Hundreds of rundll32.exe running
This topic is closed.
  • Malnutrition
    PCHF Moderator
    • 7041
    #76
    Start autoruns as admin uncheck the items with a blue mark next to them and reboot the computer.
    [ATTACH alt=“1721278984422.png”]13972[/ATTACH]
    [ATTACH alt=“1721279056442.png”]13973[/ATTACH]
    [ATTACH alt=“1721279212898.png”]13974[/ATTACH]
    For now disable windows updte, you can update later when we are done here.
    In Windows There is no option to turn off Windows Updates. Windows Update Blocker is a tool that helps you to disable or enable Updates.
    Copy the content of the code box below.
    [COLOR=rgb(184, 49, 47)]Do not copy the word code!!!
    Right Click FRST and run as Administrator.
    Click Fix once (!) and wait. The program will create a log file (Fixlog.txt).
    Attach it to your next message.
    Code:
    start::
    CreateRestorePoint:
    EmptyTemp:
    CloseProcesses:
    EmptyEventLogs:
    S3 SbieDrv; \??\d:\Program Files\Sandboxie\SbieDrv.sys [X]
    C:\Users\Ripple\AppData\Roaming\obs-virtualcam.txt
    AlternateDataStreams: C:\ProgramData\autoclickconfig.ini:07021500A6 [5162]
    AlternateDataStreams: C:\ProgramData\empty.ico:8C1C1B484F [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\desktop.ini:B1DA6C571C [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Access.lnk:A1B76439FE [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BlueStacks 5.lnk:088221F38A [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BlueStacks Multi-Instance Manager.lnk:FE00AE19CB [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\desktop.ini:41964AA945 [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Excel.lnk:B96E9B8455 [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Firefox Private Browsing.lnk:C5112377E0 [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Firefox.lnk:980850BA8A [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk:8096E45125 [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes.lnk:C5D586BE93 [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Edge.lnk:E77773B271 [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OneNote.lnk:60EC9648C0 [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Outlook.lnk:5465085A2F [5162]
    AlternateDataStreams: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PowerPoint.lnk:1DC1525F34 [5162]
    Folder: C:\Windows\System32\Tasks
    StartBatch:
    WMIC SERVICE WHERE Name="dcomlaunch" set startmode="auto"
    WMIC SERVICE WHERE Name="nsi" set startmode="auto"
    WMIC SERVICE WHERE Name="dhcp" set startmode="auto"
    WMIC SERVICE WHERE Name="rpcss" set startmode="auto"
    WMIC SERVICE WHERE Name="rpceptmapper" set startmode="auto"
    WMIC SERVICE WHERE Name="winmgmt" set startmode="auto"
    WMIC SERVICE WHERE Name="sdrsvc" set startmode="manual"
    WMIC SERVICE WHERE Name="vss" set startmode="manual"
    WMIC SERVICE WHERE Name="eventlog" set startmode="auto"
    WMIC SERVICE WHERE Name="bfe" set startmode="auto"
    WMIC SERVICE WHERE Name="eventsystem" set startmode="auto"
    WMIC SERVICE WHERE Name="msiserver" set startmode="manual"
    WMIC SERVICE WHERE Name="sstpsvc" set startmode="manual"
    WMIC SERVICE WHERE Name="rasman" set startmode="manual"
    WMIC SERVICE WHERE Name="trustedinstaller" set startmode="auto"
    net start sdrsvc
    net start vss
    net start rpcss
    net start eventsystem
    net start winmgmt
    net start msiserver
    net start bfe
    net start trustedinstaller
    "%WINDIR%\SYSTEM32\lodctr.exe" /R
    "%WINDIR%\SysWOW64\lodctr.exe" /R
    NETSH winsock reset catalog
    NETSH int ipv4 reset reset.log
    NETSH int ipv6 reset reset.log
    ipconfig /release
    ipconfig /renew
    ipconfig /flushdns
    ipconfig /registerdns
    netsh winhttp reset proxy
    bitsadmin /list /allusers
    bitsadmin /reset /allusers
    Winmgmt /salvagerepository
    Winmgmt /resetrepository
    Winmgmt /resyncperf
    netsh advfirewall reset
    netsh advfirewall set allprofiles state on
    del /f /s /q %windir%\prefetch\*.*
    sc stop sysmain
    sc config sysmain start= disabled
    sc stop DiagTrack
    sc config DiagTrack start= disabled
    sc stop dmwappushservice
    sc config dmwappushservice start= disabled
    sc stop WSearch
    sc config WSearch start= disabled
    sc stop lfsvc
    sc config lfsvc start= disabled
    Endbatch:
    CMD: del /s /q "%userprofile%\AppData\Local\temp\*.*"
    ExportKey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa\TurnOffAnonymousBlock
    ExportKey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
    ExportKey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\RunOnce
    ExportKey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run
    ExportKey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run32
    ExportKey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\StartupFolder
    ExportKey: HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions
    emptytemp:
    Reboot:
    End::
    Security Check Scan.
    [li]Download Security Check to your desktop.[/li][li]Right click it run as administrator.[/li][li]When the program completes, the tool will automatically open a log file.[/li][li]Please [COLOR=rgb(184, 49, 47)]Copy and paste that log here in your next post.[/li][li]There will be items listed in red when you post this log, those items need to be updated.[/li][/ul]
    [/COLOR][/COLOR]
    • Malnutrition
      PCHF Moderator
      • 7041
      #77
      Download and run Privazer to clean up your system. This cleaner can take a while, but removes the most amount of crap…
      Then download AVZ4 save the file to your desktop, unzip it there.
      Double click the folder and find [COLOR=rgb(184, 49, 47)]AVZ.exe right click and run as admin.
      Do not drag this file out of the folder, it must be ran from within.
      Then go to file, then database update.
      Make sure and update.
      Then go to file troubleshooting wizard.
      Then under issue type go to system issues, should be there by default.
      Then under dangerousness level select all issues,
      Then hit the start button.
      Allow that scan to complete.
      [COLOR=rgb(184, 49, 47)]Do not change any settings on your own.
      Screen shot that for me an attach the result.
      Do the same under privacy.[/COLOR][/COLOR]
      • maxim123
        • Aug 2017
        • 472
        #78
        Hi, I will have to leave now for some time. I will do the above-mentioned steps once I return. Thank you.
        • maxim123
          • Aug 2017
          • 472
          #79
          couldn’t uncheck adobe type manager.
          [ATTACH type=“full”]13977[/ATTACH]
          I am continuing with other steps.
          • maxim123
            • Aug 2017
            • 472
            #80
            I have disabled win updates with the freeware you have provided.
            Fixlog.
            [HEADING=1]
            Code:
            Fix result of Farbar Recovery Scan Tool (x64) Version: 16.07.2024
            Ran by Max (19-07-2024 11:02:42) Run:3
            Running from C:\Users\Ripple\Desktop
            Loaded Profiles: Max
            Boot Mode: Normal[/HEADING]
            fixlist content:
            [HR][/HR]
            start::
            CreateRestorePoint:
            EmptyTemp:
            CloseProcesses:
            EmptyEventLogs:
            S3 SbieDrv; ??\d:\Program Files\Sandboxie\SbieDrv.sys
            StartBatch:
            WMIC SERVICE WHERE Name=“dcomlaunch” set startmode=“auto”
            WMIC SERVICE WHERE Name=“nsi” set startmode=“auto”
            WMIC SERVICE WHERE Name=“dhcp” set startmode=“auto”
            WMIC SERVICE WHERE Name=“rpcss” set startmode=“auto”
            WMIC SERVICE WHERE Name=“rpceptmapper” set startmode=“auto”
            WMIC SERVICE WHERE Name=“winmgmt” set startmode=“auto”
            WMIC SERVICE WHERE Name=“sdrsvc” set startmode=“manual”
            WMIC SERVICE WHERE Name=“vss” set startmode=“manual”
            WMIC SERVICE WHERE Name=“eventlog” set startmode=“auto”
            WMIC SERVICE WHERE Name=“bfe” set startmode=“auto”
            WMIC SERVICE WHERE Name=“eventsystem” set startmode=“auto”
            WMIC SERVICE WHERE Name=“msiserver” set startmode=“manual”
            WMIC SERVICE WHERE Name=“sstpsvc” set startmode=“manual”
            WMIC SERVICE WHERE Name=“rasman” set startmode=“manual”
            WMIC SERVICE WHERE Name=“trustedinstaller” set startmode=“auto”
            net start sdrsvc
            net start vss
            net start rpcss
            net start winmgmt
            net start msiserver
            net start bfe
            “%WINDIR%\SYSTEM32\lodctr.exe” /R
            “%WINDIR%\SysWOW64\lodctr.exe” /R
            ipconfig /release
            ipconfig /renew
            ipconfig /flushdns
            Winmgmt /resyncperf
            del /f /s /q %windir%\prefetch*.*
            sc stop sysmain
            sc stop DiagTrack
            sc stop WSearch
            sc stop lfsvc
            Endbatch:
            CMD: del /s /q “%userprofile%\AppData\Local\temp*.*”
            emptytemp:
            Reboot:
            End::
            [HR][/HR]
            =========== EmptyEventLogs: ==========
            1173 Event logs cleared.
            HKLM\System\CurrentControlSet\Services\SbieDrv => removed successfully
            SbieDrv => service removed successfully
            C:\Users\Ripple\AppData\Roaming\obs-virtualcam.txt => moved successfully
            C:\ProgramData\autoclickconfig.ini => “:07021500A6” ADS removed successfully
            C:\ProgramData\empty.ico => “:8C1C1B484F” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\desktop.ini => “:B1DA6C571C” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Access.lnk => “:A1B76439FE” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BlueStacks 5.lnk => “:088221F38A” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BlueStacks Multi-Instance Manager.lnk => “:FE00AE19CB” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\desktop.ini => “:41964AA945” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Excel.lnk => “:B96E9B8455” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Firefox Private Browsing.lnk => “:C5112377E0” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Firefox.lnk => “:980850BA8A” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk => “:8096E45125” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes.lnk => “:C5D586BE93” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Edge.lnk => “:E77773B271” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OneNote.lnk => “:60EC9648C0” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Outlook.lnk => “:5465085A2F” ADS removed successfully
            C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PowerPoint.lnk => “:1DC1525F34” ADS removed successfully
            ========================= Folder: C:\Windows\System32\Tasks ========================
            2024-07-12 11:51 - 2024-07-19 10:56 - 000003016 ____A [FDD89532680206F2087B6AA027D1AD51] () C:\Windows\System32\Tasks\BlueStacksHelper_nxt
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002590 ____A [350F8795900C9A972AA532E9BF5BA8F1] () C:\Windows\System32\Tasks\CreateExplorerShellUnelevatedTask
            2024-07-12 11:51 - 2024-07-19 10:57 - 000003298 ____A [E20BAC84A3A554F637B9DEA74AFC7BDD] () C:\Windows\System32\Tasks\MicrosoftEdgeUpdateTaskMachineCore
            2024-07-12 11:51 - 2024-07-19 10:57 - 000003522 ____A [03005B4CD693085373FE2B3CC22206E2] () C:\Windows\System32\Tasks\MicrosoftEdgeUpdateTaskMachineUA
            2024-07-12 11:51 - 2024-07-19 10:57 - 000002220 ____A [E71112CEB89B93A87C0D288BCCFE0EFA] () C:\Windows\System32\Tasks\npcapwatchdog
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\GoogleSystem
            2024-07-12 11:51 - 2024-07-19 10:32 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\GoogleSystem\GoogleUpdater
            2024-07-19 00:58 - 2024-07-19 10:56 - 000003342 ____A [54D1A30F0D8EE26D828AF8130A77917A] () C:\Windows\System32\Tasks\GoogleSystem\GoogleUpdater\GoogleUpdaterTaskSystem128.0.6537.3{1EF25398-1393-46D7-9025-1FC7773C3FA4}
            2022-05-07 11:09 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft
            2024-07-12 11:51 - 2024-07-12 12:06 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Office
            2024-07-12 11:51 - 2024-07-12 12:06 - 000005128 ____A [78FA3BE0DB89F79D4C1CB5E6984A43AA] () C:\Windows\System32\Tasks\Microsoft\Office\Office Automatic Updates 2.0
            2024-07-12 11:51 - 2024-07-19 10:56 - 000003512 ____A [329938F0F00402FDCF288EF89A7C135D] () C:\Windows\System32\Tasks\Microsoft\Office\Office ClickToRun Service Monitor
            2024-07-12 11:51 - 2024-07-12 12:06 - 000007256 ____A [6711BDD62C8C6CA1B147758423907878] () C:\Windows\System32\Tasks\Microsoft\Office\Office Feature Updates
            2024-07-12 11:51 - 2024-07-12 12:06 - 000004332 ____A [AD6DC17A43C5A6AEAEFC6CA714B15B82] () C:\Windows\System32\Tasks\Microsoft\Office\Office Feature Updates Logon
            2024-07-12 11:51 - 2024-07-19 10:56 - 000003038 ____A [42965EB2BC7528317952C570F9178AAB] () C:\Windows\System32\Tasks\Microsoft\Office\Office Performance Monitor
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\OneCore
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\OneCore\DirectX
            2022-05-07 11:09 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows.NET Framework
            2024-07-12 11:51 - 2024-07-13 16:20 - 000003706 ____A [770D3B37566D20D56592A3DF3DBBCFD5] () C:\Windows\System32\Tasks\Microsoft\Windows.NET Framework.NET Framework NGEN v4.0.30319
            2024-07-12 11:51 - 2024-07-13 16:20 - 000003712 ____A [A2275832D00F717F0CCFC51C32C7FE28] () C:\Windows\System32\Tasks\Microsoft\Windows.NET Framework.NET Framework NGEN v4.0.30319 64
            2024-07-12 11:51 - 2024-07-12 12:51 - 000002882 ____A [C32239A18C997402DB95FAF8A4F764D2] () C:\Windows\System32\Tasks\Microsoft\Windows.NET Framework.NET Framework NGEN v4.0.30319 64 Critical
            2024-07-12 11:51 - 2024-07-12 12:51 - 000002876 ____A [B86EBF660E5832FE736763B4098BF591] () C:\Windows\System32\Tasks\Microsoft\Windows.NET Framework.NET Framework NGEN v4.0.30319 Critical
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Active Directory Rights Management Services Client
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003978 ____A [4354BDCD3AEDEAB8BBE2281D6899D42D] () C:\Windows\System32\Tasks\Microsoft\Windows\Active Directory Rights Management Services Client\AD RMS Rights Policy Template Management (Automated)
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003426 ____A [D9E587010F978D667F0212B2144C44E1] () C:\Windows\System32\Tasks\Microsoft\Windows\Active Directory Rights Management Services Client\AD RMS Rights Policy Template Management (Manual)
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\AppID
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003436 ____A [0EF7D29DB858D8D00DC3F2F1DE323E6A] () C:\Windows\System32\Tasks\Microsoft\Windows\AppID\EDP Policy Manager
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002722 ____A [EEE41022E55AAEB619210E8366C2E048] () C:\Windows\System32\Tasks\Microsoft\Windows\AppID\PolicyConverter
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003346 ____A [AA4CCBF36BBBDBCC9BA1074FD310083D] () C:\Windows\System32\Tasks\Microsoft\Windows\AppID\VerifiedPublisherCertStoreCheck
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience
            2024-07-12 11:51 - 2024-07-19 10:56 - 000003420 ____A [5E522D6EF23C53474BF8458A52B47719] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\MareBackup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003344 ____A [3297209B6C9718B80C32CE0663C4505E] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser
            2024-07-12 11:51 - 2024-07-12 12:10 - 000004368 ____A [9F0ACCD368DEBDA3AA6D8B29423CF3EE] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\PcaPatchDbTask
            2024-07-12 11:51 - 2024-07-12 12:10 - 000004366 ____A [293A942896EA2C9DA850662689C2BDA5] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\PcaWallpaperAppDetect
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003430 ____A [320E240137DB59A95346BBF332557E80] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\SdbinstMergeDbTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003090 ____A [0BDE2A4342F763D8A55251395C14AF63] () C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\StartupAppTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\ApplicationData
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003316 ____A [EBD4D1229A8BAFE4D9E0624280E20596] () C:\Windows\System32\Tasks\Microsoft\Windows\ApplicationData\appuriverifierdaily
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003422 ____A [90FC38AE67C7E55DA1445FFCD73AAAEA] () C:\Windows\System32\Tasks\Microsoft\Windows\ApplicationData\appuriverifierinstall
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003052 ____A [B97EEB6111E0CAFC5660C41463BB20B4] () C:\Windows\System32\Tasks\Microsoft\Windows\ApplicationData\CleanupTemporaryState
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002716 ____A [BDCC5D5AEA37EEC6B1BEDC1EA832B098] () C:\Windows\System32\Tasks\Microsoft\Windows\ApplicationData\DsSvcCleanup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\AppListBackup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002796 ____A [59C40D50E5F6CA2A929033554F3EC102] () C:\Windows\System32\Tasks\Microsoft\Windows\AppListBackup\Backup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003086 ____A [9DF05D3978AA95FD6661C7F171055114] () C:\Windows\System32\Tasks\Microsoft\Windows\AppListBackup\BackupNonMaintenance
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\AppxDeploymentClient
            2024-07-12 11:51 - 2024-07-13 16:20 - 000003086 ____A [39622D5C2D4710EDA8BE8FD1D127EC79] () C:\Windows\System32\Tasks\Microsoft\Windows\AppxDeploymentClient\Pre-staged app cleanup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002546 ____A [95BD3C2A2156CBA24141D2A7765CF72B] () C:\Windows\System32\Tasks\Microsoft\Windows\AppxDeploymentClient\UCPD velocity
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Autochk
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002870 ____A [072DCBFD73085D1358EBACE36C1EE1F9] () C:\Windows\System32\Tasks\Microsoft\Windows\Autochk\Proxy
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\BitLocker
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002496 ____A [6D44CDECB427D524A30AA40A5C3869F7] () C:\Windows\System32\Tasks\Microsoft\Windows\BitLocker\BitLocker Encrypt All Drives
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002344 ____A [AB84CA8B1D44095F680E4C04F7B5A96F] () C:\Windows\System32\Tasks\Microsoft\Windows\BitLocker\BitLocker MDM policy Refresh
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Bluetooth
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002328 ____A [A90757604458D5A881FA829AB95E8FE1] () C:\Windows\System32\Tasks\Microsoft\Windows\Bluetooth\UninstallDeviceTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\BrokerInfrastructure
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003088 ____A [E1F8756D91FD0DE5CB739AC623134242] () C:\Windows\System32\Tasks\Microsoft\Windows\BrokerInfrastructure\BgTaskRegistrationMaintenanceTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\capabilityaccessmanager
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003082 ____A [9EEA2079AC92ECB0EAFEAC68A79CDA00] () C:\Windows\System32\Tasks\Microsoft\Windows\capabilityaccessmanager\maintenancetasks
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002936 ____A [24D6991FFA5884C59005B31E87CBEC5E] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\AikCertEnrollTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002830 ____A [64CA400E3ED6B9B6070691BD8836EB9B] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\CryptoPolicyTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000005486 ____A [CF6B96BBA76C987B91CBE4D4291DEF1A] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\KeyPreGenTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003694 ____A [B79F280F8B06288D6A92623C7360E01E] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\SystemTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000004816 ____A [AF919660DAC7699D4C89E0F7D8160781] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\UserTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003554 ____A [DA89EF2A15ED103DC6F29B1E9E1A4E4F] () C:\Windows\System32\Tasks\Microsoft\Windows\CertificateServicesClient\UserTask-Roam
