Solved System Volume Information is not accessiblle
Download attached fixlist.txt file and save it to the Desktop. NOTE. It's important that both files, FRST/FRST64.exe and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
Fix result of Farbar Recovery Scan Tool (x64) Version: 31-08-2016
Ran by asing (08-09-2016 10:47:55) Run:1
Running from C:\Users\asing\Desktop
Loaded Profiles: asing (Available Profiles: asing)
Boot Mode: Normal
fixlist content:
start
CreateRestorePoint:
CloseProcesses:
Tcpip\Parameters: [DhcpNameServer] 192.168.0.1
Tcpip\Parameters: [NameServer] 8.8.8.8,8.8.8.4
Tcpip\..\Interfaces\{4e76a734-7c65-4c72-a035-2659afbfa011}: [DhcpNameServer] 82.163.142.7
Tcpip\..\Interfaces\{887cfca4-b497-4029-9de0-414877ad43d4}: [DhcpNameServer] 192.168.0.1
Tcpip\..\Interfaces\{8a4488e6-3e60-4626-8856-c22d37fc1d59}: [DhcpNameServer] 82.163.142.7
Tcpip\..\Interfaces\{c70aa751-e228-4ee5-be0e-848e89a14d64}: [DhcpNameServer] 172.18.13.1
Tcpip\..\Interfaces\{c9d2afb8-3469-479d-b58e-f159b8947d53}: [NameServer] 8.8.8.8,8.8.4.4
Tcpip\..\Interfaces\{c9d2afb8-3469-479d-b58e-f159b8947d53}: [DhcpNameServer] 172.18.11.1
Tcpip\..\Interfaces\{e55d0a98-efd2-4c8e-9672-01b375c995fa}: [DhcpNameServer] 82.163.142.7
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = hxxp://dell15.msn.com/?pc=DCTE
SearchScopes: HKLM -> DefaultScope {F6C75714-1346-4E38-A9DA-04F14D9305B8} URL =
FF Plugin-x32: @tools.google.com/Google Update;version=3 -> C:\Program Files (x86)\Google\Update\1.3.31.5\npGoogleUpdate3.dll [2016-08-02] (Google Inc.)
FF Plugin-x32: @tools.google.com/Google Update;version=9 -> C:\Program Files (x86)\Google\Update\1.3.31.5\npGoogleUpdate3.dll [2016-08-02] (Google Inc.)
FF ExtraCheck: C:\Program Files (x86)\mozilla firefox\defaults\pref\autoconfig.js [2016-01-07] <==== ATTENTION (Points to *.cfg file)
FF ExtraCheck: C:\Program Files (x86)\mozilla firefox\cck2.cfg [2016-01-07] <==== ATTENTION
R2 Amazon 1Button App Service; C:\Program Files (x86)\Amazon\Amazon1ButtonApp\Amazon1ButtonService64.Exe [436032 2016-02-17] (Amazon Inc.)
C:\ProgramData\e2aed428
2016-06-28 16:41 - 2016-06-28 16:41 - 0000132 _____ () C:\Users\asing\AppData\Roaming\Adobe IllExport Filter CS5 Prefs
2016-02-26 18:56 - 2016-08-18 00:31 - 0000132 _____ () C:\Users\asing\AppData\Roaming\Adobe PNG Format CS5 Prefs
2016-01-10 00:41 - 2016-02-05 16:22 - 0000132 _____ () C:\Users\asing\AppData\Roaming\Adobe PNG Format CS6 Prefs
2016-05-22 12:09 - 2016-06-27 12:39 - 0001456 _____ () C:\Users\asing\AppData\Local\Adobe Save for Web 12.0 Prefs
2016-02-11 01:15 - 2016-02-11 01:15 - 0001456 _____ () C:\Users\asing\AppData\Local\Adobe Save for Web 13.0 Prefs
2016-01-09 12:09 - 2016-09-06 09:42 - 1099372 _____ () C:\Users\asing\AppData\Local\BTServer.log
2016-01-27 16:13 - 2016-09-06 22:18 - 108199936 _____ () C:\Users\asing\AppData\Local\SageThumbs.db3
2016-08-14 01:58 - 2016-08-14 01:58 - 0000000 ____H () C:\ProgramData\DP45977C.lfl
2016-01-18 16:36 - 2016-01-18 16:36 - 0000131 _____ () C:\ProgramData\Microsoft.SqlServer.Compact.351.32.bc
2015-11-10 02:44 - 2015-11-10 02:45 - 0000121 _____ () C:\ProgramData\{1FBF6C24-C1fD-4101-A42B-0C564F9E8E79}.log
2015-11-10 02:42 - 2015-11-10 02:43 - 0000106 _____ () C:\ProgramData\{2A87D48D-3FDF-41fd-97CD-A1E370EFFFE2}.log
2015-11-10 02:44 - 2015-11-10 02:44 - 0000108 _____ () C:\ProgramData\{B46BEA36-0B71-4A4E-AE41-87241643FA0A}.log
2015-11-10 02:43 - 2015-11-10 02:44 - 0000113 _____ () C:\ProgramData\{E1646825-D391-42A0-93AA-27FA810DA093}.log
Task: {D730034A-822C-42AC-96D8-3881EB361E1F} - System32\Tasks\UninstallDDS-C960901F-CE14-4DE1-9729-1305F719A337 => C:\Windows\TEMP\DeleteFolderTask.exe <==== ATTENTION
Task: {E15FBCEE-32F0-4333-96B0-937D5ACC88D0} - System32\Tasks\{17B1EC3A-E372-6FC9-3C4A-B8E39BF90442} => Regsvr32.exe /s /n /i:"/rt" "C:\PROGRA~3\e2aed428\ab5c9d82.dll" <==== ATTENTION
Task: {E5AA2010-B6AB-4621-95D2-1EC9F37A9426} - \{7A040547-0F78-7F78-7A11-040D0A791178} -> No File <==== ATTENTION
HKLM\...\.scr: SageThumbsImage.scr => "%1" /S <===== ATTENTION
Hosts:
RemoveProxy:
Reg: reg delete HKLM\SOFTWARE\Policies\Microsoft\Windows\IPSec\Policy\Local /f
Reg: reg add HKLM\SOFTWARE\Policies\Microsoft\Windows\IPSec\Policy\Local /f
CMD: bitsadmin /reset /allusers
CMD: ipconfig /flushdns
Emptytemp:
reboot:
end
HKLM\System\CurrentControlSet\Services\Tcpip\Parameters\\DhcpNameServer => value removed successfully
HKLM\System\CurrentControlSet\Services\Tcpip\Parameters\\NameServer => value removed successfully
HKLM\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{4e76a734-7c65-4c72-a035-2659afbfa011}\\DhcpNameServer => value removed successfully
HKLM\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{887cfca4-b497-4029-9de0-414877ad43d4}\\DhcpNameServer => value removed successfully
HKLM\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{8a4488e6-3e60-4626-8856-c22d37fc1d59}\\DhcpNameServer => value removed successfully
HKLM\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{c70aa751-e228-4ee5-be0e-848e89a14d64}\\DhcpNameServer => value removed successfully
HKLM\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{c9d2afb8-3469-479d-b58e-f159b8947d53}\\NameServer => value removed successfully
HKLM\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{c9d2afb8-3469-479d-b58e-f159b8947d53}\\DhcpNameServer => value removed successfully
HKLM\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{e55d0a98-efd2-4c8e-9672-01b375c995fa}\\DhcpNameServer => value removed successfully
HKLM\Software\\Microsoft\Internet Explorer\Main\\Start Page => value restored successfully
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\Software\Microsoft\Internet Explorer\Main\\Start Page => value restored successfully
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\Software\Microsoft\Internet Explorer\Main\\Default_Page_URL => value restored successfully
HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\\DefaultScope => value restored successfully
"HKLM\Software\Wow6432Node\MozillaPlugins\@tools.google.com/Google Update;version=3" => key removed successfully
C:\Program Files (x86)\Google\Update\1.3.31.5\npGoogleUpdate3.dll => moved successfully
"HKLM\Software\Wow6432Node\MozillaPlugins\@tools.google.com/Google Update;version=9" => key removed successfully
C:\Program Files (x86)\Google\Update\1.3.31.5\npGoogleUpdate3.dll => not found.
"C:\Program Files (x86)\mozilla firefox\defaults\pref\autoconfig.js" => not found.
"C:\Program Files (x86)\mozilla firefox\cck2.cfg" => not found.
Amazon 1Button App Service => service not found.
"C:\ProgramData\e2aed428" => not found.
C:\Users\asing\AppData\Roaming\Adobe IllExport Filter CS5 Prefs => moved successfully
C:\Users\asing\AppData\Roaming\Adobe PNG Format CS5 Prefs => moved successfully
C:\Users\asing\AppData\Roaming\Adobe PNG Format CS6 Prefs => moved successfully
C:\Users\asing\AppData\Local\Adobe Save for Web 12.0 Prefs => moved successfully
C:\Users\asing\AppData\Local\Adobe Save for Web 13.0 Prefs => moved successfully
C:\Users\asing\AppData\Local\BTServer.log => moved successfully
C:\Users\asing\AppData\Local\SageThumbs.db3 => moved successfully
C:\ProgramData\DP45977C.lfl => moved successfully
C:\ProgramData\Microsoft.SqlServer.Compact.351.32.bc => moved successfully
C:\ProgramData\{1FBF6C24-C1fD-4101-A42B-0C564F9E8E79}.log => moved successfully
C:\ProgramData\{2A87D48D-3FDF-41fd-97CD-A1E370EFFFE2}.log => moved successfully
C:\ProgramData\{B46BEA36-0B71-4A4E-AE41-87241643FA0A}.log => moved successfully
C:\ProgramData\{E1646825-D391-42A0-93AA-27FA810DA093}.log => moved successfully
"HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{D730034A-822C-42AC-96D8-3881EB361E1F}" => key removed successfully
"HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{D730034A-822C-42AC-96D8-3881EB361E1F}" => key removed successfully
C:\WINDOWS\System32\Tasks\UninstallDDS-C960901F-CE14-4DE1-9729-1305F719A337 => moved successfully
"HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\UninstallDDS-C960901F-CE14-4DE1-9729-1305F719A337" => key removed successfully
"HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{E15FBCEE-32F0-4333-96B0-937D5ACC88D0}" => key removed successfully
"HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{E15FBCEE-32F0-4333-96B0-937D5ACC88D0}" => key removed successfully
C:\WINDOWS\System32\Tasks\{17B1EC3A-E372-6FC9-3C4A-B8E39BF90442} => moved successfully
"HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\{17B1EC3A-E372-6FC9-3C4A-B8E39BF90442}" => key removed successfully
"HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{E5AA2010-B6AB-4621-95D2-1EC9F37A9426}" => key removed successfully
"HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{E5AA2010-B6AB-4621-95D2-1EC9F37A9426}" => key removed successfully
"HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\{7A040547-0F78-7F78-7A11-040D0A791178}" => key removed successfully
"C:\PROGRA~3\e2aed428\ab5c9d82.dll" => not found.
HKLM\Software\Classes\.scr\\Default => value restored successfully
"C:\Program Files (x86)\Amazon\Amazon1ButtonApp\Amazon1ButtonService64.Exe" => not found.
"C:\Program Files (x86)\Amazon" => not found.
C:\Windows\System32\Drivers\etc\hosts => moved successfully
Hosts restored successfully.
HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\DefaultConnectionSettings => value removed successfully
HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\SavedLegacySettings => value removed successfully
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\DefaultConnectionSettings => value removed successfully
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\SavedLegacySettings => value removed successfully
========= reg delete HKLM\SOFTWARE\Policies\Microsoft\Windows\IPSec\Policy\Local /f =========
The operation completed successfully.
========= End of Reg: =========
========= reg add HKLM\SOFTWARE\Policies\Microsoft\Windows\IPSec\Policy\Local /f =========
========= bitsadmin /reset /allusers =========
BITSADMIN version 3.0
BITS administration utility.
(C) Copyright 2000-2006 Microsoft Corp.
BITSAdmin is deprecated and is not guaranteed to be available in future versions of Windows.
Administrative tools for the BITS service are now provided by BITS PowerShell cmdlets.
Unable to cancel {4AAE658C-5855-4459-9E04-237DCBD7C258}.
{F4DB9F40-C179-452A-9EB2-7DF9AF37226B} canceled.
{EF5BF162-E4BB-4CC9-BB52-209202BE0129} canceled.
{8C70F2E2-0402-4B3D-B47F-3C17C6DD553D} canceled.
{771654B8-D68F-4AA7-9877-7392D6BB91BA} canceled.
{E3956A34-4213-4C90-95B3-FBDBC7DCB36C} canceled.
{63B17E56-9B1E-429A-B748-2CA9AC5C30A1} canceled.
{F00417AA-0D2D-483D-A7A5-B50D5CFED563} canceled.
{C5830833-51FF-466E-9D38-FCA9247DB589} canceled.
{52FA08DE-B427-427E-98B7-1657D3A68762} canceled.
{9AA56370-DEBD-4EBB-BF93-AB98AE74C72B} canceled.
{CACBBACB-86C2-4034-9DEC-0EE95F8B0A25} canceled.
11 out of 12 jobs canceled.
Windows IP Configuration
BITS transfer queue => 32768 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 283338939 B
Java, Flash, Steam htmlcache => 711 B
Windows/system/drivers => 976204 B
Edge => 4877 B
Chrome => 1719296 B
Firefox => 80438778 B
Opera => 0 B
Default => 0 B
ProgramData => 0 B
Public => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 0 B
NetworkService => 0 B
asing => 19277271 B
RecycleBin => 0 B
EmptyTemp: => 367.9 MB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 10:48:39 ====
Sorry for the delay, can you tell me how things are running now please. Also, another scan to make sure we got everything.
JRT Scan.
  • Shut down your anti-virus, anti-spyware, and firewall software now to avoid potential conflicts.
  • Run the tool by double-clicking it. If you are using Windows Vista or Windows 7, right-click it and select Run as administrator.
  • The tool will open and start scanning your system.
  • Please be patient as this can take a while to complete depending on your system's specifications.
  • On completion, a log is saved to your desktop and will automatically open.
  • Please post the JRT log.
Adware Removal Tool Scan.
Hit Ok.
The Program will close all open programs to complete the removal, so save any work and hit OK. Then hit OK after the removal process is complete, thenOK again to finish up. Post log generated by tool.
ZHP Scan.
2. Once you have started the program, you will need to click the scanner button.
3. Once the scan is completed, the you will want to click the Repair button.
At the end of the process you may be asked to reboot your machine. After you reboot a report will open on your desktop.
Copy and paste the report here in your next reply.
Please re-run Farbar Recovery Scan Tool to give me a fresh look at your system.
  • Right-click on FRST icon and select Run as Administrator to start the tool.
    (XP users click run after receipt of Windows Security Warning - Open File).
  • Make sure that Addition option is checked.
  • Press Scan button and wait.
  • The tool will produce two logfiles on your desktop: FRST.txt, and Addition.txt.
Please Copy & Paste them into your next reply
Version: 8.0.7 (07.03.2016)
Operating System: Windows 10 Home x64
Ran by asing (Administrator) on Thu 09/08/2016 at 16:13:59.98
File System: 1
Successfully deleted: C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\bmnlcjabgnpnenekpadlanbbkooimhnj (Folder)
Registry: 1
Successfully deleted: HKLM\SYSTEM\CurrentControlSet\services\0311011473334633mcinstcleanup (Registry Key)
Scan was completed on Thu 09/08/2016 at 16:15:28.63
End of JRT log
File System: 1
Registry: 1
End of JRT log
~ ZHPCleaner v2016.9.7.124 by Nicolas Coolman (2016/09/07)
~ Run by asing (Administrator) (08/09/2016 16:34:34)
~ Blog: https://www.anti-malware.top
~ Facebook : https://www.facebook.com/nicolascoolman1
~ State version : Version OK
~ Type : Scan
~ Report : C:\Users\asing\Desktop\ZHPCleaner.txt
~ Quarantine : C:\Users\asing\AppData\Roaming\ZHP\ZHPCleaner_Quarantine.txt
~ UAC : Activate
~ Boot Mode : Normal (Normal boot)
Windows 10 Home, 64-bit (Build 14393)
---\\ Services (0)
~ No malicious or unnecessary items found.
---\\ Browser internet (0)
---\\ Hosts file (1)
~ The hosts file is legitimate (1)
---\\ Scheduled automatic tasks. (0)
---\\ Explorer ( File, Folder) (0)
---\\ Registry ( Key, Value, Data) (0)
---\\ Other deletions. (17)
~ Registry Keys Tracing deleted (17)
~ Remove the old reports ZHPCleaner. (0)
---\\ Result of repair
~ Any repair made
~ Browser not found (Opera Software)
---\\ Statistics
~ Items scanned : 642
~ Items found : 0
~ Items cancelled : 0
~ Items repaired : 0
~ End of search in 00h00mn05s
ZHPCleaner--08092016-16_32_51.txt
ZHPCleaner--08092016-16_34_21.txt
ZHPCleaner--08092016-16_34_39.txt
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 31-08-2016
Ran by asing (08-09-2016 16:45:18)
Windows 10 Home Version 1607 (X64) (2016-08-14 01:25:20)
Boot Mode: Normal
Administrator (S-1-5-21-3799958336-243299179-1538509029-500 - Administrator - Disabled)
asing (S-1-5-21-3799958336-243299179-1538509029-1001 - Administrator - Enabled) => C:\Users\asing
DefaultAccount (S-1-5-21-3799958336-243299179-1538509029-503 - Limited - Disabled)
Guest (S-1-5-21-3799958336-243299179-1538509029-501 - Limited - Disabled)
AV: McAfee Anti-Virus and Anti-Spyware (Enabled - Up to date) {DA9F8ED0-D0DE-39CC-F55A-51AB4CC1B556}
AS: McAfee Anti-Virus and Anti-Spyware (Enabled - Up to date) {61FE6F34-F6E4-3642-CFEA-6AD93746FFEB}
FW: McAfee Firewall (Enabled) {E2A40FF5-9AB1-3894-DE05-F89EB212F22D}
Adobe Acrobat Reader DC (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 15.017.20053 - Adobe Systems Incorporated)
Adobe AIR (HKLM-x32\...\Adobe AIR) (Version: 3.1.0.4880 - Adobe Systems Incorporated)
Adobe Flash Player 22 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 22.0.0.209 - Adobe Systems Incorporated)
Adobe Help Manager (HKLM-x32\...\chc.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1) (Version: 4.0.244 - Adobe Systems Incorporated)
Adobe Illustrator CS6 (HKLM-x32\...\{4869414E-7AEA-4C8E-BE1C-8D40977FD517}) (Version: 16.0 - Adobe Systems Incorporated)
Adobe Media Player (HKLM-x32\...\com.adobe.amp.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1) (Version: 1.8 - Adobe Systems Incorporated)
Adobe Photoshop CS5 (HKLM-x32\...\{15FEDA5F-141C-4127-8D7E-B962D1742728}) (Version: 12.0 - Adobe Systems Incorporated)
Adobe Premiere Pro CS6 (HKLM-x32\...\{7176B973-6011-43C1-AEBC-2D73FE7C6982}) (Version: 6.0 - Adobe Systems Incorporated)
AFPL Ghostscript 8.54 (HKLM\...\AFPL Ghostscript 8.54) (Version: - )
AFPL Ghostscript Fonts (HKLM\...\AFPL Ghostscript Fonts) (Version: - )
Alcor Micro USB Card Reader Driver (HKLM-x32\...\InstallShield_{2282AFD7-5074-4BC6-B1F7-205AAC8F6AC9}) (Version: 18.6.1844.34416 - Alcor Micro Corp.)
Alcor Micro USB Card Reader Driver (x32 Version: 18.6.1844.34416 - Alcor Micro Corp.) Hidden
Apple Application Support (32-bit) (HKLM-x32\...\{26356515-5821-40FA-9C3D-9785052A1062}) (Version: 4.3.1 - Apple Inc.)
Apple Application Support (64-bit) (HKLM\...\{C2651553-6CA3-4822-B2E6-BC4ACA6E0EA2}) (Version: 4.3.1 - Apple Inc.)
Apple Mobile Device Support (HKLM\...\{2E4AF2A6-50EA-4260-9BA4-5E582D11879A}) (Version: 9.3.0.15 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{56EC47AA-5813-4FF6-8E75-544026FBEA83}) (Version: 2.2.0.150 - Apple Inc.)
Audacity 2.1.2 (HKLM-x32\...\Audacity®_is1) (Version: 2.1.2 - Audacity Team)
bl (x32 Version: 1.0.0 - Your Company Name) Hidden
CCleaner (HKLM\...\CCleaner) (Version: 5.21 - Piriform)
Cisco EAP-FAST Module (HKLM-x32\...\{64BF0187-F3D2-498B-99EA-163AF9AE6EC9}) (Version: 2.2.14 - Cisco Systems, Inc.)
Cisco LEAP Module (HKLM-x32\...\{AF312B06-5C5C-468E-89B3-BE6DE2645722}) (Version: 1.0.19 - Cisco Systems, Inc.)
Cisco PEAP Module (HKLM-x32\...\{0A4EF0E6-A912-4CDE-A7F3-6E56E7C13A2F}) (Version: 1.1.6 - Cisco Systems, Inc.)
Citrix Online Launcher (HKLM-x32\...\{09DA5EE2-7E46-4DC4-96F9-BFEE50D40659}) (Version: 1.0.408 - Citrix)
CyberLink Media Suite Essentials (HKLM-x32\...\InstallShield_{8F14AA37-5193-4A14-BD5B-BDF9B361AEF7}) (Version: 12 - CyberLink Corp.)
Dell Data Vault (Version: 4.3.8.0 - Dell Inc.) Hidden
Dell Update (HKLM-x32\...\{DB82968B-57A4-4397-81A5-ECAB21B5DFCD}) (Version: 1.7.1015.0 - Dell Inc.)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 52.0.2743.116 - Google Inc.)
