Iβm in Australia, we use the logical date format (DD/MM/YYYY) instead of the backwards American version lmao
Intermittent connection hanging + other issues
Lets run some basic commands.
Open a Command Prompt and type the following commands, pressing Enter after each command.
ipconfig /release
ipconfig /renew
ipconfig /flushdns
ipconfig /registerdns
netsh int ipv6 reset
netsh int ipv4 reset
netsh winsock reset
Reboot the computer
Test for a bit and see if still happening.Comment
Did all of it, however got this message when I ran ipconfig /renew
After a restart I played a game of dota where the same hanging issue kept happening. Every couple of minutes the game would kind of pause for 2-3 seconds. So far the internet hasnβt dropped entirely just yet but I do expect that will happen anyway. I will try another USB port.Comment
Adware Cleaner Scan.
[li]Close all open programs and internet browsers.[/li][li]Double click on adwcleaner.exe to run the tool.[/li][li]Click on Scan button.[/li][li]When the scan has finished click on Clean button.[/li][li]Your computer will be rebooted automatically. A text file will open after the restart.[/li][li]Please post the contents of that logfile with your next reply.[/li][li]You can find the logfile at C:\AdwCleaner[S1].txt as well.[/li][/ul]
JRT Scan.
[li]Shut down your anti-virus, anti-spyware, and firewall software now to avoid potential conflicts.[/li][li]Run the tool by double-clicking it. If you are using Windows Vista or Windows 7, right-click it and select Run as administrator.[/li][li]The tool will open and start scanning your system.[/li][li]Please be patient as this can take a while to complete depending on your systemβs specifications.[/li][li]On completion, a log is saved to your desktop and will automatically open.[/li][li]Please post the JRT log.[/li][/ul]
Adware Removal Tool Scan.
[MEDIA=imgur]LOr0Gd7[/MEDIA]
Hit Ok.
[MEDIA=imgur]sYFsqHx[/MEDIA]
[MEDIA=imgur]8NcZjGc[/MEDIA]
The Program will close all open programs to complete the removal, so save any work and hit OK. Then hit OK after the removal process is complete, thenOK again to finish up. Post log generated by tool.
ZHP Scan.
Please download Zhp Cleaner to your desktop. Right Click the icon and select run as administrator.- Once you have started the program, you will need to click the scanner button.
[IMG alt="EgsT69u" width="602px" height="129px"]https://windowsinstructed.com/wp-content/uploads/2015/06/EgsT69u.png[/IMG]
3. Once the scan is completed, the you will want to click the Repair button.
[URL unfurl="true"]http://windowsinstructed.com/wp-content/uploads/2015/06/6QJjV50.png[/URL]
At the end of the process you may be asked to reboot your machine. After you reboot a report will open on your desktop.
Copy and paste the report here in your next reply.
Security Check Scan.
[li]Download Security Check to your desktop.[/li][li]Right click it run as administrator.[/li][li]When the program completes, the tool will automatically open a log file.[/li][li]Please post that log here in your next post.[/li][/ul]Comment
You didnβt post the full network test but it does show you have a very short lease for dhcp you need to login to router and increase it to a week. It also shows other stations with a signal of 100% which will wipe you out you need to change the channel on the router to a clear one and keep checking as the others may change theirs so you would be back in the same situation.Comment
Hey Iβm trying to set up a DHCP lease in my router page, but since Iβm on wifi is my MAC address my Ethernet physical address (from ipconfig /all) or is it my Wireless LAN adapter physical address?Originally posted by SamuriaYou didnβt post the full network test but it does show you have a very short lease for dhcp you need to login to router and increase it to a week. It also shows other stations with a signal of 100% which will wipe you out you need to change the channel on the router to a clear one and keep checking as the others may change theirs so you would be back in the same situation.
