Solved Win 11 Pro- New device via ethernet and adapter settings
Your screens should look like this.
General
Then on the advanced
This is using google as the dns. You can use any dns you want.
On the advanced screen you can also add Default gateway 192.168.251.0 if needed.
I get this warning PETERoZ5.png as I attempt to save the Advanced setting and it reverts the General to 192.168.251.0 PETERoZ6.png
Bit tricky hey. Im contacting the cnc provider. Please do update me with help as we go and I will also feed back what they say.
Your help IS MUCH APPRECIATED
Well thats great. Why the 192.168.0.14 and the weird DNS servers? Do I need to change other settings anywhere due to this?
Post #22 that warning is because you have the wrong gateway.
You have 192.168.251.0 on the general tab should be 192.168.0.1. as per my pic in post # 21.
Your post # 7 Shows that your computer was already using 192.168.0.14 so if we keep it the same there will not be a conflict on the network.
As I pointed out in Post #21 you do not need that DNS you can use the one from your modem/router
Or from your ISP. There are a lot of DNS providers around. That one is google.
No
Wooah I can access both.
Great
Reactions: xrobwx71
