exe
            1 C:\Windows\System32\SearchProtocolHost.exe
            1 C:\Windows\System32\SystemSettingsBroker.exe
            1 C:\Windows\System32\WUDFHost.exe
            1 C:\Windows\System32\audiodg.exe
            1 C:\Windows\System32\conhost.exe
            2 C:\Windows\System32\csrss.exe
            1 C:\Windows\System32\dllhost.exe
            1 C:\Windows\System32\dwm.exe
            1 C:\Windows\System32\fontdrvhost.exe
            1 C:\Windows\System32\lsass.exe
            1 C:\Windows\System32\services.exe
            1 C:\Windows\System32\sihost.exe
            1 C:\Windows\System32\smss.exe
            1 C:\Windows\System32\spoolsv.exe
            14 C:\Windows\System32\svchost.exe
            1 C:\Windows\System32\taskhostw.exe
            1 C:\Windows\System32\wininit.exe
            1 C:\Windows\System32\winlogon.exe
            1 C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\SearchUI.exe
            1 C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2t xyewy\ShellExperienceHost.exe
            1 C:\Windows\explorer.exe
            R4 - HKCU\Software\Microsoft\Internet Explorer\SearchScopes: DefaultScope = {6A1806CD-94D4-4689-BA73-E35EA1EA9990} - Google - Google {searchTerms}&rls=com.microsoft:{language}:{referr er:source?}&ie={inputEncoding}&oe={outputEncoding} &sourceid=ie7
            R4 - HKCU\Software\Microsoft\Internet Explorer\SearchScopes{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: SuggestionsURL = http://api.bing.com/qsml.aspx?query= {searchTerms}&maxwidth={ie:maxWidth}&rowheight={ie :rowHeight}&sectionHeight={ie:sectionHeight}&FORM= IESS02&market={language}
            R4 - HKCU\Software\Microsoft\Internet Explorer\SearchScopes{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: SuggestionsURLFallback = http://api.bing.com/qsml.aspx?query= {searchTerms}&maxwidth={ie:maxWidth}&rowheight={ie :rowHeight}&sectionHeight={ie:sectionHeight}&FORM= IESS02&market={language}
            R4 - HKCU\Software\Microsoft\Internet Explorer\SearchScopes{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: URL = Search - Microsoft Bing {searchTerms}&src=IE-SearchBox&FORM=IESR02
            R4 - HKCU\Software\Microsoft\Internet Explorer\SearchScopes{6A1806CD-94D4-4689-BA73-E35EA1EA9990} - Google - Google {searchTerms}&rls=com.microsoft:{language}:{referr er:source?}&ie={inputEncoding}&oe={outputEncoding} &sourceid=ie7
            R4 - HKLM\Software\Microsoft\Internet Explorer\SearchScopes: DefaultScope = {6A1806CD-94D4-4689-BA73-E35EA1EA9990} - Google - Google {searchTerms}&rls=com.microsoft:{language}:{referr er:source?}&ie={inputEncoding}&oe={outputEncoding} &sourceid=ie7
            R4 - HKLM\Software\Microsoft\Internet Explorer\SearchScopes{6A1806CD-94D4-4689-BA73-E35EA1EA9990} - Google - Google {searchTerms}&rls=com.microsoft:{language}:{referr er:source?}&ie={inputEncoding}&oe={outputEncoding} &sourceid=ie7
            O4 - Global User Startup: GIGABYTE OC_GURU.lnk β†’ C:\Program Files (x86)\GIGABYTE\GIGABYTE OC_GURU II\OC_GURU.exe
            O4 - HKCU..\Run: [Gyazo] C:\Program Files (x86)\Gyazo\GyStation.exe
            O4 - HKCU..\Run: [Steam] C:\Program Files (x86)\Steam\steam.exe -silent
            O4 - HKCU..\Run: [f.lux] C:\Users\Tuf Tuf\AppData\Local\FluxSoftware\Flux\flux.exe /noshow
            O4 - HKLM..\Run: [IAStorIcon] C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIconLaunch.exe β€œC:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe” 60
            O4 - HKLM..\Run: [Malwarebytes TrayApp] C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\mbamtray.exe
            O4 - HKLM..\Run: [RTHDVCPL] C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe -s
            O4 - HKLM..\Run: [ShadowPlay] C:\WINDOWS\system32\rundll32.exe C:\WINDOWS\system32\nvspcap64.dll,ShadowPlayOnSyst emStart