Also I am running all the tests now, thanks for the help.
p.s. I donβt understand what you meant by the other devices having 100% signal thing. What do I do about that?Comment
the mac address will be what your currently connected with these are other routers in your area with channels
SSID 1 : lockart cable
Network type : Infrastructure
Authentication : WPA2-Personal
Encryption : CCMP
BSSID 1 : 10:da:43:52:91:0f
Signal : 100%
Radio type : 802.11n
Channel : 1
Basic rates (Mbps) : 1 2 5.5 11
Other rates (Mbps) : 6 9 12 18 24 36 48 54
SSID 2 : PS4-517106BB3B85
Encryption : CCMP
BSSID 1 : b0:05:94:56:70:63
Signal : 100%
Channel : 1
SSID 3 : Telstra0EEB
Encryption : CCMP
BSSID 1 : 50:6a:03:89:ec:16
Signal : 84%
Channel : 6
SSID 4 : Telstra Air
Authentication : Open
Encryption : None
BSSID 1 : 52:6a:03:89:ec:18
Signal : 74%
Channel : 6
SSID 5 : Fon WiFi
Encryption : None
BSSID 1 : 52:6a:03:89:ec:19
Signal : 74%
Channel : 6
Network RoutesComment
ADW:
[HEADING=1]AdwCleaner v6.040 - Logfile created 14/12/2016 at 12:02:07[/HEADING]
[HEADING=1]Updated on 02/12/2016 by Malwarebytes[/HEADING]
[HEADING=1]Database : 2016-12-13.2 [Server][/HEADING]
[HEADING=1]Operating System : Windows 10 Pro (X64)[/HEADING]
[HEADING=1]Username : Jason - JASONSBIGPC[/HEADING]
[HEADING=1]Running from : C:\Users\Jason\Downloads\adwcleaner_6.040.exe[/HEADING]
[HEADING=1]Mode: Scan[/HEADING]
[HEADING=1]Support : https://www.malwarebytes.com/support[/HEADING]
***** [ Services ] *****
No malicious services found.
***** [ Folders ] *****
Folder Found: C:\Users\Jason\AppData\Roaming\RHEng
***** [ Files ] *****
File Found: C:\END
File Found: C:\user.js
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_cpngackimfmofbokmjmljamhdncknpmg_0.local storage
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_cpngackimfmofbokmjmljamhdncknpmg_0.local storage-journal
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_lfmhcpmkbdkbgbmkjoiopeeegenkdikp_0.local storage
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_lfmhcpmkbdkbgbmkjoiopeeegenkdikp_0.local storage-journal
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_oadboiipflhobonjjffjbfekfjcgkhco_0.local storage
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_oadboiipflhobonjjffjbfekfjcgkhco_0.local storage-journal
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_okanipcmceoeemlbjnmnbdibhgpbllgc_0.local storage
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_okanipcmceoeemlbjnmnbdibhgpbllgc_0.local storage-journal
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_nonjdcjchghhkdoolnlbekcfllmednbl_0.local storage
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_nonjdcjchghhkdoolnlbekcfllmednbl_0.local storage-journal
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Profile 2\Local Storage\hxxp_st.chatango.com_0.localstorage
File Found: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Profile 2\Local Storage\hxxp_st.chatango.com_0.localstorage-journal
***** [ DLL ] *****
No malicious DLLs found.
***** [ WMI ] *****
No malicious keys found.
***** [ Shortcuts ] *****
No infected shortcut found.
***** [ Scheduled Tasks ] *****
No malicious task found.
***** [ Registry ] *****
Key Found: HKLM\SOFTWARE\Classes\CLSID{9C4EFBD5-1ADF-41E6-BE26-AF44326E30E4}
Key Found: HKU\S-1-5-21-289513446-1386089559-2770113033-1001\Software\PRODUCTSETUP
Key Found: HKU\S-1-5-21-289513446-1386089559-2770113033-1001\Software\Squeaky
Key Found: HKU\S-1-5-21-289513446-1386089559-2770113033-1001\Software\csastats
Key Found: HKCU\Software\PRODUCTSETUP
Key Found: HKCU\Software\Squeaky
Key Found: HKCU\Software\csastats
Key Found: HKU.DEFAULT\Software\Microsoft\Internet Explorer\InternetRegistry\REGISTRY\USER\S-1-5-18\Software\V-bates
Key Found: HKLM\SOFTWARE\ComputerZ
Key Found: [x64] HKCU\Software\PRODUCTSETUP
Key Found: [x64] HKCU\Software\Squeaky
Key Found: [x64] HKCU\Software\csastats
Key Found: [x64] HKLM\SOFTWARE\pcv-var
***** [ Web browsers ] *****
No malicious Firefox based browser items found.
