There's nothing in OneDriveThat sounds like the stat menu folder has been moved to OneDrive or a networked HDD. I’d check OneDrive to see if this is the case.
I become aware of networked drives since I have this problem. I never used an networked drive beforeDo you have any networked drives connected?
This happen with all installation, and also when I try to delete any program that my pc has.Does this happen on all installations?
Have you altered any installation settings?
Can you please provide the installation path you use when attempting to install a program?
- In Speccy, click File, and then click Publish Snapshot.
- In the Publish Snapshot dialog box, click Yes to enable Speccy to proceed.
- Speccy publishes the profile and displays a second Publish Snapshot dialog box. You can open the URL in your default browser, copy it to the clipboard, or close the dialog box.
