Intermittent connection hanging + other issues
  • jfmamjjasond
    • Dec 2016
    • 20
    #31
    I haven’t had a total drop-out recently but I still have the intermittent lag every minute or so.
    • jmarket
      PCHF Owner
      • 7695
      • CachyOS
      • Intel Arc A770 (16 GB)
      #32
      Are you by any chance running the latest windows 10 update? Everyone is having Internet issues with it
      Sent from my SM-G935T using Tapatalk
      • jmarket
        PCHF Owner
        • 7695
        • CachyOS
        #33
        Also try resetting your hosts file to the default. How to reset the Hosts file back to the default - Microsoft Support
        • jfmamjjasond
          • Dec 2016
          • 20
          #34
          Yes but I’ve had these issues for many months. I just did the hosts reset.
          • jfmamjjasond
            • Dec 2016
            • 20
            #35
            So I still have the exact same issues. The lag, and my net dropped out tonight too. “No internet connection, DNS probe started”
            • Rustys
              • 7862
              #36
              Go ahead and rerun the Minitoolbox again here are this instruction if you need them again. So we can see where we are at.
              Flush DNS
              Report IE Proxy Settings
              Reset IE Proxy Settings
              Report FF Proxy Settings
              Reset FF Proxy Settings
              List content of Hosts
              List IP Configuration
              List Winsock Entries
              List Installed Programs
              List Devices (Only Problems)
              Please COPY and PASTE the log in your next reply
              • jfmamjjasond
                • Dec 2016
                • 20
                #37
                Ran by Jason (administrator) on 18-12-2016 at 21:17:01
                Running from “C:\Users\Jason\Downloads”
                Microsoft Windows 10 Pro (X64)
                Model: To be filled by O.E.M. Manufacturer: Gigabyte Technology Co., Ltd.
                Boot Mode: Normal
                Windows IP Configuration
                Proxy is not enabled.
                No Proxy Server is set.
                “Reset IE Proxy Settings”: IE Proxy Settings were reset.
                Hosts file not detected in the default directory
                Realtek RTL8192CU Wireless LAN 802.11n USB 2.0 Network Adapter = Wi-Fi (Connected)
                Xbox Wireless Adapter for Windows = Ethernet 3 (Connected)
                Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30) = Ethernet (Media disconnected)
                [HEADING=1]----------------------------------[/HEADING]
                [HEADING=1]IPv4 Configuration[/HEADING]
                pushd interface ipv4
                reset
                popd
                [HEADING=1]End of IPv4 configuration[/HEADING]
                Host Name . . . . . . . . . . . . : JASONSBIGPC
                DNS Suffix Search List. . . . . . : telstra.com.au
                Ethernet adapter Ethernet:
                Description . . . . . . . . . . . : This Qualcomm Atheros network Controller connects you to the network.
                Physical Address. . . . . . . . . : 90-2B-34-32-A2-FD
                Wireless LAN adapter Local Area Connection* 2:
                Physical Address. . . . . . . . . : E8-DE-27-A2-72-4A
                Wireless LAN adapter Wi-Fi:
                Connection-specific DNS Suffix . : telstra.com.au
                Description . . . . . . . . . . . : Realtek RTL8192CU Wireless LAN 802.11n USB 2.0 Network Adapter
                Link-local IPv6 Address . . . . . : fe80::ecce:9db6:f9f8:b36a%4(Preferred)
                IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
                Lease Obtained. . . . . . . . . . : Sunday, 18 December 2016 9:03:32 PM
                Lease Expires . . . . . . . . . . : Sunday, 18 December 2016 10:03:31 PM
                DHCPv6 IAID . . . . . . . . . . . : 233365031
                DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-C7-A3-52-90-2B-34-32-A2-FD
                DNS Servers . . . . . . . . . . . : 8.8.8.8
                8.8.4.4
                Tunnel adapter isatap.telstra.com.au:
                Tunnel adapter Teredo Tunneling Pseudo-Interface:
                Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
                IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:2005:1628:862e:7341(Preferred)
                Link-local IPv6 Address . . . . . : fe80::2005:1628:862e:7341%2(Preferred)
                Default Gateway . . . . . . . . . : ::
                DHCPv6 IAID . . . . . . . . . . . : 419430400
                Server: google-public-dns-a.google.com
                Address: 8.8.8.8
                Addresses: 2404:6800:4006:803::200e
                203.37.15.103
                203.37.15.104
                203.37.15.84
                203.37.15.123
                203.37.15.94
                203.37.15.89
                203.37.15.114
                203.37.15.108
                203.37.15.93
                203.37.15.113
                203.37.15.99
                203.37.15.109
                203.37.15.98
                203.37.15.88
                203.37.15.118
                203.37.15.119
                Pinging google.com [203.37.15.123] with 32 bytes of data:
                Reply from 203.37.15.123: bytes=32 time=11ms TTL=59
                Reply from 203.37.15.123: bytes=32 time=20ms TTL=59
                Ping statistics for 203.37.15.123:
                Minimum = 11ms, Maximum = 20ms, Average = 15ms
                Address: 8.8.8.8
                Addresses: 2001:4998:58:c02::a9
                2001:4998:44:204::a7
                2001:4998:c:a06::2:4008
                98.138.253.109
                98.139.183.24
                206.190.36.45
                Pinging yahoo.com [206.190.36.45] with 32 bytes of data:
                Reply from 206.190.36.45: bytes=32 time=327ms TTL=44
                Reply from 206.190.36.45: bytes=32 time=714ms TTL=44
                Ping statistics for 206.190.36.45:
                Minimum = 327ms, Maximum = 714ms, Average = 520ms
                [HEADING=1]Ping statistics for 127.0.0.1:
                Minimum = 0ms, Maximum = 0ms, Average = 0ms[/HEADING]
                [HEADING=1]Interface List
                15…90 2b 34 32 a2 fd …This Qualcomm Atheros network Controller connects you to the network.