Google Update Helper (x32 Version: 1.3.31.5 - Google Inc.) Hidden
GoToMeeting 7.22.1.5530 (HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\GoToMeeting) (Version: 7.22.1.5530 - CitrixOnline)
Grammarly (HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\GrammarlyForWindows) (Version: 1.4.23 - Grammarly)
Intel(R) Chipset Device Software (x32 Version: 10.1.1.13 - Intel(R) Corporation) Hidden
Intel(R) Management Engine Components (HKLM\...\{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 11.0.0.1167 - Intel Corporation)
Intel(R) Network Connections 20.2.4001.0 (HKLM\...\PROSetDX) (Version: 20.2.4001.0 - Intel)
Intel(R) Rapid Storage Technology (HKLM\...\{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 14.5.0.1081 - Intel Corporation)
Intel(R) Ready Mode Technology (HKLM\...\{885308A3-1E3C-4A84-BFEC-35A696600DF2}) (Version: 1.1.70.506 - Intel Corporation)
Intel® Security Assist (HKLM-x32\...\{4B230374-6475-4A73-BA6E-41015E9C5013}) (Version: 1.0.0.532 - Intel Corporation)
Internet Download Manager (HKLM-x32\...\Internet Download Manager) (Version: - Tonec Inc.)
iTunes (HKLM\...\{9F4BF859-C3A4-4AB6-BDD1-9C5D58188598}) (Version: 12.4.1.6 - Apple Inc.)
Java 8 Update 101 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180101F0}) (Version: 8.0.1010.13 - Oracle Corporation)
Mailbird (HKLM-x32\...\{5B1785F8-7578-446A-B380-E9810BF74712}) (Version: 2.3.18 - Mailbird)
Malwarebytes Anti-Exploit version 1.8.1.2572 (HKLM\...\Malwarebytes Anti-Exploit_is1) (Version: 1.8.1.2572 - Malwarebytes)
Malwarebytes Anti-Malware version 2.2.1.1043 (HKLM-x32\...\Malwarebytes Anti-Malware_is1) (Version: 2.2.1.1043 - Malwarebytes)
Maxx Audio Installer (x64) (Version: 2.6.6073.1 - Waves Audio Ltd.) Hidden
McAfee LiveSafe (HKLM-x32\...\MSC) (Version: 15.0.166 - McAfee, Inc.)
Microsoft Office 365 - en-us (HKLM\...\O365HomePremRetail - en-us) (Version: 16.0.7167.2040 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.51106 (HKLM-x32\...\{6e8f74e0-43bd-4dce-8477-6ff6828acc07}) (Version: 11.0.51106.1 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 (HKLM-x32\...\{a1909659-0a08-4554-8af1-2175904903a1}) (Version: 11.0.60610.1 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.21005 (HKLM-x32\...\{7f51bdb9-ee21-49ee-94d6-90afc321780e}) (Version: 12.0.21005.1 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.21005 (HKLM-x32\...\{ce085a78-074e-4823-8dc1-8a721b94b76d}) (Version: 12.0.21005.1 - Microsoft Corporation)
Mozilla Firefox 48.0.2 (x86 en-GB) (HKLM-x32\...\Mozilla Firefox 48.0.2 (x86 en-GB)) (Version: 48.0.2 - Mozilla)
Mozilla Maintenance Service (HKLM-x32\...\MozillaMaintenanceService) (Version: 48.0.2.6079 - Mozilla)
nexusfont 2.6 (ver 2.6.2.1870) (HKLM-x32\...\{EFEDD205-43FE-4208-B682-0937E803E19E}_is1) (Version: - xiles)
NVIDIA 3D Vision Controller Driver 364.44 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 364.44 - NVIDIA Corporation)
NVIDIA 3D Vision Driver 368.39 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 368.39 - NVIDIA Corporation)
NVIDIA GeForce Experience 3.0.5.22 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.0.5.22 - NVIDIA Corporation)
NVIDIA Graphics Driver 368.39 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 368.39 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.34.14 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.14 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.16.0318 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
NvNodejs (Version: 3.0.5.22 - NVIDIA Corporation) Hidden
NvTelemetry (Version: 1.0.0.0 - NVIDIA Corporation) Hidden
Office 16 Click-to-Run Extensibility Component (x32 Version: 16.0.7167.2040 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Licensing Component (Version: 16.0.7167.2040 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Localization Component (x32 Version: 16.0.7167.2040 - Microsoft Corporation) Hidden
Oxelon Media Converter 1.1 (HKLM-x32\...\Oxelon Media Converter_is1) (Version: - Oxelon)
PDF Settings CS5 (x32 Version: 10.0 - Adobe Systems Incorporated) Hidden
ph (x32 Version: 1.0.0 - Your Company Name) Hidden
Rapport (x32 Version: 3.5.1609.76 - Trusteer) Hidden
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7544 - Realtek Semiconductor Corp.)
Realtek USB Audio (HKLM-x32\...\{0A46A65D-89AC-464C-8026-3CD44960BD04}) (Version: 6.3.9600.41 - Realtek Semiconductor Corp.)
REALTEK Wireless LAN and Bluetooth Driver (HKLM-x32\...\{6BFBB929-C278-42B3-8065-FF1178E071B8}) (Version: 13.221.243 - REALTEK Semiconductor Corp.)
RogueKiller version 12 (HKLM\...\8B3D7924-ED89-486B-8322-E8594065D5CB_is1) (Version: 12 - Adlice Software)
SageThumbs 2.0.0.22 (HKLM\...\SageThumbs) (Version: 2.0.0.22 - Cherubic Software)
SHIELD Streaming (Version: 7.1.0310 - NVIDIA Corporation) Hidden
SHIELD Wireless Controller Driver (Version: 3.0.5.22 - NVIDIA Corporation) Hidden
Smart View (HKLM-x32\...\{110B183E-0D44-49D6-B4C0-33D3296DAE84}) (Version: 1.0.0.0 - Samsung )
Trusteer Endpoint Protection (HKLM-x32\...\Rapport_msi) (Version: 3.5.1609.76 - Trusteer)
TunnelBear (HKLM-x32\...\{90e7dc26-e7df-406b-af23-61df6728a9f6}) (Version: 2.3.25.0 - TunnelBear)
TunnelBear (x32 Version: 2.3.25.0 - TunnelBear) Hidden
Vector Magic (HKLM-x32\...\Vector Magic) (Version: 1.15 - Vector Magic, Inc.)
VideoMakerFX (HKLM-x32\...\VideoMakerFX 1.1) (Version: 1.1 - Webvati)
VideoMakerFX (x32 Version: 1.1 - Webvati) Hidden
VLC media player (HKLM-x32\...\VLC media player) (Version: 2.2.4 - VideoLAN)
Vulkan Run Time Libraries 1.0.11.1 (HKLM\...\VulkanRT1.0.11.1) (Version: 1.0.11.1 - LunarG, Inc.)
WhatsApp (HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\WhatsApp) (Version: 0.2.1455 - WhatsApp)
WinRAR 5.31 beta 1 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.31.1 - win.rar GmbH)
Zemana AntiMalware (HKLM-x32\...\{8F0CD7D1-42F3-4195-95CD-833578D45057}_is1) (Version: 2.30.75 - Zemana Ltd.)
CustomCLSID: HKU\S-1-5-21-3799958336-243299179-1538509029-1001_Classes\CLSID\{71DCE5D6-4B57-496B-AC21-CD5B54EB93FD}\localserver32 -> C:\Users\asing\AppData\Local\Microsoft\OneDrive\17.3.6517.0809\FileCoAuth.exe (Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-3799958336-243299179-1538509029-1001_Classes\CLSID\{84B5A313-CD5D-4904-8BA2-AFDC81C1B309}\InprocServer32 -> C:\Users\asing\AppData\Local\Citrix\GoToMeeting\4800\G2MOutlookAddin64.dll (Citrix Online, a division of Citrix Systems, Inc.)
Task: {02D4EE97-706C-49A6-9A75-04DD1328DDBF} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe [2016-02-23] (Apple Inc.)
Task: {0D75FF26-AA3A-4852-B403-4E35D2747CC9} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-03-06] (Google Inc.)
Task: {0E4A2DF9-4DD2-4CB3-BA56-576BC6BC0E0C} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-03-06] (Google Inc.)
Task: {1C6A79E0-C490-4DF0-90A8-E691C114A1AE} - System32\Tasks\AdobeAAMUpdater-1.0-MicrosoftAccount-a.singh2@hotmail.com => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe [2012-04-04] (Adobe Systems Incorporated)
Task: {20AE1760-EEA8-48FD-8C3E-4F122A22F2FF} - System32\Tasks\NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [2016-09-02] (NVIDIA Corporation)
Task: {241F84AE-4D51-4CC6-A6E6-1C2578E1A800} - System32\Tasks\McAfee\McAfee Auto Maintenance Task Agent
Task: {286FFBBE-4F02-48DF-B6D3-1E58FA777719} - System32\Tasks\NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmMon.exe [2016-09-02] (NVIDIA Corporation)
Task: {298E86EC-8B77-4F20-A936-4C52A5A9C9A8} - System32\Tasks\Intel Security DAT Reputation (AMCore) Post DAT update endpoint safety pulse => C:\Program Files\Common Files\McAfee\AMContent\scanners\x86_64\datrep\54.0\mcdatrep.exe [2016-02-16] (McAfee, Inc.)
Task: {3AC7E43E-6700-4E39-8853-FDF2EF1A6C0E} - System32\Tasks\OneDrive Standalone Update Task => C:\Users\asing\AppData\Local\Microsoft\OneDrive\17.3.6517.0809\OneDriveStandaloneUpdater.exe [2016-08-26] (Microsoft Corporation)
Task: {3B7DCC42-EE73-41A8-BAE1-0AF147FA40A4} - System32\Tasks\McAfee\McAfee Idle Detection Task
Task: {4C00DDAA-F7E8-44DC-AEDC-79660B6F0BC7} - System32\Tasks\Microsoft\Office\Office Subscription Maintenance => C:\Program Files (x86)\Microsoft Office\root\vfs\ProgramFilesCommonx86\Microsoft Shared\Office16\OLicenseHeartbeat.exe [2016-08-24] (Microsoft Corporation)
Task: {51CFAA48-6C7E-40BA-8CF1-C91B351C2BE9} - System32\Tasks\Intel Security DAT Reputation (AMCore) periodic endpoint safety pulse => C:\Program Files\Common Files\McAfee\AMContent\scanners\x86_64\datrep\54.0\mcdatrep.exe [2016-02-16] (McAfee, Inc.)
Task: {65FCA0A4-A5CF-4B4C-B951-3F84CECF223E} - System32\Tasks\CLVDLauncher => C:\Program Files (x86)\CyberLink\CyberLink Media Suite\Power2Go8\CLVDLauncher.exe [2015-01-29] (CyberLink Corp.)
Task: {717E6647-211D-4D2C-B3E9-2DCD36A7BA84} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2016-06-25] (Adobe Systems Incorporated)
Task: {71E7B1AA-1365-4C56-831E-5E5CC2E976FE} - System32\Tasks\G2MUploadTask-S-1-5-21-3799958336-243299179-1538509029-1001 => C:\Users\asing\AppData\Local\Citrix\GoToMeeting\5387\g2mupload.exe [2016-08-12] (Citrix Online, a division of Citrix Systems, Inc.)
Task: {7B178133-E42B-4072-9BE5-093FA34C449C} - System32\Tasks\Microsoft\Office\Office Automatic Updates => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2016-08-11] (Microsoft Corporation)
Task: {80C2D1C0-7FB2-46E2-A7F0-D87A241CCEA9} - System32\Tasks\NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\NvNode\nvnodejslauncher.exe [2016-09-02] (NVIDIA Corporation)
Task: {8C887E9D-A10B-4F4A-979E-A3C89B754343} - System32\Tasks\Microsoft\Windows\RemovalTools\MRT_HB => C:\Windows\system32\MRT.exe [2016-08-10] (Microsoft Corporation)
Task: {96C83F7F-6DBC-42B5-9209-A26D3EB54759} - System32\Tasks\G2MUpdateTask-S-1-5-21-3799958336-243299179-1538509029-1001 => C:\Users\asing\AppData\Local\Citrix\GoToMeeting\5387\g2mupdate.exe [2016-08-12] (Citrix Online, a division of Citrix Systems, Inc.)
Task: {9DA200C5-56CE-4E2C-A4E5-6DDD2EDF044C} - System32\Tasks\McAfeeLogon => C:\Program Files\Common Files\McAfee\platform\McUICnt.exe [2016-07-07] (McAfee, Inc.)
Task: {AAAAE666-7E03-4684-9D35-DDC096DE7736} - System32\Tasks\NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [2016-09-02] (NVIDIA Corporation)
Task: {AAF8A2A1-B02C-42E8-9350-DBE887A99FA4} - System32\Tasks\Adobe Flash Player Updater => C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2016-07-12] (Adobe Systems Incorporated)
Task: {B10F825D-37C9-45FA-8288-918C93829413} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2016-08-05] (Piriform Ltd)
Task: {E6BE5754-C8C0-4649-81C9-FF97CB1275EA} - System32\Tasks\Microsoft\Office\Office ClickToRun Service Monitor => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2016-08-11] (Microsoft Corporation)
Task: {F530D766-A50E-4412-AD13-2F2DD0D20350} - System32\Tasks\NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe [2016-09-02] (NVIDIA Corporation)
Task: {F8620F85-EF05-44F1-9EF4-5E5F42EF46C0} - System32\Tasks\CLMLSvc_P2G8 => C:\Program Files (x86)\CyberLink\CyberLink Media Suite\Power2Go8\CLMLSvc_P2G8.exe [2015-08-19] (CyberLink)
Task: C:\WINDOWS\Tasks\Adobe Flash Player Updater.job => C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
Task: C:\WINDOWS\Tasks\G2MUpdateTask-S-1-5-21-3799958336-243299179-1538509029-1001.job => C:\Users\asing\AppData\Local\Citrix\GoToMeeting\5387\g2mupdate.exe
Task: C:\WINDOWS\Tasks\G2MUploadTask-S-1-5-21-3799958336-243299179-1538509029-1001.job => C:\Users\asing\AppData\Local\Citrix\GoToMeeting\5387\g2mupload.exe
Task: C:\WINDOWS\Tasks\GoogleUpdateTaskMachineCore.job => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
Task: C:\WINDOWS\Tasks\GoogleUpdateTaskMachineUA.job => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
Task: C:\WINDOWS\Tasks\RunDLC.job => cmd c sc start Dell Help Support WORKGROUP MANISH MAN592
==================== Shortcuts =============================
2016-07-16 12:42 - 2016-07-16 12:42 - 00231424 _____ () C:\WINDOWS\SYSTEM32\ism32k.dll
2016-07-16 12:42 - 2016-07-16 12:42 - 02681200 _____ () C:\WINDOWS\system32\CoreUIComponents.dll
2016-08-14 01:58 - 2016-06-03 04:59 - 00133056 _____ () C:\Program Files\NVIDIA Corporation\Display\NvSmartMax64.dll
2015-05-19 18:11 - 2015-05-19 18:11 - 00007680 _____ () C:\Program Files (x86)\Intel\Intel(R) Security Assist\isaHelperService.exe
2016-04-22 01:07 - 2016-04-22 01:07 - 00092472 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
2016-04-22 01:07 - 2016-04-22 01:07 - 01337144 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
2015-11-10 02:55 - 2015-08-27 14:22 - 00121048 _____ () C:\Program Files (x86)\REALTEK\Realtek Bluetooth\BTDevMgr.exe
2016-05-11 08:48 - 2016-05-11 08:48 - 00041472 _____ () C:\Program Files (x86)\TunnelBear\TBear.Maintenance.exe
2016-09-08 11:03 - 2016-09-02 12:17 - 04488640 _____ () C:\Program Files\NVIDIA Corporation\NvContainer\Poco.dll
2016-09-08 11:03 - 2016-09-02 12:17 - 01147328 _____ () C:\Program Files\NVIDIA Corporation\NvContainer\libprotobuf.dll
2016-09-08 11:03 - 2016-09-02 12:17 - 00418240 _____ () C:\Program Files\NVIDIA Corporation\NvContainer\plugins\LocalSystem\_nvspserviceplugin64.dll
2015-11-10 02:44 - 2014-04-15 03:59 - 00253776 ____N () C:\Program Files (x86)\CyberLink\Shared files\RichVideo.exe
2016-07-16 12:42 - 2016-07-16 12:42 - 02681200 _____ () C:\WINDOWS\SYSTEM32\CoreUIComponents.dll
2016-08-26 23:35 - 2016-08-26 23:35 - 01864384 _____ () C:\Users\asing\AppData\Local\Microsoft\OneDrive\17.3.6517.0809\amd64\ClientTelemetry.dll
2016-05-29 21:17 - 2016-08-24 10:17 - 08921800 _____ () C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\1033\GrooveIntlResource.dll
2016-09-07 09:49 - 2016-09-07 09:49 - 00123760 _____ () C:\Program Files (x86)\Zemana AntiMalware\ZAMShellExt64.dll
2015-11-10 02:55 - 2014-07-03 18:22 - 00277720 _____ () C:\Program Files (x86)\REALTEK\Realtek Bluetooth\SkypePlugin.exe
2016-07-16 12:42 - 2016-07-16 12:42 - 00134656 _____ () C:\Windows\ShellExperiences\Windows.UI.Shell.SharedUtilities.dll
2016-07-16 12:43 - 2016-08-31 22:56 - 00474112 _____ () C:\Windows\ShellExperiences\QuickActions.dll
2016-07-16 12:43 - 2016-08-31 22:56 - 09761280 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\CortanaApi.dll
2016-08-31 23:04 - 2016-08-20 05:54 - 01401344 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Core.dll
2016-07-16 12:43 - 2016-08-31 22:56 - 00757248 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\CSGSuggestLib.dll
2016-07-16 12:43 - 2016-08-31 22:56 - 01033728 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Actions.dll
2016-08-31 23:04 - 2016-08-20 05:54 - 02438144 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.BackgroundTask.dll
2016-08-31 23:04 - 2016-08-20 05:56 - 04853760 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\RemindersUI.dll
2016-08-30 20:24 - 2016-08-30 20:25 - 00071168 _____ () C:\Program Files\WindowsApps\Microsoft.SkypeApp_11.7.113.0_x64__kzf8qxf38zg5c\SkypeHost.exe
2016-08-30 20:24 - 2016-08-30 20:25 - 00178176 _____ () C:\Program Files\WindowsApps\Microsoft.SkypeApp_11.7.113.0_x64__kzf8qxf38zg5c\SkypeBackgroundTasks.dll
2016-08-30 20:24 - 2016-08-30 20:25 - 35288064 _____ () C:\Program Files\WindowsApps\Microsoft.SkypeApp_11.7.113.0_x64__kzf8qxf38zg5c\SkyWrap.dll
2016-08-26 20:33 - 2016-08-26 20:33 - 01413120 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsAlarms_10.1608.2312.0_x64__8wekyb3d8bbwe\TimeBackground.dll
2016-08-23 17:56 - 2016-08-23 17:56 - 00055808 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11607.1001.51.0_x64__8wekyb3d8bbwe\WinStoreTasksWrapper.dll
2016-07-16 12:43 - 2016-08-31 22:56 - 00114176 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Dss.BackgroundTask.dll
2016-07-16 12:43 - 2016-08-31 22:56 - 00115712 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\DeviceSideServicesActionUriHandler.dll
2016-07-16 12:43 - 2016-08-31 22:56 - 00522752 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.NodeWinrtWrap.dll
2016-09-08 11:03 - 2016-09-02 12:17 - 00018880 _____ () C:\Program Files (x86)\NVIDIA Corporation\Update Core\detoured.dll
2015-11-10 02:42 - 2014-12-08 08:28 - 00627672 _____ () C:\Program Files (x86)\CyberLink\CyberLink Media Suite\Power2Go8\CLMediaLibrary.dll
2014-12-09 00:28 - 2014-12-09 00:28 - 00016856 _____ () C:\Program Files (x86)\CyberLink\CyberLink Media Suite\Power2Go8\CLMLSvcPS.dll
2015-09-04 20:34 - 2015-09-04 20:34 - 01243936 _____ () C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\ACE.dll
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MCODS => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\mcpltsvc => ""=""
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mcapexe => ""=""
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\McMPFSvc => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MCODS => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mcpltsvc => ""=""
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfeaack => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfeaack.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfeavfk => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfeavfk.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfefire => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfefirek => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfefirek.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfehidk => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfehidk.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfemms => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfetdi2k => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfetdi2k.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\mfevtp => ""="Service"
IE trusted site: HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\amazon.co.uk -> hxxps://amazon.co.uk
2015-07-10 12:04 - 2016-09-08 10:48 - 00000027 ____A C:\WINDOWS\system32\Drivers\etc\hosts
127.0.0.1 localhost
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\Control Panel\Desktop\\Wallpaper -> C:\Users\asing\AppData\Local\Microsoft\Windows\Themes\RoamedThemeFiles\DesktopBackground\wallpaper 1.jpg
DNS Servers: 192.168.0.1
Windows Firewall is enabled.
