Solved Sound cutting out on Toshiba Laptop
Rogue Killer Scan.
Download RogueKiller -- (Portable) -- from one of the following links and save it to your Desktop:
Link 1
Link 2
  • Close all other the running programs
  • Disable ALL Antivirus -- Antimalware -- Applications.
  • Right Click Rogue Killer and Run as Administrator.
  • Click the Start Scan button.
  • Allow the scan to run -- it can take ten minutes or more.
  • Once the scan is complete check All items for removal.
  • upload_2017-2-23_10-55-54-png.1658
  • After All items are checked then press Remove Selected.
  • Wait until the Status box shows Deleting Finished.
  • Click on open report -- then open txt
  • Copy the content of the report and paste it here in your next reply.
JRT Scan.
  • Shut down your anti-virus, anti-spyware, and firewall software now to avoid potential conflicts.
  • Run the tool by double-clicking it. If you are using Windows Vista or Windows 7, right-click it and select Run as administrator.
  • The tool will open and start scanning your system.
  • Please be patient as this can take a while to complete depending on your system's specifications.
  • On completion, a log is saved to your desktop and will automatically open.
  • Please post the JRT log.
Adware Cleaner Scan.
  • Close all open programs and internet browsers.
  • Double click on adwcleaner.exe to run the tool.
  • Click on Scan button.
  • When the scan has finished click on Clean button.
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • Please post the contents of that logfile with your next reply.
  • You can find the logfile at C:\AdwCleaner[S1].txt as well.
Malwarebytes.
  • Download MalwareBytes Anti-Malware : https://www.malwarebytes.com/mwb-download/ take the free version ( on the left )
  • Perform the installation
  • Uncheck "Enable Free Trial of Malwarebytes Anti-Malware Premium" if it's asked
  • Malwarebytes will update, let this update,
  • Click on the "Settings" tab and then on the "Detection and Protection" tab, Check the box "Search for Rootkits"
  • Click on the "Analysis" tab and then on "Start analysis"
  • Once the review is complete, check that all detections are checked and then click [Delete Selection]
  • If Malwarebytes asks you to restart your PC, click "Yes"
  • When restarting your PC, restarts Malwarebytes
  • Opens the "History" tab and then "Application logs"
  • Double click on the last Scan Log in date (the one above)
  • At the bottom click [Export] -> select "Text file (* .txt)"
  • In the explorer selects the desktop, name it mbam.txt, click [Save]
Okay RogueKiller just finished, here's the report:
RogueKiller V12.11.1.0 (x64) [Jun 4 2017] (Free) by Adlice Software
mail : http://www.adlice.com/contact/
Feedback : https://forum.adlice.com
Website : http://www.adlice.com/download/roguekiller/
Blog : http://www.adlice.com
Operating System : Windows 7 (6.1.7601 Service Pack 1) 64 bits version
Started in : Normal mode
User : Juancho [Administrator]
Started from : C:\Users\Juancho\Desktop\RogueKiller_portable64.exe
Mode : Delete -- Date : 06/10/2017 11:57:13 (Duration : 02:26:00)
¤¤¤ Processes : 0 ¤¤¤
¤¤¤ Registry : 21 ¤¤¤
[PUP.ModGoog|PUP.Gen1] (X86) HKEY_LOCAL_MACHINE\Software\GlobalUpdate -> Deleted
[PUP.Gen1] (X64) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\DailyPcClean -> Deleted
[PUP.ModGoog|PUP.Gen1] (X64) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\globalUpdate -> Deleted
[PUP.Gen1] (X64) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\Softonic -> Deleted
[PUP.Gen1] (X64) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\tstamptoken -> Deleted
[PUP.Gen1] (X64) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\Tutorials -> Deleted
[PUP.Gen1] (X64) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\YahooPartnerToolbar -> Deleted
[PUP.Gen1] (X86) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\DailyPcClean -> Deleted
[PUP.ModGoog|PUP.Gen1] (X86) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\globalUpdate -> Deleted
[PUP.Gen1] (X86) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\Softonic -> Deleted
[PUP.Gen1] (X86) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\tstamptoken -> Deleted
[PUP.Gen1] (X86) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\Tutorials -> Deleted
[PUP.Gen1] (X86) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\YahooPartnerToolbar -> Deleted
[PUP.Gen1] (X64) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\AppDataLow\Software\SmartWeb -> Deleted
[PUP.Gen1] (X86) HKEY_USERS\S-1-5-21-794287275-3297088658-3092121377-1004\Software\AppDataLow\Software\SmartWeb -> Deleted
[PUP.Gen1] (X64) HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\gpuminer -> Deleted
[PUP.Gen1] (X86) HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\{7ADF667E-E14D-4D2C-827C-B0108F0D93BC} -> Deleted
[Suspicious.Path] (X64) HKEY_LOCAL_MACHINE\System\ControlSet001\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules | TCP Query User{8FE61C01-F686-4D26-8D53-A8D6EA12184F}C:\users\juancho\appdata\local\temp\gw2.exe : v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\users\juancho\appdata\local\temp\gw2.exe|Name=Guild Wars 2 Game Client|Desc=Guild Wars 2 Game Client|Defer=User| [x] -> Deleted
[Suspicious.Path] (X64) HKEY_LOCAL_MACHINE\System\ControlSet001\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules | UDP Query User{E21913A5-3D59-47AD-A4A8-C622D6797E3D}C:\users\juancho\appdata\local\temp\gw2.exe : v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\users\juancho\appdata\local\temp\gw2.exe|Name=Guild Wars 2 Game Client|Desc=Guild Wars 2 Game Client|Defer=User| [x] -> Deleted
[Suspicious.Path] (X64) HKEY_LOCAL_MACHINE\System\ControlSet002\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules | TCP Query User{8FE61C01-F686-4D26-8D53-A8D6EA12184F}C:\users\juancho\appdata\local\temp\gw2.exe : v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\users\juancho\appdata\local\temp\gw2.exe|Name=Guild Wars 2 Game Client|Desc=Guild Wars 2 Game Client|Defer=User| [x] -> Deleted
[Suspicious.Path] (X64) HKEY_LOCAL_MACHINE\System\ControlSet002\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules | UDP Query User{E21913A5-3D59-47AD-A4A8-C622D6797E3D}C:\users\juancho\appdata\local\temp\gw2.exe : v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\users\juancho\appdata\local\temp\gw2.exe|Name=Guild Wars 2 Game Client|Desc=Guild Wars 2 Game Client|Defer=User| [x] -> Deleted
¤¤¤ Tasks : 5 ¤¤¤
[Suspicious.Path|PUP.Gen0] %WINDIR%\Tasks\c1O9pL9eoaBMG9NlwPnXI.job -- C:\Users\Juancho\AppData\Roaming\c1O9pL9eoaBMG9NlwPnXI.exe (--c=L2sA/J2Cr88zUKhWHm+dsWGuG1otaPBOF4OWEhozNYMSAGBtHoXpT2HiUfox/iSxqFBbZlARjSjbuRj0NHEUpgL1UoeVn/R7I3GY5i3HqZfTlNCGDeeu15nM+yoQVg9CR0cmc6lmM6v5MCdORcSI9qhINQPbuoGibSeRn48zE7uRa3811fwtUlCWOkcBiSyakXQMHcACj3a68mzkyCmGG4ICdee6GJvrcQzZXDMPJsioyYX/w+Kj25k7aZSOFB8ivPLDjsaK9KUg7RHslwzQtGBt0lGHl5dfcqA0eIDOxNnJtphaTJs+MpMrAqHkr/hO2mErkyR8du3y8L7jxyvmDA==) -> Deleted
[Suspicious.Path|PUP.Gen0] %WINDIR%\Tasks\grWkCgMQbwn4LWnty4JxPE.job -- C:\Users\Juancho\AppData\Roaming\grWkCgMQbwn4LWnty4JxPE.exe (--c=tPiG95T33OKW891UeOQ0UhKi1vFpd5si2h77achVcPSvPTNJZM83RDC/bmTF6jUn7Z74dl5kf4X7cY9z5SvZ2rNaNsDAcWE2nC9qWxPZgU0QJp8bC4YPyFLaFhE4eLUAupMl8GPgMA8bvMBHVY+6PhB4GsjtIS3SQyvONXgcTCE3DB38Pf1bZO/ANTEUZ/cXr1lRDFg4nj5GwfUPhg+NTvLUq2rTRaTXVn7qeg6yfstStSgLfsANGFCWhMrT//cSElL0SIWwzvfNntoPUEZNdMXN22WGpznkKhlfzU6Lz2Lfz5YG1LN6JEX1cTES3Osr8f9Q1fbl7+1R93Buifd65A==) -> Deleted
[Suspicious.Path] \5997473-40A-4E36-98B7-78964FB766FC -- C:\Users\Juancho\AppData\Local\5997473-40A-4E36-98B7-78964FB766FC\5997473-40A-4E36-98B7-78964FB766FC.exe (q::cCnnykR3kEQycJE+x#R3E#nqxkcn:x*:n*x:QcR#*D /asru /reinstalltask) -> Deleted
[Suspicious.Path|PUP.Gen0] \c1O9pL9eoaBMG9NlwPnXI -- C:\Users\Juancho\AppData\Roaming\c1O9pL9eoaBMG9NlwPnXI.exe (--c=L2sA/J2Cr88zUKhWHm+dsWGuG1otaPBOF4OWEhozNYMSAGBtHoXpT2HiUfox/iSxqFBbZlARjSjbuRj0NHEUpgL1UoeVn/R7I3GY5i3HqZfTlNCGDeeu15nM+yoQVg9CR0cmc6lmM6v5MCdORcSI9qhINQPbuoGibSeRn48zE7uRa3811fwtUlCWOkcBiSyakXQMHcACj3a68mzkyCmGG4ICdee6GJvrcQzZXDMPJsioyYX/w+Kj25k7aZSOFB8ivPLDjsaK9KUg7RHslwzQtGBt0lGHl5dfcqA0eIDOxNnJtphaTJs+MpMrAqHkr/hO2mErkyR8du3y8L7jxyvmDA==) -> Deleted
[Suspicious.Path|PUP.Gen0] \grWkCgMQbwn4LWnty4JxPE -- C:\Users\Juancho\AppData\Roaming\grWkCgMQbwn4LWnty4JxPE.exe (--c=tPiG95T33OKW891UeOQ0UhKi1vFpd5si2h77achVcPSvPTNJZM83RDC/bmTF6jUn7Z74dl5kf4X7cY9z5SvZ2rNaNsDAcWE2nC9qWxPZgU0QJp8bC4YPyFLaFhE4eLUAupMl8GPgMA8bvMBHVY+6PhB4GsjtIS3SQyvONXgcTCE3DB38Pf1bZO/ANTEUZ/cXr1lRDFg4nj5GwfUPhg+NTvLUq2rTRaTXVn7qeg6yfstStSgLfsANGFCWhMrT//cSElL0SIWwzvfNntoPUEZNdMXN22WGpznkKhlfzU6Lz2Lfz5YG1LN6JEX1cTES3Osr8f9Q1fbl7+1R93Buifd65A==) -> Deleted
¤¤¤ Files : 9 ¤¤¤
[PUP.Gen1][Folder] C:\ProgramData\Driver Manager -> Deleted
[PUP.Gen1][Folder] C:\ProgramData\Partner -> Deleted
[PUP.Gen1][File] C:\ProgramData\Partner\debug.log -> Deleted
[PUP.Gen1][Folder] C:\Users\Juancho\AppData\Roaming\cpuminer -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\aes_helper.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\blake.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\blake256.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\bmw.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\bmw256.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\cubehash.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\darkcoin-mod.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\echo.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\fugue.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\groestl.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\groestl256.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\jh.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\keccak.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\keccak1600.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\luffa.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\lyra2.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\lyra2re.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\lyra2rev2.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\lyra2v2.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\neoscrypt-old.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\neoscrypt.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\shabal.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\shavite.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\simd.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\skein.cl -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel\skein256.cl -> Deleted
[PUP.Gen1][Folder] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\kernel -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\msvcr120.dll -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\sgm.exe -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\sgminer.conf -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer\start.cmd -> Deleted
[PUP.Gen1][Folder] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer -> Deleted
[PUP.Gen1][File] C:\Users\Juancho\AppData\Roaming\cpuminer\sgminer-uninst.exe -> Deleted
[PUP.ModGoog|PUP.Gen1][Folder] C:\Users\Juancho\AppData\Local\globalUpdate -> Deleted
[PUP.ModGoog|PUP.Gen1][Folder] C:\Users\Juancho\AppData\Local\globalUpdate\CrashReports -> Deleted
[Hidden.ADS][Stream] C:\ProgramData:6B1AE0953C6D6B11 -> Deleted
[PUP.Gen1][Folder] C:\ProgramData\Driver Manager -> ERROR [3]
[PUP.Gen1][Folder] C:\ProgramData\Partner -> ERROR [3]
[PUP.ModGoog|PUP.Gen1][Folder] C:\Program Files (x86)\globalUpdate -> Deleted
[PUP.ModGoog|PUP.Gen1][Folder] C:\Program Files (x86)\globalUpdate\CrashReports -> Deleted
[PUP.Gen1][Folder] C:\Program Files (x86)\predm -> Deleted
¤¤¤ WMI : 0 ¤¤¤
¤¤¤ Hosts File : 0 ¤¤¤
¤¤¤ Antirootkit : 0 (Driver: Loaded) ¤¤¤
¤¤¤ Web browsers : 2 ¤¤¤
[PUM.HomePage][Firefox:Config] ck42sjqp.default : user_pref("browser.startup.homepage", "https://www.malwarebytes.org/restor...zftpbl02,8467e57a-1392-46b3-9b2a-1e964d7dd3b8"); -> Replaced (about:home)
[PUM.SearchEngine][Firefox:Config] ck42sjqp.default : user_pref("browser.search.defaultenginename", "Search Module"); -> Deleted
¤¤¤ MBR Check : ¤¤¤
+++++ PhysicalDrive0: +++++
--- User ---
[MBR] e90d67869f70e0e9a5b9bc6c08fe0b67
[BSP] 95d1fcc63ae4c5ee61d53497aa59d2fe : HP|VT.Unknown MBR Code
Partition table:
0 - [ACTIVE] ACER (0x27) [VISIBLE] Offset (sectors): 2048 | Size: 1500 MB
1 - [XXXXXX] NTFS (0x7) [VISIBLE] Offset (sectors): 3074048 | Size: 464762 MB [Windows Vista/7/8 Bootstrap | Windows Vista/7/8 Bootloader]
2 - [XXXXXX] NTFS (0x17) [HIDDEN!] Offset (sectors): 954906624 | Size: 10677 MB [Windows Vista/7/8 Bootstrap | Windows Vista/7/8 Bootloader]
User = LL1 ... OK
User = LL2 ... OK
+++++ PhysicalDrive1: Hitachi HTS545050B9A300 +++++
--- User ---
[MBR] 749de53ea9bc94dd18f1ac98919c5c37
[BSP] 15ffcd5d932946607149041b9664f832 : Unknown|VT.Unknown MBR Code
Partition table:
0 - [ACTIVE] NTFS (0x7) [VISIBLE] Offset (sectors): 63 | Size: 476937 MB [Unknown Bootstrap | Unknown Bootloader]
User = LL1 ... OK
User = LL2 ... OK
Now I'll proceed with the JRT scan.
Ok, once you have posted the requested logs I will prepare a fix for you with ZHP Diag, your machine is indeed infected with malware, so we need to clean it in a timely fashion.
Alrighty, here are the scans:
Version: 8.1.3 (04.10.2017)
Operating System: Windows 7 Home Premium x64
Ran by Juancho (Administrator) on Sat 10/06/2017 at 20:09:27.12
File System: 1420
Successfully deleted: C:\end (File)
Successfully deleted: C:\Users\Juancho\AppData\Local\{00028165-8DFF-4A65-BD6F-2142B467F83D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{006E4683-D26F-4610-9045-200E6A95B273} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{00B4F97B-27BF-4DE8-9950-05C4BD26491C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{00CF9E66-68B3-4141-991C-7AF3F07806DE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0189B54B-86C2-4892-8151-7654434582DB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{018B3186-AD51-43BB-8FAB-E8E961BA2417} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{01A31D28-1210-4E1E-B26E-944A9A209372} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0233B7B2-DB7D-44F8-AF57-3F5547A01E87} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{03165C48-33E5-4BDA-B6E8-68E947A0D05C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{033AB0D2-120A-4142-9C67-092E6AAED9DB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{037CBA42-FB1A-4EEA-A883-52AAC3AAAC6A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{039C21EC-5BD2-4631-810F-77FC9AF369AF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{03A3F0A2-EE4B-4CA1-BAA8-DA55C90CD7DA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{03EA90B5-B35A-4B7A-87B1-81CBB062DA73} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{044A14E3-F65D-43BE-B231-7A70D362AA9F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{045148CD-E3E3-4FC2-8214-7D88410E5072} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{04B4F91D-6C13-4CC6-A20B-63B54BF5D146} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{04F24AE1-0663-4E0C-A6E5-57ED5E75C9D7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{051EC8B0-A032-4FBB-A31A-CFBE5055F7E6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0574AF82-AB54-495E-8E26-1C3E0B72B7A8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0595247F-9AB4-48B6-9F36-A6629378B00F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{05D2399C-5888-4379-9B85-60F36C332611} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{06077110-D9EA-4AA1-9290-B61A663DC0AD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{060D31B6-955C-40A1-8885-3A3260882858} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{06128B48-6987-4E25-9E43-26940B06A503} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{062737B8-4964-4491-A77C-DF17AAD8DCA8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{069274B4-B626-4C2F-A7D1-1438F3779C65} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{06ADEB35-1154-433E-8134-D4CEF45DD2DD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{06B6AB6D-EB04-4E80-B660-3A0E7F4AE2D4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{06D72D4F-E3E3-4507-95E7-81DE38494A46} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{06E4C759-54F9-4380-AA9E-DEFDEC5504A0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{070A8C08-738E-4B01-B5DF-4E8CFA5BC551} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0715C9D4-F602-4051-8950-BAEE3EB66447} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{073A6469-995D-44B5-B159-CEB1470A0E28} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{07CA9B96-4BDA-4C8F-B6B1-A597BA9D9454} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0815DB46-5EDE-4F75-9C0A-E9DD93868671} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{085D9BC3-21BB-4829-83A1-D6076986587A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{08A34AA5-12C4-45AF-A0F0-120B34E3DEEF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{08EBFFB3-0D78-4E08-91B0-3E2EE99DFC4F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{09026119-52BD-48B3-AE9B-FBDE30310858} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0919A331-9E58-40A1-BA1E-14EBBA1A1542} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0922B0F1-FCDF-47C8-8D60-84B56A9AC636} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{093FA3F9-AD69-4EAB-BB9C-60755AAE08E8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{09696E7A-6CC7-46AB-8743-805E75DE4FA2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{096B7F1D-8CE7-4FDC-9F5C-8A6BEFA142FA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0A63161F-4C03-4C18-9465-05A5B9C5DEE4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0A7B2DB1-5DF0-4A02-BE85-96716527DFF5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0A7DFCA5-5094-4813-B3D5-9C68B1F9C3D6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0A8D3E5D-9211-4687-A08F-BB47C16B4346} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0AFC1CCB-054F-4A87-8320-DCC56BF58121} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0B4062F4-E980-4D4F-A178-5B4D667864F1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0B45CCCF-48FA-45ED-B4C2-7F220F2660C2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0B61AEEC-65EB-4435-A0C6-066D1A5AB4CF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0BB7FFF5-3C6F-4CB9-91F9-CFB3D6E942C5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0C00BD41-6DF4-49BD-BEAA-7E26EB9CB4FF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0C3D7543-F711-4B53-9E99-D1626E499B3E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0C3DE74A-C473-4634-AD74-B371EB5D7B8E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0C9DC1F5-19F1-4BFA-8C01-07BE3774D59A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0CA9953C-0819-48A7-9238-36D7D2D70E6C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0CB8AA29-6998-4966-A922-42CD76F76622} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0CCA5B9C-E3F9-436B-98E1-C64A518AADB5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0D09A2D2-A292-48AC-8B0A-065CDD8D4729} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0DA6ACFA-22E5-471F-8567-CAEB8FEB2992} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0DC813B8-C538-4DA5-A365-8EFE40B6ACCC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0E1BC6C9-8802-4D4F-B5D8-79148678526C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0E721A2D-E152-4337-826C-8A9E1DF1C97D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0EA05C60-6256-4135-909A-64490897FBBA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0ED953FF-36E3-4B51-9F35-B2A65AA4AA39} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0EEA8C5E-8EC4-4D80-AEDB-197EAFD6A108} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0F1A9942-2B3D-48D3-B2F0-68D2E9DBB077} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0F1BC2CC-4E98-4AA4-988D-38663C9BB215} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0F20E676-9F11-43DE-9904-5D023F931495} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0F50AD24-1C30-422D-BF6A-5D8D7FF441C4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0F63F16F-09A0-4F7D-8D40-B19F091DEB41} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0F965F29-B7CC-4BD3-88D8-A1C5C87F1A91} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0FCD4C34-D90F-46ED-ABE6-531EC6C48DC9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{0FF96E8D-159D-4F96-A11C-24F2696B2960} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{100304AC-173B-4AC7-9C5A-F45A1C365465} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{104DBE73-4752-4095-B1E6-1F8ED6B2BC37} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{104FDB61-6DC8-479D-91A1-16501BE40F7D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{105681AC-7B7C-48E0-B014-C51DFE81C915} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{10819F1E-9C44-431A-BF5B-FFC15CBA2373} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{108655B6-98E9-4951-9CBE-F5EC02F7E8C5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{108F4BB3-D7BA-4B27-8A8A-F49CCF6903B2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{10A1C626-B5BD-4245-AE35-72FF2BE4AB3D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{11A7E3F3-1DD0-4EAF-A98C-B28879E4A651} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{11AC1AC7-5394-4C1E-A6E2-3ED507063116} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{11D7E45B-C993-495B-B072-03347874CA87} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{11E440BB-DC54-4A1A-9C30-2AFF2C0F88C3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1216C3E0-104C-4A51-AFD6-84457BA5E2E5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{12201E0C-6B22-4616-BE84-26B135A59DA6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1243C895-AC3D-42DD-90D3-597C880E47CE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1267371F-83FB-450E-B171-FFF62840F75C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{129EDED5-844D-4092-A705-32D448711A1D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{12A0EE03-ED20-427B-BFBA-26BBBD633F72} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{12C8F08F-24A7-4E2A-8AB5-D44C4EDC8387} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{12CC99A8-7003-46C1-A808-0979997569CC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{12F6B964-565D-4312-AE5D-865C87E2630A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{13300B62-ADC3-450F-AD60-EAD1F576822D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{134F04FE-73B3-463F-AF37-5C18F0A75BBF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{13591D31-E1E0-4A4E-A785-9968F811C889} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1362BF33-D841-4BA7-8C03-2CDCC366E1C0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{13F519F2-1225-4584-BA45-1920469F0A8F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{13FD64FE-92B6-40AA-B7D2-B1051DD032D7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1401A1D3-6F83-4647-9129-C9DDAF71B826} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{140B41F1-61CB-469F-B0EF-B17821D98C21} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{14384773-9978-49C4-9AB8-983C6C94659D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{14432579-0E0B-4BEA-8EC1-F46E55AFD0B1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{14FBB072-7583-4616-87BD-E715800A876F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{15159F59-0717-4B00-AE6E-E2DC39687510} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1515BCA8-595B-4030-9170-7A218B36D164} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{15346A4E-B2CD-4B18-A87A-AB3CB1A10133} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1540D361-4F32-40B4-BA77-970C57406D7C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{15B0B1BA-7237-44F0-A8F6-836BDC45BF37} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{15D4C543-6731-4E35-AC98-BAE67D1B7714} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{162839A7-F6F4-42F2-8BEB-A3AB3297DF4E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{164D7806-554A-4615-B339-6B5E37D7EE83} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{165C80FA-7344-4A60-AD77-F03AE31CBAFC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{166BF321-12CD-495B-9E17-A69C82EAA8A4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{16C7CB3D-C24E-43FC-953A-575A4E92E207} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{173790A8-8EBC-4E6F-A98D-ADDA3E1FEB68} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{175DFBAB-C911-4BFC-9132-EE9F1CC6715F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{17AE55DB-79A5-4475-8C2B-4A263CDFC13F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{17C0E456-64EC-434A-B919-700F67DFD105} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{17E617AF-4BE6-46C4-9940-A662A526008B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{184147F8-CA7E-481C-8F97-7A970936818D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{18C783AE-0CDE-45E7-9B85-4842C63FB3EF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{18CEB842-AED9-4AE9-A9A4-E56322EA3951} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{190C0EA3-F598-4B07-8406-952EBCCDBC58} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{19314CDF-6A5F-4F16-A68D-C92B4F201DAA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1969F09A-D041-436C-ACA2-56C565244F9F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{197D44C3-DEEC-4CEA-938F-2773CA6269EC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{19951077-54EA-417E-97BC-DF54F1F75DC8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{199DE664-CB41-4378-AA0A-EC0615B8964A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{19B061BF-3741-43E2-87EE-DF320AAE97B4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{19E1E2B9-4794-4AE4-A5EF-A16DF7D7E5BE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1A37F65C-E1CF-4DE9-A1EF-3F1B65FBD4A3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1A5BD89B-1CB8-45FA-BA24-5708FE89A231} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1A6664C0-7551-4B03-90FA-5D269D07EF65} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1AC2E81D-2395-4A82-A629-1A49DCC3F596} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1AE64A07-D0BD-453E-9D0A-5ECE3C2290BD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1AEA8F87-8A9B-4816-98EB-2BF0A42A281A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1AF826A9-1B85-4B74-BAE1-21C2122C71B2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1B20A586-59E7-4D90-90D4-907D6E492DED} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1B9ED1B7-DF77-46F8-913B-5D9A3A09590D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1BCB0B7B-6FC1-401B-B9B2-1D771F6B6DC8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1BF10972-B789-40B0-B3E3-03E8DAAFBC84} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1C1B18AC-2D60-4001-9099-C77FCE53A47B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1C1C2EBA-9F71-4E63-8E80-10ACA370332F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1C355AB2-41B1-4E42-9C3D-6EA508DCBC79} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1C473EC7-DD6F-45F0-92C2-31301E16F6B6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1C688519-F58A-474E-BF35-A082F4C7FE67} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1C7E113D-0510-4491-9F74-6C132724CF1F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1CC1983F-00F8-4ECB-AA8E-B02B12726420} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1CC7EEDC-D1A5-44A9-8BAC-F5F5A06E9164} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1D2943C3-0C5F-4C4A-84AA-A9510F0B0F16} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1D4FA5F5-662D-41F1-A96A-3AA3E4FB4D9F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1D51FC66-273D-4A54-8628-F0C27210D217} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1DB882CD-481C-4371-9947-52F32BE30EF1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1DC7BF2C-D072-48A4-B4A4-0FDD8B5C3115} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1DD79021-D91C-4D86-BE99-D03A2430F83C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1E47F6C6-2516-4551-9AC1-72183D625F3E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1E5995DF-25D6-41C8-992A-ED1C160149A2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1E791555-790A-475D-A483-16FFC38D477A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1EBD0109-BE07-4D35-93D3-BEBAE6BE7B48} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1EC16EA8-5814-4756-85CF-ABB56DAC74C7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1EDD3011-DB1D-41F9-933C-884331DC15EE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1EFDD814-3463-481C-AF12-545893A796C1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1F011CFB-38FD-4DB6-80E1-8DE891BCC13F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1F6A40AF-8DA7-41AE-8DBE-28E9F4579400} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1F8F2430-1AC4-4FFD-B07F-553C466B1AC8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1F9B901B-C7A0-4E72-8C55-626FEEC27112} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1FF10BE7-FC6F-4F87-BB32-66CD2F7108C3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1FFCA986-ABD7-4B44-BA3B-7CE5316CB57B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{1FFE4DBB-FBC2-4CA0-8B10-1E7B010C213D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{201499BC-9F11-4B37-999D-7C877A22F98B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{204B551B-F3F7-431C-84C2-D9566CFA3400} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2082F19F-12B0-4AC4-9EB8-EB9E57B8E295} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{209469F8-3BC3-4CD7-8111-BB205D5E4D20} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{20A9B4D2-0236-455F-A4A7-217065C4B35D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{20B32EB1-0301-4BF1-9474-1762A57B82CA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2113912A-5D4A-4310-8082-423129A1BE73} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{21341517-552E-48AB-9DF7-28F561F46F32} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{214B57D4-CEAA-486D-BDE8-22187B253AB4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{21704751-659F-4BBD-A7CD-861AD173AF52} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{21B4C073-B17C-45E1-95CF-36FCF5F1D257} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{21D5E57B-7461-4C53-95E2-60E7F423FE91} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{21E89CED-E125-4C4B-88B4-6428AD497101} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{22667A68-50F7-4024-B9A6-9DF7733DA620} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{23308B1E-B6A3-4B0D-B4FF-D3C5AE4A7B43} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{23627CA1-3552-421D-B6FE-180B62DBA97C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{239EF313-6C73-409D-AA20-7DE3DCA8FD5C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{23B38469-86B0-411C-8DF7-42C73FC4A900} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{23DB07FD-168A-4681-AD3C-E5B3729BDED5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{23F00150-5D34-40B4-8AF0-7FF24ECB25F6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2404A977-CFD6-47B9-A641-CFAA0F90F8F9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{24FCD7CC-7946-4228-B2F5-E94E032BBA72} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{24FFEAD0-DDD4-4688-A230-FC95E4182E6C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{250C9FAB-35C9-4D30-8414-6D4A03C10C99} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{251CC634-31AE-4C62-AD7D-EE7479411813} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{25ADEBAA-A784-421E-842F-9840F7C22AF4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{25AF4AA0-9D86-4515-ACED-7914735F17A9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{263EE219-B0F2-4427-A93A-A02A1A6E96A1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{264AA751-F5AA-402C-95AC-6C73F75BB78E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{266DAA4B-7F8E-407D-9956-5193EDB8B239} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{26AC1B17-B24E-4800-A3E1-301BD448A8E2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{26B7C66E-F6F6-4215-919B-383F2D233568} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{26BAC893-D8C7-44E9-8431-009EAEF77FD9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{274C6319-9F6D-48C4-ADA5-E3662A200E3A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{27DA2C92-D61C-4FF3-BA0C-46325413B22E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{27F0822D-EDCC-4ECF-83C1-E128CE2B645D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2827BD98-6C7F-419B-8FEF-3F32003BFAFF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{28775A2C-8888-43A8-8E3B-D60C1EFEC8B6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{288531E2-58CB-45C3-9A16-7457EBF44540} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{28A1D688-87BC-4259-BFBD-5503424E84B9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{28BA16D7-35B7-4FE7-BDD2-30F907C8D6DA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{28F915D7-C056-4E2B-BC32-C96A028542B4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{294D4CFE-0523-497E-947E-93053988E032} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{29577C48-01F9-4D9C-A3F1-5F25D04D74BA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{29DC68AF-3EC5-4288-A7C6-CB4D208EC454} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{29EB3D0C-CE4B-4679-A6A6-15F0A869A026} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2A76DAF0-8148-418E-B761-149BD91EA093} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2A776664-296D-444C-A0F6-EE1A6E97B444} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2B4E5977-893D-49FA-A312-EA75C6AB3965} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2B86426F-0ADF-49CE-BA3C-15BEC0E1E50C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2BC48BDE-83DF-4B50-9937-B029CA9C7A4F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2C004EA3-7969-48A9-B901-64F17C144ECD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2C119C0C-DB1E-4059-ABB5-9AAA131FB24F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2C38BCD3-3D4B-42D0-9138-99F6ED681E5A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2C49DAF4-1944-4160-8174-8F9E123121C0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2C4FECCD-9933-4E9C-AA9E-66A47F5B5975} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2CC0F512-F08E-43EF-B093-CAB21F4AB5C9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2CCBF70F-EFA7-432F-88C4-745DE93D44F9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2CFAC2EB-D5F4-4B81-92F7-66140290B5DF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2D2C3832-71C4-4F60-BEEF-450F2D5B7845} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2D53EC40-AA66-4663-B8A0-28B17445AB15} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2D5AB2E5-94FC-4B18-9329-31D943AC166F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2D76F9BA-8DD0-4AB4-ACCD-3E00A7A7D9FD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2D9FFFAE-970D-4531-8121-BF6A06D280BF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2DA0813B-4694-4606-A9A5-2C7B81B9FBC3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2DA57AFA-3C16-4347-9AEC-4E28E3789FDF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2DABDDDA-E98D-49B3-ADF3-4FC24DC654D2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2DCB2829-9A25-41CA-976B-2FA04E77E0C4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2DEA0FB8-DAF5-4044-86E0-C4507F33F03F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2E33D510-CDCB-47A3-A783-04AEACD31B85} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2E364D0B-00D9-48E6-9456-F82DDB437AB2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2E556887-AF9C-45AA-84BA-BDBA973D5E58} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2E942D78-08F2-4DF2-91D5-1D49666FAE8B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2EDAB995-EF7E-4471-BC6F-A6D285B58256} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2EE7760D-06F4-4549-A9EF-C2A09DAF39B6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2EEB26D1-A469-430E-BE9F-25503D2414F8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2F050FEA-65B3-4FE0-8A84-1D15BA095EEF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2F1E05C2-EE72-4865-93CB-B62AD1CB11C3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2F31EDA4-D663-486E-8E33-03796874E2D0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2F368049-421E-4C1D-A4EE-1548E8A2E404} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2F7FAFA0-AC1B-4632-918C-04A348682D6C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2FA34195-663D-4C3D-933F-5C41D9A27CB6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{2FF2D5BB-412D-4604-8FD8-382F01173BBF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{300B7DDF-7D07-45C8-A3BD-E7D458FC3DA8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{30A00F96-5B22-47E5-86E9-7A6857B37C0A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{30C587C2-067C-4099-A1AA-DC7A1209AAF0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3134A6CC-F409-4E89-8499-A39B2FA289A4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{31586308-C83E-42B7-B71D-F79AC69E8694} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3200BAA7-E523-4C76-AFF9-CAB9BCF4DF01} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3237395A-9905-4B13-8A41-20A16C2FF47F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3238E39A-D639-433D-BDEE-A0287FBF18D1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{323F8B64-35B3-4072-8FF7-41941748E99C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{325342C6-6E18-4430-90FA-1F8C2481E793} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{32C20363-8276-4DB5-8525-0AF291C5FCF6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{32E563F3-8F61-4DA7-A3F8-4AAF40900855} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3342BA34-8A7C-4459-B528-B1DA0F6718F7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3355A0CC-BC66-42CB-B7E2-3D2CAE9C7B11} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3358F0B4-139D-4EF5-BF8A-8D16C4892F3A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{337F6273-3BA5-4D78-B1CA-DD6A992C68B5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{338F5053-9A03-4AA7-84E4-A1A32158DD82} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{33CDF70C-7DCC-4AE9-9D97-02161542EC1D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3419C932-86FC-4C3C-8CF3-23A922753D0F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{34232792-4757-4914-8430-BD35559FAF71} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3455A1A8-E764-4F03-9C83-19D6EB2B54BF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{34D92DE5-7829-4A41-907A-FE8D17122959} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{34F5685A-3B91-4BDE-BE80-0C395D4B778B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{352BFB2B-C805-4935-8EA1-49E7D254D040} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{35631C14-29FE-48CA-9E77-4F954FBA2E13} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3584B07D-1A23-4B4F-9430-2741D26E7820} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{358FDB13-D8A6-4478-A4BA-98C74828DCDC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{35AAD1D4-95D2-410C-8283-FC622A0F6DFC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{35BE85E8-C751-4024-ACCB-08D2FFF65C97} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{35D39A71-86F8-4CD2-A62C-1C8979A7D41F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{35D558F0-66B1-4C4E-875D-E9FA2AF24B74} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{35E04C35-8DDF-4429-AE3A-FE91E38BE1C5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{363844BF-12C3-434C-A78E-37108E72A437} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{364F692B-A192-4AA2-B1B3-052A93BEB6F8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{365B8F61-7A19-4481-89BB-B3D6ECC9E253} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3686667F-62C4-4C00-A8B2-C43EB6250AF5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{369FC8A2-75DE-440D-B682-BE7D8B6176D2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{36A84903-7B8A-48EF-9967-93421BA564E7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{36BC8E12-3ACA-4C01-868C-E8AE5F369767} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{36C31A63-4DD0-42E5-AF9D-0927EAD10152} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3731FB3E-623F-4309-A8A0-D677600FC7C7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{37513DE2-24FD-47DC-B8B6-C811C6C723A6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{384B8271-ACFE-4AE2-9C59-A0986D9460D2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{38906D6F-A7A2-4DF9-95CD-28A5D5F294B8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{38B5FDD8-C528-42A4-83E9-675426799C7E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{38BB7812-9FD7-4A6F-93A9-C8F8984C7691} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{39370FFA-F396-4DE7-BA2C-0D31DB35CF5E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3953246F-FD4A-4CD5-BB8A-4CFEE1AFFF20} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{39945D49-E6DE-4B47-BB1D-E7EB590C5CBA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{39A74C54-D871-419F-A5A0-764D2E79BB7C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{39C8F025-FBF9-4FAA-BBD4-1BBF0871228D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{39D48235-C6BE-4F18-A190-C7AEF70FD8B8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3A098ADA-4F78-4602-A7FB-A8C2169FE61C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3A1FAA66-9A57-47A0-BA7E-CA5E33782801} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3A29D8A9-5856-47B6-8516-E8B23E0226E3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3A5B2FCE-F394-426C-A16D-3B03FD5EB7D4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3A5C4464-2F88-4AAC-8CCC-752C323CE91E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3AA7DA62-73DD-4553-B4C7-87BA1B2DB041} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3ADD0451-5DA4-4DE9-9308-57EA79D641D3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3B55C1A7-1CCE-47AB-866F-BA3B36FAEB39} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3B9C12E0-C69B-4018-A38A-35133A772B9C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3BEF662E-21B7-4132-83F2-A596DE1D2939} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3C3727B6-FAA5-45D0-AAD3-88587C65EF3D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3C93288E-F85A-4CC9-8008-BB57AE7B1581} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3C94A1F8-A30A-4F0F-8DAC-0E2FEFBF5379} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3CDD224D-5E5D-4398-A11B-03A10B980DB3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3CF8C0A3-B8C8-4182-86BF-23D8988B9576} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3D583E7A-0982-4575-8C8B-64F5085C74EC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3DC23312-053D-4076-9714-A34A2D042D76} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3DD2F418-058A-456C-840A-4140E4368501} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3E3D3DDF-D32A-4E8F-9058-390C599730F4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3E484457-7B5A-402E-BA41-30A74A28624C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3E7548D1-54DC-4E73-BB30-804D5E265C09} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3E92EEAC-10AB-46A0-A783-57D2D8419799} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3E93A330-5CEC-420B-B4CB-3D190D8A472C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3E980572-E832-4916-A5D8-EB6BDD8CE66E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3EC12433-A4B0-4E12-92E4-B25BDA1FF832} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3ED1F291-CE69-45BD-A67F-4C629080CAB4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3EDEA684-5B25-40C0-A44C-2CDFBA16B7E1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3EE4D91E-0E3F-475A-BE33-43ECFE2FAAB3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3F1836CE-077F-41C1-9466-31D6AC95FF61} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3F5CACC7-7C70-4D61-9A02-B74200EFE681} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3F6539BD-6077-4652-892E-336DAEA2475E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{3FA8A2F8-4269-4EDA-9789-A8A809C6522C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{400ADB54-7C4D-4438-963C-A10DB57DA3A1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{405179E3-B941-4B04-BE5C-A54F5DE4E816} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4052563A-1CD6-41B0-8F22-BBDCA82A02A0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4064AF3D-3FD1-4308-9B0E-3BACA48E1D4B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4075DFF7-7BFF-4E1F-BC4C-3C2452FC7E08} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{40A9D092-DDC9-445A-BEA3-B1C75F3735E4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{40D816D0-B7F9-4715-A764-1FFA71FEC3EB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{40D8F3F9-A9F4-49E3-AF31-18E1E2CA0907} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{40FC0FCE-DCFE-436F-BC08-597A587ECA2C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{415AED6E-1CA0-439C-BEF8-1C5C07517CEB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{41D52F0E-8DBC-4181-974A-CA2A61DEFE07} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{41F57C80-B74F-414D-9C9F-3B2B9EE8A5F7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{41FB041B-50D9-4757-9518-31FC50E9C91D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{420EA507-0407-4014-8391-B7DF34F0E913} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{423C0204-8C19-45D9-8515-D3BBEC866A3C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{42448E57-FB5B-49BB-A8F7-1D9E85E93999} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{42A160E7-A735-4F3E-B4D4-8B7E17005097} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{42D27893-10A2-49BB-8575-F0D436DCAD6A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{42DD85E7-1E8F-4200-8D0F-F8954C9BD59C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{432BAAC7-560F-4C23-9495-BC054CE6696F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{43D4B7F0-A495-429A-8E97-EEC0F86EF4AF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4418B103-AB4A-4827-B1C6-7E58605103D1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4437CA53-E4F4-4E78-8B9B-DCCCDCA22C79} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{447D417E-B76D-4D70-B6AC-614F1206F85C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{44CC3AF4-DC7D-47EA-BFC6-448572FF211E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{44DB8DD6-CFC9-4822-8BBC-EB73C30FFB32} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{450BADB2-20A2-47D8-BFA8-B431740F7B8B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4515F8E1-6A84-4FF5-B65C-90280073DB57} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4516F9B3-26AF-47DC-BF78-16921C226899} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{45176D26-A562-46D0-A0D0-B13F0495250B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{453AC48C-3F96-4C03-AE92-3E704F3D263B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4541886C-E12B-4CCB-9D48-690B2F4B7E06} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{459120EA-6592-47E8-82E8-4C824F21FA8B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{46125E82-37F8-44A6-AB1D-34C96A24ED13} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{469CE497-237E-47AE-9243-1A36CEB1C856} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{469F1781-4236-48BF-A321-6DE729F719D2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{46A4B2D7-7158-4772-A2F5-26FCA406D38B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{46E5045A-E1F2-400E-AA2B-1E4CEE3FEC84} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{46EF93F5-A582-4441-9078-FCE11C1B97D7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{471BF677-2DAC-490D-8071-08EFA57047E4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{475C7E55-49B1-46C0-8B35-1DF652286191} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4766FB21-8417-4C6D-B898-C4BE4A447C55} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4771DBD7-D028-4C31-866A-42AD6A8EE1AA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{47ED78B3-963C-4A92-85D6-6F3FEDD4536A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4805F0AC-61DB-4480-BF51-71B33294DF3C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{48111ABF-4217-44FD-A975-7966A0793D6E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{485AC046-8655-4632-A4E4-47AE60119A91} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{488798A2-012D-4D97-B5F1-21A0DD3DE75D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{489236BF-B356-4ECF-A0AE-E8BFF8665F78} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{48BEAE9D-A758-4801-85BD-5573EE21036C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{48F6259E-4787-414F-A69F-77BC7EC2B6F1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{49724A69-D352-4557-B40F-35AB36211212} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{497D646B-4C1E-42E2-8D73-800B6120E3B8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{498B02F5-42D5-4994-9C1C-0A8447AB74C6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{49ABBE60-12EF-4F70-A2BE-47A5BC6F73AD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{49B91414-C9B1-4FE5-9304-A1EA37E82F75} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{49BD6221-F6B2-4220-9E3A-C295279C37B3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4A23646D-7C06-486A-8E1E-CFA668A8DECB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4A566AF5-B59C-4FD6-BC51-6FDB0B6FF52D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4AA2AF1D-E70C-494D-ACFD-76FF507B8549} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4AC0D3C2-2007-4C32-AF27-C324D17B3B15} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4AD9B938-5AC8-491F-9E3A-7AE283CAE950} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4AFDC8C9-1E17-440E-97EE-08984AD4627C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4BCC82EA-F722-4B98-BB25-3E85F5F98601} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4BF3B1A4-54D6-4090-9D0C-F0039D119F4A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4C42C486-3134-46B7-BA17-CFB0F46141ED} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4C460C36-E52C-4E6C-978E-A5B47BC56C3C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4CA68B97-CE68-452C-8FFC-DA04C865921E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4D616C49-5F01-4B4D-A2AD-CA6D70F43311} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4D702BA2-1EBC-48DB-9580-7C0A9EF88B0C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4DF26A24-A934-4761-B17A-8F19CF1FA16A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4E41826B-4C71-4EBA-90DA-4333427C027F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4E82E4B8-E456-454B-902C-6BE66197B834} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4E92F801-C43A-431A-860D-8253F0BED85F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4EC66415-A23A-496E-847C-C7AF01238DEF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4EE52C6A-A914-4947-9B16-AA48C001D113} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4EE67263-4F03-4717-9CCA-8B35D036CAA2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4EF65B8C-4F14-4677-853B-B7A60DFFE18A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4F798DC3-361A-463E-A4B3-279687C7471E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4F9ED79E-8CC3-4F62-8D8A-344D7F19A307} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4FB78C94-8F7C-4A44-AB7A-6DEDD480D312} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4FC68D5E-0EB1-446E-AF35-E243863E7368} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4FD5E10D-693D-4CDC-A9B5-A6414ED0EE8F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{4FF40F1C-6D05-43BF-B2E4-93E9363D1B14} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{50086AFF-A436-470C-91E1-49215C290DB4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{500F9B1C-AD47-4875-B0A2-B532111B4D2B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{504E7134-D62E-4762-95AA-B169D9E6615E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{508E74D6-4060-4F68-8A79-BD5A5246E59F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5120BB39-A5B6-4686-9150-9CF0917B9D7C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{51385BEB-DE32-45DE-AC4D-451D67DDECBD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{513B63CC-0AC7-464A-8806-FADB97916F42} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5182BBFC-01A1-403E-B78B-897E1EC02493} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{518A15F5-1637-457F-88CA-63189CC878D1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{51C96829-B891-4C25-BB32-03CA79EBA199} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5202EACC-4FC0-4CD9-A743-BB8753BA6483} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{524C8EF1-36E5-4D81-A1F9-6B08AE067D8D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{52ACEBC5-25C9-41A3-8460-980985644472} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{52B109C1-B9F2-4E15-9D1F-8B792E3EA169} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{52C3D515-4CB9-4877-B8AF-B97109FB973A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{52C6C4F2-0AA8-45D1-A41C-DF8790B6E9CC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{53097F4A-F3D1-46A9-8FE1-D3038A524901} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{532AF9F0-8342-43B9-8C98-CDDA14634906} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{53457A3B-1374-4458-9165-F7B62DAC76FB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{537214A9-8E84-4814-AE27-1730A2E9802B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{538E74E0-24BD-4910-8696-30119BE4CCBD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{53A564E2-65BB-411B-A19B-5558CE9AE0C2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{53D0CCFF-7A5A-4519-A4F8-6242BD57A2B2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{542B39C5-0981-4C0D-90F1-69F4F41CAF38} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5446B6FB-72C9-45F5-A639-7E705639E3B8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5462B497-D2EB-4AFC-B9B2-6C7C0C7223ED} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{54D192D9-F4C4-40C9-AC50-15A0C1133A5F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{55031BCD-58BC-4301-A8F1-6D787C5A6CC2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{55404490-05AD-4F38-BCD3-504D484AAE94} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{55AFDACE-A8A1-467E-96A8-794E37DE6F18} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{55B2E7F5-08B4-4F7B-A289-F7FDD5F7E2A0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{55D4CBD6-CDB2-4CD1-A13D-F83174347F45} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{55DDA15C-CA42-4BF3-A52E-DF2D01451EF3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{55EFD70C-CC2C-4DBD-A5AC-7DD365F3B4ED} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{55F03448-17FF-47C4-BCEC-AF7887FDB129} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{55F4E578-330D-47DF-A887-C6E7AF459742} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{55F6BA16-B6E8-4FEB-A44F-A9C7294F10FF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{566FC0A6-B87C-4BE6-B914-A9587A637AE4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{56B2B5AA-C539-4CD0-97AA-1427237FF701} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{56CBFDFE-D9DC-46AB-8DAA-CA5FB74F2B89} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5733B5BD-6080-424B-960F-B74555B2D84D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{57347A15-8868-4733-801B-946D47D82BA5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{578BBB77-8785-4DD6-81AB-5375A70FB81F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{57BAA106-AD77-4BD5-B3C0-8388C92A33E9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{57BDA23B-E537-4593-B076-2E9503733222} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{57F60E49-217E-4A05-9EF5-4B6E90BE9E83} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{58190B47-98B9-499E-90D8-5F8E247C4835} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{583930F2-695A-4E33-9483-ED84D06F5255} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{584A564B-34F7-44AA-994B-6F7DC7435C48} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{58BB9CE9-FE14-4A35-ABAA-4B84520F73E6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{594FE670-E64E-4F4E-99F0-828E7613F713} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{598E4CEE-B145-4383-A013-A20FC0DD1526} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{59ACEAD4-E20F-45B1-86F9-4C1B6EB5A321} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{59E1595D-2795-4646-8953-06798BB2D487} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5A188A83-C674-415E-9AA1-D56536EC0524} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5A1DF702-1EB0-4262-A3F1-78BB02A38779} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5A8DDC93-873E-4052-87BF-BF6A37B26A9E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5ABE1793-886E-4505-B256-25B5A851BA42} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5ADF17E9-5F00-49AA-A5B2-D1BC84B9E46A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5AE301B6-318E-4083-B1B0-A038E406DD47} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5AF39B3F-16B2-47E4-865A-8B6F4CE992FC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5B6E7A35-87A3-448E-A981-46BDA68BF77E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5B7A7853-26E7-4FCF-B6CE-D29305E2AB0E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5BEC6962-4304-4474-A388-CADEF0F51B9D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5C341C64-F35A-4BE7-8E02-A8BBC937FDE5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5CA331F9-8D60-4CAA-A303-BC85CD4194D7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5CA95DC0-E013-4B76-A725-59B548D3DA5A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5CDDDAF0-8B90-4F2E-A1E9-D924ACF8EDDE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5CE5350E-E1B7-4C52-9427-E07020D22F01} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5D0CABCE-4324-4AF1-AA06-5A8016F40867} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5D23141B-1259-4262-A35A-D02FA9CC924C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5D521BC7-1700-4C01-8AA4-F4D4E93CF4E3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5D7CD57A-8FFE-40A0-AD69-84F9783D99FE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5D8DF696-4EB6-47BD-ABDA-47F0CF75C068} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5DDFBD4B-4BEB-45DB-89D6-A152871A9F13} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5DE29440-CB58-49CC-B964-8A3341C6930A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5E08991D-23D0-437C-94F6-9945DBC2068C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5E27CB52-476B-4F99-AB6E-488576CD8190} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5E606983-3353-4DEC-9168-1E1AD43AA98E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5EA8EFDA-3881-49EC-A80E-0EBEEE564D90} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5EB6DBD6-7609-4E3C-9B08-8B19EE6D899F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5EC0E443-9853-4457-AD4C-F7415564815E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5EC31BC3-F59F-4AB4-91C3-67455799146B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5EC93EB6-D7F4-44DB-8DB8-FB5EFE9C658D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5EE9427A-2666-41DF-9FE9-4128C8ABE0D5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5EF797F3-6871-4600-961A-24BCB0EF88D4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5EF7F7C2-D8C0-4839-BD4A-7B241813ECD9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5F20F93E-3C09-4B86-A10D-1C1074FAF1D3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5F2E20BC-3480-434B-AA75-37B0CF280B29} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{5F63D90A-9821-49C7-BC71-B104A24BA555} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6069C204-21FA-406C-8E9D-2BFCCAADE1F9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{60FDB66F-DB56-454E-9095-F66D227CACD0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{61418A4B-FAA6-4521-A44E-2EAECB181D42} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6148BD9C-0E02-4245-A049-AE552CD3CF0A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6189A7A4-D6C8-4BEA-AA66-777CC2CC94F2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{61CABEAB-E843-4B38-B857-3BF3C3668892} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{61CC03C0-2518-494B-B824-D2E955580CC5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{621B9F6C-4424-42E3-8114-15527296C182} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{621FE634-2541-419A-B19C-74C53B1CB697} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{622D007A-F3E7-40E8-AFAB-08BC46DD01FE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6254937F-6522-4542-82FC-FF94ECD66F75} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6254AE7D-6CA7-4942-ADA3-25BCE9E456DF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{628A29C5-3C44-46A4-9CDF-8AC236C63383} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{62EB4BBE-5B03-44B0-80FB-FE040E59EC8E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{632EAED4-A701-49CC-8997-28D3341A7906} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{63E992A6-0358-48CA-B4B5-339CED9FF3ED} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{63F0FA44-B873-48B1-8CD0-BF9F22FACD6E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{63FA0A48-A951-4BB8-B473-129F7ACD81D8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{640E1DFF-0B0C-488D-93AF-09DEDAF409BD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6411E811-DD61-4351-AABD-6383039E87B1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6415ABDC-92E7-4483-98E1-047412D9A46A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{643EEE55-E866-4F68-A943-3B0B5B333C7F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{64B73553-0A7B-4C1B-8976-613DE75E1C99} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{64EFDD13-F292-43A7-8D58-1BCA292599C1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6511B221-9C25-4DAF-B1B5-692AD99D0BB9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6557096E-3281-457D-820E-BD8E27BBFAAF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{65844EC1-8FF6-40DD-BEC2-8ABFAD7F51BA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{65A3ED19-B1A7-4427-B2CC-AAF7B8F32655} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{65C811BA-570F-4AAA-810B-B26A91229AD3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6600DAAC-A02A-491E-A5D5-82684A9C4DE7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{66061C42-ACFB-4DE3-804E-61727E1D9422} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6606F495-7389-49AA-B78C-8D5EB5FA73A5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{663087F0-4FD9-4E77-B303-15FE7B2E152C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{66365412-16BF-4030-B03F-5152B86F7721} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6648E6D0-B398-46E2-ACA9-F434DF0C3F1D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{664C900E-FB91-414F-B18B-467BC8D2BB83} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{666034AD-73F1-4E56-B76D-42789704D341} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{668A6CB6-5CE8-458B-8740-6524047FD5EF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{66AB72DC-0E8E-42A1-90DF-7B8955F309DB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6731013E-0C2B-47FE-9233-F5FE09AFBC70} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{673C93CF-579D-4180-B830-D9BC2CAD9DEF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{675AB79F-BAE1-484C-BECB-3B9FBB749F6D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{67A19FCA-3DB9-4CB1-B458-CAD2013B0533} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{68049C59-8B72-4D7B-92F9-1149B629CDD0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{68745A6B-45CB-4E1E-8503-AE5306CE4912} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{687CD915-B0EF-4B20-9177-FBD283D10A85} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{690F0974-3E7A-40E1-A701-EA63B61CC0C7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{692AE442-7953-48F9-830F-4FB4BD8B28FC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{694504D2-367C-46F3-BF61-70028063CC06} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6A0F3363-7C5E-4DA7-9EB5-F2FB0F1DDDEE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6AE5CD3E-E613-4435-8BA2-C6BA878F04BF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6AE9D0A5-6C69-4EC6-82CE-00A3F4DC9962} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6B6E5B1F-755B-4B2C-82F1-D55A5EF46EA2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6BA44121-373B-47D2-932C-2DE78CB1FCF7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6C37A1EB-9025-442E-B1C0-E3161850876B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6C67A2D6-52D0-45FA-BD0C-169E9C8B1088} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6C68EBE5-EEA1-4C0E-9C65-359E40ECA5A2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6C6A1030-7086-438C-9940-5B911AAE23E2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6C914F2D-5CBD-4B60-8040-43B22A5E2E72} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6CB03EA2-FE34-455D-87BF-F3A426BBF0EA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6CF00AEE-E8A2-4C88-B3E0-AC39B289999D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6D2EAE7C-B653-456F-8471-6EA6F7C12954} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6D3CC4BF-4637-49C5-AB88-65E809969FDB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6D9B917D-2143-490A-AF92-8122478987B6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6DA517DD-C781-43E1-A3C4-383C6C19B113} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6DEC3E2C-0AED-45B1-BCD7-FE357E1721A9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6DF45E28-E663-456F-B523-AB8EEFCFEC4B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6E53F843-83DC-491C-AF38-445F9A3F122F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6E58C893-C9E0-4D09-94CA-47B32137589B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6E9E52D1-9E90-4204-8F8A-5F3512E1F812} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6EB3D602-A8B7-4890-89BA-1FBBEFD59FA1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6EB539B8-2E24-4F66-A427-7743AAE23F50} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6EF0F9D7-64A2-4BB1-B91F-6DAB42AA4AC2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6F2405CA-DC21-41D0-ADC5-66F5192BA721} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6F27DC51-696F-4645-BE0A-EA5811DAC1BC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6F38BC08-2276-4968-98FA-AD6C5B14139B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6F78C823-E55A-4AA4-840C-F031366C6BA0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6FC1C4BA-2693-4EBF-8D0E-EE43A3561E68} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6FE4F7FF-7FC4-430C-A0B7-7C8782451045} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{6FFE6978-967D-4276-BC53-4FCAF9A9E060} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7006ED1B-687E-46A7-A537-B94DF2058850} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7008A4E3-53DB-4C41-938F-9AB2362E901B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7020C63C-3DC5-4E63-942D-5ED3FA71DB40} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7027E682-ABC5-4502-97CB-DD81FFA9FB03} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7051436F-30AF-421D-A166-51EAB6F014CA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{70926AB6-35BB-4354-A61F-281709D13BF4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{70D12548-4552-4624-BF9E-84864CCCCB8B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{71038911-5C6D-4A69-9D02-B4B1588A18BE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{71121D14-675C-405B-AAD7-D7E8629749CA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{71730AAF-F21B-46FB-85A3-D7502E681511} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{71CB4996-5D61-4533-90B3-BF5D6B1FF2D3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{71F7F06E-7883-46D9-9312-40DB46C4C911} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7209FDB5-89AA-48A6-AC0F-6A1E55D2BB65} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7211A8F1-9FE8-4E60-AA34-24710EA63F03} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{722CCD6D-18B0-4CAE-ADAE-B7D42F29EA06} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{728D7903-7ED8-4B5E-B504-02DCED5594E2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{730D9A21-F654-412B-AD69-DF4A43508CF0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{732F0165-C1C8-48F9-A5A6-95080589AA47} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{73362AB3-27C5-452A-B673-F447BD3B4573} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7387A915-2B0B-4E7E-A857-BAE5A704211D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{73AFBE90-924C-4767-ABCD-8DC00751BA2E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{73C1ABA7-83EE-44C4-AD1A-1DB822C5179A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{73C38685-6375-4577-9E77-6750084D11D9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{73C7A047-05AD-4098-B76E-90B3732EF748} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{73DC3B41-886C-46A2-BB68-6BB1082BFDCA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{73E89831-89C7-4BB8-A3FD-57FABBD1A4DE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7433BE25-2051-4614-9828-23BBC941CCCB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{743C66B3-D7BF-4259-8DBF-DB2019B731DF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{748A0360-8395-4B23-B792-21BF9A5298EA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{748E04AE-1831-499E-94A3-D206780F7BCE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7496EA04-B529-47FC-A0C3-296AD1CE81C6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{74B171F9-2EBD-438B-A6B8-156252B19311} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{74B6EC24-E9BC-40AD-8B37-D033B89F4DE5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{75062E6D-A191-4D1C-AD5D-9618F88859FD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{756844E0-9CAF-4303-A648-5F1949E0E2DC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{757A9A1A-E7DE-4CC3-B31B-C348DE2D9573} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{757BD24C-08CE-466B-8331-7B73F6289F96} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{758209A7-6783-4C05-ACBB-B26A75FD14C2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7592DC40-EA64-4C7E-B5A5-3B21C43E612F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{75AFDED6-F5BD-4D42-B178-504D7F0818FF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{75BF54A3-149D-44E4-B0EF-090541117D28} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{75E14645-3732-4370-9C2F-7B89C7686AD4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7648916F-DCB1-43FA-A982-F2759B3019D5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{768C9885-D6EF-4301-966E-2143A1C1649A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7697A129-F554-4050-8746-6C742C39BA57} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{774509F9-2139-45A0-B884-5847FA2F0509} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{77E2C162-F2C5-44CB-8CA1-27A67DBAE0D5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{78A27F47-16D9-4B7E-AA71-E6113755F527} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{790E4F1B-45F2-43F3-A1BC-0D2842C2EEBC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{796D03C0-BAC0-49F7-826D-7CB519351BDE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7994496A-5DE5-469B-987F-269EC3750A31} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{79B9D148-A93C-4F72-ACB1-E13CE4AD59A9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{79CC8C0C-A4DD-45C5-B834-920F7EFE4125} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{79E02761-1F71-49DC-A925-A7841F6F6093} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{79EE3E81-8698-419E-9785-4281C0F20EA9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7A18A609-36F6-43F5-BE2E-951D4A0FBED0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7A332745-1C60-4B16-A3A2-78E66D975F8B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7A7B99C0-365C-46A5-9558-6BD4D24BA046} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7A7C13E5-857E-473C-AFD9-3121BA7D1863} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7B1B8901-1FE2-4900-A50C-B87A65555F35} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7B277DFC-6228-4571-B786-12747A2D265F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7B36B49B-6173-4EBD-B4DF-EE47065D1C70} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7B37FB2E-FC90-4E38-828D-9BC5D3059D1C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7BBFCD26-776B-4294-96BE-EB02F5AC4985} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7BF5276D-B8F9-4BAA-B9C7-10931161BFB4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7C2C2C89-1F41-456F-9CA8-652769D5F3E2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7C49B76A-3A35-49B0-AF03-BF8CBAE90F2D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7C841772-0933-47FD-908B-B42F580B4A61} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7CDACA88-B263-4759-8ED9-C2106BC59EFA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7CE3D7CF-8400-4A50-88F9-11F0C77C2831} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7DDC5D03-7C46-4672-AD67-C06578493759} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7DFF71D9-220E-4A7B-BE23-2F6C8DD408DC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7E312A67-D0EB-4415-ABF5-F680D6CD6667} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7E89CE97-B81E-4847-9D33-7DA782251A21} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7E9F287E-DD34-4C7F-BB94-C9C7573A5C9D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7ECF7ABB-23F4-4FA8-914C-08360D6FE557} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7EEE06DF-3A95-4945-A250-8DA23D101B45} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7EF5C9A2-41FF-4CF2-A899-3F23763FA14E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7EF7F466-2519-4753-8C8C-6F0CC915FB98} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7F0C18C2-B384-4DE8-A2B5-DFECB44CBECB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7F58D3C1-C7C5-4A8D-81C9-ABFBEFC2AFC6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7F922A27-765E-49C5-83E0-F06B99E5C1BD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7F9BADD0-E44D-4F07-9C05-3C70CC5F3E76} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7FD52D52-6804-43BC-A875-49C42C3DE848} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7FDDA335-EAF9-4581-AC6F-E9ED925CB5F8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7FDE5499-E910-40E8-B609-88256FBA6074} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7FE54D1B-DB19-43B9-964A-0E0583E92A10} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{7FEA3DF4-8AD4-47E4-9174-389ED284717D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8001040B-9D2A-4D5A-B375-46406BBAE1F9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{804387A3-A488-4318-9F6F-5EBB5E428432} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8057F71B-24DE-47CC-A00F-1E4A097C672C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{80C44045-DE7E-4C71-9EA5-E7EBAB2AAE78} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{80D40B0E-51BA-49F0-A2B6-0F84115C5EC3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{81875FC7-DA30-40EF-8542-978728B0F4D2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{81877559-F9A2-4318-8457-9F2850C6FF43} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{81D14B20-4495-4BF6-9C2F-94FFC6FE7DDF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{81EA09CF-C3C5-4D16-BBFD-5275AB3DD0F6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{820A5821-0145-470D-8039-B34C65E5887F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{821645EF-5B29-4E54-87AF-A0B8399AACB7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8222F11C-E625-4ABE-96E2-D160823C5AE9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{825D9CA4-1774-4F54-9A78-BD2A8102798C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{827FCE84-2494-4D8D-B7DE-BF2BD5025C32} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8311D558-FCE6-4096-9AFD-9B56555C6E2C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{833BD959-52C4-4003-887E-1E9E02F19AF5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{83966C69-575E-4C37-8B5E-9E9438AB8EE2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{83C1A57E-A2A7-4522-83F5-B9D9846785EE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{840D9F8A-D8D2-446B-807B-0614E177EA84} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8439FDEE-CAAB-4E57-918C-3B5596E1CA7A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8443C746-0DF7-4994-8090-5A1851D35AD6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8445A7D1-FC12-4761-BF23-8192001CDC6C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{846A29F0-DF04-4399-801A-026991490514} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8482CF75-2CFA-4DDF-9137-51D1FA9F6275} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{84C1CDEF-874C-4A30-925A-D1D18042A11A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{84F61F29-6791-4DA0-802C-9AB5C81F4478} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{84F86052-E498-4720-9292-5EFD20019A97} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{85410C08-9EF2-467C-9AF0-41E4556C687F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{857C0611-24C0-4248-A089-550E16A2097C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{85865A82-8E82-403B-AECA-12928D32BA4C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{85C94C66-5F2C-4E46-B44E-5FE340B548D2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{85DAFCB3-79DD-4027-9A34-AE291075F36A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{85E77535-D93B-453B-8457-830FE9F6EB6E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8671F1EC-7D0C-43A2-BC39-9C9373CCB8CC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8674030F-1C81-46A6-A9A0-756FD318D53B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{86E61FCC-B32A-419E-AE85-EDC57D034BA0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{86FB969E-350D-4D90-B95E-DE80CF473D99} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{87040070-9EEA-485D-A620-8E1EB821AC2B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{877FA722-CFA6-449F-9102-AFB743314592} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{878DC37B-5907-401C-8A39-FFDE19C74197} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{87BC9FA1-A4E8-4BCC-A246-0202483BB746} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{88510875-1327-4F9A-8E29-5A6421EEA503} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{88546A96-5C00-44BF-88FA-A677ED3E334F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{88E1F5E1-E696-4C40-BFBC-2906CAD0196A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{89007182-8720-4804-BC98-B62138960D37} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{89378FF2-F5D6-4E3A-8FE3-D1C5A770ABB1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{896C1649-8CFF-44CA-AD3D-9854E0380C2B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{89AE6499-320F-4227-AF41-3588AE87C801} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{89B06C57-7B10-4E7F-88E4-9188D16571E2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{89C05976-5ED1-43D5-A8F3-35FA4E6D3388} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8A1CE6E0-8976-4F25-B927-D042AD3201F3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8A5AF6AE-3431-4476-9ED4-56A61B98C1EE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8A819D84-DB83-4745-9971-C35B91BDEB22} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8AA8FB0C-D831-4393-A562-64867D70B58A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8AE41BE6-E4D0-4404-BF31-D8B4C850878E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8B120834-57E4-45D2-B776-364789880BF4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8B58B623-6EF6-4C10-AC9F-3786365199E2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8B630D82-50E3-4A6E-9721-BE3B336329AB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8B70353F-C319-498F-A2A4-2ABCD0E8290E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8BA13E4A-4553-4902-A81F-DD01CBE5AD79} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8BFF2810-8AFF-46B6-99E5-08019AFCA4F9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8C0B7200-F7E4-4BAB-B700-C786DF3628C9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8C14504E-D000-4E3C-828C-58D63148AD51} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8C1574C4-9DC5-4175-8716-21F1E7D18E4E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8C20D0FD-884A-415A-845A-9190F3381F76} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8C231926-35BB-407C-8890-D16C35BD6A74} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8C777B51-C047-4E3F-B261-EFBF398D117F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8C839443-54E9-40BE-86BD-17CDF648D13A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8C8C91F4-C135-4969-AE52-CCB60D3FB305} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8C9A10BD-40F4-4A88-8D54-EF7501C0293A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8CB44036-1967-4A13-A953-B6859C1A692A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8D1C4EA8-F888-4971-9D8E-DF85C223DB60} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8D3BF31A-DB57-4292-8367-27650A50B53F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8D3F6E75-49B8-4E6A-91F8-DCDE094D5BC1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8D5311A5-DC89-43A7-85E8-6E3423DFCE22} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8DD487F5-C389-482C-98C9-2D43E7059B44} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8DDAC5B4-DEA7-4F72-B88B-F7250A010C72} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8E5D4206-2CBF-4678-9AE2-B912BE5D4207} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8E5E10D3-B75E-4127-AFAD-1CD76EEFFBB4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8E6C6B54-D9E7-41D9-AA5D-4D776B9C5379} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8E92AC75-BCFE-420F-8427-DD0CF3933BD1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8E9FFA64-1C55-47F6-A534-E40CE664AFD6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8EE6C6CF-1984-4FBA-A507-A2054300C2D6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8EF1451D-B517-429B-A896-9F29D7864127} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8EFCF36B-A24B-4F11-9E5F-5C36F9E4B1B4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8F01A5C2-98F7-4580-9604-6F299FA9D926} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8F2BAB9B-1ABF-40C8-B8DB-FB76C32A9C26} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8F336FF5-F131-40A2-BA84-43607D53865C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8F9E6566-F5ED-41BD-B5A2-C4D49B8BD86E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8FB28BBD-78E4-46B8-843B-64CC0A26ACF9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8FBFD45D-7662-4EF7-9447-F3FC8B202B77} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{8FEFF1AD-6ACB-452F-BB40-E1409F8AF3BC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{901D42A9-9DB4-4633-8A42-A2823F58A01E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9033C9D1-4823-469F-9F60-55BA88181626} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{90D40A2E-81AF-48F3-A6B0-597C6C741147} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{90F5B342-7185-4FA3-9284-8EE41E65DACE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{911B243F-2D8E-4497-A356-146A208C52FC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{914BEC64-D3C6-40C5-84B6-33A05D18F3F9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{91B18221-D4E6-4AA6-97A3-59ED218EA038} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{921D5C11-0DB3-40EE-9367-B01BECFE97C8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{922D2CBA-D53D-48E5-9BF9-1F335311C24F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{923B514F-1606-4FB8-884A-35269DDD3FFA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{92501134-A263-40AA-839E-97F80BD3D596} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9278457D-B51C-41AE-83CA-1BF87821B004} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{929BE7B9-D1A9-4E35-B1A9-F20AD65D7040} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{92A78C98-5BF7-4687-946A-729592F53679} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{92BFC3DD-8CC2-4A5D-AAB4-6A0CECCD6778} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{92E0F7C9-806D-4C7E-BC9E-41E06FA9CC70} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{931CAE49-399B-4F0A-BBB8-AECAD7147CAC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{934D96C9-9811-4FAA-9C1E-E045C5262BF3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9406F315-14FC-4FAC-ACC5-452ECF9B3956} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{94188E61-21B0-4C15-A870-0CDB431C7391} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{941CF8CA-B7B8-4D51-9F43-00A8C8C5F17D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9421D4FF-ADD8-4054-AD4D-9518C7DEBD87} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{942DAF27-25E7-4682-B7D7-10C5FE8EB2F0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{942EE94C-6522-4ED9-8DC0-6E16F2438023} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{944EB25A-7889-42D3-8E91-62B835295500} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{949E6731-6745-4EA0-A289-F6BB8E464442} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{94D93528-135A-40BC-8EA0-AA07E166ECFA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{95269C40-7914-4BAF-94AF-D144930C65D4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{957DC5E1-6E1A-43EA-BA9B-D5A87E1AC46A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{95B4D75C-D3D6-4CB3-8E12-9AD7AE0E12C7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{95D360F4-9178-4E0B-B7E8-510665E4F7F1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{95FD37E4-F638-48CA-8F35-CE8A329163C4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9681E46C-C82A-4256-B9C8-03062BE9A430} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{975F1EA3-EFBB-48C5-B3DA-8E21C58B1FAC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{97A4DF70-8FDF-40D5-8A2C-E6EB02DB04C3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{97D3F021-29A2-4A6B-855E-C7615E930D52} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{982136F4-C564-4172-9589-075879B67321} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{98EBA3D0-D2AA-4206-A8C9-AF20D6ECE6C7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{98F9F845-7980-45D4-89EA-4BA1C1BB5C2F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9929E1CF-10A4-4654-91CC-37F2AFF6B7CB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9959B372-F0C9-44E6-8FA8-E3E25047D747} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{99833A68-BC57-4B9D-9026-7F2AEE761383} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{99D43219-8038-4D8D-9249-9150F7B5D329} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{99F11DC2-8142-4915-BEFB-D846615A5A2F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{99F331FC-0B11-4B7D-BD55-84D53C3557CF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9A03478B-F3E2-4461-9F1B-B436AC8891D1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9A0F2A6D-A1D0-488C-8380-BD712EC9108B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9A293646-2975-40A5-BDC6-7C9626734C49} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9A43CEAA-EC72-4FAC-ADFB-27FD7A819B36} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9A499268-6EC8-4BAF-B4F1-4D3F46692053} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9A94ABE0-992F-4C60-95E4-A2ADB0343AA0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9AA3FB71-9046-470E-863C-43A51C472A3A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9AAAE729-4EA7-4EE6-8CBE-2C05018B82E0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9AD953C9-11CA-4831-907D-82ADDF14F3DC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9AE11A78-C662-4DB7-B75E-A26B9F370847} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9AE2AE9A-6EA5-458F-B20B-D706A7EA2257} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9B0247B8-D242-4F9D-9E3E-5F1975C59B67} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9B655DAF-6A36-4557-B3AF-443D32438C0B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9B96CE83-CDF8-49D8-BCB3-6D402D35F92F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9BA3B281-726F-47A3-960B-E5F84A4A0798} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9BAD6DBA-88DC-4065-A425-E46CF063916D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9BB16A56-BB5B-4FDC-8C02-E240D0792AFC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9BE7A770-719C-4B72-87F5-E5A0960CA9A1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9C3577AB-4E3E-4821-8352-07B08CDD078A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9C74B3F0-7063-4AA9-83CD-949D5D0FDAEF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9C82F605-1AEB-4B84-A241-8D944FEB4A83} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9CBBBC70-C404-46A2-BEB5-0431C9B09AA8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9D09E0EE-FF07-47FF-A34D-CB16601B8EC4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9D0E1F08-B63F-47BA-B04B-3B9CA0AAABA8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9D178B05-C457-4B4E-9553-6FB0AF19E9C6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9D20B00B-98C8-4A56-A151-F38CF7FA9524} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9D83474B-D40D-431A-AA9F-940C7AFE7A25} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9DBD689B-D089-4B78-ADCD-CEB11C16FB77} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9E000580-0293-4C76-A0D1-0287ACD51CF2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9E6C29E7-3B47-4800-892F-4083888E62E3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9EA4BB9C-74AC-4ECE-825B-01FDCF03463A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9EC958E9-2912-4DE2-BC2E-C7B1DA47A7CA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9EDA7063-DCFB-4AB1-88F9-1F217CB4F6F4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9F4D403C-448E-4AFC-940D-5FE3DB2D7FD1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9F56F8DF-B9CC-4286-BDE1-F7A9AC857645} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9FCE57DD-034D-4E66-9DA7-5DD7B805178B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{9FFA9BEA-EA37-41EE-BCB7-A0EEC24D4030} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A0884450-3599-4285-8E0B-3C8D9E79067F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A092C27C-5205-4D4C-A538-D3630877C5CC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A0A01EDB-C9BB-429E-910D-27B2B8621886} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A0D4D4CA-2EBC-4486-967B-168149BF005C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A1046706-43AF-49CC-B6B3-CF0A2D4B4DA5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A10DD1B5-BDA3-4FFD-A0FA-DF3601FC3173} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A1F5778C-6CBD-4F99-8999-085AEF3826C3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A215C9B5-6E95-407C-8D8B-DA3DDB3AA749} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A23C6D65-9146-4DC1-8C95-2C5770BD635F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A2A0E44D-972E-4CEF-8191-D5453EF61C61} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A2AA759B-E2C2-4CBC-87B0-542A63DB5D26} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A2B00AA5-6830-4F3C-9F0A-C79C732E3D68} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A2C5FD92-5AD0-4E80-957A-E6EC2F3A854C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A2D69927-754F-47F2-8CA5-A4912B2BC4FC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A30AFB1A-0D23-48D0-A4A5-8D99F405C403} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A31D14DD-24C5-4D78-807D-A623F2C03E3E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A322BC78-63D2-406D-9F35-52E6C896CCA2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A39AED39-8AF8-468B-B981-478F55B5CDEF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A3C9853B-8733-47F1-A8B8-158BE1A8E411} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A3D2E307-7B2F-4D4C-92C1-8E5FD3FECD3B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A3DF3DBE-9E99-4C53-BB0F-55329452A21D