                16…e8 de 27 a2 72 4a …Microsoft Wi-Fi Direct Virtual Adapter
                4…e8 de 27 a2 72 4a …Realtek RTL8192CU Wireless LAN 802.11n USB 2.0 Network Adapter
                1…Software Loopback Interface 1
                11…00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
                2…00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface[/HEADING]
                [HEADING=1]IPv4 Route Table[/HEADING]
                [HEADING=1]Active Routes:
                0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.2 50
                192.168.0.0 255.255.255.0 On-link 192.168.0.2 306
                192.168.0.2 255.255.255.255 On-link 192.168.0.2 306
                192.168.0.255 255.255.255.255 On-link 192.168.0.2 306
                224.0.0.0 240.0.0.0 On-link 192.168.0.2 306
                255.255.255.255 255.255.255.255 On-link 192.168.0.2 306[/HEADING]
                Persistent Routes:
                None
                [HEADING=1]IPv6 Route Table[/HEADING]
                2 331 ::/0 On-link
                1 331 ::1/128 On-link
                2 331 2001::/32 On-link
                2 331 2001:0:9d38:6ab8:2005:1628:862e:7341/128
                On-link
                4 306 fe80::/64 On-link
                2 331 fe80::/64 On-link
                2 331 fe80::2005:1628:862e:7341/128
                On-link
                4 306 fe80::ecce:9db6:f9f8:b36a/128
                On-link
                1 331 ff00::/8 On-link
                4 306 ff00::/8 On-link
                2 331 ff00::/8 On-link[/HEADING]
                Persistent Routes:
                None
                Catalog5 01 C:\WINDOWS\SysWoW64\napinsp.dll [55808] (Microsoft Corporation)
                Catalog5 02 C:\WINDOWS\SysWoW64\pnrpnsp.dll [70656] (Microsoft Corporation)
                Catalog5 03 C:\WINDOWS\SysWoW64\pnrpnsp.dll [70656] (Microsoft Corporation)
                Catalog5 04 C:\WINDOWS\SysWoW64\NLAapi.dll [65024] (Microsoft Corporation)
                Catalog5 05 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog5 06 C:\WINDOWS\SysWoW64\winrnr.dll [24064] (Microsoft Corporation)
                Catalog5 07 C:\Program Files (x86)\Bonjour\mdnsNSP.dll [122128] (Apple Inc.)
                Catalog9 01 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog9 02 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog9 03 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog9 04 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog9 05 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog9 06 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog9 07 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog9 08 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog9 09 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog9 10 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog9 11 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                Catalog9 12 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
                x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67584] (Microsoft Corporation)
                x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
                x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
                x64-Catalog5 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31744] (Microsoft Corporation)
                x64-Catalog5 07 C:\Program Files\Bonjour\mdnsNSP.dll [133392] (Apple Inc.)
                x64-Catalog9 01 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 02 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 03 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 04 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 06 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 07 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 08 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 09 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 10 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 11 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 12 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                Error: (12/18/2016 07:32:29 PM) (Source: Office 2016 Licensing Service) (User: )
                Description: Subscription licensing service failed: -2143485936
                Error: (12/18/2016 07:32:29 PM) (Source: Microsoft Office 16) (User: )
                Description: Office Subscription licensing exception: Error Code: 0x803D0010; CorrelationId: {2136DD94-2E07-43B2-996B-0F0BE8B0783B}
                Error: (12/17/2016 11:34:52 AM) (Source: Bonjour Service) (User: )
                Description: Client application bug: DNSServiceResolve(90:8d:6c:a8:e6:52@fe80::928d:6cf f:fea8:e652._apple-mobdev2._tcp.local.) active for over two minutes. This places considerable burden on the network.
                Error: (12/17/2016 11:32:20 AM) (Source: Bonjour Service) (User: )
                Description: ERROR: handle_resolve_request bad interfaceIndex 12
                Error: (12/17/2016 11:31:49 AM) (Source: Bonjour Service) (User: )
                Description: mDNSCoreReceiveResponse: Unexpected conflict discarding 19 1.0.0.127.in-addr.arpa. PTR JASONSBIGPC.local.
                Description: mDNSCoreReceiveResponse: Received from 127.0.0.1:5353 21 1.0.0.127.in-addr.arpa. PTR JASONSBIGPC-2.local.
                Error: (12/17/2016 02:28:49 AM) (Source: Microsoft-Windows-Immersive-Shell) (User: JASONSBIGPC)
                Description: Activation of app Microsoft.Windows.ContentDeliveryManager_cw5n1h2tx yewy!App failed with error: -2144927141 See the Microsoft-Windows-TWinUI/Operational log for additional information.
                Error: (12/14/2016 03:02:09 PM) (Source: Bonjour Service) (User: )
                Error: (12/13/2016 11:20:14 PM) (Source: Application Hang) (User: )
                Description: The program Discord.exe version 0.0.40.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
                Process ID: 2bcc
                Start Time: 01d25513c44da17a
                Termination Time: 4294967295
                Application Path: C:\Users\Jason\AppData\Local\Discord\app-0.0.296\Discord.exe
                Report Id: 7f317b85-c12e-11e6-8224-6245b4e8d744
                Faulting package full name:
                Error: (12/18/2016 09:17:03 PM) (Source: Microsoft-Windows-DNS-Client) (User: NT AUTHORITY)
                Description: There was an error while attempting to read the local hosts file.
                Error: (12/18/2016 08:34:58 PM) (Source: DCOM) (User: NT AUTHORITY)
                Description: {784E29F4-5EBE-4279-9948-1E8FE941646D}
                Error: (12/18/2016 08:31:58 PM) (Source: DCOM) (User: NT AUTHORITY)
                Description: application-specificLocalActivation{8D8F4F83-3594-4F07-8369-FC3C3CAE4919}{F72671A9-012C-4725-9D2F-2A4D32D65169}NT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
                Error: (12/18/2016 07:25:35 PM) (Source: Microsoft-Windows-DNS-Client) (User: NT AUTHORITY)
                Error: (12/18/2016 07:25:27 PM) (Source: Microsoft-Windows-DNS-Client) (User: NT AUTHORITY)
                Error: (12/17/2016 11:35:19 AM) (Source: Microsoft-Windows-DNS-Client) (User: NT AUTHORITY)
                Error: (12/17/2016 11:34:41 AM) (Source: DCOM) (User: NT AUTHORITY)
                Error: (12/17/2016 11:31:31 AM) (Source: DCOM) (User: NT AUTHORITY)
                Error: (12/17/2016 02:28:50 AM) (Source: DCOM) (User: JASONSBIGPC)
                Description: {4AA0A5C4-1B9B-4F2E-99D7-99C6AEC83474}
                Error: (12/17/2016 02:28:49 AM) (Source: DCOM) (User: JASONSBIGPC)
                [HEADING=1]Microsoft Office Sessions:[/HEADING]
                Error: (12/18/2016 07:32:29 PM) (Source: Office 2016 Licensing Service)(User: )
                Error: (12/18/2016 07:32:29 PM) (Source: Microsoft Office 16)(User: )
                Error: (12/17/2016 11:34:52 AM) (Source: Bonjour Service)(User: )
                Error: (12/17/2016 11:32:20 AM) (Source: Bonjour Service)(User: )
                Error: (12/17/2016 11:31:49 AM) (Source: Bonjour Service)(User: )
                Error: (12/17/2016 02:28:49 AM) (Source: Microsoft-Windows-Immersive-Shell)(User: JASONSBIGPC)
                Description: Microsoft.Windows.ContentDeliveryManager_cw5n1h2tx yewy!App-2144927141
                Error: (12/14/2016 03:02:09 PM) (Source: Bonjour Service)(User: )
                Error: (12/13/2016 11:20:14 PM) (Source: Application Hang)(User: )
                Description: Discord.exe0.0.40.02bcc01d25513c44da17a4294967295C :\Users\Jason\AppData\Local\Discord\app-0.0.296\Discord.exe7f317b85-c12e-11e6-8224-6245b4e8d744
                [HEADING=1]CodeIntegrity Errors:[/HEADING]
                Date: 2016-12-18 19:41:09.807
                Description: Code Integrity determined that a process (\Device\HarddiskVolume1\Program Files\Windows Defender\MsMpEng.exe) attempted to load \Device\HarddiskVolume1\Program Files\Microsoft Silverlight\xapauthenticodesip.dll that did not meet the Custom 3 / Antimalware signing level requirements.
