If the boot drive has failed it involves opening up the PC, checking the type and state of the drive and potentially removing and replacing the drive, once that has been done you will then have to clean install Windows and the system drivers etc.
If you are okay with working inside of a computer we can walk you through it but any warranty check must be done first.
Your CPU was only released two years ago so it all depends on how long you have actually had the PC, if within 12 months you should contact the place of purchase,for any longer than 12 months see info here and here
