Hello i am quite new here. So because i had working cpu, showed above and with my limited budget i can't upgrade that (my 1070 i had broke and repair shop said that motherboard slot for GPU is also damaged), everything else shown in the picture is new (ssd i already had, just can't remember correct model).
So the question is will my Gpu/motherboard/Cpu have any conflicts in the future. Running on 650W bronze certified PSU, which should have no problem running those parts, i am not heavy on rgp either.
Thank you ahead