HKLM\...\StartupApproved\Run: => "RtHDVBg_MAXX6"
HKLM\...\StartupApproved\Run: => "BtServer"
HKLM\...\StartupApproved\Run: => "RTHDVCPL"
HKLM\...\StartupApproved\Run: => "WavesSvc"
HKLM\...\StartupApproved\Run: => "iTunesHelper"
HKLM\...\StartupApproved\Run: => "ShadowPlay"
HKLM\...\StartupApproved\Run32: => "AdobeCS6ServiceManager"
HKLM\...\StartupApproved\Run32: => "SwitchBoard"
HKLM\...\StartupApproved\Run32: => "AdobeCS5ServiceManager"
HKLM\...\StartupApproved\Run32: => "AdobeAAMUpdater-1.0"
HKLM\...\StartupApproved\Run32: => "IAStorIcon"
HKLM\...\StartupApproved\Run32: => "NvBackend"
HKLM\...\StartupApproved\Run32: => "SunJavaUpdateSched"
HKLM\...\StartupApproved\Run32: => "ZAM"
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\StartupApproved\Run: => "OneDrive"
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\StartupApproved\Run: => "IDMan"
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\StartupApproved\Run: => "CCleaner Monitoring"
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\StartupApproved\Run: => "TunnelBear"
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\StartupApproved\Run: => "Mailbird"
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\StartupApproved\Run: => "Uninstall C:\Users\asing\AppData\Local\Microsoft\OneDrive\17.3.6390.0509_1\amd64"
FirewallRules: [{1D2239F0-AA1E-4527-A600-23603F92668F}] => (Allow) C:\Program Files (x86)\Microsoft Office\root\Office16\outlook.exe
FirewallRules: [{EB628558-B2FD-4532-BE29-E39670C1D72B}] => (Allow) C:\Program Files\NVIDIA Corporation\NvContainer\NvContainer.exe
FirewallRules: [{471094BA-D771-4A99-BE20-631A4E9ACCD1}] => (Allow) C:\Program Files\NVIDIA Corporation\NvContainer\NvContainer.exe
FirewallRules: [{8236EBD3-2E88-4A96-8BA8-EEC4D8242BE3}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
FirewallRules: [{192B40E2-DD83-4D4B-B482-05B02A50BBF0}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
FirewallRules: [{6337D4C1-5B3F-480F-BCE5-9D78D73AA2C8}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
FirewallRules: [{59E5CD81-769C-44BF-9578-9956DCABBA04}] => (Allow) C:\Program Files\Common Files\McAfee\Platform\McSvcHost\McSvHost.exe
31-08-2016 12:30:32 Scheduled Checkpoint
07-09-2016 01:34:05 zoek.exe restore point
Application errors:
Error: (09/08/2016 04:14:22 PM) (Source: VSS) (EventID: 8193) (User: )
Description: Volume Shadow Copy Service error: Unexpected error calling routine QueryFullProcessImageNameW. hr = 0x80070006, The handle is invalid.
Operation:
Executing Asynchronous Operation
Context:
Current State: DoSnapshotSet
Error: (09/08/2016 04:14:07 PM) (Source: Microsoft-Windows-CAPI2) (EventID: 513) (User: )
Description: Cryptographic Services failed while processing the OnIdentity() call in the System Writer Object.
Details:
AddLegacyDriverFiles: Unable to back up image of binary Microsoft Link-Layer Discovery Protocol.
System Error:
Access is denied.
Error: (09/08/2016 10:55:56 AM) (Source: Microsoft-Windows-Immersive-Shell) (EventID: 5973) (User: MANISH-MAN592)
Description: Activation of app Microsoft.Windows.Photos_8wekyb3d8bbwe!App failed with error: -2147023174 See the Microsoft-Windows-TWinUI/Operational log for additional information.
Description: Activation of app Microsoft.Windows.Photos_8wekyb3d8bbwe!App failed with error: -2147023170 See the Microsoft-Windows-TWinUI/Operational log for additional information.
Error: (09/08/2016 10:48:28 AM) (Source: VSS) (EventID: 8193) (User: )
Description: Volume Shadow Copy Service error: Unexpected error calling routine QueryFullProcessImageNameW. hr = 0x8007001f, A device attached to the system is not functioning.
Operation:
Context:
Error: (09/08/2016 10:48:10 AM) (Source: Microsoft-Windows-CAPI2) (EventID: 513) (User: )
Details:
System Error:
Access is denied.
Error: (09/08/2016 10:47:58 AM) (Source: VSS) (EventID: 8194) (User: )
Description: Volume Shadow Copy Service error: Unexpected error querying for the IVssWriterCallback interface. hr = 0x80070005, Access is denied.
This is often caused by incorrect security settings in either the writer or requestor process.
Operation:
Gathering Writer Data
Context:
Writer Class Id: {e8132975-6f93-4464-a53e-1050253ae220}
Writer Name: System Writer
Writer Instance ID: {7ce92c7a-cebe-4115-b162-819de867d709}
Error: (09/08/2016 10:10:56 AM) (Source: Microsoft-Windows-EFS) (EventID: 4401) (User: MANISH-MAN592)
Description: 7.488: EFS service failed to provision a user for EDP. Error code: 0x80070005.
Error: (09/07/2016 09:04:33 PM) (Source: Office 2016 Licensing Service) (EventID: 0) (User: )
Description: Event-ID 0
Error: (09/07/2016 06:55:08 PM) (Source: ESENT) (EventID: 489) (User: )
Description: SettingSyncHost (3544) An attempt to open the file "C:\Users\asing\AppData\Local\Microsoft\Windows\SettingSync\metastore\meta.edb" for read only access failed with system error 32 (0x00000020): "The process cannot access the file because it is being used by another process. ". The open file operation will fail with error -1032 (0xfffffbf8).
System errors:
Error: (09/08/2016 04:43:12 PM) (Source: Service Control Manager) (EventID: 7022) (User: )
Description: The McAfee Module Core Service service hung on starting.
Error: (09/08/2016 04:40:17 PM) (Source: Service Control Manager) (EventID: 7022) (User: )
Description: The McAfee Home Network service hung on starting.
Error: (09/08/2016 04:36:44 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}
and APPID
{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}
to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
and APPID
Error: (09/08/2016 04:36:40 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
{8D8F4F83-3594-4F07-8369-FC3C3CAE4919}
and APPID
{F72671A9-012C-4725-9D2F-2A4D32D65169}
to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Error: (09/08/2016 04:14:17 PM) (Source: Service Control Manager) (EventID: 7031) (User: )
Description: The NVIDIA LocalSystem Container service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 1000 milliseconds: Restart the service.
Error: (09/08/2016 04:14:17 PM) (Source: Service Control Manager) (EventID: 7034) (User: )
Description: The ZAM Controller Service service terminated unexpectedly. It has done this 1 time(s).
Error: (09/08/2016 12:39:56 PM) (Source: Service Control Manager) (EventID: 7023) (User: )
Description: The Interactive Services Detection service terminated with the following error:
Incorrect function.
Error: (09/08/2016 12:39:53 PM) (Source: DCOM) (EventID: 10005) (User: NT AUTHORITY)
Description: DCOM got error "1053" attempting to start the service mcpltsvc with arguments "Unavailable" in order to run the server:
{20966775-18A4-4299-B8E3-772C336B52A7}
Error: (09/08/2016 12:39:53 PM) (Source: Service Control Manager) (EventID: 7000) (User: )
Description: The McAfee Platform Services service failed to start due to the following error:
The service did not respond to the start or control request in a timely fashion.
Processor: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
Percentage of memory in use: 12%
Total physical RAM: 32686.84 MB
Available physical RAM: 28448.49 MB
Total Virtual: 34734.84 MB
Available Virtual: 30536.14 MB
Drive c: (OS) (Fixed) (Total:917.5 GB) (Free:713.3 GB) NTFS
Drive i: (MANISHMAN) (Removable) (Total:14.52 GB) (Free:2.36 GB) FAT32
Disk: 0 (Size: 931.5 GB) (Disk ID: 61D5469A)
Partition: GPT.
Disk: 1 (Size: 14.5 GB) (Disk ID: 04030201)
Partition 1: (Not Active) - (Size=14.5 GB) - (Type=0C)
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 31-08-2016
Ran by asing (administrator) on MANISH-MAN592 (08-09-2016 16:41:15)
Platform: Windows 10 Home Version 1607 (X64) Language: English (United States)
Internet Explorer Version 11 (Default browser: FF)
Boot Mode: Normal
Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic/335081-frst-tutorial-how-to-use-farbar-recovery-scan-tool/
(NVIDIA Corporation) C:\Windows\System32\nvvsvc.exe
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvscpapisvr.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe
(Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RtkAudioService64.exe
(Waves Audio Ltd.) C:\Program Files\Waves\MaxxAudio\WavesSysSvc64.exe
(Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RAVBg64.exe
(Intel Corporation) C:\Windows\System32\IPROSetMonitor.exe
(Malwarebytes) C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe
(Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
(IBM Corp.) C:\Program Files (x86)\Trusteer\Rapport\bin\RapportMgmtService.exe
(Intel Corporation) C:\Program Files\Intel\Intel(R) Ready Mode Technology\IRMTService.exe
(Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
() C:\Program Files (x86)\Realtek\Realtek Bluetooth\BTDevMgr.exe
(Malwarebytes) C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe
(McAfee, Inc.) C:\Windows\System32\mfevtps.exe
(Malwarebytes Corporation) C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae-svc.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
(Intel Security, Inc.) C:\Program Files\Common Files\Intel Security\PEF\CORE\PEFService.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\GeForce Experience Service\nvwirelesscontroller.exe
(Microsoft Corporation) C:\Program Files\Common Files\microsoft shared\ClickToRun\OfficeClickToRun.exe
(McAfee, Inc.) C:\Program Files\Common Files\McAfee\SystemCore\mfemms.exe
(Malwarebytes Corporation) C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae64.exe
(Zemana Ltd.) C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe
(McAfee, Inc.) C:\Program Files\Common Files\McAfee\AMCore\mcshield.exe
(McAfee, Inc.) C:\Program Files\Common Files\McAfee\SystemCore\mfefire.exe
(McAfee, Inc.) C:\Program Files\Common Files\McAfee\platform\McSvcHost\McSvHost.exe
(McAfee, Inc.) C:\Program Files\mcafee\msc\McAPExe.exe
(Intel(R) Corporation) C:\Program Files\Intel\NCS2\WMIProv\ncs2prov.exe
(IBM Corp.) C:\Program Files (x86)\Trusteer\Rapport\bin\x64\RapportInjService_x64.exe
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
(Malwarebytes) C:\Program Files (x86)\Malwarebytes Anti-Malware\mbam.exe
(Node.js) C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
(Realtek Semiconductor Corporation) C:\Program Files (x86)\Realtek\Realtek Bluetooth\BTServer.exe
() C:\Program Files (x86)\Realtek\Realtek Bluetooth\SkypePlugin.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
(Microsoft Corporation) C:\Windows\System32\SettingSyncHost.exe
(Microsoft Corporation) C:\Windows\System32\smartscreen.exe
(Malwarebytes Corporation) C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae.exe
(CyberLink) C:\Program Files (x86)\CyberLink\CyberLink Media Suite\Power2Go8\CLMLSvc_P2G8.exe
(McAfee, Inc.) C:\Program Files\Common Files\McAfee\platform\McUICnt.exe
(Mozilla Corporation) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
(CyberLink Corp.) C:\Program Files (x86)\CyberLink\CyberLink Media Suite\Power2Go8\VirtualDrive.exe
(Dell Inc.) C:\Program Files\Dell\DellDataVault\DellDataVaultWiz.exe
(Dell Inc.) C:\Program Files (x86)\Dell Update\DellUpService.exe
(Dell Inc.) C:\Program Files (x86)\Dell Update\DellUpTray.exe
(Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
(Adobe Systems, Inc.) C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_22_0_0_209.exe
(Microsoft Corporation) C:\Program Files\WindowsApps\microsoft.windowscommunicationsapps_17.7167.40727.0_x64__8wekyb3d8bbwe\HxTsr.exe
(Microsoft Corporation) C:\Windows\System32\WWAHost.exe
(Microsoft Corporation) C:\Windows\System32\wbem\WMIADAP.exe
(Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
(McAfee, Inc.) C:\Program Files\Common Files\McAfee\CSP\1.9.829.0\McCSPServiceHost.exe
(McAfee, Inc.) C:\Program Files\Common Files\McAfee\ModuleCore\ModuleCoreService.exe
==================== Registry (Whitelisted) ===========================
HKLM\...\Run: [RTHDVCPL] => C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe [8512760 2016-03-04] (Realtek Semiconductor)
HKLM\...\Run: [RtHDVBg_MAXX6] => C:\Program Files\Realtek\Audio\HDA\RAVBg64.exe [1411320 2016-03-04] (Realtek Semiconductor)
HKLM\...\Run: [WavesSvc] => C:\Program Files\Waves\MaxxAudio\WavesSvc64.exe [611248 2015-04-19] (Waves Audio Ltd.)
HKLM\...\Run: [IAStorIcon] => C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe [322472 2015-06-24] (Intel Corporation)
HKLM\...\Run: [BtServer] => C:\Program Files (x86)\REALTEK\Realtek Bluetooth\BTServer.exe [230104 2015-07-10] (Realtek Semiconductor Corporation)
HKLM\...\Run: [AdobeAAMUpdater-1.0] => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe [446392 2012-04-04] (Adobe Systems Incorporated)
HKLM\...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [176952 2016-06-01] (Apple Inc.)
HKLM\...\Run: [ZAM] => C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [13624048 2016-09-02] (Zemana Ltd.)
HKLM\...\Run: [ShadowPlay] => C:\WINDOWS\system32\nvspcap64.dll [1841088 2016-09-02] (NVIDIA Corporation)
HKLM-x32\...\Run: [SwitchBoard] => C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Adobe Systems Incorporated)
HKLM-x32\...\Run: [AdobeCS5ServiceManager] => C:\Program Files (x86)\Common Files\Adobe\CS5ServiceManager\CS5ServiceManager.exe [406992 2010-02-22] (Adobe Systems Incorporated)
HKLM-x32\...\Run: [AdobeCS6ServiceManager] => C:\Program Files (x86)\Common Files\Adobe\CS6ServiceManager\CS6ServiceManager.exe [1073312 2012-03-09] (Adobe Systems Incorporated)
HKLM-x32\...\Run: [SunJavaUpdateSched] => "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
HKLM-x32\...\Run: [Malwarebytes Anti-Exploit] => C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae.exe [2631120 2016-07-28] (Malwarebytes Corporation)
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\Run: [CCleaner Monitoring] => C:\Program Files\CCleaner\CCleaner64.exe [8894680 2016-08-05] (Piriform Ltd)
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\Run: [IDMan] => C:\Program Files (x86)\Internet Download Manager\IDMan.exe [3919928 2016-04-04] (Tonec Inc.)
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\Run: [Mailbird] => C:\Program Files (x86)\Mailbird\Mailbird.exe [7338640 2016-06-14] (Mailbird)
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\Run: [TunnelBear] => C:\Program Files (x86)\TunnelBear\TBear.Client.exe [2603520 2016-05-11] (TunnelBear)
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\Run: [CCleaner] => C:\Program Files\CCleaner\CCleaner64.exe [8894680 2016-08-05] (Piriform Ltd)
HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\RunOnce: [Uninstall C:\Users\asing\AppData\Local\Microsoft\OneDrive\17.3.6390.0509_1\amd64] => C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\asing\AppData\Local\Microsoft\OneDrive\17.3.6390.0509_1\amd64"
ShellIconOverlayIdentifiers: [ IDM Shell Extension] -> {CDC95B92-E27C-4745-A8C5-64A52A78855D} => C:\Program Files (x86)\Internet Download Manager\IDMShellExt64.dll [2015-08-14] (Tonec Inc.)
Internet Explorer:
SearchScopes: HKU\S-1-5-21-3799958336-243299179-1538509029-1001 -> DefaultScope {012E1000-F331-11DB-8314-0800200C9A66} URL = hxxp://www.google.com/search?q={searchTerms}
SearchScopes: HKU\S-1-5-21-3799958336-243299179-1538509029-1001 -> {012E1000-F331-11DB-8314-0800200C9A66} URL = hxxp://www.google.com/search?q={searchTerms}
BHO: IDM integration (IDMIEHlprObj Class) -> {0055C089-8582-441B-A0BF-17B458C2A3A8} -> C:\Program Files (x86)\Internet Download Manager\IDMIECC64.dll [2015-12-08] (Internet Download Manager, Tonec Inc.)
BHO: Lync Browser Helper -> {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} -> C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\OCHelper.dll [2016-08-24] (Microsoft Corporation)
BHO: Microsoft OneDrive for Business Browser Helper -> {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} -> C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\GROOVEEX.DLL [2016-08-24] (Microsoft Corporation)
BHO-x32: IDM integration (IDMIEHlprObj Class) -> {0055C089-8582-441B-A0BF-17B458C2A3A8} -> C:\Program Files (x86)\Internet Download Manager\IDMIECC.dll [2015-12-08] (Internet Download Manager, Tonec Inc.)
BHO-x32: Java(tm) Plug-In SSV Helper -> {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} -> C:\Program Files (x86)\Java\jre1.8.0_101\bin\ssv.dll [2016-09-03] (Oracle Corporation)
BHO-x32: Java(tm) Plug-In 2 SSV Helper -> {DBC80044-A445-435b-BC74-9C25C1C588A9} -> C:\Program Files (x86)\Java\jre1.8.0_101\bin\jp2ssv.dll [2016-09-03] (Oracle Corporation)
Handler-x32: mso-minsb-roaming.16 - {83C25742-A9F7-49FB-9138-434302C88D07} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2016-08-24] (Microsoft Corporation)
Handler-x32: mso-minsb.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2016-08-24] (Microsoft Corporation)
Handler-x32: osf-roaming.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2016-08-24] (Microsoft Corporation)
Handler-x32: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2016-08-24] (Microsoft Corporation)
Filter: application/x-mfe-ipt - {3EF5086B-5478-4598-A054-786C45D75692} - c:\Program Files\mcafee\msc\McSnIePl64.dll [2016-07-07] (McAfee, Inc.)
Filter-x32: application/x-mfe-ipt - {3EF5086B-5478-4598-A054-786C45D75692} - c:\Program Files (x86)\McAfee\msc\McSnIePl.dll [2016-07-07] (McAfee, Inc.)
FireFox:
FF ProfilePath: C:\Users\asing\AppData\Roaming\Mozilla\Firefox\Profiles\bl985qzq.default-1452382459077
FF Homepage: hxxp://google.co.uk/
FF Plugin: @adobe.com/FlashPlayer -> C:\WINDOWS\system32\Macromed\Flash\NPSWF64_22_0_0_209.dll [2016-07-12] ()
FF Plugin: @mcafee.com/MSC,version=10 -> c:\PROGRA~1\mcafee\msc\NPMCSN~1.DLL [2016-07-07] ()
FF Plugin-x32: @adobe.com/FlashPlayer -> C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_22_0_0_209.dll [2016-07-12] ()
FF Plugin-x32: @Apple.com/iTunes,version=1.0 -> C:\Program Files (x86)\iTunes\Mozilla Plugins\npitunes.dll [2015-12-18] ()
FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI ipt;version=4.0.68 -> C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIIPT.dll [2015-08-24] (Intel Corporation)
FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI updater -> C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIUpdater.dll [2015-08-24] (Intel Corporation)
FF Plugin-x32: @java.com/DTPlugin,version=11.101.2 -> C:\Program Files (x86)\Java\jre1.8.0_101\bin\dtplugin\npDeployJava1.dll [2016-09-03] (Oracle Corporation)
FF Plugin-x32: @java.com/JavaPlugin,version=11.101.2 -> C:\Program Files (x86)\Java\jre1.8.0_101\bin\plugin2\npjp2.dll [2016-09-03] (Oracle Corporation)
FF Plugin-x32: @mcafee.com/MSC,version=10 -> c:\PROGRA~2\mcafee\msc\NPMCSN~1.DLL [2016-07-07] ()
FF Plugin-x32: @microsoft.com/SharePoint,version=14.0 -> C:\Program Files (x86)\Microsoft Office\root\Office16\NPSPWRAP.DLL [2016-08-24] (Microsoft Corporation)
FF Plugin-x32: @nvidia.com/3DVision -> C:\Program Files (x86)\NVIDIA Corporation\3D Vision\npnv3dv.dll [2016-06-03] (NVIDIA Corporation)
FF Plugin-x32: @nvidia.com/3DVisionStreaming -> C:\Program Files (x86)\NVIDIA Corporation\3D Vision\npnv3dvstreaming.dll [2016-06-03] (NVIDIA Corporation)
FF Plugin-x32: @videolan.org/vlc,version=2.2.2 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
FF Plugin-x32: @videolan.org/vlc,version=2.2.4 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
FF Plugin-x32: Adobe Reader -> C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AIR\nppdf32.dll [2016-06-30] (Adobe Systems Inc.)
FF Plugin HKU\S-1-5-21-3799958336-243299179-1538509029-1001: @citrixonline.com/appdetectorplugin -> C:\Users\asing\AppData\Local\Citrix\Plugins\104\npappdetector.dll [2016-05-02] (Citrix Online)
FF Extension: (Adblock Plus Pop-up Addon) - C:\Users\asing\AppData\Roaming\Mozilla\Firefox\Profiles\bl985qzq.default-1452382459077\extensions\adblockpopups@jessehakanen.net.xpi [2016-08-25]
FF Extension: (Grammarly for Firefox) - C:\Users\asing\AppData\Roaming\Mozilla\Firefox\Profiles\bl985qzq.default-1452382459077\Extensions\87677a2c52b84ad3a151a4a72f5bd3c4@jetpack.xpi [2016-08-19]
FF Extension: (United States English Spellchecker) - C:\Users\asing\AppData\Roaming\Mozilla\Firefox\Profiles\bl985qzq.default-1452382459077\Extensions\en-US@dictionaries.addons.mozilla.org [2016-05-01]
FF HKLM-x32\...\Thunderbird\Extensions: [msktbird@mcafee.com] - C:\Program Files\McAfee\MSK
FF Extension: (McAfee Anti-Spam Thunderbird Extension) - C:\Program Files\McAfee\MSK [2016-08-02] [not signed]
FF HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\Firefox\Extensions: [mozilla_cc2@internetdownloadmanager.com] - C:\Program Files (x86)\Internet Download Manager\idmmzcc2.xpi
FF Extension: (IDM integration) - C:\Program Files (x86)\Internet Download Manager\idmmzcc2.xpi [2016-03-10]
FF HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\SeaMonkey\Extensions: [mozilla_cc2@internetdownloadmanager.com] - C:\Program Files (x86)\Internet Download Manager\idmmzcc2.xpi
FF HKU\S-1-5-21-3799958336-243299179-1538509029-1001\...\SeaMonkey\Extensions: [mozilla_cc@internetdownloadmanager.com] - C:\Users\asing\AppData\Roaming\IDM\idmmzcc5
FF Extension: (IDM CC) - C:\Users\asing\AppData\Roaming\IDM\idmmzcc5 [2016-09-07] [not signed]
Chrome:
CHR Profile: C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default
CHR Extension: (Google Slides) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2016-03-06]
CHR Extension: (Google Docs) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfilokake [2016-03-06]
CHR Extension: (Google Drive) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigkjlhalf [2016-03-06]
CHR Extension: (Rapport) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\bbjllphbppobebmjpjcijfbakobcheof [2016-07-06]
CHR Extension: (YouTube) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2016-03-06]
CHR Extension: (Honey) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\bmnlcjabgnpnenekpadlanbbkooimhnj [2016-09-08]
CHR Extension: (Google Sheets) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2016-03-06]
CHR Extension: (Google Docs Offline) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2016-04-14]
CHR Extension: (TubeBuddy) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\mhkhmbddkmdggbhaaaodilponhnccicb [2016-08-09]
CHR Extension: (IDM Integration Module) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\ngpampappnmepgilojfohadhhmbhlaek [2016-07-06]
CHR Extension: (Chrome Web Store Payments) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2016-04-14]
CHR Extension: (Gmail) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2016-03-06]
CHR Extension: (Chrome Media Router) - C:\Users\asing\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm [2016-08-09]
CHR HKLM\...\Chrome\Extension: [fheoggkfdfchfphceeifdbepaooicaho] - C:\Program Files (x86)\McAfee\SiteAdvisor\McChPlg.crx <not found>
CHR HKLM\...\Chrome\Extension: [ngpampappnmepgilojfohadhhmbhlaek] - C:\Program Files (x86)\Internet Download Manager\IDMGCExt.crx [2016-03-11]
CHR HKU\S-1-5-21-3799958336-243299179-1538509029-1001\SOFTWARE\Google\Chrome\Extensions\...\Chrome\Extension: [bbjllphbppobebmjpjcijfbakobcheof] - hxxps://clients2.google.com/service/update2/crx
CHR HKLM-x32\...\Chrome\Extension: [ngpampappnmepgilojfohadhhmbhlaek] - C:\Program Files (x86)\Internet Download Manager\IDMGCExt.crx [2016-03-11]
==================== Services (Whitelisted) ========================
R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2016-03-02] (Apple Inc.)
