Solved PC is locking up when under load and when idling
Lets create a new windows account and see if logging in with the new account works properly.
If it works correctly that will show that the user is corrupt and not Windows.
On the affected user uninstall Kaspersky which you can reinstall. Prior you may need to find the License number that way you can reinstall correctly.
Alright so a few things
I uninstalled Kapersky, then went to make a new user account, and it crashed as soon as i got to the login screen. went back and made it an admin account and i was able to get in, booted up a game, and just sat in the menu for 10 minutes, but as soon as i joined a server it crashed and went to a green screen. I went to go log back in to try it another time or two and the new account is gone, like i have to make a new one
Lets run a speccy report and see what that tells us.
Include the make and model of the Power Supply Unit if this is a Desktop.
Heres the link the the Speccy: http://speccy.piriform.com/results/IVnPNcNrjumYanmdlMG1ZGM
Power Supply is a Corsair TX650M: https://www.corsair.com/us/en/Categ...-Units/txm-series-2017-config/p/CP-9020132-NA
Also might lend some insight, i tried using Google Earth (browser version) for a project, and that ended up crashing within 1-2 minutes
Sorry i dont mean to keep replying to the thread, just wanna give as much info i can.
Something interesting happened, where i was watching youtube, and it crashed, which it has never done before. I left it on for 4 hours yesterday and came back to it. After it crashed, as i was about to power down i heard a Windows alert that was like something was just plugged in or connected to it (like when you plug in a flash drive) Nothing happened but its never done that before, not sure if it's relevant
We could reset the network back to defaults and see if that clears any of the online issues.
Through Windows is
eset the network on the system
Open Settings
Click on Network & Internet
Click on Status
Click on Network reset
Click the Reset now button
Click Yes to confirm and let your computer restart
It may take a few extra time for the system to completely reboot since it is rebuilding the network then try the network and let us know.
The other way is to run some commands through the Administrator Command Prompt.
Open an Administrator Command Prompt
Type the following commands, pressing Enter after each command:
ipconfig /flushdns
ipconfig /release
ipconfig /renew
nbtstat -R
nbtstat -RR
netsh int reset all
netsh int ip reset c:\resetlog.txt
netsh int ipv6 reset
netsh int ipv4 reset
netsh winsock reset catalog
Reboot the computer
Still showing that Kaspersky is still active and running did you reinstall?
Firewall
Firewall: Enabled
Display Name: Kaspersky Security Cloud
Antivirus
Windows Defender
Antivirus: Enabled
Antivirus: Enabled
Running more than one Anti Virus scanner at the same time causes conflict.
Firewall
Firewall: Enabled
Antivirus
Windows Defender
Antivirus: Enabled
Antivirus: Enabled
No i didnt, i just looked through my programs and i dont see it anywhere?
So i did the network reset. I tried using google earth for about 10 minutes actively clicking around, and no crash, so that mightve fixed that.
Also just wanna note this, almost every time it crashes i check and get this error in Event Viewer. Not sure what DWM is but figured it might be important.
Doing some more reading have you tried reseating the Graphics Card?
Which means to (with the system powered off and discharged) remove and reinsert the display card and reattach the power if there are any.
Yes ive done that quite a few times, along with re seating the RAM
Go into the BIOS and turn on the XMP.
How is the system running?
Which slots are the RAM in?
Check the manual and or the Motherboards site to find out.
According to speccy they are in Slot 1 and 2
According to the motherboards site they should be in A2 and B2
I turned on XMP and that appears to have solved it! Im hesitant to say 100% just because its only been an hour but this the best its been yet, and im actively trying to do the things it did when it crashed.
I know you may not have these answers for me and thats alright, but what is XMP? And also if i turned it on and it fixed the problem how come this problem just started recently?