            O4 - HKLM..\Run: [WindowsDefender] C:\Program Files\Windows Defender\MSASCuiL.exe
            O4 - HKLM..\Run: [ZAM] C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe /minimized
            O4 - HKLM..\StartupApproved\Run32: [Everything] (2017/02/21)C:\Program Files (x86)\Everything\Everything.exe -startup
            O4 - HKU\S-1-5-19..\Run: [OneDriveSetup] C:\Windows\SysWOW64\OneDriveSetup.exe /thfirstsetup
            O4 - HKU\S-1-5-20..\Run: [OneDriveSetup] C:\Windows\SysWOW64\OneDriveSetup.exe /thfirstsetup
            O8 - Extra context menu item: E&xport to Microsoft Excel - C:\Program Files\Microsoft Office\Office16\EXCEL.EXE
            O8 - Extra context menu item: Se&nd to OneNote - C:\Program Files\Microsoft Office\Office16\ONBttnIE.dll
            O9 - Extra β€˜Tools’ menuitem: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files\Microsoft Office\Office16\ONBttnIELinkedNotes.dll (HKLM)
            O9 - Extra β€˜Tools’ menuitem: Se&nd to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office16\ONBttnIE.dll (HKLM)
            O9 - Extra button: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files\Microsoft Office\Office16\ONBttnIELinkedNotes.dll (HKLM)
            O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office16\ONBttnIE.dll (HKLM)
            O9-32 - Extra β€˜Tools’ menuitem: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office16\ONBttnIELinkedNotes.dll (HKLM)
            O9-32 - Extra β€˜Tools’ menuitem: Se&nd to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office16\ONBttnIE.dll (HKLM)
            O9-32 - Extra button: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office16\ONBttnIELinkedNotes.dll (HKLM)
            O9-32 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office16\ONBttnIE.dll (HKLM)
            O17 - HKLM\System\CSS\Services\Tcpip..{6acb4502-f8d6-4a8b-abee-2c7aba76975a}: NameServer = 192.168.0.1
            O17 - HKLM\System\CSS\Services\Tcpip..{6acb4502-f8d6-4a8b-abee-2c7aba76975a}: NameServer = 8.8.4.4
            O17 - HKLM\System\CSS\Services\Tcpip..{6acb4502-f8d6-4a8b-abee-2c7aba76975a}: NameServer = 8.8.8.8
            O17 - HKLM\System\CSS\Services\Tcpip..{96bdcc5c-fd56-4f15-a64d-7ccb98737bbc}: NameServer = 8.8.4.4
            O17 - HKLM\System\CSS\Services\Tcpip..{96bdcc5c-fd56-4f15-a64d-7ccb98737bbc}: NameServer = 8.8.8.8
            O17 - HKLM\System\CSS\Services\Tcpip..{c41cee96-4161-4c19-93e7-d970877c773c}: NameServer = 25.0.0.1
            O17 - HKLM\System\CSS\Services\Tcpip..{c41cee96-4161-4c19-93e7-d970877c773c}: NameServer = 8.8.4.4
            O17 - HKLM\System\CSS\Services\Tcpip..{c41cee96-4161-4c19-93e7-d970877c773c}: NameServer = 8.8.8.8
            O17 - HKLM\System\ControlSet001\Services\Tcpip..{6acb450 2-f8d6-4a8b-abee-2c7aba76975a}: NameServer = 192.168.0.1
            O17 - HKLM\System\ControlSet001\Services\Tcpip..{6acb450 2-f8d6-4a8b-abee-2c7aba76975a}: NameServer = 8.8.4.4
            O17 - HKLM\System\ControlSet001\Services\Tcpip..{6acb450 2-f8d6-4a8b-abee-2c7aba76975a}: NameServer = 8.8.8.8
            O17 - HKLM\System\ControlSet001\Services\Tcpip..{96bdcc5 c-fd56-4f15-a64d-7ccb98737bbc}: NameServer = 8.8.4.4
            O17 - HKLM\System\ControlSet001\Services\Tcpip..{96bdcc5 c-fd56-4f15-a64d-7ccb98737bbc}: NameServer = 8.8.8.8
            O17 - HKLM\System\ControlSet001\Services\Tcpip..{c41cee9 6-4161-4c19-93e7-d970877c773c}: NameServer = 25.0.0.1
            O17 - HKLM\System\ControlSet001\Services\Tcpip..{c41cee9 6-4161-4c19-93e7-d970877c773c}: NameServer = 8.8.4.4
            O17 - HKLM\System\ControlSet001\Services\Tcpip..{c41cee9 6-4161-4c19-93e7-d970877c773c}: NameServer = 8.8.8.8
