PC overheating more then usual
Andrew Alturas
31
My PC has started to heat up more then usual. The CPU goes up to about 70c when playing games like overwatch or games like that in general and its around 40c when idle (using internet). Would anybody know what it could be? I have a corsair H60 liquid cooling and i just recently replaced the thermal paste. My gpu also spikes around 55-60c when gaming and 26c when idle.
Hi Andrew and Welcome to PCHF :)
What graphics card do you have? How many fans do you have on your chassis? The more information the better :)
I have a Nvidia GeForce gtx770 and I have 2 fans in front of chassis and 2 on top. The ones in front are blowing cold air in and the top ones are blowing out.
Please provide your pc spec's and your psu spec's. Do you keep the inside of your pc clean from dust?
EDIT: With speedfan please post the voltages after it has ran for a while..maybe 30 minutes.
Lets grab some information from your machine. :)
Speccy Scan.
  • Upon Completion:
  • Hit File
  • Publish Snap Shot
MiniToolBox Scan
Checkmark following boxes:
Flush DNS
Reset FF proxy Settings
Reset Ie Proxy Settings
Report IE Proxy Settings
Report FF Proxy Settings
List content of Hosts
List IP configuration
List Winsock Entries
List last 10 Event Viewer log
List Installed Programs
List Devices (problems only)
Click Go and post the result.
Any updates for us?
After 24 to 48 Hrs this thread will be closed,however you can have it re-opened.