                Date: 2016-12-18 19:41:09.805
                Date: 2016-12-18 19:41:09.803
                Date: 2016-12-18 19:41:00.527
                Date: 2016-12-18 19:41:00.498
                Date: 2016-12-18 19:26:39.388
                Date: 2016-12-18 19:26:39.386
                Date: 2016-12-18 19:26:39.382
                Date: 2016-12-17 12:54:04.455
                Date: 2016-12-17 12:54:04.454
                4Videosoft MKV Video Converter (HKLM-x32...\4Videosoft MKV Video Converter_is1) (Version: - )
                A Bird Story (HKLM...\Steam App 327410) (Version: - Freebird Games)
                ActivePerl 5.16.3 Build 1604 (64-bit) (HKLM...{A7915697-1675-433D-AD07-759E8550582F}) (Version: 5.16.1604 - ActiveState)
                Adobe Acrobat Reader DC (HKLM-x32...{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 15.020.20042 - Adobe Systems Incorporated)
                Adobe AIR (HKLM-x32...\Adobe AIR) (Version: 3.4.0.2540 - Adobe Systems Incorporated)
                Adobe Community Help (HKLM-x32...\chc.4875E02D9FB21EE389F73B8D1702B320485DF8C E.1) (Version: 3.4.980 - Adobe Systems Incorporated.)
                Adobe Flash Player 23 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 23.0.0.207 - Adobe Systems Incorporated)
                Adobe Shockwave Player 11.6 (HKLM-x32...\Adobe Shockwave Player) (Version: 11.6.6.636 - Adobe Systems, Inc.)
                Android Commander version 0.7.9.11 (HKLM-x32...\Android Commander_is1) (Version: 0.7.9.11 - )
                Ansel (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 376.33 - NVIDIA Corporation) Hidden
                Apple Application Support (32-bit) (HKLM-x32...{D079CAAD-0C31-47A2-9AF5-A82F9CD9B221}) (Version: 5.2 - Apple Inc.)
                Apple Application Support (64-bit) (HKLM...{64E6007B-1DA9-42CD-BBE4-D5FA67A7C71D}) (Version: 5.2 - Apple Inc.)
                Apple Mobile Device Support (HKLM...{55BB2110-FB43-49B3-93F4-945A0CFB0A6C}) (Version: 10.0.1.3 - Apple Inc.)
                Apple Software Update (HKLM-x32...{56EC47AA-5813-4FF6-8E75-544026FBEA83}) (Version: 2.2.0.150 - Apple Inc.)
                Assassins Creed IV Black Flag (HKLM-x32...\Uplay Install 273) (Version: - Ubisoft)
                AutoHotkey 1.1.22.09 (HKLM...\AutoHotkey) (Version: 1.1.22.09 - Lexikos)
                Battle.net (HKLM-x32...\Battle.net) (Version: - Blizzard Entertainment)
                BattleBlock Theater (HKLM-x32...\Steam App 238460) (Version: - The Behemoth)
                BioShock Remastered (HKLM...\Steam App 409710) (Version: - 2K Boston)
                BitMeter OS (HKLM-x32...\BitMeterOS) (Version: - )
                BitX (HKLM-x32...\BitX) (Version: 2.1.5 - )
                Bonjour (HKLM...{56DDDFB8-7F79-4480-89D5-25E1F52AB28F}) (Version: 3.1.0.1 - Apple Inc.)
                Brothers - A Tale of Two Sons (HKLM-x32...\Steam App 225080) (Version: - Starbreeze Studios AB)
                Camtasia Studio 8 (HKLM-x32...{2EB28256-1D66-49F1-AF66-691BF9A27C79}) (Version: 8.0.2.918 - TechSmith Corporation)
                Canon IJ Network Scanner Selector EX (HKLM-x32...\Canon_IJ_Network_Scanner_Selector_EX) (Version: - Canon Inc.)
                Canon IJ Network Tool (HKLM-x32...\Canon_IJ_Network_UTILITY) (Version: 3.2.0 - Canon Inc.)
                Canon IJ Scan Utility (HKLM-x32...\Canon_IJ_Scan_Utility) (Version: - Canon Inc.)
                Canon MP830 MP Drivers (HKLM...{0D25F7CC-B99C-44ee-9945-B14532B2BB7B}) (Version: - Canon Inc.)
                Canon MX720 series MP Drivers (HKLM...{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}_Canon_MX720_series) (Version: 1.00 - Canon Inc.)
                Cheat Engine 6.6 (HKLM-x32...\Cheat Engine 6.6_is1) (Version: - Cheat Engine)
                Chrome Remote Desktop Host (HKLM-x32...{D669DC52-B1A4-4933-878D-CB80F660D95D}) (Version: 55.0.2883.17 - Google Inc.)
                Content Manager Assistant for PlayStation(R) (HKLM-x32...{4AC85673-668B-4CC4-8800-D28E29B77A90}) (Version: 2.10.6402.20 - Sony Computer Entertainment Inc.)
                Counter-Strike: Global Offensive (HKLM-x32...\Steam App 730) (Version: - )
                CPUID CPU-Z 1.76 (HKLM...\CPUID CPU-Z_is1) (Version: - )
                Curse Client (HKCU...\101a9f93b8f0bb6f) (Version: 5.1.1.810 - Curse)
                D3DX10 (HKLM-x32...{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
                DARK SOULS III (HKLM...\Steam App 374320) (Version: - FromSoftware, Inc.)
                Dark Souls: Prepare to Die Edition (HKLM-x32...\Steam App 211420) (Version: - )
                Discord (HKCU...\Discord) (Version: 0.0.296 - Hammer & Chisel, Inc.)
