Computer help
This topic is closed.
  • mx_599
    • Nov 2024
    • 130
    #196
    hey guys, can I come back in a few days when keyboard comes? maybe we can finalize stuff at that time depending on ideas PeterOz has.
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      #197
      Originally posted by mx_599
      Everything is checked but I don’t receive email notification
      Did you enable push notifications?
      Of course you can.
      What keyboard did you order?
      • mx_599
        • Nov 2024
        • 130
        #198
        [HEADING=2]Apple A1242 Wired USB Aluminum Keyboard 2 USB Ports MB869LL/A[/HEADING]
        I got this one. I am excited. Even if it does not work for what we need, I would like to use with my new ubuntu desk top. I assume it can be used with any computer.
        it’s not coming until 1/7/25
        I got push going. but it is my uinderstanding that this just pushes to browesr. email still does not work. maybe the forum hates hotmail addresses?
        • PeterOz
          • Mar 2021
          • 4181
          #199
          Yes when you open your browser it will pop a notice out
          you can click on the notice and it will open to the thread
            #200
            @mx_599 - where we at?
            • PeterOz
              • Mar 2021
              • 4181
              #201
              Client does not get wired keyboard until 7/1/25 usa time
              • PeterOz
                • Mar 2021
                • 4181
                #202
                @veeg
                He gets the keyboard tomorrow.
                • mx_599
                  • Nov 2024
                  • 130
                  #203
                  I received the Apple Keyboard. Can we work on it this Friday or weekend? or even tomorrow night? I have a headache.
                  can you give me some of the prompts to try or should I scroll back and try to repeat a bunch of the prior ones with the key board plugged in?
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #204
                    I will set out what to try.
                    Do it when you can
                    • PeterOz
                      • Mar 2021
                      • 4181
                      #205
                      Firs thing is do you have all the data you needed off the mac.
                      If yes
                      with keyboard plugged in and wireless keyboard turned off.
                      Turn mac on whilst holding - Keep holding until you see something.
                      [li]Command-R: Start up from the built-in macOS Recovery System. Use this key combination to re-install the latest macOS that was installed on your system or to use the other apps in macOS Recovery.[/li][/ul]
                      This should give you a recovery screen similar to this. Your one won’t say Sonoma.
                      It will be El Captain or High Sierra
                      [ATTACH type=β€œfull” width=β€œ307px” size=β€œ960x884”]14965[/ATTACH]
                      If you get that screen choose the Reinstall mac os and click continue.
                      If the above does not work.
                      Power off
                      Start holding
                      [li]Option-Command-R: Start up from macOS Recovery over the internet. Use this key combination to re-install macOS and upgrade to the latest version of macOS that’s compatible with your Mac.[/li][/ul]
                      • mx_599
                        • Nov 2024
                        • 130
                        #206
                        I am going to try plugging this in here soon and trying this if you are around later. standby…
                        • mx_599
                          • Nov 2024
                          • 130
                          #207
                          Omg! I finally got something different!!!
                          It’s going slow as molasses.
                          Will update. Also I will be bumming around for day, probably tomorrow too
                          • mx_599
                            • Nov 2024
                            • 130
                            #208
                            Ok, got this! Completely different than anything we had before
                            I think you want me to reinstall X, 2nd option down?
                            I will wait a bit to see what you say
                            Yes, I am happy with the files you helped me recover. Shouldn’t be anything on there that I didn’t get on that other drive we got
                            [ATTACH type=β€œfull” size=β€œ3024x4032”]14996[/ATTACH]
                            • PeterOz
                              • Mar 2021
                              • 4181
                              #209
                              Do you have all the data you need off the computer
                              If yes choose reinstall Mac os x
                              • PeterOz
                                • Mar 2021
                                • 4181
                                #210
                                Do you have a cable plugged in for the internet.
                                You may need it.