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Chkdsk
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002780 ____A [BD35E15531B75FEDAAC17A4F070AC2F1] () C:\Windows\System32\Tasks\Microsoft\Windows\Chkdsk\ProactiveScan
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002448 ____A [1B083E31B0725873A0AE644ABEB9F777] () C:\Windows\System32\Tasks\Microsoft\Windows\Chkdsk\SyspartRepair
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Clip
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003428 ____A [9678E6CF1E5E28843E456B0F5D0182C7] () C:\Windows\System32\Tasks\Microsoft\Windows\Clip\License Validation
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003688 ____A [FD80F9E471C41C65D8FE84FFB386CE92] () C:\Windows\System32\Tasks\Microsoft\Windows\Clip\LicenseImdsIntegration
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\CloudExperienceHost
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002240 ____A [888E9CEB54341183623016C2A2747CEF] () C:\Windows\System32\Tasks\Microsoft\Windows\CloudExperienceHost\CreateObjectTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\CloudRestore
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003358 ____A [C78EF9AC5A72B7BB979EFCF7A1AB84A7] () C:\Windows\System32\Tasks\Microsoft\Windows\CloudRestore\Backup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002970 ____A [050212FCC2D02B05466BC1D5FA716598] () C:\Windows\System32\Tasks\Microsoft\Windows\CloudRestore\Restore
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\ConsentUX
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\ConsentUX\UnifiedConsent
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003252 ____A [32E9A5C09BABC1A0260137A41DFC422E] () C:\Windows\System32\Tasks\Microsoft\Windows\ConsentUX\UnifiedConsent\UnifiedConsentSyncTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Customer Experience Improvement Program
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003030 ____A [5D240C0C8A68AFA288D765EC717BECC8] () C:\Windows\System32\Tasks\Microsoft\Windows\Customer Experience Improvement Program\Consolidator
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003162 ____A [A6B83AE2E4B0CA541CE97AA8E6E3C8FB] () C:\Windows\System32\Tasks\Microsoft\Windows\Customer Experience Improvement Program\UsbCeip
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Data Integrity Scan
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003594 ____A [8A1D6C76B26AF75382D80096E6AA0346] () C:\Windows\System32\Tasks\Microsoft\Windows\Data Integrity Scan\Data Integrity Check And Scan
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002862 ____A [A1B1EC66118786EBF58DADB125429C52] () C:\Windows\System32\Tasks\Microsoft\Windows\Data Integrity Scan\Data Integrity Scan
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003354 ____A [6DDAD9C9B84F54A3FE6B533D8FEE3815] () C:\Windows\System32\Tasks\Microsoft\Windows\Data Integrity Scan\Data Integrity Scan for Crash Recovery
            2024-07-12 11:51 - 2024-07-12 12:02 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Defrag
            2024-07-12 11:51 - 2024-07-12 12:02 - 000003472 ____A [FFD43E95164AD372649A627E587CE473] () C:\Windows\System32\Tasks\Microsoft\Windows\Defrag\ScheduledDefrag
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Device Information
            2024-07-12 11:51 - 2024-07-12 11:51 - 000004326 ____A [F38FCAE149103B3E4628A11A9FD487D1] () C:\Windows\System32\Tasks\Microsoft\Windows\Device Information\Device
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002866 ____A [6A4748317A0246A14D7333C05A463661] () C:\Windows\System32\Tasks\Microsoft\Windows\Device Information\Device User
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Device Setup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002984 ____A [7C69AFA443BB72C29624594C91745CBB] () C:\Windows\System32\Tasks\Microsoft\Windows\Device Setup\Metadata Refresh
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002784 ____A [6BE0FF19B4D3A2CB575BAAFD4D293C58] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\HandleCommand
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002784 ____A [238CF788E1B152FDCBA470D99673F00B] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\HandleWnsCommand
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003440 ____A [FF684A54E3421C6060CF17E2598A1545] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\IntegrityCheck
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002810 ____A [11EC9F0F4711DE11619E3FE7A8C5D1F0] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\LocateCommandUserSession
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003404 ____A [EF174D6265FBFB667B6E793BCABA40E1] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDeviceAccountChange
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003546 ____A [449904DDE28B518BDB71A1CE06633B22] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDeviceLocationRightsChange
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003682 ____A [1AFCBE7783B0FCBD1BC6DD7021D66A48] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDevicePeriodic24
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003402 ____A [5BAF84542B623A4AADB5718E35A75E22] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDevicePolicyChange
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003154 ____A [7EC49C1A80A2A7D2AECCCA22C75CA05F] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDeviceProtectionStateChanged
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003414 ____A [CA5C44EE39FFD765101D68AC694BE348] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterDeviceSettingChange
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003520 ____A [0E6145D43CCD097F0E256EAA9A1564C5] () C:\Windows\System32\Tasks\Microsoft\Windows\DeviceDirectoryClient\RegisterUserDevice
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Diagnosis
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003852 ____A [73A2725B3CCAE7953393FE61B89340F7] () C:\Windows\System32\Tasks\Microsoft\Windows\Diagnosis\RecommendedTroubleshootingScanner
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003092 ____A [7850154410AFA2EB17A602F025E6EC5E] () C:\Windows\System32\Tasks\Microsoft\Windows\Diagnosis\Scheduled
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DirectX
            2024-07-12 11:51 - 2024-07-16 10:05 - 000003630 ____A [9A95ACC899B1EDAD3D08BC8EC92A8C59] () C:\Windows\System32\Tasks\Microsoft\Windows\DirectX\DirectXDatabaseUpdater
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002900 ____A [EE2D333C377AFF6C922639E7947A60CC] () C:\Windows\System32\Tasks\Microsoft\Windows\DirectX\DXGIAdapterCache
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DiskCleanup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003200 ____A [3E282B45FB904C517BC11B132923443F] () C:\Windows\System32\Tasks\Microsoft\Windows\DiskCleanup\SilentCleanup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DiskDiagnostic
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003034 ____A [A76EA9910F9DCDBF48784B6F05B728AB] () C:\Windows\System32\Tasks\Microsoft\Windows\DiskDiagnostic\Microsoft-Windows-DiskDiagnosticDataCollector
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002766 ____A [580B7B4B4D02CBB334C86B2FD3E72D47] () C:\Windows\System32\Tasks\Microsoft\Windows\DiskDiagnostic\Microsoft-Windows-DiskDiagnosticResolver
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DiskFootprint
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002398 ____A [6434B8D98519D8507799B75F77278A8E] () C:\Windows\System32\Tasks\Microsoft\Windows\DiskFootprint\Diagnostics
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002366 ____A [502CD952702469DBD01DD879142E78C4] () C:\Windows\System32\Tasks\Microsoft\Windows\DiskFootprint\StorageSense
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\DUSM
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002384 ____A [3013C7C46E9F8FB3A3FD86D945E18A2B] () C:\Windows\System32\Tasks\Microsoft\Windows\DUSM\dusmtask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\EDP
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002302 ____A [7E0493D9879855F5FC2BCFACA888240E] () C:\Windows\System32\Tasks\Microsoft\Windows\EDP\EDP App Launch Task
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002284 ____A [837912F46B2DE20227F1DA00239270C1] () C:\Windows\System32\Tasks\Microsoft\Windows\EDP\EDP Auth Task
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002348 ____A [CF66586664BB7592FA145CA49FE70581] () C:\Windows\System32\Tasks\Microsoft\Windows\EDP\EDP Inaccessible Credentials Task
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002344 ____A [DBBB4F8594EE96D519644858AACA2184] () C:\Windows\System32\Tasks\Microsoft\Windows\EDP\StorageCardEncryption Task
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\EnterpriseMgmt
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002182 ____A [C11C1CBFA7B00CEEAFB8EF5FE319679A] () C:\Windows\System32\Tasks\Microsoft\Windows\EnterpriseMgmt\MDMMaintenenceTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\ExploitGuard
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003172 ____A [840EEBFA16F463D5D0ED2977838DC228] () C:\Windows\System32\Tasks\Microsoft\Windows\ExploitGuard\ExploitGuard MDM policy Refresh
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Feedback
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Feedback\Siuf
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002880 ____A [E31D70482F0F894D02FD3BE61780C3B8] () C:\Windows\System32\Tasks\Microsoft\Windows\Feedback\Siuf\DmClient
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002998 ____A [E63288313283C274D13D8C8A11253568] () C:\Windows\System32\Tasks\Microsoft\Windows\Feedback\Siuf\DmClientOnScenarioDownload
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\File Classification Infrastructure
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003596 ____A [B165A04C8788CFFDA6E77F111C4E36C0] () C:\Windows\System32\Tasks\Microsoft\Windows\File Classification Infrastructure\Property Definition Sync
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\FileHistory
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002996 ____A [E8553B036871891D2902976B5D8DFB4A] () C:\Windows\System32\Tasks\Microsoft\Windows\FileHistory\File History (maintenance mode)
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Flighting
            2024-07-12 11:51 - 2024-07-12 12:10 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\FeatureConfig
            2024-07-12 12:10 - 2024-07-13 12:15 - 000004352 ____A [1142E92D0F511DDB9D2ED8BF520A167C] () C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\FeatureConfig\BootstrapUsageDataReporting
            2024-07-12 11:51 - 2024-07-12 12:10 - 000005892 ____A [893A23A4438EB17A85241AF25EE962E1] () C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\FeatureConfig\ReconcileFeatures
            2024-07-12 11:51 - 2024-07-12 12:10 - 000004532 ____A [53504124F16A8BB58E7B06423CBFF684] () C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\FeatureConfig\UsageDataFlushing
            2024-07-12 11:51 - 2024-07-12 12:10 - 000004288 ____A [060D5462F12AE442CF7E48DCD4F0C10A] () C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\FeatureConfig\UsageDataReporting
            2024-07-12 11:51 - 2024-07-12 12:10 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\OneSettings
            2024-07-12 11:51 - 2024-07-19 10:48 - 000004756 ____A [A88364DCAED847CD423239A12D58A075] () C:\Windows\System32\Tasks\Microsoft\Windows\Flighting\OneSettings\RefreshCache
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Input
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002850 ____A [6B2C276E41A107CD4AA743B6F3A76AB4] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\InputSettingsRestoreDataAvailable
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002754 ____A [38F682826E79ED251ABD657147F939A0] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\LocalUserSyncDataAvailable
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002738 ____A [281D46016A4A1E8DCF1BD89613030037] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\MouseSyncDataAvailable
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002730 ____A [0C640C60B154EC97631A3CE62E449006] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\PenSyncDataAvailable
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002714 ____A [CACAC5A847741F80B4D8C1DBE67A5E96] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\syncpensettings
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002750 ____A [1097778E348B283A2739CB02710B3D76] () C:\Windows\System32\Tasks\Microsoft\Windows\Input\TouchpadSyncDataAvailable
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\InstallService
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002612 ____A [07C0F5F0572596060737AAFB43E9C791] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\RestoreDevice
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003452 ____A [D9DB0431F925B621E4AC64847EF13879] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\ScanForUpdates
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002596 ____A [F263B544D83C8C2BFADD39E7295649A9] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\ScanForUpdatesAsUser
            2024-07-12 11:51 - 2024-07-18 10:20 - 000005154 ____A [8A0506DD02041A5E544AE85E4F887E4E] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\SmartRetry
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002572 ____A [4BB817BD0B97E53D9C7D8D53CC488467] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\WakeUpAndContinueUpdates
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003028 ____A [52D4F47FF729418D1FB032A5AB0B85E4] () C:\Windows\System32\Tasks\Microsoft\Windows\InstallService\WakeUpAndScanForUpdates
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\International
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003276 ____A [9291F9B9D3C9680975E47D30422AE9BB] () C:\Windows\System32\Tasks\Microsoft\Windows\International\Synchronize Language Settings
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Kernel
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002916 ____A [2878D4D00E81FAF4D5B8170555F1E6E8] () C:\Windows\System32\Tasks\Microsoft\Windows\Kernel\La57Cleanup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\LanguageComponentsInstaller
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003450 ____A [3959FC3E32785F26E488CC9AF61D2F0E] () C:\Windows\System32\Tasks\Microsoft\Windows\LanguageComponentsInstaller\Installation
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003242 ____A [AAEB417B86E1311F35082C762B8092D2] () C:\Windows\System32\Tasks\Microsoft\Windows\LanguageComponentsInstaller\ReconcileLanguageResources
            2024-07-12 11:51 - 2024-07-16 10:19 - 000003232 ____A [2416C715152434A0F8A173FC7AFE2C7C] () C:\Windows\System32\Tasks\Microsoft\Windows\LanguageComponentsInstaller\Uninstallation
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\License Manager
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003340 ____A [9DC1C49D39C701F6355891C2E7B8AFAF] () C:\Windows\System32\Tasks\Microsoft\Windows\License Manager\TempSignedLicenseExchange
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Live
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Live\Roaming
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Location
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002638 ____A [8BE17095C256CF953E79F61B0673D198] () C:\Windows\System32\Tasks\Microsoft\Windows\Location\Notifications
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002572 ____A [C6255EBB1E0F758FEE929CC972836ED6] () C:\Windows\System32\Tasks\Microsoft\Windows\Location\WindowsActionDialog
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Maintenance
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003002 ____A [53A65939335DBCAA6F8BB6C5EE27214F] () C:\Windows\System32\Tasks\Microsoft\Windows\Maintenance\WinSAT
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Management
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Management\Autopilot
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003016 ____A [00B3720E4C2502AB4B63D449554454BF] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Autopilot\DetectHardwareChange
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002866 ____A [1ECE3F7368920E96D1F3AE6D1BAAFE38] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Autopilot\RemediateHardwareChange
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002690 ____A [F13D37482360D587C450373A25D5F24F] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning\Cellular
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002704 ____A [5E70A09926C6A4D555066D9E1DD4F687] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning\Logon
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002602 ____A [C07737CD1D39B7BA06676EFA060F1ED8] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning\MdmDiagnosticsCleanup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002610 ____A [698DBE142A766FEA4FC67199DBFA4073] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning\Retry
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002634 ____A [0649BFE3C5F75154409407BE5DA66D1B] () C:\Windows\System32\Tasks\Microsoft\Windows\Management\Provisioning\RunOnReboot
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Maps
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003010 ____A [CBE62B6F890796A60DD13B650F63ADEA] () C:\Windows\System32\Tasks\Microsoft\Windows\Maps\MapsToastTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003474 ____A [762819BB0E3F48F605CECA2F7D519830] () C:\Windows\System32\Tasks\Microsoft\Windows\Maps\MapsUpdateTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\MemoryDiagnostic
            2024-07-12 11:51 - 2024-07-12 11:51 - 000005826 ____A [9F0D6291BCC9164234AE00909F8424E5] () C:\Windows\System32\Tasks\Microsoft\Windows\MemoryDiagnostic\ProcessMemoryDiagnosticEvents
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003506 ____A [700CD5CDE28679001B9E8A17B9A00CDE] () C:\Windows\System32\Tasks\Microsoft\Windows\MemoryDiagnostic\RunFullMemoryDiagnostic
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\MUI
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002726 ____A [0EAFF333690E2140CF92E358F647A07F] () C:\Windows\System32\Tasks\Microsoft\Windows\MUI\LPRemove
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Multimedia
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002574 ____A [728007430D778A49687344A5AFF65046] () C:\Windows\System32\Tasks\Microsoft\Windows\Multimedia\SystemSoundsService
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\NetTrace
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002444 ____A [82B51B2A4AF7173131DE09C6BA1D9D33] () C:\Windows\System32\Tasks\Microsoft\Windows\NetTrace\GatherNetworkInfo
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\NlaSvc
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002992 ____A [63C5DC8F8BD4C7AD339EDD8F05D87417] () C:\Windows\System32\Tasks\Microsoft\Windows\NlaSvc\WiFiTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Offline Files
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003170 ____A [FEEDE6809FF58339369FE0536AEDAE27] () C:\Windows\System32\Tasks\Microsoft\Windows\Offline Files\Background Synchronization
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002840 ____A [7360A82DD523D27126372EC7CFB7A8A3] () C:\Windows\System32\Tasks\Microsoft\Windows\Offline Files\Logon Synchronization
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\PI
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003676 ____A [6121E96EAF2C0087D1793A481E5F4F87] () C:\Windows\System32\Tasks\Microsoft\Windows\PI\SecureBootEncodeUEFI
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003516 ____A [28F354CB33B3C006B0EA951585ECF2C2] () C:\Windows\System32\Tasks\Microsoft\Windows\PI\Secure-Boot-Update
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002880 ____A [C554CC00ACC83521585043B7494191D6] () C:\Windows\System32\Tasks\Microsoft\Windows\PI\Sqm-Tasks
            2022-05-07 11:09 - 2022-05-07 11:09 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\PLA
            2022-05-07 11:09 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\PLA\System
