malware & eliminate help .....and ext. !!?? help
  • rusobr2
    • 45
    a couple months ago i worked with a couple “gurus” here in help to get my PC up and running proper… well all seemed ok for awhile, but now i’m having trouble with one of the “Mal-wear” products that i installed … it keeps interrupting the workings of my PC .. i’v tried to uninstall but no worky, and i’v tried a few other things, but no worky
    thanks in advance … steve
  • Rustys
    • 7862
    What Mal Ware product are you having this issue with?
    • rusobr2
      • 45
      i thinks its “zemana” if the spellings rite
      • system
        PCHF Owner
        • 7634
        Zemana should uninstall through windows add/remove programs or better still by using revo uninstaller HERE . If you still have difficulty try re-installing it and then try to remove it in safe mode..
        • rusobr2
          • 45
          well the program zemana" would not “completely” uninstall with PC uninstaller and remained a “problem” … when i tried to uninstall “error mesgs” kept coming up,and wanted me to “reinstall, but the only reinstall that was an optional item was “pay to play” so to speak … yes, it wanted me to pay and upgrade” before it would uninstall (that’s the way i took it anyway)
          now i’m going to run the "revo product " you sent me, and we’ll see what happens …
          thanks, and i’ll be back
          thanks , steve
          • system
            PCHF Owner
            • 7634
            HERE’S a link to a trial version you don’t have to pay for if you have to reinstall it.
            • Malnutrition
              PCHF Moderator
              • 7045
              You can also use Geek Uninstaller on Force Mode to remove Zemana. But I am unsure how a free program without real time protection can hinder your computer use??
              [ATTACH]868[/ATTACH]
              • system
                PCHF Owner
                • 7634
                Depending on what happens with the above instructions maybe another look at a log might be in order??
                • jmarket
                  PCHF Owner
                  • 7634
                  Hey rusobr2
                  Any updates for us?
                    • 8982
                    #10
                    Do you have an update for us..?
                    Note: If no reply in 24 to 48 hrs. this thread will be closed,however you can have it re-opened.