                Dishonored 2 (HKLM...\Steam App 403640) (Version: - Arkane Studios)
                DisplayFusion (HKLM-x32...\Steam App 227260) (Version: - Binary Fortress Software)
                DisplayFusion 8.1.1 (HKLM-x32...\B076073A-5527-4f4f-B46B-B10692277DA2_is1) (Version: 8.1.1.0 - Binary Fortress Software)
                DivX Setup (HKLM-x32...\DivX Setup) (Version: 2.7.0.64 - DivX, LLC)
                Don’t Starve Together Beta (HKLM-x32...\Steam App 322330) (Version: - Klei Entertainment)
                Dota 2 (HKLM...\Steam App 570) (Version: - Valve)
                Droid Explorer 0.8.8.11 (x64) (HKLM...{5876342E-8D21-4ED6-AA03-549AB3170BC4}) (Version: 0.8.8.11 - Ryan Conrad)
                DS4Windows (HKLM-x32...{120A83BA-E2E4-4A67-9E53-C4C9213997E4}) (Version: 1.5.22.0 - DSDCS)
                DSSpectate (HKLM-x32...{2C5368A6-BFC0-4A63-904A-8C70DAB553EE}_is1) (Version: 1.2.0.0 - DSSpectate)
                DVD Shrink 3.2 (HKLM-x32...\DVD Shrink_is1) (Version: - DVD Shrink)
                DVDFab 8.2.0.8 (29/08/2012) Qt (HKLM-x32...\DVDFab 8 Qt_is1) (Version: - Fengtao Software Inc.)
                Dying Light (HKLM-x32...\Steam App 239140) (Version: - Techland)
                EndNote X7 (HKLM-x32...{86B3F2D6-AC2B-0017-8AE1-F2F77F781B0C}) (Version: 17.5.0.9325 - Thomson Reuters)
                EZ Setup B12.0509.01 (HKLM-x32...{DA6AF673-AD91-4AC7-B2F4-FE0C8A3A7E99}) (Version: 1.00.0000 - GIGABYTE)
                Ezvid (HKLM-x32...{F96D619D-99D6-4C9C-A393-0CD22DE1CA66}_is1) (Version: 0.8.9.5 - Ezvid, inc.)
                f.lux (HKCU...\Flux) (Version: - )
                Fallout 4 (HKLM-x32...\Steam App 377160) (Version: - Bethesda Game Studios)
                Far Cry 4 (HKLM-x32...\Uplay Install 420) (Version: - Ubisoft)
                Fiddler (HKLM-x32...\Fiddler2) (Version: 4.4.9.7 - Telerik)
                Flashtool (HKLM-x32...\Flashtool) (Version: 0.9.15.0 - Androxyde)
                Flawless Widescreen version 1.0.15 (HKLM-x32...{7348D82E-8C68-48FF-BA2D-8C97B5B4B3D8}_is1) (Version: 1.0.15 - Flawless Widescreen)
                Fraps (remove only) (HKLM-x32...\Fraps) (Version: - )
                Freemake Video Converter version 4.1.4 (HKLM-x32...\Freemake Video Converter_is1) (Version: 4.1.4 - Ellora Assets Corporation)
                GOG Galaxy (HKLM-x32...{7258BA11-600C-430E-A759-27E2C691A335}_is1) (Version: - GOG.com)
                Google Chrome (HKLM-x32...\Google Chrome) (Version: 56.0.2924.28 - Google Inc.)
                Google Update Helper (HKLM-x32...{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.32.7 - Google Inc.) Hidden
                Gpg4win (2.2.6) (HKLM-x32...\GPG4Win) (Version: 2.2.6 - The Gpg4win Project)
                GPU Temp version 1.0 (HKLM-x32...{8C8711FD-0FC8-4801-B33E-ED19BB0350B1}_is1) (Version: 1.0 - gputemp.com)
                Grand Theft Auto V (HKLM-x32...{E01FA564-2094-4833-8F2F-1FFEC6AFCC46}) (Version: “1.00.0000” - Rockstar Games)
                Half-Life 2 (HKLM-x32...\Steam App 220) (Version: - Valve)
                Half-Life 2: Lost Coast (HKLM-x32...\Steam App 340) (Version: - Valve)
                HandBrake 0.9.8 (HKLM-x32...\HandBrake) (Version: 0.9.8 - )
                Heroes of the Storm (HKLM-x32...\Heroes of the Storm) (Version: - Blizzard Entertainment)
                Hitman: Absolution (HKLM-x32...\Steam App 203140) (Version: - )
                ibb & obb (HKLM-x32...\Steam App 95400) (Version: - Sparpweed)
                iFunbox (v3.0.3109.1352) (HKLM-x32...\iFunbox_is1) (Version: v3.0.3109.1352 - iFunbox DevTeam)
                InfraRecorder 0.53 (x64 edition) (HKLM...{2C22EA92-CB30-4932-0053-000001000000}) (Version: 0.53.00.00 - Christian Kindahl)
                Inside (HKLM-x32...{9BD4503F-F711-491D-984A-AB4ABD66B8C2}_is1) (Version: - Playdead)
                Intel(R) Chipset Device Software (HKLM-x32...{619e726e-d2b4-4e28-9568-c964fd81ee6c}) (Version: 10.1.1.14 - Intel(R) Corporation) Hidden
                Intel(R) Driver Update Utility 2.5 (HKLM-x32...{8EF465B2-1D08-4CA2-8ACC-1911B573725D}) (Version: 2.5.0.22 - Intel) Hidden
                Intel(R) Product Improvement Program (HKLM-x32...{5859045D-9DED-4776-9930-C9461AB2FF12}) (Version: 2.1.27.3 - Intel) Hidden
                Intel(R) Rapid Start Technology (HKLM-x32...\3D073343-CEEB-4ce7-85AC-A69A7631B5D6) (Version: 1.0.0.1022 - Intel Corporation)
                Intel(R) Rapid Storage Technology (HKLM-x32...{3E29EE6C-963A-4aae-86C1-DC237C4A49FC}) (Version: 11.5.0.1207 - Intel Corporation)
                Intel® Driver Update Utility (HKLM-x32...{aa1dec3b-dc4b-4db0-8c18-9157457eff1f}) (Version: 2.5.0.22 - Intel)
                iTunes (HKLM...{81C96689-EA5B-4B7D-A04F-16326EC51BC2}) (Version: 12.5.4.42 - Apple Inc.)