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Plug and Play
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002972 ____A [7006D76C475F875686CC2B3A16F7E268] () C:\Windows\System32\Tasks\Microsoft\Windows\Plug and Play\Device Install Group Policy
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003028 ____A [D61490D56D6D66C8B9298A1220F43F49] () C:\Windows\System32\Tasks\Microsoft\Windows\Plug and Play\Device Install Reboot Required
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002338 ____A [EF7774860D9C4EE92A88CA23247087E2] () C:\Windows\System32\Tasks\Microsoft\Windows\Plug and Play\Sysprep Generalize Drivers
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Power Efficiency Diagnostics
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003128 ____A [180AAD66C4F7FA7B250B31B9DE349BF1] () C:\Windows\System32\Tasks\Microsoft\Windows\Power Efficiency Diagnostics\AnalyzeSystem
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Printing
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002590 ____A [B5CA0D4927CE89C08F3A71BE170ED4F5] () C:\Windows\System32\Tasks\Microsoft\Windows\Printing\EduPrintProv
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002840 ____A [984C26E454D816DDD581D058D43746C0] () C:\Windows\System32\Tasks\Microsoft\Windows\Printing\PrinterCleanupTask
            2024-07-12 11:51 - 2024-07-12 12:00 - 000002900 ____A [E8F50C7157BF421A74B6D64A6F0DEA58] () C:\Windows\System32\Tasks\Microsoft\Windows\Printing\PrintJobCleanupTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\PushToInstall
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003274 ____A [ACD87914D6481E5AB186D19716317A65] () C:\Windows\System32\Tasks\Microsoft\Windows\PushToInstall\LoginCheck
            2024-07-12 11:51 - 2024-07-19 10:36 - 000004280 ____A [A7E8C14FC851794901E536CDF8081205] () C:\Windows\System32\Tasks\Microsoft\Windows\PushToInstall\Registration
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Ras
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003462 ____A [CD108933BF9D3A1C35833955F6309B15] () C:\Windows\System32\Tasks\Microsoft\Windows\Ras\MobilityManager
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\RecoveryEnvironment
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003420 ____A [BF34A1CF5753F0832452E40502974461] () C:\Windows\System32\Tasks\Microsoft\Windows\RecoveryEnvironment\VerifyWinRE
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Registry
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003218 ____A [05777A5442924D1153176D5AC129E733] () C:\Windows\System32\Tasks\Microsoft\Windows\Registry\RegIdleBackup
            2022-05-07 11:09 - 2022-05-07 11:09 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\RemoteApp and Desktop Connections Update
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\RemoteAssistance
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003796 ____A [2A9FA9855B9BA3E94FC4DAA7CC3F2837] () C:\Windows\System32\Tasks\Microsoft\Windows\RemoteAssistance\RemoteAssistanceTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\RetailDemo
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Security
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Security\Pwdless
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003412 ____A [00000000000000000000000000000000] () C:\Windows\System32\Tasks\Microsoft\Windows\Security\Pwdless\IntelligentPwdlessTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Servicing
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002502 ____A [8699B124702DE82A8AFA348B36FE7338] () C:\Windows\System32\Tasks\Microsoft\Windows\Servicing\StartComponentCleanup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SettingSync
            2024-07-12 11:51 - 2024-07-15 09:43 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Setup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002838 ____A [8CAF365DE578AA10C0703CBF8106CAC9] () C:\Windows\System32\Tasks\Microsoft\Windows\Setup\SetupCleanupTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SharedPC
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002766 ____A [691CA16FBAA65A6D4983D0949F678F8B] () C:\Windows\System32\Tasks\Microsoft\Windows\SharedPC\Account Cleanup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Shell
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002636 ____A [E478D400176B927DF62A1EC131E0CE77] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\CreateObjectTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002622 ____A [DDCFF84B918E9D6465CB7B28FB0A7612] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\FamilySafetyMonitor
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003200 ____A [C4ECBFD478D78881435DA7E15FE76105] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\FamilySafetyRefreshTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002858 ____A [98BC4202BE211FC77B0D36B4900DEDA6] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\IndexerAutomaticMaintenance
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002482 ____A [2CACFCD99A7F0BA4A7BD3FAFFAE8AE11] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\ThemeAssetTask_SyncFODState
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003104 ____A [132925FD74EAD847954F40D6F94A6C6D] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\ThemesSyncedImageDownload
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002330 ____A [C6C43C44DEE21EB257D9439E733138DF] () C:\Windows\System32\Tasks\Microsoft\Windows\Shell\UpdateUserPictureTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SoftwareProtectionPlatform
            2024-07-12 11:51 - 2024-07-19 11:02 - 000004676 ____A [B6223A1AADF05B1884A905835FA2B32E] () C:\Windows\System32\Tasks\Microsoft\Windows\SoftwareProtectionPlatform\SvcRestartTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003312 ____A [8CBC84881481158749FD559D1D305C46] () C:\Windows\System32\Tasks\Microsoft\Windows\SoftwareProtectionPlatform\SvcRestartTaskLogon
            2024-07-12 11:51 - 2024-07-12 12:11 - 000003984 ____A [302A119B87944C644B8463363D118378] () C:\Windows\System32\Tasks\Microsoft\Windows\SoftwareProtectionPlatform\SvcRestartTaskNetwork
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003322 ____A [3FED7DA36547FB494449DFD6072DE650] () C:\Windows\System32\Tasks\Microsoft\Windows\SoftwareProtectionPlatform\SvcTrigger
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SpacePort
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003006 ____A [C68AC5388FB517EE7473E7CE3057D4AC] () C:\Windows\System32\Tasks\Microsoft\Windows\SpacePort\SpaceAgentTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003066 ____A [9E43447E0BF6F4548FD49B4CBAE4C81C] () C:\Windows\System32\Tasks\Microsoft\Windows\SpacePort\SpaceManagerTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Speech
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003276 ____A [0FED9B1246FE5B26E9EBB2B6D068447C] () C:\Windows\System32\Tasks\Microsoft\Windows\Speech\SpeechModelDownloadTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\StateRepository
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003112 ____A [183D04307BA05AC13166A073984CC57B] () C:\Windows\System32\Tasks\Microsoft\Windows\StateRepository\MaintenanceTasks
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Storage Tiers Management
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003204 ____A [B40EBFE0838AB7047C24F94B422FD580] () C:\Windows\System32\Tasks\Microsoft\Windows\Storage Tiers Management\Storage Tiers Management Initialization
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003290 ____A [FB566A50AF497D794A624B19D509616E] () C:\Windows\System32\Tasks\Microsoft\Windows\Storage Tiers Management\Storage Tiers Optimization
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Subscription
            2024-07-12 11:51 - 2024-07-12 11:51 - 000004684 ____A [86718857482C80C6C6A4E87C8CE54D82] () C:\Windows\System32\Tasks\Microsoft\Windows\Subscription\EnableLicenseAcquisition
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003758 ____A [C8CBEE3BB05636F7C0D1C98530C66A93] () C:\Windows\System32\Tasks\Microsoft\Windows\Subscription\LicenseAcquisition
            2022-05-07 11:09 - 2022-05-07 11:09 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SyncCenter
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Sysmain
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003056 ____A [E9F1539E90748BC8F9AF47003D83870D] () C:\Windows\System32\Tasks\Microsoft\Windows\Sysmain\HybridDriveCachePrepopulate
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003126 ____A [B251415191CB5DF30ABC19C607FB9570] () C:\Windows\System32\Tasks\Microsoft\Windows\Sysmain\HybridDriveCacheRebalance
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002972 ____A [93AC0F9DCF4B395B1D047FBDE22D886E] () C:\Windows\System32\Tasks\Microsoft\Windows\Sysmain\ResPriStaticDbSync
            2024-07-12 11:51 - 2024-07-16 10:24 - 000003858 ____A [F1C1C8BDD3D71C4DA978A1703159E4AF] () C:\Windows\System32\Tasks\Microsoft\Windows\Sysmain\WsSwapAssessmentTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\SystemRestore
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002976 ____A [7B4EF601179BED6FE32DB84939A55905] () C:\Windows\System32\Tasks\Microsoft\Windows\SystemRestore\SR
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Task Manager
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002762 ____A [62248D9B519AEB9F06998AF03D3023EE] () C:\Windows\System32\Tasks\Microsoft\Windows\Task Manager\Interactive
            2022-05-07 11:09 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\TaskScheduler
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\TextServicesFramework
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002622 ____A [688479812C2BAFE266ACDAF952BBC332] () C:\Windows\System32\Tasks\Microsoft\Windows\TextServicesFramework\MsCtfMonitor
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Time Synchronization
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003190 ____A [A957215CABCE94ADADD28EBDD76C67CA] () C:\Windows\System32\Tasks\Microsoft\Windows\Time Synchronization\ForceSynchronizeTime
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002900 ____A [1CA85B19D81E65D657F8538DC95055E5] () C:\Windows\System32\Tasks\Microsoft\Windows\Time Synchronization\SynchronizeTime
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Time Zone
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002600 ____A [33BB30ACA14F3F52139EDD37581D0B9F] () C:\Windows\System32\Tasks\Microsoft\Windows\Time Zone\SynchronizeTimeZone
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\TPM
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002816 ____A [3AD67DD47B006D6D20419FEE24BF399B] () C:\Windows\System32\Tasks\Microsoft\Windows\TPM\Tpm-HASCertRetr
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003592 ____A [DBBA597DD8D026AB3AF7295B476D1D13] () C:\Windows\System32\Tasks\Microsoft\Windows\TPM\Tpm-Maintenance
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\UNP
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003084 ____A [3282993A8B7FC8573AEAEBBF6E116167] () C:\Windows\System32\Tasks\Microsoft\Windows\UNP\RunUpdateNotificationMgr
            2024-07-12 11:51 - 2024-07-17 15:14 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator
            2024-07-12 11:51 - 2024-07-19 11:02 - 000003380 ____A [3672DB8374F857B00F74FFBB516A6BAF] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Report policies
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002324 ____A [4A1207C912587C864073A62A3CDE142A] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Schedule Maintenance Work
            2024-07-12 11:51 - 2024-07-19 11:02 - 000002730 ____A [84C9EE948CDD912FC4EDCC553F551AED] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Schedule Scan
            2024-07-12 11:51 - 2024-07-19 11:02 - 000004382 ____A [732319BCE149DAA5C92D20A19ECE3BB5] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Schedule Scan Static Task
            2024-07-12 11:51 - 2024-07-12 12:08 - 000003376 ____A [390C4CA7F90CE9FA8EE7729CD56A6D64] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Schedule Wake To Work
            2024-07-12 11:51 - 2024-07-19 10:46 - 000003362 ____A [B8E743E5D182065A3A0C9B02EF4EC645] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Schedule Work
            2024-07-12 11:51 - 2024-07-19 11:02 - 000003114 ____A [18FDD08EAAF67C3EA084F8AD2F8EC79A] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\Start Oobe Expedite Work
            2024-07-12 11:51 - 2024-07-19 11:02 - 000003064 ____A [67BF07D344697161CD2F5D2B3B53A612] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\StartOobeAppsScan_LicenseAccepted
            2024-07-12 11:51 - 2024-07-19 11:02 - 000003086 ____A [5225EF2E8CBDE5FF4BB3E8E33C333318] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\StartOobeAppsScanAfterUpdate
            2024-07-12 11:51 - 2024-07-19 11:02 - 000003058 ____A [98130A24A8DFE0CE84822E2DF2DEADB4] () C:\Windows\System32\Tasks\Microsoft\Windows\UpdateOrchestrator\UUS Failover Task
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\UPnP
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002328 ____A [614592EEDDA9F8208953550A929CAE63] () C:\Windows\System32\Tasks\Microsoft\Windows\UPnP\UPnPHostConfig
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\USB
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003496 ____A [4EE9864F2A542BF944A9014E6E0ABDA5] () C:\Windows\System32\Tasks\Microsoft\Windows\USB\Usb-Notifications
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\User Profile Service
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003650 ____A [F990F1B964EBE5E6DACE8C3B5C01E76F] () C:\Windows\System32\Tasks\Microsoft\Windows\User Profile Service\HiveUploadTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WaaSMedic
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003218 ____A [8D6B6FE629C79A128E46A71063DF3F53] () C:\Windows\System32\Tasks\Microsoft\Windows\WaaSMedic\PerformRemediation
            2022-05-07 11:09 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WCM
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002922 ____A [1DEEF230FFB132F3B772664DB91C1660] () C:\Windows\System32\Tasks\Microsoft\Windows\WCM\WiFiTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WDI
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002892 ____A [452959337E560E3F54599166FDACA2CD] () C:\Windows\System32\Tasks\Microsoft\Windows\WDI\ResolutionHost
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Activation Technologies
            2024-07-12 11:51 - 2024-07-16 10:24 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Defender
            2024-07-12 11:51 - 2024-07-16 10:24 - 000003816 ____A [0E1835929C6BAFBC49F6C5A83CB1CD41] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Cache Maintenance
            2024-07-12 11:51 - 2024-07-16 10:24 - 000003770 ____A [760E277C5B22309528E33EEC2ADC4E20] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Cleanup
            2024-07-12 11:51 - 2024-07-16 10:24 - 000003822 ____A [5075AF368DC7A5B1574A5B0DB6E327D0] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Scheduled Scan
            2024-07-12 11:51 - 2024-07-16 10:24 - 000003800 ____A [A47CE15091E55D020CAE8643F7DC3DD9] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Verification
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Error Reporting
            2024-07-12 11:51 - 2024-07-12 11:51 - 000004522 ____A [A870165FA94D21282A70FCABDFFBBEFF] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Error Reporting\QueueReporting
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Filtering Platform
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003288 ____A [C169971DBB83A272CD3925491D102517] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Filtering Platform\BfeOnServiceStartTypeChange
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Media Sharing
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003420 ____A [29788CF87DCF702A9516AEBC3EEDD0FC] () C:\Windows\System32\Tasks\Microsoft\Windows\Windows Media Sharing\UpdateLibrary
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Windows Subsystem For Linux
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WindowsBackup
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WindowsColorSystem
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003164 ____A [94AD66D07959598F514279EE85F6FFCA] () C:\Windows\System32\Tasks\Microsoft\Windows\WindowsColorSystem\Calibration Loader
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WindowsUpdate
            2024-07-12 11:51 - 2024-07-19 11:02 - 000003072 ____A [D87322B7AF634AFB0047B945AECD259C] () C:\Windows\System32\Tasks\Microsoft\Windows\WindowsUpdate\Refresh Group Policy Cache
            2024-07-12 11:51 - 2024-07-19 11:01 - 000004022 ____A [E83DCDCBAC2DAD168E9716CBBAC7E338] () C:\Windows\System32\Tasks\Microsoft\Windows\WindowsUpdate\Scheduled Start
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Wininet
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002564 ____A [652CA5AE0B16AC099DF8E45F72730C2B] () C:\Windows\System32\Tasks\Microsoft\Windows\Wininet\CacheTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WlanSvc
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002646 ____A [0E02197D41CBC25A6C969377F286A8C3] () C:\Windows\System32\Tasks\Microsoft\Windows\WlanSvc\CDSSync
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002860 ____A [A1E75931A6DC62F4D2C77E32E5BE632B] () C:\Windows\System32\Tasks\Microsoft\Windows\WlanSvc\MoProfileManagement
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WOF
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003060 ____A [8275A4BA11503CA1901151E1B5D556A4] () C:\Windows\System32\Tasks\Microsoft\Windows\WOF\WIM-Hash-Management
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002794 ____A [6AC7FCDC9047FAF56AC5BDEAC9B8D013] () C:\Windows\System32\Tasks\Microsoft\Windows\WOF\WIM-Hash-Validation
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Work Folders
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002790 ____A [4896237B881AA3E758AC1B0DDD3160AC] () C:\Windows\System32\Tasks\Microsoft\Windows\Work Folders\Work Folders Logon Synchronization
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003090 ____A [066A2DB4C72E617E8F1C2B15AE02494A] () C:\Windows\System32\Tasks\Microsoft\Windows\Work Folders\Work Folders Maintenance Work
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\Workplace Join
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003832 ____A [B17F649F80963DE7EE1CC18C573840E3] () C:\Windows\System32\Tasks\Microsoft\Windows\Workplace Join\Automatic-Device-Join
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003150 ____A [58B1C87F937EADB70ADDE26B8D5EAB2A] () C:\Windows\System32\Tasks\Microsoft\Windows\Workplace Join\Device-Sync
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002848 ____A [EF4E679D9823AE2D2A995E4FE7116B0D] () C:\Windows\System32\Tasks\Microsoft\Windows\Workplace Join\Recovery-Check
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WS
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\Windows\WwanSvc
            2024-07-12 11:51 - 2024-07-12 11:51 - 000003012 ____A [273C6C8ECD0A76FF04F5033EB2F5F00D] () C:\Windows\System32\Tasks\Microsoft\Windows\WwanSvc\NotificationTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000004292 ____A [04D9E30E380A9096A53D2872ED950BBF] () C:\Windows\System32\Tasks\Microsoft\Windows\WwanSvc\OobeDiscovery
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Microsoft\XblGameSave
            2024-07-12 11:51 - 2024-07-12 11:51 - 000002622 ____A [C60657E94BB87AD4189FA676C3248E39] () C:\Windows\System32\Tasks\Microsoft\XblGameSave\XblGameSaveTask
            2024-07-12 11:51 - 2024-07-12 11:51 - 000000000 ____D [00000000000000000000000000000000] C:\Windows\System32\Tasks\Mozilla
            2024-07-12 11:51 - 2024-07-19 10:57 - 000004114 ____A [AB9267BB9DCBBFB3BB41ADCEA9587E35] () C:\Windows\System32\Tasks\Mozilla\Firefox Background Update 308046B0AF4A39CB
            2024-07-12 11:51 - 2024-07-19 10:57 - 000003980 ____A [E9A76796016850AA782FA4D45D155F6F] () C:\Windows\System32\Tasks\Mozilla\Firefox Default Browser Agent 308046B0AF4A39CB
            ====== End of Folder: ======
            ========= Batch: =========
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“DcomLaunch”’
            Property(s) update successful.