            O17 - HKLM\System\ControlSet002\Services\Tcpip..{6ACB450 2-F8D6-4A8B-ABEE-2C7ABA76975A}: NameServer = 192.168.0.1
            O17 - HKLM\System\ControlSet002\Services\Tcpip..{6ACB450 2-F8D6-4A8B-ABEE-2C7ABA76975A}: NameServer = 8.8.4.4
            O17 - HKLM\System\ControlSet002\Services\Tcpip..{6ACB450 2-F8D6-4A8B-ABEE-2C7ABA76975A}: NameServer = 8.8.8.8
            O17 - HKLM\System\ControlSet002\Services\Tcpip..{96BDCC5 C-FD56-4F15-A64D-7CCB98737BBC}: NameServer = 8.8.4.4
            O17 - HKLM\System\ControlSet002\Services\Tcpip..{96BDCC5 C-FD56-4F15-A64D-7CCB98737BBC}: NameServer = 8.8.8.8
            O17 - HKLM\System\ControlSet002\Services\Tcpip..{C41CEE9 6-4161-4C19-93E7-D970877C773C}: NameServer = 25.0.0.1
            O17 - HKLM\System\ControlSet002\Services\Tcpip..{C41CEE9 6-4161-4C19-93E7-D970877C773C}: NameServer = 8.8.4.4
            O17 - HKLM\System\ControlSet002\Services\Tcpip..{C41CEE9 6-4161-4C19-93E7-D970877C773C}: NameServer = 8.8.8.8
            O18 - Filter hijack: text/xml - {807583E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\Microsoft Shared\OFFICE16\MSOXMLMF.DLL
            O18 - Protocol: mso-minsb.16 - {3459B272-CC19-4448-86C9-DDC3B4B2FAD3} - C:\Program Files\Microsoft Office\Office16\MSOSB.DLL
            O18 - Protocol: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files\Microsoft Office\Office16\MSOSB.DLL
            O22 - Task (Disabled): \Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser - C:\WINDOWS\system32\compattelrunner.exe
            O22 - Task (Disabled): \Microsoft\Windows\Application Experience\ProgramDataUpdater - C:\WINDOWS\system32\compattelrunner.exe -maintenance
            O22 - Task (Ready): Adobe Flash Player PPAPI Notifier - C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_25_ 0_0_148_pepper.exe -check pepperplugin
            O22 - Task (Ready): Adobe Flash Player Updater - C:\WINDOWS\SysWoW64\Macromed\Flash\FlashPlayerUpda teService.exe
            O22 - Task (Ready): GoogleUpdateTaskMachineCore - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe /c
            O22 - Task (Ready): GoogleUpdateTaskMachineUA - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe /ua /installsource scheduler
            O22 - Task (Ready): GyazoUpdateTaskMachine - C:\Program Files (x86)\Gyazo\GyazoUpdate.exe
            O22 - Task (Ready): GyazoUpdateTaskMachineDaily - C:\Program Files (x86)\Gyazo\GyazoUpdate.exe
            O22 - Task (Ready): NvDriverUpdateCheckDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe -d β€œC:\Program Files\NVIDIA Corporation\NvDriverUpdateCheck” -l 3 -f C:\ProgramData\NVIDIA\NvContainerDriverUpdateCheck .log
            O22 - Task (Ready): NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files (x86)\NVIDIA Corporation\NvNode\nvnodejslauncher.exe --launcher=TaskScheduler
            O22 - Task (Ready): NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe
            O22 - Task (Ready): NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe
            O22 - Task (Ready): NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmMon.exe
            O22 - Task (Ready): NvTmRepOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe --logon
            O22 - Task (Ready): NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe
            O22 - Task (Ready): Opera scheduled Autoupdate 1492187757 - C:\Program Files\Opera\launcher.exe --scheduledautoupdate $(Arg0)
            O22 - Task (Ready): \AVAST Software\Avast settings backup - C:\Program Files\Common Files\AV\avast! Antivirus\backup.exe /backup /iavs (file missing)
            O22 - Task (Ready): \Microsoft\Office\Office 15 Subscription Heartbeat - C:\Program Files\Common Files\Microsoft Shared\Office16\OLicenseHeartbeat.exe
