Please Help
Davidowx
Ok so i have just installed a new Samsung 970 EVO M.2 SSD. When i try to create a partition for it, it does not come up for me to create one. The weird thing is that it comes up in my bios and Device Manager but not my Disk Management. I have no idea what the problem is.
What options do you get if you right click on the drive in Device Manager?
Click on the Scan for hardware changes option, if this doesn`t work we will need to format the drive the details of which we will provide for you if need be.