Chrome pref Found: [C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Profile 2\Secure Preferences ] - bopakagnckmlgajfccecajhnimjiiedh
C:\AdwCleaner\AdwCleaner[R0].txt - [1363 Bytes] - [29/04/2014 00:53:49]
C:\AdwCleaner\AdwCleaner[R1].txt - [3693 Bytes] - [24/06/2014 04:42:56]
C:\AdwCleaner\AdwCleaner[R2].txt - [1791 Bytes] - [24/06/2014 05:12:46]
C:\AdwCleaner\AdwCleaner[S0].txt - [1462 Bytes] - [29/04/2014 00:56:50]
C:\AdwCleaner\AdwCleaner[S1].txt - [3601 Bytes] - [24/06/2014 04:44:43]
C:\AdwCleaner\AdwCleaner[S2].txt - [1862 Bytes] - [24/06/2014 05:22:28]
C:\AdwCleaner\AdwCleaner[S3].txt - [4118 Bytes] - [14/12/2016 12:02:07]
########## EOF - C:\AdwCleaner\AdwCleaner[S3].txt - [4191 Bytes] ##########
JRT:
File System: 5Code:Junkware Removal Tool (JRT) by Malwarebytes Version: 8.0.9 (09.30.2016) Operating System: Windows 10 Pro x64 Ran by Jason (Administrator) on Wed 14/12/2016 at 12:09:19.44
Successfully deleted: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Extension Settings\obciceimmggglbmelaidpjlmodcebijb (Folder)
Successfully deleted: C:\Users\Jason\Appdata\LocalLow\company (Folder)
Successfully deleted: C:\Users\Jason\AppData\Roaming\nico mak computing (Folder)
Successfully deleted: C:\WINDOWS\SysWOW64\REN37F1.tmp (File)
Successfully deleted: C:\WINDOWS\SysWOW64\REN9AFA.tmp (File)
Registry: 1
Successfully deleted: HKCU\Software\Microsoft\Windows\CurrentVersion\Run \GoogleChromeAutoLaunch_EBF55E2D20B0831DD9C62517F8 BC1054 (Registry Value)
I am currently running the necessary scans. Here are the logs so far.Code:Scan was completed on Wed 14/12/2016 at 12:10:53.33 End of JRT log
Iβm trying to change my DHCP lease in my router, but see no options for time limits or anything.
I have added my current mac/IP as you can see but not sure if thatβs all I need to do there?
And I gather I should change my router channel to something else, but since my PS4 is right next to me that will just update too and I will end up in the same situation. Right?
@Rustys, modem is Netgear βTelstra Gateway Maxβ (C6300BD-1TLAUS)Comment
~ ZHPCleaner v2016.12.13.215 by Nicolas Coolman (2016/12/13)
~ Run by Jason (Administrator) (14/12/2016 12:38:06)
~ Blog: https://www.anti-malware.top
~ Facebook : ZHP
~ State version : Version OK
~ Type : Repair
~ Report : C:\Users\Jason\Desktop\ZHPCleaner.txt
~ Quarantine : C:\Users\Jason\AppData\Roaming\ZHP\ZHPCleaner_Quar antine.txt
~ UAC : Activate
~ Boot Mode : Normal (Normal boot)
Windows 10 Pro, 64-bit (Build 14393)
β\ Services (0)
~ No malicious or unnecessary items found.
