Hello, i know that this problem has been asked millions of times, but I've tried every solution i could find online and still ended up with nothing. A while back i had posted a thread explaining that my PC turned on without the cpu conector plugged after my psu died. We ended up that the motherboard was the problem. Fast forward to now, i bought a new motherboard (ASUS Prime Z90-P) and it fixed the problem that the PC managed to turn on with everything connected, the problem now is that when I turn the PC on, everything runs fine. Fans are spinning, graphics card is working, motherboard IO connections are working fine, but now the PC just turns on but doesn't display a signal or boot up to windows nor even the bios, the PC just runs on nothing pretty much. I've tried everything that i could find to help, resetting the bios by taking out and putting the CMOS battery back, turning it on with 1 of the both ram sticks with both of them, turning it on without the graphics card, rechecking if everything was connected properly, plugging it into a different outlet source, nothing seems to work. As i said, everything turns on but my keyboard and mouse or any sort of display. Any chance anyone can help see if there's a solution to this?
My specs are:
Intel 10400F
ASUS Prime Z90-P
Thermaltake ux 100 5v cpu cooler
Rtx 2060
Evga 610 bp 610w bronze rated power supply
Vulcan G 512 ssd
8x2 gb olay ddr4 3200mhz ram
Deepcool matrexx 50 case
2tb WD external hard drive
My specs are:
Intel 10400F
ASUS Prime Z90-P
Rtx 2060
Vulcan G 512 ssd
