Hi there and welcome to PC Help Forum (PCHF), a more effective way to get the Tech Support you need!
I have been receiving this strange error the past couple of days, that a file: "GL503GE_pre.sign" was unable to be copied. GL503GE is my laptop model, but I am not copying this file, I wasn't even able to find out any info about it. I don't know what is causing it, I scanned my PC using MalwareBytes and Windows Defender (full scans for both) but nothing was detected and I have no idea why this happens. I will attach a screenshot of the error. Any help will be greatly appreciated.
Once downloaded right click the FRST desktop icon and select "Run as administrator" from the menu"
FRST will open with two dialogue boxes, accept the disclaimer.
Accept the default whitelist options,
If the additions.txt options box is not checked please select it.
Then select Scan
Please Attach the contents of these logs in your next post for review by our Security Team
Also, download the everything search engine, and type .sign in the everything search window.
Then click Edit select all.
Right click highlighted text.
Copy full name to clipboard.
Post those results in your next reply along with the FRST and Addition.txt logs.
Then select Scan
FRST Fix.
Download attached fixlist.txt file and save it to the Desktop. NOTE. It's important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
FRST Fix. Download attached fixlist.txt file and save it to the Desktop. NOTE. It's important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
Hey! I was not able to run Security Check on my PC, but the error that used to show up daily has stopped! It was a strange error, popping up once a day, but not anymore now!
Thank you for helping me out with this, Malnutrition!
