I am experience this weird sound as you can hear in the clip, it happens when I am in a fullscreen game
I tried capping FPS it worked in Valorant a bit (sounds much much quieter) but in Apex it doesn't work.
I've noticed that the same noise is also present in the PC, if I am not wrong its coming from the motherboard cpu area ish (can't really locate it)
Is this normal? should I be concerned and is there any possible fix?
Thanks
Thanks
