Not an appropriate PSU when there is anything more than the most basic of add on video cards present, they are still available new but having only been released in 2018 the VS range has been discontinued already with the equally as feeble CV (Corsair value) range, the type of use that Corsair recommend for their VS (value series) range of PSU is as follows;
This VS series power supply has 550W of guaranteed power and is
perfect for home or office system build. The VS550 offers 80 PLUS efficiency allowing you to enjoy lower energy bills. The built in 120mm fan is thermally controlled, so only spinning when its pushed hard.
For a gaming quality GPU you need a minimum of a Gold efficiency rated PSU, what is recommended for your GPU can be found
here 700W seems a bit ott to me and I feel that a good quality brand 650W Gold efficiency rated PSU would be adequate, fingers crossed for you that a weak PSU has not damaged your card, is there anyone that you can ask to test the GPU in their system for you, alternative being to ask a local tech/tech store what they would charge to test the card for you.
You have a couple of other equally important things going on according to Speccy but if you wish to address them while waiting to upgrade the PSU I would strongly suggest that you disconnect your second screen so as to lighten the load and drop the internal temps of the PSU.
