Solved Unable To Click In Taskbar
BobGoblin
63
4
44
Hello - i ran seagate seatools to check the hard drive for errors and it passed. And it has antivirus installed and it is showing no issues. However, when I type the pin to loginto windows 10 it takes me to the desktop, and I can click on shortcuts on the desktop no issue.
However, if I try to click the start button, it never displays. I can click the up arrow in the right side to see "extra" running programs, and I can hover over the programs to see names, but if I try to click on one (example the wifi icon) it never opens, or never gives me addition options like properties, etc.
What steps do I need to take to remedy this issue?
let’s get your PC specs...
download Speccy from here; https://www.piriform.com/speccy/builds
paste that link into a post.
One area Speccy doesn’t show is the Power Supply Unit, so also include the make/model of the PSU.
while we wait for those, have you tried these from an elevated command prompt;
  • chkdsk c: /r
  • sfc /scannow
  • dism /online /cleanup-image /restorehealth
  • dism /online /cleanup-image /startcomponentcleanup /resetbase
okay - and results are in :D
C:\WINDOWS\system32>dism /online /cleanup-image /restorehealth
Deployment Image Servicing and Management tool
Version: 10.0.19041.844
Image Version: 10.0.19043.2364
[===========================84.9%================= ]
[==========================100.0%==========================] The restore operation completed successfully.
The operation completed successfully.
C:\WINDOWS\system32>dism /online /cleanup-image /startcomponentcleanup /resetbase
only issues Speccy highlighted were; your C:\ is very low on space, and either your logging in as a user called TEMP or your main account has a cuurputed profile and the system has logged you in as TEMP.
create another user account and log in as that and see if the problem goes away.
no change.
I noticed that myself is that it's logging me in with a Temp profile even tho I choose my profile and input my pin.
I'll try to create a new profile...gotta remember how to open control panel with keyboard shortcuts :D
@Bruce -
Am I doing this wrong? I did
windows + r
typed control
navigated to Control Panel\User Accounts\User Accounts\Manage Accounts
Now I am trying to click on "Add a new user in PC Settings" but nothing is happening.
Update - using netplwiz I was able to create a local account and log-in succesfully.
The issue is non-existent with the new account I just created.
So it is a corrupted user profile?
What options do I have for creating a new account tied to my yahoo account, and not loose my desktop/documents/downloads etc?
Must be logged out of profile you wish to fix.
WOW - I wish i had known about this months ago!
Does it work 100% of the time? What is the likelyhood of success?
Works well. I’m sure there are cases when it does not, but I have had success. Nothing is a guarantee when dealing with windows.
I also never new about Account Profile Fixer.
I have always created another profile from the system created TEMP account, then signed into the new account.
from there, go to C:\users\old profile and copy its Doc, Pics, Vids, Downloads, Desktop, and Music folders.
anything else is a luxury but if it's important, you can always find the browser bookmark folder, email folder and anything else that you may need.
Nice recommend on the restore point first - I would not have thought of that.
But the handy app Account Profile Fixer seems to have done the job quite nicely.
Thanks for the support!
Reactions: Malnutrition