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A441B159-675B-46FF-8AC0-4F02336F08C1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A449C4EB-AF96-4F95-B422-633658D74C4D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A48ECB68-A6A2-4D22-BEC4-CA335695A6CA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A4954E45-0F37-4AE2-A220-F5007A863666} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A4C12A99-DF15-4D9D-AD72-D475E084B0B5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A509280F-1A44-4152-B12C-828BC10330E6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A540B3FA-1ED5-4F18-944E-018ED72B596D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A567DA9C-2A07-4971-86AC-CA1C6B715359} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A5727DC3-5ED6-4F32-9550-4BA8D32B1772} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A58D64B6-7AA2-4A75-9895-35A058D043EE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A5C5A026-871E-4887-AA97-85611481CD36} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A5DE4499-DE41-4D80-BDB0-C04B39D9469F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A6060F16-3DBA-443C-B196-22192A2E8903} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A635CD77-712C-4319-844B-19EF324DDFA9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A6691FDF-2542-4883-9F25-7E461E294DCF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A6A04A8B-6B2E-4322-BF52-51AF9A2B60A8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A6FEC4F9-D608-4E77-990D-4D838BB9D301} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A73A6C0E-DD71-4BF3-A31E-53466247634F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A7463546-A168-4395-A479-3FF5ACB902F4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A79F19A5-F20B-4860-84CB-339F6AB35F9C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A7ABDCC8-6349-477F-A0DE-17ABA0C3AB30} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A7B42BEE-2F64-4BC2-A8B1-8DDCB5532D67} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A7E36A52-B07A-492C-9564-F6572D187A18} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A7E7F8CE-DAEB-4ACA-AA2E-2502FD7196B0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A80E4F57-E303-4FAE-9B7B-BFFE62DA4E72} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A83AEFC1-7F93-435A-A36E-60180820BAE5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A84BBD78-7C7A-4FAA-8DC2-B9FCDA18E987} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A8CF0962-BF4D-4A3A-84CF-C88CEA74F726} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A8FAE92C-8C1D-4B50-B76E-D1DFFC6EFA88} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A903841E-EE7E-4681-BF0F-F7F168AF3FAD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A9168D9E-8790-4DFD-B68A-6F96AD4611D7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A93DFA51-DBF9-4CFF-8525-EC54BE670BDD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A9616282-6B82-4BB9-B515-8AF8256C0FC8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A98CC890-924C-46FC-A5C5-76525980CE0A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A992EE4B-3F0A-4229-A423-0720E3B503CD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{A9F20D97-C0FB-4341-80AA-1942A42C9433} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AA19A4A1-34CF-4CBE-935A-EEFF94BE1680} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AAA2D709-D701-4786-B7B9-137C6FF6165F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AAAA7A3D-F122-454B-90A2-A653722102D9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AAB3497F-7A96-46AC-9662-C142CCC6F6BB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AAF5881E-DB78-4058-A70E-6CBC263FC7CF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AB1285EF-B61B-4891-BBCA-5558CD2C5647} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AB97F858-6110-437C-B8CE-17289A9664AC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ABC946E0-654A-44CC-A8C7-5A88F2A674A9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ABF5A119-97BA-4D3E-B639-3D87603D4149} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AC1CDB01-B3D1-48A0-A5C8-597482892517} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ACD54401-724A-47B7-9D14-846B6B142282} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ACEB1BF1-A2DE-4EA5-8526-60A7343C5850} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AD08A298-3C3B-456F-9B4B-018B8513841F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AD1E5F36-58E6-416B-9261-E78E09D11703} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AD78276D-A9BD-405E-8964-FD6CEE7CE987} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AD796037-54FE-47AA-BAD0-39DB8576C32B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AD883807-A677-4FEE-B74F-299886D70318} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ADFFD837-F81C-453F-AF73-C81A8B388DCD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AE1AB629-C984-4697-9B8A-015B1DA8F34B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AE4F9B3E-E257-4634-86DB-CF4B5770C8DA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AEB48175-7C77-4A1F-BE93-1B7F3A8361A5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AEDFF173-FEBF-4AD7-AF57-5BDB107F362D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AF06AC2C-50E9-4864-809E-6DD14E5809CF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AF1F1BEC-481A-4FCE-B707-0BCEDCEB0643} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AF383150-F648-46AE-A8CD-E317C4D7E368} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AF7043ED-FEAE-4347-8877-B54D7E419C70} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AF738DE6-AD67-4976-98CA-B43EE650ADA5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AF9C5A56-1B84-4D70-807A-02F3B1926C20} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AFDA4A04-8266-4638-B861-C1984AEBBD52} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AFE13CB6-1E5E-4FCF-B4A3-609E03D897DE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{AFF4598D-F65A-4E12-AB63-EEF831BE1AA3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B007B64E-6500-430B-A0ED-BA2781BA8F82} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B077AD93-656D-4E34-A4C2-1B4DDF2BDECC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B09E1DB4-46CE-4D4A-96D1-CC2096128550} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B0B58A04-ADC1-4EDE-B323-3E3793B4999D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B100666A-143A-4D44-9807-8CEEED40848F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B1056906-D7AF-40DD-9BD2-7F665F5161F2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B1A54DC0-DA00-4BFE-B1D0-64E574FD8668} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B1C944F1-01FD-456E-BCF2-062914B1F810} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B1D8E66C-66F6-4793-A1BA-48C752EA9282} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B1DA4D4F-FF6E-42D0-9E35-BC65CAD6E529} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B1E88115-EDD8-46A2-8CB1-68D5FB59E71E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B1EFCCE9-715B-48D5-952C-56EF09B7FCE5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B1F6CE76-A517-48A0-B8ED-CAE239984D50} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B1FDBF20-754B-495E-BA4B-BFD7B4269759} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B206763B-29E2-4EA9-8032-8170F9B2CEB0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B21C3040-511B-406F-8736-22E44E8745AA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B26B8270-213E-47CE-A927-A2BE584BEFCC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B26D43CD-5E4B-4B8B-B2E1-A6353F4D309C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B2BCA3C2-3BFC-4596-BF30-6AAA5DC5FC32} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B317E6C6-CFAF-4EE0-8EC0-244A2A6B793E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B3462665-A82D-4DB0-9C80-61CC1C0BBC3F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B37E9CB8-1071-4277-B1B9-DBDCD57838C6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B3A6CF4B-C53E-41D3-8751-7615B5EE5948} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B3CF6A30-1804-4C4B-AFF4-241697DFA6E3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B40BA491-065E-4204-964F-5FD47AB8B8D2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B4631A80-0773-4E31-BBD7-747F2F9AFBD9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B4663ACC-B121-4603-AD0A-2642CDAD6E1F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B4776FE4-253C-43C5-A43C-E02F40E0964D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B499BA0D-54C5-4DA8-BFFC-48E4FF55F45E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B4DD876F-C619-4A0F-B03A-F853C86D90C8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B5178278-96F8-44C3-82B5-AADC7F7758DA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B517B5B7-4505-4AD2-8C32-A23EF93C4884} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B55A15A9-303A-4658-81E0-ECF449AEA94F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B5B6FCCC-2972-4BDD-B1EE-200948E20A70} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B602788D-8DF6-4A75-A945-D0BA1BB8ECC5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B61A1DEE-F43D-49FE-AB30-595AF3AE0C36} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B633F992-5EC6-48EA-8478-3F5B08C12170} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B64988D1-44CB-4345-9078-0F5E4BCFE506} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B65A6054-0461-4C3F-AAEC-0113E4593D55} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B665D258-F63D-48F7-A01D-45F07F90B6F8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B6AF4BC6-6E7F-4DF3-97B2-3A9D88E5FE40} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B6D41B88-EC5A-4F2F-AC6E-6EC89A45A737} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B6FC323D-077F-4F95-B9E1-49F6A76E256C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B7476E4A-DD3B-45C6-8792-A0F4658C5AA2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B7721023-F75E-4F7A-AF8D-357387930A6F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B77D3087-634A-47F7-A7C6-5D67454D36F6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B79B2CA9-924A-45C7-A314-AAD8481DF228} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B7E9FC9E-E57A-42CE-8A51-F48B2789B07D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B83649E1-4D1B-4272-A44E-390C1481C101} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B8485255-B328-4773-B67B-025ECBD4DC32} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B854D6B9-5285-4DA7-9C07-DFAA3C523D69} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B8A370D3-786B-4686-87E9-0E6F3CD31D8E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B8A7B90A-A8F2-4A20-BBB5-54120F7B11A2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B9577456-F375-4CA5-A78B-7BE008F96459} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B97FEDDF-CAEA-4F0D-9F2B-2DD6B2AAD779} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{B9AE086E-AD04-4067-93F7-2D9BFCB9FA07} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BA192629-4A88-490C-BF92-1FF0BE0840FC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BA516C29-8216-4D5C-B788-11C15F726A38} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BA98A479-1692-41F5-B93D-52C6CF104E9C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BAF63E61-172B-41CE-B740-A88C17AA6C6F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BB63FDCE-2D19-4D90-A847-0279FEA3CCD7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BB656631-E437-47DE-A68D-596273C6E954} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BB7144F7-7588-434C-AD7F-5E0D576B70F3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BBF40FB1-939E-42A8-9450-7297C36D9EFE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BBF741EC-8F5A-479B-BAE5-278796312067} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BC3898B8-F22C-407B-AD19-3F899FD973DE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BC4E7712-05BE-46A5-BA2F-B9673A14460C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BC8751F5-490F-4F61-ABBC-6A6D6D54DA7A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BC8760E8-9D6F-4DAA-A8A2-C9D25B39B290} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BCAA3B59-1CC1-4682-B9F0-B457623B0CD9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BCB2197B-F781-447C-BC77-CCE5394F5A14} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BCC51703-092C-4257-A743-690845293802} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BCD65F24-B658-445B-B7AF-3D1FBAF33841} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BD03B63E-B415-4F7A-AF8C-4226FA0AD1D1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BD09DA90-6FDF-4B89-848A-58654ECEBBCA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BD934A58-7EF1-4745-9BA8-D11F69C2EEA6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BDCC62B5-B713-42B7-A443-86384EC26DEC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BDD9CA5D-B120-4ADC-ACE5-6F5F3AE77889} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BDDCD27F-5E53-4E7E-B180-F61447BE1246} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BDEECBB1-7A27-46AB-B5D9-487955EDC672} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BDF41536-BB6C-4AEA-B21C-D5CC99F493EE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BE0AE070-EDC3-4726-8F0E-833721D76E0C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BE10B26A-5903-4A49-A7C8-19A0C2B3C5FA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BE27CF2E-8F33-4688-8BA5-91867904F66D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BE44407E-DD55-4E59-97FD-6140C6D873D9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BE54E344-F111-4343-B9F9-8D4FA98CADF2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BEC8E26D-7D8E-4785-AD40-77E26BBF8EDE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BEE1D41C-393F-4C19-B9E7-E8983E2CE806} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BEF87715-E921-4EDB-B085-68F87B26A7F0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BF3B80D1-CC7E-477E-9683-7B674BDACA12} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BF441DFA-8EDF-4681-99A2-07BB495A4A45} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BF5CAA8E-2229-4AC9-8438-1AC81A61D64D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{BF6F231A-5AB7-4465-A302-A3F7008B617D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C01D6135-A25A-4019-BB4F-C992CBD2DF06} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C027F013-7B58-4467-9DA6-BB50895D3CD1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C02CFC7F-0403-4D30-8D7F-F67693ED05E7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C068A82C-2492-4E81-B385-492AB856D47C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C081063A-1D03-4E77-9EF2-D67C01FD2FB4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C08828E0-AD2A-457F-B25A-18E92B6FB3C4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C09C369D-6020-41E0-9FEB-300CA147CC17} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C0A04C4E-1AA3-47DF-9B4B-783ADA859903} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C0B5630A-06AB-4C9F-A684-4ADC96EC1500} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C0EA9F0C-00C8-4ADA-9159-6719B56C6FBF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C125E37E-CCBC-4B2A-963E-2B1D568D0F81} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C12DC55A-2922-443F-97C3-5EC807F1D5B8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C13B2428-A549-4A88-8548-9552276B0CF6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C1529C36-3EBC-4453-BC07-EA89D96D9688} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C16B1396-2A19-4C68-8ADA-78F2194180F8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C19A89A7-8EFA-4E54-A2CA-AA73CE4DDADF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C1C30DAA-FAFC-445B-BDDD-835662FF4B3C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C26CA2BD-2822-4AD3-80AD-F489B92FB003} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C2C4497F-3BBC-48C3-A2CA-EB2A8D5B792C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C2DF685E-A4A4-4DE3-AC94-701C2D99804D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C34750E0-7CA5-4F45-8D4F-1C3E5F9465E6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C372E17B-281B-4F0D-B68C-3AE61911D08A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C3977B9C-3734-42A1-80BA-F7C4F70E4A24} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C3AAB077-3A03-4584-8569-0F245AB2E5CD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C3B019E5-F15A-4AB0-A4D9-F72C133EE5EF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C3BEB885-13F8-4114-9A9E-64F613F213EE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C3ED2279-51EA-40FF-A5E1-424F34D1A14B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C42EB2AC-385D-4172-9C52-673A03DC5E88} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C46190A7-1E0F-4FB0-A10D-5765206C3C66} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C4AC722F-146C-49BF-9C61-14185E8AEBFE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C4BDC063-696F-4C64-823A-59CDF202BB03} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C4C51C4C-7584-479A-ADE2-AC91CC95E458} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C4EC3B04-5065-4CF5-AAE6-8CFB6B712889} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C4ED31EF-1C8B-4929-BEA5-A06FE7DF27D0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C50B842E-0455-44AF-89B3-BDA62867E9E2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C5143EF0-0F9C-46E5-9445-24E9DCD06886} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C518C4AE-1C88-4AD6-961E-EDFE6F4CA7E7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C54CE5D2-D8A3-4843-A62F-B9E844BA62B8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C553E93F-494C-4D32-BAA1-D5AE719547CA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C58F72B5-5602-44B1-81D0-F005F84F24B6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C5A02DB9-BF16-4676-8768-8AE7A741DE63} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C5B94A7B-D913-4536-8199-97969269AABD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C5C6869E-AE96-4122-A845-A8F280BC7B5C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C5C9293B-1552-47CF-A5BE-7DBA2D44B69A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C5CDA246-72CC-49E5-890C-BF0C37CFFEEE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C5D76798-4644-4F71-8AD4-FD73ECF46827} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C5E96236-883B-4D5E-96AE-4C0F9C15575B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C5F0E801-59D2-46BA-931F-2FD45C315BC4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C5F3A3AC-A61C-4DB1-B2D0-7E8376B7EA4E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C6223EA6-057C-4F08-AB32-0F89DFD091D2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C6926E7E-CB4E-45D0-9DCA-122B4D234AC8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C6D8D304-4DAF-4B41-BE5A-D431A3CD0E1F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C76DA508-AD78-4D2A-802B-4FE2327D913D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C7B31DAE-1BDA-48BC-8209-4407B13441F5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C8043610-B62C-466B-A1BB-8A183E255D48} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C80E87A2-95C5-40CE-A6EE-6491F26BCCCD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C817067E-ED59-4A61-9867-03FBDFA9513F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C84B185F-EF20-4CCF-9944-EAC8C836CA1F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C888F443-625E-42A6-97B0-7A8EA7552883} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C9023644-96A9-4245-AF86-2D8F70D167F3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C91352BA-E145-4771-A0BE-5276325E95B6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C916A213-3F8B-4BE1-AE7A-EEB3C22B5BF9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C9525509-34FD-4058-AB44-388A1D60F81D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C989F170-7B76-4FEE-8674-238683DC5716} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C98B6853-3CD2-45E1-8A17-7F54C7D75B8C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C9B61D89-C9EA-4C91-9BB6-1E510A83756E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C9F27281-2DF7-441B-B273-2583F7B88E1C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{C9F609B3-5DCE-4531-B245-2401EBB71771} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CA1DD4E5-1EA4-40C6-9012-72F0DAAFF582} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CA50D879-188A-457C-99F0-841102B96FD6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CA568E3E-D9AD-4FDD-99E6-E8786449D790} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CA8259B6-4034-4FD9-9722-77659488C906} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CAA8A30D-495A-48BB-85BE-486C540F321E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CB05F43C-94B6-4C19-AA93-4E64FD58DBF0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CB45E6F9-E951-4017-858C-4C4F37BC3678} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CB4C58A4-2E94-4483-B8F1-700FE0458DF9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CBA3F660-7353-4B55-8653-AE50C16DD460} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CBAACF3D-AE93-44DD-99FF-1B9BB8724AB5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CC9E7860-C212-43AE-AEFD-B73B808B1D82} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CCBD1FA2-DC8E-4976-9E96-88E4CD33D439} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CCE2F147-ACA8-4667-9F9A-EA64165383E9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CD46EC7B-12E0-4992-B5EA-5F31773364FD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CD6E2560-4A2B-4F0F-AA50-8EC3812437FE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CE234181-DEB7-406C-A813-48C6D97F76FC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CE2641D5-1AC4-4FA7-BB3C-DAACACD70D3A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CE2C0451-883A-4BB9-85DB-1CEC432C354B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CE435D99-F549-4ACC-AF18-8E406E67056D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CEE20B22-185E-4303-BD0C-9BAE0DA4BF52} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CEF58FF8-0C9E-4C79-81C1-DEF4AF177324} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CF224321-AD4A-4C7E-9E30-598FF97E7F9A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CF297457-08C3-4B8A-995A-D25CA5670121} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CF307092-B79B-446D-950C-7B5361147176} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CF568C30-F8F4-4836-BB0B-38B7586CF369} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CF9FD007-F8DF-4068-BA25-B7EC27D7236B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CFC53EBA-C4B2-4827-A8E1-52FA3E27497D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{CFDF79BF-381C-49EE-B797-E7BF3DAC905F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D0386BFF-0482-4FD4-827F-0A161963D9D0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D07E86B8-DE68-49FE-A81F-4D90A373B3C9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D08B73C2-7B98-411A-992B-6254ABF75D40} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D0B99F13-C9EF-4884-827A-E9740E8FC408} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D10F452E-C1CD-416A-8919-8FD402B5E394} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D1774DD0-B19B-4F93-A70B-EFBE41909DAE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D195AE93-8253-4A75-AE88-B327F2CE4A4A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D1AE7801-DB31-4CB1-98BB-88B775FBCA92} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D1B16512-3C5C-4554-B49A-CD7E8DC6982C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D1CEA565-A5D0-4BBD-9ECA-F32A248BFF06} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D27D35DD-FDF3-4C15-AA98-43A7B10AA129} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D280ECEA-B662-4B7C-8849-B05F0C888DAB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D28E9159-00FB-4976-9066-F383071EDCA1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D2D647D0-821A-4262-AC56-0C0C112C4A63} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D2DBC15C-443C-4556-B410-98F4DBADF96F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D2E60EE4-F4D4-4F55-967F-E7F2ED5F076B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D2ECFDB9-140A-4251-92C4-AD755B85B50E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D34B15F7-C3DA-4A86-ADDE-21F34E235267} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D38BA01B-E85E-4701-91D0-A2F7C39BA816} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D38F7EBF-0A72-4D02-AFC6-73A1CA061946} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D3BDF425-B916-4DEB-BD44-686852568790} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D3EC0D3C-EE9F-4194-BD6F-EB1EEF93A1C7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D3F35A91-6BBA-4E78-A892-A80D42C6F0E7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D43540C8-F7C0-4D81-9763-AB151251F696} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D4468E74-C243-4167-B89A-BF7EBA4E7C97} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D4605A27-F533-4D65-A10E-558CB16B0940} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D48D0134-0856-4519-AC1A-A13B7F08C428} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D523D87C-252A-4052-9FB0-E7407D0FD3DE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D59279C3-B481-4EDA-9302-4A62ECE70DD2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D5B1832E-3B8C-455F-A760-E0E132EB3E3E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D5E66345-DB0E-4CD1-9235-3C9521DCC06D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D6037CFF-E471-47CA-A35E-C5FBB44D8BA4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D621BF52-D331-4DCC-8C74-9762C633E980} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D62D2CF9-71D7-40D0-97A1-7BDCC7895A3E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D64217B7-7E65-471E-850C-27C2475F14D1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D67F43C6-4F09-44B1-82FB-72D82E7C28A0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D6E38E71-179B-484A-9B2B-403213A38231} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D71CCEAC-0C97-4F04-A87D-00B89AD702A1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D7368C51-0F75-427F-9B25-4D9432BEE24D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D7943A08-6BE0-423B-AB25-11352B7E0859} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D7B232C5-5F77-4F2D-87F0-5C6ECFAF8D17} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D7BD2EE5-DF6E-413E-801B-82B619E77448} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D8168658-CA19-4581-AFCD-815B05BCB931} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D8371017-823F-4B06-9D50-B3A2F588AECE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D8B5A7C9-CE1D-43FD-8A13-CB2958710F90} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D8BE51CD-4692-4BEC-BF10-D21BA056884F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D8C9EE60-EAE0-4ACD-AD86-39E292BBE3AC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D8DD0D2E-6B25-4D58-BF9F-91F384710E5F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D950E9E2-6E25-484A-AC8C-CD697AA8FB6A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D956D634-3301-4735-9844-1E8F3E68BEB7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D981404F-08A7-497C-B83C-8BDB3375EAE4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D994D485-F598-4E55-BCEA-004500308167} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D99F19EF-3A12-4B97-8B8C-59E452E55C7F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D9B3B960-ACA9-40B8-8975-B6FCE5981F61} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D9B88C56-11F0-4821-930F-A8967B1E9791} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D9D2CB48-CB2B-4002-8D87-DE269E8F63CF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{D9F979D3-BEC3-4A19-B633-C82B71AAD300} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DA64C5A8-4582-49F2-9EC5-2F08941E3115} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DABF7394-CA9D-4B75-9CD4-177D20CE4B56} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DABFFDE3-3396-4786-B36A-4432F858281B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DAF3D2A3-4F8C-46E3-85F0-439A51CE3AC0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DB199670-3F02-4F92-9568-E40D75586DE4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DB460753-AA7A-45D2-84AA-DF27A44D683F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DB83CE8E-7C4A-4C87-990C-4B91C047CDF5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DBC83C35-28E4-4860-BEA1-9B088B2712C6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DBE5103F-B62C-4945-8DF1-68E0E01C4748} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DC2F509A-20A9-454A-A3DA-6D7DD46DF787} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DC9BF016-945A-4A4D-84EE-C8CB3DC67E1C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DCAC8003-4361-4107-B812-CBE2E2830D72} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DCD7D8BF-DA1A-468B-95EB-E3CD08212407} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DCF3099B-2E89-46E4-B23E-FB6BAD2A2A8F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DD1A664A-95BA-4643-8908-373B94F13773} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DD1F4EAA-4951-44F5-AD66-1A7202519EA7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DD2AF6C1-DAE1-4ADF-9EE7-72846D2F74D2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DD737BB5-E687-4495-9A57-E63F1A9CFADC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DD8AF793-1808-444E-93F2-B4ED63F6B5FE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DEF84FC2-96A0-426C-B814-9F2E10FF8A5E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DF1179F4-98D2-4956-9C47-D54AE5511F0D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DF291F5B-6743-4B20-9F74-1035867CDA32} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DF9801E7-B7BB-4F1A-8904-875CB405090A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DFA4B633-3EEE-47BC-BA37-3090A3DA3E10} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DFBA4A93-60BE-456E-94DF-11668B217E73} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{DFDD13BF-2362-4283-9DDF-3A870A52C840} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E0083FA6-68F1-4F49-822D-45DDD4F748D0} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E00C0678-0C15-4E56-8327-4B299EC75032} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E02A3EBF-208C-409D-8B95-B69642B8F6F2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E032E8EF-0E62-4231-95F2-BFEDF880301C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E059E05F-CCBB-42CA-B437-E15ACE16A964} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E082ECDA-697E-4219-B5C9-B1A27BAB779A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E0C94B6D-B165-4DD1-AB5A-0622B723939B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E0D4AFB4-0FBE-4451-A2F5-57C0090DFD58} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E10AD1B5-9E0E-421C-854A-4981371F57B6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E12B6FE0-298F-4B52-A8A4-9F8D0D14FBB8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E1348A62-B9ED-44FD-A8B5-F47C58244DD2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E17520C8-5DC3-47E7-AF20-CF4A5DC7320C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E187006C-58E4-4B1B-8CCB-6A76BE59FD58} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E1D5023F-F022-4EDF-B76E-6C7060307292} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E1D95A6B-17E7-45D1-94DB-FECC04FF835D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E22A3E47-CF51-45B1-91FD-A2F341B7DDCB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E22D91AF-2A73-457A-AA01-BF2B288A09E3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E2742FCD-C41E-49DD-B7DD-2C249C57F683} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E27FC1F7-8B3D-49D7-9C76-04F1C9D66C21} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E32150C3-CEF5-433B-888D-4DF6147E07A4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E3303D53-A33F-439A-9FBA-929B37541AAC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E338FC8F-D842-4348-A06A-980982E4C08D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E349D781-C60A-4104-B5EA-8EA57F4637B3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E39AFBB1-2976-4B02-A1E9-5468A7F87B41} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E3DEACA9-9672-4CDB-8C17-08C1026B295F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E4249181-7DC9-43BB-A203-0CE2716F57C4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E44B15F2-813E-44E3-B6EF-0F4206DFB93A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E47D37E2-5E42-41E5-9D41-461DEE0E9E53} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E48B47AE-12E3-46F1-A9D0-9CEFF7CFBC79} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E4DB1C03-479C-40ED-886C-2C33BB7CCF52} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E4DE00A1-AD86-47EB-9A94-5CCBD0AF3CA8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E553AE25-980F-4AC6-B690-0E30933D53EA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E58597B2-E836-44D6-A5DC-AC0CF8705B83} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E5CEED89-8970-4D20-B03A-436FB9F3BB02} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E5EA85DF-56CF-4B1B-A8C7-4ED82E326C40} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E6247E65-A492-49A1-AD3C-EDA1B7395E24} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E6715927-6A36-4862-B7EA-AE16C322FCCE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E6A02C25-D05B-4085-8A9E-094D1A4483DB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E6B1D805-1E47-42F7-B4B7-57D088106B09} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E6C10194-3DBD-4226-9A7F-4EF64D17ED94} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E7143BFB-A744-439E-8334-4314DBF24E5B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E76A9615-F720-45C5-BE02-DAA49FD7E157} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E78137D8-50F7-4986-9B6C-A30885EAAAF5} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E7AA3935-2E6F-45AC-9E51-96CFD0A72842} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E7B7FB8D-12D9-4456-9CBB-121007D5F03C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E7BC757A-E2E0-4777-84C2-60496A8459FE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E7D53228-1565-4713-A1DE-0A3972E95117} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E7F12D55-259D-4119-9945-696A788BE422} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E85C6E8F-E657-4FD0-A1A2-34C7646EC210} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E8641ECD-6C84-4DBE-BD65-022BD511E820} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E88896C4-779B-465D-8877-8D4D33C98CD2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E88E85A0-C2FD-4F21-A6B7-32CBEF97E134} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E9325D5D-772C-4FD2-880B-F6F254F00D5D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E945750A-0BD4-43F6-BA77-2529643E0937} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E94C0BD4-7AED-48A9-BC29-01B11960B954} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E966AF45-48AD-4CC4-9304-9B780F0D3832} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E9C1861F-929A-480A-81D8-66FFA3A31B1F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{E9C75C2E-7466-47A3-848A-C2DBA081CEE1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EA3F751F-7893-41F0-BAF8-F5A9DD27EA06} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EA5D7525-FAB3-4CAB-A28C-6F0D8695EDC1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EA856572-F011-4D69-81D8-6DC922FCF587} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EAB68705-F51A-4F24-989E-4C1F6CBEC772} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EADE8E19-567B-4757-BB4A-275F17BD5F5B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EB00FEAE-2652-48E7-8763-3EC897DE4697} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EB0D9931-F568-4768-95DE-A11FD187D572} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EB22E5A4-89D7-4655-9004-99A127697FAD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EBA4FF82-F795-4B4E-B037-98BE7D219152} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EBABDE88-9F0A-4B46-A3F3-7EA4A4DF8796} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EBC528AC-76E2-4705-B0BC-47BF575058EA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EBD5371D-4BFE-46D3-984C-B698854EC64C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EC498424-2201-48C4-8AA2-F8ED90400801} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EC4D4BC8-DFC5-458B-80BC-B121E2A1B9C2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EC835D00-24A1-4A95-9CBB-6F04DC2D8E1E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ECBE69C4-233C-49FD-8F9A-1F7ACF15E659} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ECFE2FB0-9A79-47A3-AB78-4BB99968D7F7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ED054A04-C0E8-492D-AE6A-6D35407B5063} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ED5BBC26-0E6F-4A1C-8442-C149D23C2280} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ED693AE3-C03C-43C3-BC8A-085C6FE13396} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ED88BA7B-1ED5-45DF-BD97-D7062641F870} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ED8A6B30-AE88-42A0-9044-4155718BF224} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{ED90B9CD-544F-475F-BB30-FB51A2689FE7} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EDFBF393-E71F-44D9-8C25-4C2BC9712678} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EE18F7C4-FF2B-41BF-891D-C24B3D5BD568} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EE342B62-8DD2-4795-AE25-6BE93DE43F31} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EE50910D-10E1-476F-89D3-248AF550682F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EE58F9ED-2E93-4282-80D8-C3140A1E7D62} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EF89BCAD-1E35-4AFC-B133-9106D41E8BE1} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{EFD66AC6-2C9B-4482-B7F0-2F70B0966068} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F0042C51-B8D3-4527-88A1-5FB230FAF8CF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F0B5F470-352E-4359-8C01-34E82198ACCB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F0DBB679-D127-4E85-9AB4-F0E13F83053C} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F0F01CCB-5EA7-4035-86B5-9C0005A597DC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F0FB804E-3B0E-4C13-8D2E-872127F5FD2B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F11EC5B2-D786-42C5-A571-181978921440} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F1611FF5-AC64-4BA0-92DB-98D60774B5E2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F1733A10-7CB1-45BE-903C-41BD9898313D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F1BA0D22-1F24-4472-ABF9-F3A8BE60F38A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F2060986-5466-4E3B-B928-630CE6E97F02} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F2111B3B-6F2E-4CA2-A7BA-43EB6FBABF41} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F23855E1-C576-4185-A12D-BA5784D5ACC9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F2803DF5-C6B7-4231-B2C6-6157360C6851} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F288CC15-5628-466F-9EB2-E67C06CFF504} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F2AAD283-FD7C-464D-980D-229CBA5792AE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F2C61046-CBDA-46A5-85EE-40148678F2A8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F30945B2-60EC-4435-8825-18C3BB5BC7DC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F3C8E2A3-8B20-4053-8A72-D0208AEB61B3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F3E34FC3-B24D-41E3-9DB8-37A8068F37CF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F408045F-CC48-4EB2-B114-CF9B7A2E060A} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F41C1435-F1E4-4A37-AEEF-06577E4123DA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F452B38C-0FEC-4B89-97D8-B13DE533183D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F46181E5-4260-4ACA-A3E4-4FB1F6A218AB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F4C6C867-7B14-4D69-9624-4A5690D0261E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F4C937AC-2737-439F-819E-4F14E624C2DA} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F4DD1FF2-F0CD-451D-9AF6-FF2DF77067ED} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F51B39A5-D908-4C7C-AC1E-A41DBF0D78D2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F5279EAA-AE09-4392-801F-C1D3A847C32F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F541C04E-0219-4F25-925E-DF12A5A38CCD} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F5A43F37-A5BA-4A46-9A3F-DE9DE7D589A3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F5A7A85A-5D23-4AE7-A524-BA4952A6EB4D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F5C5022A-BFB4-4788-ADD2-F3E5D60D6E46} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F5EBC9B4-71C0-48B1-BB8F-B85FC2C23551} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F6072E6D-4014-44DA-9303-D970018BDE7D} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F626636A-5E44-4A72-AEE2-8149DAC4F407} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F6530E3C-EECE-498A-8566-D95551A08D7E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F7D96A6C-7BF9-46C8-A89C-1B41D5C9D156} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F813A918-7C51-4848-904B-58239A58B7AE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F86E9790-8788-494E-A53A-F73BB10BDD13} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F871C9DA-932C-4AE4-A84C-17F9708C4817} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F8791C1C-AC5C-41C9-BC94-77084434D7A9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F8B831A6-693C-4845-A9FE-4519992BCE12} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F8CD7F52-292C-4C62-A50F-B4ED75B7B4C3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F8DD13EE-0B5B-4314-A26D-FDEA0917A8B9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F8E3A5DC-C218-4963-9A92-5C4338147EBE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F8F7049C-C0C4-4E05-8B03-B519590251DF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F909971B-A414-46D2-8289-744C5F6B9956} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F93736DA-424F-416D-A595-35FDFC44767B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F94476D5-FF8C-405D-9C94-D4A5DD8B5C65} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F95FE52C-163F-4C6D-B2BF-D8F303D05DAF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F9B88C98-7F77-4109-A657-E4E8C5E31ED8} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F9EE1574-46FB-4660-B837-1F5AB13B5394} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{F9FC0C64-ED5A-40D2-9B2D-CACEE2A134EC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FA8FA892-042F-4F2F-8D39-2CF0009CA08F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FA9637EC-245A-4B5B-9CD7-49E20A71CC4B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FAD0CDC7-2A8F-48B8-87AA-FEE2DB3737A6} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FAE3FED4-AEE1-4CD3-AB70-3AE713C14394} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FAFC7577-0C5C-4C55-92F4-1AF8255C87F4} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FB6E7C4C-EEC4-496A-B5CB-051D5094C8AB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FBADB193-B214-4BB8-AA12-C6F6D743F35E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FBBE766A-C39C-4E8D-BDC9-1513CD262111} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FBCC22B8-B94B-4B43-AD31-E646CE0B0C52} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FBDF494A-7C2D-4CD9-9A33-558A98314214} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FC3225C2-5A0C-47A0-9B5E-E14E3545F653} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FC537A8F-14B9-43A4-8443-B8C796738A4B} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FC82F668-7EE4-4478-A128-2707A4765127} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FCA6BF44-731D-4955-8F92-56A24EE2C65E} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FCA79032-7DC2-493A-AAA1-C915D70EC997} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FD001723-394F-4EF9-83A1-AC4AB2C49B11} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FD072258-4416-496F-BEE4-D44CF6C030FC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FD2DFC24-CD8E-4811-BF9F-4BDC70FE1D9F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FD401536-EED1-4E83-A211-FA4C59CEAD08} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FD43AE5F-635B-420B-81BB-3106D59503AF} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FD595E32-AE1B-4096-A012-2D79C74A2D09} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FD652B6F-44D7-4FC5-8B08-A8FF4A92D9D3} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FD933A09-AEEF-47AA-87B5-4B4CD5911058} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FE0CF349-765B-445B-9A18-470C1E8F9A48} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FE0EFF10-5FFB-4BFB-8535-1E43A3BA3E08} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FE0F17DD-D643-44C3-8A52-7E00FD7A308F} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FE2C336D-F8BE-4209-9626-168BB3360F81} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FED6FE92-0416-4E94-8FC2-3E0381ED89FC} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FF76A8A1-FBFC-45F0-A9F2-077E5B16B6AB} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FF87BA01-6596-4019-A66C-ECC27D5DD675} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FF8B1BE1-2C76-4B61-97AF-104B733552B2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FFA211A4-5838-497D-951F-77994315B757} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FFA4213C-91BC-44ED-B62A-B54CEC6C18F2} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FFAA1F0A-EDB9-4F81-A8D5-D34E4408A7F9} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FFADE07B-4BBA-441A-9BA8-CA36645476AE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FFCC0739-1424-4027-B312-8745FD0E3026} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FFD011F1-8E84-4A98-8F76-664EA4AC6CAE} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\{FFFFB0B9-0FD6-4167-B311-1B06C4863D94} (Empty Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\28050 (Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\installer (Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\0TI1XVLY (Temporary Internet Files Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\8WH0UXB5 (Temporary Internet Files Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\9OWE5M7M (Temporary Internet Files Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\AF4528J0 (Temporary Internet Files Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\CJTB0U0D (Temporary Internet Files Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\EVZBHXKS (Temporary Internet Files Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\GN7EV0H5 (Temporary Internet Files Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\LF8O655R (Temporary Internet Files Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\SQS2MG2L (Temporary Internet Files Folder)
Successfully deleted: C:\Users\Juancho\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\Z5IJDRN9 (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\0TI1XVLY (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\8WH0UXB5 (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\9OWE5M7M (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\AF4528J0 (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\CJTB0U0D (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\EVZBHXKS (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\GN7EV0H5 (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\LF8O655R (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\SQS2MG2L (Temporary Internet Files Folder)
Successfully deleted: C:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\Z5IJDRN9 (Temporary Internet Files Folder)
Registry: 0
Scan was completed on Sat 10/06/2017 at 20:18:42.82
End of JRT log
# AdwCleaner v6.047 - Logfile created 10/06/2017 at 20:23:30
# Updated on 19/05/2017 by Malwarebytes
# Database : 2017-06-10.1 [Server]
# Operating System : Windows 7 Home Premium Service Pack 1 (X64)
# Username : Juancho - JUANCHO-PC
# Running from : C:\Users\Juancho\Desktop\adwcleaner_6.047.exe
# Mode: Clean
# Support : https://www.malwarebytes.com/support
***** [ Services ] *****
***** [ Folders ] *****
***** [ Files ] *****
[-] File deleted: C:\Users\Juancho\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Launch Internet-Explorer Browser.lnk
***** [ DLL ] *****
***** [ WMI ] *****
***** [ Shortcuts ] *****
***** [ Scheduled Tasks ] *****
***** [ Registry ] *****
[-] Key deleted: HKLM\SOFTWARE\Classes\protector_dll.ProtectorBho
[-] Key deleted: HKLM\SOFTWARE\Classes\protector_dll.ProtectorBho.1
[#] Key deleted on reboot: [x64] HKLM\SOFTWARE\Classes\protector_dll.ProtectorBho
[#] Key deleted on reboot: [x64] HKLM\SOFTWARE\Classes\protector_dll.ProtectorBho.1
[-] Key deleted: HKU\.DEFAULT\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\windows_ie_ac_001\Software\_CrossriderRegNamePlaceHolder_
[-] Key deleted: HKU\S-1-5-21-794287275-3297088658-3092121377-1004\Software\Microsoft\Tinstalls
[-] Key deleted: HKU\S-1-5-21-794287275-3297088658-3092121377-1004\Software\INSTALLPATH\STATUS
[-] Key deleted: HKU\S-1-5-21-794287275-3297088658-3092121377-1004\Software\Spark
[#] Key deleted on reboot: HKU\S-1-5-18\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\windows_ie_ac_001\Software\_CrossriderRegNamePlaceHolder_
[#] Key deleted on reboot: HKCU\Software\Microsoft\Tinstalls
[#] Key deleted on reboot: HKCU\Software\INSTALLPATH\STATUS
[#] Key deleted on reboot: HKCU\Software\Spark
[-] Key deleted: HKLM\SOFTWARE\AppDataLow\SOFTWARE\_CrossriderRegNamePlaceHolder_
[#] Key deleted on reboot: [x64] HKCU\Software\Microsoft\Tinstalls
[#] Key deleted on reboot: [x64] HKCU\Software\INSTALLPATH\STATUS
[#] Key deleted on reboot: [x64] HKCU\Software\Spark
[-] Key deleted: [x64] HKLM\SOFTWARE\Microsoft\Shared Tools\MsConfig\StartupReg\gpuminer
[-] Key deleted: HKLM\SYSTEM\CurrentControlSet\Control\Class\{0C95ABFE-4FB6-49DB-B22F-0E1F5FC4BEEC}
[-] Key deleted: HKLM\SYSTEM\CurrentControlSet\Control\Class\{EEEFACB3-729F-4484-B66D-E7A7917BBFC1}
[-] Key deleted: HKCU\SOFTWARE\Classes\ChromeHTML
***** [ Web browsers ] *****
:: "Tracing" keys deleted
:: Winsock settings cleared
C:\AdwCleaner\AdwCleaner[C0].txt - [2627 Bytes] - [10/06/2017 20:23:30]
C:\AdwCleaner\AdwCleaner[S0].txt - [2783 Bytes] - [10/06/2017 20:22:57]
########## EOF - C:\AdwCleaner\AdwCleaner[C0].txt - [2773 Bytes] ##########
Malwarebytes
-Log Details-
Scan Date: 6/10/17
Scan Time: 8:39 PM
Log File: Malwarebytes.txt
Administrator: Yes
-Software Information-
Version: 3.1.2.1733
Components Version: 1.0.141
Update Package Version: 1.0.2127
License: Trial
-System Information-
OS: Windows 7 Service Pack 1
CPU: x64
File System: NTFS
User: Juancho-PC\Juancho
-Scan Summary-
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 447534
Threats Detected: 9
Threats Quarantined: 9
Time Elapsed: 25 min, 4 sec
-Scan Options-
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Enabled
Heuristics: Enabled
PUP: Enabled
PUM: Enabled
-Scan Details-
Process: 0
(No malicious items detected)
Module: 0
Registry Key: 5
PUP.Optional.DeskBar, HKLM\SOFTWARE\MICROSOFT\TRACING\DeskBar_RASAPI32, Quarantined, [9606], [246292],1.0.2127
PUP.Optional.DeskBar, HKLM\SOFTWARE\MICROSOFT\TRACING\DeskBar_RASMANCS, Quarantined, [9606], [246292],1.0.2127
PUP.Optional.Goobzo, HKLM\SOFTWARE\MICROSOFT\WINDOWS NT\CURRENTVERSION\SCHEDULE\TASKCACHE\TASKS\{2673946B-ECEB-4DAD-9DF4-F7097D9E6659}, Quarantined, [350], [258425],1.0.2127
Adware.SmartWeb, HKLM\SOFTWARE\MICROSOFT\WINDOWS NT\CURRENTVERSION\SCHEDULE\TASKCACHE\TASKS\{3A0D86FE-562D-40D6-9521-2CB9D938E9D0}, Quarantined, [2982], [351608],1.0.2127
PUP.Optional.Elex, HKLM\SOFTWARE\MICROSOFT\WINDOWS NT\CURRENTVERSION\SCHEDULE\TASKCACHE\TASKS\{B7EC1E5E-6A14-41CC-9217-124325078318}, Quarantined, [8], [309198],1.0.2127
Registry Value: 3
PUP.Optional.Goobzo, HKLM\SOFTWARE\MICROSOFT\WINDOWS NT\CURRENTVERSION\SCHEDULE\TASKCACHE\TASKS\{2673946B-ECEB-4DAD-9DF4-F7097D9E6659}|PATH, Quarantined, [350], [258425],1.0.2127
Adware.SmartWeb, HKLM\SOFTWARE\MICROSOFT\WINDOWS NT\CURRENTVERSION\SCHEDULE\TASKCACHE\TASKS\{3A0D86FE-562D-40D6-9521-2CB9D938E9D0}|PATH, Quarantined, [2982], [351608],1.0.2127
PUP.Optional.Elex, HKLM\SOFTWARE\MICROSOFT\WINDOWS NT\CURRENTVERSION\SCHEDULE\TASKCACHE\TASKS\{B7EC1E5E-6A14-41CC-9217-124325078318}|PATH, Quarantined, [8], [309198],1.0.2127
Registry Data: 0
Data Stream: 0
Folder: 0
File: 1
HackTool.CheatEngine, C:\PROGRAM FILES (X86)\CHEAT ENGINE 6.2\CHEATENGINE-I386.EXE, Quarantined, [1130], [118005],1.0.2127
Physical Sector: 0
(end)
ZHP Diag Fix.
ZHP Fix
  • Disable your antivirus prior to this fix!
  • Download ZHP-Fix from here.
  • UnZip it to your desktop -- Tool Here if needed.... 7-Zip
  • Install it.
  • Click Suivant 5 Times.
  • Then Installer.
  • Then Terminer.
  • Then right clcick the ZHP Fix icon Run as admin.
  • Copy the entire content of the code box below, the next step will grab it from your clipboard.
  • Then click on import.
  • Then click GO.
  • If you see any Prompts like the one below, select Oui. = Yes in French.
  • upload_2017-5-24_21-17-40-png.2248
  • Allow completion.
  • A log file will appear on your desktop.
  • Post it here in your next reply.
Code:
Script ZhpFix
SysRestore
EmptyFlash
ProxyFix
EmptyCLSID
O23 - Service: PnkBstrA (PnkBstrA) . (...) - C:\windows\system32\PnkBstrA.exe (.not file.) =>.PunkBuster Games
SS - Disabl [11/12/2014] [ 315496] Canon Inkjet Printer/Scanner/Fax Extended Survey Program (IJPLMSVC) . (.Copyright CANON INC. 2006-2010 All Rights Reserved.) - C:\Program Files (x86)\Canon\IJPLM\ijplmsvc.exe =>.Canon Inc.®
SS - Disabl [11/12/2014] [ 315496] Mozilla Maintenance Service (MozillaMaintenance) . (.Mozilla Foundation.) - C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe =>.Mozilla Corporation®
SS - Disabl [11/12/2014] [ 315496] Skype Updater (SkypeUpdate) . (.Skype Technologies.) - C:\Program Files (x86)\Skype\Updater\Updater.exe =>.Skype Software Sarl®
[MD5.00000000000000000000000000000000] [APT] [5997473-40A-4E36-98B7-78964FB766FC] (...) -- C:\Users\Juancho\AppData\Local\5997473-40A-4E36-98B7-78964FB766FC\5997473-40A-4E36-98B7-78964FB766FC.exe (.not file.) [0] (.Activate.) =>Heuristic.Graftor
[MD5.00000000000000000000000000000000] [APT] [Adobe Flash Player Updater] (...) -- C:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [c1O9pL9eoaBMG9NlwPnXI] (...) -- C:\Users\Juancho\AppData\Roaming\c1O9pL9eoaBMG9NlwPnXI.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [ConfigFree Startup Programs] (...) -- C:\Program Files (x86)\TOSHIBA\ConfigFree\NDSTray.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [GoogleUpdateTaskMachineCore] (...) -- C:\Program Files (x86)\Google\Update\GoogleUpdate.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [GoogleUpdateTaskMachineUA] (...) -- C:\Program Files (x86)\Google\Update\GoogleUpdate.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [grWkCgMQbwn4LWnty4JxPE] (...) -- C:\Users\Juancho\AppData\Roaming\grWkCgMQbwn4LWnty4JxPE.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{012BD29A-9649-478B-BD5B-886D7EA2ACA8}] (...) -- D:\SETUP.EXE (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{1B89EFF7-9169-4B7E-8856-0D0F217993EB}] (...) -- C:\Program Files (x86)\Rockstar Games\L.A. Noire\LANLauncher.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{347F2A55-820C-47D0-9143-3DF9B53E6F8A}] (...) -- C:\Program Files (x86)\Doom 3 Demo\Doom3.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{3F36ABA8-9F20-4592-97D5-A5680A404B2B}] (...) -- C:\Program Files (x86)\InstallShield Installation Information\{33A22B2D-55BA-4508-B767-BF2E9C21A73F}\setup.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{6D19A283-B6DC-483D-8D11-C8D1368245AB}] (...) -- D:\Setup.now.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{8284A1E7-21EB-40BF-B8DE-A0A2C088D644}] (...) -- D:\ASIO_Driver\Setup.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{8484D166-C4D2-4C57-9A83-E9C7E93FE4BF}] (...) -- D:\AutoRunCD.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{9D62F8B2-C655-42AA-99C3-2E2E8E52667D}] (...) -- C:\Program Files (x86)\Doom 3 Demo\Doom3.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{A9BE53DD-C633-435E-B9C3-E2AF25266E22}] (...) -- C:\Program Files (x86)\Doom 3 Demo\Doom3.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{AB6F53B5-C8FC-43C0-A53A-81A1B0A93834}] (...) -- D:\SETUP.EXE (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{CA968E23-0FB4-4F48-B783-E29A70CF73A7}] (...) -- C:\Users\Juancho\Desktop\ARMA2_OA_Build_95248\ARMA2_OA_Build_95248.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
[MD5.00000000000000000000000000000000] [APT] [{CF66E521-AC58-4C9C-901B-A09406856F01}] (...) -- C:\Program Files (x86)\InstallShield Installation Information\{A357EF4C-2B6F-4980-ACA9-B1E42A74D7F3}\setup.exe (.not file.) [0] (.Activate.) =>.Superfluous.Empty
O39 - APT: Adobe Flash Player Updater - (...) -- C:\windows\Tasks\Adobe Flash Player Updater.job [830] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: c1O9pL9eoaBMG9NlwPnXI - (...) -- C:\windows\Tasks\c1O9pL9eoaBMG9NlwPnXI.job [1022] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: grWkCgMQbwn4LWnty4JxPE - (...) -- C:\windows\Tasks\grWkCgMQbwn4LWnty4JxPE.job [1024] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: 5997473-40A-4E36-98B7-78964FB766FC - (...) -- C:\windows\System32\Tasks\5997473-40A-4E36-98B7-78964FB766FC [4300] (.Orphan.) =>Heuristic.Graftor
O39 - APT: Adobe Flash Player Updater - (...) -- C:\windows\System32\Tasks\Adobe Flash Player Updater [3770] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: c1O9pL9eoaBMG9NlwPnXI - (...) -- C:\windows\System32\Tasks\c1O9pL9eoaBMG9NlwPnXI [4068] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: grWkCgMQbwn4LWnty4JxPE - (...) -- C:\windows\System32\Tasks\grWkCgMQbwn4LWnty4JxPE [4058] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {012BD29A-9649-478B-BD5B-886D7EA2ACA8} - (...) -- C:\windows\System32\Tasks\{012BD29A-9649-478B-BD5B-886D7EA2ACA8} [3040] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {1B89EFF7-9169-4B7E-8856-0D0F217993EB} - (...) -- C:\windows\System32\Tasks\{1B89EFF7-9169-4B7E-8856-0D0F217993EB} [3004] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {347F2A55-820C-47D0-9143-3DF9B53E6F8A} - (...) -- C:\windows\System32\Tasks\{347F2A55-820C-47D0-9143-3DF9B53E6F8A} [2964] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {3F36ABA8-9F20-4592-97D5-A5680A404B2B} - (...) -- C:\windows\System32\Tasks\{3F36ABA8-9F20-4592-97D5-A5680A404B2B} [3300] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {6D19A283-B6DC-483D-8D11-C8D1368245AB} - (...) -- C:\windows\System32\Tasks\{6D19A283-B6DC-483D-8D11-C8D1368245AB} [3048] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {8284A1E7-21EB-40BF-B8DE-A0A2C088D644} - (...) -- C:\windows\System32\Tasks\{8284A1E7-21EB-40BF-B8DE-A0A2C088D644} [3088] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {8484D166-C4D2-4C57-9A83-E9C7E93FE4BF} - (...) -- C:\windows\System32\Tasks\{8484D166-C4D2-4C57-9A83-E9C7E93FE4BF} [3048] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {9D62F8B2-C655-42AA-99C3-2E2E8E52667D} - (...) -- C:\windows\System32\Tasks\{9D62F8B2-C655-42AA-99C3-2E2E8E52667D} [2964] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {A9BE53DD-C633-435E-B9C3-E2AF25266E22} - (...) -- C:\windows\System32\Tasks\{A9BE53DD-C633-435E-B9C3-E2AF25266E22} [2964] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {AB6F53B5-C8FC-43C0-A53A-81A1B0A93834} - (...) -- C:\windows\System32\Tasks\{AB6F53B5-C8FC-43C0-A53A-81A1B0A93834} [3058] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {CA968E23-0FB4-4F48-B783-E29A70CF73A7} - (...) -- C:\windows\System32\Tasks\{CA968E23-0FB4-4F48-B783-E29A70CF73A7} [3240] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: {CF66E521-AC58-4C9C-901B-A09406856F01} - (...) -- C:\windows\System32\Tasks\{CF66E521-AC58-4C9C-901B-A09406856F01} [3300] (.Orphan.) =>.Superfluous.Orphan
O39 - APT: Unknown - (...) -- C:\windows\System32\Tasks\{E6CB6FCE-9395-48B7-BD65-2D38296B68C6} [3276]
G0 - GCSP: Preferences [User Data\Default][HomePage] http://ajax.googleapis.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://d31qbv1cthcecs.cloudfront.net =>.Superfluous.CloudfrontNet
G0 - GCSP: Preferences [User Data\Default][HomePage] http://d5nxst8fruw4z.cloudfront.net =>.Superfluous.CloudfrontNet
G0 - GCSP: Preferences [User Data\Default][HomePage] http://pchf2-jew4efcjsvzg0rz43cny.stackpathdns.com
G0 - GCSP: Preferences [User Data\Default][HomePage] http://ssl.google-analytics.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://ssl.gstatic.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://stats.g.doubleclick.net
G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.google-analytics.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.google.com.au =>.Google Inc.
G2 - GCE: Preference [User Data\Default] [lpoimibckejjdjcfbdnajaicnklhfplh] __MSG_ExtensionName__
G2 - GCE: Preference [User Data\Default] [nmmhkkegccagdldgiimedpiccmgmieda] Google Chrome manifest =>.Google Inc.
G2 - GCE: Preference [User Data\Default] [pjldcfjmnllhmgjclecdnfampinooman] __MSG_ExtensionName__
G2 - GCE: Preference [User Data\Default] [pkedcjkdefgpdelpbcmbmeomcjbeemfm] Chrome Media Router =>.Google Inc.
G2 - GCE: Preference [User Data\Default] [hakdifolhalapjijoafobooafbilfakh] __MSG_ExtensionName__
G2 - GCE: Preference [User Data\Default] [hghkgaeecgjhjkannahfamoehjmkjail] __MSG_ExtensionName__
G2 - GCE: Preference [User Data\Default] [jagncdcchgajhfhijbbhecadmaiegcmh] __MSG_ExtensionName__
G2 - GCE: Preference [User Data\Default] [cmedhionkhpnakcndndgjdbohmhepckk] __MSG_extension_name__ =>.Better Adblock
M1 - SPR:Search Page Redirection - C:\Program Files (x86)\Mozilla Firefox\extensions\{82AF8DCA-6DE9-405D-BD5E-43525BDAD38A}
O3 - Toolbar: 0xB1C218236549D4119B18009027A5CD4F - [HKCU]{2318C2B1-4965-11D4-9B18-009027A5CD4F} . (...) -- (.not file.)
HKLM\SOFTWARE\Wow6432Node\Symantec =>.Symantec
HKCU\SOFTWARE\c1O9pL9eoaBMG9NlwPnXI
HKCU\SOFTWARE\Chris
HKCU\SOFTWARE\Chromium =>.Chromium
HKCU\SOFTWARE\DailyPcClean =>PUP.Optional.DailyPCClean
HKCU\SOFTWARE\globalUpdate =>PUP.Optional.GlobalUpdate
HKCU\SOFTWARE\grWkCgMQbwn4LWnty4JxPE
HKCU\SOFTWARE\McAfee =>.McAfee Inc.
HKCU\SOFTWARE\Norton =>.Symantec Corporation
HKCU\SOFTWARE\YahooPartnerToolbar =>Toolbar.YahooPartner
O43 - CFD: 17/09/2015 - [] D -- C:\Program Files (x86)\globalUpdate =>PUP.Optional.GlobalUpdate
O43 - CFD: 17/09/2015 - [0] D -- C:\Program Files (x86)\predm =>PUP.Optional.Downware
O43 - CFD: 02/05/2013 - [] D -- C:\ProgramData\McAfee =>.McAfee
O43 - CFD: 28/02/2011 - [] D -- C:\ProgramData\Norton =>.Symantec Corporation
O43 - CFD: 05/08/2010 - [] D -- C:\ProgramData\NortonInstaller =>.Symantec
O43 - CFD: 01/03/2011 - [] D -- C:\ProgramData\Partner =>Toolbar.YahooPartner
O43 - CFD: 17/09/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\cpuminer =>PUP.Optional.CPUminer
O43 - CFD: 22/06/2012 - [] D -- C:\Users\Juancho\AppData\Local\201280
O43 - CFD: 03/10/2011 - [] D -- C:\Users\Juancho\AppData\Local\28050
O43 - CFD: 17/09/2015 - [0] D -- C:\Users\Juancho\AppData\Local\5997473-40A-4E36-98B7-78964FB766FC =>Heuristic.Graftor
O43 - CFD: 17/06/2011 - [] D -- C:\Users\Juancho\AppData\Local\76561198020804561
O43 - CFD: 02/12/2011 - [] D -- C:\Users\Juancho\AppData\Local\Chromium =>.Chromium
O43 - CFD: 01/12/2012 - [] D -- C:\Users\Juancho\AppData\Local\dxhr
O43 - CFD: 13/09/2015 - [] D -- C:\Users\Juancho\AppData\Local\globalUpdate =>PUP.Optional.GlobalUpdate
O43 - CFD: 08/06/2015 - [] D -- C:\Users\Juancho\AppData\Local\GWX =>.GWX
O43 - CFD: 14/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{00028165-8DFF-4A65-BD6F-2142B467F83D} =>.Superfluous.Empty
O43 - CFD: 21/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{006E4683-D26F-4610-9045-200E6A95B273} =>.Superfluous.Empty
O43 - CFD: 03/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{00B4F97B-27BF-4DE8-9950-05C4BD26491C} =>.Superfluous.Empty
O43 - CFD: 18/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{00CF9E66-68B3-4141-991C-7AF3F07806DE} =>.Superfluous.Empty
O43 - CFD: 13/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0189B54B-86C2-4892-8151-7654434582DB} =>.Superfluous.Empty
O43 - CFD: 27/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{018B3186-AD51-43BB-8FAB-E8E961BA2417} =>.Superfluous.Empty
O43 - CFD: 25/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{01A31D28-1210-4E1E-B26E-944A9A209372} =>.Superfluous.Empty
O43 - CFD: 05/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{0233B7B2-DB7D-44F8-AF57-3F5547A01E87} =>.Superfluous.Empty
O43 - CFD: 09/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{03165C48-33E5-4BDA-B6E8-68E947A0D05C} =>.Superfluous.Empty
O43 - CFD: 27/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{033AB0D2-120A-4142-9C67-092E6AAED9DB} =>.Superfluous.Empty
O43 - CFD: 23/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{037CBA42-FB1A-4EEA-A883-52AAC3AAAC6A} =>.Superfluous.Empty
O43 - CFD: 03/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{039C21EC-5BD2-4631-810F-77FC9AF369AF} =>.Superfluous.Empty
O43 - CFD: 16/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{03A3F0A2-EE4B-4CA1-BAA8-DA55C90CD7DA} =>.Superfluous.Empty
O43 - CFD: 10/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{03EA90B5-B35A-4B7A-87B1-81CBB062DA73} =>.Superfluous.Empty
O43 - CFD: 19/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{044A14E3-F65D-43BE-B231-7A70D362AA9F} =>.Superfluous.Empty
O43 - CFD: 14/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{045148CD-E3E3-4FC2-8214-7D88410E5072} =>.Superfluous.Empty
O43 - CFD: 14/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{04B4F91D-6C13-4CC6-A20B-63B54BF5D146} =>.Superfluous.Empty
O43 - CFD: 09/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{04F24AE1-0663-4E0C-A6E5-57ED5E75C9D7} =>.Superfluous.Empty
O43 - CFD: 12/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{051EC8B0-A032-4FBB-A31A-CFBE5055F7E6} =>.Superfluous.Empty
O43 - CFD: 07/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0574AF82-AB54-495E-8E26-1C3E0B72B7A8} =>.Superfluous.Empty
O43 - CFD: 07/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0595247F-9AB4-48B6-9F36-A6629378B00F} =>.Superfluous.Empty
O43 - CFD: 19/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{05D2399C-5888-4379-9B85-60F36C332611} =>.Superfluous.Empty
O43 - CFD: 29/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{06077110-D9EA-4AA1-9290-B61A663DC0AD} =>.Superfluous.Empty
O43 - CFD: 16/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{060D31B6-955C-40A1-8885-3A3260882858} =>.Superfluous.Empty
O43 - CFD: 06/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{06128B48-6987-4E25-9E43-26940B06A503} =>.Superfluous.Empty
O43 - CFD: 28/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{062737B8-4964-4491-A77C-DF17AAD8DCA8} =>.Superfluous.Empty
O43 - CFD: 16/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{069274B4-B626-4C2F-A7D1-1438F3779C65} =>.Superfluous.Empty
O43 - CFD: 20/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{06ADEB35-1154-433E-8134-D4CEF45DD2DD} =>.Superfluous.Empty
O43 - CFD: 24/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{06B6AB6D-EB04-4E80-B660-3A0E7F4AE2D4} =>.Superfluous.Empty
O43 - CFD: 20/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{06D72D4F-E3E3-4507-95E7-81DE38494A46} =>.Superfluous.Empty
O43 - CFD: 05/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{06E4C759-54F9-4380-AA9E-DEFDEC5504A0} =>.Superfluous.Empty
O43 - CFD: 06/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{070A8C08-738E-4B01-B5DF-4E8CFA5BC551} =>.Superfluous.Empty
O43 - CFD: 05/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0715C9D4-F602-4051-8950-BAEE3EB66447} =>.Superfluous.Empty
O43 - CFD: 30/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{073A6469-995D-44B5-B159-CEB1470A0E28} =>.Superfluous.Empty
O43 - CFD: 04/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{07CA9B96-4BDA-4C8F-B6B1-A597BA9D9454} =>.Superfluous.Empty
O43 - CFD: 16/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0815DB46-5EDE-4F75-9C0A-E9DD93868671} =>.Superfluous.Empty
O43 - CFD: 22/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{085D9BC3-21BB-4829-83A1-D6076986587A} =>.Superfluous.Empty
O43 - CFD: 18/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{08A34AA5-12C4-45AF-A0F0-120B34E3DEEF} =>.Superfluous.Empty
O43 - CFD: 05/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{08EBFFB3-0D78-4E08-91B0-3E2EE99DFC4F} =>.Superfluous.Empty
O43 - CFD: 27/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{09026119-52BD-48B3-AE9B-FBDE30310858} =>.Superfluous.Empty
O43 - CFD: 01/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0919A331-9E58-40A1-BA1E-14EBBA1A1542} =>.Superfluous.Empty
O43 - CFD: 19/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0922B0F1-FCDF-47C8-8D60-84B56A9AC636} =>.Superfluous.Empty
O43 - CFD: 17/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{093FA3F9-AD69-4EAB-BB9C-60755AAE08E8} =>.Superfluous.Empty
O43 - CFD: 16/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{09696E7A-6CC7-46AB-8743-805E75DE4FA2} =>.Superfluous.Empty
O43 - CFD: 25/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{096B7F1D-8CE7-4FDC-9F5C-8A6BEFA142FA} =>.Superfluous.Empty
O43 - CFD: 08/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0A63161F-4C03-4C18-9465-05A5B9C5DEE4} =>.Superfluous.Empty
O43 - CFD: 15/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0A7B2DB1-5DF0-4A02-BE85-96716527DFF5} =>.Superfluous.Empty
O43 - CFD: 13/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0A7DFCA5-5094-4813-B3D5-9C68B1F9C3D6} =>.Superfluous.Empty
O43 - CFD: 14/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0A8D3E5D-9211-4687-A08F-BB47C16B4346} =>.Superfluous.Empty
O43 - CFD: 08/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0AFC1CCB-054F-4A87-8320-DCC56BF58121} =>.Superfluous.Empty
O43 - CFD: 21/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0B4062F4-E980-4D4F-A178-5B4D667864F1} =>.Superfluous.Empty
O43 - CFD: 01/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0B45CCCF-48FA-45ED-B4C2-7F220F2660C2} =>.Superfluous.Empty
O43 - CFD: 08/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0B61AEEC-65EB-4435-A0C6-066D1A5AB4CF} =>.Superfluous.Empty
O43 - CFD: 08/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0BB7FFF5-3C6F-4CB9-91F9-CFB3D6E942C5} =>.Superfluous.Empty
O43 - CFD: 17/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0C00BD41-6DF4-49BD-BEAA-7E26EB9CB4FF} =>.Superfluous.Empty
O43 - CFD: 22/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0C3D7543-F711-4B53-9E99-D1626E499B3E} =>.Superfluous.Empty
O43 - CFD: 28/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0C3DE74A-C473-4634-AD74-B371EB5D7B8E} =>.Superfluous.Empty
O43 - CFD: 24/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0C9DC1F5-19F1-4BFA-8C01-07BE3774D59A} =>.Superfluous.Empty
O43 - CFD: 05/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{0CA9953C-0819-48A7-9238-36D7D2D70E6C} =>.Superfluous.Empty
O43 - CFD: 08/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0CB8AA29-6998-4966-A922-42CD76F76622} =>.Superfluous.Empty
O43 - CFD: 10/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0CCA5B9C-E3F9-436B-98E1-C64A518AADB5} =>.Superfluous.Empty
O43 - CFD: 24/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0D09A2D2-A292-48AC-8B0A-065CDD8D4729} =>.Superfluous.Empty
O43 - CFD: 29/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0DA6ACFA-22E5-471F-8567-CAEB8FEB2992} =>.Superfluous.Empty
O43 - CFD: 08/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0DC813B8-C538-4DA5-A365-8EFE40B6ACCC} =>.Superfluous.Empty
O43 - CFD: 21/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0E1BC6C9-8802-4D4F-B5D8-79148678526C} =>.Superfluous.Empty
O43 - CFD: 16/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0E721A2D-E152-4337-826C-8A9E1DF1C97D} =>.Superfluous.Empty
O43 - CFD: 25/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0EA05C60-6256-4135-909A-64490897FBBA} =>.Superfluous.Empty
O43 - CFD: 16/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0ED953FF-36E3-4B51-9F35-B2A65AA4AA39} =>.Superfluous.Empty
O43 - CFD: 28/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0EEA8C5E-8EC4-4D80-AEDB-197EAFD6A108} =>.Superfluous.Empty
O43 - CFD: 09/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0F1A9942-2B3D-48D3-B2F0-68D2E9DBB077} =>.Superfluous.Empty
O43 - CFD: 02/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0F1BC2CC-4E98-4AA4-988D-38663C9BB215} =>.Superfluous.Empty
O43 - CFD: 25/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0F20E676-9F11-43DE-9904-5D023F931495} =>.Superfluous.Empty
O43 - CFD: 20/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{0F50AD24-1C30-422D-BF6A-5D8D7FF441C4} =>.Superfluous.Empty
O43 - CFD: 22/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0F63F16F-09A0-4F7D-8D40-B19F091DEB41} =>.Superfluous.Empty
O43 - CFD: 15/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0F965F29-B7CC-4BD3-88D8-A1C5C87F1A91} =>.Superfluous.Empty
O43 - CFD: 04/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0FCD4C34-D90F-46ED-ABE6-531EC6C48DC9} =>.Superfluous.Empty
O43 - CFD: 20/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{0FF96E8D-159D-4F96-A11C-24F2696B2960} =>.Superfluous.Empty
O43 - CFD: 25/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{100304AC-173B-4AC7-9C5A-F45A1C365465} =>.Superfluous.Empty
O43 - CFD: 06/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{104DBE73-4752-4095-B1E6-1F8ED6B2BC37} =>.Superfluous.Empty
O43 - CFD: 09/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{104FDB61-6DC8-479D-91A1-16501BE40F7D} =>.Superfluous.Empty
O43 - CFD: 24/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{105681AC-7B7C-48E0-B014-C51DFE81C915} =>.Superfluous.Empty
O43 - CFD: 21/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{10819F1E-9C44-431A-BF5B-FFC15CBA2373} =>.Superfluous.Empty
O43 - CFD: 13/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{108655B6-98E9-4951-9CBE-F5EC02F7E8C5} =>.Superfluous.Empty
O43 - CFD: 26/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{108F4BB3-D7BA-4B27-8A8A-F49CCF6903B2} =>.Superfluous.Empty
O43 - CFD: 29/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{10A1C626-B5BD-4245-AE35-72FF2BE4AB3D} =>.Superfluous.Empty
O43 - CFD: 04/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{11A7E3F3-1DD0-4EAF-A98C-B28879E4A651} =>.Superfluous.Empty
O43 - CFD: 19/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{11AC1AC7-5394-4C1E-A6E2-3ED507063116} =>.Superfluous.Empty
O43 - CFD: 19/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{11D7E45B-C993-495B-B072-03347874CA87} =>.Superfluous.Empty
O43 - CFD: 12/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{11E440BB-DC54-4A1A-9C30-2AFF2C0F88C3} =>.Superfluous.Empty
O43 - CFD: 20/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1216C3E0-104C-4A51-AFD6-84457BA5E2E5} =>.Superfluous.Empty
O43 - CFD: 17/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{12201E0C-6B22-4616-BE84-26B135A59DA6} =>.Superfluous.Empty
O43 - CFD: 06/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1243C895-AC3D-42DD-90D3-597C880E47CE} =>.Superfluous.Empty
O43 - CFD: 19/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1267371F-83FB-450E-B171-FFF62840F75C} =>.Superfluous.Empty
O43 - CFD: 02/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{129EDED5-844D-4092-A705-32D448711A1D} =>.Superfluous.Empty
O43 - CFD: 13/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{12A0EE03-ED20-427B-BFBA-26BBBD633F72} =>.Superfluous.Empty
O43 - CFD: 01/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{12C8F08F-24A7-4E2A-8AB5-D44C4EDC8387} =>.Superfluous.Empty
O43 - CFD: 13/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{12CC99A8-7003-46C1-A808-0979997569CC} =>.Superfluous.Empty
O43 - CFD: 23/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{12F6B964-565D-4312-AE5D-865C87E2630A} =>.Superfluous.Empty
O43 - CFD: 06/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{13300B62-ADC3-450F-AD60-EAD1F576822D} =>.Superfluous.Empty
O43 - CFD: 01/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{134F04FE-73B3-463F-AF37-5C18F0A75BBF} =>.Superfluous.Empty
O43 - CFD: 06/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{13591D31-E1E0-4A4E-A785-9968F811C889} =>.Superfluous.Empty
O43 - CFD: 04/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1362BF33-D841-4BA7-8C03-2CDCC366E1C0} =>.Superfluous.Empty
O43 - CFD: 23/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{13F519F2-1225-4584-BA45-1920469F0A8F} =>.Superfluous.Empty
O43 - CFD: 03/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{13FD64FE-92B6-40AA-B7D2-B1051DD032D7} =>.Superfluous.Empty
O43 - CFD: 06/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1401A1D3-6F83-4647-9129-C9DDAF71B826} =>.Superfluous.Empty
O43 - CFD: 19/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{140B41F1-61CB-469F-B0EF-B17821D98C21} =>.Superfluous.Empty
O43 - CFD: 25/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{14384773-9978-49C4-9AB8-983C6C94659D} =>.Superfluous.Empty
O43 - CFD: 19/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{14432579-0E0B-4BEA-8EC1-F46E55AFD0B1} =>.Superfluous.Empty
O43 - CFD: 13/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{14FBB072-7583-4616-87BD-E715800A876F} =>.Superfluous.Empty
O43 - CFD: 18/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{15159F59-0717-4B00-AE6E-E2DC39687510} =>.Superfluous.Empty
O43 - CFD: 20/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1515BCA8-595B-4030-9170-7A218B36D164} =>.Superfluous.Empty
O43 - CFD: 13/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{15346A4E-B2CD-4B18-A87A-AB3CB1A10133} =>.Superfluous.Empty
O43 - CFD: 23/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1540D361-4F32-40B4-BA77-970C57406D7C} =>.Superfluous.Empty
O43 - CFD: 05/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{15B0B1BA-7237-44F0-A8F6-836BDC45BF37} =>.Superfluous.Empty
O43 - CFD: 14/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{15D4C543-6731-4E35-AC98-BAE67D1B7714} =>.Superfluous.Empty
O43 - CFD: 02/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{162839A7-F6F4-42F2-8BEB-A3AB3297DF4E} =>.Superfluous.Empty
O43 - CFD: 30/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{164D7806-554A-4615-B339-6B5E37D7EE83} =>.Superfluous.Empty
O43 - CFD: 28/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{165C80FA-7344-4A60-AD77-F03AE31CBAFC} =>.Superfluous.Empty
O43 - CFD: 01/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{166BF321-12CD-495B-9E17-A69C82EAA8A4} =>.Superfluous.Empty
O43 - CFD: 20/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{16C7CB3D-C24E-43FC-953A-575A4E92E207} =>.Superfluous.Empty
O43 - CFD: 01/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{173790A8-8EBC-4E6F-A98D-ADDA3E1FEB68} =>.Superfluous.Empty
O43 - CFD: 27/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{175DFBAB-C911-4BFC-9132-EE9F1CC6715F} =>.Superfluous.Empty
O43 - CFD: 01/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{17AE55DB-79A5-4475-8C2B-4A263CDFC13F} =>.Superfluous.Empty
O43 - CFD: 12/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{17C0E456-64EC-434A-B919-700F67DFD105} =>.Superfluous.Empty
O43 - CFD: 13/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{17E617AF-4BE6-46C4-9940-A662A526008B} =>.Superfluous.Empty
O43 - CFD: 09/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{184147F8-CA7E-481C-8F97-7A970936818D} =>.Superfluous.Empty
O43 - CFD: 06/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{18C783AE-0CDE-45E7-9B85-4842C63FB3EF} =>.Superfluous.Empty
O43 - CFD: 10/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{18CEB842-AED9-4AE9-A9A4-E56322EA3951} =>.Superfluous.Empty
O43 - CFD: 27/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{190C0EA3-F598-4B07-8406-952EBCCDBC58} =>.Superfluous.Empty
O43 - CFD: 03/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{19314CDF-6A5F-4F16-A68D-C92B4F201DAA} =>.Superfluous.Empty
O43 - CFD: 03/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1969F09A-D041-436C-ACA2-56C565244F9F} =>.Superfluous.Empty
O43 - CFD: 25/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{197D44C3-DEEC-4CEA-938F-2773CA6269EC} =>.Superfluous.Empty
O43 - CFD: 22/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{19951077-54EA-417E-97BC-DF54F1F75DC8} =>.Superfluous.Empty
O43 - CFD: 29/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{199DE664-CB41-4378-AA0A-EC0615B8964A} =>.Superfluous.Empty
O43 - CFD: 03/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{19B061BF-3741-43E2-87EE-DF320AAE97B4} =>.Superfluous.Empty
O43 - CFD: 27/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{19E1E2B9-4794-4AE4-A5EF-A16DF7D7E5BE} =>.Superfluous.Empty
O43 - CFD: 12/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1A37F65C-E1CF-4DE9-A1EF-3F1B65FBD4A3} =>.Superfluous.Empty
O43 - CFD: 15/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1A5BD89B-1CB8-45FA-BA24-5708FE89A231} =>.Superfluous.Empty
O43 - CFD: 20/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1A6664C0-7551-4B03-90FA-5D269D07EF65} =>.Superfluous.Empty
O43 - CFD: 26/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1AC2E81D-2395-4A82-A629-1A49DCC3F596} =>.Superfluous.Empty
O43 - CFD: 07/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1AE64A07-D0BD-453E-9D0A-5ECE3C2290BD} =>.Superfluous.Empty
O43 - CFD: 08/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1AEA8F87-8A9B-4816-98EB-2BF0A42A281A} =>.Superfluous.Empty
O43 - CFD: 04/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1AF826A9-1B85-4B74-BAE1-21C2122C71B2} =>.Superfluous.Empty
O43 - CFD: 26/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1B20A586-59E7-4D90-90D4-907D6E492DED} =>.Superfluous.Empty
O43 - CFD: 13/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1B9ED1B7-DF77-46F8-913B-5D9A3A09590D} =>.Superfluous.Empty
O43 - CFD: 31/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1BCB0B7B-6FC1-401B-B9B2-1D771F6B6DC8} =>.Superfluous.Empty
O43 - CFD: 22/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{1BF10972-B789-40B0-B3E3-03E8DAAFBC84} =>.Superfluous.Empty
O43 - CFD: 27/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1C1B18AC-2D60-4001-9099-C77FCE53A47B} =>.Superfluous.Empty
O43 - CFD: 05/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1C1C2EBA-9F71-4E63-8E80-10ACA370332F} =>.Superfluous.Empty
O43 - CFD: 09/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1C355AB2-41B1-4E42-9C3D-6EA508DCBC79} =>.Superfluous.Empty
O43 - CFD: 14/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1C473EC7-DD6F-45F0-92C2-31301E16F6B6} =>.Superfluous.Empty
O43 - CFD: 12/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1C688519-F58A-474E-BF35-A082F4C7FE67} =>.Superfluous.Empty
O43 - CFD: 26/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1C7E113D-0510-4491-9F74-6C132724CF1F} =>.Superfluous.Empty
O43 - CFD: 05/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1CC1983F-00F8-4ECB-AA8E-B02B12726420} =>.Superfluous.Empty
O43 - CFD: 23/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1CC7EEDC-D1A5-44A9-8BAC-F5F5A06E9164} =>.Superfluous.Empty
O43 - CFD: 01/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1D2943C3-0C5F-4C4A-84AA-A9510F0B0F16} =>.Superfluous.Empty
O43 - CFD: 08/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1D4FA5F5-662D-41F1-A96A-3AA3E4FB4D9F} =>.Superfluous.Empty
O43 - CFD: 20/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1D51FC66-273D-4A54-8628-F0C27210D217} =>.Superfluous.Empty
O43 - CFD: 15/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1DB882CD-481C-4371-9947-52F32BE30EF1} =>.Superfluous.Empty
O43 - CFD: 11/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1DC7BF2C-D072-48A4-B4A4-0FDD8B5C3115} =>.Superfluous.Empty
O43 - CFD: 31/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1DD79021-D91C-4D86-BE99-D03A2430F83C} =>.Superfluous.Empty
O43 - CFD: 14/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1E47F6C6-2516-4551-9AC1-72183D625F3E} =>.Superfluous.Empty
O43 - CFD: 12/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1E5995DF-25D6-41C8-992A-ED1C160149A2} =>.Superfluous.Empty
O43 - CFD: 09/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1E791555-790A-475D-A483-16FFC38D477A} =>.Superfluous.Empty
O43 - CFD: 20/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1EBD0109-BE07-4D35-93D3-BEBAE6BE7B48} =>.Superfluous.Empty
O43 - CFD: 09/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1EC16EA8-5814-4756-85CF-ABB56DAC74C7} =>.Superfluous.Empty
O43 - CFD: 25/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1EDD3011-DB1D-41F9-933C-884331DC15EE} =>.Superfluous.Empty
O43 - CFD: 02/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1EFDD814-3463-481C-AF12-545893A796C1} =>.Superfluous.Empty
O43 - CFD: 21/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1F011CFB-38FD-4DB6-80E1-8DE891BCC13F} =>.Superfluous.Empty
O43 - CFD: 22/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1F6A40AF-8DA7-41AE-8DBE-28E9F4579400} =>.Superfluous.Empty
O43 - CFD: 29/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1F8F2430-1AC4-4FFD-B07F-553C466B1AC8} =>.Superfluous.Empty
O43 - CFD: 01/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{1F9B901B-C7A0-4E72-8C55-626FEEC27112} =>.Superfluous.Empty
O43 - CFD: 11/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{1FF10BE7-FC6F-4F87-BB32-66CD2F7108C3} =>.Superfluous.Empty
O43 - CFD: 01/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1FFCA986-ABD7-4B44-BA3B-7CE5316CB57B} =>.Superfluous.Empty
O43 - CFD: 21/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{1FFE4DBB-FBC2-4CA0-8B10-1E7B010C213D} =>.Superfluous.Empty
O43 - CFD: 30/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{201499BC-9F11-4B37-999D-7C877A22F98B} =>.Superfluous.Empty
O43 - CFD: 02/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{204B551B-F3F7-431C-84C2-D9566CFA3400} =>.Superfluous.Empty
O43 - CFD: 05/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{2082F19F-12B0-4AC4-9EB8-EB9E57B8E295} =>.Superfluous.Empty
O43 - CFD: 08/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{209469F8-3BC3-4CD7-8111-BB205D5E4D20} =>.Superfluous.Empty
O43 - CFD: 30/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{20A9B4D2-0236-455F-A4A7-217065C4B35D} =>.Superfluous.Empty
O43 - CFD: 07/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{20B32EB1-0301-4BF1-9474-1762A57B82CA} =>.Superfluous.Empty
O43 - CFD: 13/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2113912A-5D4A-4310-8082-423129A1BE73} =>.Superfluous.Empty
O43 - CFD: 24/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{21341517-552E-48AB-9DF7-28F561F46F32} =>.Superfluous.Empty
O43 - CFD: 06/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{214B57D4-CEAA-486D-BDE8-22187B253AB4} =>.Superfluous.Empty
O43 - CFD: 26/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{21704751-659F-4BBD-A7CD-861AD173AF52} =>.Superfluous.Empty
O43 - CFD: 21/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{21B4C073-B17C-45E1-95CF-36FCF5F1D257} =>.Superfluous.Empty
O43 - CFD: 01/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{21D5E57B-7461-4C53-95E2-60E7F423FE91} =>.Superfluous.Empty
O43 - CFD: 31/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{21E89CED-E125-4C4B-88B4-6428AD497101} =>.Superfluous.Empty
O43 - CFD: 07/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{22667A68-50F7-4024-B9A6-9DF7733DA620} =>.Superfluous.Empty
O43 - CFD: 04/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{23308B1E-B6A3-4B0D-B4FF-D3C5AE4A7B43} =>.Superfluous.Empty
O43 - CFD: 15/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{23627CA1-3552-421D-B6FE-180B62DBA97C} =>.Superfluous.Empty
O43 - CFD: 31/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{239EF313-6C73-409D-AA20-7DE3DCA8FD5C} =>.Superfluous.Empty
O43 - CFD: 06/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{23B38469-86B0-411C-8DF7-42C73FC4A900} =>.Superfluous.Empty
O43 - CFD: 02/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{23DB07FD-168A-4681-AD3C-E5B3729BDED5} =>.Superfluous.Empty
O43 - CFD: 26/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{23F00150-5D34-40B4-8AF0-7FF24ECB25F6} =>.Superfluous.Empty
O43 - CFD: 04/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2404A977-CFD6-47B9-A641-CFAA0F90F8F9} =>.Superfluous.Empty
O43 - CFD: 22/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{24FCD7CC-7946-4228-B2F5-E94E032BBA72} =>.Superfluous.Empty
O43 - CFD: 06/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{24FFEAD0-DDD4-4688-A230-FC95E4182E6C} =>.Superfluous.Empty
O43 - CFD: 21/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{250C9FAB-35C9-4D30-8414-6D4A03C10C99} =>.Superfluous.Empty
O43 - CFD: 02/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{251CC634-31AE-4C62-AD7D-EE7479411813} =>.Superfluous.Empty
O43 - CFD: 25/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{25ADEBAA-A784-421E-842F-9840F7C22AF4} =>.Superfluous.Empty
O43 - CFD: 21/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{25AF4AA0-9D86-4515-ACED-7914735F17A9} =>.Superfluous.Empty
O43 - CFD: 21/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{263EE219-B0F2-4427-A93A-A02A1A6E96A1} =>.Superfluous.Empty
O43 - CFD: 07/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{264AA751-F5AA-402C-95AC-6C73F75BB78E} =>.Superfluous.Empty
O43 - CFD: 26/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{266DAA4B-7F8E-407D-9956-5193EDB8B239} =>.Superfluous.Empty
O43 - CFD: 18/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{26AC1B17-B24E-4800-A3E1-301BD448A8E2} =>.Superfluous.Empty
O43 - CFD: 23/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{26B7C66E-F6F6-4215-919B-383F2D233568} =>.Superfluous.Empty
O43 - CFD: 11/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{26BAC893-D8C7-44E9-8431-009EAEF77FD9} =>.Superfluous.Empty
O43 - CFD: 27/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{274C6319-9F6D-48C4-ADA5-E3662A200E3A} =>.Superfluous.Empty
O43 - CFD: 15/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{27DA2C92-D61C-4FF3-BA0C-46325413B22E} =>.Superfluous.Empty
O43 - CFD: 20/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{27F0822D-EDCC-4ECF-83C1-E128CE2B645D} =>.Superfluous.Empty
O43 - CFD: 17/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2827BD98-6C7F-419B-8FEF-3F32003BFAFF} =>.Superfluous.Empty
O43 - CFD: 21/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{28775A2C-8888-43A8-8E3B-D60C1EFEC8B6} =>.Superfluous.Empty
O43 - CFD: 22/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{288531E2-58CB-45C3-9A16-7457EBF44540} =>.Superfluous.Empty
O43 - CFD: 18/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{28A1D688-87BC-4259-BFBD-5503424E84B9} =>.Superfluous.Empty
O43 - CFD: 01/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{28BA16D7-35B7-4FE7-BDD2-30F907C8D6DA} =>.Superfluous.Empty
O43 - CFD: 15/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{28F915D7-C056-4E2B-BC32-C96A028542B4} =>.Superfluous.Empty
O43 - CFD: 26/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{294D4CFE-0523-497E-947E-93053988E032} =>.Superfluous.Empty
O43 - CFD: 23/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{29577C48-01F9-4D9C-A3F1-5F25D04D74BA} =>.Superfluous.Empty
O43 - CFD: 24/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{29DC68AF-3EC5-4288-A7C6-CB4D208EC454} =>.Superfluous.Empty
O43 - CFD: 19/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{29EB3D0C-CE4B-4679-A6A6-15F0A869A026} =>.Superfluous.Empty
O43 - CFD: 28/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2A76DAF0-8148-418E-B761-149BD91EA093} =>.Superfluous.Empty
O43 - CFD: 06/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2A776664-296D-444C-A0F6-EE1A6E97B444} =>.Superfluous.Empty
O43 - CFD: 22/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2B4E5977-893D-49FA-A312-EA75C6AB3965} =>.Superfluous.Empty
O43 - CFD: 25/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2B86426F-0ADF-49CE-BA3C-15BEC0E1E50C} =>.Superfluous.Empty
