Hello PCHF!
I've had a problem for about a week now and that's when I try to connect my android phone to my PC. When plug the USB cord in I get the error message "Usb not recognized/Device not recognized by windows". But it's strange because it worked fine just a week ago. I have not done anything on my PC or phone other than taking more photos with my android.
Things I have tried to fix the problem:
1. Deleted all USB drivers, restarted the PC and the reinstalled everything. (I also cut the power for about 10 minutes before restarting the pc)
2. Turned off all power save options in control panel and also the Root Hub power save option that allows windows to turn off USB's to save power.
3. Tried to install legacy USB options using Device Manager.
4. Installed Windows updates AND Android updates. (I had about 3 windows and 2 Android updates, still nothing)
5. Tried different USB cords and different outlets.
6. Turned on Developer mode on my Android and activated USB debugging.
All other USB's work fine. It's just my phone that won't connect so I'm assuming it's my phone that acts up. I want to mention that I have a LOT of photos on my phone and that may be the cause? It recently told me that my SD card is full and that it will continue to store on my phone. Is that an issue?
I get the USB connection sound on windows when I plug my phone in, but the phone won't show up under My computer. I just get the error message mentioned earlier.