β\ Browser internet (0)
β\ Hosts file (1)
~ The hosts file is legitimate (14)
β\ Scheduled automatic tasks. (0)
β\ Explorer ( File, Folder) (49)
MOVED file: C:\Windows\Installer\wix{159AA592-31AA-4EAC-A6CB-B47AB2CB1476}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{2D7D85DF-8BBA-427F-8E85-055CD22F2D2A}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{2E4AF2A6-50EA-4260-9BA4-5E582D11879A}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{2E9C0CF2-6FD1-417E-A5A1-5AE93C0032DF}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{3540181E-340A-4E7A-B409-31663472B2F7}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{5032D869-5D74-46FD-8C52-7F15420589B0}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{55BB2110-FB43-49B3-93F4-945A0CFB0A6C}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{5D61F006-168C-4B8B-B7FD-F113C10AE0E4}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{61F565EB-B101-4EBE-89BB-EF0AA3F2FFB8}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{6FC79C95-F54F-4515-8012-01F33D894492}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{7446FE8D-C1F9-4D42-AAAE-5DBCE58605A6}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{7D2C319D-3907-472D-9B55-EC1F240962FC}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{8432E4EF-ABFB-48C8-B77B-24728E71D3DD}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{912422D4-0A22-4F70-BF8D-802B4BCD0999}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{95EB2FCC-AE0B-40E9-B804-347C6358923B}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{A1A724F3-F1A6-479C-AE98-208946717E2B}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{A6B6501F-A987-437B-BFAC-319AE1F990ED}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{C230A275-D2A0-446B-ACE5-06BF067D50F2}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{C9F8858E-B6F9-4E56-B155-2A5CE7FC74B9}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{CDF9E1C8-4B97-4F8B-A848-7DD0E8BEB89F}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{D4D86CB2-2370-4691-8272-3869EDED6C64}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{D669DC52-B1A4-4933-878D-CB80F660D95D}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{EBFF2EA1-3944-4CA2-89FA-8B70C0058DD3}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{FD244E19-6EFE-4A2D-948A-0D45D4C168BE}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{FD6E648E-1378-467F-AD37-2B98B379B0DD}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Users\Jason\Downloads\SecureDownloadManager.log =>PUP.Optional.SearchAssist
MOVED file: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_static.olark.com_0.localstorage =>PUP.Optional.Generic
MOVED file: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_static.olark.com_0.localstorage-journal =>PUP.Optional.Generic
MOVED file: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_ebookbrowsee.net_0.localstorage =>PUP.Optional.Multiplug
MOVED file: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_ebookbrowsee.net_0.localstorage-journal =>PUP.Optional.Multiplug
MOVED file: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.ask.com_0.localstorage =>Toolbar.Ask
MOVED file: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.ask.com_0.localstorage-journal =>Toolbar.Ask
MOVED file: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.metrolyrics.com_0.localstorage =>PUP.Optional.AddLyrics
MOVED file: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.metrolyrics.com_0.localstorage-journal =>PUP.Optional.AddLyrics
MOVED file: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.putlocker.com_0.localstorage =>PUP.Optional.PutLocker
MOVED file: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.putlocker.com_0.localstorage-journal =>PUP.Optional.PutLocker
MOVED folder: C:\Users\Jason\AppData\Local\Google\Chrome\User Data\Default\Extensions\hdokiejnpimakedhajhdlcegep lioahd =>Hijacker.Browser [ LastPass - Release Notes ]
MOVED folder: C:\Program Files (x86)\QuickTime =>Riskware.QuickTime
