Solved Problems with headphones
melaniedj
3
my laptop has been doing this thing where every once in a while (seemingly without cause) it won't send audio through any headphones. It will reconise that it has connected. seen as it'll ask what I plugged in, headphones or a speaker, when i click either while i actively have sound playing i can hear that sound for a split second before it cuts out. I have tried most things that I've seen people do (such as: updating driver, reinstalling driver, cleaning the headphone plug, restarting it etc.) I have tested these headphones and they work, the problem also stays even if I plug in a different headphone.
previously it either fixed itself if I just give it time or restarting it has worked (currently it's not working however). I'd very much appreciate any help with this since this has been going on for such a long time.
I use a msi gs75 stealth 95d laptop and windows 10
Don't hesitate to ask more questions
Can you post the brand and model name or number of the headphones.
But are the headphones the USB port or standard headphone jack type, this is important to know because USB ports can have different settings such as suspend which turns the port/s off when they have been idle for a set time.
Only really seeing the one thing in Speccy;
Power Profile
Active power scheme: Balanced
You need to change the Windows Power Plan to High Performance or your dedicated GPU will not be able to work properly, Balanced only uses the Intel HD graphics because of the low power available, you having a second screen hooked up will not be helping things either.
its a standard headphone jack type. Thank you for the power tip I'll be sure to apply this.
No follow up from the OP so we will take it that the issue is resolved.