                Java 8 Update 101 (HKLM-x32...{26A24AE4-039D-4CA4-87B4-2F32180101F0}) (Version: 8.0.1010.13 - Oracle Corporation)
                Java SE Development Kit 7 Update 6 (HKLM-x32...{32A3A4F4-B792-11D6-A78A-00B0D0170060}) (Version: 1.7.0.60 - Oracle)
                Java SE Development Kit 7 Update 7 (64-bit) (HKLM...{64A3A4F4-B792-11D6-A78A-00B0D0170070}) (Version: 1.7.0.70 - Oracle)
                Java SE Development Kit 7 Update 7 (HKLM-x32...{32A3A4F4-B792-11D6-A78A-00B0D0170070}) (Version: 1.7.0.70 - Oracle)
                JDiskReport 1.4.1 (HKLM-x32...\JDiskReport 1.4.1) (Version: 1.4.1 (2014-02-26 11:50:44) - JGoodies Karsten Lentzsch)
                Junk Mail filter update (HKLM-x32...{FECB76C1-1C1D-4A84-8D47-5754C74B5A5E}) (Version: 16.4.3503.0728 - Microsoft Corporation) Hidden
                Lagarith lossless video codec (Remove Only) (HKLM-x32...\LAGARITH) (Version: - )
                LG United Mobile Driver (HKLM-x32...{2A3A4BD6-6CE0-4e2a-80D2-1D0FF6ACBFBA}) (Version: 3.12.3.0 - LG Electronics)
                Life Is Strange™ (HKLM...\Steam App 319630) (Version: - DONTNOD Entertainment)
                LIMBO (HKLM-x32...\Steam App 48000) (Version: - )
                Macro Recorder 5.8.0 (HKLM-x32...\Macro Recorder_is1) (Version: 5.8.0 - Jitbit Software)
                Mark of the Ninja (HKLM-x32...\Steam App 214560) (Version: - )
                Max Payne 3 (HKLM-x32...\Steam App 204100) (Version: - Rockstar)
                Microsoft .NET Framework 4 Multi-Targeting Pack (HKLM-x32...{CFEF48A8-BFB8-3EAC-8BA5-DE4F8AA267CE}) (Version: 4.0.30319 - Microsoft Corporation)
                Microsoft ASP.NET MVC 4 Runtime (HKLM-x32...{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
                Microsoft Expression Blend 3 SDK (HKLM-x32...{256E7DAC-9BE8-494E-8DE7-7857BF96B774}) (Version: 1.0.1343.0 - Microsoft Corporation)
                Microsoft Expression Blend SDK for .NET 4 (HKLM-x32...{9B3A1C97-A361-463E-8817-444F9F88CDFE}) (Version: 2.0.20525.0 - Microsoft Corporation)
                Microsoft Expression Blend SDK for Silverlight 4 (HKLM-x32...{1C997E1C-5CE9-4AF3-AAA9-DC65E6090827}) (Version: 2.0.20525.0 - Microsoft Corporation)
                Microsoft Expression Encoder 4 (HKLM-x32...\Encoder_4.0.1639.0) (Version: 4.0.1639.0 - Microsoft Corporation)
                Microsoft Expression Encoder 4 Screen Capture Codec (HKLM-x32...{BF127B80-CFD5-4379-9752-E8AF1A5D0141}) (Version: 4.0.1639.0 - Microsoft Corporation)
                Microsoft Expression Studio 4 (HKLM-x32...\ExpressionStudio_4.0.20525.0) (Version: 4.0.20525.0 - Microsoft Corporation)
                Microsoft Games for Windows - LIVE Redistributable (HKLM-x32...{832D9DE0-8AFC-4689-9819-4DBBDEBD3E4F}) (Version: 3.5.92.0 - Microsoft Corporation)
                Microsoft Games for Windows Marketplace (HKLM-x32...{4CB0307C-565E-4441-86BE-0DF2E4FB828C}) (Version: 3.5.50.0 - Microsoft Corporation)
                Microsoft Office 365 ProPlus - en-us (HKLM...\O365ProPlusRetail - en-us) (Version: 16.0.6965.2105 - Microsoft Corporation)
                Microsoft OneDrive (HKCU...\OneDriveSetup.exe) (Version: 17.3.6720.1207 - Microsoft Corporation)
                Microsoft Online Services Sign-in Assistant (HKLM...{46E637E2-AC34-4B45-B5DF-D20903A3DB61}) (Version: 7.250.4303.0 - Microsoft Corporation)
                Microsoft Silverlight (HKLM...{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50901.0 - Microsoft Corporation)
                Microsoft Silverlight 3 SDK (HKLM-x32...{2012098D-EEE9-4769-8DD3-B038050854D4}) (Version: 3.0.40818.0 - Microsoft Corporation)
                Microsoft Silverlight 4 SDK (HKLM-x32...{801B0DA3-A3FF-46CC-B97F-D76D510AF5AE}) (Version: 4.0.50401.0 - Microsoft Corporation)
                Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32...{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
                Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM...{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
                Microsoft Visual C++ 2008 Redistributable - x86 9.0.21022 (HKLM-x32...{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}) (Version: 9.0.21022 - Microsoft Corporation)
                Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32...{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
                Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24210 (HKLM-x32...{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}) (Version: 14.0.24210.0 - Microsoft Corporation)
                Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24210 (HKLM-x32...{23658c02-145e-483d-ba6b-1eb82c580529}) (Version: 14.0.24210.0 - Microsoft Corporation)
                Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
                Microsoft XNA Framework Redistributable 4.0 Refresh (HKLM-x32...{D69C8EDE-BBC5-436B-8E0E-C5A6D311CF4F}) (Version: 4.0.30901.0 - Microsoft Corporation)
                Middle-earth: Shadow of Mordor (HKLM-x32...\Steam App 241930) (Version: - Monolith Productions, Inc.)
                MKV TO AVI CONVERTER version 3.32 (HKLM-x32...\MKV TO AVI CONVERTER_is1) (Version: - )
                Movie Maker (HKLM-x32...{40F55150-F43D-4C9F-9A00-1A0A6F1EB7F0}) (Version: 16.4.3503.0728 - Microsoft Corporation) Hidden
                Movie Maker (HKLM-x32...{D71BC54E-A4E6-4E06-866C-FD6EE16EA187}) (Version: 16.4.3503.0728 - Microsoft Corporation) Hidden
                MyHarmony (HKCU...\036a0e4fc6a247ec) (Version: 1.0.1.257 - Logitech)
                Notepad++ (HKLM-x32...\Notepad++) (Version: 6.8.6 - Notepad++ Team)
                NVIDIA 3D Vision Controller Driver 369.04 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 369.04 - NVIDIA Corporation)
                NVIDIA 3D Vision Driver 376.33 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 376.33 - NVIDIA Corporation)
                NVIDIA GeForce Experience 3.1.2.31 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.1.2.31 - NVIDIA Corporation)
                NVIDIA Graphics Driver 376.33 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 376.33 - NVIDIA Corporation)
                NVIDIA HD Audio Driver 1.3.34.17 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.17 - NVIDIA Corporation)
                NVIDIA PhysX System Software 9.16.0318 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
                NvNodejs (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs) (Version: 3.1.2.31 - NVIDIA Corporation) Hidden
                NvTelemetry (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}NvTelemetry) (Version: 1.2.0.0 - NVIDIA Corporation) Hidden
                Office 16 Click-to-Run Extensibility Component (HKLM...{90160000-008C-0000-1000-0000000FF1CE}) (Version: 16.0.6965.2105 - Microsoft Corporation) Hidden
                Office 16 Click-to-Run Licensing Component (HKLM...{90160000-007E-0000-1000-0000000FF1CE}) (Version: 16.0.6965.2105 - Microsoft Corporation) Hidden
                Office 16 Click-to-Run Localization Component (HKLM...{90160000-008C-0409-1000-0000000FF1CE}) (Version: 16.0.6965.2105 - Microsoft Corporation) Hidden
                OpenOffice.org 3.4.1 (HKLM-x32...{9F1F2AEA-C72A-4DD6-991E-C5506A5625E4}) (Version: 3.41.9593 - Apache Software Foundation)
                Origin (HKLM-x32...\Origin) (Version: 10.3.3.1921 - Electronic Arts, Inc.)