O43 - CFD: 05/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2BC48BDE-83DF-4B50-9937-B029CA9C7A4F} =>.Superfluous.Empty
O43 - CFD: 24/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{2C004EA3-7969-48A9-B901-64F17C144ECD} =>.Superfluous.Empty
O43 - CFD: 13/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2C119C0C-DB1E-4059-ABB5-9AAA131FB24F} =>.Superfluous.Empty
O43 - CFD: 25/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2C38BCD3-3D4B-42D0-9138-99F6ED681E5A} =>.Superfluous.Empty
O43 - CFD: 20/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2C49DAF4-1944-4160-8174-8F9E123121C0} =>.Superfluous.Empty
O43 - CFD: 06/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{2C4FECCD-9933-4E9C-AA9E-66A47F5B5975} =>.Superfluous.Empty
O43 - CFD: 14/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2CC0F512-F08E-43EF-B093-CAB21F4AB5C9} =>.Superfluous.Empty
O43 - CFD: 21/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2CCBF70F-EFA7-432F-88C4-745DE93D44F9} =>.Superfluous.Empty
O43 - CFD: 26/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2CFAC2EB-D5F4-4B81-92F7-66140290B5DF} =>.Superfluous.Empty
O43 - CFD: 09/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2D2C3832-71C4-4F60-BEEF-450F2D5B7845} =>.Superfluous.Empty
O43 - CFD: 14/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2D53EC40-AA66-4663-B8A0-28B17445AB15} =>.Superfluous.Empty
O43 - CFD: 07/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2D5AB2E5-94FC-4B18-9329-31D943AC166F} =>.Superfluous.Empty
O43 - CFD: 31/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{2D76F9BA-8DD0-4AB4-ACCD-3E00A7A7D9FD} =>.Superfluous.Empty
O43 - CFD: 18/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2D9FFFAE-970D-4531-8121-BF6A06D280BF} =>.Superfluous.Empty
O43 - CFD: 02/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{2DA0813B-4694-4606-A9A5-2C7B81B9FBC3} =>.Superfluous.Empty
O43 - CFD: 12/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2DA57AFA-3C16-4347-9AEC-4E28E3789FDF} =>.Superfluous.Empty
O43 - CFD: 09/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2DABDDDA-E98D-49B3-ADF3-4FC24DC654D2} =>.Superfluous.Empty
O43 - CFD: 18/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2DCB2829-9A25-41CA-976B-2FA04E77E0C4} =>.Superfluous.Empty
O43 - CFD: 01/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2DEA0FB8-DAF5-4044-86E0-C4507F33F03F} =>.Superfluous.Empty
O43 - CFD: 04/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2E33D510-CDCB-47A3-A783-04AEACD31B85} =>.Superfluous.Empty
O43 - CFD: 20/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2E364D0B-00D9-48E6-9456-F82DDB437AB2} =>.Superfluous.Empty
O43 - CFD: 16/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2E556887-AF9C-45AA-84BA-BDBA973D5E58} =>.Superfluous.Empty
O43 - CFD: 24/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2E942D78-08F2-4DF2-91D5-1D49666FAE8B} =>.Superfluous.Empty
O43 - CFD: 04/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{2EDAB995-EF7E-4471-BC6F-A6D285B58256} =>.Superfluous.Empty
O43 - CFD: 30/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2EE7760D-06F4-4549-A9EF-C2A09DAF39B6} =>.Superfluous.Empty
O43 - CFD: 17/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2EEB26D1-A469-430E-BE9F-25503D2414F8} =>.Superfluous.Empty
O43 - CFD: 16/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2F050FEA-65B3-4FE0-8A84-1D15BA095EEF} =>.Superfluous.Empty
O43 - CFD: 10/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2F1E05C2-EE72-4865-93CB-B62AD1CB11C3} =>.Superfluous.Empty
O43 - CFD: 11/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2F31EDA4-D663-486E-8E33-03796874E2D0} =>.Superfluous.Empty
O43 - CFD: 02/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2F368049-421E-4C1D-A4EE-1548E8A2E404} =>.Superfluous.Empty
O43 - CFD: 05/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2F7FAFA0-AC1B-4632-918C-04A348682D6C} =>.Superfluous.Empty
O43 - CFD: 05/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{2FA34195-663D-4C3D-933F-5C41D9A27CB6} =>.Superfluous.Empty
O43 - CFD: 18/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{2FF2D5BB-412D-4604-8FD8-382F01173BBF} =>.Superfluous.Empty
O43 - CFD: 25/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{300B7DDF-7D07-45C8-A3BD-E7D458FC3DA8} =>.Superfluous.Empty
O43 - CFD: 20/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{30A00F96-5B22-47E5-86E9-7A6857B37C0A} =>.Superfluous.Empty
O43 - CFD: 11/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{30C587C2-067C-4099-A1AA-DC7A1209AAF0} =>.Superfluous.Empty
O43 - CFD: 15/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3134A6CC-F409-4E89-8499-A39B2FA289A4} =>.Superfluous.Empty
O43 - CFD: 29/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{31586308-C83E-42B7-B71D-F79AC69E8694} =>.Superfluous.Empty
O43 - CFD: 03/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3200BAA7-E523-4C76-AFF9-CAB9BCF4DF01} =>.Superfluous.Empty
O43 - CFD: 22/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3237395A-9905-4B13-8A41-20A16C2FF47F} =>.Superfluous.Empty
O43 - CFD: 01/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3238E39A-D639-433D-BDEE-A0287FBF18D1} =>.Superfluous.Empty
O43 - CFD: 06/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{323F8B64-35B3-4072-8FF7-41941748E99C} =>.Superfluous.Empty
O43 - CFD: 21/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{325342C6-6E18-4430-90FA-1F8C2481E793} =>.Superfluous.Empty
O43 - CFD: 29/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{32C20363-8276-4DB5-8525-0AF291C5FCF6} =>.Superfluous.Empty
O43 - CFD: 22/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{32E563F3-8F61-4DA7-A3F8-4AAF40900855} =>.Superfluous.Empty
O43 - CFD: 08/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3342BA34-8A7C-4459-B528-B1DA0F6718F7} =>.Superfluous.Empty
O43 - CFD: 16/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3355A0CC-BC66-42CB-B7E2-3D2CAE9C7B11} =>.Superfluous.Empty
O43 - CFD: 12/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3358F0B4-139D-4EF5-BF8A-8D16C4892F3A} =>.Superfluous.Empty
O43 - CFD: 09/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{337F6273-3BA5-4D78-B1CA-DD6A992C68B5} =>.Superfluous.Empty
O43 - CFD: 17/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{338F5053-9A03-4AA7-84E4-A1A32158DD82} =>.Superfluous.Empty
O43 - CFD: 22/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{33CDF70C-7DCC-4AE9-9D97-02161542EC1D} =>.Superfluous.Empty
O43 - CFD: 26/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3419C932-86FC-4C3C-8CF3-23A922753D0F} =>.Superfluous.Empty
O43 - CFD: 23/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{34232792-4757-4914-8430-BD35559FAF71} =>.Superfluous.Empty
O43 - CFD: 19/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3455A1A8-E764-4F03-9C83-19D6EB2B54BF} =>.Superfluous.Empty
O43 - CFD: 07/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{34D92DE5-7829-4A41-907A-FE8D17122959} =>.Superfluous.Empty
O43 - CFD: 16/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{34F5685A-3B91-4BDE-BE80-0C395D4B778B} =>.Superfluous.Empty
O43 - CFD: 19/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{352BFB2B-C805-4935-8EA1-49E7D254D040} =>.Superfluous.Empty
O43 - CFD: 27/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{35631C14-29FE-48CA-9E77-4F954FBA2E13} =>.Superfluous.Empty
O43 - CFD: 05/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3584B07D-1A23-4B4F-9430-2741D26E7820} =>.Superfluous.Empty
O43 - CFD: 16/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{358FDB13-D8A6-4478-A4BA-98C74828DCDC} =>.Superfluous.Empty
O43 - CFD: 11/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{35AAD1D4-95D2-410C-8283-FC622A0F6DFC} =>.Superfluous.Empty
O43 - CFD: 26/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{35BE85E8-C751-4024-ACCB-08D2FFF65C97} =>.Superfluous.Empty
O43 - CFD: 03/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{35D39A71-86F8-4CD2-A62C-1C8979A7D41F} =>.Superfluous.Empty
O43 - CFD: 28/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{35D558F0-66B1-4C4E-875D-E9FA2AF24B74} =>.Superfluous.Empty
O43 - CFD: 09/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{35E04C35-8DDF-4429-AE3A-FE91E38BE1C5} =>.Superfluous.Empty
O43 - CFD: 20/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{363844BF-12C3-434C-A78E-37108E72A437} =>.Superfluous.Empty
O43 - CFD: 19/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{364F692B-A192-4AA2-B1B3-052A93BEB6F8} =>.Superfluous.Empty
O43 - CFD: 15/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{365B8F61-7A19-4481-89BB-B3D6ECC9E253} =>.Superfluous.Empty
O43 - CFD: 26/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3686667F-62C4-4C00-A8B2-C43EB6250AF5} =>.Superfluous.Empty
O43 - CFD: 26/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{369FC8A2-75DE-440D-B682-BE7D8B6176D2} =>.Superfluous.Empty
O43 - CFD: 27/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{36A84903-7B8A-48EF-9967-93421BA564E7} =>.Superfluous.Empty
O43 - CFD: 03/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{36BC8E12-3ACA-4C01-868C-E8AE5F369767} =>.Superfluous.Empty
O43 - CFD: 14/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{36C31A63-4DD0-42E5-AF9D-0927EAD10152} =>.Superfluous.Empty
O43 - CFD: 25/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3731FB3E-623F-4309-A8A0-D677600FC7C7} =>.Superfluous.Empty
O43 - CFD: 03/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{37513DE2-24FD-47DC-B8B6-C811C6C723A6} =>.Superfluous.Empty
O43 - CFD: 20/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{384B8271-ACFE-4AE2-9C59-A0986D9460D2} =>.Superfluous.Empty
O43 - CFD: 14/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{38906D6F-A7A2-4DF9-95CD-28A5D5F294B8} =>.Superfluous.Empty
O43 - CFD: 11/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{38B5FDD8-C528-42A4-83E9-675426799C7E} =>.Superfluous.Empty
O43 - CFD: 22/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{38BB7812-9FD7-4A6F-93A9-C8F8984C7691} =>.Superfluous.Empty
O43 - CFD: 30/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{39370FFA-F396-4DE7-BA2C-0D31DB35CF5E} =>.Superfluous.Empty
O43 - CFD: 27/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3953246F-FD4A-4CD5-BB8A-4CFEE1AFFF20} =>.Superfluous.Empty
O43 - CFD: 10/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{39945D49-E6DE-4B47-BB1D-E7EB590C5CBA} =>.Superfluous.Empty
O43 - CFD: 01/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{39A74C54-D871-419F-A5A0-764D2E79BB7C} =>.Superfluous.Empty
O43 - CFD: 11/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{39C8F025-FBF9-4FAA-BBD4-1BBF0871228D} =>.Superfluous.Empty
O43 - CFD: 22/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{39D48235-C6BE-4F18-A190-C7AEF70FD8B8} =>.Superfluous.Empty
O43 - CFD: 21/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3A098ADA-4F78-4602-A7FB-A8C2169FE61C} =>.Superfluous.Empty
O43 - CFD: 21/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3A1FAA66-9A57-47A0-BA7E-CA5E33782801} =>.Superfluous.Empty
O43 - CFD: 07/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3A29D8A9-5856-47B6-8516-E8B23E0226E3} =>.Superfluous.Empty
O43 - CFD: 11/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3A5B2FCE-F394-426C-A16D-3B03FD5EB7D4} =>.Superfluous.Empty
O43 - CFD: 07/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3A5C4464-2F88-4AAC-8CCC-752C323CE91E} =>.Superfluous.Empty
O43 - CFD: 13/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3AA7DA62-73DD-4553-B4C7-87BA1B2DB041} =>.Superfluous.Empty
O43 - CFD: 09/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3ADD0451-5DA4-4DE9-9308-57EA79D641D3} =>.Superfluous.Empty
O43 - CFD: 02/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3B55C1A7-1CCE-47AB-866F-BA3B36FAEB39} =>.Superfluous.Empty
O43 - CFD: 10/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3B9C12E0-C69B-4018-A38A-35133A772B9C} =>.Superfluous.Empty
O43 - CFD: 09/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3BEF662E-21B7-4132-83F2-A596DE1D2939} =>.Superfluous.Empty
O43 - CFD: 05/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3C3727B6-FAA5-45D0-AAD3-88587C65EF3D} =>.Superfluous.Empty
O43 - CFD: 30/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3C93288E-F85A-4CC9-8008-BB57AE7B1581} =>.Superfluous.Empty
O43 - CFD: 07/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3C94A1F8-A30A-4F0F-8DAC-0E2FEFBF5379} =>.Superfluous.Empty
O43 - CFD: 05/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3CDD224D-5E5D-4398-A11B-03A10B980DB3} =>.Superfluous.Empty
O43 - CFD: 19/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3CF8C0A3-B8C8-4182-86BF-23D8988B9576} =>.Superfluous.Empty
O43 - CFD: 09/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3D583E7A-0982-4575-8C8B-64F5085C74EC} =>.Superfluous.Empty
O43 - CFD: 29/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3DC23312-053D-4076-9714-A34A2D042D76} =>.Superfluous.Empty
O43 - CFD: 25/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3DD2F418-058A-456C-840A-4140E4368501} =>.Superfluous.Empty
O43 - CFD: 11/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3E3D3DDF-D32A-4E8F-9058-390C599730F4} =>.Superfluous.Empty
O43 - CFD: 31/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3E484457-7B5A-402E-BA41-30A74A28624C} =>.Superfluous.Empty
O43 - CFD: 30/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3E7548D1-54DC-4E73-BB30-804D5E265C09} =>.Superfluous.Empty
O43 - CFD: 15/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3E92EEAC-10AB-46A0-A783-57D2D8419799} =>.Superfluous.Empty
O43 - CFD: 23/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3E93A330-5CEC-420B-B4CB-3D190D8A472C} =>.Superfluous.Empty
O43 - CFD: 24/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3E980572-E832-4916-A5D8-EB6BDD8CE66E} =>.Superfluous.Empty
O43 - CFD: 25/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3EC12433-A4B0-4E12-92E4-B25BDA1FF832} =>.Superfluous.Empty
O43 - CFD: 27/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{3ED1F291-CE69-45BD-A67F-4C629080CAB4} =>.Superfluous.Empty
O43 - CFD: 21/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3EDEA684-5B25-40C0-A44C-2CDFBA16B7E1} =>.Superfluous.Empty
O43 - CFD: 24/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{3EE4D91E-0E3F-475A-BE33-43ECFE2FAAB3} =>.Superfluous.Empty
O43 - CFD: 23/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{3F1836CE-077F-41C1-9466-31D6AC95FF61} =>.Superfluous.Empty
O43 - CFD: 09/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3F5CACC7-7C70-4D61-9A02-B74200EFE681} =>.Superfluous.Empty
O43 - CFD: 24/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3F6539BD-6077-4652-892E-336DAEA2475E} =>.Superfluous.Empty
O43 - CFD: 09/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{3FA8A2F8-4269-4EDA-9789-A8A809C6522C} =>.Superfluous.Empty
O43 - CFD: 04/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{400ADB54-7C4D-4438-963C-A10DB57DA3A1} =>.Superfluous.Empty
O43 - CFD: 11/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{405179E3-B941-4B04-BE5C-A54F5DE4E816} =>.Superfluous.Empty
O43 - CFD: 05/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4052563A-1CD6-41B0-8F22-BBDCA82A02A0} =>.Superfluous.Empty
O43 - CFD: 08/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4064AF3D-3FD1-4308-9B0E-3BACA48E1D4B} =>.Superfluous.Empty
O43 - CFD: 07/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{4075DFF7-7BFF-4E1F-BC4C-3C2452FC7E08} =>.Superfluous.Empty
O43 - CFD: 28/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{40A9D092-DDC9-445A-BEA3-B1C75F3735E4} =>.Superfluous.Empty
O43 - CFD: 14/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{40D816D0-B7F9-4715-A764-1FFA71FEC3EB} =>.Superfluous.Empty
O43 - CFD: 14/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{40D8F3F9-A9F4-49E3-AF31-18E1E2CA0907} =>.Superfluous.Empty
O43 - CFD: 07/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{40FC0FCE-DCFE-436F-BC08-597A587ECA2C} =>.Superfluous.Empty
O43 - CFD: 13/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{415AED6E-1CA0-439C-BEF8-1C5C07517CEB} =>.Superfluous.Empty
O43 - CFD: 04/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{41D52F0E-8DBC-4181-974A-CA2A61DEFE07} =>.Superfluous.Empty
O43 - CFD: 09/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{41F57C80-B74F-414D-9C9F-3B2B9EE8A5F7} =>.Superfluous.Empty
O43 - CFD: 11/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{41FB041B-50D9-4757-9518-31FC50E9C91D} =>.Superfluous.Empty
O43 - CFD: 12/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{420EA507-0407-4014-8391-B7DF34F0E913} =>.Superfluous.Empty
O43 - CFD: 14/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{423C0204-8C19-45D9-8515-D3BBEC866A3C} =>.Superfluous.Empty
O43 - CFD: 11/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{42448E57-FB5B-49BB-A8F7-1D9E85E93999} =>.Superfluous.Empty
O43 - CFD: 25/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{42A160E7-A735-4F3E-B4D4-8B7E17005097} =>.Superfluous.Empty
O43 - CFD: 02/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{42D27893-10A2-49BB-8575-F0D436DCAD6A} =>.Superfluous.Empty
O43 - CFD: 01/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{42DD85E7-1E8F-4200-8D0F-F8954C9BD59C} =>.Superfluous.Empty
O43 - CFD: 03/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{432BAAC7-560F-4C23-9495-BC054CE6696F} =>.Superfluous.Empty
O43 - CFD: 05/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{43D4B7F0-A495-429A-8E97-EEC0F86EF4AF} =>.Superfluous.Empty
O43 - CFD: 08/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4418B103-AB4A-4827-B1C6-7E58605103D1} =>.Superfluous.Empty
O43 - CFD: 03/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{4437CA53-E4F4-4E78-8B9B-DCCCDCA22C79} =>.Superfluous.Empty
O43 - CFD: 03/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{447D417E-B76D-4D70-B6AC-614F1206F85C} =>.Superfluous.Empty
O43 - CFD: 28/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{44CC3AF4-DC7D-47EA-BFC6-448572FF211E} =>.Superfluous.Empty
O43 - CFD: 28/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{44DB8DD6-CFC9-4822-8BBC-EB73C30FFB32} =>.Superfluous.Empty
O43 - CFD: 01/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{450BADB2-20A2-47D8-BFA8-B431740F7B8B} =>.Superfluous.Empty
O43 - CFD: 11/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4515F8E1-6A84-4FF5-B65C-90280073DB57} =>.Superfluous.Empty
O43 - CFD: 30/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4516F9B3-26AF-47DC-BF78-16921C226899} =>.Superfluous.Empty
O43 - CFD: 28/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{45176D26-A562-46D0-A0D0-B13F0495250B} =>.Superfluous.Empty
O43 - CFD: 23/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{453AC48C-3F96-4C03-AE92-3E704F3D263B} =>.Superfluous.Empty
O43 - CFD: 17/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4541886C-E12B-4CCB-9D48-690B2F4B7E06} =>.Superfluous.Empty
O43 - CFD: 14/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{459120EA-6592-47E8-82E8-4C824F21FA8B} =>.Superfluous.Empty
O43 - CFD: 18/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{46125E82-37F8-44A6-AB1D-34C96A24ED13} =>.Superfluous.Empty
O43 - CFD: 20/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{469CE497-237E-47AE-9243-1A36CEB1C856} =>.Superfluous.Empty
O43 - CFD: 12/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{469F1781-4236-48BF-A321-6DE729F719D2} =>.Superfluous.Empty
O43 - CFD: 29/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{46A4B2D7-7158-4772-A2F5-26FCA406D38B} =>.Superfluous.Empty
O43 - CFD: 01/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{46E5045A-E1F2-400E-AA2B-1E4CEE3FEC84} =>.Superfluous.Empty
O43 - CFD: 04/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{46EF93F5-A582-4441-9078-FCE11C1B97D7} =>.Superfluous.Empty
O43 - CFD: 21/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{471BF677-2DAC-490D-8071-08EFA57047E4} =>.Superfluous.Empty
O43 - CFD: 12/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{475C7E55-49B1-46C0-8B35-1DF652286191} =>.Superfluous.Empty
O43 - CFD: 24/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4766FB21-8417-4C6D-B898-C4BE4A447C55} =>.Superfluous.Empty
O43 - CFD: 16/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4771DBD7-D028-4C31-866A-42AD6A8EE1AA} =>.Superfluous.Empty
O43 - CFD: 19/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{47ED78B3-963C-4A92-85D6-6F3FEDD4536A} =>.Superfluous.Empty
O43 - CFD: 30/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4805F0AC-61DB-4480-BF51-71B33294DF3C} =>.Superfluous.Empty
O43 - CFD: 10/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{48111ABF-4217-44FD-A975-7966A0793D6E} =>.Superfluous.Empty
O43 - CFD: 12/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{485AC046-8655-4632-A4E4-47AE60119A91} =>.Superfluous.Empty
O43 - CFD: 24/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{488798A2-012D-4D97-B5F1-21A0DD3DE75D} =>.Superfluous.Empty
O43 - CFD: 03/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{489236BF-B356-4ECF-A0AE-E8BFF8665F78} =>.Superfluous.Empty
O43 - CFD: 05/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{48BEAE9D-A758-4801-85BD-5573EE21036C} =>.Superfluous.Empty
O43 - CFD: 18/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{48F6259E-4787-414F-A69F-77BC7EC2B6F1} =>.Superfluous.Empty
O43 - CFD: 13/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{49724A69-D352-4557-B40F-35AB36211212} =>.Superfluous.Empty
O43 - CFD: 20/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{497D646B-4C1E-42E2-8D73-800B6120E3B8} =>.Superfluous.Empty
O43 - CFD: 09/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{498B02F5-42D5-4994-9C1C-0A8447AB74C6} =>.Superfluous.Empty
O43 - CFD: 02/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{49ABBE60-12EF-4F70-A2BE-47A5BC6F73AD} =>.Superfluous.Empty
O43 - CFD: 27/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{49B91414-C9B1-4FE5-9304-A1EA37E82F75} =>.Superfluous.Empty
O43 - CFD: 26/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{49BD6221-F6B2-4220-9E3A-C295279C37B3} =>.Superfluous.Empty
O43 - CFD: 11/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4A23646D-7C06-486A-8E1E-CFA668A8DECB} =>.Superfluous.Empty
O43 - CFD: 11/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4A566AF5-B59C-4FD6-BC51-6FDB0B6FF52D} =>.Superfluous.Empty
O43 - CFD: 18/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4AA2AF1D-E70C-494D-ACFD-76FF507B8549} =>.Superfluous.Empty
O43 - CFD: 30/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4AC0D3C2-2007-4C32-AF27-C324D17B3B15} =>.Superfluous.Empty
O43 - CFD: 13/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4AD9B938-5AC8-491F-9E3A-7AE283CAE950} =>.Superfluous.Empty
O43 - CFD: 23/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4AFDC8C9-1E17-440E-97EE-08984AD4627C} =>.Superfluous.Empty
O43 - CFD: 30/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4BCC82EA-F722-4B98-BB25-3E85F5F98601} =>.Superfluous.Empty
O43 - CFD: 27/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4BF3B1A4-54D6-4090-9D0C-F0039D119F4A} =>.Superfluous.Empty
O43 - CFD: 13/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4C42C486-3134-46B7-BA17-CFB0F46141ED} =>.Superfluous.Empty
O43 - CFD: 03/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4C460C36-E52C-4E6C-978E-A5B47BC56C3C} =>.Superfluous.Empty
O43 - CFD: 24/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4CA68B97-CE68-452C-8FFC-DA04C865921E} =>.Superfluous.Empty
O43 - CFD: 14/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4D616C49-5F01-4B4D-A2AD-CA6D70F43311} =>.Superfluous.Empty
O43 - CFD: 15/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4D702BA2-1EBC-48DB-9580-7C0A9EF88B0C} =>.Superfluous.Empty
O43 - CFD: 25/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4DF26A24-A934-4761-B17A-8F19CF1FA16A} =>.Superfluous.Empty
O43 - CFD: 11/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4E41826B-4C71-4EBA-90DA-4333427C027F} =>.Superfluous.Empty
O43 - CFD: 10/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4E82E4B8-E456-454B-902C-6BE66197B834} =>.Superfluous.Empty
O43 - CFD: 21/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4E92F801-C43A-431A-860D-8253F0BED85F} =>.Superfluous.Empty
O43 - CFD: 01/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{4EC66415-A23A-496E-847C-C7AF01238DEF} =>.Superfluous.Empty
O43 - CFD: 16/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{4EE52C6A-A914-4947-9B16-AA48C001D113} =>.Superfluous.Empty
O43 - CFD: 08/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4EE67263-4F03-4717-9CCA-8B35D036CAA2} =>.Superfluous.Empty
O43 - CFD: 14/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4EF65B8C-4F14-4677-853B-B7A60DFFE18A} =>.Superfluous.Empty
O43 - CFD: 15/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4F798DC3-361A-463E-A4B3-279687C7471E} =>.Superfluous.Empty
O43 - CFD: 25/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4F9ED79E-8CC3-4F62-8D8A-344D7F19A307} =>.Superfluous.Empty
O43 - CFD: 06/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{4FB78C94-8F7C-4A44-AB7A-6DEDD480D312} =>.Superfluous.Empty
O43 - CFD: 19/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{4FC68D5E-0EB1-446E-AF35-E243863E7368} =>.Superfluous.Empty
O43 - CFD: 23/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4FD5E10D-693D-4CDC-A9B5-A6414ED0EE8F} =>.Superfluous.Empty
O43 - CFD: 19/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{4FF40F1C-6D05-43BF-B2E4-93E9363D1B14} =>.Superfluous.Empty
O43 - CFD: 11/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{50086AFF-A436-470C-91E1-49215C290DB4} =>.Superfluous.Empty
O43 - CFD: 09/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{500F9B1C-AD47-4875-B0A2-B532111B4D2B} =>.Superfluous.Empty
O43 - CFD: 22/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{504E7134-D62E-4762-95AA-B169D9E6615E} =>.Superfluous.Empty
O43 - CFD: 01/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{508E74D6-4060-4F68-8A79-BD5A5246E59F} =>.Superfluous.Empty
O43 - CFD: 31/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5120BB39-A5B6-4686-9150-9CF0917B9D7C} =>.Superfluous.Empty
O43 - CFD: 12/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{51385BEB-DE32-45DE-AC4D-451D67DDECBD} =>.Superfluous.Empty
O43 - CFD: 21/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{513B63CC-0AC7-464A-8806-FADB97916F42} =>.Superfluous.Empty
O43 - CFD: 10/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5182BBFC-01A1-403E-B78B-897E1EC02493} =>.Superfluous.Empty
O43 - CFD: 11/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{518A15F5-1637-457F-88CA-63189CC878D1} =>.Superfluous.Empty
O43 - CFD: 16/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{51C96829-B891-4C25-BB32-03CA79EBA199} =>.Superfluous.Empty
O43 - CFD: 29/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5202EACC-4FC0-4CD9-A743-BB8753BA6483} =>.Superfluous.Empty
O43 - CFD: 13/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{524C8EF1-36E5-4D81-A1F9-6B08AE067D8D} =>.Superfluous.Empty
O43 - CFD: 04/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{52ACEBC5-25C9-41A3-8460-980985644472} =>.Superfluous.Empty
O43 - CFD: 13/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{52B109C1-B9F2-4E15-9D1F-8B792E3EA169} =>.Superfluous.Empty
O43 - CFD: 06/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{52C3D515-4CB9-4877-B8AF-B97109FB973A} =>.Superfluous.Empty
O43 - CFD: 28/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{52C6C4F2-0AA8-45D1-A41C-DF8790B6E9CC} =>.Superfluous.Empty
O43 - CFD: 30/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{53097F4A-F3D1-46A9-8FE1-D3038A524901} =>.Superfluous.Empty
O43 - CFD: 06/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{532AF9F0-8342-43B9-8C98-CDDA14634906} =>.Superfluous.Empty
O43 - CFD: 07/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{53457A3B-1374-4458-9165-F7B62DAC76FB} =>.Superfluous.Empty
O43 - CFD: 21/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{537214A9-8E84-4814-AE27-1730A2E9802B} =>.Superfluous.Empty
O43 - CFD: 13/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{538E74E0-24BD-4910-8696-30119BE4CCBD} =>.Superfluous.Empty
O43 - CFD: 15/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{53A564E2-65BB-411B-A19B-5558CE9AE0C2} =>.Superfluous.Empty
O43 - CFD: 17/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{53D0CCFF-7A5A-4519-A4F8-6242BD57A2B2} =>.Superfluous.Empty
O43 - CFD: 19/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{542B39C5-0981-4C0D-90F1-69F4F41CAF38} =>.Superfluous.Empty
O43 - CFD: 25/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5446B6FB-72C9-45F5-A639-7E705639E3B8} =>.Superfluous.Empty
O43 - CFD: 01/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5462B497-D2EB-4AFC-B9B2-6C7C0C7223ED} =>.Superfluous.Empty
O43 - CFD: 07/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{54D192D9-F4C4-40C9-AC50-15A0C1133A5F} =>.Superfluous.Empty
O43 - CFD: 24/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{55031BCD-58BC-4301-A8F1-6D787C5A6CC2} =>.Superfluous.Empty
O43 - CFD: 16/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{55404490-05AD-4F38-BCD3-504D484AAE94} =>.Superfluous.Empty
O43 - CFD: 27/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{55AFDACE-A8A1-467E-96A8-794E37DE6F18} =>.Superfluous.Empty
O43 - CFD: 02/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{55B2E7F5-08B4-4F7B-A289-F7FDD5F7E2A0} =>.Superfluous.Empty
O43 - CFD: 23/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{55D4CBD6-CDB2-4CD1-A13D-F83174347F45} =>.Superfluous.Empty
O43 - CFD: 28/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{55DDA15C-CA42-4BF3-A52E-DF2D01451EF3} =>.Superfluous.Empty
O43 - CFD: 25/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{55EFD70C-CC2C-4DBD-A5AC-7DD365F3B4ED} =>.Superfluous.Empty
O43 - CFD: 26/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{55F03448-17FF-47C4-BCEC-AF7887FDB129} =>.Superfluous.Empty
O43 - CFD: 07/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{55F4E578-330D-47DF-A887-C6E7AF459742} =>.Superfluous.Empty
O43 - CFD: 07/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{55F6BA16-B6E8-4FEB-A44F-A9C7294F10FF} =>.Superfluous.Empty
O43 - CFD: 26/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{566FC0A6-B87C-4BE6-B914-A9587A637AE4} =>.Superfluous.Empty
O43 - CFD: 03/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{56B2B5AA-C539-4CD0-97AA-1427237FF701} =>.Superfluous.Empty
O43 - CFD: 03/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{56CBFDFE-D9DC-46AB-8DAA-CA5FB74F2B89} =>.Superfluous.Empty
O43 - CFD: 09/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5733B5BD-6080-424B-960F-B74555B2D84D} =>.Superfluous.Empty
O43 - CFD: 17/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{57347A15-8868-4733-801B-946D47D82BA5} =>.Superfluous.Empty
O43 - CFD: 19/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{578BBB77-8785-4DD6-81AB-5375A70FB81F} =>.Superfluous.Empty
O43 - CFD: 20/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{57BAA106-AD77-4BD5-B3C0-8388C92A33E9} =>.Superfluous.Empty
O43 - CFD: 18/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{57BDA23B-E537-4593-B076-2E9503733222} =>.Superfluous.Empty
O43 - CFD: 21/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{57F60E49-217E-4A05-9EF5-4B6E90BE9E83} =>.Superfluous.Empty
O43 - CFD: 02/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{58190B47-98B9-499E-90D8-5F8E247C4835} =>.Superfluous.Empty
O43 - CFD: 10/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{583930F2-695A-4E33-9483-ED84D06F5255} =>.Superfluous.Empty
O43 - CFD: 02/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{584A564B-34F7-44AA-994B-6F7DC7435C48} =>.Superfluous.Empty
O43 - CFD: 14/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{58BB9CE9-FE14-4A35-ABAA-4B84520F73E6} =>.Superfluous.Empty
O43 - CFD: 18/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{594FE670-E64E-4F4E-99F0-828E7613F713} =>.Superfluous.Empty
O43 - CFD: 30/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{598E4CEE-B145-4383-A013-A20FC0DD1526} =>.Superfluous.Empty
O43 - CFD: 01/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{59ACEAD4-E20F-45B1-86F9-4C1B6EB5A321} =>.Superfluous.Empty
O43 - CFD: 12/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{59E1595D-2795-4646-8953-06798BB2D487} =>.Superfluous.Empty
O43 - CFD: 28/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5A188A83-C674-415E-9AA1-D56536EC0524} =>.Superfluous.Empty
O43 - CFD: 12/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5A1DF702-1EB0-4262-A3F1-78BB02A38779} =>.Superfluous.Empty
O43 - CFD: 26/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5A8DDC93-873E-4052-87BF-BF6A37B26A9E} =>.Superfluous.Empty
O43 - CFD: 10/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5ABE1793-886E-4505-B256-25B5A851BA42} =>.Superfluous.Empty
O43 - CFD: 23/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5ADF17E9-5F00-49AA-A5B2-D1BC84B9E46A} =>.Superfluous.Empty
O43 - CFD: 21/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5AE301B6-318E-4083-B1B0-A038E406DD47} =>.Superfluous.Empty
O43 - CFD: 27/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5AF39B3F-16B2-47E4-865A-8B6F4CE992FC} =>.Superfluous.Empty
O43 - CFD: 04/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5B6E7A35-87A3-448E-A981-46BDA68BF77E} =>.Superfluous.Empty
O43 - CFD: 28/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5B7A7853-26E7-4FCF-B6CE-D29305E2AB0E} =>.Superfluous.Empty
O43 - CFD: 20/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5BEC6962-4304-4474-A388-CADEF0F51B9D} =>.Superfluous.Empty
O43 - CFD: 06/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5C341C64-F35A-4BE7-8E02-A8BBC937FDE5} =>.Superfluous.Empty
O43 - CFD: 06/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5CA331F9-8D60-4CAA-A303-BC85CD4194D7} =>.Superfluous.Empty
O43 - CFD: 06/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5CA95DC0-E013-4B76-A725-59B548D3DA5A} =>.Superfluous.Empty
O43 - CFD: 01/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5CDDDAF0-8B90-4F2E-A1E9-D924ACF8EDDE} =>.Superfluous.Empty
O43 - CFD: 12/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5CE5350E-E1B7-4C52-9427-E07020D22F01} =>.Superfluous.Empty
O43 - CFD: 12/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5D0CABCE-4324-4AF1-AA06-5A8016F40867} =>.Superfluous.Empty
O43 - CFD: 14/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5D23141B-1259-4262-A35A-D02FA9CC924C} =>.Superfluous.Empty
O43 - CFD: 14/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5D521BC7-1700-4C01-8AA4-F4D4E93CF4E3} =>.Superfluous.Empty
O43 - CFD: 05/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5D7CD57A-8FFE-40A0-AD69-84F9783D99FE} =>.Superfluous.Empty
O43 - CFD: 02/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5D8DF696-4EB6-47BD-ABDA-47F0CF75C068} =>.Superfluous.Empty
O43 - CFD: 11/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5DDFBD4B-4BEB-45DB-89D6-A152871A9F13} =>.Superfluous.Empty
O43 - CFD: 10/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5DE29440-CB58-49CC-B964-8A3341C6930A} =>.Superfluous.Empty
O43 - CFD: 17/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5E08991D-23D0-437C-94F6-9945DBC2068C} =>.Superfluous.Empty
O43 - CFD: 25/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5E27CB52-476B-4F99-AB6E-488576CD8190} =>.Superfluous.Empty
O43 - CFD: 26/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5E606983-3353-4DEC-9168-1E1AD43AA98E} =>.Superfluous.Empty
O43 - CFD: 16/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5EA8EFDA-3881-49EC-A80E-0EBEEE564D90} =>.Superfluous.Empty
O43 - CFD: 19/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5EB6DBD6-7609-4E3C-9B08-8B19EE6D899F} =>.Superfluous.Empty
O43 - CFD: 10/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{5EC0E443-9853-4457-AD4C-F7415564815E} =>.Superfluous.Empty
O43 - CFD: 03/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5EC31BC3-F59F-4AB4-91C3-67455799146B} =>.Superfluous.Empty
O43 - CFD: 23/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{5EC93EB6-D7F4-44DB-8DB8-FB5EFE9C658D} =>.Superfluous.Empty
O43 - CFD: 30/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5EE9427A-2666-41DF-9FE9-4128C8ABE0D5} =>.Superfluous.Empty
O43 - CFD: 03/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{5EF797F3-6871-4600-961A-24BCB0EF88D4} =>.Superfluous.Empty
O43 - CFD: 23/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5EF7F7C2-D8C0-4839-BD4A-7B241813ECD9} =>.Superfluous.Empty
O43 - CFD: 05/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5F20F93E-3C09-4B86-A10D-1C1074FAF1D3} =>.Superfluous.Empty
O43 - CFD: 25/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5F2E20BC-3480-434B-AA75-37B0CF280B29} =>.Superfluous.Empty
O43 - CFD: 22/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{5F63D90A-9821-49C7-BC71-B104A24BA555} =>.Superfluous.Empty
O43 - CFD: 08/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6069C204-21FA-406C-8E9D-2BFCCAADE1F9} =>.Superfluous.Empty
O43 - CFD: 06/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{60FDB66F-DB56-454E-9095-F66D227CACD0} =>.Superfluous.Empty
O43 - CFD: 16/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{61418A4B-FAA6-4521-A44E-2EAECB181D42} =>.Superfluous.Empty
O43 - CFD: 22/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{6148BD9C-0E02-4245-A049-AE552CD3CF0A} =>.Superfluous.Empty
O43 - CFD: 02/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6189A7A4-D6C8-4BEA-AA66-777CC2CC94F2} =>.Superfluous.Empty
O43 - CFD: 09/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{61CABEAB-E843-4B38-B857-3BF3C3668892} =>.Superfluous.Empty
O43 - CFD: 12/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{61CC03C0-2518-494B-B824-D2E955580CC5} =>.Superfluous.Empty
O43 - CFD: 24/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{621B9F6C-4424-42E3-8114-15527296C182} =>.Superfluous.Empty
O43 - CFD: 24/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{621FE634-2541-419A-B19C-74C53B1CB697} =>.Superfluous.Empty
O43 - CFD: 28/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{622D007A-F3E7-40E8-AFAB-08BC46DD01FE} =>.Superfluous.Empty
O43 - CFD: 04/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6254937F-6522-4542-82FC-FF94ECD66F75} =>.Superfluous.Empty
O43 - CFD: 16/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6254AE7D-6CA7-4942-ADA3-25BCE9E456DF} =>.Superfluous.Empty
O43 - CFD: 15/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{628A29C5-3C44-46A4-9CDF-8AC236C63383} =>.Superfluous.Empty
O43 - CFD: 18/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{62EB4BBE-5B03-44B0-80FB-FE040E59EC8E} =>.Superfluous.Empty
O43 - CFD: 22/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{632EAED4-A701-49CC-8997-28D3341A7906} =>.Superfluous.Empty
O43 - CFD: 09/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{63E992A6-0358-48CA-B4B5-339CED9FF3ED} =>.Superfluous.Empty
O43 - CFD: 26/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{63F0FA44-B873-48B1-8CD0-BF9F22FACD6E} =>.Superfluous.Empty
O43 - CFD: 14/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{63FA0A48-A951-4BB8-B473-129F7ACD81D8} =>.Superfluous.Empty
O43 - CFD: 26/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{640E1DFF-0B0C-488D-93AF-09DEDAF409BD} =>.Superfluous.Empty
O43 - CFD: 04/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6411E811-DD61-4351-AABD-6383039E87B1} =>.Superfluous.Empty
O43 - CFD: 06/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6415ABDC-92E7-4483-98E1-047412D9A46A} =>.Superfluous.Empty
O43 - CFD: 27/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{643EEE55-E866-4F68-A943-3B0B5B333C7F} =>.Superfluous.Empty
O43 - CFD: 22/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{64B73553-0A7B-4C1B-8976-613DE75E1C99} =>.Superfluous.Empty
O43 - CFD: 27/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{64EFDD13-F292-43A7-8D58-1BCA292599C1} =>.Superfluous.Empty
O43 - CFD: 10/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6511B221-9C25-4DAF-B1B5-692AD99D0BB9} =>.Superfluous.Empty
O43 - CFD: 01/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6557096E-3281-457D-820E-BD8E27BBFAAF} =>.Superfluous.Empty
O43 - CFD: 17/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{65844EC1-8FF6-40DD-BEC2-8ABFAD7F51BA} =>.Superfluous.Empty
O43 - CFD: 16/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{65A3ED19-B1A7-4427-B2CC-AAF7B8F32655} =>.Superfluous.Empty
O43 - CFD: 30/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{65C811BA-570F-4AAA-810B-B26A91229AD3} =>.Superfluous.Empty
O43 - CFD: 21/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6600DAAC-A02A-491E-A5D5-82684A9C4DE7} =>.Superfluous.Empty
O43 - CFD: 28/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{66061C42-ACFB-4DE3-804E-61727E1D9422} =>.Superfluous.Empty
O43 - CFD: 23/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6606F495-7389-49AA-B78C-8D5EB5FA73A5} =>.Superfluous.Empty
O43 - CFD: 19/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{663087F0-4FD9-4E77-B303-15FE7B2E152C} =>.Superfluous.Empty
O43 - CFD: 19/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{66365412-16BF-4030-B03F-5152B86F7721} =>.Superfluous.Empty
O43 - CFD: 30/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6648E6D0-B398-46E2-ACA9-F434DF0C3F1D} =>.Superfluous.Empty
O43 - CFD: 03/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{664C900E-FB91-414F-B18B-467BC8D2BB83} =>.Superfluous.Empty
O43 - CFD: 29/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{666034AD-73F1-4E56-B76D-42789704D341} =>.Superfluous.Empty
O43 - CFD: 27/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{668A6CB6-5CE8-458B-8740-6524047FD5EF} =>.Superfluous.Empty
O43 - CFD: 07/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{66AB72DC-0E8E-42A1-90DF-7B8955F309DB} =>.Superfluous.Empty
O43 - CFD: 20/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6731013E-0C2B-47FE-9233-F5FE09AFBC70} =>.Superfluous.Empty
O43 - CFD: 02/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{673C93CF-579D-4180-B830-D9BC2CAD9DEF} =>.Superfluous.Empty
O43 - CFD: 03/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{675AB79F-BAE1-484C-BECB-3B9FBB749F6D} =>.Superfluous.Empty
O43 - CFD: 20/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{67A19FCA-3DB9-4CB1-B458-CAD2013B0533} =>.Superfluous.Empty
O43 - CFD: 11/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{68049C59-8B72-4D7B-92F9-1149B629CDD0} =>.Superfluous.Empty
O43 - CFD: 29/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{68745A6B-45CB-4E1E-8503-AE5306CE4912} =>.Superfluous.Empty
O43 - CFD: 19/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{687CD915-B0EF-4B20-9177-FBD283D10A85} =>.Superfluous.Empty
O43 - CFD: 05/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{690F0974-3E7A-40E1-A701-EA63B61CC0C7} =>.Superfluous.Empty
O43 - CFD: 17/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{692AE442-7953-48F9-830F-4FB4BD8B28FC} =>.Superfluous.Empty
O43 - CFD: 23/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{694504D2-367C-46F3-BF61-70028063CC06} =>.Superfluous.Empty
O43 - CFD: 23/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{6A0F3363-7C5E-4DA7-9EB5-F2FB0F1DDDEE} =>.Superfluous.Empty
O43 - CFD: 26/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6AE5CD3E-E613-4435-8BA2-C6BA878F04BF} =>.Superfluous.Empty
O43 - CFD: 25/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6AE9D0A5-6C69-4EC6-82CE-00A3F4DC9962} =>.Superfluous.Empty
O43 - CFD: 06/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6B6E5B1F-755B-4B2C-82F1-D55A5EF46EA2} =>.Superfluous.Empty
O43 - CFD: 25/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6BA44121-373B-47D2-932C-2DE78CB1FCF7} =>.Superfluous.Empty
O43 - CFD: 04/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6C37A1EB-9025-442E-B1C0-E3161850876B} =>.Superfluous.Empty
O43 - CFD: 10/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6C67A2D6-52D0-45FA-BD0C-169E9C8B1088} =>.Superfluous.Empty
O43 - CFD: 02/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6C68EBE5-EEA1-4C0E-9C65-359E40ECA5A2} =>.Superfluous.Empty
O43 - CFD: 07/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6C6A1030-7086-438C-9940-5B911AAE23E2} =>.Superfluous.Empty
O43 - CFD: 17/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6C914F2D-5CBD-4B60-8040-43B22A5E2E72} =>.Superfluous.Empty
O43 - CFD: 22/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6CB03EA2-FE34-455D-87BF-F3A426BBF0EA} =>.Superfluous.Empty
O43 - CFD: 15/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6CF00AEE-E8A2-4C88-B3E0-AC39B289999D} =>.Superfluous.Empty
O43 - CFD: 18/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6D2EAE7C-B653-456F-8471-6EA6F7C12954} =>.Superfluous.Empty
O43 - CFD: 02/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6D3CC4BF-4637-49C5-AB88-65E809969FDB} =>.Superfluous.Empty
O43 - CFD: 24/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6D9B917D-2143-490A-AF92-8122478987B6} =>.Superfluous.Empty
O43 - CFD: 13/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6DA517DD-C781-43E1-A3C4-383C6C19B113} =>.Superfluous.Empty
O43 - CFD: 28/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6DEC3E2C-0AED-45B1-BCD7-FE357E1721A9} =>.Superfluous.Empty
O43 - CFD: 15/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6DF45E28-E663-456F-B523-AB8EEFCFEC4B} =>.Superfluous.Empty
O43 - CFD: 25/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{6E53F843-83DC-491C-AF38-445F9A3F122F} =>.Superfluous.Empty
O43 - CFD: 23/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6E58C893-C9E0-4D09-94CA-47B32137589B} =>.Superfluous.Empty
O43 - CFD: 14/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6E9E52D1-9E90-4204-8F8A-5F3512E1F812} =>.Superfluous.Empty
O43 - CFD: 03/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6EB3D602-A8B7-4890-89BA-1FBBEFD59FA1} =>.Superfluous.Empty
O43 - CFD: 12/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6EB539B8-2E24-4F66-A427-7743AAE23F50} =>.Superfluous.Empty
O43 - CFD: 24/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{6EF0F9D7-64A2-4BB1-B91F-6DAB42AA4AC2} =>.Superfluous.Empty
O43 - CFD: 14/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6F2405CA-DC21-41D0-ADC5-66F5192BA721} =>.Superfluous.Empty
O43 - CFD: 22/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6F27DC51-696F-4645-BE0A-EA5811DAC1BC} =>.Superfluous.Empty
O43 - CFD: 26/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6F38BC08-2276-4968-98FA-AD6C5B14139B} =>.Superfluous.Empty
O43 - CFD: 19/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6F78C823-E55A-4AA4-840C-F031366C6BA0} =>.Superfluous.Empty
O43 - CFD: 30/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{6FC1C4BA-2693-4EBF-8D0E-EE43A3561E68} =>.Superfluous.Empty
O43 - CFD: 23/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{6FE4F7FF-7FC4-430C-A0B7-7C8782451045} =>.Superfluous.Empty
O43 - CFD: 21/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{6FFE6978-967D-4276-BC53-4FCAF9A9E060} =>.Superfluous.Empty
O43 - CFD: 03/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7006ED1B-687E-46A7-A537-B94DF2058850} =>.Superfluous.Empty
O43 - CFD: 03/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7008A4E3-53DB-4C41-938F-9AB2362E901B} =>.Superfluous.Empty
O43 - CFD: 01/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{7020C63C-3DC5-4E63-942D-5ED3FA71DB40} =>.Superfluous.Empty
O43 - CFD: 07/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7027E682-ABC5-4502-97CB-DD81FFA9FB03} =>.Superfluous.Empty
O43 - CFD: 29/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7051436F-30AF-421D-A166-51EAB6F014CA} =>.Superfluous.Empty
O43 - CFD: 10/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{70926AB6-35BB-4354-A61F-281709D13BF4} =>.Superfluous.Empty
O43 - CFD: 01/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{70D12548-4552-4624-BF9E-84864CCCCB8B} =>.Superfluous.Empty
O43 - CFD: 28/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{71038911-5C6D-4A69-9D02-B4B1588A18BE} =>.Superfluous.Empty
O43 - CFD: 27/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{71121D14-675C-405B-AAD7-D7E8629749CA} =>.Superfluous.Empty
O43 - CFD: 07/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{71730AAF-F21B-46FB-85A3-D7502E681511} =>.Superfluous.Empty
O43 - CFD: 20/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{71CB4996-5D61-4533-90B3-BF5D6B1FF2D3} =>.Superfluous.Empty
O43 - CFD: 18/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{71F7F06E-7883-46D9-9312-40DB46C4C911} =>.Superfluous.Empty
O43 - CFD: 08/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7209FDB5-89AA-48A6-AC0F-6A1E55D2BB65} =>.Superfluous.Empty
O43 - CFD: 28/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7211A8F1-9FE8-4E60-AA34-24710EA63F03} =>.Superfluous.Empty
O43 - CFD: 26/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{722CCD6D-18B0-4CAE-ADAE-B7D42F29EA06} =>.Superfluous.Empty
O43 - CFD: 11/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{728D7903-7ED8-4B5E-B504-02DCED5594E2} =>.Superfluous.Empty
O43 - CFD: 01/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{730D9A21-F654-412B-AD69-DF4A43508CF0} =>.Superfluous.Empty
O43 - CFD: 07/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{732F0165-C1C8-48F9-A5A6-95080589AA47} =>.Superfluous.Empty
O43 - CFD: 18/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{73362AB3-27C5-452A-B673-F447BD3B4573} =>.Superfluous.Empty
O43 - CFD: 31/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7387A915-2B0B-4E7E-A857-BAE5A704211D} =>.Superfluous.Empty
O43 - CFD: 29/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{73AFBE90-924C-4767-ABCD-8DC00751BA2E} =>.Superfluous.Empty
O43 - CFD: 29/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{73C1ABA7-83EE-44C4-AD1A-1DB822C5179A} =>.Superfluous.Empty
O43 - CFD: 05/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{73C38685-6375-4577-9E77-6750084D11D9} =>.Superfluous.Empty
O43 - CFD: 28/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{73C7A047-05AD-4098-B76E-90B3732EF748} =>.Superfluous.Empty
O43 - CFD: 20/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{73DC3B41-886C-46A2-BB68-6BB1082BFDCA} =>.Superfluous.Empty
O43 - CFD: 26/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{73E89831-89C7-4BB8-A3FD-57FABBD1A4DE} =>.Superfluous.Empty
O43 - CFD: 07/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7433BE25-2051-4614-9828-23BBC941CCCB} =>.Superfluous.Empty
O43 - CFD: 15/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{743C66B3-D7BF-4259-8DBF-DB2019B731DF} =>.Superfluous.Empty
O43 - CFD: 24/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{748A0360-8395-4B23-B792-21BF9A5298EA} =>.Superfluous.Empty
O43 - CFD: 29/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{748E04AE-1831-499E-94A3-D206780F7BCE} =>.Superfluous.Empty
O43 - CFD: 14/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7496EA04-B529-47FC-A0C3-296AD1CE81C6} =>.Superfluous.Empty
O43 - CFD: 13/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{74B171F9-2EBD-438B-A6B8-156252B19311} =>.Superfluous.Empty
O43 - CFD: 03/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{74B6EC24-E9BC-40AD-8B37-D033B89F4DE5} =>.Superfluous.Empty
O43 - CFD: 12/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{75062E6D-A191-4D1C-AD5D-9618F88859FD} =>.Superfluous.Empty
O43 - CFD: 05/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{756844E0-9CAF-4303-A648-5F1949E0E2DC} =>.Superfluous.Empty
O43 - CFD: 08/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{757A9A1A-E7DE-4CC3-B31B-C348DE2D9573} =>.Superfluous.Empty
O43 - CFD: 21/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{757BD24C-08CE-466B-8331-7B73F6289F96} =>.Superfluous.Empty
O43 - CFD: 10/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{758209A7-6783-4C05-ACBB-B26A75FD14C2} =>.Superfluous.Empty
O43 - CFD: 28/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7592DC40-EA64-4C7E-B5A5-3B21C43E612F} =>.Superfluous.Empty
O43 - CFD: 05/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{75AFDED6-F5BD-4D42-B178-504D7F0818FF} =>.Superfluous.Empty
O43 - CFD: 30/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{75BF54A3-149D-44E4-B0EF-090541117D28} =>.Superfluous.Empty
O43 - CFD: 23/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{75E14645-3732-4370-9C2F-7B89C7686AD4} =>.Superfluous.Empty
O43 - CFD: 29/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7648916F-DCB1-43FA-A982-F2759B3019D5} =>.Superfluous.Empty
O43 - CFD: 23/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{768C9885-D6EF-4301-966E-2143A1C1649A} =>.Superfluous.Empty
O43 - CFD: 26/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7697A129-F554-4050-8746-6C742C39BA57} =>.Superfluous.Empty
O43 - CFD: 28/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{774509F9-2139-45A0-B884-5847FA2F0509} =>.Superfluous.Empty
O43 - CFD: 24/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{77E2C162-F2C5-44CB-8CA1-27A67DBAE0D5} =>.Superfluous.Empty
O43 - CFD: 25/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{78A27F47-16D9-4B7E-AA71-E6113755F527} =>.Superfluous.Empty
O43 - CFD: 04/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{790E4F1B-45F2-43F3-A1BC-0D2842C2EEBC} =>.Superfluous.Empty
O43 - CFD: 13/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{796D03C0-BAC0-49F7-826D-7CB519351BDE} =>.Superfluous.Empty
O43 - CFD: 08/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7994496A-5DE5-469B-987F-269EC3750A31} =>.Superfluous.Empty
O43 - CFD: 23/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{79B9D148-A93C-4F72-ACB1-E13CE4AD59A9} =>.Superfluous.Empty
O43 - CFD: 21/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{79CC8C0C-A4DD-45C5-B834-920F7EFE4125} =>.Superfluous.Empty
O43 - CFD: 06/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{79E02761-1F71-49DC-A925-A7841F6F6093} =>.Superfluous.Empty
O43 - CFD: 25/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{79EE3E81-8698-419E-9785-4281C0F20EA9} =>.Superfluous.Empty
O43 - CFD: 15/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{7A18A609-36F6-43F5-BE2E-951D4A0FBED0} =>.Superfluous.Empty
O43 - CFD: 13/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7A332745-1C60-4B16-A3A2-78E66D975F8B} =>.Superfluous.Empty
O43 - CFD: 27/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7A7B99C0-365C-46A5-9558-6BD4D24BA046} =>.Superfluous.Empty
O43 - CFD: 26/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{7A7C13E5-857E-473C-AFD9-3121BA7D1863} =>.Superfluous.Empty
O43 - CFD: 04/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7B1B8901-1FE2-4900-A50C-B87A65555F35} =>.Superfluous.Empty
O43 - CFD: 17/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7B277DFC-6228-4571-B786-12747A2D265F} =>.Superfluous.Empty
O43 - CFD: 13/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7B36B49B-6173-4EBD-B4DF-EE47065D1C70} =>.Superfluous.Empty
O43 - CFD: 16/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7B37FB2E-FC90-4E38-828D-9BC5D3059D1C} =>.Superfluous.Empty
O43 - CFD: 18/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7BBFCD26-776B-4294-96BE-EB02F5AC4985} =>.Superfluous.Empty
O43 - CFD: 22/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7BF5276D-B8F9-4BAA-B9C7-10931161BFB4} =>.Superfluous.Empty
O43 - CFD: 02/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7C2C2C89-1F41-456F-9CA8-652769D5F3E2} =>.Superfluous.Empty
O43 - CFD: 31/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7C49B76A-3A35-49B0-AF03-BF8CBAE90F2D} =>.Superfluous.Empty
O43 - CFD: 26/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7C841772-0933-47FD-908B-B42F580B4A61} =>.Superfluous.Empty
O43 - CFD: 18/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7CDACA88-B263-4759-8ED9-C2106BC59EFA} =>.Superfluous.Empty
O43 - CFD: 24/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{7CE3D7CF-8400-4A50-88F9-11F0C77C2831} =>.Superfluous.Empty
O43 - CFD: 27/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7DDC5D03-7C46-4672-AD67-C06578493759} =>.Superfluous.Empty
O43 - CFD: 21/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7DFF71D9-220E-4A7B-BE23-2F6C8DD408DC} =>.Superfluous.Empty
O43 - CFD: 27/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7E312A67-D0EB-4415-ABF5-F680D6CD6667} =>.Superfluous.Empty
O43 - CFD: 04/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7E89CE97-B81E-4847-9D33-7DA782251A21} =>.Superfluous.Empty
O43 - CFD: 01/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7E9F287E-DD34-4C7F-BB94-C9C7573A5C9D} =>.Superfluous.Empty
O43 - CFD: 23/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7ECF7ABB-23F4-4FA8-914C-08360D6FE557} =>.Superfluous.Empty
O43 - CFD: 17/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7EEE06DF-3A95-4945-A250-8DA23D101B45} =>.Superfluous.Empty
O43 - CFD: 08/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7EF5C9A2-41FF-4CF2-A899-3F23763FA14E} =>.Superfluous.Empty
O43 - CFD: 02/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7EF7F466-2519-4753-8C8C-6F0CC915FB98} =>.Superfluous.Empty
O43 - CFD: 02/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7F0C18C2-B384-4DE8-A2B5-DFECB44CBECB} =>.Superfluous.Empty
O43 - CFD: 13/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{7F58D3C1-C7C5-4A8D-81C9-ABFBEFC2AFC6} =>.Superfluous.Empty
O43 - CFD: 01/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7F922A27-765E-49C5-83E0-F06B99E5C1BD} =>.Superfluous.Empty
O43 - CFD: 10/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7F9BADD0-E44D-4F07-9C05-3C70CC5F3E76} =>.Superfluous.Empty
O43 - CFD: 12/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{7FD52D52-6804-43BC-A875-49C42C3DE848} =>.Superfluous.Empty
O43 - CFD: 12/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7FDDA335-EAF9-4581-AC6F-E9ED925CB5F8} =>.Superfluous.Empty
O43 - CFD: 07/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7FDE5499-E910-40E8-B609-88256FBA6074} =>.Superfluous.Empty
O43 - CFD: 20/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{7FE54D1B-DB19-43B9-964A-0E0583E92A10} =>.Superfluous.Empty
O43 - CFD: 09/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{7FEA3DF4-8AD4-47E4-9174-389ED284717D} =>.Superfluous.Empty
O43 - CFD: 14/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8001040B-9D2A-4D5A-B375-46406BBAE1F9} =>.Superfluous.Empty
O43 - CFD: 25/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{804387A3-A488-4318-9F6F-5EBB5E428432} =>.Superfluous.Empty
O43 - CFD: 13/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8057F71B-24DE-47CC-A00F-1E4A097C672C} =>.Superfluous.Empty
O43 - CFD: 11/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{80C44045-DE7E-4C71-9EA5-E7EBAB2AAE78} =>.Superfluous.Empty
O43 - CFD: 19/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{80D40B0E-51BA-49F0-A2B6-0F84115C5EC3} =>.Superfluous.Empty
O43 - CFD: 10/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{81875FC7-DA30-40EF-8542-978728B0F4D2} =>.Superfluous.Empty
O43 - CFD: 29/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{81877559-F9A2-4318-8457-9F2850C6FF43} =>.Superfluous.Empty
O43 - CFD: 13/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{81D14B20-4495-4BF6-9C2F-94FFC6FE7DDF} =>.Superfluous.Empty
O43 - CFD: 16/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{81EA09CF-C3C5-4D16-BBFD-5275AB3DD0F6} =>.Superfluous.Empty
O43 - CFD: 14/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{820A5821-0145-470D-8039-B34C65E5887F} =>.Superfluous.Empty
O43 - CFD: 10/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{821645EF-5B29-4E54-87AF-A0B8399AACB7} =>.Superfluous.Empty
O43 - CFD: 19/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8222F11C-E625-4ABE-96E2-D160823C5AE9} =>.Superfluous.Empty
O43 - CFD: 20/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{825D9CA4-1774-4F54-9A78-BD2A8102798C} =>.Superfluous.Empty
O43 - CFD: 09/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{827FCE84-2494-4D8D-B7DE-BF2BD5025C32} =>.Superfluous.Empty
O43 - CFD: 22/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8311D558-FCE6-4096-9AFD-9B56555C6E2C} =>.Superfluous.Empty
O43 - CFD: 01/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{833BD959-52C4-4003-887E-1E9E02F19AF5} =>.Superfluous.Empty
O43 - CFD: 18/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{83966C69-575E-4C37-8B5E-9E9438AB8EE2} =>.Superfluous.Empty
O43 - CFD: 17/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{83C1A57E-A2A7-4522-83F5-B9D9846785EE} =>.Superfluous.Empty
O43 - CFD: 31/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{840D9F8A-D8D2-446B-807B-0614E177EA84} =>.Superfluous.Empty
O43 - CFD: 02/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8439FDEE-CAAB-4E57-918C-3B5596E1CA7A} =>.Superfluous.Empty
O43 - CFD: 28/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8443C746-0DF7-4994-8090-5A1851D35AD6} =>.Superfluous.Empty
O43 - CFD: 13/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8445A7D1-FC12-4761-BF23-8192001CDC6C} =>.Superfluous.Empty
O43 - CFD: 02/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{846A29F0-DF04-4399-801A-026991490514} =>.Superfluous.Empty
O43 - CFD: 01/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8482CF75-2CFA-4DDF-9137-51D1FA9F6275} =>.Superfluous.Empty
O43 - CFD: 27/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{84C1CDEF-874C-4A30-925A-D1D18042A11A} =>.Superfluous.Empty
O43 - CFD: 15/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{84F61F29-6791-4DA0-802C-9AB5C81F4478} =>.Superfluous.Empty
O43 - CFD: 12/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{84F86052-E498-4720-9292-5EFD20019A97} =>.Superfluous.Empty
O43 - CFD: 28/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{85410C08-9EF2-467C-9AF0-41E4556C687F} =>.Superfluous.Empty
O43 - CFD: 06/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{857C0611-24C0-4248-A089-550E16A2097C} =>.Superfluous.Empty
O43 - CFD: 29/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{85865A82-8E82-403B-AECA-12928D32BA4C} =>.Superfluous.Empty
O43 - CFD: 24/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{85C94C66-5F2C-4E46-B44E-5FE340B548D2} =>.Superfluous.Empty
O43 - CFD: 29/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{85DAFCB3-79DD-4027-9A34-AE291075F36A} =>.Superfluous.Empty
O43 - CFD: 17/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{85E77535-D93B-453B-8457-830FE9F6EB6E} =>.Superfluous.Empty
O43 - CFD: 20/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{8671F1EC-7D0C-43A2-BC39-9C9373CCB8CC} =>.Superfluous.Empty
O43 - CFD: 30/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8674030F-1C81-46A6-A9A0-756FD318D53B} =>.Superfluous.Empty
O43 - CFD: 12/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{86E61FCC-B32A-419E-AE85-EDC57D034BA0} =>.Superfluous.Empty
O43 - CFD: 28/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{86FB969E-350D-4D90-B95E-DE80CF473D99} =>.Superfluous.Empty
O43 - CFD: 07/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{87040070-9EEA-485D-A620-8E1EB821AC2B} =>.Superfluous.Empty
O43 - CFD: 28/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{877FA722-CFA6-449F-9102-AFB743314592} =>.Superfluous.Empty
O43 - CFD: 08/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{878DC37B-5907-401C-8A39-FFDE19C74197} =>.Superfluous.Empty
O43 - CFD: 11/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{87BC9FA1-A4E8-4BCC-A246-0202483BB746} =>.Superfluous.Empty
O43 - CFD: 12/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{88510875-1327-4F9A-8E29-5A6421EEA503} =>.Superfluous.Empty
O43 - CFD: 27/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{88546A96-5C00-44BF-88FA-A677ED3E334F} =>.Superfluous.Empty
O43 - CFD: 18/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{88E1F5E1-E696-4C40-BFBC-2906CAD0196A} =>.Superfluous.Empty
O43 - CFD: 24/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{89007182-8720-4804-BC98-B62138960D37} =>.Superfluous.Empty
O43 - CFD: 02/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{89378FF2-F5D6-4E3A-8FE3-D1C5A770ABB1} =>.Superfluous.Empty
O43 - CFD: 02/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{896C1649-8CFF-44CA-AD3D-9854E0380C2B} =>.Superfluous.Empty
O43 - CFD: 19/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{89AE6499-320F-4227-AF41-3588AE87C801} =>.Superfluous.Empty
O43 - CFD: 15/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{89B06C57-7B10-4E7F-88E4-9188D16571E2} =>.Superfluous.Empty
O43 - CFD: 12/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{89C05976-5ED1-43D5-A8F3-35FA4E6D3388} =>.Superfluous.Empty
O43 - CFD: 15/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8A1CE6E0-8976-4F25-B927-D042AD3201F3} =>.Superfluous.Empty
O43 - CFD: 24/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8A5AF6AE-3431-4476-9ED4-56A61B98C1EE} =>.Superfluous.Empty
O43 - CFD: 11/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8A819D84-DB83-4745-9971-C35B91BDEB22} =>.Superfluous.Empty
O43 - CFD: 27/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{8AA8FB0C-D831-4393-A562-64867D70B58A} =>.Superfluous.Empty
O43 - CFD: 03/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8AE41BE6-E4D0-4404-BF31-D8B4C850878E} =>.Superfluous.Empty
O43 - CFD: 09/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8B120834-57E4-45D2-B776-364789880BF4} =>.Superfluous.Empty
O43 - CFD: 17/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8B58B623-6EF6-4C10-AC9F-3786365199E2} =>.Superfluous.Empty
O43 - CFD: 04/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8B630D82-50E3-4A6E-9721-BE3B336329AB} =>.Superfluous.Empty
O43 - CFD: 04/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8B70353F-C319-498F-A2A4-2ABCD0E8290E} =>.Superfluous.Empty
O43 - CFD: 13/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8BA13E4A-4553-4902-A81F-DD01CBE5AD79} =>.Superfluous.Empty
O43 - CFD: 13/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8BFF2810-8AFF-46B6-99E5-08019AFCA4F9} =>.Superfluous.Empty
O43 - CFD: 15/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8C0B7200-F7E4-4BAB-B700-C786DF3628C9} =>.Superfluous.Empty
O43 - CFD: 30/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8C14504E-D000-4E3C-828C-58D63148AD51} =>.Superfluous.Empty
O43 - CFD: 27/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{8C1574C4-9DC5-4175-8716-21F1E7D18E4E} =>.Superfluous.Empty
O43 - CFD: 21/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{8C20D0FD-884A-415A-845A-9190F3381F76} =>.Superfluous.Empty
O43 - CFD: 31/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8C231926-35BB-407C-8890-D16C35BD6A74} =>.Superfluous.Empty
O43 - CFD: 03/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8C777B51-C047-4E3F-B261-EFBF398D117F} =>.Superfluous.Empty
O43 - CFD: 09/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8C839443-54E9-40BE-86BD-17CDF648D13A} =>.Superfluous.Empty
O43 - CFD: 25/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8C8C91F4-C135-4969-AE52-CCB60D3FB305} =>.Superfluous.Empty
O43 - CFD: 28/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8C9A10BD-40F4-4A88-8D54-EF7501C0293A} =>.Superfluous.Empty
O43 - CFD: 22/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8CB44036-1967-4A13-A953-B6859C1A692A} =>.Superfluous.Empty
O43 - CFD: 17/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8D1C4EA8-F888-4971-9D8E-DF85C223DB60} =>.Superfluous.Empty
O43 - CFD: 25/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8D3BF31A-DB57-4292-8367-27650A50B53F} =>.Superfluous.Empty
O43 - CFD: 27/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8D3F6E75-49B8-4E6A-91F8-DCDE094D5BC1} =>.Superfluous.Empty
O43 - CFD: 12/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8D5311A5-DC89-43A7-85E8-6E3423DFCE22} =>.Superfluous.Empty
O43 - CFD: 16/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8DD487F5-C389-482C-98C9-2D43E7059B44} =>.Superfluous.Empty
O43 - CFD: 15/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8DDAC5B4-DEA7-4F72-B88B-F7250A010C72} =>.Superfluous.Empty
O43 - CFD: 20/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8E5D4206-2CBF-4678-9AE2-B912BE5D4207} =>.Superfluous.Empty
O43 - CFD: 31/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8E5E10D3-B75E-4127-AFAD-1CD76EEFFBB4} =>.Superfluous.Empty
O43 - CFD: 06/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8E6C6B54-D9E7-41D9-AA5D-4D776B9C5379} =>.Superfluous.Empty
O43 - CFD: 24/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8E92AC75-BCFE-420F-8427-DD0CF3933BD1} =>.Superfluous.Empty
O43 - CFD: 12/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8E9FFA64-1C55-47F6-A534-E40CE664AFD6} =>.Superfluous.Empty
O43 - CFD: 26/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8EE6C6CF-1984-4FBA-A507-A2054300C2D6} =>.Superfluous.Empty
O43 - CFD: 21/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8EF1451D-B517-429B-A896-9F29D7864127} =>.Superfluous.Empty
O43 - CFD: 01/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8EFCF36B-A24B-4F11-9E5F-5C36F9E4B1B4} =>.Superfluous.Empty
O43 - CFD: 21/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{8F01A5C2-98F7-4580-9604-6F299FA9D926} =>.Superfluous.Empty
O43 - CFD: 08/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8F2BAB9B-1ABF-40C8-B8DB-FB76C32A9C26} =>.Superfluous.Empty
O43 - CFD: 11/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8F336FF5-F131-40A2-BA84-43607D53865C} =>.Superfluous.Empty
O43 - CFD: 05/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{8F9E6566-F5ED-41BD-B5A2-C4D49B8BD86E} =>.Superfluous.Empty
O43 - CFD: 05/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8FB28BBD-78E4-46B8-843B-64CC0A26ACF9} =>.Superfluous.Empty
O43 - CFD: 10/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{8FBFD45D-7662-4EF7-9447-F3FC8B202B77} =>.Superfluous.Empty
O43 - CFD: 09/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{8FEFF1AD-6ACB-452F-BB40-E1409F8AF3BC} =>.Superfluous.Empty
O43 - CFD: 11/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{901D42A9-9DB4-4633-8A42-A2823F58A01E} =>.Superfluous.Empty
O43 - CFD: 30/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9033C9D1-4823-469F-9F60-55BA88181626} =>.Superfluous.Empty
O43 - CFD: 12/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{90D40A2E-81AF-48F3-A6B0-597C6C741147} =>.Superfluous.Empty
O43 - CFD: 09/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{90F5B342-7185-4FA3-9284-8EE41E65DACE} =>.Superfluous.Empty
O43 - CFD: 27/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{911B243F-2D8E-4497-A356-146A208C52FC} =>.Superfluous.Empty
O43 - CFD: 01/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{914BEC64-D3C6-40C5-84B6-33A05D18F3F9} =>.Superfluous.Empty
O43 - CFD: 03/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{91B18221-D4E6-4AA6-97A3-59ED218EA038} =>.Superfluous.Empty
O43 - CFD: 03/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{921D5C11-0DB3-40EE-9367-B01BECFE97C8} =>.Superfluous.Empty
O43 - CFD: 18/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{922D2CBA-D53D-48E5-9BF9-1F335311C24F} =>.Superfluous.Empty
O43 - CFD: 20/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{923B514F-1606-4FB8-884A-35269DDD3FFA} =>.Superfluous.Empty
O43 - CFD: 23/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{92501134-A263-40AA-839E-97F80BD3D596} =>.Superfluous.Empty
O43 - CFD: 11/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9278457D-B51C-41AE-83CA-1BF87821B004} =>.Superfluous.Empty
O43 - CFD: 11/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{929BE7B9-D1A9-4E35-B1A9-F20AD65D7040} =>.Superfluous.Empty
O43 - CFD: 08/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{92A78C98-5BF7-4687-946A-729592F53679} =>.Superfluous.Empty
O43 - CFD: 18/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{92BFC3DD-8CC2-4A5D-AAB4-6A0CECCD6778} =>.Superfluous.Empty
O43 - CFD: 10/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{92E0F7C9-806D-4C7E-BC9E-41E06FA9CC70} =>.Superfluous.Empty
O43 - CFD: 03/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{931CAE49-399B-4F0A-BBB8-AECAD7147CAC} =>.Superfluous.Empty
O43 - CFD: 13/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{934D96C9-9811-4FAA-9C1E-E045C5262BF3} =>.Superfluous.Empty
O43 - CFD: 28/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9406F315-14FC-4FAC-ACC5-452ECF9B3956} =>.Superfluous.Empty
O43 - CFD: 26/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{94188E61-21B0-4C15-A870-0CDB431C7391} =>.Superfluous.Empty
O43 - CFD: 02/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{941CF8CA-B7B8-4D51-9F43-00A8C8C5F17D} =>.Superfluous.Empty
O43 - CFD: 10/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9421D4FF-ADD8-4054-AD4D-9518C7DEBD87} =>.Superfluous.Empty
O43 - CFD: 27/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{942DAF27-25E7-4682-B7D7-10C5FE8EB2F0} =>.Superfluous.Empty
O43 - CFD: 24/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{942EE94C-6522-4ED9-8DC0-6E16F2438023} =>.Superfluous.Empty
O43 - CFD: 10/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{944EB25A-7889-42D3-8E91-62B835295500} =>.Superfluous.Empty
O43 - CFD: 19/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{949E6731-6745-4EA0-A289-F6BB8E464442} =>.Superfluous.Empty
O43 - CFD: 05/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{94D93528-135A-40BC-8EA0-AA07E166ECFA} =>.Superfluous.Empty
O43 - CFD: 13/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{95269C40-7914-4BAF-94AF-D144930C65D4} =>.Superfluous.Empty
O43 - CFD: 06/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{957DC5E1-6E1A-43EA-BA9B-D5A87E1AC46A} =>.Superfluous.Empty
O43 - CFD: 21/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{95B4D75C-D3D6-4CB3-8E12-9AD7AE0E12C7} =>.Superfluous.Empty
O43 - CFD: 16/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{95D360F4-9178-4E0B-B7E8-510665E4F7F1} =>.Superfluous.Empty
O43 - CFD: 03/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{95FD37E4-F638-48CA-8F35-CE8A329163C4} =>.Superfluous.Empty
O43 - CFD: 25/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9681E46C-C82A-4256-B9C8-03062BE9A430} =>.Superfluous.Empty
O43 - CFD: 23/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{975F1EA3-EFBB-48C5-B3DA-8E21C58B1FAC} =>.Superfluous.Empty
O43 - CFD: 15/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{97A4DF70-8FDF-40D5-8A2C-E6EB02DB04C3} =>.Superfluous.Empty
O43 - CFD: 02/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{97D3F021-29A2-4A6B-855E-C7615E930D52} =>.Superfluous.Empty
O43 - CFD: 05/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{982136F4-C564-4172-9589-075879B67321} =>.Superfluous.Empty
O43 - CFD: 28/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{98EBA3D0-D2AA-4206-A8C9-AF20D6ECE6C7} =>.Superfluous.Empty
O43 - CFD: 16/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{98F9F845-7980-45D4-89EA-4BA1C1BB5C2F} =>.Superfluous.Empty
O43 - CFD: 08/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9929E1CF-10A4-4654-91CC-37F2AFF6B7CB} =>.Superfluous.Empty
O43 - CFD: 27/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9959B372-F0C9-44E6-8FA8-E3E25047D747} =>.Superfluous.Empty
O43 - CFD: 25/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{99833A68-BC57-4B9D-9026-7F2AEE761383} =>.Superfluous.Empty
O43 - CFD: 19/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{99D43219-8038-4D8D-9249-9150F7B5D329} =>.Superfluous.Empty
O43 - CFD: 19/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{99F11DC2-8142-4915-BEFB-D846615A5A2F} =>.Superfluous.Empty
O43 - CFD: 03/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{99F331FC-0B11-4B7D-BD55-84D53C3557CF} =>.Superfluous.Empty
O43 - CFD: 07/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9A03478B-F3E2-4461-9F1B-B436AC8891D1} =>.Superfluous.Empty
O43 - CFD: 16/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{9A0F2A6D-A1D0-488C-8380-BD712EC9108B} =>.Superfluous.Empty
O43 - CFD: 13/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9A293646-2975-40A5-BDC6-7C9626734C49} =>.Superfluous.Empty
O43 - CFD: 25/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9A43CEAA-EC72-4FAC-ADFB-27FD7A819B36} =>.Superfluous.Empty
O43 - CFD: 20/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9A499268-6EC8-4BAF-B4F1-4D3F46692053} =>.Superfluous.Empty
O43 - CFD: 22/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{9A94ABE0-992F-4C60-95E4-A2ADB0343AA0} =>.Superfluous.Empty
O43 - CFD: 16/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9AA3FB71-9046-470E-863C-43A51C472A3A} =>.Superfluous.Empty
O43 - CFD: 24/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9AAAE729-4EA7-4EE6-8CBE-2C05018B82E0} =>.Superfluous.Empty
O43 - CFD: 12/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9AD953C9-11CA-4831-907D-82ADDF14F3DC} =>.Superfluous.Empty
O43 - CFD: 12/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9AE11A78-C662-4DB7-B75E-A26B9F370847} =>.Superfluous.Empty
O43 - CFD: 15/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{9AE2AE9A-6EA5-458F-B20B-D706A7EA2257} =>.Superfluous.Empty
O43 - CFD: 08/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9B0247B8-D242-4F9D-9E3E-5F1975C59B67} =>.Superfluous.Empty
O43 - CFD: 11/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9B655DAF-6A36-4557-B3AF-443D32438C0B} =>.Superfluous.Empty
O43 - CFD: 10/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9B96CE83-CDF8-49D8-BCB3-6D402D35F92F} =>.Superfluous.Empty
O43 - CFD: 27/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9BA3B281-726F-47A3-960B-E5F84A4A0798} =>.Superfluous.Empty
O43 - CFD: 23/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9BAD6DBA-88DC-4065-A425-E46CF063916D} =>.Superfluous.Empty
O43 - CFD: 11/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9BB16A56-BB5B-4FDC-8C02-E240D0792AFC} =>.Superfluous.Empty
O43 - CFD: 11/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9BE7A770-719C-4B72-87F5-E5A0960CA9A1} =>.Superfluous.Empty
O43 - CFD: 12/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9C3577AB-4E3E-4821-8352-07B08CDD078A} =>.Superfluous.Empty
O43 - CFD: 27/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9C74B3F0-7063-4AA9-83CD-949D5D0FDAEF} =>.Superfluous.Empty
O43 - CFD: 10/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9C82F605-1AEB-4B84-A241-8D944FEB4A83} =>.Superfluous.Empty
O43 - CFD: 21/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9CBBBC70-C404-46A2-BEB5-0431C9B09AA8} =>.Superfluous.Empty
O43 - CFD: 17/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{9D09E0EE-FF07-47FF-A34D-CB16601B8EC4} =>.Superfluous.Empty
O43 - CFD: 20/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9D0E1F08-B63F-47BA-B04B-3B9CA0AAABA8} =>.Superfluous.Empty
O43 - CFD: 30/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9D178B05-C457-4B4E-9553-6FB0AF19E9C6} =>.Superfluous.Empty
O43 - CFD: 07/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9D20B00B-98C8-4A56-A151-F38CF7FA9524} =>.Superfluous.Empty
O43 - CFD: 19/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{9D83474B-D40D-431A-AA9F-940C7AFE7A25} =>.Superfluous.Empty
O43 - CFD: 30/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9DBD689B-D089-4B78-ADCD-CEB11C16FB77} =>.Superfluous.Empty
O43 - CFD: 06/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9E000580-0293-4C76-A0D1-0287ACD51CF2} =>.Superfluous.Empty
O43 - CFD: 21/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9E6C29E7-3B47-4800-892F-4083888E62E3} =>.Superfluous.Empty
O43 - CFD: 03/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9EA4BB9C-74AC-4ECE-825B-01FDCF03463A} =>.Superfluous.Empty
O43 - CFD: 30/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{9EC958E9-2912-4DE2-BC2E-C7B1DA47A7CA} =>.Superfluous.Empty
O43 - CFD: 12/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9EDA7063-DCFB-4AB1-88F9-1F217CB4F6F4} =>.Superfluous.Empty
O43 - CFD: 09/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9F4D403C-448E-4AFC-940D-5FE3DB2D7FD1} =>.Superfluous.Empty
O43 - CFD: 15/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{9F56F8DF-B9CC-4286-BDE1-F7A9AC857645} =>.Superfluous.Empty
O43 - CFD: 03/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{9FCE57DD-034D-4E66-9DA7-5DD7B805178B} =>.Superfluous.Empty
O43 - CFD: 30/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{9FFA9BEA-EA37-41EE-BCB7-A0EEC24D4030} =>.Superfluous.Empty
O43 - CFD: 12/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A0884450-3599-4285-8E0B-3C8D9E79067F} =>.Superfluous.Empty
O43 - CFD: 26/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A092C27C-5205-4D4C-A538-D3630877C5CC} =>.Superfluous.Empty
O43 - CFD: 16/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A0A01EDB-C9BB-429E-910D-27B2B8621886} =>.Superfluous.Empty
O43 - CFD: 06/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A0D4D4CA-2EBC-4486-967B-168149BF005C} =>.Superfluous.Empty
O43 - CFD: 22/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A1046706-43AF-49CC-B6B3-CF0A2D4B4DA5} =>.Superfluous.Empty
O43 - CFD: 18/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A10DD1B5-BDA3-4FFD-A0FA-DF3601FC3173} =>.Superfluous.Empty
O43 - CFD: 09/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A1F5778C-6CBD-4F99-8999-085AEF3826C3} =>.Superfluous.Empty
O43 - CFD: 19/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A215C9B5-6E95-407C-8D8B-DA3DDB3AA749} =>.Superfluous.Empty
O43 - CFD: 29/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A23C6D65-9146-4DC1-8C95-2C5770BD635F} =>.Superfluous.Empty
O43 - CFD: 24/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{A2A0E44D-972E-4CEF-8191-D5453EF61C61} =>.Superfluous.Empty
O43 - CFD: 05/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A2AA759B-E2C2-4CBC-87B0-542A63DB5D26} =>.Superfluous.Empty
O43 - CFD: 23/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A2B00AA5-6830-4F3C-9F0A-C79C732E3D68} =>.Superfluous.Empty
O43 - CFD: 14/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A2C5FD92-5AD0-4E80-957A-E6EC2F3A854C} =>.Superfluous.Empty
O43 - CFD: 23/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A2D69927-754F-47F2-8CA5-A4912B2BC4FC} =>.Superfluous.Empty
O43 - CFD: 23/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A30AFB1A-0D23-48D0-A4A5-8D99F405C403} =>.Superfluous.Empty
O43 - CFD: 04/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A31D14DD-24C5-4D78-807D-A623F2C03E3E} =>.Superfluous.Empty
O43 - CFD: 20/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A322BC78-63D2-406D-9F35-52E6C896CCA2} =>.Superfluous.Empty
O43 - CFD: 12/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A39AED39-8AF8-468B-B981-478F55B5CDEF} =>.Superfluous.Empty
O43 - CFD: 23/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A3C9853B-8733-47F1-A8B8-158BE1A8E411} =>.Superfluous.Empty
O43 - CFD: 20/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A3D2E307-7B2F-4D4C-92C1-8E5FD3FECD3B} =>.Superfluous.Empty
O43 - CFD: 22/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A3DF3DBE-9E99-4C53-BB0F-55329452A21D} =>.Superfluous.Empty
O43 - CFD: 20/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A441B159-675B-46FF-8AC0-4F02336F08C1} =>.Superfluous.Empty
O43 - CFD: 25/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A449C4EB-AF96-4F95-B422-633658D74C4D} =>.Superfluous.Empty
O43 - CFD: 10/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{A48ECB68-A6A2-4D22-BEC4-CA335695A6CA} =>.Superfluous.Empty
O43 - CFD: 16/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A4954E45-0F37-4AE2-A220-F5007A863666} =>.Superfluous.Empty
O43 - CFD: 04/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A4C12A99-DF15-4D9D-AD72-D475E084B0B5} =>.Superfluous.Empty
O43 - CFD: 10/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A509280F-1A44-4152-B12C-828BC10330E6} =>.Superfluous.Empty
O43 - CFD: 11/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A540B3FA-1ED5-4F18-944E-018ED72B596D} =>.Superfluous.Empty
O43 - CFD: 24/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A567DA9C-2A07-4971-86AC-CA1C6B715359} =>.Superfluous.Empty
O43 - CFD: 01/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A5727DC3-5ED6-4F32-9550-4BA8D32B1772} =>.Superfluous.Empty
O43 - CFD: 22/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A58D64B6-7AA2-4A75-9895-35A058D043EE} =>.Superfluous.Empty
O43 - CFD: 22/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A5C5A026-871E-4887-AA97-85611481CD36} =>.Superfluous.Empty
O43 - CFD: 22/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A5DE4499-DE41-4D80-BDB0-C04B39D9469F} =>.Superfluous.Empty
O43 - CFD: 27/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A6060F16-3DBA-443C-B196-22192A2E8903} =>.Superfluous.Empty
O43 - CFD: 22/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A635CD77-712C-4319-844B-19EF324DDFA9} =>.Superfluous.Empty
O43 - CFD: 28/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A6691FDF-2542-4883-9F25-7E461E294DCF} =>.Superfluous.Empty
O43 - CFD: 31/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A6A04A8B-6B2E-4322-BF52-51AF9A2B60A8} =>.Superfluous.Empty
O43 - CFD: 24/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A6FEC4F9-D608-4E77-990D-4D838BB9D301} =>.Superfluous.Empty
O43 - CFD: 27/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A73A6C0E-DD71-4BF3-A31E-53466247634F} =>.Superfluous.Empty
O43 - CFD: 27/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A7463546-A168-4395-A479-3FF5ACB902F4} =>.Superfluous.Empty
O43 - CFD: 08/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A79F19A5-F20B-4860-84CB-339F6AB35F9C} =>.Superfluous.Empty
O43 - CFD: 16/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A7ABDCC8-6349-477F-A0DE-17ABA0C3AB30} =>.Superfluous.Empty
O43 - CFD: 28/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A7B42BEE-2F64-4BC2-A8B1-8DDCB5532D67} =>.Superfluous.Empty
O43 - CFD: 06/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{A7E36A52-B07A-492C-9564-F6572D187A18} =>.Superfluous.Empty
O43 - CFD: 15/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{A7E7F8CE-DAEB-4ACA-AA2E-2502FD7196B0} =>.Superfluous.Empty
O43 - CFD: 11/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A80E4F57-E303-4FAE-9B7B-BFFE62DA4E72} =>.Superfluous.Empty
O43 - CFD: 09/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A83AEFC1-7F93-435A-A36E-60180820BAE5} =>.Superfluous.Empty
O43 - CFD: 04/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A84BBD78-7C7A-4FAA-8DC2-B9FCDA18E987} =>.Superfluous.Empty
O43 - CFD: 17/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A8CF0962-BF4D-4A3A-84CF-C88CEA74F726} =>.Superfluous.Empty
O43 - CFD: 25/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A8FAE92C-8C1D-4B50-B76E-D1DFFC6EFA88} =>.Superfluous.Empty
O43 - CFD: 27/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{A903841E-EE7E-4681-BF0F-F7F168AF3FAD} =>.Superfluous.Empty
O43 - CFD: 06/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A9168D9E-8790-4DFD-B68A-6F96AD4611D7} =>.Superfluous.Empty
O43 - CFD: 16/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A93DFA51-DBF9-4CFF-8525-EC54BE670BDD} =>.Superfluous.Empty
O43 - CFD: 23/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{A9616282-6B82-4BB9-B515-8AF8256C0FC8} =>.Superfluous.Empty
O43 - CFD: 29/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A98CC890-924C-46FC-A5C5-76525980CE0A} =>.Superfluous.Empty
O43 - CFD: 22/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A992EE4B-3F0A-4229-A423-0720E3B503CD} =>.Superfluous.Empty
O43 - CFD: 06/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{A9F20D97-C0FB-4341-80AA-1942A42C9433} =>.Superfluous.Empty
O43 - CFD: 11/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AA19A4A1-34CF-4CBE-935A-EEFF94BE1680} =>.Superfluous.Empty
O43 - CFD: 12/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AAA2D709-D701-4786-B7B9-137C6FF6165F} =>.Superfluous.Empty
O43 - CFD: 09/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AAAA7A3D-F122-454B-90A2-A653722102D9} =>.Superfluous.Empty
O43 - CFD: 18/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{AAB3497F-7A96-46AC-9662-C142CCC6F6BB} =>.Superfluous.Empty
O43 - CFD: 06/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{AAF5881E-DB78-4058-A70E-6CBC263FC7CF} =>.Superfluous.Empty
O43 - CFD: 06/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AB1285EF-B61B-4891-BBCA-5558CD2C5647} =>.Superfluous.Empty
O43 - CFD: 17/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AB97F858-6110-437C-B8CE-17289A9664AC} =>.Superfluous.Empty
O43 - CFD: 19/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{ABC946E0-654A-44CC-A8C7-5A88F2A674A9} =>.Superfluous.Empty
O43 - CFD: 28/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{ABF5A119-97BA-4D3E-B639-3D87603D4149} =>.Superfluous.Empty
O43 - CFD: 22/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{AC1CDB01-B3D1-48A0-A5C8-597482892517} =>.Superfluous.Empty
O43 - CFD: 10/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{ACD54401-724A-47B7-9D14-846B6B142282} =>.Superfluous.Empty
O43 - CFD: 07/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{ACEB1BF1-A2DE-4EA5-8526-60A7343C5850} =>.Superfluous.Empty
O43 - CFD: 15/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{AD08A298-3C3B-456F-9B4B-018B8513841F} =>.Superfluous.Empty
O43 - CFD: 10/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{AD1E5F36-58E6-416B-9261-E78E09D11703} =>.Superfluous.Empty
O43 - CFD: 11/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{AD78276D-A9BD-405E-8964-FD6CEE7CE987} =>.Superfluous.Empty
O43 - CFD: 12/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AD796037-54FE-47AA-BAD0-39DB8576C32B} =>.Superfluous.Empty
O43 - CFD: 21/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{AD883807-A677-4FEE-B74F-299886D70318} =>.Superfluous.Empty
O43 - CFD: 28/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{ADFFD837-F81C-453F-AF73-C81A8B388DCD} =>.Superfluous.Empty
O43 - CFD: 03/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{AE1AB629-C984-4697-9B8A-015B1DA8F34B} =>.Superfluous.Empty
O43 - CFD: 03/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AE4F9B3E-E257-4634-86DB-CF4B5770C8DA} =>.Superfluous.Empty
O43 - CFD: 12/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AEB48175-7C77-4A1F-BE93-1B7F3A8361A5} =>.Superfluous.Empty
O43 - CFD: 23/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AEDFF173-FEBF-4AD7-AF57-5BDB107F362D} =>.Superfluous.Empty
O43 - CFD: 24/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{AF06AC2C-50E9-4864-809E-6DD14E5809CF} =>.Superfluous.Empty
O43 - CFD: 15/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AF1F1BEC-481A-4FCE-B707-0BCEDCEB0643} =>.Superfluous.Empty
O43 - CFD: 18/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AF383150-F648-46AE-A8CD-E317C4D7E368} =>.Superfluous.Empty
O43 - CFD: 28/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AF7043ED-FEAE-4347-8877-B54D7E419C70} =>.Superfluous.Empty
O43 - CFD: 27/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AF738DE6-AD67-4976-98CA-B43EE650ADA5} =>.Superfluous.Empty
O43 - CFD: 27/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{AF9C5A56-1B84-4D70-807A-02F3B1926C20} =>.Superfluous.Empty
O43 - CFD: 12/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{AFDA4A04-8266-4638-B861-C1984AEBBD52} =>.Superfluous.Empty
O43 - CFD: 09/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{AFE13CB6-1E5E-4FCF-B4A3-609E03D897DE} =>.Superfluous.Empty
O43 - CFD: 17/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{AFF4598D-F65A-4E12-AB63-EEF831BE1AA3} =>.Superfluous.Empty
O43 - CFD: 08/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B007B64E-6500-430B-A0ED-BA2781BA8F82} =>.Superfluous.Empty
O43 - CFD: 25/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B077AD93-656D-4E34-A4C2-1B4DDF2BDECC} =>.Superfluous.Empty
O43 - CFD: 09/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B09E1DB4-46CE-4D4A-96D1-CC2096128550} =>.Superfluous.Empty
O43 - CFD: 13/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B0B58A04-ADC1-4EDE-B323-3E3793B4999D} =>.Superfluous.Empty
O43 - CFD: 10/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B100666A-143A-4D44-9807-8CEEED40848F} =>.Superfluous.Empty
O43 - CFD: 26/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B1056906-D7AF-40DD-9BD2-7F665F5161F2} =>.Superfluous.Empty
O43 - CFD: 17/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B1A54DC0-DA00-4BFE-B1D0-64E574FD8668} =>.Superfluous.Empty
O43 - CFD: 09/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B1C944F1-01FD-456E-BCF2-062914B1F810} =>.Superfluous.Empty
O43 - CFD: 21/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B1D8E66C-66F6-4793-A1BA-48C752EA9282} =>.Superfluous.Empty
O43 - CFD: 25/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B1DA4D4F-FF6E-42D0-9E35-BC65CAD6E529} =>.Superfluous.Empty
