poor sound quality
boka
8
24
When I boot my laptop, I experience awful sound quality from my headphones (i've tried to switch to a different headphones, but this did't help). But if I unplug and plug in the headphones, it fixes the problem.
The default sound test on Fedora Linux works fine, even with headphones.
My default laptop speaker works fine.
I also noticed that if I run "pactl list short sinks" and then, for example, "pactl suspend-sink 51 1", it partially fixes the problem.
i also had this problem on linux mint
I am not a Linux user, but found this on google. Honestly have no idea if this will help. I'll tag a couple people to see if they have input. @jmarket @Bruce @PeterOz
Edit:
Code:
DEFAULT_SINK=$(pactl list short sinks | grep RUNNING | awk '{print $1}')
if [ -z "$DEFAULT_SINK" ]; then
fi
pactl suspend-sink "$DEFAULT_SINK" 1
sleep 1
pactl suspend-sink "$DEFAULT_SINK" 0
Reactions: boka
Edit:
Code:
fi
sleep 1
i've tried this
if I run "pactl list short sinks" and then, for example, "pactl suspend-sink 51 1", it partially fixes the problem. Partially means that the sound before this commands is awful, and after it is better, but still sounds like it's coming from a barrel.
A full fix happens only if I physically reconnect the headphones. It would be great if there were a way to do this from the terminal. However, I would like to resolve this issue fully without using a workaround.
Hello,
What distro are you using? Can you post a pic of your fastfetch or neofetch?
Let's try this. Let's run this command:
Bash:
mkdir ~/.config/pipewire
cp /usr/share/pipewire/*.conf ~/.config/pipewire
chown $USER ~/.config/pipewire/pipewire-pulse.conf
nano ~/.config/pipewire/pipewire-pulse.conf
in the conf file find pulse properties and put:
Code:
pulse.min.req = 1024/48000
pulse.min.frag = 1024/48000
pulse.min.quantum = 1024/48000
then save and reboot.
Bash:
Code:
I tried adding it to both pulse.properties and pulse.rules, but there is no effect.
Bash:
Code:
for some reason default fedora sound test works well
but any other audio is bad.
i started speaker-test -t wav -c 6 and here is the output from pavucontrol:
The sound from spotify and from speaker-test uses the same port, but sound from spotify (or any other audio) is bad. If after replugging headphones everything works fine
Bash:
Code:
i also noticed that if i set balance to smth like this:
or
sound is much better, but it is still dull
And when plugged in, the headphones are still crap?
No, i have the problem with sound only after boot/reboot. if the headphones were connected while booting, the sound is bad. Only reconnecting the headphones fixes this problem. If the headphones were not connected when the system was booted and I connected them after, the sound works as it should