R2 BTDevManager; C:\Program Files (x86)\REALTEK\Realtek Bluetooth\BTDevMgr.exe [121048 2015-08-27] ()
R2 ClickToRunSvc; C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe [2981056 2016-08-11] (Microsoft Corporation)
S2 DellDataVault; C:\Program Files\Dell\DellDataVault\DellDataVault.exe [2572024 2016-03-11] (Dell Inc.)
R2 DellDataVaultWiz; C:\Program Files\Dell\DellDataVault\DellDataVaultWiz.exe [202488 2016-03-11] (Dell Inc.)
R2 DellUpdate; C:\Program Files (x86)\Dell Update\DellUpService.exe [237272 2015-08-27] (Dell Inc.)
U2 HomeNetSvc; C:\Program Files\Common Files\McAfee\Platform\McSvcHost\McSvHost.exe [596768 2016-07-07] (McAfee, Inc.)
R2 IAStorDataMgrSvc; C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe [18856 2015-06-24] (Intel Corporation)
S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [881152 2015-05-22] (Intel(R) Corporation)
S3 Intel(R) Security Assist; C:\Program Files (x86)\Intel\Intel(R) Security Assist\isa.exe [335872 2015-05-19] (Intel Corporation) [File not signed]
R2 IRMTService; c:\Program Files\Intel\Intel(R) Ready Mode Technology\IRMTService.exe [181520 2015-06-17] (Intel Corporation)
R2 isaHelperSvc; C:\Program Files (x86)\Intel\Intel(R) Security Assist\isaHelperService.exe [7680 2015-05-19] () [File not signed]
R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [207648 2015-09-04] (Intel Corporation)
S3 MailbirdUpdater.exe; C:\Program Files (x86)\Mailbird\MailbirdUpdater.exe [390800 2016-06-14] (Mailbird)
R2 MbaeSvc; C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae-svc.exe [750032 2016-07-28] (Malwarebytes Corporation)
R2 MBAMScheduler; C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe [1514464 2016-03-10] (Malwarebytes)
R2 MBAMService; C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe [1136608 2016-03-10] (Malwarebytes)
R2 McAPExe; C:\Program Files\McAfee\MSC\McAPExe.exe [993824 2016-07-07] (McAfee, Inc.)
S3 McAWFwk; C:\Program Files\Common Files\McAfee\ActWiz\McAWFwk.exe [338208 2015-03-20] (McAfee, Inc.)
R2 McBootDelayStartSvc; C:\Program Files\Common Files\McAfee\Platform\McSvcHost\McSvHost.exe [596768 2016-07-07] (McAfee, Inc.)
R2 mccspsvc; C:\Program Files\Common Files\McAfee\CSP\1.9.829.0\\McCSPServiceHost.exe [1910000 2016-05-31] (McAfee, Inc.)
R2 McMPFSvc; C:\Program Files\Common Files\McAfee\Platform\McSvcHost\McSvHost.exe [596768 2016-07-07] (McAfee, Inc.)
R2 McNaiAnn; C:\Program Files\Common Files\McAfee\platform\McSvcHost\McSvHost.exe [596768 2016-07-07] (McAfee, Inc.)
S3 McODS; C:\Program Files\mcafee\VirusScan\mcods.exe [816128 2016-06-21] (McAfee, Inc.)
S4 McOobeSv2; C:\Program Files\Common Files\McAfee\platform\McSvcHost\McSvHost.exe [596768 2016-07-07] (McAfee, Inc.)
R2 mcpltsvc; C:\Program Files\Common Files\McAfee\platform\McSvcHost\McSvHost.exe [596768 2016-07-07] (McAfee, Inc.)
R2 McProxy; C:\Program Files\Common Files\McAfee\platform\McSvcHost\McSvHost.exe [596768 2016-07-07] (McAfee, Inc.)
R3 mfefire; C:\Program Files\Common Files\McAfee\SystemCore\\mfefire.exe [232688 2016-04-26] (McAfee, Inc.)
R2 mfemms; C:\Program Files\Common Files\McAfee\SystemCore\\mfemms.exe [382456 2016-06-23] (McAfee, Inc.)
R2 mfevtp; C:\Windows\system32\mfevtps.exe [277744 2016-04-26] (McAfee, Inc.)
U2 ModuleCoreService; C:\Program Files\Common Files\McAfee\ModuleCore\ModuleCoreService.exe [1454216 2016-06-17] (McAfee, Inc.)
S3 MSK80Service; C:\Program Files\Common Files\McAfee\Platform\McSvcHost\McSvHost.exe [596768 2016-07-07] (McAfee, Inc.)
R2 NvContainerLocalSystem; C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [457152 2016-09-02] (NVIDIA Corporation)
S3 NvContainerNetworkService; C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [457152 2016-09-02] (NVIDIA Corporation)
R2 NVIDIA Wireless Controller Service; C:\Program Files\NVIDIA Corporation\GeForce Experience Service\nvwirelesscontroller.exe [1163712 2016-09-02] (NVIDIA Corporation)
R2 PEFService; C:\Program Files\Common Files\Intel Security\PEF\CORE\PEFService.exe [1045336 2016-05-25] (Intel Security, Inc.)
R2 RapportMgmtService; C:\Program Files (x86)\Trusteer\Rapport\bin\RapportMgmtService.exe [2383344 2016-07-11] (IBM Corp.)
R2 RichVideo; C:\Program Files (x86)\CyberLink\Shared files\RichVideo.exe [253776 2014-04-15] ()
R2 RtkAudioService; C:\Program Files\Realtek\Audio\HDA\RtkAudioService64.exe [312056 2016-03-04] (Realtek Semiconductor)
S3 SwitchBoard; C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Adobe Systems Incorporated) [File not signed]
R2 TunnelBearMaintenance; C:\Program Files (x86)\TunnelBear\TBear.Maintenance.exe [41472 2016-05-11] ()
R2 WavesSysSvc; C:\Program Files\Waves\MaxxAudio\WavesSysSvc64.exe [563456 2015-01-20] (Waves Audio Ltd.)
S3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [347328 2016-07-16] (Microsoft Corporation)
S3 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [103720 2016-07-16] (Microsoft Corporation)
R2 ZAMSvc; C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [13624048 2016-09-02] (Zemana Ltd.)
===================== Drivers (Whitelisted) ==========================
R3 BthAudioHF; C:\Windows\system32\drivers\RtkHfp.sys [104688 2015-09-09] (Realtek Semiconductor Corporation)
R3 cfwids; C:\Windows\System32\drivers\cfwids.sys [78632 2016-04-27] (McAfee, Inc.)
R1 CLVirtualDrive; C:\Windows\system32\DRIVERS\CLVirtualDrive.sys [91912 2013-11-12] (CyberLink)
S3 CMUSBDAC; C:\Windows\system32\DRIVERS\CMUSBDAC.sys [3778592 2016-02-24] (C-MEDIA)
R3 DDDriver; C:\Windows\system32\drivers\DDDriver64Dcsa.sys [32464 2015-09-11] (Dell Computer Corporation)
R3 DellProf; C:\Windows\system32\drivers\DellProf.sys [24240 2015-09-11] (Dell Computer Corporation)
R3 e1dexpress; C:\Windows\system32\DRIVERS\e1d65x64.sys [547840 2016-01-09] (Intel Corporation)
R1 ESProtectionDriver; C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae64.sys [75360 2016-08-04] ()
S3 HipShieldK; C:\Windows\System32\drivers\HipShieldK.sys [207968 2016-02-24] (McAfee, Inc.)
R3 IntelReadyModeDriver; C:\Windows\System32\drivers\IntelReadyModeDriver.sys [33512 2015-06-17] (Intel Corporation)
R3 MBAMProtector; C:\WINDOWS\system32\drivers\mbam.sys [27008 2016-03-10] (Malwarebytes)
R3 MBAMSwissArmy; C:\WINDOWS\system32\drivers\MBAMSwissArmy.sys [192216 2016-09-08] (Malwarebytes)
R3 MBAMWebAccessControl; C:\WINDOWS\system32\drivers\mwac.sys [65408 2016-03-10] (Malwarebytes Corporation)
R2 mfeaack; C:\Windows\System32\drivers\mfeaack.sys [419616 2016-04-27] (McAfee, Inc.)
R3 mfeavfk; C:\Windows\System32\drivers\mfeavfk.sys [349480 2016-04-27] (McAfee, Inc.)
S0 mfeelamk; C:\Windows\System32\drivers\mfeelamk.sys [83608 2016-04-27] (McAfee, Inc.)
R3 mfefirek; C:\Windows\System32\drivers\mfefirek.sys [493352 2016-04-27] (McAfee, Inc.)
R0 mfehidk; C:\Windows\System32\drivers\mfehidk.sys [843048 2016-04-27] (McAfee, Inc.)
R3 mfencbdc; C:\Windows\System32\DRIVERS\mfencbdc.sys [519976 2016-04-27] (McAfee, Inc.)
S3 mfencrk; C:\Windows\System32\DRIVERS\mfencrk.sys [100136 2016-04-27] (McAfee, Inc.)
R0 mfewfpk; C:\Windows\System32\drivers\mfewfpk.sys [243488 2016-04-27] (McAfee, Inc.)
S3 NetAdapterCx; C:\Windows\System32\drivers\NetAdapterCx.sys [90624 2016-07-16] ()
R3 nvvad_WaveExtensible; C:\Windows\system32\drivers\nvvad64v.sys [46016 2016-09-02] (NVIDIA Corporation)
S1 RapportCerberus_1609042; C:\ProgramData\Trusteer\Rapport\store\exts\RapportCerberus\baseline\RapportCerberus64_1609042.sys [1157960 2016-08-02] (IBM Corp.)
S1 RapportEI64; C:\Program Files (x86)\Trusteer\Rapport\bin\x64\RapportEI64.sys [544360 2016-07-11] (IBM Corp.)
S0 RapportHades64; C:\Windows\System32\Drivers\RapportHades64.sys [215560 2016-07-11] (IBM Corp.)
S0 RapportKE64; C:\Windows\System32\Drivers\RapportKE64.sys [470056 2016-07-11] (IBM Corp.)
S1 RapportPG64; C:\Program Files (x86)\Trusteer\Rapport\bin\x64\RapportPG64.sys [525992 2016-07-11] (IBM Corp.)
R3 RtkBtFilter; C:\Windows\system32\DRIVERS\RtkBtfilter.sys [615728 2016-03-04] (Realtek Semiconductor Corporation)
R3 RTWlanE; C:\Windows\System32\drivers\rtwlane.sys [5144064 2016-07-16] (Realtek Semiconductor Corporation )
R3 tap-tb-0901; C:\Windows\System32\drivers\tap-tb-0901.sys [38656 2015-08-10] (The OpenVPN Project)
U3 TrueSight; C:\Windows\System32\drivers\TrueSight.sys [28272 2016-09-07] ()
S3 WdBoot; C:\Windows\system32\drivers\WdBoot.sys [44056 2016-07-16] (Microsoft Corporation)
S3 WdFilter; C:\Windows\system32\drivers\WdFilter.sys [290144 2016-07-16] (Microsoft Corporation)
S3 WdNisDrv; C:\Windows\System32\Drivers\WdNisDrv.sys [123232 2016-07-16] (Microsoft Corporation)
R1 ZAM; C:\WINDOWS\System32\drivers\zam64.sys [203680 2016-09-07] (Zemana Ltd.)
R1 ZAM_Guard; C:\WINDOWS\System32\drivers\zamguard64.sys [203680 2016-09-07] (Zemana Ltd.)
2016-09-08 16:39 - 2016-09-08 16:39 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\McAfee
2016-09-08 16:32 - 2016-09-08 16:34 - 00001453 _____ C:\Users\asing\Desktop\ZHPCleaner.txt
2016-09-08 16:28 - 2016-09-08 16:34 - 00000000 ____D C:\Users\asing\AppData\Roaming\ZHP
2016-09-08 16:28 - 2016-09-08 16:28 - 00000877 _____ C:\Users\asing\Desktop\ZHPCleaner.lnk
2016-09-08 16:27 - 2016-09-08 16:28 - 02370048 _____ C:\Users\asing\Desktop\ZHPCleaner.exe
2016-09-08 16:21 - 2016-09-08 16:21 - 00290304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\subinacl.exe
2016-09-08 16:21 - 2016-09-08 16:21 - 00000000 ____D C:\Program Files (x86)\Adware Removal Tool by TSA
2016-09-08 16:20 - 2016-09-08 16:20 - 00752296 _____ C:\Users\asing\Desktop\Adware Removal Tool by TSA.exe
2016-09-08 16:15 - 2016-09-08 16:15 - 00000801 _____ C:\Users\asing\Desktop\JRT.txt
2016-09-08 16:12 - 2016-09-08 16:13 - 01610560 _____ (Malwarebytes) C:\Users\asing\Desktop\JRT.exe
2016-09-08 11:04 - 2016-09-08 11:04 - 00001487 _____ C:\Users\Public\Desktop\GeForce Experience.lnk
2016-09-08 11:03 - 2016-09-08 11:03 - 00003998 _____ C:\WINDOWS\System32\Tasks\NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
2016-09-08 11:03 - 2016-09-08 11:03 - 00003970 _____ C:\WINDOWS\System32\Tasks\NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
2016-09-08 11:03 - 2016-09-08 11:03 - 00003934 _____ C:\WINDOWS\System32\Tasks\NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
2016-09-08 11:03 - 2016-09-08 11:03 - 00003908 _____ C:\WINDOWS\System32\Tasks\NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
2016-09-08 11:03 - 2016-09-08 11:03 - 00003704 _____ C:\WINDOWS\System32\Tasks\NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
2016-09-08 11:03 - 2016-09-08 11:03 - 00000000 ____D C:\WINDOWS\LastGood.Tmp
2016-09-08 11:03 - 2016-09-02 12:17 - 01841088 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvspcap64.dll
2016-09-08 11:03 - 2016-09-02 12:17 - 01755072 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvspbridge64.dll
2016-09-08 11:03 - 2016-09-02 12:17 - 01448384 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvspcap.dll
2016-09-08 11:03 - 2016-09-02 12:17 - 01317312 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvspbridge.dll
2016-09-08 11:03 - 2016-09-02 12:17 - 00120256 _____ C:\WINDOWS\system32\NvRtmpStreamer64.dll
2016-09-08 11:03 - 2016-09-02 12:17 - 00104384 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvaudcap64v.dll
2016-09-08 11:03 - 2016-09-02 12:17 - 00094144 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvaudcap32v.dll
2016-09-08 11:03 - 2016-09-02 12:17 - 00046016 _____ (NVIDIA Corporation) C:\WINDOWS\system32\Drivers\nvvad64v.sys
2016-09-08 11:03 - 2016-09-02 12:03 - 00001951 _____ C:\WINDOWS\NvContainerRecovery.bat
2016-09-08 10:47 - 2016-09-08 10:48 - 00012798 _____ C:\Users\asing\Desktop\Fixlog.txt
2016-09-07 15:09 - 2016-09-07 15:09 - 00000000 ____D C:\Users\asing\Downloads\shoguns-clan
2016-09-07 14:25 - 2016-09-07 14:25 - 00000000 ____D C:\Users\asing\AppData\Local\NetworkTiles
2016-09-07 11:51 - 2016-09-07 11:52 - 00000000 ____D C:\Users\asing\Downloads\dUninstaller
2016-09-07 11:30 - 2016-09-07 11:56 - 00000000 ____D C:\Users\asing\AppData\Roaming\Geek Uninstaller
2016-09-07 11:30 - 2016-09-07 11:30 - 00000000 ____D C:\Users\asing\Downloads\geek
2016-09-07 11:05 - 2016-09-07 11:05 - 00000000 ____D C:\Users\asing\AppData\Local\CrashDumps
2016-09-07 11:04 - 2016-09-07 11:04 - 08228024 _____ (Piriform Ltd) C:\Users\asing\Downloads\ccsetup521pro.exe
2016-09-07 11:04 - 2016-09-07 11:04 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner
2016-09-07 10:33 - 2016-09-07 10:33 - 00028272 _____ C:\WINDOWS\system32\Drivers\TrueSight.sys
2016-09-07 10:31 - 2016-09-07 10:31 - 00000901 _____ C:\Users\Public\Desktop\RogueKiller.lnk
2016-09-07 10:31 - 2016-09-07 10:31 - 00000000 ____D C:\ProgramData\RogueKiller
2016-09-07 10:31 - 2016-09-07 10:31 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RogueKiller
2016-09-07 10:31 - 2016-09-07 10:31 - 00000000 ____D C:\Program Files\RogueKiller
2016-09-07 10:30 - 2016-09-07 10:31 - 33106704 _____ (Adlice Software ) C:\Users\asing\Downloads\setup.exe
2016-09-07 09:49 - 2016-09-08 16:42 - 00026286 _____ C:\WINDOWS\ZAM_Guard.krnl.trace
2016-09-07 09:49 - 2016-09-08 16:41 - 00066430 _____ C:\WINDOWS\ZAM.krnl.trace
2016-09-07 09:49 - 2016-09-07 09:49 - 00203680 _____ (Zemana Ltd.) C:\WINDOWS\system32\Drivers\zamguard64.sys
2016-09-07 09:49 - 2016-09-07 09:49 - 00203680 _____ (Zemana Ltd.) C:\WINDOWS\system32\Drivers\zam64.sys
2016-09-07 09:49 - 2016-09-07 09:49 - 00001219 _____ C:\Users\Public\Desktop\Zemana AntiMalware.lnk
2016-09-07 09:49 - 2016-09-07 09:49 - 00000000 ____D C:\Users\asing\AppData\Local\Zemana
2016-09-07 09:49 - 2016-09-07 09:49 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zemana AntiMalware
2016-09-07 09:49 - 2016-09-07 09:49 - 00000000 ____D C:\Program Files (x86)\Zemana AntiMalware
2016-09-07 09:48 - 2016-09-07 09:49 - 05292304 _____ ( ) C:\Users\asing\Downloads\Zemana.AntiMalware.Setup.exe
2016-09-07 09:42 - 2016-09-07 09:27 - 00024064 _____ C:\WINDOWS\zoek-delete.exe
2016-09-07 09:06 - 2016-09-07 09:06 - 00000000 ____D C:\ProgramData\IDM
2016-09-07 01:32 - 2016-09-07 01:44 - 00000000 ____D C:\zoek_backup
2016-09-07 01:27 - 2016-09-07 01:32 - 01309184 _____ C:\Users\asing\Desktop\zoek.exe
2016-09-07 01:20 - 2016-09-07 01:20 - 00001743 _____ C:\Users\asing\Desktop\aswMBR.txt
2016-09-07 01:20 - 2016-09-07 01:20 - 00000512 _____ C:\Users\asing\Desktop\MBR.dat
2016-09-07 01:12 - 2016-09-07 11:05 - 00000000 ____D C:\WINDOWS\Minidump
2016-09-07 00:41 - 2016-09-07 00:41 - 05200384 _____ (AVAST Software) C:\Users\asing\Desktop\aswmbr.exe
2016-09-06 23:33 - 2016-09-06 23:33 - 00388608 _____ (Trend Micro Inc.) C:\Users\asing\Desktop\HijackThis.exe
2016-09-06 22:47 - 2016-09-06 22:48 - 00041923 _____ C:\Users\asing\Desktop\Addition.txt
2016-09-06 22:45 - 2016-09-08 16:41 - 00028436 _____ C:\Users\asing\Desktop\FRST.txt
2016-09-06 22:44 - 2016-09-08 16:41 - 00000000 ____D C:\FRST
2016-09-06 22:44 - 2016-09-06 22:44 - 02397696 _____ (Farbar) C:\Users\asing\Desktop\FRST64.exe
2016-09-06 11:55 - 2016-09-06 11:55 - 00001090 _____ C:\Users\Public\Desktop\nexusfont.lnk
2016-09-06 11:55 - 2016-09-06 11:55 - 00000000 ____D C:\Users\asing\AppData\Roaming\NexusFont
2016-09-06 11:55 - 2016-09-06 11:55 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\nexusfont
2016-09-06 11:55 - 2016-09-06 11:55 - 00000000 ____D C:\Program Files (x86)\nexusfont
2016-09-06 11:54 - 2016-09-06 11:54 - 02392038 _____ (xiles ) C:\Users\asing\Downloads\nexusfont_setup_2.6.2.exe
2016-09-06 11:42 - 2016-09-06 11:42 - 00000000 ____D C:\Users\asing\Downloads\nexusfont_2.6.2
2016-09-05 23:04 - 2016-09-08 10:51 - 00000000 ____D C:\ProgramData\Malwarebytes Anti-Exploit
2016-09-05 23:04 - 2016-09-05 23:04 - 01875208 _____ (Malwarebytes ) C:\Users\asing\Downloads\mbae_premium.exe
2016-09-05 23:04 - 2016-09-05 23:04 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes Anti-Exploit
2016-09-05 23:04 - 2016-09-05 23:04 - 00000000 ____D C:\Program Files (x86)\Malwarebytes Anti-Exploit
2016-09-05 22:58 - 2016-09-05 22:59 - 22851472 _____ (Malwarebytes ) C:\Users\asing\Downloads\mbam-setup-web.NT-2.2.1.1043.exe
2016-09-03 22:18 - 2016-09-03 22:18 - 00739904 _____ (Oracle Corporation) C:\Users\asing\Downloads\JavaSetup8u101.exe
2016-08-31 23:04 - 2016-08-27 13:45 - 00268800 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfksproxy.dll
2016-08-31 23:04 - 2016-08-27 10:37 - 00184832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfksproxy.dll
2016-08-31 23:04 - 2016-08-27 06:12 - 04130944 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfcore.dll
2016-08-31 23:04 - 2016-08-27 06:12 - 00244816 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfps.dll
2016-08-31 23:04 - 2016-08-27 05:58 - 03893376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfcore.dll
2016-08-31 23:04 - 2016-08-27 05:58 - 00121368 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfps.dll
2016-08-31 23:04 - 2016-08-27 05:44 - 00027136 _____ (Microsoft Corporation) C:\WINDOWS\system32\encapi.dll
2016-08-31 23:04 - 2016-08-27 05:43 - 00022528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\encapi.dll
2016-08-31 23:04 - 2016-08-27 05:39 - 00314880 _____ (Microsoft Corporation) C:\WINDOWS\system32\FSClient.dll
2016-08-31 23:04 - 2016-08-27 05:38 - 00294912 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsensorgroup.dll
2016-08-31 23:04 - 2016-08-27 05:38 - 00181760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsensorgroup.dll
2016-08-31 23:04 - 2016-08-27 05:37 - 00198144 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\FSClient.dll
2016-08-31 23:04 - 2016-08-27 05:25 - 00804864 _____ (Microsoft Corporation) C:\WINDOWS\system32\FrameServer.dll
2016-08-31 23:04 - 2016-08-20 07:26 - 00484584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioSes.dll
2016-08-31 23:04 - 2016-08-20 07:13 - 00590952 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioSes.dll
2016-08-31 23:04 - 2016-08-20 07:06 - 01046976 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.efi
2016-08-31 23:04 - 2016-08-20 07:06 - 00885832 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.exe
2016-08-31 23:04 - 2016-08-20 07:06 - 00108384 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\pdc.sys
2016-08-31 23:04 - 2016-08-20 07:05 - 01377008 _____ (Microsoft Corporation) C:\WINDOWS\system32\ClipUp.exe
2016-08-31 23:04 - 2016-08-20 07:04 - 07814488 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
2016-08-31 23:04 - 2016-08-20 07:04 - 01349120 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.efi
2016-08-31 23:04 - 2016-08-20 07:04 - 01163696 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.exe
2016-08-31 23:04 - 2016-08-20 07:03 - 02257248 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ntfs.sys
2016-08-31 23:04 - 2016-08-20 07:03 - 01883784 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntdll.dll
2016-08-31 23:04 - 2016-08-20 06:52 - 07219672 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
2016-08-31 23:04 - 2016-08-20 06:52 - 02190688 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
2016-08-31 23:04 - 2016-08-20 06:52 - 01859264 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.ApplicationModel.Store.dll
2016-08-31 23:04 - 2016-08-20 06:52 - 01279328 _____ (Microsoft Corporation) C:\WINDOWS\system32\LicenseManager.dll
2016-08-31 23:04 - 2016-08-20 06:52 - 00857440 _____ (Microsoft Corporation) C:\WINDOWS\system32\WWAHost.exe