            O23 - Service R2: ASRock IO Monitor Service - (ASRockIOMon) - C:\Program Files (x86)\ASRock Utility\A-Tuning\Bin\IOMonitorSrv.exe
            O23 - Service R2: Everything - C:\Program Files (x86)\Everything\Everything.exe
            O23 - Service R2: Intel(R) Rapid Storage Technology - (IAStorDataMgrSvc) - C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
            O23 - Service R2: LiveUpdate - (LiveUpdateSvc) - C:\Program Files (x86)\IObit\LiveUpdate\LiveUpdate.exe
            O23 - Service R2: LogMeIn Hamachi Tunneling Engine - (Hamachi2Svc) - C:\Program Files (x86)\LogMeIn Hamachi\x64\hamachi-2.exe
            O23 - Service R2: Malwarebytes Service - (MBAMService) - C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe
            O23 - Service R2: NVIDIA Display Container LS - (NVDisplay.ContainerLocalSystem) - C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe
            O23 - Service R2: NVIDIA LocalSystem Container - (NvContainerLocalSystem) - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
            O23 - Service R2: NVIDIA Telemetry Container - (NvTelemetryContainer) - C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
            O23 - Service R2: Origin Web Helper Service - C:\Program Files (x86)\Origin\OriginWebHelperService.exe
            O23 - Service R2: Windows Defender Service - (WinDefend) - C:\Program Files\Windows Defender\MsMpEng.exe
            O23 - Service R2: ZAM Controller Service - (ZAMSvc) - C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe
            O23 - Service R2: cFosSpeed System Service - (cFosSpeedS) - C:\Program Files\ASRock\XFast LAN\spd.exe
            O23 - Service R3: LMIGuardianSvc - C:\Program Files (x86)\LogMeIn Hamachi\x64\LMIGuardianSvc.exe
            O23 - Service R3: Steam Client Service - C:\Program Files (x86)\Common Files\Steam\SteamService.exe
            O23 - Service R3: Windows Defender Network Inspection Service - (WdNisSvc) - C:\Program Files\Windows Defender\NisSrv.exe
            O23 - Service S2: Google Update Service (gupdate) - (gupdate) - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
            O23 - Service S3: Adobe Flash Player Update Service - (AdobeFlashPlayerUpdateSvc) - C:\WINDOWS\SysWoW64\Macromed\Flash\FlashPlayerUpda teService.exe
            O23 - Service S3: BattlEye Service - (BEService) - C:\Program Files (x86)\Common Files\BattlEye\BEService.exe
            O23 - Service S3: EasyAntiCheat - C:\WINDOWS\SysWow64\EasyAntiCheat.exe
            O23 - Service S3: Google Update Service (gupdatem) - (gupdatem) - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
            O23 - Service S3: InstallDriver Table Manager - (IDriverT) - C:\Program Files (x86)\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe
            O23 - Service S3: Intel(R) Integrated Clock Controller Service - Intel(R) ICCS - (ICCS) - C:\Program Files (x86)\Intel\Intel(R) Integrated Clock Controller Service\ICCProxy.exe
            O23 - Service S3: NVIDIA NetworkService Container - (NvContainerNetworkService) - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
            O23 - Service S3: Origin Client Service - C:\Program Files (x86)\Origin\OriginClientService.exe
            O23 - Service S3: TeamViewer 12 - (TeamViewer) - C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
            O23 - Service S3: TunnelBear Maintenance - (TunnelBearMaintenance) - C:\Program Files (x86)\TunnelBear\TBear.Maintenance.exe
            O23 - Service S3: TunngleService - C:\Program Files (x86)\Tunngle\TnglCtrl.exe
            End of file - Time spent: 7 sec. - 35838 bytes, CRC32: FFFFFFFF. Sign: ḩ憻
            • Malnutrition
              PCHF Moderator
              • 7041
              Step 1: Download and run the Iobit Removal Tool
              Step 2: Create and run batch file.