O43 - CFD: 15/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B1E88115-EDD8-46A2-8CB1-68D5FB59E71E} =>.Superfluous.Empty
O43 - CFD: 13/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B1EFCCE9-715B-48D5-952C-56EF09B7FCE5} =>.Superfluous.Empty
O43 - CFD: 04/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B1F6CE76-A517-48A0-B8ED-CAE239984D50} =>.Superfluous.Empty
O43 - CFD: 13/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B1FDBF20-754B-495E-BA4B-BFD7B4269759} =>.Superfluous.Empty
O43 - CFD: 17/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B206763B-29E2-4EA9-8032-8170F9B2CEB0} =>.Superfluous.Empty
O43 - CFD: 11/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B21C3040-511B-406F-8736-22E44E8745AA} =>.Superfluous.Empty
O43 - CFD: 16/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B26B8270-213E-47CE-A927-A2BE584BEFCC} =>.Superfluous.Empty
O43 - CFD: 07/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B26D43CD-5E4B-4B8B-B2E1-A6353F4D309C} =>.Superfluous.Empty
O43 - CFD: 26/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B2BCA3C2-3BFC-4596-BF30-6AAA5DC5FC32} =>.Superfluous.Empty
O43 - CFD: 03/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B317E6C6-CFAF-4EE0-8EC0-244A2A6B793E} =>.Superfluous.Empty
O43 - CFD: 15/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B3462665-A82D-4DB0-9C80-61CC1C0BBC3F} =>.Superfluous.Empty
O43 - CFD: 05/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B37E9CB8-1071-4277-B1B9-DBDCD57838C6} =>.Superfluous.Empty
O43 - CFD: 29/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B3A6CF4B-C53E-41D3-8751-7615B5EE5948} =>.Superfluous.Empty
O43 - CFD: 28/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B3CF6A30-1804-4C4B-AFF4-241697DFA6E3} =>.Superfluous.Empty
O43 - CFD: 10/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B40BA491-065E-4204-964F-5FD47AB8B8D2} =>.Superfluous.Empty
O43 - CFD: 10/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B4631A80-0773-4E31-BBD7-747F2F9AFBD9} =>.Superfluous.Empty
O43 - CFD: 09/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B4663ACC-B121-4603-AD0A-2642CDAD6E1F} =>.Superfluous.Empty
O43 - CFD: 02/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B4776FE4-253C-43C5-A43C-E02F40E0964D} =>.Superfluous.Empty
O43 - CFD: 08/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B499BA0D-54C5-4DA8-BFFC-48E4FF55F45E} =>.Superfluous.Empty
O43 - CFD: 27/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B4DD876F-C619-4A0F-B03A-F853C86D90C8} =>.Superfluous.Empty
O43 - CFD: 16/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B5178278-96F8-44C3-82B5-AADC7F7758DA} =>.Superfluous.Empty
O43 - CFD: 24/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B517B5B7-4505-4AD2-8C32-A23EF93C4884} =>.Superfluous.Empty
O43 - CFD: 03/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B55A15A9-303A-4658-81E0-ECF449AEA94F} =>.Superfluous.Empty
O43 - CFD: 04/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B5B6FCCC-2972-4BDD-B1EE-200948E20A70} =>.Superfluous.Empty
O43 - CFD: 09/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B602788D-8DF6-4A75-A945-D0BA1BB8ECC5} =>.Superfluous.Empty
O43 - CFD: 31/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B61A1DEE-F43D-49FE-AB30-595AF3AE0C36} =>.Superfluous.Empty
O43 - CFD: 20/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B633F992-5EC6-48EA-8478-3F5B08C12170} =>.Superfluous.Empty
O43 - CFD: 13/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B64988D1-44CB-4345-9078-0F5E4BCFE506} =>.Superfluous.Empty
O43 - CFD: 16/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B65A6054-0461-4C3F-AAEC-0113E4593D55} =>.Superfluous.Empty
O43 - CFD: 26/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B665D258-F63D-48F7-A01D-45F07F90B6F8} =>.Superfluous.Empty
O43 - CFD: 05/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B6AF4BC6-6E7F-4DF3-97B2-3A9D88E5FE40} =>.Superfluous.Empty
O43 - CFD: 04/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B6D41B88-EC5A-4F2F-AC6E-6EC89A45A737} =>.Superfluous.Empty
O43 - CFD: 28/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B6FC323D-077F-4F95-B9E1-49F6A76E256C} =>.Superfluous.Empty
O43 - CFD: 12/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B7476E4A-DD3B-45C6-8792-A0F4658C5AA2} =>.Superfluous.Empty
O43 - CFD: 19/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B7721023-F75E-4F7A-AF8D-357387930A6F} =>.Superfluous.Empty
O43 - CFD: 08/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B77D3087-634A-47F7-A7C6-5D67454D36F6} =>.Superfluous.Empty
O43 - CFD: 25/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B79B2CA9-924A-45C7-A314-AAD8481DF228} =>.Superfluous.Empty
O43 - CFD: 12/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B7E9FC9E-E57A-42CE-8A51-F48B2789B07D} =>.Superfluous.Empty
O43 - CFD: 18/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B83649E1-4D1B-4272-A44E-390C1481C101} =>.Superfluous.Empty
O43 - CFD: 15/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B8485255-B328-4773-B67B-025ECBD4DC32} =>.Superfluous.Empty
O43 - CFD: 12/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B854D6B9-5285-4DA7-9C07-DFAA3C523D69} =>.Superfluous.Empty
O43 - CFD: 17/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B8A370D3-786B-4686-87E9-0E6F3CD31D8E} =>.Superfluous.Empty
O43 - CFD: 25/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{B8A7B90A-A8F2-4A20-BBB5-54120F7B11A2} =>.Superfluous.Empty
O43 - CFD: 11/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{B9577456-F375-4CA5-A78B-7BE008F96459} =>.Superfluous.Empty
O43 - CFD: 29/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B97FEDDF-CAEA-4F0D-9F2B-2DD6B2AAD779} =>.Superfluous.Empty
O43 - CFD: 31/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{B9AE086E-AD04-4067-93F7-2D9BFCB9FA07} =>.Superfluous.Empty
O43 - CFD: 08/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BA192629-4A88-490C-BF92-1FF0BE0840FC} =>.Superfluous.Empty
O43 - CFD: 02/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BA516C29-8216-4D5C-B788-11C15F726A38} =>.Superfluous.Empty
O43 - CFD: 21/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BA98A479-1692-41F5-B93D-52C6CF104E9C} =>.Superfluous.Empty
O43 - CFD: 24/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BAF63E61-172B-41CE-B740-A88C17AA6C6F} =>.Superfluous.Empty
O43 - CFD: 18/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BB63FDCE-2D19-4D90-A847-0279FEA3CCD7} =>.Superfluous.Empty
O43 - CFD: 21/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BB656631-E437-47DE-A68D-596273C6E954} =>.Superfluous.Empty
O43 - CFD: 11/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BB7144F7-7588-434C-AD7F-5E0D576B70F3} =>.Superfluous.Empty
O43 - CFD: 19/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BBF40FB1-939E-42A8-9450-7297C36D9EFE} =>.Superfluous.Empty
O43 - CFD: 17/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BBF741EC-8F5A-479B-BAE5-278796312067} =>.Superfluous.Empty
O43 - CFD: 09/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BC3898B8-F22C-407B-AD19-3F899FD973DE} =>.Superfluous.Empty
O43 - CFD: 29/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BC4E7712-05BE-46A5-BA2F-B9673A14460C} =>.Superfluous.Empty
O43 - CFD: 22/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BC8751F5-490F-4F61-ABBC-6A6D6D54DA7A} =>.Superfluous.Empty
O43 - CFD: 18/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BC8760E8-9D6F-4DAA-A8A2-C9D25B39B290} =>.Superfluous.Empty
O43 - CFD: 29/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BCAA3B59-1CC1-4682-B9F0-B457623B0CD9} =>.Superfluous.Empty
O43 - CFD: 27/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BCB2197B-F781-447C-BC77-CCE5394F5A14} =>.Superfluous.Empty
O43 - CFD: 04/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{BCC51703-092C-4257-A743-690845293802} =>.Superfluous.Empty
O43 - CFD: 20/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BCD65F24-B658-445B-B7AF-3D1FBAF33841} =>.Superfluous.Empty
O43 - CFD: 14/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BD03B63E-B415-4F7A-AF8C-4226FA0AD1D1} =>.Superfluous.Empty
O43 - CFD: 10/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{BD09DA90-6FDF-4B89-848A-58654ECEBBCA} =>.Superfluous.Empty
O43 - CFD: 30/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BD934A58-7EF1-4745-9BA8-D11F69C2EEA6} =>.Superfluous.Empty
O43 - CFD: 17/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BDCC62B5-B713-42B7-A443-86384EC26DEC} =>.Superfluous.Empty
O43 - CFD: 26/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BDD9CA5D-B120-4ADC-ACE5-6F5F3AE77889} =>.Superfluous.Empty
O43 - CFD: 03/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BDDCD27F-5E53-4E7E-B180-F61447BE1246} =>.Superfluous.Empty
O43 - CFD: 31/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BDEECBB1-7A27-46AB-B5D9-487955EDC672} =>.Superfluous.Empty
O43 - CFD: 31/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BDF41536-BB6C-4AEA-B21C-D5CC99F493EE} =>.Superfluous.Empty
O43 - CFD: 12/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BE0AE070-EDC3-4726-8F0E-833721D76E0C} =>.Superfluous.Empty
O43 - CFD: 06/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BE10B26A-5903-4A49-A7C8-19A0C2B3C5FA} =>.Superfluous.Empty
O43 - CFD: 20/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BE27CF2E-8F33-4688-8BA5-91867904F66D} =>.Superfluous.Empty
O43 - CFD: 21/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BE44407E-DD55-4E59-97FD-6140C6D873D9} =>.Superfluous.Empty
O43 - CFD: 10/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BE54E344-F111-4343-B9F9-8D4FA98CADF2} =>.Superfluous.Empty
O43 - CFD: 31/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BEC8E26D-7D8E-4785-AD40-77E26BBF8EDE} =>.Superfluous.Empty
O43 - CFD: 23/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BEE1D41C-393F-4C19-B9E7-E8983E2CE806} =>.Superfluous.Empty
O43 - CFD: 26/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BEF87715-E921-4EDB-B085-68F87B26A7F0} =>.Superfluous.Empty
O43 - CFD: 06/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BF3B80D1-CC7E-477E-9683-7B674BDACA12} =>.Superfluous.Empty
O43 - CFD: 26/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BF441DFA-8EDF-4681-99A2-07BB495A4A45} =>.Superfluous.Empty
O43 - CFD: 13/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{BF5CAA8E-2229-4AC9-8438-1AC81A61D64D} =>.Superfluous.Empty
O43 - CFD: 18/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{BF6F231A-5AB7-4465-A302-A3F7008B617D} =>.Superfluous.Empty
O43 - CFD: 18/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{C01D6135-A25A-4019-BB4F-C992CBD2DF06} =>.Superfluous.Empty
O43 - CFD: 19/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C027F013-7B58-4467-9DA6-BB50895D3CD1} =>.Superfluous.Empty
O43 - CFD: 21/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C02CFC7F-0403-4D30-8D7F-F67693ED05E7} =>.Superfluous.Empty
O43 - CFD: 21/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C068A82C-2492-4E81-B385-492AB856D47C} =>.Superfluous.Empty
O43 - CFD: 14/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C081063A-1D03-4E77-9EF2-D67C01FD2FB4} =>.Superfluous.Empty
O43 - CFD: 10/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C08828E0-AD2A-457F-B25A-18E92B6FB3C4} =>.Superfluous.Empty
O43 - CFD: 13/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C09C369D-6020-41E0-9FEB-300CA147CC17} =>.Superfluous.Empty
O43 - CFD: 20/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C0A04C4E-1AA3-47DF-9B4B-783ADA859903} =>.Superfluous.Empty
O43 - CFD: 20/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C0B5630A-06AB-4C9F-A684-4ADC96EC1500} =>.Superfluous.Empty
O43 - CFD: 08/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C0EA9F0C-00C8-4ADA-9159-6719B56C6FBF} =>.Superfluous.Empty
O43 - CFD: 14/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C125E37E-CCBC-4B2A-963E-2B1D568D0F81} =>.Superfluous.Empty
O43 - CFD: 16/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C12DC55A-2922-443F-97C3-5EC807F1D5B8} =>.Superfluous.Empty
O43 - CFD: 12/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C13B2428-A549-4A88-8548-9552276B0CF6} =>.Superfluous.Empty
O43 - CFD: 15/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C1529C36-3EBC-4453-BC07-EA89D96D9688} =>.Superfluous.Empty
O43 - CFD: 19/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C16B1396-2A19-4C68-8ADA-78F2194180F8} =>.Superfluous.Empty
O43 - CFD: 30/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C19A89A7-8EFA-4E54-A2CA-AA73CE4DDADF} =>.Superfluous.Empty
O43 - CFD: 24/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C1C30DAA-FAFC-445B-BDDD-835662FF4B3C} =>.Superfluous.Empty
O43 - CFD: 26/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C26CA2BD-2822-4AD3-80AD-F489B92FB003} =>.Superfluous.Empty
O43 - CFD: 12/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C2C4497F-3BBC-48C3-A2CA-EB2A8D5B792C} =>.Superfluous.Empty
O43 - CFD: 08/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{C2DF685E-A4A4-4DE3-AC94-701C2D99804D} =>.Superfluous.Empty
O43 - CFD: 11/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C34750E0-7CA5-4F45-8D4F-1C3E5F9465E6} =>.Superfluous.Empty
O43 - CFD: 08/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C372E17B-281B-4F0D-B68C-3AE61911D08A} =>.Superfluous.Empty
O43 - CFD: 29/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C3977B9C-3734-42A1-80BA-F7C4F70E4A24} =>.Superfluous.Empty
O43 - CFD: 13/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C3AAB077-3A03-4584-8569-0F245AB2E5CD} =>.Superfluous.Empty
O43 - CFD: 26/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C3B019E5-F15A-4AB0-A4D9-F72C133EE5EF} =>.Superfluous.Empty
O43 - CFD: 29/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C3BEB885-13F8-4114-9A9E-64F613F213EE} =>.Superfluous.Empty
O43 - CFD: 11/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C3ED2279-51EA-40FF-A5E1-424F34D1A14B} =>.Superfluous.Empty
O43 - CFD: 11/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C42EB2AC-385D-4172-9C52-673A03DC5E88} =>.Superfluous.Empty
O43 - CFD: 14/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{C46190A7-1E0F-4FB0-A10D-5765206C3C66} =>.Superfluous.Empty
O43 - CFD: 10/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C4AC722F-146C-49BF-9C61-14185E8AEBFE} =>.Superfluous.Empty
O43 - CFD: 30/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C4BDC063-696F-4C64-823A-59CDF202BB03} =>.Superfluous.Empty
O43 - CFD: 16/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C4C51C4C-7584-479A-ADE2-AC91CC95E458} =>.Superfluous.Empty
O43 - CFD: 08/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C4EC3B04-5065-4CF5-AAE6-8CFB6B712889} =>.Superfluous.Empty
O43 - CFD: 23/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C4ED31EF-1C8B-4929-BEA5-A06FE7DF27D0} =>.Superfluous.Empty
O43 - CFD: 07/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C50B842E-0455-44AF-89B3-BDA62867E9E2} =>.Superfluous.Empty
O43 - CFD: 07/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C5143EF0-0F9C-46E5-9445-24E9DCD06886} =>.Superfluous.Empty
O43 - CFD: 24/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C518C4AE-1C88-4AD6-961E-EDFE6F4CA7E7} =>.Superfluous.Empty
O43 - CFD: 23/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C54CE5D2-D8A3-4843-A62F-B9E844BA62B8} =>.Superfluous.Empty
O43 - CFD: 07/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C553E93F-494C-4D32-BAA1-D5AE719547CA} =>.Superfluous.Empty
O43 - CFD: 27/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C58F72B5-5602-44B1-81D0-F005F84F24B6} =>.Superfluous.Empty
O43 - CFD: 11/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C5A02DB9-BF16-4676-8768-8AE7A741DE63} =>.Superfluous.Empty
O43 - CFD: 21/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C5B94A7B-D913-4536-8199-97969269AABD} =>.Superfluous.Empty
O43 - CFD: 28/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C5C6869E-AE96-4122-A845-A8F280BC7B5C} =>.Superfluous.Empty
O43 - CFD: 09/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C5C9293B-1552-47CF-A5BE-7DBA2D44B69A} =>.Superfluous.Empty
O43 - CFD: 13/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C5CDA246-72CC-49E5-890C-BF0C37CFFEEE} =>.Superfluous.Empty
O43 - CFD: 17/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{C5D76798-4644-4F71-8AD4-FD73ECF46827} =>.Superfluous.Empty
O43 - CFD: 29/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C5E96236-883B-4D5E-96AE-4C0F9C15575B} =>.Superfluous.Empty
O43 - CFD: 17/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C5F0E801-59D2-46BA-931F-2FD45C315BC4} =>.Superfluous.Empty
O43 - CFD: 29/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C5F3A3AC-A61C-4DB1-B2D0-7E8376B7EA4E} =>.Superfluous.Empty
O43 - CFD: 31/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C6223EA6-057C-4F08-AB32-0F89DFD091D2} =>.Superfluous.Empty
O43 - CFD: 29/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C6926E7E-CB4E-45D0-9DCA-122B4D234AC8} =>.Superfluous.Empty
O43 - CFD: 15/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C6D8D304-4DAF-4B41-BE5A-D431A3CD0E1F} =>.Superfluous.Empty
O43 - CFD: 15/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C76DA508-AD78-4D2A-802B-4FE2327D913D} =>.Superfluous.Empty
O43 - CFD: 26/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C7B31DAE-1BDA-48BC-8209-4407B13441F5} =>.Superfluous.Empty
O43 - CFD: 24/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C8043610-B62C-466B-A1BB-8A183E255D48} =>.Superfluous.Empty
O43 - CFD: 02/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C80E87A2-95C5-40CE-A6EE-6491F26BCCCD} =>.Superfluous.Empty
O43 - CFD: 18/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C817067E-ED59-4A61-9867-03FBDFA9513F} =>.Superfluous.Empty
O43 - CFD: 20/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C84B185F-EF20-4CCF-9944-EAC8C836CA1F} =>.Superfluous.Empty
O43 - CFD: 26/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{C888F443-625E-42A6-97B0-7A8EA7552883} =>.Superfluous.Empty
O43 - CFD: 08/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{C9023644-96A9-4245-AF86-2D8F70D167F3} =>.Superfluous.Empty
O43 - CFD: 16/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C91352BA-E145-4771-A0BE-5276325E95B6} =>.Superfluous.Empty
O43 - CFD: 20/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C916A213-3F8B-4BE1-AE7A-EEB3C22B5BF9} =>.Superfluous.Empty
O43 - CFD: 19/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C9525509-34FD-4058-AB44-388A1D60F81D} =>.Superfluous.Empty
O43 - CFD: 14/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C989F170-7B76-4FEE-8674-238683DC5716} =>.Superfluous.Empty
O43 - CFD: 25/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{C98B6853-3CD2-45E1-8A17-7F54C7D75B8C} =>.Superfluous.Empty
O43 - CFD: 07/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C9B61D89-C9EA-4C91-9BB6-1E510A83756E} =>.Superfluous.Empty
O43 - CFD: 30/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{C9F27281-2DF7-441B-B273-2583F7B88E1C} =>.Superfluous.Empty
O43 - CFD: 27/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{C9F609B3-5DCE-4531-B245-2401EBB71771} =>.Superfluous.Empty
O43 - CFD: 16/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CA1DD4E5-1EA4-40C6-9012-72F0DAAFF582} =>.Superfluous.Empty
O43 - CFD: 05/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CA50D879-188A-457C-99F0-841102B96FD6} =>.Superfluous.Empty
O43 - CFD: 27/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CA568E3E-D9AD-4FDD-99E6-E8786449D790} =>.Superfluous.Empty
O43 - CFD: 14/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CA8259B6-4034-4FD9-9722-77659488C906} =>.Superfluous.Empty
O43 - CFD: 17/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CAA8A30D-495A-48BB-85BE-486C540F321E} =>.Superfluous.Empty
O43 - CFD: 01/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CB05F43C-94B6-4C19-AA93-4E64FD58DBF0} =>.Superfluous.Empty
O43 - CFD: 19/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CB45E6F9-E951-4017-858C-4C4F37BC3678} =>.Superfluous.Empty
O43 - CFD: 09/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CB4C58A4-2E94-4483-B8F1-700FE0458DF9} =>.Superfluous.Empty
O43 - CFD: 18/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CBA3F660-7353-4B55-8653-AE50C16DD460} =>.Superfluous.Empty
O43 - CFD: 12/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CBAACF3D-AE93-44DD-99FF-1B9BB8724AB5} =>.Superfluous.Empty
O43 - CFD: 17/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CC9E7860-C212-43AE-AEFD-B73B808B1D82} =>.Superfluous.Empty
O43 - CFD: 12/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CCBD1FA2-DC8E-4976-9E96-88E4CD33D439} =>.Superfluous.Empty
O43 - CFD: 11/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CCE2F147-ACA8-4667-9F9A-EA64165383E9} =>.Superfluous.Empty
O43 - CFD: 07/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CD46EC7B-12E0-4992-B5EA-5F31773364FD} =>.Superfluous.Empty
O43 - CFD: 08/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CD6E2560-4A2B-4F0F-AA50-8EC3812437FE} =>.Superfluous.Empty
O43 - CFD: 16/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CE234181-DEB7-406C-A813-48C6D97F76FC} =>.Superfluous.Empty
O43 - CFD: 16/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CE2641D5-1AC4-4FA7-BB3C-DAACACD70D3A} =>.Superfluous.Empty
O43 - CFD: 19/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CE2C0451-883A-4BB9-85DB-1CEC432C354B} =>.Superfluous.Empty
O43 - CFD: 14/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{CE435D99-F549-4ACC-AF18-8E406E67056D} =>.Superfluous.Empty
O43 - CFD: 13/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CEE20B22-185E-4303-BD0C-9BAE0DA4BF52} =>.Superfluous.Empty
O43 - CFD: 10/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CEF58FF8-0C9E-4C79-81C1-DEF4AF177324} =>.Superfluous.Empty
O43 - CFD: 20/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CF224321-AD4A-4C7E-9E30-598FF97E7F9A} =>.Superfluous.Empty
O43 - CFD: 21/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CF297457-08C3-4B8A-995A-D25CA5670121} =>.Superfluous.Empty
O43 - CFD: 14/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CF307092-B79B-446D-950C-7B5361147176} =>.Superfluous.Empty
O43 - CFD: 27/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CF568C30-F8F4-4836-BB0B-38B7586CF369} =>.Superfluous.Empty
O43 - CFD: 10/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CF9FD007-F8DF-4068-BA25-B7EC27D7236B} =>.Superfluous.Empty
O43 - CFD: 02/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{CFC53EBA-C4B2-4827-A8E1-52FA3E27497D} =>.Superfluous.Empty
O43 - CFD: 11/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{CFDF79BF-381C-49EE-B797-E7BF3DAC905F} =>.Superfluous.Empty
O43 - CFD: 08/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D0386BFF-0482-4FD4-827F-0A161963D9D0} =>.Superfluous.Empty
O43 - CFD: 14/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D07E86B8-DE68-49FE-A81F-4D90A373B3C9} =>.Superfluous.Empty
O43 - CFD: 01/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D08B73C2-7B98-411A-992B-6254ABF75D40} =>.Superfluous.Empty
O43 - CFD: 15/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D0B99F13-C9EF-4884-827A-E9740E8FC408} =>.Superfluous.Empty
O43 - CFD: 05/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D10F452E-C1CD-416A-8919-8FD402B5E394} =>.Superfluous.Empty
O43 - CFD: 21/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D1774DD0-B19B-4F93-A70B-EFBE41909DAE} =>.Superfluous.Empty
O43 - CFD: 28/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D195AE93-8253-4A75-AE88-B327F2CE4A4A} =>.Superfluous.Empty
O43 - CFD: 31/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D1AE7801-DB31-4CB1-98BB-88B775FBCA92} =>.Superfluous.Empty
O43 - CFD: 28/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D1B16512-3C5C-4554-B49A-CD7E8DC6982C} =>.Superfluous.Empty
O43 - CFD: 02/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D1CEA565-A5D0-4BBD-9ECA-F32A248BFF06} =>.Superfluous.Empty
O43 - CFD: 17/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D27D35DD-FDF3-4C15-AA98-43A7B10AA129} =>.Superfluous.Empty
O43 - CFD: 12/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{D280ECEA-B662-4B7C-8849-B05F0C888DAB} =>.Superfluous.Empty
O43 - CFD: 27/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D28E9159-00FB-4976-9066-F383071EDCA1} =>.Superfluous.Empty
O43 - CFD: 25/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D2D647D0-821A-4262-AC56-0C0C112C4A63} =>.Superfluous.Empty
O43 - CFD: 25/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D2DBC15C-443C-4556-B410-98F4DBADF96F} =>.Superfluous.Empty
O43 - CFD: 18/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D2E60EE4-F4D4-4F55-967F-E7F2ED5F076B} =>.Superfluous.Empty
O43 - CFD: 01/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D2ECFDB9-140A-4251-92C4-AD755B85B50E} =>.Superfluous.Empty
O43 - CFD: 17/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D34B15F7-C3DA-4A86-ADDE-21F34E235267} =>.Superfluous.Empty
O43 - CFD: 05/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D38BA01B-E85E-4701-91D0-A2F7C39BA816} =>.Superfluous.Empty
O43 - CFD: 26/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D38F7EBF-0A72-4D02-AFC6-73A1CA061946} =>.Superfluous.Empty
O43 - CFD: 24/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D3BDF425-B916-4DEB-BD44-686852568790} =>.Superfluous.Empty
O43 - CFD: 01/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D3EC0D3C-EE9F-4194-BD6F-EB1EEF93A1C7} =>.Superfluous.Empty
O43 - CFD: 27/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D3F35A91-6BBA-4E78-A892-A80D42C6F0E7} =>.Superfluous.Empty
O43 - CFD: 04/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D43540C8-F7C0-4D81-9763-AB151251F696} =>.Superfluous.Empty
O43 - CFD: 18/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D4468E74-C243-4167-B89A-BF7EBA4E7C97} =>.Superfluous.Empty
O43 - CFD: 22/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D4605A27-F533-4D65-A10E-558CB16B0940} =>.Superfluous.Empty
O43 - CFD: 21/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D48D0134-0856-4519-AC1A-A13B7F08C428} =>.Superfluous.Empty
O43 - CFD: 15/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D523D87C-252A-4052-9FB0-E7407D0FD3DE} =>.Superfluous.Empty
O43 - CFD: 05/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D59279C3-B481-4EDA-9302-4A62ECE70DD2} =>.Superfluous.Empty
O43 - CFD: 24/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D5B1832E-3B8C-455F-A760-E0E132EB3E3E} =>.Superfluous.Empty
O43 - CFD: 11/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D5E66345-DB0E-4CD1-9235-3C9521DCC06D} =>.Superfluous.Empty
O43 - CFD: 05/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D6037CFF-E471-47CA-A35E-C5FBB44D8BA4} =>.Superfluous.Empty
O43 - CFD: 15/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D621BF52-D331-4DCC-8C74-9762C633E980} =>.Superfluous.Empty
O43 - CFD: 01/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D62D2CF9-71D7-40D0-97A1-7BDCC7895A3E} =>.Superfluous.Empty
O43 - CFD: 10/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D64217B7-7E65-471E-850C-27C2475F14D1} =>.Superfluous.Empty
O43 - CFD: 13/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D67F43C6-4F09-44B1-82FB-72D82E7C28A0} =>.Superfluous.Empty
O43 - CFD: 06/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D6E38E71-179B-484A-9B2B-403213A38231} =>.Superfluous.Empty
O43 - CFD: 13/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{D71CCEAC-0C97-4F04-A87D-00B89AD702A1} =>.Superfluous.Empty
O43 - CFD: 08/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{D7368C51-0F75-427F-9B25-4D9432BEE24D} =>.Superfluous.Empty
O43 - CFD: 09/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D7943A08-6BE0-423B-AB25-11352B7E0859} =>.Superfluous.Empty
O43 - CFD: 14/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D7B232C5-5F77-4F2D-87F0-5C6ECFAF8D17} =>.Superfluous.Empty
O43 - CFD: 18/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D7BD2EE5-DF6E-413E-801B-82B619E77448} =>.Superfluous.Empty
O43 - CFD: 13/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D8168658-CA19-4581-AFCD-815B05BCB931} =>.Superfluous.Empty
O43 - CFD: 24/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D8371017-823F-4B06-9D50-B3A2F588AECE} =>.Superfluous.Empty
O43 - CFD: 04/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D8B5A7C9-CE1D-43FD-8A13-CB2958710F90} =>.Superfluous.Empty
O43 - CFD: 21/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D8BE51CD-4692-4BEC-BF10-D21BA056884F} =>.Superfluous.Empty
O43 - CFD: 16/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D8C9EE60-EAE0-4ACD-AD86-39E292BBE3AC} =>.Superfluous.Empty
O43 - CFD: 27/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D8DD0D2E-6B25-4D58-BF9F-91F384710E5F} =>.Superfluous.Empty
O43 - CFD: 01/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{D950E9E2-6E25-484A-AC8C-CD697AA8FB6A} =>.Superfluous.Empty
O43 - CFD: 09/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D956D634-3301-4735-9844-1E8F3E68BEB7} =>.Superfluous.Empty
O43 - CFD: 07/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D981404F-08A7-497C-B83C-8BDB3375EAE4} =>.Superfluous.Empty
O43 - CFD: 04/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D994D485-F598-4E55-BCEA-004500308167} =>.Superfluous.Empty
O43 - CFD: 12/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D99F19EF-3A12-4B97-8B8C-59E452E55C7F} =>.Superfluous.Empty
O43 - CFD: 31/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{D9B3B960-ACA9-40B8-8975-B6FCE5981F61} =>.Superfluous.Empty
O43 - CFD: 07/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{D9B88C56-11F0-4821-930F-A8967B1E9791} =>.Superfluous.Empty
O43 - CFD: 19/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D9D2CB48-CB2B-4002-8D87-DE269E8F63CF} =>.Superfluous.Empty
O43 - CFD: 19/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{D9F979D3-BEC3-4A19-B633-C82B71AAD300} =>.Superfluous.Empty
O43 - CFD: 04/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DA64C5A8-4582-49F2-9EC5-2F08941E3115} =>.Superfluous.Empty
O43 - CFD: 24/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DABF7394-CA9D-4B75-9CD4-177D20CE4B56} =>.Superfluous.Empty
O43 - CFD: 03/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DABFFDE3-3396-4786-B36A-4432F858281B} =>.Superfluous.Empty
O43 - CFD: 21/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{DAF3D2A3-4F8C-46E3-85F0-439A51CE3AC0} =>.Superfluous.Empty
O43 - CFD: 18/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{DB199670-3F02-4F92-9568-E40D75586DE4} =>.Superfluous.Empty
O43 - CFD: 03/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{DB460753-AA7A-45D2-84AA-DF27A44D683F} =>.Superfluous.Empty
O43 - CFD: 01/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DB83CE8E-7C4A-4C87-990C-4B91C047CDF5} =>.Superfluous.Empty
O43 - CFD: 10/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{DBC83C35-28E4-4860-BEA1-9B088B2712C6} =>.Superfluous.Empty
O43 - CFD: 09/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DBE5103F-B62C-4945-8DF1-68E0E01C4748} =>.Superfluous.Empty
O43 - CFD: 19/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{DC2F509A-20A9-454A-A3DA-6D7DD46DF787} =>.Superfluous.Empty
O43 - CFD: 18/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{DC9BF016-945A-4A4D-84EE-C8CB3DC67E1C} =>.Superfluous.Empty
O43 - CFD: 27/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{DCAC8003-4361-4107-B812-CBE2E2830D72} =>.Superfluous.Empty
O43 - CFD: 29/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{DCD7D8BF-DA1A-468B-95EB-E3CD08212407} =>.Superfluous.Empty
O43 - CFD: 26/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DCF3099B-2E89-46E4-B23E-FB6BAD2A2A8F} =>.Superfluous.Empty
O43 - CFD: 14/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{DD1A664A-95BA-4643-8908-373B94F13773} =>.Superfluous.Empty
O43 - CFD: 21/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{DD1F4EAA-4951-44F5-AD66-1A7202519EA7} =>.Superfluous.Empty
O43 - CFD: 16/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DD2AF6C1-DAE1-4ADF-9EE7-72846D2F74D2} =>.Superfluous.Empty
O43 - CFD: 17/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DD737BB5-E687-4495-9A57-E63F1A9CFADC} =>.Superfluous.Empty
O43 - CFD: 27/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{DD8AF793-1808-444E-93F2-B4ED63F6B5FE} =>.Superfluous.Empty
O43 - CFD: 12/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{DEF84FC2-96A0-426C-B814-9F2E10FF8A5E} =>.Superfluous.Empty
O43 - CFD: 14/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{DF1179F4-98D2-4956-9C47-D54AE5511F0D} =>.Superfluous.Empty
O43 - CFD: 15/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DF291F5B-6743-4B20-9F74-1035867CDA32} =>.Superfluous.Empty
O43 - CFD: 15/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DF9801E7-B7BB-4F1A-8904-875CB405090A} =>.Superfluous.Empty
O43 - CFD: 07/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DFA4B633-3EEE-47BC-BA37-3090A3DA3E10} =>.Superfluous.Empty
O43 - CFD: 17/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DFBA4A93-60BE-456E-94DF-11668B217E73} =>.Superfluous.Empty
O43 - CFD: 06/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{DFDD13BF-2362-4283-9DDF-3A870A52C840} =>.Superfluous.Empty
O43 - CFD: 30/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E0083FA6-68F1-4F49-822D-45DDD4F748D0} =>.Superfluous.Empty
O43 - CFD: 15/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E00C0678-0C15-4E56-8327-4B299EC75032} =>.Superfluous.Empty
O43 - CFD: 24/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E02A3EBF-208C-409D-8B95-B69642B8F6F2} =>.Superfluous.Empty
O43 - CFD: 12/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{E032E8EF-0E62-4231-95F2-BFEDF880301C} =>.Superfluous.Empty
O43 - CFD: 28/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E059E05F-CCBB-42CA-B437-E15ACE16A964} =>.Superfluous.Empty
O43 - CFD: 13/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E082ECDA-697E-4219-B5C9-B1A27BAB779A} =>.Superfluous.Empty
O43 - CFD: 04/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E0C94B6D-B165-4DD1-AB5A-0622B723939B} =>.Superfluous.Empty
O43 - CFD: 16/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E0D4AFB4-0FBE-4451-A2F5-57C0090DFD58} =>.Superfluous.Empty
O43 - CFD: 16/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E10AD1B5-9E0E-421C-854A-4981371F57B6} =>.Superfluous.Empty
O43 - CFD: 27/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E12B6FE0-298F-4B52-A8A4-9F8D0D14FBB8} =>.Superfluous.Empty
O43 - CFD: 20/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{E1348A62-B9ED-44FD-A8B5-F47C58244DD2} =>.Superfluous.Empty
O43 - CFD: 15/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E17520C8-5DC3-47E7-AF20-CF4A5DC7320C} =>.Superfluous.Empty
O43 - CFD: 03/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E187006C-58E4-4B1B-8CCB-6A76BE59FD58} =>.Superfluous.Empty
O43 - CFD: 12/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E1D5023F-F022-4EDF-B76E-6C7060307292} =>.Superfluous.Empty
O43 - CFD: 27/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E1D95A6B-17E7-45D1-94DB-FECC04FF835D} =>.Superfluous.Empty
O43 - CFD: 23/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E22A3E47-CF51-45B1-91FD-A2F341B7DDCB} =>.Superfluous.Empty
O43 - CFD: 27/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E22D91AF-2A73-457A-AA01-BF2B288A09E3} =>.Superfluous.Empty
O43 - CFD: 18/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E2742FCD-C41E-49DD-B7DD-2C249C57F683} =>.Superfluous.Empty
O43 - CFD: 03/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E27FC1F7-8B3D-49D7-9C76-04F1C9D66C21} =>.Superfluous.Empty
O43 - CFD: 28/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E32150C3-CEF5-433B-888D-4DF6147E07A4} =>.Superfluous.Empty
O43 - CFD: 27/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E3303D53-A33F-439A-9FBA-929B37541AAC} =>.Superfluous.Empty
O43 - CFD: 05/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E338FC8F-D842-4348-A06A-980982E4C08D} =>.Superfluous.Empty
O43 - CFD: 29/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E349D781-C60A-4104-B5EA-8EA57F4637B3} =>.Superfluous.Empty
O43 - CFD: 24/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E39AFBB1-2976-4B02-A1E9-5468A7F87B41} =>.Superfluous.Empty
O43 - CFD: 14/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E3DEACA9-9672-4CDB-8C17-08C1026B295F} =>.Superfluous.Empty
O43 - CFD: 05/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E4249181-7DC9-43BB-A203-0CE2716F57C4} =>.Superfluous.Empty
O43 - CFD: 14/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E44B15F2-813E-44E3-B6EF-0F4206DFB93A} =>.Superfluous.Empty
O43 - CFD: 26/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E47D37E2-5E42-41E5-9D41-461DEE0E9E53} =>.Superfluous.Empty
O43 - CFD: 03/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{E48B47AE-12E3-46F1-A9D0-9CEFF7CFBC79} =>.Superfluous.Empty
O43 - CFD: 27/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E4DB1C03-479C-40ED-886C-2C33BB7CCF52} =>.Superfluous.Empty
O43 - CFD: 30/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E4DE00A1-AD86-47EB-9A94-5CCBD0AF3CA8} =>.Superfluous.Empty
O43 - CFD: 23/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E553AE25-980F-4AC6-B690-0E30933D53EA} =>.Superfluous.Empty
O43 - CFD: 25/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E58597B2-E836-44D6-A5DC-AC0CF8705B83} =>.Superfluous.Empty
O43 - CFD: 19/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E5CEED89-8970-4D20-B03A-436FB9F3BB02} =>.Superfluous.Empty
O43 - CFD: 26/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E5EA85DF-56CF-4B1B-A8C7-4ED82E326C40} =>.Superfluous.Empty
O43 - CFD: 13/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{E6247E65-A492-49A1-AD3C-EDA1B7395E24} =>.Superfluous.Empty
O43 - CFD: 16/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{E6715927-6A36-4862-B7EA-AE16C322FCCE} =>.Superfluous.Empty
O43 - CFD: 04/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E6A02C25-D05B-4085-8A9E-094D1A4483DB} =>.Superfluous.Empty
O43 - CFD: 17/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E6B1D805-1E47-42F7-B4B7-57D088106B09} =>.Superfluous.Empty
O43 - CFD: 28/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E6C10194-3DBD-4226-9A7F-4EF64D17ED94} =>.Superfluous.Empty
O43 - CFD: 12/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E7143BFB-A744-439E-8334-4314DBF24E5B} =>.Superfluous.Empty
O43 - CFD: 18/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E76A9615-F720-45C5-BE02-DAA49FD7E157} =>.Superfluous.Empty
O43 - CFD: 28/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E78137D8-50F7-4986-9B6C-A30885EAAAF5} =>.Superfluous.Empty
O43 - CFD: 30/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E7AA3935-2E6F-45AC-9E51-96CFD0A72842} =>.Superfluous.Empty
O43 - CFD: 28/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E7B7FB8D-12D9-4456-9CBB-121007D5F03C} =>.Superfluous.Empty
O43 - CFD: 06/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E7BC757A-E2E0-4777-84C2-60496A8459FE} =>.Superfluous.Empty
O43 - CFD: 26/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E7D53228-1565-4713-A1DE-0A3972E95117} =>.Superfluous.Empty
O43 - CFD: 22/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E7F12D55-259D-4119-9945-696A788BE422} =>.Superfluous.Empty
O43 - CFD: 20/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E85C6E8F-E657-4FD0-A1A2-34C7646EC210} =>.Superfluous.Empty
O43 - CFD: 03/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E8641ECD-6C84-4DBE-BD65-022BD511E820} =>.Superfluous.Empty
O43 - CFD: 22/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E88896C4-779B-465D-8877-8D4D33C98CD2} =>.Superfluous.Empty
O43 - CFD: 16/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E88E85A0-C2FD-4F21-A6B7-32CBEF97E134} =>.Superfluous.Empty
O43 - CFD: 13/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E9325D5D-772C-4FD2-880B-F6F254F00D5D} =>.Superfluous.Empty
O43 - CFD: 17/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{E945750A-0BD4-43F6-BA77-2529643E0937} =>.Superfluous.Empty
O43 - CFD: 20/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E94C0BD4-7AED-48A9-BC29-01B11960B954} =>.Superfluous.Empty
O43 - CFD: 18/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E966AF45-48AD-4CC4-9304-9B780F0D3832} =>.Superfluous.Empty
O43 - CFD: 02/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{E9C1861F-929A-480A-81D8-66FFA3A31B1F} =>.Superfluous.Empty
O43 - CFD: 03/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{E9C75C2E-7466-47A3-848A-C2DBA081CEE1} =>.Superfluous.Empty
O43 - CFD: 18/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{EA3F751F-7893-41F0-BAF8-F5A9DD27EA06} =>.Superfluous.Empty
O43 - CFD: 08/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{EA5D7525-FAB3-4CAB-A28C-6F0D8695EDC1} =>.Superfluous.Empty
O43 - CFD: 15/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{EA856572-F011-4D69-81D8-6DC922FCF587} =>.Superfluous.Empty
O43 - CFD: 19/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{EAB68705-F51A-4F24-989E-4C1F6CBEC772} =>.Superfluous.Empty
O43 - CFD: 05/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{EADE8E19-567B-4757-BB4A-275F17BD5F5B} =>.Superfluous.Empty
O43 - CFD: 08/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{EB00FEAE-2652-48E7-8763-3EC897DE4697} =>.Superfluous.Empty
O43 - CFD: 10/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{EB0D9931-F568-4768-95DE-A11FD187D572} =>.Superfluous.Empty
O43 - CFD: 16/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{EB22E5A4-89D7-4655-9004-99A127697FAD} =>.Superfluous.Empty
O43 - CFD: 13/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{EBA4FF82-F795-4B4E-B037-98BE7D219152} =>.Superfluous.Empty
O43 - CFD: 19/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{EBABDE88-9F0A-4B46-A3F3-7EA4A4DF8796} =>.Superfluous.Empty
O43 - CFD: 28/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{EBC528AC-76E2-4705-B0BC-47BF575058EA} =>.Superfluous.Empty
O43 - CFD: 04/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{EBD5371D-4BFE-46D3-984C-B698854EC64C} =>.Superfluous.Empty
O43 - CFD: 24/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{EC498424-2201-48C4-8AA2-F8ED90400801} =>.Superfluous.Empty
O43 - CFD: 05/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{EC4D4BC8-DFC5-458B-80BC-B121E2A1B9C2} =>.Superfluous.Empty
O43 - CFD: 03/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{EC835D00-24A1-4A95-9CBB-6F04DC2D8E1E} =>.Superfluous.Empty
O43 - CFD: 13/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{ECBE69C4-233C-49FD-8F9A-1F7ACF15E659} =>.Superfluous.Empty
O43 - CFD: 01/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{ECFE2FB0-9A79-47A3-AB78-4BB99968D7F7} =>.Superfluous.Empty
O43 - CFD: 10/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{ED054A04-C0E8-492D-AE6A-6D35407B5063} =>.Superfluous.Empty
O43 - CFD: 04/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{ED5BBC26-0E6F-4A1C-8442-C149D23C2280} =>.Superfluous.Empty
O43 - CFD: 27/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{ED693AE3-C03C-43C3-BC8A-085C6FE13396} =>.Superfluous.Empty
O43 - CFD: 22/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{ED88BA7B-1ED5-45DF-BD97-D7062641F870} =>.Superfluous.Empty
O43 - CFD: 25/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{ED8A6B30-AE88-42A0-9044-4155718BF224} =>.Superfluous.Empty
O43 - CFD: 09/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{ED90B9CD-544F-475F-BB30-FB51A2689FE7} =>.Superfluous.Empty
O43 - CFD: 23/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{EDFBF393-E71F-44D9-8C25-4C2BC9712678} =>.Superfluous.Empty
O43 - CFD: 24/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{EE18F7C4-FF2B-41BF-891D-C24B3D5BD568} =>.Superfluous.Empty
O43 - CFD: 22/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{EE342B62-8DD2-4795-AE25-6BE93DE43F31} =>.Superfluous.Empty
O43 - CFD: 24/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{EE50910D-10E1-476F-89D3-248AF550682F} =>.Superfluous.Empty
O43 - CFD: 14/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{EE58F9ED-2E93-4282-80D8-C3140A1E7D62} =>.Superfluous.Empty
O43 - CFD: 23/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{EF89BCAD-1E35-4AFC-B133-9106D41E8BE1} =>.Superfluous.Empty
O43 - CFD: 23/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{EFD66AC6-2C9B-4482-B7F0-2F70B0966068} =>.Superfluous.Empty
O43 - CFD: 06/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F0042C51-B8D3-4527-88A1-5FB230FAF8CF} =>.Superfluous.Empty
O43 - CFD: 19/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F0B5F470-352E-4359-8C01-34E82198ACCB} =>.Superfluous.Empty
O43 - CFD: 26/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F0DBB679-D127-4E85-9AB4-F0E13F83053C} =>.Superfluous.Empty
O43 - CFD: 04/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F0F01CCB-5EA7-4035-86B5-9C0005A597DC} =>.Superfluous.Empty
O43 - CFD: 23/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F0FB804E-3B0E-4C13-8D2E-872127F5FD2B} =>.Superfluous.Empty
O43 - CFD: 11/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F11EC5B2-D786-42C5-A571-181978921440} =>.Superfluous.Empty
O43 - CFD: 04/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F1611FF5-AC64-4BA0-92DB-98D60774B5E2} =>.Superfluous.Empty
O43 - CFD: 08/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F1733A10-7CB1-45BE-903C-41BD9898313D} =>.Superfluous.Empty
O43 - CFD: 09/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F1BA0D22-1F24-4472-ABF9-F3A8BE60F38A} =>.Superfluous.Empty
O43 - CFD: 06/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F2060986-5466-4E3B-B928-630CE6E97F02} =>.Superfluous.Empty
O43 - CFD: 03/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F2111B3B-6F2E-4CA2-A7BA-43EB6FBABF41} =>.Superfluous.Empty
O43 - CFD: 23/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F23855E1-C576-4185-A12D-BA5784D5ACC9} =>.Superfluous.Empty
O43 - CFD: 20/11/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F2803DF5-C6B7-4231-B2C6-6157360C6851} =>.Superfluous.Empty
O43 - CFD: 08/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F288CC15-5628-466F-9EB2-E67C06CFF504} =>.Superfluous.Empty
O43 - CFD: 29/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F2AAD283-FD7C-464D-980D-229CBA5792AE} =>.Superfluous.Empty
O43 - CFD: 12/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F2C61046-CBDA-46A5-85EE-40148678F2A8} =>.Superfluous.Empty
O43 - CFD: 03/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F30945B2-60EC-4435-8825-18C3BB5BC7DC} =>.Superfluous.Empty
O43 - CFD: 31/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F3C8E2A3-8B20-4053-8A72-D0208AEB61B3} =>.Superfluous.Empty
O43 - CFD: 22/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F3E34FC3-B24D-41E3-9DB8-37A8068F37CF} =>.Superfluous.Empty
O43 - CFD: 03/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F408045F-CC48-4EB2-B114-CF9B7A2E060A} =>.Superfluous.Empty
O43 - CFD: 04/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F41C1435-F1E4-4A37-AEEF-06577E4123DA} =>.Superfluous.Empty
O43 - CFD: 17/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F452B38C-0FEC-4B89-97D8-B13DE533183D} =>.Superfluous.Empty
O43 - CFD: 14/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F46181E5-4260-4ACA-A3E4-4FB1F6A218AB} =>.Superfluous.Empty
O43 - CFD: 13/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F4C6C867-7B14-4D69-9624-4A5690D0261E} =>.Superfluous.Empty
O43 - CFD: 20/09/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F4C937AC-2737-439F-819E-4F14E624C2DA} =>.Superfluous.Empty
O43 - CFD: 29/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F4DD1FF2-F0CD-451D-9AF6-FF2DF77067ED} =>.Superfluous.Empty
O43 - CFD: 11/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F51B39A5-D908-4C7C-AC1E-A41DBF0D78D2} =>.Superfluous.Empty
O43 - CFD: 23/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F5279EAA-AE09-4392-801F-C1D3A847C32F} =>.Superfluous.Empty
O43 - CFD: 05/04/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{F541C04E-0219-4F25-925E-DF12A5A38CCD} =>.Superfluous.Empty
O43 - CFD: 03/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{F5A43F37-A5BA-4A46-9A3F-DE9DE7D589A3} =>.Superfluous.Empty
O43 - CFD: 06/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F5A7A85A-5D23-4AE7-A524-BA4952A6EB4D} =>.Superfluous.Empty
O43 - CFD: 20/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F5C5022A-BFB4-4788-ADD2-F3E5D60D6E46} =>.Superfluous.Empty
O43 - CFD: 07/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F5EBC9B4-71C0-48B1-BB8F-B85FC2C23551} =>.Superfluous.Empty
O43 - CFD: 05/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F6072E6D-4014-44DA-9303-D970018BDE7D} =>.Superfluous.Empty
O43 - CFD: 13/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F626636A-5E44-4A72-AEE2-8149DAC4F407} =>.Superfluous.Empty
O43 - CFD: 05/10/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F6530E3C-EECE-498A-8566-D95551A08D7E} =>.Superfluous.Empty
O43 - CFD: 30/10/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F7D96A6C-7BF9-46C8-A89C-1B41D5C9D156} =>.Superfluous.Empty
O43 - CFD: 29/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F813A918-7C51-4848-904B-58239A58B7AE} =>.Superfluous.Empty
O43 - CFD: 13/03/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F86E9790-8788-494E-A53A-F73BB10BDD13} =>.Superfluous.Empty
O43 - CFD: 14/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F871C9DA-932C-4AE4-A84C-17F9708C4817} =>.Superfluous.Empty
O43 - CFD: 21/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F8791C1C-AC5C-41C9-BC94-77084434D7A9} =>.Superfluous.Empty
O43 - CFD: 30/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F8B831A6-693C-4845-A9FE-4519992BCE12} =>.Superfluous.Empty
O43 - CFD: 09/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F8CD7F52-292C-4C62-A50F-B4ED75B7B4C3} =>.Superfluous.Empty
O43 - CFD: 24/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F8DD13EE-0B5B-4314-A26D-FDEA0917A8B9} =>.Superfluous.Empty
O43 - CFD: 04/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F8E3A5DC-C218-4963-9A92-5C4338147EBE} =>.Superfluous.Empty
O43 - CFD: 29/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{F8F7049C-C0C4-4E05-8B03-B519590251DF} =>.Superfluous.Empty
O43 - CFD: 24/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F909971B-A414-46D2-8289-744C5F6B9956} =>.Superfluous.Empty
O43 - CFD: 16/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F93736DA-424F-416D-A595-35FDFC44767B} =>.Superfluous.Empty
O43 - CFD: 23/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{F94476D5-FF8C-405D-9C94-D4A5DD8B5C65} =>.Superfluous.Empty
O43 - CFD: 24/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F95FE52C-163F-4C6D-B2BF-D8F303D05DAF} =>.Superfluous.Empty
O43 - CFD: 21/03/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F9B88C98-7F77-4109-A657-E4E8C5E31ED8} =>.Superfluous.Empty
O43 - CFD: 01/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{F9EE1574-46FB-4660-B837-1F5AB13B5394} =>.Superfluous.Empty
O43 - CFD: 12/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{F9FC0C64-ED5A-40D2-9B2D-CACEE2A134EC} =>.Superfluous.Empty
O43 - CFD: 20/08/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FA8FA892-042F-4F2F-8D39-2CF0009CA08F} =>.Superfluous.Empty
O43 - CFD: 07/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{FA9637EC-245A-4B5B-9CD7-49E20A71CC4B} =>.Superfluous.Empty
O43 - CFD: 26/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FAD0CDC7-2A8F-48B8-87AA-FEE2DB3737A6} =>.Superfluous.Empty
O43 - CFD: 22/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FAE3FED4-AEE1-4CD3-AB70-3AE713C14394} =>.Superfluous.Empty
O43 - CFD: 09/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FAFC7577-0C5C-4C55-92F4-1AF8255C87F4} =>.Superfluous.Empty
O43 - CFD: 15/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FB6E7C4C-EEC4-496A-B5CB-051D5094C8AB} =>.Superfluous.Empty
O43 - CFD: 22/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FBADB193-B214-4BB8-AA12-C6F6D743F35E} =>.Superfluous.Empty
O43 - CFD: 24/06/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FBBE766A-C39C-4E8D-BDC9-1513CD262111} =>.Superfluous.Empty
O43 - CFD: 30/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FBCC22B8-B94B-4B43-AD31-E646CE0B0C52} =>.Superfluous.Empty
O43 - CFD: 18/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FBDF494A-7C2D-4CD9-9A33-558A98314214} =>.Superfluous.Empty
O43 - CFD: 21/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FC3225C2-5A0C-47A0-9B5E-E14E3545F653} =>.Superfluous.Empty
O43 - CFD: 08/02/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FC537A8F-14B9-43A4-8443-B8C796738A4B} =>.Superfluous.Empty
O43 - CFD: 07/03/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{FC82F668-7EE4-4478-A128-2707A4765127} =>.Superfluous.Empty
O43 - CFD: 12/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FCA6BF44-731D-4955-8F92-56A24EE2C65E} =>.Superfluous.Empty
O43 - CFD: 10/02/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{FCA79032-7DC2-493A-AAA1-C915D70EC997} =>.Superfluous.Empty
O43 - CFD: 17/05/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FD001723-394F-4EF9-83A1-AC4AB2C49B11} =>.Superfluous.Empty
O43 - CFD: 13/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FD072258-4416-496F-BEE4-D44CF6C030FC} =>.Superfluous.Empty
O43 - CFD: 26/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FD2DFC24-CD8E-4811-BF9F-4BDC70FE1D9F} =>.Superfluous.Empty
O43 - CFD: 13/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FD401536-EED1-4E83-A211-FA4C59CEAD08} =>.Superfluous.Empty
O43 - CFD: 02/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FD43AE5F-635B-420B-81BB-3106D59503AF} =>.Superfluous.Empty
O43 - CFD: 29/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FD595E32-AE1B-4096-A012-2D79C74A2D09} =>.Superfluous.Empty
O43 - CFD: 18/01/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FD652B6F-44D7-4FC5-8B08-A8FF4A92D9D3} =>.Superfluous.Empty
O43 - CFD: 15/02/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FD933A09-AEEF-47AA-87B5-4B4CD5911058} =>.Superfluous.Empty
O43 - CFD: 07/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FE0CF349-765B-445B-9A18-470C1E8F9A48} =>.Superfluous.Empty
O43 - CFD: 30/06/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FE0EFF10-5FFB-4BFB-8535-1E43A3BA3E08} =>.Superfluous.Empty
O43 - CFD: 01/04/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FE0F17DD-D643-44C3-8A52-7E00FD7A308F} =>.Superfluous.Empty
O43 - CFD: 06/08/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FE2C336D-F8BE-4209-9626-168BB3360F81} =>.Superfluous.Empty
O43 - CFD: 14/07/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FED6FE92-0416-4E94-8FC2-3E0381ED89FC} =>.Superfluous.Empty
O43 - CFD: 09/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FF76A8A1-FBFC-45F0-A9F2-077E5B16B6AB} =>.Superfluous.Empty
O43 - CFD: 16/07/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FF87BA01-6596-4019-A66C-ECC27D5DD675} =>.Superfluous.Empty
O43 - CFD: 02/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FF8B1BE1-2C76-4B61-97AF-104B733552B2} =>.Superfluous.Empty
O43 - CFD: 22/09/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FFA211A4-5838-497D-951F-77994315B757} =>.Superfluous.Empty
O43 - CFD: 13/04/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FFA4213C-91BC-44ED-B62A-B54CEC6C18F2} =>.Superfluous.Empty
O43 - CFD: 14/11/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FFAA1F0A-EDB9-4F81-A8D5-D34E4408A7F9} =>.Superfluous.Empty
O43 - CFD: 18/12/2012 - [0] D -- C:\Users\Juancho\AppData\Local\{FFADE07B-4BBA-441A-9BA8-CA36645476AE} =>.Superfluous.Empty
O43 - CFD: 28/05/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FFCC0739-1424-4027-B312-8745FD0E3026} =>.Superfluous.Empty
O43 - CFD: 01/12/2011 - [0] D -- C:\Users\Juancho\AppData\Local\{FFD011F1-8E84-4A98-8F76-664EA4AC6CAE} =>.Superfluous.Empty
O43 - CFD: 02/01/2013 - [0] D -- C:\Users\Juancho\AppData\Local\{FFFFB0B9-0FD6-4167-B311-1B06C4863D94} =>.Superfluous.Empty
O87 - FAEL: "{8F01A867-5FE5-47B1-8A18-091A7920D708}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Sierra\FEAR\FEAR.exe (.not file.)
O87 - FAEL: "{F2E4F866-F14B-4770-ADC6-140211FFB64A}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Sierra\FEAR\FEAR.exe (.not file.)
O87 - FAEL: "{42829A33-89C6-4CDB-9143-85DFA052C295}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Sierra\FEAR\FEARMP.exe (.not file.)
O87 - FAEL: "{210BD69E-F159-4A39-B14B-201A402380C7}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Sierra\FEAR\FEARMP.exe (.not file.)
O87 - FAEL: "{19376CEE-FAFB-4AA2-B103-7599595F2ADB}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Rockstar Games\L.A. Noire\LANLauncher.exe (.not file.)
O87 - FAEL: "{2E8BC498-3F26-46AE-98F8-4EA7D834370E}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Rockstar Games\L.A. Noire\LANLauncher.exe (.not file.)
O87 - FAEL: "{2163CA95-27A2-4ADA-B840-08951876EEC9}" [In-None-P6-FALSE] .(...) -- C:\Program Files (x86)\Rockstar Games\L.A. Noire\LANLauncher.exe (.not file.)
O87 - FAEL: "{A168C14A-5B0B-492A-9CBD-80C267720610}" [In-None-P17-FALSE] .(...) -- C:\Program Files (x86)\Rockstar Games\L.A. Noire\LANLauncher.exe (.not file.)
O87 - FAEL: "TCP Query User{3D8A4F92-E35B-4BF8-BF78-266D29FBBE38}E:\maxpayne3.exe" [In-None-P6-TRUE] .(...) -- E:\maxpayne3.exe (.not file.)
O87 - FAEL: "UDP Query User{BA497497-FD4C-4C91-9041-835F22E3529F}E:\maxpayne3.exe" [In-None-P17-TRUE] .(...) -- E:\maxpayne3.exe (.not file.)
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_d160accw6snlyf.cloudfront.net_0.localstorage =>.Superfluous.CloudfrontNet
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_d160accw6snlyf.cloudfront.net_0.localstorage-journal =>.Superfluous.CloudfrontNet
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_d22j4fzzszoii2.cloudfront.net_0.localstorage =>.Superfluous.CloudfrontNet
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_d22j4fzzszoii2.cloudfront.net_0.localstorage-journal =>.Superfluous.CloudfrontNet
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_putlocker.ac_0.localstorage =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_putlocker.ac_0.localstorage-journal =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_static.audienceinsights.net_0.localstorage =>.Superfluous.AudienceInsights
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_static.audienceinsights.net_0.localstorage-journal =>.Superfluous.AudienceInsights
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_static.olark.com_0.localstorage =>PUP.Optional.Generic
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_static.olark.com_0.localstorage-journal =>PUP.Optional.Generic
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_the-putlocker.com_0.localstorage =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_the-putlocker.com_0.localstorage-journal =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_video-editor-free.en.softonic.com_0.localstorage =>.Superfluous.Softonic
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\https_video-editor-free.en.softonic.com_0.localstorage-journal =>.Superfluous.Softonic
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_howtosimplified.dl.tb.ask.com_0.localstorage =>Toolbar.Ask
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_howtosimplified.dl.tb.ask.com_0.localstorage-journal =>Toolbar.Ask
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_members.driverguide.com_0.localstorage =>PUP.Optional.DriverGuide
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_members.driverguide.com_0.localstorage-journal =>PUP.Optional.DriverGuide
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_putlocker-movies.is_0.localstorage =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_putlocker-movies.is_0.localstorage-journal =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_putlocker.ac_0.localstorage =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_putlocker.ac_0.localstorage-journal =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_putlockers.ch_0.localstorage =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_putlockers.ch_0.localstorage-journal =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_st.chatango.com_0.localstorage =>PUP.Optional.Chatango
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_st.chatango.com_0.localstorage-journal =>PUP.Optional.Chatango
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.driverguide.com_0.localstorage =>PUP.Optional.DriverGuide
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.driverguide.com_0.localstorage-journal =>PUP.Optional.DriverGuide
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.putlocker.wtf_0.localstorage =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.putlocker.wtf_0.localstorage-journal =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.putlockers-movies.net_0.localstorage =>PUP.Optional.PutLocker
C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.putlockers-movies.net_0.localstorage-journal =>PUP.Optional.PutLocker
EmptyTemp
ZHP Scan.
2. Once you have started the program, you will need to click the scanner button.
3. Once the scan is completed, the you will want to click the Repair button.
At the end of the process you may be asked to reboot your machine. After you reboot a report will open on your desktop.
Copy and paste the report here in your next reply.
Adware Removal Tool Scan.
Hit Ok.
The Program will close all open programs to complete the removal, so save any work and hit OK. Then hit OK after the removal process is complete, thenOK again to finish up. Post log generated by tool.
Security Check Scan.
  • Download Security Check to your desktop.
  • Right click it run as administrator.
  • When the program completes, the tool will automatically open a log file.
  • Please post that log here in your next post.
Okay here you go. All done. The Adware Removal Tool didn't find any issues, so there wasn't a log report made from the program.
Rapport de ZHPFix 2015.10.19.9 par Nicolas Coolman, Update du 19/10/2015
Fichier d'export Registre :
Run by Juancho at 10/06/2017 10:08:14 PM
High Elevated Privileges : OK
Windows 7 Home Premium Edition, 64-bit Service Pack 1 (Build 7601)
Recycle Bin emptied (08mn AMs)
========== Registry keys ==========
REMOVES: Service: PnkBstrA
REMOVES: HKLM\SOFTWARE\Wow6432Node\Symantec
REMOVES: HKCU\SOFTWARE\c1O9pL9eoaBMG9NlwPnXI
REMOVES: HKCU\SOFTWARE\Chris
REMOVES: HKCU\SOFTWARE\Chromium
REMOVES: HKCU\SOFTWARE\grWkCgMQbwn4LWnty4JxPE
REMOVES: HKCU\SOFTWARE\McAfee
REMOVES: HKCU\SOFTWARE\Norton
========== Registry values ==========
ProxyFix : Proxy configuration successfully removed
REMOVES ProxyServer Value
REMOVES ProxyEnable Value
REMOVES EnableHttp1_1 Value
REMOVES ProxyHttp1.1 Value
REMOVES ProxyOverride Value
REMOVES: {8F01A867-5FE5-47B1-8A18-091A7920D708}
REMOVES: {F2E4F866-F14B-4770-ADC6-140211FFB64A}
REMOVES: {42829A33-89C6-4CDB-9143-85DFA052C295}
REMOVES: {210BD69E-F159-4A39-B14B-201A402380C7}
REMOVES: {19376CEE-FAFB-4AA2-B103-7599595F2ADB}
REMOVES: {2E8BC498-3F26-46AE-98F8-4EA7D834370E}
REMOVES: {2163CA95-27A2-4ADA-B840-08951876EEC9}
REMOVES: {A168C14A-5B0B-492A-9CBD-80C267720610}
REMOVES: TCP Query User{3D8A4F92-E35B-4BF8-BF78-266D29FBBE38}E:\maxpayne3.exe
REMOVES: UDP Query User{BA497497-FD4C-4C91-9041-835F22E3529F}E:\maxpayne3.exe
========== Preferences browser ==========
NOW Chrome File: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Preferences
ABSENT Chrome Site: http://ajax.googleapis.com
ABSENT Chrome Site: http://d31qbv1cthcecs.cloudfront.net
ABSENT Chrome Site: http://d5nxst8fruw4z.cloudfront.net
ABSENT Chrome Site: http://pchf2-jew4efcjsvzg0rz43cny.stackpathdns.com
ABSENT Chrome Site: http://ssl.google-analytics.com
ABSENT Chrome Site: http://ssl.gstatic.com
ABSENT Chrome Site: http://stats.g.doubleclick.net
ABSENT Chrome Site: http://www.google-analytics.com
ABSENT Chrome Site: http://www.google.com.au
REMOVES Folder Chrome: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\lpoimibckejjdjcfbdnajaicnklhfplh
REMOVES Folder Chrome: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda
REMOVES Folder Chrome: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjldcfjmnllhmgjclecdnfampinooman
REMOVES Folder Chrome: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm
REMOVES Folder Chrome: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\hakdifolhalapjijoafobooafbilfakh
REMOVES Folder Chrome: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\hghkgaeecgjhjkannahfamoehjmkjail
REMOVES Folder Chrome: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\jagncdcchgajhfhijbbhecadmaiegcmh
REMOVES Folder Chrome: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\cmedhionkhpnakcndndgjdbohmhepckk
========== Folders ==========
No folders empty CLSID Local user
REMOVES: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\lpoimibckejjdjcfbdnajaicnklhfplh
REMOVES: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda
REMOVES: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjldcfjmnllhmgjclecdnfampinooman
REMOVES: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm
REMOVES: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\hakdifolhalapjijoafobooafbilfakh
REMOVES: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\hghkgaeecgjhjkannahfamoehjmkjail
REMOVES: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\jagncdcchgajhfhijbbhecadmaiegcmh
REMOVES: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Extensions\cmedhionkhpnakcndndgjdbohmhepckk
REMOVES: C:\ProgramData\McAfee
REMOVES: C:\ProgramData\Norton
REMOVES: C:\ProgramData\NortonInstaller
REMOVES: C:\Users\Juancho\AppData\Local\201280
REMOVES: C:\Users\Juancho\AppData\Local\5997473-40A-4E36-98B7-78964FB766FC
REMOVES: C:\Users\Juancho\AppData\Local\76561198020804561
REMOVES: C:\Users\Juancho\AppData\Local\Chromium
REMOVES: C:\Users\Juancho\AppData\Local\dxhr
REMOVES: C:\Users\Juancho\AppData\Local\GWX
Deletes temporary Windows (11)
========== Files ==========
REMOVES Flash Cookies (0) (0 octets)
REMOVES Reboot: c:\windows\system32\tasks\{e6cb6fce-9395-48b7-bd65-2d38296b68c6}
REMOVES Reboot: c:\program files (x86)\mozilla firefox\extensions\{82af8dca-6de9-405d-bd5e-43525bdad38a}
Deletes temporary Windows (164) (5,957,103 octets)
========== Scheduled task ==========
REMOVES: Adobe Flash Player Updater
REMOVES: {012BD29A-9649-478B-BD5B-886D7EA2ACA8}
REMOVES: {1B89EFF7-9169-4B7E-8856-0D0F217993EB}
REMOVES: {347F2A55-820C-47D0-9143-3DF9B53E6F8A}
REMOVES: {3F36ABA8-9F20-4592-97D5-A5680A404B2B}
REMOVES: {6D19A283-B6DC-483D-8D11-C8D1368245AB}
REMOVES: {8284A1E7-21EB-40BF-B8DE-A0A2C088D644}
REMOVES: {8484D166-C4D2-4C57-9A83-E9C7E93FE4BF}
REMOVES: {9D62F8B2-C655-42AA-99C3-2E2E8E52667D}
REMOVES: {A9BE53DD-C633-435E-B9C3-E2AF25266E22}
REMOVES: {AB6F53B5-C8FC-43C0-A53A-81A1B0A93834}
REMOVES: {CA968E23-0FB4-4F48-B783-E29A70CF73A7}
REMOVES: {CF66E521-AC58-4C9C-901B-A09406856F01}
========== System restore ==========
The system successfully created restore point
========== Summary ==========
8 : Registry keys
16 : Registry values
19 : Folders
4 : Files
26 : Preferences browser
13 : Scheduled task
1 : System restore
End of clean in 02mn AMs
========== Path to file report ==========
C:\Users\Juancho\AppData\Roaming\ZHP\ZHPFix[R1].txt - 10/06/2017 10:08:23 PM [6575]
~ ZHPCleaner v2017.6.9.95 by Nicolas Coolman (2017/06/09)
~ Run by Juancho (Administrator) (10/06/2017 22:36:20)
~ Blog: https://nicolascoolman.eu/
~ Facebook : https://www.facebook.com/nicolascoolman1
~ State version : Version OK
~ Type : Repair
~ Report : C:\Users\Juancho\Desktop\ZHPCleaner.txt
~ Quarantine : C:\Users\Juancho\AppData\Roaming\ZHP\ZHPCleaner_Reg.txt
~ UAC : Activate
~ Boot Mode : Normal (Normal boot)
Windows 7 Home Premium, 64-bit Service Pack 1 (Build 7601)
---\\ Services (0)
~ No malicious or unnecessary items found.
---\\ Browser internet (2)
REPLACED Google Chrome Preferences: "https://d31qbv1cthcecs.cloudfront.net/" =>.Superfluous.CloudfrontNet
REPLACED Google Chrome Preferences: "https://d5nxst8fruw4z.cloudfront.net/" =>.Superfluous.CloudfrontNet
---\\ Hosts file (1)
~ The hosts file is legitimate (21)
---\\ Scheduled automatic tasks. (0)
---\\ Explorer ( File, Folder) (7)
MOVED file: C:\Windows\Installer\wix{0A596141-97D5-45FA-9281-98DFAF48D579}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\wix{E5C95CA5-4565-4B9D-97ED-05088D775614}.SchedServiceConfig.rmi =>.Superfluous.Empty
MOVED file: C:\Windows\Installer\MSI8FA9.tmp =>.Superfluous.MSIInstaller
MOVED file: C:\Windows\Installer\MSIA3B7.tmp =>.Superfluous.MSIInstaller
MOVED file: C:\Windows\Installer\MSIEDA9.tmp =>.Superfluous.MSIInstaller
MOVED folder: C:\Program Files (x86)\QuickTime =>Riskware.QuickTime
MOVED folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QuickTime =>Riskware.QuickTime
---\\ Registry ( Key, Value, Data) (1)
DELETED key*: HKLM\SYSTEM\CurrentControlSet\Services\GameConsoleService [C:\Program Files (x86)\TOSHIBA Games\TOSHIBA Game Console\GameConsoleService.exe (Not File)] =>PUP.Optional.Youndoo
---\\ Summary of the elements found (5)
https://nicolascoolman.eu/2017/02/02/superfluous-cloudfrontnet/ =>.Superfluous.CloudfrontNet
https://nicolascoolman.eu/2017/01/20/logiciels-superflus/ =>.Superfluous.Empty
https://nicolascoolman.eu/2017/01/20/logiciels-superflus/ =>.Superfluous.MSIInstaller
https://nicolascoolman.eu/2017/01/15/riskware-quicktime/ =>Riskware.QuickTime
https://nicolascoolman.eu/2017/03/11/superfluous-youndoo/ =>PUP.Optional.Youndoo
---\\ Other deletions. (26)
~ Registry Keys Tracing deleted (26)
~ Remove the old reports ZHPCleaner. (0)
---\\ Result of repair
~ Repair carried out successfully
~ Browser not found (Opera Software)
---\\ Statistics
~ Items scanned : 1285
~ Items found : 0
~ Items cancelled : 0
~ Items repaired : 10
~ End of clean in 00h00mn25s
ZHPCleaner-[R]-10062017-22_36_45.txt
ZHPCleaner--10062017-22_24_52.txt
ZHPCleaner--10062017-22_35_44.txt
SecurityCheck by glax24 & Severnyj v.1.4.0.50 [06.06.17]
WebSite: www.safezone.cc
DateLog: 10.06.2017 23:17:42
Path starting: C:\Users\Juancho\AppData\Local\Temp\SecurityCheck\SecurityCheck.exe
Log directory: C:\SecurityCheck\
IsAdmin: True
User: Juancho
VersionXML: 4.35is-08.06.2017
___________________________________________________________________________
Windows 7(6.1.7601) Service Pack 1 (x64) HomePremium Lang: English(0409)
Installation date OS: 08.02.2011 07:49:06
Boot Mode: Normal
Default Browser: C:\Users\Juancho\AppData\Local\Google\Chrome\Application\chrome.exe
SystemDrive: C: FS: [NTFS] Capacity: [453.9 Gb] Used: [251 Gb] Free: [202.9 Gb]
------------------------------- [ Windows ] -------------------------------
Internet Explorer 11.0.9600.18665
User Account Control enabled
Automatically download and schedule installation
Date install updates: 2017-06-09 04:11:11
Windows Update (wuauserv) - The service is running
Security Center (wscsvc) - The service is running
Remote Registry (RemoteRegistry) - The service has stopped
SSDP Discovery (SSDPSRV) - The service is running
Remote Desktop Services (TermService) - The service has stopped
Windows Remote Management (WS-Management) (WinRM) - The service has stopped
------------------------------ [ MS Office ] ------------------------------
Microsoft Office 2010 x86 v.14.0.7015.1000
--------------------------- [ FirewallWindows ] ---------------------------
Windows Firewall (MpsSvc) - The service is running
Disabled the domain profile of Windows Firewall
Disabled the public profile of Windows Firewall
Disabled the standard profile for Windows Firewall
---------------------- [ AntiVirusFirewallInstall ] -----------------------
Kaspersky PURE 3.0 v.13.0.2.558
-------------------------- [ SecurityUtilities ] --------------------------
Malwarebytes version 3.1.2.1733 v.3.1.2.1733
--------------------------- [ OtherUtilities ] ----------------------------
Microsoft Silverlight v.5.1.50906.0
VLC media player v.2.2.4 Warning! Download Update
WinRAR 4.10 beta 1 (32-bit) v.4.10.1 Warning! Download Update
--------------------------------- [ IM ] ----------------------------------
Skype™ 7.0 v.7.0.102 Warning! Download Update
^Optional update.^
--------------------------- [ AppleProduction ] ---------------------------
Bonjour v.3.1.0.1
iTunes v.12.6.1.25
QuickTime v.7.73.80.64 Warning! This software is no longer supported. Please uninstall it and use another software.
Bonjour Service (Bonjour Service) - The service is running
--------------------------- [ AdobeProduction ] ---------------------------
Adobe AIR v.1.5.0.7220 Warning! Download Update
Adobe Flash Player 20 ActiveX v.20.0.0.270 Warning! Download Update
Adobe Flash Player 20 NPAPI v.20.0.0.267 Warning! Download Update
Adobe Shockwave Player 12.2 v.12.2.4.194 Warning! Download Update
Adobe Reader 9.5.0 v.9.5.0 Warning! This software is no longer supported. Please uninstall it and use Adobe Reader XI or Adobe Acrobat Reader DC.
------------------------------- [ Browser ] -------------------------------
Google Chrome v.58.0.3029.110 Warning! Download Update
Mozilla Firefox 43.0.1 (x86 en-GB) v.43.0.1 Warning! Download Update
----------------------------- [ EmailClient ] -----------------------------
Windows Live Mail v.15.4.3502.0922 Warning! This software is no longer supported.
--------------------------- [ RunningProcess ] ----------------------------
C:\Users\Juancho\AppData\Local\Google\Chrome\Application\chrome.exe v.58.0.3029.110
chrome.exe
------------------ [ AntivirusFirewallProcessServices ] -------------------
Kaspersky Anti-Virus Service (AVP) - The service is running
C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\avp.exe v.13.0.2.628
C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe v.3.0.0.1068
Malwarebytes Service (MBAMService) - The service is running
C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe v.3.1.0.479
Windows Defender (WinDefend) - The service is running
---------------------------- [ UnwantedApps ] -----------------------------
WildTangent ORB Game Console << Hidden Warning! Application is distributed through the partnership programs and bundle assemblies. Uninstallation recommended. Possible you became a victim of fraud or social engineering.
FATE v.2.2.0.82 << Hidden Warning! Application is distributed through the partnership programs and bundle assemblies. Uninstallation recommended. Possible you became a victim of fraud or social engineering.
Skype Click to Call v.6.12.13601 Warning! Browser's toolbar. It can slow down the working of your browser and have violation privacy problems.
----------------------------- [ End of Log ] ------------------------------
How's your machine running now? Can you also post a fresh zhp diag log so I can see if there is anything else that needs to be removed.
My laptop is fine now, it's pretty quiet, doesn't sound like the fan is overworking or anything like that either. As far as I can tell my laptop is a-okay. Here's a zhp diag log I just did now, if you don't see anything bad I think we're good! I suppose now I can have another go with Pro Tools, see what happens.
~ ZHPDiag v2017.6.10.96 By Nicolas Coolman (2017/06/10)
~ Run by Juancho (Administrator) (2017/06/11 15:14:05)
~ Facebook: https://www.facebook.com/nicolascoolman1
~ State version: Version OK
~ Mode: Scan
~ Report: C:\Users\Juancho\Desktop\ZHPDiag.txt
~ Report: C:\Users\Juancho\AppData\Roaming\ZHP\ZHPDiag.txt
~ UAC: Activate
~ System startup: Normal (Normal boot)
Windows 7 Home Premium, 64-bit Service Pack 1 (Build 7601) =>.Microsoft Corporation
---\\ Internet Browsers (2) - 0s
~ MFIE: Mozilla Firefox 43.0.1 (x86 en-GB)
~ MSIE: Internet Explorer v11.0.9600.18665
---\\ Windows Product Information (4) - 0s
~ Windows Server License Manager Script : OK
~ Licence Script File Génération : OK
Windows Automatic Updates : OK
Windows Activation Technologies : OK
---\\ System protection software (1) - 5s
Kaspersky PURE 3.0 v13.0.2.558 (Protection)
---\\ Surveillance software (2) - 7s
~ Adobe Flash Player 20 NPAPI (Surveillance)
~ Adobe Reader 9.5.0 (Surveillance)
---\\ Information on the system (6) - 0s
~ Operating System: Intel64 Family 6 Model 30 Stepping 5, GenuineIntel
~ Operating System: 64-bit
~ Boot mode: Normal (Normal boot)
Total RAM: 8376.812 MB (73% free) : OK =>.RAM Value
System Restore: Activé (Enable)
System drive C: has 206 GB (44%) free of 464 GB : OK =>.Disk Space
---\\ Connection to the system mode (3) - 0s
~ Computer Name: JUANCHO-PC
~ User Name: Juancho
~ Logged in as Administrator
---\\ Enumeration of the disk units (2) - 0s
~ Drive C: has 206 GB free of 464 GB (System)
~ Drive E: has 404 GB free of 476 GB
---\\ State of the Windows Security Center (11) - 0s
[HKLM\SOFTWARE\Microsoft\Security Center\Svc] AntiSpywareOverride: OK
[HKLM\SOFTWARE\Microsoft\Security Center\Svc] AntiVirusOverride: OK
[HKLM\SOFTWARE\Microsoft\Security Center\Svc] FirewallOverride: OK
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer] NoActiveDesktopChanges: Modified
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system] EnableLUA: OK
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\NOHIDDEN] CheckedValue: Modified
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\SHOWALL] CheckedValue: OK
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Associations] Application: OK
[HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon] Shell: OK
[HKLM\SYSTEM\CurrentControlSet\Services\COMSysApp] Type: OK
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install] LastSuccessTime : OK
---\\ Search Generic System Files (24) - 1s
[MD5.38AE1B3C38FAEF56FE4907922F0385BA] - 11/12/2014 - (.Microsoft Corporation - Windows Explorer.) -- C:\windows\Explorer.exe [3229696] =>.Microsoft Corporation
[MD5.DD81D91FF3B0763C392422865C9AC12E] - 11/12/2014 - (.Microsoft Corporation - Windows host process (Rundll32).) -- C:\windows\System32\rundll32.exe [45568] =>.Microsoft Corporation
[MD5.94355C28C1970635A31B3FE52EB7CEBA] - 11/12/2014 - (.Microsoft Corporation - Windows Start-Up Application.) -- C:\windows\System32\Wininit.exe [129024] =>.Microsoft Corporation
[MD5.4A60B440DC5D2BFAD65B55926BC2C292] - 11/12/2014 - (.Microsoft Corporation - Internet Extensions for Win32.) -- C:\windows\System32\wininet.dll [3241472] =>.Microsoft Corporation
[MD5.8CEBD9D0A0A879CDE9F36F4383B7CAEA] - 11/12/2014 - (.Microsoft Corporation - Windows Logon Application.) -- C:\windows\System32\Winlogon.exe [455168] =>.Microsoft Corporation
[MD5.067FA52BFB59A56110A12312EF9AF243] - 11/12/2014 - (.Microsoft Corporation - Software Licensing Library.) -- C:\windows\System32\sppcomapi.dll [232448] =>.Microsoft Corporation
[MD5.492D07D79E7024CA310867B526D9636D] - 11/12/2014 - (.Microsoft Corporation - DNS Client API DLL.) -- C:\windows\System32\dnsapi.dll [357888] =>.Microsoft Corporation
[MD5.B40420876B9288E0A1C8CCA8A84E5DC9] - 11/12/2014 - (.Microsoft Corporation - DNS Client API DLL.) -- C:\windows\Syswow64\dnsapi.dll [270336] =>.Microsoft Corporation
[MD5.0DC2A9882540DEA4A55B08785E09D8FC] - 11/12/2014 - (.Microsoft Corporation - Ancillary Function Driver for WinSock.) -- C:\windows\System32\drivers\AFD.sys [496128] =>.Microsoft Corporation
[MD5.02062C0B390B7729EDC9E69C680A6F3C] - 11/12/2014 - (.Microsoft Corporation - ATAPI IDE Miniport Driver.) -- C:\windows\System32\drivers\atapi.sys [24128] =>.Microsoft Windows®
[MD5.B8BD2BB284668C84865658C77574381A] - 11/12/2014 - (.Microsoft Corporation - CD-ROM File System Driver.) -- C:\windows\System32\drivers\Cdfs.sys [92160] =>.Microsoft Corporation
[MD5.F036CE71586E93D94DAB220D7BDF4416] - 11/12/2014 - (.Microsoft Corporation - SCSI CD-ROM Driver.) -- C:\windows\System32\drivers\Cdrom.sys [147456] =>.Microsoft Corporation
[MD5.9B38580063D281A99E68EF5813022A5F] - 11/12/2014 - (.Microsoft Corporation - DFS Namespace Client Driver.) -- C:\windows\System32\drivers\DfsC.sys [106496] =>.Microsoft Corporation
[MD5.97BFED39B6B79EB12CDDBFEED51F56BB] - 11/12/2014 - (.Microsoft Corporation - High Definition Audio Bus Driver.) -- C:\windows\System32\drivers\HDAudBus.sys [122368] =>.Microsoft Corporation
[MD5.FA55C73D4AFFA7EE23AC4BE53B4592D3] - 11/12/2014 - (.Microsoft Corporation - i8042 Port Driver.) -- C:\windows\System32\drivers\i8042prt.sys [105472] =>.Microsoft Corporation
[MD5.AF9B39A7E7B6CAA203B3862582E9F2D0] - 11/12/2014 - (.Microsoft Corporation - IP Network Address Translator.) -- C:\windows\System32\drivers\IpNat.sys [116224] =>.Microsoft Corporation
[MD5.054F780A442DB96F9FE10501B35E75CA] - 11/12/2014 - (.Microsoft Corporation - Windows NT SMB Minirdr.) -- C:\windows\System32\drivers\MRxSmb.sys [159744] =>.Microsoft Corporation
[MD5.E47D571FEC2C76E867935109AB2A770C] - 11/12/2014 - (.Microsoft Corporation - MBT Transport driver.) -- C:\windows\System32\drivers\netBT.sys [262144] =>.Microsoft Corporation
[MD5.47B2D0B31BDC3EBE6090228E2BA3764D] - 11/12/2014 - (.Microsoft Corporation - NT File System Driver.) -- C:\windows\System32\drivers\ntfs.sys [1684416] =>.Microsoft Windows®
[MD5.0086431C29C35BE1DBC43F52CC273887] - 11/12/2014 - (.Microsoft Corporation - Parallel Port Driver.) -- C:\windows\System32\drivers\Parport.sys [97280] =>.Microsoft Corporation
[MD5.471815800AE33E6F1C32FB1B97C490CA] - 11/12/2014 - (.Microsoft Corporation - RAS L2TP mini-port/call-manager driver.) -- C:\windows\System32\drivers\Rasl2tp.sys [129536] =>.Microsoft Corporation
[MD5.548260A7B8654E024DC30BF8A7C5BAA4] - 11/12/2014 - (.Microsoft Corporation - SMB Transport driver.) -- C:\windows\System32\drivers\smb.sys [93184] =>.Microsoft Corporation
[MD5.EC75A942C32F7F405659D86156DCE4C5] - 11/12/2014 - (.Microsoft Corporation - TDI Translation Driver.) -- C:\windows\System32\drivers\tdx.sys [117760] =>.Microsoft Corporation
[MD5.0D08D2F3B3FF84E433346669B5E0F639] - 11/12/2014 - (.Microsoft Corporation - Volume Shadow Copy Driver.) -- C:\windows\System32\drivers\volsnap.sys [295808] =>.Microsoft Windows®
---\\ Non Microsoft non disabled Windows Services (4) - 1s
O23 - Service: Apple Mobile Device Service (Apple Mobile Device Service) . (.Apple Inc. - MobileDeviceService.) - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe =>.Apple Inc.®
O23 - Service: Kaspersky Anti-Virus Service (AVP) . (.Kaspersky Lab ZAO - Kaspersky Anti-Virus.) - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\avp.exe =>.Kaspersky Lab®
O23 - Service: Bonjour Service (Bonjour Service) . (.Apple Inc. - Bonjour Service.) - C:\Program Files\Bonjour\mDNSResponder.exe =>.Apple Inc.®
O23 - Service: Malwarebytes Service (MBAMService) . (.Malwarebytes - Malwarebytes Service.) - C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe =>.Malwarebytes Corporation®
---\\ Services not Microsoft (SR=Run, SS=Stop) (27) - 6s
SS - Auto [11/12/2014] [ 315496] Apple Mobile Device Service (Apple Mobile Device Service) . (.Apple Inc..) - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe =>.Apple Inc.®
SS - Disabl [11/12/2014] [ 315496] Avid Hub Service (AvidHubService) . (...) - C:\Program Files\Avid\Cloud Client Services\Hub.exe {32FCE884652634BA17F648BC5BE6F36F}
SS - Disabl [11/12/2014] [ 315496] Avid Transport Client (AvidTransportClient) . (.Avid Technology, Inc..) - C:\Program Files\Avid\Cloud Client Services\TransportClient.exe {32FCE884652634BA17F648BC5BE6F36F} =>.Avid Technology, Inc.
SS - Auto [11/12/2014] [ 315496] Kaspersky Anti-Virus Service (AVP) . (.Kaspersky Lab ZAO.) - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\avp.exe =>.Kaspersky Lab®
SS - Disabl [11/12/2014] [ 315496] BattlEye Service (BEService) . (...) - C:\Program Files (x86)\Common Files\BattlEye\BEService.exe =>.Bastian Suter®
SS - Auto [11/12/2014] [ 315496] Bonjour Service (Bonjour Service) . (.Apple Inc..) - C:\Program Files\Bonjour\mDNSResponder.exe =>.Apple Inc.®
SS - Disabl [11/12/2014] [ 315496] BitRaider Mini-Support Service Stub Loader (BRSptStub) . (.BitRaider, LLC.) - C:\ProgramData\BitRaider\BRSptStub.exe =>.BitRaider LLC®
SS - Disabl [11/12/2014] [ 315496] CryptoStorage control service (CSObjectsSrv) . (.Infowatch.) - C:\Program Files (x86)\Common Files\InfoWatch\CryptoStorage\ProtectedObjectsSrv.exe {24151D1E4045E32A4EA4E75CE81EA5C9} =>.Infowatch
SS - Disabl [11/12/2014] [ 315496] NVIDIA GeForce Experience Service (GfExperienceService) . (.NVIDIA Corporation.) - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe =>.NVIDIA Corporation®
SS - Disabl [11/12/2014] [ 315496] Intel(R) Rapid Storage Technology (IAStorDataMgrSvc) . (.Intel Corporation.) - C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe =>.Intel Corporation®
SS - Disabl [11/12/2014] [ 315496] InstallDriver Table Manager (IDriverT) . (.Macrovision Corporation.) - C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe =>.Macrovision Corporation
SS - Disabl [11/12/2014] [ 315496] Canon Inkjet Printer/Scanner/Fax Extended Survey Program (IJPLMSVC) . (.Copyright CANON INC. 2006-2010 All Rights Reserved.) - C:\Program Files (x86)\Canon\IJPLM\ijplmsvc.exe =>.Canon Inc.®
SS - Demand [11/12/2014] [ 315496] iPod Service (iPod Service) . (.Apple Inc..) - C:\Program Files\iPod\bin\iPodService.exe =>.Apple Inc.®
SS - Disabl [11/12/2014] [ 315496] IviRegMgr (IviRegMgr) . (.InterVideo.) - C:\Program Files (x86)\Common Files\InterVideo\RegMgr\iviRegMgr.exe =>.Intervideo, Inc.®
SS - Auto [11/12/2014] [ 315496] Malwarebytes Service (MBAMService) . (.Malwarebytes.) - C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe =>.Malwarebytes Corporation®
SS - Disabl [11/12/2014] [ 315496] Mozilla Maintenance Service (MozillaMaintenance) . (.Mozilla Foundation.) - C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe =>.Mozilla Corporation®
SS - Disabl [11/12/2014] [ 315496] NVIDIA Network Service (NvNetworkService) . (.NVIDIA Corporation.) - C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe =>.NVIDIA Corporation®
SS - Disabl [11/12/2014] [ 315496] NVIDIA Streamer Service (NvStreamSvc) . (.NVIDIA Corporation.) - C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamsvc.exe =>.NVIDIA Corporation®
SS - Disabl [11/12/2014] [ 315496] NVIDIA Display Driver Service (nvsvc) . (.NVIDIA Corporation.) - C:\windows\system32\nvvsvc.exe =>.NVIDIA Corporation®
SS - Disabl [11/12/2014] [ 315496] O2FLASH (O2FLASH) . (.O2Micro International.) - C:\windows\system32\DRIVERS\o2flash.exe =>.O2Micro International
SS - Disabl [11/12/2014] [ 315496] Origin Client Service (Origin Client Service) . (.Electronic Arts.) - C:\Program Files (x86)\Origin\OriginClientService.exe =>.Electronic Arts, Inc.®
SS - Disabl [11/12/2014] [ 315496] Skype C2C Service (Skype C2C Service) . (.Skype Technologies S.A..) - C:\ProgramData\Skype\Toolbars\Skype C2C Service\c2c_service.exe =>.Skype Technologies SA®
SS - Disabl [11/12/2014] [ 315496] Skype Updater (SkypeUpdate) . (.Skype Technologies.) - C:\Program Files (x86)\Skype\Updater\Updater.exe =>.Skype Software Sarl®
SS - Disabl [11/12/2014] [ 315496] Steam Client Service (Steam Client Service) . (.Valve Corporation.) - C:\Program Files (x86)\Common Files\Steam\SteamService.exe =>.Valve®
SS - Disabl [11/12/2014] [ 315496] TOSHIBA HDD Protection (Thpsrv) . (.TOSHIBA Corporation.) - C:\windows\system32\ThpSrv.exe =>.TOSHIBA CORPORATION®
SS - Disabl [11/12/2014] [ 315496] TOSHIBA Bluetooth Service (TOSHIBA Bluetooth Service) . (.TOSHIBA CORPORATION.) - C:\Program Files (x86)\Toshiba\Bluetooth Toshiba Stack\TosBtSrv.exe =>.TOSHIBA CORPORATION®
SS - Disabl [11/12/2014] [ 315496] TOSHIBA HDD SSD Alert Service (TOSHIBA HDD SSD Alert Service) . (.TOSHIBA Corporation.) - C:\Program Files\Toshiba\TOSHIBA HDD SSD Alert\TosSmartSrv.exe =>.TOSHIBA CORPORATION®
---\\ Task Planned Automatically (13) - 5s
[MD5.E5550587CC154E805433DFC99CE7937E] [APT] [CCleanerSkipUAC] (.Piriform Ltd.) -- C:\Program Files\CCleaner\CCleaner.exe [7619288] (.Activate.) =>.Piriform Ltd®
[MD5.DD7423ABBE2913E70D50E9318AD57EE4] [APT] [GoogleUpdateTaskUserS-1-5-21-794287275-3297088658-3092121377-1004Core] (.Google Inc..) -- C:\Users\Juancho\AppData\Local\Google\Update\GoogleUpdate.exe [144200] (.Activate.) =>.Google Inc®
[MD5.DD7423ABBE2913E70D50E9318AD57EE4] [APT] [GoogleUpdateTaskUserS-1-5-21-794287275-3297088658-3092121377-1004UA] (.Google Inc..) -- C:\Users\Juancho\AppData\Local\Google\Update\GoogleUpdate.exe [144200] (.Activate.) =>.Google Inc®
[MD5.AF714B804D3C605CFEE19713EB8190E0] [APT] [Kaspersky_Upgrade_Launcher_{278ADC42-419D-4547-A6CA-5B74BE0AD901}] (.AO Kaspersky Lab.) -- C:\Program Files\Common Files\AV\Kaspersky Lab\upgrade_launcher.exe [501416] (.Activate.) =>.Kaspersky Lab®
[MD5.454487751F04C9EFA9C9C5F3FE501B05] [APT] [{3D085530-2A46-48C6-BA7D-1EFCA89A122A}] (.BioWare.) -- C:\Program Files (x86)\Common Files\BioWare\Uninstall Mass Effect.exe [242696] (.Activate.) =>.BioWare®
[MD5.BF5464B78EFA008040A9B14A019C42EB] [APT] [{C0D69CF6-BA5F-4BAD-9611-508F1BCCD3DB}] (.InstallShield Software Corporation.) -- C:\Windows\IsUninst.exe [304128] (.Activate.) =>.InstallShield Software Corporation
O39 - APT: CCleanerSkipUAC - (.Piriform Ltd.) -- C:\windows\System32\Tasks\CCleanerSkipUAC [2798] =>.Piriform Ltd®
O39 - APT: GoogleUpdateTaskUserS-1-5-21-794287275-3297088658-3092121377-1004Core - (.Google Inc..) -- C:\windows\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-794287275-3297088658-3092121377-1004Core [3240] =>.Google Inc®
O39 - APT: GoogleUpdateTaskUserS-1-5-21-794287275-3297088658-3092121377-1004UA - (.Google Inc..) -- C:\windows\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-794287275-3297088658-3092121377-1004UA [3512] =>.Google Inc®
O39 - APT: Kaspersky_Upgrade_Launcher_{278ADC42-419D-4547-A6CA-5B74BE0AD901} - (.AO Kaspersky Lab.) -- C:\windows\System32\Tasks\Kaspersky_Upgrade_Launcher_{278ADC42-419D-4547-A6CA-5B74BE0AD901} [3032] =>.Kaspersky Lab®
O39 - APT: {3D085530-2A46-48C6-BA7D-1EFCA89A122A} - (.BioWare.) -- C:\windows\System32\Tasks\{3D085530-2A46-48C6-BA7D-1EFCA89A122A} [3162] =>.BioWare®
O39 - APT: {C0D69CF6-BA5F-4BAD-9611-508F1BCCD3DB} - (.InstallShield Software Corporation.) -- C:\windows\System32\Tasks\{C0D69CF6-BA5F-4BAD-9611-508F1BCCD3DB} [3168] =>.InstallShield Software Corporation
O39 - APT: Unknown - (...) -- C:\windows\System32\Tasks\{E6CB6FCE-9395-48B7-BD65-2D38296B68C6} [3276]
---\\ Auto loading programs from Registry and folders (11) - 0s
O4 - HKLM\..\Run: [iTunesHelper] . (.Apple Inc. - iTunesHelper.) -- C:\Program Files\iTunes\iTunesHelper.exe =>.Apple Inc.®
O4 - HKLM\..\Run: [Malwarebytes TrayApp] . (.Malwarebytes - Malwarebytes Tray Application.) -- C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\mbamtray.exe =>.Malwarebytes Corporation®
O4 - HKCU\..\Run: [CCleaner] . (.Piriform Ltd - CCleaner.) -- C:\Program Files\CCleaner\CCleaner64.exe =>.Piriform Ltd®
O4 - HKLM\..\Wow6432Node\Run: [AVP] . (.Kaspersky Lab ZAO - Kaspersky Anti-Virus.) -- C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\avp.exe =>.Kaspersky Lab®
O4 - HKUS\.DEFAULT\..\Run: [Raptr] . (. - Raptr Client.) -- C:\Program Files (x86)\Raptr\raptrstub.exe =>.Raptr, Inc®
O4 - HKUS\S-1-5-18\..\Run: [Raptr] . (. - Raptr Client.) -- C:\Program Files (x86)\Raptr\raptrstub.exe =>.Raptr, Inc®
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] . (.Microsoft Corporation - Windows Desktop Gadgets.) -- C:\Program Files\Windows Sidebar\sidebar.exe =>.Microsoft Corporation
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] . (.Microsoft Corporation - Windows Desktop Gadgets.) -- C:\Program Files\Windows Sidebar\sidebar.exe =>.Microsoft Corporation
O4 - HKUS\S-1-5-19\..\RunOnce: [mctadmin] . (.Microsoft Corporation - MCTAdmin.) -- C:\Windows\System32\mctadmin.exe =>.Microsoft Corporation
O4 - HKUS\S-1-5-20\..\RunOnce: [mctadmin] . (.Microsoft Corporation - MCTAdmin.) -- C:\Windows\System32\mctadmin.exe =>.Microsoft Corporation
O4 - HKUS\S-1-5-21-794287275-3297088658-3092121377-1004\..\Run: [CCleaner] . (.Piriform Ltd - CCleaner.) -- C:\Program Files\CCleaner\CCleaner64.exe =>.Piriform Ltd®
---\\ Google Chrome, Start,Search,Extensions (17) - 1s
G0 - GCSP: Preferences [User Data\Default][HomePage] http://ajax.googleapis.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://apis.google.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://d31qbv1cthcecs.cloudfront.net =>.Superfluous.CloudfrontNet
G0 - GCSP: Preferences [User Data\Default][HomePage] http://d5nxst8fruw4z.cloudfront.net =>.Superfluous.CloudfrontNet
G0 - GCSP: Preferences [User Data\Default][HomePage] http://pchelpforum.net
G0 - GCSP: Preferences [User Data\Default][HomePage] http://pchf2-jew4efcjsvzg0rz43cny.stackpathdns.com
G0 - GCSP: Preferences [User Data\Default][HomePage] http://ssl.gstatic.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.google-analytics.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.google.com.au =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.gstatic.com =>.Google Inc.
