There is a game where im unpacking sounds. Sounds are packed in Cpk and Csb. There were not many problems with the CPK, but the ones with the csb....Make some troubles.
Extracting everything from csb (aax which is then redirected to adx, then to waf and back to CSB), the replaced files in the game are not Playng at all. The "boom-bang-bang" sounds - they all are small. All names and extensions same as the original, but even if you just take the original files, pull them out and pack them back in, they are no longer readable.
Thanks if you can help.
Im using such software as: PESSFC, CpkFileBuilde, VGMToolbox, SFIVAM, ADX Frontend.
I realy need to replace that files and play them inside the game. CPK are perfectly fine with that, but not CSB.