                Overwatch (HKLM-x32...\Overwatch) (Version: - Blizzard Entertainment)
                Overwolf (HKLM-x32...\Overwolf) (Version: 0.100.227.0 - Overwolf Ltd.)
                PAYDAY: The Heist (HKLM-x32...\Steam App 24240) (Version: - Overkill)
                PixelJunk™ Monsters Ultimate (HKLM...\Steam App 243780) (Version: - Double Eleven)
                Platform (HKLM-x32...{20D4A895-748C-4D88-871C-FDB1695B0169}) (Version: 1.39 - VIA Technologies, Inc.) Hidden
                Prison Architect (HKLM-x32...\Steam App 233450) (Version: - Introversion Software)
                PS3 Media Server (HKLM-x32...\PS3 Media Server) (Version: 1.90.1 - PS3 Media Server)
                PunkBuster Services (HKLM-x32...\PunkBusterSvc) (Version: 0.991 - Even Balance, Inc.)
                puush (HKLM-x32...{C3592426-531E-4110-911D-BFECE2CE284B}) (Version: 1.0.0.0 - Dean Herbert)
                qBittorrent 3.2.0 (HKLM-x32...\qBittorrent) (Version: 3.2.0 - The qBittorrent project)
                QuickTime 7 (HKLM-x32...{3D2CBC2C-65D4-4463-87AB-BB2C859C1F3E}) (Version: 7.76.80.95 - Apple Inc.)
                Razer Synapse (HKLM-x32...{0D78BEE2-F8FF-4498-AF1A-3FF81CED8AC6}) (Version: 2.20.15.804 - Razer Inc.)
                rebox.NET 1.9.6.1 (HKLM-x32...\rebox.NET 1.9.6.1) (Version: 1.9.6.1 - clone.AD)
                ResearchSoft Direct Export Helper (HKLM-x32...\ResearchSoft Direct Export Helper) (Version: - Thomson Reuters)
                Rockstar Games Social Club (HKLM-x32...\Rockstar Games Social Club) (Version: 1.1.6.5 - Rockstar Games)
                Samsung Kies3 (HKLM-x32...{88547073-C566-4895-9005-EBE98EA3F7C7}) (Version: 3.2.15041.2 - Samsung Electronics Co., Ltd.) Hidden
                Samsung Kies3 (HKLM-x32...\InstallShield
                Samsung Magician (HKLM-x32...{29AE3F9F-7158-4ca7-B1ED-28A73ECDB215}_is1) (Version: 4.5.1 - Samsung Electronics)
                SAMSUNG USB Driver for Mobile Phones (HKLM...{D0795B21-0CDA-4a92-AB9E-6E92D8111E44}) (Version: 1.5.49.0 - SAMSUNG Electronics Co., Ltd.)
                Secure Download Manager (HKLM-x32...{4A5667B2-5D13-46C2-85B5-9D46A6096F61}) (Version: 3.1.0 - Kivuto Solutions Inc.)
                SHIELD Streaming (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 7.1.0340 - NVIDIA Corporation) Hidden
                SHIELD Wireless Controller Driver (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController) (Version: 3.1.2.31 - NVIDIA Corporation) Hidden
                Shutdown8 (HKCU...\Shutdown8) (Version: 1.0 - Bandisoft.com)
                Sid Meier’s Civilization VI (HKLM...\Steam App 289070) (Version: - Firaxis)
                Sid Meier’s Civilization: Beyond Earth (HKLM-x32...\Steam App 65980) (Version: - Firaxis Games)
                SimCity 2000 Special Edition (HKLM-x32...{59D2C751-F7BE-4E9F-9C8C-1F16013802C7}) (Version: 2.0.0.1 - Electronic Arts)
                Simple Port Forwarding (HKLM-x32...\Simple Port Forwarding) (Version: 3.8.5 - PcWinTech.com)
                Skulls of the Shogun (HKLM-x32...\Steam App 228960) (Version: - 17-BIT)
                Skype™ 7.27 (HKLM-x32...{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.27.101 - Skype Technologies S.A.)
                SlimDX Runtime .NET 4.0 x86 (January 2012) (HKLM-x32...{7EBD0E43-6AC0-4CA8-9990-00E50069AD29}) (Version: 2.0.13.43 - SlimDX Group)
                Smartflix (HKCU...\smartflix) (Version: 1.3.1 - Smartflix)
                Sony Mobile Update Engine (HKLM-x32...\Update Engine) (Version: 2.14.12.201408250841 - Sony Mobile Communications AB)
                Sony PC Companion 2.10.221 (HKLM-x32...{F09EF8F2-0976-42C1-8D9D-8DF78337C6E3}) (Version: 2.10.221 - Sony)
                Source SDK Base 2007 (HKLM-x32...\Steam App 218) (Version: - Valve)
                Spotflux (HKLM-x32...\Spotflux) (Version: 2.9.11 - Spotflux)
                StarCraft II (HKLM-x32...\StarCraft II) (Version: - Blizzard Entertainment)
                Steam (HKLM-x32...{048298C9-A4D3-490B-9FF9-AB023A9238F3}) (Version: 1.0.0.0 - Valve Corporation)
                SteamTool 1.1 (HKLM-x32...{B442D7D6-5153-4DBC-954D-BFFAACACDFDC}_is1) (Version: 1.1 - Stefan Jones)
                swMSM (HKLM-x32...{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
                SymMover (HKLM-x32...\SymMover) (Version: - )
                System Requirements Lab CYRI (HKLM-x32...{705216C1-BA52-4B16-AFE4-4143B340D62D}) (Version: 6.0.12.6 - Husdawg, LLC)
                TeamSpeak 3 Client (HKLM...\TeamSpeak 3 Client) (Version: 3.0.9.2 - TeamSpeak Systems GmbH)
                The Sims™ 4 (HKLM-x32...{48EBEBBF-B9F8-4520-A3CF-89A730721917}) (Version: 1.3.33.1010 - Electronic Arts Inc.)