2016-08-31 23:04 - 2016-08-20 06:52 - 00658776 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
2016-08-31 23:04 - 2016-08-20 06:52 - 00402272 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms1.sys
2016-08-31 23:04 - 2016-08-20 06:52 - 00178528 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudExperienceHostUser.dll
2016-08-31 23:04 - 2016-08-20 06:51 - 00681312 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ClipSp.sys
2016-08-31 23:04 - 2016-08-20 06:50 - 02913104 _____ (Microsoft Corporation) C:\WINDOWS\system32\combase.dll
2016-08-31 23:04 - 2016-08-20 06:50 - 01267512 _____ (Microsoft Corporation) C:\WINDOWS\system32\WinTypes.dll
2016-08-31 23:04 - 2016-08-20 06:50 - 01099608 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvix64.exe
2016-08-31 23:04 - 2016-08-20 06:50 - 00987992 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvax64.exe
2016-08-31 23:04 - 2016-08-20 06:50 - 00942424 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.efi
2016-08-31 23:04 - 2016-08-20 06:50 - 00807776 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.exe
2016-08-31 23:04 - 2016-08-20 06:50 - 00073568 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hvservice.sys
2016-08-31 23:04 - 2016-08-20 06:50 - 00026408 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuauclt.exe
2016-08-31 23:04 - 2016-08-20 06:50 - 00020320 _____ (Microsoft Corporation) C:\WINDOWS\system32\kdhvcom.dll
2016-08-31 23:04 - 2016-08-20 06:47 - 22218808 _____ (Microsoft Corporation) C:\WINDOWS\system32\shell32.dll
2016-08-31 23:04 - 2016-08-20 06:47 - 01453992 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfnetsrc.dll
2016-08-31 23:04 - 2016-08-20 06:47 - 01071728 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfnetcore.dll
2016-08-31 23:04 - 2016-08-20 06:46 - 01570680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntdll.dll
2016-08-31 23:04 - 2016-08-20 06:43 - 01418312 _____ (Microsoft Corporation) C:\WINDOWS\system32\msctf.dll
2016-08-31 23:04 - 2016-08-20 06:42 - 02537824 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tcpip.sys
2016-08-31 23:04 - 2016-08-20 06:34 - 01430200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Store.dll
2016-08-31 23:04 - 2016-08-20 06:34 - 00782176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WWAHost.exe
2016-08-31 23:04 - 2016-08-20 06:34 - 00136032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CloudExperienceHostUser.dll
2016-08-31 23:04 - 2016-08-20 06:33 - 05722312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
2016-08-31 23:04 - 2016-08-20 06:33 - 00852824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LicenseManager.dll
2016-08-31 23:04 - 2016-08-20 06:32 - 02166232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\combase.dll
2016-08-31 23:04 - 2016-08-20 06:32 - 00846552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WinTypes.dll
2016-08-31 23:04 - 2016-08-20 06:29 - 20965240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shell32.dll
2016-08-31 23:04 - 2016-08-20 06:29 - 01360464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfnetsrc.dll
2016-08-31 23:04 - 2016-08-20 06:29 - 00980832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfnetcore.dll
2016-08-31 23:04 - 2016-08-20 06:25 - 01264912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msctf.dll
2016-08-31 23:04 - 2016-08-20 06:22 - 22571008 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
2016-08-31 23:04 - 2016-08-20 06:22 - 00028672 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Management.Provisioning.ProxyStub.dll
2016-08-31 23:04 - 2016-08-20 06:21 - 02755584 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.tlb
2016-08-31 23:04 - 2016-08-20 06:21 - 00568832 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Speech.UXRes.dll
2016-08-31 23:04 - 2016-08-20 06:21 - 00227840 _____ (Microsoft Corporation) C:\WINDOWS\system32\C_G18030.DLL
2016-08-31 23:04 - 2016-08-20 06:21 - 00140288 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakrathunk.dll
2016-08-31 23:04 - 2016-08-20 06:21 - 00061952 _____ (Microsoft Corporation) C:\WINDOWS\system32\RemovableMediaProvisioningPlugin.dll
2016-08-31 23:04 - 2016-08-20 06:21 - 00032768 _____ (Microsoft Corporation) C:\WINDOWS\system32\wups2.dll
2016-08-31 23:04 - 2016-08-20 06:21 - 00014848 _____ (Microsoft Corporation) C:\WINDOWS\system32\c_GSM7.DLL
2016-08-31 23:04 - 2016-08-20 06:20 - 00119808 _____ (Microsoft Corporation) C:\WINDOWS\system32\KnobsCsp.dll
2016-08-31 23:04 - 2016-08-20 06:20 - 00085504 _____ (Microsoft Corporation) C:\WINDOWS\system32\BarcodeProvisioningPlugin.dll
2016-08-31 23:04 - 2016-08-20 06:20 - 00076800 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwanprotdim.dll
2016-08-31 23:04 - 2016-08-20 06:20 - 00043520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\xinputhid.sys
2016-08-31 23:04 - 2016-08-20 06:20 - 00017408 _____ (Microsoft Corporation) C:\WINDOWS\system32\C_IS2022.DLL
2016-08-31 23:04 - 2016-08-20 06:19 - 00097792 _____ (Microsoft Corporation) C:\WINDOWS\system32\NFCProvisioningPlugin.dll
2016-08-31 23:04 - 2016-08-20 06:19 - 00083968 _____ (Microsoft Corporation) C:\WINDOWS\system32\ProvPluginEng.dll
2016-08-31 23:04 - 2016-08-20 06:18 - 00200704 _____ (Microsoft Corporation) C:\WINDOWS\system32\provisioningcsp.dll
2016-08-31 23:04 - 2016-08-20 06:18 - 00186880 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusNotification.exe
2016-08-31 23:04 - 2016-08-20 06:18 - 00114176 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthenum.sys
2016-08-31 23:04 - 2016-08-20 06:18 - 00066048 _____ (Microsoft Corporation) C:\WINDOWS\system32\provtool.exe
2016-08-31 23:04 - 2016-08-20 06:17 - 00247296 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\BthLEEnum.sys
2016-08-31 23:04 - 2016-08-20 06:17 - 00235008 _____ (Microsoft Corporation) C:\WINDOWS\system32\KnobsCore.dll
2016-08-31 23:04 - 2016-08-20 06:17 - 00227840 _____ (Microsoft Corporation) C:\WINDOWS\system32\cdd.dll
2016-08-31 23:04 - 2016-08-20 06:17 - 00026112 _____ (Microsoft Corporation) C:\WINDOWS\system32\LicenseManagerSvc.dll
2016-08-31 23:04 - 2016-08-20 06:16 - 02755584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.tlb
2016-08-31 23:04 - 2016-08-20 06:16 - 00380928 _____ (Microsoft Corporation) C:\WINDOWS\system32\wincorlib.dll
2016-08-31 23:04 - 2016-08-20 06:16 - 00200704 _____ (Microsoft Corporation) C:\WINDOWS\system32\ClipboardServer.dll
2016-08-31 23:04 - 2016-08-20 06:15 - 00349184 _____ (Microsoft Corporation) C:\WINDOWS\system32\provengine.dll
2016-08-31 23:04 - 2016-08-20 06:15 - 00295424 _____ (Microsoft Corporation) C:\WINDOWS\system32\provhandlers.dll
2016-08-31 23:04 - 2016-08-20 06:15 - 00231424 _____ (Microsoft Corporation) C:\WINDOWS\system32\shutdownux.dll
2016-08-31 23:04 - 2016-08-20 06:15 - 00211456 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallAgent.exe
2016-08-31 23:04 - 2016-08-20 06:15 - 00084992 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\BTHUSB.SYS
2016-08-31 23:04 - 2016-08-20 06:14 - 00225280 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\C_G18030.DLL
2016-08-31 23:04 - 2016-08-20 06:14 - 00220672 _____ (Microsoft Corporation) C:\WINDOWS\system32\provops.dll
2016-08-31 23:04 - 2016-08-20 06:14 - 00121344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakrathunk.dll
2016-08-31 23:04 - 2016-08-20 06:14 - 00086016 _____ (Microsoft Corporation) C:\WINDOWS\system32\provdatastore.dll
2016-08-31 23:04 - 2016-08-20 06:14 - 00058880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ConfigureExpandedStorage.dll
2016-08-31 23:04 - 2016-08-20 06:14 - 00014336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\C_IS2022.DLL
2016-08-31 23:04 - 2016-08-20 06:14 - 00012800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\c_GSM7.DLL
2016-08-31 23:04 - 2016-08-20 06:13 - 01081856 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
2016-08-31 23:04 - 2016-08-20 06:13 - 00743424 _____ (Microsoft Corporation) C:\WINDOWS\system32\StoreAgent.dll
2016-08-31 23:04 - 2016-08-20 06:13 - 00568832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Speech.UXRes.dll
2016-08-31 23:04 - 2016-08-20 06:13 - 00259584 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallAgentUserBroker.exe
2016-08-31 23:04 - 2016-08-20 06:12 - 01014784 _____ (Microsoft Corporation) C:\WINDOWS\system32\XblAuthManager.dll
2016-08-31 23:04 - 2016-08-20 06:12 - 00605184 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcastdvr.exe
2016-08-31 23:04 - 2016-08-20 06:12 - 00521728 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusUpdateHandlers.dll
2016-08-31 23:04 - 2016-08-20 06:12 - 00476672 _____ (Microsoft Corporation) C:\WINDOWS\system32\schannel.dll
2016-08-31 23:04 - 2016-08-20 06:12 - 00453120 _____ (Microsoft Corporation) C:\WINDOWS\system32\CredProvDataModel.dll
2016-08-31 23:04 - 2016-08-20 06:12 - 00261120 _____ (Microsoft Corporation) C:\WINDOWS\system32\indexeddbserver.dll
2016-08-31 23:04 - 2016-08-20 06:12 - 00215040 _____ (Microsoft Corporation) C:\WINDOWS\system32\fveapibase.dll
2016-08-31 23:04 - 2016-08-20 06:11 - 00965120 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthport.sys
2016-08-31 23:04 - 2016-08-20 06:11 - 00410624 _____ (Microsoft Corporation) C:\WINDOWS\system32\facecredentialprovider.dll
2016-08-31 23:04 - 2016-08-20 06:11 - 00320000 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.ApplicationModel.Store.TestingFramework.dll
2016-08-31 23:04 - 2016-08-20 06:11 - 00156672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BcastDVRHelper.dll
2016-08-31 23:04 - 2016-08-20 06:11 - 00089600 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatepolicy.dll
2016-08-31 23:04 - 2016-08-20 06:10 - 00956416 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.desktop.dll
2016-08-31 23:04 - 2016-08-20 06:10 - 00775168 _____ (Microsoft Corporation) C:\WINDOWS\system32\GamePanel.exe
2016-08-31 23:04 - 2016-08-20 06:10 - 00539136 _____ (Microsoft Corporation) C:\WINDOWS\system32\usocore.dll
2016-08-31 23:04 - 2016-08-20 06:09 - 09128448 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.dll
2016-08-31 23:04 - 2016-08-20 06:09 - 06285312 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.dll
2016-08-31 23:04 - 2016-08-20 06:09 - 00642048 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.InkControls.dll
2016-08-31 23:04 - 2016-08-20 06:09 - 00491520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcastdvr.exe
2016-08-31 23:04 - 2016-08-20 06:08 - 01906176 _____ (Microsoft Corporation) C:\WINDOWS\system32\wsp_fs.dll
2016-08-31 23:04 - 2016-08-20 06:08 - 01547264 _____ (Microsoft Corporation) C:\WINDOWS\system32\wsp_health.dll
2016-08-31 23:04 - 2016-08-20 06:08 - 00471552 _____ (Microsoft Corporation) C:\WINDOWS\system32\DscCore.dll
2016-08-31 23:04 - 2016-08-20 06:08 - 00204288 _____ (Windows (R) Win 7 DDK provider) C:\WINDOWS\system32\DscCoreConfProv.dll
2016-08-31 23:04 - 2016-08-20 06:08 - 00179712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallAgent.exe
2016-08-31 23:04 - 2016-08-20 06:08 - 00171520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ClipboardServer.dll
2016-08-31 23:04 - 2016-08-20 06:07 - 01403392 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Editing.dll
2016-08-31 23:04 - 2016-08-20 06:07 - 00822784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakradiag.dll
2016-08-31 23:04 - 2016-08-20 06:07 - 00554496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\StoreAgent.dll
2016-08-31 23:04 - 2016-08-20 06:07 - 00288768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wincorlib.dll
2016-08-31 23:04 - 2016-08-20 06:07 - 00203776 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXApplicabilityBlob.dll
2016-08-31 23:04 - 2016-08-20 06:07 - 00104960 _____ (Microsoft Corporation) C:\WINDOWS\system32\CastLaunch.dll
2016-08-31 23:04 - 2016-08-20 06:07 - 00023552 _____ (Microsoft Corporation) C:\WINDOWS\system32\smphost.dll
2016-08-31 23:04 - 2016-08-20 06:06 - 00389632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\schannel.dll
2016-08-31 23:04 - 2016-08-20 06:06 - 00222720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallAgentUserBroker.exe
2016-08-31 23:04 - 2016-08-20 06:06 - 00025600 _____ (Microsoft Corporation) C:\WINDOWS\system32\storagewmi_passthru.dll
2016-08-31 23:04 - 2016-08-20 06:05 - 00715264 _____ (Microsoft Corporation) C:\WINDOWS\system32\clusapi.dll
2016-08-31 23:04 - 2016-08-20 06:05 - 00380928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CredProvDataModel.dll
2016-08-31 23:04 - 2016-08-20 06:04 - 23682560 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
2016-08-31 23:04 - 2016-08-20 06:04 - 03245056 _____ (Microsoft Corporation) C:\WINDOWS\system32\mispace.dll
2016-08-31 23:04 - 2016-08-20 06:04 - 00592384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GamePanel.exe
2016-08-31 23:04 - 2016-08-20 06:04 - 00253952 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Store.TestingFramework.dll
2016-08-31 23:04 - 2016-08-20 06:04 - 00198656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\indexeddbserver.dll
2016-08-31 23:04 - 2016-08-20 06:04 - 00074240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\updatepolicy.dll
2016-08-31 23:04 - 2016-08-20 06:04 - 00026112 _____ (Microsoft Corporation) C:\WINDOWS\system32\delegatorprovider.dll
2016-08-31 23:04 - 2016-08-20 06:03 - 05398016 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aclui.dll
2016-08-31 23:04 - 2016-08-20 06:03 - 04749312 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_nt.dll
2016-08-31 23:04 - 2016-08-20 06:03 - 02846208 _____ (Microsoft Corporation) C:\WINDOWS\system32\storagewmi.dll
2016-08-31 23:04 - 2016-08-20 06:03 - 00944640 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiosrv.dll
2016-08-31 23:04 - 2016-08-20 06:02 - 01217024 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Audio.dll
2016-08-31 23:04 - 2016-08-20 06:01 - 04612096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.dll
2016-08-31 23:04 - 2016-08-20 06:01 - 00936960 _____ (Microsoft Corporation) C:\WINDOWS\system32\MCRecvSrc.dll
2016-08-31 23:04 - 2016-08-20 06:01 - 00468992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.InkControls.dll
2016-08-31 23:04 - 2016-08-20 06:00 - 19423232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
2016-08-31 23:04 - 2016-08-20 06:00 - 08124416 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
2016-08-31 23:04 - 2016-08-20 06:00 - 01316352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wsp_fs.dll
2016-08-31 23:04 - 2016-08-20 06:00 - 00141824 _____ (Windows (R) Win 7 DDK provider) C:\WINDOWS\SysWOW64\DscCoreConfProv.dll
2016-08-31 23:04 - 2016-08-20 05:59 - 07624192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.dll
2016-08-31 23:04 - 2016-08-20 05:59 - 05511680 _____ (Microsoft Corporation) C:\WINDOWS\system32\aclui.dll
2016-08-31 23:04 - 2016-08-20 05:59 - 02510848 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkMobileSettings.dll
2016-08-31 23:04 - 2016-08-20 05:59 - 01690112 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.onecore.dll
2016-08-31 23:04 - 2016-08-20 05:59 - 01106944 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wsp_health.dll
2016-08-31 23:04 - 2016-08-20 05:59 - 01077760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Editing.dll
2016-08-31 23:04 - 2016-08-20 05:59 - 00020992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\smphost.dll
2016-08-31 23:04 - 2016-08-20 05:58 - 01643008 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Speech.dll
2016-08-31 23:04 - 2016-08-20 05:58 - 00020480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\storagewmi_passthru.dll
2016-08-31 23:04 - 2016-08-20 05:57 - 02680832 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Logon.dll
2016-08-31 23:04 - 2016-08-20 05:57 - 02264064 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
2016-08-31 23:04 - 2016-08-20 05:57 - 01282048 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwansvc.dll
2016-08-31 23:04 - 2016-08-20 05:57 - 00558080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\clusapi.dll
2016-08-31 23:04 - 2016-08-20 05:56 - 02711040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mispace.dll
2016-08-31 23:04 - 2016-08-20 05:56 - 02315264 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
2016-08-31 23:04 - 2016-08-20 05:56 - 02289664 _____ (Microsoft Corporation) C:\WINDOWS\system32\dwmcore.dll
2016-08-31 23:04 - 2016-08-20 05:56 - 02143232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\storagewmi.dll
2016-08-31 23:04 - 2016-08-20 05:56 - 01006080 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3D12.dll
2016-08-31 23:04 - 2016-08-20 05:56 - 00909312 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Search.dll
2016-08-31 23:04 - 2016-08-20 05:56 - 00391168 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhext.dll
2016-08-31 23:04 - 2016-08-20 05:56 - 00020992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\delegatorprovider.dll
2016-08-31 23:04 - 2016-08-20 05:55 - 19418624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
2016-08-31 23:04 - 2016-08-20 05:55 - 00726016 _____ (Microsoft Corporation) C:\WINDOWS\system32\fveapi.dll
2016-08-31 23:04 - 2016-08-20 05:54 - 00806912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3D12.dll
2016-08-31 23:04 - 2016-08-20 05:53 - 03617792 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
2016-08-31 23:04 - 2016-08-20 05:53 - 03299328 _____ (Microsoft Corporation) C:\WINDOWS\system32\mstsc.exe
2016-08-31 23:04 - 2016-08-20 05:53 - 01220608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Audio.dll
2016-08-31 23:04 - 2016-08-20 05:52 - 00640000 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MCRecvSrc.dll
2016-08-31 23:04 - 2016-08-20 05:51 - 06044672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
2016-08-31 23:04 - 2016-08-20 05:51 - 01992704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dwmcore.dll
2016-08-31 23:04 - 2016-08-20 05:51 - 01170944 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Speech.dll
2016-08-31 23:04 - 2016-08-20 05:50 - 01875456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Logon.dll
2016-08-31 23:04 - 2016-08-20 05:49 - 02999296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32kfull.sys
2016-08-31 23:04 - 2016-08-20 05:46 - 03105792 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mstsc.exe
2016-08-31 23:04 - 2016-08-19 02:33 - 00162850 _____ C:\WINDOWS\system32\C_932.NLS
2016-08-31 16:42 - 2016-08-31 16:42 - 00043472 _____ C:\Users\asing\Downloads\Copperplate-Bold.ttf
2016-08-30 14:33 - 2016-08-30 14:33 - 00000000 ____D C:\Users\asing\Downloads\ghostbusters
2016-08-26 23:35 - 2016-09-07 11:11 - 00002882 _____ C:\WINDOWS\System32\Tasks\OneDrive Standalone Update Task
2016-08-26 23:35 - 2016-08-26 23:35 - 00000000 ____D C:\Users\asing\AppData\Roaming\Skype
2016-08-25 12:33 - 2016-09-07 10:26 - 00000000 ____D C:\Program Files (x86)\Mozilla Firefox
2016-08-24 14:35 - 2016-08-24 14:35 - 00027804 _____ C:\Users\asing\Documents\cc_20160824_143526.reg
2016-08-23 20:30 - 2016-08-06 05:33 - 00354264 _____ (Microsoft Corporation) C:\WINDOWS\system32\systemreset.exe
2016-08-23 20:30 - 2016-08-06 05:31 - 00077664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\stornvme.sys