              Open a notepad and copy the entire content of the code box below.
              Paste the txt into the notepad. Save the file to your desktop as InternetFlush.bat
              Now you will right click the on InternetFlush.bat and run as administrator.
              Note: If you are using a third party firewall – you will want to leave out the top two lines of the script.
              At the end of the batch file there will be a prompt to
              Warning: This batch file will reboot your machine when complete! Save all work prior to running!!
              [ICODE]netsh advfirewall reset netsh advfirewall set allprofiles state ON ipconfig /flushdns netsh winsock reset catalog netsh int ip reset c:\resetlog.txt ipconfig /release ipconfig /renew netsh int ipv4 reset netsh int ipv6 reset bitsadmin /reset /allusers reg delete HKLM\SOFTWARE\Policies\Microsoft\Windows\IPSec\Pol icy\Local /f reg add HKLM\SOFTWARE\Policies\Microsoft\Windows\IPSec\Pol icy\Local /f netsh interface ipv6 6to4 set state state=disabled undoonstop=disabled netsh interface ipv6 isatap set state state=disabled netsh interface teredo set state disabled netsh interface tcp set global autotuning=disabled reg add hklm\system\currentcontrolset\services\tcpip6\para meters /v DisabledComponents /t REG_DWORD /d 0xFFFFFFFF for /F "tokens=*" %%a in ('wevtutil.exe el') DO wevtutil.exe cl "%%a" shutdown -r[/ICODE]
              Step 3: Hijack This Fix.
              Start HijackThis , Right Click Run as Admin.
              Click System Scan Only.
              Now click on fix checked.
              After the machine reboots, please tell me what issues remain,.
              • srkzzzi
                • Feb 2017
                • 22
                I’ve removed the startup programs and everything is working fine now, any other recommendation concerning safety and pc performance?
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  Let’s have a quick look at your system before I send you off…
                  ZHP Diag Scan
                  Download ZHP Diag to your desktop.
                  1. Right Click Run as Admin.
                    2. Click the Scanner button.
                  A notepad will open… copy and paste the report in your next reply.
                  • srkzzzi
                    • Feb 2017
                    • 22
                    #10
                    the download button isnt working, the file doesn’t start downloading, just refreshes the page.
                    • Malnutrition
                      PCHF Moderator
                      • 7041
                      #11
                      Uploaded for you.
                      • srkzzzi
                        • Feb 2017
                        • 22
                        #12
                        There seems to be a problem
                        • srkzzzi
                          • Feb 2017
                          • 22
                          #13
                          [RΓ©solu] ZHPDiag : Message d'erreur Γ  74 % - Nicolas Coolman
                          Tried using this fix but it’s still showing the same error.
                          • Malnutrition
                            PCHF Moderator
                            • 7041
                            #14
                            Quick Diag Scan.
                            Download Quick Diag to your desktop.
                            Very Important!! – Make sure program is on your desktop.
                            Disable your Antivirus/Antispyware prior to scanning.
                            Right Click Run as Administrator.
                            Select the Quick Scan.
                            Post the log that is generated in your next post.
                            • srkzzzi
                              • Feb 2017
                              • 22
                              #15
                              Here’s the log