                The Stanley Parable (HKLM-x32...\Steam App 221910) (Version: - Galactic Cafe)
                The Wolf Among Us (HKLM-x32...\Steam App 250320) (Version: - Telltale Games)
                Tom Clancy’s Splinter Cell Blacklist (HKLM-x32...\Steam App 235600) (Version: - Ubisoft Toronto)
                Tom Clancy’s The Division (HKLM-x32...\Uplay Install 568) (Version: - Ubisoft)
                TP-LINK TL-WN821N(C)TL-WN822N_TL-WN823N Driver (HKLM-x32...{852E893E-E4FD-45BB-8B17-72ADDF686974}) (Version: 1.3.1 - TP-LINK)
                TP-LINK Wireless Configuration Utility (HKLM-x32...{319D91C6-3D44-436C-9F79-36C0D22372DC}) (Version: 1.3.1 - TP-LINK)
                Tune Sweeper (HKLM-x32...{5E1E4C7A-A7D6-42F0-BDBA-DF20200E144E}) (Version: 2.001 - Wide Angle Software)
                Unity Web Player (HKCU...\UnityWebPlayer) (Version: - Unity Technologies ApS)
                Universal Adb Driver (HKLM-x32...{D9C4202E-6D51-4B06-A8F1-22316E654BCA}) (Version: 1.0.0 - ClockworkMod)
                Uplay (HKLM-x32...\Uplay) (Version: 15.0 - Ubisoft)
                VC80CRTRedist - 8.0.50727.6195 (HKLM-x32...{933B4015-4618-4716-A828-5289FC03165F}) (Version: 1.2.0 - DivX, Inc) Hidden
                VIA Platform Device Manager (HKLM-x32...\InstallShield
                VLC media player (HKLM-x32...\VLC media player) (Version: 2.2.4 - VideoLAN)
                VLC Setup Helper (HKLM-x32...\VLC Setup Helper_is1) (Version: - Hobbyist Software)
                Vulkan Run Time Libraries 1.0.26.0 (HKLM...\VulkanRT1.0.26.0) (Version: 1.0.26.0 - LunarG, Inc.)
                Windows Live Essentials (HKLM-x32...\WinLiveSuite) (Version: 16.4.3503.0728 - Microsoft Corporation)
                WinPcap 4.1.2 (HKLM-x32...\WinPcapInst) (Version: 4.1.0.2001 - CACE Technologies)
                WinRAR 4.20 (64-bit) (HKLM...\WinRAR archiver) (Version: 4.20.0 - win.rar GmbH)
                WinX DVD Ripper Platinum 6.9.2 (HKLM-x32...\WinX DVD Ripper Platinum_is1) (Version: - Digiarty Software, Inc.)
                WizTree v1.07 (HKLM-x32...\WizTree_is1) (Version: - Antibody Software)
                World of Warcraft (HKLM-x32...\World of Warcraft) (Version: - Blizzard Entertainment)
                WPF Toolkit February 2010 (Version 3.5.50211.1) (HKLM-x32...{5EE6E987-1B79-4A93-832B-27472C7D1579}) (Version: 3.5.50211.1 - Microsoft Corporation)
                Percentage of memory in use: 31%
                Total physical RAM: 16344.23 MB
                Available physical RAM: 11145.53 MB
                Total Virtual: 18776.23 MB
                Available Virtual: 12577.8 MB
                1 Drive c: (SSD) (Fixed) (Total:100.99 GB) (Free:15.45 GB) NTFS
                2 Drive d: (1TB WD Black Caviar) (Fixed) (Total:931.51 GB) (Free:86.32 GB) NTFS
                3 Drive e: (Samsung SSD) (Fixed) (Total:465.76 GB) (Free:262.65 GB) NTFS
                4 Drive f: (Overwatch 1.0) (CDROM) (Total:4.83 GB) (Free:0 GB) CDFS
                5 Drive h: (My Passport) (Fixed) (Total:298.02 GB) (Free:192.63 GB) FAT32
                User accounts for \JASONSBIGPC
                Jason
                **** End of log ****
                • Rustys
                  • 7862
                  #38
                  Found this on how to change the channel on the modem. You may try setting it to a different channel and see how that works. This may take a few tries looks like you may want to avoid Channel 6 and 1.
                  [COLOR=rgb(255, 128, 0)]How to Change the WiFi Channel on the Netgear C6300BD Cable Modem[/COLOR]
                  • Rustys
                    • 7862
                    #39
                    You also use a Torrent software have you disable the software to see if that helps.
                    They are also sometimes known to be the fastest way to get a system infected if the user is not cautious when using them. You can have out Security Team Check your system.
                    Security Forum Guidelines
                    Read Before Following Prework Instructions
                    [Prework] Please Read Before Posting
                    • jfmamjjasond
                      • Dec 2016
                      • 20
                      #40
                      But the torrent program is not open, and I have just run a heap of security scans. I’ve also changed the channel already a few days ago.
                      Tonight I’ve been getting insane packet loss, so I ran MTB. This came out.