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“nsi”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“Dhcp”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“RpcSs”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“RpcEptMapper”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“Winmgmt”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“SDRSVC”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“VSS”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“EventLog”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“BFE”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“EventSystem”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“msiserver”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“SstpSvc”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“RasMan”’
            Updating property(s) of ‘\DESKTOP-NLBF3N2\ROOT\CIMV2:Win32_Service.Name=“TrustedInstaller”’
            The Windows Backup service is starting.
            The Windows Backup service was started successfully.
            The requested service has already been started.
            More help is available by typing NET HELPMSG 2182.
            The Windows Installer service is starting.
            The Windows Installer service was started successfully.
            The Windows Modules Installer service is starting.
            The Windows Modules Installer service was started successfully.
            Info: Successfully rebuilt performance counter setting from system backup store
            Sucessfully reset the Winsock Catalog.
            You must restart the computer in order to complete the reset.
            Resetting Compartment Forwarding, OK!
            Resetting Compartment, OK!
            Resetting Control Protocol, OK!
            Resetting Echo Sequence Request, OK!
            Resetting Global, OK!
            Resetting Interface, OK!
            Resetting Anycast Address, OK!
            Resetting Multicast Address, OK!
            Resetting Unicast Address, OK!
            Resetting Neighbor, OK!
            Resetting Path, OK!
            Resetting Potential, OK!
            Resetting Prefix Policy, OK!
            Resetting Proxy Neighbor, OK!
            Resetting Route, OK!
            Resetting Site Prefix, OK!
            Resetting Subinterface, OK!
            Resetting Wakeup Pattern, OK!
            Resetting Resolve Neighbor, OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , failed.
            Access is denied.
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Restart the computer to complete this action.
            Resetting Path, OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , failed.
            Access is denied.
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Resetting , OK!
            Windows IP Configuration
            No operation can be performed on Wi-Fi while it has its media disconnected.
            No operation can be performed on Local Area Connection* 1 while it has its media disconnected.
            No operation can be performed on Local Area Connection* 10 while it has its media disconnected.
            No operation can be performed on Bluetooth Network Connection while it has its media disconnected.
            Ethernet adapter Ethernet:
            IPv6 Address. . . . . . . . . . . : 2404:7c00:48:9fb2:9a:a2a0:cf95:ea69
            Temporary IPv6 Address. . . . . . : 2404:7c00:48:9fb2:193:4a21:b946:6f0a
            Link-local IPv6 Address . . . . . : fe80::f61b:df1b:1949:74bd%11
            Default Gateway . . . . . . . . . : fe80::82f7:a6ff:fe26:b28c%11
            Wireless LAN adapter Wi-Fi:
            Wireless LAN adapter Local Area Connection* 1:
            Wireless LAN adapter Local Area Connection* 10:
            Ethernet adapter Bluetooth Network Connection:
            IPv4 Address. . . . . . . . . . . : 192.168.101.2
            192.168.101.1
            Registration of the DNS resource records for all adapters of this computer has been initiated. Any errors will be reported in the Event Viewer in 15 minutes.
            Current WinHTTP proxy settings:
            [CODE]Direct access (no proxy server).
            BITSADMIN version 3.0
            BITS administration utility.
            (C) Copyright Microsoft Corp.
            Listed 0 job(s).
            0 out of 0 jobs canceled.
            WMI repository is consistent
            WMI repository has been reset
            Ok.
            Ok.
            Deleted file - C:\WINDOWS\prefetch\0.DAT-78DFFE22.pf
            Deleted file - C:\WINDOWS\prefetch\0.DAT-AEC11D05.pf
            Deleted file - C:\WINDOWS\prefetch\126.0.6478.128_CHROME_INSTALL-38D806D2.pf
            Deleted file - C:\WINDOWS\prefetch\3RVX.EXE-5383B269.pf
            Deleted file - C:\WINDOWS\prefetch\7ZFM.EXE-44040917.pf
            Deleted file - C:\WINDOWS\prefetch\7ZG.EXE-D9AA3A0B.pf
            Deleted file - C:\WINDOWS\prefetch\ACCOUNTSCONTROLHOST.EXE-3ED0EE8B.pf
            Deleted file - C:\WINDOWS\prefetch\ADDINUTIL.EXE-4E6085D4.pf
            Deleted file - C:\WINDOWS\prefetch\AGGREGATORHOST.EXE-8DA5EB72.pf
            Deleted file - C:\WINDOWS\prefetch\AM_DELTA.EXE-78CA83B0.pf
            Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.103.0.EX-18A92BEB.pf
            Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.120.0.EX-42F42326.pf
            Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.125.0.EX-C7F1EF2F.pf
            Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.134.0.EX-1D973267.pf
            Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.150.0.EX-C6E29A6D.pf
            Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.50.0.EXE-2A7F4D80.pf
            Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.60.0.EXE-01241FED.pf
            Deleted file - C:\WINDOWS\prefetch\AM_DELTA_PATCH_1.415.66.0.EXE-07217B2B.pf
            Deleted file - C:\WINDOWS\prefetch\APPINSTALLER.EXE-B75F1120.pf
            Deleted file - C:\WINDOWS\prefetch\APPINSTALLERFULLTRUSTAPPSERVI-7A4B47DE.pf
            Deleted file - C:\WINDOWS\prefetch\APPLICATIONFRAMEHOST.EXE-8CE9A1EE.pf
            Deleted file - C:\WINDOWS\prefetch\APPVSHNOTIFY.EXE-FB3C42F5.pf
            Deleted file - C:\WINDOWS\prefetch\AUDIODG.EXE-AB22E9A6.pf
            Deleted file - C:\WINDOWS\prefetch\AUTOHOTKEYU64.EXE-6FF3B212.pf
            Deleted file - C:\WINDOWS\prefetch\AUTOHOTKEYUX.EXE-28C1E1E8.pf
            Deleted file - C:\WINDOWS\prefetch\AUTOLOGGER.EXE-11748E4D.pf
            Deleted file - C:\WINDOWS\prefetch\AUTORUNS64.EXE-7ED120A7.pf
            Deleted file - C:\WINDOWS\prefetch\AV_Z.EXE-4D174C78.pf
            Deleted file - C:\WINDOWS\prefetch\BACKGROUNDTASKHOST.EXE-6D58042C.pf
            Deleted file - C:\WINDOWS\prefetch\BACKGROUNDTASKHOST.EXE-97CA74D0.pf
            Deleted file - C:\WINDOWS\prefetch\BACKGROUNDTASKHOST.EXE-DFDB6B55.pf
            Deleted file - C:\WINDOWS\prefetch\BACKGROUNDTRANSFERHOST.EXE-1DD38560.pf
            Deleted file - C:\WINDOWS\prefetch\BCDEDIT.EXE-FE221428.pf
            Deleted file - C:\WINDOWS\prefetch\BITSADMIN.EXE-61856B04.pf
            Deleted file - C:\WINDOWS\prefetch\BYTECODEGENERATOR.EXE-FB938A53.pf
            Deleted file - C:\WINDOWS\prefetch\CALCULATORAPP.EXE-3E92A9D6.pf
            Deleted file - C:\WINDOWS\prefetch\CHCP.COM-2CF9B15C.pf
            Deleted file - C:\WINDOWS\prefetch\CHECKNETISOLATION.EXE-B39F2C30.pf
            Deleted file - C:\WINDOWS\prefetch\CHECK_FOR_64BIT_VISUAL_STUDIO-CE2ADCF6.pf
            Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA3C.pf
            Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA3D.pf
            Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA3E.pf
            Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA40.pf
            Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA45.pf
            Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA46.pf
            Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA47.pf
            Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA48.pf
            Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA49.pf
            Deleted file - C:\WINDOWS\prefetch\CHROME.EXE-AED7BA4A.pf
            Deleted file - C:\WINDOWS\prefetch\CHSIME.EXE-450F47D5.pf
            Deleted file - C:\WINDOWS\prefetch\CHXSMARTSCREEN.EXE-2D9D9C45.pf
            Deleted file - C:\WINDOWS\prefetch\CLEARLNK.EXE-63D5F4B4.pf
            Deleted file - C:\WINDOWS\prefetch\CLIPUP.EXE-4C5C7B66.pf
            Deleted file - C:\WINDOWS\prefetch\CMD.EXE-0BD30981.pf
            Deleted file - C:\WINDOWS\prefetch\CMD.EXE-6D6290C5.pf
            Deleted file - C:\WINDOWS\prefetch\COMPATTELRUNNER.EXE-B7A68ECC.pf
            Deleted file - C:\WINDOWS\prefetch\COMPPKGSRV.EXE-4780F0C1.pf
            Deleted file - C:\WINDOWS\prefetch\COMPUTERHARDWAREIDS.EXE-21FB5DC0.pf
            Deleted file - C:\WINDOWS\prefetch\CONHOST.EXE-0C6456FB.pf
            Deleted file - C:\WINDOWS\prefetch\CONSENT.EXE-40419367.pf
            Deleted file - C:\WINDOWS\prefetch\CROSSDEVICESERVICE.EXE-1987D0F6.pf
            Deleted file - C:\WINDOWS\prefetch\CSC.EXE-B6D5E435.pf
            Deleted file - C:\WINDOWS\prefetch\CSLOL-DIAG.EXE-9AB04EE5.pf
            Deleted file - C:\WINDOWS\prefetch\CSLOL-MANAGER.EXE-CE44A2A0.pf
            Deleted file - C:\WINDOWS\prefetch\CTFMON.EXE-795F8130.pf
            Deleted file - C:\WINDOWS\prefetch\CVTRES.EXE-BBD3ED93.pf
            Deleted file - C:\WINDOWS\prefetch\DATAEXCHANGEHOST.EXE-8B66795C.pf
            Deleted file - C:\WINDOWS\prefetch\DBINSTALLER.EXE-284684E2.pf
            Deleted file - C:\WINDOWS\prefetch\DEFAULTTOOL.EXE-41C87A60.pf
            Deleted file - C:\WINDOWS\prefetch\DEFRAG.EXE-3D9E8D72.pf
            Deleted file - C:\WINDOWS\prefetch\DEVCON.EXE-66458A35.pf
            Deleted file - C:\WINDOWS\prefetch\DIRECTXDATABASEUPDATER.EXE-7B8AED66.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF221.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF222.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF223.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF224.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF225.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-3F4EF229.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D66.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D67.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D68.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D69.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D6A.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORD.EXE-968B1D6E.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORDHOOKHELPER.EXE-39E1795B.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORDHOOKHELPER.EXE-73597721.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORDHOOKHELPER64.EXE-326CF78D.pf
            Deleted file - C:\WINDOWS\prefetch\DISCORDHOOKHELPER64.EXE-4CB86EF3.pf
            Deleted file - C:\WINDOWS\prefetch\DISM.EXE-AA0F2086.pf
            Deleted file - C:\WINDOWS\prefetch\DISMHOST.EXE-9ED88D89.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-0BCCFE33.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-1BAE06BB.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-47BE07DC.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-51C0C0B8.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-6F625E57.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-7D5CE0CA.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-858FE9DA.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-97AE7A57.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-A3CD2B45.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-A6DA1980.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-B8720A9F.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-D200FEC3.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-DEEF2761.pf
            Deleted file - C:\WINDOWS\prefetch\DLLHOST.EXE-F7FC6593.pf
            Deleted file - C:\WINDOWS\prefetch\DOUYIN.EXE-62DB6C84.pf
            Deleted file - C:\WINDOWS\prefetch\DOUYIN.EXE-62DB6C85.pf
            Deleted file - C:\WINDOWS\prefetch\DOUYIN.EXE-62DB6C86.pf
            Deleted file - C:\WINDOWS\prefetch\DOUYIN.EXE-62DB6C8C.pf
            Deleted file - C:\WINDOWS\prefetch\DOUYIN_LAUNCHER.EXE-3CA6CE73.pf
            Deleted file - C:\WINDOWS\prefetch\DOUYIN_TRAY.EXE-CB951C9B.pf
            Deleted file - C:\WINDOWS\prefetch\DRVINST.EXE-39D9EAC7.pf
            Deleted file - C:\WINDOWS\prefetch\DSMUSERTASK.EXE-853A6893.pf
            Deleted file - C:\WINDOWS\prefetch\DUMP_REPORTER.EXE-A2CA3D84.pf
            Deleted file - C:\WINDOWS\prefetch\DWM.EXE-314E93C5.pf
            Deleted file - C:\WINDOWS\prefetch\dynrespri.7db
            Deleted file - C:\WINDOWS\prefetch\ELEVATION_SERVICE.EXE-4FCD2BB0.pf
            Deleted file - C:\WINDOWS\prefetch\ELEVATION_SERVICE.EXE-527613F3.pf
            Deleted file - C:\WINDOWS\prefetch\ELEVATION_SERVICE.EXE-87CAB08F.pf
            Deleted file - C:\WINDOWS\prefetch\ELEVATION_SERVICE.EXE-8B683CA8.pf
            Deleted file - C:\WINDOWS\prefetch\EVERYTHING-1.4.1.1024.X64-SET-9A7A990B.pf
            Deleted file - C:\WINDOWS\prefetch\EVERYTHING.EXE-2260A499.pf
            Deleted file - C:\WINDOWS\prefetch\EVERYTHING.EXE-5F5BA4E5.pf
            Deleted file - C:\WINDOWS\prefetch\EXCEL.EXE-FE860005.pf
            Deleted file - C:\WINDOWS\prefetch\EXPLORER.EXE-54012F5E.pf
            Deleted file - C:\WINDOWS\prefetch\EXPLORER.EXE-D5E97654.pf
            Deleted file - C:\WINDOWS\prefetch\FIND.EXE-66A35B26.pf
            Deleted file - C:\WINDOWS\prefetch\FIREFOX.EXE-66015FD1.pf
            Deleted file - C:\WINDOWS\prefetch\FRST64.EXE-8A45F98D.pf
            Deleted file - C:\WINDOWS\prefetch\FSQUIRT.EXE-A8FF1DEB.pf
            Deleted file - C:\WINDOWS\prefetch\GAMEBARPRESENCEWRITER.EXE-5ADEE7C2.pf