2016-08-23 20:30 - 2016-08-06 05:31 - 00041824 _____ (Microsoft Corporation) C:\WINDOWS\system32\SysResetErr.exe
2016-08-23 20:30 - 2016-08-06 05:29 - 00199008 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\wof.sys
2016-08-23 20:30 - 2016-08-06 05:29 - 00128352 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\partmgr.sys
2016-08-23 20:30 - 2016-08-06 05:26 - 01176664 _____ (Microsoft Corporation) C:\WINDOWS\system32\rpcrt4.dll
2016-08-23 20:30 - 2016-08-06 05:23 - 00168800 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ksecpkg.sys
2016-08-23 20:30 - 2016-08-06 05:18 - 02745224 _____ (Microsoft Corporation) C:\WINDOWS\system32\iertutil.dll
2016-08-23 20:30 - 2016-08-06 05:18 - 00584032 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSyncHost.exe
2016-08-23 20:30 - 2016-08-06 05:18 - 00396168 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlanapi.dll
2016-08-23 20:30 - 2016-08-06 05:17 - 00790760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rpcrt4.dll
2016-08-23 20:30 - 2016-08-06 05:17 - 00619368 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cng.sys
2016-08-23 20:30 - 2016-08-06 05:17 - 00450400 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb.sys
2016-08-23 20:30 - 2016-08-06 05:17 - 00224096 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb20.sys
2016-08-23 20:30 - 2016-08-06 05:16 - 00435040 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\rdbss.sys
2016-08-23 20:30 - 2016-08-06 05:15 - 00408600 _____ (Microsoft Corporation) C:\WINDOWS\system32\tsmf.dll
2016-08-23 20:30 - 2016-08-06 05:13 - 01847048 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsrcsnk.dll
2016-08-23 20:30 - 2016-08-06 05:13 - 01694200 _____ (Microsoft Corporation) C:\WINDOWS\system32\winmde.dll
2016-08-23 20:30 - 2016-08-06 05:13 - 01066096 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsvr.dll
2016-08-23 20:30 - 2016-08-06 05:13 - 00595488 _____ (Microsoft Corporation) C:\WINDOWS\system32\mf.dll
2016-08-23 20:30 - 2016-08-06 05:13 - 00381760 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockAppHost.exe
2016-08-23 20:30 - 2016-08-06 05:13 - 00044472 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfpmp.exe
2016-08-23 20:30 - 2016-08-06 05:09 - 00151224 _____ (Microsoft Corporation) C:\WINDOWS\system32\acmigration.dll
2016-08-23 20:30 - 2016-08-06 05:08 - 02251432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iertutil.dll
2016-08-23 20:30 - 2016-08-06 05:08 - 01469120 _____ (Microsoft Corporation) C:\WINDOWS\system32\appraiser.dll
2016-08-23 20:30 - 2016-08-06 05:08 - 00587968 _____ (Microsoft Corporation) C:\WINDOWS\system32\generaltel.dll
2016-08-23 20:30 - 2016-08-06 05:08 - 00509784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSyncHost.exe
2016-08-23 20:30 - 2016-08-06 05:08 - 00313560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wlanapi.dll
2016-08-23 20:30 - 2016-08-06 05:08 - 00050880 _____ (Microsoft Corporation) C:\WINDOWS\system32\CompatTelRunner.exe
2016-08-23 20:30 - 2016-08-06 05:04 - 00361096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tsmf.dll
2016-08-23 20:30 - 2016-08-06 05:03 - 01557296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winmde.dll
2016-08-23 20:30 - 2016-08-06 05:03 - 01343928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsrcsnk.dll
2016-08-23 20:30 - 2016-08-06 05:03 - 00955008 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsvr.dll
2016-08-23 20:30 - 2016-08-06 05:03 - 00529928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mf.dll
2016-08-23 20:30 - 2016-08-06 05:03 - 00036168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfpmp.exe
2016-08-23 20:30 - 2016-08-06 05:02 - 00321280 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LockAppHost.exe
2016-08-23 20:30 - 2016-08-06 04:48 - 01631232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Resources.dll
2016-08-23 20:30 - 2016-08-06 04:48 - 01631232 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.Resources.dll
2016-08-23 20:30 - 2016-08-06 04:48 - 00015872 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlanhlp.dll
2016-08-23 20:30 - 2016-08-06 04:48 - 00015360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wlanhlp.dll
2016-08-23 20:30 - 2016-08-06 04:48 - 00011264 _____ (Microsoft Corporation) C:\WINDOWS\system32\ResetEngine.exe
2016-08-23 20:30 - 2016-08-06 04:48 - 00010752 _____ (Microsoft Corporation) C:\WINDOWS\system32\spwmp.dll
2016-08-23 20:30 - 2016-08-06 04:48 - 00009216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\spwmp.dll
2016-08-23 20:30 - 2016-08-06 04:48 - 00005120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msdxm.ocx
2016-08-23 20:30 - 2016-08-06 04:48 - 00005120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxmasf.dll
2016-08-23 20:30 - 2016-08-06 04:47 - 00038400 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hidusb.sys
2016-08-23 20:30 - 2016-08-06 04:47 - 00034304 _____ (Microsoft Corporation) C:\WINDOWS\system32\iernonce.dll
2016-08-23 20:30 - 2016-08-06 04:47 - 00027648 _____ (Microsoft Corporation) C:\WINDOWS\system32\WiFiConfigSP.dll
2016-08-23 20:30 - 2016-08-06 04:47 - 00006656 _____ (Microsoft Corporation) C:\WINDOWS\system32\msdxm.ocx
2016-08-23 20:30 - 2016-08-06 04:47 - 00006656 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxmasf.dll
2016-08-23 20:30 - 2016-08-06 04:46 - 09260032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wmploc.DLL
2016-08-23 20:30 - 2016-08-06 04:46 - 09260032 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmploc.DLL
2016-08-23 20:30 - 2016-08-06 04:46 - 00094720 _____ (Microsoft Corporation) C:\WINDOWS\system32\dasHost.exe
2016-08-23 20:30 - 2016-08-06 04:46 - 00057344 _____ (Microsoft Corporation) C:\WINDOWS\system32\WinBioDataModelOOBE.exe
2016-08-23 20:30 - 2016-08-06 04:46 - 00047104 _____ (Microsoft Corporation) C:\WINDOWS\system32\wfdprov.dll
2016-08-23 20:30 - 2016-08-06 04:46 - 00040960 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hidparse.sys
2016-08-23 20:30 - 2016-08-06 04:45 - 00327680 _____ (Microsoft Corporation) C:\WINDOWS\system32\container.dll
2016-08-23 20:30 - 2016-08-06 04:45 - 00226304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\container.dll
2016-08-23 20:30 - 2016-08-06 04:45 - 00066560 _____ (Microsoft Corporation) C:\WINDOWS\system32\iesetup.dll
2016-08-23 20:30 - 2016-08-06 04:45 - 00049664 _____ (Microsoft Corporation) C:\WINDOWS\system32\StorageUsage.dll
2016-08-23 20:30 - 2016-08-06 04:45 - 00038912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wfdprov.dll
2016-08-23 20:30 - 2016-08-06 04:45 - 00030208 _____ (Microsoft Corporation) C:\WINDOWS\system32\netiougc.exe
2016-08-23 20:30 - 2016-08-06 04:45 - 00029696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iernonce.dll
2016-08-23 20:30 - 2016-08-06 04:45 - 00025600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netiougc.exe
2016-08-23 20:30 - 2016-08-06 04:44 - 00061440 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iesetup.dll
2016-08-23 20:30 - 2016-08-06 04:44 - 00047616 _____ (Microsoft Corporation) C:\WINDOWS\system32\deviceassociation.dll
2016-08-23 20:30 - 2016-08-06 04:44 - 00035328 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\deviceassociation.dll
2016-08-23 20:30 - 2016-08-06 04:43 - 00280064 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_WorkAccess.dll
2016-08-23 20:30 - 2016-08-06 04:43 - 00268800 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceCensus.exe
2016-08-23 20:30 - 2016-08-06 04:43 - 00156672 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hidclass.sys
2016-08-23 20:30 - 2016-08-06 04:43 - 00026112 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlansvcpal.dll
2016-08-23 20:30 - 2016-08-06 04:42 - 00223744 _____ (Microsoft Corporation) C:\WINDOWS\system32\ie4uinit.exe
2016-08-23 20:30 - 2016-08-06 04:41 - 13867520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll
2016-08-23 20:30 - 2016-08-06 04:41 - 00462336 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlansec.dll
2016-08-23 20:30 - 2016-08-06 04:41 - 00412160 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlanmsm.dll
2016-08-23 20:30 - 2016-08-06 04:41 - 00323584 _____ (Microsoft Corporation) C:\WINDOWS\system32\domgmt.dll
2016-08-23 20:30 - 2016-08-06 04:41 - 00266240 _____ (Microsoft Corporation) C:\WINDOWS\system32\ConsoleLogon.dll
2016-08-23 20:30 - 2016-08-06 04:41 - 00243712 _____ (Microsoft Corporation) C:\WINDOWS\system32\WinBioDataModel.dll
2016-08-23 20:30 - 2016-08-06 04:41 - 00231424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CloudBackupSettings.dll
2016-08-23 20:30 - 2016-08-06 04:41 - 00068096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSyncPolicy.dll
2016-08-23 20:30 - 2016-08-06 04:40 - 00426496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\OneDriveSettingSyncProvider.dll
2016-08-23 20:30 - 2016-08-06 04:40 - 00387584 _____ (Microsoft Corporation) C:\WINDOWS\system32\iedkcs32.dll
2016-08-23 20:30 - 2016-08-06 04:40 - 00239104 _____ (Microsoft Corporation) C:\WINDOWS\system32\dafpos.dll
2016-08-23 20:30 - 2016-08-06 04:40 - 00234496 _____ (Microsoft Corporation) C:\WINDOWS\system32\tcpipcfg.dll
2016-08-23 20:30 - 2016-08-06 04:40 - 00083968 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSyncPolicy.dll
2016-08-23 20:30 - 2016-08-06 04:39 - 00431616 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpAXHolder.dll
2016-08-23 20:30 - 2016-08-06 04:39 - 00298496 _____ (Microsoft Corporation) C:\WINDOWS\system32\wifiprofilessettinghandler.dll
2016-08-23 20:30 - 2016-08-06 04:39 - 00295424 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudBackupSettings.dll
2016-08-23 20:30 - 2016-08-06 04:39 - 00181760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tcpipcfg.dll
2016-08-23 20:30 - 2016-08-06 04:38 - 17187328 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.dll
2016-08-23 20:30 - 2016-08-06 04:38 - 00526848 _____ (Microsoft Corporation) C:\WINDOWS\system32\OneDriveSettingSyncProvider.dll
2016-08-23 20:30 - 2016-08-06 04:37 - 00340480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iedkcs32.dll
2016-08-23 20:30 - 2016-08-06 04:36 - 00447488 _____ (Microsoft Corporation) C:\WINDOWS\system32\das.dll
2016-08-23 20:30 - 2016-08-06 04:33 - 01082368 _____ (Microsoft Corporation) C:\WINDOWS\system32\reseteng.dll
2016-08-23 20:30 - 2016-08-06 04:33 - 00396800 _____ (Microsoft Corporation) C:\WINDOWS\system32\StorSvc.dll
2016-08-23 20:30 - 2016-08-06 04:31 - 12174336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
2016-08-23 20:30 - 2016-08-06 04:31 - 01908224 _____ (Microsoft Corporation) C:\WINDOWS\system32\AzureSettingSyncProvider.dll
2016-08-23 20:30 - 2016-08-06 04:31 - 01052672 _____ (Microsoft Corporation) C:\WINDOWS\system32\qmgr.dll
2016-08-23 20:30 - 2016-08-06 04:31 - 00884224 _____ (Microsoft Corporation) C:\WINDOWS\system32\samsrv.dll
2016-08-23 20:30 - 2016-08-06 04:31 - 00100864 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpninprc.dll
2016-08-23 20:30 - 2016-08-06 04:30 - 13080576 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
2016-08-23 20:30 - 2016-08-06 04:30 - 12345344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wmp.dll
2016-08-23 20:30 - 2016-08-06 04:30 - 01255936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AzureSettingSyncProvider.dll
2016-08-23 20:30 - 2016-08-06 04:29 - 13433856 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmp.dll
2016-08-23 20:30 - 2016-08-06 04:29 - 00627200 _____ (Microsoft Corporation) C:\WINDOWS\system32\uReFS.dll
2016-08-23 20:30 - 2016-08-06 04:29 - 00237568 _____ (Microsoft Corporation) C:\WINDOWS\system32\offlinesam.dll
2016-08-23 20:30 - 2016-08-06 04:29 - 00123904 _____ (Microsoft Corporation) C:\WINDOWS\system32\samlib.dll
2016-08-23 20:30 - 2016-08-06 04:28 - 00544768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\uReFS.dll
2016-08-23 20:30 - 2016-08-06 04:28 - 00210432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\offlinesam.dll
2016-08-23 20:30 - 2016-08-06 04:28 - 00086016 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\samlib.dll
2016-08-23 20:30 - 2016-08-06 04:26 - 02422784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSAJApi.dll
2016-08-23 20:30 - 2016-08-06 04:26 - 00758784 _____ (Microsoft Corporation) C:\WINDOWS\system32\msfeeds.dll
2016-08-23 20:30 - 2016-08-06 04:26 - 00691712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msfeeds.dll
2016-08-23 20:30 - 2016-08-06 04:25 - 03116032 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSAJApi.dll
2016-08-23 20:30 - 2016-08-06 04:25 - 01595904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\urlmon.dll
2016-08-23 20:30 - 2016-08-06 04:24 - 02095616 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetcpl.cpl
2016-08-23 20:30 - 2016-08-06 04:24 - 02026496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\inetcpl.cpl
2016-08-23 20:30 - 2016-08-06 04:23 - 02370048 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlansvc.dll
2016-08-23 20:30 - 2016-08-06 04:23 - 01780736 _____ (Microsoft Corporation) C:\WINDOWS\system32\urlmon.dll
2016-08-23 20:30 - 2016-08-06 04:23 - 01508864 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
2016-08-23 20:30 - 2016-08-06 04:23 - 01491456 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsasrv.dll
2016-08-23 20:30 - 2016-08-06 04:23 - 01231872 _____ (Microsoft Corporation) C:\WINDOWS\system32\dosvc.dll
2016-08-23 20:30 - 2016-08-06 04:23 - 01062400 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSyncCore.dll
2016-08-23 20:30 - 2016-08-06 04:23 - 00860672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSyncCore.dll
2016-08-23 20:30 - 2016-08-06 04:23 - 00520192 _____ (Microsoft Corporation) C:\WINDOWS\system32\w32time.dll
2016-08-23 20:30 - 2016-08-06 04:21 - 00102400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\offlinelsa.dll
2016-08-23 20:30 - 2016-08-06 04:19 - 01812480 _____ (Microsoft Corporation) C:\WINDOWS\system32\ResetEngine.dll
2016-08-23 20:30 - 2016-08-06 04:19 - 00114688 _____ (Microsoft Corporation) C:\WINDOWS\system32\offlinelsa.dll
2016-08-23 20:30 - 2016-08-05 10:14 - 01066328 _____ (Microsoft Corporation) C:\WINDOWS\system32\pidgenx.dll
2016-08-23 20:30 - 2016-08-05 10:12 - 05622600 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppsvc.exe
2016-08-23 20:30 - 2016-08-05 10:10 - 00939872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\pidgenx.dll
2016-08-23 20:30 - 2016-08-05 10:05 - 00665768 _____ (Microsoft Corporation) C:\WINDOWS\system32\GenValObj.exe
2016-08-23 20:30 - 2016-08-05 09:29 - 00019968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\slcext.dll
2016-08-23 20:30 - 2016-08-05 09:28 - 00022016 _____ (Microsoft Corporation) C:\WINDOWS\system32\slcext.dll
2016-08-23 20:30 - 2016-08-05 09:23 - 00105984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sppc.dll
2016-08-23 20:30 - 2016-08-05 09:22 - 00138240 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppc.dll
2016-08-23 20:30 - 2016-08-05 09:20 - 00538112 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppcext.dll
2016-08-23 20:30 - 2016-08-05 09:20 - 00466432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sppcext.dll
2016-08-23 20:30 - 2016-08-05 09:18 - 00118272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\slc.dll
2016-08-23 20:30 - 2016-08-05 09:08 - 00135168 _____ (Microsoft Corporation) C:\WINDOWS\system32\slc.dll
2016-08-18 20:31 - 2016-08-18 20:31 - 00000000 ____D C:\Users\asing\Downloads\ryan-splint_rapscallion
2016-08-16 17:35 - 2016-08-16 17:35 - 00048856 _____ C:\Users\asing\Downloads\08634_ClarendonBT.ttf
2016-08-16 15:26 - 2016-08-16 15:26 - 00000000 ____D C:\Users\asing\Downloads\adler
2016-08-14 16:50 - 2016-09-07 17:11 - 00004208 _____ C:\WINDOWS\System32\Tasks\Intel Security DAT Reputation (AMCore) Post DAT update endpoint safety pulse
2016-08-14 10:54 - 2016-08-24 14:34 - 00000000 ___DC C:\WINDOWS\Panther
2016-08-14 10:52 - 2016-08-14 10:52 - 01708544 _____ (Microsoft Corporation) C:\WINDOWS\system32\wevtsvc.dll
2016-08-14 10:52 - 2016-08-14 10:52 - 01656320 _____ (Microsoft Corporation) C:\WINDOWS\system32\GdiPlus.dll
2016-08-14 10:52 - 2016-08-14 10:52 - 01461200 _____ (Microsoft Corporation) C:\WINDOWS\system32\user32.dll
2016-08-14 10:52 - 2016-08-14 10:52 - 01456640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GdiPlus.dll
2016-08-14 10:52 - 2016-08-14 10:52 - 01435896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\user32.dll
2016-08-14 10:52 - 2016-08-14 10:52 - 00770048 _____ (Microsoft Corporation) C:\WINDOWS\system32\bisrv.dll
2016-08-14 10:52 - 2016-08-14 10:52 - 00509952 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Bluetooth.dll
2016-08-14 10:52 - 2016-08-14 10:52 - 00495104 _____ (Microsoft Corporation) C:\WINDOWS\system32\DataSenseHandlers.dll
2016-08-14 10:52 - 2016-08-14 10:52 - 00389000 _____ (Microsoft Corporation) C:\WINDOWS\system32\wevtapi.dll
2016-08-14 10:52 - 2016-08-14 10:52 - 00297552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wevtapi.dll
2016-08-14 10:52 - 2016-08-14 10:52 - 00062816 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dam.sys
2016-08-14 10:51 - 2016-08-14 10:51 - 00008192 _____ C:\WINDOWS\system32\config\userdiff
2016-08-14 10:49 - 2016-08-14 10:49 - 00000000 ____D C:\Program Files\Reference Assemblies
2016-08-14 10:49 - 2016-08-14 10:49 - 00000000 ____D C:\Program Files\MSBuild
2016-08-14 10:49 - 2016-08-14 10:49 - 00000000 ____D C:\Program Files (x86)\Reference Assemblies
2016-08-14 10:49 - 2016-08-14 10:49 - 00000000 ____D C:\Program Files (x86)\MSBuild
2016-08-14 10:49 - 2016-05-25 23:31 - 01166520 _____ (Microsoft Corporation) C:\WINDOWS\system32\PresentationNative_v0300.dll
2016-08-14 10:49 - 2016-05-25 23:31 - 00124624 _____ (Microsoft Corporation) C:\WINDOWS\system32\PresentationCFFRasterizerNative_v0300.dll
2016-08-14 10:49 - 2016-05-25 23:31 - 00035480 _____ (Microsoft Corporation) C:\WINDOWS\system32\TsWpfWrp.exe
2016-08-14 10:49 - 2016-05-25 20:03 - 00778936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PresentationNative_v0300.dll
2016-08-14 10:49 - 2016-05-25 20:03 - 00103120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PresentationCFFRasterizerNative_v0300.dll
2016-08-14 10:49 - 2016-05-25 20:03 - 00035480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TsWpfWrp.exe
2016-08-14 03:31 - 2016-08-14 03:31 - 00000000 ____D C:\ProgramData\Microsoft OneDrive
2016-08-14 03:28 - 2016-08-14 11:19 - 00000000 ____D C:\Users\asing\AppData\Local\ConnectedDevicesPlatform
2016-08-14 03:28 - 2016-08-14 03:28 - 00000020 ___SH C:\Users\asing\ntuser.ini
2016-08-14 02:25 - 2016-08-14 02:25 - 00000000 _SHDL C:\Users\Default\My Documents
2016-08-14 02:25 - 2016-08-14 02:25 - 00000000 _SHDL C:\Users\Default\Documents\My Videos
2016-08-14 02:25 - 2016-08-14 02:25 - 00000000 _SHDL C:\Users\Default\Documents\My Pictures
2016-08-14 02:25 - 2016-08-14 02:25 - 00000000 _SHDL C:\Users\Default\Documents\My Music
2016-08-14 02:25 - 2016-08-14 02:25 - 00000000 _SHDL C:\Users\Default User\Documents\My Videos
2016-08-14 02:25 - 2016-08-14 02:25 - 00000000 _SHDL C:\Users\Default User\Documents\My Pictures
2016-08-14 02:25 - 2016-08-14 02:25 - 00000000 _SHDL C:\Users\Default User\Documents\My Music