G2 - GCE: Preference [User Data\Default] [dchlnpcodkpfdpacogkljefecpegganj] __MSG_ExtensionName__
G2 - GCE: Preference [User Data\Default] [hakdifolhalapjijoafobooafbilfakh] __MSG_ExtensionName__
G2 - GCE: Preference [User Data\Default] [hghkgaeecgjhjkannahfamoehjmkjail] __MSG_ExtensionName__
G2 - GCE: Preference [User Data\Default] [jagncdcchgajhfhijbbhecadmaiegcmh] __MSG_ExtensionName__
G2 - GCE: Preference [User Data\Default] [nmmhkkegccagdldgiimedpiccmgmieda] Google Chrome manifest =>.Google Inc.
G2 - GCE: Preference [User Data\Default] [pjldcfjmnllhmgjclecdnfampinooman] __MSG_ExtensionName__
G2 - GCE: Preference [User Data\Default] [pkedcjkdefgpdelpbcmbmeomcjbeemfm] Chrome Media Router =>.Google Inc.
---\\ Mozilla Firefox,Plugins,Start,Search,Extensions (14) - 2s
P2 - EXT: (.Adobe Systems Inc. - Adobe PDF Plug-In For Firefox and Netscape.) -- C:\Program Files (x86)\Mozilla Firefox\Plugins\nppdf32.dll =>.Adobe Systems, Incorporated®
P2 - EXT: (.Apple Inc. - The QuickTime Plugin allows you to view a w.) -- C:\Program Files (x86)\Mozilla Firefox\Plugins\npqtplugin.dll =>.Apple Inc.
P2 - EXT: (.Apple Inc. - The QuickTime Plugin allows you to view a w.) -- C:\Program Files (x86)\Mozilla Firefox\Plugins\npqtplugin2.dll =>.Apple Inc.
P2 - EXT: (.Apple Inc. - The QuickTime Plugin allows you to view a w.) -- C:\Program Files (x86)\Mozilla Firefox\Plugins\npqtplugin3.dll =>.Apple Inc.
P2 - EXT: (.Apple Inc. - The QuickTime Plugin allows you to view a w.) -- C:\Program Files (x86)\Mozilla Firefox\Plugins\npqtplugin4.dll =>.Apple Inc.
P2 - EXT: (.Apple Inc. - The QuickTime Plugin allows you to view a w.) -- C:\Program Files (x86)\Mozilla Firefox\Plugins\npqtplugin5.dll =>.Apple Inc.
P2 - EXT: (.Apple Inc. - The QuickTime Plugin allows you to view a w.) -- C:\Program Files (x86)\Mozilla Firefox\Plugins\npqtplugin6.dll =>.Apple Inc.
P2 - EXT: (.Apple Inc. - The QuickTime Plugin allows you to view a w.) -- C:\Program Files (x86)\Mozilla Firefox\Plugins\npqtplugin7.dll =>.Apple Inc.
P2 - EXT: (.Apple Inc..) -- C:\Program Files (x86)\Mozilla Firefox\Plugins\QuickTimePlugin.class =>.Apple Inc.
P2 - EXT FILE: (.Firefox Hotfix - Firefox Hotfix: avoid updates that wou.) -- C:\Users\Juancho\AppData\Roaming\Mozilla\Firefox\Profiles\ck42sjqp.default\extensions\firefox-hotfix@mozilla.org.xpi =>.Firefox Hotfix
P2 - EXT: (.Skype Technologies S.A. - Skype Click to Call.) -- C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{82AF8DCA-6DE9-405D-BD5E-43525BDAD38A} =>.Skype Technologies S.A.
P2 - EXT: (.Mozilla - Default.) -- C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd} =>.Mozilla
P2 - FPN: [HKCU] [ubisoft.com/uplaypc] - (...) -- C:\Program Files (x86)\Ubisoft\Ubisoft Game Launcher\npuplaypc.dll
P2 - FPN: [HKLM] [@esn/npbattlelog,version=2.6.2] - (.EA Digital Illusions CE AB.) -- C:\Program Files (x86)\Battlelog Web Plugins\2.6.2\npbattlelog.dll =>.EA Digital Illusions CE AB
---\\ Internet Explorer Extensions, Start, Search (16) - 0s
R0 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
R0 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
R0 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.google.com/ =>.Google Inc.
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Extensions Off Page = about:noadd-ons =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Security Risk Page = about:securityrisk =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Extensions Off Page = about:noadd-ons =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Security Risk Page = about:securityrisk =>.Microsoft Corporation
R3 - URLSearchHook: (no name) - {CFBFAE00-17A6-11D0-99CB-00C04FD64497} Orphan =>.Microsoft Internet Explorer
---\\ Internet Explorer, Proxy Management (6) - 0s
R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyEnable = 0
R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,MigrateProxy = 1
R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,EnableHttp1_1 = 1
R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,AutoConfigProxy = wininet.dll
R5 - HKLM\SYSTEM\CurrentControlSet\services\NlaSvc\Parameters\Internet\ManualProxies [] =>.Microsoft
---\\ Line Analysis, IniFiles, Auto loading programs (3) - 0s
F2 - REG:system.ini: UserInit=userinit.exe (.Microsoft Corporation.) =>.Microsoft Corporation
F2 - REG:system.ini: Shell=C:\windows\explorer.exe (.Microsoft Corporation.) =>.Microsoft Corporation
F2 - REG:system.ini: VMApplet=C:\windows\SysWOW64\SystemPropertiesPerformance.exe (.Microsoft Corporation.) =>.Microsoft Corporation
---\\ Hosts file redirection (1) - 0s
~ Le fichier hôte est sain (The hosts file is clean) (21)
---\\ Browser Helper Object (BHO) (7) - 0s
O2 - BHO: ContentBlockerBrowserHelperObject [64Bits] - {5564CC73-EFA7-4CBF-918A-5CF7FBBFFF4F} . (.Kaspersky Lab ZAO - Content Blocker Plugin.) -- C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\IEExt\ContentBlocker\ie_content_blocker_plugin.dll =>.Kaspersky Lab®
O2 - BHO: VirtualKeyboardBrowserHelperObject [64Bits] - {73455575-E40C-433C-9784-C78DC7761455} . (.Kaspersky Lab ZAO - Virtual Keyboard Plugin.) -- C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\IEExt\VirtualKeyboard\ie_virtual_keyboard_plugin.dll =>.Kaspersky Lab®
O2 - BHO: Windows Live ID Sign-in Helper [64Bits] - {9030D464-4C02-4ABF-8ECC-5164760863C6} . (.Microsoft Corp. - Microsoft® Windows Live ID Login Helper.) -- C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll =>.Microsoft Corporation®
O2 - BHO: Safe Money Plugin [64Bits] - {9E6D0D23-3D72-4A94-AE1F-2D167624E3D9} . (.Kaspersky Lab ZAO - Safe Money Plugin.) -- C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\IEExt\OnlineBanking\online_banking_bho.dll =>.Kaspersky Lab®
O2 - BHO: SkypeIEPluginBHO [64Bits] - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} . (.Skype Technologies S.A. - Skype Click to Call for Internet Explorer.) -- C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll =>.Skype Technologies SA®
O2 - BHO: URLRedirectionBHO [64Bits] - {B4F3A835-0E21-4959-BA22-42B3008E02FF} . (.Microsoft Corporation - Microsoft Office Document Cache Handler.) -- C:\Program Files (x86)\Microsoft Office\Office14\URLREDIR.DLL =>.Microsoft Corporation®
O2 - BHO: link filter bho [64Bits] - {E33CF602-D945-461A-83F0-819F76A199F8} . (.Kaspersky Lab ZAO - URL Advisor Plugin.) -- C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\IEExt\UrlAdvisor\klwtbbho.dll =>.Kaspersky Lab®
---\\ Internet Explorer Toolbars (1) - 0s
O3 - Toolbar: 0xB1C218236549D4119B18009027A5CD4F - [HKCU]{2318C2B1-4965-11D4-9B18-009027A5CD4F} . (...) -- (.not file.)
---\\ Global shortcuts Startup (121) - 7s
O4 - GS\Desktop [Administrator]: Microsoft Word 2010.lnk . (...) C:\windows\Installer\{90140000-003D-0000-0000-0000000FF1CE}\wordicon.exe =>.Microsoft Corporation®
O4 - GS\Desktop [Administrator]: ZHPCleaner.lnk . (.Nicolas Coolman - ZHPCleane.) C:\Users\Juancho\ZHPCleaner.exe =>.Nicolas Coolman
O4 - GS\Desktop [Administrator]: ZHPDiag.lnk . (.Nicolas Coolman - ZHPDiag.) C:\Users\Juancho\AppData\Roaming\ZHP\ZHPDiag3.exe =>.Nicolas Coolman
O4 - GS\Quicklaunch [Administrator]: GameSpy Comrade.lnk . (.IGN Entertainment Inc. - Comrade.) C:\Program Files (x86)\GameSpy\Comrade\Comrade.exe =>.IGN Entertainment Inc.
O4 - GS\Quicklaunch [Administrator]: Launch Internet Explorer Browser.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\sendTo [Administrator]: Fax Recipient.lnk . (.Microsoft Corporation - Microsoft Windows Fax and Scan.) C:\windows\system32\WFS.exe /SendTo =>.Microsoft Corporation
O4 - GS\sendTo [Administrator]: Skype.lnk . (.Skype Technologies S.A. - Skype.) C:\Program Files (x86)\Skype\Phone\Skype.exe /sendto: =>.Skype Software Sarl®
O4 - GS\TaskBar [Administrator]: Geek Unіnstaller.lnk . (.Geek Unіnstaller - Geek Unіnstaller.) C:\Users\Juancho\Desktop\Geek Uninstaller.exe =>.CrystalBit Solutions®
O4 - GS\TaskBar [Administrator]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Users\Juancho\AppData\Local\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\TaskBar [Administrator]: itunes - Shortcut.lnk . (.Apple Inc. - .) C:\Program Files (x86)\iTunes\iTunes.exe =>.Apple Inc.
O4 - GS\TaskBar [Administrator]: iTunes.lnk . (.Apple Inc. - .) C:\Program Files (x86)\iTunes\iTunes.exe =>.Apple Inc.
O4 - GS\TaskBar [Administrator]: Microsoft Word 2010.lnk . (...) C:\windows\Installer\{90140000-003D-0000-0000-0000000FF1CE}\wordicon.exe =>.Microsoft Corporation®
O4 - GS\TaskBar [Administrator]: Snappy Driver Installer (2).lnk . (...) C:\Users\Juancho\Desktop\SDI_x64_R1751.exe
O4 - GS\TaskBar [Administrator]: Snappy Driver Installer.lnk . (...) C:\Users\Juancho\Desktop\SDI_x64_R1751.exe
O4 - GS\Programs [Administrator]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Administrator]: Internet-Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Administrator]: MaxBatch.lnk . (...) C:\Program Files (x86)\Steam\steamapps\common\max payne\MaxBatch.bat =>.Steam Games
O4 - GS\Programs [Administrator]: Total Uninstall 5.lnk . (...) C:\Program Files (x86)\Total Uninstall 5\loader.exe
O4 - GS\Desktop [ASPNET]: Microsoft Word 2010.lnk . (...) C:\windows\Installer\{90140000-003D-0000-0000-0000000FF1CE}\wordicon.exe =>.Microsoft Corporation®
O4 - GS\Desktop [ASPNET]: ZHPCleaner.lnk . (.Nicolas Coolman - ZHPCleane.) C:\Users\Juancho\ZHPCleaner.exe =>.Nicolas Coolman
O4 - GS\Desktop [ASPNET]: ZHPDiag.lnk . (.Nicolas Coolman - ZHPDiag.) C:\Users\Juancho\AppData\Roaming\ZHP\ZHPDiag3.exe =>.Nicolas Coolman
O4 - GS\Quicklaunch [ASPNET]: GameSpy Comrade.lnk . (.IGN Entertainment Inc. - Comrade.) C:\Program Files (x86)\GameSpy\Comrade\Comrade.exe =>.IGN Entertainment Inc.
O4 - GS\Quicklaunch [ASPNET]: Launch Internet Explorer Browser.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\sendTo [ASPNET]: Fax Recipient.lnk . (.Microsoft Corporation - Microsoft Windows Fax and Scan.) C:\windows\system32\WFS.exe /SendTo =>.Microsoft Corporation
O4 - GS\sendTo [ASPNET]: Skype.lnk . (.Skype Technologies S.A. - Skype.) C:\Program Files (x86)\Skype\Phone\Skype.exe /sendto: =>.Skype Software Sarl®
O4 - GS\TaskBar [ASPNET]: Geek Unіnstaller.lnk . (.Geek Unіnstaller - Geek Unіnstaller.) C:\Users\Juancho\Desktop\Geek Uninstaller.exe =>.CrystalBit Solutions®
O4 - GS\TaskBar [ASPNET]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Users\Juancho\AppData\Local\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\TaskBar [ASPNET]: itunes - Shortcut.lnk . (.Apple Inc. - .) C:\Program Files (x86)\iTunes\iTunes.exe =>.Apple Inc.
O4 - GS\TaskBar [ASPNET]: iTunes.lnk . (.Apple Inc. - .) C:\Program Files (x86)\iTunes\iTunes.exe =>.Apple Inc.
O4 - GS\TaskBar [ASPNET]: Microsoft Word 2010.lnk . (...) C:\windows\Installer\{90140000-003D-0000-0000-0000000FF1CE}\wordicon.exe =>.Microsoft Corporation®
O4 - GS\TaskBar [ASPNET]: Snappy Driver Installer (2).lnk . (...) C:\Users\Juancho\Desktop\SDI_x64_R1751.exe
O4 - GS\TaskBar [ASPNET]: Snappy Driver Installer.lnk . (...) C:\Users\Juancho\Desktop\SDI_x64_R1751.exe
O4 - GS\Programs [ASPNET]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [ASPNET]: Internet-Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [ASPNET]: MaxBatch.lnk . (...) C:\Program Files (x86)\Steam\steamapps\common\max payne\MaxBatch.bat =>.Steam Games
O4 - GS\Programs [ASPNET]: Total Uninstall 5.lnk . (...) C:\Program Files (x86)\Total Uninstall 5\loader.exe
O4 - GS\Desktop [Guest]: Microsoft Word 2010.lnk . (...) C:\windows\Installer\{90140000-003D-0000-0000-0000000FF1CE}\wordicon.exe =>.Microsoft Corporation®
O4 - GS\Desktop [Guest]: ZHPCleaner.lnk . (.Nicolas Coolman - ZHPCleane.) C:\Users\Juancho\ZHPCleaner.exe =>.Nicolas Coolman
O4 - GS\Desktop [Guest]: ZHPDiag.lnk . (.Nicolas Coolman - ZHPDiag.) C:\Users\Juancho\AppData\Roaming\ZHP\ZHPDiag3.exe =>.Nicolas Coolman
O4 - GS\Quicklaunch [Guest]: GameSpy Comrade.lnk . (.IGN Entertainment Inc. - Comrade.) C:\Program Files (x86)\GameSpy\Comrade\Comrade.exe =>.IGN Entertainment Inc.
O4 - GS\Quicklaunch [Guest]: Launch Internet Explorer Browser.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\sendTo [Guest]: Fax Recipient.lnk . (.Microsoft Corporation - Microsoft Windows Fax and Scan.) C:\windows\system32\WFS.exe /SendTo =>.Microsoft Corporation
O4 - GS\sendTo [Guest]: Skype.lnk . (.Skype Technologies S.A. - Skype.) C:\Program Files (x86)\Skype\Phone\Skype.exe /sendto: =>.Skype Software Sarl®
O4 - GS\TaskBar [Guest]: Geek Unіnstaller.lnk . (.Geek Unіnstaller - Geek Unіnstaller.) C:\Users\Juancho\Desktop\Geek Uninstaller.exe =>.CrystalBit Solutions®
O4 - GS\TaskBar [Guest]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Users\Juancho\AppData\Local\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\TaskBar [Guest]: itunes - Shortcut.lnk . (.Apple Inc. - .) C:\Program Files (x86)\iTunes\iTunes.exe =>.Apple Inc.
O4 - GS\TaskBar [Guest]: iTunes.lnk . (.Apple Inc. - .) C:\Program Files (x86)\iTunes\iTunes.exe =>.Apple Inc.
O4 - GS\TaskBar [Guest]: Microsoft Word 2010.lnk . (...) C:\windows\Installer\{90140000-003D-0000-0000-0000000FF1CE}\wordicon.exe =>.Microsoft Corporation®
O4 - GS\TaskBar [Guest]: Snappy Driver Installer (2).lnk . (...) C:\Users\Juancho\Desktop\SDI_x64_R1751.exe
O4 - GS\TaskBar [Guest]: Snappy Driver Installer.lnk . (...) C:\Users\Juancho\Desktop\SDI_x64_R1751.exe
O4 - GS\Programs [Guest]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Guest]: Internet-Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Guest]: MaxBatch.lnk . (...) C:\Program Files (x86)\Steam\steamapps\common\max payne\MaxBatch.bat =>.Steam Games
O4 - GS\Programs [Guest]: Total Uninstall 5.lnk . (...) C:\Program Files (x86)\Total Uninstall 5\loader.exe
O4 - GS\Desktop [Juancho]: Microsoft Word 2010.lnk . (...) C:\windows\Installer\{90140000-003D-0000-0000-0000000FF1CE}\wordicon.exe =>.Microsoft Corporation®
O4 - GS\Desktop [Juancho]: ZHPCleaner.lnk . (.Nicolas Coolman - ZHPCleane.) C:\Users\Juancho\ZHPCleaner.exe =>.Nicolas Coolman
O4 - GS\Desktop [Juancho]: ZHPDiag.lnk . (.Nicolas Coolman - ZHPDiag.) C:\Users\Juancho\AppData\Roaming\ZHP\ZHPDiag3.exe =>.Nicolas Coolman
O4 - GS\Quicklaunch [Juancho]: GameSpy Comrade.lnk . (.IGN Entertainment Inc. - Comrade.) C:\Program Files (x86)\GameSpy\Comrade\Comrade.exe =>.IGN Entertainment Inc.
O4 - GS\Quicklaunch [Juancho]: Launch Internet Explorer Browser.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\sendTo [Juancho]: Fax Recipient.lnk . (.Microsoft Corporation - Microsoft Windows Fax and Scan.) C:\windows\system32\WFS.exe /SendTo =>.Microsoft Corporation
O4 - GS\sendTo [Juancho]: Skype.lnk . (.Skype Technologies S.A. - Skype.) C:\Program Files (x86)\Skype\Phone\Skype.exe /sendto: =>.Skype Software Sarl®
O4 - GS\TaskBar [Juancho]: Geek Unіnstaller.lnk . (.Geek Unіnstaller - Geek Unіnstaller.) C:\Users\Juancho\Desktop\Geek Uninstaller.exe =>.CrystalBit Solutions®
O4 - GS\TaskBar [Juancho]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Users\Juancho\AppData\Local\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\TaskBar [Juancho]: itunes - Shortcut.lnk . (.Apple Inc. - .) C:\Program Files (x86)\iTunes\iTunes.exe =>.Apple Inc.
O4 - GS\TaskBar [Juancho]: iTunes.lnk . (.Apple Inc. - .) C:\Program Files (x86)\iTunes\iTunes.exe =>.Apple Inc.
O4 - GS\TaskBar [Juancho]: Microsoft Word 2010.lnk . (...) C:\windows\Installer\{90140000-003D-0000-0000-0000000FF1CE}\wordicon.exe =>.Microsoft Corporation®
O4 - GS\TaskBar [Juancho]: Snappy Driver Installer (2).lnk . (...) C:\Users\Juancho\Desktop\SDI_x64_R1751.exe
O4 - GS\TaskBar [Juancho]: Snappy Driver Installer.lnk . (...) C:\Users\Juancho\Desktop\SDI_x64_R1751.exe
O4 - GS\Programs [Juancho]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Juancho]: Internet-Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Juancho]: MaxBatch.lnk . (...) C:\Program Files (x86)\Steam\steamapps\common\max payne\MaxBatch.bat =>.Steam Games
O4 - GS\Programs [Juancho]: Total Uninstall 5.lnk . (...) C:\Program Files (x86)\Total Uninstall 5\loader.exe
O4 - GS\CommonDesktop [Public]: foobar2000.lnk . (.Piotr Pawlowski - foobar2000.) C:\Program Files (x86)\foobar2000\foobar2000.exe =>.Piotr Pawlowski
O4 - GS\CommonDesktop [Public]: iTunes.lnk . (.Apple Inc. - .) C:\Program Files (x86)\iTunes\iTunes.exe =>.Apple Inc.
O4 - GS\CommonDesktop [Public]: VLC media player.lnk . (.VideoLAN - VLC media player.) C:\Program Files (x86)\VideoLAN\VLC\vlc.exe =>.VideoLAN®
O4 - GS\Programs [Public]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Public]: Internet-Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Public]: MaxBatch.lnk . (...) C:\Program Files (x86)\Steam\steamapps\common\max payne\MaxBatch.bat =>.Steam Games
O4 - GS\Programs [Public]: Total Uninstall 5.lnk . (...) C:\Program Files (x86)\Total Uninstall 5\loader.exe
O4 - GS\Accessories [Public]: Command Prompt.lnk . (.Microsoft Corporation - Windows Command Processor.) C:\windows\system32\cmd.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Notepad.lnk . (.Microsoft Corporation - Notepad.) C:\windows\system32\notepad.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Windows Explorer.lnk . (.Microsoft Corporation - Windows Explorer.) C:\windows\explorer.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Internet Explorer (No Add-ons).lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\SystemTools [Public]: Internet-Explorer (No Add-ons).lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\SystemTools [Public]: Private Character Editor.lnk . (.Microsoft Corporation - Private Character Editor.) C:\windows\system32\eudcedit.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: AC Box Combo.lnk . (.Native Instruments GmbH - ACBox Combo.) C:\Program Files (x86)\Native Instruments\AC Box Combo\ACBoxCombo.exe =>.Native Instruments GmbH
O4 - GS\Accessories [Public]: Calculator.lnk . (.Microsoft Corporation - Windows Calculator.) C:\windows\system32\calc.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: displayswitch.lnk . (.Microsoft Corporation - Display Switch.) C:\windows\system32\displayswitch.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Math Input Panel.lnk . (.Microsoft Corporation - Math Input Panel Accessory.) C:\Program Files (x86)\Common Files\Microsoft Shared\Ink\mip.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Mobility Center.lnk . (.Microsoft Corporation - Windows Mobility Center.) C:\windows\system32\mblctr.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Remote Desktop Connection.lnk . (.Microsoft Corporation - Remote Desktop Connection.) C:\windows\system32\mstsc.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Snipping Tool.lnk . (.Microsoft Corporation - Snipping Tool.) C:\windows\system32\SnippingTool.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Sticky Notes.lnk . (.Microsoft Corporation - Sticky Notes.) C:\windows\system32\StikyNot.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Sync Center.lnk . (.Microsoft Corporation - Microsoft Sync Center.) C:\windows\System32\mobsync.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Welcome Center.lnk . (.Microsoft Corporation - Windows host process (Rundll32).) C:\windows\system32\rundll32.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Wordpad.lnk . (.Microsoft Corporation - Windows Wordpad Application.) C:\Program Files (x86)\Windows NT\Accessories\wordpad.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Character Map.lnk . (.Microsoft Corporation - Character Map.) C:\windows\system32\charmap.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: dfrgui.lnk . (.Microsoft Corporation - Microsoft® Disk Defragmenter.) C:\windows\system32\dfrgui.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Disk Cleanup.lnk . (.Microsoft Corporation - Disk Space Cleanup Manager for Windows.) C:\windows\system32\cleanmgr.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Resource Monitor.lnk . (.Microsoft Corporation - Resource and Performance Monitor.) C:\windows\system32\perfmon.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: System Information.lnk . (.Microsoft Corporation - System Information.) C:\windows\system32\msinfo32.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: System Restore.lnk . (.Microsoft Corporation - Microsoft® Windows System Restore.) C:\windows\system32\rstrui.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Task Scheduler.lnk . (...) C:\windows\system32\taskschd.msc =>..Microsoft Corporation
O4 - GS\SystemTools [Public]: Windows Easy Transfer Reports.lnk . (.Microsoft Corporation - Windows Easy Transfer Post Migration Applic.) C:\windows\system32\migwiz\postmig.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Windows Easy Transfer.lnk . (.Microsoft Corporation - Windows Easy Transfer Application.) C:\windows\system32\migwiz\migwiz.exe =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Acrobat.com.lnk . (...) C:\Program Files (x86)\Adobe\Acrobat.com\Acrobat.com.exe
O4 - GS\ProgramsCommon [Public]: Adobe Reader 9.lnk . (...) C:\windows\Installer\{AC76BA86-7AD7-1033-7B44-A95000000001}\SC_Reader.ico =>.Adobe Inc.
O4 - GS\ProgramsCommon [Public]: Apple Software Update.lnk . (...) C:\windows\Installer\{52D87F32-70E4-4348-8148-C0B9F35B1314}\AppleSoftwareUpdateIco.exe =>.Apple Inc.
O4 - GS\ProgramsCommon [Public]: Audacity 1.3 Beta (Unicode).lnk . (.The Audacity Team - Audacity®, the Free, Cross-Platform Sound E.) C:\Program Files (x86)\Audacity 1.3 Beta (Unicode)\audacity.exe =>.The Audacity Team
O4 - GS\ProgramsCommon [Public]: BD DVD PLAYER.lnk . (.TOSHIBA Corporation - TOSHIBA HD DVD Launcher.) C:\Program Files (x86)\TOSHIBA\TOSHIBA DVD PLAYER\TosDVD.exe =>.TOSHIBA CORPORATION®
O4 - GS\ProgramsCommon [Public]: foobar2000.lnk . (.Piotr Pawlowski - foobar2000.) C:\Program Files (x86)\foobar2000\foobar2000.exe =>.Piotr Pawlowski
O4 - GS\ProgramsCommon [Public]: Media Center.lnk . (.Microsoft Corporation - Windows Media Center.) C:\windows\ehome\ehshell.exe =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Sidebar.lnk . (.Microsoft Corporation - Windows Desktop Gadgets.) C:\Program Files (x86)\Windows Sidebar\sidebar.exe =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Windows Anytime Upgrade.lnk . (.Microsoft Corporation - Windows Anytime Upgrade User Interface.) C:\windows\system32\WindowsAnytimeUpgradeUI.exe =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Windows DVD Maker.lnk . (.Microsoft Corporation - .) C:\Program Files (x86)\DVD Maker\DVDMaker.exe =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Windows Fax and Scan.lnk . (.Microsoft Corporation - Microsoft Windows Fax and Scan.) C:\windows\system32\WFS.exe =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Windows Live Mail.lnk . (.Microsoft Corporation - Windows Live Mail.) C:\Program Files (x86)\Windows Live\Mail\wlmail.exe =>.Microsoft Corporation®
O4 - GS\ProgramsCommon [Public]: Windows Live Movie Maker.lnk . (.Microsoft Corporation - Windows Live Movie Maker.) C:\Program Files (x86)\Windows Live\Photo Gallery\MovieMaker.exe =>.Microsoft Corporation®
O4 - GS\ProgramsCommon [Public]: Windows Live Photo Gallery.lnk . (.Microsoft Corporation - Windows Live Photo Gallery.) C:\Program Files (x86)\Windows Live\Photo Gallery\WLXPhotoGallery.exe =>.Microsoft Corporation®
O4 - GS\ProgramsCommon [Public]: Windows Media Player.lnk . (.Microsoft Corporation - Windows Media Player.) C:\Program Files (x86)\Windows Media Player\wmplayer.exe /prefetch:1 =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: XPS Viewer.lnk . (.Microsoft Corporation - XPS Viewer.) C:\windows\system32\xpsrchvw.exe =>.Microsoft Corporation
---\\ Lop.com/Domain Hijackers (3) - 0s
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1 =>.Local IP Adress
O17 - HKLM\System\CCS\Services\Tcpip\..\{14D0BC66-A641-41B2-B4C2-67DEE217A8F5}: DhcpNameServer = 192.168.1.1 =>.Local IP Adress
O17 - HKLM\System\CCS\Services\Tcpip\..\{D4C41734-5C1E-49A7-BDF3-662C9C24EFBF}: DhcpNameServer = 192.168.2.1 =>.Local IP Adress
---\\ Extra protocols (22) - 1s
O18 - Handler: about [64Bits] - {3050F406-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) -- C:\Windows\SysWOW64\mshtml.dll =>.Microsoft Corporation
O18 - Handler: dvd [64Bits] - {12D51199-0DB5-46FE-A120-47A3D7D937CC} . (.Microsoft Corporation - ActiveX control for streaming video.) -- C:\Windows\SysWOW64\MSVidCtl.dll =>.Microsoft Corporation
O18 - Handler: http [64Bits] - {79eac9e2-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) -- C:\Windows\SysWOW64\urlmon.dll =>.Microsoft Corporation
O18 - Handler: https [64Bits] - {79eac9e5-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) -- C:\Windows\SysWOW64\urlmon.dll =>.Microsoft Corporation
O18 - Handler: its [64Bits] - {9D148291-B9C8-11D0-A4CC-0000F80149F6} . (.Microsoft Corporation - Microsoft® InfoTech Storage System Library.) -- C:\Windows\System32\itss.dll =>.Microsoft Corporation
O18 - Handler: javascript [64Bits] - {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) -- C:\Windows\SysWOW64\mshtml.dll =>.Microsoft Corporation
O18 - Handler: livecall [64Bits] - {828030A1-22C1-4009-854F-8E305202313F} . (...) -- C:\Program Files (x86)\Windows Live\Messenger\msgrapp.dll (.not file.)
O18 - Handler: mailto [64Bits] - {3050f3DA-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) -- C:\Windows\SysWOW64\mshtml.dll =>.Microsoft Corporation
O18 - Handler: mhtml [64Bits] - {05300401-BCBC-11d0-85E3-00C04FD85AB4} . (.Microsoft Corporation - Microsoft Internet Messaging API Resources.) -- C:\Windows\System32\inetcomm.dll =>.Microsoft Corporation
O18 - Handler: ms-help [64Bits] - {314111c7-a502-11d2-bbca-00c04f8ec294} . (.Microsoft Corporation - Microsoft® Help Data Services Module.) -- C:\Program Files (x86)\Common Files\Microsoft Shared\Help\hxds.dll =>.Microsoft Corporation®
O18 - Handler: ms-its [64Bits] - {9D148291-B9C8-11D0-A4CC-0000F80149F6} . (.Microsoft Corporation - Microsoft® InfoTech Storage System Library.) -- C:\Windows\System32\itss.dll =>.Microsoft Corporation
O18 - Handler: msnim [64Bits] - {828030A1-22C1-4009-854F-8E305202313F} . (...) -- C:\Program Files (x86)\Windows Live\Messenger\msgrapp.dll (.not file.)
O18 - Handler: res [64Bits] - {3050F3BC-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) -- C:\Windows\SysWOW64\mshtml.dll =>.Microsoft Corporation
O18 - Handler: skype-ie-addon-data [64Bits] - {91774881-D725-4E58-B298-07617B9B86A8} . (.Skype Technologies S.A. - Skype Click to Call for Internet Explorer.) -- C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll =>.Skype Technologies SA®
O18 - Handler: tv [64Bits] - {CBD30858-AF45-11D2-B6D6-00C04FBBDE6E} . (.Microsoft Corporation - ActiveX control for streaming video.) -- C:\Windows\SysWOW64\MSVidCtl.dll =>.Microsoft Corporation
O18 - Handler: vbscript [64Bits] - {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) -- C:\Windows\SysWOW64\mshtml.dll =>.Microsoft Corporation
O18 - Handler: wlmailhtml [64Bits] - {03C514A3-1EFB-4856-9F99-10D7BE1653C0} . (.Microsoft Corporation - Windows Live Mail.) -- C:\Program Files (x86)\Windows Live\Mail\mailcomm.dll =>.Microsoft Corporation®
O18 - Handler: wlpg [64Bits] - {E43EF6CD-A37A-4A9B-9E6F-83F89B8E6324} . (.Microsoft Corporation - Windows Live Album Download Protocol Handle.) -- C:\Program Files (x86)\Windows Live\Photo Gallery\AlbumDownloadProtocolHandler.dll =>.Microsoft Corporation®
O18 - Filter: application/octet-stream [64Bits] - {1E66F26B-79EE-11D2-8710-00C04F79ED0D} . (.Microsoft Corporation - Microsoft .NET Runtime Execution Engine.) -- C:\Windows\System32\mscoree.dll =>.Microsoft Corporation®
O18 - Filter: application/x-complus [64Bits] - {1E66F26B-79EE-11D2-8710-00C04F79ED0D} . (.Microsoft Corporation - Microsoft .NET Runtime Execution Engine.) -- C:\Windows\System32\mscoree.dll =>.Microsoft Corporation®
O18 - Filter: application/x-msdownload [64Bits] - {1E66F26B-79EE-11D2-8710-00C04F79ED0D} . (.Microsoft Corporation - Microsoft .NET Runtime Execution Engine.) -- C:\Windows\System32\mscoree.dll =>.Microsoft Corporation®
O18 - Filter: text/xml [64Bits] - {807573E5-5146-11D5-A672-00B0D022E945} . (.Microsoft Corporation - Microsoft Office XML MIME Filter.) -- C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE14\MSOXMLMF.DLL =>.Microsoft Corporation®
---\\ Software installed (165) - 32s
O42 - Logiciel: Acrobat.com - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- {287ECFA4-719A-2143-A09B-D6A12DE54E40} =>.Adobe Systems Incorporated
O42 - Logiciel: Adobe AIR - (.Adobe Systems Inc..) [HKLM][64Bits] -- {A2BCA9F1-566C-4805-97D1-7FDC93386723} =>.Adobe Systems Inc.
O42 - Logiciel: Adobe AIR - (.Adobe Systems Inc..) [HKLM][64Bits] -- Adobe AIR =>.Adobe Systems Incorporated®
O42 - Logiciel: Adobe Flash Player 20 ActiveX - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- Adobe Flash Player ActiveX =>.Adobe Systems Incorporated
O42 - Logiciel: Adobe Flash Player 20 NPAPI - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- Adobe Flash Player NPAPI =>.Adobe Systems Incorporated
O42 - Logiciel: Adobe Reader 9.5.0 - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- {AC76BA86-7AD7-1033-7B44-A95000000001} =>.Adobe Systems Incorporated
O42 - Logiciel: Adobe Shockwave Player 12.2 - (.Adobe Systems, Inc..) [HKLM][64Bits] -- Adobe Shockwave Player =>.Adobe Systems, Inc.
O42 - Logiciel: AIR Xpand!2 - (.AIR Music Technology.) [HKLM][64Bits] -- {69A89482-FEC4-4E34-97F9-46BB287D0953} =>.AIR Music Technology
O42 - Logiciel: Apple Application Support (32-bit) - (.Apple Inc..) [HKLM][64Bits] -- {E92BB800-BCC5-4C25-8102-AC2C3B7C7C1E} =>.Apple Inc.
O42 - Logiciel: Apple Application Support (64-bit) - (.Apple Inc..) [HKLM][64Bits] -- {9C912B1E-06DD-43EF-BB2B-45CB2C88BAAE} =>.Apple Inc.
O42 - Logiciel: Apple Mobile Device Support - (.Apple Inc..) [HKLM][64Bits] -- {0A596141-97D5-45FA-9281-98DFAF48D579} =>.Apple Inc.
O42 - Logiciel: Apple Software Update - (.Apple Inc..) [HKLM][64Bits] -- {52D87F32-70E4-4348-8148-C0B9F35B1314} =>.Apple Inc.
O42 - Logiciel: Atheros Communications Inc.(R) AR81Family Gigabit/Fast Ethernet Driver - (.Atheros Communications Inc..) [HKLM][64Bits] -- {3108C217-BE83-42E4-AE9E-A56A2A92E549} =>.Atheros Communications Inc.
O42 - Logiciel: Audacity 1.2.6 - (.Audacity.) [HKLM][64Bits] -- Audacity_is1 =>.Audacity
O42 - Logiciel: Audacity 1.3.13 (Unicode) - (.Audacity Team.) [HKLM][64Bits] -- Audacity 1.3 Beta (Unicode)_is1 =>.Audacity Team
O42 - Logiciel: Avid Application Manager - (.Avid Technology, Inc..) [HKLM][64Bits] -- {A59C0B17-6673-46E6-9E00-BB25E755A299} =>.Avid Technology, Inc.
O42 - Logiciel: Avid Cloud Client Services - (.Avid Technology, Inc..) [HKLM][64Bits] -- {F9A1CAF7-904F-4542-AD7A-9D2D2E3AA80F} =>.Avid Technology, Inc.
O42 - Logiciel: Avid Effects - (.Avid Technology, Inc..) [HKLM][64Bits] -- {C7DB24AC-3016-45A3-AE71-790F09BFBFC3} =>.Avid Technology, Inc.
O42 - Logiciel: Battlelog Web Plugins - (.EA Digital Illusions CE AB.) [HKLM][64Bits] -- Battlelog Web Plugins =>.EA Digital Illusions CE AB
O42 - Logiciel: BattlEye for OA Uninstall - (.Bohemia Interactive Studio.) [HKLM][64Bits] -- BattlEye for OA
O42 - Logiciel: BattlEye Uninstall - (.Bohemia Interactive Studio.) [HKLM][64Bits] -- BattlEye for A2
O42 - Logiciel: BEHRINGER USB AUDIO DRIVER - (..) [HKLM][64Bits] -- USB_AUDIO_DEusb-audio.deBehringer2902 =>.Ploytec GmbH®
O42 - Logiciel: Bejeweled 2 Deluxe - (.WildTangent.) [HKLM][64Bits] -- WT078308 =>.WildTangent
O42 - Logiciel: BioShock 2 - (.Take-Two Interactive Software.) [HKLM][64Bits] -- {5454085C-129F-416C-9C0B-8B1000058301} =>.Take-Two Interactive Software
O42 - Logiciel: BioShock 2 - (.Take-Two Interactive Software.) [HKLM][64Bits] -- {5454085C-840F-4070-8FAA-441000038301} =>.Take-Two Interactive Software
O42 - Logiciel: BitRaider Streaming Client - (.BitRaider, LLC.) [HKLM][64Bits] -- BitRaider Streaming Client =>.Electronic Arts®
O42 - Logiciel: Bluetooth Stack for Windows by Toshiba - (.TOSHIBA CORPORATION.) [HKLM][64Bits] -- {CEBB6BFB-D708-4F99-A633-BC2600E01EF6} =>.Toshiba Corporation
O42 - Logiciel: Bonjour - (.Apple Inc..) [HKLM][64Bits] -- {56DDDFB8-7F79-4480-89D5-25E1F52AB28F} =>.Apple Inc.
O42 - Logiciel: BOSS - (.BOSS Development Team.) [HKLM][64Bits] -- BOSS =>.BOSS Development Team
O42 - Logiciel: Business Contact Manager for Outlook 2007 SP2 - (.Microsoft Corporation.) [HKLM][64Bits] -- {B32C4059-6E7A-41EF-AD20-56DF1872B923} =>.Microsoft Corporation
O42 - Logiciel: Business Contact Manager for Outlook 2007 SP2 - (.Microsoft Corporation.) [HKLM][64Bits] -- Business Contact Manager =>.Microsoft Corporation®
O42 - Logiciel: Canon Easy-PhotoPrint EX - (..) [HKLM][64Bits] -- Easy-PhotoPrint EX =>.Canon Inc.®
O42 - Logiciel: Canon Easy-WebPrint EX - (..) [HKLM][64Bits] -- Easy-WebPrint EX =>.Canon Inc.®
O42 - Logiciel: Canon IJ Network Tool - (..) [HKLM][64Bits] -- Canon_IJ_Network_UTILITY =>.Canon Inc.®
O42 - Logiciel: Canon Inkjet Printer/Scanner/Fax Extended Survey Program - (..) [HKLM][64Bits] -- CANONIJPLM100 =>.Canon Inc.®
O42 - Logiciel: Canon MP Navigator EX 4.0 - (.Canon Inc..) [HKLM][64Bits] -- MP Navigator EX 4.0 =>.Canon Inc.®
O42 - Logiciel: Canon MP495 series MP Drivers - (.Canon Inc..) [HKLM][64Bits] -- {1199FAD5-9546-44f3-81CF-FFDB8040B7BF}_Canon_MP495_series =>.Canon Inc.
O42 - Logiciel: Canon My Printer - (..) [HKLM][64Bits] -- CanonMyPrinter =>.Canon Inc.®
O42 - Logiciel: CCleaner - (.Piriform.) [HKLM][64Bits] -- CCleaner =>.Piriform Ltd®
O42 - Logiciel: Cheat Engine 6.2 - (.Dark Byte.) [HKLM][64Bits] -- Cheat Engine 6.2_is1 =>.Dark Byte
O42 - Logiciel: Chuzzle Deluxe - (.WildTangent.) [HKLM][64Bits] -- WT078316 =>.WildTangent
O42 - Logiciel: Cities: Skylines - (.Colossal Order.) [HKLM][64Bits] -- Steam App 255710 =>.Valve®
O42 - Logiciel: Conexant HD Audio - (.Conexant.) [HKLM][64Bits] -- CNXT_AUDIO =>.Conexant Systems, Inc.®
O42 - Logiciel: D3DX10 - (.Microsoft.) [HKLM][64Bits] -- {E09C4DB7-630C-4F06-A631-8EA7239923AF} =>.Microsoft
O42 - Logiciel: Dead Rising 2 - (.Capcom.) [HKLM][64Bits] -- {4343080E-448E-4E2C-B27F-B91000028201} =>.CAPCOM
O42 - Logiciel: Direct DiscRecorder - (.Corel Corporation.) [HKLM][64Bits] -- {F2004B8D-7791-4B35-A3FA-D8CA8BB4DD81} =>.Corel Corporation
O42 - Logiciel: Direct DiscRecorder - (.Corel Corporation.) [HKLM][64Bits] -- InstallShield_{F2004B8D-7791-4B35-A3FA-D8CA8BB4DD81} =>.Corel Corporation
O42 - Logiciel: Dolby Control Center - (.Dolby.) [HKLM][64Bits] -- {20387B45-18A4-4D48-ABD9-A23D2CBE42B3} =>.Dolby
O42 - Logiciel: Dual-Core Optimizer - (.AMD.) [HKLM][64Bits] -- {9FD6F1A8-5550-46AF-8509-271DF0E768B5} =>.AMD
O42 - Logiciel: DVD MovieFactory for TOSHIBA - (.Corel Corporation.) [HKLM][64Bits] -- {50F68032-B5B7-4513-9116-C978DBD8F27A} =>.Corel Corporation
O42 - Logiciel: DVD MovieFactory for TOSHIBA - (.Corel Corporation.) [HKLM][64Bits] -- InstallShield_{50F68032-B5B7-4513-9116-C978DBD8F27A} =>.Corel Corporation
O42 - Logiciel: EAX4 Unified Redist - (.Creative Labs.) [HKLM][64Bits] -- {89661B04-C646-4412-B6D3-5E19F02F1F37} =>.Creative Labs
O42 - Logiciel: FATE - (.WildTangent.) [HKLM][64Bits] -- WT078108 =>.WildTangent
O42 - Logiciel: foobar2000 v1.3.15 - (.Peter Pawlowski.) [HKLM][64Bits] -- foobar2000 =>.Peter Pawlowski
O42 - Logiciel: GameSpy Comrade - (.GameSpy.) [HKLM][64Bits] -- {5F4C776F-8CBD-4C4F-892F-B568ABDD70C8} =>.GameSpy
O42 - Logiciel: Google Chrome - (.Google Inc..) [HKCU][64Bits] -- Google Chrome =>.Google Inc®
O42 - Logiciel: HDMI Control Manager - (.TOSHIBA CORPORATION.) [HKLM][64Bits] -- {63DA1F6A-2E65-4367-99B9-9E39FADEC446} =>.Toshiba Corporation
O42 - Logiciel: HDMI Control Manager - (.TOSHIBA CORPORATION.) [HKLM][64Bits] -- InstallShield_{63DA1F6A-2E65-4367-99B9-9E39FADEC446} =>.Toshiba Corporation
O42 - Logiciel: Indiana Jones and the Fate of Atlantis - (.LucasArts.) [HKLM][64Bits] -- Steam App 6010 =>.Valve®
O42 - Logiciel: Intel(R) Control Center - (.Intel Corporation.) [HKLM][64Bits] -- {F8A9085D-4C7A-41a9-8A77-C8998A96C421} =>.Intel Corporation®
O42 - Logiciel: Intel(R) Rapid Storage Technology - (.Intel Corporation.) [HKLM][64Bits] -- {3E29EE6C-963A-4aae-86C1-DC237C4A49FC} =>.Intel Corporation®
O42 - Logiciel: InterVideo WinDVD BD for TOSHIBA - (.InterVideo Inc..) [HKLM][64Bits] -- {20471B27-D702-4FE8-8DEC-0702CC8C0A85} =>.InterVideo Inc.
O42 - Logiciel: InterVideo WinDVD BD for TOSHIBA - (.InterVideo Inc..) [HKLM][64Bits] -- InstallShield_{20471B27-D702-4FE8-8DEC-0702CC8C0A85} =>.InterVideo Inc.
O42 - Logiciel: iTunes - (.Apple Inc..) [HKLM][64Bits] -- {F0C7385A-9D20-45F3-8101-05D383885180} =>.Apple Inc.
O42 - Logiciel: Junk Mail filter update - (.Microsoft Corporation.) [HKLM][64Bits] -- {1F6AB0E7-8CDD-4B93-8A23-AA9EB2FEFCE4} =>.Microsoft Corporation
O42 - Logiciel: Kane and Lynch: Dead Men - (.Eidos.) [HKLM][64Bits] -- {A66C4716-7E10-4A53-8101-00C3C11D6A9C} =>.Eidos
O42 - Logiciel: Kaspersky PURE 3.0 - (.Kaspersky Lab.) [HKLM][64Bits] -- {D0702EE9-9DE4-419A-9C6C-4730B1C985BA} =>.Kaspersky Lab
O42 - Logiciel: Kaspersky PURE 3.0 - (.Kaspersky Lab.) [HKLM][64Bits] -- InstallWIX_{D0702EE9-9DE4-419A-9C6C-4730B1C985BA} =>.Kaspersky Lab
O42 - Logiciel: LAV Filters 0.62.0 - (.Hendrik Leppkes.) [HKLM][64Bits] -- lavfilters_is1 =>.Hendrik Leppkes
O42 - Logiciel: Life Is Strange™ - (.DONTNOD Entertainment.) [HKLM][64Bits] -- Steam App 319630 =>.Valve®
O42 - Logiciel: Magic Match - The Genie's Journey - (.WildTangent.) [HKLM][64Bits] -- WT078338 =>.WildTangent
O42 - Logiciel: Malwarebytes version 3.1.2.1733 - (.Malwarebytes.) [HKLM][64Bits] -- {35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1 =>.Malwarebytes Corporation®
O42 - Logiciel: Mass Effect 2 - (.Electronic Arts, Inc..) [HKLM][64Bits] -- {75D84EF7-0D8C-4e70-B3FA-7B42A5D4E0EB} =>.BioWare®
O42 - Logiciel: Max Payne 3 - (.Rockstar Games.) [HKLM][64Bits] -- {1AA94747-3BF6-4237-9E1A-7B3067738FE1} =>.Take-Two Interactive Software, Inc.®
O42 - Logiciel: Microsoft Application Error Reporting - (.Microsoft Corporation.) [HKLM][64Bits] -- {95120000-00B9-0409-1000-0000000FF1CE} =>.Microsoft Corporation
O42 - Logiciel: Microsoft Games for Windows - LIVE Redistributable - (.Microsoft Corporation.) [HKLM][64Bits] -- {42AA4CA8-DCD8-4308-BCAB-0B6D75856A9D} =>.Microsoft Corporation
O42 - Logiciel: Microsoft Games for Windows Marketplace - (.Microsoft Corporation.) [HKLM][64Bits] -- {4CB0307C-565E-4441-86BE-0DF2E4FB828C} =>.Microsoft Corporation
O42 - Logiciel: Microsoft Silverlight - (.Microsoft Corporation.) [HKLM][64Bits] -- {89F4137D-6C26-4A84-BDB8-2E5A4BB71E00} =>.Microsoft Corporation
O42 - Logiciel: Microsoft WSE 3.0 Runtime - (.Microsoft Corp..) [HKLM][64Bits] -- {E3E71D07-CD27-46CB-8448-16D4FB29AA13} =>.Microsoft Corp.
O42 - Logiciel: Microsoft XNA Framework Redistributable 4.0 - (.Microsoft Corporation.) [HKLM][64Bits] -- {2BFC7AA0-544C-4E3A-8796-67F3BE655BE9} =>.Microsoft Corporation
O42 - Logiciel: Monopoly - (.WildTangent.) [HKLM][64Bits] -- WT078123 =>.WildTangent
O42 - Logiciel: Mozilla Firefox 43.0.1 (x86 en-GB) - (.Mozilla.) [HKLM][64Bits] -- Mozilla Firefox 43.0.1 (x86 en-GB) =>.Mozilla Corporation®
O42 - Logiciel: Mozilla Maintenance Service - (.Mozilla.) [HKLM][64Bits] -- MozillaMaintenanceService =>.Mozilla
O42 - Logiciel: MS Access 97 SP2 - (..) [HKLM][64Bits] -- MS Access 97 SP2
O42 - Logiciel: MSVCRT - (.Microsoft.) [HKLM][64Bits] -- {8DD46C6A-0056-4FEC-B70A-28BB16A1F11F} =>.Microsoft
O42 - Logiciel: MSVCRT_amd64 - (.Microsoft.) [HKLM][64Bits] -- {D0B44725-3666-492D-BEF6-587A14BD9BD9} =>.Microsoft
O42 - Logiciel: MSXML 4.0 SP2 (KB954430) - (.Microsoft Corporation.) [HKLM][64Bits] -- {86493ADD-824D-4B8E-BD72-8C5DCDC52A71} =>.Microsoft Corporation
O42 - Logiciel: MSXML 4.0 SP2 (KB973688) - (.Microsoft Corporation.) [HKLM][64Bits] -- {F662A8E6-F4DC-41A2-901E-8C11F044BDEC} =>.Microsoft Corporation
O42 - Logiciel: My Game Long Name - (.Epic Games, Inc..) [HKLM][64Bits] -- UDK-1734a83b-3ca5-4f44-a23f-ab7b53e39c82 =>.Epic Games, Inc.
O42 - Logiciel: My Game Long Name - (.Epic Games, Inc..) [HKLM][64Bits] -- UDK-c02085fa-7eb8-44b6-a885-985b9cfb9c61 =>.Epic Games, Inc.
O42 - Logiciel: Native Instruments AC Box Combo - (..) [HKLM][64Bits] -- Native Instruments AC Box Combo
O42 - Logiciel: Native Instruments Service Center - (..) [HKLM][64Bits] -- Native Instruments Service Center
O42 - Logiciel: Nexus Mod Manager - (.Black Tree Gaming.) [HKLM][64Bits] -- 6af12c54-643b-4752-87d0-8335503010de_is1 =>.Black Tree Gaming
O42 - Logiciel: Nokia Connectivity Cable Driver - (..) [HKLM][64Bits] -- {BC4AE628-81A4-4FC6-863A-7A9BA2E2531F}
O42 - Logiciel: NVIDIA 3D Vision Controller Driver - (.NVIDIA Corporation.) [HKLM][64Bits] -- NVIDIA StereoUSB Driver =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA 3D Vision Controller Driver 340.50 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA Control Panel 341.44 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46c3-BAEC-A80AA35AC5B8}_Display.ControlPanel =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA GeForce Experience 2.4.3.22 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA GeForce Experience Service - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GfExperienceService =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA Graphics Driver 341.44 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA HD Audio Driver 1.3.30.1 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA Install Application - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_installer =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA LED Visualizer 1.0 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.LEDVisualizer =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA Network Service - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Network.Service =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA PhysX - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B455E95A-B804-439F-B533-336B1635AE97} =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA ShadowPlay 2.4.3.22 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShadowPlay =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA Update 2.4.3.22 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Update =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA Update Core - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Update.Core =>.NVIDIA Corporation
O42 - Logiciel: NVIDIA Virtual Audio 1.2.27 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_VirtualAudio.Driver =>.NVIDIA Corporation
O42 - Logiciel: O2Micro Flash Memory Card Windows Driver - (.O2Micro International LTD..) [HKLM][64Bits] -- {08D341E2-6FC3-4361-B18A-48E8AC004FEB} =>.O2Micro International LTD.
O42 - Logiciel: O2Micro Flash Memory Card Windows Driver - (.O2Micro International LTD..) [HKLM][64Bits] -- InstallShield_{08D341E2-6FC3-4361-B18A-48E8AC004FEB} =>.O2Micro Inc.®
O42 - Logiciel: OpenAL - (.Open Audio Library.) [HKLM][64Bits] -- OpenAL =>.Open Audio Library
O42 - Logiciel: Origin - (.Electronic Arts, Inc..) [HKLM][64Bits] -- Origin =>.Electronic Arts, Inc.®
O42 - Logiciel: Paranormal - (.Epic Games, Inc..) [HKLM][64Bits] -- UDK-894f5f43-0329-4bcc-911c-cbd31c758333 =>.Epic Games, Inc.
O42 - Logiciel: Peggle - (.WildTangent.) [HKLM][64Bits] -- WT078364 =>.WildTangent
O42 - Logiciel: PlayReady PC Runtime amd64 - (.Microsoft Corporation.) [HKLM][64Bits] -- {BCA9334F-B6C9-4F65-9A73-AC5A329A4D04} =>.Microsoft Corporation
O42 - Logiciel: Polar Bowler - (.WildTangent.) [HKLM][64Bits] -- WT078129 =>.WildTangent
O42 - Logiciel: Polar Golfer - (.WildTangent.) [HKLM][64Bits] -- WT078492 =>.WildTangent
O42 - Logiciel: Portal 2 - (.Valve.) [HKLM][64Bits] -- Steam App 620 =>.Valve®
O42 - Logiciel: PunkBuster Services - (.Even Balance, Inc..) [HKLM][64Bits] -- PunkBusterSvc =>.Even Balance, Inc.
O42 - Logiciel: QuickTime - (.Apple Inc..) [HKLM][64Bits] -- {AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A} =>Riskware.QuickTime
O42 - Logiciel: Raptr - (..) [HKLM][64Bits] -- Raptr
O42 - Logiciel: Rapture3D 2.5.1 Game - (.Blue Ripple Sound.) [HKLM][64Bits] -- {D2FCA41E-AC01-4DCD-B3A7-DC9E32363065}}_is1 =>.Blue Ripple Sound
O42 - Logiciel: Rayman Origins - (.Ubisoft.) [HKLM][64Bits] -- Uplay Install 80 =>.Ubisoft Entertainment Sweden AB®
O42 - Logiciel: Realtek WLAN Driver - (.Realtek.) [HKLM][64Bits] -- {0FB630AB-7BD8-40AE-B223-60397D57C3C9} =>.Realtek
O42 - Logiciel: Red Faction: Guerrilla - (.THQ.) [HKLM][64Bits] -- {54510837-BD04-4C32-9676-DB1000038201} =>.THQ
O42 - Logiciel: Red Faction: Guerrilla - (.THQ.) [HKLM][64Bits] -- {54510837-BD04-4C32-9676-DB1000038202} =>.THQ
O42 - Logiciel: redist - (.redist.) [HKLM][64Bits] -- {153C7D89-9CF4-4719-A551-C5BF45236DB5}
O42 - Logiciel: Regi - (.InterVideo Inc..) [HKLM][64Bits] -- {63B4D80D-7BAC-4D1D-B9B6-27FF54197982} =>.InterVideo Inc.
O42 - Logiciel: Rockstar Games Social Club - (.Rockstar Games.) [HKLM][64Bits] -- Rockstar Games Social Club =>.Rockstar Games, Inc.®
O42 - Logiciel: ScummVM 1.6.0 - (.The ScummVM Team.) [HKLM][64Bits] -- ScummVM_is1 =>.The ScummVM Team
O42 - Logiciel: SHIELD Streaming - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv =>.NVIDIA Corporation
O42 - Logiciel: SHIELD Wireless Controller Driver - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController =>.NVIDIA Corporation
O42 - Logiciel: Shockwave - (..) [HKLM][64Bits] -- Shockwave
O42 - Logiciel: Skype Click to Call - (.Skype Technologies S.A..) [HKLM][64Bits] -- {B6CF2967-C81E-40C0-9815-C05774FEF120} =>.Skype Technologies S.A.
O42 - Logiciel: Skype™ 7.0 - (.Skype Technologies S.A..) [HKLM][64Bits] -- {24991BA0-F0EE-44AD-9CC8-5EC50AECF6B7} =>.Skype Technologies S.A.
O42 - Logiciel: Spelling Dictionaries Support For Adobe Reader 9 - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- {AC76BA86-7AD7-5464-3428-900000000004} =>.Adobe Systems Incorporated
O42 - Logiciel: Star Wars The Old Republic - (.Bioware/EA.) [HKLM][64Bits] -- swtor_swtor =>.Electronic Arts®
O42 - Logiciel: Star Wars: The Old Republic - (.Electronic Arts, Inc..) [HKLM][64Bits] -- {3B11D799-48E0-48ED-BFD7-EA655676D8BB} =>.Electronic Arts®
O42 - Logiciel: Steam - (.Valve Corporation.) [HKLM][64Bits] -- {048298C9-A4D3-490B-9FF9-AB023A9238F3} =>.Valve Corporation
O42 - Logiciel: swMSM - (.Adobe Systems, Inc.) [HKLM][64Bits] -- {612C34C7-5E90-47D8-9B5C-0F717DD82726} =>.Adobe Systems, Inc
O42 - Logiciel: Synaptics Pointing Device Driver - (.Synaptics Incorporated.) [HKLM][64Bits] -- SynTPDeinstKey =>.Synaptics Incorporated
O42 - Logiciel: System Requirements Lab - (.Husdawg, LLC.) [HKLM][64Bits] -- {0A3A9522-EFA2-4C56-9138-101692C2A130} =>.Husdawg, LLC
O42 - Logiciel: System Requirements Lab - (.System Requirements Lab.) [HKLM][64Bits] -- SystemRequirementsLab
O42 - Logiciel: System Requirements Lab CYRI - (.Husdawg, LLC.) [HKLM][64Bits] -- {1110A014-1471-4B66-BFDC-E8EED120CC59} =>.Husdawg, LLC
O42 - Logiciel: System Requirements Lab Detection - (.Husdawg, LLC.) [HKLM][64Bits] -- {9099668B-1005-43DD-92FA-D8341E1D7FE2} =>.Husdawg, LLC
O42 - Logiciel: Tales from the Borderlands - (.Telltale Games.) [HKLM][64Bits] -- Steam App 330830 =>.Valve®
O42 - Logiciel: TOSHIBA DVD PLAYER - (.TOSHIBA Corporation.) [HKLM][64Bits] -- {6C5F3BDC-0A1B-4436-A696-5939629D5C31} =>.Macrovision Corporation®
O42 - Logiciel: TOSHIBA HDD Protection - (.TOSHIBA Corporation.) [HKLM][64Bits] -- {94A90C69-71C1-470A-88F5-AA47ECC96B40} =>.Toshiba Corporation
O42 - Logiciel: TOSHIBA HDD/SSD Alert - (.TOSHIBA Corporation.) [HKLM][64Bits] -- {D4322448-B6AF-4316-B859-D8A0E84DCB38} =>.Toshiba Corporation
O42 - Logiciel: TOSHIBA HDD/SSD Alert - (.TOSHIBA Corporation.) [HKLM][64Bits] -- InstallShield_{D4322448-B6AF-4316-B859-D8A0E84DCB38} =>.Toshiba Corporation
O42 - Logiciel: TOSHIBA Supervisor Password - (.Toshiba Corporation.) [HKLM][64Bits] -- InstallShield_{CBD6B23D-41D5-4A46-8019-6208516C9712} =>.Toshiba Corporation
O42 - Logiciel: TOSHIBA Supervisor Password - (.TOSHIBA.) [HKLM][64Bits] -- {CBD6B23D-41D5-4A46-8019-6208516C9712} =>.Toshiba
O42 - Logiciel: TOSHIBA USB Sleep and Charge Utility - (.TOSHIBA Corporation.) [HKLM][64Bits] -- {E487EE7D-EAAA-4E2A-9116-E3B477D8A74F} =>.Macrovision Corporation®
O42 - Logiciel: TOSHIBA Web Camera Application - (.TOSHIBA Corporation.) [HKLM][64Bits] -- {5E6F6CF3-BACC-4144-868C-E14622C658F3} =>.Macrovision Corporation®
O42 - Logiciel: Ubisoft Game Launcher - (.UBISOFT.) [HKLM][64Bits] -- {888F1505-C2B3-4FDE-835D-36353EBD4754} =>.Ubisoft
O42 - Logiciel: Uplay - (.Ubisoft.) [HKLM][64Bits] -- Uplay =>.Ubisoft Entertainment Sweden AB®
O42 - Logiciel: VLC media player - (.VideoLAN.) [HKLM][64Bits] -- VLC media player =>.VideoLAN
O42 - Logiciel: VRally Multiplayer Championship Edition - (..) [HKLM][64Bits] -- VRally Multiplayer Championship Edition
O42 - Logiciel: WildTangent ORB Game Console - (.WildTangent.) [HKLM][64Bits] -- TOSHIBA Game Console =>.WildTangent
O42 - Logiciel: Windows Phone app for desktop - (.Microsoft Corporation.) [HKLM][64Bits] -- {5F71448B-88EB-4357-9A98-8658D4C49C48} =>.Microsoft Corporation
O42 - Logiciel: WinRAR 4.10 beta 1 (32-bit) - (.win.rar GmbH.) [HKLM][64Bits] -- WinRAR archiver =>.win.rar GmbH
O42 - Logiciel: ZHPFix 2015 - (.Nicolas Coolman.) [HKLM][64Bits] -- ZHPFix_is1 =>.Nicolas Coolman
O42 - Logiciel: Zuma Deluxe - (.WildTangent.) [HKLM][64Bits] -- WT078480 =>.WildTangent
---\\ HKCU & HKLM Software Keys (222) - 32s
HKLM\SOFTWARE\Wow6432Node\Activision =>.Activision
HKLM\SOFTWARE\Wow6432Node\Adobe =>.Adobe
HKLM\SOFTWARE\Wow6432Node\Adware Removal Tool by TSA =>.TSA Softwares
HKLM\SOFTWARE\Wow6432Node\AGEIA Technologies =>.AGEIA Technologies
HKLM\SOFTWARE\Wow6432Node\AMD =>.AMD
HKLM\SOFTWARE\Wow6432Node\AppDataLow =>.Microsoft Corporation
HKLM\SOFTWARE\Wow6432Node\Apple Computer, Inc. =>.Apple Computer, Inc.
HKLM\SOFTWARE\Wow6432Node\Apple Inc. =>.Apple Inc.
HKLM\SOFTWARE\Wow6432Node\Arkane
HKLM\SOFTWARE\Wow6432Node\ASIO =>.Steinberg Media Technologies
HKLM\SOFTWARE\Wow6432Node\Aspyr
HKLM\SOFTWARE\Wow6432Node\Atheros Communications Inc. =>.Qualcomm Atheros
HKLM\SOFTWARE\Wow6432Node\Avid =>.Avid
HKLM\SOFTWARE\Wow6432Node\Avid Technology =>.Avid Technology
HKLM\SOFTWARE\Wow6432Node\Battlelog Web Plugins
HKLM\SOFTWARE\Wow6432Node\Bethesda Softworks =>.Bethesda Softworks
HKLM\SOFTWARE\Wow6432Node\BioWare =>.BioWare
HKLM\SOFTWARE\Wow6432Node\BlueRippleSound
HKLM\SOFTWARE\Wow6432Node\Bohemia Interactive =>.Bohemia Interactive
HKLM\SOFTWARE\Wow6432Node\Bohemia Interactive Studio =>.Bohemia Interactive Studio
HKLM\SOFTWARE\Wow6432Node\BOSS
HKLM\SOFTWARE\Wow6432Node\C07ft5Y =>.Total War Game
HKLM\SOFTWARE\Wow6432Node\Canneverbe Limited =>.Canneverbe Limited
HKLM\SOFTWARE\Wow6432Node\Canon =>.Canon
HKLM\SOFTWARE\Wow6432Node\Capcom =>.CAPCOM
HKLM\SOFTWARE\Wow6432Node\CD Projekt RED =>.CD Projekt RED
HKLM\SOFTWARE\Wow6432Node\Codemasters =>.Codemasters
HKLM\SOFTWARE\Wow6432Node\Crystal Dynamics =>.Crystal Dynamics
HKLM\SOFTWARE\Wow6432Node\Crytek =>.Crytek
HKLM\SOFTWARE\Wow6432Node\Cyberlink =>.CyberLink Corporation
HKLM\SOFTWARE\Wow6432Node\DICE =>.DICE
HKLM\SOFTWARE\Wow6432Node\Digidesign =>.Avid Audio
HKLM\SOFTWARE\Wow6432Node\EA DICE
HKLM\SOFTWARE\Wow6432Node\Eidos =>.Eidos
HKLM\SOFTWARE\Wow6432Node\Eidos Interactive =>.Eidos Interactive
HKLM\SOFTWARE\Wow6432Node\Eidos Interactive Limited =>.Eidos Interactive Limited
HKLM\SOFTWARE\Wow6432Node\Electronic Arts =>.Electronic Arts
HKLM\SOFTWARE\Wow6432Node\FilePlanet
HKLM\SOFTWARE\Wow6432Node\foobar2000 =>.Peter Pawlowski
HKLM\SOFTWARE\Wow6432Node\Fraps =>.Beepa
HKLM\SOFTWARE\Wow6432Node\GamersFirst =>.GamersFirst
HKLM\SOFTWARE\Wow6432Node\GameSpy =>.GameSpy
HKLM\SOFTWARE\Wow6432Node\Gearbox Software =>.Gearbox Software
HKLM\SOFTWARE\Wow6432Node\GOG.com =>.GOG.com
HKLM\SOFTWARE\Wow6432Node\Google =>.Google
HKLM\SOFTWARE\Wow6432Node\GSC Game World =>.GSC Game World
HKLM\SOFTWARE\Wow6432Node\id
HKLM\SOFTWARE\Wow6432Node\IM Providers =>.IM Providers
HKLM\SOFTWARE\Wow6432Node\Infogrames
HKLM\SOFTWARE\Wow6432Node\InfoWatch =>.Infowatch
HKLM\SOFTWARE\Wow6432Node\InstallShield =>.InstallShield
HKLM\SOFTWARE\Wow6432Node\Intel =>.Intel
HKLM\SOFTWARE\Wow6432Node\InterVideo =>.InterVideo
HKLM\SOFTWARE\Wow6432Node\Ion Storm
HKLM\SOFTWARE\Wow6432Node\JavaSoft =>.JavaSoft
HKLM\SOFTWARE\Wow6432Node\JreMetrics =>.JreMetrics
HKLM\SOFTWARE\Wow6432Node\KasperskyLab =>.Kaspersky Labs
HKLM\SOFTWARE\Wow6432Node\Khronos =>.Khronos
HKLM\SOFTWARE\Wow6432Node\lucasarts =>.LucasArts
HKLM\SOFTWARE\Wow6432Node\LucasArts Entertainment Company LLC =>.LucasArts Entertainment Company LLC
HKLM\SOFTWARE\Wow6432Node\Macromedia =>.Macromedia
HKLM\SOFTWARE\Wow6432Node\Malwarebytes' Anti-Malware =>.Malwarebytes' Anti-Malware
HKLM\SOFTWARE\Wow6432Node\Mozilla =>.Mozilla
HKLM\SOFTWARE\Wow6432Node\mozilla.org =>.mozilla.org
HKLM\SOFTWARE\Wow6432Node\MozillaPlugins =>.MozillaPlugins
HKLM\SOFTWARE\Wow6432Node\namco bandai games =>.NAMCO BANDAI Games
HKLM\SOFTWARE\Wow6432Node\Native Instruments =>.Native Instruments
HKLM\SOFTWARE\Wow6432Node\NCH Software =>.NCH Software
HKLM\SOFTWARE\Wow6432Node\NCH Swift Sound =>.NCH Swift Sound
HKLM\SOFTWARE\Wow6432Node\NVIDIA Corporation =>.nVidia Corporation
HKLM\SOFTWARE\Wow6432Node\ODBC =>.DB Connectivity Solutions
HKLM\SOFTWARE\Wow6432Node\OpenAL =>.Open Audio Library
HKLM\SOFTWARE\Wow6432Node\Opera Software =>.Opera Software
HKLM\SOFTWARE\Wow6432Node\Origin =>.Electronic Arts, Inc.
HKLM\SOFTWARE\Wow6432Node\Origin Games =>.Electronic Arts, Inc.
HKLM\SOFTWARE\Wow6432Node\perfect world entertainment =>.Perfect World Entertainment
HKLM\SOFTWARE\Wow6432Node\Propellerhead Software =>.Propellerhead Software
HKLM\SOFTWARE\Wow6432Node\Raptr =>.Raptr
HKLM\SOFTWARE\Wow6432Node\Razer =>.Razer
HKLM\SOFTWARE\Wow6432Node\Re-Logic =>.Re-Logic
HKLM\SOFTWARE\Wow6432Node\Realtek Semiconductor Corp. =>.Realtek Semiconductor Corp.
HKLM\SOFTWARE\Wow6432Node\Rebellion =>.Rebellion
HKLM\SOFTWARE\Wow6432Node\Remedy Entertainment
HKLM\SOFTWARE\Wow6432Node\Rockstar Games =>.Rockstar Games
HKLM\SOFTWARE\Wow6432Node\RocksteadyLtd
HKLM\SOFTWARE\Wow6432Node\RtWLan =>.Realtek Semiconductor Corp.
HKLM\SOFTWARE\Wow6432Node\Skype =>.Skype
HKLM\SOFTWARE\Wow6432Node\Square Enix =>.Square Enix
HKLM\SOFTWARE\Wow6432Node\Square Enix Limited =>.Square Enix Limited
HKLM\SOFTWARE\Wow6432Node\SystemRequirementsLab =>.System Requirements Lab
HKLM\SOFTWARE\Wow6432Node\TeamViewer =>.TeamViewer
HKLM\SOFTWARE\Wow6432Node\Techland =>.Techland
HKLM\SOFTWARE\Wow6432Node\telltale games =>.Telltale Games
HKLM\SOFTWARE\Wow6432Node\TequilaWorks
HKLM\SOFTWARE\Wow6432Node\THQ =>.THQ
HKLM\SOFTWARE\Wow6432Node\TOSHIBA =>.Toshiba Corporation
HKLM\SOFTWARE\Wow6432Node\TOSHIBA Corporation =>.Toshiba Corporation
HKLM\SOFTWARE\Wow6432Node\Ubisoft =>.Ubisoft
HKLM\SOFTWARE\Wow6432Node\Ulead Systems =>.Ulead Systems
HKLM\SOFTWARE\Wow6432Node\Valve =>.Valve
HKLM\SOFTWARE\Wow6432Node\VideoLAN =>.VideoLAN
HKLM\SOFTWARE\Wow6432Node\Volatile =>.Microsoft Corporation
HKLM\SOFTWARE\Wow6432Node\Volition Inc
HKLM\SOFTWARE\Wow6432Node\Warner Bros =>.Warner Bros
HKLM\SOFTWARE\Wow6432Node\Warner Bros Interactive Entertainment
HKLM\SOFTWARE\Wow6432Node\WildTangent =>.WildTangent
HKLM\SOFTWARE\Wow6432Node\Windows =>.Microsoft Corporation
HKLM\SOFTWARE\Wow6432Node\WinRAR =>.WinRAR
HKLM\SOFTWARE\Wow6432Node\RegisteredApplications =>.Microsoft Corporation
HKCU\SOFTWARE\4A-Games
HKCU\SOFTWARE\Activision =>.Activision
HKCU\SOFTWARE\Adobe =>.Adobe
HKCU\SOFTWARE\AIRMusicTech
HKCU\SOFTWARE\AppDataLow =>.Microsoft Corporation
HKCU\SOFTWARE\Apple Computer, Inc. =>.Apple Computer, Inc.
HKCU\SOFTWARE\Apple Inc. =>.Apple Inc.
HKCU\SOFTWARE\Arkane
HKCU\SOFTWARE\Audacity =>.Audacity
HKCU\SOFTWARE\Avid =>.Avid
HKCU\SOFTWARE\Avid Technology =>.Avid Technology
HKCU\SOFTWARE\Blizzard Entertainment =>.Blizzard Entertainment
HKCU\SOFTWARE\BlueRippleSound
HKCU\SOFTWARE\Bohemia Interactive Studio =>.Bohemia Interactive Studio
HKCU\SOFTWARE\Bossa Studios =>.Bossa Studios
HKCU\SOFTWARE\Canneverbe Limited =>.Canneverbe Limited
HKCU\SOFTWARE\Canon =>.Canon
HKCU\SOFTWARE\Cardboard Computer
HKCU\SOFTWARE\Cheat Engine =>.Dark Byte
HKCU\SOFTWARE\Colossal Order =>.Colossal Order
HKCU\SOFTWARE\Creability =>.Legitimate
HKCU\SOFTWARE\Cryptic =>.Cryptic Studios
HKCU\SOFTWARE\Crystal Dynamics =>.Crystal Dynamics
HKCU\SOFTWARE\Cyan Worlds
HKCU\SOFTWARE\Deep Silver =>.Deep Silver
HKCU\SOFTWARE\Digital Extremes =>.Digital Extremes
HKCU\SOFTWARE\DIGITAL HAPPINESS
HKCU\SOFTWARE\DSS =>.DSS Software
HKCU\SOFTWARE\E-Line Media =>.E-Line Media
HKCU\SOFTWARE\EA Games =>.EA Games
HKCU\SOFTWARE\Eidos =>.Eidos
HKCU\SOFTWARE\Eidos Montreal =>.Eidos Montreal
HKCU\SOFTWARE\ej-technologies =>.ej-technologies
HKCU\SOFTWARE\Electronic Arts =>.Electronic Arts
HKCU\SOFTWARE\Enterbrain =>.Enterbrain
HKCU\SOFTWARE\Epic Games =>.Epic Games
HKCU\SOFTWARE\FilePlanet
HKCU\SOFTWARE\foobar2000 =>.Peter Pawlowski
HKCU\SOFTWARE\FUEL Demo
HKCU\SOFTWARE\GameSpy =>.GameSpy
HKCU\SOFTWARE\Geek Uninstaller =>.Geek Uninstaller
HKCU\SOFTWARE\GOG.com =>.GOG.com
HKCU\SOFTWARE\Google =>.Google
HKCU\SOFTWARE\GRE
HKCU\SOFTWARE\Haemimont Games =>.Haemimont Games
HKCU\SOFTWARE\Hinterland
HKCU\SOFTWARE\IM Providers =>.IM Providers
HKCU\SOFTWARE\Imagination Technologies =>.Imagination Technologies
HKCU\SOFTWARE\InstallPath =>.Legitimate
HKCU\SOFTWARE\InterVideo =>.InterVideo
HKCU\SOFTWARE\IO Interactive =>.IO Interactive
HKCU\SOFTWARE\JavaSoft =>.JavaSoft
HKCU\SOFTWARE\JEDI-VCL =>.JEDI Project
HKCU\SOFTWARE\KasperskyLab =>.Kaspersky Labs
HKCU\SOFTWARE\LAV =>.LAV Inc
HKCU\SOFTWARE\LucasArts =>.LucasArts
HKCU\SOFTWARE\Macromedia =>.Macromedia
HKCU\SOFTWARE\Malwarebytes =>.Malwarebytes
HKCU\SOFTWARE\MediaChance =>.Mediachance
HKCU\SOFTWARE\MountAndBladeWarbandKeys =>.Mount And Blade
HKCU\SOFTWARE\Mozilla =>.Mozilla
HKCU\SOFTWARE\MozillaPlugins =>.MozillaPlugins
HKCU\SOFTWARE\Native Instruments =>.Native Instruments
HKCU\SOFTWARE\NCH Software =>.NCH Software
HKCU\SOFTWARE\NCH Swift Sound =>.NCH Swift Sound
HKCU\SOFTWARE\Netscape =>.Netscape
HKCU\SOFTWARE\Nowhere Studios
HKCU\SOFTWARE\NVIDIA Corporation =>.nVidia Corporation
HKCU\SOFTWARE\ODBC =>.DB Connectivity Solutions
HKCU\SOFTWARE\Open Labs
HKCU\SOFTWARE\OpenAutomate =>.nVidia Corporation
HKCU\SOFTWARE\Opera Software =>.Opera Software
HKCU\SOFTWARE\PaceAP
HKCU\SOFTWARE\Parsec Productions
HKCU\SOFTWARE\Phosphor
HKCU\SOFTWARE\Piriform =>.Piriform
HKCU\SOFTWARE\PreSonus =>.PreSonus
HKCU\SOFTWARE\QtProject =>.QtProject
HKCU\SOFTWARE\Red Thread Games
HKCU\SOFTWARE\Remedy Entertainment
HKCU\SOFTWARE\Rockstar Games =>.Rockstar Games
HKCU\SOFTWARE\SecuROM =>.SecuROM
HKCU\SOFTWARE\SKS =>.SKS Software
HKCU\SOFTWARE\Skype =>.Skype
HKCU\SOFTWARE\Smartly Dressed Games =>.Smartly Dressed Games
HKCU\SOFTWARE\Sony Corporation =>.Sony Corporation
HKCU\SOFTWARE\Square Enix =>.Square Enix
HKCU\SOFTWARE\Synaptics =>.Synaptics
HKCU\SOFTWARE\System Requirements Lab =>.System Requirements Lab
HKCU\SOFTWARE\TeamPsykskallar =>.Team Psykskallar
HKCU\SOFTWARE\TeamViewer =>.TeamViewer
HKCU\SOFTWARE\Telltale Games =>.Telltale Games
HKCU\SOFTWARE\Terraria
HKCU\SOFTWARE\The Fullbright Company =>.The Fullbright Company
HKCU\SOFTWARE\TOSHIBA =>.Toshiba Corporation
HKCU\SOFTWARE\Trolltech =>.Trolltech
HKCU\SOFTWARE\Ubisoft =>.Ubisoft
HKCU\SOFTWARE\Ulead Systems =>.Ulead Systems
HKCU\SOFTWARE\Unity =>.Unity
HKCU\SOFTWARE\Valve =>.Valve
HKCU\SOFTWARE\Visage Imaging
HKCU\SOFTWARE\Volition =>.Volition
HKCU\SOFTWARE\WinRAR =>.WinRAR
HKCU\SOFTWARE\WinRAR SFX =>.RarLab
HKCU\SOFTWARE\Wow6432Node =>.Microsoft Corporation
HKCU\SOFTWARE\ZebHelpProcess Helper =>.Nicolas Coolman
HKCU\SOFTWARE\ZHP =>.Nicolas Coolman
HKCU\SOFTWARE\AppDataLow\Software =>.Microsoft Corporation
HKCU\SOFTWARE\AppDataLow\Software\Adobe =>.Adobe
HKCU\SOFTWARE\AppDataLow\Software\Canon =>.Canon
HKCU\SOFTWARE\AppDataLow\Software\FilePlanet
HKCU\SOFTWARE\AppDataLow\Software\Google =>.Google
HKCU\SOFTWARE\AppDataLow\Software\JavaSoft =>.JavaSoft
---\\ Contents of the Common Files folders (430) - 18s
O43 - CFD: 14/04/2017 - [] D -- C:\Program Files\AIR Music Technology =>.AIR Music Technology
O43 - CFD: 01/06/2017 - [] D -- C:\Program Files\Avid {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files\Bonjour =>.Apple Inc.
O43 - CFD: 25/06/2011 - [] D -- C:\Program Files\Canon =>.Canon Inc.®
O43 - CFD: 25/06/2011 - [] HD -- C:\Program Files\CanonBJ =>.Canon Inc.
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files\CCleaner =>.Piriform Ltd
O43 - CFD: 14/04/2017 - [] D -- C:\Program Files\Common Files =>.Microsoft Corporation
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files\CONEXANT =>.Conexant Systems, Inc.®
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files\Dolby =>.Dolby
O43 - CFD: 17/03/2017 - [] D -- C:\Program Files\DVD Maker =>.Aone Software
O43 - CFD: 17/05/2017 - [] D -- C:\Program Files\Google =>.Google
O43 - CFD: 17/05/2017 - [] D -- C:\Program Files\Internet Explorer =>.Microsoft Corporation
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files\iPod =>.Apple Inc.®
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files\iTunes =>.Apple Inc.
O43 - CFD: 10/06/2017 - [] D -- C:\Program Files\Malwarebytes =>.Malwarebytes
O43 - CFD: 14/07/2009 - [] D -- C:\Program Files\Microsoft Games =>.Microsoft Corporation
O43 - CFD: 08/04/2012 - [] D -- C:\Program Files\Microsoft Office =>.Microsoft Corporation
O43 - CFD: 13/04/2017 - [] D -- C:\Program Files\Microsoft Silverlight =>.Microsoft Corporation
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files\Microsoft SQL Server =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [] D -- C:\Program Files\MSBuild =>.Microsoft Corporation
O43 - CFD: 02/02/2013 - [] D -- C:\Program Files\Nexus Mod Manager =>.Winstep Software Technologies
O43 - CFD: 06/05/2015 - [] D -- C:\Program Files\NVIDIA Corporation =>.nVidia Corporation
O43 - CFD: 05/12/2009 - [] D -- C:\Program Files\PlayReady =>.Microsoft Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\Program Files\Pro Tools First
O43 - CFD: 14/07/2009 - [] D -- C:\Program Files\Reference Assemblies =>.Microsoft Corporation
O43 - CFD: 15/06/2016 - [] D -- C:\Program Files\Rockstar Games =>.Rockstar Games, Inc.®
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files\Synaptics =>.Synaptics Incorporated®
O43 - CFD: 08/06/2017 - [] AD -- C:\Program Files\Toshiba =>.Toshiba Corporation
O43 - CFD: 14/07/2009 - [0] HD -- C:\Program Files\Uninstall Information =>.Microsoft Corporation
O43 - CFD: 11/07/2013 - [] D -- C:\Program Files\Windows Defender =>.Microsoft Corporation
O43 - CFD: 13/04/2012 - [] D -- C:\Program Files\Windows Live =>.Microsoft Corporation
O43 - CFD: 27/05/2011 - [] D -- C:\Program Files\Windows Mail =>.Microsoft Corporation
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files\Windows Media Player =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [] D -- C:\Program Files\Windows NT =>.Microsoft Corporation
O43 - CFD: 27/05/2011 - [] D -- C:\Program Files\Windows Photo Viewer =>.Microsoft Corporation
O43 - CFD: 27/05/2011 - [] D -- C:\Program Files\Windows Portable Devices =>.Microsoft Corporation
O43 - CFD: 27/05/2011 - [] D -- C:\Program Files\Windows Sidebar =>.Microsoft Corporation
O43 - CFD: 17/09/2015 - [] D -- C:\Program Files (x86)\Adobe =>.Adobe Systems, Incorporated®
O43 - CFD: 10/06/2017 - [] D -- C:\Program Files (x86)\Adware Removal Tool by TSA =>.TSA Softwares
O43 - CFD: 05/02/2015 - [0] D -- C:\Program Files (x86)\AGEIA Technologies =>.AGEIA Technologies
O43 - CFD: 22/06/2011 - [] D -- C:\Program Files (x86)\AMD =>.AMD
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files (x86)\Apple Software Update =>.Apple Inc.
O43 - CFD: 16/04/2017 - [0] D -- C:\Program Files (x86)\ASIO4ALL v2 =>.Michael Tippach
O43 - CFD: 08/03/2015 - [] D -- C:\Program Files (x86)\Audacity =>.Audacity
O43 - CFD: 30/09/2011 - [] D -- C:\Program Files (x86)\Audacity 1.3 Beta (Unicode) =>.Audacity
O43 - CFD: 01/06/2017 - [] D -- C:\Program Files (x86)\Avid {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files (x86)\Bonjour =>.Apple Inc.
O43 - CFD: 12/11/2012 - [] D -- C:\Program Files (x86)\BRS
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files (x86)\Canon =>.Canon Inc.®
O43 - CFD: 10/06/2017 - [] D -- C:\Program Files (x86)\Cheat Engine 6.2 =>.Dark Byte
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files (x86)\Common Files =>.Microsoft Corporation
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files (x86)\Corel =>.Corel Corporation
O43 - CFD: 11/09/2012 - [] D -- C:\Program Files (x86)\Dotjosh Studios =>.Dotjosh Studios
O43 - CFD: 09/02/2017 - [] D -- C:\Program Files (x86)\Dropbox =>.Dropbox
O43 - CFD: 11/08/2016 - [] D -- C:\Program Files (x86)\Eidos =>.Eidos
O43 - CFD: 25/07/2015 - [] D -- C:\Program Files (x86)\Electronic Arts =>.Electronic Arts®
O43 - CFD: 09/06/2017 - [] D -- C:\Program Files (x86)\foobar2000 =>.Peter Pawlowski
O43 - CFD: 08/05/2011 - [] D -- C:\Program Files (x86)\GameSpy =>.GameSpy
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files (x86)\Google =>.Google
O43 - CFD: 08/06/2017 - [] HD -- C:\Program Files (x86)\InstallShield Installation Information =>.InstallShield Software
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files (x86)\Intel =>.Intel Corporation
O43 - CFD: 12/05/2017 - [] D -- C:\Program Files (x86)\Internet Explorer =>.Microsoft Corporation
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files (x86)\InterVideo =>.Corel Corporation®
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files (x86)\Java =>.Oracle
O43 - CFD: 17/09/2015 - [] D -- C:\Program Files (x86)\Kaspersky Lab =>.Kaspersky Lab
O43 - CFD: 29/11/2014 - [] D -- C:\Program Files (x86)\LAV Filters =>.Hendrik Leppkes
O43 - CFD: 27/02/2013 - [] D -- C:\Program Files (x86)\Maxis =>.Maxis
O43 - CFD: 29/03/2011 - [] D -- C:\Program Files (x86)\Microsoft Analysis Services =>.Microsoft Corporation
O43 - CFD: 16/10/2014 - [] D -- C:\Program Files (x86)\Microsoft ASP.NET =>.Microsoft Corporation
O43 - CFD: 06/05/2011 - [] D -- C:\Program Files (x86)\Microsoft Games for Windows - LIVE =>.Microsoft Corporation
O43 - CFD: 29/03/2011 - [] D -- C:\Program Files (x86)\Microsoft Office =>.Microsoft Corporation
O43 - CFD: 13/04/2017 - [] D -- C:\Program Files (x86)\Microsoft Silverlight =>.Microsoft Corporation
O43 - CFD: 29/03/2011 - [] D -- C:\Program Files (x86)\Microsoft Small Business =>.Microsoft Corporation
O43 - CFD: 02/03/2011 - [] D -- C:\Program Files (x86)\Microsoft SQL Server =>.Microsoft Corporation
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files (x86)\Microsoft SQL Server Compact Edition =>.Microsoft Corporation
O43 - CFD: 08/02/2011 - [] D -- C:\Program Files (x86)\Microsoft WSE =>.Microsoft Corporation
O43 - CFD: 23/01/2013 - [] D -- C:\Program Files (x86)\Microsoft XNA =>.Microsoft Corporation
O43 - CFD: 29/03/2011 - [] D -- C:\Program Files (x86)\Microsoft.NET =>.Microsoft Corporation
O43 - CFD: 23/03/2016 - [] D -- C:\Program Files (x86)\Mozilla Firefox =>.Mozilla
O43 - CFD: 24/03/2016 - [] D -- C:\Program Files (x86)\Mozilla Maintenance Service =>.Mozilla
O43 - CFD: 14/07/2009 - [] D -- C:\Program Files (x86)\MSBuild =>.Microsoft Corporation
O43 - CFD: 29/10/2012 - [] D -- C:\Program Files (x86)\MSECache =>.Microsoft Corporation
O43 - CFD: 09/02/2011 - [0] D -- C:\Program Files (x86)\MSXML 4.0 =>.Microsoft Corporation
O43 - CFD: 22/02/2015 - [] D -- C:\Program Files (x86)\Native Instruments =>.Native Instruments
O43 - CFD: 28/12/2016 - [] D -- C:\Program Files (x86)\Navman =>.Navman New Zealand
O43 - CFD: 03/06/2014 - [] D -- C:\Program Files (x86)\NVIDIA Corporation =>.nVidia Corporation
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files (x86)\O2Micro =>.O2Micro
O43 - CFD: 12/11/2011 - [] D -- C:\Program Files (x86)\OpenAL =>.Open Audio Library
O43 - CFD: 13/09/2015 - [] D -- C:\Program Files (x86)\Opera =>.Opera Software
O43 - CFD: 07/12/2015 - [] D -- C:\Program Files (x86)\Origin =>.Electronic Arts, Inc.
O43 - CFD: 07/12/2015 - [0] D -- C:\Program Files (x86)\Origin Games =>.Electronic Arts, Inc.