            Deleted file - C:\WINDOWS\prefetch\GCUSERVICE.EXE-B6520827.pf
            Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-1CD184BF.pf
            Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-3BB6BE9E.pf
            Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-7F0CD7C6.pf
            Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-83F04398.pf
            Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-9B08747A.pf
            Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-B433E1C8.pf
            Deleted file - C:\WINDOWS\prefetch\GEEK.EXE-E3E71DA6.pf
            Deleted file - C:\WINDOWS\prefetch\GEEK64.EXE-69B8A6E8.pf
            Deleted file - C:\WINDOWS\prefetch\GET-GRAPHICS-OFFSETS32.EXE-DA327B27.pf
            Deleted file - C:\WINDOWS\prefetch\GET-GRAPHICS-OFFSETS64.EXE-313543E8.pf
            Deleted file - C:\WINDOWS\prefetch\GPU_ENCODER_HELPER.EXE-3534FDB9.pf
            Deleted file - C:\WINDOWS\prefetch\GPU_ENCODER_HELPER.EXE-5578D93C.pf
            Deleted file - C:\WINDOWS\prefetch\GRPCONV.EXE-A548DBA8.pf
            Deleted file - C:\WINDOWS\prefetch\GSDK-VULKAN-INIT.EXE-2B90F7F0.pf
            Deleted file - C:\WINDOWS\prefetch\HIJACKTHIS.EXE-43AA66B9.pf
            Deleted file - C:\WINDOWS\prefetch\IDENTITY_HELPER.EXE-B1938933.pf
            Deleted file - C:\WINDOWS\prefetch\IDMAN.EXE-82E77CDF.pf
            Deleted file - C:\WINDOWS\prefetch\IDMGRHLP.EXE-C29D073D.pf
            Deleted file - C:\WINDOWS\prefetch\IDMINTEGRATOR64.EXE-6B94A449.pf
            Deleted file - C:\WINDOWS\prefetch\IDMMSGHOST.EXE-9A561A25.pf
            Deleted file - C:\WINDOWS\prefetch\IEXPLORE.EXE-058FE8F5.pf
            Deleted file - C:\WINDOWS\prefetch\IEXPLORE.EXE-A033F7A0.pf
            Deleted file - C:\WINDOWS\prefetch\INSTALLUTIL.EXE-BB270139.pf
            Deleted file - C:\WINDOWS\prefetch\INTEGRATOR.EXE-873C4A60.pf
            Deleted file - C:\WINDOWS\prefetch\IPCONFIG.EXE-BFEC2AD0.pf
            Deleted file - C:\WINDOWS\prefetch\IPF_HELPER.EXE-337CFBF9.pf
            Deleted file - C:\WINDOWS\prefetch\IPF_UF.EXE-93A855E0.pf
            Deleted file - C:\WINDOWS\prefetch\JAVAW.EXE-44DB5C38.pf
            Deleted file - C:\WINDOWS\prefetch\Layout.ini
            Deleted file - C:\WINDOWS\prefetch\LEAGUE OF LEGENDS.EXE-BE4BA152.pf
            Deleted file - C:\WINDOWS\prefetch\LEAGUECLIENT.EXE-F9AC060C.pf
            Deleted file - C:\WINDOWS\prefetch\LEAGUECLIENTUX.EXE-67EA7345.pf
            Deleted file - C:\WINDOWS\prefetch\LEAGUECLIENTUXRENDER.EXE-3C47C0AE.pf
            Deleted file - C:\WINDOWS\prefetch\LEAGUECLIENTUXRENDER.EXE-3C47C0AF.pf
            Deleted file - C:\WINDOWS\prefetch\LEAGUECLIENTUXRENDER.EXE-3C47C0B5.pf
            Deleted file - C:\WINDOWS\prefetch\LEAGUECRASHHANDLER64.EXE-1095281E.pf
            Deleted file - C:\WINDOWS\prefetch\LEAGUECRASHHANDLER64.EXE-EBE229AC.pf
            Deleted file - C:\WINDOWS\prefetch\LOCKAPP.EXE-7ED5B9D8.pf
            Deleted file - C:\WINDOWS\prefetch\LODCTR.EXE-21DD01F9.pf
            Deleted file - C:\WINDOWS\prefetch\LODCTR.EXE-57DC4D95.pf
            Deleted file - C:\WINDOWS\prefetch\LOGONUI.EXE-F639BD7E.pf
            Deleted file - C:\WINDOWS\prefetch\MDSCHED.EXE-21C4D84D.pf
            Deleted file - C:\WINDOWS\prefetch\METAEDITOR.EXE-7164C368.pf
            Deleted file - C:\WINDOWS\prefetch\MICROSOFTEDGEUPDATE.EXE-7A595326.pf
            Deleted file - C:\WINDOWS\prefetch\MMC.EXE-410C5F73.pf
            Deleted file - C:\WINDOWS\prefetch\MOBSYNC.EXE-B307E1CC.pf
            Deleted file - C:\WINDOWS\prefetch\MOD-TOOLS.EXE-24AA5448.pf
            Deleted file - C:\WINDOWS\prefetch\MOFCOMP.EXE-5225C32D.pf
            Deleted file - C:\WINDOWS\prefetch\MONOTIFICATIONUX.EXE-23180524.pf
            Deleted file - C:\WINDOWS\prefetch\MONOTIFICATIONUX.EXE-62024999.pf
            Deleted file - C:\WINDOWS\prefetch\MOUSECLICKER.EXE-4DEF9CEE.pf
            Deleted file - C:\WINDOWS\prefetch\MOUSOCOREWORKER.EXE-44A01CE7.pf
            Deleted file - C:\WINDOWS\prefetch\MPCMDRUN.EXE-766ACDEA.pf
            Deleted file - C:\WINDOWS\prefetch\MPCMDRUN.EXE-82616995.pf
            Deleted file - C:\WINDOWS\prefetch\MPDEFENDERCORESERVICE.EXE-9657D0C8.pf
            Deleted file - C:\WINDOWS\prefetch\MPRECOVERY.EXE-F2C7680F.pf
            Deleted file - C:\WINDOWS\prefetch\MPSIGSTUB.EXE-5D0450B3.pf
            Deleted file - C:\WINDOWS\prefetch\MPSIGSTUB.EXE-FD441709.pf
            Deleted file - C:\WINDOWS\prefetch\MSCORSVW.EXE-16B291C4.pf
            Deleted file - C:\WINDOWS\prefetch\MSCORSVW.EXE-8CE1A322.pf
            Deleted file - C:\WINDOWS\prefetch\MSDT.EXE-D579957D.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25F9A.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25F9B.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25F9C.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25F9E.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25FA5.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25FA6.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25FA7.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25FA8.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGE.EXE-37D25FAA.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE758A.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE758B.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE758C.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE758E.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE7594.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE7595.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-72EE7598.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4AF.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4B0.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4B1.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4B3.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4B9.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4BA.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4BC.pf
            Deleted file - C:\WINDOWS\prefetch\MSEDGEWEBVIEW2.EXE-953EC4BD.pf
            Deleted file - C:\WINDOWS\prefetch\MSIEXEC.EXE-8FFB1633.pf
            Deleted file - C:\WINDOWS\prefetch\MSIEXEC.EXE-CDBFC0F7.pf
            Deleted file - C:\WINDOWS\prefetch\MSMPENG.EXE-37E24A32.pf
            Deleted file - C:\WINDOWS\prefetch\MSMPENG.EXE-AC5FF58F.pf
            Deleted file - C:\WINDOWS\prefetch\MSPAINT.EXE-CB27A74E.pf
            Deleted file - C:\WINDOWS\prefetch\N2NIMHE1.EXE-EE203998.pf
            Deleted file - C:\WINDOWS\prefetch\NET.EXE-0225D674.pf
            Deleted file - C:\WINDOWS\prefetch\NET.EXE-A0964F30.pf
            Deleted file - C:\WINDOWS\prefetch\NET1.EXE-091D8149.pf
            Deleted file - C:\WINDOWS\prefetch\NET1.EXE-509326A5.pf
            Deleted file - C:\WINDOWS\prefetch\NETSH.EXE-A596235F.pf
            Deleted file - C:\WINDOWS\prefetch\NGEN.EXE-4A8DA13E.pf
            Deleted file - C:\WINDOWS\prefetch\NGEN.EXE-734C6620.pf
            Deleted file - C:\WINDOWS\prefetch\NGENTASK.EXE-0E6CEC17.pf
            Deleted file - C:\WINDOWS\prefetch\NGENTASK.EXE-849BFD75.pf
            Deleted file - C:\WINDOWS\prefetch\NISSRV.EXE-72EC3F25.pf
            Deleted file - C:\WINDOWS\prefetch\NISSRV.EXE-98CC5D80.pf
            Deleted file - C:\WINDOWS\prefetch\NOTEPAD.EXE-162FBFE7.pf
            Deleted file - C:\WINDOWS\prefetch\NVCLEANSTALL_1.16.0.EXE-01060082.pf
            Deleted file - C:\WINDOWS\prefetch\NVCLEANSTALL_7ZIP.EXE-1A9B9602.pf
            Deleted file - C:\WINDOWS\prefetch\NVDISPCO64.EXE-FA73F936.pf
            Deleted file - C:\WINDOWS\prefetch\NVDISPLAY.CONTAINER.EXE-EE9DB6A0.pf
            Deleted file - C:\WINDOWS\prefetch\NVIDIA-SMI.EXE-43C94612.pf
            Deleted file - C:\WINDOWS\prefetch\NVIDIA-SMI.EXE-5733439B.pf
            Deleted file - C:\WINDOWS\prefetch\NVNGX_UPDATE.EXE-CB453E5D.pf
            Deleted file - C:\WINDOWS\prefetch\NVSHIM.EXE-C1BF347B.pf
            Deleted file - C:\WINDOWS\prefetch\NYTJDFGLX1N.EXE-488A4B0B.pf
            Deleted file - C:\WINDOWS\prefetch\OAWRAPPER.EXE-C9A635FF.pf
            Deleted file - C:\WINDOWS\prefetch\OBS-BACKGROUNDREMOVAL-1.1.13–0C530748.pf
            Deleted file - C:\WINDOWS\prefetch\OBS-BACKGROUNDREMOVAL-1.1.13–1593CFC8.pf
            Deleted file - C:\WINDOWS\prefetch\OBS-BACKGROUNDREMOVAL-1.1.13–BD4C73AB.pf
            Deleted file - C:\WINDOWS\prefetch\OBS-BROWSER-PAGE.EXE-B650FAFD.pf
            Deleted file - C:\WINDOWS\prefetch\OBS-BROWSER-PAGE.EXE-B650FAFE.pf
            Deleted file - C:\WINDOWS\prefetch\OBS-BROWSER-PAGE.EXE-B650FB04.pf
            Deleted file - C:\WINDOWS\prefetch\OBS-NVENC-TEST.EXE-256562AF.pf
            Deleted file - C:\WINDOWS\prefetch\OBS-QSV-TEST.EXE-C01625D7.pf
            Deleted file - C:\WINDOWS\prefetch\OBS-STUDIO-30.2.0-WINDOWS-INS-40CB636A.pf
            Deleted file - C:\WINDOWS\prefetch\OBS64.EXE-40AD00BD.pf
            Deleted file - C:\WINDOWS\prefetch\OFFICECLICKTORUN.EXE-4587B16B.pf
            Deleted file - C:\WINDOWS\prefetch\OFFICECLICKTORUN.EXE-F5CCE208.pf
            Deleted file - C:\WINDOWS\prefetch\OMEGAT.EXE-3F06549A.pf
            Deleted file - C:\WINDOWS\prefetch\ONEDRIVESETUP.EXE-2F4C4906.pf
            Deleted file - C:\WINDOWS\prefetch\OPENCONSOLE.EXE-A617E510.pf
            Deleted file - C:\WINDOWS\prefetch\OPENWITH.EXE-8B50D58B.pf
            Deleted file - C:\WINDOWS\prefetch\PERFBOOST.EXE-D7CAB4F4.pf
            Deleted file - C:\WINDOWS\prefetch\PfPre_2fa6a7e2.mkd
            Deleted file - C:\WINDOWS\prefetch\PHOTOS.EXE-1D3AFA6C.pf
            Deleted file - C:\WINDOWS\prefetch\PICKERHOST.EXE-DE4B8E61.pf
            Deleted file - C:\WINDOWS\prefetch\PING.EXE-0314C2F7.pf
            Deleted file - C:\WINDOWS\prefetch\PINGSENDER.EXE-B4914655.pf
            Deleted file - C:\WINDOWS\prefetch\PLUGIN-CONTAINER.EXE-C6EE3785.pf
            Deleted file - C:\WINDOWS\prefetch\PNPUTIL.EXE-372B05C1.pf
            Deleted file - C:\WINDOWS\prefetch\POQEXEC.EXE-567EE1A6.pf
            Deleted file - C:\WINDOWS\prefetch\POWERSHELL.EXE-AE8EDC9B.pf
            Deleted file - C:\WINDOWS\prefetch\POWERSHELL.EXE-CA1AE517.pf
            Deleted file - C:\WINDOWS\prefetch\PREMID-INSTALLER.EXE-C47DB514.pf
            Deleted file - C:\WINDOWS\prefetch\PREMID.EXE-DFD65C30.pf
            Deleted file - C:\WINDOWS\prefetch\PREMID.EXE-DFD65C32.pf
            Deleted file - C:\WINDOWS\prefetch\PREMID.EXE-DFD65C38.pf
            Deleted file - C:\WINDOWS\prefetch\PROCEXP64.EXE-9F0720F4.pf
            Deleted file - C:\WINDOWS\prefetch\PWAHELPER.EXE-93ECA8BC.pf
            Deleted file - C:\WINDOWS\prefetch\QBITTORRENT.EXE-97E1315C.pf
            Deleted file - C:\WINDOWS\prefetch\QS76K3X5.EXE-9501BC5C.pf
            Deleted file - C:\WINDOWS\prefetch\QUALIFICATION_APP.EXE-C5E6086A.pf
            Deleted file - C:\WINDOWS\prefetch\RAZERINSTALLER.EXE-108EAF16.pf
            Deleted file - C:\WINDOWS\prefetch\RAZERSYNAPSEINSTALLER_PRODDIS-4FE6294D.pf
            Deleted file - C:\WINDOWS\prefetch\REG.EXE-0AC99A87.pf
            Deleted file - C:\WINDOWS\prefetch\REG.EXE-A93A1343.pf
            Deleted file - C:\WINDOWS\prefetch\REGEDIT.EXE-DAB4D60B.pf
            Deleted file - C:\WINDOWS\prefetch\REGSVR32.EXE-03D3FB87.pf
            Deleted file - C:\WINDOWS\prefetch\REGSVR32.EXE-B31EC963.pf
            Deleted file - C:\WINDOWS\prefetch\ResPriUHMStaticDb.ebd
            Deleted file - C:\WINDOWS\prefetch\RIOT CLIENT.EXE-DB5D0153.pf
            Deleted file - C:\WINDOWS\prefetch\RIOT CLIENT.EXE-DB5D0154.pf
            Deleted file - C:\WINDOWS\prefetch\RIOT CLIENT.EXE-DB5D0155.pf
            Deleted file - C:\WINDOWS\prefetch\RIOT CLIENT.EXE-DB5D015A.pf
            Deleted file - C:\WINDOWS\prefetch\RIOT CLIENT.EXE-DB5D015B.pf
            Deleted file - C:\WINDOWS\prefetch\RIOTCLIENTCRASHHANDLER.EXE-56653DA5.pf
            Deleted file - C:\WINDOWS\prefetch\RIOTCLIENTSERVICES.EXE-0C7DC176.pf
            Deleted file - C:\WINDOWS\prefetch\RSITX64.EXE-68FCBFCB.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-012D304A.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-0B0F028C.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-26F63A71.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-27E52A2D.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-29B5A95A.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-6E75ABA4.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-7241955C.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-75313621.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-880E5BDF.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-A751CE9B.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-A7DB9FAD.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-C0159C27.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-C575CB2E.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-C87919CF.pf
            Deleted file - C:\WINDOWS\prefetch\RUNDLL32.EXE-CCD98664.pf
            Deleted file - C:\WINDOWS\prefetch\RUNONCE.EXE-BD8A4C8F.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-0C405ED0.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-28060877.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-3B032F93.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-4163B14B.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-4551A062.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-489B63D4.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-4D3D38F0.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-5B4167E1.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-7475E422.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-967B2208.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-AB37D56F.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-B408371A.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-B5475AD7.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-B95961EC.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-C6D4F558.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-CEE04A22.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-D0F9CBDE.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-D9F8A976.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-DE17AACA.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-E0A7F531.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-E404484C.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-E4296D27.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-F0E0C793.pf