                      Ran by Jason (administrator) on 20-12-2016 at 01:12:20
                      Boot Mode: Normal
                      reset
                      popd
                      Lease Obtained. . . . . . . . . . : Tuesday, 20 December 2016 12:28:30 AM
                      Lease Expires . . . . . . . . . . : Tuesday, 20 December 2016 1:58:36 AM
                      8.8.4.4
                      Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
                      Address: 8.8.8.8
                      Addresses: 2404:6800:4006:807::200e
                      144.131.80.123
                      144.131.80.118
                      144.131.80.99
                      144.131.80.113
                      144.131.80.94
                      144.131.80.88
                      144.131.80.89
                      144.131.80.98
                      144.131.80.93
                      144.131.80.103
                      144.131.80.109
                      144.131.80.108
                      144.131.80.104
                      144.131.80.84
                      144.131.80.119
                      144.131.80.114
                      Pinging google.com [144.131.80.99] with 32 bytes of data:
                      Reply from 144.131.80.99: bytes=32 time=13ms TTL=59
                      Reply from 144.131.80.99: bytes=32 time=16ms TTL=59
                      Ping statistics for 144.131.80.99:
                      Minimum = 13ms, Maximum = 16ms, Average = 14ms
                      Address: 8.8.8.8
                      Addresses: 2001:4998:c:a06::2:4008
                      98.139.183.24
                      206.190.36.45
                      98.138.253.109
                      Reply from 206.190.36.45: bytes=32 time=325ms TTL=44
                      Minimum = 325ms, Maximum = 327ms, Average = 326ms
                      17…00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2[/HEADING]
                      Persistent Routes:
                      None
                      2 331 ::/0 On-link
                      On-link
                      On-link
                      On-link
                      4 306 ff00::/8 On-link[/HEADING]
                      Persistent Routes:
                      None
                      Error: (12/19/2016 10:43:55 PM) (Source: Application Error) (User: )
                      Description: Faulting application name: microsoftedgecp.exe, version: 11.0.14393.82, time stamp: 0x57a55786
                      Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
                      Exception code: 0xc0000604
                      Fault offset: 0x0000000000000000
                      Faulting process id: 0x39e4
                      Faulting application start time: 0xmicrosoftedgecp.exe0
                      Faulting application path: microsoftedgecp.exe1
                      Faulting module path: microsoftedgecp.exe2
                      Report Id: microsoftedgecp.exe3
                      Faulting package full name: microsoftedgecp.exe4
                      Faulting package-relative application ID: microsoftedgecp.exe5
                      Error: (12/19/2016 10:43:54 PM) (Source: Application Error) (User: )
                      Error: (12/19/2016 10:43:51 PM) (Source: Application Error) (User: )
                      Faulting process id: 0x3080
                      Error: (12/19/2016 10:43:49 PM) (Source: Application Error) (User: )
                      Error: (12/19/2016 06:59:15 PM) (Source: Bonjour Service) (User: )
                      Error: (12/19/2016 08:32:55 AM) (Source: Bonjour Service) (User: )
                      Error: (12/20/2016 01:12:23 AM) (Source: Microsoft-Windows-DNS-Client) (User: NT AUTHORITY)
                      Error: (12/20/2016 12:28:34 AM) (Source: Microsoft-Windows-DNS-Client) (User: NT AUTHORITY)
                      Error: (12/20/2016 12:28:31 AM) (Source: Microsoft-Windows-DNS-Client) (User: NT AUTHORITY)
                      Error: (12/19/2016 07:01:36 PM) (Source: DCOM) (User: NT AUTHORITY)
                      Error: (12/19/2016 06:58:35 PM) (Source: DCOM) (User: NT AUTHORITY)
                      Error: (12/19/2016 06:58:21 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (User: NT AUTHORITY)
                      Description: WLAN AutoConfig detected limit connectivity, performing Reset/Recover.adapter.
                      Code: 8 0x0 0x0
                      Error: (12/19/2016 06:58:20 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (User: NT AUTHORITY)
                      Code: 2 0xdeaddeed 0xeeec
                      Code: 1 0xc 0x4
                      Error: (12/19/2016 06:57:03 PM) (Source: Microsoft-Windows-DNS-Client) (User: NT AUTHORITY)
                      Error: (12/19/2016 06:57:00 PM) (Source: Microsoft-Windows-DNS-Client) (User: NT AUTHORITY)
                      Error: (12/19/2016 10:43:55 PM) (Source: Application Error)(User: )
                      Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0 .0.000000000c0000604000000000000000039e401d259ed2c 508808C:\Windows\SystemApps\Microsoft.MicrosoftEdg e_8wekyb3d8bbwe\microsoftedgecp.exeunknown7166872d-1ed7-47ed-a3be-17fd81ab5888Microsoft.MicrosoftEdge_38.14393.0.0_n eutral__8wekyb3d8bbweMicrosoftEdge
                      Error: (12/19/2016 10:43:54 PM) (Source: Application Error)(User: )
                      Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0 .0.000000000c0000604000000000000000039e401d259ed2c 508808C:\Windows\SystemApps\Microsoft.MicrosoftEdg e_8wekyb3d8bbwe\microsoftedgecp.exeunknown39a68fd7-a3b5-40e9-8aab-969a6c39c3f5Microsoft.MicrosoftEdge_38.14393.0.0_n eutral__8wekyb3d8bbweMicrosoftEdge
                      Error: (12/19/2016 10:43:51 PM) (Source: Application Error)(User: )
                      Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0 .0.000000000c00006040000000000000000308001d259ed29 55c82aC:\Windows\SystemApps\Microsoft.MicrosoftEdg e_8wekyb3d8bbwe\microsoftedgecp.exeunknowna9211101-a3d6-4a1d-9a9f-96c988f69c14Microsoft.MicrosoftEdge_38.14393.0.0_n eutral__8wekyb3d8bbweMicrosoftEdge
                      Error: (12/19/2016 10:43:49 PM) (Source: Application Error)(User: )
                      Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0 .0.000000000c00006040000000000000000308001d259ed29 55c82aC:\Windows\SystemApps\Microsoft.MicrosoftEdg e_8wekyb3d8bbwe\microsoftedgecp.exeunknowndbcb88d1-3494-460f-adcc-8264883f0d40Microsoft.MicrosoftEdge_38.14393.0.0_n eutral__8wekyb3d8bbweMicrosoftEdge
                      Error: (12/19/2016 06:59:15 PM) (Source: Bonjour Service)(User: )
                      Error: (12/19/2016 08:32:55 AM) (Source: Bonjour Service)(User: )
                      Date: 2016-12-19 23:43:58.119
                      Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume1\Windows\System32\nvspcap64 .dll because the set of per-page image hashes could not be found on the system.
                      Date: 2016-12-19 23:43:58.111
                      Date: 2016-12-19 23:43:58.059
                      Date: 2016-12-19 23:43:58.050
                      Date: 2016-12-19 22:36:09.914
                      Date: 2016-12-19 22:36:09.905
                      Date: 2016-12-19 22:36:09.846
                      Date: 2016-12-19 22:36:09.837
                      Date: 2016-12-19 19:15:37.445
                      Date: 2016-12-19 19:15:37.444
                      Percentage of memory in use: 42%
                      Available physical RAM: 9323.68 MB
                      Available Virtual: 6983.85 MB
                      1 Drive c: (SSD) (Fixed) (Total:100.99 GB) (Free:15.21 GB) NTFS
                      Jason
                        #41
                        The torrent software you have and i am assuming you have used it before,so make sure that the torrent software isn’t seeding. This option is easy to miss and a lot of times it is in the the bundled install. Seeding is when the torrent software is using your internet for uploads to other pc’s to help the torrent business so to speak.
                        • jfmamjjasond
                          • Dec 2016
                          • 20
                          #42
                          I pause my torrents once they finish, but regardless it’s not open anyway
                            #43
                            Regardless whether the torrent software is open or not, some torrent software continue to seed while the main program is off ..
                            • Rustys
                              • 7862
                              #44
                              This way they can have a up to date scan.
                              The only other thing that can be done is run a MSConfig check.
                              Start in the test box type MSConfig
                              Right click and Run as Administrator
                              Select the Boot Tab
                              Take out al of the has marks
                              Click OK
                              Reboot and try the system.
                              If it works then go back to MSConfig and put a hash in the First one
                              Then Click OK
                              Repeat until the system acts up and that is possibility the one or combination that is causing the issue.
                              Other wise follow the instruction in post #39.
                              • Rustys
                                • 7862
                                #45
                                @jfmamjjasond do you have any new information for us?