O43 - CFD: 09/05/2015 - [] D -- C:\Program Files (x86)\Project64 1.6 =>.Project64
O43 - CFD: 12/05/2011 - [] D -- C:\Program Files (x86)\Raptr =>.Raptr, Inc®
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files (x86)\Realtek WLAN Driver =>.Realtek Semiconductor Corp.
O43 - CFD: 14/07/2009 - [] D -- C:\Program Files (x86)\Reference Assemblies =>.Microsoft Corporation
O43 - CFD: 15/06/2016 - [] D -- C:\Program Files (x86)\Rockstar Games =>.Rockstar Games, Inc.®
O43 - CFD: 06/06/2013 - [] D -- C:\Program Files (x86)\ScummVM =>.ScummVM
O43 - CFD: 29/04/2012 - [0] D -- C:\Program Files (x86)\Sierra =>.Sierra
O43 - CFD: 15/04/2015 - [] RD -- C:\Program Files (x86)\Skype =>.Skype
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files (x86)\Steam =>.Steam Games
O43 - CFD: 28/07/2014 - [] D -- C:\Program Files (x86)\SystemRequirementsLab =>.System Requirements Lab
O43 - CFD: 26/12/2011 - [] D -- C:\Program Files (x86)\TeamViewer =>.TeamViewer
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files (x86)\Toshiba =>.Toshiba Corporation
O43 - CFD: 30/04/2012 - [] D -- C:\Program Files (x86)\Total Uninstall 5 =>.Gavrila Martau
O43 - CFD: 02/01/2015 - [] D -- C:\Program Files (x86)\Ubisoft =>.Ubisoft
O43 - CFD: 14/07/2009 - [0] HD -- C:\Program Files (x86)\Uninstall Information =>.Microsoft Corporation
O43 - CFD: 04/11/2012 - [] D -- C:\Program Files (x86)\VideoLAN =>.VideoLan Team
O43 - CFD: 12/05/2011 - [] D -- C:\Program Files (x86)\Volition Inc {4EB6B899B1F199772BCA4BE44FEA1EC5}
O43 - CFD: 11/07/2013 - [] D -- C:\Program Files (x86)\Windows Defender =>.Microsoft Corporation
O43 - CFD: 25/04/2013 - [] D -- C:\Program Files (x86)\Windows Live =>.Microsoft Corporation
O43 - CFD: 27/05/2011 - [] D -- C:\Program Files (x86)\Windows Mail =>.Microsoft Corporation
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files (x86)\Windows Media Player =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [] D -- C:\Program Files (x86)\Windows NT =>.Microsoft Corporation
O43 - CFD: 30/12/2014 - [] D -- C:\Program Files (x86)\Windows Phone =>.Microsoft Corporation
O43 - CFD: 27/05/2011 - [] D -- C:\Program Files (x86)\Windows Photo Viewer =>.Microsoft Corporation
O43 - CFD: 27/05/2011 - [] D -- C:\Program Files (x86)\Windows Portable Devices =>.Microsoft Corporation
O43 - CFD: 27/05/2011 - [] D -- C:\Program Files (x86)\Windows Sidebar =>.Microsoft Corporation
O43 - CFD: 15/10/2011 - [] D -- C:\Program Files (x86)\WinRAR =>.WinRAR
O43 - CFD: 10/06/2017 - [] D -- C:\Program Files (x86)\ZHPFix =>.Nicolas Coolman
O43 - CFD: 17/05/2017 - [] RD -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories =>.Microsoft Corporation
O43 - CFD: 17/05/2017 - [] RD -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools =>.Administrative Tools
O43 - CFD: 01/06/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avid =>.Avid
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Blue Ripple Sound =>.Blue Ripple Sound
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Bohemia Interactive =>.Bohemia Interactive
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BOSS
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon IJ Network Utilities =>.Canon Inc.
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon MP495 series =>.Canon Inc.
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon MP495 series Manual =>.Canon Inc.
O43 - CFD: 08/06/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Canon Utilities =>.Canon Inc.
O43 - CFD: 08/06/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner =>.Piriform Ltd
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cheat Engine 6.2 =>.Dark Byte
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Dolby =>.Dolby
O43 - CFD: 08/10/2013 - [0] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Doom 3 Demo
O43 - CFD: 09/02/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Dropbox =>.Dropbox
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DVD MovieFactory for TOSHIBA =>.Toshiba Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\EA =>.Electronic Arts, Inc.
O43 - CFD: 08/06/2017 - [0] RD -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Games =>.Microsoft Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\GameSpy =>.GameSpy
O43 - CFD: 17/05/2017 - [] RD -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel =>.Intel Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\InterVideo WinDVD =>.InterVideo Inc
O43 - CFD: 08/06/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes =>.Apple Inc.
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kaspersky PURE 3.0 =>.Kaspersky Labs
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\LAV Filters =>.Hendrik Leppkes
O43 - CFD: 17/05/2017 - [] RD -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Maintenance =>.Microsoft Corporation
O43 - CFD: 10/06/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes =>.Malwarebytes
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Games for Windows Marketplace =>.Microsoft Corporation
O43 - CFD: 01/06/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office =>.Microsoft Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight =>.Microsoft Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft SQL Server 2005 =>.Microsoft Corporation
O43 - CFD: 08/06/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MusicBee
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments =>.Native Instruments
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nexus Mod Manager =>.Winstep Software Technologies
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation =>.nVidia Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Origin =>.Electronic Arts, Inc.
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Rockstar Games =>.Rockstar Games
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ScummVM =>.ScummVM
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Skype =>.Skype
O43 - CFD: 23/05/2017 - [] RD -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup =>.Microsoft Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Steam =>.Steam Games
O43 - CFD: 08/06/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TOSHIBA =>.Toshiba Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TOSHIBA DVD PLAYER =>.Toshiba Corporation
O43 - CFD: 08/10/2013 - [0] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ubisoft =>.Ubisoft
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\V-RALLY Multiplayer Championship Edition
O43 - CFD: 08/06/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN =>.VideoLan Team
O43 - CFD: 17/05/2017 - [] RD -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Live =>.Microsoft Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Phone =>.Microsoft Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR =>.WinRAR
O43 - CFD: 10/06/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ZHP =>.Nicolas Coolman
O43 - CFD: 11/03/2015 - [] D -- C:\ProgramData\.mono =>.Legitimate
O43 - CFD: 16/04/2013 - [] D -- C:\ProgramData\Adobe =>.Adobe
O43 - CFD: 20/02/2011 - [] D -- C:\ProgramData\Age of Empires 3
O43 - CFD: 08/06/2017 - [] D -- C:\ProgramData\Apple =>.Apple Inc.
O43 - CFD: 08/06/2017 - [] D -- C:\ProgramData\Apple Computer =>.Apple Inc.
O43 - CFD: 14/07/2009 - [0] SHD -- C:\ProgramData\Application Data =>.Microsoft Corporation
O43 - CFD: 14/04/2017 - [] D -- C:\ProgramData\Avid =>.Avid
O43 - CFD: 11/09/2012 - [] D -- C:\ProgramData\Battle.net =>.Games Software
O43 - CFD: 22/12/2011 - [] D -- C:\ProgramData\BioWare =>.BioWare
O43 - CFD: 25/07/2015 - [] D -- C:\ProgramData\BitRaider =>.BitRaider
O43 - CFD: 15/07/2011 - [] D -- C:\ProgramData\Blizzard =>.Blizzard
O43 - CFD: 11/09/2012 - [] D -- C:\ProgramData\Blizzard Entertainment =>.Blizzard Entertainment
O43 - CFD: 05/05/2015 - [] D -- C:\ProgramData\Bohemia Interactive Studio =>.Bohemia Interactive Studio
O43 - CFD: 05/08/2014 - [] D -- C:\ProgramData\boost_interprocess =>.boost.org
O43 - CFD: 25/06/2011 - [0] D -- C:\ProgramData\Canon IJ Network Tool =>.Canon Inc.
O43 - CFD: 25/06/2011 - [] HD -- C:\ProgramData\CanonBJ =>.Canon Inc.
O43 - CFD: 25/06/2011 - [0] HD -- C:\ProgramData\CanonEPP =>.Canon Inc.
O43 - CFD: 25/06/2011 - [] D -- C:\ProgramData\CanonIJ =>.Canon Inc.
O43 - CFD: 25/06/2011 - [] HD -- C:\ProgramData\CanonIJEGV =>.Canon Inc.
O43 - CFD: 25/06/2011 - [0] HD -- C:\ProgramData\CanonIJEPPEX2 =>.Canon Inc.
O43 - CFD: 25/06/2011 - [] D -- C:\ProgramData\CanonIJMSetup =>.Canon Inc.
O43 - CFD: 25/06/2011 - [] HD -- C:\ProgramData\CanonIJMyPrinter =>.Canon Inc.
O43 - CFD: 13/05/2015 - [] D -- C:\ProgramData\CanonIJPLM =>.Canon Inc.
O43 - CFD: 25/06/2011 - [] HD -- C:\ProgramData\CanonIJScan =>.Canon Inc.
O43 - CFD: 25/06/2011 - [] HD -- C:\ProgramData\CanonIJSolutionMenuEX =>.Canon Inc.
O43 - CFD: 25/06/2011 - [] D -- C:\ProgramData\CanonIJWSpt =>.Canon Inc.
O43 - CFD: 21/02/2014 - [] D -- C:\ProgramData\Codemasters =>.Codemasters
O43 - CFD: 15/04/2017 - [] D -- C:\ProgramData\Conexant =>.Conexant
O43 - CFD: 14/07/2009 - [0] SHD -- C:\ProgramData\Desktop =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [0] SHD -- C:\ProgramData\Documents =>.Microsoft Corporation
O43 - CFD: 22/01/2017 - [] D -- C:\ProgramData\Dropbox =>.Dropbox
O43 - CFD: 04/06/2011 - [] SHD -- C:\ProgramData\DSS =>.DSS Software
O43 - CFD: 14/07/2011 - [] D -- C:\ProgramData\EA Core =>.Electronic Arts, Inc.
O43 - CFD: 12/05/2012 - [] D -- C:\ProgramData\EA Logs =>.Electronic Arts, Inc.
O43 - CFD: 04/05/2012 - [] D -- C:\ProgramData\Electronic Arts =>.Electronic Arts
O43 - CFD: 14/07/2009 - [0] SHD -- C:\ProgramData\Favorites =>.Microsoft Corporation
O43 - CFD: 03/07/2014 - [] D -- C:\ProgramData\fltk.org =>.fltk.org
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Google =>.Google
O43 - CFD: 08/06/2017 - [] D -- C:\ProgramData\InstallShield =>.InstallShield
O43 - CFD: 16/02/2011 - [] D -- C:\ProgramData\InterVideo =>.InterVideo
O43 - CFD: 11/06/2017 - [] D -- C:\ProgramData\Kaspersky Lab =>.Kaspersky Lab
O43 - CFD: 10/06/2017 - [] D -- C:\ProgramData\Malwarebytes =>.Malwarebytes
O43 - CFD: 30/04/2012 - [] D -- C:\ProgramData\Martau =>.Martau
O43 - CFD: 10/12/2014 - [] SD -- C:\ProgramData\Microsoft =>.Microsoft Corporation
O43 - CFD: 01/06/2017 - [] D -- C:\ProgramData\Microsoft Help =>.Microsoft Corporation
O43 - CFD: 04/05/2012 - [] D -- C:\ProgramData\Mozilla =>.Mozilla Corporation
O43 - CFD: 25/02/2015 - [] D -- C:\ProgramData\NVIDIA =>.nVidia Corporation
O43 - CFD: 03/06/2014 - [] D -- C:\ProgramData\NVIDIA Corporation =>.nVidia Corporation
O43 - CFD: 17/05/2017 - [] D -- C:\ProgramData\Oracle =>.Oracle
O43 - CFD: 07/12/2015 - [] D -- C:\ProgramData\Origin =>.Electronic Arts, Inc.
O43 - CFD: 14/04/2017 - [] D -- C:\ProgramData\PACE
O43 - CFD: 25/03/2017 - [] D -- C:\ProgramData\Package Cache =>.Microsoft Corporation
O43 - CFD: 08/06/2017 - [] D -- C:\ProgramData\PreSonus =>.PreSonus
O43 - CFD: 24/10/2014 - [] D -- C:\ProgramData\Razer =>.Razer
O43 - CFD: 07/06/2016 - [] D -- C:\ProgramData\Rockstar Games =>.Rockstar Games
O43 - CFD: 10/06/2017 - [] D -- C:\ProgramData\RogueKiller =>.Adlice
O43 - CFD: 27/07/2014 - [] D -- C:\ProgramData\RzMaelstromVAD_1.1.58.1854
O43 - CFD: 30/08/2011 - [] SHD -- C:\ProgramData\SecuROM =>.SecuROM
O43 - CFD: 15/04/2015 - [] D -- C:\ProgramData\Skype =>.Skype
O43 - CFD: 08/10/2013 - [] D -- C:\ProgramData\Solidshield =>.Solidshield Technologies
O43 - CFD: 14/07/2009 - [0] SHD -- C:\ProgramData\Start Menu =>.Microsoft Corporation
O43 - CFD: 14/07/2011 - [] D -- C:\ProgramData\Sun =>.Oracle
O43 - CFD: 12/10/2013 - [] D -- C:\ProgramData\SystemRequirementsLab =>.System Requirements Lab
O43 - CFD: 17/02/2011 - [] D -- C:\ProgramData\Tages
O43 - CFD: 14/07/2009 - [0] SHD -- C:\ProgramData\Templates =>.Microsoft Corporation
O43 - CFD: 08/06/2017 - [] D -- C:\ProgramData\TOSHIBA =>.Toshiba Corporation
O43 - CFD: 02/01/2015 - [] D -- C:\ProgramData\Ubisoft =>.Ubisoft
O43 - CFD: 05/08/2010 - [] D -- C:\ProgramData\Ulead Systems =>.Ulead Systems
O43 - CFD: 18/02/2011 - [] D -- C:\ProgramData\{93E26451-CD9A-43A5-A2FA-C42392EA4001} =>.GEAR Software, Inc.
O43 - CFD: 13/01/2012 - [] D -- C:\Program Files (x86)\Common Files\Adobe =>.Adobe
O43 - CFD: 05/12/2009 - [] D -- C:\Program Files (x86)\Common Files\Adobe AIR =>.Adobe Inc.
O43 - CFD: 08/06/2017 - [] D -- C:\Program Files (x86)\Common Files\Apple =>.Apple Inc.
O43 - CFD: 14/04/2017 - [] D -- C:\Program Files (x86)\Common Files\Avid =>.Avid
O43 - CFD: 05/05/2015 - [] D -- C:\Program Files (x86)\Common Files\BattlEye =>.BattlEye
O43 - CFD: 25/07/2015 - [] D -- C:\Program Files (x86)\Common Files\BioWare =>.BioWare
O43 - CFD: 14/05/2014 - [] D -- C:\Program Files (x86)\Common Files\DESIGNER =>.Designer
O43 - CFD: 22/02/2015 - [] D -- C:\Program Files (x86)\Common Files\Digidesign =>.Digidesign
O43 - CFD: 03/06/2016 - [] HD -- C:\Program Files (x86)\Common Files\EAInstaller =>.Electronic Arts, Inc.
O43 - CFD: 17/09/2015 - [] D -- C:\Program Files (x86)\Common Files\InfoWatch =>.Infowatch
O43 - CFD: 23/02/2011 - [] D -- C:\Program Files (x86)\Common Files\InstallShield =>.InstallShield
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files (x86)\Common Files\InterVideo =>.InterVideo
O43 - CFD: 20/02/2011 - [] D -- C:\Program Files (x86)\Common Files\Microsoft Games =>.Microsoft Corporation
O43 - CFD: 11/09/2013 - [] D -- C:\Program Files (x86)\Common Files\microsoft shared =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [] D -- C:\Program Files (x86)\Common Files\Services =>.Microsoft Corporation
O43 - CFD: 15/04/2015 - [] D -- C:\Program Files (x86)\Common Files\Skype =>.Skype
O43 - CFD: 14/07/2009 - [] D -- C:\Program Files (x86)\Common Files\SpeechEngines =>.Microsoft Corporation
O43 - CFD: 16/04/2017 - [] D -- C:\Program Files (x86)\Common Files\Steam =>.Steam Games
O43 - CFD: 28/02/2011 - [0] D -- C:\Program Files (x86)\Common Files\Symantec Shared =>.Symantec Corporation
O43 - CFD: 10/11/2011 - [] D -- C:\Program Files (x86)\Common Files\System =>.Microsoft Corporation
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files (x86)\Common Files\TOSHIBA Shared =>.Toshiba Corporation
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files (x86)\Common Files\Ulead Systems =>.Ulead Systems
O43 - CFD: 05/08/2010 - [] D -- C:\Program Files (x86)\Common Files\Windows Live =>.Microsoft Corporation
O43 - CFD: 21/09/2014 - [] D -- C:\Program Files (x86)\Common Files\Wise Installation Wizard =>.Seagate
O43 - CFD: 11/03/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\.mono =>.Legitimate
O43 - CFD: 27/11/2014 - [] D -- C:\Users\Juancho\AppData\Roaming\11bitstudios
O43 - CFD: 15/03/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Adobe =>.Adobe
O43 - CFD: 08/06/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\Apple Computer =>.Apple Inc.
O43 - CFD: 14/02/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\Audacity =>.Audacity
O43 - CFD: 01/06/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\Avid =>.Avid
O43 - CFD: 06/02/2014 - [] D -- C:\Users\Juancho\AppData\Roaming\BigHugeEngine
O43 - CFD: 11/04/2013 - [] D -- C:\Users\Juancho\AppData\Roaming\Bioshock
O43 - CFD: 29/08/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Bioshock2
O43 - CFD: 09/06/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\Canneverbe Limited =>.Canneverbe Limited
O43 - CFD: 25/06/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Canon =>.Canon
O43 - CFD: 11/03/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\Colossal Order =>.Colossal Order Ltd
O43 - CFD: 22/01/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\Dropbox =>.Dropbox
O43 - CFD: 14/04/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\FLEXnet =>.Flexera Software
O43 - CFD: 03/07/2014 - [] D -- C:\Users\Juancho\AppData\Roaming\fltk.org =>.fltk.org
O43 - CFD: 11/06/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\foobar2000 =>.Peter Pawlowski
O43 - CFD: 15/04/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\FUEL Demo
O43 - CFD: 16/05/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\Geek Uninstaller =>.Geek Uninstaller
O43 - CFD: 08/02/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Google =>.Google
O43 - CFD: 23/03/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\Guild Wars 2 =>.NCsoft Corporation, Ltd.
O43 - CFD: 08/02/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Identities =>.Microsoft Corporation
O43 - CFD: 11/06/2014 - [] D -- C:\Users\Juancho\AppData\Roaming\InstallShield =>.InstallShield
O43 - CFD: 08/02/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Intel Corporation =>.Intel Corporation
O43 - CFD: 16/02/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\InterVideo =>.InterVideo
O43 - CFD: 22/05/2013 - [] D -- C:\Users\Juancho\AppData\Roaming\Kalypso Media =>.Kalypso Media
O43 - CFD: 14/07/2013 - [] D -- C:\Users\Juancho\AppData\Roaming\Lionhead Studios =>.Lionhead Studios
O43 - CFD: 30/06/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\LucasArts =>.LucasArts
O43 - CFD: 08/02/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Macromedia =>.Macromedia
O43 - CFD: 14/07/2009 - [0] D -- C:\Users\Juancho\AppData\Roaming\Media Center Programs =>.Microsoft Corporation
O43 - CFD: 18/05/2017 - [] SD -- C:\Users\Juancho\AppData\Roaming\Microsoft =>.Microsoft Corporation
O43 - CFD: 05/07/2013 - [] D -- C:\Users\Juancho\AppData\Roaming\Milestone =>.Milestone
O43 - CFD: 18/07/2013 - [] D -- C:\Users\Juancho\AppData\Roaming\Mount&Blade Warband =>.Mount And Blade
O43 - CFD: 04/08/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Mozilla =>.Mozilla Corporation
O43 - CFD: 13/04/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\NCH Software =>.NCH Software
O43 - CFD: 23/12/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\NVIDIA =>.nVidia Corporation
O43 - CFD: 19/12/2013 - [] D -- C:\Users\Juancho\AppData\Roaming\Omerta Demo
O43 - CFD: 13/09/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\Opera Software =>.Opera Software
O43 - CFD: 07/12/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\Origin =>.Electronic Arts, Inc.
O43 - CFD: 15/12/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\PunkBuster =>.PunkBuster Games
O43 - CFD: 12/05/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Raptr =>.Raptr
O43 - CFD: 06/06/2013 - [] D -- C:\Users\Juancho\AppData\Roaming\ScummVM =>.ScummVM
O43 - CFD: 09/02/2011 - [] RHD -- C:\Users\Juancho\AppData\Roaming\SecuROM =>.SecuROM
O43 - CFD: 22/04/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\Skype =>.Skype
O43 - CFD: 16/12/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\SystemRequirementsLab =>.System Requirements Lab
O43 - CFD: 07/03/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\The Creative Assembly =>.The Creative Assembly
O43 - CFD: 29/08/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\The Longest Journey Demo
O43 - CFD: 08/02/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Toshiba =>.Toshiba Corporation
O43 - CFD: 16/02/2013 - [] D -- C:\Users\Juancho\AppData\Roaming\Trine2 =>.Trine Game
O43 - CFD: 16/06/2013 - [] D -- C:\Users\Juancho\AppData\Roaming\Tropico 4 =>.Kalypso Media
O43 - CFD: 22/07/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\Trove =>.Trion Worlds, Inc
O43 - CFD: 02/01/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\Ubisoft =>.Ubisoft
O43 - CFD: 08/02/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Ulead Systems =>.Ulead Systems
O43 - CFD: 17/12/2012 - [] D -- C:\Users\Juancho\AppData\Roaming\Visage Imaging
O43 - CFD: 09/06/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\vlc =>.VideoLan Team
O43 - CFD: 20/02/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\Warner Bros. Interactive Entertainment =>.Warner Bros. Interactive Entertainment
O43 - CFD: 11/06/2014 - [] D -- C:\Users\Juancho\AppData\Roaming\WinBatch =>.winbatch.com
O43 - CFD: 15/10/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\WinRAR =>.WinRAR
O43 - CFD: 11/06/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\ZHP =>.Nicolas Coolman
O43 - CFD: 06/04/2017 - [] D -- C:\Users\Juancho\AppData\Roaming\Zynewave
O43 - CFD: 16/06/2013 - [0] D -- C:\Users\Juancho\AppData\Local\2K Games =>.2K Games
O43 - CFD: 09/09/2013 - [] D -- C:\Users\Juancho\AppData\Local\4A Games =>.4A Games
O43 - CFD: 10/05/2015 - [] D -- C:\Users\Juancho\AppData\Local\Activision =>.Activision
O43 - CFD: 25/12/2016 - [] D -- C:\Users\Juancho\AppData\Local\Adobe =>.Adobe
O43 - CFD: 08/06/2017 - [] D -- C:\Users\Juancho\AppData\Local\Apple =>.Apple Inc.
O43 - CFD: 02/01/2014 - [] D -- C:\Users\Juancho\AppData\Local\Apple Computer =>.Apple Inc.
O43 - CFD: 08/02/2011 - [0] SHD -- C:\Users\Juancho\AppData\Local\Application Data =>.Microsoft Corporation
O43 - CFD: 14/02/2014 - [] D -- C:\Users\Juancho\AppData\Local\ApplicationHistory =>.Microsoft Corporation
O43 - CFD: 24/07/2012 - [] D -- C:\Users\Juancho\AppData\Local\ArmA 2 =>.Bohemia Interactive Studio
O43 - CFD: 05/05/2015 - [] D -- C:\Users\Juancho\AppData\Local\ArmA 2 OA =>.Bohemia Interactive Studio
O43 - CFD: 05/05/2013 - [] D -- C:\Users\Juancho\AppData\Local\Aspyr
O43 - CFD: 14/04/2017 - [] D -- C:\Users\Juancho\AppData\Local\Avid =>.Avid
O43 - CFD: 02/02/2013 - [] D -- C:\Users\Juancho\AppData\Local\Black_Tree_Gaming =>.Black Tree Gaming Ltd
O43 - CFD: 07/03/2015 - [] D -- C:\Users\Juancho\AppData\Local\CAPCOM =>.CAPCOM
O43 - CFD: 22/07/2015 - [] D -- C:\Users\Juancho\AppData\Local\CEF =>.CEF
O43 - CFD: 11/03/2015 - [] D -- C:\Users\Juancho\AppData\Local\Colossal Order =>.Colossal Order Ltd
O43 - CFD: 25/04/2011 - [] D -- C:\Users\Juancho\AppData\Local\Conexant =>.Conexant
O43 - CFD: 08/06/2017 - [0] D -- C:\Users\Juancho\AppData\Local\CrashDumps =>.Microsoft Corporation
O43 - CFD: 21/10/2013 - [] D -- C:\Users\Juancho\AppData\Local\Daedalic Entertainment =>.Daedalic Entertainment
O43 - CFD: 11/09/2012 - [] D -- C:\Users\Juancho\AppData\Local\DayZCommander
O43 - CFD: 18/05/2017 - [] D -- C:\Users\Juancho\AppData\Local\Diagnostics =>.Microsoft Corporation
O43 - CFD: 14/04/2017 - [] D -- C:\Users\Juancho\AppData\Local\Downloaded Installations =>.Microsoft Corporation
O43 - CFD: 22/01/2017 - [] D -- C:\Users\Juancho\AppData\Local\Dropbox =>.Dropbox
O43 - CFD: 24/05/2013 - [] D -- C:\Users\Juancho\AppData\Local\EA Games =>.EA Games
O43 - CFD: 05/05/2013 - [] D -- C:\Users\Juancho\AppData\Local\Electronic Arts =>.Electronic Arts
O43 - CFD: 07/06/2017 - [] D -- C:\Users\Juancho\AppData\Local\ElevatedDiagnostics =>.Microsoft Corporation
O43 - CFD: 13/09/2015 - [0] SHD -- C:\Users\Juancho\AppData\Local\EmieSiteList =>.Enterprise mode Site List Mgr
O43 - CFD: 13/09/2015 - [0] SHD -- C:\Users\Juancho\AppData\Local\EmieUserList =>.Enterprise mode Site List Mgr
O43 - CFD: 28/07/2014 - [] D -- C:\Users\Juancho\AppData\Local\ESN =>.ESN
O43 - CFD: 03/03/2011 - [] D -- C:\Users\Juancho\AppData\Local\Fallout3 =>.Black Isle Studios
O43 - CFD: 05/12/2011 - [] D -- C:\Users\Juancho\AppData\Local\FalloutNV =>.Games Software
O43 - CFD: 14/02/2015 - [] D -- C:\Users\Juancho\AppData\Local\Focus Home Interactive =>.Focus Home Interactive
O43 - CFD: 08/04/2015 - [] D -- C:\Users\Juancho\AppData\Local\GHOSTBUSTERS (tm)
O43 - CFD: 08/06/2017 - [] D -- C:\Users\Juancho\AppData\Local\Google =>.Google
O43 - CFD: 08/02/2011 - [0] SHD -- C:\Users\Juancho\AppData\Local\History =>.Microsoft Corporation
O43 - CFD: 11/08/2016 - [] D -- C:\Users\Juancho\AppData\Local\kaneandlynch
O43 - CFD: 23/06/2012 - [] D -- C:\Users\Juancho\AppData\Local\Macromedia =>.Macromedia
O43 - CFD: 27/08/2013 - [] D -- C:\Users\Juancho\AppData\Local\MercurySteam =>.MercurySteam
O43 - CFD: 22/07/2015 - [] D -- C:\Users\Juancho\AppData\Local\Microsoft =>.Microsoft Corporation
O43 - CFD: 28/07/2011 - [] D -- C:\Users\Juancho\AppData\Local\Microsoft Games =>.Microsoft Corporation
O43 - CFD: 30/03/2011 - [] D -- C:\Users\Juancho\AppData\Local\Microsoft Help =>.Microsoft Corporation
O43 - CFD: 07/04/2015 - [0] D -- C:\Users\Juancho\AppData\Local\ModManagerData
O43 - CFD: 18/09/2013 - [] D -- C:\Users\Juancho\AppData\Local\Mozilla =>.Mozilla Corporation
O43 - CFD: 26/06/2014 - [] D -- C:\Users\Juancho\AppData\Local\mslug3
O43 - CFD: 03/08/2012 - [] D -- C:\Users\Juancho\AppData\Local\My Games =>.My Games
O43 - CFD: 28/12/2016 - [] D -- C:\Users\Juancho\AppData\Local\Navman_Technology_New_Zea
O43 - CFD: 28/09/2013 - [] D -- C:\Users\Juancho\AppData\Local\NBGI
O43 - CFD: 21/02/2014 - [] D -- C:\Users\Juancho\AppData\Local\NVIDIA =>.nVidia Corporation
O43 - CFD: 11/10/2014 - [] D -- C:\Users\Juancho\AppData\Local\NVIDIA Corporation =>.nVidia Corporation
O43 - CFD: 05/12/2011 - [] D -- C:\Users\Juancho\AppData\Local\Oblivion =>.Games Software
O43 - CFD: 15/04/2015 - [] D -- C:\Users\Juancho\AppData\Local\openvr =>.Legitimate
O43 - CFD: 13/09/2015 - [0] D -- C:\Users\Juancho\AppData\Local\Opera Software =>.Opera Software
O43 - CFD: 14/08/2013 - [] D -- C:\Users\Juancho\AppData\Local\Origin =>.Electronic Arts, Inc.
O43 - CFD: 01/06/2017 - [] D -- C:\Users\Juancho\AppData\Local\PaceAP
O43 - CFD: 02/01/2015 - [] D -- C:\Users\Juancho\AppData\Local\PAYDAY 2
O43 - CFD: 20/06/2014 - [] D -- C:\Users\Juancho\AppData\Local\PAYDAY 2 (Demo)
O43 - CFD: 08/06/2014 - [] D -- C:\Users\Juancho\AppData\Local\Programs =>.Microsoft Corporation
O43 - CFD: 28/07/2014 - [] D -- C:\Users\Juancho\AppData\Local\PunkBuster =>.PunkBuster Games
O43 - CFD: 24/10/2014 - [] D -- C:\Users\Juancho\AppData\Local\Razer =>.Razer
O43 - CFD: 27/06/2012 - [] D -- C:\Users\Juancho\AppData\Local\Risen2
O43 - CFD: 31/08/2015 - [] D -- C:\Users\Juancho\AppData\Local\Risen3
O43 - CFD: 02/12/2011 - [] D -- C:\Users\Juancho\AppData\Local\Rockstar Games =>.Rockstar Games
O43 - CFD: 02/12/2011 - [] D -- C:\Users\Juancho\AppData\Local\SKIDROW =>.SKIDROW
O43 - CFD: 22/04/2015 - [] D -- C:\Users\Juancho\AppData\Local\Skype =>.Skype
O43 - CFD: 04/02/2013 - [] D -- C:\Users\Juancho\AppData\Local\Skyrim =>.Skyrim Games
O43 - CFD: 12/04/2014 - [] D -- C:\Users\Juancho\AppData\Local\SniperV2 =>.Games Software
O43 - CFD: 17/08/2012 - [] D -- C:\Users\Juancho\AppData\Local\SniperV2 Demo =>.Games Software
O43 - CFD: 14/02/2017 - [] D -- C:\Users\Juancho\AppData\Local\Steam =>.Steam Games
O43 - CFD: 27/07/2015 - [] D -- C:\Users\Juancho\AppData\Local\SWTOR =>.Electronic Arts, Inc.
O43 - CFD: 25/07/2015 - [] D -- C:\Users\Juancho\AppData\Local\SWTORPerf =>.Electronic Arts, Inc.
O43 - CFD: 29/05/2013 - [] D -- C:\Users\Juancho\AppData\Local\techland =>.Techland
O43 - CFD: 11/06/2017 - [] D -- C:\Users\Juancho\AppData\Local\Temp =>.Microsoft Corporation
O43 - CFD: 08/02/2011 - [0] SHD -- C:\Users\Juancho\AppData\Local\Temporary Internet Files =>.Microsoft Corporation
O43 - CFD: 19/11/2011 - [] D -- C:\Users\Juancho\AppData\Local\The Witcher 2 =>.Atari Inc
O43 - CFD: 11/05/2015 - [] D -- C:\Users\Juancho\AppData\Local\THQ =>.THQ
O43 - CFD: 08/02/2011 - [] D -- C:\Users\Juancho\AppData\Local\TOSHIBA_Corporation =>.Toshiba Corporation
O43 - CFD: 08/06/2011 - [] D -- C:\Users\Juancho\AppData\Local\Ubisoft =>.Ubisoft
O43 - CFD: 08/06/2017 - [] D -- C:\Users\Juancho\AppData\Local\Ubisoft Game Launcher =>.Ubisoft
O43 - CFD: 05/08/2014 - [] D -- C:\Users\Juancho\AppData\Local\UWebKit
O43 - CFD: 05/12/2011 - [] D -- C:\Users\Juancho\AppData\Local\VirtualStore =>.Microsoft Corporation
O43 - CFD: 26/04/2013 - [] D -- C:\Users\Juancho\AppData\Local\Warframe =>.Digital Extremes
O43 - CFD: 03/02/2015 - [] D -- C:\Users\Juancho\AppData\Local\Warner Bros. Interactive Entertainment =>.Warner Bros. Interactive Entertainment
O43 - CFD: 18/08/2012 - [] D -- C:\Users\Juancho\AppData\Local\Windows Live =>.Microsoft Corporation
O43 - CFD: 10/06/2017 - [] D -- C:\Users\Juancho\AppData\Local\ZHP =>.Nicolas Coolman
O43 - CFD: 08/06/2014 - [0] D -- C:\Users\Juancho\AppData\Local\Programs\Common =>.Microsoft Corporation
O43 - CFD: 22/02/2015 - [] RD -- C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Accessories =>.Microsoft Corporation
O43 - CFD: 09/02/2017 - [] RD -- C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools =>.Administrative Tools
O43 - CFD: 25/07/2012 - [] D -- C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Bohemia Interactive =>.Bohemia Interactive
O43 - CFD: 17/09/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Games =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [] RD -- C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Maintenance =>.Microsoft Corporation
O43 - CFD: 22/02/2015 - [] D -- C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Native Instruments =>.Native Instruments
O43 - CFD: 12/05/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Raptr =>.Raptr
O43 - CFD: 09/02/2017 - [] RD -- C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup =>.Microsoft Corporation
O43 - CFD: 26/07/2014 - [0] D -- C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Steam =>.Steam Games
O43 - CFD: 12/05/2014 - [] D -- C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Ubisoft =>.Ubisoft
O43 - CFD: 15/10/2011 - [] D -- C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WinRAR =>.WinRAR
O43 - CFD: 14/07/2009 - [0] SHD -- C:\Users\Default\AppData\Local\Application Data =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [0] SHD -- C:\Users\Default\AppData\Local\History =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [] D -- C:\Users\Default\AppData\Local\Microsoft =>.Microsoft Corporation
O43 - CFD: 09/02/2011 - [0] D -- C:\Users\Default\AppData\Local\Microsoft Help =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [0] D -- C:\Users\Default\AppData\Local\Temp =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [0] SHD -- C:\Users\Default\AppData\Local\Temporary Internet Files =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [0] SHD -- C:\Users\Default User\AppData\Local\Application Data =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [0] SHD -- C:\Users\Default User\AppData\Local\History =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [] D -- C:\Users\Default User\AppData\Local\Microsoft =>.Microsoft Corporation
O43 - CFD: 09/02/2011 - [0] D -- C:\Users\Default User\AppData\Local\Microsoft Help =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [0] D -- C:\Users\Default User\AppData\Local\Temp =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - [0] SHD -- C:\Users\Default User\AppData\Local\Temporary Internet Files =>.Microsoft Corporation
O43 - CFD: 01/06/2017 - [] D -- C:\windows\System32\Config\systemprofile\AppData\Local\Microsoft =>.Microsoft Corporation
O43 - CFD: 05/12/2009 - [] SD -- C:\windows\System32\Config\systemprofile\AppData\Roaming\Microsoft =>.Microsoft Corporation
---\\ ShellIconOverlayIdentifiers (SIOI) (3) - 0s
O106 - SIOI: Enhanced Storage Icon Overlay Handler Class [EnhancedStorageShell] - {D9144DCD-E998-4ECA-AB6A-DCD83CCBA16D}. (.Microsoft Corporation - Windows Enhanced Storage Shell Extension DL.) -- C:\Windows\System32\EhStorShell.dll =>.Microsoft Corporation
O106 - SIOI: [KAVOverlayIcon] - {dd230880-495a-11d1-b064-008048ec2fc5}. (.Kaspersky Lab ZAO - Windows Shell Extension.) -- C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\shellex.dll =>.Kaspersky Lab®
O106 - SIOI: Sharing Overlay (Private) [SharingPrivate] - {08244EE6-92F0-47f2-9FC9-929BAA2E7235}. (.Microsoft Corporation - Shell extensions for sharing.) -- C:\Windows\System32\ntshrui.dll =>.Microsoft Corporation
---\\ Image File Execution Options (4) - 0s
O50 - IFEO:C:\windows\System32\ie4uinit.exe - (.Microsoft Corporation - IE Per-User Initialization Utility.) [MitigationOptions\\256] =>.Microsoft Corporation
O50 - IFEO:C:\Windows\System32\ieUnatt.exe - (.Microsoft Corporation - IE 7.0 Unattended Install Utility.) [MitigationOptions\\256] =>.Microsoft Corporation
O50 - IFEO:C:\Windows\System32\msfeedssync.exe - (.Microsoft Corporation - Microsoft Feeds Synchronization.) [MitigationOptions\\256] =>.Microsoft Corporation
O50 - IFEO:C:\Windows\System32\mshta.exe - (.Microsoft Corporation - Microsoft (R) HTML Application host.) [MitigationOptions\\256] =>.Microsoft Corporation
---\\ System Drivers List (96) - 67s
O58 - SDL:2009/07/14 11:52:21 A . (.Adaptec, Inc. - Adaptec Windows SAS/SATA Storport Driver.) -- C:\windows\System32\drivers\adp94xx.sys [491088] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:52:21 A . (.Adaptec, Inc. - Adaptec Windows SATA Storport Driver.) -- C:\windows\System32\drivers\adpahci.sys [339536] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:52:21 A . (.Adaptec, Inc. - Adaptec StorPort Ultra320 SCSI Driver (X64).) -- C:\windows\System32\drivers\adpu320.sys [182864] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:52:21 A . (.Acer Laboratories Inc. - ALi mini IDE Driver.) -- C:\windows\System32\drivers\aliide.sys [15440] =>.Microsoft Windows®
O58 - SDL:2011/03/11 16:41:12 A . (.Advanced Micro Devices - AHCI 1.2 Device Driver.) -- C:\windows\System32\drivers\amdsata.sys [107904] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:52:20 A . (.AMD Technologies Inc. - AMD Technology AHCI Compatible Controller D.) -- C:\windows\System32\drivers\amdsbs.sys [194128] =>.Microsoft Windows®
O58 - SDL:2011/03/11 16:41:12 A . (.Advanced Micro Devices - Storage Filter Driver.) -- C:\windows\System32\drivers\amdxata.sys [27008] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:52:21 A . (.Adaptec, Inc. - Adaptec RAID Storport Driver.) -- C:\windows\System32\drivers\arc.sys [87632] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:52:21 A . (.Adaptec, Inc. - Adaptec SAS RAID WS03 Driver.) -- C:\windows\System32\drivers\arcsas.sys [97856] =>.Microsoft Windows®
O58 - SDL:2011/02/17 16:07:25 A . (.Authors - .) -- C:\windows\System32\drivers\atksgt.sys [314016] =>.Tages SA®
O58 - SDL:2009/06/11 06:34:23 A . (.Broadcom Corporation - Broadcom NetXtreme Gigabit Ethernet NDIS6.x.) -- C:\windows\System32\drivers\b57nd60a.sys [270848] =>.Broadcom Corporation
O58 - SDL:2009/06/11 06:41:06 A . (.Brother Industries, Ltd. - Windows ME USB Mass-Storage Bulk-Only Lower.) -- C:\windows\System32\drivers\BrFiltLo.sys [18432] =>.Brother Industries, Ltd.
O58 - SDL:2009/06/11 06:41:06 A . (.Brother Industries, Ltd. - Windows ME USB Mass-Storage Bulk-Only Upper.) -- C:\windows\System32\drivers\BrFiltUp.sys [8704] =>.Brother Industries, Ltd.
O58 - SDL:2009/07/14 11:19:07 A . (.Brother Industries Ltd. - Brotehr Serial I/F Driver (WDM).) -- C:\windows\System32\drivers\BrSerId.sys [286720] =>.Brother Industries Ltd.
O58 - SDL:2009/06/11 06:41:10 A . (.Brother Industries Ltd. - Brother Serial driver (WDM version).) -- C:\windows\System32\drivers\BrSerWdm.sys [47104] =>.Brother Industries Ltd.
O58 - SDL:2009/06/11 06:41:10 A . (.Brother Industries Ltd. - Brother USB MDM Driver.) -- C:\windows\System32\drivers\BrUsbMdm.sys [14976] =>.Brother Industries Ltd.
O58 - SDL:2009/06/11 06:41:10 A . (.Brother Industries Ltd. - Brother USB Serial Driver.) -- C:\windows\System32\drivers\BrUsbSer.sys [14720] =>.Brother Industries Ltd.
O58 - SDL:2009/10/30 22:39:54 A . (.BEHRINGER - BEHRINGER USB AUDIO DRIVER.) -- C:\windows\System32\drivers\BUSB2902.sys [460864] =>.Ploytec GmbH®
O58 - SDL:2009/10/30 22:39:54 N . (.BEHRINGER - BEHRINGER USB WDM Audio Driver.) -- C:\windows\System32\drivers\busbwdm.sys [49728] =>.Ploytec GmbH®
O58 - SDL:2009/06/11 06:34:28 A . (.Broadcom Corporation - Broadcom NetXtreme II GigE VBD.) -- C:\windows\System32\drivers\bxvbda.sys [468480] =>.Broadcom Corporation
O58 - SDL:2011/08/17 08:58:20 A . (.Nokia - Nokia USB Phone Bus Driver.) -- C:\windows\System32\drivers\ccdcmbox64.sys [27136] =>.Nokia
O58 - SDL:2011/08/17 08:58:16 A . (.Nokia - Nokia USB Phone Bus Driver.) -- C:\windows\System32\drivers\ccdcmbx64.sys [19968] =>.Nokia
O58 - SDL:2010/06/22 13:28:06 A . (.Conexant Systems Inc. - 64-bit High Definition Audio Function Drive.) -- C:\windows\System32\drivers\CHDRT64.sys [729216] =>.Conexant Systems, Inc.®
O58 - SDL:2009/07/14 11:52:31 A . (.CMD Technology, Inc. - CMD PCI IDE Bus Driver.) -- C:\windows\System32\drivers\cmdide.sys [17488] =>.Microsoft Windows®
O58 - SDL:2011/06/02 14:39:44 A . (.Infowatch - Cryptographic Algorithm Lib Driver..) -- C:\windows\System32\drivers\CSCrySec.sys [84536] =>.InfoWatch®
O58 - SDL:2011/06/02 14:39:44 A . (.Infowatch - Virtual Volume Container Driver (wnet).) -- C:\windows\System32\drivers\CSVirtualDiskDrv.sys [66616] =>.InfoWatch®
O58 - SDL:2009/07/14 11:47:48 A . (.Emulex - Storport Miniport Driver for LightPulse HBA.) -- C:\windows\System32\drivers\elxstor.sys [530496] =>.Microsoft Windows®
O58 - SDL:2009/06/11 06:34:33 A . (.Broadcom Corporation - Broadcom NetXtreme II 10 GigE VBD.) -- C:\windows\System32\drivers\evbda.sys [3286016] =>.Broadcom Corporation
O58 - SDL:2017/06/11 15:03:52 A . (.Malwarebytes - Malwarebytes Anti-Ransomware Protection.) -- C:\windows\System32\drivers\farflt.sys [113592] =>.Malwarebytes Corporation®
O58 - SDL:2017/01/10 01:37:42 A . (.GEAR Software Inc. - CD DVD Filter.) -- C:\windows\System32\drivers\GEARAspiWDM.sys [34472] {0EB96F03CCAB1DB5CE3FF406C18E21AE} =>.GEAR Software Inc.
O58 - SDL:2009/06/11 06:31:59 A . (.Hauppauge Computer Works, Inc. - Hauppauge WinTV 885 Consumer IR Driver for.) -- C:\windows\System32\drivers\hcw85cir.sys [31232] =>.Hauppauge Computer Works, Inc.
O58 - SDL:2010/11/20 23:33:35 A . (.Hewlett-Packard Company - Smart Array SAS/SATA Controller Media Drive.) -- C:\windows\System32\drivers\HpSAMD.sys [78720] =>.Microsoft Windows®
O58 - SDL:2009/12/18 03:42:08 A . (.Intel Corporation - Intel Matrix Storage Manager driver - x64.) -- C:\windows\System32\drivers\iaStor.sys [538136] =>.Intel Corporation®
O58 - SDL:2011/03/11 16:41:26 A . (.Intel Corporation - Intel Matrix Storage Manager driver - x64.) -- C:\windows\System32\drivers\iaStorV.sys [410496] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:48:04 A . (.Intel Corp./ICP vortex GmbH - Intel/ICP Raid Storport Driver.) -- C:\windows\System32\drivers\iirsp.sys [44112] =>.Microsoft Windows®
O58 - SDL:2015/09/17 18:29:12 A . (.Kaspersky Lab ZAO - Kaspersky Unified Driver.) -- C:\windows\System32\drivers\kl1.sys [458336] =>.Kaspersky Lab®
O58 - SDL:2015/09/17 18:29:13 A . (.Kaspersky Lab ZAO - Filter Core [fre_wlh_x64].) -- C:\windows\System32\drivers\klflt.sys [92768] =>.Kaspersky Lab®
O58 - SDL:2015/09/17 18:29:13 A . (.Kaspersky Lab ZAO - Klif Mini-Filter [fre_wlh_x64].) -- C:\windows\System32\drivers\klif.sys [628288] =>.Kaspersky Lab®
O58 - SDL:2015/09/17 18:29:14 A . (.Kaspersky Lab ZAO - Kaspersky Lab Intermediate Network Driver.) -- C:\windows\System32\drivers\klim6.sys [29792] =>.Kaspersky Lab®
O58 - SDL:2013/11/11 20:40:50 A . (.Kaspersky Lab ZAO - KLKBDFLT Keyboard Device Filter [fre_wlh_x6.) -- C:\windows\System32\drivers\klkbdflt.sys [29280] =>.Kaspersky Lab®
O58 - SDL:2013/11/11 20:40:50 A . (.Kaspersky Lab ZAO - KLMOUFLT Mouse Device Filter [fre_wlh_x64].) -- C:\windows\System32\drivers\klmouflt.sys [29280] =>.Kaspersky Lab®
O58 - SDL:2013/11/11 20:40:50 A . (.Kaspersky Lab ZAO - Network filtering component.) -- C:\windows\System32\drivers\kltdi.sys [54368] =>.Kaspersky Lab®
O58 - SDL:2015/09/17 18:29:14 A . (.Kaspersky Lab ZAO - KNEPS Power [fre_wnet_amd64].) -- C:\windows\System32\drivers\kneps.sys [177864] =>.Kaspersky Lab®
O58 - SDL:2009/11/14 10:47:36 A . (.Atheros Communications, Inc. - Atheros L1c PCI-E Gigabit Ethernet Controll.) -- C:\windows\System32\drivers\L1C62x64.sys [67072] =>.Atheros Communications, Inc.
O58 - SDL:2011/02/17 16:07:25 A . (.Authors - .) -- C:\windows\System32\drivers\lirsgt.sys [43680] =>.Tages SA®
O58 - SDL:2009/07/14 11:48:04 A . (.LSI Corporation - LSI Fusion-MPT FC Driver (StorPort).) -- C:\windows\System32\drivers\lsi_fc.sys [114752] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:48:04 A . (.LSI Corporation - LSI Fusion-MPT SAS Driver (StorPort).) -- C:\windows\System32\drivers\lsi_sas.sys [106560] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:48:04 A . (.LSI Corporation - LSI SAS Gen2 Driver (StorPort).) -- C:\windows\System32\drivers\lsi_sas2.sys [65600] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:48:04 A . (.LSI Corporation - LSI Fusion-MPT SCSI Driver (StorPort).) -- C:\windows\System32\drivers\lsi_scsi.sys [115776] =>.Microsoft Windows®
O58 - SDL:2017/05/25 11:58:02 A . (.Authors - .) -- C:\windows\System32\drivers\mbae64.sys [77376] =>.Malwarebytes Corporation®
O58 - SDL:2017/06/11 15:03:51 A . (.Malwarebytes - Malwarebytes Real-Time Protection.) -- C:\windows\System32\drivers\mbam.sys [44960] =>.Malwarebytes Corporation®
O58 - SDL:2017/06/10 20:32:45 A . (.Malwarebytes - Malwarebytes Chameleon.) -- C:\windows\System32\drivers\MBAMChameleon.sys [188312] =>.Malwarebytes Corporation®
O58 - SDL:2017/06/11 15:03:37 A . (.Malwarebytes - Malwarebytes SwissArmy.) -- C:\windows\System32\drivers\MBAMSwissArmy.sys [252832] =>.Malwarebytes Corporation®
O58 - SDL:2009/07/14 11:48:04 A . (.LSI Corporation - MEGASAS RAID Controller Driver for Windows.) -- C:\windows\System32\drivers\megasas.sys [35392] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:48:04 A . (.LSI Corporation, Inc. - LSI MegaRAID Software RAID Driver.) -- C:\windows\System32\drivers\MegaSR.sys [284736] =>.Microsoft Windows®
O58 - SDL:2017/06/11 15:03:51 A . (.Malwarebytes - Malwarebytes Web Protection.) -- C:\windows\System32\drivers\mwac.sys [84256] =>.Malwarebytes Corporation®
O58 - SDL:2009/07/14 11:48:26 A . (.IBM Corporation - IBM ServeRAID Controller Driver.) -- C:\windows\System32\drivers\nfrd960.sys [51264] =>.Microsoft Windows®
O58 - SDL:2013/11/28 23:38:18 A . (.NVIDIA Corporation - NVIDIA HDMI Audio Driver.) -- C:\windows\System32\drivers\nvhda64v.sys [197408] =>.NVIDIA Corporation®
O58 - SDL:2015/02/04 13:56:28 A . (.NVIDIA Corporation - NVIDIA Windows Kernel Mode Driver, Version.) -- C:\windows\System32\drivers\nvlddmkm.sys [12894024] =>.NVIDIA Corporation®
O58 - SDL:2011/03/11 16:41:34 A . (.NVIDIA Corporation - NVIDIA® nForce(TM) RAID Driver.) -- C:\windows\System32\drivers\nvraid.sys [148352] =>.Microsoft Windows®
O58 - SDL:2011/03/11 16:41:34 A . (.NVIDIA Corporation - NVIDIA® nForce(TM) Sata Performance Driver.) -- C:\windows\System32\drivers\nvstor.sys [166272] =>.Microsoft Windows®
O58 - SDL:2014/11/22 20:46:30 A . (.NVIDIA Corporation - NVIDIA Virtual Audio Driver.) -- C:\windows\System32\drivers\nvvad64v.sys [38032] =>.NVIDIA Corporation®
O58 - SDL:2009/11/04 02:21:18 A . (.O2Micro - .) -- C:\windows\System32\drivers\o2mdgx64.sys [74016] =>.O2Micro Inc.®
O58 - SDL:2009/08/19 11:41:06 A . (.O2Micro - O2Micro SD Reader Driver (AMD64).) -- C:\windows\System32\drivers\o2sdgx64.sys [49568] =>.O2Micro Inc.®
O58 - SDL:2009/06/23 10:06:38 A . (.TOSHIBA Corporation - TOSHIBA Universal Camera Filter Driver.) -- C:\windows\System32\drivers\PGEffect.sys [35008] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/06/16 07:58:50 A . (.TOSHIBA - Generic IO & Memory Access.) -- C:\windows\System32\drivers\QIOMem.sys [12800] =>.Toshiba
O58 - SDL:2009/07/14 11:45:46 A . (.QLogic Corporation - QLogic Fibre Channel Stor Miniport Driver.) -- C:\windows\System32\drivers\ql2300.sys [1524816] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:45:45 A . (.QLogic Corporation - QLogic iSCSI Storport Miniport Driver.) -- C:\windows\System32\drivers\ql40xx.sys [128592] =>.Microsoft Windows®
O58 - SDL:2007/04/17 13:51:50 RA . (.InterVideo - regi driver.) -- C:\windows\System32\drivers\regi.sys [14112] =>.Intervideo, Inc.®
O58 - SDL:2009/10/03 06:33:48 A . (.Realtek Semiconductor Corporation - Realtek RTL81892SE NDIS Driverr.) -- C:\windows\System32\drivers\rtl8192se.sys [946688] =>.Realtek Semiconductor Corporation
O58 - SDL:2014/06/11 08:01:04 A . (.Realtek Semiconductor Corp. - Realtek UVC Driver for XP/Vista/Win7/Win8.) -- C:\windows\System32\drivers\rtsuvc.sys [9121496] =>.Realtek Semiconductor Corp®
O58 - SDL:2014/06/09 19:49:00 A . (.Windows (R) Win 7 DDK provider - Maelstrom VAD Audio driver.) -- C:\windows\System32\drivers\RzMaelstromVAD.sys [32768] =>.Windows (R) Win 7 DDK provider
O58 - SDL:2009/06/11 06:37:19 A . (.Macrovision Corporation, Macrovision Europe Limited, - Macrovision SECURITY Driver.) -- C:\windows\System32\drivers\secdrv.sys [23040] =>.Macrovision Corporation, Macrovision Europe Limited,
O58 - SDL:2009/07/14 10:00:40 A . (.Brother Industries Ltd. - Brotehr Serial I/F Driver (WDM).) -- C:\windows\System32\drivers\serial.sys [94208] =>.Brother Industries Ltd.
O58 - SDL:2009/07/14 11:45:45 A . (.Silicon Integrated Systems Corp. - SiS RAID Stor Miniport Driver.) -- C:\windows\System32\drivers\sisraid2.sys [43584] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:45:46 A . (.Silicon Integrated Systems - SiS AHCI Stor-Miniport Driver.) -- C:\windows\System32\drivers\sisraid4.sys [80464] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:45:55 A . (.Promise Technology - Promise SuperTrak EX Series Driver for Win.) -- C:\windows\System32\drivers\stexstor.sys [24656] =>.Microsoft Windows®
O58 - SDL:2009/07/31 11:20:18 A . (.Synaptics Incorporated - Synaptics Touchpad Driver.) -- C:\windows\System32\drivers\SynTP.sys [281648] =>.Synaptics Incorporated®
O58 - SDL:2009/06/30 03:25:22 A . (.TOSHIBA Corporation - TOSHIBA HDD Protection Driver.) -- C:\windows\System32\drivers\thpdrv.sys [34880] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/06/30 09:16:20 A . (.TOSHIBA Corporation - TOSHIBA HDD Protection - Shock Sensor Drive.) -- C:\windows\System32\drivers\Thpevm.sys [14784] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/06/18 05:01:04 A . (.TOSHIBA Corporation - TOSHIBA Bluetooth Port Emulation Driver.) -- C:\windows\System32\drivers\tosporte.sys [54664] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/09/25 10:55:00 A . (.TOSHIBA CORPORATION - Bluetooth RF Bus Driver.) -- C:\windows\System32\drivers\tosrfbd.sys [212072] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/06/20 02:59:32 A . (.TOSHIBA Corporation - Bluetooth RFBNEP Driver.) -- C:\windows\System32\drivers\tosrfbnp.sys [50664] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/07/29 13:02:10 A . (.TOSHIBA Corporation - Bluetooth RFCOMM Driver.) -- C:\windows\System32\drivers\tosrfcom.sys [81768] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/07/14 15:12:36 A . (.TOSHIBA Corporation - TOSHIBA Bluetooth EC Driver.) -- C:\windows\System32\drivers\tosrfec.sys [19824] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/06/20 03:00:26 A . (.TOSHIBA Corporation. - Bluetooth HID Driver from TOSHIBA.) -- C:\windows\System32\drivers\Tosrfhid.sys [94336] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/07/25 04:33:14 A . (.TOSHIBA Corporation. - Bluetooth BNEP Driver.) -- C:\windows\System32\drivers\tosrfnds.sys [26472] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/08/06 05:56:04 A . (.TOSHIBA Corporation - Bluetooth Audio Driver (WDM).) -- C:\windows\System32\drivers\TosRfSnd.sys [63856] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/09/15 07:30:26 A . (.TOSHIBA CORPORATION - Bluetooth USB Miniport Driver.) -- C:\windows\System32\drivers\tosrfusb.sys [58744] =>.TOSHIBA CORPORATION®
O58 - SDL:2009/07/25 08:57:08 A . (.TOSHIBA Corporation - tos_sps64.) -- C:\windows\System32\drivers\tos_sps64.sys [482384] =>.TOSHIBA CORPORATION®
O58 - SDL:2017/06/10 11:57:16 A . (.Authors - .) -- C:\windows\System32\drivers\TrueSight.sys [28272] =>.Adlice®
O58 - SDL:2009/07/15 08:31:18 A . (.TOSHIBA Corporation - TOSHIBA ACPI-Based Value Added Logical and.) -- C:\windows\System32\drivers\TVALZ_O.SYS [26840] =>.TOSHIBA CORPORATION®
O58 - SDL:2011/08/17 08:58:26 A . (.Nokia - Filter Driver for Nokia USB Phone Bus Drive.) -- C:\windows\System32\drivers\usbser_lowerfltjx64.sys [9216] =>.Nokia
O58 - SDL:2011/08/17 08:58:22 A . (.Nokia - Filter Driver for Nokia USB Phone Bus Drive.) -- C:\windows\System32\drivers\usbser_lowerfltx64.sys [9216] =>.Nokia
O58 - SDL:2009/07/14 11:45:55 A . (.VIA Technologies, Inc. - VIA Generic PCI IDE Bus Driver.) -- C:\windows\System32\drivers\viaide.sys [17488] =>.Microsoft Windows®
O58 - SDL:2009/07/14 11:45:55 A . (.VIA Technologies Inc.,Ltd - VIA RAID DRIVER FOR AMD-X86-64.) -- C:\windows\System32\drivers\vsmraid.sys [161872] =>.Microsoft Windows®
---\\ Last modified or created user files (3) - 46s
O61 - LFC: 2017/06/10 22:09:48 A . (.Copyright © 2015.) -- C:\Users\Juancho\Desktop\pc help forum stuff\Adware Removal Tool by TSA.exe [752296] {317DD1C55F51AC2756D9C93C060C6FA5}
O61 - LFC: 2017/06/10 22:09:47 A . (.glax24 (safezone.cc).) -- C:\Users\Juancho\Desktop\pc help forum stuff\SecurityCheck.exe [513726]
O61 - LFC: 2017/06/10 22:40:02 A . (.glax24 (safezone.cc).) -- C:\Users\Juancho\Documents\Downloads\SecurityCheck (1).exe [513726]
---\\ File Associations Shell Spawning (10) - 0s
O67 - Shell Spawning: <.bat> <batfile>[HKLM\..\open\Command] (...) -- "%1" %*
O67 - Shell Spawning: <.cpl> <cplfile>[HKLM\..\cplopen\Command] (.Microsoft Corporation - Windows Control Panel.) -- C:\Windows\System32\control.exe =>.Microsoft Corporation
O67 - Shell Spawning: <.cmd> <cmdfile>[HKLM\..\open\Command] (...) -- "%1" %*
O67 - Shell Spawning: <.com> <comfile>[HKLM\..\open\Command] (...) -- "%1" %*
O67 - Shell Spawning: <.evt> <evtfile>[HKLM\..\open\Command] (.Microsoft Corporation - Event Viewer Snapin Launcher.) -- C:\Windows\System32\eventvwr.exe =>.Microsoft Corporation
O67 - Shell Spawning: <.exe> <exefile>[HKLM\..\open\Command] (...) -- "%1" %*
O67 - Shell Spawning: <.html> <htmlfile>[HKLM\..\open\Command] (.Microsoft Corporation - Internet Explorer.) -- C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O67 - Shell Spawning: <.js> <JSFile>[HKLM\..\open\Command] (.Microsoft Corporation - Microsoft ® Windows Based Script Host.) -- C:\Windows\System32\wscript.exe =>.Microsoft Corporation
O67 - Shell Spawning: <.reg> <regfile>[HKLM\..\open\Command] (.Microsoft Corporation - Registry Editor.) -- C:\Windows\regedit.exe =>.Microsoft Corporation
O67 - Shell Spawning: <.scr> <scrfile>[HKLM\..\open\Command] (...) -- "%1" /S
---\\ Start Menu Internet (12) - 0s
O68 - StartMenuInternet: <FIREFOX.EXE> <Mozilla Firefox>[HKLM\..\Shell\open\Command] (.Mozilla Corporation - Firefox.) -- C:\Program Files (x86)\Mozilla Firefox\firefox.exe =>.Mozilla Corporation®
O68 - StartMenuInternet: <Google Chrome> <Google Chrome>[HKLM\..\Shell\open\Command] (.Google Inc. - Google Chrome.) -- C:\Users\Juancho\AppData\Local\Google\Chrome\Application\chrome.exe =>.Google Inc®
O68 - StartMenuInternet: <IEXPLORE.EXE> <Internet Explorer>[HKLM\..\Shell\open\Command] (.Microsoft Corporation - Internet Explorer.) -- C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O68 - StartMenuInternet: <FIREFOX.EXE> <Mozilla Firefox>[HKLM\..\InstallInfo\ShowIconsCommand] (.Mozilla Corporation - Firefox Helper.) -- C:\Program Files (x86)\Mozilla Firefox\uninstall\helper.exe =>.Mozilla Corporation
O68 - StartMenuInternet: <Google Chrome> <Google Chrome>[HKLM\..\InstallInfo\ShowIconsCommand] (.Google Inc. - Google Chrome.) -- C:\Users\Juancho\AppData\Local\Google\Chrome\Application\chrome.exe =>.Google Inc.
O68 - StartMenuInternet: <IEXPLORE.EXE> <Internet Explorer>[HKLM\..\InstallInfo\ShowIconsCommand] (.Microsoft Corporation - IE Per-User Initialization Utility.) -- C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
O68 - StartMenuInternet: <FIREFOX.EXE> <Mozilla Firefox>[HKLM\..\InstallInfo\ReinstallCommand] (.Mozilla Corporation - Firefox Helper.) -- C:\Program Files (x86)\Mozilla Firefox\uninstall\helper.exe =>.Mozilla Corporation
O68 - StartMenuInternet: <Google Chrome> <Google Chrome>[HKLM\..\InstallInfo\ReinstallCommand] (.Google Inc. - Google Chrome.) -- C:\Users\Juancho\AppData\Local\Google\Chrome\Application\chrome.exe =>.Google Inc.
O68 - StartMenuInternet: <IEXPLORE.EXE> <Internet Explorer>[HKLM\..\InstallInfo\ReinstallCommand] (.Microsoft Corporation - IE Per-User Initialization Utility.) -- C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
O68 - StartMenuInternet: <FIREFOX.EXE> <Mozilla Firefox>[HKLM\..\InstallInfo\HideIconsCommand] (.Mozilla Corporation - Firefox Helper.) -- C:\Program Files (x86)\Mozilla Firefox\uninstall\helper.exe =>.Mozilla Corporation
O68 - StartMenuInternet: <Google Chrome> <Google Chrome>[HKLM\..\InstallInfo\HideIconsCommand] (.Google Inc. - Google Chrome.) -- C:\Users\Juancho\AppData\Local\Google\Chrome\Application\chrome.exe =>.Google Inc.
O68 - StartMenuInternet: <IEXPLORE.EXE> <Internet Explorer>[HKLM\..\InstallInfo\HideIconsCommand] (.Microsoft Corporation - IE Per-User Initialization Utility.) -- C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
---\\ Search Browser Infection (8) - 12s
O69 - SBI: SearchScopes [HKCU] {0633EE93-D776-472f-A0FF-E1416B8B2E3A} [DefaultScope] - (Bing) - http://www.bing.com/ =>.Bing.com
O69 - SBI: SearchScopes [HKCU] {67C334C0-408D-4E6D-B5A7-0ADD6AFFA252} - (Google) - http://www.google.com/ =>.Google Inc.
O69 - SBI: SearchScopes [HKCU] {6A1806CD-94D4-4689-BA73-E35EA1EA9990} - (Google) - http://www.google.com/ =>.Google Inc.
O69 - SBI: SearchScopes [HKCU] {C1504460-8476-4083-B651-4E0C3A64FAE4} - (Google) - http://www.google.com/ =>.Google Inc.
O69 - SBI: SearchScopes [HKLM] {0633EE93-D776-472f-A0FF-E1416B8B2E3A} - (@ieframe.dll,-12512) - http://www.bing.com/ =>.Bing.com
O69 - SBI: SearchScopes [HKLM] {67A2568C-7A0A-4EED-AECC-B5405DE63B64} [DefaultScope] - (Google) - http://www.google.com/ =>.Google Inc.
O69 - SBI: SearchScopes [HKLM] {67C334C0-408D-4E6D-B5A7-0ADD6AFFA252} - (Google) - http://www.google.com/ =>.Google Inc.
O69 - SBI: SearchScopes [HKLM] {6A1806CD-94D4-4689-BA73-E35EA1EA9990} - (Google) - http://www.google.com/ =>.Google Inc.
---\\ Search Svchost Services (32) - 1s
O83 - Search Svchost Services: AeLookupSvc (AeLookupSvc) . (.Microsoft Corporation - Application Experience Service.) -- C:\windows\System32\aelupsvc.dll [72192] =>.Microsoft Corporation
O83 - Search Svchost Services: CertPropSvc (CertPropSvc) . (.Microsoft Corporation - Microsoft Smartcard Certificate Propagation.) -- C:\windows\System32\certprop.dll [80384] =>.Microsoft Corporation
O83 - Search Svchost Services: SCPolicySvc (SCPolicySvc) . (.Microsoft Corporation - Microsoft Smartcard Certificate Propagation.) -- C:\windows\System32\certprop.dll [80384] =>.Microsoft Corporation
O83 - Search Svchost Services: lanmanserver (lanmanserver) . (.Microsoft Corporation - Server Service DLL.) -- C:\windows\system32\srvsvc.dll [236032] =>.Microsoft Corporation
O83 - Search Svchost Services: gpsvc (gpsvc) . (.Microsoft Corporation - Group Policy Client.) -- C:\windows\System32\gpsvc.dll [794624] =>.Microsoft Corporation
O83 - Search Svchost Services: IKEEXT (IKEEXT) . (.Microsoft Corporation - IKE extension.) -- C:\windows\System32\ikeext.dll [859648] =>.Microsoft Corporation
O83 - Search Svchost Services: AudioSrv (AudioSrv) . (.Microsoft Corporation - Windows Audio Service.) -- C:\windows\System32\Audiosrv.dll [680448] =>.Microsoft Corporation
O83 - Search Svchost Services: Rasauto (Rasauto) . (.Microsoft Corporation - Remote Access AutoDial Manager.) -- C:\windows\System32\rasauto.dll [99328] =>.Microsoft Corporation
O83 - Search Svchost Services: Rasman (Rasman) . (.Microsoft Corporation - Remote Access Connection Manager.) -- C:\windows\System32\rasmans.dll [344064] =>.Microsoft Corporation
O83 - Search Svchost Services: Remoteaccess (Remoteaccess) . (.Microsoft Corporation - Dynamic Interface Manager.) -- C:\Windows\System32\mprdim.dll [97792] =>.Microsoft Corporation
O83 - Search Svchost Services: SENS (SENS) . (.Microsoft Corporation - System Event Notification Service (SENS).) -- C:\Windows\System32\Sens.dll [64512] =>.Microsoft Corporation
O83 - Search Svchost Services: Sharedaccess (Sharedaccess) . (.Microsoft Corporation - Microsoft NAT Helper Components.) -- C:\windows\System32\ipnathlp.dll [359424] =>.Microsoft Corporation
O83 - Search Svchost Services: Tapisrv (Tapisrv) . (.Microsoft Corporation - Microsoft® Windows(TM) Telephony Server.) -- C:\Windows\System32\tapisrv.dll [316928] =>.Microsoft Corporation
O83 - Search Svchost Services: TermService (TermService) . (.Microsoft Corporation - Remote Desktop Session Host Server Remote C.) -- C:\windows\System32\termsrv.dll [683520] =>.Microsoft Corporation
O83 - Search Svchost Services: wuauserv (wuauserv) . (.Microsoft Corporation - Windows Update Agent.) -- C:\windows\system32\wuaueng.dll [2651136] =>.Microsoft Corporation
O83 - Search Svchost Services: BITS (BITS) . (.Microsoft Corporation - Background Intelligent Transfer Service.) -- C:\windows\System32\qmgr.dll [849920] =>.Microsoft Corporation
O83 - Search Svchost Services: ShellHWDetection (ShellHWDetection) . (.Microsoft Corporation - Windows Shell Services Dll.) -- C:\Windows\System32\shsvcs.dll [370688] =>.Microsoft Corporation
O83 - Search Svchost Services: iphlpsvc (iphlpsvc) . (.Microsoft Corporation - Service that offers IPv6 connectivity over.) -- C:\windows\System32\iphlpsvc.dll [569344] =>.Microsoft Corporation
O83 - Search Svchost Services: seclogon (seclogon) . (.Microsoft Corporation - Secondary Logon Service DLL.) -- C:\windows\system32\seclogon.dll [30720] =>.Microsoft Corporation
O83 - Search Svchost Services: AppInfo (AppInfo) . (.Microsoft Corporation - Application Information Service.) -- C:\windows\System32\appinfo.dll [70144] =>.Microsoft Corporation
O83 - Search Svchost Services: msiscsi (msiscsi) . (.Microsoft Corporation - iSCSI Discovery service.) -- C:\windows\system32\iscsiexe.dll [156672] =>.Microsoft Corporation
O83 - Search Svchost Services: MMCSS (MMCSS) . (.Microsoft Corporation - Multimedia Class Scheduler Service.) -- C:\windows\system32\mmcss.dll [67584] =>.Microsoft Corporation
O83 - Search Svchost Services: winmgmt (winmgmt) . (.Microsoft Corporation - WMI.) -- C:\windows\system32\wbem\WMIsvc.dll [242688] =>.Microsoft Corporation
O83 - Search Svchost Services: SessionEnv (SessionEnv) . (.Microsoft Corporation - Remote Desktop Configuration service.) -- C:\Windows\System32\SessEnv.dll [121856] =>.Microsoft Corporation
O83 - Search Svchost Services: browser (browser) . (.Microsoft Corporation - Computer Browser Service DLL.) -- C:\windows\System32\browser.dll [136704] =>.Microsoft Corporation
O83 - Search Svchost Services: EapHost (EapHost) . (.Microsoft Corporation - Microsoft EAPHost service.) -- C:\windows\System32\eapsvc.dll [111104] =>.Microsoft Corporation
O83 - Search Svchost Services: schedule (schedule) . (.Microsoft Corporation - Task Scheduler Service.) -- C:\windows\system32\schedsvc.dll [1110016] =>.Microsoft Corporation
O83 - Search Svchost Services: hkmsvc (hkmsvc) . (.Microsoft Corporation - Key Management Service.) -- C:\windows\system32\kmsvc.dll [90624] =>.Microsoft Corporation
O83 - Search Svchost Services: wercplsupport (wercplsupport) . (.Microsoft Corporation - Problem Reports and Solutions.) -- C:\windows\System32\wercplsupport.dll [84480] =>.Microsoft Corporation
O83 - Search Svchost Services: ProfSvc (ProfSvc) . (.Microsoft Corporation - ProfSvc.) -- C:\windows\system32\profsvc.dll [210432] =>.Microsoft Corporation
O83 - Search Svchost Services: Themes (Themes) . (.Microsoft Corporation - Windows Shell Theme Service Dll.) -- C:\windows\system32\themeservice.dll [44544] =>.Microsoft Corporation
O83 - Search Svchost Services: BDESVC (BDESVC) . (.Microsoft Corporation - BDE Service.) -- C:\windows\System32\bdesvc.dll [100864] =>.Microsoft Corporation
---\\ Firewall Active Exception List (166) - 7s
O87 - FAEL: "{8709B73A-8EAE-429D-9805-5CF67FF55DCC}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe (.not file.)
O87 - FAEL: "{5AFB6B84-D25C-42D5-8D26-31B11B1C01C1}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Electronic Arts\Battlefield Bad Company 2\BFBC2Updater.exe (.not file.)
O87 - FAEL: "{B5E95FD6-CE2C-4D85-BAEB-BCF8B2479DB9}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Electronic Arts\Battlefield Bad Company 2\BFBC2Updater.exe (.not file.)
O87 - FAEL: "TCP Query User{E81DD8C0-7BF9-4C5D-B8A3-4E34C7FA1BB1}C:\program files (x86)\electronic arts\need for speed prostreet\nfs.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\electronic arts\need for speed prostreet\nfs.exe (.not file.)
O87 - FAEL: "UDP Query User{68B6E369-C23A-41C4-A15D-320641CC876A}C:\program files (x86)\electronic arts\need for speed prostreet\nfs.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\electronic arts\need for speed prostreet\nfs.exe (.not file.)
O87 - FAEL: "TCP Query User{41F92801-18B0-4251-9F97-9ADC92FC1C3C}C:\program files (x86)\activision\singularity(tm)\binaries\singularity.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\activision\singularity(tm)\binaries\singularity.exe (.not file.)
O87 - FAEL: "UDP Query User{181B1F6F-BAA1-4726-A49B-A1BB4187A596}C:\program files (x86)\activision\singularity(tm)\binaries\singularity.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\activision\singularity(tm)\binaries\singularity.exe (.not file.)
O87 - FAEL: "TCP Query User{7148E516-18B5-4912-8ECD-40D03D45BB42}C:\program files (x86)\bethesda softworks\fallout 3\fallout3.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\bethesda softworks\fallout 3\fallout3.exe (.not file.)
O87 - FAEL: "UDP Query User{9E643217-2BC5-499B-B4D5-EEE8D9597641}C:\program files (x86)\bethesda softworks\fallout 3\fallout3.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\bethesda softworks\fallout 3\fallout3.exe (.not file.)
O87 - FAEL: "{92C3DCE4-177C-4710-8742-6C169022D1E7}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\crysis 2 - demo\Bin32\Crysis2Demo.exe (.not file.) =>.Steam Games
O87 - FAEL: "{A3C993E0-940E-43AF-90AB-7B94A9AF6452}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\crysis 2 - demo\Bin32\Crysis2Demo.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{B317C696-45F1-4D2D-90AF-781A3826AD29}C:\program files (x86)\rockstar games\midnight club ii demo\mc2_demo.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\rockstar games\midnight club ii demo\mc2_demo.exe (.not file.)
O87 - FAEL: "UDP Query User{88F072FA-08A8-4FEF-B703-3D105A094DEC}C:\program files (x86)\rockstar games\midnight club ii demo\mc2_demo.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\rockstar games\midnight club ii demo\mc2_demo.exe (.not file.)
O87 - FAEL: "TCP Query User{06672C6B-B4B1-4777-BCD6-A6A9EAB664AE}C:\program files (x86)\electronic arts\dead space\dead space.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\electronic arts\dead space\dead space.exe (.not file.)
O87 - FAEL: "UDP Query User{FB74024F-54B3-4C2A-9193-E161EDBBB068}C:\program files (x86)\electronic arts\dead space\dead space.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\electronic arts\dead space\dead space.exe (.not file.)
O87 - FAEL: "TCP Query User{E0F1F31B-3662-4489-BAD6-E763EF6619E2}C:\program files (x86)\electronic arts\battlefield bad company 2\bfbc2game.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\electronic arts\battlefield bad company 2\bfbc2game.exe (.not file.)
O87 - FAEL: "UDP Query User{3E48EA2E-2E6F-41E0-81A3-2231DBA90159}C:\program files (x86)\electronic arts\battlefield bad company 2\bfbc2game.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\electronic arts\battlefield bad company 2\bfbc2game.exe (.not file.)
O87 - FAEL: "TCP Query User{86106556-5266-4F6D-9DF7-EE7756279EA4}C:\program files (x86)\electronic arts\medal of honor\mp\mohmpgame.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\electronic arts\medal of honor\mp\mohmpgame.exe (.not file.)
O87 - FAEL: "UDP Query User{3A343018-2D59-46D1-B58A-CED2E13DD783}C:\program files (x86)\electronic arts\medal of honor\mp\mohmpgame.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\electronic arts\medal of honor\mp\mohmpgame.exe (.not file.)
O87 - FAEL: "TCP Query User{8E8D59A2-F82F-47E2-8943-CC9B45EFF251}C:\program files (x86)\steam\steamapps\common\champions online\champions online\live\gameclient.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\champions online\champions online\live\gameclient.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{0AD6B98F-77F2-4CB5-A892-9FF476FFC5AE}C:\program files (x86)\steam\steamapps\common\champions online\champions online\live\gameclient.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\champions online\champions online\live\gameclient.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{063343D6-B652-4F20-AFDB-FB712F834E0D}C:\program files (x86)\electronic arts\crytek\crysis 2\bin32\crysis2.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\electronic arts\crytek\crysis 2\bin32\crysis2.exe (.not file.)
O87 - FAEL: "UDP Query User{E80E4453-E806-4515-93DF-1CF8CFFEC9EE}C:\program files (x86)\electronic arts\crytek\crysis 2\bin32\crysis2.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\electronic arts\crytek\crysis 2\bin32\crysis2.exe (.not file.)
O87 - FAEL: "TCP Query User{0B7F45AB-5A02-466E-9C8D-EE634CE8A231}C:\program files (x86)\steam\steamapps\cookiedog123\team fortress 2\hl2.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\cookiedog123\team fortress 2\hl2.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{F7227656-AB27-4104-BC8F-21A4978D301F}C:\program files (x86)\steam\steamapps\cookiedog123\team fortress 2\hl2.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\cookiedog123\team fortress 2\hl2.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{49C2D121-8296-4F52-B420-F05AA579BF7F}C:\program files (x86)\steam\steamapps\common\batman arkham asylum goty\binaries\shippingpc-bmgame.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\batman arkham asylum goty\binaries\shippingpc-bmgame.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{E2E66EB5-3195-471B-9F63-D84979770C61}C:\program files (x86)\steam\steamapps\common\batman arkham asylum goty\binaries\shippingpc-bmgame.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\batman arkham asylum goty\binaries\shippingpc-bmgame.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{93561F7C-EA43-4100-8485-5C3E4D13A288}C:\program files (x86)\steam\steamapps\common\dirt 3\dirt3_game.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\dirt 3\dirt3_game.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{DD49906C-3AAB-4755-8A73-71BC1FC03E88}C:\program files (x86)\steam\steamapps\common\dirt 3\dirt3_game.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\dirt 3\dirt3_game.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{05987F09-B0AF-44C6-9E47-4469A8A7AB05}C:\program files (x86)\the witcher 2\bin\witcher2.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\the witcher 2\bin\witcher2.exe (.not file.)
O87 - FAEL: "UDP Query User{CB1FEFBD-86B2-4997-8CC0-CFFEE29414CD}C:\program files (x86)\the witcher 2\bin\witcher2.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\the witcher 2\bin\witcher2.exe (.not file.)
O87 - FAEL: "TCP Query User{05ABA2B0-8314-4BED-AF45-57F08E33041C}C:\program files (x86)\steam\steamapps\common\grand theft auto iv\gtaiv\gtaiv.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\grand theft auto iv\gtaiv\gtaiv.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{0A53808B-F622-471C-9625-94EDEA2EFE2B}C:\program files (x86)\steam\steamapps\common\grand theft auto iv\gtaiv\gtaiv.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\grand theft auto iv\gtaiv\gtaiv.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{7888BF4D-33F8-4EBB-ADC4-878629C6CCC5}C:\program files (x86)\steam\steamapps\common\grand theft auto iv episodes from liberty city\eflc\eflc.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\grand theft auto iv episodes from liberty city\eflc\eflc.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{B7664430-C5E6-43A5-898E-EF72D051E72D}C:\program files (x86)\steam\steamapps\common\grand theft auto iv episodes from liberty city\eflc\eflc.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\grand theft auto iv episodes from liberty city\eflc\eflc.exe (.not file.) =>.Steam Games
O87 - FAEL: "{F68CD7E1-4936-44C4-B3AD-DC4C5B800623}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\dragon age ultimate edition\docs\EA Help\Electronic_Arts_Technical_Support.htm (.not file.) =>.Steam Games
O87 - FAEL: "{5FF0B147-85FD-4771-9F86-B7CF49FF3BD3}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\dragon age ultimate edition\docs\EA Help\Electronic_Arts_Technical_Support.htm (.not file.) =>.Steam Games
O87 - FAEL: "{6E298098-8E07-4B6C-B4B2-4E9F889B7225}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\dragon age ultimate edition\bin_ship\DAUpdaterSvc.Service.exe (.not file.) =>.Steam Games
O87 - FAEL: "{CBB1330D-C051-4F10-BE75-0ACECC0556BB}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\dragon age ultimate edition\bin_ship\DAUpdaterSvc.Service.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{7473A9A8-C322-423A-BA34-A07435124EB0}C:\program files (x86)\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{0285BF06-2CD3-4BF6-AB66-96E6AA708941}C:\program files (x86)\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{AE24B221-E61C-4B94-B52D-1E9BD71176DE}E:\tom clancy's splinter cell double agent\scda-offline\system\splintercell4.exe" [In-None-P6-TRUE] .(...) -- E:\tom clancy's splinter cell double agent\scda-offline\system\splintercell4.exe (.not file.)
O87 - FAEL: "UDP Query User{EA0F987A-C9F6-4372-A5AE-5212B3C6537F}E:\tom clancy's splinter cell double agent\scda-offline\system\splintercell4.exe" [In-None-P17-TRUE] .(...) -- E:\tom clancy's splinter cell double agent\scda-offline\system\splintercell4.exe (.not file.)
O87 - FAEL: "TCP Query User{8905A400-5C4E-4158-BE73-56A3C5B30492}C:\program files (x86)\steam\steamapps\common\arma 2 operation arrowhead\expansion\beta\arma2oa.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\arma 2 operation arrowhead\expansion\beta\arma2oa.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{BBB20F95-99D0-4F7E-B806-DD8BEFB5B023}C:\program files (x86)\steam\steamapps\common\arma 2 operation arrowhead\expansion\beta\arma2oa.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\arma 2 operation arrowhead\expansion\beta\arma2oa.exe (.not file.) =>.Steam Games
O87 - FAEL: "{6228D06F-4FDC-4C4F-BAA2-A75EE1A04497}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\apb reloaded\Binaries\APB.exe (.not file.) =>.Steam Games
O87 - FAEL: "{ADC5C6C5-ECED-4249-9969-CFDBEF5A9AF9}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\apb reloaded\Binaries\APB.exe (.not file.) =>.Steam Games
O87 - FAEL: "{751DD4D3-8C0E-4B15-A333-96927BA29F8C}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\apb reloaded\Binaries\VivoxVoiceService.exe (.not file.) =>.Steam Games
O87 - FAEL: "{277D7ADA-8FD4-4FCC-B338-090EC000EB76}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\apb reloaded\Binaries\VivoxVoiceService.exe (.not file.) =>.Steam Games
O87 - FAEL: "{85427CC4-CEDF-4B2D-A991-07A147DE17B0}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Home\Home PC v1.3.1s.exe (.not file.) =>.Steam Games
O87 - FAEL: "{76C8D698-4ADF-4679-98C9-130A8CB70C4B}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Home\Home PC v1.3.1s.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{791F6774-4143-46D1-8814-0A3015E296DE}C:\program files (x86)\ubisoft\splinter cell pandora tomorrow\pandora.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\ubisoft\splinter cell pandora tomorrow\pandora.exe (.not file.)
O87 - FAEL: "UDP Query User{DDDB0BF1-2418-4EF3-B2B4-14378F8D2CA6}C:\program files (x86)\ubisoft\splinter cell pandora tomorrow\pandora.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\ubisoft\splinter cell pandora tomorrow\pandora.exe (.not file.)
O87 - FAEL: "TCP Query User{9FF66915-FCEE-4B53-B2CF-485C442B748D}C:\program files (x86)\ubisoft\tom clancy's splinter cell conviction\src\system\conviction_game.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\ubisoft\tom clancy's splinter cell conviction\src\system\conviction_game.exe (.not file.)
O87 - FAEL: "UDP Query User{2593B930-C3E5-4323-A79B-B50C7A0CE657}C:\program files (x86)\ubisoft\tom clancy's splinter cell conviction\src\system\conviction_game.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\ubisoft\tom clancy's splinter cell conviction\src\system\conviction_game.exe (.not file.)
O87 - FAEL: "TCP Query User{9A279DCC-C0D3-49A2-9F77-5B2FBE2A14C0}E:\tom clancy's ghost recon future soldier\future soldier.exe" [In-None-P6-TRUE] .(...) -- E:\tom clancy's ghost recon future soldier\future soldier.exe (.not file.)
O87 - FAEL: "UDP Query User{60D861DE-1C5B-44B8-8C33-2009B49F7641}E:\tom clancy's ghost recon future soldier\future soldier.exe" [In-None-P17-TRUE] .(...) -- E:\tom clancy's ghost recon future soldier\future soldier.exe (.not file.)
O87 - FAEL: "{0DC29C14-5309-42B1-B661-089FCD5A4E55}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Euro Truck Simulator 2 Demo\bin\win_x86\eurotrucks2.exe (.not file.) =>.Steam Games
O87 - FAEL: "{D3644B20-F783-4B19-BBFB-AF661E01E658}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Euro Truck Simulator 2 Demo\bin\win_x86\eurotrucks2.exe (.not file.) =>.Steam Games
O87 - FAEL: "{579C97F3-15D3-49BB-A99F-749086C8A33B}" [In-None-P17-TRUE] .(...) -- E:\SteamLibrary\steamapps\common\Warframe\Warframe.exe (.not file.) =>.Steam Games
O87 - FAEL: "{30DC85DD-059E-467F-BEE5-626630723B4E}" [In-None-P17-TRUE] .(...) -- E:\SteamLibrary\steamapps\common\Warframe\Warframe.x64.exe (.not file.) =>.Steam Games
O87 - FAEL: "{06A8C917-87CE-45B6-9F15-01BC93FFD0DA}" [Out-None-P17-TRUE] .(...) -- E:\SteamLibrary\steamapps\common\Warframe\Warframe.exe (.not file.) =>.Steam Games
O87 - FAEL: "{3417785A-9394-4337-9E4A-741C067B6A43}" [Out-None-P17-TRUE] .(...) -- E:\SteamLibrary\steamapps\common\Warframe\Warframe.x64.exe (.not file.) =>.Steam Games
O87 - FAEL: "{4583AAEE-68B7-4136-B9C6-C08E3464C4B6}" [Out-None-P6-TRUE] .(...) -- E:\SteamLibrary\steamapps\common\Warframe\Warframe.exe (.not file.) =>.Steam Games
O87 - FAEL: "{0CCCDD55-7513-4E70-9D40-7666BE439851}" [Out-None-P6-TRUE] .(...) -- E:\SteamLibrary\steamapps\common\Warframe\Warframe.x64.exe (.not file.) =>.Steam Games
O87 - FAEL: "{44612442-4660-4FFF-A27C-F4ECCBC078A4}" [Out-None-P6-TRUE] .(...) -- E:\SteamLibrary\steamapps\common\Warframe\Tools\Launcher.exe (.not file.) =>.Steam Games
O87 - FAEL: "{E44289A9-F99C-4398-B4DB-468A949A0C97}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\call of duty black ops\BlackOpsMP.exe (.not file.) =>.Steam Games
O87 - FAEL: "{90730CC7-FADF-4B01-93AE-9B0AD6C63F1F}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\call of duty black ops\BlackOpsMP.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{82727836-B918-4E3C-81FE-1187B94D6B56}E:\steamlibrary\steamapps\common\cry of fear\cof.exe" [In-None-P6-TRUE] .(...) -- E:\steamlibrary\steamapps\common\cry of fear\cof.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{BB0D8F41-19C2-4CA1-B752-5B5B773AE6FA}E:\steamlibrary\steamapps\common\cry of fear\cof.exe" [In-None-P17-TRUE] .(...) -- E:\steamlibrary\steamapps\common\cry of fear\cof.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{5B71CA91-FD3B-4802-A219-72CD36D173C0}C:\program files (x86)\ea games\dead space 2\deadspace2.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\ea games\dead space 2\deadspace2.exe (.not file.)