            Deleted file - C:\WINDOWS\prefetch\RUNTIMEBROKER.EXE-FE5973AE.pf
            Deleted file - C:\WINDOWS\prefetch\RZS3WIZARDPKGS3.EXE-8AEC2626.pf
            Deleted file - C:\WINDOWS\prefetch\SBIECTRL.EXE-2EAD5991.pf
            Deleted file - C:\WINDOWS\prefetch\SBIESVC.EXE-1FFD779C.pf
            Deleted file - C:\WINDOWS\prefetch\SBIESVC.EXE-3C641EB1.pf
            Deleted file - C:\WINDOWS\prefetch\SC.EXE-6C4D4413.pf
            Deleted file - C:\WINDOWS\prefetch\SC.EXE-F4E1A8F7.pf
            Deleted file - C:\WINDOWS\prefetch\SCHTASKS.EXE-8B6144A9.pf
            Deleted file - C:\WINDOWS\prefetch\SDBINST.EXE-49E8B208.pf
            Deleted file - C:\WINDOWS\prefetch\SDIAGNHOST.EXE-B3171AA1.pf
            Deleted file - C:\WINDOWS\prefetch\SDXHELPER.EXE-832215EB.pf
            Deleted file - C:\WINDOWS\prefetch\SEARCHFILTERHOST.EXE-44162447.pf
            Deleted file - C:\WINDOWS\prefetch\SEARCHHOST.EXE-8F97BC4E.pf
            Deleted file - C:\WINDOWS\prefetch\SEARCHHOST.EXE-BA67C789.pf
            Deleted file - C:\WINDOWS\prefetch\SEARCHINDEXER.EXE-1CF42BC6.pf
            Deleted file - C:\WINDOWS\prefetch\SEARCHPROTOCOLHOST.EXE-69C456C3.pf
            Deleted file - C:\WINDOWS\prefetch\SECEDIT.EXE-B8517D62.pf
            Deleted file - C:\WINDOWS\prefetch\SECHEALTHUI.EXE-EF8E0FA0.pf
            Deleted file - C:\WINDOWS\prefetch\SECURITYHEALTHHOST.EXE-2216DC19.pf
            Deleted file - C:\WINDOWS\prefetch\SECURITYHEALTHSERVICE.EXE-91B5FB98.pf
            Deleted file - C:\WINDOWS\prefetch\SETUP.EXE-5C4105FE.pf
            Deleted file - C:\WINDOWS\prefetch\SETUP.EXE-5C410602.pf
            Deleted file - C:\WINDOWS\prefetch\SETUP.EXE-9C1B62B2.pf
            Deleted file - C:\WINDOWS\prefetch\SETUP.EXE-D24E177E.pf
            Deleted file - C:\WINDOWS\prefetch\SFC.EXE-425529A1.pf
            Deleted file - C:\WINDOWS\prefetch\SHELLEXPERIENCEHOST.EXE-6EC78D4F.pf
            Deleted file - C:\WINDOWS\prefetch\SIHCLIENT.EXE-98C47F6C.pf
            Deleted file - C:\WINDOWS\prefetch\SMARTSCREEN.EXE-EACC1250.pf
            Deleted file - C:\WINDOWS\prefetch\SNIPPINGTOOL.EXE-80F9E627.pf
            Deleted file - C:\WINDOWS\prefetch\SONAR.DEVINST.EXE-A075643E.pf
            Deleted file - C:\WINDOWS\prefetch\SPECCY64.EXE-943BD3B0.pf
            Deleted file - C:\WINDOWS\prefetch\SPLWOW64.EXE-57576C25.pf
            Deleted file - C:\WINDOWS\prefetch\SPOTIFY.EXE-E13D5529.pf
            Deleted file - C:\WINDOWS\prefetch\SPOTIFY.EXE-E13D552A.pf
            Deleted file - C:\WINDOWS\prefetch\SPOTIFY.EXE-E13D552B.pf
            Deleted file - C:\WINDOWS\prefetch\SPOTIFY.EXE-E13D5531.pf
            Deleted file - C:\WINDOWS\prefetch\SPPEXTCOMOBJ.EXE-7D45A1AB.pf
            Deleted file - C:\WINDOWS\prefetch\SPPSVC.EXE-96070FE0.pf
            Deleted file - C:\WINDOWS\prefetch\SPSETUP133.EXE-241F9597.pf
            Deleted file - C:\WINDOWS\prefetch\SRTASKS.EXE-3C9D2EEC.pf
            Deleted file - C:\WINDOWS\prefetch\SSDTSHPX_SETUP.EXE-B1FC74F8.pf
            Deleted file - C:\WINDOWS\prefetch\SSHZEXECUTOR.EXE-EBDA1112.pf
            Deleted file - C:\WINDOWS\prefetch\START.EXE-6188BADF.pf
            Deleted file - C:\WINDOWS\prefetch\STARTMENUEXPERIENCEHOST.EXE-4DCEE2F2.pf
            Deleted file - C:\WINDOWS\prefetch\STEELSERIESENGINE.EXE-217B9D8D.pf
            Deleted file - C:\WINDOWS\prefetch\STEELSERIESGG.EXE-030ABABB.pf
            Deleted file - C:\WINDOWS\prefetch\STEELSERIESGGINSTALLERDOWNLOA-437312BD.pf
            Deleted file - C:\WINDOWS\prefetch\STEELSERIESGGINSTALLERSWC.EXE-B91581C3.pf
            Deleted file - C:\WINDOWS\prefetch\STEELSERIESGGWEBINSTALLER-1.3-09C38D87.pf
            Deleted file - C:\WINDOWS\prefetch\STEELSERIESPRISM.EXE-14A76429.pf
            Deleted file - C:\WINDOWS\prefetch\STEELSERIESSONAR.EXE-34591847.pf
            Deleted file - C:\WINDOWS\prefetch\STOREDESKTOPEXTENSION.EXE-FAFBC5D3.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-09F4AEA4.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-0A049705.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-117C4441.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-13304EB0.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-1454AA18.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-14E28BF5.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-18C5C6E4.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-19B557B1.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-1B73F444.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-2FFEC382.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-3CDB0077.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-41084AF7.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-44191FB8.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-4B98D760.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-4BD0A607.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-4D0E9C8C.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-4E79CC0D.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-502A129B.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-529F9AC1.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-59780EBF.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-5F87ABED.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-62105D0D.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-677C0885.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-6867B1E5.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-6A4A44E7.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-73D024B2.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-764FA25C.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-768E59F7.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-77C41F85.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-7AAD9645.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-7CA96BCB.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-84F32335.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-852EC587.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-8A4EB855.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-952637C2.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-9A28EB78.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-9D041ABC.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-A9721AD5.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-AA89143F.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-B18C213B.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-BE3D0421.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-C2DA4F6F.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-C38EF8DD.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-C625B657.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-C88A2A3B.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-CAEF0A6A.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-D2385079.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-D5481872.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-D8C907E1.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-DF14C859.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-E5CD0034.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-EA9BB143.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-EBBF67E6.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-F1E39519.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-F57A5173.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-F5E1DCD3.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-F952D9A9.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-FA38241C.pf
            Deleted file - C:\WINDOWS\prefetch\SVCHOST.EXE-FC46CD61.pf
            Deleted file - C:\WINDOWS\prefetch\SYSTEMINFO.EXE-14DA5704.pf
            Deleted file - C:\WINDOWS\prefetch\SYSTEMSETTINGS.EXE-084BB8F9.pf
            Deleted file - C:\WINDOWS\prefetch\SYSTEMSETTINGSADMINFLOWS.EXE-F74198E7.pf
            Deleted file - C:\WINDOWS\prefetch\SYSTEMSETTINGSBROKER.EXE-8BBE2894.pf
            Deleted file - C:\WINDOWS\prefetch\SYSTRAYCOMPONENT.EXE-C9F17BFE.pf
            Deleted file - C:\WINDOWS\prefetch\TASKHOSTW.EXE-2E5D4B75.pf
            Deleted file - C:\WINDOWS\prefetch\TASKKILL.EXE-0ECD41EC.pf
            Deleted file - C:\WINDOWS\prefetch\TASKKILL.EXE-BE180FC8.pf
            Deleted file - C:\WINDOWS\prefetch\TASKLIST.EXE-4641012C.pf
            Deleted file - C:\WINDOWS\prefetch\TASKMGR.EXE-4C8500BA.pf
            Deleted file - C:\WINDOWS\prefetch\TELEGRAM.EXE-4045FED7.pf
            Deleted file - C:\WINDOWS\prefetch\TERMINAL.EXE-138A7F7E.pf
            Deleted file - C:\WINDOWS\prefetch\TEXTINPUTHOST.EXE-861368C0.pf
            Deleted file - C:\WINDOWS\prefetch\TIWORKER.EXE-65F8DEAA.pf
            Deleted file - C:\WINDOWS\prefetch\TRUSTEDINSTALLER.EXE-766EFF52.pf
            Deleted file - C:\WINDOWS\prefetch\UNINS000.EXE-FAB5105F.pf
            Deleted file - C:\WINDOWS\prefetch\UNINST.EXE-0066B9B0.pf
            Deleted file - C:\WINDOWS\prefetch\UNINST.EXE-8DB82EF2.pf
            Deleted file - C:\WINDOWS\prefetch\UNINSTALL.EXE-16C50215.pf
            Deleted file - C:\WINDOWS\prefetch\UNINSTALL.EXE-C8A9BD2C.pf
            Deleted file - C:\WINDOWS\prefetch\UN_A.EXE-25687529.pf
            Deleted file - C:\WINDOWS\prefetch\UPDATE.EXE-D390C843.pf
            Deleted file - C:\WINDOWS\prefetch\UPDATEPLATFORM.AMD64FRE.EXE-804667A0.pf
            Deleted file - C:\WINDOWS\prefetch\UPDATER.EXE-8551D93C.pf
            Deleted file - C:\WINDOWS\prefetch\UPDATER.EXE-8B065B0B.pf
            Deleted file - C:\WINDOWS\prefetch\UPDATER.EXE-8CA706AA.pf
            Deleted file - C:\WINDOWS\prefetch\UPDATERSETUP.EXE-0CC28D5F.pf
            Deleted file - C:\WINDOWS\prefetch\USERINIT.EXE-5114915C.pf
            Deleted file - C:\WINDOWS\prefetch\USEROOBEBROKER.EXE-65584ADF.pf
            Deleted file - C:\WINDOWS\prefetch\USOCLIENT.EXE-4ADC110B.pf
            Deleted file - C:\WINDOWS\prefetch\VGC.EXE-1D5BD981.pf
            Deleted file - C:\WINDOWS\prefetch\VLC.EXE-F1ED81B3.pf
            Deleted file - C:\WINDOWS\prefetch\VSSVC.EXE-6C8F0C66.pf
            Deleted file - C:\WINDOWS\prefetch\WAB.EXE-5899287B.pf
            Deleted file - C:\WINDOWS\prefetch\WERFAULT.EXE-155C56CF.pf
            Deleted file - C:\WINDOWS\prefetch\WERFAULT.EXE-19E0D4EB.pf
            Deleted file - C:\WINDOWS\prefetch\WERFAULT.EXE-661188F3.pf
            Deleted file - C:\WINDOWS\prefetch\WEVTUTIL.EXE-1E154F39.pf
            Deleted file - C:\WINDOWS\prefetch\WINDOWSCAMERA.EXE-8A1EBB0D.pf
            Deleted file - C:\WINDOWS\prefetch\WINDOWSPACKAGEMANAGERSERVER.E-201C94F9.pf
            Deleted file - C:\WINDOWS\prefetch\WINDOWSTERMINAL.EXE-DD240BFA.pf
            Deleted file - C:\WINDOWS\prefetch\WINMGMT.EXE-C981BB27.pf
            Deleted file - C:\WINDOWS\prefetch\WINPILOT.EXE-38CA5639.pf
            Deleted file - C:\WINDOWS\prefetch\WINSAT.EXE-C345C80B.pf
            Deleted file - C:\WINDOWS\prefetch\WINSTORE.APP.EXE-743DDED5.pf
            Deleted file - C:\WINDOWS\prefetch\WIN_DRIVER_INSTALLER.EXE-1B3E4E9D.pf
            Deleted file - C:\WINDOWS\prefetch\WLRMDR.EXE-A7C36FDD.pf
            Deleted file - C:\WINDOWS\prefetch\WMIADAP.EXE-BB21CD77.pf
            Deleted file - C:\WINDOWS\prefetch\WMIAPSRV.EXE-FC8436DD.pf
            Deleted file - C:\WINDOWS\prefetch\WMIC.EXE-311B5CB4.pf
            Deleted file - C:\WINDOWS\prefetch\WMIC.EXE-98223A30.pf
            Deleted file - C:\WINDOWS\prefetch\WMIPRVSE.EXE-39F97B2D.pf
            Deleted file - C:\WINDOWS\prefetch\WMIPRVSE.EXE-E8B8DD29.pf
            Deleted file - C:\WINDOWS\prefetch\WT.EXE-26219B2E.pf
            Deleted file - C:\WINDOWS\prefetch\WUAUCLTCORE.EXE-07BDE0CF.pf
            Deleted file - C:\WINDOWS\prefetch\WUAUCLTCORE.EXE-84257BB2.pf
            Deleted file - C:\WINDOWS\prefetch\WUB_X64.EXE-2FDFC964.pf
            Deleted file - C:\WINDOWS\prefetch\WWAHOST.EXE-02A78870.pf
            Deleted file - C:\WINDOWS\prefetch\WWAHOST.EXE-37768102.pf
            Deleted file - C:\WINDOWS\prefetch\ZHPCLEANER(1).EXE-0803C826.pf
            Deleted file - C:\WINDOWS\prefetch\ZHPCLEANER.EXE-285CB844.pf
            Deleted file - C:\WINDOWS\prefetch_IU14D2N.TMP-5860BBFB.pf
            Deleted file - C:\WINDOWS\prefetch_UNINSTALL36096-4F505AA8.pf
            Deleted file - C:\WINDOWS\prefetch\ReadyBoot\rblayout.xin
            Deleted file - C:\WINDOWS\prefetch\ReadyBoot\Trace5.fx
            Deleted file - C:\WINDOWS\prefetch\ReadyBoot\Trace6.fx
            Deleted file - C:\WINDOWS\prefetch\ReadyBoot\Trace7.fx
            Deleted file - C:\WINDOWS\prefetch\ReadyBoot\Trace8.fx
            Deleted file - C:\WINDOWS\prefetch\ReadyBoot\Trace9.fx
            SERVICE_NAME: sysmain
            TYPE : 30 WIN32
            STATE : 3 STOP_PENDING
            (STOPPABLE, NOT_PAUSABLE, ACCEPTS_SHUTDOWN)
            WIN32_EXIT_CODE : 0 (0x0)
            SERVICE_EXIT_CODE : 0 (0x0)
            CHECKPOINT : 0x0
            WAIT_HINT : 0x2710
            [SC] ChangeServiceConfig SUCCESS
            SERVICE_NAME: DiagTrack
            TYPE : 10 WIN32_OWN_PROCESS
            (STOPPABLE, NOT_PAUSABLE, ACCEPTS_PRESHUTDOWN)
            CHECKPOINT : 0x3
            WAIT_HINT : 0x0
            [SC] ControlService FAILED 1062:
            The service has not been started.