2016-08-14 02:25 - 2016-08-14 02:25 - 00000000 ____D C:\ProgramData\USOShared
2016-08-14 02:23 - 2016-08-14 02:24 - 00007623 _____ C:\WINDOWS\diagwrn.xml
2016-08-14 02:23 - 2016-08-14 02:24 - 00007623 _____ C:\WINDOWS\diagerr.xml
2016-08-14 02:16 - 2016-09-08 16:35 - 00000006 ____H C:\WINDOWS\Tasks\SA.DAT
2016-08-14 02:16 - 2016-09-08 15:41 - 00002218 _____ C:\WINDOWS\System32\Tasks\CCleanerSkipUAC
2016-08-14 02:16 - 2016-09-08 12:38 - 00003126 _____ C:\WINDOWS\System32\Tasks\McAfeeLogon
2016-08-14 02:16 - 2016-09-08 12:38 - 00000000 ____D C:\WINDOWS\System32\Tasks\McAfee
2016-08-14 02:16 - 2016-09-08 10:13 - 00004020 _____ C:\WINDOWS\System32\Tasks\Intel Security DAT Reputation (AMCore) periodic endpoint safety pulse
2016-08-14 02:16 - 2016-09-07 11:11 - 00003542 _____ C:\WINDOWS\System32\Tasks\Adobe Acrobat Update Task
2016-08-14 02:16 - 2016-09-07 11:11 - 00003506 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineUA
2016-08-14 02:16 - 2016-09-07 11:11 - 00003340 _____ C:\WINDOWS\System32\Tasks\G2MUploadTask-S-1-5-21-3799958336-243299179-1538509029-1001
2016-08-14 02:16 - 2016-09-07 11:11 - 00003282 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineCore
2016-08-14 02:16 - 2016-09-07 11:11 - 00003244 _____ C:\WINDOWS\System32\Tasks\G2MUpdateTask-S-1-5-21-3799958336-243299179-1538509029-1001
2016-08-14 02:16 - 2016-09-07 11:11 - 00003104 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater
2016-08-14 02:16 - 2016-09-07 11:11 - 00002864 _____ C:\WINDOWS\System32\Tasks\AdobeAAMUpdater-1.0-MicrosoftAccount-a.singh2@hotmail.com
2016-08-14 02:16 - 2016-08-14 02:16 - 00003304 _____ C:\WINDOWS\System32\Tasks\User_Feed_Synchronization-{CB27D891-4B90-433F-AF80-2837BEBBDE1D}
2016-08-14 02:16 - 2016-08-14 02:16 - 00002528 _____ C:\WINDOWS\System32\Tasks\CLVDLauncher
2016-08-14 02:16 - 2016-08-14 02:16 - 00002528 _____ C:\WINDOWS\System32\Tasks\CLMLSvc_P2G8
2016-08-14 02:16 - 2016-08-14 02:16 - 00000000 ____D C:\WINDOWS\System32\Tasks\Apple
2016-08-14 02:07 - 2016-08-14 02:07 - 00001576 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Media Player.lnk
2016-08-14 02:07 - 2016-08-14 02:07 - 00000000 ____D C:\Users\Default\AppData\Roaming\Macromedia
2016-08-14 02:07 - 2016-08-14 02:07 - 00000000 ____D C:\Users\Default\AppData\Local\Trusteer
2016-08-14 02:07 - 2016-08-14 02:07 - 00000000 ____D C:\Users\Default User\AppData\Roaming\Macromedia
2016-08-14 02:07 - 2016-08-14 02:07 - 00000000 ____D C:\Users\Default User\AppData\Local\Trusteer
2016-08-14 02:04 - 2016-08-14 02:09 - 00000000 ____D C:\WINDOWS\system32\config\bbimigrate
2016-08-14 02:02 - 2016-09-07 11:56 - 00000000 ____D C:\Users\asing
2016-08-14 02:02 - 2016-08-14 02:02 - 00000000 _SHDL C:\Users\asing\My Documents
2016-08-14 02:02 - 2016-08-14 02:02 - 00000000 _SHDL C:\Users\asing\Documents\My Videos
2016-08-14 02:02 - 2016-08-14 02:02 - 00000000 _SHDL C:\Users\asing\Documents\My Pictures
2016-08-14 02:02 - 2016-08-14 02:02 - 00000000 _SHDL C:\Users\asing\Documents\My Music
2016-08-14 01:58 - 2016-09-08 16:36 - 00000000 ____D C:\ProgramData\NVIDIA
2016-08-14 01:58 - 2016-08-14 01:58 - 01087759 _____ C:\WINDOWS\system32\Drivers\rtwavesskdy.dat
2016-08-14 01:58 - 2016-08-14 01:58 - 00456480 _____ C:\WINDOWS\system32\Drivers\RTWAVES60.dat
2016-08-14 01:58 - 2016-08-14 01:58 - 00075545 _____ C:\WINDOWS\system32\Drivers\rtwavesvp3cap.dat
2016-08-14 01:58 - 2016-08-14 01:58 - 00031095 _____ C:\WINDOWS\system32\Drivers\rtwavesEFX.dat
2016-08-14 01:58 - 2016-08-14 01:58 - 00010945 _____ C:\WINDOWS\system32\Drivers\rtwavesMFX.dat
2016-08-14 01:58 - 2016-08-14 01:58 - 00002995 _____ C:\WINDOWS\system32\Drivers\rtwavesmvpss.dat
2016-08-14 01:58 - 2016-08-14 01:58 - 00000000 ____D C:\WINDOWS\SysWOW64\RTCOM
2016-08-14 01:58 - 2016-08-14 01:58 - 00000000 ____D C:\WINDOWS\system32\SRSLabs
2016-08-14 01:58 - 2016-08-14 01:58 - 00000000 ____D C:\Program Files\Realtek
2016-08-14 01:58 - 2016-07-16 12:41 - 02716672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PrintConfig.dll
2016-08-14 01:58 - 2016-06-03 04:59 - 06452948 _____ C:\WINDOWS\system32\nvcoproc.bin
2016-08-14 01:58 - 2016-06-03 04:59 - 06364216 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcpl.dll
2016-08-14 01:58 - 2016-06-03 04:59 - 02455608 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvc64.dll
2016-08-14 01:58 - 2016-06-03 04:59 - 01762752 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvcr.dll
2016-08-14 01:58 - 2016-06-03 04:59 - 01352760 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvvsvc.exe
2016-08-14 01:58 - 2016-06-03 04:59 - 00534072 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshext.dll
2016-08-14 01:58 - 2016-06-03 04:59 - 00392128 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvmctray.dll
2016-08-14 01:58 - 2016-06-03 04:59 - 00081856 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshextr.dll
2016-08-14 01:58 - 2016-06-03 04:59 - 00069568 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvshext.dll
2016-08-14 01:57 - 2016-09-08 11:04 - 00000000 ____D C:\ProgramData\NVIDIA Corporation
2016-08-14 01:57 - 2016-09-08 11:03 - 00000000 ____D C:\Program Files\NVIDIA Corporation
2016-08-14 01:57 - 2016-09-08 11:03 - 00000000 ____D C:\Program Files (x86)\NVIDIA Corporation
2016-08-14 01:57 - 2016-08-14 01:57 - 00000000 ____H C:\WINDOWS\system32\Drivers\Msft_User_WpdFs_01_11_00.Wdf
2016-08-14 01:56 - 2016-09-08 11:39 - 00000000 ____D C:\WINDOWS\system32\SleepStudy
2016-08-14 01:56 - 2016-09-08 10:51 - 10955392 _____ C:\WINDOWS\system32\FNTCACHE.DAT
2016-08-14 01:56 - 2016-08-14 01:56 - 00000000 ____D C:\WINDOWS\ServiceProfiles
2016-08-14 01:33 - 2016-08-14 01:33 - 00000085 _____ C:\Users\asing\Documents\jpotash.txt
2016-08-13 17:46 - 2016-08-13 17:46 - 00000000 ____D C:\Users\asing\Downloads\new-york-jets
2016-08-13 17:36 - 2016-08-13 17:36 - 00014984 _____ C:\Users\asing\Desktop\new-york-jets.zip
2016-08-11 12:14 - 2016-08-11 12:14 - 00000000 ____D C:\Users\asing\Downloads\Simple-TItles-for-Premiere-Pro-cinecom.net_
2016-08-09 21:24 - 2016-08-10 18:47 - 00289108 _____ C:\Users\asing\Downloads\the-fresh-prince.otf
2016-08-09 21:21 - 2016-08-09 21:21 - 00000000 ____D C:\Users\asing\Downloads\reskagraf
2016-09-08 16:42 - 2015-11-10 02:46 - 01019822 _____ C:\WINDOWS\system32\PerfStringBackup.INI
2016-09-08 16:37 - 2016-01-27 16:13 - 01329152 _____ C:\Users\asing\AppData\Local\SageThumbs.db3
2016-09-08 16:36 - 2016-02-09 21:29 - 00192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MBAMSwissArmy.sys
2016-09-08 16:35 - 2016-07-16 07:04 - 00524288 _____ C:\WINDOWS\system32\config\BBI
2016-09-08 15:41 - 2016-07-16 12:45 - 00000000 ____D C:\WINDOWS\INF
2016-09-08 15:11 - 2016-06-08 00:34 - 00000000 ____D C:\Users\asing\AppData\Local\NVIDIA Corporation
2016-09-08 12:51 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\AppReadiness
2016-09-08 11:09 - 2015-11-10 02:59 - 00000000 ____D C:\Program Files (x86)\Microsoft Office
2016-09-08 11:03 - 2016-06-08 00:33 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation
2016-09-08 11:03 - 2016-01-09 12:09 - 00000000 ____D C:\Users\asing\AppData\Local\NVIDIA
2016-09-08 10:51 - 2016-07-16 07:04 - 00008192 _____ C:\WINDOWS\system32\config\ELAM
2016-09-08 10:48 - 2016-02-04 16:52 - 00000000 ____D C:\Users\asing\AppData\LocalLow\Temp
2016-09-08 10:12 - 2016-01-09 23:53 - 00000000 ____D C:\Users\asing\AppData\Local\Adobe
2016-09-07 23:47 - 2016-02-25 01:58 - 00000000 ____D C:\Users\asing\AppData\Roaming\Audacity
2016-09-07 23:11 - 2016-05-11 00:50 - 00000000 ____D C:\Users\asing\Desktop\Amazon Review Videos
2016-09-07 12:02 - 2016-07-16 12:47 - 00000000 ___HD C:\Program Files\WindowsApps
2016-09-07 11:50 - 2016-01-29 17:28 - 00000000 ____D C:\ProgramData\SupportAssistAgent
2016-09-07 11:50 - 2015-11-10 02:56 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Dell
2016-09-07 11:50 - 2015-11-10 02:56 - 00000000 ____D C:\Program Files\Dell
2016-09-07 11:49 - 2015-11-10 02:42 - 00000000 ___HD C:\Program Files (x86)\InstallShield Installation Information
2016-09-07 11:49 - 2015-11-10 02:11 - 00000000 ____D C:\ProgramData\Dell
2016-09-07 11:18 - 2016-05-02 18:54 - 00000686 _____ C:\WINDOWS\Tasks\G2MUploadTask-S-1-5-21-3799958336-243299179-1538509029-1001.job
2016-09-07 11:18 - 2016-05-02 18:54 - 00000590 _____ C:\WINDOWS\Tasks\G2MUpdateTask-S-1-5-21-3799958336-243299179-1538509029-1001.job
2016-09-07 11:18 - 2016-03-06 00:49 - 00000934 _____ C:\WINDOWS\Tasks\GoogleUpdateTaskMachineUA.job
2016-09-07 11:18 - 2016-03-06 00:49 - 00000930 _____ C:\WINDOWS\Tasks\GoogleUpdateTaskMachineCore.job
2016-09-07 11:18 - 2016-01-14 21:35 - 00000830 _____ C:\WINDOWS\Tasks\Adobe Flash Player Updater.job
2016-09-07 11:16 - 2016-01-09 12:12 - 00000000 ___RD C:\Users\asing\OneDrive
2016-09-07 11:05 - 2016-02-10 16:31 - 00000000 ____D C:\Program Files\CCleaner
2016-09-07 11:04 - 2016-02-10 16:31 - 00000865 _____ C:\Users\Public\Desktop\CCleaner.lnk
2016-09-07 10:47 - 2015-07-10 12:04 - 00000000 ___HD C:\WINDOWS\system32\GroupPolicy
2016-09-07 09:42 - 2016-01-26 16:37 - 00000000 ____D C:\Users\asing\AppData\Roaming\DMCache
2016-09-07 00:16 - 2016-02-27 00:59 - 00000000 ____D C:\Users\asing\AppData\Roaming\vlc
2016-09-06 23:46 - 2016-02-21 15:29 - 00000000 ____D C:\Users\asing\Desktop\Camera Roll
2016-09-05 23:12 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\Registration
2016-09-05 23:12 - 2016-07-11 00:08 - 00000000 ____D C:\Program Files (x86)\TunnelBear
2016-09-05 22:59 - 2016-02-09 21:28 - 00001173 _____ C:\Users\Public\Desktop\Malwarebytes Anti-Malware.lnk
2016-09-05 22:59 - 2016-02-09 21:28 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes Anti-Malware
2016-09-05 22:59 - 2016-02-09 21:28 - 00000000 ____D C:\Program Files (x86)\Malwarebytes Anti-Malware
2016-09-03 22:19 - 2016-03-11 01:02 - 00097856 _____ (Oracle Corporation) C:\WINDOWS\SysWOW64\WindowsAccessBridge-32.dll
2016-09-03 22:19 - 2016-03-11 01:02 - 00000000 ____D C:\Users\asing\.oracle_jre_usage
2016-09-03 22:19 - 2016-03-11 01:02 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java
2016-09-03 22:19 - 2016-03-11 01:01 - 00000000 ____D C:\ProgramData\Oracle
2016-09-03 22:19 - 2016-03-11 01:01 - 00000000 ____D C:\Program Files (x86)\Java
2016-09-02 12:14 - 2016-07-16 12:36 - 00000000 ____D C:\WINDOWS\CbsTemp
2016-09-01 04:55 - 2015-11-10 03:30 - 00000000 __RHD C:\Users\Public\AccountPictures
2016-09-01 02:39 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\rescache
2016-09-01 00:16 - 2016-01-09 18:31 - 00000000 ____D C:\Program Files (x86)\Mozilla Maintenance Service
2016-09-01 00:14 - 2016-07-16 12:47 - 00000000 ___SD C:\WINDOWS\system32\dsc
2016-09-01 00:14 - 2016-07-16 12:47 - 00000000 ___RD C:\WINDOWS\ImmersiveControlPanel
2016-09-01 00:14 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\WinBioPlugIns
2016-09-01 00:14 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\lv-LV
2016-09-01 00:14 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\lt-LT
2016-09-01 00:14 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\et-EE
2016-09-01 00:14 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\es-MX
2016-09-01 00:14 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\en-GB
2016-09-01 00:14 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\ShellExperiences
2016-09-01 00:14 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\Provisioning
2016-08-31 22:57 - 2016-07-16 12:42 - 00409952 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\FWPKCLNT.SYS
2016-08-31 22:56 - 2016-07-16 12:43 - 06474752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mspaint.exe
2016-08-31 22:56 - 2016-07-16 12:43 - 00496128 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettings.UserAccountsHandlers.dll
2016-08-31 22:56 - 2016-07-16 12:43 - 00374784 _____ (Microsoft Corporation) C:\WINDOWS\system32\resutils.dll
2016-08-31 22:56 - 2016-07-16 12:43 - 00298496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\resutils.dll
2016-08-31 22:56 - 2016-07-16 12:43 - 00289792 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeveloperOptionsSettingsHandlers.dll
2016-08-31 22:56 - 2016-07-16 12:43 - 00049152 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Shell.dll
2016-08-31 22:56 - 2016-07-16 12:43 - 00034304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LaunchWinApp.exe
2016-08-31 22:56 - 2016-07-16 12:42 - 06664192 _____ (Microsoft Corporation) C:\WINDOWS\system32\mspaint.exe
2016-08-31 22:56 - 2016-07-16 12:42 - 00711680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Search.dll
2016-08-31 22:56 - 2016-07-16 12:42 - 00241504 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudExperienceHost.dll
2016-08-31 22:56 - 2016-07-16 12:42 - 00210944 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32k.sys
2016-08-31 22:56 - 2016-07-16 12:42 - 00150528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32k.sys
2016-08-31 22:56 - 2016-07-16 12:42 - 00114192 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32u.dll
2016-08-31 22:56 - 2016-07-16 12:42 - 00079544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32u.dll
2016-08-31 22:56 - 2016-07-16 12:42 - 00058880 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Shell.Search.UriHandler.dll
2016-08-31 22:56 - 2016-07-16 12:42 - 00047104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Shell.Search.UriHandler.dll
2016-08-31 22:56 - 2016-07-16 12:42 - 00043008 _____ (Microsoft Corporation) C:\WINDOWS\system32\LaunchWinApp.exe
2016-08-26 23:35 - 2016-01-09 12:12 - 00002365 _____ C:\Users\asing\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\OneDrive.lnk
2016-08-26 06:43 - 2016-07-16 12:49 - 00828408 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
2016-08-26 06:43 - 2016-07-16 12:49 - 00176632 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
2016-08-24 10:22 - 2016-07-16 12:47 - 00000000 ____D C:\ProgramData\regid.1991-06.com.microsoft
2016-08-23 22:15 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\appraiser
2016-08-23 20:44 - 2016-01-09 19:57 - 00000000 ____D C:\Users\asing\Desktop\Axe Apparel
2016-08-22 20:44 - 2016-07-11 00:08 - 00000000 ____D C:\Users\asing\AppData\Roaming\TunnelBear
2016-08-18 18:59 - 2016-07-16 12:47 - 00000000 ___HD C:\WINDOWS\ELAMBKUP
2016-08-14 11:49 - 2016-01-09 12:09 - 00000000 ____D C:\Users\asing\AppData\Local\Packages
2016-08-14 11:29 - 2016-03-06 20:05 - 00000000 ____D C:\Users\asing\AppData\Local\ElevatedDiagnostics
2016-08-14 11:20 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\appcompat
2016-08-14 10:54 - 2016-07-16 12:47 - 00028672 _____ C:\WINDOWS\system32\config\BCD-Template
2016-08-14 10:51 - 2016-07-16 15:15 - 00000000 ____D C:\WINDOWS\OCR
2016-08-14 02:25 - 2016-07-16 12:47 - 00000000 ____D C:\ProgramData\USOPrivate
2016-08-14 02:22 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\WinBioDatabase
2016-08-14 02:22 - 2015-10-30 08:24 - 00000000 ____D C:\WINDOWS\system32\Tasks_Migrated
2016-08-14 02:16 - 2016-03-05 18:54 - 00022840 _____ C:\WINDOWS\system32\emptyregdb.dat
2016-08-14 02:14 - 2016-07-16 12:47 - 00000000 __RHD C:\Users\Public\Libraries
2016-08-14 02:13 - 2015-11-10 02:50 - 00891172 _____ C:\WINDOWS\SysWOW64\PerfStringBackup.INI
2016-08-14 02:09 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\NDF
2016-08-14 02:09 - 2016-07-11 00:08 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TunnelBear
2016-08-14 02:09 - 2016-06-14 11:10 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
2016-08-14 02:09 - 2016-06-09 15:04 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Trusteer Endpoint Protection
2016-08-14 02:09 - 2016-06-06 15:59 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mailbird
2016-08-14 02:09 - 2016-05-29 21:17 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2016 Tools
2016-08-14 02:09 - 2016-05-02 17:17 - 00000000 ____D C:\Users\asing\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Grammarly
2016-08-14 02:09 - 2016-05-01 14:58 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Oxelon Media Converter
2016-08-14 02:09 - 2016-04-04 16:23 - 00000000 ____D C:\Users\asing\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Internet Download Manager
2016-08-14 02:09 - 2016-04-04 16:23 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Internet Download Manager
2016-08-14 02:09 - 2016-02-27 00:59 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN
2016-08-14 02:09 - 2016-02-19 17:40 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe
2016-08-14 02:09 - 2016-01-27 16:17 - 00000000 ____D C:\Users\asing\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Ghostscript
2016-08-14 02:09 - 2016-01-27 16:13 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SageThumbs
2016-08-14 02:09 - 2016-01-12 22:57 - 00000000 ____D C:\Users\asing\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Vector Magic
2016-08-14 02:09 - 2016-01-11 13:46 - 00000000 ____D C:\ProgramData\regid.1995-09.com.example
2016-08-14 02:09 - 2016-01-11 13:46 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoMakerFX
2016-08-14 02:09 - 2016-01-10 00:02 - 00000000 ____D C:\ProgramData\regid.1986-12.com.adobe
2016-08-14 02:09 - 2016-01-09 23:45 - 00000000 ____D C:\Users\asing\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WinRAR
2016-08-14 02:09 - 2016-01-09 23:45 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR
2016-08-14 02:09 - 2015-11-10 02:50 - 00000000 ___RD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel
2016-08-14 02:09 - 2015-11-10 02:46 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Dell Audio
2016-08-14 02:07 - 2015-10-30 07:28 - 00000000 ____D C:\Users\Default.migrated
2016-08-14 02:05 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\SysWOW64\Macromed
2016-08-14 02:05 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\spool
2016-08-14 02:05 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\oobe
2016-08-14 02:05 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\Macromed
2016-08-14 02:04 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\LiveKernelReports
2016-08-14 02:04 - 2016-07-16 12:47 - 00000000 ____D C:\Program Files\Common Files\microsoft shared
2016-08-14 02:03 - 2016-05-13 01:23 - 00000000 ____D C:\Users\asing\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WhatsApp
2016-08-14 02:01 - 2016-07-16 07:04 - 00000000 ____D C:\WINDOWS\system32\Sysprep
2016-08-14 01:59 - 2016-07-16 12:47 - 00000000 ___RD C:\WINDOWS\PrintDialog
2016-08-14 01:59 - 2016-07-16 12:47 - 00000000 ___RD C:\WINDOWS\MiracastView
2016-08-14 01:58 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\Help
2016-08-10 10:21 - 2016-01-09 22:24 - 00000000 ____D C:\WINDOWS\system32\MRT
2016-08-10 10:16 - 2016-01-09 22:24 - 147640136 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
2016-09-08 10:51 - 2016-09-08 16:37 - 0008642 _____ () C:\Users\asing\AppData\Local\BTServer.log
2016-01-27 16:13 - 2016-09-08 16:37 - 1329152 _____ () C:\Users\asing\AppData\Local\SageThumbs.db3
==================== Bamital & volsnap =================
LastRegBack: 2016-09-05 11:37
Ok, you still have all of the startup items and scheduled task running with your machine at boot. Can you re-look at the instructions for CCleaner please. All of these items running with your machine needlessly can slow things down. If you need help disabling anything let me know please.
