My Surface Pro 8 is running very slow, much slower than my old pro 5
This topic is closed.
  • 7055
    • Jul 2025
    • 13
    Hello, I have a Surface Pro 8 and always loved the hardware and ease of using Windows in the past, however lately my Surface Pro 8 has been super slow. I can only open maybe 8 or so internet tabs at once before it starts freezing up and it often takes forever just to turn it on. Even searching in the search menu seems slow. My old surface pro 5 which I had for years never even got this bad.
    Could someone be kind enough to guide me through whatever that scanning process is to help determine the problem with my computer and fix it?
    Let me get you some help.
    @PeterOz
      @PeterOz
      • PeterOz
        PCHF Technical Response Team
        • Mar 2021
        • 4181
        Not really my forte.
        I would make a system image/backup as a first step.
        next is to either do a refresh of windows or ask @Malnutrition if his tools can find anything.
        I have tagged @Malnutrition and he should reply when he has time.
        • PeterOz
          • Mar 2021
          • 4181
          • Malnutrition
            PCHF Moderator
            • 7041
            Please download MiniToolBox and save it to your desktop.
            Run the program by right clicking on it and selecting Run as administrator.
            When the program opens check mark Select All Then hit GO
            Please post the log in your next reply. Attach or copy and paste, whatever is easier for you.
            Speccy Scan.
            [li]Please go here and download Speccy.[/li][li]Install and run the program.[/li][li]Upon Completion:[/li][li]Hit File[/li][li]Publish Snap Shot[/li][li]A link will appear, post that link.[/li][/ul]
            Disable Boot Defrag. Enable or disable boot defrag
            Disable Fast Boot. https://help.uaudio.com/hc/en-us/art...-in-Windows-10
            Download and run HellZerg Optimizer. Download Optimizer 16.7
            Disable everything you do not use, just leave system restore enabled.
            • Malnutrition
              PCHF Moderator
              • 7041
              Speccy Scan.
              • 7055
                • Jul 2025
                • 13
                okay, thanks, here it is attached
                • 7055
                  • Jul 2025
                  • 13
                    #10
                    Apologies for the wait in you getting a reply, please let us know if you still need help with this.
                      #11
                      • 7055
                        • Jul 2025
                        • 13
                        #12
                        Yes I do please still need help
                        • 7055
                          • Jul 2025
                          • 13
                          #13
                          • 7055
                            • Jul 2025
                            • 13
                            #14
                            I have done everything in Malnutritions steps so far, awaiting next instructions
                            • 7055
                              • Jul 2025
                              • 13
                              #15