            SERVICE_NAME: WSearch
            (NOT_STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
            CHECKPOINT : 0x2
            WAIT_HINT : 0x7530
            ========= End of Batch: =========
            ========= del /s /q “%userprofile%\AppData\Local\temp*.*” =========
            Deleted file - C:\Users\Ripple\AppData\Local\temp\000e5e9f-7d5c-47ed-bece-e4b3a9f8e489.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\02b41375-20bc-4178-82a8-7d79c6dd972f.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\02d6d97e-57a7-4f5b-8b86-1d4d7aee209e.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\03abe1be-d0f9-4d83-ad08-a84666c67f6e.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\03f1d3f2-dfa7-432e-9d6f-fd2e323f1fdd.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\06138131-2e01-430b-b7b0-0e1d3ce56283.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\08700c85-9fd2-4b5c-8c90-91384e7cf119.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\088c9fd0-bdf2-4842-b685-e29dbb58516f.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\093458cb-86fc-42c3-9315-596d51ff84d0.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\0afb4d07-1702-4797-850a-10695459ba40.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\0cb06e50-5646-4c83-86fd-a9c31fc15dc6.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\0cbf380a-2f78-4068-b803-00728fbedebd.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\0cbf7ec3-ee7f-4206-9be7-fb50aca61686.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\0e0ceef9-336f-49d9-8351-8af09ed69779.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\0ecb665c-226d-4506-b269-cced8d56e4cb.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\10aaf4a2-d7b4-464b-b5ee-acdadd5ca921.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\1614f8ee-618f-426d-9ae5-ca38c20c60e2.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\16cccebf-448e-4687-83ee-4a7d398d228f.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\17441628-b533-4877-a6c5-1c511eb17268.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\176feff4-ea9c-4845-a35a-30874496cd88.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\17bd9ba8-7db2-46f4-b5f6-5108238cada0.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\1c72bf29-00cd-43ca-97fd-87591a9a6bb9.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\1d1f8f16-996c-4e23-8169-ae043ec340ef.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\1d5a225b-a358-4f0f-a6b9-0d1c8d5894bb.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\1dd4593a-633f-4e25-b949-fac232ef6027.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\1ee7981f-f33a-4ed6-8f4c-a22f0d5c0b85.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\204a4cbb-83e4-4f76-a043-1f611d14723e.tmp.ico
            Deleted file - C:\Users\Ripple\AppData\Local\temp\21335448-da85-430b-b419-96768265981c.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\248b5755-f492-4993-b76e-fb26130c40a3.tmp.ico
            Deleted file - C:\Users\Ripple\AppData\Local\temp\24fd1dd6-6c8a-4654-a272-06dd14af86e4.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\25707d32-0881-4764-8973-a570016eec35.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\27494c44-3aec-4e87-949a-ff68182ec350.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\27e535e4-1283-4c8a-a8ad-ba058dcb06d8.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\287bd5f8-3eb1-463b-8d2f-d1196f3385eb.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\29936927-270b-458b-89c0-c8f9f884c85c.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\29d85551-f32c-4e2a-8d7b-39a5673cc143.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\2a4967d1-b182-4468-a0c4-5d806ede8b6c.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\2b149659-240a-43e2-b48d-bc76b0158a33.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\2ca61c94-6aa7-4df3-b2e4-0f75bad6ceb4.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\2f2b59ff-f9ab-4c3e-9735-51c35422d600.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\311fb624-90d2-4b3b-a0e0-b48bcb9cf58c.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\3455ca0d-8d8b-4aa7-83ba-22e2341d7115.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\351ce3e0-0b65-42cb-8caa-93085de012d4.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\37fe0948-ad3d-4240-8463-cd5ba34b9662.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\38837797-6bc5-47da-9e21-8dec95bf3b50.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\3924a4c2-4690-4ecd-bad5-ddb372f26bcd.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\3a0ed51f-7d30-4035-8258-a82d21edf81b.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\3aa97a99-8548-4839-abbb-0fbbbd9b4f87.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\3b9ce3b0-2da4-4cc7-95dd-f59ffb55dec3.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\3d10391a-fb94-4263-9b0d-7337718dea25.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\3e6c5a28-9b4c-4c69-b195-dbbb4a080a3d.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\3fc83836-a399-435c-8e9c-d1f7f63bd47e.tmp.ico
            Deleted file - C:\Users\Ripple\AppData\Local\temp\40c45357-cf97-4711-af24-eca4b32821df.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\40f9dbff-fbee-488b-a618-3762a62ccd93.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\413c2a73-afdb-4b42-aea5-df8bf843b093.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\425739d1-241e-44de-8ce0-007d20c6310c.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\4435737d-28af-4f51-bf9d-92065d21c468.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\4a2dc72c-bc9d-455c-b856-a1a71f33d15f.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\4bcf2b7c-8980-4d21-9835-62ac0ecffe52.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\4be11248-6d34-4f17-aae0-3f9211e8618e.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\4ccf16a8-4a2b-42b7-a677-e883b32c0ac5.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\4d32bdcd-ab79-45a3-b134-1007cfdafb38.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\4eb46d45-df26-4f77-b3c7-9bc51dcc2003.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\4f24f544-5c7a-4957-bedc-12aa402d9285.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\513be19d-c1df-4125-81ba-26c67ab1029b.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\51b19fde-1ab0-4b8a-a622-d038b6f3d5cd.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\5444c64b-adfa-4d72-a548-23c3e55e0dc3.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\5639ed6e-d1e7-4d06-870c-d5a0e372a5eb.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\5755d083-91b4-46b6-9111-0d54287bf465.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\5784b4ca-a0ff-4696-9bb5-57acde18753f.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\57a6846f-df91-4f99-b2cf-3aec2c875832.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\5eb3413a-05bf-4913-849b-3ef1e5f7bfc4.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\60360540-3a45-41e5-9378-70f60fc6a9d0.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\618d26df-503f-4dec-ab74-2499d16ea330.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\6417fc96-3c41-4131-92fb-c90594f30dcf.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\67959dc3-cd78-40cd-9874-72dec185826d.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\691fec44-ca19-4165-b24e-5ffbd32a9e0b.tmp.ico
            Deleted file - C:\Users\Ripple\AppData\Local\temp\69ada4e2-6e07-459b-a553-ba15cdd85186.tmp.ico
            Deleted file - C:\Users\Ripple\AppData\Local\temp\6d85d38b-8e82-45ab-af85-012b70fb7581.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\6d8c8f66-ae4e-4398-bad8-9e0ca89f8353.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\70abf38e-1d69-4297-8822-bb87db05a360.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\721accb8-627f-47f9-a013-41850aa79c6c.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\7596c69a-c92e-4f95-b6db-b5a65767f2b0.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\7657ad3a-4232-4164-bf13-dc6a7a5f71b0.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\76f88e00-93f8-465d-bd5f-93b01b0c3875.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\770b3f09-b127-43d0-a649-e43d05162934.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\7a0c3507-014b-43f8-9c15-35b24bd6d521.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\7a1ffb21-31ca-4c7a-a44a-c1058cd75655.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\7b02d9c3-e735-4813-90ed-674897c45f3b.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\7c26c876-2108-48e5-a39d-d8a95d6e9616.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\7e36632a-e85c-4e14-b35e-3a26185fcc46.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\7f5615f7-211c-4be2-8dfa-cf7bc2edc8b3.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\8055d93b-ac18-4ccc-814c-c45572be4c14.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\8155a832-a0e7-4ef7-b274-cf6ccfdf680a.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\86112906-5a25-48b8-99c7-dd8113615d2d.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\865b672f-2f32-49a9-b3b1-e7d803d57797.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\86e3a39b-a064-4080-be3e-fdd05e2e30de.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\87b5246a-58df-4838-957f-e6df90eb2686.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\88fc2d63-a850-4da2-aa6f-c9ab174a0b59.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\89728c09-073b-4df4-aecf-8e2b090b2728.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\8c8385c7-43d0-4a56-bad8-ff63a32d16fc.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\8c91d6e5-60ce-4c11-9ba7-ae2b5e267a17.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\8cdde2ad-c3c9-44ed-8c95-c71644ff8cf1.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\90d30e15-48f8-4bbe-bbe3-406a5d316bc8.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\92aef77e-6e97-4582-ac88-770c83c0c0af.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\944e102a-8553-4341-8ea2-0cc9805ee6dc.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\960ccb30-35cd-4de8-80b3-5aa9f9a2fbc9.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\98d5bee4-678e-4a4a-b48d-9af5c2b030c7.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\9a9caf36-52a6-4161-b091-93cf367b9d06.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\a19680ac-2604-45b8-9f5c-8b42946fb7c3.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\a5d738e1-d562-457a-8c03-2ebbef19d9a4.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\a618582a-4ba6-4f99-a637-e0a94bf1d14a.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\a949ed98-7d65-4e7c-b27e-271a998c5dcd.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\a9777db5-5567-4d29-8c01-a5224b014a02.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\a9c653a5-e7ab-4689-9bdc-ae30439b48bd.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\a9d3e8ae-acc7-4e7c-9760-b85c615a86ef.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\ae0175f7-c336-4a14-99e7-fb214faf0d8f.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\APPX.2169egdoy7 qu5rh34oy90fv8b.tmp
            Deleted file - C:\Users\Ripple\AppData\Local\temp\APPX.7lovvdpy3m blafavt9wyc1vkc.tmp
            C:\Users\Ripple\AppData\Local\temp\APPX.kwf676q8r6 twf8bkzi07nqsid.tmp
            Deleted file - C:\Users\Ripple\AppData\Local\temp\APPX.s265uzbfpf ah7wm0i0itwjfwh.tmp
            C:\Users\Ripple\AppData\Local\temp\APPX.v8kwcn_j_m 7mnd4yboxyd047e.tmp
            C:\Users\Ripple\AppData\Local\temp\APPX._ez70vzve9 365tweu4ympi64f.tmp
            Deleted file - C:\Users\Ripple\AppData\Local\temp\b4de437e-e8d7-43ae-8f20-971eac8e48d5.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\b5d9e86a-6e00-4ace-9e48-e63159ae2105.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\b60c01ac-6c78-4cba-8f56-21c2fab12805.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\b9e99d52-a542-483f-84a9-390c97017f56.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\be7ba3ec-3fcc-4d79-a2e1-ca07fcde311c.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\bf2a244a-0153-4a3d-96f9-23bf51c36570.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\c15e2da8-c50c-49c6-8853-1580d39f3fd2.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\c2bace452413230 a505b65c1d241e36f-{87A94AB0-E370-4cde-98D3-ACC110C5967D}
            Deleted file - C:\Users\Ripple\AppData\Local\temp\c3d7bd22-ea4c-40b9-aaab-4c298545c248.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\c4d819b2-d497-4abb-9f50-de72a85adfc1.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\c4ff978a-8b24-4142-bbf6-906b3a3f209f.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\c6aca8c4-b3f5-47e6-baca-371ffb2b04ff.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\c7d7f1be-8852-42b0-a0f1-cc5d11df12a2.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\c83a8131-6cce-43de-828b-5f1151073217.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\c9015c66-4923-4a86-a0fd-b5e7ade91538.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\cbac82aa-a649-4899-b990-9393ea8c2a15.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\ClearLNK.ini
            Deleted file - C:\Users\Ripple\AppData\Local\temp\d0bd2760-c657-497e-acad-5ecd0ee39a1a.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\d0dc2a04-621b-4f2d-96ee-8ce1d95cf0f6.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\d2b3f8f6-c8a8-4b29-b5e7-4733c0823a88.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\d53eaaa9-fb79-4131-892a-47c7f4c44061.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\d5cece84-ea35-47c5-9bce-52f346977511.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\d6830396-a513-4ed4-ad84-f826246fb6dc.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\dd1cc1e5-c9c8-4bfb-a812-09badee09a5f.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\e01e56fe-a4fd-44bc-9004-d85cd2103bb6.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\e12650c9-e916-43e9-a356-488596d824f8.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\e5d4df96-707d-4387-b2b1-8c6a4e1faca9.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\e60f3cf9-fe64-49db-8f32-6fa8c5bbe7d3.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\e6e63636-6238-4bba-a721-a15a6969a253.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\e881c859-4c42-4819-8b4d-62bb71df687c.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\e9a88954-c9b4-4e44-8b0f-9374dc3161a4.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\ed2a61dc-809a-428a-bf0b-22e32796fd1f.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\ef29dbeb-3c17-4e12-9b7f-2c08058f596b.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\f44592c3-f326-46a3-8288-5c35bd50592d.tmp.html
            Deleted file - C:\Users\Ripple\AppData\Local\temp\f4c5f64c-f29d-403d-9506-b92ed11a8a5a.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\f59fd667-7f1c-4e58-a928-ba841a6dbb26.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\f6e4fea1-df00-4642-b45b-cb33136d3085.tmp.ico
            Deleted file - C:\Users\Ripple\AppData\Local\temp\f7c82924-7b58-4679-9a67-830da1124521.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\f8481d58-863f-40b2-951b-aac7d2841379.tmp.css
            Deleted file - C:\Users\Ripple\AppData\Local\temp\fa61fb9b-990e-4828-937b-ee410cf14bf5.tmp.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\faa9cd7c-f566-4cf5-952d-5bed0fb54074.tmp.ttf
            Deleted file - C:\Users\Ripple\AppData\Local\temp\fd7efcc0-5fda-41b9-a35b-acaae0b3bf12.tmp.woff2
            Deleted file - C:\Users\Ripple\AppData\Local\temp\fddf17ad-c871-4c55-b7b4-8958051cf628.tmp.js
            Deleted file - C:\Users\Ripple\AppData\Local\temp\geek64.exe
            Deleted file - C:\Users\Ripple\AppData\Local\temp\jna491156046525 9692089.hunspell-win-x86-64.dll
            Deleted file - C:\Users\Ripple\AppData\Local\temp\jna823227470572 3621799.hunspell-win-x86-64.dll
            Deleted file - C:\Users\Ripple\AppData\Local\temp{45B1D970-9886-4A4D-9212-28ADD3F319DD} - OProcSessId.dat
            Deleted file - C:\Users\Ripple\AppData\Local\temp{4E1B62C6-B77E-48EF-9334-E9EE6DC0B96F} - OProcSessId.dat
            Deleted file - C:\Users\Ripple\AppData\Local\temp{B86C5B59-9C82-44EB-8ED2-40A6B223770B} - OProcSessId.dat
            Deleted file - C:\Users\Ripple\AppData\Local\temp{CA82AAAF-6622-47A0-9831-A0225D73F433} - OProcSessId.dat
            Deleted file - C:\Users\Ripple\AppData\Local\temp\7zO462FA464\622 .csv
            Deleted file - C:\Users\Ripple\AppData\Local\temp\8b24d924-537b-459b-a0ab-cc06ba89e145_geek.7z.145\geek.exe
            Deleted file - C:\Users\Ripple\AppData\Local\temp\bafc3223-ebf9-45b3-b865-ade479cb0537_geek.7z.537\geek.exe
            Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXC EL\Primary1721209092230134600_6B5745FF-DCF1-4A62-B90D-E6DB8088F33B.log
            Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXC EL\Primary1721209092231158800_6B5745FF-DCF1-4A62-B90D-E6DB8088F33B.log
            Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXC EL\Additional\Additional1721209092231715100_6B5745 FF-DCF1-4A62-B90D-E6DB8088F33B.log
            Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXC EL\Additional\Additional1721209092232561400_6B5745 FF-DCF1-4A62-B90D-E6DB8088F33B.log
            Deleted file - C:\Users\Ripple\AppData\Local\temp\jna-77124\jna10132358105755066225.dll
            Deleted file - C:\Users\Ripple\AppData\Local\temp\jna-77124\jna10132358105755066225.dll.x
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir12632 _109146484\2032b01729dfe2104b52920da5d09b0e.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir12632 _109146484\6c9718f1d954c09fb3dc8d410b704522.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir12632 _109146484\71c066cc37aa2518ca6ebfebae2a0e58.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir12632 _109146484\cdf383ff3876c44ae2c876a3579c9387.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir12632 _109146484\f1ff99935cbf2dcc8247ddb580c640c1.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_ 240717956\6c4e70c602352c04108faae6415f9299.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_ 240717956\814a388d5d40c07857a4a94a5a6d0281.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_ 240717956\84d4e23663500c265a42412358bbb81e.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_ 240717956\a0df42cc9edc6f9eb5d2d0b78d287790.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_ 240717956\b8e6d1a5e8a307e7a2a5601107b2c420.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_ 240717956\ca7300b352a09d1fa44864da6f46dcab.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\scoped_dir1972_ 240717956\de99dc7c3dd658f382a1850e1b439e7c.png
            Deleted file - C:\Users\Ripple\AppData\Local\temp\SmartScreen\Rem oteData\LastPing
            Deleted file - C:\Users\Ripple\AppData\Local\temp\SmartScreen\Rem oteData\windowsSettings
            Deleted file - C:\Users\Ripple\AppData\Local\temp\SmartScreen\Rem oteData\windowsSettings_1.0-7e3544113374bc2769af5f67e125ab81de1b4b64c07fe68e2a 7bc03646c85dfc
            ================== ExportKey: ===================
            [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Lsa\TurnOffAnonymousBlock]
            “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contr ol\Lsa\TurnOffAnonymousBlock” => not found
            [HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\Run]
            “3RVX”=“D:\Program Files (x86)\3RVX\3RVX.exe”
            “electron.app.BlueStacks Services”=“C:\Users\Ripple\AppData\Local\Programs\ bluestacks-services\BlueStacksServices.exe --hidden”
            “PreMiD”=““C:\Users\Ripple\AppData\Roaming\PreMiD\ PreMiD.exe” --hidden”
            === End of ExportKey ===
            [HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\Run Once]
            [HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run]
            “MicrosoftEdgeAutoLaunch_2D11F281AFD682F6488A744B0 F127922”=“020000000000000000000000”
            “OneDrive”=“020000000000000000000000”
            “RiotClient”=“020000000000000000000000”
            “Discord”=“03000000d94903f7dccdda01”
            “IDMan”=“020000000000000000000000”
            “3RVX”=“020000000000000000000000”
            “electron.app.BlueStacks Services”=“03000000345b2cb6355bda01”
            “SandboxieControl”=“020000000000000000000000”
            “Synapse3”=“03000000c9f6f665ccbbda01”
            “PreMiD”=“020000000000000000000000”
            [HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32]
            “HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32” => not found
            [HKU\S-1-5-21-2515384590-1499498081-2273501178-1001\Software\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\StartupFolder]
            “Rainmeter.lnk”=“03000000a5a1eaf5bb2eda01”
            “FANTECH X4S MACRO Gaming Mouse.lnk”=“030000004a4552ac5136da01”
            [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Defender\Exclusions]
            [HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions\Extensions]
            [HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions\IpAddresses]
            [HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions\Paths]
            “C:\Windows\System32\SppExtComObjHook.dll”=“0”
            “C:\Users\Ripple\AppData\Local\WinRAR”=“0”
            “C:\Program Files (x86)\Internet Explorer”=“0”
            “C:\Windows\Microsoft.NET”=“0”
            [HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions\Processes]
            “Rar64.exe”=“0”
            “aspnet_compiler.exe”=“0”
            “RuntimeBroker.exe”=“0”
            “CrashReporter.exe”=“0”
            “RegAsm.exe”=“0”
            “ngentask.exe”=“0”
            “WsatConfig.exe”=“0”
            “taskhostw.exe”=“0”
            [HKLM\SOFTWARE\Microsoft\Windows Defender\Exclusions\TemporaryPaths]
            FlushDNS => completed
            BITS transfer queue => 0 B
            DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 12680561 B
            Java, Discord, Steam htmlcache, WinHttpAutoProxySvc/winhttp *.cache => 395746794 B
            Windows/system/drivers => 2096490 B
            Edge => 0 B
            Chrome => 10721977 B
            Firefox => 1162885094 B
            Opera => 0 B
            Default => 0 B
            ProgramData => 0 B
            Public => 0 B
            systemprofile => 0 B
            systemprofile32 => 0 B
            LocalService => 0 B
            NetworkService => 2340 B
            Ripple => 32536 B
            RecycleBin => 0 B
            EmptyTemp: => 1.5 GB temporary data Removed.