Other than that how are things now?
I had disabled everything that was stated in the instructions, I just checked and those in windows are still disabled but there are some others in schedule task tab that wasn't there before or was disabled before that is now enabled again. I disabled everything again so let's see.
With regards to the performance, I have seen a bit of improvement in the was the system operates, but it still lags at start up and also the font software is still hanging when trying to read uninstalled fonts from a folder.
Alright, lets have a look at a fresh Hijack this log please.
HijackThis.
2- Run the program.
5- Copy paste the log here.
Security Check Scan.
Download Security Check to your desktop, right click it run as administrator. When the program completes, the tool will automatically open a log file, please post that log here in your next post.
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 8:56:17 PM, on 9/9/2016
Platform: Unknown Windows (WinNT 6.02.1008)
MSIE: Internet Explorer v11.0 (11.00.14393.0000)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
C:\Program Files (x86)\Malwarebytes Anti-Malware\mbam.exe
C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe
C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae.exe
C:\Program Files (x86)\CyberLink\CyberLink Media Suite\Power2Go8\CLMLSvc_P2G8.exe
C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
C:\Program Files (x86)\Dell Update\DellUpTray.exe
C:\Program Files (x86)\Mozilla Firefox\firefox.exe
C:\Program Files (x86)\Mozilla Firefox\plugin-container.exe
C:\WINDOWS\SysWoW64\Macromed\Flash\FlashPlayerPlugin_22_0_0_209.exe
C:\Program Files (x86)\Common Files\Adobe\CS6ServiceManager\CS6ServiceManager.exe
C:\Users\asing\Desktop\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/p/?LinkId=255141
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/p/?LinkId=255141
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page = %11%\blank.htm
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O2 - BHO: IDM Helper - {0055C089-8582-441B-A0BF-17B458C2A3A8} - C:\Program Files (x86)\Internet Download Manager\IDMIECC.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre1.8.0_101\bin\ssv.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre1.8.0_101\bin\jp2ssv.dll
O4 - HKLM\..\Run: [SwitchBoard] C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
O4 - HKLM\..\Run: [AdobeCS5ServiceManager] "C:\Program Files (x86)\Common Files\Adobe\CS5ServiceManager\CS5ServiceManager.exe" -launchedbylogin
O4 - HKLM\..\Run: [AdobeCS6ServiceManager] "C:\Program Files (x86)\Common Files\Adobe\CS6ServiceManager\CS6ServiceManager.exe" -launchedbylogin
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [Malwarebytes Anti-Exploit] C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae.exe
O4 - HKCU\..\Run: [OneDrive] "C:\Users\asing\AppData\Local\Microsoft\OneDrive\OneDrive.exe" /background
O4 - HKCU\..\Run: [CCleaner Monitoring] "C:\Program Files\CCleaner\CCleaner64.exe" /MONITOR
O4 - HKCU\..\Run: [IDMan] C:\Program Files (x86)\Internet Download Manager\IDMan.exe /onboot
O4 - HKCU\..\Run: [Mailbird] "C:\Program Files (x86)\Mailbird\Mailbird.exe" startup
O4 - HKCU\..\Run: [TunnelBear] C:\Program Files (x86)\TunnelBear\TBear.Client.exe -autoconnect
O4 - HKCU\..\Run: [CCleaner] "C:\Program Files\CCleaner\CCleaner64.exe" /AUTO
O4 - HKCU\..\RunOnce: [Uninstall C:\Users\asing\AppData\Local\Microsoft\OneDrive\17.3.6390.0509_1\amd64] C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\asing\AppData\Local\Microsoft\OneDrive\17.3.6390.0509_1\amd64"
O4 - HKUS\S-1-5-19\..\Run: [OneDriveSetup] C:\Windows\SysWOW64\OneDriveSetup.exe /thfirstsetup (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [OneDriveSetup] C:\Windows\SysWOW64\OneDriveSetup.exe /thfirstsetup (User 'NETWORK SERVICE')
O8 - Extra context menu item: Download all links with IDM - C:\Program Files (x86)\Internet Download Manager\IEGetAll.htm
O8 - Extra context menu item: Download with IDM - C:\Program Files (x86)\Internet Download Manager\IEExt.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\Program Files (x86)\Microsoft Office\Root\Office16\EXCEL.EXE/3000
O8 - Extra context menu item: Se&nd to OneNote - res://C:\Program Files (x86)\Microsoft Office\Root\Office16\ONBttnIE.dll/105
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\root\Office16\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: Se&nd to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\root\Office16\ONBttnIE.dll
O9 - Extra button: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\root\Office16\ONBttnIELinkedNotes.dll
O9 - Extra 'Tools' menuitem: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\root\Office16\ONBttnIELinkedNotes.dll
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O18 - Protocol: mso-minsb-roaming.16 - {83C25742-A9F7-49FB-9138-434302C88D07} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL
O18 - Protocol: mso-minsb.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL
O18 - Protocol: osf-roaming.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL
O18 - Protocol: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL
O18 - Protocol: tbauth - {14654CA6-5711-491D-B89A-58E571679951} - C:\Windows\SysWOW64\tbauth.dll
O18 - Protocol: windows.tbauth - {14654CA6-5711-491D-B89A-58E571679951} - C:\Windows\SysWOW64\tbauth.dll
O18 - Filter: application/x-mfe-ipt - {3EF5086B-5478-4598-A054-786C45D75692} - c:\PROGRA~2\mcafee\msc\mcsniepl.dll
O23 - Service: Adobe Acrobat Update Service (AdobeARMservice) - Adobe Systems Incorporated - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
O23 - Service: Adobe Flash Player Update Service (AdobeFlashPlayerUpdateSvc) - Adobe Systems Incorporated - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\WINDOWS\System32\alg.exe (file missing)
O23 - Service: Apple Mobile Device Service - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: BTDevManager - Unknown owner - C:\Program Files (x86)\REALTEK\Realtek Bluetooth\BTDevMgr.exe
O23 - Service: Dell Data Vault (DellDataVault) - Dell Inc. - C:\Program Files\Dell\DellDataVault\DellDataVault.exe
O23 - Service: Dell Data Vault Wizard (DellDataVaultWiz) - Dell Inc. - C:\Program Files\Dell\DellDataVault\DellDataVaultWiz.exe
O23 - Service: Dell Update Service (DellUpdate) - Dell Inc. - C:\Program Files (x86)\Dell Update\DellUpService.exe
O23 - Service: @%SystemRoot%\system32\DiagSvcs\DiagnosticsHub.StandardCollector.ServiceRes.dll,-1000 (diagnosticshub.standardcollector.service) - Unknown owner - C:\WINDOWS\system32\DiagSvcs\DiagnosticsHub.StandardCollector.Service.exe (file missing)
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\WINDOWS\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\WINDOWS\system32\fxssvc.exe (file missing)
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Google Update Service (gupdatem) (gupdatem) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: McAfee Home Network (HomeNetSvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\Platform\McSvcHost\McSvHost.exe
O23 - Service: Intel(R) Rapid Storage Technology (IAStorDataMgrSvc) - Intel Corporation - C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
O23 - Service: Intel(R) Capability Licensing Service TCP IP Interface - Intel(R) Corporation - C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe
O23 - Service: Intel(R) PROSet Monitoring Service - Unknown owner - C:\WINDOWS\system32\IProsetMonitor.exe (file missing)
O23 - Service: Intel(R) Security Assist - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Security Assist\isa.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Intel(R) Ready Mode Technology (IRMTService) - Intel Corporation - c:\Program Files\Intel\Intel(R) Ready Mode Technology\IRMTService.exe
O23 - Service: Intel(R) Security Assist Helper (isaHelperSvc) - Unknown owner - C:\Program Files (x86)\Intel\Intel(R) Security Assist\isaHelperService.exe
O23 - Service: Intel(R) Dynamic Application Loader Host Interface Service (jhi_service) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\WINDOWS\system32\lsass.exe (file missing)
O23 - Service: Intel(R) Management and Security Application Local Management Service (LMS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
O23 - Service: Mailbird Updater (MailbirdUpdater.exe) - Mailbird - C:\Program Files (x86)\Mailbird\MailbirdUpdater.exe
O23 - Service: Malwarebytes Anti-Exploit Service (MbaeSvc) - Malwarebytes Corporation - C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae-svc.exe
O23 - Service: MBAMScheduler - Malwarebytes - C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe
O23 - Service: MBAMService - Malwarebytes - C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe
O23 - Service: McAfee AP Service (McAPExe) - McAfee, Inc. - C:\Program Files\McAfee\MSC\McAPExe.exe
O23 - Service: McAfee Activation Service (McAWFwk) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\ActWiz\McAWFwk.exe
O23 - Service: McAfee Boot Delay Start Service (McBootDelayStartSvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\Platform\McSvcHost\McSvHost.exe
O23 - Service: McAfee CSP Service (mccspsvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\CSP\1.9.829.0\\McCSPServiceHost.exe
O23 - Service: McAfee Personal Firewall Service (McMPFSvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\Platform\McSvcHost\McSvHost.exe
O23 - Service: McAfee VirusScan Announcer (McNaiAnn) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\platform\McSvcHost\McSvHost.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\Program Files\mcafee\VirusScan\mcods.exe
O23 - Service: McAfee Platform Services (mcpltsvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\platform\McSvcHost\McSvHost.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\platform\McSvcHost\McSvHost.exe
O23 - Service: McAfee Firewall Core Service (mfefire) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mfefire.exe
O23 - Service: McAfee Service Controller (mfemms) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mfemms.exe
O23 - Service: McAfee Validation Trust Protection Service (mfevtp) - Unknown owner - C:\Windows\system32\mfevtps.exe (file missing)
O23 - Service: McAfee Module Core Service (ModuleCoreService) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\ModuleCore\ModuleCoreService.exe
O23 - Service: Mozilla Maintenance Service (MozillaMaintenance) - Mozilla Foundation - C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\WINDOWS\System32\msdtc.exe (file missing)
O23 - Service: McAfee Anti-Spam Service (MSK80Service) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\Platform\McSvcHost\McSvHost.exe
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\WINDOWS\system32\lsass.exe (file missing)
O23 - Service: NVIDIA LocalSystem Container (NvContainerLocalSystem) - NVIDIA Corporation - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
O23 - Service: NVIDIA NetworkService Container (NvContainerNetworkService) - NVIDIA Corporation - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
O23 - Service: NVIDIA Wireless Controller Service - NVIDIA Corporation - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\nvwirelesscontroller.exe
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\WINDOWS\system32\nvvsvc.exe (file missing)
O23 - Service: Intel Security PEF Service (PEFService) - Intel Security, Inc. - C:\Program Files\Common Files\Intel Security\PEF\CORE\PEFService.exe
O23 - Service: Rapport Management Service (RapportMgmtService) - IBM Corp. - C:\Program Files (x86)\Trusteer\Rapport\bin\RapportMgmtService.exe
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files (x86)\CyberLink\Shared files\RichVideo.exe
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\WINDOWS\system32\locator.exe (file missing)
O23 - Service: Realtek Audio Service (RtkAudioService) - Realtek Semiconductor - C:\Program Files\Realtek\Audio\HDA\RtkAudioService64.exe
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\WINDOWS\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\SensorDataService.exe,-101 (SensorDataService) - Unknown owner - C:\WINDOWS\System32\SensorDataService.exe (file missing)
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\WINDOWS\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\WINDOWS\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\WINDOWS\system32\sppsvc.exe (file missing)
O23 - Service: NVIDIA Stereoscopic 3D Driver Service (Stereo Service) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvscpapisvr.exe
O23 - Service: Adobe SwitchBoard (SwitchBoard) - Adobe Systems Incorporated - C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
O23 - Service: @%SystemRoot%\system32\TieringEngineService.exe,-702 (TieringEngineService) - Unknown owner - C:\WINDOWS\system32\TieringEngineService.exe (file missing)
O23 - Service: TunnelBear Maintenance (TunnelBearMaintenance) - Unknown owner - C:\Program Files (x86)\TunnelBear\TBear.Maintenance.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\WINDOWS\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\WINDOWS\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\WINDOWS\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\WINDOWS\system32\vssvc.exe (file missing)
O23 - Service: Waves System Service (WavesSysSvc) - Waves Audio Ltd. - C:\Program Files\Waves\MaxxAudio\WavesSysSvc64.exe
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\WINDOWS\system32\wbengine.exe (file missing)
O23 - Service: @%ProgramFiles%\Windows Defender\MpAsDesc.dll,-320 (WdNisSvc) - Unknown owner - C:\Program Files (x86)\Windows Defender\NisSrv.exe (file missing)
O23 - Service: @%ProgramFiles%\Windows Defender\MpAsDesc.dll,-310 (WinDefend) - Unknown owner - C:\Program Files (x86)\Windows Defender\MsMpEng.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\WINDOWS\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%PROGRAMFILES%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
O23 - Service: ZAM Controller Service (ZAMSvc) - Zemana Ltd. - C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe
End of file - 16831 bytes
SecurityCheck by glax24 & Severnyj v.1.4.0.44 [17.08.16]
WebSite: www.safezone.cc
DateLog: 09.09.2016 20:56:59
Path starting: C:\Users\asing\AppData\Local\Temp\SecurityCheck\SecurityCheck.exe
Log directory: C:\SecurityCheck\
IsAdmin: True
User: asing
VersionXML: 3.30is-07.09.2016
___________________________________________________________________________
Windows 10(6.3.14393) (x64) Core Lang: English(0409)
Installation date OS: 14.08.2016 01:25:20
LicenseStatus: Windows(R), Core edition The machine is permanently activated.
LicenseStatus: Office 16, Office16O365HomePremR_SubTrial5 edition Windows is in Notification mode
Boot Mode: Normal
Default Browser: C:\Program Files (x86)\Mozilla Firefox\firefox.exe
SystemDrive: C: FS: [NTFS] Capacity: [917.5 Gb] Used: [203.9 Gb] Free: [713.6 Gb]
------------------------------- [ Windows ] -------------------------------
User Account Control enabled
Automatic Updates disabled (-1)
Windows Update (wuauserv) - The service has stopped
Security Center (wscsvc) - The service is running
Remote Registry (RemoteRegistry) - The service has stopped
SSDP Discovery (SSDPSRV) - The service is running
Remote Desktop Services (TermService) - The service has stopped
Windows Remote Management (WS-Management) (WinRM) - The service has stopped
---------------------------- [ Antivirus_WMI ] ----------------------------
Windows Defender (disabled and up to date)
McAfee Anti-Virus and Anti-Spyware (enabled)
---------------------------- [ Firewall_WMI ] -----------------------------
McAfee Firewall
--------------------------- [ AntiSpyware_WMI ] ---------------------------
---------------------- [ AntiVirusFirewallInstall ] -----------------------
McAfee LiveSafe v.15.0.166
-------------------------- [ SecurityUtilities ] --------------------------
Malwarebytes Anti-Malware version 2.2.1.1043 v.2.2.1.1043
Zemana AntiMalware v.2.30.75
--------------------------- [ OtherUtilities ] ----------------------------
WinRAR 5.31 beta 1 (64-bit) v.5.31.1 Warning! Download Update
VLC media player v.2.2.4
---------------------------- [ ProxyAndVPNs ] -----------------------------
TunnelBear v.2.3.25.0 Warning! This app can show ads.
-------------------------------- [ Java ] ---------------------------------
Java 8 Update 101 v.8.0.1010.13 Warning! Download Update
Uninstall old version and install new one (jre-8u102-windows-i586.exe).
--------------------------- [ AppleProduction ] ---------------------------
Bonjour v.3.1.0.1
iTunes v.12.4.1.6 Warning! Download Update
^Please use Apple Software Update tool.^
Bonjour Service (Bonjour Service) - The service is running
--------------------------- [ AdobeProduction ] ---------------------------
Adobe AIR v.3.1.0.4880 Warning! Download Update
Adobe Flash Player 22 NPAPI v.22.0.0.209
Adobe Acrobat Reader DC v.15.017.20053
------------------------------- [ Browser ] -------------------------------
Google Chrome v.52.0.2743.116 Warning! Download Update
Mozilla Firefox 48.0.2 (x86 en-GB) v.48.0.2
--------------------------- [ RunningProcess ] ----------------------------
C:\Program Files (x86)\Mozilla Firefox\firefox.exe v.48.0.2.6079
------------------ [ AntivirusFirewallProcessServices ] -------------------
C:\Program Files (x86)\Malwarebytes Anti-Malware\mbam.exe v.2.3.173.0
MBAMScheduler (MBAMScheduler) - The service is running
C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe v.3.1.7.0
MBAMService (MBAMService) - The service is running
C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe v.3.2.21.0
Malwarebytes Anti-Exploit Service (MbaeSvc) - The service is running
C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae-svc.exe v.1.8.1.2572
C:\Program Files\Common Files\McAfee\SystemCore\mfemms.exe v.15.4.0.822
McAfee Validation Trust Protection Service (mfevtp) - The service is running
C:\Windows\System32\mfevtps.exe
C:\Program Files\Common Files\McAfee\AMCore\mcshield.exe v.1.4.1.612
McAfee Firewall Core Service (mfefire) - The service is running
C:\Program Files\Common Files\McAfee\SystemCore\mfefire.exe v.15.4.0.822
McAfee AP Service (McAPExe) - The service is running
C:\Program Files\mcafee\msc\McAPExe.exe v.15.0.166.0
McAfee Personal Firewall Service (McMPFSvc) - The service is running
C:\Program Files\Common Files\McAfee\platform\McSvcHost\McSvHost.exe v.6.0.151.0
C:\Program Files\Common Files\McAfee\platform\McUICnt.exe v.8.0.140.0
McAfee CSP Service (mccspsvc) - The service is running
C:\Program Files\Common Files\McAfee\CSP\1.9.829.0\McCSPServiceHost.exe v.1.9.829.0
McAfee Scanner (McODS) - The service has stopped
McAfee Service Controller (mfemms) - The service is running
McAfee Module Core Service (ModuleCoreService) - The service is running
C:\Program Files\Common Files\McAfee\ModuleCore\ModuleCoreService.exe v.1.3.118.0
McAfee Home Network (HomeNetSvc) - The service is running
McAfee VirusScan Announcer (McNaiAnn) - The service is running
McAfee OOBE Service2 (McOobeSv2) - The service has stopped
McAfee Platform Services (mcpltsvc) - The service is running
McAfee Proxy Service (McProxy) - The service is running
McAfee Boot Delay Start Service (McBootDelayStartSvc) - The service is running
Windows Defender Service (WinDefend) - The service has stopped
Windows Defender Network Inspection Service (WdNisSvc) - The service has stopped
ZAM Controller Service (ZAMSvc) - The service is running
C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe v.0.0.0.0
----------------------------- [ End of Log ] ------------------------------
Fix with HijackThis!
Close all other programs!
Right Click Hijack this, run as administrator.
Click do a system scan only.
Place a tick next to the items below.
Click fix checked.
Accept the prompt.
Reboot the machine after.
Update your programs.
Make sure and update all programs suggested by the Security Check tool, you can update manually, or use this effective tool.
Removing Security Programs.
I have noted over the years of helping in forums that Trusteer Endpoint Protection has been known to slow down machines and cause issues, if this program is not needed, then I would suggest removing it. I think that removing Mcafee and then re-installing it may also help. Make sure and remove it reboot, and then run the Mcafee Removal Tool then reboot, and then reinstall the program.
Finally, running a check disk on your machine...
Run chkdsk /f /r From elevated Command Prompt.
I have made a video explaining how to run check disk on your computer found below.
Thanks for your responses. So I have done everything else that you mentioned apart from removing Trusteer Endpoint Protection as I do lots of online shopping and not sure if this software protects me in anyway. Also I haven't removed McAfee because the program came pre installed with my system and I had a look in program files for an .exe file so that I can re install later, but I found some other mcafee .exe files and I'm unsure which do which.
Finally when I run the check disk I got this message which is different from the one in the video so I exited it and came here to make this post.
here is the message I got from check disk after I hit enter:
Access Denied as you do not have sufficient privileges.
You have to invoke this utility running in elevated mode.