O87 - FAEL: "UDP Query User{3A893224-7522-46F1-BF14-9917504BB1C2}C:\program files (x86)\ea games\dead space 2\deadspace2.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\ea games\dead space 2\deadspace2.exe (.not file.)
O87 - FAEL: "TCP Query User{094DADD6-948C-413F-A941-F7224A5DD7C9}E:\steamlibrary\steamapps\common\bioshock infinite\binaries\win32\bioshockinfinite.exe" [In-None-P6-TRUE] .(...) -- E:\steamlibrary\steamapps\common\bioshock infinite\binaries\win32\bioshockinfinite.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{38972354-6AAD-4DD8-95E5-10A2D31178F6}E:\steamlibrary\steamapps\common\bioshock infinite\binaries\win32\bioshockinfinite.exe" [In-None-P17-TRUE] .(...) -- E:\steamlibrary\steamapps\common\bioshock infinite\binaries\win32\bioshockinfinite.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{49C1118C-A013-48A9-A902-EFE2DA74DB42}E:\steamlibrary\steamapps\common\dead island\deadislandgame.exe" [In-None-P6-TRUE] .(...) -- E:\steamlibrary\steamapps\common\dead island\deadislandgame.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{1F95553B-DEAC-4920-88F0-B52390F312C6}E:\steamlibrary\steamapps\common\dead island\deadislandgame.exe" [In-None-P17-TRUE] .(...) -- E:\steamlibrary\steamapps\common\dead island\deadislandgame.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{F7972054-101F-48E2-913D-07DA69F4F557}E:\steamlibrary\steamapps\common\motogp 13 demo\motogp13.exe" [In-None-P6-TRUE] .(...) -- E:\steamlibrary\steamapps\common\motogp 13 demo\motogp13.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{D24F36E9-547C-4294-958E-622473379CB9}E:\steamlibrary\steamapps\common\motogp 13 demo\motogp13.exe" [In-None-P17-TRUE] .(...) -- E:\steamlibrary\steamapps\common\motogp 13 demo\motogp13.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{3EDE6673-BA39-4A8F-AD90-203EBD1C4E30}E:\steamlibrary\steamapps\common\fable 3\fable3.exe" [In-None-P6-TRUE] .(...) -- E:\steamlibrary\steamapps\common\fable 3\fable3.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{F70DAF51-E239-4C0C-B4A8-B1D0F81BE409}E:\steamlibrary\steamapps\common\fable 3\fable3.exe" [In-None-P17-TRUE] .(...) -- E:\steamlibrary\steamapps\common\fable 3\fable3.exe (.not file.) =>.Steam Games
O87 - FAEL: "{C52753D0-63C5-4343-A74C-9A1FE50C8FBA}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\CastlevaniaLoS_Demo\bin\DemoCastlevaniaLoSUE.exe (.not file.) =>.Steam Games
O87 - FAEL: "{16FA2460-B686-48A9-BD73-348AE9DB6C3E}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\CastlevaniaLoS_Demo\bin\DemoCastlevaniaLoSUE.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{96437C0B-1A43-4DCC-BC41-48F9C325CFEC}E:\steamlibrary\steamapps\common\dark souls prepare to die edition\data\data.exe" [In-None-P6-TRUE] .(...) -- E:\steamlibrary\steamapps\common\dark souls prepare to die edition\data\data.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{BBDFA6D6-9250-4DB2-A2A7-16244D8EF4E3}E:\steamlibrary\steamapps\common\dark souls prepare to die edition\data\data.exe" [In-None-P17-TRUE] .(...) -- E:\steamlibrary\steamapps\common\dark souls prepare to die edition\data\data.exe (.not file.) =>.Steam Games
O87 - FAEL: "{95C11CDB-E464-4BB6-939E-4546CD143AA9}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Terraria\Terraria.exe (.not file.) =>.Steam Games
O87 - FAEL: "{86144603-A2E6-4351-BFBD-530835A7B474}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Terraria\Terraria.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{9E6B56F6-AB33-46CC-BBE9-B0FDB8E0DD95}E:\steamlibrary\steamapps\common\dark void\nativepc\binaries\shippingpc-skygame.exe" [In-None-P6-TRUE] .(...) -- E:\steamlibrary\steamapps\common\dark void\nativepc\binaries\shippingpc-skygame.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{0DDBC61C-9DED-4BB3-B32C-38E221C66FB0}E:\steamlibrary\steamapps\common\dark void\nativepc\binaries\shippingpc-skygame.exe" [In-None-P17-TRUE] .(...) -- E:\steamlibrary\steamapps\common\dark void\nativepc\binaries\shippingpc-skygame.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{FBB87EDD-28A9-43B0-AAEC-828F4715B38E}E:\steamlibrary\steamapps\common\the stanley parable demo\stanley.exe" [In-None-P6-TRUE] .(...) -- E:\steamlibrary\steamapps\common\the stanley parable demo\stanley.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{46B611EA-36C3-4D72-B448-888F64440D85}E:\steamlibrary\steamapps\common\the stanley parable demo\stanley.exe" [In-None-P17-TRUE] .(...) -- E:\steamlibrary\steamapps\common\the stanley parable demo\stanley.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{D46F7C79-0118-4B4B-B431-9C6D8E06FF6A}E:\steamlibrary\steamapps\common\the stanley parable\stanley.exe" [In-None-P6-TRUE] .(...) -- E:\steamlibrary\steamapps\common\the stanley parable\stanley.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{20BBA33D-BDE3-4499-932C-3722589121D1}E:\steamlibrary\steamapps\common\the stanley parable\stanley.exe" [In-None-P17-TRUE] .(...) -- E:\steamlibrary\steamapps\common\the stanley parable\stanley.exe (.not file.) =>.Steam Games
O87 - FAEL: "{AA0EDE20-6A55-4894-8E84-35043E6A1B8E}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Grand Theft Auto 3\gta3.exe (.not file.) =>.Steam Games
O87 - FAEL: "{FA73D114-8FF1-4392-95F9-004B11FDFFEB}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Grand Theft Auto 3\gta3.exe (.not file.) =>.Steam Games
O87 - FAEL: "{3FC23F48-770E-4701-A5A3-88647DE975A0}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Need for Speed Hot Pursuit\Support\EA Help\Electronic_Arts_Technical_Support.htm (.not file.) =>.Steam Games
O87 - FAEL: "{A66E4E5D-A5E5-43A1-A89B-8D500C7A84AF}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Need for Speed Hot Pursuit\Support\EA Help\Electronic_Arts_Technical_Support.htm (.not file.) =>.Steam Games
O87 - FAEL: "{DB745647-2624-44D6-AD10-0AB1144EA0B1}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Dishonored\Binaries\Win32\Dishonored.exe (.not file.) =>.Steam Games
O87 - FAEL: "{BAFB006C-3E7B-43A8-8838-05329222EED9}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Dishonored\Binaries\Win32\Dishonored.exe (.not file.) =>.Steam Games
O87 - FAEL: "{7CCF4DA0-3DDD-4A45-AF0C-8ACE468A9981}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Deadlight\Binaries\Win32\LOTDGame.exe (.not file.) =>.Steam Games
O87 - FAEL: "{B0FB17D9-CEFE-4615-895D-44888B0EAFC1}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Deadlight\Binaries\Win32\LOTDGame.exe (.not file.) =>.Steam Games
O87 - FAEL: "{9DC5221B-3868-4E9D-92E5-B2B4B67AC4FD}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\I am Alive\src\SYSTEM\IAmAlive_game.exe (.not file.) =>.Steam Games
O87 - FAEL: "{3BD9ED08-3921-43FF-8C29-D7A8458F1B02}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\I am Alive\src\SYSTEM\IAmAlive_game.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{07226273-76B1-4CD1-B26A-39758B493F03}C:\program files (x86)\steam\steamapps\common\outlast\binaries\win64\olgame.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\outlast\binaries\win64\olgame.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{B2B83313-42E5-4167-8A12-F57CFBFD47C4}C:\program files (x86)\steam\steamapps\common\outlast\binaries\win64\olgame.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\outlast\binaries\win64\olgame.exe (.not file.) =>.Steam Games
O87 - FAEL: "{DB6442BA-EA39-4B67-9416-1E97647C8156}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\BioShock Infinite\Binaries\Win32\Benchmark.bat (.not file.) =>.Steam Games
O87 - FAEL: "{D87267BE-0A85-486B-A30B-B2876E0456AB}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\BioShock Infinite\Binaries\Win32\Benchmark.bat (.not file.) =>.Steam Games
O87 - FAEL: "{E09C2643-42AE-4C10-9BEC-5B5E9D9DE2F9}" [In-None-P6-TRUE] .(...) -- E:\Steam\steamapps\common\Batman Arkham City GOTY\RunLauncher.bat (.not file.) =>.Steam Games
O87 - FAEL: "{7E57FE9E-8780-4643-8419-CB5A568E60B4}" [In-None-P17-TRUE] .(...) -- E:\Steam\steamapps\common\Batman Arkham City GOTY\RunLauncher.bat (.not file.) =>.Steam Games
O87 - FAEL: "{2CE64809-1C61-4B5A-BDA9-05A263E4D787}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\BioShock Infinite\Binaries\Win32\Benchmark.bat (.not file.) =>.Steam Games
O87 - FAEL: "{E9F4E79D-F2EF-4F0E-AC40-526CA4BC1E0A}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\BioShock Infinite\Binaries\Win32\Benchmark.bat (.not file.) =>.Steam Games
O87 - FAEL: "{7CDD36FA-7799-4FAA-8C8E-EEE051B3C7C9}" [In-None-P6-TRUE] .(...) -- E:\Steam\steamapps\common\Grand Theft Auto Vice City\gta-vc.exe =>.Steam Games
O87 - FAEL: "{1B883CB0-C34B-4187-945C-2F453F9A6621}" [In-None-P17-TRUE] .(...) -- E:\Steam\steamapps\common\Grand Theft Auto Vice City\gta-vc.exe =>.Steam Games
O87 - FAEL: "{4CC4FEEF-E93D-424C-B97D-07998530494A}" [In-None-P6-TRUE] .(...) -- E:\Steam\steamapps\common\Antichamber\Binaries\Win32\UDK.exe (.not file.) =>.Steam Games
O87 - FAEL: "{98015833-E0E8-4DD7-BB70-120235DD02D1}" [In-None-P17-TRUE] .(...) -- E:\Steam\steamapps\common\Antichamber\Binaries\Win32\UDK.exe (.not file.) =>.Steam Games
O87 - FAEL: "{C88B3AC1-1663-454A-9EC6-55359CF050AA}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Mass Effect 2\Binaries\MassEffect2.exe (.not file.)
O87 - FAEL: "{6506CDF0-D4B6-4078-8ADF-BD718D2E9C00}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Mass Effect 2\Binaries\MassEffect2.exe (.not file.)
O87 - FAEL: "{376D6A16-D1CB-4857-9207-1AF4FF6A3C9B}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Mass Effect 2\MassEffect2Launcher.exe (.not file.)
O87 - FAEL: "{F8469B06-FC0A-4F7A-8210-FB90DB565B17}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Mass Effect 2\MassEffect2Launcher.exe (.not file.)
O87 - FAEL: "TCP Query User{485CB6CF-B20F-437D-AAE3-7D28A0572E6B}E:\guild wars 2\gw2.exe" [In-None-P6-TRUE] .(...) -- E:\guild wars 2\gw2.exe (.not file.)
O87 - FAEL: "UDP Query User{87DCCC5D-5549-4228-9FFD-174C3AA67BAE}E:\guild wars 2\gw2.exe" [In-None-P17-TRUE] .(...) -- E:\guild wars 2\gw2.exe (.not file.)
O87 - FAEL: "{1358E2F9-0901-4800-B7A6-6EB4EEC18531}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Sniper Elite V2\bin\SniperEliteV2.exe (.not file.) =>.Steam Games
O87 - FAEL: "{A9C3D5B7-3E8E-461E-BA66-39123060AEB4}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Sniper Elite V2\bin\SniperEliteV2.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{FD7777A1-47F0-4CEC-8D35-23A355E49A9C}C:\program files (x86)\steam\steamapps\common\nether\game\binaries\win64\nether.exe" [In-None-P6-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\nether\game\binaries\win64\nether.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{A7389DD9-C8B0-4BA8-BD2D-14B483362A0D}C:\program files (x86)\steam\steamapps\common\nether\game\binaries\win64\nether.exe" [In-None-P17-TRUE] .(...) -- C:\program files (x86)\steam\steamapps\common\nether\game\binaries\win64\nether.exe (.not file.) =>.Steam Games
O87 - FAEL: "{ADD6F303-5E8F-4E24-AAC8-66462F7FC620}" [In-None-P6-TRUE] .(...) -- E:\Tom Clancy's Ghost Recon Future Soldier\Future Soldier DX11.exe (.not file.)
O87 - FAEL: "{9C6968BD-9CB8-4EC4-92CE-16044FB65189}" [In-None-P17-TRUE] .(...) -- E:\Tom Clancy's Ghost Recon Future Soldier\Future Soldier DX11.exe (.not file.)
O87 - FAEL: "{C1CE0599-9BA6-49DF-88E9-AE199CE4DBAB}" [In-None-P6-TRUE] .(...) -- E:\Tom Clancy's Ghost Recon Future Soldier\Future Soldier DX9.exe (.not file.)
O87 - FAEL: "{AF8081E1-0CE5-4148-B888-7448D8748426}" [In-None-P17-TRUE] .(...) -- E:\Tom Clancy's Ghost Recon Future Soldier\Future Soldier DX9.exe (.not file.)
O87 - FAEL: "{B4D5A631-CA2F-4854-AE69-7D15C7B89EC0}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\alan wake\AlanWake.exe (.not file.) =>.Steam Games
O87 - FAEL: "{2B37343D-BF39-44F8-BF25-A8E8732EBC7E}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\alan wake\AlanWake.exe (.not file.) =>.Steam Games
O87 - FAEL: "{0747F4A5-CFFD-42F3-975A-EFE8C149743F}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\bin\steamwebhelper.exe (.not file.)
O87 - FAEL: "{DF3F8CD9-1939-4D4E-BF3C-02B362DD110F}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\bin\steamwebhelper.exe (.not file.)
O87 - FAEL: "{C527F45C-BEB3-4D40-B73B-0D5E1007E612}" [In-None-P6-TRUE] .(...) -- E:\Steam\steamapps\common\Portal 2\portal2.exe =>.Steam Games
O87 - FAEL: "{067A4844-87F3-4DBE-B20A-3B1F15F58A04}" [In-None-P17-TRUE] .(...) -- E:\Steam\steamapps\common\Portal 2\portal2.exe =>.Steam Games
O87 - FAEL: "{A19B4930-3C6E-43F8-8D8B-AF8D13189A18}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Metro Last Light\MetroLL.exe (.not file.) =>.Steam Games
O87 - FAEL: "{0593C150-85A4-4265-A73C-4274F6AC197D}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\Metro Last Light\MetroLL.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{6E5A4724-F974-48AF-B2D4-BB450C73E383}E:\steam\steamapps\common\grand theft auto iv\gtaiv\gtaiv.exe" [In-None-P6-TRUE] .(...) -- E:\steam\steamapps\common\grand theft auto iv\gtaiv\gtaiv.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{F88F6ABD-4045-4BA8-93B1-23887A404A1E}E:\steam\steamapps\common\grand theft auto iv\gtaiv\gtaiv.exe" [In-None-P17-TRUE] .(...) -- E:\steam\steamapps\common\grand theft auto iv\gtaiv\gtaiv.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{5274B88B-1C3A-48BF-AE5F-E5CF997A1EE1}E:\steam\steamapps\common\the vanishing of ethan carter\binaries\win64\astronautsgame-win64-shipping.exe" [In-None-P6-TRUE] .(...) -- E:\steam\steamapps\common\the vanishing of ethan carter\binaries\win64\astronautsgame-win64-shipping.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{E2B698F3-AC04-4F48-9D4B-4C114ADBA35F}E:\steam\steamapps\common\the vanishing of ethan carter\binaries\win64\astronautsgame-win64-shipping.exe" [In-None-P17-TRUE] .(...) -- E:\steam\steamapps\common\the vanishing of ethan carter\binaries\win64\astronautsgame-win64-shipping.exe (.not file.) =>.Steam Games
O87 - FAEL: "{C8F04B73-6E78-40C2-B7A3-1BF2346D7D46}" [In-None-P6-TRUE] .(...) -- E:\Steam\steamapps\common\Dream\Binaries\Win32\Dream.exe (.not file.) =>.Steam Games
O87 - FAEL: "{95A68B81-692F-4A34-8332-BB73B06B76EB}" [In-None-P17-TRUE] .(...) -- E:\Steam\steamapps\common\Dream\Binaries\Win32\Dream.exe (.not file.) =>.Steam Games
O87 - FAEL: "{48EBD326-8AA3-4667-BA1C-970392B9E40D}" [In-None-P6-TRUE] .(...) -- E:\Steam\steamapps\common\Dream\_Rift\Binaries\Win32\DreamRift.exe (.not file.) =>.Steam Games
O87 - FAEL: "{E3E5E6E6-0B2A-4EE7-8B56-F5C907F4EBBE}" [In-None-P17-TRUE] .(...) -- E:\Steam\steamapps\common\Dream\_Rift\Binaries\Win32\DreamRift.exe (.not file.) =>.Steam Games
O87 - FAEL: "{0C64E46A-AA1F-44E3-BE35-DF0F53537BB7}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Ubisoft\Assassin's Creed Revelations\ACRMP.exe (.not file.)
O87 - FAEL: "{401F137B-EFE0-4A80-9D6C-8684DC50F8B4}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Ubisoft\Assassin's Creed Revelations\ACRMP.exe (.not file.)
O87 - FAEL: "TCP Query User{7E7C60E4-401A-447C-A340-8321CF56F4F1}E:\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe" [In-None-P6-TRUE] .(...) -- E:\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{F5DB8D48-2494-497A-88CE-7B7E73D2F34D}E:\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe" [In-None-P17-TRUE] .(...) -- E:\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe (.not file.) =>.Steam Games
O87 - FAEL: "TCP Query User{F925EC34-0BFA-48CB-B7E2-CADE99C2CD3E}E:\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe" [In-None-P6-TRUE] .(...) -- E:\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe (.not file.) =>.Steam Games
O87 - FAEL: "UDP Query User{12957E6D-2F2C-45CE-8753-ADB24E16E0D8}E:\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe" [In-None-P17-TRUE] .(...) -- E:\steam\steamapps\common\dragon age ultimate edition\bin_ship\daorigins.exe (.not file.) =>.Steam Games
O87 - FAEL: "{0A45A649-448B-4264-B0E4-AB934ED3D6EE}" [In-None-P6-TRUE] .(...) -- E:\Steam\steamapps\common\Cities_Skylines\Cities.exe =>.Steam Games
O87 - FAEL: "{4D2EF20F-E111-4DB9-A0E8-7BCDA808710D}" [In-None-P17-TRUE] .(...) -- E:\Steam\steamapps\common\Cities_Skylines\Cities.exe =>.Steam Games
O87 - FAEL: "{8AF7EE0B-95AE-4A18-B794-860FB0B5DBDB}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\POSTAL2Complete\System\Launcher.exe (.not file.) =>.Steam Games
O87 - FAEL: "{EF093121-8E49-493C-A28C-A9BA91775688}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\POSTAL2Complete\System\Launcher.exe (.not file.) =>.Steam Games
O87 - FAEL: "{D979F436-E790-4528-A83E-18A132D0DB23}" [In-None-P6-TRUE] .(...) -- C:\Windows\SysWOW64\PnkBstrA.exe (.not file.)
O87 - FAEL: "{63C6E32B-21D9-483D-9450-DBD99120DB27}" [In-None-P17-TRUE] .(...) -- C:\Windows\SysWOW64\PnkBstrA.exe (.not file.)
O87 - FAEL: "{8AB3C85E-3A9F-4265-9F29-19743E73B344}" [In-None-P6-TRUE] .(...) -- C:\Windows\SysWOW64\PnkBstrB.exe (.not file.)
O87 - FAEL: "{3DBF99E7-F489-49D6-BD22-5D6AC5F7DE98}" [In-None-P17-TRUE] .(...) -- C:\Windows\SysWOW64\PnkBstrB.exe (.not file.)
O87 - FAEL: "{8A233DC0-7764-4E09-A2B1-BF9CF06BD290}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\paranormal\PT2\WindowsNoEditor\ParanormalPT2.exe (.not file.) =>.Steam Games
O87 - FAEL: "{7607FC37-7357-41D9-A986-F9C9492821D5}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\paranormal\PT2\WindowsNoEditor\ParanormalPT2.exe (.not file.) =>.Steam Games
O87 - FAEL: "{315E4CDC-BBB8-41B5-BCAF-ADA051071356}" [In-None-P6-TRUE] .(...) -- E:\Steam\steamapps\common\Dark Souls Prepare to Die Edition\DATA\DARKSOULS.exe (.not file.) =>.Steam Games
O87 - FAEL: "{DA510E3D-71DD-49E1-8BF1-196F720DA10A}" [In-None-P17-TRUE] .(...) -- E:\Steam\steamapps\common\Dark Souls Prepare to Die Edition\DATA\DARKSOULS.exe (.not file.) =>.Steam Games
O87 - FAEL: "{14B6A4CA-46FE-4E0A-9663-CEA53E3A0EAB}" [In-None-P6-TRUE] .(...) -- E:\Steam\steamapps\common\Risen 3\system\Risen3.exe (.not file.) =>.Steam Games
O87 - FAEL: "{5E0537FE-DA6B-45D1-A481-650EF2937BA2}" [In-None-P17-TRUE] .(...) -- E:\Steam\steamapps\common\Risen 3\system\Risen3.exe (.not file.) =>.Steam Games
O87 - FAEL: "{DE33D55F-80FC-4C65-B329-E469CDC4347C}" [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\paranormal\Binaries\Win32\UDK.exe (.not file.) =>.Steam Games
O87 - FAEL: "{F4013729-C8F4-4D42-9FC4-53EB5C6F81FC}" [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Steam\steamapps\common\paranormal\Binaries\Win32\UDK.exe (.not file.) =>.Steam Games
---\\ Additional Scan (O88) (2) - 1s
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A} =>Riskware.QuickTime
HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A} =>Riskware.QuickTime
---\\ Summary of the elements found (2) - 0s
https://nicolascoolman.eu/2017/02/02/superfluous-cloudfrontnet/ =>.Superfluous.CloudfrontNet
https://nicolascoolman.eu/2017/01/15/riskware-quicktime/ =>Riskware.QuickTime
~ Unselected Options:
~ End of the scan, 96334 items in 04mn43s (1567)(0)
OK. I will have a look at this latest log and let you know it will take a few hours cause I'm about to go to sleep. Whenever I wake up I will get back to you.
Make sure and update all of your old programs with Patch My PC
ZHP Diag Fix.
ZHP Fix
  • Disable your antivirus prior to this fix!
  • Download ZHP-Fix from here.
  • UnZip it to your desktop -- Tool Here if needed.... 7-Zip
  • Install it.
  • Click Suivant 5 Times.
  • Then Installer.
  • Then Terminer.
  • Then right clcick the ZHP Fix icon Run as admin.
  • Copy the entire content of the code box below, the next step will grab it from your clipboard.
  • Then click on import.
  • Then click GO.
  • If you see any Prompts like the one below, select Oui. = Yes in French.
  • upload_2017-5-24_21-17-40-png.2248
  • Allow completion.
  • A log file will appear on your desktop.
  • Post it here in your next reply.\
Code:
Script ZhpFix
SysRestore
EmptyFlash
ProxyFix
EmptyCLSID
SS - Disabl [11/12/2014] [ 315496] Mozilla Maintenance Service (MozillaMaintenance) . (.Mozilla Foundation.) - C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe =>.Mozilla Corporation®
SS - Disabl [11/12/2014] [ 315496] Skype Updater (SkypeUpdate) . (.Skype Technologies.) - C:\Program Files (x86)\Skype\Updater\Updater.exe =>.Skype Software Sarl®
O39 - APT: {3D085530-2A46-48C6-BA7D-1EFCA89A122A} - (.BioWare.) -- C:\windows\System32\Tasks\{3D085530-2A46-48C6-BA7D-1EFCA89A122A} [3162] =>.BioWare®
O39 - APT: {C0D69CF6-BA5F-4BAD-9611-508F1BCCD3DB} - (.InstallShield Software Corporation.) -- C:\windows\System32\Tasks\{C0D69CF6-BA5F-4BAD-9611-508F1BCCD3DB} [3168] =>.InstallShield Software Corporation
O39 - APT: Unknown - (...) -- C:\windows\System32\Tasks\{E6CB6FCE-9395-48B7-BD65-2D38296B68C6} [3276]
G0 - GCSP: Preferences [User Data\Default][HomePage] http://ajax.googleapis.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://apis.google.com =>.Google Inc.
G0 - GCSP: G0 - GCSP: Preferences [User Data\Default][HomePage] http://ssl.gstatic.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.google-analytics.com =>.Google Inc.Preferences [User Data\Default][HomePage] http://d31qbv1cthcecs.cloudfront.net =>.Superfluous.CloudfrontNet
G0 - GCSP: Preferences [User Data\Default][HomePage] http://d5nxst8fruw4z.cloudfront.net =>.Superfluous.CloudfrontNet
O3 - Toolbar: 0xB1C218236549D4119B18009027A5CD4F - [HKCU]{2318C2B1-4965-11D4-9B18-009027A5CD4F} . (...) -- (.not file.)
O18 - Handler: livecall [64Bits] - {828030A1-22C1-4009-854F-8E305202313F} . (...) -- C:\Program Files (x86)\Windows Live\Messenger\msgrapp.dll (.not file.)
O18 - Handler: msnim [64Bits] - {828030A1-22C1-4009-854F-8E305202313F} . (...) -- C:\Program Files (x86)\Windows Live\Messenger\msgrapp.dll (.not file.)
O42 - Logiciel: Mozilla Maintenance Service - (.Mozilla.) [HKLM][64Bits] -- MozillaMaintenanceService =>.Mozilla
O42 - Logiciel: TOSHIBA DVD PLAYER - (.TOSHIBA Corporation.) [HKLM][64Bits] -- {6C5F3BDC-0A1B-4436-A696-5939629D5C31} =>.Macrovision Corporation®
O42 - Logiciel: TOSHIBA HDD Protection - (.TOSHIBA Corporation.) [HKLM][64Bits] -- {94A90C69-71C1-470A-88F5-AA47ECC96B40} =>.Toshiba Corporation
O42 - Logiciel: TOSHIBA HDD/SSD Alert - (.TOSHIBA Corporation.) [HKLM][64Bits] -- {D4322448-B6AF-4316-B859-D8A0E84DCB38} =>.Toshiba Corporation
O42 - Logiciel: TOSHIBA HDD/SSD Alert - (.TOSHIBA Corporation.) [HKLM][64Bits] -- InstallShield_{D4322448-B6AF-4316-B859-D8A0E84DCB38} =>.Toshiba Corporation
O42 - Logiciel: TOSHIBA Supervisor Password - (.Toshiba Corporation.) [HKLM][64Bits] -- InstallShield_{CBD6B23D-41D5-4A46-8019-6208516C9712} =>.Toshiba Corporation
O42 - Logiciel: TOSHIBA Supervisor Password - (.TOSHIBA.) [HKLM][64Bits] -- {CBD6B23D-41D5-4A46-8019-6208516C9712} =>.Toshiba
O43 - CFD: 28/02/2011 - [0] D -- C:\Program Files (x86)\Common Files\Symantec Shared =>.Symantec Corporation
EmptyTemp
Full Zemana Scan.
Zemana Deep Scan
    • Right click on Zemana and run as admin.
    • Click the Cog/Sproket Wheel, at the top right of Zemana
    • Select Advanced - I have read the warning and wish to proceed.
    • Place a tick next to Detect Suspicious (Root CA) Certificates.
    • Then click the house icon in Zemana.
    • Then hit your start button at the lower left hand corner of your desktop.
    • Then left click on Computer.
    • Drag Local Disk C: or whichever drive you decide to check first.
    • Into the area of Zemana that reads Drag and drop files here to scan them.
    • Once the scan has completed click graph icon on the top right of the programs User interface.
    • Double click to open the latest log-file.
    • Copy it to your clipboard.
    • Post the log here in your next reply.
Eliminate restrictive settings with this tool.
  • Temporarily disable your antivirus --- Your antivirus may flag this tool as malware, it is safe to run I assure you.
  • Download SupRestric.exe save to your desktop.
  • Close all running programs.
  • Double click the file to launch it.
  • Windows: 7/8/10 Vista and run as administrator
  • Click Yes at any prompt.
  • The analysis takes only a few moments.
  • The report is on the desktop ( CTR.txt )
  • Copy paste report in next reply.
  • A reboot is needed to complete the repairs.
HijackThis.
1- Please Click HERE to download HijackThis. -- Unzip to your desktop.
2- Right click run as admin.
5- Copy paste the log here.
Oh so you found more malware? Sorry about the late reply, I just saw this post. There's a weird thing happening with my browser, it wipes all the history when I log off, that wasn't happening before starting the cleanup we've been doing. Do one of the programs I installed do that?
Go ahead and complete the scans, as far as your browsing history being cleaned, CCleaner is set to do that.
Okay then, I've just downloaded all those programs you just provided. I'll complete the scans now.
Hi sorry about disappearing for a bit, I started a new job and that's been consuming a lot of my time.
I began with the Zemana scan and my laptop crashed in the middle of it. I have a day off today so I'm going to do all the scans and everything you recommended today. Also I thought I should mention, my laptop seems to often crash when the power setting is on "Balanced", if it's on "Power Saver" it doesn't crash, not sure if that means anything to you. I'll keep you posted today.
Ok, we will dive into that issue once everything else is done. :)
Once you have completed everything else, I'd like to see a Speccy log to give me an idea about the above issue.
Speccy Scan.
  • Upon Completion:
  • Hit File
  • Publish Snap Shot
Okay here are the ZHP Fix log,the Zemana log and the HiJackThis log. The SupRestric program didn't work, it came up with the attached error. I redownloaded the program, made sure and everything was closed and it still came up with the error:
Rapport de ZHPFix 2015.10.19.9 par Nicolas Coolman, Update du 19/10/2015
Fichier d'export Registre :
Run by Juancho at 20/06/2017 8:56:44 PM
High Elevated Privileges : OK
Windows 7 Home Premium Edition, 64-bit Service Pack 1 (Build 7601)
Recycle Bin emptied (02mn AMs)
========== Registry values ==========
ProxyFix : Proxy configuration successfully removed
REMOVES ProxyServer Value
REMOVES ProxyEnable Value
REMOVES EnableHttp1_1 Value
REMOVES ProxyHttp1.1 Value
REMOVES ProxyOverride Value
========== Elements of the registry data ==========
ERROR CLSID PAPP: {828030A1-22C1-4009-854F-8E305202313F}
========== Preferences browser ==========
NOW Chrome File: C:\Users\Juancho\AppData\Local\Google\Chrome\User Data\Default\Preferences
ABSENT Chrome Site: http://ajax.googleapis.com
ABSENT Chrome Site: http://apis.google.com
ABSENT Chrome Site: http://ssl.gstatic.com
ABSENT Chrome Site: http://www.google-analytics.com
ABSENT Chrome Site: http://d5nxst8fruw4z.cloudfront.net
========== Folders ==========
No folders empty CLSID Local user
Deletes temporary Windows (7)
========== Files ==========
REMOVES Flash Cookies (0) (0 octets)
REMOVES Reboot: c:\windows\system32\tasks\{3d085530-2a46-48c6-ba7d-1efca89a122a}
REMOVES Reboot: c:\windows\system32\tasks\{c0d69cf6-ba5f-4bad-9611-508f1bccd3db}
Deletes temporary Windows (23) (59,226 octets)
========== System restore ==========
The system successfully created restore point
========== Summary ==========
6 : Registry values
1 : Elements of the registry data
2 : Folders
4 : Files
10 : Preferences browser
1 : System restore
End of clean in 47mn AMs
========== Path to file report ==========
C:\Users\Juancho\AppData\Roaming\ZHP\ZHPFix[R1].txt - 10/06/2017 10:08:23 PM [6660]
C:\Users\Juancho\AppData\Roaming\ZHP\ZHPFix[R2].txt - 15/06/2017 9:52:04 PM [2816]
C:\Users\Juancho\AppData\Roaming\ZHP\ZHPFix[R3].txt - 20/06/2017 8:56:47 PM [2253]
Zemana AntiMalware 2.74.2.49 (Installed)
Scan Result : Completed
Scan Date : 2017/6/20
Operating System : Windows 7 64-bit
Processor : 8X Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz
BIOS Mode : Legacy
CUID : 12DF606E0EB9646A1D5D23
Scan Type : Custom Scan
Duration : 309m 57s
Scanned Objects : 355654
Detected Objects : 3
Excluded Objects : 0
Read Level : SCSI
Auto Upload : Enabled
Detect All Extensions : Disabled
Scan Documents : Disabled
Domain Info : WORKGROUP,0,2
Detected Objects
loader.exe
Status : Scanned
Object : %programfiles%\total uninstall 5\loader.exe
MD5 : A7E72A4FAF4D880FF671F6E88418AD56
Publisher : -
Version : -
Detection : PUA:Win32/SoftCrack.Gen
Cleaning Action : Quarantine
Related Objects :
File - %programfiles%\total uninstall 5\loader.exe
Reference - C:\Users\Juancho\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Total Uninstall 5.lnk
patch2_0_EFIGS.exe
Status : Scanned
Object : %userprofile%\documents\witcher 2\downloads\patch2_0_efigs.exe
MD5 : C5E82B1C48879E76404B8A25342F7730
Publisher : -
Version : 0.0.0.0
Detection : Malware:Win32/Cardunia.A!Eret
Related Objects :
File - %userprofile%\documents\witcher 2\downloads\patch2_0_efigs.exe
mscss7cm_es.dub
Status : Failed
Object : %programfiles%\microsoft office\office14\mscss7cm_es.dub
MD5 : 8AB6DC7B7ED467E467683074884ADBE6
Publisher : -
Version : 14.0.7140.5000
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\mscss7cm_es.dub
mscss7cm_en.dub
Status : Failed
Object : %programfiles%\microsoft office\office14\mscss7cm_en.dub
MD5 : 535B807E95EB36D0CAF548482D20BD5D
Publisher : -
Version : 14.0.7157.5000
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\mscss7cm_en.dub
MSTORE.HXS
Status : Failed
Object : %programfiles%\microsoft office\office14\1033\mstore.hxs
MD5 : 8C62402378BD312B4D98BD961CE563CA
Publisher : -
Version : 12.0.8416.9
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\1033\mstore.hxs
MSPUB.HXS
Status : Failed
Object : %programfiles%\microsoft office\office14\1033\mspub.hxs
MD5 : D2841AC10C8A4605DE456EE801C89F4D
Publisher : -
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\1033\mspub.hxs
MSOUC.HXS
Status : Failed
Object : %programfiles%\microsoft office\office14\1033\msouc.hxs
MD5 : 2B9BE70CE1ED7570681830B3B66A9347
Publisher : -
Version : 12.0.8511.12
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\1033\msouc.hxs
XOCR3.PSP
Status : Failed
Object : %programfiles%\microsoft office\office14\xocr3.psp
MD5 : 2401FF315D0D5861E74C2445BF3BDF50
Publisher : -
Version : 14.0.6106.5000
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\xocr3.psp
Service Center Setup.exe
Status : Failed
Object : %programfiles%\native instruments\ac box combo\service center setup.exe
MD5 : 251BEC413E0F79E894A5B4F79A469145
Publisher : Native Instruments
Version : 1.0.0.0
Detection :
Related Objects :
File - %programfiles%\native instruments\ac box combo\service center setup.exe
ONENOTE.HXS
Status : Failed
Object : %programfiles%\microsoft office\office14\1033\onenote.hxs
MD5 : 31F98C6C4420FEA3591BD7574095685E
Publisher : -
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\1033\onenote.hxs
mscss7wre_fr.dub
Status : Failed
Object : %programfiles%\microsoft office\office14\mscss7wre_fr.dub
MD5 : A30BAB83197BD92163433915A9248626
Publisher : -
Version : 14.0.7136.5000
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\mscss7wre_fr.dub
mscss7wre_es.dub
Status : Failed
Object : %programfiles%\microsoft office\office14\mscss7wre_es.dub
MD5 : FC80A472A7238966F00E088E31209903
Publisher : -
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\mscss7wre_es.dub
mscss7wre_en.dub
Status : Failed
Object : %programfiles%\microsoft office\office14\mscss7wre_en.dub
MD5 : 5CD4493A10C4C49D995782453B186E59
Publisher : -
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\mscss7wre_en.dub
OIS.HXS
Status : Failed
Object : %programfiles%\microsoft office\office14\1033\ois.hxs
MD5 : 6DC7B1411C47A3AC7E2E4C6ECCDCB605
Publisher : -
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\1033\ois.hxs
mscss7cm_fr.dub
Status : Failed
Object : %programfiles%\microsoft office\office14\mscss7cm_fr.dub
MD5 : 258F9719F83FD947E555D3335FC8CAC4
Publisher : -
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\mscss7cm_fr.dub
stpass.ENU
Status : Failed
Object : %programfiles%\kaspersky lab\kaspersky pure 3.0\kaspersky password manager\stpass.enu
MD5 : 810D63CDBD07214BF25EFE32FDF6A495
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\kaspersky lab\kaspersky pure 3.0\kaspersky password manager\stpass.enu
stpass.ENU.ap
Status : Failed
Object : %programfiles%\kaspersky lab\kaspersky pure 3.0\kaspersky password manager\stpass.enu.ap
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\kaspersky lab\kaspersky pure 3.0\kaspersky password manager\stpass.enu.ap
WINWORD.HXS
Status : Failed
Object : %programfiles%\microsoft office\office14\1033\winword.hxs
MD5 : 5FF87F6BF944FCD7040C201219B7FFC6
Publisher : -
Version : 12.0.8511.14
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\1033\winword.hxs
spCapBtn.ENU
Status : Failed
Object : %programfiles%\kaspersky lab\kaspersky pure 3.0\kaspersky password manager\spcapbtn.enu
MD5 : CCC4BDCDF474508F9C8937B15283102B
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\kaspersky lab\kaspersky pure 3.0\kaspersky password manager\spcapbtn.enu
spCapBtn.ENU.ap
Status : Failed
Object : %programfiles%\kaspersky lab\kaspersky pure 3.0\kaspersky password manager\spcapbtn.enu.ap
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\kaspersky lab\kaspersky pure 3.0\kaspersky password manager\spcapbtn.enu.ap
OUTLOOK.HXS
Status : Failed
Object : %programfiles%\microsoft office\office14\1033\outlook.hxs
MD5 : 19A800721016F0D30F46D51C8E435FBF
Publisher : -
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\1033\outlook.hxs
ACBoxCombo.dll
Status : Failed
Object : %programfiles%\native instruments\ac box combo\vstplugins\acboxcombo.dll
MD5 : 97CF42C3C48ACDEB7D7A23409F541212
Publisher : -
Version : 1.1.1.2
Detection :
Related Objects :
File - %programfiles%\native instruments\ac box combo\vstplugins\acboxcombo.dll
ISSetup.dll
Status : Failed
Object : %programfiles%\installshield installation information\{50f68032-b5b7-4513-9116-c978dbd8f27a}\issetup.dll
MD5 : D97C9231E205DE92BE61CF33EC157FC7
Publisher : -
Version : 12.0.0.58851
Detection :
Related Objects :
File - %programfiles%\installshield installation information\{50f68032-b5b7-4513-9116-c978dbd8f27a}\issetup.dll
ISSetup.dll
Status : Failed
Object : %programfiles%\installshield installation information\{f2004b8d-7791-4b35-a3fa-d8ca8bb4dd81}\issetup.dll
Publisher : -
Detection :
Related Objects :
File - %programfiles%\installshield installation information\{f2004b8d-7791-4b35-a3fa-d8ca8bb4dd81}\issetup.dll
Launcher.exe
Status : Failed
Object : %programfiles%\eidos\kane and lynch dead men\launcher.exe
MD5 : E1007C63FE88BEAD5E3145DEC9F4925C
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\eidos\kane and lynch dead men\launcher.exe
Reference - C:\Program Files (x86)\Eidos\Kane and Lynch Dead Men\Launcher-MCE.lnk
SETLANG.HXS
Status : Failed
Object : %programfiles%\microsoft office\office14\1033\setlang.hxs
MD5 : CA60536DCEB319E78A14DBBBDA278232
Publisher : -
Detection :
Related Objects :
File - %programfiles%\microsoft office\office14\1033\setlang.hxs
zlib1.dll
Status : Failed
Object : %programfiles%\intervideo\dvd8\zlib1.dll
MD5 : 95169FEA06F32D21A9C4C8F79305543A
Publisher : -
Version : 1.2.2.0
Detection :
Related Objects :
File - %programfiles%\intervideo\dvd8\zlib1.dll
IAStorDataMgr.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\de-de\iastordatamgr.resources.dll
MD5 : 0FF872347CBE03E14F3C5E3A765A289C
Publisher : -
Version : 9.5.6.1002
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\de-de\iastordatamgr.resources.dll
IntelVisualDesign.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\da-dk\intelvisualdesign.resources.dll
MD5 : F56FAC5AACACA533C9F96205F3C76F2F
Publisher : -
Version : 0.0.0.0
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\da-dk\intelvisualdesign.resources.dll
IAStorUtil.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastorutil.resources.dll
MD5 : 8EB8073D7B91929F2DF2E4AB8F8FFD6B
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastorutil.resources.dll
IAStorUIHelper.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastoruihelper.resources.dll
MD5 : 366F40E66248BF7BCBC9605E3093815C
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastoruihelper.resources.dll
IAStorUI.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastorui.resources.dll
MD5 : 473D3DC22817C0D5874D4265E4E916D4
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastorui.resources.dll
IAStorIcon.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastoricon.resources.dll
MD5 : 0140F35C626D5B268FBD8AD06F6DB4DA
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastoricon.resources.dll
IAStorHelp.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastorhelp.resources.dll
MD5 : 2BC9B58288B6714E49BBD6458750017D
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastorhelp.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastordatamgr.resources.dll
MD5 : 571106773F5B460DA6793095CF36B1ED
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\da-dk\iastordatamgr.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\cs-cz\intelvisualdesign.resources.dll
MD5 : F738F71C0ECA3251FFC9CC819DC43866
Publisher : -
Version : 0.0.0.0
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\cs-cz\intelvisualdesign.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastorutil.resources.dll
MD5 : EBEADDED18A2BC23D8D962FC0C755AEE
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastorutil.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastoruihelper.resources.dll
MD5 : AA45AAE457E2CDDB5C17E6B5AB584FEC
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastoruihelper.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastorui.resources.dll
MD5 : 79EC387F0C2E1FDE603E617BC64E02E1
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastorui.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastoricon.resources.dll
MD5 : 7F9F8FF42D236932EB1EDA82299FC14F
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastoricon.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastorhelp.resources.dll
MD5 : D28923A5CAD2FD0562C1ADD623FB442E
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastorhelp.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastordatamgr.resources.dll
MD5 : AF5EC54767B0722CD785174DCB13DDF6
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\cs-cz\iastordatamgr.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\ar-sa\intelvisualdesign.resources.dll
MD5 : 1897339E3BD719D7A71DE75D2D8D12EC
Publisher : -
Version : 0.0.0.0
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\ar-sa\intelvisualdesign.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastorutil.resources.dll
MD5 : 7EBADB7BEA5F8907915CE340812BD64A
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastorutil.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastoruihelper.resources.dll
MD5 : F68B2136B49650A7B00D8FD1BDA199B3
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastoruihelper.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastorui.resources.dll
MD5 : 7AA37E2C5C3A00C7FD60EFDF99C2B3F4
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastorui.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastoricon.resources.dll
MD5 : 30FD70E274C2AC95FA1FC6C7CFC3E0BE
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastoricon.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastorhelp.resources.dll
MD5 : 939AA7F59164DCF11DDA0F4AA9E60A20
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastorhelp.resources.dll
Status : Failed
Object : %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastordatamgr.resources.dll
MD5 : 0CD8F972C2382D1A663CD7BEBDF67731
Publisher : -
Detection :
Related Objects :
File - %programfiles%\intel\intel(r) rapid storage technology\ar-sa\iastordatamgr.resources.dll
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\zh-tw\setupicc.exe.mui
MD5 : 22BF673E3FCFCBF0310CAA2BA5B546C7
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\zh-tw\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\zh-cn\setupicc.exe.mui
MD5 : 9C5348743155DB8404BC5F7C62958482
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\zh-cn\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\tr-tr\setupicc.exe.mui
MD5 : 2C75545BBC883654D567FE2E50009F5D
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\tr-tr\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\th-th\setupicc.exe.mui
MD5 : 93FDE5F614C11CA937C00663F23B3AAE
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\th-th\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\sv-se\setupicc.exe.mui
MD5 : E0388A756D4945DC92EBE7178F25E598
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\sv-se\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\sl-si\setupicc.exe.mui
MD5 : 0332EC3D5172882AF2B80B5089A679F6
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\sl-si\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\sk-sk\setupicc.exe.mui
MD5 : F02CEE9B5055908431F9350D5B0856AB
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\sk-sk\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\ru-ru\setupicc.exe.mui
MD5 : EE67A8F1BE4C77E235D2100259419881
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\ru-ru\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\pt-pt\setupicc.exe.mui
MD5 : A4A4541297FCDAD001ABD7FC3EF50427
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\pt-pt\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\pt-br\setupicc.exe.mui
MD5 : C576D4B1B8C01F54FA8F78233D168625
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\pt-br\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\pl-pl\setupicc.exe.mui
MD5 : C5AC1921ACE8CF179AFD9522DF62AAE8
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\pl-pl\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\nl-nl\setupicc.exe.mui
MD5 : 843D469820232C90AE060385C1242B29
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\nl-nl\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\nb-no\setupicc.exe.mui
MD5 : 6EB4127F41FBF514BAF689A33E3A32C0
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\nb-no\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\ko-kr\setupicc.exe.mui
MD5 : BB7DAA2B5AD624815B1AE4D75EEAEA67
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\ko-kr\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\ja-jp\setupicc.exe.mui
MD5 : 9C39F30DD8599B3D14BC0186D512DD14
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\ja-jp\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\it-it\setupicc.exe.mui
MD5 : 67C4C4F5A008215D319AB4C63D45F7FD
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\it-it\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\hu-hu\setupicc.exe.mui
MD5 : 857662A3A92568FD6CA51200E0A203B0
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\hu-hu\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\he-il\setupicc.exe.mui
MD5 : B37D7A2AA46FAE7E5CFAC9BE7CC02C79
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\he-il\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\fr-fr\setupicc.exe.mui
MD5 : D4BB5182B6F3A76EDAED6892158C6543
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\fr-fr\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\fi-fi\setupicc.exe.mui
MD5 : 81DCF220EDC074C316D92165B2DE5438
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\fi-fi\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\es-es\setupicc.exe.mui
MD5 : FE5D606F8B3A4C7F4A9A0719FB101B4E
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\es-es\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\en-us\setupicc.exe.mui
MD5 : 3DFBC9CB86EA0AE244DE392CD95A6EE6
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\en-us\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\el-gr\setupicc.exe.mui
MD5 : E0374672A025DD40BDB4DC5011A0ABC7
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\el-gr\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\de-de\setupicc.exe.mui
MD5 : 909C2B2F329127CE7CC6748529613E9A
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\de-de\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\da-dk\setupicc.exe.mui
MD5 : 45BC487BE1F5A19DB92DFC0DB6FD48B0
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\da-dk\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\cs-cz\setupicc.exe.mui
MD5 : B83CDFD126FC41B76095DE9EB896EE46
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\cs-cz\setupicc.exe.mui
setupicc.exe.mui
Status : Failed
Object : %programfiles%\intel\intel control center\uninstaller\ar-sa\setupicc.exe.mui
MD5 : ABCB09B222008E5322AB086DE27D83CB
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\intel\intel control center\uninstaller\ar-sa\setupicc.exe.mui
setup.exe
Status : Failed
Object : %programfiles%\installshield installation information\{f2004b8d-7791-4b35-a3fa-d8ca8bb4dd81}\setup.exe
MD5 : 9330845195D1C0A86791D9D89CAADE0A
Publisher : -
Detection :
Related Objects :
File - %programfiles%\installshield installation information\{f2004b8d-7791-4b35-a3fa-d8ca8bb4dd81}\setup.exe
kpmAutofill.crx.ap
Status : Failed
Object : %programfiles%\kaspersky lab\kaspersky pure 3.0\kaspersky password manager\kpmautofill.crx.ap
MD5 : E892F5B27DE561A9D0976C1BCB88FF72
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\kaspersky lab\kaspersky pure 3.0\kaspersky password manager\kpmautofill.crx.ap
SHDocVw.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\shdocvw.dll
MD5 : C846E1EFC425D45EBD945F3CFF5556E7
Publisher : -
Version : 1.1.0.0
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\shdocvw.dll
setup.exe
Status : Failed
Object : %programfiles%\installshield installation information\{d4322448-b6af-4316-b859-d8a0e84dcb38}\setup.exe
MD5 : 67420951983FF681CE93A90AAF9AB479
Publisher : -
Detection :
Related Objects :
File - %programfiles%\installshield installation information\{d4322448-b6af-4316-b859-d8a0e84dcb38}\setup.exe
ServiceData.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\servicedata.dll
MD5 : 5EC4ADD74A4F1BFD04D37AAC0355E48B
Publisher : -
Version : 1.0.0.0
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\servicedata.dll
rscoree.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\rscoree.dll
MD5 : F0C786A21FEFABC396104C329EF8E96B
Publisher : -
Version : 2.0.1.0
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\rscoree.dll
NetDetect.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\netdetect.dll
MD5 : EADA54087B681BB14EE16ADBE2D332C8
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\netdetect.dll
MsHtmHstInterop.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\mshtmhstinterop.dll
MD5 : 668C1AF6DEA0FC60FB8CC8076EEEF98B
Publisher : -
Version : 0.0.0.0
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\mshtmhstinterop.dll
MessengerAPI.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\messengerapi.dll
MD5 : 25467703692CCE924B640321C209466C
Publisher : -
Version : 1.0.0.0
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\messengerapi.dll
GPNET.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\gpnet.dll
MD5 : DCF7D205CB0E4EEB78146BBB28A5563B
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\gpnet.dll
GameSpy.VEngine.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\gamespy.vengine.dll
MD5 : 56E048AC808CA6EA58F5852D5B2F67FE
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\gamespy.vengine.dll
GameSpy.Services.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\gamespy.services.dll
MD5 : 112FD741E7776D1A068D4B9ABC837F2C
Publisher : -
Version : 1.0.2736.25280
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\gamespy.services.dll
GameSpy.Servers.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\gamespy.servers.dll
MD5 : A3329A7D07E44C75B4DA231AF92849EF
Publisher : -
Version : 1.0.2736.25283
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\gamespy.servers.dll
GameSpy.Presence.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\gamespy.presence.dll
MD5 : 6C2A3708EB7737C3AFE81D3BA9AB57D4
Publisher : -
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\gamespy.presence.dll
GameSpy.Core.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\gamespy.core.dll
MD5 : 17E2198B07BD2E0089B3DB50355E60F0
Publisher : -
Version : 1.0.2736.25263
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\gamespy.core.dll
GameSpy.Controls.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\gamespy.controls.dll
MD5 : 0036A3A7B9E53F7C450DDC8148C488A1
Publisher : -
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\gamespy.controls.dll
GameSpy.BuddySync.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\gamespy.buddysync.dll
MD5 : 22E5BDC726D665B102A83039AD06A6AB
Publisher : -
Version : 1.0.2736.25281
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\gamespy.buddysync.dll
ComradeLib.resources.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\fr-fr\comradelib.resources.dll
MD5 : F365B8D544642F53F88D34A795A02F03
Publisher : -
Version : 1.5.0.156
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\fr-fr\comradelib.resources.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\fr\comradelib.resources.dll
MD5 : FBA6B9E6FAF0E8220722BEDD0DA04986
Publisher : -
Version : 1.5.0.156
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\fr\comradelib.resources.dll
GPIProxy.dll
Status : Failed
Object : %programfiles%\intervideo\dvd8\gpiproxy.dll
MD5 : 60FA5438E640367A924742E570D9268C
Publisher : -
Version : 8.0.20.185
Detection :
Related Objects :
File - %programfiles%\intervideo\dvd8\gpiproxy.dll
DetectLib.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\detectlib.dll
MD5 : A2153E085AD430041EF221250B850251
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\detectlib.dll
ISSetup.dll
Status : Failed
Object : %programfiles%\installshield installation information\{d4322448-b6af-4316-b859-d8a0e84dcb38}\issetup.dll
MD5 : 6AB3B00D4E61BD41043C411837A427C7
Publisher : -
Detection :
Related Objects :
File - %programfiles%\installshield installation information\{d4322448-b6af-4316-b859-d8a0e84dcb38}\issetup.dll
ComradeLib.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\comradelib.dll
MD5 : 852EF7663F0A737923690BA38D43D897
Publisher : -
Version : 1.5.0.156
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\comradelib.dll
AxSHDocVw.dll
Status : Failed
Object : %programfiles%\gamespy\comrade\156\axshdocvw.dll
MD5 : 8E807BF384BD9F45D3B29C8728CD057D
Publisher : -
Version : 1.1.0.0
Detection :
Related Objects :
File - %programfiles%\gamespy\comrade\156\axshdocvw.dll
setup.exe
Status : Failed
Object : %programfiles%\installshield installation information\{9322a850-9091-4d0e-b252-3e82eda3d94a}\setup.exe
MD5 : 4C19B11CE6A82C3028EC9122BF7E4B1B
Publisher : -
Detection :
Related Objects :
File - %programfiles%\installshield installation information\{9322a850-9091-4d0e-b252-3e82eda3d94a}\setup.exe
zlib1.dll
Status : Failed
Object : %programfiles%\foobar2000\zlib1.dll
MD5 : BA235AF458435F95BD21F861B82DE874
Publisher : -
Version : 1.2.11.0
Detection :
Related Objects :
File - %programfiles%\foobar2000\zlib1.dll
uninstall.exe
Status : Failed
Object : %programfiles%\foobar2000\uninstall.exe
MD5 : 18E3A09DD4403538A8B9D5DF1D81A191
Publisher : -
Version : 1.3.15.0
Detection :
Related Objects :
File - %programfiles%\foobar2000\uninstall.exe
HttpURLConnection.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\httpurlconnection.dll
MD5 : A7713F005191569EC74F0B9085B289E2
Publisher : -
Version : 4.1.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\httpurlconnection.dll
Intlace.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\intlace.vfx
MD5 : 8890D8192C0CA0B89480E3A79F207D57
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\intlace.vfx
HerDocRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\herdocrc.dll
MD5 : A9D6A9BB56E0E3AA3892EF48413355AA
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\herdocrc.dll
HerDocInterface.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\herdocinterface.dll
MD5 : 3AB4C9F2E763A8FA6E23F75FF4CEBE71
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\herdocinterface.dll
Funnel.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\funnel.vfx
MD5 : 5CB172AB5F7D28C817DF0804C5639009
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\funnel.vfx
foldbox.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\foldbox.vfx
MD5 : FDA659FC9867CB1F15CF5C7BDFCABEF7
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\foldbox.vfx
Flip.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\flip.vfx
MD5 : 7130DCFAD8D861311E6AD8CDBC61B422
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\flip.vfx
Fire.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\fire.vfx
MD5 : 121AF63B4D09F9F4AD7BA50827BA20BB
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\fire.vfx
Fade.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\fade.vfx
MD5 : E0D605320C95279FAD228B3CF8C4BD88
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\fade.vfx
Distort2.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\distort2.vfx
MD5 : 33DBE0AF21A8FDBD2F53A9E706C5FBE4
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\distort2.vfx
Distort.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\distort.vfx
MD5 : EF4B9BE8A90D31A43F7A70A0F411B036
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\distort.vfx
Dissolve.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\dissolve.vfx
MD5 : D9461A88776EDB112F46F26FB2B52450
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\dissolve.vfx
HerDocdll.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\herdocdll.dll
MD5 : 7114158D472B08CFF23DD4165B2F0AAA
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\herdocdll.dll
Diamond.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\diamond.vfx
MD5 : 34885ACBBB3B93F64621C40ACAB42919
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\diamond.vfx
HDRf.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\hdrf.dll
MD5 : E3D545492C82B57569385A9073F1409D
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\hdrf.dll
Cube.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\cube.vfx
MD5 : CFF17279CB2670679DDF407B75159B56
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\cube.vfx
croszoom.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\croszoom.vfx
MD5 : 68C4A60B2897E0128172A0F72E56B9B7
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\croszoom.vfx
Crosswip.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\crosswip.vfx
MD5 : 86FFAEF4EBDB94DC252FA32786A769BF
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\crosswip.vfx
Crosssli.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\crosssli.vfx
MD5 : 46DBDC9CDC7AF5030C9F9D9AAB666CC2
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\crosssli.vfx
Crosspus.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\crosspus.vfx
MD5 : 61CC69913DD5EAA1283D698BF828A3F7
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\crosspus.vfx
Crossbar.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\crossbar.vfx
MD5 : CF1AAC036EF808887B3F5965AA16FAEF
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\crossbar.vfx
Cross.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\cross.vfx
MD5 : C64CACE86FBA3039F4328EBA781573DC
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\cross.vfx
Corwipe.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\corwipe.vfx
MD5 : EC8FEDC4D7BBE016D25B3D1052404AAF
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\corwipe.vfx
Corstret.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\corstret.vfx
MD5 : 7D6FDC8C2F539F134C87423539C2FBE6
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\corstret.vfx
Corslide.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\corslide.vfx
MD5 : 4642319935E3A3028BB29EF53BFEE566
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\corslide.vfx
Clock7.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock7.vfx
MD5 : E3954074A0225BA4DB3C016E29E92242
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock7.vfx
Clock6.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock6.vfx
MD5 : A44D15D14CF9B06DA3C77F7E3FECB15B
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock6.vfx
Clock5.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock5.vfx
MD5 : B5AF29474C98B7A1E2F92AEF1AC10D18
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock5.vfx
HDDOM.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\hddom.dll
MD5 : 5FDDF0E9C858723236EFC5B1C372E52F
Publisher : -
Version : 1.1.74.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\hddom.dll
Clock4.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock4.vfx
MD5 : 9F0A648A71F5BD999830F686F6B8FDE6
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock4.vfx
Clock3.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock3.vfx
MD5 : 1022A96EB394C4AD34D4F12D32A66EAC
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock3.vfx
Clock2.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock2.vfx
MD5 : 4869F6D66A091304DB9EB126F893D307
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock2.vfx
Clock1.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock1.vfx
MD5 : 1C4C051AAD1F2697AD6AF96781C2A3BA
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\clock1.vfx
Cirflow.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\cirflow.vfx
MD5 : 12327B6CC28FF38B7454320D63324FB5
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\cirflow.vfx
Circle.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\circle.vfx
MD5 : B731E1132DC43C709C20E926253B59C2
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\circle.vfx
Checker.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\checker.vfx
MD5 : 9823BC5646494F562D2A1BADD25C05EB
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\checker.vfx
clrtoclr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\clrtoclr.dll
MD5 : 71A7DEC06517DE44FE46CBEE83E8DF17
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\clrtoclr.dll
CDLabelRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\cdlabelrc.dll
MD5 : 383A5D103478EA859749278637187063
Publisher : -
Version : 3.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\cdlabelrc.dll
Center.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\center.vfx
MD5 : 81FC1A154299F2148063B5DC7E86CEDD
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\center.vfx
Cellfly.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\cellfly.vfx
MD5 : 0469212D874B34A982A7DDD9E8F7438B
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\cellfly.vfx
CDLabel.exe
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\cdlabel.exe
MD5 : 1FEBF19D97000CC49599017511576B57
Publisher : -
Version : 6.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\cdlabel.exe
BWOut.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\bwout.vfx
MD5 : 013867215E6B9568AB08668E911D2823
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\bwout.vfx
CDLabel.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\cdlabel.dll
MD5 : 54448DC44B6220E2E09F94F038F70E00
Publisher : -
Version : 3.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\cdlabel.dll
CapMgrRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\capmgrrc.dll
MD5 : 57B0717F5C26682633709DBAD338647E
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\capmgrrc.dll
Broken.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\broken.vfx
MD5 : 3471530FCD20038B1D649FFF6B4C88AC
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\broken.vfx
CapMgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\capmgr.dll
MD5 : FE8BB6EE519544D51AFA13275713F1CC
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\capmgr.dll
Boxfill.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\boxfill.vfx
MD5 : D955A53740236C08C8DDA0B6330FF34B
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\boxfill.vfx
Box7.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box7.vfx
MD5 : 776A79C31B314DDE4B2545832620F119
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box7.vfx
Box6.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box6.vfx
MD5 : C24EBAE4E73ACCD5F179BA4B4D57F88A
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box6.vfx
BurnStarR.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\burnstarr.dll
MD5 : 1B9B557299AE72D9EFDAC31B4F48EB67
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\burnstarr.dll
HDControl.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\hdcontrol.dll
MD5 : 552F05602354808BFB433E0BF0A3516F
Publisher : -
Version : 1.1.74.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\hdcontrol.dll
GridOptDlg.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\gridoptdlg.dll
MD5 : 1707C777FEFFB936BEEA6D175268B5D1
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\gridoptdlg.dll
ulDevMgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\uldevmgr.dll
MD5 : B2774DFDEFC549F1CDC3A353FDD3A0B2
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\uldevmgr.dll
Box5.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box5.vfx
MD5 : 90356DEFB0ECAADF91D6596BFD9CBCD1
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box5.vfx
uGDIPlusTool.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\ugdiplustool.dll
MD5 : 99FDFB212DBA39743C99E0CEFF230310
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\ugdiplustool.dll
GBlurfilter.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\gblurfilter.dll
MD5 : 6CF0E4B6E5990C86135F7811821C7B47
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\gblurfilter.dll
Box4.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box4.vfx
MD5 : 94B6926226441742ACB78E7B9F6DF269
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box4.vfx
uDVDUser.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\udvduser.dll
MD5 : B63EBFC171A05CD293A273E64BB41B43
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\udvduser.dll
fourier.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fourier.dll
MD5 : 85708E35727F3946AAAEBC940FA256B6
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fourier.dll
Box3.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box3.vfx
MD5 : 678097D262A60A7C41BA6635269342C2
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box3.vfx
u32sn.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\u32sn.dll
MD5 : 2B67A36A5E4D90227B687F75C462D116
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\u32sn.dll
uFioUtil.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\ufioutil.dll
MD5 : 05FDBEF7AB6FBBF4494246B93CD3F367
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\ufioutil.dll
u32Cvt.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\u32cvt.dll
MD5 : E75FF5305752DDBB97F48FBA5CF987DB
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\u32cvt.dll
u32zlib.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32zlib.dll
MD5 : 958ADCBB2315E2CE2CC63CC2020B2F0A
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32zlib.dll
Box2.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box2.vfx
MD5 : 9F13C892824D0BE6F2B0E520605DF20A
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box2.vfx
u32Comm.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\u32comm.dll
MD5 : 3F775E29533B066E02A9C49567154B03
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\u32comm.dll
u32Tif.fio
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32tif.fio
MD5 : 9E86502FCFA0A54137845210A1369269
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32tif.fio
Box1.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box1.vfx
MD5 : 3215AC656F56FC0107051C8E253C6888
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box1.vfx
u32Cfg.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\u32cfg.dll
MD5 : A38E637C303B0B3A3BBE87D14AFC9BE9
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\u32cfg.dll
u32Tga.fio
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32tga.fio
MD5 : C4DA08F839F6D252925C79979FA5E9FE
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32tga.fio
u32Base.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\u32base.dll
MD5 : 0068D845ABD6AC6B83F1534C0E655F3D
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\u32base.dll
Box.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box.vfx
MD5 : 61D31DE1F35DDEB18D91A346EAD5BE96
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\box.vfx
u32Prj.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32prj.dll
MD5 : 3BB1AE7140896E65A7EFAF7523EB6E8B
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32prj.dll
Board.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\board.vfx
MD5 : 91FED922C3CCF0DAA00E36CB68170433
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\board.vfx
u32Png.fio
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32png.fio
MD5 : 40CB57718B42E400CAF2188D3CF65706
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32png.fio
u32lzw.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32lzw.dll
MD5 : 4CD6C0B1BA4714E0AAAD931C36E7E0E3
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32lzw.dll
Blind.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\blind.vfx
MD5 : 4CAF6697C8F626E7A44325E168DE80C9
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\blind.vfx
u32Jpg.fio
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32jpg.fio
MD5 : 5438C0B23BBBF134C7B737A9924313E7
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32jpg.fio
Blend4.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\blend4.vfx
MD5 : 68230ADE7B3978F6B83675504B90E790
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\blend4.vfx
BNRetver.exe
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\bnretver.exe
MD5 : FCBB291DC471AE76420343F249B66C9C
Publisher : -
Version : 1.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\bnretver.exe
Blend3.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\blend3.vfx
MD5 : 8E88BBAEC6ACED5ACD9219E367CB7278
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\blend3.vfx
u32Jpc.fio
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32jpc.fio
MD5 : 270741A6062E94B5C35A40A2B36A490F
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32jpc.fio
Blend2.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\blend2.vfx
MD5 : 6EC4A33CA555B2C3E960F29073F12B42
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\blend2.vfx
u32Jp2.fio
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32jp2.fio
MD5 : 996E8020DE79B22C5FB0A1D7B6FC7EF7
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32jp2.fio
AIKRC2.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\aikrc2.dll
MD5 : 478B6F62335E0BEF63915E510990A49E
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bnretver\aikrc2.dll
u32Gif.fio
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32gif.fio
MD5 : DF76F8FC63412862C32F487C27B756B7
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32gif.fio
Blend1.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\blend1.vfx
MD5 : F041D61BDAF5E9FE41459AECE2E8DEFB
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\blend1.vfx
u32Bmp.fio
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32bmp.fio
MD5 : B1ADCACB79B1A530DDC8F74E3EAAE637
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\u32bmp.fio
Barndoor.vfx
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\barndoor.vfx
MD5 : 38EB46A5C47A51753B5151627A82DD32
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfx_plug\barndoor.vfx
FIORC2.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\fiorc2.dll
MD5 : 6D0A698DAF17BF1D3B5DA2A65EDFA885
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\fio\fiorc2.dll
CapMgrRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\capmgrrc.dll
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\capmgrrc.dll
cutime.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\cutime.dll
MD5 : FCFCA1B6B06899B32103D6E94AF618FE
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\cutime.dll
ConverDib.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\converdib.dll
MD5 : 677DB5106F341B82423A9E749FB1CB70
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\converdib.dll
balance.vft
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\balance.vft
MD5 : 1E910081209F5D971AF8882631330766
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\balance.vft
b&c.vft
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\b&c.vft
MD5 : 56A7DFDAAC2B5FCB9E0525D8324E122C
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\b&c.vft
average.vft
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\average.vft
MD5 : BB978CCDB104ACED81BF2B6745DF4E90
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\average.vft
autolevel.vft
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\autolevel.vft
MD5 : DF0F8407AF9ABA58B861B1BB5FD8575F
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\autolevel.vft
AutoEnhance.vft
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\autoenhance.vft
MD5 : B8A8E33F8B25BD953E38BF5C707A1273
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\autoenhance.vft
AutoColor.vft
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\autocolor.vft
MD5 : C6D7D6583320363C533C79883D009B8D
Publisher : -
Version : 8.0.0.0
Detection :
Cleaning Action : Quarantine
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft_plug\autocolor.vft
vftrc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vftrc.dll
MD5 : EDB8BF793BA3980D655873B7F1E7F277
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vftrc.dll
vftbase.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vftbase.dll
MD5 : B427ECC37AD27B8EA73AF81370A1BF50
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vftbase.dll
vftatrc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vftatrc.dll
MD5 : 284B5B12B18907454A6E3AB6E2498453
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vftatrc.dll
Vft32rc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft32rc.dll
MD5 : F409EB95E5CFE9B27A4D55A067B07A36
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft32rc.dll
Vft32.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft32.dll
MD5 : 42119D9A2549097048E2C9448F2B53A3
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vft32.dll
Vfefile.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfefile.dll
MD5 : 6006171FDF1FC61C1C047F9B19B5EAC1
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vfefile.dll
veui32rc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\veui32rc.dll
MD5 : 14EF13119B16F74210B124A01ADC5896
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\veui32rc.dll
Veui32.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\veui32.dll
MD5 : 6D48FBB02A16C4343D1196662761B422
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\veui32.dll
Vepb40.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vepb40.dll
MD5 : 503EAC6DCF3E7EE5D49A378F40C74B66
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vepb40.dll
Vcvrt32.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vcvrt32.dll
MD5 : 6AD9317166A0F0D95D2E632A433815EF
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\vcvrt32.dll
uwUpdate.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uwupdate.dll
MD5 : 2B891E35A7C44327259773540E17328D
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uwupdate.dll
uvwtxt.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvwtxt.dll
MD5 : 3FDA88984DF4C9881823FE1CC3108B1D
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvwtxt.dll
uvwprjio.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvwprjio.dll
MD5 : DE206DC7DC46F7C56E3F5927C002A73F
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvwprjio.dll
uvWMEProfile.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvwmeprofile.dll
MD5 : 6564F122799B680100B1E16813E60496
Publisher : -
Version : 2.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvwmeprofile.dll
uvVIOCapShareModuleRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvviocapsharemodulerc.dll
MD5 : 5B63C67FBAB7D8B5B809C2E909F8D274
Publisher : -
Version : 2.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvviocapsharemodulerc.dll
UvUserRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvuserrc.dll
MD5 : 717F5415D9C49613F50C990F34B745A8
Publisher : -
Version : 8.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvuserrc.dll
uvUser.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvuser.dll
MD5 : 0964CDD245E4C164BC6286A7453A8CB4
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvuser.dll
uvSmartProxyMgrRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvsmartproxymgrrc.dll
MD5 : 948905F9E3E4580467DAF6E723E13425
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvsmartproxymgrrc.dll
uvSmartProxyMgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvsmartproxymgr.dll
MD5 : 5A0635FFF48C8796D678C3D4890496A5
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvsmartproxymgr.dll
uvSEPA.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvsepa.dll
MD5 : DD7B386B03297B42B253C9C86A036B40
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvsepa.dll
uvPreScan.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvprescan.dll
MD5 : 6B19017A385C7ABBDBA575E3225B285A
Publisher : -
Version : 1.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvprescan.dll
uvPlay.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvplay.dll
MD5 : 268131B2DC84BC0AFB635E0685AABCD7
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvplay.dll
uvMPEGWO.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvmpegwo.dll
MD5 : 5219A4ABA251F274370BA7C772087BDC
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvmpegwo.dll
uvMP4SEPA.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvmp4sepa.dll
MD5 : EA231CF9C3B2B5155BFA4DC4A735C037
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvmp4sepa.dll
uvMP4Drv.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvmp4drv.dll
MD5 : 9008CDAAED94342C986E142C66898E86
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvmp4drv.dll
uvipp.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvipp.dll
MD5 : 84CABFE3D7DEEFD55FECF1E6FDA12E34
Publisher : -
Version : 0.9.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvipp.dll
uviplW7.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviplw7.dll
MD5 : 88A24C73C540A161963076CB2EA94783
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviplw7.dll
uviplpX.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviplpx.dll
MD5 : 8C3DC2107ADBC9D3107FDC14B76017C5
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviplpx.dll
uviplP6.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviplp6.dll
MD5 : 3A4355CB665746E78F5D097F0DE5BBC4
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviplp6.dll
uviplM6.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviplm6.dll
MD5 : 27E2B93B3224D9A173A3FB697C91B236
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviplm6.dll
uviplA6.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvipla6.dll
MD5 : 2EA540F54220D30710A6D0FCF76CD504
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvipla6.dll
uvipl.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvipl.dll
MD5 : 37F6481B4DA50C5488288BBE1BD0A85B
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvipl.dll
uVioWrapRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviowraprc.dll
MD5 : 934176429268101E17DE13B6D7FF38D2
Publisher : -
Version : 3.3.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviowraprc.dll
uVIOWrap.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviowrap.dll
MD5 : F0BB58708A8D8C6AF6878D130FBFD912
Publisher : -
Version : 3.6.12.18
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uviowrap.dll
uVideoTool.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvideotool.dll
MD5 : 832A27E112BE5507BC831B39C2D9E582
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvideotool.dll
uVideoEditDBRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvideoeditdbrc.dll
MD5 : D5F69340BBE5933FE4BC11215A6F93B1
Publisher : -
Version : 1.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvideoeditdbrc.dll
uVideoEditDB.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvideoeditdb.dll
MD5 : 4BE662AF9F647A78A8009194ED52D577
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvideoeditdb.dll
uvHTMPEG2.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvhtmpeg2.dll
MD5 : FBBE00DDB880DE8BD4A4CB521CF9BBC6
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvhtmpeg2.dll
uvgrc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvgrc.dll
MD5 : 9F7E25F2DAD8F70BC7F6FC1049381F23
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvgrc.dll
uVESDKRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvesdkrc.dll
MD5 : E4B2DCA685694DA43F8BA29303EF6F63
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvesdkrc.dll
uVESDK.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvesdk.dll
MD5 : 0BD3487E9B15A0176AD7D8BFED27B8B7
Publisher : -
Version : 1.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvesdk.dll
uVeCfg.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvecfg.dll
MD5 : C978A6F6E0BB8ECF2894287DA1C6B325
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvecfg.dll
uvDV.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvdv.dll
MD5 : 444BDE189EE9BB215F75AAE75669DDA8
Publisher : -
Version : 6.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvdv.dll
uvDSBase.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvdsbase.dll
MD5 : 28B7E691875A9A22CDC3083062681912
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvdsbase.dll
uvCaptureRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvcapturerc.dll
MD5 : D19D7FD875288373B02F7093538054AF
Publisher : -
Version : 3.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvcapturerc.dll
uvBase.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvbase.dll
MD5 : BB7C3BF1FF369D1E913FA81F9F8A134B
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uvbase.dll
Utmpmgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utmpmgr.dll
MD5 : 2503D1A9318C72C69976AD31C44264C8
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utmpmgr.dll
uTimeCode.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utimecode.dll
MD5 : 19469BF270CC5FBF9B13C7F05C7941C1
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utimecode.dll
uTextUser.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utextuser.dll
MD5 : 53DC2D04EAFA7A255768B40212477598
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utextuser.dll
uTextToolRc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utexttoolrc.dll
MD5 : 7FDE5C3D350C35F2715CAFB4EB0F55C8
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utexttoolrc.dll
uTextTool.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utexttool.dll
MD5 : 18CDDF1F53C1BA8016B4CB65B95A25F7
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utexttool.dll
uTextCfg.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utextcfg.dll
MD5 : 92D02DDDCBF981ECA55BA49CFB3B5FAB
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\utextcfg.dll
uSurround.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\usurround.dll
MD5 : EE2F189DBDC8D203445C6B2AEF45DEDF
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\usurround.dll
uSmartSndMgrRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\usmartsndmgrrc.dll
MD5 : 7B2497BFAB192DA3E3C274D22E4763E2
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\usmartsndmgrrc.dll
uSmartSndMgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\usmartsndmgr.dll
MD5 : 98DE96D6819D88CF6E854AD150B9B50A
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\usmartsndmgr.dll
uSmartMultiTrim.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\usmartmultitrim.dll
MD5 : 6C1EABFE014F92EFBDDE75A2176AD9B7
Publisher : -
Version : 2.0.0.2
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\usmartmultitrim.dll
uShadow.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ushadow.dll
MD5 : C2C3B2A672000F92A36E52522A8EDFC2
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ushadow.dll
uRenderS.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\urenders.dll
MD5 : 03DF906248A2F406829EA3B91DCB8235
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\urenders.dll
uRenderA.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\urendera.dll
MD5 : C8870C38A535B5B4D31BEFA8ACDC6EFF
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\urendera.dll
uRender.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\urender.dll
MD5 : 35C6566427D7DFE72F308E49D5EDAB79
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\urender.dll
UpVwDlg.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upvwdlg.dll
MD5 : 7CC2ACB95C0836C64B66698C2B78B418
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upvwdlg.dll
UpViewSvr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upviewsvr.dll
MD5 : DCC07E57BC92C244208FC28B59A90A64
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upviewsvr.dll
upview.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upview.dll
MD5 : F6533C2560765340977B27EFC390438C
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upview.dll
upliabox2.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upliabox2.dll
MD5 : 9C95C36E8715EB2178DFFE10E9DF3D1A
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upliabox2.dll
upliabox.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upliabox.dll
MD5 : 0A3155C0856510709CFCBB5F1D12182A
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upliabox.dll
upliabom.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upliabom.dll
MD5 : CCDDFF49417D4BF4945001D52D933D29
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upliabom.dll
upliabog.dLL
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upliabog.dll
MD5 : E50DFCFAE076299216A6DF617175F484
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upliabog.dll
uplcpuinf.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uplcpuinf.dll
MD5 : 0C367450E66ACAE0244954552D839EF5
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uplcpuinf.dll
upl.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upl.dll
MD5 : 02A481D41CCD0F3A6A5357EC99F35FF4
Publisher : -
Version : 0.7.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upl.dll
jdwp.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdj\jre\bin\jdwp.dll
MD5 : 2AA592305C01509808D83306600C007D
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdj\jre\bin\jdwp.dll
jcov.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdj\jre\bin\jcov.dll
MD5 : 690B000F5D10AAFED7262B299E01FB53
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdj\jre\bin\jcov.dll
hprof.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdj\jre\bin\hprof.dll
MD5 : CCF8675163E620CE7DC51913B4A19CCC
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdj\jre\bin\hprof.dll
dt_socket.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdj\jre\bin\dt_socket.dll
MD5 : 397367EABD1A32E52776D4EEB31B4306
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdj\jre\bin\dt_socket.dll
ulaacdec.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulaacdec.dll
MD5 : A29C5E8D10B9BA85DA65678C1F70687D
Publisher : -
Version : 2.0.0.2
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulaacdec.dll
Ul3dui32.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ul3dui32.dll
MD5 : 930A8BCB462B82761906C1261E5EE34C
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ul3dui32.dll
ul263enc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ul263enc.dll
MD5 : E7125D778CB81451D2C52D8A17B6AE66
Publisher : -
Version : 2.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ul263enc.dll
ukMgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ukmgr.dll
MD5 : 17BD7C8E9978A6B15168E5C2FA7246E4
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ukmgr.dll
UItemSMP.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uitemsmp.dll
MD5 : 4A96D3ED481D904F13C47BF88B59731D
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uitemsmp.dll
UIShareTools.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uisharetools.dll
MD5 : E19CFC5541C136B3B8CD1C939015DD81
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uisharetools.dll
cvmi.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdj\jre\bin\cvmi.dll
MD5 : B9026C92FA13618F4CAACD2EE419F11F
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdj\jre\bin\cvmi.dll
UpiRc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upirc.dll
MD5 : 5382A9CB1B21D028126AC3B142295FBF
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\upirc.dll
BDControl.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdcontrol.dll
MD5 : 66E67B48267D2E0C4F9D161822E4C03A
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\bdcontrol.dll
uviplW7.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uviplw7.dll
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uviplw7.dll
uvPreScan.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uvprescan.dll
Publisher : -
Version : 1.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uvprescan.dll
ul263enc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ul263enc.dll
Publisher : -
Version : 2.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ul263enc.dll
ulaacdec.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulaacdec.dll
Publisher : -
Version : 2.0.0.2
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulaacdec.dll
upliabog.dLL
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\upliabog.dll
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\upliabog.dll
upliabom.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\upliabom.dll
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\upliabom.dll
upliabox.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\upliabox.dll
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\upliabox.dll
upliabox2.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\upliabox2.dll
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\upliabox2.dll
uvCaptureRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uvcapturerc.dll
Publisher : -
Version : 3.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uvcapturerc.dll
uvDSBase.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uvdsbase.dll
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uvdsbase.dll
uvipl.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uvipl.dll
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uvipl.dll
uviplA6.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uvipla6.dll
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uvipla6.dll
uviplM6.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uviplm6.dll
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uviplm6.dll
uviplP6.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uviplp6.dll
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uviplp6.dll
uviplpX.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uviplpx.dll
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uviplpx.dll
uDVDUser.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvduser.dll
MD5 : D9E5290B4877D14F782B681D8244CBA3
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvduser.dll
ulRender.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulrender.dll
MD5 : 780D130D778AC95D571FD7E4E8D424E0
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulrender.dll
uDVDTitlePlay.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdtitleplay.dll
MD5 : 28B9DE94F37DCAFA002BAECD84854D4A
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdtitleplay.dll
ulProjectIO.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulprojectio.dll
MD5 : 8D3023DF251543CDECA4A7D0989412AD
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulprojectio.dll
uDVDStgUtl.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdstgutl.dll
MD5 : 0DCE0DA5D12EDF4174265866F37121DC
Publisher : -
Version : 1.0.0.3
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdstgutl.dll
uDVDEnc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdenc.dll
MD5 : 2485EFA07CBC0F24466446670906A393
Publisher : -
Version : 3.3.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdenc.dll
ULPRNTPRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulprntprc.dll
MD5 : 899FC27AAE85BCFF2C7762DD6D6D9D4E
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulprntprc.dll
uDVDCommRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdcommrc.dll
MD5 : 387632C061634626BFB4D4F7DCFBF3ED
Publisher : -
Version : 3.2.1.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdcommrc.dll
ulprntp.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulprntp.dll
MD5 : 888383E8EAF86F37815DFC85B4205286
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulprntp.dll
uDVDComm.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdcomm.dll
MD5 : F53E4514314BF9F0603DFD14F42FF183
Publisher : -
Version : 3.2.6.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdcomm.dll
ulPrevRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulprevrc.dll
MD5 : 6C3211C13E956382D9C2D6EEF17AFEF1
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulprevrc.dll
uDVDCaptureRc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdcapturerc.dll
MD5 : A7726D6BA2BE490F4B5B8D0DAEBF6FEE
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdcapturerc.dll
uDVDCapture.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdcapture.dll
MD5 : 58D3E8B9D086739105C57C84CB621633
Publisher : -
Version : 5.0.0.2
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdcapture.dll
uDVDBuf.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdbuf.dll
MD5 : DDE7737CE75D4FB7CC180D5433A3A053
Publisher : -
Version : 3.2.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udvdbuf.dll
ulPrev.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulprev.dll
MD5 : 99A516FD798A32CE960FFC26C0603966
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulprev.dll
ulPPMgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulppmgr.dll
MD5 : 3C4450B85C39F72B07CF100E4F7C5C55
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulppmgr.dll
uDrawingTool.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udrawingtool.dll
MD5 : 9B0D4A4B6B866C5FB4A6B6DE00371ED5
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udrawingtool.dll
ulPLDrv.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulpldrv.dll
MD5 : 9BAB8B20C87C900299EB4F6D2AAAE4BA
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulpldrv.dll
uDMFTaskMgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udmftaskmgr.dll
MD5 : 13658F8140FEADEED5DCEBECD2B2B17A
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udmftaskmgr.dll
uDMFGUIRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udmfguirc.dll
MD5 : B53F455DFBADC1971E2B74BBA58E9333
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udmfguirc.dll
ulOle32.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulole32.dll
MD5 : AC4F303A03D80066C5B537821B198DDF
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulole32.dll
uDMFGUI.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udmfgui.dll
MD5 : 4F21083FEEB0C8CBEA0B1A0E82C62087
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udmfgui.dll
uDMFBaseTask.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udmfbasetask.dll
MD5 : 6458DE7B935235BA69AEE7706BAC92FA
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udmfbasetask.dll
uDMFBasePage.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udmfbasepage.dll
MD5 : 8795C0033F637B2A9D1E808A60FEA8BA
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udmfbasepage.dll
udevmgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udevmgr.dll
MD5 : 8114FC8641CDAC82AD2458A0073EDA67
Publisher : -
Version : 9.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\udevmgr.dll
ulmp4lib.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulmp4lib.dll
MD5 : 43373D80CCFE11D7C84986260B8EAFE9
Publisher : -
Version : 2.0.7.88
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulmp4lib.dll
ucvtmem.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucvtmem.dll
MD5 : 72FE332324D11463309028C24E5B55FC
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucvtmem.dll
ulmp3enc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulmp3enc.dll
MD5 : 6FF64BF5B1DA051C0930FF35BE3ACAFE
Publisher : -
Version : 1.0.0.5
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulmp3enc.dll
uCutCFUser.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucutcfuser.dll
MD5 : C3BEF51F23610E164B8DD428AF0A3E04
Publisher : -
Version : 2.8.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucutcfuser.dll
ulibtif.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibtif.dll
MD5 : FE6C273B744C64BA6F480B17DEE7BF33
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibtif.dll
uCutCFGDI.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucutcfgdi.dll
MD5 : ED6D73D75F0D0E184BDBA253897429DC
Publisher : -
Version : 2.6.0.2
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucutcfgdi.dll
ulibraw.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibraw.dll
MD5 : C77CE62E9BFF9C6B253095F8945894A6
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibraw.dll
uCutCFDB.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucutcfdb.dll
MD5 : E0B7DD78B6904F505C5D71618D41C843
Publisher : -
Version : 2.8.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucutcfdb.dll
ulibpng.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibpng.dll
MD5 : 883AF1515511C30956FD4A0CD46DB0C9
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibpng.dll
uliblzw.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uliblzw.dll
MD5 : BAB1D9AC5C7A4B88C70E8B800BE11850
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uliblzw.dll
ucp1.ucp
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucp1.ucp
MD5 : EF511501EB591ED7526068B7110ACF5E
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucp1.ucp
ulibjpg.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibjpg.dll
MD5 : 0A948491F6C2CBAC353E80AAF6A3C9ED
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibjpg.dll
ucimg.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucimg.dll
MD5 : 73C268002FB130418B70B94BAFE04A23
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ucimg.dll
ulibjpc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibjpc.dll
MD5 : 565FF55B6578E181D3571DC4B0468F76
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibjpc.dll
uBaseObject.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ubaseobject.dll
MD5 : 75BADAC8C7D06FC25E1D9DE208023C61
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ubaseobject.dll
ulibjp2.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibjp2.dll
MD5 : CBB2CD05367BC6674952670A292AA2BC
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibjp2.dll
uAutoEditWrapRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uautoeditwraprc.dll
MD5 : F459E80F7E28DCA90787B431A3DFE81D
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uautoeditwraprc.dll
ulibgif.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibgif.dll
MD5 : E801CAA9F17518CEE89B9AFA6BE0A4E5
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulibgif.dll
uAutoEditWrap.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uautoeditwrap.dll
MD5 : 1C895386392CB556D9309F6F91B75CE5
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uautoeditwrap.dll
Ulead_DRM_module.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulead_drm_module.dll
MD5 : D22D1D312904E50854AEF19D2421BE3B
Publisher : -
Version : 1.0.0.6
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulead_drm_module.dll
uAMModule.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uammodule.dll
MD5 : 146BB863430B0CA141422C2B24E479CC
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uammodule.dll
UleadLinks.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uleadlinks.dll
MD5 : 0708E4052207E02221E8A74E847AFD18
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uleadlinks.dll
uAfxUnknown.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uafxunknown.dll
MD5 : BC6FE4080AFB2DED7DC831CBBA75136A
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uafxunknown.dll
UAboutBox.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uaboutbox.dll
MD5 : 7AF976EC94E4F8FCF348F2D492CA444B
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\uaboutbox.dll
u32xView.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32xview.dll
MD5 : C28AD01CBC8E887D90D41DA93F49393D
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32xview.dll
u32video.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32video.dll
MD5 : DCB7B6F3C15A90E49ABF7E26ED38DC35
Publisher : -
Version : 6.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32video.dll
ulDevMgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uldevmgr.dll
MD5 : 2C5A7179B14E1F14E8D416C82E0F4C5F
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uldevmgr.dll