            The system needed a reboot.
            ==== End of Fixlog 11:04:17 ====[/CODE][/HEADING]
            • maxim123
              • Aug 2017
              • 472
              #81
              Originally posted by Malnutrition
              Please [COLOR=rgb(184, 49, 47)]Copy and paste that log here in your next post.
              [/COLOR]
              Hi, just copy and paste directly right? I posted it in code and it seemed the colors were not shown. so copy pasted in the next reply, since I can’t delete this reply. do I update those red marked files?[/color]
              • maxim123
                • Aug 2017
                • 472
                #82
                SecurityCheck by glax24 & Severnyj v.1.4.0.57 [24.01.24]
                WebSite: www.safezone.cc
                DateLog: 19.07.2024 11:07:53
                Path starting: C:\Users\Ripple\AppData\Local\Temp\SecurityCheck\S ecurityCheck.exe
                Log directory: C:\SecurityCheck
                IsAdmin: True
                User: Max
                VersionXML: 12.38is-14.07.2024
                Windows 11(6.3.22631) (x64) Professional Release: 23H2 Lang: English(0409)
                Installation date OS: 12.07.2024 06:06:13
                LicenseStatus: Windows(R), Professional edition The machine is permanently activated.
                LicenseStatus: Office 21, Office21ProPlus2021VL_KMS_Client_AE edition Initial grace period ends :33164 minutes
                Boot Mode: Normal
                Default Browser: C:\Program Files\Mozilla Firefox\firefox.exe
                SystemDrive: C: FS: [NTFS] Capacity: [247.1 Gb] Used: [154.8 Gb] Free: [92.3 Gb]
                ------------------------------- [ Windows ] -------------------------------
                User Account Control enabled (Level 3)
                Never check for updates
                The computer gets its updates from a WSUS server
                Security Center (wscsvc) - The service is running
                Remote Registry (RemoteRegistry) - The service has stopped
                SSDP Discovery (SSDPSRV) - The service is running
                Remote Desktop Services (TermService) - The service has stopped
                Windows Remote Management (WS-Management) (WinRM) - The service has stopped
                --------------------------- [ FirewallWindows ] ---------------------------
                Windows Defender Firewall (mpssvc) - The service is running
                ---------------------- [ AntiVirusFirewallInstall ] -----------------------
                Malwarebytes version 5.1.6.117 v.5.1.6.117
                --------------------------- [ OtherUtilities ] ----------------------------
                Microsoft Edge WebView2 Runtime v.126.0.2592.102
                Steam v.2.10.91.91
                Wireshark 4.2.5 x64 v.4.2.5 Warning! Download Update
                Microsoft Visual C++ 2015-2022 Redistributable (x86) - 14.40.33810 v.14.40.33810.0
                Microsoft Visual C++ 2015-2022 Redistributable (x64) - 14.40.33810 v.14.40.33810.0
                ------------------------------ [ ArchAndFM ] ------------------------------
                7-Zip 22.01 (x64) v.22.01 Warning! Download Update
                Uninstall old version and install new one.
                -------------------------- [ IMAndCollaborate ] ---------------------------
                Telegram Desktop v.5.2.3
                --------------------------------- [ P2P ] ---------------------------------
                qBittorrent v.4.6.5
                -------------------------------- [ Media ] --------------------------------
                VLC media player v.3.0.20 Warning! Download Update
                ------------------------------- [ Browser ] -------------------------------
                Mozilla Firefox (x64 en-US) v.127.0.2 Warning! Download Update
                Google Chrome v.126.0.6478.128 [+]
                Microsoft Edge v.126.0.2592.102
                ------------------ [ AntivirusFirewallProcessServices ] -------------------
                Malwarebytes Service (MBAMService) - The service has stopped
                C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\MsMpEng.exe v.4.18.24060.7
                C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\NisSrv.exe v.4.18.24060.7
                Microsoft Defender Antivirus Service (WinDefend) - The service is running
                Microsoft Defender Antivirus Network Inspection Service (WdNisSvc) - The service is running
                ----------------------------- [ End of Log ] ------------------------------
                • maxim123
                  • Aug 2017
                  • 472
                  #83
                  Double click the folder and find [COLOR=rgb(184, 49, 47)]AVZ.exe right click and run as admin.
                  [/COLOR]
                  [ATTACH type=“full”]13978[/ATTACH]
                  [ATTACH type=“full”]13979[/ATTACH]
                  also, finished Privazer. maybe because its a repair version installed, it didn’t take much time to scan and clean. total was about 10 mins or less I think.[/color]
                  • Malnutrition
                    PCHF Moderator
                    • 7041
                    #84
                    Yes.
                    couldn’t uncheck adobe type manager.
                    Download Runx.exe drag and drop Autoruns program onto Runx and then you will be able to uncheck it,.
                    Disable Bitlocker How to Disable BitLocker Encryption on Windows 10 and 11
                    Do you use Ms Edge? If not then disable it. Edge Blocker v2.0
                    Disable Customer experience imporovement program. https://www.thewindowsclub.com/disab...vement-program
                    Also check for and disable the task of these to ensure they are off. Task Scheduler Viewer for Windows 11 / 10 / 7 / 8 / Vista
                    Copy the content of the code box below.
                    [COLOR=rgb(184, 49, 47)]Do not copy the word code!!!
                    Right Click FRST and run as Administrator.
                    Click Fix once (!) and wait. The program will create a log file (Fixlog.txt).
                    Attach it to your next message.
                    Code:
                    start::
                    CreateRestorePoint:
                    EmptyTemp:
                    CloseProcesses:
                    startpowershell:
                    Set-ExecutionPolicy -Scope CurrentUser -ExecutionPolicy Unrestricted -force -ErrorAction SilentlyContinue -Confirm:$false
                    # Funtion Remove-all-windefend-excludes to Remove all exclusions on MS Windefend
                    Function Remove-all-windefend-excludes {
                    $Paths=(Get-MpPreference).ExclusionPath
                    $Extensions=(Get-MpPreference).ExclusionExtension
                    $Processes=(Get-MpPreference).ExclusionProcess
                    foreach ($Path in $Paths) { Remove-MpPreference -ExclusionPath $Path -force}
                    foreach ($Extension in $Extensions) { Remove-MpPreference -ExclusionExtension $Extension -force}
                    foreach ($Process in $Processes) { Remove-MpPreference -ExclusionProcess $Process -force}
                    # Remove all exclusions on MS Windefend
                    Write-Output "Removing all exclusions on MS Windefend antivirus"
                    Set-MpPreference -DisableAutoExclusions $true -Force
                    EndPowerShell:
                    startpowershell:
                    Remove-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender" -Name "DisableAntiVirus" –Force
                    Remove-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender" -Name "DisableAntiSpyware" –Force
                    Remove-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender" -Name "PUAProtection" –Force
                    Remove-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender" -Name "DisableRoutinelyTakingAction" –Force
                    Remove-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender\Real-Time Protection" -Name "DisableBehaviorMonitoring" -force
                    Remove-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender\Real-Time Protection" -Name "DisableOnAccessProtection" -force
                    Remove-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender\Real-Time Protection" -Name "DisableScanOnRealtimeEnable" -force
                    Get-Service windefend | Select-Object -Property Name, StartType, Status
                    Set-Service -Name securityhealthservice -StartupType manual -force
                    Get-Service securityhealthservice | Select-Object -Property Name, StartType, Status
                    Set-MpPreference -CheckForSignaturesBeforeRunningScan $true -Force
                    Set-MpPreference -DisableArchiveScanning $false -Force
                    Set-MpPreference -DisableBehaviorMonitoring $false -Force
                    Set-MpPreference -DisableEmailScanning $False -Force
                    Set-MpPreference -DisableIOAVProtection $false -Force
                    Set-MpPreference -DisablePrivacyMode $true -Force
                    Set-MpPreference -DisableRealtimeMonitoring $false -Force
                    Set-MpPreference -MAPSReporting Advanced -Force
                    Set-MpPreference -PUAProtection enabled -Force
                    Set-MpPreference -SignatureScheduleDay Everyday -Force
                    Set-MpPreference -DisableRemovableDriveScanning $false -Force
                    Set-MpPreference -SubmitSamplesConsent SendSafeSamples
                    # Reset and check Secure Health status
                    Get-AppxPackage Microsoft.SecHealthUI -AllUsers | Reset-AppxPackage
                    Get-AppxPackage Microsoft.SecHealthUI -AllUsers|select Name, Status
                    # Check if these services are running
                    Get-Service mbamservice, Windefend, SecurityHealthService, wscsvc, mpsdrv, mpssvc, bfe, WdNisSvc, WdNisDrv, sense, winmgmt, rpcss, RpcEptMapper, bits, cryptsvc, wuauserv, dcomlaunch | Select Name, DisplayName, Status, starttype
                    EndPowerShell:
                    startpowershell:
                    Remove-Item -Path "C:\Windows\Prefetch\*" -force -recurse -ErrorAction SilentlyContinue
                    Write-Output "updating"
                    Update-MpSignature
                    Write-Output "scanning quick scan"
                    Start-MpScan -ScanType QuickScan
                    Remove-MpThreat
                    EndPowerShell:
                    CMD: del /s /q "%userprofile%\AppData\Local\temp\*.*"
                    emptytemp:
                    Reboot:
                    End::
                    [ATTACH alt=“1721365362197.png”]13980[/ATTACH]
                    [ATTACH alt=“1721365440781.png”]13981[/ATTACH][/COLOR]
                    • Malnutrition
                      PCHF Moderator
                      • 7041
                      #85
                      After all of the above, let me know the performance of the machine and upload a final set of FRST logs for review.
                      • maxim123
                        • Aug 2017
                        • 472
                        #86
                        Hi, I will update this at evening here (gmt+5.45 timezone), as I have to leave for a while again.
                        • maxim123
                          • Aug 2017
                          • 472
                          #87
                          Yes.
                          updated. vlc says the version is latest when i checked through the app.
                          Still says failed to disable adobe type manager. I tried running with trusted source and system user, but both gave the same thing when trying to uncheck adobe type manager.
                          they are already turned off it seems.
                          [ATTACH type=“full”]13982[/ATTACH]
                          do I disable these two? I didn’t see ms edge and customer experience in the task scheduler.
                          • maxim123
                            • Aug 2017
                            • 472
                            #88
                            [HEADING=1]
                            Code:
                            Fix result of Farbar Recovery Scan Tool (x64) Version: 16.07.2024
                            Ran by Max (19-07-2024 20:55:57) Run:4
                            Running from C:\Users\Ripple\Desktop
                            Loaded Profiles: Max
                            Boot Mode: Normal[/HEADING]
                            fixlist content:
                            [HR][/HR]
                            start::
                            CreateRestorePoint:
                            EmptyTemp:
                            CloseProcesses:
                            startpowershell:
                            [HEADING=1]Funtion Remove-all-windefend-excludes to Remove all exclusions on MS Windefend[/HEADING]
                            [HEADING=1]Remove all exclusions on MS Windefend[/HEADING]
                            Write-Output “Removing all exclusions on MS Windefend antivirus”
                            EndPowerShell:
                            startpowershell:
                            Remove-ItemProperty -Path “HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender” -Name “DisableAntiVirus” –Force
                            Remove-ItemProperty -Path “HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender” -Name “DisableAntiSpyware” –Force
                            Remove-ItemProperty -Path “HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender” -Name “PUAProtection” –Force
                            Remove-ItemProperty -Path “HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender” -Name “DisableRoutinelyTakingAction” –Force
                            Remove-ItemProperty -Path “HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender\Real-Time Protection” -Name “DisableBehaviorMonitoring” -force
                            Remove-ItemProperty -Path “HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender\Real-Time Protection” -Name “DisableOnAccessProtection” -force
                            Remove-ItemProperty -Path “HKLM:\SOFTWARE\Policies\Microsoft\Windows Defender\Real-Time Protection” -Name “DisableScanOnRealtimeEnable” -force
                            [HEADING=1]Reset and check Secure Health status[/HEADING]
                            [HEADING=1]Check if these services are running[/HEADING]
                            EndPowerShell:
                            startpowershell:
                            Remove-Item -Path “C:\Windows\Prefetch*” -force -recurse -ErrorAction SilentlyContinue
                            Write-Output “updating”
                            Update-MpSignature
                            Write-Output “scanning quick scan”
                            Remove-MpThreat
                            EndPowerShell:
                            CMD: del /s /q “%userprofile%\AppData\Local\temp*.*”
                            emptytemp:
                            Reboot:
                            End::
                            [HR][/HR]
                            “C:\Windows\System32\SppExtComObjHook.dll” => not found
                            “C:\Users\Ripple\AppData\Local\WinRAR” => not found
                            ========= Powershell: =========
                            ========= End of Powershell: =========
                            Name StartType Status
                            [HR][/HR]
                            windefend Automatic Running
                            securityhealthservice Manual Stopped
                            Microsoft.SecHealthUI Ok
                            bfe Automatic Running
                            bits Manual Stopped
                            cryptsvc Automatic Running
                            dcomlaunch Automatic Running
                            mbamservice Manual Stopped
                            mpsdrv Manual Running
                            mpssvc Automatic Running
                            RpcEptMapper Automatic Running
                            rpcss Automatic Running
                            SecurityHealthService Manual Stopped
                            sense Manual Stopped
                            WdNisDrv Manual Running
                            WdNisSvc Manual Running
                            Windefend Automatic Running
                            winmgmt Automatic Running
                            wscsvc Automatic Running
                            wuauserv Disabled Stopped
                            updating
                            scanning quick scan
                            C:\Users\Ripple\AppData\Local\temp\APPX.7swgbv6vm5h747d2otp3edbah.tmp
                            C:\Users\Ripple\AppData\Local\temp\APPX.ahuj04oh386vmy0uhwigzhu4f.tmp
                            C:\Users\Ripple\AppData\Local\temp\APPX.tp31zuhyoum1tn7y5u_9qazuc.tmp
                            Deleted file - C:\Users\Ripple\AppData\Local\temp\geek64.bak
                            Deleted file - C:\Users\Ripple\AppData\Local\temp\7zO8B9DECC1\622.csv
                            Deleted file - C:\Users\Ripple\AppData\Local\temp\886f9e13-d918-43cb-ac90-9a2a81ffa4c2_geek.7z.4c2\geek.bak
                            Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXCEL\Primary1721400000565297400_7BDF8B25-26BC-41A0-81F1-5A383DBC556E.log
                            Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXCEL\Primary1721400000565820400_7BDF8B25-26BC-41A0-81F1-5A383DBC556E.log
                            Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXCEL\Additional\Additional1721400000566235400_7BDF8B25-26BC-41A0-81F1-5A383DBC556E.log
                            Deleted file - C:\Users\Ripple\AppData\Local\temp\Diagnostics\EXCEL\Additional\Additional1721400000566795100_7BDF8B25-26BC-41A0-81F1-5A383DBC556E.log
                            BITS transfer queue => 786432 B
                            DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 10573589 B
                            Java, Discord, Steam htmlcache, WinHttpAutoProxySvc/winhttp *.cache => 80328990 B
                            Windows/system/drivers => 192097 B
                            Edge => 0 B
                            Chrome => 0 B
                            Firefox => 64539140 B
                            Opera => 0 B
                            Default => 0 B
                            ProgramData => 0 B
                            Public => 0 B
                            LocalService => 0 B
                            NetworkService => 1170 B
                            Ripple => 25429 B
                            RecycleBin => 0 B
                            EmptyTemp: => 149.2 MB temporary data Removed.
                            ==== End of Fixlog 21:01:20 ====
                            Hi, also, lot of files in desktop, do I remove them? is it okay to just shift delete them?[/HEADING]
                            • Malnutrition
                              PCHF Moderator
                              • 7041
                              #89
                              Yes disable both bitlocker items.
                              I’ll give a more detailed reply when I get home from work, on lunch now.
                              Uninstall malwarebytes and run a scan with windows defender.
                              How is the computer running now?
                              • maxim123
                                • Aug 2017
                                • 472
                                #90
                                [ATTACH type=“full” alt=“1721415997147.png”]13983[/ATTACH]
                                I ran this as admin but it still shows this error. I tried to disable them one by one too, but the same thing.
                                I have uninstalled malwarebytes, win defender was off, when I clicked the notification and opened it, it said something like your IT something has disabled some access to this app or something. thought the error would come again after I closed it and opened the defender again, but it didn’t come, so not sure what the error was exactly. going to scan now. [edit. the quick scan finished with no threats found.]
                                I think I faced no explorer hanging issue today, there was no BSOD in morning too. will still have to check tmrw to be sure after i turn it off and open it again.