MOVED folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QuickTime =>Riskware.QuickTime
MOVED folder: C:\WINDOWS\Installer\MSI2039.tmp- =>.Superfluous.Empty
MOVED folder: C:\WINDOWS\Installer\MSI2144.tmp- =>.Superfluous.Empty
MOVED folder: C:\WINDOWS\Installer\MSI3BC1.tmp- =>.Superfluous.Empty
MOVED folder: C:\WINDOWS\Installer\MSI3C8D.tmp- =>.Superfluous.Empty
MOVED folder: C:\WINDOWS\Installer\MSI4664.tmp- =>.Superfluous.Empty
MOVED folder: C:\WINDOWS\Installer\MSI47CD.tmp- =>.Superfluous.Empty
MOVED folder: C:\WINDOWS\Installer\MSI6640.tmp- =>.Superfluous.Empty
MOVED folder: C:\WINDOWS\Installer\MSI678A.tmp- =>.Superfluous.Empty
MOVED folder: C:\WINDOWS\Installer\MSIE6DC.tmp- =>.Superfluous.Empty
MOVED folder: C:\WINDOWS\Installer\MSIEECD.tmp- =>.Superfluous.Empty
β\ Registry ( Key, Value, Data) (9)
DELETED data: HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{3dc0fc79-3933-4539-bd45-fe7cbfd0feaf}\DhcpNameServer [Bad : 61.9.194.49 61.9.195.193] =>Hijacker.Browser
DELETED data: HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Param eters\DhcpNameServer [Bad : 61.9.194.49 61.9.195.193] =>Hijacker.Browser
DELETED key*: [X64] HKLM\SOFTWARE\Classes\S =>Toolbar.Agent
DELETED key*: [X64] HKLM\SOFTWARE\Classes\AppID{4D076AB4-7562-427A-B5D2-BD96E19DEE56} [secman] =>PUP.Optional.Camec
DELETED key*: HKLM\SYSTEM\CurrentControlSet\Services\CscService =>.Superfluous.PCSpeedUp
DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ins taller\UserData\S-1-5-18\Components\014AA45914BC47A46AC4007B890B0404 [C:\Perl64\lib\ExtUtils\Command] =>PUP.Optional.Manager
DELETED key: [X64] HKLM\SOFTWARE\Wow6432Node\Classes\AppID{4D076AB4-7562-427A-B5D2-BD96E19DEE56} [secman] =>PUP.Optional.Camec
DELETED key*: [X64] HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\Curren tVersion\Uninstall{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2} [Google Inc.] =>Heuristic.Suspect
DELETED value: HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\MusicManager [0x0300000076DC1EB75D54CE01] =>.Superfluous.MusicManager
β\ Summary of the elements found (16)
Blog - Nicolas Coolman =>.Superfluous.Empty
https://www.nicolascoolman.com/fr/re...et_infections/ =>PUP.Optional.SearchAssist
Redirecting... =>PUP.Optional.Generic
Redirecting... =>PUP.Optional.Multiplug
Redirecting... =>Toolbar.Ask
https://www.nicolascoolman.com/fr/adware-addlyrics/ =>PUP.Optional.AddLyrics
https://www.nicolascoolman.com/fr/spyware-putlocker/ =>PUP.Optional.PutLocker
https://www.nicolascoolman.com/fr/re...et_infections/ =>Hijacker.Browser [ LastPass - Release Notes ]
Redirecting... =>Riskware.QuickTime
https://www.nicolascoolman.com/fr/hijacker-browser/ =>Hijacker.Browser
FRST 2025 TΓ©lΓ©charger - Nicolas Coolman =>Toolbar.Agent
https://www.nicolascoolman.com/fr/re...et_infections/ =>PUP.Optional.Camec
https://www.nicolascoolman.com/fr/su...-pcspeeduppro/ =>.Superfluous.PCSpeedUp
https://www.nicolascoolman.com/fr/pup-manager/ =>PUP.Optional.Manager
Redirecting... =>Heuristic.Suspect
Redirecting... =>.Superfluous.MusicManager
β\ Other deletions. (17)
~ Registry Keys Tracing deleted (17)
~ Remove the old reports ZHPCleaner. (0)
β\ Result of repair
~ Repair carried out successfully
~ Browser not found (Mozilla Firefox)
~ Browser not found (Opera Software)
β\ Statistics
~ Items scanned : 929
~ Items found : 0
~ Items cancelled : 0
~ Items repaired : 58
~ End of clean in 00h00mn26s
ZHPCleaner-[R]-14122016-12_38_32.txt
ZHPCleaner--14122016-12_36_55.txt
[S]SecurityCheck by glax24 & Severnyj v.1.4.0.46 [22.09.16]
WebSite: www.safezone.cc
DateLog: 14.12.2016 12:47:31
Path starting: C:\Users\Jason\AppData\Local\Temp\SecurityCheck\Se curityCheck.exe
Log directory: C:\SecurityCheck
IsAdmin: True
User: Jason
VersionXML: 3.62is-13.12.2016
Windows 10(6.3.14393) (x64) Professional Lang: English(0409)
Installation date OS: 23.09.2016 14:02:33
LicenseStatus: Office 16, Office16O365ProPlusR_Subscription1 edition Timebased activation will expire :56647 minutes
LicenseStatus: Windows(R), Professional edition The machine is permanently activated.
