Wireless headset audio + mic problem
  • MihaiMalos
    • Apr 2020
    • 2
    Hi, i have a Sony WH-CH500 headset and i got a little problem there. I hear the sound very well when i’m not using the headset’s mic, but when i enter in a discord channel the audio freeze and just the microphone is working, but the audio is still working, but i can’t hear it. And it shows a pictogram that says discord is using the mic
    [IMG alt="9cdff952a59e5ca69760d1cf199e61f0" width="347px" height="58px"]https://i.gyazo.com/9cdff952a59e5ca69760d1cf199e61f0.png[/IMG]
    [IMG alt="e305c0e12aaf0207ad91aa59266fde96" width="114px" height="32px"]https://i.gyazo.com/e305c0e12aaf0207ad91aa59266fde96.png[/IMG]
  • Rustys
    • 7862
    Is it only in Discord that this is affected?
    • MihaiMalos
      • Apr 2020
      • 2
      No, it is on every app that use my microphone. On my phone it’s working properly, but on windows not
      • Rustys
        • 7862
        Others may have more ideas lets start here.
        @Bruce
        Open the Control Panel and select Sound
        Click on the Communications Tab
        Try different setting
        [ATTACH type=β€œfull”]6353[/ATTACH]
          so when you pair the headphones into your smartphone, audio and mic work fine.
          but paired to your PC and the audio stops once the mic is used - is that all correct?
          what is the PC device?
          is the headset only bluetooth connection?
          what versions of bluetooth do both devices run?
          • Rustys
            • 7862
            @MihaiMalos do you need any assistance?
            • Rustys
              • 7862
              No response from @MihaiMalos thread is closed.
