The Pc’s operating system is windows XP and I have been working on this computer for about a month. I took it apart, cleaned it out and it runs quite a bit smoother. There is only issue with it, which was an issue when I first started working on it. The USB ports are not working. When I go to plug in anything that uses a USB the computer recognizes that there is something plugged in, but it doesn’t work. For example, when I plug in a mouse it will recognize it but the cursor won’t move and the mouse doesn’t work. I know a lot about computers, bit this one has stumped me.
HP a1530n pc problem
This topic is closed.
Tags: None
Yes I have tried that port and it does not work either, but the port for the keyboard in the back works perfectly fine.Originally posted by vgerHello
Maybe it’s the voltage regulator for the usb ports that has failed. Have you tried the ps/2 port,with supported mouse?
@Evan OmoComment
I reseated the connectors and now it is deciding to have another issue. The tower is running, but it is not going anywhere on the monitor. I have posted a photo of it.Comment