Boot Mode: Normal
Default Browser: Microsoft Edge (C:\WINDOWS\system32\LaunchWinApp.exe)
SystemDrive: C: FS: [NTFS] Capacity: [101 Gb] Used: [82.8 Gb] Free: [18.2 Gb]
------------------------------- [ Windows ] -------------------------------
Internet Explorer 11.447.14393.0
User Account Control enabled
Automatically download and schedule installation
Windows Update (wuauserv) - The service is running
Security Center (wscsvc) - The service is running
Remote Registry (RemoteRegistry) - The service has stopped
SSDP Discovery (SSDPSRV) - The service is running
Remote Desktop Services (TermService) - The service has stopped
Windows Remote Management (WS-Management) (WinRM) - The service has stopped
System Restore Disable
---------------------------- [ Antivirus_WMI ] ----------------------------
Windows Defender (enabled and up to date)
--------------------------- [ FirewallWindows ] ---------------------------
Windows Firewall (MpsSvc) - The service is running
--------------------------- [ AntiSpyware_WMI ] ---------------------------
--------------------------- [ OtherUtilities ] ----------------------------
WinRAR 4.20 (64-bit) v.4.20.0 Warning! Download Update
Microsoft Silverlight v.5.1.50901.0
DivX Setup v.2.7.0.64
VLC media player v.2.2.4
OpenOffice.org 3.4.1 v.3.41.9593 Warning! Download Update
--------------------------------- [ IM ] ----------------------------------
Skypeβ’ 7.27 v.7.27.101 Warning! Download Update
^Optional update.[1]
---------------------------- [ ProxyAndVPNs ] -----------------------------
Spotflux v.2.9.11 Warning! This app can show ads.
--------------------------------- [ P2P ] ---------------------------------
qBittorrent 3.2.0 v.3.2.0 Warning! P2P-client.
-------------------------------- [ Java ] ---------------------------------
Java SE Development Kit 7 Update 7 (64-bit) v.1.7.0.70 Warning! This software is no longer supported. Please uninstall it and use Java SDK 8 (jdk-8u112-windows-x64.exe).
Java 8 Update 101 v.8.0.1010.13 Warning! Download Update
Uninstall old version and install new one (jre-8u112-windows-i586.exe).
Java SE Development Kit 7 Update 6 v.1.7.0.60 Warning! This software is no longer supported. Please uninstall it and use Java SDK 8 (jdk-8u112-windows-i586.exe).
Java SE Development Kit 7 Update 7 v.1.7.0.70 Warning! This software is no longer supported. Please uninstall it and use Java SDK 8 (jdk-8u112-windows-i586.exe).
--------------------------- [ AppleProduction ] ---------------------------
iTunes v.12.5.3.17
Bonjour v.3.1.0.1
QuickTime 7 v.7.76.80.95 Warning! This software is no longer supported. Please uninstall it and use another software.
Bonjour Service (Bonjour Service) - The service is running
--------------------------- [ AdobeProduction ] ---------------------------
Adobe AIR v.3.4.0.2540 Warning! Download Update
Adobe Flash Player 23 NPAPI v.23.0.0.207 Warning! Download Update
Adobe Shockwave Player 11.6 v.11.6.6.636 Warning! Download Update
Adobe Acrobat Reader DC v.15.020.20042
------------------------------- [ Browser ] -------------------------------
Google Chrome v.56.0.2924.21
----------------------------- [ EmailClient ] -----------------------------
Windows Live Mail v.16.4.3503.0728
--------------------------- [ RunningProcess ] ----------------------------
C:\Program Files (x86)\Google\Chrome\Application\chrome.exe v.56.0.2924.21
------------------ [ AntivirusFirewallProcessServices ] -------------------
C:\Program Files\Windows Defender\MsMpEng.exe v.4.10.14393.0
C:\Program Files\Windows Defender\MpCmdRun.exe v.4.10.14393.0
C:\Program Files\Windows Defender\NisSrv.exe v.4.10.14393.0
Windows Defender Service (WinDefend) - The service is running
Windows Defender Network Inspection Service (WdNisSvc) - The service is running
---------------------------- [ UnwantedApps ] -----------------------------
Unity Web Player Warning! Application is distributed through the partnership programs and bundle assemblies. Uninstallation recommended. Possible you became a victim of fraud or social engineering.
----------------------------- [ End of Log ] ------------------------------
[/S]
- /B β©οΈ
