Five days ago, I created a copy from old laptop in my USB, (it has some archives. The backup has some pictures, videos, and music, I guess music was the problem, because when backup was at 99% it was failed and after that i plug it again but the pendrive slow downs the laptop, so i ejected without safely mode and pluged it in my PC, but the pendrive started to do same, the computer started to slow down and after that restarted. The USB doesn't work when I plug it, only appears in device administrator for some seconds and after that Windows show up a message error:
USB can't be recongized. The last USB doesn't work correctly and Windows doesn't recognize
I tried everithing that I found on internet, installing programs to recover it, using powershell or CMD to located it, uninstall drivers and uninstall the USB from device administrator, but I can't try anything of these, because Windows expuls USB after some seconds, and if I try to do someting in that seconds, the program didn't respond or sometimes PC show up blue screen
I guess could be a virus that was in the old music files, I just want to delete everything and recover the USB.
The Pendrive is an ADATA UV128 / 64GB and I used only twice or three times.
I don't know what other things I can do, I hope someone will tell me if you have had this problem in the past and if that has a solution or not.
It's my first time in a forum and excuse me if I didn't a good translation, I did my best.
Thanks a lot!
Thanks a lot!