uldbglog.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uldbglog.dll
MD5 : CFD6E7FE96AC77F1859B7D1A126BFC97
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uldbglog.dll
u32utx.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32utx.dll
MD5 : 2C3007EAFB78F7BA9801731B5080B8AC
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32utx.dll
ulDARMgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uldarmgr.dll
MD5 : F877658396791B5DAC8CBEACB5D998EE
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uldarmgr.dll
U32USPRC.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32usprc.dll
MD5 : 2EAFE05888054EC8CCB19622D29A8CBB
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32usprc.dll
ulColorBar.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulcolorbar.dll
MD5 : DB41F8FA6A5D732EA83BB0C6EE731F43
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulcolorbar.dll
u32usp.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32usp.dll
MD5 : D60E32BA1A0FD2E399DFBAD586475285
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32usp.dll
Ulclrtxt.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulclrtxt.dll
MD5 : 71BE038DE3ED3C4FB049AB2EE8D8B641
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulclrtxt.dll
uLauncherDllRc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulauncherdllrc.dll
MD5 : BBCE34127217D867D7D09B4D0E83A818
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulauncherdllrc.dll
u32uscUI.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32uscui.dll
MD5 : CFF853BFDA6DA5F5D22FF2395B33E9C8
Publisher : -
Version : 4.1.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32uscui.dll
u32uscRES.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32uscres.dll
MD5 : F583FE350AE69BCA166BB8B4B28DCF15
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32uscres.dll
u32txtur.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32txtur.dll
MD5 : E21A7FF78D617B3BD2BDBEDE380AF9B0
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32txtur.dll
u32txEx.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32txex.dll
MD5 : 1DBD73D772A67614CE665FEE5EFCE7F8
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32txex.dll
ulaspenc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulaspenc.dll
MD5 : 13A0909F4E2F9F1458B89BA279D230E9
Publisher : -
Version : 1.0.1.3
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulaspenc.dll
u32Tx.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32tx.dll
MD5 : DE2CB1296195B8B85268CD94055C3AB5
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32tx.dll
ulaspdec.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulaspdec.dll
MD5 : 695DEC94C08A93CD5B20EB75B7762319
Publisher : -
Version : 2.0.0.6
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulaspdec.dll
u32Tu.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32tu.dll
MD5 : C0629207A0D1C4F0D24DFD10B8299626
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32tu.dll
ulamrenc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulamrenc.dll
MD5 : C7A96401C62FCA87A8C9646442FB1CCD
Publisher : -
Version : 2.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulamrenc.dll
u32sn.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32sn.dll
MD5 : 6D5595F14004BE59E18A76E5A339E1FB
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32sn.dll
u32SMP.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32smp.dll
MD5 : 97DD31C06985CF366F4389D88DBB6921
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32smp.dll
ulamrdec.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulamrdec.dll
MD5 : 5DE3EE1EDB02CEC0EE45333FE8C36843
Publisher : -
Version : 2.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulamrdec.dll
u32Sel.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32sel.dll
MD5 : BB3ACA484D8288AFF2EF6FC1EB615738
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32sel.dll
ulAFAdapter.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulafadapter.dll
MD5 : E7C1C88BEE9F62163CCDAED6B4BD0A5B
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulafadapter.dll
u32Scan.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32scan.dll
MD5 : 2DB62FA0584372FA9AC9F6CDD1CF3B62
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32scan.dll
u32r2v.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32r2v.dll
MD5 : BE35FCBAE570E44FB18485415405C6F5
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32r2v.dll
ulaacenc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulaacenc.dll
MD5 : B668BD4F90384842482941A21FAB340D
Publisher : -
Version : 2.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ulaacenc.dll
Ul3dui32.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ul3dui32.dll
MD5 : 972B2AA19EA02117D5E940956B7C805F
Publisher : -
Version : 13.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ul3dui32.dll
u32Prod.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32prod.dll
MD5 : 7822016E6EAE207779DD2986E90FE370
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32prod.dll
ukMgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ukmgr.dll
MD5 : 87641EF391D63A824CF8C0A381C535BD
Publisher : -
Version : 8.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\ukmgr.dll
u32Print.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32print.dll
MD5 : 9658516676D153F922D585D49C138411
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32print.dll
UItemSMP.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uitemsmp.dll
MD5 : 87ACF6E9E06C51A2529A75C6A54B32CD
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uitemsmp.dll
u32Plug.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32plug.dll
MD5 : 19CC651BADB29B22EB5AFE4B86D40C86
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32plug.dll
UIShareTools.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uisharetools.dll
MD5 : 06FC0ED7A833014C2C16C5874BD8F9EB
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\uisharetools.dll
U32path.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32path.dll
MD5 : 24CE04A4A8BD72B70818A7F3FA49CB8B
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32path.dll
u32Misc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32misc.dll
MD5 : E200C286E955B95284EAC5F06D038A1D
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32misc.dll
u32File.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32file.dll
MD5 : 62CE826B4AA7D487369CA866A781CD7F
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32file.dll
u32Fido.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32fido.dll
MD5 : 72567573D9CF41E86FD8C23099AEA0A2
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32fido.dll
u32FeUI_s.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32feui_s.dll
MD5 : 235E3D969BF0B7F2E8CC96296CE0FEE8
Publisher : -
Version : 11.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\u32feui_s.dll
ulaacenc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulaacenc.dll
Publisher : -
Version : 2.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulaacenc.dll
ulamrdec.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulamrdec.dll
Publisher : -
Version : 2.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulamrdec.dll
ulamrenc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulamrenc.dll
Publisher : -
Version : 2.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulamrenc.dll
ulaspdec.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulaspdec.dll
Publisher : -
Version : 2.0.0.6
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulaspdec.dll
ulaspenc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulaspenc.dll
Publisher : -
Version : 1.0.1.3
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulaspenc.dll
ulmp3enc.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulmp3enc.dll
Publisher : -
Version : 1.0.0.5
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\direct discrecorder\ulmp3enc.dll
udevmgr.dll
Status : Failed
Object : %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\udevmgr.dll
Publisher : -
Version : 9.0.0.0
Detection :
Related Objects :
File - %programfiles%\corel\dvd moviefactory for toshiba\dvd moviefactory\udevmgr.dll
standalonephase1.dat
Status : Scanned
Object : %programfiles%\cheat engine 6.2\standalonephase1.dat
MD5 : 0F765155AFB428331CED4BCB14100102
Publisher : -
Version : -
Detection : PUA:Win32/HackTool.Gen
Related Objects :
File - %programfiles%\cheat engine 6.2\standalonephase1.dat
reflow.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\reflow.api
MD5 : 18D586B57125F1FC70B0E6CD792202D5
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\reflow.api
ReadOutLoud.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\readoutloud.api
MD5 : 18A6FD4BA8C2DF42226B692A94942797
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\readoutloud.api
PPKLite.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\ppklite.api
MD5 : E2172CF8B298082D25CEBAE8FC5D8B47
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\ppklite.api
PDDom.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\pddom.api
MD5 : B69462206BE6672D3C4F6752A70DF81D
Publisher : -
Version : 9.5.0.270
Detection :
Cleaning Action : Quarantine
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\pddom.api
IJPLMLIB.DLL
Status : Failed
Object : %programfiles%\canon\ijplm\ijplmlib.dll
MD5 : 08389A9DCCAB142E8645781CB82CBDCE
Publisher : -
Version : 3.2.0.102
Detection :
Related Objects :
File - %programfiles%\canon\ijplm\ijplmlib.dll
IJPLML64.DLL
Status : Failed
Object : %programfiles%\canon\ijplm\ijplml64.dll
MD5 : 3C8B779B903460881DF4BD26552A7220
Publisher : -
Version : 3.2.0.102
Detection :
Related Objects :
File - %programfiles%\canon\ijplm\ijplml64.dll
Multimedia.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia.api
MD5 : 4B1471D8FCB0A8D4F96B15330EB8A5EF
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia.api
cmvuirc.dll
Status : Failed
Object : %programfiles%\canon\ij manual\easy guide viewer\cmvuirc.dll
MD5 : CDBC751F6D9246E4CFFCA4825B5CF31D
Publisher : -
Version : 1.4.0.0
Detection :
Related Objects :
File - %programfiles%\canon\ij manual\easy guide viewer\cmvuirc.dll
WindowsMedia.mpp
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia\mpp\windowsmedia.mpp
MD5 : 41819E422D932B35685630F0269D347C
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia\mpp\windowsmedia.mpp
Real.mpp
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia\mpp\real.mpp
MD5 : 4CBBDF125A873E97C37B7AAD385DF9D4
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia\mpp\real.mpp
QuickTime.mpp
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia\mpp\quicktime.mpp
MD5 : 23A3CAAE7024AA87DA9C2C2F97EA9AE9
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia\mpp\quicktime.mpp
MCIMPP.mpp
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia\mpp\mcimpp.mpp
MD5 : 57CD85E8BC754CA5C4E426FEE591B846
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia\mpp\mcimpp.mpp
Flash.mpp
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia\mpp\flash.mpp
MD5 : 090A5490B4C9FA8E6FA17892925BCAE2
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\multimedia\mpp\flash.mpp
MakeAccessible.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\makeaccessible.api
MD5 : A62200BBE6742E932DB839C3B7FF2FFA
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\makeaccessible.api
IA32.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\ia32.api
MD5 : 77BE131E22F8634BE20C9308AC853DED
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\ia32.api
HLS.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\hls.api
MD5 : 14519208B4AEA7266FD6ECF09342C452
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\hls.api
EScript.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\escript.api
MD5 : C576340FC38A040815E9E34DD96241A7
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\escript.api
eBook.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\ebook.api
MD5 : 10FF3C923145C8E6EFA8A75C6B3AFA34
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\ebook.api
DVA.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\dva.api
MD5 : 9002AA257406620656057085426BD30A
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\dva.api
DigSig.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\digsig.api
MD5 : BFEF3032B024DA4CD53A4BC2C5214422
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\digsig.api
Checkers.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\checkers.api
MD5 : 7B38F7D9F5F3694AC29D33286D17FF4D
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\checkers.api
Annots.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\annots.api
MD5 : AA239E4591D14F6C36F3C7823E97BEED
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\annots.api
AcroForm.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\acroform.api
MD5 : 2315BD1F4CC2D866C661536DD857344E
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\acroform.api
QRCode.pmp
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\acroform\pmp\qrcode.pmp
MD5 : 40398612FF91108A21E19F8BBFA3569A
Publisher : -
Version : 3.0.8262.0
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\acroform\pmp\qrcode.pmp
DataMatrix.pmp
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\acroform\pmp\datamatrix.pmp
MD5 : CD0DA2C3F5032F4D78E4A10D4982D17A
Publisher : -
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\acroform\pmp\datamatrix.pmp
AdobePDF417.pmp
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\acroform\pmp\adobepdf417.pmp
MD5 : EC90CA2ACAC40DE42DEFBCC0D05496AD
Publisher : -
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\acroform\pmp\adobepdf417.pmp
Accessibility.api
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\plug_ins\accessibility.api
MD5 : 719F81D49AE292AC5E0418B6E97CC195
Publisher : -
Version : 9.5.0.270
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\plug_ins\accessibility.api
CoolType.dll
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\cooltype.dll
MD5 : EFA006D53E877EF658CD64CAAD9A1F56
Publisher : -
Version : 5.5.83.1
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\cooltype.dll
authplay.dll
Status : Failed
Object : %programfiles%\adobe\reader 9.0\reader\authplay.dll
MD5 : 03B6F2FBAFC2D8ABC4048F575069D817
Publisher : -
Version : 10.3.183.11
Detection :
Related Objects :
File - %programfiles%\adobe\reader 9.0\reader\authplay.dll
svpwutil.exe.mui
Status : Failed
Object : %programw6432%\toshiba\utilities\zh-cn\svpwutil.exe.mui
MD5 : 5ABC7EF61C714CAD4E6AE918E9DE6245
Publisher : -
Version : 4.2.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\utilities\zh-cn\svpwutil.exe.mui
svpwutil.exe.mui
Status : Failed
Object : %programw6432%\toshiba\utilities\tr-tr\svpwutil.exe.mui
MD5 : 554FED5FE1B0E067A490077AEC0D360F
Publisher : -
Version : 4.2.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\utilities\tr-tr\svpwutil.exe.mui
SVPWUTIL.exe
Status : Failed
Object : %programw6432%\toshiba\utilities\svpwutil.exe
MD5 : 20695D2EA22541214C556F7839BDC95F
Publisher : -
Version : 4.2.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\utilities\svpwutil.exe
RGUpdate.exe
Status : Failed
Object : %programw6432%\toshiba\utilities\svpwhwdriver\rgupdate.exe
MD5 : E08B3E5AD0AB7C31BEC41855BB7C1AB2
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programw6432%\toshiba\utilities\svpwhwdriver\rgupdate.exe
DevCtrl.exe
Status : Failed
Object : %programw6432%\toshiba\utilities\svpwhwdriver\devctrl.exe
MD5 : 7D02B678C900C2C5A587CAED1607F2E5
Publisher : -
Version : 2.0.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\utilities\svpwhwdriver\devctrl.exe
svpwutil.exe.mui
Status : Failed
Object : %programw6432%\toshiba\utilities\sv-se\svpwutil.exe.mui
MD5 : F633B3A75265579F17908A734EEC4F20
Publisher : -
Version : 4.2.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\utilities\sv-se\svpwutil.exe.mui
CNMNPUTC.DLL
Status : Failed
Object : %programfiles%\canon\canon ij network tool\cnmnputc.dll
MD5 : A8A7F72636A6E91EC678E9D05B84EF4C
Publisher : -
Version : 2.7.0.60
Detection :
Related Objects :
File - %programfiles%\canon\canon ij network tool\cnmnputc.dll
policytool.exe
Status : Failed
Object : %programfiles%\avid\application manager\jre\bin\policytool.exe
MD5 : 1670C572D42F375135BB39C2C30A127D
Publisher : -
Version : 7.0.0.32
Detection :
Related Objects :
File - %programfiles%\avid\application manager\jre\bin\policytool.exe
pack200.exe
Status : Failed
Object : %programfiles%\avid\application manager\jre\bin\pack200.exe
MD5 : B125CD18DD78BD829383349423D512B0
Publisher : -
Version : 7.0.0.32
Detection :
Related Objects :
File - %programfiles%\avid\application manager\jre\bin\pack200.exe
orbd.exe
Status : Failed
Object : %programfiles%\avid\application manager\jre\bin\orbd.exe
MD5 : 5C39389C95771C03BD94929561DE3F53
Publisher : -
Version : 7.0.0.32
Detection :
Related Objects :
File - %programfiles%\avid\application manager\jre\bin\orbd.exe
npt.dll
Status : Failed
Object : %programfiles%\avid\application manager\jre\bin\npt.dll
MD5 : DFD51C92901955334BDEE8F4F9980D43
Publisher : -
Version : 7.0.0.32
Detection :
Related Objects :
File - %programfiles%\avid\application manager\jre\bin\npt.dll
nio.dll
Status : Failed
Object : %programfiles%\avid\application manager\jre\bin\nio.dll
MD5 : 50BA3E90658EC9B736976B22BE33CF95
Publisher : -
Version : 7.0.0.32
Detection :
Related Objects :
File - %programfiles%\avid\application manager\jre\bin\nio.dll
net.dll
Status : Failed
Object : %programfiles%\avid\application manager\jre\bin\net.dll
MD5 : F8489C1291945ADE10B198C91CA83FD2
Publisher : -
Version : 7.0.0.32
Detection :
Related Objects :
File - %programfiles%\avid\application manager\jre\bin\net.dll
unins000.exe
Status : Failed
Object : %programfiles%\brs\unins000.exe
MD5 : DC97F719679DDBC77AB40E1203D573EC
Publisher : -
Version : 51.52.0.0
Detection :
Related Objects :
File - %programfiles%\brs\unins000.exe
mlib_image.dll
Status : Failed
Object : %programfiles%\avid\application manager\jre\bin\mlib_image.dll
MD5 : 083E92F3AFF6F7F29D42EB818D5267B2
Publisher : -
Version : 7.0.0.32
Detection :
Related Objects :
File - %programfiles%\avid\application manager\jre\bin\mlib_image.dll
management.dll
Status : Failed
Object : %programfiles%\avid\application manager\jre\bin\management.dll
MD5 : 2E54FB0DCB7FCA66916E0961963A30F1
Publisher : -
Version : 7.0.0.32
Detection :
Related Objects :
File - %programfiles%\avid\application manager\jre\bin\management.dll
ssleay32.dll
Status : Failed
Object : %programfiles%\avid\application manager\ssleay32.dll
MD5 : C9778FE070B8E34C7A071B27526A6D68
Publisher : -
Version : 1.0.0.4
Detection :
Related Objects :
File - %programfiles%\avid\application manager\ssleay32.dll
lcms.dll
Status : Failed
Object : %programfiles%\avid\application manager\jre\bin\lcms.dll
MD5 : 1DB0DB715B4D1C214F4D5FD0A3DBD9C1
Publisher : -
Version : 7.0.0.32
Detection :
Related Objects :
File - %programfiles%\avid\application manager\jre\bin\lcms.dll
ktab.exe
Status : Failed
Object : %programfiles%\avid\application manager\jre\bin\ktab.exe
MD5 : F6EC490C210425B16237A300F208AB0C
Publisher : -
Version : 7.0.0.32
Detection :
Related Objects :
File - %programfiles%\avid\application manager\jre\bin\ktab.exe
tosssdalert.exe.mui
Status : Failed
Object : %programw6432%\toshiba\toshiba hdd ssd alert\zh-hk\tosssdalert.exe.mui
MD5 : 64A24ACA3A88CD0368D34E30E1749F49
Publisher : -
Version : 1.0.64.13
Detection :
Related Objects :
File - %programw6432%\toshiba\toshiba hdd ssd alert\zh-hk\tosssdalert.exe.mui
ISSetup.dll
Status : Failed
Object : %programw6432%\toshiba\tvap\tvap\issetup.dll
MD5 : 0A88BC9697D284350B60C87F7C7E1900
Publisher : -
Version : 12.0.0.58851
Detection :
Related Objects :
File - %programw6432%\toshiba\tvap\tvap\issetup.dll
tosssdalert.exe.mui
Status : Failed
Object : %programw6432%\toshiba\toshiba hdd ssd alert\zh-tw\tosssdalert.exe.mui
MD5 : 06C89D992A86D62C789D110D5A988035
Publisher : -
Version : 1.0.64.13
Detection :
Related Objects :
File - %programw6432%\toshiba\toshiba hdd ssd alert\zh-tw\tosssdalert.exe.mui
tossenotify.exe.mui
Status : Failed
Object : %programw6432%\toshiba\toshiba hdd ssd alert\zh-tw\tossenotify.exe.mui
MD5 : F57012933250C3358CAC8908C4C014A6
Publisher : -
Version : 1.0.64.15
Detection :
Related Objects :
File - %programw6432%\toshiba\toshiba hdd ssd alert\zh-tw\tossenotify.exe.mui
toscpcbackup.exe.mui
Status : Failed
Object : %programw6432%\toshiba\toshiba hdd ssd alert\zh-tw\toscpcbackup.exe.mui
MD5 : 72C41F40C743113E894C9A1BBA356A92
Publisher : -
Version : 1.0.64.12
Detection :
Related Objects :
File - %programw6432%\toshiba\toshiba hdd ssd alert\zh-tw\toscpcbackup.exe.mui
rmi.dll
Status : Failed
Object : %programfiles%\avid\application manager\jre\bin\rmi.dll
MD5 : 10A7D1FEFC4561690677D19A951D97C9
Publisher : -
Version : 7.0.0.32
Detection :
Related Objects :
File - %programfiles%\avid\application manager\jre\bin\rmi.dll
mpnlng.dll
Status : Failed
Object : %programfiles%\canon\mp navigator ex 4.0\mpnlng.dll
MD5 : 45A7DA0E7B64A80334027B80E80961F6
Publisher : -
Version : 4.0.0.0
Detection :
Related Objects :
File - %programfiles%\canon\mp navigator ex 4.0\mpnlng.dll
nvupdtr.dll
Status : Failed
Object : %programw6432%\nvidia corporation\installer2\nvidia.update.1\nvupdtr.dll
MD5 : FAA4E1AE2FBD6BE5E6A89ACC25491EE3
Publisher : -
Version : 1.3.5.0
Detection :
Related Objects :
File - %programw6432%\nvidia corporation\installer2\nvidia.update.1\nvupdtr.dll
nvupdtr.dll
Status : Failed
Object : %programw6432%\nvidia corporation\installer2\display.update.0\nvupdtr.dll
MD5 : 58AA20D8A429D97385DB3A845716CCEC
Publisher : -
Version : 1.1.34.0
Detection :
Related Objects :
File - %programw6432%\nvidia corporation\installer2\display.update.0\nvupdtr.dll
ThemedControlsLibrary.dll
Status : Failed
Object : %programw6432%\dolby\dolby control center\themedcontrolslibrary.dll
MD5 : 20311EC32A0B9ED864B90FA46B340D43
Publisher : -
Version : 1.0.3146.25731
Detection :
Related Objects :
File - %programw6432%\dolby\dolby control center\themedcontrolslibrary.dll
stapi32.dll
Status : Failed
Object : %programw6432%\dolby\dolby control center\stapi32.dll
MD5 : DA016B64ED597DCCFC58C9322DA52748
Publisher : -
Version : 1.0.6033.2
Detection :
Related Objects :
File - %programw6432%\dolby\dolby control center\stapi32.dll
RtkApoApi.dll
Status : Failed
Object : %programw6432%\dolby\dolby control center\rtkapoapi.dll
MD5 : 08C87B064CE53089829CB62592CF189E
Publisher : -
Version : 1.0.0.1
Detection :
Related Objects :
File - %programw6432%\dolby\dolby control center\rtkapoapi.dll
DolbyVistaConfig.exe
Status : Failed
Object : %programw6432%\dolby\dolby control center\dolbyvistaconfig.exe
MD5 : 5C3A423404424B1C4579FA71B5B5787C
Publisher : -
Version : 2.2.1.0
Detection :
Related Objects :
File - %programw6432%\dolby\dolby control center\dolbyvistaconfig.exe
SmartAudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\zh-tw\smartaudio.resources.dll
MD5 : 7AED6417ADF3FE21E3F5324E0114CA59
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\zh-tw\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\zh-hant\smartaudio.resources.dll
MD5 : 957C30943296C842CCBACA876ECF46E1
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\zh-hant\smartaudio.resources.dll
sc4.dll
Status : Failed
Object : %programfiles%\audacity\plug-ins\sc4.dll
MD5 : 231B749A8B860C707EE2FA2FC4699CB7
Publisher : -
Version : -
Detection :
Related Objects :
File - %programfiles%\audacity\plug-ins\sc4.dll
System.Net.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\system.net.ni.dll
MD5 : 99F163C3C17E4CB1518B1C66FE537ADF
Publisher : -
Version : 5.1.50907.0
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\system.net.ni.dll
System.Core.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\system.core.ni.dll
MD5 : 2ED44483077D138BC159E86B9D657B18
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\system.core.ni.dll
mscorlib.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\mscorlib.ni.dll
MD5 : A9AD31F7DC0D52CCDEA7322DAA69E545
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\mscorlib.ni.dll
Microsoft.Xna.Framework.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\microsoft.xna.framework.ni.dll
MD5 : 71D39E3E90A9F46238EFE62B122F39E3
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\microsoft.xna.framework.ni.dll
Microsoft.Xna.Framework.Graphics.Shaders.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\microsoft.xna.framework.graphics.shaders.ni.dll
MD5 : D4CE34AB59B95F7BF62EC8BC650A2D61
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\microsoft.xna.framework.graphics.shaders.ni.dll
Microsoft.Xna.Framework.Graphics.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\microsoft.xna.framework.graphics.ni.dll
MD5 : F41AA7AF5CBD8D239F5B6FA1FD51B535
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\microsoft.xna.framework.graphics.ni.dll
SETUP.EXE
Status : Failed
Object : %programw6432%\microsoft office\setup\setup.exe
MD5 : 0ADD51AABEFA76B8633035DA48005DA8
Publisher : -
Version : 3.0.0.1029
Detection :
Related Objects :
File - %programw6432%\microsoft office\setup\setup.exe
mssetup.dll
Status : Failed
Object : %programw6432%\microsoft office\setup\mssetup.dll
MD5 : 2E6B66B0ABD2B52694DDCEB3D8D29CE9
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft office\setup\mssetup.dll
msodeusa.dll
Status : Failed
Object : %programw6432%\microsoft office\setup\msodeusa.dll
MD5 : 1C47CF3D3469F1C8EBECB3A8F02BFD94
Publisher : -
Version : 3.0.0.1820
Detection :
Related Objects :
File - %programw6432%\microsoft office\setup\msodeusa.dll
msacccah.dll
Status : Failed
Object : %programw6432%\microsoft office\setup\msacccah.dll
MD5 : 4126CEE75A7829122B3EF5097AB8580A
Publisher : -
Version : 1.20.0.2402
Detection :
Related Objects :
File - %programw6432%\microsoft office\setup\msacccah.dll
32AUTOLE.DLL
Status : Failed
Object : %programw6432%\microsoft office\setup\32autole.dll
MD5 : 0D303488CCE054204C323C37657AFA34
Publisher : -
Version : 2.40.4277.1
Detection :
Related Objects :
File - %programw6432%\microsoft office\setup\32autole.dll
SOA800.DLL
Status : Failed
Object : %programw6432%\microsoft office\office\soa800.dll
MD5 : 816A78403677AE254643A6F853BE76C1
Publisher : -
Version : 8.0.0.3720
Detection :
Related Objects :
File - %programw6432%\microsoft office\office\soa800.dll
MSAIN800.DLL
Status : Failed
Object : %programw6432%\microsoft office\office\msain800.dll
MD5 : AF9467B7B670FB1CD6DA0A2DC0C36639
Publisher : -
Version : 8.0.0.3511
Detection :
Related Objects :
File - %programw6432%\microsoft office\office\msain800.dll
MSACCESS.EXE
Status : Failed
Object : %programw6432%\microsoft office\office\msaccess.exe
MD5 : 3FCD641C1E928502E955890E0C604A15
Publisher : -
Version : 8.0.0.5903
Detection :
Related Objects :
File - %programw6432%\microsoft office\office\msaccess.exe
MSACC8.OLB
Status : Failed
Object : %programw6432%\microsoft office\office\msacc8.olb
MD5 : AFE18544E3AFABAEA2F3AEF94480873C
Publisher : -
Version : 8.0.0.3512
Detection :
Related Objects :
File - %programw6432%\microsoft office\office\msacc8.olb
lang-9999.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-9999.dll
MD5 : B45721A745A538BAF0C732665AE2F1B5
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-9999.dll
lang-5146.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-5146.dll
MD5 : FD5B2132332E07D00E9ED3C19D64CA6F
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-5146.dll
lang-3098.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-3098.dll
MD5 : 1CBEDF6A80B6453D57FD86B0C39222E0
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-3098.dll
lang-2074.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-2074.dll
MD5 : 4A99E0BA9AE239BB08DABEA1B477A7A6
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-2074.dll
lang-2070.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-2070.dll
MD5 : E4A11B42803D9AD64BB1EAA6AD3E562A
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-2070.dll
lang-2052.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-2052.dll
MD5 : DC63282FADD8A33F7DB0382D69A5FA62
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-2052.dll
lang-1155.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1155.dll
MD5 : BCE55ED817985189E65479B825AA7B96
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1155.dll
lang-1110.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1110.dll
MD5 : 931019300BB57C127C8A4905F0AA2C48
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1110.dll
lang-1109.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1109.dll
MD5 : FF6B0DF4A5173075E3BD964E6D2159E8
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1109.dll
lang-1104.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1104.dll
MD5 : 471DA8FC7D95AD6FD87D1EE0012BEC0E
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1104.dll
lang-1102.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1102.dll
MD5 : 6F154BB337577BC2B470E79F8898DD8D
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1102.dll
lang-1092.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1092.dll
MD5 : F56E61D7BCC993F0C6524A29AA5CE8A0
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1092.dll
lang-1090.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1090.dll
MD5 : 51C375E94A65A14F71A13EF76791F2A8
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1090.dll
lang-1087.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1087.dll
MD5 : CE2C96D23A1779BD845E951A7BCC297E
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1087.dll
lang-1081.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1081.dll
MD5 : F8B9DAC32A81A4152EDB5841E4586003
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1081.dll
lang-1079.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1079.dll
MD5 : D594D7C1917BFB60E82B532361D9D22C
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1079.dll
lang-1071.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1071.dll
MD5 : 53D1391B20973A4E636006715069452A
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1071.dll
lang-1068.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1068.dll
MD5 : 6D06BBCB6167638BE65730BFC7DCFCB7
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1068.dll
lang-1067.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1067.dll
MD5 : ED9FB0F8EF21C066F51D4437C7438B14
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1067.dll
lang-1066.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1066.dll
MD5 : 54F7CD8A904C3AC6AC1580B27E3F21D7
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1066.dll
lang-1065.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1065.dll
MD5 : 080E9039B733D07F5006808DCF54FB56
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1065.dll
lang-1063.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1063.dll
MD5 : 70FDE668536A75A3A8EE0DCFAF23B297
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1063.dll
lang-1062.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1062.dll
MD5 : 1CDED8E3C8D5868033BD8D2A37C4B413
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1062.dll
lang-1061.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1061.dll
MD5 : 12D054F027767EC84C25DB431A6EC16C
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1061.dll
lang-1060.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1060.dll
MD5 : 52DC94D646A315B2E67C99AC56F351BC
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1060.dll
lang-1059.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1059.dll
MD5 : 272243594AC536CA0A42A3D7D2CFB001
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1059.dll
Status : Failed
Object : %programw6432%\conexant\saii\zh-hans\smartaudio.resources.dll
MD5 : 72F47CC539FD41417399838F3B679551
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\zh-hans\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\zh-cn\smartaudio.resources.dll
MD5 : FD62CE91717A619896593FABBC4A5BD7
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\zh-cn\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\tr-tr\smartaudio.resources.dll
MD5 : 47D09DE264C66BFC07B5BDE63F9A4F91
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\tr-tr\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\th-th\smartaudio.resources.dll
MD5 : 45DF6AB9E9D7027E413257DC7F94DF6E
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\th-th\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\sv-se\smartaudio.resources.dll
MD5 : 349270255F795C76E7986D5F52697FC5
Publisher : -
Version : 6.0.48.3
Detection :
Related Objects :
File - %programw6432%\conexant\saii\sv-se\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\sl-si\smartaudio.resources.dll
MD5 : B5181092CA03E18DC70615EEE03D605A
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\sl-si\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\sk-sk\smartaudio.resources.dll
MD5 : 91236957C0BDA7969422469C2CEF1183
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\sk-sk\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\ru-ru\smartaudio.resources.dll
MD5 : 49FF5F7885F090B959D86A11426468F6
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\ru-ru\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\ro-ro\smartaudio.resources.dll
MD5 : 093C1E455B0998F794E0D274308A13B0
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\ro-ro\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\pt-pt\smartaudio.resources.dll
MD5 : 9333A0620081D87DCB318163E20197DD
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\pt-pt\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\pt-br\smartaudio.resources.dll
MD5 : D326E18B173E19B36CFDDBBB6B4183DA
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\pt-br\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\pl-pl\smartaudio.resources.dll
MD5 : D989CFD9D3522D27CB4C230E88A8B9EA
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\pl-pl\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\nl-nl\smartaudio.resources.dll
MD5 : 68CDAED4C4B5482E7ED3C40E74782503
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\nl-nl\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\en-us\smartaudio.resources.dll
MD5 : AC97F304807A7DC7AEAFEFE7CB7A4BA6
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\en-us\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\el-gr\smartaudio.resources.dll
MD5 : 98B64AE84F25BEB82EC6AB4AE23E9072
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\el-gr\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\de-de\smartaudio.resources.dll
MD5 : 3EFF0F54DFB4962DFD5421A6049DE000
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\de-de\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\ja-jp\smartaudio.resources.dll
MD5 : 5F69050B372993E858FB7A375F9869ED
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\ja-jp\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\it-it\smartaudio.resources.dll
MD5 : D8756CA659964BA4779D6FC8C95E82A7
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\it-it\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\hu-hu\smartaudio.resources.dll
MD5 : 66590E95C0930BBE8EC2891E238BFCD6
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\hu-hu\smartaudio.resources.dll
DarkSouls.ModScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\darksouls.modscript.dll
MD5 : 7008EA2E388DBF9E32508E1CB632630A
Publisher : -
Version : 1.1.4780.24962
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\darksouls.modscript.dll
DarkSouls.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\darksouls.dll
MD5 : 6DDCDD398C96FEDFCAEA3469417F6D31
Publisher : -
Version : 1.1.4780.24961
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\darksouls.dll
Commanding.dll
Status : Failed
Object : %programw6432%\nexus mod manager\commanding.dll
MD5 : 92C63DE19CF31037AA64CAB09B755634
Publisher : -
Version : 1.1.4780.24960
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\commanding.dll
ChinhDo.Transactions.dll
Status : Failed
Object : %programw6432%\nexus mod manager\chinhdo.transactions.dll
MD5 : 119B655450690384048E561EA0ACF29B
Publisher : -
Version : 1.1.0.25
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\chinhdo.transactions.dll
System.Xml.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\system.xml.ni.dll
MD5 : 42AA44BC8BFA85486D7C36E52F3350C3
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\system.xml.ni.dll
System.Windows.Xna.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\system.windows.xna.ni.dll
MD5 : 58401BF0D375A1B2677F535291624478
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\system.windows.xna.ni.dll
System.Windows.RuntimeHost.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\system.windows.runtimehost.ni.dll
MD5 : C104A6ACE446F246850395D0BF371C47
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\system.windows.runtimehost.ni.dll
System.Windows.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\system.windows.ni.dll
MD5 : 5DCBDC1221F52ED5C023E39AE1AE6D17
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\system.windows.ni.dll
System.Windows.Browser.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\system.windows.browser.ni.dll
MD5 : BEB824EFA15163E76A22AB1348BA66AD
Publisher : -
Version : 8.1.50907.0
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\system.windows.browser.ni.dll
System.ServiceModel.Web.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\system.servicemodel.web.ni.dll
MD5 : FAEBCFBDDEAEAA5B5E8F6903FD8C6B1B
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\system.servicemodel.web.ni.dll
System.ServiceModel.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\system.servicemodel.ni.dll
MD5 : 6EEA336D75DCFDDA148FEAE36DF9D6DE
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\system.servicemodel.ni.dll
System.Runtime.Serialization.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\system.runtime.serialization.ni.dll
MD5 : F820C80DD89B1BFB246E6E450E58AC4A
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\system.runtime.serialization.ni.dll
lang-1058.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1058.dll
MD5 : 416114E0B74C0015B78567615D037900
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1058.dll
lang-1057.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1057.dll
MD5 : 666EB6339CD6902ACFD883730B1AE69B
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1057.dll
lang-1055.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1055.dll
MD5 : 38ED3CF777A7F22583D80BB8F4451028
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1055.dll
lang-1054.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1054.dll
MD5 : 605C8D45964CBA721FAAB974DD1562E9
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1054.dll
lang-1053.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1053.dll
MD5 : 6E42D9BA02DA249CF7A371F202BAD349
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1053.dll
lang-1052.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1052.dll
MD5 : 74206B429B195792D192FA974B01BA96
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1052.dll
lang-1051.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1051.dll
MD5 : EEDEFBE370622FFD77DAD1A5D8ABCEF3
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1051.dll
lang-1050.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1050.dll
MD5 : 0FB7D465A4FCE21BF2EC550BFD285E45
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1050.dll
lang-1049.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1049.dll
MD5 : 92B7F5B4E7AE5C2F378AAC85C25B3CFB
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1049.dll
lang-1048.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1048.dll
MD5 : C1FA5259B9FEBC64D717256949DB3762
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1048.dll
lang-1046.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1046.dll
MD5 : 726D72EBA932C25F43DA3CB12F6A4F99
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1046.dll
lang-1045.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1045.dll
MD5 : 049BB6B13E349BA44D447BED7E993E9B
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1045.dll
Status : Failed
Object : %programw6432%\conexant\saii\da-dk\smartaudio.resources.dll
MD5 : 3213DD9DE9C8C5B16454C081EC37C8CE
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\da-dk\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\cs-cz\smartaudio.resources.dll
MD5 : 047D3BA72889F64FD6346DB8C3388454
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\cs-cz\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\ar-ae\smartaudio.resources.dll
MD5 : D484868960C5AC8AC3BBEFE9A2A2AAC2
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\ar-ae\smartaudio.resources.dll
Hdmicec.dll
Status : Failed
Object : %commonprogramw6432%\toshiba shared\hdmicec.dll
MD5 : 5076022B6B157FC9C06BDDEFFF081DCD
Publisher : -
Version : 1.5.0.0
Detection :
Related Objects :
File - %commonprogramw6432%\toshiba shared\hdmicec.dll
WeifenLuo.WinFormsUI.Docking.dll
Status : Failed
Object : %programw6432%\nexus mod manager\weifenluo.winformsui.docking.dll
MD5 : EECE681635356648DE4FF59832417D0A
Publisher : -
Version : 2.5.0.0
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\weifenluo.winformsui.docking.dll
Util.dll
Status : Failed
Object : %programw6432%\nexus mod manager\util.dll
MD5 : FE1F61F9990154B004F83FB27990852E
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\util.dll
unins000.exe
Status : Failed
Object : %programw6432%\nexus mod manager\uninstall\unins000.exe
MD5 : EDFE97BD8216BB934DEBA938E4DEBC81
Publisher : -
Version : 51.52.0.0
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\uninstall\unins000.exe
UI.dll
Status : Failed
Object : %programw6432%\nexus mod manager\ui.dll
MD5 : 07139B692452506506032F4EF08F00A8
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\ui.dll
Transactions.dll
Status : Failed
Object : %programw6432%\nexus mod manager\transactions.dll
MD5 : 88291E7A981233236E9B5E186C43B583
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\transactions.dll
XmlScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\scripttypes\xmlscript.dll
MD5 : 9A3ABF108444ABDF883566B804904599
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\scripttypes\xmlscript.dll
ModScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\scripttypes\modscript.dll
MD5 : 54ED4FD688211366EB637065917C8F6F
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\scripttypes\modscript.dll
CSharpScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\scripttypes\csharpscript.dll
MD5 : CEF679902C7132A66C15AA0ABC11036D
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\scripttypes\csharpscript.dll
AntlrUtil.dll
Status : Failed
Object : %programw6432%\nexus mod manager\scripttypes\antlrutil.dll
MD5 : 018085695EC04401D24EAA8612BFCE1E
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\scripttypes\antlrutil.dll
Scripting.dll
Status : Failed
Object : %programw6432%\nexus mod manager\scripting.dll
MD5 : C4C42CEFCB93B06AAE87CBB6043B1600
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\scripting.dll
ObjectListView.dll
Status : Failed
Object : %programw6432%\nexus mod manager\objectlistview.dll
MD5 : 7FD9B3FE3B39B35D91E2E0600D9DEAD1
Publisher : -
Version : 2.5.1.0
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\objectlistview.dll
NexusClient.Interface.dll
Status : Failed
Object : %programw6432%\nexus mod manager\nexusclient.interface.dll
MD5 : B6A9EE3D6A5D2D2984BC86D2CF483664
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\nexusclient.interface.dll
NexusClient.exe
Status : Failed
Object : %programw6432%\nexus mod manager\nexusclient.exe
MD5 : 5A8B4EBC70674D39C4B9CF5ED9CD24DC
Publisher : -
Version : 0.41.0.0
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\nexusclient.exe
Mods.dll
Status : Failed
Object : %programw6432%\nexus mod manager\mods.dll
MD5 : 72C19FCF468502FCF70BB417EDF2EADF
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\mods.dll
ModManager.Interface.dll
Status : Failed
Object : %programw6432%\nexus mod manager\modmanager.interface.dll
MD5 : F9E42E9B490BF36E13A40A6E4DC99592
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\modmanager.interface.dll
Status : Failed
Object : %programw6432%\conexant\saii\nb-no\smartaudio.resources.dll
MD5 : 8757C14245E16D2C127CB84EC5DAC879
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\nb-no\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\ko-kr\smartaudio.resources.dll
MD5 : D684EEF4FD0F50C65F6B440259BF1EAA
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\ko-kr\smartaudio.resources.dll
OMod.dll
Status : Failed
Object : %programw6432%\nexus mod manager\modformats\omod.dll
MD5 : 04AC9FDA024F9C04CDD79B2E44030050
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\modformats\omod.dll
FOMod.dll
Status : Failed
Object : %programw6432%\nexus mod manager\modformats\fomod.dll
MD5 : FE0B37AC3AA48F1FAFF05D47D79C8E40
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\modformats\fomod.dll
WorldOfTanks.ModScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\worldoftanks.modscript.dll
MD5 : BA5B99111FC03EAF517BD341DE479964
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\worldoftanks.modscript.dll
WorldOfTanks.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\worldoftanks.dll
MD5 : 049AD3A28C002100CD222F59EC06C3CC
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\worldoftanks.dll
Skyrim.XmlScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\skyrim.xmlscript.dll
MD5 : 3CB691385EAC3187332580D9FAFDA20B
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\skyrim.xmlscript.dll
Skyrim.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\skyrim.dll
MD5 : 84BF9F005503860E8A5EE20875BC182D
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\skyrim.dll
Skyrim.CSharpScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\skyrim.csharpscript.dll
MD5 : 7386F1329825CF65ED1AB9A7D13FF010
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\skyrim.csharpscript.dll
Oblivion.ModScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\oblivion.modscript.dll
MD5 : B54A23E16683CDB1176B121A109EC178
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\oblivion.modscript.dll
Oblivion.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\oblivion.dll
MD5 : 434C7E40DF8349E5C8F7D2E3208FE246
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\oblivion.dll
Morrowind.ModScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\morrowind.modscript.dll
MD5 : 69CBB97956F02619CA149C8643A8CC63
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\morrowind.modscript.dll
Morrowind.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\morrowind.dll
MD5 : 9B689D264D29936F9D7FFEAA2A550FE6
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\morrowind.dll
Grimrock.ModScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\grimrock.modscript.dll
MD5 : 87AFCB09FFB44416F9F5D932A832320A
Publisher : -
Version : 1.1.4780.24963
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\grimrock.modscript.dll
Grimrock.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\grimrock.dll
MD5 : 587E681C8C82B0080C37EBB1EBB37A60
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\grimrock.dll
GamebryoBase.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\gamebryobase.dll
MD5 : 21D5E97A90494F1655380C5371E12E86
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\gamebryobase.dll
FalloutNV.XmlScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\falloutnv.xmlscript.dll
MD5 : FC20395F4F938D49B1DFAA7B03C78FB6
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\falloutnv.xmlscript.dll
FalloutNV.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\falloutnv.dll
MD5 : 11BD88BAB7CC54473327598F6578E9A3
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\falloutnv.dll
FalloutNV.CSharpScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\falloutnv.csharpscript.dll
MD5 : F2B418780E917A2E2116BC18093C38F2
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\falloutnv.csharpscript.dll
Fallout3.XmlScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\fallout3.xmlscript.dll
MD5 : 0E3D811D0FFA7F93775869A09A657677
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\fallout3.xmlscript.dll
Fallout3.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\fallout3.dll
MD5 : DBDB77609F9374F2E39FEB9A1861095C
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\fallout3.dll
Fallout3.CSharpScript.dll
Status : Failed
Object : %programw6432%\nexus mod manager\gamemodes\fallout3.csharpscript.dll
MD5 : F85235047F34F633EC1F4E5D468B3757
Publisher : -
Detection :
Related Objects :
File - %programw6432%\nexus mod manager\gamemodes\fallout3.csharpscript.dll
Status : Failed
Object : %programw6432%\conexant\saii\hr-hr\smartaudio.resources.dll
MD5 : 9423C5C21B5FAD5CC0AF89EE1C82C3CE
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\hr-hr\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\he-il\smartaudio.resources.dll
MD5 : 7C0B977F67F33D8698C11C4C2029C1AC
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\he-il\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\fr-fr\smartaudio.resources.dll
MD5 : DDE87EE01DC0DADE86612576B068C712
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\fr-fr\smartaudio.resources.dll
Status : Failed
Object : %programw6432%\conexant\saii\fi-fi\smartaudio.resources.dll
MD5 : 5A093DEF87351428AACCE01BC59D729E
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\fi-fi\smartaudio.resources.dll
System.ni.dll
Status : Failed
Object : %programw6432%\microsoft silverlight\5.1.50907.0\system.ni.dll
MD5 : 895257573C274145BA534D6E810D0769
Publisher : -
Detection :
Related Objects :
File - %programw6432%\microsoft silverlight\5.1.50907.0\system.ni.dll
lang-1044.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1044.dll
MD5 : DAFECAD347FFD720BB34BCF32602FE7C
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1044.dll
lang-1043.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1043.dll
MD5 : 77DA9313257BA311F8E50C18B6DA533F
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1043.dll
lang-1042.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1042.dll
MD5 : 0982D104C9CD2155D0483C91ED720A19
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1042.dll
Status : Failed
Object : %programw6432%\conexant\saii\es-es\smartaudio.resources.dll
MD5 : 8195DB9F39A5446E846B8F89D9BD1EF3
Publisher : -
Version : 6.0.67.10
Detection :
Related Objects :
File - %programw6432%\conexant\saii\es-es\smartaudio.resources.dll
lang-1034.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1034.dll
MD5 : FA72FAD76D7F2AB0F673BC4F61B5097C
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1034.dll
lang-1032.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1032.dll
MD5 : BB4434B4A2B3B0F846A05683D3FC597B
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1032.dll
lang-1031.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1031.dll
MD5 : 1F4B2792D338201E88C92711920F5CCC
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1031.dll
lang-1030.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1030.dll
MD5 : 0DA1E9D0D575487D7C8F07F74C7FE888
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1030.dll
lang-1029.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1029.dll
MD5 : 8F008F0F938A7114D849D84C3985982D
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1029.dll
lang-1028.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1028.dll
MD5 : 2113C73FF39D57C6D18014C080C41F17
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1028.dll
lang-1027.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1027.dll
MD5 : 9265D55B0265E1C167E95A72E0D06AAF
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1027.dll
lang-1026.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1026.dll
MD5 : E6CE73F989433868EAE981197F34A182
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1026.dll
lang-1025.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1025.dll
MD5 : 618FC66AC77D2B594C03CA66E0F42601
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1025.dll
IJDIAH6.DLL
Status : Failed
Object : %programw6432%\canonbj\ijprinter\canon mp495 series\ijdiah6.dll
MD5 : 1D1A2F25A7E26996322E3A01E231F504
Publisher : -
Version : 1.8.0.70
Detection :
Related Objects :
File - %programw6432%\canonbj\ijprinter\canon mp495 series\ijdiah6.dll
lang-1041.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1041.dll
MD5 : 4F941D4710D55C6168585B616A257E86
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1041.dll
lang-1040.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1040.dll
MD5 : 1C1F8DA05A81363F31140ED3733B5E97
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1040.dll
lang-1038.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1038.dll
MD5 : D2D593E539A96841FC2C39C28799B6D4
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1038.dll
lang-1037.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1037.dll
MD5 : 0C83BA1903EC0DE03B6A5025DD1BDF70
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1037.dll
lang-1036.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1036.dll
MD5 : B1247DE4AFF39078E55D0EC433CE81F1
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1036.dll
lang-1035.dll
Status : Failed
Object : %programw6432%\ccleaner\lang\lang-1035.dll
MD5 : 358D1A697C90197CAC4A68459E28F6AA
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\ccleaner\lang\lang-1035.dll
ntdll.dll.mui
Status : Failed
Object : %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\system32\en-us\ntdll.dll.mui
MD5 : 5FFCA315F30C05A2D149398055092897
Publisher : -
Version : 10.0.10240.16384
Detection :
Related Objects :
File - %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\system32\en-us\ntdll.dll.mui
LOG.DLL
Status : Failed
Object : %programw6432%\canon\myprinter\log.dll
MD5 : F4A3931E60111AE6B55F4C3B29B59061
Publisher : -
Version : 2.5.0.0
Detection :
Related Objects :
File - %programw6432%\canon\myprinter\log.dll
BJMYRES.DLL
Status : Failed
Object : %programw6432%\canon\myprinter\bjmyres.dll
MD5 : 94AD6E6496D500AF2B87D50F9950F9A7
Publisher : -
Version : 2.5.0.0
Detection :
Related Objects :
File - %programw6432%\canon\myprinter\bjmyres.dll
BJMYDRC.DLL
Status : Failed
Object : %programw6432%\canon\myprinter\bjmydrc.dll
MD5 : AEEF9E8AD37954724F45B1804DFB96BB
Publisher : -
Version : 2.5.0.0
Detection :
Related Objects :
File - %programw6432%\canon\myprinter\bjmydrc.dll
BJMYRES.DLL
Status : Failed
Object : %programw6432%\canon\myprinter\32bit\bjmyres.dll
MD5 : 184305B8D032D19B09E805E5AD82CCE2
Publisher : -
Version : 2.5.0.0
Detection :
Related Objects :
File - %programw6432%\canon\myprinter\32bit\bjmyres.dll
ZipCompressionPlugin.acf
Status : Failed
Object : %programw6432%\avid\cloud client services\avx2_plug-ins\zipcompression\zipcompressionplugin.acf
MD5 : E4BF8C8CB4638EF5C3AD72B81BB49B05
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\avid\cloud client services\avx2_plug-ins\zipcompression\zipcompressionplugin.acf
XMLPlugin.avx
Status : Failed
Object : %programw6432%\avid\cloud client services\avx2_plug-ins\xml\xmlplugin.avx
MD5 : 3B04F1214DE07DB93AF58DDFD49C2890
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\avid\cloud client services\avx2_plug-ins\xml\xmlplugin.avx
EncryptedFileStreamPlugin.acf
Status : Failed
Object : %programw6432%\avid\cloud client services\avx2_plug-ins\xml\encryptedfilestreamplugin.acf
MD5 : A0ECC63C65F5ECF7B601917409D3077B
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\avid\cloud client services\avx2_plug-ins\xml\encryptedfilestreamplugin.acf
WavPackCompressionPlugin.acf
Status : Failed
Object : %programw6432%\avid\cloud client services\avx2_plug-ins\wavpackcompression\wavpackcompressionplugin.acf
MD5 : 177E0AD01E2BD1079BA05E6536FDE970
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\avid\cloud client services\avx2_plug-ins\wavpackcompression\wavpackcompressionplugin.acf
TransportCog.acf
Status : Failed
Object : %programw6432%\avid\cloud client services\avx2_plug-ins\transportcog.acf
MD5 : D31ED87EB1F58D4E4E0D9A4F7694B240
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\avid\cloud client services\avx2_plug-ins\transportcog.acf
ZipPlugin.acf
Status : Failed
Object : %programw6432%\avid\cloud client services\avx2_plug-ins\pxf\zipplugin.acf
MD5 : 44A23A6C005840743D4E631EAAF984C3
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\avid\cloud client services\avx2_plug-ins\pxf\zipplugin.acf
PXFPlugin.acf
Status : Failed
Object : %programw6432%\avid\cloud client services\avx2_plug-ins\pxf\pxfplugin.acf
MD5 : 43EDC9FE45C8096226A20CA2446CBD8F
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\avid\cloud client services\avx2_plug-ins\pxf\pxfplugin.acf
ACFString.avx
Status : Failed
Object : %programw6432%\avid\cloud client services\avx2_plug-ins\pxf\acfstring.avx
MD5 : 252F75532EDF96944AB65124189C6286
Publisher : -
Version : 1.0.0.525
Detection :
Related Objects :
File - %programw6432%\avid\cloud client services\avx2_plug-ins\pxf\acfstring.avx
ProjectSyncInterfaceCog.acf
Status : Failed
Object : %programw6432%\avid\cloud client services\avx2_plug-ins\projectsyncinterfacecog.acf
MD5 : 89513EB1EB40BAF0FC06DD35319E55F5
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\avid\cloud client services\avx2_plug-ins\projectsyncinterfacecog.acf
ProjectSyncCog.acf
Status : Failed
Object : %programw6432%\avid\cloud client services\avx2_plug-ins\projectsynccog.acf
MD5 : C21BB0FEE81CB5EF6312BA6B2F2B7689
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\avid\cloud client services\avx2_plug-ins\projectsynccog.acf
NetworkInterfaceCog.acf
Status : Failed
Object : %programw6432%\avid\cloud client services\avx2_plug-ins\networkinterfacecog.acf
MD5 : AB67DC8E10E12B39E44E116352DFDBCD
Publisher : -
Version : -
Detection :
Related Objects :
File - %programw6432%\avid\cloud client services\avx2_plug-ins\networkinterfacecog.acf
CbsProvider.dll.mui
Status : Failed
Object : %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..providers.resources_31bf3856ad364e35_10.0.10240.16384_en-us_790333db033912ce\cbsprovider.dll.mui
MD5 : 12B6C7AE620F86696C42E899CCE1FCF1
Publisher : -
Detection :
Related Objects :
File - %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..providers.resources_31bf3856ad364e35_10.0.10240.16384_en-us_790333db033912ce\cbsprovider.dll.mui
LogProvider.dll.mui
Status : Failed
Object : %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..ment-core.resources_31bf3856ad364e35_10.0.10240.16384_en-us_19f225195be92fc9\logprovider.dll.mui
MD5 : FF8621E734C216A980733BEAC7F57DD0
Publisher : -
Detection :
Related Objects :
File - %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..ment-core.resources_31bf3856ad364e35_10.0.10240.16384_en-us_19f225195be92fc9\logprovider.dll.mui
FolderProvider.dll.mui
Status : Failed
Object : %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..ment-core.resources_31bf3856ad364e35_10.0.10240.16384_en-us_19f225195be92fc9\folderprovider.dll.mui
MD5 : 1D6C115B9B76FB553DD71E9F8A97EA14
Publisher : -
Detection :
Related Objects :
File - %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..ment-core.resources_31bf3856ad364e35_10.0.10240.16384_en-us_19f225195be92fc9\folderprovider.dll.mui
DismProv.dll.mui
Status : Failed
Object : %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..ment-core.resources_31bf3856ad364e35_10.0.10240.16384_en-us_19f225195be92fc9\dismprov.dll.mui
MD5 : 1B8A287246CDEA7A0BB2C14A270DBF72
Publisher : -
Detection :
Related Objects :
File - %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..ment-core.resources_31bf3856ad364e35_10.0.10240.16384_en-us_19f225195be92fc9\dismprov.dll.mui
DismCore.dll.mui
Status : Failed
Object : %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..ment-core.resources_31bf3856ad364e35_10.0.10240.16384_en-us_19f225195be92fc9\dismcore.dll.mui
MD5 : 0D85F84DB92DDCF25FDAEDB9EC239E97
Publisher : -
Detection :
Cleaning Action : Quarantine
Related Objects :
File - %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..ment-core.resources_31bf3856ad364e35_10.0.10240.16384_en-us_19f225195be92fc9\dismcore.dll.mui
PEProvider.dll.mui
Status : Failed
Object : %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..ers-winpe.resources_31bf3856ad364e35_10.0.10240.16384_en-us_458dc983f54fcfda\peprovider.dll.mui
MD5 : 31EB380CADA1A6497F4AF1165A2CDC78
Publisher : -
Detection :
Related Objects :
File - %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-d..ers-winpe.resources_31bf3856ad364e35_10.0.10240.16384_en-us_458dc983f54fcfda\peprovider.dll.mui
boss64.dll
Status : Failed
Object : %homedrive%\boss\api\boss64.dll
MD5 : 6E9C212415602DCD6FD84EE41B6D4A51
Publisher : -
Version : -
Detection :
Related Objects :
File - %homedrive%\boss\api\boss64.dll
boss32.dll
Status : Failed
Object : %homedrive%\boss\api\boss32.dll
MD5 : 33AB386840365070C7B011B423D256BD
Publisher : -
Version : -
Detection :
Related Objects :
File - %homedrive%\boss\api\boss32.dll
BOOTSECT.BAK
Status : Failed
Object : %homedrive%\bootsect.bak
MD5 : 2ECEECBFBFB1F60DF8B2415E8574AE4B
Publisher : -
Version : -
Detection :
Related Objects :
File - %homedrive%\bootsect.bak
sw3d.dll
Status : Failed
Object : %homedrive%\.jagex_cache_32\runescape\sw3d.dll
MD5 : 6D6F4F16500B192B90E81EABC3B33456
Publisher : -
Version : -
Detection :
Related Objects :
File - %homedrive%\.jagex_cache_32\runescape\sw3d.dll
jagmisc.dll
Status : Failed
Object : %homedrive%\.jagex_cache_32\runescape\jagmisc.dll
MD5 : B1AEC1C2F33969077D489DDEF7C5B307
Publisher : -
Version : -
Detection :
Related Objects :
File - %homedrive%\.jagex_cache_32\runescape\jagmisc.dll
jaggl.dll
Status : Failed
Object : %homedrive%\.jagex_cache_32\runescape\jaggl.dll
MD5 : FBE7E528729FB12977578A79F95A9601
Publisher : -
Version : -
Detection :
Related Objects :
File - %homedrive%\.jagex_cache_32\runescape\jaggl.dll
jagdx.dll
Status : Failed
Object : %homedrive%\.jagex_cache_32\runescape\jagdx.dll
MD5 : 92B1AC438863D37C591DDC6204688848
Publisher : -
Version : -
Detection :
Related Objects :
File - %homedrive%\.jagex_cache_32\runescape\jagdx.dll
jaclib.dll
Status : Failed
Object : %homedrive%\.jagex_cache_32\runescape\jaclib.dll
MD5 : A94659D5832930D7E7AD04DFE16FCFA6
Publisher : -
Version : -
Detection :
Related Objects :
File - %homedrive%\.jagex_cache_32\runescape\jaclib.dll
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\zh-tw\hdmictrlman.exe.mui
MD5 : F060EBBBC7CE8B969D04FAC2BB917387
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\zh-tw\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\zh-tw\hdmictrlcfg.exe.mui
MD5 : 087B8B51CC18FC7AC6B92EF24A811508
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\zh-tw\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\zh-cn\hdmictrlman.exe.mui
MD5 : F6F8E8296AF278325C39B7A0416EC4E1
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\zh-cn\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\zh-cn\hdmictrlcfg.exe.mui
MD5 : 52CAFDAD8D6CB73FE79947A81A9580AB
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\zh-cn\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\tr\hdmictrlman.exe.mui
MD5 : 6CF1B75969A755F695040A800DB844A3
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\tr\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\tr\hdmictrlcfg.exe.mui
MD5 : ED12B7672F2C4320165DDEB6C19B93F5
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\tr\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\sv\hdmictrlman.exe.mui
MD5 : D06936A30765FC226619ED172778F146
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\sv\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\sv\hdmictrlcfg.exe.mui
MD5 : 34A3AB7BD493DCAD6136E5995BEDE69F
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\sv\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\sk\hdmictrlman.exe.mui
MD5 : B9871D4BD604BDF473BACC7BAC7213BD
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\sk\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\sk\hdmictrlcfg.exe.mui
MD5 : 800866C13C3BD1D0180CD405337D1E7E
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\sk\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\ru\hdmictrlman.exe.mui
MD5 : 58EFC8AB406D59CEE5D4011198523E12
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\ru\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\ru\hdmictrlcfg.exe.mui
MD5 : 835A5F3E5F9B4F9252D4366EA87ADB58
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\ru\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\pt\hdmictrlman.exe.mui
MD5 : F58044DA2AB6BFFF288F37AC27A37381
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\pt\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\pt\hdmictrlcfg.exe.mui
MD5 : C0A25DB8DDE8BC19CCDE3D15212351F9
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\pt\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\pl\hdmictrlman.exe.mui
MD5 : 58D76EAB322776211F23F6C17B4DD3FE
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\pl\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\pl\hdmictrlcfg.exe.mui
MD5 : 1DA0FBE40E1F410DAFAE64C8C667A195
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\pl\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\no\hdmictrlman.exe.mui
MD5 : DE064094BE7AEDAC835E428F586F4D71
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\no\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\no\hdmictrlcfg.exe.mui
MD5 : 8B9B704049C69E9D59998303950BF696
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\no\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\nl\hdmictrlman.exe.mui
MD5 : 86986951B4A48E5A73D30978604CBB7E
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\nl\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\nl\hdmictrlcfg.exe.mui
MD5 : CDDED7F7E5743D75979983D2BEB08763
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\nl\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\ko-kr\hdmictrlman.exe.mui
MD5 : 3463D08DD1CF821C5A71DA08E427350E
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\ko-kr\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\ko-kr\hdmictrlcfg.exe.mui
MD5 : 05DB346925C6C3D4EE233D16A039C738
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\ko-kr\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\ja-jp\hdmictrlman.exe.mui
MD5 : 596679ECD094D29EA25EAE3F60642856
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\ja-jp\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\ja-jp\hdmictrlcfg.exe.mui
MD5 : B98C42C4F6698200FE5512E517DCA7D5
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\ja-jp\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\it\hdmictrlman.exe.mui
MD5 : 93F4EC790CD198D88EEA7D215B2C9163
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\it\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\it\hdmictrlcfg.exe.mui
MD5 : 64287D3B08509544C5E7990C763C1A1A
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\it\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\hu\hdmictrlman.exe.mui
MD5 : 9794B99ECBB10136CC19998C36B8333C
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\hu\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\hu\hdmictrlcfg.exe.mui
MD5 : 2234E87E1194BA28E5B9083E2CF5EC29
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\hu\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\fr\hdmictrlman.exe.mui
MD5 : 291CE452C138CF0F088B0FD579A497A4
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\fr\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\fr\hdmictrlcfg.exe.mui
MD5 : FCBF956437BB90F0FD691E2FBCF77333
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\fr\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\fi\hdmictrlman.exe.mui
MD5 : 371FCD352C16D37C0727CC41C4B3BF8C
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\fi\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\fi\hdmictrlcfg.exe.mui
MD5 : 9ACC0438DBA86F534CD41FE53B261F1E
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\fi\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\es\hdmictrlman.exe.mui
MD5 : CCE7AA3CAF29338F5D257060D3458856
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\es\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\es\hdmictrlcfg.exe.mui
MD5 : 32ED74E8243CD9C07D802C1B4C4CC3BB
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\es\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\en\hdmictrlman.exe.mui
MD5 : 52F7AC000EA5127C0A4579B05C5BE4C5
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\en\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\en\hdmictrlcfg.exe.mui
MD5 : E896E8E21B0075B3CE84558BC4435AAC
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\en\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\el\hdmictrlman.exe.mui
MD5 : 300716F75C72C2FC5377472FD80D32CF
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\el\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\el\hdmictrlcfg.exe.mui
MD5 : 81CF3A7D4C9166EA5A96D8D785D1E32B
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\el\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\de\hdmictrlman.exe.mui
MD5 : 6FAB2D60C25BF68275023AAE833626A4
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\de\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\de\hdmictrlcfg.exe.mui
MD5 : 6C05A22CCB26FB0391F22786AEC2ADB2
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\de\hdmictrlcfg.exe.mui
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\da\hdmictrlman.exe.mui
MD5 : 19E0A8938CF473D610287E981390ADAC
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\da\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\da\hdmictrlcfg.exe.mui
MD5 : 6EB3E13895344C2989D630E5D723F100
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\da\hdmictrlcfg.exe.mui
ntdll.dll.mui
Status : Failed
Object : %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-ntdll.resources_31bf3856ad364e35_10.0.10240.16384_en-us_709524c3f6cf3e3d\ntdll.dll.mui
Publisher : -
Detection :
Related Objects :
File - %homedrive%\$windows.~bt\sources\safeos\safeos.mount\windows\winsxs\amd64_microsoft-windows-ntdll.resources_31bf3856ad364e35_10.0.10240.16384_en-us_709524c3f6cf3e3d\ntdll.dll.mui
thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\zh-cn\thp3dv.exe.mui
MD5 : 6500BB7A2368E045FEC244017D594520
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\zh-cn\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\zh-cn\notifythp.dll.mui
MD5 : 2245AFC8AA381B4E0683D3B4B7E55B8D
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\zh-cn\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\tr\thp3dv.exe.mui
MD5 : 3AB2F6D8D72DD8B5D2B6073A0B225AAB
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\tr\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\tr\notifythp.dll.mui
MD5 : BF639B4B4BC34D1A08D9EFE4A97F77D3
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\tr\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\sv\thp3dv.exe.mui
MD5 : FA2453BF1A52BA6849B00D1077BF0D27
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\sv\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\sv\notifythp.dll.mui
MD5 : 1E3709419A5BFDB622E82DB64B2D8EA1
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\sv\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\sk\thp3dv.exe.mui
MD5 : 89EA561822E453386A4206A30DA456D0
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\sk\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\sk\notifythp.dll.mui
MD5 : 2468DB0CD048A4D32655727085CD7380
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\sk\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\ru\thp3dv.exe.mui
MD5 : 7F7D9921C400750460D8CCD16B626903
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\ru\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\ru\notifythp.dll.mui
MD5 : 046D79F0ABB2E137D70BE16BA49E0FFC
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\ru\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\pt\thp3dv.exe.mui
MD5 : CDB76DF1F08BE476EB4070CE30C8E20F
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\pt\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\pt\notifythp.dll.mui
MD5 : 8E4C60CFC3C961823EB90855EA1E0D4F
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\pt\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\pl\thp3dv.exe.mui
MD5 : DF384DE75578E93D21E733C7E97C72DB
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\pl\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\pl\notifythp.dll.mui
MD5 : 2F767C162C0DBA9049E6E5A46A5E2904
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\pl\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\no\thp3dv.exe.mui
MD5 : 2B23D99A5B70B44B95FB84BED28CFF84
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\no\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\no\notifythp.dll.mui
MD5 : 0E66F54475CABE0E8474F2F68DED1367
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\no\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\nl\thp3dv.exe.mui
MD5 : 650CA93BC18EC17EA841D29B7A9F3A89
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\nl\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\nl\notifythp.dll.mui
MD5 : 43B592FBA2B41F972AC83531C35312C2
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\nl\notifythp.dll.mui
thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\ko-kr\thp3dv.exe.mui
MD5 : 29E29F4F4246E30C0D0AAA11877579F3
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\ko-kr\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\ko-kr\notifythp.dll.mui
MD5 : 40E56D37C392852A037CC59FB0E3A52A
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\ko-kr\notifythp.dll.mui
thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\ja-jp\thp3dv.exe.mui
MD5 : E31F7E74FA18E1149CF1FDC9596ABCC3
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\ja-jp\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\ja-jp\notifythp.dll.mui
MD5 : 5FB79E6FC7715BEDEF2C8A55C82E4148
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\ja-jp\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\it\thp3dv.exe.mui
MD5 : 6A49719C9DDFB16823D62B2D5F80D0E2
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\it\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\it\notifythp.dll.mui
MD5 : B138636D8E1234166132F1ECD24F8C17
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\it\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\hu\thp3dv.exe.mui
MD5 : 6EA1EE395004BE1F247045D469D0EC4F
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\hu\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\hu\notifythp.dll.mui
MD5 : 7BDE145BE5105CC25E46606BEEC0F295
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\hu\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\fr\thp3dv.exe.mui
MD5 : 2C3520884193D215106A27270D496C9D
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\fr\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\fr\notifythp.dll.mui
MD5 : 717D046EF85B8542E38350418F6319E2
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\fr\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\fi\thp3dv.exe.mui
MD5 : 3F92B93F2E98D5AB432D24B61AE6279F
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\fi\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\fi\notifythp.dll.mui
MD5 : E04CD7B513F8A8DF37BCCB0624381CA7
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\fi\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\es\thp3dv.exe.mui
MD5 : 2F54B451DCCA08A95B3F9B5EA02BE419
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\es\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\es\notifythp.dll.mui
MD5 : A007F97B7C11459CFBA6160B1A1A92D2
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\es\notifythp.dll.mui
thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\en\thp3dv.exe.mui
MD5 : 0F341B441FA22FBE35CD0D537AC47796
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\en\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\en\notifythp.dll.mui
MD5 : D2124A1E607B07017F44154FB9E45DA2
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\en\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\el\thp3dv.exe.mui
MD5 : 7B815743C0DE22F1DB94F6D1257BE08F
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\el\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\el\notifythp.dll.mui
MD5 : E3C1C1679645378BB6FD2DD2C6CC606A
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\el\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\de\thp3dv.exe.mui
MD5 : 18DDF360C26FDF6BB450E46DECECEC89
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\de\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\de\notifythp.dll.mui
MD5 : 8D98B44958F1D9309F7726D5124D1B68
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\de\notifythp.dll.mui
Thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\da\thp3dv.exe.mui
MD5 : 268C45DC53574AFBE4258CE17CD957D2
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\da\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\da\notifythp.dll.mui
MD5 : 41F212F4F608CF63640976210885D096
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\da\notifythp.dll.mui
CXHDMI.dll
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\cxhdmi.dll
MD5 : A614185C9525BF453EF735FB2BFD800E
Publisher : -
Version : 1.5.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\cxhdmi.dll
HDMICtrlMan.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\cs\hdmictrlman.exe.mui
MD5 : AF174E1D0D1F28A792ADFD399DAC14BB
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\cs\hdmictrlman.exe.mui
HDMICtrlCfg.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdmictrlman\cs\hdmictrlcfg.exe.mui
MD5 : FF868FA28DAA3DC34E6ADB9A5C322FD2
Publisher : -
Version : 1.6.0.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdmictrlman\cs\hdmictrlcfg.exe.mui
thp3dv.exe.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\zh-tw\thp3dv.exe.mui
MD5 : 41BDD8B2592BF1B1F214B70CAFE5755A
Publisher : -
Version : 1.0.2.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\zh-tw\thp3dv.exe.mui
NotifyTHP.dll.mui
Status : Failed
Object : %programw6432%\toshiba\hdd protection\zh-tw\notifythp.dll.mui
MD5 : DFD4D12F61FAA17BA8C2F40A6CDDFB65
Publisher : -
Version : 1.0.1.0
Detection :
Related Objects :
File - %programw6432%\toshiba\hdd protection\zh-tw\notifythp.dll.mui
Logfile of HiJackThis Fork (Alpha) by Alex Dragokas v.2.6.4.17
Platform: x64 Windows 7 (Home Premium), 6.1.7601, Service Pack: 1
Time: 20.06.2017 - 21:11
Language: OS: English (0x409). Display: English (0x409). Non-Unicode: English (0x409)
Elevated: Yes
Ran by: Juancho (group: Administrator) on JUANCHO-PC
Chrome: 58.0.3029.110
Firefox: 43.0.1.5828
Internet Explorer: 11.0.9600.18698
Boot mode: Normal
Running processes:
Number | Path
2 C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\avp.exe
1 C:\Program Files (x86)\Microsoft SQL Server\90\Shared\sqlbrowser.exe
1 C:\Program Files (x86)\Microsoft SQL Server\MSSQL.1\MSSQL\Binn\sqlservr.exe
1 C:\Program Files (x86)\Microsoft Small Business\Business Contact Manager\BcmSqlStartupSvc.exe
1 C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe
1 C:\Program Files\Bonjour\mDNSResponder.exe
1 C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
1 C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE
1 C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVCM.EXE
1 C:\Program Files\Microsoft SQL Server\90\Shared\sqlwriter.exe
8 C:\Users\Juancho\AppData\Local\Google\Chrome\Application\chrome.exe
1 C:\Users\Juancho\Desktop\pc help forum stuff\HiJackThis\HiJackThis.exe
2 C:\Windows\SysWOW64\dllhost.exe
1 C:\Windows\SysWOW64\notepad.exe
1 C:\Windows\SysWOW64\wbem\WmiPrvSE.exe
1 C:\Windows\System32\SearchFilterHost.exe
1 C:\Windows\System32\SearchIndexer.exe
1 C:\Windows\System32\SearchProtocolHost.exe
1 C:\Windows\System32\audiodg.exe
2 C:\Windows\System32\csrss.exe
2 C:\Windows\System32\dllhost.exe
1 C:\Windows\System32\dwm.exe
1 C:\Windows\System32\lsass.exe
1 C:\Windows\System32\lsm.exe
1 C:\Windows\System32\services.exe
1 C:\Windows\System32\smss.exe
1 C:\Windows\System32\spoolsv.exe
14 C:\Windows\System32\svchost.exe
2 C:\Windows\System32\taskhost.exe
1 C:\Windows\System32\wininit.exe
1 C:\Windows\System32\winlogon.exe
1 C:\Windows\explorer.exe
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R4 - HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: SuggestionsURL = http://api.bing.com/qsml.aspx?query={searchTerms}&market={language}&maxwidth={ie:maxWidth}&rowheight={ie:rowHeight}&sectionHeight={ie:sectionHeight}&FORM=IESS02&pc=UE11
R4 - HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: TopResultURL = http://www.bing.com/search?q={searchTerms}&src=IE-TopResult&FORM=IETR02&pc=UE11
R4 - HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: URL = http://www.bing.com/search?q={searchTerms}&src=IE-SearchBox&FORM=IESR02&pc=UE11
R4 - HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{67C334C0-408D-4E6D-B5A7-0ADD6AFFA252} - Google - http://www.google.com/search?q={searchTerms}&sourceid=ie7&rls=com.microsoft:{language}:{referrer:source}&ie={inputEncoding?}&oe={outputEncoding?}
R4 - HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{6A1806CD-94D4-4689-BA73-E35EA1EA9990} - Google - http://www.google.com/search?q={searchTerms}&rls=com.microsoft:{language}:{referrer:source?}&ie={inputEncoding}&oe={outputEncoding}&sourceid=ie7
R4 - HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{C1504460-8476-4083-B651-4E0C3A64FAE4} - Google - http://www.google.com/search?sourceid=ie7&q={searchTerms}&rls=com.microsoft:{language}:{referrer:source?}&ie={inputEncoding}&oe={outputEncoding}&rlz=1I7TSAU_enAU418AU418
R4 - HKLM\Software\Microsoft\Internet Explorer\SearchScopes: DefaultScope = {67A2568C-7A0A-4EED-AECC-B5405DE63B64} - Google - http://www.google.com/search?sourceid=ie7&q={searchTerms}&rls=com.microsoft:{language}:{referrer:source?}&ie={inputEncoding}&oe={outputEncoding}&rlz=1I7TSAU
R4 - HKLM\Software\Microsoft\Internet Explorer\SearchScopes\{67A2568C-7A0A-4EED-AECC-B5405DE63B64} - Google - http://www.google.com/search?sourceid=ie7&q={searchTerms}&rls=com.microsoft:{language}:{referrer:source?}&ie={inputEncoding}&oe={outputEncoding}&rlz=1I7TSAU
O2 - BHO: ContentBlockerBrowserHelperObject - {5564CC73-EFA7-4CBF-918A-5CF7FBBFFF4F} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\x64\IEExt\ContentBlocker\ie_content_blocker_plugin.dll
O2 - BHO: Safe Money Plugin - {9E6D0D23-3D72-4A94-AE1F-2D167624E3D9} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\x64\IEExt\OnlineBanking\online_banking_bho.dll
O2 - BHO: SkypeIEPluginBHO - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer x64\skypeieplugin.dll
O2 - BHO: URLRedirectionBHO - {B4F3A835-0E21-4959-BA22-42B3008E02FF} - C:\Program Files\Microsoft Office\Office14\URLREDIR.DLL
O2 - BHO: VirtualKeyboardBrowserHelperObject - {73455575-E40C-433C-9784-C78DC7761455} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\x64\IEExt\VirtualKeyboard\ie_virtual_keyboard_plugin.dll
O2 - BHO: Windows Live ID Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: link filter bho - {E33CF602-D945-461A-83F0-819F76A199F8} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\x64\IEExt\UrlAdvisor\klwtbbho.dll
O2-32 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2-32 - BHO: Canon Easy-WebPrint EX BHO - {3785D0AD-BFFF-47F6-BF5B-A587C162FED9} - C:\Program Files (x86)\Canon\Easy-WebPrint EX\ewpexbho.dll
O2-32 - BHO: ContentBlockerBrowserHelperObject - {5564CC73-EFA7-4CBF-918A-5CF7FBBFFF4F} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\IEExt\ContentBlocker\ie_content_blocker_plugin.dll
O2-32 - BHO: Safe Money Plugin - {9E6D0D23-3D72-4A94-AE1F-2D167624E3D9} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\IEExt\OnlineBanking\online_banking_bho.dll
O2-32 - BHO: SkypeIEPluginBHO - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O2-32 - BHO: URLRedirectionBHO - {B4F3A835-0E21-4959-BA22-42B3008E02FF} - C:\Program Files (x86)\Microsoft Office\Office14\URLREDIR.DLL
O2-32 - BHO: VirtualKeyboardBrowserHelperObject - {73455575-E40C-433C-9784-C78DC7761455} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\IEExt\VirtualKeyboard\ie_virtual_keyboard_plugin.dll
O2-32 - BHO: Windows Live ID Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2-32 - BHO: link filter bho - {E33CF602-D945-461A-83F0-819F76A199F8} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\IEExt\UrlAdvisor\klwtbbho.dll
O3-32 - Toolbar: Canon Easy-WebPrint EX - {759D9886-0C6F-4498-BAB6-4A5F47C6C72F} - C:\Program Files (x86)\Canon\Easy-WebPrint EX\ewpexhlp.dll
O4 - HKCU\..\Run: [CCleaner] C:\Program Files\CCleaner\CCleaner64.exe /AUTO
O4 - HKLM\..\Run: [ZAM] C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe /minimized
O4 - HKLM\..\Run: [iTunesHelper] C:\Program Files\iTunes\iTunesHelper.exe (file missing)
O4 - HKU\S-1-5-18\..\Run: [Raptr] C:\Program Files (x86)\Raptr\raptrstub.exe --startup
O4 - HKU\S-1-5-19\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\Sidebar.exe /autoRun
O4 - HKU\S-1-5-19\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe
O4 - HKU\S-1-5-20\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\Sidebar.exe /autoRun
O4 - HKU\S-1-5-20\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe
O4 - MSConfig\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^Avid Application Manager.lnk - C:\windows\Installer\{A59C0B17-6673-46E6-9E00-BB25E755A299}\NewShortcut1_E1E0FF1FC1474601A40EFEF248F11D43.exe --trayonly (2017/05/23)
O4 - MSConfig\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^Bluetooth Manager.lnk - C:\Program Files (x86)\Toshiba\Bluetooth Toshiba Stack\TosBtMng.exe (2013/10/08)
O4 - MSConfig\startupreg: [00TCrdMain] %ProgramFiles%\TOSHIBA\FlashCards\TCrdMain.exe (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [APSDaemon] C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [Adobe ARM] C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [Adobe Reader Speed Launcher] C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [AppManHelper] C:\Program Files (x86)\Avid\Application Manager\AvidAppManHelper.exe (HKLM) (2017/05/23)
O4 - MSConfig\startupreg: [CanonMyPrinter] C:\Program Files\Canon\MyPrinter\BJMyPrt.exe /logon (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [CanonSolutionMenuEx] C:\Program Files (x86)\Canon\Solution Menu EX\CNSEMAIN.EXE /logon (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [DigidesignMMERefresh] (no file) (HKLM) (2017/05/23)
O4 - MSConfig\startupreg: [EA Core] C:\Program Files (x86)\Electronic Arts\EADM\Core.exe -silent (file missing) (HKCU) (2017/06/08)
O4 - MSConfig\startupreg: [Google Update] C:\Users\Juancho\AppData\Local\Google\Update\1.3.33.5\GoogleUpdateCore.exe (HKCU) (2017/06/08)
O4 - MSConfig\startupreg: [HDMICtrlMan] %ProgramFiles%\TOSHIBA\HDMICtrlMan\HDMICtrlMan.exe (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [HSON] %ProgramFiles%\TOSHIBA\TBS\HSON.exe (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [IAStorIcon] C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [ITSecMng] %ProgramFiles%\TOSHIBA\Bluetooth Toshiba Stack\ItSecMng.exe /START (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [NvBackend] C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe (HKLM) (2017/05/23)
O4 - MSConfig\startupreg: [Nvtmru] C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Update Core\nvtmru.exe (file missing) (HKLM) (2015/09/18)
O4 - MSConfig\startupreg: [QuickTime Task] C:\Program Files (x86)\QuickTime\QTTask.exe -atboottime (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [ShadowPlay] C:\windows\system32\rundll32.exe C:\windows\system32\nvspcap64.dll,ShadowPlayOnSystemStart (HKLM) (2017/05/23)
O4 - MSConfig\startupreg: [SmartAudio] C:\Program Files\CONEXANT\SAII\SAIICpl.exe /t (HKLM) (2017/05/23)
O4 - MSConfig\startupreg: [SmartFaceVWatcher] %ProgramFiles%\Toshiba\SmartFaceV\SmartFaceVWatcher.exe (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [SmoothView] %ProgramFiles%\Toshiba\SmoothView\SmoothView.exe (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [SunJavaUpdateSched] C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [SynTPEnh] %ProgramFiles%\Synaptics\SynTP\SynTPEnh.exe (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [TPwrMain] %ProgramFiles%\TOSHIBA\Power Saver\TPwrMain.EXE (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [TUSBSleepChargeSrv] %ProgramFiles(x86)%\TOSHIBA\TOSHIBA USB Sleep and Charge Utility\TUSBSleepChargeSrv.exe (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [TWebCamera] C:\Program Files (x86)\TOSHIBA\TOSHIBA Web Camera Application\TWebCamera.exe autorun (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [Teco] %ProgramFiles%\TOSHIBA\TECO\Teco.exe /r (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [ThpSrv] C:\windows\system32\thpsrv.exe /logon (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [TosNC] %ProgramFiles%\Toshiba\BulletinBoard\TosNcCore.exe (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [TosReelTimeMonitor] %ProgramFiles%\TOSHIBA\ReelTime\TosReelTimeMonitor.exe (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [TosSENotify] C:\Program Files\TOSHIBA\TOSHIBA HDD SSD Alert\TosWaitSrv.exe (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [TosWaitSrv] %ProgramFiles%\TOSHIBA\TPHM\TosWaitSrv.exe (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [ToshibaServiceStation] C:\Program Files (x86)\TOSHIBA\TOSHIBA Service Station\ToshibaServiceStation.exe /hide:60 (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [amd_dc_opt] C:\Program Files (x86)\AMD\Dual-Core Optimizer\amd_dc_opt.exe (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [cAudioFilterAgent] C:\Program Files\Conexant\cAudioFilterAgent\cAudioFilterAgent64.exe (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [iTunesHelper] C:\Program Files (x86)\iTunes\iTunesHelper.exe (file missing) (HKLM) (2013/10/08)
O4 - MSConfig\startupreg: [igndlm.exe] C:\Program Files (x86)\Download Manager\DLM.exe /windowsstart /startifwork (file missing) (HKCU) (2013/10/08)
O4 - MSConfig\startupreg: [swg] C:\Program Files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (file missing) (HKCU) (2017/05/23)
O4-32 - HKLM\..\Run: [AVP] C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\avp.exe
O8 - Extra context menu item: Add to Anti-Banner - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\ie_banner_deny.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - C:\Program Files (x86)\Microsoft Office\Office14\EXCEL.EXE
O8 - Extra context menu item: Se&nd to OneNote - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files\Microsoft Office\Office14\ONBttnIELinkedNotes.dll (HKLM)
O9 - Extra 'Tools' menuitem: Se&nd to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office14\ONBttnIE.dll (HKLM)
O9 - Extra button: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files\Microsoft Office\Office14\ONBttnIELinkedNotes.dll (HKLM)
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office14\ONBttnIE.dll (HKLM)
O9 - Extra button: Skype Click to Call - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer x64\skypeieplugin.dll (HKLM)
O9 - Extra button: URLs check - {CCF151D8-D089-449F-A5A4-D9909053F20F} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\x64\IEExt\UrlAdvisor\klwtbbho.dll (HKLM)
O9 - Extra button: Virtual Keyboard - {0C4CC089-D306-440D-9772-464E226F6539} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\x64\IEExt\VirtualKeyboard\ie_virtual_keyboard_plugin.dll (HKLM)
O9-32 - Extra 'Tools' menuitem: &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll (HKLM)
O9-32 - Extra 'Tools' menuitem: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIELinkedNotes.dll (HKLM)
O9-32 - Extra 'Tools' menuitem: Se&nd to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIE.dll (HKLM)
O9-32 - Extra button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll (HKLM)
O9-32 - Extra button: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIELinkedNotes.dll (HKLM)
O9-32 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIE.dll (HKLM)
O9-32 - Extra button: Skype Click to Call - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (HKLM)
O9-32 - Extra button: URLs check - {CCF151D8-D089-449F-A5A4-D9909053F20F} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\IEExt\UrlAdvisor\klwtbbho.dll (HKLM)
O9-32 - Extra button: Virtual Keyboard - {0C4CC089-D306-440D-9772-464E226F6539} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\IEExt\VirtualKeyboard\ie_virtual_keyboard_plugin.dll (HKLM)
O16-32 - DPF: {166B1BCA-3F9C-11CF-8075-444553540000} (Shockwave ActiveX Control) - http://download.macromedia.com/pub/shockwave/cabs/director/sw.cab
O16-32 - DPF: {1E54D648-B804-468d-BC78-4AFFED8E262F} (System Requirements Lab) - http://www.nvidia.com/content/DriverDownload/srl/3.0.0.4/srl_bin/sysreqlab_nvd.cab
O16-32 - DPF: {39B0684F-D7BF-4743-B050-FDC3F48F7E3B} - http://www.fileplanet.com/fpdlmgr/cabs/FPDC_2.3.10.115.cab
O16-32 - DPF: {E6F480FC-BD44-4CBA-B74A-89AF7842937D} - http://content.systemrequirementslab.com.s3.amazonaws.com/global/bin/srldetect_cyri_4.4.26.0.cab
O17 - DHCP DNS - 1: 192.168.1.1
O18 - Filter hijack: text/xml - {807573E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\Microsoft Shared\OFFICE14\MSOXMLMF.DLL
O18 - Protocol: skype-ie-addon-data - {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer x64\skypeieplugin.dll
O18 - Protocol: wlpg - {E43EF6CD-A37A-4A9B-9E6F-83F89B8E6324} - C:\Program Files (x86)\Windows Live\Photo Gallery\AlbumDownloadProtocolHandler.dll
O22 - Task (Disabled): GoogleUpdateTaskUserS-1-5-21-794287275-3297088658-3092121377-1004Core - C:\Users\Juancho\AppData\Local\Google\Update\GoogleUpdate.exe /c
O22 - Task (Disabled): GoogleUpdateTaskUserS-1-5-21-794287275-3297088658-3092121377-1004UA - C:\Users\Juancho\AppData\Local\Google\Update\GoogleUpdate.exe /ua /installsource scheduler
O22 - Task (Disabled): \OfficeSoftwareProtectionPlatform\SvcRestartTask - C:\windows\system32\sc.exe start osppsvc
O22 - Task (Ready): CCleanerSkipUAC - C:\Program Files\CCleaner\CCleaner.exe $(Arg0)
O22 - Task (Ready): Kaspersky_Upgrade_Launcher_{278ADC42-419D-4547-A6CA-5B74BE0AD901} - C:\Program Files\Common Files\AV\Kaspersky Lab\upgrade_launcher.exe /waitUpgrade
O22 - Task (Ready): \Microsoft\Windows Live\SOXE\Extractor Definitions Update Task - {3519154C-227E-47F3-9CC9-12C3F05817F1} - (no file)
O22 - Task (Ready): \Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser - C:\windows\system32\CompatTelRunner.exe
O22 - Task (Ready): \Microsoft\Windows\Application Experience\ProgramDataUpdater - C:\windows\system32\compattelrunner.exe -maintenance
O22 - Task (Ready): \Microsoft\Windows\Customer Experience Improvement Program\Uploader - C:\windows\system32\WSqmCons.exe -u
O22 - Task (Ready): \Microsoft\Windows\Windows Activation Technologies\ValidationTask - C:\windows\system32\Wat\WatAdminSvc.exe /run
O22 - Task (Ready): \Microsoft\Windows\Windows Activation Technologies\ValidationTaskDeadline - C:\windows\system32\schtasks.exe /run /I /TN "\Microsoft\Windows\Windows Activation Technologies\ValidationTask"
O22 - Task (Ready): {3D085530-2A46-48C6-BA7D-1EFCA89A122A} - C:\windows\system32\pcalua.exe -a "C:\Program Files (x86)\Common Files\BioWare\Uninstall Mass Effect.exe" -c 2.exe
O22 - Task (Ready): {C0D69CF6-BA5F-4BAD-9611-508F1BCCD3DB} - C:\windows\system32\pcalua.exe -a C:\windows\IsUninst.exe -c -f"C:\Program Files (x86)\Infogrames\V-Rally\Uninst.isu"
O23 - Service R2: Apple Mobile Device Service - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service R2: Bonjour Service - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service R2: Kaspersky Anti-Virus Service - (AVP) - C:\Program Files (x86)\Kaspersky Lab\Kaspersky PURE 3.0\avp.exe
O23 - Service R2: Windows Defender - (WinDefend) - C:\windows\System32\svchost.exe; "ServiceDll" = C:\Program Files\Windows Defender\mpsvc.dll
O23 - Service R2: ZAM Controller Service - (ZAMSvc) - C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe
O23 - Service S3: Dragon Age: Origins - Content Updater - (DAUpdaterSvc) - c:\program files (x86)\steam\steamapps\common\dragon age ultimate edition\bin_ship\DAUpdaterSvc.Service.exe (file missing)
O23 - Service S3: iPod Service - C:\Program Files\iPod\bin\iPodService.exe (file missing)
End of file - Time spent: 26 sec. - 40606 bytes, CRC32: FFFFFFFF. Sign: 똗ܚ
Would you like me to do the Speccy test now or do you have an idea how I can resolve the error that comes up with SupRestric program?
Yes, please post the speccy report link. Nevermind the other program it will not run on some machines, no worry.
